RTEMS 6.2-rc1
This header file defines the Message Manager API. More...
#include <stddef.h>#include <stdint.h>#include <rtems/rtems/attr.h>#include <rtems/rtems/options.h>#include <rtems/rtems/status.h>#include <rtems/rtems/types.h>#include <rtems/score/coremsgbuffer.h>Go to the source code of this file.
| struct | rtems_message_queue_config |
| This structure defines the configuration of a message queue constructed by rtems_message_queue_construct(). More... | |
| #define | RTEMS_MESSAGE_QUEUE_BUFFER(_maximum_message_size) |
| Defines a structure which can be used as a message queue buffer for messages of the specified maximum size. | |
| rtems_status_code | rtems_message_queue_create (rtems_name name, uint32_t count, size_t max_message_size, rtems_attribute attribute_set, rtems_id *id) |
| Creates a message queue. | |
| rtems_status_code | rtems_message_queue_construct (const rtems_message_queue_config *config, rtems_id *id) |
| Constructs a message queue from the specified the message queue configuration. | |
| rtems_status_code | rtems_message_queue_ident (rtems_name name, uint32_t node, rtems_id *id) |
| Identifies a message queue by the object name. | |
| rtems_status_code | rtems_message_queue_delete (rtems_id id) |
| Deletes the message queue. | |
| rtems_status_code | rtems_message_queue_send (rtems_id id, const void *buffer, size_t size) |
| Puts the message at the rear of the queue. | |
| rtems_status_code | rtems_message_queue_urgent (rtems_id id, const void *buffer, size_t size) |
| Puts the message at the front of the queue. | |
| rtems_status_code | rtems_message_queue_broadcast (rtems_id id, const void *buffer, size_t size, uint32_t *count) |
| Broadcasts the messages to the tasks waiting at the queue. | |
| rtems_status_code | rtems_message_queue_receive (rtems_id id, void *buffer, size_t *size, rtems_option option_set, rtems_interval timeout) |
| Receives a message from the queue. | |
| rtems_status_code | rtems_message_queue_get_number_pending (rtems_id id, uint32_t *count) |
| Gets the number of messages pending on the queue. | |
| rtems_status_code | rtems_message_queue_flush (rtems_id id, uint32_t *count) |
| Flushes all messages on the queue. | |
