RTEMS 6.2-rc1
Header file of IWDG HAL module. More...
#include "stm32h7xx_hal_def.h"Go to the source code of this file.
| struct | IWDG_InitTypeDef |
| IWDG Init structure definition. More... | |
| struct | IWDG_HandleTypeDef |
| IWDG Handle Structure definition. More... | |
| #define | IWDG_PRESCALER_4 0x00000000u |
| #define | IWDG_PRESCALER_8 IWDG_PR_PR_0 |
| #define | IWDG_PRESCALER_16 IWDG_PR_PR_1 |
| #define | IWDG_PRESCALER_32 (IWDG_PR_PR_1 | IWDG_PR_PR_0) |
| #define | IWDG_PRESCALER_64 IWDG_PR_PR_2 |
| #define | IWDG_PRESCALER_128 (IWDG_PR_PR_2 | IWDG_PR_PR_0) |
| #define | IWDG_PRESCALER_256 (IWDG_PR_PR_2 | IWDG_PR_PR_1) |
| #define | IWDG_WINDOW_DISABLE IWDG_WINR_WIN |
| #define | __HAL_IWDG_START(__HANDLE__) WRITE_REG((__HANDLE__)->Instance->KR, IWDG_KEY_ENABLE) |
| Enable the IWDG peripheral. | |
| #define | __HAL_IWDG_RELOAD_COUNTER(__HANDLE__) WRITE_REG((__HANDLE__)->Instance->KR, IWDG_KEY_RELOAD) |
| Reload IWDG counter with value defined in the reload register (write access to IWDG_PR, IWDG_RLR and IWDG_WINR registers disabled). | |
| #define | IWDG_KEY_RELOAD 0x0000AAAAu |
| IWDG Key Register BitMask. | |
| #define | IWDG_KEY_ENABLE 0x0000CCCCu |
| #define | IWDG_KEY_WRITE_ACCESS_ENABLE 0x00005555u |
| #define | IWDG_KEY_WRITE_ACCESS_DISABLE 0x00000000u |
| #define | IWDG_ENABLE_WRITE_ACCESS(__HANDLE__) WRITE_REG((__HANDLE__)->Instance->KR, IWDG_KEY_WRITE_ACCESS_ENABLE) |
| Enable write access to IWDG_PR, IWDG_RLR and IWDG_WINR registers. | |
| #define | IWDG_DISABLE_WRITE_ACCESS(__HANDLE__) WRITE_REG((__HANDLE__)->Instance->KR, IWDG_KEY_WRITE_ACCESS_DISABLE) |
| Disable write access to IWDG_PR, IWDG_RLR and IWDG_WINR registers. | |
| #define | IS_IWDG_PRESCALER(__PRESCALER__) |
| Check IWDG prescaler value. | |
| #define | IS_IWDG_RELOAD(__RELOAD__) ((__RELOAD__) <= IWDG_RLR_RL) |
| Check IWDG reload value. | |
| #define | IS_IWDG_WINDOW(__WINDOW__) ((__WINDOW__) <= IWDG_WINR_WIN) |
| Check IWDG window value. | |
| HAL_StatusTypeDef | HAL_IWDG_Init (IWDG_HandleTypeDef *hiwdg) |
| HAL_StatusTypeDef | HAL_IWDG_Refresh (IWDG_HandleTypeDef *hiwdg) |
