RTEMS 6.1-rc8
Header file of SWPMI HAL module. More...
#include "stm32h7xx_hal_def.h"Go to the source code of this file.
| struct | SWPMI_InitTypeDef |
| SWPMI Init Structure definition. More... | |
| struct | SWPMI_HandleTypeDef |
| SWPMI handle Structure definition. More... | |
| #define | HAL_SWPMI_ERROR_NONE ((uint32_t)0x00000000) |
| #define | HAL_SWPMI_ERROR_CRC ((uint32_t)0x00000004) |
| #define | HAL_SWPMI_ERROR_OVR ((uint32_t)0x00000008) |
| #define | HAL_SWPMI_ERROR_UDR ((uint32_t)0x0000000C) |
| #define | HAL_SWPMI_ERROR_DMA ((uint32_t)0x00000010) |
| #define | HAL_SWPMI_ERROR_TIMEOUT ((uint32_t)0x00000020) |
| #define | HAL_SWPMI_ERROR_TXBEF_TIMEOUT ((uint32_t)0x00000040) |
| #define | HAL_SWPMI_ERROR_TRANSCEIVER_NOT_READY ((uint32_t)0x00000080) |
| #define | SWPMI_VOLTAGE_CLASS_C ((uint32_t)0x00000000) |
| #define | SWPMI_VOLTAGE_CLASS_B SWPMI_OR_CLASS |
| #define | SWPMI_TX_NO_SOFTWAREBUFFER ((uint32_t)0x00000000) |
| #define | SWPMI_TX_SINGLE_SOFTWAREBUFFER ((uint32_t)0x00000000) |
| #define | SWPMI_TX_MULTI_SOFTWAREBUFFER SWPMI_CR_TXMODE |
| #define | SWPMI_RX_NO_SOFTWAREBUFFER ((uint32_t)0x00000000) |
| #define | SWPMI_RX_SINGLE_SOFTWAREBUFFER ((uint32_t)0x00000000) |
| #define | SWPMI_RX_MULTI_SOFTWAREBUFFER SWPMI_CR_RXMODE |
| #define | SWPMI_FLAG_RXBFF SWPMI_ISR_RXBFF |
| #define | SWPMI_FLAG_TXBEF SWPMI_ISR_TXBEF |
| #define | SWPMI_FLAG_RXBERF SWPMI_ISR_RXBERF |
| #define | SWPMI_FLAG_RXOVRF SWPMI_ISR_RXOVRF |
| #define | SWPMI_FLAG_TXUNRF SWPMI_ISR_TXUNRF |
| #define | SWPMI_FLAG_RXNE SWPMI_ISR_RXNE |
| #define | SWPMI_FLAG_TXE SWPMI_ISR_TXE |
| #define | SWPMI_FLAG_TCF SWPMI_ISR_TCF |
| #define | SWPMI_FLAG_SRF SWPMI_ISR_SRF |
| #define | SWPMI_FLAG_SUSP SWPMI_ISR_SUSP |
| #define | SWPMI_FLAG_DEACTF SWPMI_ISR_DEACTF |
| #define | SWPMI_FLAG_RDYF SWPMI_ISR_RDYF |
| #define | SWPMI_IT_RDYIE SWPMI_IER_RDYIE |
| #define | SWPMI_IT_SRIE SWPMI_IER_SRIE |
| #define | SWPMI_IT_TCIE SWPMI_IER_TCIE |
| #define | SWPMI_IT_TIE SWPMI_IER_TIE |
| #define | SWPMI_IT_RIE SWPMI_IER_RIE |
| #define | SWPMI_IT_TXUNRIE SWPMI_IER_TXUNRIE |
| #define | SWPMI_IT_RXOVRIE SWPMI_IER_RXOVRIE |
| #define | SWPMI_IT_RXBERIE SWPMI_IER_RXBERIE |
| #define | SWPMI_IT_TXBEIE SWPMI_IER_TXBEIE |
| #define | SWPMI_IT_RXBFIE SWPMI_IER_RXBFIE |
| #define | __HAL_SWPMI_RESET_HANDLE_STATE(__HANDLE__) ((__HANDLE__)->State = HAL_SWPMI_STATE_RESET) |
| Reset SWPMI handle state. | |
| #define | __HAL_SWPMI_ENABLE(__HANDLE__) SET_BIT((__HANDLE__)->Instance->CR, SWPMI_CR_SWPACT) |
| Enable the SWPMI peripheral. | |
| #define | __HAL_SWPMI_DISABLE(__HANDLE__) CLEAR_BIT((__HANDLE__)->Instance->CR, SWPMI_CR_SWPACT) |
| Disable the SWPMI peripheral. | |
| #define | __HAL_SWPMI_TRANSCEIVER_ENABLE(__HANDLE__) SET_BIT((__HANDLE__)->Instance->CR, SWPMI_CR_SWPEN) |
| Enable the SWPMI transceiver. | |
| #define | __HAL_SWPMI_TRANSCEIVER_DISABLE(__HANDLE__) CLEAR_BIT((__HANDLE__)->Instance->CR, SWPMI_CR_SWPEN) |
| Disable the SWPMI transceiver. | |
| #define | __HAL_SWPMI_GET_FLAG(__HANDLE__, __FLAG__) (READ_BIT((__HANDLE__)->Instance->ISR, (__FLAG__)) == (__FLAG__)) |
| Check whether the specified SWPMI flag is set or not. | |
| #define | __HAL_SWPMI_CLEAR_FLAG(__HANDLE__, __FLAG__) WRITE_REG((__HANDLE__)->Instance->ICR, (__FLAG__)) |
| Clear the specified SWPMI ISR flag. | |
| #define | __HAL_SWPMI_ENABLE_IT(__HANDLE__, __INTERRUPT__) SET_BIT((__HANDLE__)->Instance->IER, (__INTERRUPT__)) |
| Enable the specified SWPMI interrupt. | |
| #define | __HAL_SWPMI_DISABLE_IT(__HANDLE__, __INTERRUPT__) CLEAR_BIT((__HANDLE__)->Instance->IER, (__INTERRUPT__)) |
| Disable the specified SWPMI interrupt. | |
| #define | __HAL_SWPMI_GET_IT(__HANDLE__, __IT__) (READ_BIT((__HANDLE__)->Instance->ISR,(__IT__)) == (__IT__)) |
| Check whether the specified SWPMI interrupt has occurred or not. | |
| #define | __HAL_SWPMI_GET_IT_SOURCE(__HANDLE__, __IT__) ((READ_BIT((__HANDLE__)->Instance->IER, (__IT__)) == (__IT__)) ? SET : RESET) |
| Check whether the specified SWPMI interrupt source is enabled or not. | |
| #define | IS_SWPMI_VOLTAGE_CLASS(__CLASS__) |
| #define | IS_SWPMI_BITRATE_VALUE(__VALUE__) (((__VALUE__) <= 255U)) |
| #define | IS_SWPMI_TX_BUFFERING_MODE(__MODE__) |
| #define | IS_SWPMI_RX_BUFFERING_MODE(__MODE__) |
Enumerations | |
| enum | HAL_SWPMI_StateTypeDef { HAL_SWPMI_STATE_RESET = 0x00 , HAL_SWPMI_STATE_READY = 0x01 , HAL_SWPMI_STATE_BUSY = 0x02 , HAL_SWPMI_STATE_BUSY_TX = 0x12 , HAL_SWPMI_STATE_BUSY_RX = 0x22 , HAL_SWPMI_STATE_BUSY_TX_RX = 0x32 , HAL_SWPMI_STATE_TIMEOUT = 0x03 , HAL_SWPMI_STATE_ERROR = 0x04 } |
| HAL SWPMI State structures definition. More... | |
| HAL_StatusTypeDef | HAL_SWPMI_Init (SWPMI_HandleTypeDef *hswpmi) |
| HAL_StatusTypeDef | HAL_SWPMI_DeInit (SWPMI_HandleTypeDef *hswpmi) |
| void | HAL_SWPMI_MspInit (SWPMI_HandleTypeDef *hswpmi) |
| void | HAL_SWPMI_MspDeInit (SWPMI_HandleTypeDef *hswpmi) |
| HAL_StatusTypeDef | HAL_SWPMI_Transmit (SWPMI_HandleTypeDef *hswpmi, uint32_t *pData, uint16_t Size, uint32_t Timeout) |
| HAL_StatusTypeDef | HAL_SWPMI_Receive (SWPMI_HandleTypeDef *hswpmi, uint32_t *pData, uint16_t Size, uint32_t Timeout) |
| HAL_StatusTypeDef | HAL_SWPMI_Transmit_IT (SWPMI_HandleTypeDef *hswpmi, uint32_t *pData, uint16_t Size) |
| HAL_StatusTypeDef | HAL_SWPMI_Receive_IT (SWPMI_HandleTypeDef *hswpmi, uint32_t *pData, uint16_t Size) |
| HAL_StatusTypeDef | HAL_SWPMI_Transmit_DMA (SWPMI_HandleTypeDef *hswpmi, uint32_t *pData, uint16_t Size) |
| HAL_StatusTypeDef | HAL_SWPMI_Receive_DMA (SWPMI_HandleTypeDef *hswpmi, uint32_t *pData, uint16_t Size) |
| HAL_StatusTypeDef | HAL_SWPMI_DMAStop (SWPMI_HandleTypeDef *hswpmi) |
| HAL_StatusTypeDef | HAL_SWPMI_EnableLoopback (SWPMI_HandleTypeDef *hswpmi) |
| HAL_StatusTypeDef | HAL_SWPMI_DisableLoopback (SWPMI_HandleTypeDef *hswpmi) |
| void | HAL_SWPMI_IRQHandler (SWPMI_HandleTypeDef *hswpmi) |
| void | HAL_SWPMI_TxCpltCallback (SWPMI_HandleTypeDef *hswpmi) |
| void | HAL_SWPMI_TxHalfCpltCallback (SWPMI_HandleTypeDef *hswpmi) |
| void | HAL_SWPMI_RxCpltCallback (SWPMI_HandleTypeDef *hswpmi) |
| void | HAL_SWPMI_RxHalfCpltCallback (SWPMI_HandleTypeDef *hswpmi) |
| void | HAL_SWPMI_ErrorCallback (SWPMI_HandleTypeDef *hswpmi) |
| HAL_SWPMI_StateTypeDef | HAL_SWPMI_GetState (SWPMI_HandleTypeDef *hswpmi) |
| uint32_t | HAL_SWPMI_GetError (SWPMI_HandleTypeDef *hswpmi) |
