RTEMS 6.1-rc8
This header file provides a configurable validation test suite runner and application configuration for tests which should run within an idle task without a user initialization task. More...
#include <rtems.h>#include <rtems/bspIo.h>#include <rtems/test-info.h>#include <rtems/testopts.h>#include <rtems/test.h>#include "tx-support.h"#include <rtems/confdefs.h>Go to the source code of this file.
| #define | CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER |
| #define | CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 0 |
| #define | CONFIGURE_DISABLE_NEWLIB_REENTRANCY |
| #define | CONFIGURE_APPLICATION_DISABLE_FILESYSTEM |
| #define | CONFIGURE_INITIAL_EXTENSIONS { .fatal = FatalInitialExtension } |
| #define | CONFIGURE_IDLE_TASK_STORAGE_SIZE RTEMS_MINIMUM_STACK_SIZE |
| #define | CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION |
| #define | CONFIGURE_IDLE_TASK_BODY IdleBody |
| #define | CONFIGURE_INIT |
| void * | IdleBody (uintptr_t ignored) |
