RTEMS 6.1-rc8
This header file provides the support functions for the validation test cases. More...
#include <rtems.h>#include <rtems/irq-extension.h>#include <rtems/score/atomic.h>#include <rtems/score/threadq.h>Go to the source code of this file.
| struct | TaskTimerInfo |
| struct | MemoryContext |
| struct | CallWithinISRRequest |
| struct | WrapThreadQueueContext |
| struct | Timer_Scheduling_Data |
| This structure provides data used by RTEMS to schedule a timer service routine. More... | |
| struct | ExtensionCalls |
| #define | PRIO_DEFAULT 1 |
| This constants represents the default priority of the runner task. | |
| #define | PRIO_INVALID 0xfffffffe |
| This constants represents an invalid RTEMS task priority value. | |
| #define | PRIO_NEARLY_IDLE 126 |
| This constants represents a priority which is close to the priority of the idle thread. | |
| #define | PRIO_FLEXIBLE 64 |
| This constants represents a priority with a wider range of higher and lower priorities around it. | |
| #define | INVALID_ID 0xfffffffd |
| This constants represents an invalid RTEMS object identifier. | |
| #define | OBJECT_NAME rtems_build_name( 'T', 'E', 'S', 'T' ) |
| This constants represents an object name for tests. | |
| #define | CreateTask(name, priority) |
| #define | SCHEDULER_A_ID 0xf010001 |
| #define | SCHEDULER_B_ID 0xf010002 |
| #define | SCHEDULER_C_ID 0xf010003 |
| #define | SCHEDULER_D_ID 0xf010004 |
| #define | SOFTWARE_TIMECOUNTER_FREQUENCY 1000000 |
| This constant represents the fake frequency of the software timecounter. | |
Typedefs | |
| typedef uint32_t(* | GetTimecountHandler) (void) |
| typedef void(* | FatalHandler) (rtems_fatal_source source, rtems_fatal_code code, void *arg) |
Enumerations | |
| enum | Priority { PRIO_PSEUDO_ISR , PRIO_VERY_ULTRA_HIGH , PRIO_ULTRA_HIGH , PRIO_VERY_HIGH , PRIO_HIGH , PRIO_NORMAL , PRIO_LOW , PRIO_VERY_LOW , PRIO_ULTRA_LOW } |
| enum | TaskTimerState { TASK_TIMER_INVALID , TASK_TIMER_INACTIVE , TASK_TIMER_TICKS , TASK_TIMER_REALTIME , TASK_TIMER_MONOTONIC } |
| enum | Timer_States { TIMER_INVALID , TIMER_INACTIVE , TIMER_SCHEDULED , TIMER_PENDING } |
| The various states of a timer. | |
| rtems_id | DoCreateTask (rtems_name name, rtems_task_priority priority) |
| void | StartTask (rtems_id id, rtems_task_entry entry, void *arg) |
| void | DeleteTask (rtems_id id) |
| void | SuspendTask (rtems_id id) |
| void | SuspendSelf (void) |
| void | ResumeTask (rtems_id id) |
| bool | IsTaskSuspended (rtems_id id) |
| rtems_event_set | QueryPendingEvents (void) |
| rtems_event_set | PollAnyEvents (void) |
| rtems_event_set | ReceiveAnyEvents (void) |
| rtems_event_set | ReceiveAnyEventsTimed (rtems_interval ticks) |
| void | ReceiveAllEvents (rtems_event_set events) |
| void | SendEvents (rtems_id id, rtems_event_set events) |
| rtems_mode | GetMode (void) |
| rtems_mode | SetMode (rtems_mode set, rtems_mode mask) |
| rtems_task_priority | GetPriority (rtems_id id) |
| rtems_task_priority | GetPriorityByScheduler (rtems_id task_id, rtems_id scheduler_id) |
| rtems_task_priority | SetPriority (rtems_id id, rtems_task_priority priority) |
| rtems_task_priority | GetSelfPriority (void) |
| rtems_task_priority | SetSelfPriority (rtems_task_priority priority) |
| rtems_task_priority | SetSelfPriorityNoYield (rtems_task_priority priority) |
| rtems_id | GetScheduler (rtems_id id) |
| rtems_id | GetSelfScheduler (void) |
| void | SetScheduler (rtems_id task_id, rtems_id scheduler_id, rtems_task_priority priority) |
| void | SetSelfScheduler (rtems_id scheduler_id, rtems_task_priority priority) |
| void | GetAffinity (rtems_id id, cpu_set_t *set) |
| void | GetSelfAffinity (cpu_set_t *set) |
| void | SetAffinity (rtems_id id, const cpu_set_t *set) |
| void | SetSelfAffinity (const cpu_set_t *set) |
| void | SetAffinityOne (rtems_id id, uint32_t cpu_index) |
| void | SetSelfAffinityOne (uint32_t cpu_index) |
| void | SetAffinityAll (rtems_id id) |
| void | SetSelfAffinityAll (void) |
| void | Yield (void) |
| void | YieldTask (rtems_id id) |
| void | AddProcessor (rtems_id scheduler_id, uint32_t cpu_index) |
| void | RemoveProcessor (rtems_id scheduler_id, uint32_t cpu_index) |
| rtems_id | CreateMutex (void) |
| rtems_id | CreateMutexNoProtocol (void) |
| rtems_id | CreateMutexFIFO (void) |
| bool | IsMutexOwner (rtems_id id) |
| void | DeleteMutex (rtems_id id) |
| void | ObtainMutex (rtems_id id) |
| void | ObtainMutexTimed (rtems_id id, rtems_interval ticks) |
| void | ObtainMutexDeadlock (rtems_id id) |
| void | ReleaseMutex (rtems_id id) |
| struct Thread_queue_Queue * | GetMutexThreadQueue (rtems_id id) |
| void | RestoreRunnerASR (void) |
| void | RestoreRunnerMode (void) |
| void | RestoreRunnerPriority (void) |
| void | RestoreRunnerScheduler (void) |
| struct _Thread_Control * | GetThread (rtems_id id) |
| struct _Thread_Control * | GetExecuting (void) |
| void | KillZombies (void) |
| void | WaitForExecutionStop (rtems_id task_id) |
| void | WaitForIntendToBlock (rtems_id task_id) |
| void | WaitForHeir (uint32_t cpu_index, rtems_id task_id) |
| void | WaitForNextTask (uint32_t cpu_index, rtems_id task_id) |
| void | GetTaskTimerInfo (rtems_id id, TaskTimerInfo *info) |
| void | GetTaskTimerInfoByThread (struct _Thread_Control *thread, TaskTimerInfo *info) |
| void | ClockTick (void) |
| void | FinalClockTick (void) |
| Simulates a clock tick with the final expire time point of UINT64_MAX for all clocks. | |
| void | TimecounterTick (void) |
| Simulates a single clock tick using the software timecounter. | |
| GetTimecountHandler | SetGetTimecountHandler (GetTimecountHandler handler) |
| Sets the get timecount handler. | |
| uint32_t | GetTimecountCounter (void) |
| Gets the software timecount counter value. | |
| uint32_t | SetTimecountCounter (uint32_t counter) |
| Sets and gets the software timecount counter value. | |
| rtems_id | GetTimerServerTaskId (void) |
| Return the task id of the timer server task. | |
| bool | DeleteTimerServer (void) |
| Undo the effects of rtems_timer_initiate_server() | |
| void | MemorySave (MemoryContext *ctx) |
| void | MemoryRestore (const MemoryContext *ctx) |
| void | MemoryAllocationFailWhen (uint32_t counter) |
| Fails a dynamic memory allocation when the counter reaches zero. | |
| void | CallWithinISR (void(*handler)(void *), void *arg) |
| void | CallWithinISRSubmit (CallWithinISRRequest *request) |
| void | CallWithinISRWait (const CallWithinISRRequest *request) |
| void | CallWithinISRRaise (void) |
| void | CallWithinISRClear (void) |
| rtems_vector_number | CallWithinISRGetVector (void) |
| rtems_vector_number | GetSoftwareInterruptVector (void) |
| void | WrapThreadQueueInitialize (WrapThreadQueueContext *ctx, void(*handler)(void *), void *arg) |
| void | WrapThreadQueueExtract (WrapThreadQueueContext *ctx, struct _Thread_Control *thread) |
| void | WrapThreadQueueExtractDirect (WrapThreadQueueContext *ctx, Thread_Control *thread) |
| void | WrapThreadQueueDestroy (WrapThreadQueueContext *ctx) |
| void | SetPreemptionIntervention (struct Per_CPU_Control *cpu, void(*handler)(void *), void *arg) |
| rtems_vector_number | GetValidInterruptVectorNumber (const rtems_interrupt_attributes *required) |
| rtems_vector_number | GetTestableInterruptVector (const rtems_interrupt_attributes *required) |
| rtems_status_code | RaiseSoftwareInterrupt (rtems_vector_number vector) |
| rtems_status_code | ClearSoftwareInterrupt (rtems_vector_number vector) |
| bool | HasInterruptVectorEntriesInstalled (rtems_vector_number vector) |
| Timer_Classes | GetTimerClass (rtems_id id) |
| Get the clock and context of a timer from RTEMS internal data. | |
| void | GetTimerSchedulingData (rtems_id id, Timer_Scheduling_Data *data) |
| Get data related to scheduling a timer service routine from RTEMS internal structures. | |
| Timer_States | GetTimerState (rtems_id id) |
| Get the state of a timer from RTEMS internal data. | |
| void | UnsetClock (void) |
| Mark the realtime clock as never set. | |
| void | FatalInitialExtension (rtems_fatal_source source, bool always_set_to_false, rtems_fatal_code code) |
| void | SetFatalHandler (FatalHandler fatal, void *arg) |
| void | SetTaskSwitchExtension (rtems_task_switch_extension task_switch) |
| void | ClearExtensionCalls (ExtensionCalls *calls) |
| void | CopyExtensionCalls (const ExtensionCalls *from, ExtensionCalls *to) |
| void | SetIORelaxHandler (void(*handler)(void *), void *arg) |
| void | StartDelayThreadDispatch (uint32_t cpu_index) |
| void | StopDelayThreadDispatch (uint32_t cpu_index) |
| bool | AreInterruptsEnabled (void) |
| bool | IsWhiteSpaceOnly (const char *s) |
| bool | IsEqualIgnoreWhiteSpace (const char *a, const char *b) |
| void * | IdleBody (uintptr_t ignored) |
| const rtems_task_config | DefaultTaskConfig |
| This task configurations may be used to construct a task during tests. | |
