RTEMS 6.1-rc8
Header file of COMP HAL module. More...
#include "stm32h7xx_hal_def.h"Go to the source code of this file.
| struct | COMP_InitTypeDef |
| COMP Init structure definition More... | |
| struct | COMP_HandleTypeDef |
| COMP Handle Structure definition. More... | |
| #define | COMP_STATE_BITFIELD_LOCK ((uint32_t)0x10) |
| HAL COMP state machine: HAL COMP states definition. | |
| #define | HAL_COMP_ERROR_NONE (0x00U) |
| #define | COMP_WINDOWMODE_DISABLE ((uint32_t)0x00000000) |
| #define | COMP_WINDOWMODE_COMP1_INPUT_PLUS_COMMON (COMP_CFGRx_WINMODE) |
| #define | COMP_POWERMODE_HIGHSPEED ((uint32_t)0x00000000) |
| #define | COMP_POWERMODE_MEDIUMSPEED (COMP_CFGRx_PWRMODE_0) |
| #define | COMP_POWERMODE_ULTRALOWPOWER (COMP_CFGRx_PWRMODE) |
| #define | COMP_INPUT_PLUS_IO1 ((uint32_t)0x00000000) |
| #define | COMP_INPUT_PLUS_IO2 (COMP_CFGRx_INPSEL) |
| #define | COMP_INPUT_MINUS_1_4VREFINT ( COMP_CFGRx_SCALEN | COMP_CFGRx_BRGEN) |
| #define | COMP_INPUT_MINUS_1_2VREFINT ( COMP_CFGRx_INMSEL_0 | COMP_CFGRx_SCALEN | COMP_CFGRx_BRGEN) |
| #define | COMP_INPUT_MINUS_3_4VREFINT ( COMP_CFGRx_INMSEL_1 | COMP_CFGRx_SCALEN | COMP_CFGRx_BRGEN) |
| #define | COMP_INPUT_MINUS_VREFINT ( COMP_CFGRx_INMSEL_1 | COMP_CFGRx_INMSEL_0 | COMP_CFGRx_SCALEN ) |
| #define | COMP_INPUT_MINUS_DAC1_CH1 ( COMP_CFGRx_INMSEL_2 ) |
| #define | COMP_INPUT_MINUS_DAC1_CH2 ( COMP_CFGRx_INMSEL_2 | COMP_CFGRx_INMSEL_0 ) |
| #define | COMP_INPUT_MINUS_IO1 ( COMP_CFGRx_INMSEL_2 | COMP_CFGRx_INMSEL_1 ) |
| #define | COMP_INPUT_MINUS_IO2 ( COMP_CFGRx_INMSEL_2 | COMP_CFGRx_INMSEL_1 | COMP_CFGRx_INMSEL_0 ) |
| #define | COMP_HYSTERESIS_NONE ((uint32_t)0x00000000) |
| #define | COMP_HYSTERESIS_LOW (COMP_CFGRx_HYST_0) |
| #define | COMP_HYSTERESIS_MEDIUM (COMP_CFGRx_HYST_1) |
| #define | COMP_HYSTERESIS_HIGH (COMP_CFGRx_HYST) |
| #define | COMP_OUTPUTPOL_NONINVERTED ((uint32_t)0x00000000) |
| #define | COMP_OUTPUTPOL_INVERTED (COMP_CFGRx_POLARITY) |
| #define | COMP_BLANKINGSRC_NONE ((uint32_t)0x00000000) |
| #define | COMP_BLANKINGSRC_TIM1_OC5 (COMP_CFGRx_BLANKING_0) |
| #define | COMP_BLANKINGSRC_TIM2_OC3 (COMP_CFGRx_BLANKING_1) |
| #define | COMP_BLANKINGSRC_TIM3_OC3 (COMP_CFGRx_BLANKING_0 |COMP_CFGRx_BLANKING_1) |
| #define | COMP_BLANKINGSRC_TIM3_OC4 (COMP_CFGRx_BLANKING_2) |
| #define | COMP_BLANKINGSRC_TIM8_OC5 (COMP_CFGRx_BLANKING_2|COMP_CFGRx_BLANKING_0) |
| #define | COMP_BLANKINGSRC_TIM15_OC1 (COMP_CFGRx_BLANKING_2|COMP_CFGRx_BLANKING_1) |
| #define | COMP_OUTPUT_LEVEL_LOW ((uint32_t)0x00000000) |
| #define | COMP_OUTPUT_LEVEL_HIGH ((uint32_t)0x00000001) |
| #define | COMP_TRIGGERMODE_NONE ((uint32_t)0x00000000) |
| #define | COMP_TRIGGERMODE_IT_RISING (COMP_EXTI_IT | COMP_EXTI_RISING) |
| #define | COMP_TRIGGERMODE_IT_FALLING (COMP_EXTI_IT | COMP_EXTI_FALLING) |
| #define | COMP_TRIGGERMODE_IT_RISING_FALLING (COMP_EXTI_IT | COMP_EXTI_RISING | COMP_EXTI_FALLING) |
| #define | COMP_TRIGGERMODE_EVENT_RISING (COMP_EXTI_EVENT | COMP_EXTI_RISING) |
| #define | COMP_TRIGGERMODE_EVENT_FALLING (COMP_EXTI_EVENT | COMP_EXTI_FALLING) |
| #define | COMP_TRIGGERMODE_EVENT_RISING_FALLING (COMP_EXTI_EVENT | COMP_EXTI_RISING | COMP_EXTI_FALLING) |
| #define | COMP_FLAG_C1I COMP_SR_C1IF |
| #define | COMP_FLAG_C2I COMP_SR_C2IF |
| #define | COMP_FLAG_LOCK COMP_CFGRx_LOCK |
| #define | COMP_CLEAR_C1IF COMP_ICFR_C1IF |
| #define | COMP_CLEAR_C2IF COMP_ICFR_C2IF |
| #define | COMP_IT_EN COMP_CFGRx_ITEN |
| #define | __HAL_COMP_RESET_HANDLE_STATE(__HANDLE__) ((__HANDLE__)->State = HAL_COMP_STATE_RESET) |
| Reset COMP handle state. | |
| #define | COMP_CLEAR_ERRORCODE(__HANDLE__) ((__HANDLE__)->ErrorCode = HAL_COMP_ERROR_NONE) |
| Clear COMP error code (set it to no error code "HAL_COMP_ERROR_NONE"). | |
| #define | __HAL_COMP_ENABLE(__HANDLE__) SET_BIT((__HANDLE__)->Instance->CFGR, COMP_CFGRx_EN) |
| Enable the specified comparator. | |
| #define | __HAL_COMP_DISABLE(__HANDLE__) CLEAR_BIT((__HANDLE__)->Instance->CFGR, COMP_CFGRx_EN) |
| Disable the specified comparator. | |
| #define | __HAL_COMP_LOCK(__HANDLE__) SET_BIT((__HANDLE__)->Instance->CFGR, COMP_CFGRx_LOCK) |
| Lock the specified comparator configuration. | |
| #define | __HAL_COMP_IS_LOCKED(__HANDLE__) (READ_BIT((__HANDLE__)->Instance->CFGR, COMP_CFGRx_LOCK) == COMP_CFGRx_LOCK) |
| Check whether the specified comparator is locked. | |
| #define | __HAL_COMP_COMP1_EXTI_ENABLE_RISING_EDGE() SET_BIT(EXTI->RTSR1, COMP_EXTI_LINE_COMP1) |
| Enable the COMP1 EXTI line rising edge trigger. | |
| #define | __HAL_COMP_COMP1_EXTI_DISABLE_RISING_EDGE() CLEAR_BIT(EXTI->RTSR1, COMP_EXTI_LINE_COMP1) |
| Disable the COMP1 EXTI line rising edge trigger. | |
| #define | __HAL_COMP_COMP1_EXTI_ENABLE_FALLING_EDGE() SET_BIT(EXTI->FTSR1, COMP_EXTI_LINE_COMP1) |
| Enable the COMP1 EXTI line falling edge trigger. | |
| #define | __HAL_COMP_COMP1_EXTI_DISABLE_FALLING_EDGE() CLEAR_BIT(EXTI->FTSR1, COMP_EXTI_LINE_COMP1) |
| Disable the COMP1 EXTI line falling edge trigger. | |
| #define | __HAL_COMP_COMP1_EXTI_ENABLE_RISING_FALLING_EDGE() |
| Enable the COMP1 EXTI line rising & falling edge trigger. | |
| #define | __HAL_COMP_COMP1_EXTI_DISABLE_RISING_FALLING_EDGE() |
| Disable the COMP1 EXTI line rising & falling edge trigger. | |
| #define | __HAL_COMP_COMP1_EXTI_ENABLE_IT() SET_BIT(EXTI_D1->IMR1, COMP_EXTI_LINE_COMP1) |
| Enable the COMP1 EXTI line in interrupt mode. | |
| #define | __HAL_COMP_COMP1_EXTI_DISABLE_IT() CLEAR_BIT(EXTI_D1->IMR1, COMP_EXTI_LINE_COMP1) |
| Disable the COMP1 EXTI line in interrupt mode. | |
| #define | __HAL_COMP_COMP1_EXTI_ENABLE_EVENT() SET_BIT(EXTI_D1->EMR1, COMP_EXTI_LINE_COMP1) |
| Enable the COMP1 EXTI Line in event mode. | |
| #define | __HAL_COMP_COMP1_EXTI_DISABLE_EVENT() CLEAR_BIT(EXTI_D1->EMR1, COMP_EXTI_LINE_COMP1) |
| Disable the COMP1 EXTI Line in event mode. | |
| #define | __HAL_COMP_COMP1_EXTI_GET_FLAG() READ_BIT(EXTI_D1->PR1, COMP_EXTI_LINE_COMP1) |
| Check whether the COMP1 EXTI line flag is set or not. | |
| #define | __HAL_COMP_COMP1_EXTI_CLEAR_FLAG() WRITE_REG(EXTI_D1->PR1, COMP_EXTI_LINE_COMP1) |
| Clear the COMP1 EXTI flag. | |
| #define | __HAL_COMP_COMP1_EXTI_GENERATE_SWIT() SET_BIT(EXTI->SWIER1, COMP_EXTI_LINE_COMP1) |
| Generate a software interrupt on the COMP1 EXTI line. | |
| #define | __HAL_COMP_COMP1_EXTID3_ENABLE_EVENT() SET_BIT(EXTI->D3PMR1, COMP_EXTI_LINE_COMP1) |
| Enable the COMP1 D3 EXTI Line in event mode. | |
| #define | __HAL_COMP_COMP1_EXTID3_DISABLE_EVENT() CLEAR_BIT(EXTI->D3PMR1, COMP_EXTI_LINE_COMP1) |
| Disable the COMP1 D3 EXTI Line in event mode. | |
| #define | __HAL_COMP_COMP2_EXTI_ENABLE_RISING_EDGE() SET_BIT(EXTI->RTSR1, COMP_EXTI_LINE_COMP2) |
| Enable the COMP2 EXTI line rising edge trigger. | |
| #define | __HAL_COMP_COMP2_EXTI_DISABLE_RISING_EDGE() CLEAR_BIT(EXTI->RTSR1, COMP_EXTI_LINE_COMP2) |
| Disable the COMP2 EXTI line rising edge trigger. | |
| #define | __HAL_COMP_COMP2_EXTI_ENABLE_FALLING_EDGE() SET_BIT(EXTI->FTSR1, COMP_EXTI_LINE_COMP2) |
| Enable the COMP2 EXTI line falling edge trigger. | |
| #define | __HAL_COMP_COMP2_EXTI_DISABLE_FALLING_EDGE() CLEAR_BIT(EXTI->FTSR1, COMP_EXTI_LINE_COMP2) |
| Disable the COMP2 EXTI line falling edge trigger. | |
| #define | __HAL_COMP_COMP2_EXTI_ENABLE_RISING_FALLING_EDGE() |
| Enable the COMP2 EXTI line rising & falling edge trigger. | |
| #define | __HAL_COMP_COMP2_EXTI_DISABLE_RISING_FALLING_EDGE() |
| Disable the COMP2 EXTI line rising & falling edge trigger. | |
| #define | __HAL_COMP_COMP2_EXTI_ENABLE_IT() SET_BIT(EXTI_D1->IMR1, COMP_EXTI_LINE_COMP2) |
| Enable the COMP2 EXTI line. | |
| #define | __HAL_COMP_COMP2_EXTI_DISABLE_IT() CLEAR_BIT(EXTI_D1->IMR1, COMP_EXTI_LINE_COMP2) |
| Disable the COMP2 EXTI line. | |
| #define | __HAL_COMP_COMP2_EXTI_ENABLE_EVENT() SET_BIT(EXTI_D1->EMR1, COMP_EXTI_LINE_COMP2) |
| Enable the COMP2 EXTI Line in event mode. | |
| #define | __HAL_COMP_COMP2_EXTI_DISABLE_EVENT() CLEAR_BIT(EXTI_D1->EMR1, COMP_EXTI_LINE_COMP2) |
| Disable the COMP2 EXTI Line in event mode. | |
| #define | __HAL_COMP_COMP2_EXTI_GET_FLAG() READ_BIT(EXTI_D1->PR1, COMP_EXTI_LINE_COMP2) |
| Check whether the COMP2 EXTI line flag is set or not. | |
| #define | __HAL_COMP_COMP2_EXTI_CLEAR_FLAG() WRITE_REG(EXTI_D1->PR1, COMP_EXTI_LINE_COMP2) |
| Clear the the COMP2 EXTI flag. | |
| #define | __HAL_COMP_COMP2_EXTID3_ENABLE_EVENT() SET_BIT(EXTI->D3PMR1, COMP_EXTI_LINE_COMP2) |
| Enable the COMP2 D3 EXTI Line in event mode. | |
| #define | __HAL_COMP_COMP2_EXTID3_DISABLE_EVENT() CLEAR_BIT(EXTI->D3PMR1, COMP_EXTI_LINE_COMP2) |
| Disable the COMP2 D3 EXTI Line in event mode. | |
| #define | __HAL_COMP_COMP2_EXTI_GENERATE_SWIT() SET_BIT(EXTI->SWIER1, COMP_EXTI_LINE_COMP2) |
| Generate a software interrupt on the COMP2 EXTI line. | |
| #define | __HAL_COMP_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__) ((((__HANDLE__)->Instance->CFGR & (__INTERRUPT__)) == (__INTERRUPT__)) ? SET : RESET) |
| Checks if the specified COMP interrupt source is enabled or disabled. | |
| #define | __HAL_COMP_GET_FLAG(__FLAG__) ((COMP12->SR & (__FLAG__)) == (__FLAG__)) |
| Checks whether the specified COMP flag is set or not. | |
| #define | __HAL_COMP_CLEAR_FLAG(__FLAG__) (COMP12->ICFR = (__FLAG__)) |
| Clears the specified COMP pending flag. | |
| #define | __HAL_COMP_CLEAR_C1IFLAG() __HAL_COMP_CLEAR_FLAG( COMP_CLEAR_C1IF) |
| Clear the COMP C1I flag. | |
| #define | __HAL_COMP_CLEAR_C2IFLAG() __HAL_COMP_CLEAR_FLAG( COMP_CLEAR_C2IF) |
| Clear the COMP C2I flag. | |
| #define | __HAL_COMP_ENABLE_IT(__HANDLE__, __INTERRUPT__) ( ((__HANDLE__)->Instance->CFGR) |= (__INTERRUPT__) ) |
| Enable the specified COMP interrupt. | |
| #define | __HAL_COMP_DISABLE_IT(__HANDLE__, __INTERRUPT__) (((__HANDLE__)->Instance->CFGR) &= ~(__INTERRUPT__)) |
| Disable the specified COMP interrupt. | |
| #define | __HAL_COMP_ENABLE_OR(__AF__) SET_BIT(COMP12->OR, (__AF__)) |
| Enable the specified bit in the Option register. | |
| #define | __HAL_COMP_DISABLE_OR(__AF__) CLEAR_BIT(COMP12->OR, (__AF__)) |
| Disable the specified bit in the Option register. | |
| #define | COMP_EXTI_LINE_COMP1 (EXTI_IMR1_IM20) |
| #define | COMP_EXTI_LINE_COMP2 (EXTI_IMR1_IM21) |
| #define | COMP_EXTI_IT ((uint32_t) 0x01) |
| #define | COMP_EXTI_EVENT ((uint32_t) 0x02) |
| #define | COMP_EXTI_RISING ((uint32_t) 0x10) |
| #define | COMP_EXTI_FALLING ((uint32_t) 0x20) |
| #define | COMP_GET_EXTI_LINE(__INSTANCE__) |
| Get the specified EXTI line for a comparator instance. | |
| #define | IS_COMP_WINDOWMODE(__WINDOWMODE__) |
| #define | IS_COMP_POWERMODE(__POWERMODE__) |
| #define | IS_COMP_INPUT_PLUS(__COMP_INSTANCE__, __INPUT_PLUS__) |
| #define | IS_COMP_INPUT_MINUS(__COMP_INSTANCE__, __INPUT_MINUS__) |
| #define | IS_COMP_HYSTERESIS(__HYSTERESIS__) |
| #define | IS_COMP_OUTPUTPOL(__POL__) |
| #define | IS_COMP_BLANKINGSRCE(__SOURCE__) |
| #define | IS_COMP_TRIGGERMODE(__MODE__) |
| #define | IS_COMP_OUTPUT_LEVEL(__OUTPUT_LEVEL__) |
Enumerations | |
| enum | HAL_COMP_StateTypeDef { HAL_COMP_STATE_RESET = 0x00 , HAL_COMP_STATE_RESET_LOCKED = (HAL_COMP_STATE_RESET | COMP_STATE_BITFIELD_LOCK) , HAL_COMP_STATE_READY = 0x01 , HAL_COMP_STATE_READY_LOCKED = (HAL_COMP_STATE_READY | COMP_STATE_BITFIELD_LOCK) , HAL_COMP_STATE_BUSY = 0x02 , HAL_COMP_STATE_BUSY_LOCKED = (HAL_COMP_STATE_BUSY | COMP_STATE_BITFIELD_LOCK) } |
| HAL_StatusTypeDef | HAL_COMP_Init (COMP_HandleTypeDef *hcomp) |
| HAL_StatusTypeDef | HAL_COMP_DeInit (COMP_HandleTypeDef *hcomp) |
| void | HAL_COMP_MspInit (COMP_HandleTypeDef *hcomp) |
| void | HAL_COMP_MspDeInit (COMP_HandleTypeDef *hcomp) |
| HAL_StatusTypeDef | HAL_COMP_Start (COMP_HandleTypeDef *hcomp) |
| HAL_StatusTypeDef | HAL_COMP_Stop (COMP_HandleTypeDef *hcomp) |
| HAL_StatusTypeDef | HAL_COMP_Start_IT (COMP_HandleTypeDef *hcomp) |
| HAL_StatusTypeDef | HAL_COMP_Stop_IT (COMP_HandleTypeDef *hcomp) |
| void | HAL_COMP_IRQHandler (COMP_HandleTypeDef *hcomp) |
| HAL_StatusTypeDef | HAL_COMP_Lock (COMP_HandleTypeDef *hcomp) |
| uint32_t | HAL_COMP_GetOutputLevel (COMP_HandleTypeDef *hcomp) |
| void | HAL_COMP_TriggerCallback (COMP_HandleTypeDef *hcomp) |
| HAL_COMP_StateTypeDef | HAL_COMP_GetState (COMP_HandleTypeDef *hcomp) |
| uint32_t | HAL_COMP_GetError (COMP_HandleTypeDef *hcomp) |
