RTEMS 6.2-rc1
Header file of NOR HAL module. More...
#include "stm32h7xx_ll_fmc.h"Go to the source code of this file.
| struct | NOR_IDTypeDef |
| FMC NOR ID typedef. More... | |
| struct | NOR_CFITypeDef |
| FMC NOR CFI typedef. More... | |
| struct | NOR_HandleTypeDef |
| NOR handle Structure definition. More... | |
| #define | __HAL_NOR_RESET_HANDLE_STATE(__HANDLE__) ((__HANDLE__)->State = HAL_NOR_STATE_RESET) |
| Reset NOR handle state. | |
| #define | MC_ADDRESS ((uint16_t)0x0000) |
| #define | DEVICE_CODE1_ADDR ((uint16_t)0x0001) |
| #define | DEVICE_CODE2_ADDR ((uint16_t)0x000E) |
| #define | DEVICE_CODE3_ADDR ((uint16_t)0x000F) |
| #define | CFI1_ADDRESS ((uint16_t)0x0061) |
| #define | CFI2_ADDRESS ((uint16_t)0x0062) |
| #define | CFI3_ADDRESS ((uint16_t)0x0063) |
| #define | CFI4_ADDRESS ((uint16_t)0x0064) |
| #define | NOR_TMEOUT ((uint16_t)0xFFFF) |
| #define | NOR_MEMORY_8B ((uint8_t)0x00) |
| #define | NOR_MEMORY_16B ((uint8_t)0x01) |
| #define | NOR_MEMORY_ADRESS1 (0x60000000U) |
| #define | NOR_MEMORY_ADRESS2 (0x64000000U) |
| #define | NOR_MEMORY_ADRESS3 (0x68000000U) |
| #define | NOR_MEMORY_ADRESS4 (0x6C000000U) |
| #define | NOR_ADDR_SHIFT(__NOR_ADDRESS, __NOR_MEMORY_WIDTH_, __ADDRESS__) |
| NOR memory address shifting. | |
| #define | NOR_WRITE(__ADDRESS__, __DATA__) |
| NOR memory write data to specified address. | |
Enumerations | |
| enum | HAL_NOR_StateTypeDef { HAL_NOR_STATE_RESET = 0x00U , HAL_NOR_STATE_READY = 0x01U , HAL_NOR_STATE_BUSY = 0x02U , HAL_NOR_STATE_ERROR = 0x03U , HAL_NOR_STATE_PROTECTED = 0x04U } |
| HAL SRAM State structures definition. More... | |
| enum | HAL_NOR_StatusTypeDef { HAL_NOR_STATUS_SUCCESS = 0U , HAL_NOR_STATUS_ONGOING , HAL_NOR_STATUS_ERROR , HAL_NOR_STATUS_TIMEOUT } |
| FMC NOR Status typedef. | |
| HAL_StatusTypeDef | HAL_NOR_Init (NOR_HandleTypeDef *hnor, FMC_NORSRAM_TimingTypeDef *Timing, FMC_NORSRAM_TimingTypeDef *ExtTiming) |
| HAL_StatusTypeDef | HAL_NOR_DeInit (NOR_HandleTypeDef *hnor) |
| void | HAL_NOR_MspInit (NOR_HandleTypeDef *hnor) |
| void | HAL_NOR_MspDeInit (NOR_HandleTypeDef *hnor) |
| void | HAL_NOR_MspWait (NOR_HandleTypeDef *hnor, uint32_t Timeout) |
| HAL_StatusTypeDef | HAL_NOR_Read_ID (NOR_HandleTypeDef *hnor, NOR_IDTypeDef *pNOR_ID) |
| HAL_StatusTypeDef | HAL_NOR_ReturnToReadMode (NOR_HandleTypeDef *hnor) |
| HAL_StatusTypeDef | HAL_NOR_Read (NOR_HandleTypeDef *hnor, uint32_t *pAddress, uint16_t *pData) |
| HAL_StatusTypeDef | HAL_NOR_Program (NOR_HandleTypeDef *hnor, uint32_t *pAddress, uint16_t *pData) |
| HAL_StatusTypeDef | HAL_NOR_ReadBuffer (NOR_HandleTypeDef *hnor, uint32_t uwAddress, uint16_t *pData, uint32_t uwBufferSize) |
| HAL_StatusTypeDef | HAL_NOR_ProgramBuffer (NOR_HandleTypeDef *hnor, uint32_t uwAddress, uint16_t *pData, uint32_t uwBufferSize) |
| HAL_StatusTypeDef | HAL_NOR_Erase_Block (NOR_HandleTypeDef *hnor, uint32_t BlockAddress, uint32_t Address) |
| HAL_StatusTypeDef | HAL_NOR_Erase_Chip (NOR_HandleTypeDef *hnor, uint32_t Address) |
| HAL_StatusTypeDef | HAL_NOR_Read_CFI (NOR_HandleTypeDef *hnor, NOR_CFITypeDef *pNOR_CFI) |
| HAL_StatusTypeDef | HAL_NOR_WriteOperation_Enable (NOR_HandleTypeDef *hnor) |
| HAL_StatusTypeDef | HAL_NOR_WriteOperation_Disable (NOR_HandleTypeDef *hnor) |
| HAL_NOR_StateTypeDef | HAL_NOR_GetState (const NOR_HandleTypeDef *hnor) |
| HAL_NOR_StatusTypeDef | HAL_NOR_GetStatus (NOR_HandleTypeDef *hnor, uint32_t Address, uint32_t Timeout) |
