RTEMS 6.1-rc8
CMSIS Cortex-Mx Device System Source File for STM32H7xx devices. More...
| void | SystemInit (void) |
| Setup the microcontroller system. Initialize the System and update the SystemFrequency variable. | |
| void | SystemCoreClockUpdate (void) |
| Update SystemCoreClock variable according to Clock Register Values. The SystemCoreClock variable contains the core clock , it can be used by the user application to setup the SysTick timer or configure other parameters. | |
| uint32_t | SystemCoreClock |
| System clock frequency (core clock) | |
| uint32_t | SystemD2Clock |
| const uint8_t | D1CorePrescTable [16] |
