RTEMS 6.2-rc1
Header file of SWPMI LL module. More...
#include "stm32h7xx.h"Go to the source code of this file.
| __STATIC_INLINE void | LL_SWPMI_SetReceptionMode (SWPMI_TypeDef *SWPMIx, uint32_t RxBufferingMode) |
| Set Reception buffering mode. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_GetReceptionMode (SWPMI_TypeDef *SWPMIx) |
| Get Reception buffering mode @rmtoll CR RXMODE LL_SWPMI_GetReceptionMode. | |
| __STATIC_INLINE void | LL_SWPMI_SetTransmissionMode (SWPMI_TypeDef *SWPMIx, uint32_t TxBufferingMode) |
| Set Transmission buffering mode. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_GetTransmissionMode (SWPMI_TypeDef *SWPMIx) |
| Get Transmission buffering mode @rmtoll CR TXMODE LL_SWPMI_GetTransmissionMode. | |
| __STATIC_INLINE void | LL_SWPMI_EnableLoopback (SWPMI_TypeDef *SWPMIx) |
| Enable loopback mode @rmtoll CR LPBK LL_SWPMI_EnableLoopback. | |
| __STATIC_INLINE void | LL_SWPMI_DisableLoopback (SWPMI_TypeDef *SWPMIx) |
| Disable loopback mode @rmtoll CR LPBK LL_SWPMI_DisableLoopback. | |
| __STATIC_INLINE void | LL_SWPMI_EnableTransceiver (SWPMI_TypeDef *SWPMIx) |
| Enable SWPMI transceiver. | |
| __STATIC_INLINE void | LL_SWPMI_DisableTransceiver (SWPMI_TypeDef *SWPMIx) |
| Disable SWPMI transceiver. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsEnabledTransceiver (SWPMI_TypeDef *SWPMIx) |
| Check if SWPMI transceiver is enabled @rmtoll CR SWPEN LL_SWPMI_IsEnabledTransceiver. | |
| __STATIC_INLINE void | LL_SWPMI_Activate (SWPMI_TypeDef *SWPMIx) |
| Activate Single wire protocol bus (SUSPENDED or ACTIVATED state) | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsActivated (SWPMI_TypeDef *SWPMIx) |
| Check if Single wire protocol bus is in ACTIVATED state. @rmtoll CR SWPACT LL_SWPMI_Activate. | |
| __STATIC_INLINE void | LL_SWPMI_Deactivate (SWPMI_TypeDef *SWPMIx) |
| Deactivate immediately Single wire protocol bus (immediate transition to DEACTIVATED state) @rmtoll CR SWPACT LL_SWPMI_Deactivate. | |
| __STATIC_INLINE void | LL_SWPMI_RequestDeactivation (SWPMI_TypeDef *SWPMIx) |
| Request a deactivation of Single wire protocol bus (request to go in DEACTIVATED state if no resume from slave) @rmtoll CR DEACT LL_SWPMI_RequestDeactivation. | |
| __STATIC_INLINE void | LL_SWPMI_SetBitRatePrescaler (SWPMI_TypeDef *SWPMIx, uint32_t BitRatePrescaler) |
| Set Bitrate prescaler SWPMI_freq = SWPMI_clk / (((BitRate) + 1) * 4) @rmtoll BRR BR LL_SWPMI_SetBitRatePrescaler. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_GetBitRatePrescaler (SWPMI_TypeDef *SWPMIx) |
| Get Bitrate prescaler @rmtoll BRR BR LL_SWPMI_GetBitRatePrescaler. | |
| __STATIC_INLINE void | LL_SWPMI_SetVoltageClass (SWPMI_TypeDef *SWPMIx, uint32_t VoltageClass) |
| Set SWP Voltage Class @rmtoll OR CLASS LL_SWPMI_SetVoltageClass. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_GetVoltageClass (SWPMI_TypeDef *SWPMIx) |
| Get SWP Voltage Class @rmtoll OR CLASS LL_SWPMI_GetVoltageClass. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsActiveFlag_RXBF (SWPMI_TypeDef *SWPMIx) |
| Check if the last word of the frame under reception has arrived in SWPMI_RDR. @rmtoll ISR RXBFF LL_SWPMI_IsActiveFlag_RXBF. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsActiveFlag_TXBE (SWPMI_TypeDef *SWPMIx) |
| Check if Frame transmission buffer has been emptied @rmtoll ISR TXBEF LL_SWPMI_IsActiveFlag_TXBE. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsActiveFlag_RXBER (SWPMI_TypeDef *SWPMIx) |
| Check if CRC error in reception has been detected @rmtoll ISR RXBERF LL_SWPMI_IsActiveFlag_RXBER. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsActiveFlag_RXOVR (SWPMI_TypeDef *SWPMIx) |
| Check if Overrun in reception has been detected @rmtoll ISR RXOVRF LL_SWPMI_IsActiveFlag_RXOVR. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsActiveFlag_TXUNR (SWPMI_TypeDef *SWPMIx) |
| Check if underrun error in transmission has been detected @rmtoll ISR TXUNRF LL_SWPMI_IsActiveFlag_TXUNR. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsActiveFlag_RXNE (SWPMI_TypeDef *SWPMIx) |
| Check if Receive data register not empty (it means that Received data is ready to be read in the SWPMI_RDR register) @rmtoll ISR RXNE LL_SWPMI_IsActiveFlag_RXNE. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsActiveFlag_TXE (SWPMI_TypeDef *SWPMIx) |
| Check if Transmit data register is empty (it means that Data written in transmit data register SWPMI_TDR has been transmitted and SWPMI_TDR can be written to again) @rmtoll ISR TXE LL_SWPMI_IsActiveFlag_TXE. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsActiveFlag_TC (SWPMI_TypeDef *SWPMIx) |
| Check if Both transmission and reception are completed and SWP is switched to the SUSPENDED state @rmtoll ISR TCF LL_SWPMI_IsActiveFlag_TC. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsActiveFlag_SR (SWPMI_TypeDef *SWPMIx) |
| Check if a Resume by slave state has been detected during the SWP bus SUSPENDED state @rmtoll ISR SRF LL_SWPMI_IsActiveFlag_SR. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsActiveFlag_SUSP (SWPMI_TypeDef *SWPMIx) |
| Check if SWP bus is in SUSPENDED or DEACTIVATED state @rmtoll ISR SUSP LL_SWPMI_IsActiveFlag_SUSP. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsActiveFlag_DEACT (SWPMI_TypeDef *SWPMIx) |
| Check if SWP bus is in DEACTIVATED state @rmtoll ISR DEACTF LL_SWPMI_IsActiveFlag_DEACT. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsActiveFlag_RDYF (SWPMI_TypeDef *SWPMIx) |
| Check if SWPMI transceiver is ready @rmtoll ISR RDYF LL_SWPMI_IsActiveFlag_RDYF. | |
| __STATIC_INLINE void | LL_SWPMI_ClearFlag_RXBF (SWPMI_TypeDef *SWPMIx) |
| Clear receive buffer full flag @rmtoll ICR CRXBFF LL_SWPMI_ClearFlag_RXBF. | |
| __STATIC_INLINE void | LL_SWPMI_ClearFlag_TXBE (SWPMI_TypeDef *SWPMIx) |
| Clear transmit buffer empty flag @rmtoll ICR CTXBEF LL_SWPMI_ClearFlag_TXBE. | |
| __STATIC_INLINE void | LL_SWPMI_ClearFlag_RXBER (SWPMI_TypeDef *SWPMIx) |
| Clear receive CRC error flag @rmtoll ICR CRXBERF LL_SWPMI_ClearFlag_RXBER. | |
| __STATIC_INLINE void | LL_SWPMI_ClearFlag_RXOVR (SWPMI_TypeDef *SWPMIx) |
| Clear receive overrun error flag @rmtoll ICR CRXOVRF LL_SWPMI_ClearFlag_RXOVR. | |
| __STATIC_INLINE void | LL_SWPMI_ClearFlag_TXUNR (SWPMI_TypeDef *SWPMIx) |
| Clear transmit underrun error flag @rmtoll ICR CTXUNRF LL_SWPMI_ClearFlag_TXUNR. | |
| __STATIC_INLINE void | LL_SWPMI_ClearFlag_TC (SWPMI_TypeDef *SWPMIx) |
| Clear transfer complete flag @rmtoll ICR CTCF LL_SWPMI_ClearFlag_TC. | |
| __STATIC_INLINE void | LL_SWPMI_ClearFlag_SR (SWPMI_TypeDef *SWPMIx) |
| Clear slave resume flag @rmtoll ICR CSRF LL_SWPMI_ClearFlag_SR. | |
| __STATIC_INLINE void | LL_SWPMI_ClearFlag_RDY (SWPMI_TypeDef *SWPMIx) |
| Clear SWPMI transceiver ready flag @rmtoll ISR CRDYF LL_SWPMI_ClearFlag_RDY. | |
| __STATIC_INLINE void | LL_SWPMI_EnableIT_RDY (SWPMI_TypeDef *SWPMIx) |
| Enable SWPMI transceiver ready interrupt @rmtoll IER RDYIE LL_SWPMI_EnableIT_RDY. | |
| __STATIC_INLINE void | LL_SWPMI_EnableIT_SR (SWPMI_TypeDef *SWPMIx) |
| Enable Slave resume interrupt @rmtoll IER SRIE LL_SWPMI_EnableIT_SR. | |
| __STATIC_INLINE void | LL_SWPMI_EnableIT_TC (SWPMI_TypeDef *SWPMIx) |
| Enable Transmit complete interrupt @rmtoll IER TCIE LL_SWPMI_EnableIT_TC. | |
| __STATIC_INLINE void | LL_SWPMI_EnableIT_TX (SWPMI_TypeDef *SWPMIx) |
| Enable Transmit interrupt @rmtoll IER TIE LL_SWPMI_EnableIT_TX. | |
| __STATIC_INLINE void | LL_SWPMI_EnableIT_RX (SWPMI_TypeDef *SWPMIx) |
| Enable Receive interrupt @rmtoll IER RIE LL_SWPMI_EnableIT_RX. | |
| __STATIC_INLINE void | LL_SWPMI_EnableIT_TXUNR (SWPMI_TypeDef *SWPMIx) |
| Enable Transmit underrun error interrupt @rmtoll IER TXUNRIE LL_SWPMI_EnableIT_TXUNR. | |
| __STATIC_INLINE void | LL_SWPMI_EnableIT_RXOVR (SWPMI_TypeDef *SWPMIx) |
| Enable Receive overrun error interrupt @rmtoll IER RXOVRIE LL_SWPMI_EnableIT_RXOVR. | |
| __STATIC_INLINE void | LL_SWPMI_EnableIT_RXBER (SWPMI_TypeDef *SWPMIx) |
| Enable Receive CRC error interrupt @rmtoll IER RXBERIE LL_SWPMI_EnableIT_RXBER. | |
| __STATIC_INLINE void | LL_SWPMI_EnableIT_TXBE (SWPMI_TypeDef *SWPMIx) |
| Enable Transmit buffer empty interrupt @rmtoll IER TXBEIE LL_SWPMI_EnableIT_TXBE. | |
| __STATIC_INLINE void | LL_SWPMI_EnableIT_RXBF (SWPMI_TypeDef *SWPMIx) |
| Enable Receive buffer full interrupt @rmtoll IER RXBFIE LL_SWPMI_EnableIT_RXBF. | |
| __STATIC_INLINE void | LL_SWPMI_DisableIT_RDY (SWPMI_TypeDef *SWPMIx) |
| Disable SWPMI transceiver ready interrupt @rmtoll IER RDYIE LL_SWPMI_DisableIT_RDY. | |
| __STATIC_INLINE void | LL_SWPMI_DisableIT_SR (SWPMI_TypeDef *SWPMIx) |
| Disable Slave resume interrupt @rmtoll IER SRIE LL_SWPMI_DisableIT_SR. | |
| __STATIC_INLINE void | LL_SWPMI_DisableIT_TC (SWPMI_TypeDef *SWPMIx) |
| Disable Transmit complete interrupt @rmtoll IER TCIE LL_SWPMI_DisableIT_TC. | |
| __STATIC_INLINE void | LL_SWPMI_DisableIT_TX (SWPMI_TypeDef *SWPMIx) |
| Disable Transmit interrupt @rmtoll IER TIE LL_SWPMI_DisableIT_TX. | |
| __STATIC_INLINE void | LL_SWPMI_DisableIT_RX (SWPMI_TypeDef *SWPMIx) |
| Disable Receive interrupt @rmtoll IER RIE LL_SWPMI_DisableIT_RX. | |
| __STATIC_INLINE void | LL_SWPMI_DisableIT_TXUNR (SWPMI_TypeDef *SWPMIx) |
| Disable Transmit underrun error interrupt @rmtoll IER TXUNRIE LL_SWPMI_DisableIT_TXUNR. | |
| __STATIC_INLINE void | LL_SWPMI_DisableIT_RXOVR (SWPMI_TypeDef *SWPMIx) |
| Disable Receive overrun error interrupt @rmtoll IER RXOVRIE LL_SWPMI_DisableIT_RXOVR. | |
| __STATIC_INLINE void | LL_SWPMI_DisableIT_RXBER (SWPMI_TypeDef *SWPMIx) |
| Disable Receive CRC error interrupt @rmtoll IER RXBERIE LL_SWPMI_DisableIT_RXBER. | |
| __STATIC_INLINE void | LL_SWPMI_DisableIT_TXBE (SWPMI_TypeDef *SWPMIx) |
| Disable Transmit buffer empty interrupt @rmtoll IER TXBEIE LL_SWPMI_DisableIT_TXBE. | |
| __STATIC_INLINE void | LL_SWPMI_DisableIT_RXBF (SWPMI_TypeDef *SWPMIx) |
| Disable Receive buffer full interrupt @rmtoll IER RXBFIE LL_SWPMI_DisableIT_RXBF. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsEnabledIT_RDY (SWPMI_TypeDef *SWPMIx) |
| Check if SWPMI transceiver ready interrupt is enabled @rmtoll IER RDYIE LL_SWPMI_IsEnabledIT_RDY. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsEnabledIT_SR (SWPMI_TypeDef *SWPMIx) |
| Check if Slave resume interrupt is enabled @rmtoll IER SRIE LL_SWPMI_IsEnabledIT_SR. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsEnabledIT_TC (SWPMI_TypeDef *SWPMIx) |
| Check if Transmit complete interrupt is enabled @rmtoll IER TCIE LL_SWPMI_IsEnabledIT_TC. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsEnabledIT_TX (SWPMI_TypeDef *SWPMIx) |
| Check if Transmit interrupt is enabled @rmtoll IER TIE LL_SWPMI_IsEnabledIT_TX. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsEnabledIT_RX (SWPMI_TypeDef *SWPMIx) |
| Check if Receive interrupt is enabled @rmtoll IER RIE LL_SWPMI_IsEnabledIT_RX. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsEnabledIT_TXUNR (SWPMI_TypeDef *SWPMIx) |
| Check if Transmit underrun error interrupt is enabled @rmtoll IER TXUNRIE LL_SWPMI_IsEnabledIT_TXUNR. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsEnabledIT_RXOVR (SWPMI_TypeDef *SWPMIx) |
| Check if Receive overrun error interrupt is enabled @rmtoll IER RXOVRIE LL_SWPMI_IsEnabledIT_RXOVR. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsEnabledIT_RXBER (SWPMI_TypeDef *SWPMIx) |
| Check if Receive CRC error interrupt is enabled @rmtoll IER RXBERIE LL_SWPMI_IsEnabledIT_RXBER. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsEnabledIT_TXBE (SWPMI_TypeDef *SWPMIx) |
| Check if Transmit buffer empty interrupt is enabled @rmtoll IER TXBEIE LL_SWPMI_IsEnabledIT_TXBE. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsEnabledIT_RXBF (SWPMI_TypeDef *SWPMIx) |
| Check if Receive buffer full interrupt is enabled @rmtoll IER RXBFIE LL_SWPMI_IsEnabledIT_RXBF. | |
| __STATIC_INLINE void | LL_SWPMI_EnableDMAReq_RX (SWPMI_TypeDef *SWPMIx) |
| Enable DMA mode for reception @rmtoll CR RXDMA LL_SWPMI_EnableDMAReq_RX. | |
| __STATIC_INLINE void | LL_SWPMI_DisableDMAReq_RX (SWPMI_TypeDef *SWPMIx) |
| Disable DMA mode for reception @rmtoll CR RXDMA LL_SWPMI_DisableDMAReq_RX. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsEnabledDMAReq_RX (SWPMI_TypeDef *SWPMIx) |
| Check if DMA mode for reception is enabled @rmtoll CR RXDMA LL_SWPMI_IsEnabledDMAReq_RX. | |
| __STATIC_INLINE void | LL_SWPMI_EnableDMAReq_TX (SWPMI_TypeDef *SWPMIx) |
| Enable DMA mode for transmission @rmtoll CR TXDMA LL_SWPMI_EnableDMAReq_TX. | |
| __STATIC_INLINE void | LL_SWPMI_DisableDMAReq_TX (SWPMI_TypeDef *SWPMIx) |
| Disable DMA mode for transmission @rmtoll CR TXDMA LL_SWPMI_DisableDMAReq_TX. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_IsEnabledDMAReq_TX (SWPMI_TypeDef *SWPMIx) |
| Check if DMA mode for transmission is enabled @rmtoll CR TXDMA LL_SWPMI_IsEnabledDMAReq_TX. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_DMA_GetRegAddr (SWPMI_TypeDef *SWPMIx, uint32_t Direction) |
| Get the data register address used for DMA transfer @rmtoll TDR TD LL_SWPMI_DMA_GetRegAddr RDR RD LL_SWPMI_DMA_GetRegAddr. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_GetReceiveFrameLength (SWPMI_TypeDef *SWPMIx) |
| Retrieve number of data bytes present in payload of received frame @rmtoll RFL RFL LL_SWPMI_GetReceiveFrameLength. | |
| __STATIC_INLINE void | LL_SWPMI_TransmitData32 (SWPMI_TypeDef *SWPMIx, uint32_t TxData) |
| Transmit Data Register @rmtoll TDR TD LL_SWPMI_TransmitData32. | |
| __STATIC_INLINE uint32_t | LL_SWPMI_ReceiveData32 (SWPMI_TypeDef *SWPMIx) |
| Receive Data Register @rmtoll RDR RD LL_SWPMI_ReceiveData32. | |
| __STATIC_INLINE void | LL_SWPMI_EnableTXBypass (SWPMI_TypeDef *SWPMIx) |
| Enable SWP Transceiver Bypass. | |
| __STATIC_INLINE void | LL_SWPMI_DisableTXBypass (SWPMI_TypeDef *SWPMIx) |
| Disable SWP Transceiver Bypass. | |
