RTEMS 6.2-rc1
Modules | Files | Data Structures | Typedefs
This group contains the GRCAN interfaces. More...
 Configuration Register (CanCONF)
 This group contains register bit definitions.
 Control Register (CanCTRL)
 Receive Channel Address Register (CanRxADDR)
 Receive Channel Code Register (CanRxCODE)
 Receive Channel Control Register (CanRxCTRL)
 Receive Channel Interrupt Register (CanRxIRQ)
 Receive Channel Mask Register (CanRxMASK)
 Receive Channel Read Register (CanRxRD)
 Receive Channel Size Register (CanRxSIZE)
 Receive Channel Write Register (CanRxWR)
 SYNC Code Filter Register (CanCODE)
 SYNC Mask Filter Register (CanMASK)
 Status Register (CanSTAT)
 Transmit Channel Address Register (CanTxADDR)
 Transmit Channel Control Register (CanTxCTRL)
 Transmit Channel Interrupt Register (CanTxIRQ)
 Transmit Channel Read Register (CanTxRD)
 Transmit Channel Size Register (CanTxSIZE)
 Transmit Channel Write Register (CanTxWR)
file  grcan-regs.h
 This header file defines the GRCAN register block interface.
struct  grcan
 This structure defines the GRCAN register block memory map. More...
typedef struct grcan grcan
