RTEMS 6.1-rc8
Header file of SDRAM HAL module. More...
#include "stm32h7xx_ll_fmc.h"Go to the source code of this file.
| struct | SDRAM_HandleTypeDef |
| SDRAM handle Structure definition. More... | |
| #define | __HAL_SDRAM_RESET_HANDLE_STATE(__HANDLE__) ((__HANDLE__)->State = HAL_SDRAM_STATE_RESET) |
| Reset SDRAM handle state. | |
Enumerations | |
| enum | HAL_SDRAM_StateTypeDef { HAL_SDRAM_STATE_RESET = 0x00U , HAL_SDRAM_STATE_READY = 0x01U , HAL_SDRAM_STATE_BUSY = 0x02U , HAL_SDRAM_STATE_ERROR = 0x03U , HAL_SDRAM_STATE_WRITE_PROTECTED = 0x04U , HAL_SDRAM_STATE_PRECHARGED = 0x05U } |
| HAL SDRAM State structure definition. More... | |
| HAL_StatusTypeDef | HAL_SDRAM_Init (SDRAM_HandleTypeDef *hsdram, FMC_SDRAM_TimingTypeDef *Timing) |
| HAL_StatusTypeDef | HAL_SDRAM_DeInit (SDRAM_HandleTypeDef *hsdram) |
| void | HAL_SDRAM_MspInit (SDRAM_HandleTypeDef *hsdram) |
| void | HAL_SDRAM_MspDeInit (SDRAM_HandleTypeDef *hsdram) |
| void | HAL_SDRAM_IRQHandler (SDRAM_HandleTypeDef *hsdram) |
| void | HAL_SDRAM_RefreshErrorCallback (SDRAM_HandleTypeDef *hsdram) |
| void | HAL_SDRAM_DMA_XferCpltCallback (MDMA_HandleTypeDef *hmdma) |
| void | HAL_SDRAM_DMA_XferErrorCallback (MDMA_HandleTypeDef *hmdma) |
| HAL_StatusTypeDef | HAL_SDRAM_Read_8b (SDRAM_HandleTypeDef *hsdram, uint32_t *pAddress, uint8_t *pDstBuffer, uint32_t BufferSize) |
| HAL_StatusTypeDef | HAL_SDRAM_Write_8b (SDRAM_HandleTypeDef *hsdram, uint32_t *pAddress, uint8_t *pSrcBuffer, uint32_t BufferSize) |
| HAL_StatusTypeDef | HAL_SDRAM_Read_16b (SDRAM_HandleTypeDef *hsdram, uint32_t *pAddress, uint16_t *pDstBuffer, uint32_t BufferSize) |
| HAL_StatusTypeDef | HAL_SDRAM_Write_16b (SDRAM_HandleTypeDef *hsdram, uint32_t *pAddress, uint16_t *pSrcBuffer, uint32_t BufferSize) |
| HAL_StatusTypeDef | HAL_SDRAM_Read_32b (SDRAM_HandleTypeDef *hsdram, uint32_t *pAddress, uint32_t *pDstBuffer, uint32_t BufferSize) |
| HAL_StatusTypeDef | HAL_SDRAM_Write_32b (SDRAM_HandleTypeDef *hsdram, uint32_t *pAddress, uint32_t *pSrcBuffer, uint32_t BufferSize) |
| HAL_StatusTypeDef | HAL_SDRAM_Read_DMA (SDRAM_HandleTypeDef *hsdram, uint32_t *pAddress, uint32_t *pDstBuffer, uint32_t BufferSize) |
| HAL_StatusTypeDef | HAL_SDRAM_Write_DMA (SDRAM_HandleTypeDef *hsdram, uint32_t *pAddress, uint32_t *pSrcBuffer, uint32_t BufferSize) |
| HAL_StatusTypeDef | HAL_SDRAM_WriteProtection_Enable (SDRAM_HandleTypeDef *hsdram) |
| HAL_StatusTypeDef | HAL_SDRAM_WriteProtection_Disable (SDRAM_HandleTypeDef *hsdram) |
| HAL_StatusTypeDef | HAL_SDRAM_SendCommand (SDRAM_HandleTypeDef *hsdram, FMC_SDRAM_CommandTypeDef *Command, uint32_t Timeout) |
| HAL_StatusTypeDef | HAL_SDRAM_ProgramRefreshRate (SDRAM_HandleTypeDef *hsdram, uint32_t RefreshRate) |
| HAL_StatusTypeDef | HAL_SDRAM_SetAutoRefreshNumber (SDRAM_HandleTypeDef *hsdram, uint32_t AutoRefreshNumber) |
| uint32_t | HAL_SDRAM_GetModeStatus (SDRAM_HandleTypeDef *hsdram) |
| HAL_SDRAM_StateTypeDef | HAL_SDRAM_GetState (SDRAM_HandleTypeDef *hsdram) |
