RTEMS 6.2-rc1
stm32h7xx_hal_pwr.h File Reference
Header file of PWR HAL module. More...
#include "stm32h7xx_hal_def.h"
#include "stm32h7xx_hal_pwr_ex.h"
struct  PWR_PVDTypeDef
 PWR PVD configuration structure definition. More...
#define PWR_PVDLEVEL_0   PWR_CR1_PLS_LEV0
#define PWR_PVDLEVEL_1   PWR_CR1_PLS_LEV1
#define PWR_PVDLEVEL_2   PWR_CR1_PLS_LEV2
#define PWR_PVDLEVEL_3   PWR_CR1_PLS_LEV3
#define PWR_PVDLEVEL_4   PWR_CR1_PLS_LEV4
#define PWR_PVDLEVEL_5   PWR_CR1_PLS_LEV5
#define PWR_PVDLEVEL_6   PWR_CR1_PLS_LEV6
#define PWR_PVDLEVEL_7   PWR_CR1_PLS_LEV7
#define PWR_PVD_MODE_NORMAL   (0x00000000U)
#define PWR_PVD_MODE_IT_RISING   (0x00010001U)
#define PWR_PVD_MODE_IT_FALLING   (0x00010002U)
#define PWR_PVD_MODE_IT_RISING_FALLING   (0x00010003U)
#define PWR_PVD_MODE_EVENT_RISING   (0x00020001U)
#define PWR_PVD_MODE_EVENT_FALLING   (0x00020002U)
#define PWR_PVD_MODE_EVENT_RISING_FALLING   (0x00020003U)
#define PWR_MAINREGULATOR_ON   (0U)
#define PWR_LOWPOWERREGULATOR_ON   PWR_CR1_LPDS
#define PWR_SLEEPENTRY_WFI   (0x01U)
#define PWR_SLEEPENTRY_WFE   (0x02U)
#define PWR_STOPENTRY_WFI   (0x01U)
#define PWR_STOPENTRY_WFE   (0x02U)
#define PWR_REGULATOR_VOLTAGE_SCALE0   (0U)
#define PWR_REGULATOR_VOLTAGE_SCALE1   (PWR_D3CR_VOS_1 | PWR_D3CR_VOS_0)
#define PWR_REGULATOR_VOLTAGE_SCALE2   (PWR_D3CR_VOS_1)
#define PWR_REGULATOR_VOLTAGE_SCALE3   (PWR_D3CR_VOS_0)
#define PWR_FLAG_STOP   (0x01U)
#define PWR_FLAG_SB   (0x04U)
#define PWR_FLAG_PVDO   (0x0BU)
#define PWR_FLAG_AVDO   (0x0CU)
#define PWR_FLAG_ACTVOSRDY   (0x0DU)
#define PWR_FLAG_ACTVOS   (0x0EU)
#define PWR_FLAG_BRR   (0x0FU)
#define PWR_FLAG_VOSRDY   (0x10U)
#define PWR_FLAG_SCUEN   (0x11U)
#define PWR_FLAG_USB33RDY   (0x13U)
#define PWR_FLAG_TEMPH   (0x14U)
#define PWR_FLAG_TEMPL   (0x15U)
#define PWR_FLAG_VBATH   (0x16U)
#define PWR_FLAG_VBATL   (0x17U)
#define PWR_FLAG_WKUP1   PWR_WKUPCR_WKUPC1
#define PWR_FLAG_WKUP2   PWR_WKUPCR_WKUPC2
#define PWR_FLAG_WKUP3   PWR_WKUPCR_WKUPC3
#define PWR_FLAG_WKUP4   PWR_WKUPCR_WKUPC4
#define PWR_FLAG_WKUP5   PWR_WKUPCR_WKUPC5
#define PWR_FLAG_WKUP6   PWR_WKUPCR_WKUPC6
#define PWR_EWUP_MASK   (0x0FFF3F3FU)
#define __HAL_PWR_VOLTAGESCALING_CONFIG(__REGULATOR__)
 Configure the main internal regulator output voltage.
#define __HAL_PWR_GET_FLAG(__FLAG__)
 Check PWR flags are set or not.
#define __HAL_PWR_GET_WAKEUPFLAG(__FLAG__)   ((PWR->WKUPFR & (__FLAG__)) ? 0 : 1)
 Check PWR wake up flags are set or not.
#define __HAL_PWR_CLEAR_FLAG(__FLAG__)   SET_BIT(PWR->CPUCR, PWR_CPUCR_CSSF)
 Clear CPU PWR flags.
#define __HAL_PWR_CLEAR_WAKEUPFLAG(__FLAG__)   SET_BIT(PWR->WKUPCR, (__FLAG__))
 Clear PWR wake up flags.
#define __HAL_PWR_PVD_EXTI_ENABLE_IT()   SET_BIT(EXTI->IMR1, PWR_EXTI_LINE_PVD)
 Enable the PVD EXTI Line 16.
#define __HAL_PWR_PVD_EXTI_DISABLE_IT()   CLEAR_BIT(EXTI->IMR1, PWR_EXTI_LINE_PVD)
 Disable the PVD EXTI Line 16.
#define __HAL_PWR_PVD_EXTI_ENABLE_EVENT()   SET_BIT(EXTI->EMR1, PWR_EXTI_LINE_PVD)
 Enable event on PVD EXTI Line 16.
#define __HAL_PWR_PVD_EXTI_DISABLE_EVENT()   CLEAR_BIT(EXTI->EMR1, PWR_EXTI_LINE_PVD)
 Disable event on PVD EXTI Line 16.
#define __HAL_PWR_PVD_EXTI_ENABLE_RISING_EDGE()   SET_BIT(EXTI->RTSR1, PWR_EXTI_LINE_PVD)
 Enable the PVD Rising Interrupt Trigger.
#define __HAL_PWR_PVD_EXTI_DISABLE_RISING_EDGE()   CLEAR_BIT(EXTI->RTSR1, PWR_EXTI_LINE_PVD)
 Disable the PVD Rising Interrupt Trigger.
#define __HAL_PWR_PVD_EXTI_ENABLE_FALLING_EDGE()   SET_BIT(EXTI->FTSR1, PWR_EXTI_LINE_PVD)
 Enable the PVD Falling Interrupt Trigger.
#define __HAL_PWR_PVD_EXTI_DISABLE_FALLING_EDGE()   CLEAR_BIT(EXTI->FTSR1, PWR_EXTI_LINE_PVD)
 Disable the PVD Falling Interrupt Trigger.
#define __HAL_PWR_PVD_EXTI_ENABLE_RISING_FALLING_EDGE()
 Enable the PVD Rising & Falling Interrupt Trigger.
#define __HAL_PWR_PVD_EXTI_DISABLE_RISING_FALLING_EDGE()
 Disable the PVD Rising & Falling Interrupt Trigger.
#define __HAL_PWR_PVD_EXTI_GET_FLAG()   ((READ_BIT(EXTI->PR1, PWR_EXTI_LINE_PVD) == PWR_EXTI_LINE_PVD) ? 1UL : 0UL)
 Check whether the specified PVD EXTI interrupt flag is set or not.
#define __HAL_PWR_PVD_EXTI_CLEAR_FLAG()   SET_BIT(EXTI->PR1, PWR_EXTI_LINE_PVD)
 Clear the PVD EXTI flag.
#define __HAL_PWR_PVD_EXTI_GENERATE_SWIT()   SET_BIT(EXTI->SWIER1, PWR_EXTI_LINE_PVD)
 Generates a Software interrupt on PVD EXTI line.
#define PWR_EXTI_LINE_PVD   EXTI_IMR1_IM16
#define IS_PWR_PVD_LEVEL(LEVEL)
#define IS_PWR_PVD_MODE(MODE)
#define IS_PWR_REGULATOR(REGULATOR)
#define IS_PWR_SLEEP_ENTRY(ENTRY)
#define IS_PWR_STOP_ENTRY(ENTRY)
#define IS_PWR_REGULATOR_VOLTAGE(VOLTAGE)
void HAL_PWR_DeInit (void)
void HAL_PWR_EnableBkUpAccess (void)
void HAL_PWR_DisableBkUpAccess (void)
void HAL_PWR_ConfigPVD (PWR_PVDTypeDef *sConfigPVD)
void HAL_PWR_EnablePVD (void)
void HAL_PWR_DisablePVD (void)
void HAL_PWR_EnableWakeUpPin (uint32_t WakeUpPinPolarity)
void HAL_PWR_DisableWakeUpPin (uint32_t WakeUpPinx)
void HAL_PWR_EnterSTOPMode (uint32_t Regulator, uint8_t STOPEntry)
void HAL_PWR_EnterSLEEPMode (uint32_t Regulator, uint8_t SLEEPEntry)
void HAL_PWR_EnterSTANDBYMode (void)
void HAL_PWR_PVD_IRQHandler (void)
void HAL_PWR_PVDCallback (void)
void HAL_PWR_EnableSleepOnExit (void)
void HAL_PWR_DisableSleepOnExit (void)
void HAL_PWR_EnableSEVOnPend (void)
void HAL_PWR_DisableSEVOnPend (void)
Author
MCD Application Team
Attention
