RTEMS 6.2-rc2
Modules | Files | Macros | Variables
spec:/testsuites/fatal-start-on-not-online-processor
This validation test suite contains a test case which triggers a fatal error during system initialization. More...
 spec:/score/smp/val/fatal-start-on-not-online-processor
 Tests a fatal error.
file  ts-fatal-start-on-not-online-processor.c
#define FATAL_SYSINIT_RUN   ScoreSmpValFatalStartOnNotOnlineProcessor_Run
#define CONFIGURE_IDLE_TASK_BODY   _CPU_Thread_Idle_body
#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
#define CONFIGURE_MAXIMUM_PROCESSORS   2
const char rtems_test_name [] = "TestsuitesFatalStartOnNotOnlineProcessor"
 Each test must define a test name string.
