RTEMS 6.1-rc8
Public Member Functions | |
| SPIN_DECLARE (devlock) | |
Data Fields | |
| struct drvmgr_dev * | dev |
| char | devName [52] |
| pelican_regs * | regs |
| int | byte_regs |
| int | irq |
| occan_speed_regs | timing |
| int | channel |
| int | single_mode |
| unsigned int | sys_freq_hz |
| rtems_id | devsem |
| rtems_id | txsem |
| rtems_id | rxsem |
| int | open |
| int | started |
| int | rxblk |
| int | txblk |
| int | sending |
| unsigned int | status |
| occan_stats | stats |
| occan_fifo * | rxfifo |
| occan_fifo * | txfifo |
| unsigned int | speed |
| unsigned char | acode [4] |
| unsigned char | amask [4] |
