RTEMS 6.2-rc1
This validation test suite contains test cases related to the thread-local storage support. More...
Modules | |
| spec:/score/thread/val/tls | |
| Tests properties of thread-local objects. | |
| spec:/score/thread/val/tls-max-zero | |
Files | |
| file | ts-validation-tls-1.c |
| #define | CONFIGURE_IDLE_TASK_STORAGE_SIZE ( RTEMS_MINIMUM_STACK_SIZE + 4096 ) |
| const char | rtems_test_name [] = "TestsuitesValidationTls1" |
| Each test must define a test name string. | |
