RTEMS 6.2-rc1
This header file provides interfaces of the RTEMS Test Support. More...
| struct | rtems_test_parallel_context |
| Internal context for parallel job execution. More... | |
| struct | rtems_test_parallel_job |
| Basic parallel job description. More... | |
| #define | RTEMS_TEST_INITIAL_EXTENSION { NULL, NULL, NULL, NULL, NULL, NULL, NULL, rtems_test_fatal_extension, NULL } |
| Initial extension for tests. | |
| #define | TEST_STATE RTEMS_TEST_STATE_PASS |
| #define | RTEMS_TEST_PARALLEL_PROCESSOR_MAX 32 |
Typedefs | |
| typedef struct rtems_test_parallel_job | rtems_test_parallel_job |
| typedef void(* | rtems_test_parallel_worker_setup) (rtems_test_parallel_context *ctx, size_t worker_index, rtems_id worker_id) |
| Worker task setup handler. | |
Enumerations | |
| enum | RTEMS_TEST_STATE { RTEMS_TEST_STATE_PASS , RTEMS_TEST_STATE_FAIL , RTEMS_TEST_STATE_USER_INPUT , RTEMS_TEST_STATE_INDETERMINATE , RTEMS_TEST_STATE_BENCHMARK } |
| Test states. | |
| void | rtems_test_fatal_extension (rtems_fatal_source source, bool always_set_to_false, rtems_fatal_code code) |
| Fatal extension for tests. | |
| int | rtems_test_begin (const char *name, const RTEMS_TEST_STATE state) |
| Prints a begin of test message using printf(). | |
| int | rtems_test_end (const char *name) |
| Prints an end of test message using printf(). | |
| RTEMS_NO_RETURN void | rtems_test_exit (int status) |
| Exit the test without calling exit() since it closes stdin, etc and pulls in stdio code. | |
| void | rtems_test_parallel (rtems_test_parallel_context *ctx, rtems_test_parallel_worker_setup worker_setup, const rtems_test_parallel_job *jobs, size_t job_count) |
| Runs a bunch of jobs in parallel on all processors of the system. | |
| void | rtems_test_busy_cpu_usage (time_t seconds, long nanoseconds) |
| Performs a busy loop for the specified seconds and nanoseconds based on the CPU usage of the executing thread. | |
| RTEMS_NO_RETURN void | rtems_test_run (rtems_task_argument arg, const RTEMS_TEST_STATE state) |
| Runs the test cases of the RTEMS Test Framework using a default configuration in the context of a task. | |
| void | rtems_test_gcov_dump_info (void) |
| Dumps the gcov information as a base64 encoded gcfn and gcda data stream using rtems_put_char(). | |
| const char | rtems_test_name [] |
| Each test must define a test name string. | |
