RTEMS 6.2-rc1
leon3.h
2
11/*
12 * Copyright (C) 2014, 2023 embedded brains GmbH & Co. KG
13 *
14 * Copyright (C) 2015 Cobham Gaisler AB
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 * 1. Redistributions of source code must retain the above copyright
20 * notice, this list of conditions and the following disclaimer.
21 * 2. Redistributions in binary form must reproduce the above copyright
22 * notice, this list of conditions and the following disclaimer in the
23 * documentation and/or other materials provided with the distribution.
24 *
25 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35 * POSSIBILITY OF SUCH DAMAGE.
36 */
37
38#ifndef LIBBSP_SPARC_LEON3_BSP_LEON3_H
39#define LIBBSP_SPARC_LEON3_BSP_LEON3_H
40
41#include <grlib/apbuart-regs.h>
42#include <grlib/gptimer-regs.h>
43
44#include <bspopts.h>
45#include <bsp/irqimpl.h>
46
47#if !defined(LEON3_PLB_FREQUENCY_DEFINED_BY_GPTIMER)
48#include <grlib/ambapp.h>
49#endif
50
51#include <sys/timetc.h>
52
53#ifdef __cplusplus
54extern "C" {
55#endif
56
68
73#define LEON3_REG_CACHE_CTRL_FI 0x00200000U
74
79#define LEON3_REG_CACHE_CTRL_DS 0x00800000U
80
88static inline void leon3_set_system_register( uint32_t addr, uint32_t val )
89{
90 __asm__ volatile(
91 "sta %1, [%0] 2"
92 :
93 : "r" ( addr ), "r" ( val )
94 );
95}
96
104static inline uint32_t leon3_get_system_register( uint32_t addr )
105{
106 uint32_t val;
107
108 __asm__ volatile(
109 "lda [%1] 2, %0"
110 : "=r" ( val )
111 : "r" ( addr )
112 );
113
114 return val;
115}
116
122static inline void leon3_set_cache_control_register( uint32_t val )
123{
124 leon3_set_system_register( 0x0, val );
125}
126
132static inline uint32_t leon3_get_cache_control_register( void )
133{
134 return leon3_get_system_register( 0x0 );
135}
136
143static inline bool leon3_data_cache_snooping_enabled( void )
144{
145 return ( leon3_get_cache_control_register() & LEON3_REG_CACHE_CTRL_DS ) != 0;
146}
147
153static inline uint32_t leon3_get_inst_cache_config_register( void )
154{
155 return leon3_get_system_register( 0x8 );
156}
157
163static inline uint32_t leon3_get_data_cache_config_register( void )
164{
165 return leon3_get_system_register( 0xc );
166}
167
175static inline uint32_t leon3_get_cpu_count( const irqamp *regs )
176{
177 return IRQAMP_MPSTAT_NCPU_GET( grlib_load_32( &regs->mpstat ) ) + 1;
178}
179
180#if !defined(LEON3_GPTIMER_BASE)
196extern int leon3_timer_core_index;
197
212extern unsigned int leon3_timer_prescaler;
213#endif
214
219#if !defined(RTEMS_MULTIPROCESSING)
220#define LEON3_CLOCK_INDEX 0
221#elif defined(LEON3_GPTIMER_BASE)
222#define LEON3_CLOCK_INDEX ( 2 * LEON3_Cpu_Index )
223#else
224#define LEON3_CLOCK_INDEX ( leon3_timer_core_index != 0 ? 0 : 2 * LEON3_Cpu_Index )
225#endif
226
231#define LEON3_COUNTER_GPTIMER_INDEX ( LEON3_CLOCK_INDEX + 1 )
232
241#define LEON3_GPTIMER_0_FREQUENCY_SET_BY_BOOT_LOADER 1000000
242
246#if defined(LEON3_GPTIMER_BASE)
247#define LEON3_Timer_Regs ((gptimer *) LEON3_GPTIMER_BASE)
248#else
250
254extern struct ambapp_dev *LEON3_Timer_Adev;
255#endif
256
262static inline uint32_t leon3_processor_local_bus_frequency( void )
263{
264#if defined(LEON3_PLB_FREQUENCY_DEFINED_BY_GPTIMER)
265 return ( grlib_load_32( &LEON3_Timer_Regs->sreload ) + 1 ) *
267#else
268 /*
269 * For simplicity, assume that the interrupt controller uses the processor
270 * clock. This is at least true on the GR740.
271 */
272 return ambapp_freq_get( ambapp_plb(), LEON3_IrqCtrl_Adev );
273#endif
274}
275
281static inline uint32_t leon3_up_counter_low( void )
282{
283 uint32_t asr23;
284
285 __asm__ volatile (
286 "mov %%asr23, %0"
287 : "=&r" (asr23)
288 );
289
290 return asr23;
291}
292
298static inline uint32_t leon3_up_counter_high(void)
299{
300 uint32_t asr22;
301
302 __asm__ volatile (
303 "mov %%asr22, %0"
304 : "=&r" (asr22)
305 );
306
307 return asr22;
308}
309
313static inline void leon3_up_counter_enable( void )
314{
315 __asm__ volatile (
316 "mov %g0, %asr22"
317 );
318}
319
320#if !defined(LEON3_HAS_ASR_22_23_UP_COUNTER)
328static inline bool leon3_up_counter_is_available( void )
329{
330 return leon3_up_counter_low() != leon3_up_counter_low();
331}
332#endif
333
339static inline uint32_t leon3_up_counter_frequency( void )
340{
341 return leon3_processor_local_bus_frequency();
342}
343
347#if defined(LEON3_APBUART_BASE)
348#define leon3_debug_uart ((struct apbuart *) LEON3_APBUART_BASE)
349#else
351#endif
352
356typedef struct {
360 struct timecounter base;
361
362#if !defined(LEON3_HAS_ASR_22_23_UP_COUNTER)
367
371 volatile uint32_t *counter_register;
372#endif
374
381
382#if RTEMS_INTERRUPT_LOCK_NEEDS_OBJECT
389extern rtems_interrupt_lock leon3_l2c_lock;
390#endif
391
394#ifdef __cplusplus
395}
396#endif
397
398#endif /* LIBBSP_SPARC_LEON3_BSP_LEON3_H */
This header file defines the APBUART register block interface.
This header file defines the GPTIMER register block interface.
#define RTEMS_NO_RETURN
Tells the compiler in a function declaration that this function does not return.
Definition: basedefs.h:386
char rtems_interrupt_lock
This structure represents an ISR lock.
Definition: intr.h:532
struct ambapp_dev * LEON3_Timer_Adev
This pointer provides the GPTIMER device information block.
Definition: amba.c:127
gptimer * LEON3_Timer_Regs
This pointer provides the GPTIMER register block address.
Definition: amba.c:126
apbuart * leon3_debug_uart
This pointer provides the debug APBUART register block address.
Definition: printk_support.c:54
This object lets the user override which on-chip GPTIMER core will be used for system clock timer.
This object lets the user override system clock timer prescaler.
This constant represents the data cache snooping enable flag of the LEON cache control register.
Definition: leon3.h:79
This constant defines the frequency set by the boot loader of the first GPTIMER instance.
Definition: leon3.h:241
struct ambapp_dev * LEON3_IrqCtrl_Adev
This pointer provides the IRQ(A)MP device information block.
Definition: amba.c:122
RTEMS_NO_RETURN void leon3_power_down_loop(void)
Sets asr19 to zero to enter the power-down mode of the processor in an infinite loop.
leon3_timecounter leon3_timecounter_instance
Provides the LEON3-specific timecounter.
Definition: cpucounter.c:224
struct ambapp_bus * ambapp_plb(void)
Gets the fully scanned AMBA Plug & Play Processor Local Bus (PLB).
Definition: bspstart.c:58
Definition: ambapp.h:94
This structure defines the APBUART register block memory map.
Definition: apbuart-regs.h:248
This structure defines the GPTIMER register block memory map.
Definition: gptimer-regs.h:346
uint32_t sreload
See Scaler reload value register (SRELOAD).
Definition: gptimer-regs.h:355
This structure defines the IRQ(A)MP register block memory map.
Definition: irqamp-regs.h:780
uint32_t mpstat
See Multiprocessor status register (MPSTAT).
Definition: irqamp-regs.h:804
Represents the LEON3-specific timecounter.
Definition: leon3.h:356
volatile uint32_t * counter_register
This member may reference a hardware counter register.
Definition: leon3.h:371
uint32_t software_counter
This member provides a software fall-back counter.
Definition: leon3.h:366
Definition: timetc.h:58
This header file provides interfaces of the timecounter implementation.
