RTEMS 6.2-rc1
Header file of DMA HAL extension module. More...
#include "stm32h7xx_hal_def.h"Go to the source code of this file.
| struct | HAL_DMA_MuxSyncConfigTypeDef |
| HAL DMAMUX Synchronization configuration structure definition. More... | |
| struct | HAL_DMA_MuxRequestGeneratorConfigTypeDef |
| HAL DMAMUX request generator parameters structure definition. More... | |
Enumerations | |
| enum | HAL_DMA_MemoryTypeDef { MEMORY0 = 0x00U , MEMORY1 = 0x01U } |
| HAL DMA Memory definition. More... | |
| HAL_StatusTypeDef | HAL_DMAEx_MultiBufferStart (DMA_HandleTypeDef *hdma, uint32_t SrcAddress, uint32_t DstAddress, uint32_t SecondMemAddress, uint32_t DataLength) |
| HAL_StatusTypeDef | HAL_DMAEx_MultiBufferStart_IT (DMA_HandleTypeDef *hdma, uint32_t SrcAddress, uint32_t DstAddress, uint32_t SecondMemAddress, uint32_t DataLength) |
| HAL_StatusTypeDef | HAL_DMAEx_ChangeMemory (DMA_HandleTypeDef *hdma, uint32_t Address, HAL_DMA_MemoryTypeDef memory) |
| HAL_StatusTypeDef | HAL_DMAEx_ConfigMuxSync (DMA_HandleTypeDef *hdma, HAL_DMA_MuxSyncConfigTypeDef *pSyncConfig) |
| HAL_StatusTypeDef | HAL_DMAEx_ConfigMuxRequestGenerator (DMA_HandleTypeDef *hdma, HAL_DMA_MuxRequestGeneratorConfigTypeDef *pRequestGeneratorConfig) |
| HAL_StatusTypeDef | HAL_DMAEx_EnableMuxRequestGenerator (DMA_HandleTypeDef *hdma) |
| HAL_StatusTypeDef | HAL_DMAEx_DisableMuxRequestGenerator (DMA_HandleTypeDef *hdma) |
| void | HAL_DMAEx_MUX_IRQHandler (DMA_HandleTypeDef *hdma) |
