RTEMS 6.2-rc1
This header file defines the DSU4 register block interface. More...
#include <stdint.h>Go to the source code of this file.
| struct | dsu4 |
| This structure defines the DSU4 register block memory map. More... | |
| #define | DSU4_CTRL_PW 0x800U |
| #define | DSU4_CTRL_HL 0x400U |
| #define | DSU4_CTRL_PE 0x200U |
| #define | DSU4_CTRL_EB 0x100U |
| #define | DSU4_CTRL_EE 0x80U |
| #define | DSU4_CTRL_DM 0x40U |
| #define | DSU4_CTRL_BZ 0x20U |
| #define | DSU4_CTRL_BX 0x10U |
| #define | DSU4_CTRL_BS 0x8U |
| #define | DSU4_CTRL_BW 0x4U |
| #define | DSU4_CTRL_BE 0x2U |
| #define | DSU4_CTRL_TE 0x1U |
| #define | DSU4_DTTC_TIMETAG_SHIFT 0 |
| #define | DSU4_DTTC_TIMETAG_MASK 0xffffffffU |
| #define | DSU4_DTTC_TIMETAG_GET(_reg) |
| #define | DSU4_DTTC_TIMETAG_SET(_reg, _val) |
| #define | DSU4_DTTC_TIMETAG(_val) |
| #define | DSU4_BRSS_SS_3_0_SHIFT 16 |
| #define | DSU4_BRSS_SS_3_0_MASK 0xf0000U |
| #define | DSU4_BRSS_SS_3_0_GET(_reg) |
| #define | DSU4_BRSS_SS_3_0_SET(_reg, _val) |
| #define | DSU4_BRSS_SS_3_0(_val) |
| #define | DSU4_BRSS_BN_3_0_SHIFT 0 |
| #define | DSU4_BRSS_BN_3_0_MASK 0xfU |
| #define | DSU4_BRSS_BN_3_0_GET(_reg) |
| #define | DSU4_BRSS_BN_3_0_SET(_reg, _val) |
| #define | DSU4_BRSS_BN_3_0(_val) |
| #define | DSU4_DBGM_DM_3_0_SHIFT 16 |
| #define | DSU4_DBGM_DM_3_0_MASK 0xf0000U |
| #define | DSU4_DBGM_DM_3_0_GET(_reg) |
| #define | DSU4_DBGM_DM_3_0_SET(_reg, _val) |
| #define | DSU4_DBGM_DM_3_0(_val) |
| #define | DSU4_DBGM_ED_3_0_SHIFT 0 |
| #define | DSU4_DBGM_ED_3_0_MASK 0xfU |
| #define | DSU4_DBGM_ED_3_0_GET(_reg) |
| #define | DSU4_DBGM_ED_3_0_SET(_reg, _val) |
| #define | DSU4_DBGM_ED_3_0(_val) |
| #define | DSU4_DTR_EM 0x1000U |
| #define | DSU4_DTR_TRAPTYPE_SHIFT 4 |
| #define | DSU4_DTR_TRAPTYPE_MASK 0xff0U |
| #define | DSU4_DTR_TRAPTYPE_GET(_reg) |
| #define | DSU4_DTR_TRAPTYPE_SET(_reg, _val) |
| #define | DSU4_DTR_TRAPTYPE(_val) |
| #define | DSU4_DASI_ASI_SHIFT 0 |
| #define | DSU4_DASI_ASI_MASK 0xffU |
| #define | DSU4_DASI_ASI_GET(_reg) |
| #define | DSU4_DASI_ASI_SET(_reg, _val) |
| #define | DSU4_DASI_ASI(_val) |
| #define | DSU4_ATBC_DCNT_SHIFT 16 |
| #define | DSU4_ATBC_DCNT_MASK 0xff0000U |
| #define | DSU4_ATBC_DCNT_GET(_reg) |
| #define | DSU4_ATBC_DCNT_SET(_reg, _val) |
| #define | DSU4_ATBC_DCNT(_val) |
| #define | DSU4_ATBC_DF 0x100U |
| #define | DSU4_ATBC_SF 0x80U |
| #define | DSU4_ATBC_TE 0x40U |
| #define | DSU4_ATBC_TF 0x20U |
| #define | DSU4_ATBC_BW_SHIFT 3 |
| #define | DSU4_ATBC_BW_MASK 0x18U |
| #define | DSU4_ATBC_BW_GET(_reg) |
| #define | DSU4_ATBC_BW_SET(_reg, _val) |
| #define | DSU4_ATBC_BW(_val) |
| #define | DSU4_ATBC_BR 0x4U |
| #define | DSU4_ATBC_DM 0x2U |
| #define | DSU4_ATBC_EN 0x1U |
| #define | DSU4_ATBI_INDEX_SHIFT 4 |
| #define | DSU4_ATBI_INDEX_MASK 0xff0U |
| #define | DSU4_ATBI_INDEX_GET(_reg) |
| #define | DSU4_ATBI_INDEX_SET(_reg, _val) |
| #define | DSU4_ATBI_INDEX(_val) |
| #define | DSU4_ATBFC_WPF_SHIFT 12 |
| #define | DSU4_ATBFC_WPF_MASK 0x3000U |
| #define | DSU4_ATBFC_WPF_GET(_reg) |
| #define | DSU4_ATBFC_WPF_SET(_reg, _val) |
| #define | DSU4_ATBFC_WPF(_val) |
| #define | DSU4_ATBFC_BPF_SHIFT 8 |
| #define | DSU4_ATBFC_BPF_MASK 0x300U |
| #define | DSU4_ATBFC_BPF_GET(_reg) |
| #define | DSU4_ATBFC_BPF_SET(_reg, _val) |
| #define | DSU4_ATBFC_BPF(_val) |
| #define | DSU4_ATBFC_PF 0x8U |
| #define | DSU4_ATBFC_AF 0x4U |
| #define | DSU4_ATBFC_FR 0x2U |
| #define | DSU4_ATBFC_FW 0x1U |
| #define | DSU4_ATBFM_SMASK_15_0_SHIFT 16 |
| #define | DSU4_ATBFM_SMASK_15_0_MASK 0xffff0000U |
| #define | DSU4_ATBFM_SMASK_15_0_GET(_reg) |
| #define | DSU4_ATBFM_SMASK_15_0_SET(_reg, _val) |
| #define | DSU4_ATBFM_SMASK_15_0(_val) |
| #define | DSU4_ATBFM_MMASK_15_0_SHIFT 0 |
| #define | DSU4_ATBFM_MMASK_15_0_MASK 0xffffU |
| #define | DSU4_ATBFM_MMASK_15_0_GET(_reg) |
| #define | DSU4_ATBFM_MMASK_15_0_SET(_reg, _val) |
| #define | DSU4_ATBFM_MMASK_15_0(_val) |
| #define | DSU4_ATBBA_BADDR_31_2_SHIFT 2 |
| #define | DSU4_ATBBA_BADDR_31_2_MASK 0xfffffffcU |
| #define | DSU4_ATBBA_BADDR_31_2_GET(_reg) |
| #define | DSU4_ATBBA_BADDR_31_2_SET(_reg, _val) |
| #define | DSU4_ATBBA_BADDR_31_2(_val) |
| #define | DSU4_ATBBM_BMASK_31_2_SHIFT 2 |
| #define | DSU4_ATBBM_BMASK_31_2_MASK 0xfffffffcU |
| #define | DSU4_ATBBM_BMASK_31_2_GET(_reg) |
| #define | DSU4_ATBBM_BMASK_31_2_SET(_reg, _val) |
| #define | DSU4_ATBBM_BMASK_31_2(_val) |
| #define | DSU4_ATBBM_LD 0x2U |
| #define | DSU4_ATBBM_ST 0x1U |
| #define | DSU4_ICNT_CE 0x80000000U |
| #define | DSU4_ICNT_IC 0x40000000U |
| #define | DSU4_ICNT_PE 0x20000000U |
| #define | DSU4_ICNT_ICOUNT_28_0_SHIFT 0 |
| #define | DSU4_ICNT_ICOUNT_28_0_MASK 0x1fffffffU |
| #define | DSU4_ICNT_ICOUNT_28_0_GET(_reg) |
| #define | DSU4_ICNT_ICOUNT_28_0_SET(_reg, _val) |
| #define | DSU4_ICNT_ICOUNT_28_0(_val) |
| #define | DSU4_AHBWPC_IN 0x40U |
| #define | DSU4_AHBWPC_CP 0x20U |
| #define | DSU4_AHBWPC_EN 0x10U |
| #define | DSU4_AHBWPC_IN 0x4U |
| #define | DSU4_AHBWPC_CP 0x2U |
| #define | DSU4_AHBWPC_EN 0x1U |
| #define | DSU4_AHBWPD_DATA_SHIFT 0 |
| #define | DSU4_AHBWPD_DATA_MASK 0xffffffffU |
| #define | DSU4_AHBWPD_DATA_GET(_reg) |
| #define | DSU4_AHBWPD_DATA_SET(_reg, _val) |
| #define | DSU4_AHBWPD_DATA(_val) |
| #define | DSU4_AHBWPM_MASK_SHIFT 0 |
| #define | DSU4_AHBWPM_MASK_MASK 0xffffffffU |
| #define | DSU4_AHBWPM_MASK_GET(_reg) |
| #define | DSU4_AHBWPM_MASK_SET(_reg, _val) |
| #define | DSU4_AHBWPM_MASK(_val) |
| #define | DSU4_ITBC0_TFILT_SHIFT 28 |
| #define | DSU4_ITBC0_TFILT_MASK 0xf0000000U |
| #define | DSU4_ITBC0_TFILT_GET(_reg) |
| #define | DSU4_ITBC0_TFILT_SET(_reg, _val) |
| #define | DSU4_ITBC0_TFILT(_val) |
| #define | DSU4_ITBC0_ITPOINTER_SHIFT 0 |
| #define | DSU4_ITBC0_ITPOINTER_MASK 0xffffU |
| #define | DSU4_ITBC0_ITPOINTER_GET(_reg) |
| #define | DSU4_ITBC0_ITPOINTER_SET(_reg, _val) |
| #define | DSU4_ITBC0_ITPOINTER(_val) |
| #define | DSU4_ITBC1_WO 0x8000000U |
| #define | DSU4_ITBC1_TLIM_SHIFT 24 |
| #define | DSU4_ITBC1_TLIM_MASK 0x7000000U |
| #define | DSU4_ITBC1_TLIM_GET(_reg) |
| #define | DSU4_ITBC1_TLIM_SET(_reg, _val) |
| #define | DSU4_ITBC1_TLIM(_val) |
| #define | DSU4_ITBC1_TOV 0x800000U |
Typedefs | |
| typedef struct dsu4 | dsu4 |
| This structure defines the DSU4 register block memory map. | |
