RTEMS 6.2-rc1
exception.h
2
12/*
13 * Copyright (C) 2021 On-Line Applications Research Corporation (OAR)
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef _RTEMS_EXCEPTION_H
38#define _RTEMS_EXCEPTION_H
39
40#include <rtems/fatal.h>
41
42#ifdef __cplusplus
43extern "C" {
44#endif
45
63 bool always_set_to_false,
64 Internal_errors_t code
65);
66
67#ifdef __cplusplus
68}
69#endif
70
71#endif /* _RTEMS_EXCEPTION_H */
This header file defines the Fatal Error Manager API.
void _Exception_Raise_signal(Internal_errors_Source source, bool always_set_to_false, Internal_errors_t code)
Handle an exception frame for the purpose of mapping signals.
Definition: exceptionmapping.c:61
This type lists the possible sources from which an error can be reported.
Definition: interr.h:63
Definition: inftrees.h:24
