RTEMS 6.1-rc8
| #define | TX4938_REG_BASE 0xFF1F0000 |
| #define | TX4938_PCI1_PCIID 0x7000 |
| #define | TX4938_PCI1_PCISTATUS 0x7004 |
| #define | TX4938_PCI1_PCICFG1 0x700c |
| #define | TX4938_PCI1_P2GM1PLBASE 0x7018 |
| #define | TX4938_PCI1_P2GCFG 0x7090 |
| #define | TX4938_PCI1_PBAREQPORT 0x7100 |
| #define | TX4938_PCI1_PBACFG 0x7104 |
| #define | TX4938_PCI1_G2PM0GBASE 0x7120 |
| #define | TX4938_PCI1_G2PIOGBASE 0x7138 |
| #define | TX4938_PCI1_G2PM0MASK 0x7140 |
| #define | TX4938_PCI1_G2PIOMASK 0x714c |
| #define | TX4938_PCI1_G2PM0PBASE 0x7150 |
| #define | TX4938_PCI1_G2PIOPBASE 0x7168 |
| #define | TX4938_PCI1_PCICCFG 0x7170 |
| #define | TX4938_PCI1_PCICSTATUS 0x7174 |
| #define | TX4938_PCI1_P2GM1GBASE 0x7188 |
| #define | TX4938_PCI1_G2PCFGADRS 0x71a0 |
| #define | TX4938_PCI1_G2PCFGDATA 0x71a4 |
| #define | TX4938_CFG_CCFG 0xE000 /* Chip Configuration Register */ |
| #define | TX4938_CFG_REVID 0xE008 /* Chip Revision ID Register */ |
| #define | TX4938_CFG_PCFG 0xE010 /* Pin Configuration Register */ |
| #define | TX4938_CFG_TOEA 0xE018 /* TimeOut Error Access Address Register */ |
| #define | TX4938_CFG_CLKCTR 0xE020 /* Clock Control Register */ |
| #define | TX4938_CFG_GARBC 0xE030 /* GBUS Arbiter Control Register */ |
| #define | TX4938_CFG_RAMP 0xE048 /* Register Address Mapping Register */ |
| #define | SELCHI 0x00100000 |
| #define | SELTMR0 0x00000200 |
| #define | TX4938_TIMER0_BASE 0xF000 |
| #define | TX4938_TIMER1_BASE 0xF100 |
| #define | TX4938_TIMER2_BASE 0xF200 |
| #define | TX4938_TIMER_TCR 0x00 /* Timer Control Register */ |
| #define | TX4938_TIMER_TISR 0x04 /* Timer Interrupt Status Register */ |
| #define | TX4938_TIMER_CPRA 0x08 /* Compare Register A */ |
| #define | TX4938_TIMER_CPRB 0x0C /* Compare Register B */ |
| #define | TX4938_TIMER_ITMR 0x10 /* Interval Timer Mode Register */ |
| #define | TX4938_TIMER_CCDR 0x20 /* Divide Cycle Register */ |
| #define | TX4938_TIMER_PGMR 0x30 /* Pulse Generator Mode Register */ |
| #define | TX4938_TIMER_WTMR 0x40 /* Reserved Register */ |
| #define | TX4938_TIMER_TRR 0xF0 /* Timer Read Register */ |
| #define | TIMER_CLEAR_ENABLE_MASK 0x1 |
| #define | TIMER_INT_ENABLE_MASK 0x8000 |
| #define | FFI 0x1 |
| #define | TPIAE 0x4000 |
| #define | TPIBE 0x8000 |
| #define | TIIS 0x1 |
| #define | TPIAS 0x2 |
| #define | TPIBS 0x4 |
| #define | TWIS 0x8 |
| #define | TX4938_IRQCTL_DEN 0xF600 /* Interrupt Detection Enable Register */ |
| #define | TX4938_IRQCTL_DM0 0xF604 /* Interrupt Detection Mode Register 0 */ |
| #define | TX4938_IRQCTL_DM1 0xF608 /* Interrupt Detection Mode Register 1 */ |
| #define | TX4938_IRQCTL_LVL0 0xF610 /* Interrupt Level Register 0 */ |
| #define | TX4938_IRQCTL_LVL1 0xF614 /* Interrupt Level Register 1 */ |
| #define | TX4938_IRQCTL_LVL2 0xF618 /* Interrupt Level Register 2 */ |
| #define | TX4938_IRQCTL_LVL3 0xF61C /* Interrupt Level Register 3 */ |
| #define | TX4938_IRQCTL_LVL4 0xF620 /* Interrupt Level Register 4 */ |
| #define | TX4938_IRQCTL_LVL5 0xF624 /* Interrupt Level Register 5 */ |
| #define | TX4938_IRQCTL_LVL6 0xF628 /* Interrupt Level Register 6 */ |
| #define | TX4938_IRQCTL_LVL7 0xF62C /* Interrupt Level Register 7 */ |
| #define | TX4938_IRQCTL_MSK 0xF640 /* Interrupt Mask Register */ |
| #define | TX4938_IRQCTL_EDC 0xF660 /* Interrupt Edge Detection Clear Register */ |
| #define | TX4938_IRQCTL_PND 0xF680 /* Interrupt Pending Register */ |
| #define | TX4938_IRQCTL_CS 0xF6A0 /* Interrupt Current Status Register */ |
| #define | TX4938_IRQCTL_FLAG0 0xF510 /* Interrupt Request Flag Register 0 */ |
| #define | TX4938_IRQCTL_FLAG1 0xF514 /* Interrupt Request Flag Register 1 */ |
| #define | TX4938_IRQCTL_POL 0xF518 /* Interrupt Request Polarity Control Register */ |
| #define | TX4938_IRQCTL_RCNT 0xF51C /* Interrupt Request Control Register */ |
| #define | TX4938_IRQCTL_MASKINT 0xF520 /* Interrupt Request Internal Interrupt Mask Register */ |
| #define | TX4938_IRQCTL_MASKEXT 0xF524 /* Interrupt Request External Interrupt Mask Register */ |
| #define | TX4938_REG_READ(_base, _register) *((volatile uint32_t *)((_base) + (_register))) |
| #define | TX4938_REG_WRITE(_base, _register, _value) *((volatile uint32_t *)((_base) + (_register))) = (_value) |
| #define | TX4938_CCFG_SYSSP_SHF 6 |
| #define | TX4938_CCFG_SYSSP_MSK (MSK(2) << TX4938_CCFG_SYSSP_SHF) |
| #define | TX4938_CCFG_PCI1DMD_SHF 8 |
| #define | TX4938_CCFG_PCI1DMD_MSK (MSK(1) << TX4938_CCFG_PCI1DMD_SHF) |
| #define | TX4938_CCFG_PCIDIVMODE_SHF 10 |
| #define | TX4938_CCFG_PCIDIVMODE_MSK (MSK(3) << TX4938_CCFG_PCIDIVMODE_SHF) |
| #define | TX4938_CCFG_PCI166_SHF 21 |
| #define | TX4938_CCFG_PCI166_MSK ((UINT64)MSK(1) << TX4938_CCFG_PCI166_SHF) |
| #define | TX4938_CCFG_PCIMODE_SHF 22 |
| #define | TX4938_CCFG_PCIMODE_MSK ((UINT64)MSK(1) << TX4938_CCFG_PCIMODE_SHF) |
| #define | TX4938_CCFG_BRDTY_SHF 36 |
| #define | TX4938_CCFG_RRDTY_MSK ((UINT64)MSK(4) << TX4938_CCFG_BRDTY_SHF) |
| #define | TX4938_CCFG_BRDRV_SHF 32 |
| #define | TX4938_CCFG_BRDRV_MSK ((UINT64)MSK(4) << TX4938_CCFG_BRDRV_SHF) |
| #define | TX4938_CLKCTR_PCIC1RST_SHF 11 |
| #define | TX4938_CLKCTR_PCIC1RST_MSK (MSK(1) << TX4938_CLKCTR_PCIC1RST_SHF) |
| #define | TX4938_PCI_PCISTATUS_MEMSP_SHF 1 |
| #define | TX4938_PCI_PCISTATUS_MEMSP_MSK (MSK(1) << TX4938_PCI_PCISTATUS_MEMSP_SHF) |
| #define | TX4938_PCI_PCISTATUS_BM_SHF 2 |
| #define | TX4938_PCI_PCISTATUS_BM_MSK (MSK(1) << TX4938_PCI_PCISTATUS_BM_SHF) |
| #define | TX4938_PCI_PBACFG_RPBA_SHF 2 |
| #define | TX4938_PCI_PBACFG_RPBA_MSK (MSK(1) << TX4938_PCI_PBACFG_RPBA_SHF) |
| #define | TX4938_PCI_PBACFG_PBAEN_SHF 1 |
| #define | TX4938_PCI_PBACFG_PBAEN_MSK (MSK(1) << TX4938_PCI_PBACFG_PBAEN_SHF) |
| #define | TX4938_PCI_PCICFG_G2PM0EN_SHF 6 |
| #define | TX4938_PCI_PCICFG_G2PM0EN_MSK (MSK(1) << TX4938_PCI_PCICFG_G2PM0EN_SHF) |
| #define | TX4938_PCI_PCICFG_G2PIOEN_SHF 5 |
| #define | TX4938_PCI_PCICFG_G2PIOEN_MSK (MSK(1) << TX4938_PCI_PCICFG_G2PIOEN_SHF) |
| #define | TX4938_PCI_PCICFG_TCAR_SHF 4 |
| #define | TX4938_PCI_PCICFG_TCAR_MSK (MSK(1) << TX4938_PCI_PCICFG_TCAR_SHF) |
MIPS Tx4938 specific information
