RTEMS 6.2-rc1
Header file of ADC HAL extended module. More...
#include "stm32h7xx_hal_def.h"Go to the source code of this file.
| struct | ADC_InjOversamplingTypeDef |
| ADC Injected Conversion Oversampling structure definition. More... | |
| struct | ADC_InjectionConfTypeDef |
| Structure definition of ADC group injected and ADC channel affected to ADC group injected. More... | |
| struct | ADC_MultiModeTypeDef |
| Structure definition of ADC multimode. More... | |
| #define | ADC_INJECTED_SOFTWARE_START (LL_ADC_INJ_TRIG_SOFTWARE) |
| #define | ADC_EXTERNALTRIGINJEC_T1_TRGO (LL_ADC_INJ_TRIG_EXT_TIM1_TRGO) |
| #define | ADC_EXTERNALTRIGINJEC_T1_CC4 (LL_ADC_INJ_TRIG_EXT_TIM1_CH4) |
| #define | ADC_EXTERNALTRIGINJEC_T2_TRGO (LL_ADC_INJ_TRIG_EXT_TIM2_TRGO) |
| #define | ADC_EXTERNALTRIGINJEC_T2_CC1 (LL_ADC_INJ_TRIG_EXT_TIM2_CH1) |
| #define | ADC_EXTERNALTRIGINJEC_T3_CC4 (LL_ADC_INJ_TRIG_EXT_TIM3_CH4) |
| #define | ADC_EXTERNALTRIGINJEC_T4_TRGO (LL_ADC_INJ_TRIG_EXT_TIM4_TRGO) |
| #define | ADC_EXTERNALTRIGINJEC_EXT_IT15 (LL_ADC_INJ_TRIG_EXT_EXTI_LINE15) |
| #define | ADC_EXTERNALTRIGINJEC_T8_CC4 (LL_ADC_INJ_TRIG_EXT_TIM8_CH4) |
| #define | ADC_EXTERNALTRIGINJEC_T1_TRGO2 (LL_ADC_INJ_TRIG_EXT_TIM1_TRGO2) |
| #define | ADC_EXTERNALTRIGINJEC_T8_TRGO (LL_ADC_INJ_TRIG_EXT_TIM8_TRGO) |
| #define | ADC_EXTERNALTRIGINJEC_T8_TRGO2 (LL_ADC_INJ_TRIG_EXT_TIM8_TRGO2) |
| #define | ADC_EXTERNALTRIGINJEC_T3_CC3 (LL_ADC_INJ_TRIG_EXT_TIM3_CH3) |
| #define | ADC_EXTERNALTRIGINJEC_T3_TRGO (LL_ADC_INJ_TRIG_EXT_TIM3_TRGO) |
| #define | ADC_EXTERNALTRIGINJEC_T3_CC1 (LL_ADC_INJ_TRIG_EXT_TIM3_CH1) |
| #define | ADC_EXTERNALTRIGINJEC_T6_TRGO (LL_ADC_INJ_TRIG_EXT_TIM6_TRGO) |
| #define | ADC_EXTERNALTRIGINJEC_T15_TRGO (LL_ADC_INJ_TRIG_EXT_TIM15_TRGO) |
| #define | ADC_EXTERNALTRIGINJEC_LPTIM1_OUT (LL_ADC_INJ_TRIG_EXT_LPTIM1_OUT) |
| #define | ADC_EXTERNALTRIGINJEC_LPTIM2_OUT (LL_ADC_INJ_TRIG_EXT_LPTIM2_OUT) |
| #define | ADC_EXTERNALTRIGINJEC_LPTIM3_OUT (LL_ADC_INJ_TRIG_EXT_LPTIM3_OUT) |
| #define | ADC_EXTERNALTRIGINJECCONV_EDGE_NONE (0x00000000UL) |
| #define | ADC_EXTERNALTRIGINJECCONV_EDGE_RISING (ADC_JSQR_JEXTEN_0) |
| #define | ADC_EXTERNALTRIGINJECCONV_EDGE_FALLING (ADC_JSQR_JEXTEN_1) |
| #define | ADC_EXTERNALTRIGINJECCONV_EDGE_RISINGFALLING (ADC_JSQR_JEXTEN) |
| #define | ADC_SINGLE_ENDED (LL_ADC_SINGLE_ENDED) |
| #define | ADC_DIFFERENTIAL_ENDED (LL_ADC_DIFFERENTIAL_ENDED) |
| #define | ADC_OFFSET_NONE (ADC_OFFSET_4 + 1U) |
| #define | ADC_OFFSET_1 (LL_ADC_OFFSET_1) |
| #define | ADC_OFFSET_2 (LL_ADC_OFFSET_2) |
| #define | ADC_OFFSET_3 (LL_ADC_OFFSET_3) |
| #define | ADC_OFFSET_4 (LL_ADC_OFFSET_4) |
| #define | ADC_INJECTED_RANK_1 (LL_ADC_INJ_RANK_1) |
| #define | ADC_INJECTED_RANK_2 (LL_ADC_INJ_RANK_2) |
| #define | ADC_INJECTED_RANK_3 (LL_ADC_INJ_RANK_3) |
| #define | ADC_INJECTED_RANK_4 (LL_ADC_INJ_RANK_4) |
| #define | ADC_MODE_INDEPENDENT (LL_ADC_MULTI_INDEPENDENT) |
| #define | ADC_DUALMODE_REGSIMULT (LL_ADC_MULTI_DUAL_REG_SIMULT) |
| #define | ADC_DUALMODE_INTERL (LL_ADC_MULTI_DUAL_REG_INTERL) |
| #define | ADC_DUALMODE_INJECSIMULT (LL_ADC_MULTI_DUAL_INJ_SIMULT) |
| #define | ADC_DUALMODE_ALTERTRIG (LL_ADC_MULTI_DUAL_INJ_ALTERN) |
| #define | ADC_DUALMODE_REGSIMULT_INJECSIMULT (LL_ADC_MULTI_DUAL_REG_SIM_INJ_SIM) |
| #define | ADC_DUALMODE_REGSIMULT_ALTERTRIG (LL_ADC_MULTI_DUAL_REG_SIM_INJ_ALT) |
| #define | ADC_DUALMODE_REGINTERL_INJECSIMULT (LL_ADC_MULTI_DUAL_REG_INT_INJ_SIM) |
| #define | ADC_DUALMODEDATAFORMAT_DISABLED (0x00000000UL) |
| #define | ADC_DUALMODEDATAFORMAT_32_10_BITS (ADC_CCR_DAMDF_1) |
| #define | ADC_DUALMODEDATAFORMAT_8_BITS ((ADC_CCR_DAMDF_0 |ADC_CCR_DAMDF_1)) |
| #define | ADC_TWOSAMPLINGDELAY_1CYCLE (LL_ADC_MULTI_TWOSMP_DELAY_1CYCLE_5) |
| #define | ADC_TWOSAMPLINGDELAY_2CYCLES (LL_ADC_MULTI_TWOSMP_DELAY_2CYCLES_5) |
| #define | ADC_TWOSAMPLINGDELAY_3CYCLES (LL_ADC_MULTI_TWOSMP_DELAY_3CYCLES_5) |
| #define | ADC_TWOSAMPLINGDELAY_4CYCLES (LL_ADC_MULTI_TWOSMP_DELAY_4CYCLES_5) |
| #define | ADC_TWOSAMPLINGDELAY_5CYCLES (LL_ADC_MULTI_TWOSMP_DELAY_5CYCLES_5) |
| #define | ADC_TWOSAMPLINGDELAY_6CYCLES (LL_ADC_MULTI_TWOSMP_DELAY_6CYCLES_5) |
| #define | ADC_TWOSAMPLINGDELAY_7CYCLES (LL_ADC_MULTI_TWOSMP_DELAY_7CYCLES_5) |
| #define | ADC_TWOSAMPLINGDELAY_8CYCLES (LL_ADC_MULTI_TWOSMP_DELAY_8CYCLES) |
| #define | ADC_TWOSAMPLINGDELAY_9CYCLES (LL_ADC_MULTI_TWOSMP_DELAY_9CYCLES) |
| #define | ADC_REGULAR_GROUP (LL_ADC_GROUP_REGULAR) |
| #define | ADC_INJECTED_GROUP (LL_ADC_GROUP_INJECTED) |
| #define | ADC_REGULAR_INJECTED_GROUP (LL_ADC_GROUP_REGULAR_INJECTED) |
| #define | ADC_CFGR_FIELDS |
| #define | ADC_SMPR1_FIELDS |
| #define | ADC_CFGR_FIELDS_2 ((uint32_t)(ADC_CFGR_DMNGT | ADC_CFGR_AUTDLY)) |
| #define | ADC_FORCE_MODE_INDEPENDENT(__HANDLE__) LL_ADC_SetMultimode(__LL_ADC_COMMON_INSTANCE((__HANDLE__)->Instance), LL_ADC_MULTI_INDEPENDENT) |
| Force ADC instance in multimode mode independent (multimode disable). | |
| #define | ADC_IS_SOFTWARE_START_INJECTED(__HANDLE__) (((__HANDLE__)->Instance->JSQR & ADC_JSQR_JEXTEN) == 0UL) |
| Test if conversion trigger of injected group is software start or external trigger. | |
| #define | ADC_IS_CONVERSION_ONGOING_REGULAR_INJECTED(__HANDLE__) |
| Check if conversion is on going on regular or injected groups. | |
| #define | ADC_IS_CONVERSION_ONGOING_INJECTED(__HANDLE__) (LL_ADC_INJ_IsConversionOngoing((__HANDLE__)->Instance)) |
| Check if conversion is on going on injected group. | |
| #define | ADC_JSQR_RK(__CHANNELNB__, __RANKNB__) ((((__CHANNELNB__) & ADC_CHANNEL_ID_NUMBER_MASK) >> ADC_CHANNEL_ID_NUMBER_BITOFFSET_POS) << ((__RANKNB__) & ADC_INJ_RANK_ID_JSQR_MASK)) |
| Set the selected injected Channel rank. | |
| #define | ADC_CFGR_INJECT_CONTEXT_QUEUE(__INJECT_CONTEXT_QUEUE_MODE__) ((__INJECT_CONTEXT_QUEUE_MODE__) << ADC_CFGR_JQM_Pos) |
| Configure ADC injected context queue. | |
| #define | ADC_CFGR_INJECT_DISCCONTINUOUS(__INJECT_DISCONTINUOUS_MODE__) ((__INJECT_DISCONTINUOUS_MODE__) << ADC_CFGR_JDISCEN_Pos) |
| Configure ADC discontinuous conversion mode for injected group. | |
| #define | ADC_CFGR_REG_DISCONTINUOUS(__REG_DISCONTINUOUS_MODE__) ((__REG_DISCONTINUOUS_MODE__) << ADC_CFGR_DISCEN_Pos) |
| Configure ADC discontinuous conversion mode for regular group. | |
| #define | ADC_CFGR_DISCONTINUOUS_NUM(__NBR_DISCONTINUOUS_CONV__) (((__NBR_DISCONTINUOUS_CONV__) - 1UL) << ADC_CFGR_DISCNUM_Pos) |
| Configure the number of discontinuous conversions for regular group. | |
| #define | ADC_CFGR_AUTOWAIT(__AUTOWAIT__) ((__AUTOWAIT__) << ADC_CFGR_AUTDLY_Pos) |
| Configure the ADC auto delay mode. | |
| #define | ADC_CFGR_CONTINUOUS(__CONTINUOUS_MODE__) ((__CONTINUOUS_MODE__) << ADC_CFGR_CONT_Pos) |
| Configure ADC continuous conversion mode. | |
| #define | ADC_CFGR_DMACONTREQ(__DMACONTREQ_MODE__) ((__DMACONTREQ_MODE__)) |
| Enable the ADC DMA continuous request. | |
| #define | ADC_OFR_CHANNEL(__CHANNEL__) ((__CHANNEL__) << ADC_OFR1_OFFSET1_CH_Pos) |
| Configure the channel number into offset OFRx register. | |
| #define | ADC_DIFSEL_CHANNEL(__CHANNEL__) (1UL << (__CHANNEL__)) |
| Configure the channel number into differential mode selection register. | |
| #define | ADC_CALFACT_DIFF_SET(__CALIBRATION_FACTOR__) (((__CALIBRATION_FACTOR__) & (ADC_CALFACT_CALFACT_D_Pos >> ADC_CALFACT_CALFACT_D_Pos) ) << ADC_CALFACT_CALFACT_D_Pos) |
| Configure calibration factor in differential mode to be set into calibration register. | |
| #define | ADC_CALFACT_DIFF_GET(__CALIBRATION_FACTOR__) ((__CALIBRATION_FACTOR__) >> ADC_CALFACT_CALFACT_D_Pos) |
| Calibration factor in differential mode to be retrieved from calibration register. | |
| #define | ADC_TRX_HIGHTHRESHOLD(__THRESHOLD__) ((__THRESHOLD__) << 16UL) |
| Configure the analog watchdog high threshold into registers TR1, TR2 or TR3. | |
| #define | ADC_CCR_MULTI_DMACONTREQ(__DMACONTREQ_MODE__) ((__DMACONTREQ_MODE__) << ADC_CCR_DMACFG_Pos) |
| Configure the ADC DMA continuous request for ADC multimode. | |
| #define | ADC_OFFSET_SHIFT_RESOLUTION(__HANDLE__, __OFFSET__) |
| Shift the offset in function of the selected ADC resolution. | |
| #define | ADC_AWD1THRESHOLD_SHIFT_RESOLUTION(__HANDLE__, __THRESHOLD__) |
| Shift the AWD1 threshold in function of the selected ADC resolution. | |
| #define | ADC_AWD23THRESHOLD_SHIFT_RESOLUTION(__HANDLE__, __THRESHOLD__) |
| Shift the AWD2 and AWD3 threshold in function of the selected ADC resolution. | |
| #define | ADC12_COMMON_REGISTER(__HANDLE__) (ADC12_COMMON) |
| Clear Common Control Register. | |
| #define | ADC_MASTER_REGISTER(__HANDLE__) ( (ADC1)) |
| Report Master Instance. | |
| #define | ADC_IS_DUAL_REGULAR_CONVERSION_ENABLE(__HANDLE__) |
| Check whether or not dual regular conversions are enabled. | |
| #define | ADC12_NONMULTIMODE_OR_MULTIMODEMASTER(__HANDLE__) |
| Verification of condition for ADC start conversion: ADC must be in non-MultiMode or MultiMode with handle of ADC master. | |
| #define | ADC_INDEPENDENT_OR_NONMULTIMODEREGULAR_SLAVE(__HANDLE__) |
| Ensure ADC Instance is Independent or Master, or is not Slave ADC with dual regular conversions enabled. | |
| #define | ADC_INDEPENDENT_OR_NONMULTIMODEINJECTED_SLAVE(__HANDLE__) |
| Ensure ADC Instance is Independent or Master, or is not Slave ADC with dual injected conversions enabled. | |
| #define | ADC_CLEAR_COMMON_CONTROL_REGISTER(__HANDLE__) |
| #define | ADC_MULTI_SLAVE(__HANDLE_MASTER__, __HANDLE_SLAVE__) ( (((__HANDLE_MASTER__)->Instance == ADC1)) ? ((__HANDLE_SLAVE__)->Instance = ADC2) : ((__HANDLE_SLAVE__)->Instance = NULL) ) |
| Set handle instance of the ADC slave associated to the ADC master. | |
| #define | ADC_TEMPERATURE_SENSOR_INSTANCE(__HANDLE__) (((__HANDLE__)->Instance) == ADC2) |
| Verify the ADC instance connected to the temperature sensor. | |
| #define | ADC_BATTERY_VOLTAGE_INSTANCE(__HANDLE__) (((__HANDLE__)->Instance) == ADC2) |
| Verify the ADC instance connected to the battery voltage VBAT. | |
| #define | ADC_VREFINT_INSTANCE(__HANDLE__) (((__HANDLE__)->Instance) == ADC2) |
| Verify the ADC instance connected to the internal voltage reference VREFINT. | |
| #define | IS_ADC_INJECTED_NB_CONV(__LENGTH__) (((__LENGTH__) >= (1U)) && ((__LENGTH__) <= (4U))) |
| Verify the length of scheduled injected conversions group. | |
| #define | IS_ADC_CALFACT(__CALIBRATION_FACTOR__) ((__CALIBRATION_FACTOR__) <= (0x7FFU)) |
| Calibration factor size verification (11 bits maximum). | |
| #define | IS_ADC_CHANNEL(__CHANNEL__) |
| Verify the ADC channel setting. | |
| #define | IS_ADC1_DIFF_CHANNEL(__CHANNEL__) |
| Verify the ADC channel setting in differential mode for ADC1. | |
| #define | IS_ADC2_DIFF_CHANNEL(__CHANNEL__) |
| Verify the ADC channel setting in differential mode for ADC2. | |
| #define | IS_ADC3_DIFF_CHANNEL(__CHANNEL__) |
| Verify the ADC channel setting in differential mode for ADC3. | |
| #define | IS_ADC_SINGLE_DIFFERENTIAL(__SING_DIFF__) |
| Verify the ADC single-ended input or differential mode setting. | |
| #define | IS_ADC_OFFSET_NUMBER(__OFFSET_NUMBER__) |
| Verify the ADC offset management setting. | |
| #define | IS_ADC_INJECTED_RANK(__CHANNEL__) |
| Verify the ADC injected channel setting. | |
| #define | IS_ADC_EXTTRIGINJEC(__INJTRIG__) |
| Verify the ADC injected conversions external trigger. | |
| #define | IS_ADC_EXTTRIGINJEC_EDGE(__EDGE__) |
| Verify the ADC edge trigger setting for injected group. | |
| #define | IS_ADC_MULTIMODE(__MODE__) |
| Verify the ADC multimode setting. | |
| #define | IS_ADC_DUAL_DATA_MODE(MODE) |
| Verify the ADC dual data mode setting. | |
| #define | IS_ADC_SAMPLING_DELAY(__DELAY__) |
| Verify the ADC multimode delay setting. | |
| #define | IS_ADC_ANALOG_WATCHDOG_NUMBER(__WATCHDOG__) |
| Verify the ADC analog watchdog setting. | |
| #define | IS_ADC_ANALOG_WATCHDOG_MODE(__WATCHDOG_MODE__) |
| Verify the ADC analog watchdog mode setting. | |
| #define | IS_ADC_CONVERSION_GROUP(__CONVERSION__) |
| Verify the ADC conversion (regular or injected or both). | |
| #define | IS_ADC_EVENT_TYPE(__EVENT__) |
| Verify the ADC event type. | |
| #define | IS_ADC_OVERSAMPLING_RATIO(RATIO) (((RATIO) >= 1UL) && ((RATIO) <= 1024UL)) |
| Verify the ADC oversampling ratio. | |
| #define | IS_ADC_RIGHT_BIT_SHIFT(__SHIFT__) |
| Verify the ADC oversampling shift. | |
| #define | IS_ADC_TRIGGERED_OVERSAMPLING_MODE(__MODE__) |
| Verify the ADC oversampling triggered mode. | |
| #define | IS_ADC_REGOVERSAMPLING_MODE(__MODE__) |
| Verify the ADC oversampling regular conversion resumed or continued mode. | |
| #define | IS_ADC_DFSDMCFG_MODE(__HANDLE__) (SET) |
| Verify the DFSDM mode configuration. | |
| #define | ADC_CFGR_DFSDM(__HANDLE__) (0x0UL) |
| Return the DFSDM configuration mode. | |
| HAL_StatusTypeDef | HAL_ADCEx_Calibration_Start (ADC_HandleTypeDef *hadc, uint32_t CalibrationMode, uint32_t SingleDiff) |
| uint32_t | HAL_ADCEx_Calibration_GetValue (ADC_HandleTypeDef *hadc, uint32_t SingleDiff) |
| HAL_StatusTypeDef | HAL_ADCEx_LinearCalibration_GetValue (ADC_HandleTypeDef *hadc, uint32_t *LinearCalib_Buffer) |
| HAL_StatusTypeDef | HAL_ADCEx_Calibration_SetValue (ADC_HandleTypeDef *hadc, uint32_t SingleDiff, uint32_t CalibrationFactor) |
| HAL_StatusTypeDef | HAL_ADCEx_LinearCalibration_SetValue (ADC_HandleTypeDef *hadc, uint32_t *LinearCalib_Buffer) |
| HAL_StatusTypeDef | HAL_ADCEx_LinearCalibration_FactorLoad (ADC_HandleTypeDef *hadc) |
| HAL_StatusTypeDef | HAL_ADCEx_InjectedStart (ADC_HandleTypeDef *hadc) |
| HAL_StatusTypeDef | HAL_ADCEx_InjectedStop (ADC_HandleTypeDef *hadc) |
| HAL_StatusTypeDef | HAL_ADCEx_InjectedPollForConversion (ADC_HandleTypeDef *hadc, uint32_t Timeout) |
| HAL_StatusTypeDef | HAL_ADCEx_InjectedStart_IT (ADC_HandleTypeDef *hadc) |
| HAL_StatusTypeDef | HAL_ADCEx_InjectedStop_IT (ADC_HandleTypeDef *hadc) |
| HAL_StatusTypeDef | HAL_ADCEx_MultiModeStart_DMA (ADC_HandleTypeDef *hadc, uint32_t *pData, uint32_t Length) |
| HAL_StatusTypeDef | HAL_ADCEx_MultiModeStop_DMA (ADC_HandleTypeDef *hadc) |
| uint32_t | HAL_ADCEx_MultiModeGetValue (ADC_HandleTypeDef *hadc) |
| uint32_t | HAL_ADCEx_InjectedGetValue (ADC_HandleTypeDef *hadc, uint32_t InjectedRank) |
| void | HAL_ADCEx_InjectedConvCpltCallback (ADC_HandleTypeDef *hadc) |
| void | HAL_ADCEx_InjectedQueueOverflowCallback (ADC_HandleTypeDef *hadc) |
| void | HAL_ADCEx_LevelOutOfWindow2Callback (ADC_HandleTypeDef *hadc) |
| void | HAL_ADCEx_LevelOutOfWindow3Callback (ADC_HandleTypeDef *hadc) |
| void | HAL_ADCEx_EndOfSamplingCallback (ADC_HandleTypeDef *hadc) |
| HAL_StatusTypeDef | HAL_ADCEx_RegularStop (ADC_HandleTypeDef *hadc) |
| HAL_StatusTypeDef | HAL_ADCEx_RegularStop_IT (ADC_HandleTypeDef *hadc) |
| HAL_StatusTypeDef | HAL_ADCEx_RegularStop_DMA (ADC_HandleTypeDef *hadc) |
| HAL_StatusTypeDef | HAL_ADCEx_RegularMultiModeStop_DMA (ADC_HandleTypeDef *hadc) |
| HAL_StatusTypeDef | HAL_ADCEx_InjectedConfigChannel (ADC_HandleTypeDef *hadc, ADC_InjectionConfTypeDef *sConfigInjected) |
| HAL_StatusTypeDef | HAL_ADCEx_MultiModeConfigChannel (ADC_HandleTypeDef *hadc, ADC_MultiModeTypeDef *multimode) |
| HAL_StatusTypeDef | HAL_ADCEx_EnableInjectedQueue (ADC_HandleTypeDef *hadc) |
| HAL_StatusTypeDef | HAL_ADCEx_DisableInjectedQueue (ADC_HandleTypeDef *hadc) |
| HAL_StatusTypeDef | HAL_ADCEx_DisableVoltageRegulator (ADC_HandleTypeDef *hadc) |
| HAL_StatusTypeDef | HAL_ADCEx_EnterADCDeepPowerDownMode (ADC_HandleTypeDef *hadc) |
