RTEMS 6.2-rc2
This group contains the GPTIMER interfaces. More...
Modules | |
| Configuration register (CONFIG) | |
| This group contains register bit definitions. | |
| GPTIMER TIMER | |
| This group contains the GPTIMER TIMER interfaces. | |
| Scaler reload value register (SRELOAD) | |
| Scaler value register (SCALER) | |
| Timer latch configuration register (LATCHCFG) | |
Files | |
| file | gptimer-regs.h |
| This header file defines the GPTIMER register block interface. | |
| struct | gptimer |
| This structure defines the GPTIMER register block memory map. More... | |
Typedefs | |
| typedef struct gptimer | gptimer |
| This structure defines the GPTIMER register block memory map. | |
