RTEMS 6.1-rc8
This header file provides the Timecounter Support API. More...
| struct | rtems_timecounter_simple |
| Simple timecounter to support legacy clock drivers. More... | |
| #define | RTEMS_TIMECOUNTER_QUALITY_CLOCK_DRIVER 100 |
| Timecounter quality for the clock drivers. | |
Typedefs | |
| typedef void | rtems_timecounter_simple_at_tick(rtems_timecounter_simple *tc) |
| At tick handling done under protection of the timecounter lock. | |
| typedef uint32_t | rtems_timecounter_simple_get(rtems_timecounter_simple *tc) |
| Returns the current value of a simple timecounter. | |
| typedef bool | rtems_timecounter_simple_is_pending(rtems_timecounter_simple *tc) |
| Returns true if the interrupt of a simple timecounter is pending, and false otherwise. | |
| void | rtems_timecounter_simple_install (rtems_timecounter_simple *tc, uint32_t counter_frequency_in_hz, uint32_t counter_ticks_per_clock_tick, timecounter_get_t *get_timecount) |
| Initializes and installs a simple timecounter. | |
