RTEMS 6.2-rc1
#include <bsp/bootcard.h>#include <rtems/test-info.h>#include <rtems/test.h>#include <rtems/testopts.h>#include "tr-io-kernel.h"#include <rtems/confdefs.h>Macros | |
| #define | CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER |
| #define | CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 0 |
| #define | CONFIGURE_DISABLE_NEWLIB_REENTRANCY |
| #define | CONFIGURE_APPLICATION_DISABLE_FILESYSTEM |
| #define | CONFIGURE_SCHEDULER_USER |
| #define | CONFIGURE_SCHEDULER |
| #define | CONFIGURE_SCHEDULER_TABLE_ENTRIES { } |
| #define | CONFIGURE_IDLE_TASK_STORAGE_SIZE RTEMS_MINIMUM_STACK_SIZE |
| #define | CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION |
| #define | CONFIGURE_IDLE_TASK_BODY IdleBody |
| #define | CONFIGURE_INIT |
| void | boot_card (const char *cmdline) |
| Standard system initialization procedure. | |
| const char | rtems_test_name [] = "TestsuitesValidationIoKernel" |
| Each test must define a test name string. | |
