RTEMS
6.2-rc1
bsps
arm
lpc32xx
include
bsp
hsu.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
* Copyright (C) 2010, 2014 embedded brains GmbH & Co. KG
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#ifndef LIBBSP_ARM_LPC32XX_HSU_H
37
#define LIBBSP_ARM_LPC32XX_HSU_H
38
39
rtems/termiostypes.h
40
41
#ifdef __cplusplus
42
extern
"C"
43
#endif
/* __cplusplus */
44
55
typedef
struct
56
uint32_t fifo;
57
uint32_t level;
58
uint32_t iir;
59
uint32_t ctrl;
60
uint32_t rate;
61
lpc32xx_hsu
62
63
typedef
struct
64
rtems_termios_device_context
base;
65
volatile
lpc32xx_hsu
*hsu;
66
size_t
chars_in_transmission;
67
rtems_vector_number
irq;
68
uint32_t initial_baud;
69
lpc32xx_hsu_context
70
71
extern
const
rtems_termios_device_handler
lpc32xx_hsu_fns;
72
73
bool
lpc32xx_hsu_probe(
*base);
74
77
#ifdef __cplusplus
78
79
#endif
/* __cplusplus */
80
81
#endif
/* LIBBSP_ARM_LPC32XX_HSU_H */
rtems_vector_number
ISR_Vector_number rtems_vector_number
This integer type represents interrupt vector numbers.
Definition:
intr.h:102
lpc32xx_hsu_context
Definition:
hsu.h:63
lpc32xx_hsu
Definition:
hsu.h:55
Termios device context.
Definition:
termiosdevice.h:68
Termios device handler.
Definition:
termiosdevice.h:100
termiostypes.h
