RTEMS 6.2-rc1
This header file provides functions used by corresponding test suite. More...
#include <rtems.h>Go to the source code of this file.
| void | ThreadBeginExtension0 (rtems_tcb *executing) |
| bool | ThreadCreateExtension0 (rtems_tcb *executing, rtems_tcb *created) |
| void | ThreadDeleteExtension0 (rtems_tcb *executing, rtems_tcb *deleted) |
| void | ThreadExittedExtension0 (rtems_tcb *executing) |
| void | ThreadRestartExtension0 (rtems_tcb *executing, rtems_tcb *restarted) |
| void | ThreadStartExtension0 (rtems_tcb *executing, rtems_tcb *started) |
| void | ThreadSwitchExtension0 (rtems_tcb *executing, rtems_tcb *heir) |
| void | ThreadTerminateExtension0 (rtems_tcb *executing) |
| void | FatalExtension0 (rtems_fatal_source source, bool always_set_to_false, rtems_fatal_code code) |
| void | ThreadBeginExtension1 (rtems_tcb *executing) |
| bool | ThreadCreateExtension1 (rtems_tcb *executing, rtems_tcb *created) |
| void | ThreadDeleteExtension1 (rtems_tcb *executing, rtems_tcb *deleted) |
| void | ThreadExittedExtension1 (rtems_tcb *executing) |
| void | ThreadRestartExtension1 (rtems_tcb *executing, rtems_tcb *restarted) |
| void | ThreadStartExtension1 (rtems_tcb *executing, rtems_tcb *started) |
| void | ThreadSwitchExtension1 (rtems_tcb *executing, rtems_tcb *heir) |
| void | ThreadTerminateExtension1 (rtems_tcb *executing) |
| void | FatalExtension1 (rtems_fatal_source source, bool always_set_to_false, rtems_fatal_code code) |
