RTEMS 6.2-rc1
Header file of NAND HAL module. More...
#include "stm32h7xx_ll_fmc.h"Go to the source code of this file.
| struct | NAND_IDTypeDef |
| NAND Memory electronic signature Structure definition. More... | |
| struct | NAND_AddressTypeDef |
| NAND Memory address Structure definition. More... | |
| struct | NAND_DeviceConfigTypeDef |
| NAND Memory info Structure definition. More... | |
| struct | NAND_HandleTypeDef |
| NAND handle Structure definition. More... | |
| #define | __HAL_NAND_RESET_HANDLE_STATE(__HANDLE__) ((__HANDLE__)->State = HAL_NAND_STATE_RESET) |
| Reset NAND handle state. | |
| #define | NAND_DEVICE 0x80000000UL |
| #define | NAND_WRITE_TIMEOUT 0x01000000UL |
| #define | CMD_AREA (1UL<<16U) /* A16 = CLE high */ |
| #define | ADDR_AREA (1UL<<17U) /* A17 = ALE high */ |
| #define | NAND_CMD_AREA_A ((uint8_t)0x00) |
| #define | NAND_CMD_AREA_B ((uint8_t)0x01) |
| #define | NAND_CMD_AREA_C ((uint8_t)0x50) |
| #define | NAND_CMD_AREA_TRUE1 ((uint8_t)0x30) |
| #define | NAND_CMD_WRITE0 ((uint8_t)0x80) |
| #define | NAND_CMD_WRITE_TRUE1 ((uint8_t)0x10) |
| #define | NAND_CMD_ERASE0 ((uint8_t)0x60) |
| #define | NAND_CMD_ERASE1 ((uint8_t)0xD0) |
| #define | NAND_CMD_READID ((uint8_t)0x90) |
| #define | NAND_CMD_STATUS ((uint8_t)0x70) |
| #define | NAND_CMD_LOCK_STATUS ((uint8_t)0x7A) |
| #define | NAND_CMD_RESET ((uint8_t)0xFF) |
| #define | NAND_VALID_ADDRESS 0x00000100UL |
| #define | NAND_INVALID_ADDRESS 0x00000200UL |
| #define | NAND_TIMEOUT_ERROR 0x00000400UL |
| #define | NAND_BUSY 0x00000000UL |
| #define | NAND_ERROR 0x00000001UL |
| #define | NAND_READY 0x00000040UL |
| #define | ARRAY_ADDRESS(__ADDRESS__, __HANDLE__) |
| NAND memory address computation. | |
| #define | COLUMN_ADDRESS(__HANDLE__) ((__HANDLE__)->Config.PageSize) |
| NAND memory Column address computation. | |
| #define | ADDR_1ST_CYCLE(__ADDRESS__) (uint8_t)(__ADDRESS__) /* 1st addressing cycle */ |
| NAND memory address cycling. | |
| #define | ADDR_2ND_CYCLE(__ADDRESS__) (uint8_t)((__ADDRESS__) >> 8) /* 2nd addressing cycle */ |
| #define | ADDR_3RD_CYCLE(__ADDRESS__) (uint8_t)((__ADDRESS__) >> 16) /* 3rd addressing cycle */ |
| #define | ADDR_4TH_CYCLE(__ADDRESS__) (uint8_t)((__ADDRESS__) >> 24) /* 4th addressing cycle */ |
| #define | COLUMN_1ST_CYCLE(__ADDRESS__) (uint8_t)((__ADDRESS__) & 0xFFU) /* 1st Column addressing cycle */ |
| NAND memory Columns cycling. | |
| #define | COLUMN_2ND_CYCLE(__ADDRESS__) (uint8_t)((__ADDRESS__) >> 8) /* 2nd Column addressing cycle */ |
Enumerations | |
| enum | HAL_NAND_StateTypeDef { HAL_NAND_STATE_RESET = 0x00U , HAL_NAND_STATE_READY = 0x01U , HAL_NAND_STATE_BUSY = 0x02U , HAL_NAND_STATE_ERROR = 0x03U } |
| HAL NAND State structures definition. More... | |
| HAL_StatusTypeDef | HAL_NAND_Init (NAND_HandleTypeDef *hnand, FMC_NAND_PCC_TimingTypeDef *ComSpace_Timing, FMC_NAND_PCC_TimingTypeDef *AttSpace_Timing) |
| HAL_StatusTypeDef | HAL_NAND_DeInit (NAND_HandleTypeDef *hnand) |
| HAL_StatusTypeDef | HAL_NAND_ConfigDevice (NAND_HandleTypeDef *hnand, NAND_DeviceConfigTypeDef *pDeviceConfig) |
| HAL_StatusTypeDef | HAL_NAND_Read_ID (NAND_HandleTypeDef *hnand, NAND_IDTypeDef *pNAND_ID) |
| void | HAL_NAND_MspInit (NAND_HandleTypeDef *hnand) |
| void | HAL_NAND_MspDeInit (NAND_HandleTypeDef *hnand) |
| void | HAL_NAND_IRQHandler (NAND_HandleTypeDef *hnand) |
| void | HAL_NAND_ITCallback (NAND_HandleTypeDef *hnand) |
| HAL_StatusTypeDef | HAL_NAND_Reset (NAND_HandleTypeDef *hnand) |
| HAL_StatusTypeDef | HAL_NAND_Read_Page_8b (NAND_HandleTypeDef *hnand, const NAND_AddressTypeDef *pAddress, uint8_t *pBuffer, uint32_t NumPageToRead) |
| HAL_StatusTypeDef | HAL_NAND_Write_Page_8b (NAND_HandleTypeDef *hnand, const NAND_AddressTypeDef *pAddress, const uint8_t *pBuffer, uint32_t NumPageToWrite) |
| HAL_StatusTypeDef | HAL_NAND_Read_SpareArea_8b (NAND_HandleTypeDef *hnand, const NAND_AddressTypeDef *pAddress, uint8_t *pBuffer, uint32_t NumSpareAreaToRead) |
| HAL_StatusTypeDef | HAL_NAND_Write_SpareArea_8b (NAND_HandleTypeDef *hnand, const NAND_AddressTypeDef *pAddress, const uint8_t *pBuffer, uint32_t NumSpareAreaTowrite) |
| HAL_StatusTypeDef | HAL_NAND_Read_Page_16b (NAND_HandleTypeDef *hnand, const NAND_AddressTypeDef *pAddress, uint16_t *pBuffer, uint32_t NumPageToRead) |
| HAL_StatusTypeDef | HAL_NAND_Write_Page_16b (NAND_HandleTypeDef *hnand, const NAND_AddressTypeDef *pAddress, const uint16_t *pBuffer, uint32_t NumPageToWrite) |
| HAL_StatusTypeDef | HAL_NAND_Read_SpareArea_16b (NAND_HandleTypeDef *hnand, const NAND_AddressTypeDef *pAddress, uint16_t *pBuffer, uint32_t NumSpareAreaToRead) |
| HAL_StatusTypeDef | HAL_NAND_Write_SpareArea_16b (NAND_HandleTypeDef *hnand, const NAND_AddressTypeDef *pAddress, const uint16_t *pBuffer, uint32_t NumSpareAreaTowrite) |
| HAL_StatusTypeDef | HAL_NAND_Erase_Block (NAND_HandleTypeDef *hnand, const NAND_AddressTypeDef *pAddress) |
| uint32_t | HAL_NAND_Address_Inc (const NAND_HandleTypeDef *hnand, NAND_AddressTypeDef *pAddress) |
| HAL_StatusTypeDef | HAL_NAND_ECC_Enable (NAND_HandleTypeDef *hnand) |
| HAL_StatusTypeDef | HAL_NAND_ECC_Disable (NAND_HandleTypeDef *hnand) |
| HAL_StatusTypeDef | HAL_NAND_GetECC (NAND_HandleTypeDef *hnand, uint32_t *ECCval, uint32_t Timeout) |
| HAL_NAND_StateTypeDef | HAL_NAND_GetState (const NAND_HandleTypeDef *hnand) |
| uint32_t | HAL_NAND_Read_Status (const NAND_HandleTypeDef *hnand) |
