RTEMS 6.2-rc2
This group contains the AHBTRACE interfaces. More...
Modules | |
| Trace buffer break address registers (TBBA) | |
| This group contains register bit definitions. | |
| Trace buffer break mask registers (TBBM) | |
| Trace buffer control register (CTRL) | |
| Trace buffer index register (INDEX) | |
| Trace buffer master/slave filter register (MSFILT) | |
| Trace buffer time tag register (TIMETAG) | |
Files | |
| file | ahbtrace-regs.h |
| This header file defines the AHBTRACE register block interface. | |
| struct | ahbtrace |
| This structure defines the AHBTRACE register block memory map. More... | |
Typedefs | |
| typedef struct ahbtrace | ahbtrace |
| This structure defines the AHBTRACE register block memory map. | |
