RTEMS 6.1-rc8
CMSIS STM32H753xx Device Peripheral Access Layer Header File. More...
| struct | ADC_TypeDef |
| Analog to Digital Converter. More... | |
| struct | ADC_Common_TypeDef |
| struct | VREFBUF_TypeDef |
| VREFBUF. More... | |
| struct | FDCAN_GlobalTypeDef |
| FD Controller Area Network. More... | |
| struct | TTCAN_TypeDef |
| TTFD Controller Area Network. More... | |
| struct | FDCAN_ClockCalibrationUnit_TypeDef |
| struct | CEC_TypeDef |
| Consumer Electronics Control. More... | |
| struct | CRC_TypeDef |
| CRC calculation unit. More... | |
| struct | CRS_TypeDef |
| Clock Recovery System. More... | |
| struct | DAC_TypeDef |
| Digital to Analog Converter. More... | |
| struct | DFSDM_Filter_TypeDef |
| DFSDM module registers. More... | |
| struct | DFSDM_Channel_TypeDef |
| DFSDM channel configuration registers. More... | |
| struct | DBGMCU_TypeDef |
| Debug MCU. More... | |
| struct | DCMI_TypeDef |
| DCMI. More... | |
| struct | DMA_Stream_TypeDef |
| DMA Controller. More... | |
| struct | DMA_TypeDef |
| struct | BDMA_Channel_TypeDef |
| struct | BDMA_TypeDef |
| struct | DMAMUX_Channel_TypeDef |
| struct | DMAMUX_ChannelStatus_TypeDef |
| struct | DMAMUX_RequestGen_TypeDef |
| struct | DMAMUX_RequestGenStatus_TypeDef |
| struct | MDMA_TypeDef |
| MDMA Controller. More... | |
| struct | MDMA_Channel_TypeDef |
| struct | DMA2D_TypeDef |
| DMA2D Controller. More... | |
| struct | ETH_TypeDef |
| Ethernet MAC. More... | |
| struct | EXTI_TypeDef |
| External Interrupt/Event Controller. More... | |
| struct | EXTI_Core_TypeDef |
| This structure registers corresponds to EXTI_Typdef CPU1/CPU2 registers subset (IMRx, EMRx and PRx), allowing to define EXTI_D1/EXTI_D2 with rapid/common access to these IMRx, EMRx, PRx registers for CPU1 and CPU2. Note that EXTI_D1 and EXTI_D2 bases addresses are calculated to point to CPUx first register: IMR1 in case of EXTI_D1 that is addressing CPU1 (Cortex-M7) C2IMR1 in case of EXTI_D2 that is addressing CPU2 (Cortex-M4) Note: EXTI_D2 and corresponding C2IMRx, C2EMRx and C2PRx registers are available for Dual Core devices only. More... | |
| struct | FLASH_TypeDef |
| FLASH Registers. More... | |
| struct | FMC_Bank1_TypeDef |
| Flexible Memory Controller. More... | |
| struct | FMC_Bank1E_TypeDef |
| Flexible Memory Controller Bank1E. More... | |
| struct | FMC_Bank2_TypeDef |
| Flexible Memory Controller Bank2. More... | |
| struct | FMC_Bank3_TypeDef |
| Flexible Memory Controller Bank3. More... | |
| struct | FMC_Bank5_6_TypeDef |
| Flexible Memory Controller Bank5 and 6. More... | |
| struct | GPIO_TypeDef |
| General Purpose I/O. More... | |
| struct | OPAMP_TypeDef |
| Operational Amplifier (OPAMP) More... | |
| struct | SYSCFG_TypeDef |
| System configuration controller. More... | |
| struct | I2C_TypeDef |
| Inter-integrated Circuit Interface. More... | |
| struct | IWDG_TypeDef |
| Independent WATCHDOG. More... | |
| struct | JPEG_TypeDef |
| JPEG Codec. More... | |
| struct | LTDC_TypeDef |
| LCD-TFT Display Controller. More... | |
| struct | LTDC_Layer_TypeDef |
| LCD-TFT Display layer x Controller. More... | |
| struct | PWR_TypeDef |
| Power Control. More... | |
| struct | RCC_TypeDef |
| Reset and Clock Control. More... | |
| struct | RTC_TypeDef |
| Real-Time Clock. More... | |
| struct | SAI_TypeDef |
| Serial Audio Interface. More... | |
| struct | SAI_Block_TypeDef |
| struct | SPDIFRX_TypeDef |
| SPDIF-RX Interface. More... | |
| struct | SDMMC_TypeDef |
| Secure digital input/output Interface. More... | |
| struct | DLYB_TypeDef |
| Delay Block DLYB. More... | |
| struct | HSEM_TypeDef |
| HW Semaphore HSEM. More... | |
| struct | HSEM_Common_TypeDef |
| struct | SPI_TypeDef |
| Serial Peripheral Interface. More... | |
| struct | QUADSPI_TypeDef |
| QUAD Serial Peripheral Interface. More... | |
| struct | TIM_TypeDef |
| TIM. More... | |
| struct | LPTIM_TypeDef |
| LPTIMIMER. More... | |
| struct | COMPOPT_TypeDef |
| Comparator. More... | |
| struct | COMP_TypeDef |
| struct | COMP_Common_TypeDef |
| struct | USART_TypeDef |
| Universal Synchronous Asynchronous Receiver Transmitter. More... | |
| struct | SWPMI_TypeDef |
| Single Wire Protocol Master Interface SPWMI. More... | |
| struct | WWDG_TypeDef |
| Window WATCHDOG. More... | |
| struct | RAMECC_MonitorTypeDef |
| RAM_ECC_Specific_Registers. More... | |
| struct | RAMECC_TypeDef |
| struct | CRYP_TypeDef |
| Crypto Processor. More... | |
| struct | HASH_TypeDef |
| HASH. More... | |
| struct | HASH_DIGEST_TypeDef |
| HASH_DIGEST. More... | |
| struct | HRTIM_Master_TypeDef |
| High resolution Timer (HRTIM) More... | |
| struct | HRTIM_Timerx_TypeDef |
| struct | HRTIM_Common_TypeDef |
| struct | HRTIM_TypeDef |
| struct | RNG_TypeDef |
| RNG. More... | |
| struct | MDIOS_TypeDef |
| MDIOS. More... | |
| struct | USB_OTG_GlobalTypeDef |
| USB_OTG_Core_Registers. More... | |
| struct | USB_OTG_DeviceTypeDef |
| USB_OTG_device_Registers. More... | |
| struct | USB_OTG_INEndpointTypeDef |
| USB_OTG_IN_Endpoint-Specific_Register. More... | |
| struct | USB_OTG_OUTEndpointTypeDef |
| USB_OTG_OUT_Endpoint-Specific_Registers. More... | |
| struct | USB_OTG_HostTypeDef |
| USB_OTG_Host_Mode_Register_Structures. More... | |
| struct | USB_OTG_HostChannelTypeDef |
| USB_OTG_Host_Channel_Specific_Registers. More... | |
| struct | GPV_TypeDef |
| Global Programmer View. More... | |
| #define | __CM7_REV 0x0101U |
| Configuration of the Cortex-M7 Processor and Core Peripherals. | |
| #define | __MPU_PRESENT 1U |
| #define | __NVIC_PRIO_BITS 4U |
| #define | __Vendor_SysTickConfig 0U |
| #define | __FPU_PRESENT 1U |
| #define | __ICACHE_PRESENT 1U |
| #define | __DCACHE_PRESENT 1U |
| #define | D1_ITCMRAM_BASE (0x00000000UL) |
| #define | D1_ITCMICP_BASE (0x00100000UL) |
| #define | D1_DTCMRAM_BASE (0x20000000UL) |
| #define | D1_AXIFLASH_BASE (0x08000000UL) |
| #define | D1_AXIICP_BASE (0x1FF00000UL) |
| #define | D1_AXISRAM_BASE (0x24000000UL) |
| #define | D2_AXISRAM_BASE (0x10000000UL) |
| #define | D2_AHBSRAM_BASE (0x30000000UL) |
| #define | D3_BKPSRAM_BASE (0x38800000UL) |
| #define | D3_SRAM_BASE (0x38000000UL) |
| #define | PERIPH_BASE (0x40000000UL) |
| #define | QSPI_BASE (0x90000000UL) |
| #define | FLASH_BANK1_BASE (0x08000000UL) |
| #define | FLASH_BANK2_BASE (0x08100000UL) |
| #define | FLASH_END (0x081FFFFFUL) |
| #define | FLASH_BASE FLASH_BANK1_BASE |
| #define | UID_BASE (0x1FF1E800UL) |
| #define | FLASHSIZE_BASE (0x1FF1E880UL) |
| #define | D2_APB1PERIPH_BASE PERIPH_BASE |
| #define | D2_APB2PERIPH_BASE (PERIPH_BASE + 0x00010000UL) |
| #define | D2_AHB1PERIPH_BASE (PERIPH_BASE + 0x00020000UL) |
| #define | D2_AHB2PERIPH_BASE (PERIPH_BASE + 0x08020000UL) |
| #define | D1_APB1PERIPH_BASE (PERIPH_BASE + 0x10000000UL) |
| #define | D1_AHB1PERIPH_BASE (PERIPH_BASE + 0x12000000UL) |
| #define | D3_APB1PERIPH_BASE (PERIPH_BASE + 0x18000000UL) |
| #define | D3_AHB1PERIPH_BASE (PERIPH_BASE + 0x18020000UL) |
| #define | APB1PERIPH_BASE PERIPH_BASE |
| #define | APB2PERIPH_BASE (PERIPH_BASE + 0x00010000UL) |
| #define | AHB1PERIPH_BASE (PERIPH_BASE + 0x00020000UL) |
| #define | AHB2PERIPH_BASE (PERIPH_BASE + 0x08000000UL) |
| #define | MDMA_BASE (D1_AHB1PERIPH_BASE + 0x0000UL) |
| #define | DMA2D_BASE (D1_AHB1PERIPH_BASE + 0x1000UL) |
| #define | JPGDEC_BASE (D1_AHB1PERIPH_BASE + 0x3000UL) |
| #define | FLASH_R_BASE (D1_AHB1PERIPH_BASE + 0x2000UL) |
| #define | FMC_R_BASE (D1_AHB1PERIPH_BASE + 0x4000UL) |
| #define | QSPI_R_BASE (D1_AHB1PERIPH_BASE + 0x5000UL) |
| #define | DLYB_QSPI_BASE (D1_AHB1PERIPH_BASE + 0x6000UL) |
| #define | SDMMC1_BASE (D1_AHB1PERIPH_BASE + 0x7000UL) |
| #define | DLYB_SDMMC1_BASE (D1_AHB1PERIPH_BASE + 0x8000UL) |
| #define | RAMECC1_BASE (D1_AHB1PERIPH_BASE + 0x9000UL) |
| #define | DMA1_BASE (D2_AHB1PERIPH_BASE + 0x0000UL) |
| #define | DMA2_BASE (D2_AHB1PERIPH_BASE + 0x0400UL) |
| #define | DMAMUX1_BASE (D2_AHB1PERIPH_BASE + 0x0800UL) |
| #define | ADC1_BASE (D2_AHB1PERIPH_BASE + 0x2000UL) |
| #define | ADC2_BASE (D2_AHB1PERIPH_BASE + 0x2100UL) |
| #define | ADC12_COMMON_BASE (D2_AHB1PERIPH_BASE + 0x2300UL) |
| #define | ETH_BASE (D2_AHB1PERIPH_BASE + 0x8000UL) |
| #define | ETH_MAC_BASE (ETH_BASE) |
| #define | USB1_OTG_HS_PERIPH_BASE (0x40040000UL) |
| #define | USB2_OTG_FS_PERIPH_BASE (0x40080000UL) |
| #define | USB_OTG_GLOBAL_BASE (0x000UL) |
| #define | USB_OTG_DEVICE_BASE (0x800UL) |
| #define | USB_OTG_IN_ENDPOINT_BASE (0x900UL) |
| #define | USB_OTG_OUT_ENDPOINT_BASE (0xB00UL) |
| #define | USB_OTG_EP_REG_SIZE (0x20UL) |
| #define | USB_OTG_HOST_BASE (0x400UL) |
| #define | USB_OTG_HOST_PORT_BASE (0x440UL) |
| #define | USB_OTG_HOST_CHANNEL_BASE (0x500UL) |
| #define | USB_OTG_HOST_CHANNEL_SIZE (0x20UL) |
| #define | USB_OTG_PCGCCTL_BASE (0xE00UL) |
| #define | USB_OTG_FIFO_BASE (0x1000UL) |
| #define | USB_OTG_FIFO_SIZE (0x1000UL) |
| #define | DCMI_BASE (D2_AHB2PERIPH_BASE + 0x0000UL) |
| #define | CRYP_BASE (D2_AHB2PERIPH_BASE + 0x1000UL) |
| #define | HASH_BASE (D2_AHB2PERIPH_BASE + 0x1400UL) |
| #define | HASH_DIGEST_BASE (D2_AHB2PERIPH_BASE + 0x1710UL) |
| #define | RNG_BASE (D2_AHB2PERIPH_BASE + 0x1800UL) |
| #define | SDMMC2_BASE (D2_AHB2PERIPH_BASE + 0x2400UL) |
| #define | DLYB_SDMMC2_BASE (D2_AHB2PERIPH_BASE + 0x2800UL) |
| #define | RAMECC2_BASE (D2_AHB2PERIPH_BASE + 0x3000UL) |
| #define | GPIOA_BASE (D3_AHB1PERIPH_BASE + 0x0000UL) |
| #define | GPIOB_BASE (D3_AHB1PERIPH_BASE + 0x0400UL) |
| #define | GPIOC_BASE (D3_AHB1PERIPH_BASE + 0x0800UL) |
| #define | GPIOD_BASE (D3_AHB1PERIPH_BASE + 0x0C00UL) |
| #define | GPIOE_BASE (D3_AHB1PERIPH_BASE + 0x1000UL) |
| #define | GPIOF_BASE (D3_AHB1PERIPH_BASE + 0x1400UL) |
| #define | GPIOG_BASE (D3_AHB1PERIPH_BASE + 0x1800UL) |
| #define | GPIOH_BASE (D3_AHB1PERIPH_BASE + 0x1C00UL) |
| #define | GPIOI_BASE (D3_AHB1PERIPH_BASE + 0x2000UL) |
| #define | GPIOJ_BASE (D3_AHB1PERIPH_BASE + 0x2400UL) |
| #define | GPIOK_BASE (D3_AHB1PERIPH_BASE + 0x2800UL) |
| #define | RCC_BASE (D3_AHB1PERIPH_BASE + 0x4400UL) |
| #define | PWR_BASE (D3_AHB1PERIPH_BASE + 0x4800UL) |
| #define | CRC_BASE (D3_AHB1PERIPH_BASE + 0x4C00UL) |
| #define | BDMA_BASE (D3_AHB1PERIPH_BASE + 0x5400UL) |
| #define | DMAMUX2_BASE (D3_AHB1PERIPH_BASE + 0x5800UL) |
| #define | ADC3_BASE (D3_AHB1PERIPH_BASE + 0x6000UL) |
| #define | ADC3_COMMON_BASE (D3_AHB1PERIPH_BASE + 0x6300UL) |
| #define | HSEM_BASE (D3_AHB1PERIPH_BASE + 0x6400UL) |
| #define | RAMECC3_BASE (D3_AHB1PERIPH_BASE + 0x7000UL) |
| #define | LTDC_BASE (D1_APB1PERIPH_BASE + 0x1000UL) |
| #define | LTDC_Layer1_BASE (LTDC_BASE + 0x84UL) |
| #define | LTDC_Layer2_BASE (LTDC_BASE + 0x104UL) |
| #define | WWDG1_BASE (D1_APB1PERIPH_BASE + 0x3000UL) |
| #define | TIM2_BASE (D2_APB1PERIPH_BASE + 0x0000UL) |
| #define | TIM3_BASE (D2_APB1PERIPH_BASE + 0x0400UL) |
| #define | TIM4_BASE (D2_APB1PERIPH_BASE + 0x0800UL) |
| #define | TIM5_BASE (D2_APB1PERIPH_BASE + 0x0C00UL) |
| #define | TIM6_BASE (D2_APB1PERIPH_BASE + 0x1000UL) |
| #define | TIM7_BASE (D2_APB1PERIPH_BASE + 0x1400UL) |
| #define | TIM12_BASE (D2_APB1PERIPH_BASE + 0x1800UL) |
| #define | TIM13_BASE (D2_APB1PERIPH_BASE + 0x1C00UL) |
| #define | TIM14_BASE (D2_APB1PERIPH_BASE + 0x2000UL) |
| #define | LPTIM1_BASE (D2_APB1PERIPH_BASE + 0x2400UL) |
| #define | SPI2_BASE (D2_APB1PERIPH_BASE + 0x3800UL) |
| #define | SPI3_BASE (D2_APB1PERIPH_BASE + 0x3C00UL) |
| #define | SPDIFRX_BASE (D2_APB1PERIPH_BASE + 0x4000UL) |
| #define | USART2_BASE (D2_APB1PERIPH_BASE + 0x4400UL) |
| #define | USART3_BASE (D2_APB1PERIPH_BASE + 0x4800UL) |
| #define | UART4_BASE (D2_APB1PERIPH_BASE + 0x4C00UL) |
| #define | UART5_BASE (D2_APB1PERIPH_BASE + 0x5000UL) |
| #define | I2C1_BASE (D2_APB1PERIPH_BASE + 0x5400UL) |
| #define | I2C2_BASE (D2_APB1PERIPH_BASE + 0x5800UL) |
| #define | I2C3_BASE (D2_APB1PERIPH_BASE + 0x5C00UL) |
| #define | CEC_BASE (D2_APB1PERIPH_BASE + 0x6C00UL) |
| #define | DAC1_BASE (D2_APB1PERIPH_BASE + 0x7400UL) |
| #define | UART7_BASE (D2_APB1PERIPH_BASE + 0x7800UL) |
| #define | UART8_BASE (D2_APB1PERIPH_BASE + 0x7C00UL) |
| #define | CRS_BASE (D2_APB1PERIPH_BASE + 0x8400UL) |
| #define | SWPMI1_BASE (D2_APB1PERIPH_BASE + 0x8800UL) |
| #define | OPAMP_BASE (D2_APB1PERIPH_BASE + 0x9000UL) |
| #define | OPAMP1_BASE (D2_APB1PERIPH_BASE + 0x9000UL) |
| #define | OPAMP2_BASE (D2_APB1PERIPH_BASE + 0x9010UL) |
| #define | MDIOS_BASE (D2_APB1PERIPH_BASE + 0x9400UL) |
| #define | FDCAN1_BASE (D2_APB1PERIPH_BASE + 0xA000UL) |
| #define | FDCAN2_BASE (D2_APB1PERIPH_BASE + 0xA400UL) |
| #define | FDCAN_CCU_BASE (D2_APB1PERIPH_BASE + 0xA800UL) |
| #define | SRAMCAN_BASE (D2_APB1PERIPH_BASE + 0xAC00UL) |
| #define | TIM1_BASE (D2_APB2PERIPH_BASE + 0x0000UL) |
| #define | TIM8_BASE (D2_APB2PERIPH_BASE + 0x0400UL) |
| #define | USART1_BASE (D2_APB2PERIPH_BASE + 0x1000UL) |
| #define | USART6_BASE (D2_APB2PERIPH_BASE + 0x1400UL) |
| #define | SPI1_BASE (D2_APB2PERIPH_BASE + 0x3000UL) |
| #define | SPI4_BASE (D2_APB2PERIPH_BASE + 0x3400UL) |
| #define | TIM15_BASE (D2_APB2PERIPH_BASE + 0x4000UL) |
| #define | TIM16_BASE (D2_APB2PERIPH_BASE + 0x4400UL) |
| #define | TIM17_BASE (D2_APB2PERIPH_BASE + 0x4800UL) |
| #define | SPI5_BASE (D2_APB2PERIPH_BASE + 0x5000UL) |
| #define | SAI1_BASE (D2_APB2PERIPH_BASE + 0x5800UL) |
| #define | SAI1_Block_A_BASE (SAI1_BASE + 0x004UL) |
| #define | SAI1_Block_B_BASE (SAI1_BASE + 0x024UL) |
| #define | SAI2_BASE (D2_APB2PERIPH_BASE + 0x5C00UL) |
| #define | SAI2_Block_A_BASE (SAI2_BASE + 0x004UL) |
| #define | SAI2_Block_B_BASE (SAI2_BASE + 0x024UL) |
| #define | SAI3_BASE (D2_APB2PERIPH_BASE + 0x6000UL) |
| #define | SAI3_Block_A_BASE (SAI3_BASE + 0x004UL) |
| #define | SAI3_Block_B_BASE (SAI3_BASE + 0x024UL) |
| #define | DFSDM1_BASE (D2_APB2PERIPH_BASE + 0x7000UL) |
| #define | DFSDM1_Channel0_BASE (DFSDM1_BASE + 0x00UL) |
| #define | DFSDM1_Channel1_BASE (DFSDM1_BASE + 0x20UL) |
| #define | DFSDM1_Channel2_BASE (DFSDM1_BASE + 0x40UL) |
| #define | DFSDM1_Channel3_BASE (DFSDM1_BASE + 0x60UL) |
| #define | DFSDM1_Channel4_BASE (DFSDM1_BASE + 0x80UL) |
| #define | DFSDM1_Channel5_BASE (DFSDM1_BASE + 0xA0UL) |
| #define | DFSDM1_Channel6_BASE (DFSDM1_BASE + 0xC0UL) |
| #define | DFSDM1_Channel7_BASE (DFSDM1_BASE + 0xE0UL) |
| #define | DFSDM1_Filter0_BASE (DFSDM1_BASE + 0x100UL) |
| #define | DFSDM1_Filter1_BASE (DFSDM1_BASE + 0x180UL) |
| #define | DFSDM1_Filter2_BASE (DFSDM1_BASE + 0x200UL) |
| #define | DFSDM1_Filter3_BASE (DFSDM1_BASE + 0x280UL) |
| #define | HRTIM1_BASE (D2_APB2PERIPH_BASE + 0x7400UL) |
| #define | HRTIM1_TIMA_BASE (HRTIM1_BASE + 0x00000080UL) |
| #define | HRTIM1_TIMB_BASE (HRTIM1_BASE + 0x00000100UL) |
| #define | HRTIM1_TIMC_BASE (HRTIM1_BASE + 0x00000180UL) |
| #define | HRTIM1_TIMD_BASE (HRTIM1_BASE + 0x00000200UL) |
| #define | HRTIM1_TIME_BASE (HRTIM1_BASE + 0x00000280UL) |
| #define | HRTIM1_COMMON_BASE (HRTIM1_BASE + 0x00000380UL) |
| #define | EXTI_BASE (D3_APB1PERIPH_BASE + 0x0000UL) |
| #define | EXTI_D1_BASE (EXTI_BASE + 0x0080UL) |
| #define | EXTI_D2_BASE (EXTI_BASE + 0x00C0UL) |
| #define | SYSCFG_BASE (D3_APB1PERIPH_BASE + 0x0400UL) |
| #define | LPUART1_BASE (D3_APB1PERIPH_BASE + 0x0C00UL) |
| #define | SPI6_BASE (D3_APB1PERIPH_BASE + 0x1400UL) |
| #define | I2C4_BASE (D3_APB1PERIPH_BASE + 0x1C00UL) |
| #define | LPTIM2_BASE (D3_APB1PERIPH_BASE + 0x2400UL) |
| #define | LPTIM3_BASE (D3_APB1PERIPH_BASE + 0x2800UL) |
| #define | LPTIM4_BASE (D3_APB1PERIPH_BASE + 0x2C00UL) |
| #define | LPTIM5_BASE (D3_APB1PERIPH_BASE + 0x3000UL) |
| #define | COMP12_BASE (D3_APB1PERIPH_BASE + 0x3800UL) |
| #define | COMP1_BASE (COMP12_BASE + 0x0CUL) |
| #define | COMP2_BASE (COMP12_BASE + 0x10UL) |
| #define | VREFBUF_BASE (D3_APB1PERIPH_BASE + 0x3C00UL) |
| #define | RTC_BASE (D3_APB1PERIPH_BASE + 0x4000UL) |
| #define | IWDG1_BASE (D3_APB1PERIPH_BASE + 0x4800UL) |
| #define | SAI4_BASE (D3_APB1PERIPH_BASE + 0x5400UL) |
| #define | SAI4_Block_A_BASE (SAI4_BASE + 0x004UL) |
| #define | SAI4_Block_B_BASE (SAI4_BASE + 0x024UL) |
| #define | BDMA_Channel0_BASE (BDMA_BASE + 0x0008UL) |
| #define | BDMA_Channel1_BASE (BDMA_BASE + 0x001CUL) |
| #define | BDMA_Channel2_BASE (BDMA_BASE + 0x0030UL) |
| #define | BDMA_Channel3_BASE (BDMA_BASE + 0x0044UL) |
| #define | BDMA_Channel4_BASE (BDMA_BASE + 0x0058UL) |
| #define | BDMA_Channel5_BASE (BDMA_BASE + 0x006CUL) |
| #define | BDMA_Channel6_BASE (BDMA_BASE + 0x0080UL) |
| #define | BDMA_Channel7_BASE (BDMA_BASE + 0x0094UL) |
| #define | DMAMUX2_Channel0_BASE (DMAMUX2_BASE) |
| #define | DMAMUX2_Channel1_BASE (DMAMUX2_BASE + 0x0004UL) |
| #define | DMAMUX2_Channel2_BASE (DMAMUX2_BASE + 0x0008UL) |
| #define | DMAMUX2_Channel3_BASE (DMAMUX2_BASE + 0x000CUL) |
| #define | DMAMUX2_Channel4_BASE (DMAMUX2_BASE + 0x0010UL) |
| #define | DMAMUX2_Channel5_BASE (DMAMUX2_BASE + 0x0014UL) |
| #define | DMAMUX2_Channel6_BASE (DMAMUX2_BASE + 0x0018UL) |
| #define | DMAMUX2_Channel7_BASE (DMAMUX2_BASE + 0x001CUL) |
| #define | DMAMUX2_RequestGenerator0_BASE (DMAMUX2_BASE + 0x0100UL) |
| #define | DMAMUX2_RequestGenerator1_BASE (DMAMUX2_BASE + 0x0104UL) |
| #define | DMAMUX2_RequestGenerator2_BASE (DMAMUX2_BASE + 0x0108UL) |
| #define | DMAMUX2_RequestGenerator3_BASE (DMAMUX2_BASE + 0x010CUL) |
| #define | DMAMUX2_RequestGenerator4_BASE (DMAMUX2_BASE + 0x0110UL) |
| #define | DMAMUX2_RequestGenerator5_BASE (DMAMUX2_BASE + 0x0114UL) |
| #define | DMAMUX2_RequestGenerator6_BASE (DMAMUX2_BASE + 0x0118UL) |
| #define | DMAMUX2_RequestGenerator7_BASE (DMAMUX2_BASE + 0x011CUL) |
| #define | DMAMUX2_ChannelStatus_BASE (DMAMUX2_BASE + 0x0080UL) |
| #define | DMAMUX2_RequestGenStatus_BASE (DMAMUX2_BASE + 0x0140UL) |
| #define | DMA1_Stream0_BASE (DMA1_BASE + 0x010UL) |
| #define | DMA1_Stream1_BASE (DMA1_BASE + 0x028UL) |
| #define | DMA1_Stream2_BASE (DMA1_BASE + 0x040UL) |
| #define | DMA1_Stream3_BASE (DMA1_BASE + 0x058UL) |
| #define | DMA1_Stream4_BASE (DMA1_BASE + 0x070UL) |
| #define | DMA1_Stream5_BASE (DMA1_BASE + 0x088UL) |
| #define | DMA1_Stream6_BASE (DMA1_BASE + 0x0A0UL) |
| #define | DMA1_Stream7_BASE (DMA1_BASE + 0x0B8UL) |
| #define | DMA2_Stream0_BASE (DMA2_BASE + 0x010UL) |
| #define | DMA2_Stream1_BASE (DMA2_BASE + 0x028UL) |
| #define | DMA2_Stream2_BASE (DMA2_BASE + 0x040UL) |
| #define | DMA2_Stream3_BASE (DMA2_BASE + 0x058UL) |
| #define | DMA2_Stream4_BASE (DMA2_BASE + 0x070UL) |
| #define | DMA2_Stream5_BASE (DMA2_BASE + 0x088UL) |
| #define | DMA2_Stream6_BASE (DMA2_BASE + 0x0A0UL) |
| #define | DMA2_Stream7_BASE (DMA2_BASE + 0x0B8UL) |
| #define | DMAMUX1_Channel0_BASE (DMAMUX1_BASE) |
| #define | DMAMUX1_Channel1_BASE (DMAMUX1_BASE + 0x0004UL) |
| #define | DMAMUX1_Channel2_BASE (DMAMUX1_BASE + 0x0008UL) |
| #define | DMAMUX1_Channel3_BASE (DMAMUX1_BASE + 0x000CUL) |
| #define | DMAMUX1_Channel4_BASE (DMAMUX1_BASE + 0x0010UL) |
| #define | DMAMUX1_Channel5_BASE (DMAMUX1_BASE + 0x0014UL) |
| #define | DMAMUX1_Channel6_BASE (DMAMUX1_BASE + 0x0018UL) |
| #define | DMAMUX1_Channel7_BASE (DMAMUX1_BASE + 0x001CUL) |
| #define | DMAMUX1_Channel8_BASE (DMAMUX1_BASE + 0x0020UL) |
| #define | DMAMUX1_Channel9_BASE (DMAMUX1_BASE + 0x0024UL) |
| #define | DMAMUX1_Channel10_BASE (DMAMUX1_BASE + 0x0028UL) |
| #define | DMAMUX1_Channel11_BASE (DMAMUX1_BASE + 0x002CUL) |
| #define | DMAMUX1_Channel12_BASE (DMAMUX1_BASE + 0x0030UL) |
| #define | DMAMUX1_Channel13_BASE (DMAMUX1_BASE + 0x0034UL) |
| #define | DMAMUX1_Channel14_BASE (DMAMUX1_BASE + 0x0038UL) |
| #define | DMAMUX1_Channel15_BASE (DMAMUX1_BASE + 0x003CUL) |
| #define | DMAMUX1_RequestGenerator0_BASE (DMAMUX1_BASE + 0x0100UL) |
| #define | DMAMUX1_RequestGenerator1_BASE (DMAMUX1_BASE + 0x0104UL) |
| #define | DMAMUX1_RequestGenerator2_BASE (DMAMUX1_BASE + 0x0108UL) |
| #define | DMAMUX1_RequestGenerator3_BASE (DMAMUX1_BASE + 0x010CUL) |
| #define | DMAMUX1_RequestGenerator4_BASE (DMAMUX1_BASE + 0x0110UL) |
| #define | DMAMUX1_RequestGenerator5_BASE (DMAMUX1_BASE + 0x0114UL) |
| #define | DMAMUX1_RequestGenerator6_BASE (DMAMUX1_BASE + 0x0118UL) |
| #define | DMAMUX1_RequestGenerator7_BASE (DMAMUX1_BASE + 0x011CUL) |
| #define | DMAMUX1_ChannelStatus_BASE (DMAMUX1_BASE + 0x0080UL) |
| #define | DMAMUX1_RequestGenStatus_BASE (DMAMUX1_BASE + 0x0140UL) |
| #define | FMC_Bank1_R_BASE (FMC_R_BASE + 0x0000UL) |
| #define | FMC_Bank1E_R_BASE (FMC_R_BASE + 0x0104UL) |
| #define | FMC_Bank2_R_BASE (FMC_R_BASE + 0x0060UL) |
| #define | FMC_Bank3_R_BASE (FMC_R_BASE + 0x0080UL) |
| #define | FMC_Bank5_6_R_BASE (FMC_R_BASE + 0x0140UL) |
| #define | DBGMCU_BASE (0x5C001000UL) |
| #define | MDMA_Channel0_BASE (MDMA_BASE + 0x00000040UL) |
| #define | MDMA_Channel1_BASE (MDMA_BASE + 0x00000080UL) |
| #define | MDMA_Channel2_BASE (MDMA_BASE + 0x000000C0UL) |
| #define | MDMA_Channel3_BASE (MDMA_BASE + 0x00000100UL) |
| #define | MDMA_Channel4_BASE (MDMA_BASE + 0x00000140UL) |
| #define | MDMA_Channel5_BASE (MDMA_BASE + 0x00000180UL) |
| #define | MDMA_Channel6_BASE (MDMA_BASE + 0x000001C0UL) |
| #define | MDMA_Channel7_BASE (MDMA_BASE + 0x00000200UL) |
| #define | MDMA_Channel8_BASE (MDMA_BASE + 0x00000240UL) |
| #define | MDMA_Channel9_BASE (MDMA_BASE + 0x00000280UL) |
| #define | MDMA_Channel10_BASE (MDMA_BASE + 0x000002C0UL) |
| #define | MDMA_Channel11_BASE (MDMA_BASE + 0x00000300UL) |
| #define | MDMA_Channel12_BASE (MDMA_BASE + 0x00000340UL) |
| #define | MDMA_Channel13_BASE (MDMA_BASE + 0x00000380UL) |
| #define | MDMA_Channel14_BASE (MDMA_BASE + 0x000003C0UL) |
| #define | MDMA_Channel15_BASE (MDMA_BASE + 0x00000400UL) |
| #define | RAMECC1_Monitor1_BASE (RAMECC1_BASE + 0x20UL) |
| #define | RAMECC1_Monitor2_BASE (RAMECC1_BASE + 0x40UL) |
| #define | RAMECC1_Monitor3_BASE (RAMECC1_BASE + 0x60UL) |
| #define | RAMECC1_Monitor4_BASE (RAMECC1_BASE + 0x80UL) |
| #define | RAMECC1_Monitor5_BASE (RAMECC1_BASE + 0xA0UL) |
| #define | RAMECC2_Monitor1_BASE (RAMECC2_BASE + 0x20UL) |
| #define | RAMECC2_Monitor2_BASE (RAMECC2_BASE + 0x40UL) |
| #define | RAMECC2_Monitor3_BASE (RAMECC2_BASE + 0x60UL) |
| #define | RAMECC2_Monitor4_BASE (RAMECC2_BASE + 0x80UL) |
| #define | RAMECC2_Monitor5_BASE (RAMECC2_BASE + 0xA0UL) |
| #define | RAMECC3_Monitor1_BASE (RAMECC3_BASE + 0x20UL) |
| #define | RAMECC3_Monitor2_BASE (RAMECC3_BASE + 0x40UL) |
| #define | GPV_BASE (PERIPH_BASE + 0x11000000UL) |
| #define | TIM2 ((TIM_TypeDef *) TIM2_BASE) |
| #define | TIM3 ((TIM_TypeDef *) TIM3_BASE) |
| #define | TIM4 ((TIM_TypeDef *) TIM4_BASE) |
| #define | TIM5 ((TIM_TypeDef *) TIM5_BASE) |
| #define | TIM6 ((TIM_TypeDef *) TIM6_BASE) |
| #define | TIM7 ((TIM_TypeDef *) TIM7_BASE) |
| #define | TIM13 ((TIM_TypeDef *) TIM13_BASE) |
| #define | TIM14 ((TIM_TypeDef *) TIM14_BASE) |
| #define | VREFBUF ((VREFBUF_TypeDef *) VREFBUF_BASE) |
| #define | RTC ((RTC_TypeDef *) RTC_BASE) |
| #define | WWDG1 ((WWDG_TypeDef *) WWDG1_BASE) |
| #define | IWDG1 ((IWDG_TypeDef *) IWDG1_BASE) |
| #define | SPI2 ((SPI_TypeDef *) SPI2_BASE) |
| #define | SPI3 ((SPI_TypeDef *) SPI3_BASE) |
| #define | SPI4 ((SPI_TypeDef *) SPI4_BASE) |
| #define | SPI5 ((SPI_TypeDef *) SPI5_BASE) |
| #define | SPI6 ((SPI_TypeDef *) SPI6_BASE) |
| #define | USART2 ((USART_TypeDef *) USART2_BASE) |
| #define | USART3 ((USART_TypeDef *) USART3_BASE) |
| #define | USART6 ((USART_TypeDef *) USART6_BASE) |
| #define | UART7 ((USART_TypeDef *) UART7_BASE) |
| #define | UART8 ((USART_TypeDef *) UART8_BASE) |
| #define | CRS ((CRS_TypeDef *) CRS_BASE) |
| #define | UART4 ((USART_TypeDef *) UART4_BASE) |
| #define | UART5 ((USART_TypeDef *) UART5_BASE) |
| #define | I2C1 ((I2C_TypeDef *) I2C1_BASE) |
| #define | I2C2 ((I2C_TypeDef *) I2C2_BASE) |
| #define | I2C3 ((I2C_TypeDef *) I2C3_BASE) |
| #define | I2C4 ((I2C_TypeDef *) I2C4_BASE) |
| #define | FDCAN1 ((FDCAN_GlobalTypeDef *) FDCAN1_BASE) |
| #define | FDCAN2 ((FDCAN_GlobalTypeDef *) FDCAN2_BASE) |
| #define | FDCAN_CCU ((FDCAN_ClockCalibrationUnit_TypeDef *) FDCAN_CCU_BASE) |
| #define | CEC ((CEC_TypeDef *) CEC_BASE) |
| #define | LPTIM1 ((LPTIM_TypeDef *) LPTIM1_BASE) |
| #define | PWR ((PWR_TypeDef *) PWR_BASE) |
| #define | DAC1 ((DAC_TypeDef *) DAC1_BASE) |
| #define | LPUART1 ((USART_TypeDef *) LPUART1_BASE) |
| #define | SWPMI1 ((SWPMI_TypeDef *) SWPMI1_BASE) |
| #define | LPTIM2 ((LPTIM_TypeDef *) LPTIM2_BASE) |
| #define | LPTIM3 ((LPTIM_TypeDef *) LPTIM3_BASE) |
| #define | LPTIM4 ((LPTIM_TypeDef *) LPTIM4_BASE) |
| #define | LPTIM5 ((LPTIM_TypeDef *) LPTIM5_BASE) |
| #define | SYSCFG ((SYSCFG_TypeDef *) SYSCFG_BASE) |
| #define | COMP12 ((COMPOPT_TypeDef *) COMP12_BASE) |
| #define | COMP1 ((COMP_TypeDef *) COMP1_BASE) |
| #define | COMP2 ((COMP_TypeDef *) COMP2_BASE) |
| #define | COMP12_COMMON ((COMP_Common_TypeDef *) COMP2_BASE) |
| #define | OPAMP ((OPAMP_TypeDef *) OPAMP_BASE) |
| #define | OPAMP1 ((OPAMP_TypeDef *) OPAMP1_BASE) |
| #define | OPAMP2 ((OPAMP_TypeDef *) OPAMP2_BASE) |
| #define | EXTI ((EXTI_TypeDef *) EXTI_BASE) |
| #define | EXTI_D1 ((EXTI_Core_TypeDef *) EXTI_D1_BASE) |
| #define | EXTI_D2 ((EXTI_Core_TypeDef *) EXTI_D2_BASE) |
| #define | TIM1 ((TIM_TypeDef *) TIM1_BASE) |
| #define | SPI1 ((SPI_TypeDef *) SPI1_BASE) |
| #define | TIM8 ((TIM_TypeDef *) TIM8_BASE) |
| #define | USART1 ((USART_TypeDef *) USART1_BASE) |
| #define | TIM12 ((TIM_TypeDef *) TIM12_BASE) |
| #define | TIM15 ((TIM_TypeDef *) TIM15_BASE) |
| #define | TIM16 ((TIM_TypeDef *) TIM16_BASE) |
| #define | TIM17 ((TIM_TypeDef *) TIM17_BASE) |
| #define | HRTIM1 ((HRTIM_TypeDef *) HRTIM1_BASE) |
| #define | HRTIM1_TIMA ((HRTIM_Timerx_TypeDef *) HRTIM1_TIMA_BASE) |
| #define | HRTIM1_TIMB ((HRTIM_Timerx_TypeDef *) HRTIM1_TIMB_BASE) |
| #define | HRTIM1_TIMC ((HRTIM_Timerx_TypeDef *) HRTIM1_TIMC_BASE) |
| #define | HRTIM1_TIMD ((HRTIM_Timerx_TypeDef *) HRTIM1_TIMD_BASE) |
| #define | HRTIM1_TIME ((HRTIM_Timerx_TypeDef *) HRTIM1_TIME_BASE) |
| #define | HRTIM1_COMMON ((HRTIM_Common_TypeDef *) HRTIM1_COMMON_BASE) |
| #define | SAI1 ((SAI_TypeDef *) SAI1_BASE) |
| #define | SAI1_Block_A ((SAI_Block_TypeDef *)SAI1_Block_A_BASE) |
| #define | SAI1_Block_B ((SAI_Block_TypeDef *)SAI1_Block_B_BASE) |
| #define | SAI2 ((SAI_TypeDef *) SAI2_BASE) |
| #define | SAI2_Block_A ((SAI_Block_TypeDef *)SAI2_Block_A_BASE) |
| #define | SAI2_Block_B ((SAI_Block_TypeDef *)SAI2_Block_B_BASE) |
| #define | SAI3 ((SAI_TypeDef *) SAI3_BASE) |
| #define | SAI3_Block_A ((SAI_Block_TypeDef *)SAI3_Block_A_BASE) |
| #define | SAI3_Block_B ((SAI_Block_TypeDef *)SAI3_Block_B_BASE) |
| #define | SAI4 ((SAI_TypeDef *) SAI4_BASE) |
| #define | SAI4_Block_A ((SAI_Block_TypeDef *)SAI4_Block_A_BASE) |
| #define | SAI4_Block_B ((SAI_Block_TypeDef *)SAI4_Block_B_BASE) |
| #define | SPDIFRX ((SPDIFRX_TypeDef *) SPDIFRX_BASE) |
| #define | DFSDM1_Channel0 ((DFSDM_Channel_TypeDef *) DFSDM1_Channel0_BASE) |
| #define | DFSDM1_Channel1 ((DFSDM_Channel_TypeDef *) DFSDM1_Channel1_BASE) |
| #define | DFSDM1_Channel2 ((DFSDM_Channel_TypeDef *) DFSDM1_Channel2_BASE) |
| #define | DFSDM1_Channel3 ((DFSDM_Channel_TypeDef *) DFSDM1_Channel3_BASE) |
| #define | DFSDM1_Channel4 ((DFSDM_Channel_TypeDef *) DFSDM1_Channel4_BASE) |
| #define | DFSDM1_Channel5 ((DFSDM_Channel_TypeDef *) DFSDM1_Channel5_BASE) |
| #define | DFSDM1_Channel6 ((DFSDM_Channel_TypeDef *) DFSDM1_Channel6_BASE) |
| #define | DFSDM1_Channel7 ((DFSDM_Channel_TypeDef *) DFSDM1_Channel7_BASE) |
| #define | DFSDM1_Filter0 ((DFSDM_Filter_TypeDef *) DFSDM1_Filter0_BASE) |
| #define | DFSDM1_Filter1 ((DFSDM_Filter_TypeDef *) DFSDM1_Filter1_BASE) |
| #define | DFSDM1_Filter2 ((DFSDM_Filter_TypeDef *) DFSDM1_Filter2_BASE) |
| #define | DFSDM1_Filter3 ((DFSDM_Filter_TypeDef *) DFSDM1_Filter3_BASE) |
| #define | DMA2D ((DMA2D_TypeDef *) DMA2D_BASE) |
| #define | DCMI ((DCMI_TypeDef *) DCMI_BASE) |
| #define | RCC ((RCC_TypeDef *) RCC_BASE) |
| #define | FLASH ((FLASH_TypeDef *) FLASH_R_BASE) |
| #define | CRC ((CRC_TypeDef *) CRC_BASE) |
| #define | GPIOA ((GPIO_TypeDef *) GPIOA_BASE) |
| #define | GPIOB ((GPIO_TypeDef *) GPIOB_BASE) |
| #define | GPIOC ((GPIO_TypeDef *) GPIOC_BASE) |
| #define | GPIOD ((GPIO_TypeDef *) GPIOD_BASE) |
| #define | GPIOE ((GPIO_TypeDef *) GPIOE_BASE) |
| #define | GPIOF ((GPIO_TypeDef *) GPIOF_BASE) |
| #define | GPIOG ((GPIO_TypeDef *) GPIOG_BASE) |
| #define | GPIOH ((GPIO_TypeDef *) GPIOH_BASE) |
| #define | GPIOI ((GPIO_TypeDef *) GPIOI_BASE) |
| #define | GPIOJ ((GPIO_TypeDef *) GPIOJ_BASE) |
| #define | GPIOK ((GPIO_TypeDef *) GPIOK_BASE) |
| #define | ADC1 ((ADC_TypeDef *) ADC1_BASE) |
| #define | ADC2 ((ADC_TypeDef *) ADC2_BASE) |
| #define | ADC3 ((ADC_TypeDef *) ADC3_BASE) |
| #define | ADC3_COMMON ((ADC_Common_TypeDef *) ADC3_COMMON_BASE) |
| #define | ADC12_COMMON ((ADC_Common_TypeDef *) ADC12_COMMON_BASE) |
| #define | CRYP ((CRYP_TypeDef *) CRYP_BASE) |
| #define | HASH ((HASH_TypeDef *) HASH_BASE) |
| #define | HASH_DIGEST ((HASH_DIGEST_TypeDef *) HASH_DIGEST_BASE) |
| #define | RNG ((RNG_TypeDef *) RNG_BASE) |
| #define | SDMMC2 ((SDMMC_TypeDef *) SDMMC2_BASE) |
| #define | DLYB_SDMMC2 ((DLYB_TypeDef *) DLYB_SDMMC2_BASE) |
| #define | BDMA ((BDMA_TypeDef *) BDMA_BASE) |
| #define | BDMA_Channel0 ((BDMA_Channel_TypeDef *) BDMA_Channel0_BASE) |
| #define | BDMA_Channel1 ((BDMA_Channel_TypeDef *) BDMA_Channel1_BASE) |
| #define | BDMA_Channel2 ((BDMA_Channel_TypeDef *) BDMA_Channel2_BASE) |
| #define | BDMA_Channel3 ((BDMA_Channel_TypeDef *) BDMA_Channel3_BASE) |
| #define | BDMA_Channel4 ((BDMA_Channel_TypeDef *) BDMA_Channel4_BASE) |
| #define | BDMA_Channel5 ((BDMA_Channel_TypeDef *) BDMA_Channel5_BASE) |
| #define | BDMA_Channel6 ((BDMA_Channel_TypeDef *) BDMA_Channel6_BASE) |
| #define | BDMA_Channel7 ((BDMA_Channel_TypeDef *) BDMA_Channel7_BASE) |
| #define | RAMECC1 ((RAMECC_TypeDef *)RAMECC1_BASE) |
| #define | RAMECC1_Monitor1 ((RAMECC_MonitorTypeDef *)RAMECC1_Monitor1_BASE) |
| #define | RAMECC1_Monitor2 ((RAMECC_MonitorTypeDef *)RAMECC1_Monitor2_BASE) |
| #define | RAMECC1_Monitor3 ((RAMECC_MonitorTypeDef *)RAMECC1_Monitor3_BASE) |
| #define | RAMECC1_Monitor4 ((RAMECC_MonitorTypeDef *)RAMECC1_Monitor4_BASE) |
| #define | RAMECC1_Monitor5 ((RAMECC_MonitorTypeDef *)RAMECC1_Monitor5_BASE) |
| #define | RAMECC2 ((RAMECC_TypeDef *)RAMECC2_BASE) |
| #define | RAMECC2_Monitor1 ((RAMECC_MonitorTypeDef *)RAMECC2_Monitor1_BASE) |
| #define | RAMECC2_Monitor2 ((RAMECC_MonitorTypeDef *)RAMECC2_Monitor2_BASE) |
| #define | RAMECC2_Monitor3 ((RAMECC_MonitorTypeDef *)RAMECC2_Monitor3_BASE) |
| #define | RAMECC2_Monitor4 ((RAMECC_MonitorTypeDef *)RAMECC2_Monitor4_BASE) |
| #define | RAMECC2_Monitor5 ((RAMECC_MonitorTypeDef *)RAMECC2_Monitor5_BASE) |
| #define | RAMECC3 ((RAMECC_TypeDef *)RAMECC3_BASE) |
| #define | RAMECC3_Monitor1 ((RAMECC_MonitorTypeDef *)RAMECC3_Monitor1_BASE) |
| #define | RAMECC3_Monitor2 ((RAMECC_MonitorTypeDef *)RAMECC3_Monitor2_BASE) |
| #define | DMAMUX2 ((DMAMUX_Channel_TypeDef *) DMAMUX2_BASE) |
| #define | DMAMUX2_Channel0 ((DMAMUX_Channel_TypeDef *) DMAMUX2_Channel0_BASE) |
| #define | DMAMUX2_Channel1 ((DMAMUX_Channel_TypeDef *) DMAMUX2_Channel1_BASE) |
| #define | DMAMUX2_Channel2 ((DMAMUX_Channel_TypeDef *) DMAMUX2_Channel2_BASE) |
| #define | DMAMUX2_Channel3 ((DMAMUX_Channel_TypeDef *) DMAMUX2_Channel3_BASE) |
| #define | DMAMUX2_Channel4 ((DMAMUX_Channel_TypeDef *) DMAMUX2_Channel4_BASE) |
| #define | DMAMUX2_Channel5 ((DMAMUX_Channel_TypeDef *) DMAMUX2_Channel5_BASE) |
| #define | DMAMUX2_Channel6 ((DMAMUX_Channel_TypeDef *) DMAMUX2_Channel6_BASE) |
| #define | DMAMUX2_Channel7 ((DMAMUX_Channel_TypeDef *) DMAMUX2_Channel7_BASE) |
| #define | DMAMUX2_RequestGenerator0 ((DMAMUX_RequestGen_TypeDef *) DMAMUX2_RequestGenerator0_BASE) |
| #define | DMAMUX2_RequestGenerator1 ((DMAMUX_RequestGen_TypeDef *) DMAMUX2_RequestGenerator1_BASE) |
| #define | DMAMUX2_RequestGenerator2 ((DMAMUX_RequestGen_TypeDef *) DMAMUX2_RequestGenerator2_BASE) |
| #define | DMAMUX2_RequestGenerator3 ((DMAMUX_RequestGen_TypeDef *) DMAMUX2_RequestGenerator3_BASE) |
| #define | DMAMUX2_RequestGenerator4 ((DMAMUX_RequestGen_TypeDef *) DMAMUX2_RequestGenerator4_BASE) |
| #define | DMAMUX2_RequestGenerator5 ((DMAMUX_RequestGen_TypeDef *) DMAMUX2_RequestGenerator5_BASE) |
| #define | DMAMUX2_RequestGenerator6 ((DMAMUX_RequestGen_TypeDef *) DMAMUX2_RequestGenerator6_BASE) |
| #define | DMAMUX2_RequestGenerator7 ((DMAMUX_RequestGen_TypeDef *) DMAMUX2_RequestGenerator7_BASE) |
| #define | DMAMUX2_ChannelStatus ((DMAMUX_ChannelStatus_TypeDef *) DMAMUX2_ChannelStatus_BASE) |
| #define | DMAMUX2_RequestGenStatus ((DMAMUX_RequestGenStatus_TypeDef *) DMAMUX2_RequestGenStatus_BASE) |
| #define | DMA2 ((DMA_TypeDef *) DMA2_BASE) |
| #define | DMA2_Stream0 ((DMA_Stream_TypeDef *) DMA2_Stream0_BASE) |
| #define | DMA2_Stream1 ((DMA_Stream_TypeDef *) DMA2_Stream1_BASE) |
| #define | DMA2_Stream2 ((DMA_Stream_TypeDef *) DMA2_Stream2_BASE) |
| #define | DMA2_Stream3 ((DMA_Stream_TypeDef *) DMA2_Stream3_BASE) |
| #define | DMA2_Stream4 ((DMA_Stream_TypeDef *) DMA2_Stream4_BASE) |
| #define | DMA2_Stream5 ((DMA_Stream_TypeDef *) DMA2_Stream5_BASE) |
| #define | DMA2_Stream6 ((DMA_Stream_TypeDef *) DMA2_Stream6_BASE) |
| #define | DMA2_Stream7 ((DMA_Stream_TypeDef *) DMA2_Stream7_BASE) |
| #define | DMA1 ((DMA_TypeDef *) DMA1_BASE) |
| #define | DMA1_Stream0 ((DMA_Stream_TypeDef *) DMA1_Stream0_BASE) |
| #define | DMA1_Stream1 ((DMA_Stream_TypeDef *) DMA1_Stream1_BASE) |
| #define | DMA1_Stream2 ((DMA_Stream_TypeDef *) DMA1_Stream2_BASE) |
| #define | DMA1_Stream3 ((DMA_Stream_TypeDef *) DMA1_Stream3_BASE) |
| #define | DMA1_Stream4 ((DMA_Stream_TypeDef *) DMA1_Stream4_BASE) |
| #define | DMA1_Stream5 ((DMA_Stream_TypeDef *) DMA1_Stream5_BASE) |
| #define | DMA1_Stream6 ((DMA_Stream_TypeDef *) DMA1_Stream6_BASE) |
| #define | DMA1_Stream7 ((DMA_Stream_TypeDef *) DMA1_Stream7_BASE) |
| #define | DMAMUX1 ((DMAMUX_Channel_TypeDef *) DMAMUX1_BASE) |
| #define | DMAMUX1_Channel0 ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel0_BASE) |
| #define | DMAMUX1_Channel1 ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel1_BASE) |
| #define | DMAMUX1_Channel2 ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel2_BASE) |
| #define | DMAMUX1_Channel3 ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel3_BASE) |
| #define | DMAMUX1_Channel4 ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel4_BASE) |
| #define | DMAMUX1_Channel5 ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel5_BASE) |
| #define | DMAMUX1_Channel6 ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel6_BASE) |
| #define | DMAMUX1_Channel7 ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel7_BASE) |
| #define | DMAMUX1_Channel8 ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel8_BASE) |
| #define | DMAMUX1_Channel9 ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel9_BASE) |
| #define | DMAMUX1_Channel10 ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel10_BASE) |
| #define | DMAMUX1_Channel11 ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel11_BASE) |
| #define | DMAMUX1_Channel12 ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel12_BASE) |
| #define | DMAMUX1_Channel13 ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel13_BASE) |
| #define | DMAMUX1_Channel14 ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel14_BASE) |
| #define | DMAMUX1_Channel15 ((DMAMUX_Channel_TypeDef *) DMAMUX1_Channel15_BASE) |
| #define | DMAMUX1_RequestGenerator0 ((DMAMUX_RequestGen_TypeDef *) DMAMUX1_RequestGenerator0_BASE) |
| #define | DMAMUX1_RequestGenerator1 ((DMAMUX_RequestGen_TypeDef *) DMAMUX1_RequestGenerator1_BASE) |
| #define | DMAMUX1_RequestGenerator2 ((DMAMUX_RequestGen_TypeDef *) DMAMUX1_RequestGenerator2_BASE) |
| #define | DMAMUX1_RequestGenerator3 ((DMAMUX_RequestGen_TypeDef *) DMAMUX1_RequestGenerator3_BASE) |
| #define | DMAMUX1_RequestGenerator4 ((DMAMUX_RequestGen_TypeDef *) DMAMUX1_RequestGenerator4_BASE) |
| #define | DMAMUX1_RequestGenerator5 ((DMAMUX_RequestGen_TypeDef *) DMAMUX1_RequestGenerator5_BASE) |
| #define | DMAMUX1_RequestGenerator6 ((DMAMUX_RequestGen_TypeDef *) DMAMUX1_RequestGenerator6_BASE) |
| #define | DMAMUX1_RequestGenerator7 ((DMAMUX_RequestGen_TypeDef *) DMAMUX1_RequestGenerator7_BASE) |
| #define | DMAMUX1_ChannelStatus ((DMAMUX_ChannelStatus_TypeDef *) DMAMUX1_ChannelStatus_BASE) |
| #define | DMAMUX1_RequestGenStatus ((DMAMUX_RequestGenStatus_TypeDef *) DMAMUX1_RequestGenStatus_BASE) |
| #define | FMC_Bank1_R ((FMC_Bank1_TypeDef *) FMC_Bank1_R_BASE) |
| #define | FMC_Bank1E_R ((FMC_Bank1E_TypeDef *) FMC_Bank1E_R_BASE) |
| #define | FMC_Bank2_R ((FMC_Bank2_TypeDef *) FMC_Bank2_R_BASE) |
| #define | FMC_Bank3_R ((FMC_Bank3_TypeDef *) FMC_Bank3_R_BASE) |
| #define | FMC_Bank5_6_R ((FMC_Bank5_6_TypeDef *) FMC_Bank5_6_R_BASE) |
| #define | QUADSPI ((QUADSPI_TypeDef *) QSPI_R_BASE) |
| #define | DLYB_QUADSPI ((DLYB_TypeDef *) DLYB_QSPI_BASE) |
| #define | SDMMC1 ((SDMMC_TypeDef *) SDMMC1_BASE) |
| #define | DLYB_SDMMC1 ((DLYB_TypeDef *) DLYB_SDMMC1_BASE) |
| #define | DBGMCU ((DBGMCU_TypeDef *) DBGMCU_BASE) |
| #define | JPEG ((JPEG_TypeDef *) JPGDEC_BASE) |
| #define | HSEM ((HSEM_TypeDef *) HSEM_BASE) |
| #define | HSEM_COMMON ((HSEM_Common_TypeDef *) (HSEM_BASE + 0x100UL)) |
| #define | LTDC ((LTDC_TypeDef *)LTDC_BASE) |
| #define | LTDC_Layer1 ((LTDC_Layer_TypeDef *)LTDC_Layer1_BASE) |
| #define | LTDC_Layer2 ((LTDC_Layer_TypeDef *)LTDC_Layer2_BASE) |
| #define | MDIOS ((MDIOS_TypeDef *) MDIOS_BASE) |
| #define | ETH ((ETH_TypeDef *)ETH_BASE) |
| #define | MDMA ((MDMA_TypeDef *)MDMA_BASE) |
| #define | MDMA_Channel0 ((MDMA_Channel_TypeDef *)MDMA_Channel0_BASE) |
| #define | MDMA_Channel1 ((MDMA_Channel_TypeDef *)MDMA_Channel1_BASE) |
| #define | MDMA_Channel2 ((MDMA_Channel_TypeDef *)MDMA_Channel2_BASE) |
| #define | MDMA_Channel3 ((MDMA_Channel_TypeDef *)MDMA_Channel3_BASE) |
| #define | MDMA_Channel4 ((MDMA_Channel_TypeDef *)MDMA_Channel4_BASE) |
| #define | MDMA_Channel5 ((MDMA_Channel_TypeDef *)MDMA_Channel5_BASE) |
| #define | MDMA_Channel6 ((MDMA_Channel_TypeDef *)MDMA_Channel6_BASE) |
| #define | MDMA_Channel7 ((MDMA_Channel_TypeDef *)MDMA_Channel7_BASE) |
| #define | MDMA_Channel8 ((MDMA_Channel_TypeDef *)MDMA_Channel8_BASE) |
| #define | MDMA_Channel9 ((MDMA_Channel_TypeDef *)MDMA_Channel9_BASE) |
| #define | MDMA_Channel10 ((MDMA_Channel_TypeDef *)MDMA_Channel10_BASE) |
| #define | MDMA_Channel11 ((MDMA_Channel_TypeDef *)MDMA_Channel11_BASE) |
| #define | MDMA_Channel12 ((MDMA_Channel_TypeDef *)MDMA_Channel12_BASE) |
| #define | MDMA_Channel13 ((MDMA_Channel_TypeDef *)MDMA_Channel13_BASE) |
| #define | MDMA_Channel14 ((MDMA_Channel_TypeDef *)MDMA_Channel14_BASE) |
| #define | MDMA_Channel15 ((MDMA_Channel_TypeDef *)MDMA_Channel15_BASE) |
| #define | USB1_OTG_HS ((USB_OTG_GlobalTypeDef *) USB1_OTG_HS_PERIPH_BASE) |
| #define | USB2_OTG_FS ((USB_OTG_GlobalTypeDef *) USB2_OTG_FS_PERIPH_BASE) |
| #define | USB_OTG_HS USB1_OTG_HS |
| #define | USB_OTG_HS_PERIPH_BASE USB1_OTG_HS_PERIPH_BASE |
| #define | USB_OTG_FS USB2_OTG_FS |
| #define | USB_OTG_FS_PERIPH_BASE USB2_OTG_FS_PERIPH_BASE |
| #define | GPV ((GPV_TypeDef *) GPV_BASE) |
| #define | LSI_STARTUP_TIME 130U |
| #define | ADC_VER_V5_X |
| #define | ADC_ISR_ADRDY_Pos (0U) |
| #define | ADC_ISR_ADRDY_Msk (0x1UL << ADC_ISR_ADRDY_Pos) |
| #define | ADC_ISR_ADRDY ADC_ISR_ADRDY_Msk |
| #define | ADC_ISR_EOSMP_Pos (1U) |
| #define | ADC_ISR_EOSMP_Msk (0x1UL << ADC_ISR_EOSMP_Pos) |
| #define | ADC_ISR_EOSMP ADC_ISR_EOSMP_Msk |
| #define | ADC_ISR_EOC_Pos (2U) |
| #define | ADC_ISR_EOC_Msk (0x1UL << ADC_ISR_EOC_Pos) |
| #define | ADC_ISR_EOC ADC_ISR_EOC_Msk |
| #define | ADC_ISR_EOS_Pos (3U) |
| #define | ADC_ISR_EOS_Msk (0x1UL << ADC_ISR_EOS_Pos) |
| #define | ADC_ISR_EOS ADC_ISR_EOS_Msk |
| #define | ADC_ISR_OVR_Pos (4U) |
| #define | ADC_ISR_OVR_Msk (0x1UL << ADC_ISR_OVR_Pos) |
| #define | ADC_ISR_OVR ADC_ISR_OVR_Msk |
| #define | ADC_ISR_JEOC_Pos (5U) |
| #define | ADC_ISR_JEOC_Msk (0x1UL << ADC_ISR_JEOC_Pos) |
| #define | ADC_ISR_JEOC ADC_ISR_JEOC_Msk |
| #define | ADC_ISR_JEOS_Pos (6U) |
| #define | ADC_ISR_JEOS_Msk (0x1UL << ADC_ISR_JEOS_Pos) |
| #define | ADC_ISR_JEOS ADC_ISR_JEOS_Msk |
| #define | ADC_ISR_AWD1_Pos (7U) |
| #define | ADC_ISR_AWD1_Msk (0x1UL << ADC_ISR_AWD1_Pos) |
| #define | ADC_ISR_AWD1 ADC_ISR_AWD1_Msk |
| #define | ADC_ISR_AWD2_Pos (8U) |
| #define | ADC_ISR_AWD2_Msk (0x1UL << ADC_ISR_AWD2_Pos) |
| #define | ADC_ISR_AWD2 ADC_ISR_AWD2_Msk |
| #define | ADC_ISR_AWD3_Pos (9U) |
| #define | ADC_ISR_AWD3_Msk (0x1UL << ADC_ISR_AWD3_Pos) |
| #define | ADC_ISR_AWD3 ADC_ISR_AWD3_Msk |
| #define | ADC_ISR_JQOVF_Pos (10U) |
| #define | ADC_ISR_JQOVF_Msk (0x1UL << ADC_ISR_JQOVF_Pos) |
| #define | ADC_ISR_JQOVF ADC_ISR_JQOVF_Msk |
| #define | ADC_ISR_LDORDY_Pos (12U) |
| #define | ADC_ISR_LDORDY_Msk (0x1UL << ADC_ISR_LDORDY_Pos) |
| #define | ADC_ISR_LDORDY ADC_ISR_LDORDY_Msk |
| #define | ADC_IER_ADRDYIE_Pos (0U) |
| #define | ADC_IER_ADRDYIE_Msk (0x1UL << ADC_IER_ADRDYIE_Pos) |
| #define | ADC_IER_ADRDYIE ADC_IER_ADRDYIE_Msk |
| #define | ADC_IER_EOSMPIE_Pos (1U) |
| #define | ADC_IER_EOSMPIE_Msk (0x1UL << ADC_IER_EOSMPIE_Pos) |
| #define | ADC_IER_EOSMPIE ADC_IER_EOSMPIE_Msk |
| #define | ADC_IER_EOCIE_Pos (2U) |
| #define | ADC_IER_EOCIE_Msk (0x1UL << ADC_IER_EOCIE_Pos) |
| #define | ADC_IER_EOCIE ADC_IER_EOCIE_Msk |
| #define | ADC_IER_EOSIE_Pos (3U) |
| #define | ADC_IER_EOSIE_Msk (0x1UL << ADC_IER_EOSIE_Pos) |
| #define | ADC_IER_EOSIE ADC_IER_EOSIE_Msk |
| #define | ADC_IER_OVRIE_Pos (4U) |
| #define | ADC_IER_OVRIE_Msk (0x1UL << ADC_IER_OVRIE_Pos) |
| #define | ADC_IER_OVRIE ADC_IER_OVRIE_Msk |
| #define | ADC_IER_JEOCIE_Pos (5U) |
| #define | ADC_IER_JEOCIE_Msk (0x1UL << ADC_IER_JEOCIE_Pos) |
| #define | ADC_IER_JEOCIE ADC_IER_JEOCIE_Msk |
| #define | ADC_IER_JEOSIE_Pos (6U) |
| #define | ADC_IER_JEOSIE_Msk (0x1UL << ADC_IER_JEOSIE_Pos) |
| #define | ADC_IER_JEOSIE ADC_IER_JEOSIE_Msk |
| #define | ADC_IER_AWD1IE_Pos (7U) |
| #define | ADC_IER_AWD1IE_Msk (0x1UL << ADC_IER_AWD1IE_Pos) |
| #define | ADC_IER_AWD1IE ADC_IER_AWD1IE_Msk |
| #define | ADC_IER_AWD2IE_Pos (8U) |
| #define | ADC_IER_AWD2IE_Msk (0x1UL << ADC_IER_AWD2IE_Pos) |
| #define | ADC_IER_AWD2IE ADC_IER_AWD2IE_Msk |
| #define | ADC_IER_AWD3IE_Pos (9U) |
| #define | ADC_IER_AWD3IE_Msk (0x1UL << ADC_IER_AWD3IE_Pos) |
| #define | ADC_IER_AWD3IE ADC_IER_AWD3IE_Msk |
| #define | ADC_IER_JQOVFIE_Pos (10U) |
| #define | ADC_IER_JQOVFIE_Msk (0x1UL << ADC_IER_JQOVFIE_Pos) |
| #define | ADC_IER_JQOVFIE ADC_IER_JQOVFIE_Msk |
| #define | ADC_CR_ADEN_Pos (0U) |
| #define | ADC_CR_ADEN_Msk (0x1UL << ADC_CR_ADEN_Pos) |
| #define | ADC_CR_ADEN ADC_CR_ADEN_Msk |
| #define | ADC_CR_ADDIS_Pos (1U) |
| #define | ADC_CR_ADDIS_Msk (0x1UL << ADC_CR_ADDIS_Pos) |
| #define | ADC_CR_ADDIS ADC_CR_ADDIS_Msk |
| #define | ADC_CR_ADSTART_Pos (2U) |
| #define | ADC_CR_ADSTART_Msk (0x1UL << ADC_CR_ADSTART_Pos) |
| #define | ADC_CR_ADSTART ADC_CR_ADSTART_Msk |
| #define | ADC_CR_JADSTART_Pos (3U) |
| #define | ADC_CR_JADSTART_Msk (0x1UL << ADC_CR_JADSTART_Pos) |
| #define | ADC_CR_JADSTART ADC_CR_JADSTART_Msk |
| #define | ADC_CR_ADSTP_Pos (4U) |
| #define | ADC_CR_ADSTP_Msk (0x1UL << ADC_CR_ADSTP_Pos) |
| #define | ADC_CR_ADSTP ADC_CR_ADSTP_Msk |
| #define | ADC_CR_JADSTP_Pos (5U) |
| #define | ADC_CR_JADSTP_Msk (0x1UL << ADC_CR_JADSTP_Pos) |
| #define | ADC_CR_JADSTP ADC_CR_JADSTP_Msk |
| #define | ADC_CR_BOOST_Pos (8U) |
| #define | ADC_CR_BOOST_Msk (0x3UL << ADC_CR_BOOST_Pos) |
| #define | ADC_CR_BOOST ADC_CR_BOOST_Msk |
| #define | ADC_CR_BOOST_0 (0x1UL << ADC_CR_BOOST_Pos) |
| #define | ADC_CR_BOOST_1 (0x2UL << ADC_CR_BOOST_Pos) |
| #define | ADC_CR_ADCALLIN_Pos (16U) |
| #define | ADC_CR_ADCALLIN_Msk (0x1UL << ADC_CR_ADCALLIN_Pos) |
| #define | ADC_CR_ADCALLIN ADC_CR_ADCALLIN_Msk |
| #define | ADC_CR_LINCALRDYW1_Pos (22U) |
| #define | ADC_CR_LINCALRDYW1_Msk (0x1UL << ADC_CR_LINCALRDYW1_Pos) |
| #define | ADC_CR_LINCALRDYW1 ADC_CR_LINCALRDYW1_Msk |
| #define | ADC_CR_LINCALRDYW2_Pos (23U) |
| #define | ADC_CR_LINCALRDYW2_Msk (0x1UL << ADC_CR_LINCALRDYW2_Pos) |
| #define | ADC_CR_LINCALRDYW2 ADC_CR_LINCALRDYW2_Msk |
| #define | ADC_CR_LINCALRDYW3_Pos (24U) |
| #define | ADC_CR_LINCALRDYW3_Msk (0x1UL << ADC_CR_LINCALRDYW3_Pos) |
| #define | ADC_CR_LINCALRDYW3 ADC_CR_LINCALRDYW3_Msk |
| #define | ADC_CR_LINCALRDYW4_Pos (25U) |
| #define | ADC_CR_LINCALRDYW4_Msk (0x1UL << ADC_CR_LINCALRDYW4_Pos) |
| #define | ADC_CR_LINCALRDYW4 ADC_CR_LINCALRDYW4_Msk |
| #define | ADC_CR_LINCALRDYW5_Pos (26U) |
| #define | ADC_CR_LINCALRDYW5_Msk (0x1UL << ADC_CR_LINCALRDYW5_Pos) |
| #define | ADC_CR_LINCALRDYW5 ADC_CR_LINCALRDYW5_Msk |
| #define | ADC_CR_LINCALRDYW6_Pos (27U) |
| #define | ADC_CR_LINCALRDYW6_Msk (0x1UL << ADC_CR_LINCALRDYW6_Pos) |
| #define | ADC_CR_LINCALRDYW6 ADC_CR_LINCALRDYW6_Msk |
| #define | ADC_CR_ADVREGEN_Pos (28U) |
| #define | ADC_CR_ADVREGEN_Msk (0x1UL << ADC_CR_ADVREGEN_Pos) |
| #define | ADC_CR_ADVREGEN ADC_CR_ADVREGEN_Msk |
| #define | ADC_CR_DEEPPWD_Pos (29U) |
| #define | ADC_CR_DEEPPWD_Msk (0x1UL << ADC_CR_DEEPPWD_Pos) |
| #define | ADC_CR_DEEPPWD ADC_CR_DEEPPWD_Msk |
| #define | ADC_CR_ADCALDIF_Pos (30U) |
| #define | ADC_CR_ADCALDIF_Msk (0x1UL << ADC_CR_ADCALDIF_Pos) |
| #define | ADC_CR_ADCALDIF ADC_CR_ADCALDIF_Msk |
| #define | ADC_CR_ADCAL_Pos (31U) |
| #define | ADC_CR_ADCAL_Msk (0x1UL << ADC_CR_ADCAL_Pos) |
| #define | ADC_CR_ADCAL ADC_CR_ADCAL_Msk |
| #define | ADC_CFGR_DMNGT_Pos (0U) |
| #define | ADC_CFGR_DMNGT_Msk (0x3UL << ADC_CFGR_DMNGT_Pos) |
| #define | ADC_CFGR_DMNGT ADC_CFGR_DMNGT_Msk |
| #define | ADC_CFGR_DMNGT_0 (0x1UL << ADC_CFGR_DMNGT_Pos) |
| #define | ADC_CFGR_DMNGT_1 (0x2UL << ADC_CFGR_DMNGT_Pos) |
| #define | ADC_CFGR_RES_Pos (2U) |
| #define | ADC_CFGR_RES_Msk (0x7UL << ADC_CFGR_RES_Pos) |
| #define | ADC_CFGR_RES ADC_CFGR_RES_Msk |
| #define | ADC_CFGR_RES_0 (0x1UL << ADC_CFGR_RES_Pos) |
| #define | ADC_CFGR_RES_1 (0x2UL << ADC_CFGR_RES_Pos) |
| #define | ADC_CFGR_RES_2 (0x4UL << ADC_CFGR_RES_Pos) |
| #define | ADC_CFGR_EXTSEL_Pos (5U) |
| #define | ADC_CFGR_EXTSEL_Msk (0x1FUL << ADC_CFGR_EXTSEL_Pos) |
| #define | ADC_CFGR_EXTSEL ADC_CFGR_EXTSEL_Msk |
| #define | ADC_CFGR_EXTSEL_0 (0x01UL << ADC_CFGR_EXTSEL_Pos) |
| #define | ADC_CFGR_EXTSEL_1 (0x02UL << ADC_CFGR_EXTSEL_Pos) |
| #define | ADC_CFGR_EXTSEL_2 (0x04UL << ADC_CFGR_EXTSEL_Pos) |
| #define | ADC_CFGR_EXTSEL_3 (0x08UL << ADC_CFGR_EXTSEL_Pos) |
| #define | ADC_CFGR_EXTSEL_4 (0x10UL << ADC_CFGR_EXTSEL_Pos) |
| #define | ADC_CFGR_EXTEN_Pos (10U) |
| #define | ADC_CFGR_EXTEN_Msk (0x3UL << ADC_CFGR_EXTEN_Pos) |
| #define | ADC_CFGR_EXTEN ADC_CFGR_EXTEN_Msk |
| #define | ADC_CFGR_EXTEN_0 (0x1UL << ADC_CFGR_EXTEN_Pos) |
| #define | ADC_CFGR_EXTEN_1 (0x2UL << ADC_CFGR_EXTEN_Pos) |
| #define | ADC_CFGR_OVRMOD_Pos (12U) |
| #define | ADC_CFGR_OVRMOD_Msk (0x1UL << ADC_CFGR_OVRMOD_Pos) |
| #define | ADC_CFGR_OVRMOD ADC_CFGR_OVRMOD_Msk |
| #define | ADC_CFGR_CONT_Pos (13U) |
| #define | ADC_CFGR_CONT_Msk (0x1UL << ADC_CFGR_CONT_Pos) |
| #define | ADC_CFGR_CONT ADC_CFGR_CONT_Msk |
| #define | ADC_CFGR_AUTDLY_Pos (14U) |
| #define | ADC_CFGR_AUTDLY_Msk (0x1UL << ADC_CFGR_AUTDLY_Pos) |
| #define | ADC_CFGR_AUTDLY ADC_CFGR_AUTDLY_Msk |
| #define | ADC_CFGR_DISCEN_Pos (16U) |
| #define | ADC_CFGR_DISCEN_Msk (0x1UL << ADC_CFGR_DISCEN_Pos) |
| #define | ADC_CFGR_DISCEN ADC_CFGR_DISCEN_Msk |
| #define | ADC_CFGR_DISCNUM_Pos (17U) |
| #define | ADC_CFGR_DISCNUM_Msk (0x7UL << ADC_CFGR_DISCNUM_Pos) |
| #define | ADC_CFGR_DISCNUM ADC_CFGR_DISCNUM_Msk |
| #define | ADC_CFGR_DISCNUM_0 (0x1UL << ADC_CFGR_DISCNUM_Pos) |
| #define | ADC_CFGR_DISCNUM_1 (0x2UL << ADC_CFGR_DISCNUM_Pos) |
| #define | ADC_CFGR_DISCNUM_2 (0x4UL << ADC_CFGR_DISCNUM_Pos) |
| #define | ADC_CFGR_JDISCEN_Pos (20U) |
| #define | ADC_CFGR_JDISCEN_Msk (0x1UL << ADC_CFGR_JDISCEN_Pos) |
| #define | ADC_CFGR_JDISCEN ADC_CFGR_JDISCEN_Msk |
| #define | ADC_CFGR_JQM_Pos (21U) |
| #define | ADC_CFGR_JQM_Msk (0x1UL << ADC_CFGR_JQM_Pos) |
| #define | ADC_CFGR_JQM ADC_CFGR_JQM_Msk |
| #define | ADC_CFGR_AWD1SGL_Pos (22U) |
| #define | ADC_CFGR_AWD1SGL_Msk (0x1UL << ADC_CFGR_AWD1SGL_Pos) |
| #define | ADC_CFGR_AWD1SGL ADC_CFGR_AWD1SGL_Msk |
| #define | ADC_CFGR_AWD1EN_Pos (23U) |
| #define | ADC_CFGR_AWD1EN_Msk (0x1UL << ADC_CFGR_AWD1EN_Pos) |
| #define | ADC_CFGR_AWD1EN ADC_CFGR_AWD1EN_Msk |
| #define | ADC_CFGR_JAWD1EN_Pos (24U) |
| #define | ADC_CFGR_JAWD1EN_Msk (0x1UL << ADC_CFGR_JAWD1EN_Pos) |
| #define | ADC_CFGR_JAWD1EN ADC_CFGR_JAWD1EN_Msk |
| #define | ADC_CFGR_JAUTO_Pos (25U) |
| #define | ADC_CFGR_JAUTO_Msk (0x1UL << ADC_CFGR_JAUTO_Pos) |
| #define | ADC_CFGR_JAUTO ADC_CFGR_JAUTO_Msk |
| #define | ADC_CFGR_AWD1CH_Pos (26U) |
| #define | ADC_CFGR_AWD1CH_Msk (0x1FUL << ADC_CFGR_AWD1CH_Pos) |
| #define | ADC_CFGR_AWD1CH ADC_CFGR_AWD1CH_Msk |
| #define | ADC_CFGR_AWD1CH_0 (0x01UL << ADC_CFGR_AWD1CH_Pos) |
| #define | ADC_CFGR_AWD1CH_1 (0x02UL << ADC_CFGR_AWD1CH_Pos) |
| #define | ADC_CFGR_AWD1CH_2 (0x04UL << ADC_CFGR_AWD1CH_Pos) |
| #define | ADC_CFGR_AWD1CH_3 (0x08UL << ADC_CFGR_AWD1CH_Pos) |
| #define | ADC_CFGR_AWD1CH_4 (0x10UL << ADC_CFGR_AWD1CH_Pos) |
| #define | ADC_CFGR_JQDIS_Pos (31U) |
| #define | ADC_CFGR_JQDIS_Msk (0x1UL << ADC_CFGR_JQDIS_Pos) |
| #define | ADC_CFGR_JQDIS ADC_CFGR_JQDIS_Msk |
| #define | ADC_CFGR2_ROVSE_Pos (0U) |
| #define | ADC_CFGR2_ROVSE_Msk (0x1UL << ADC_CFGR2_ROVSE_Pos) |
| #define | ADC_CFGR2_ROVSE ADC_CFGR2_ROVSE_Msk |
| #define | ADC_CFGR2_JOVSE_Pos (1U) |
| #define | ADC_CFGR2_JOVSE_Msk (0x1UL << ADC_CFGR2_JOVSE_Pos) |
| #define | ADC_CFGR2_JOVSE ADC_CFGR2_JOVSE_Msk |
| #define | ADC_CFGR2_OVSS_Pos (5U) |
| #define | ADC_CFGR2_OVSS_Msk (0xFUL << ADC_CFGR2_OVSS_Pos) |
| #define | ADC_CFGR2_OVSS ADC_CFGR2_OVSS_Msk |
| #define | ADC_CFGR2_OVSS_0 (0x1UL << ADC_CFGR2_OVSS_Pos) |
| #define | ADC_CFGR2_OVSS_1 (0x2UL << ADC_CFGR2_OVSS_Pos) |
| #define | ADC_CFGR2_OVSS_2 (0x4UL << ADC_CFGR2_OVSS_Pos) |
| #define | ADC_CFGR2_OVSS_3 (0x8UL << ADC_CFGR2_OVSS_Pos) |
| #define | ADC_CFGR2_TROVS_Pos (9U) |
| #define | ADC_CFGR2_TROVS_Msk (0x1UL << ADC_CFGR2_TROVS_Pos) |
| #define | ADC_CFGR2_TROVS ADC_CFGR2_TROVS_Msk |
| #define | ADC_CFGR2_ROVSM_Pos (10U) |
| #define | ADC_CFGR2_ROVSM_Msk (0x1UL << ADC_CFGR2_ROVSM_Pos) |
| #define | ADC_CFGR2_ROVSM ADC_CFGR2_ROVSM_Msk |
| #define | ADC_CFGR2_RSHIFT1_Pos (11U) |
| #define | ADC_CFGR2_RSHIFT1_Msk (0x1UL << ADC_CFGR2_RSHIFT1_Pos) |
| #define | ADC_CFGR2_RSHIFT1 ADC_CFGR2_RSHIFT1_Msk |
| #define | ADC_CFGR2_RSHIFT2_Pos (12U) |
| #define | ADC_CFGR2_RSHIFT2_Msk (0x1UL << ADC_CFGR2_RSHIFT2_Pos) |
| #define | ADC_CFGR2_RSHIFT2 ADC_CFGR2_RSHIFT2_Msk |
| #define | ADC_CFGR2_RSHIFT3_Pos (13U) |
| #define | ADC_CFGR2_RSHIFT3_Msk (0x1UL << ADC_CFGR2_RSHIFT3_Pos) |
| #define | ADC_CFGR2_RSHIFT3 ADC_CFGR2_RSHIFT3_Msk |
| #define | ADC_CFGR2_RSHIFT4_Pos (14U) |
| #define | ADC_CFGR2_RSHIFT4_Msk (0x1UL << ADC_CFGR2_RSHIFT4_Pos) |
| #define | ADC_CFGR2_RSHIFT4 ADC_CFGR2_RSHIFT4_Msk |
| #define | ADC_CFGR2_OVSR_Pos (16U) |
| #define | ADC_CFGR2_OVSR_Msk (0x3FFUL << ADC_CFGR2_OVSR_Pos) |
| #define | ADC_CFGR2_OVSR ADC_CFGR2_OVSR_Msk |
| #define | ADC_CFGR2_OVSR_0 (0x001UL << ADC_CFGR2_OVSR_Pos) |
| #define | ADC_CFGR2_OVSR_1 (0x002UL << ADC_CFGR2_OVSR_Pos) |
| #define | ADC_CFGR2_OVSR_2 (0x004UL << ADC_CFGR2_OVSR_Pos) |
| #define | ADC_CFGR2_OVSR_3 (0x008UL << ADC_CFGR2_OVSR_Pos) |
| #define | ADC_CFGR2_OVSR_4 (0x010UL << ADC_CFGR2_OVSR_Pos) |
| #define | ADC_CFGR2_OVSR_5 (0x020UL << ADC_CFGR2_OVSR_Pos) |
| #define | ADC_CFGR2_OVSR_6 (0x040UL << ADC_CFGR2_OVSR_Pos) |
| #define | ADC_CFGR2_OVSR_7 (0x080UL << ADC_CFGR2_OVSR_Pos) |
| #define | ADC_CFGR2_OVSR_8 (0x100UL << ADC_CFGR2_OVSR_Pos) |
| #define | ADC_CFGR2_OVSR_9 (0x200UL << ADC_CFGR2_OVSR_Pos) |
| #define | ADC_CFGR2_LSHIFT_Pos (28U) |
| #define | ADC_CFGR2_LSHIFT_Msk (0xFUL << ADC_CFGR2_LSHIFT_Pos) |
| #define | ADC_CFGR2_LSHIFT ADC_CFGR2_LSHIFT_Msk |
| #define | ADC_CFGR2_LSHIFT_0 (0x1UL << ADC_CFGR2_LSHIFT_Pos) |
| #define | ADC_CFGR2_LSHIFT_1 (0x2UL << ADC_CFGR2_LSHIFT_Pos) |
| #define | ADC_CFGR2_LSHIFT_2 (0x4UL << ADC_CFGR2_LSHIFT_Pos) |
| #define | ADC_CFGR2_LSHIFT_3 (0x8UL << ADC_CFGR2_LSHIFT_Pos) |
| #define | ADC_SMPR1_SMP0_Pos (0U) |
| #define | ADC_SMPR1_SMP0_Msk (0x7UL << ADC_SMPR1_SMP0_Pos) |
| #define | ADC_SMPR1_SMP0 ADC_SMPR1_SMP0_Msk |
| #define | ADC_SMPR1_SMP0_0 (0x1UL << ADC_SMPR1_SMP0_Pos) |
| #define | ADC_SMPR1_SMP0_1 (0x2UL << ADC_SMPR1_SMP0_Pos) |
| #define | ADC_SMPR1_SMP0_2 (0x4UL << ADC_SMPR1_SMP0_Pos) |
| #define | ADC_SMPR1_SMP1_Pos (3U) |
| #define | ADC_SMPR1_SMP1_Msk (0x7UL << ADC_SMPR1_SMP1_Pos) |
| #define | ADC_SMPR1_SMP1 ADC_SMPR1_SMP1_Msk |
| #define | ADC_SMPR1_SMP1_0 (0x1UL << ADC_SMPR1_SMP1_Pos) |
| #define | ADC_SMPR1_SMP1_1 (0x2UL << ADC_SMPR1_SMP1_Pos) |
| #define | ADC_SMPR1_SMP1_2 (0x4UL << ADC_SMPR1_SMP1_Pos) |
| #define | ADC_SMPR1_SMP2_Pos (6U) |
| #define | ADC_SMPR1_SMP2_Msk (0x7UL << ADC_SMPR1_SMP2_Pos) |
| #define | ADC_SMPR1_SMP2 ADC_SMPR1_SMP2_Msk |
| #define | ADC_SMPR1_SMP2_0 (0x1UL << ADC_SMPR1_SMP2_Pos) |
| #define | ADC_SMPR1_SMP2_1 (0x2UL << ADC_SMPR1_SMP2_Pos) |
| #define | ADC_SMPR1_SMP2_2 (0x4UL << ADC_SMPR1_SMP2_Pos) |
| #define | ADC_SMPR1_SMP3_Pos (9U) |
| #define | ADC_SMPR1_SMP3_Msk (0x7UL << ADC_SMPR1_SMP3_Pos) |
| #define | ADC_SMPR1_SMP3 ADC_SMPR1_SMP3_Msk |
| #define | ADC_SMPR1_SMP3_0 (0x1UL << ADC_SMPR1_SMP3_Pos) |
| #define | ADC_SMPR1_SMP3_1 (0x2UL << ADC_SMPR1_SMP3_Pos) |
| #define | ADC_SMPR1_SMP3_2 (0x4UL << ADC_SMPR1_SMP3_Pos) |
| #define | ADC_SMPR1_SMP4_Pos (12U) |
| #define | ADC_SMPR1_SMP4_Msk (0x7UL << ADC_SMPR1_SMP4_Pos) |
| #define | ADC_SMPR1_SMP4 ADC_SMPR1_SMP4_Msk |
| #define | ADC_SMPR1_SMP4_0 (0x1UL << ADC_SMPR1_SMP4_Pos) |
| #define | ADC_SMPR1_SMP4_1 (0x2UL << ADC_SMPR1_SMP4_Pos) |
| #define | ADC_SMPR1_SMP4_2 (0x4UL << ADC_SMPR1_SMP4_Pos) |
| #define | ADC_SMPR1_SMP5_Pos (15U) |
| #define | ADC_SMPR1_SMP5_Msk (0x7UL << ADC_SMPR1_SMP5_Pos) |
| #define | ADC_SMPR1_SMP5 ADC_SMPR1_SMP5_Msk |
| #define | ADC_SMPR1_SMP5_0 (0x1UL << ADC_SMPR1_SMP5_Pos) |
| #define | ADC_SMPR1_SMP5_1 (0x2UL << ADC_SMPR1_SMP5_Pos) |
| #define | ADC_SMPR1_SMP5_2 (0x4UL << ADC_SMPR1_SMP5_Pos) |
| #define | ADC_SMPR1_SMP6_Pos (18U) |
| #define | ADC_SMPR1_SMP6_Msk (0x7UL << ADC_SMPR1_SMP6_Pos) |
| #define | ADC_SMPR1_SMP6 ADC_SMPR1_SMP6_Msk |
| #define | ADC_SMPR1_SMP6_0 (0x1UL << ADC_SMPR1_SMP6_Pos) |
| #define | ADC_SMPR1_SMP6_1 (0x2UL << ADC_SMPR1_SMP6_Pos) |
| #define | ADC_SMPR1_SMP6_2 (0x4UL << ADC_SMPR1_SMP6_Pos) |
| #define | ADC_SMPR1_SMP7_Pos (21U) |
| #define | ADC_SMPR1_SMP7_Msk (0x7UL << ADC_SMPR1_SMP7_Pos) |
| #define | ADC_SMPR1_SMP7 ADC_SMPR1_SMP7_Msk |
| #define | ADC_SMPR1_SMP7_0 (0x1UL << ADC_SMPR1_SMP7_Pos) |
| #define | ADC_SMPR1_SMP7_1 (0x2UL << ADC_SMPR1_SMP7_Pos) |
| #define | ADC_SMPR1_SMP7_2 (0x4UL << ADC_SMPR1_SMP7_Pos) |
| #define | ADC_SMPR1_SMP8_Pos (24U) |
| #define | ADC_SMPR1_SMP8_Msk (0x7UL << ADC_SMPR1_SMP8_Pos) |
| #define | ADC_SMPR1_SMP8 ADC_SMPR1_SMP8_Msk |
| #define | ADC_SMPR1_SMP8_0 (0x1UL << ADC_SMPR1_SMP8_Pos) |
| #define | ADC_SMPR1_SMP8_1 (0x2UL << ADC_SMPR1_SMP8_Pos) |
| #define | ADC_SMPR1_SMP8_2 (0x4UL << ADC_SMPR1_SMP8_Pos) |
| #define | ADC_SMPR1_SMP9_Pos (27U) |
| #define | ADC_SMPR1_SMP9_Msk (0x7UL << ADC_SMPR1_SMP9_Pos) |
| #define | ADC_SMPR1_SMP9 ADC_SMPR1_SMP9_Msk |
| #define | ADC_SMPR1_SMP9_0 (0x1UL << ADC_SMPR1_SMP9_Pos) |
| #define | ADC_SMPR1_SMP9_1 (0x2UL << ADC_SMPR1_SMP9_Pos) |
| #define | ADC_SMPR1_SMP9_2 (0x4UL << ADC_SMPR1_SMP9_Pos) |
| #define | ADC_SMPR2_SMP10_Pos (0U) |
| #define | ADC_SMPR2_SMP10_Msk (0x7UL << ADC_SMPR2_SMP10_Pos) |
| #define | ADC_SMPR2_SMP10 ADC_SMPR2_SMP10_Msk |
| #define | ADC_SMPR2_SMP10_0 (0x1UL << ADC_SMPR2_SMP10_Pos) |
| #define | ADC_SMPR2_SMP10_1 (0x2UL << ADC_SMPR2_SMP10_Pos) |
| #define | ADC_SMPR2_SMP10_2 (0x4UL << ADC_SMPR2_SMP10_Pos) |
| #define | ADC_SMPR2_SMP11_Pos (3U) |
| #define | ADC_SMPR2_SMP11_Msk (0x7UL << ADC_SMPR2_SMP11_Pos) |
| #define | ADC_SMPR2_SMP11 ADC_SMPR2_SMP11_Msk |
| #define | ADC_SMPR2_SMP11_0 (0x1UL << ADC_SMPR2_SMP11_Pos) |
| #define | ADC_SMPR2_SMP11_1 (0x2UL << ADC_SMPR2_SMP11_Pos) |
| #define | ADC_SMPR2_SMP11_2 (0x4UL << ADC_SMPR2_SMP11_Pos) |
| #define | ADC_SMPR2_SMP12_Pos (6U) |
| #define | ADC_SMPR2_SMP12_Msk (0x7UL << ADC_SMPR2_SMP12_Pos) |
| #define | ADC_SMPR2_SMP12 ADC_SMPR2_SMP12_Msk |
| #define | ADC_SMPR2_SMP12_0 (0x1UL << ADC_SMPR2_SMP12_Pos) |
| #define | ADC_SMPR2_SMP12_1 (0x2UL << ADC_SMPR2_SMP12_Pos) |
| #define | ADC_SMPR2_SMP12_2 (0x4UL << ADC_SMPR2_SMP12_Pos) |
| #define | ADC_SMPR2_SMP13_Pos (9U) |
| #define | ADC_SMPR2_SMP13_Msk (0x7UL << ADC_SMPR2_SMP13_Pos) |
| #define | ADC_SMPR2_SMP13 ADC_SMPR2_SMP13_Msk |
| #define | ADC_SMPR2_SMP13_0 (0x1UL << ADC_SMPR2_SMP13_Pos) |
| #define | ADC_SMPR2_SMP13_1 (0x2UL << ADC_SMPR2_SMP13_Pos) |
| #define | ADC_SMPR2_SMP13_2 (0x4UL << ADC_SMPR2_SMP13_Pos) |
| #define | ADC_SMPR2_SMP14_Pos (12U) |
| #define | ADC_SMPR2_SMP14_Msk (0x7UL << ADC_SMPR2_SMP14_Pos) |
| #define | ADC_SMPR2_SMP14 ADC_SMPR2_SMP14_Msk |
| #define | ADC_SMPR2_SMP14_0 (0x1UL << ADC_SMPR2_SMP14_Pos) |
| #define | ADC_SMPR2_SMP14_1 (0x2UL << ADC_SMPR2_SMP14_Pos) |
| #define | ADC_SMPR2_SMP14_2 (0x4UL << ADC_SMPR2_SMP14_Pos) |
| #define | ADC_SMPR2_SMP15_Pos (15U) |
| #define | ADC_SMPR2_SMP15_Msk (0x7UL << ADC_SMPR2_SMP15_Pos) |
| #define | ADC_SMPR2_SMP15 ADC_SMPR2_SMP15_Msk |
| #define | ADC_SMPR2_SMP15_0 (0x1UL << ADC_SMPR2_SMP15_Pos) |
| #define | ADC_SMPR2_SMP15_1 (0x2UL << ADC_SMPR2_SMP15_Pos) |
| #define | ADC_SMPR2_SMP15_2 (0x4UL << ADC_SMPR2_SMP15_Pos) |
| #define | ADC_SMPR2_SMP16_Pos (18U) |
| #define | ADC_SMPR2_SMP16_Msk (0x7UL << ADC_SMPR2_SMP16_Pos) |
| #define | ADC_SMPR2_SMP16 ADC_SMPR2_SMP16_Msk |
| #define | ADC_SMPR2_SMP16_0 (0x1UL << ADC_SMPR2_SMP16_Pos) |
| #define | ADC_SMPR2_SMP16_1 (0x2UL << ADC_SMPR2_SMP16_Pos) |
| #define | ADC_SMPR2_SMP16_2 (0x4UL << ADC_SMPR2_SMP16_Pos) |
| #define | ADC_SMPR2_SMP17_Pos (21U) |
| #define | ADC_SMPR2_SMP17_Msk (0x7UL << ADC_SMPR2_SMP17_Pos) |
| #define | ADC_SMPR2_SMP17 ADC_SMPR2_SMP17_Msk |
| #define | ADC_SMPR2_SMP17_0 (0x1UL << ADC_SMPR2_SMP17_Pos) |
| #define | ADC_SMPR2_SMP17_1 (0x2UL << ADC_SMPR2_SMP17_Pos) |
| #define | ADC_SMPR2_SMP17_2 (0x4UL << ADC_SMPR2_SMP17_Pos) |
| #define | ADC_SMPR2_SMP18_Pos (24U) |
| #define | ADC_SMPR2_SMP18_Msk (0x7UL << ADC_SMPR2_SMP18_Pos) |
| #define | ADC_SMPR2_SMP18 ADC_SMPR2_SMP18_Msk |
| #define | ADC_SMPR2_SMP18_0 (0x1UL << ADC_SMPR2_SMP18_Pos) |
| #define | ADC_SMPR2_SMP18_1 (0x2UL << ADC_SMPR2_SMP18_Pos) |
| #define | ADC_SMPR2_SMP18_2 (0x4UL << ADC_SMPR2_SMP18_Pos) |
| #define | ADC_SMPR2_SMP19_Pos (27U) |
| #define | ADC_SMPR2_SMP19_Msk (0x7UL << ADC_SMPR2_SMP19_Pos) |
| #define | ADC_SMPR2_SMP19 ADC_SMPR2_SMP19_Msk |
| #define | ADC_SMPR2_SMP19_0 (0x1UL << ADC_SMPR2_SMP19_Pos) |
| #define | ADC_SMPR2_SMP19_1 (0x2UL << ADC_SMPR2_SMP19_Pos) |
| #define | ADC_SMPR2_SMP19_2 (0x4UL << ADC_SMPR2_SMP19_Pos) |
| #define | ADC_PCSEL_PCSEL_Pos (0U) |
| #define | ADC_PCSEL_PCSEL_Msk (0xFFFFFUL << ADC_PCSEL_PCSEL_Pos) |
| #define | ADC_PCSEL_PCSEL ADC_PCSEL_PCSEL_Msk |
| #define | ADC_PCSEL_PCSEL_0 (0x00001UL << ADC_PCSEL_PCSEL_Pos) |
| #define | ADC_PCSEL_PCSEL_1 (0x00002UL << ADC_PCSEL_PCSEL_Pos) |
| #define | ADC_PCSEL_PCSEL_2 (0x00004UL << ADC_PCSEL_PCSEL_Pos) |
| #define | ADC_PCSEL_PCSEL_3 (0x00008UL << ADC_PCSEL_PCSEL_Pos) |
| #define | ADC_PCSEL_PCSEL_4 (0x00010UL << ADC_PCSEL_PCSEL_Pos) |
| #define | ADC_PCSEL_PCSEL_5 (0x00020UL << ADC_PCSEL_PCSEL_Pos) |
| #define | ADC_PCSEL_PCSEL_6 (0x00040UL << ADC_PCSEL_PCSEL_Pos) |
| #define | ADC_PCSEL_PCSEL_7 (0x00080UL << ADC_PCSEL_PCSEL_Pos) |
| #define | ADC_PCSEL_PCSEL_8 (0x00100UL << ADC_PCSEL_PCSEL_Pos) |
| #define | ADC_PCSEL_PCSEL_9 (0x00200UL << ADC_PCSEL_PCSEL_Pos) |
| #define | ADC_PCSEL_PCSEL_10 (0x00400UL << ADC_PCSEL_PCSEL_Pos) |
| #define | ADC_PCSEL_PCSEL_11 (0x00800UL << ADC_PCSEL_PCSEL_Pos) |
| #define | ADC_PCSEL_PCSEL_12 (0x01000UL << ADC_PCSEL_PCSEL_Pos) |
| #define | ADC_PCSEL_PCSEL_13 (0x02000UL << ADC_PCSEL_PCSEL_Pos) |
| #define | ADC_PCSEL_PCSEL_14 (0x04000UL << ADC_PCSEL_PCSEL_Pos) |
| #define | ADC_PCSEL_PCSEL_15 (0x08000UL << ADC_PCSEL_PCSEL_Pos) |
| #define | ADC_PCSEL_PCSEL_16 (0x10000UL << ADC_PCSEL_PCSEL_Pos) |
| #define | ADC_PCSEL_PCSEL_17 (0x20000UL << ADC_PCSEL_PCSEL_Pos) |
| #define | ADC_PCSEL_PCSEL_18 (0x40000UL << ADC_PCSEL_PCSEL_Pos) |
| #define | ADC_PCSEL_PCSEL_19 (0x80000UL << ADC_PCSEL_PCSEL_Pos) |
| #define | ADC_LTR_LT_Pos (0U) |
| #define | ADC_LTR_LT_Msk (0x3FFFFFFUL << ADC_LTR_LT_Pos) |
| #define | ADC_LTR_LT ADC_LTR_LT_Msk |
| #define | ADC_HTR_HT_Pos (0U) |
| #define | ADC_HTR_HT_Msk (0x3FFFFFFUL << ADC_HTR_HT_Pos) |
| #define | ADC_HTR_HT ADC_HTR_HT_Msk |
| #define | ADC_SQR1_L_Pos (0U) |
| #define | ADC_SQR1_L_Msk (0xFUL << ADC_SQR1_L_Pos) |
| #define | ADC_SQR1_L ADC_SQR1_L_Msk |
| #define | ADC_SQR1_L_0 (0x1UL << ADC_SQR1_L_Pos) |
| #define | ADC_SQR1_L_1 (0x2UL << ADC_SQR1_L_Pos) |
| #define | ADC_SQR1_L_2 (0x4UL << ADC_SQR1_L_Pos) |
| #define | ADC_SQR1_L_3 (0x8UL << ADC_SQR1_L_Pos) |
| #define | ADC_SQR1_SQ1_Pos (6U) |
| #define | ADC_SQR1_SQ1_Msk (0x1FUL << ADC_SQR1_SQ1_Pos) |
| #define | ADC_SQR1_SQ1 ADC_SQR1_SQ1_Msk |
| #define | ADC_SQR1_SQ1_0 (0x01UL << ADC_SQR1_SQ1_Pos) |
| #define | ADC_SQR1_SQ1_1 (0x02UL << ADC_SQR1_SQ1_Pos) |
| #define | ADC_SQR1_SQ1_2 (0x04UL << ADC_SQR1_SQ1_Pos) |
| #define | ADC_SQR1_SQ1_3 (0x08UL << ADC_SQR1_SQ1_Pos) |
| #define | ADC_SQR1_SQ1_4 (0x10UL << ADC_SQR1_SQ1_Pos) |
| #define | ADC_SQR1_SQ2_Pos (12U) |
| #define | ADC_SQR1_SQ2_Msk (0x1FUL << ADC_SQR1_SQ2_Pos) |
| #define | ADC_SQR1_SQ2 ADC_SQR1_SQ2_Msk |
| #define | ADC_SQR1_SQ2_0 (0x01UL << ADC_SQR1_SQ2_Pos) |
| #define | ADC_SQR1_SQ2_1 (0x02UL << ADC_SQR1_SQ2_Pos) |
| #define | ADC_SQR1_SQ2_2 (0x04UL << ADC_SQR1_SQ2_Pos) |
| #define | ADC_SQR1_SQ2_3 (0x08UL << ADC_SQR1_SQ2_Pos) |
| #define | ADC_SQR1_SQ2_4 (0x10UL << ADC_SQR1_SQ2_Pos) |
| #define | ADC_SQR1_SQ3_Pos (18U) |
| #define | ADC_SQR1_SQ3_Msk (0x1FUL << ADC_SQR1_SQ3_Pos) |
| #define | ADC_SQR1_SQ3 ADC_SQR1_SQ3_Msk |
| #define | ADC_SQR1_SQ3_0 (0x01UL << ADC_SQR1_SQ3_Pos) |
| #define | ADC_SQR1_SQ3_1 (0x02UL << ADC_SQR1_SQ3_Pos) |
| #define | ADC_SQR1_SQ3_2 (0x04UL << ADC_SQR1_SQ3_Pos) |
| #define | ADC_SQR1_SQ3_3 (0x08UL << ADC_SQR1_SQ3_Pos) |
| #define | ADC_SQR1_SQ3_4 (0x10UL << ADC_SQR1_SQ3_Pos) |
| #define | ADC_SQR1_SQ4_Pos (24U) |
| #define | ADC_SQR1_SQ4_Msk (0x1FUL << ADC_SQR1_SQ4_Pos) |
| #define | ADC_SQR1_SQ4 ADC_SQR1_SQ4_Msk |
| #define | ADC_SQR1_SQ4_0 (0x01UL << ADC_SQR1_SQ4_Pos) |
| #define | ADC_SQR1_SQ4_1 (0x02UL << ADC_SQR1_SQ4_Pos) |
| #define | ADC_SQR1_SQ4_2 (0x04UL << ADC_SQR1_SQ4_Pos) |
| #define | ADC_SQR1_SQ4_3 (0x08UL << ADC_SQR1_SQ4_Pos) |
| #define | ADC_SQR1_SQ4_4 (0x10UL << ADC_SQR1_SQ4_Pos) |
| #define | ADC_SQR2_SQ5_Pos (0U) |
| #define | ADC_SQR2_SQ5_Msk (0x1FUL << ADC_SQR2_SQ5_Pos) |
| #define | ADC_SQR2_SQ5 ADC_SQR2_SQ5_Msk |
| #define | ADC_SQR2_SQ5_0 (0x01UL << ADC_SQR2_SQ5_Pos) |
| #define | ADC_SQR2_SQ5_1 (0x02UL << ADC_SQR2_SQ5_Pos) |
| #define | ADC_SQR2_SQ5_2 (0x04UL << ADC_SQR2_SQ5_Pos) |
| #define | ADC_SQR2_SQ5_3 (0x08UL << ADC_SQR2_SQ5_Pos) |
| #define | ADC_SQR2_SQ5_4 (0x10UL << ADC_SQR2_SQ5_Pos) |
| #define | ADC_SQR2_SQ6_Pos (6U) |
| #define | ADC_SQR2_SQ6_Msk (0x1FUL << ADC_SQR2_SQ6_Pos) |
| #define | ADC_SQR2_SQ6 ADC_SQR2_SQ6_Msk |
| #define | ADC_SQR2_SQ6_0 (0x01UL << ADC_SQR2_SQ6_Pos) |
| #define | ADC_SQR2_SQ6_1 (0x02UL << ADC_SQR2_SQ6_Pos) |
| #define | ADC_SQR2_SQ6_2 (0x04UL << ADC_SQR2_SQ6_Pos) |
| #define | ADC_SQR2_SQ6_3 (0x08UL << ADC_SQR2_SQ6_Pos) |
| #define | ADC_SQR2_SQ6_4 (0x10UL << ADC_SQR2_SQ6_Pos) |
| #define | ADC_SQR2_SQ7_Pos (12U) |
| #define | ADC_SQR2_SQ7_Msk (0x1FUL << ADC_SQR2_SQ7_Pos) |
| #define | ADC_SQR2_SQ7 ADC_SQR2_SQ7_Msk |
| #define | ADC_SQR2_SQ7_0 (0x01UL << ADC_SQR2_SQ7_Pos) |
| #define | ADC_SQR2_SQ7_1 (0x02UL << ADC_SQR2_SQ7_Pos) |
| #define | ADC_SQR2_SQ7_2 (0x04UL << ADC_SQR2_SQ7_Pos) |
| #define | ADC_SQR2_SQ7_3 (0x08UL << ADC_SQR2_SQ7_Pos) |
| #define | ADC_SQR2_SQ7_4 (0x10UL << ADC_SQR2_SQ7_Pos) |
| #define | ADC_SQR2_SQ8_Pos (18U) |
| #define | ADC_SQR2_SQ8_Msk (0x1FUL << ADC_SQR2_SQ8_Pos) |
| #define | ADC_SQR2_SQ8 ADC_SQR2_SQ8_Msk |
| #define | ADC_SQR2_SQ8_0 (0x01UL << ADC_SQR2_SQ8_Pos) |
| #define | ADC_SQR2_SQ8_1 (0x02UL << ADC_SQR2_SQ8_Pos) |
| #define | ADC_SQR2_SQ8_2 (0x04UL << ADC_SQR2_SQ8_Pos) |
| #define | ADC_SQR2_SQ8_3 (0x08UL << ADC_SQR2_SQ8_Pos) |
| #define | ADC_SQR2_SQ8_4 (0x10UL << ADC_SQR2_SQ8_Pos) |
| #define | ADC_SQR2_SQ9_Pos (24U) |
| #define | ADC_SQR2_SQ9_Msk (0x1FUL << ADC_SQR2_SQ9_Pos) |
| #define | ADC_SQR2_SQ9 ADC_SQR2_SQ9_Msk |
| #define | ADC_SQR2_SQ9_0 (0x01UL << ADC_SQR2_SQ9_Pos) |
| #define | ADC_SQR2_SQ9_1 (0x02UL << ADC_SQR2_SQ9_Pos) |
| #define | ADC_SQR2_SQ9_2 (0x04UL << ADC_SQR2_SQ9_Pos) |
| #define | ADC_SQR2_SQ9_3 (0x08UL << ADC_SQR2_SQ9_Pos) |
| #define | ADC_SQR2_SQ9_4 (0x10UL << ADC_SQR2_SQ9_Pos) |
| #define | ADC_SQR3_SQ10_Pos (0U) |
| #define | ADC_SQR3_SQ10_Msk (0x1FUL << ADC_SQR3_SQ10_Pos) |
| #define | ADC_SQR3_SQ10 ADC_SQR3_SQ10_Msk |
| #define | ADC_SQR3_SQ10_0 (0x01UL << ADC_SQR3_SQ10_Pos) |
| #define | ADC_SQR3_SQ10_1 (0x02UL << ADC_SQR3_SQ10_Pos) |
| #define | ADC_SQR3_SQ10_2 (0x04UL << ADC_SQR3_SQ10_Pos) |
| #define | ADC_SQR3_SQ10_3 (0x08UL << ADC_SQR3_SQ10_Pos) |
| #define | ADC_SQR3_SQ10_4 (0x10UL << ADC_SQR3_SQ10_Pos) |
| #define | ADC_SQR3_SQ11_Pos (6U) |
| #define | ADC_SQR3_SQ11_Msk (0x1FUL << ADC_SQR3_SQ11_Pos) |
| #define | ADC_SQR3_SQ11 ADC_SQR3_SQ11_Msk |
| #define | ADC_SQR3_SQ11_0 (0x01UL << ADC_SQR3_SQ11_Pos) |
| #define | ADC_SQR3_SQ11_1 (0x02UL << ADC_SQR3_SQ11_Pos) |
| #define | ADC_SQR3_SQ11_2 (0x04UL << ADC_SQR3_SQ11_Pos) |
| #define | ADC_SQR3_SQ11_3 (0x08UL << ADC_SQR3_SQ11_Pos) |
| #define | ADC_SQR3_SQ11_4 (0x10UL << ADC_SQR3_SQ11_Pos) |
| #define | ADC_SQR3_SQ12_Pos (12U) |
| #define | ADC_SQR3_SQ12_Msk (0x1FUL << ADC_SQR3_SQ12_Pos) |
| #define | ADC_SQR3_SQ12 ADC_SQR3_SQ12_Msk |
| #define | ADC_SQR3_SQ12_0 (0x01UL << ADC_SQR3_SQ12_Pos) |
| #define | ADC_SQR3_SQ12_1 (0x02UL << ADC_SQR3_SQ12_Pos) |
| #define | ADC_SQR3_SQ12_2 (0x04UL << ADC_SQR3_SQ12_Pos) |
| #define | ADC_SQR3_SQ12_3 (0x08UL << ADC_SQR3_SQ12_Pos) |
| #define | ADC_SQR3_SQ12_4 (0x10UL << ADC_SQR3_SQ12_Pos) |
| #define | ADC_SQR3_SQ13_Pos (18U) |
| #define | ADC_SQR3_SQ13_Msk (0x1FUL << ADC_SQR3_SQ13_Pos) |
| #define | ADC_SQR3_SQ13 ADC_SQR3_SQ13_Msk |
| #define | ADC_SQR3_SQ13_0 (0x01UL << ADC_SQR3_SQ13_Pos) |
| #define | ADC_SQR3_SQ13_1 (0x02UL << ADC_SQR3_SQ13_Pos) |
| #define | ADC_SQR3_SQ13_2 (0x04UL << ADC_SQR3_SQ13_Pos) |
| #define | ADC_SQR3_SQ13_3 (0x08UL << ADC_SQR3_SQ13_Pos) |
| #define | ADC_SQR3_SQ13_4 (0x10UL << ADC_SQR3_SQ13_Pos) |
| #define | ADC_SQR3_SQ14_Pos (24U) |
| #define | ADC_SQR3_SQ14_Msk (0x1FUL << ADC_SQR3_SQ14_Pos) |
| #define | ADC_SQR3_SQ14 ADC_SQR3_SQ14_Msk |
| #define | ADC_SQR3_SQ14_0 (0x01UL << ADC_SQR3_SQ14_Pos) |
| #define | ADC_SQR3_SQ14_1 (0x02UL << ADC_SQR3_SQ14_Pos) |
| #define | ADC_SQR3_SQ14_2 (0x04UL << ADC_SQR3_SQ14_Pos) |
| #define | ADC_SQR3_SQ14_3 (0x08UL << ADC_SQR3_SQ14_Pos) |
| #define | ADC_SQR3_SQ14_4 (0x10UL << ADC_SQR3_SQ14_Pos) |
| #define | ADC_SQR4_SQ15_Pos (0U) |
| #define | ADC_SQR4_SQ15_Msk (0x1FUL << ADC_SQR4_SQ15_Pos) |
| #define | ADC_SQR4_SQ15 ADC_SQR4_SQ15_Msk |
| #define | ADC_SQR4_SQ15_0 (0x01UL << ADC_SQR4_SQ15_Pos) |
| #define | ADC_SQR4_SQ15_1 (0x02UL << ADC_SQR4_SQ15_Pos) |
| #define | ADC_SQR4_SQ15_2 (0x04UL << ADC_SQR4_SQ15_Pos) |
| #define | ADC_SQR4_SQ15_3 (0x08UL << ADC_SQR4_SQ15_Pos) |
| #define | ADC_SQR4_SQ15_4 (0x10UL << ADC_SQR4_SQ15_Pos) |
| #define | ADC_SQR4_SQ16_Pos (6U) |
| #define | ADC_SQR4_SQ16_Msk (0x1FUL << ADC_SQR4_SQ16_Pos) |
| #define | ADC_SQR4_SQ16 ADC_SQR4_SQ16_Msk |
| #define | ADC_SQR4_SQ16_0 (0x01UL << ADC_SQR4_SQ16_Pos) |
| #define | ADC_SQR4_SQ16_1 (0x02UL << ADC_SQR4_SQ16_Pos) |
| #define | ADC_SQR4_SQ16_2 (0x04UL << ADC_SQR4_SQ16_Pos) |
| #define | ADC_SQR4_SQ16_3 (0x08UL << ADC_SQR4_SQ16_Pos) |
| #define | ADC_SQR4_SQ16_4 (0x10UL << ADC_SQR4_SQ16_Pos) |
| #define | ADC_DR_RDATA_Pos (0U) |
| #define | ADC_DR_RDATA_Msk (0xFFFFFFFFUL << ADC_DR_RDATA_Pos) |
| #define | ADC_DR_RDATA ADC_DR_RDATA_Msk |
| #define | ADC_JSQR_JL_Pos (0U) |
| #define | ADC_JSQR_JL_Msk (0x3UL << ADC_JSQR_JL_Pos) |
| #define | ADC_JSQR_JL ADC_JSQR_JL_Msk |
| #define | ADC_JSQR_JL_0 (0x1UL << ADC_JSQR_JL_Pos) |
| #define | ADC_JSQR_JL_1 (0x2UL << ADC_JSQR_JL_Pos) |
| #define | ADC_JSQR_JEXTSEL_Pos (2U) |
| #define | ADC_JSQR_JEXTSEL_Msk (0x1FUL << ADC_JSQR_JEXTSEL_Pos) |
| #define | ADC_JSQR_JEXTSEL ADC_JSQR_JEXTSEL_Msk |
| #define | ADC_JSQR_JEXTSEL_0 (0x01UL << ADC_JSQR_JEXTSEL_Pos) |
| #define | ADC_JSQR_JEXTSEL_1 (0x02UL << ADC_JSQR_JEXTSEL_Pos) |
| #define | ADC_JSQR_JEXTSEL_2 (0x04UL << ADC_JSQR_JEXTSEL_Pos) |
| #define | ADC_JSQR_JEXTSEL_3 (0x08UL << ADC_JSQR_JEXTSEL_Pos) |
| #define | ADC_JSQR_JEXTSEL_4 (0x10UL << ADC_JSQR_JEXTSEL_Pos) |
| #define | ADC_JSQR_JEXTEN_Pos (7U) |
| #define | ADC_JSQR_JEXTEN_Msk (0x3UL << ADC_JSQR_JEXTEN_Pos) |
| #define | ADC_JSQR_JEXTEN ADC_JSQR_JEXTEN_Msk |
| #define | ADC_JSQR_JEXTEN_0 (0x1UL << ADC_JSQR_JEXTEN_Pos) |
| #define | ADC_JSQR_JEXTEN_1 (0x2UL << ADC_JSQR_JEXTEN_Pos) |
| #define | ADC_JSQR_JSQ1_Pos (9U) |
| #define | ADC_JSQR_JSQ1_Msk (0x1FUL << ADC_JSQR_JSQ1_Pos) |
| #define | ADC_JSQR_JSQ1 ADC_JSQR_JSQ1_Msk |
| #define | ADC_JSQR_JSQ1_0 (0x01UL << ADC_JSQR_JSQ1_Pos) |
| #define | ADC_JSQR_JSQ1_1 (0x02UL << ADC_JSQR_JSQ1_Pos) |
| #define | ADC_JSQR_JSQ1_2 (0x04UL << ADC_JSQR_JSQ1_Pos) |
| #define | ADC_JSQR_JSQ1_3 (0x08UL << ADC_JSQR_JSQ1_Pos) |
| #define | ADC_JSQR_JSQ1_4 (0x10UL << ADC_JSQR_JSQ1_Pos) |
| #define | ADC_JSQR_JSQ2_Pos (15U) |
| #define | ADC_JSQR_JSQ2_Msk (0x1FUL << ADC_JSQR_JSQ2_Pos) |
| #define | ADC_JSQR_JSQ2 ADC_JSQR_JSQ2_Msk |
| #define | ADC_JSQR_JSQ2_0 (0x01UL << ADC_JSQR_JSQ2_Pos) |
| #define | ADC_JSQR_JSQ2_1 (0x02UL << ADC_JSQR_JSQ2_Pos) |
| #define | ADC_JSQR_JSQ2_2 (0x04UL << ADC_JSQR_JSQ2_Pos) |
| #define | ADC_JSQR_JSQ2_3 (0x08UL << ADC_JSQR_JSQ2_Pos) |
| #define | ADC_JSQR_JSQ2_4 (0x10UL << ADC_JSQR_JSQ2_Pos) |
| #define | ADC_JSQR_JSQ3_Pos (21U) |
| #define | ADC_JSQR_JSQ3_Msk (0x1FUL << ADC_JSQR_JSQ3_Pos) |
| #define | ADC_JSQR_JSQ3 ADC_JSQR_JSQ3_Msk |
| #define | ADC_JSQR_JSQ3_0 (0x01UL << ADC_JSQR_JSQ3_Pos) |
| #define | ADC_JSQR_JSQ3_1 (0x02UL << ADC_JSQR_JSQ3_Pos) |
| #define | ADC_JSQR_JSQ3_2 (0x04UL << ADC_JSQR_JSQ3_Pos) |
| #define | ADC_JSQR_JSQ3_3 (0x08UL << ADC_JSQR_JSQ3_Pos) |
| #define | ADC_JSQR_JSQ3_4 (0x10UL << ADC_JSQR_JSQ3_Pos) |
| #define | ADC_JSQR_JSQ4_Pos (27U) |
| #define | ADC_JSQR_JSQ4_Msk (0x1FUL << ADC_JSQR_JSQ4_Pos) |
| #define | ADC_JSQR_JSQ4 ADC_JSQR_JSQ4_Msk |
| #define | ADC_JSQR_JSQ4_0 (0x01UL << ADC_JSQR_JSQ4_Pos) |
| #define | ADC_JSQR_JSQ4_1 (0x02UL << ADC_JSQR_JSQ4_Pos) |
| #define | ADC_JSQR_JSQ4_2 (0x04UL << ADC_JSQR_JSQ4_Pos) |
| #define | ADC_JSQR_JSQ4_3 (0x08UL << ADC_JSQR_JSQ4_Pos) |
| #define | ADC_JSQR_JSQ4_4 (0x10UL << ADC_JSQR_JSQ4_Pos) |
| #define | ADC_OFR1_OFFSET1_Pos (0U) |
| #define | ADC_OFR1_OFFSET1_Msk (0x3FFFFFFUL << ADC_OFR1_OFFSET1_Pos) |
| #define | ADC_OFR1_OFFSET1 ADC_OFR1_OFFSET1_Msk |
| #define | ADC_OFR1_OFFSET1_0 (0x0000001UL << ADC_OFR1_OFFSET1_Pos) |
| #define | ADC_OFR1_OFFSET1_1 (0x0000002UL << ADC_OFR1_OFFSET1_Pos) |
| #define | ADC_OFR1_OFFSET1_2 (0x0000004UL << ADC_OFR1_OFFSET1_Pos) |
| #define | ADC_OFR1_OFFSET1_3 (0x0000008UL << ADC_OFR1_OFFSET1_Pos) |
| #define | ADC_OFR1_OFFSET1_4 (0x0000010UL << ADC_OFR1_OFFSET1_Pos) |
| #define | ADC_OFR1_OFFSET1_5 (0x0000020UL << ADC_OFR1_OFFSET1_Pos) |
| #define | ADC_OFR1_OFFSET1_6 (0x0000040UL << ADC_OFR1_OFFSET1_Pos) |
| #define | ADC_OFR1_OFFSET1_7 (0x0000080UL << ADC_OFR1_OFFSET1_Pos) |
| #define | ADC_OFR1_OFFSET1_8 (0x0000100UL << ADC_OFR1_OFFSET1_Pos) |
| #define | ADC_OFR1_OFFSET1_9 (0x0000200UL << ADC_OFR1_OFFSET1_Pos) |
| #define | ADC_OFR1_OFFSET1_10 (0x0000400UL << ADC_OFR1_OFFSET1_Pos) |
| #define | ADC_OFR1_OFFSET1_11 (0x0000800UL << ADC_OFR1_OFFSET1_Pos) |
| #define | ADC_OFR1_OFFSET1_12 (0x0001000UL << ADC_OFR1_OFFSET1_Pos) |
| #define | ADC_OFR1_OFFSET1_13 (0x0002000UL << ADC_OFR1_OFFSET1_Pos) |
| #define | ADC_OFR1_OFFSET1_14 (0x0004000UL << ADC_OFR1_OFFSET1_Pos) |
| #define | ADC_OFR1_OFFSET1_15 (0x0008000UL << ADC_OFR1_OFFSET1_Pos) |
| #define | ADC_OFR1_OFFSET1_16 (0x0010000UL << ADC_OFR1_OFFSET1_Pos) |
| #define | ADC_OFR1_OFFSET1_17 (0x0020000UL << ADC_OFR1_OFFSET1_Pos) |
| #define | ADC_OFR1_OFFSET1_18 (0x0040000UL << ADC_OFR1_OFFSET1_Pos) |
| #define | ADC_OFR1_OFFSET1_19 (0x0080000UL << ADC_OFR1_OFFSET1_Pos) |
| #define | ADC_OFR1_OFFSET1_20 (0x0100000UL << ADC_OFR1_OFFSET1_Pos) |
| #define | ADC_OFR1_OFFSET1_21 (0x0200000UL << ADC_OFR1_OFFSET1_Pos) |
| #define | ADC_OFR1_OFFSET1_22 (0x0400000UL << ADC_OFR1_OFFSET1_Pos) |
| #define | ADC_OFR1_OFFSET1_23 (0x0800000UL << ADC_OFR1_OFFSET1_Pos) |
| #define | ADC_OFR1_OFFSET1_24 (0x1000000UL << ADC_OFR1_OFFSET1_Pos) |
| #define | ADC_OFR1_OFFSET1_25 (0x2000000UL << ADC_OFR1_OFFSET1_Pos) |
| #define | ADC_OFR1_OFFSET1_CH_Pos (26U) |
| #define | ADC_OFR1_OFFSET1_CH_Msk (0x1FUL << ADC_OFR1_OFFSET1_CH_Pos) |
| #define | ADC_OFR1_OFFSET1_CH ADC_OFR1_OFFSET1_CH_Msk |
| #define | ADC_OFR1_OFFSET1_CH_0 (0x01UL << ADC_OFR1_OFFSET1_CH_Pos) |
| #define | ADC_OFR1_OFFSET1_CH_1 (0x02UL << ADC_OFR1_OFFSET1_CH_Pos) |
| #define | ADC_OFR1_OFFSET1_CH_2 (0x04UL << ADC_OFR1_OFFSET1_CH_Pos) |
| #define | ADC_OFR1_OFFSET1_CH_3 (0x08UL << ADC_OFR1_OFFSET1_CH_Pos) |
| #define | ADC_OFR1_OFFSET1_CH_4 (0x10UL << ADC_OFR1_OFFSET1_CH_Pos) |
| #define | ADC_OFR1_SSATE_Pos (31U) |
| #define | ADC_OFR1_SSATE_Msk (0x1UL << ADC_OFR1_SSATE_Pos) |
| #define | ADC_OFR1_SSATE ADC_OFR1_SSATE_Msk |
| #define | ADC_OFR2_OFFSET2_Pos (0U) |
| #define | ADC_OFR2_OFFSET2_Msk (0x3FFFFFFUL << ADC_OFR2_OFFSET2_Pos) |
| #define | ADC_OFR2_OFFSET2 ADC_OFR2_OFFSET2_Msk |
| #define | ADC_OFR2_OFFSET2_0 (0x0000001UL << ADC_OFR2_OFFSET2_Pos) |
| #define | ADC_OFR2_OFFSET2_1 (0x0000002UL << ADC_OFR2_OFFSET2_Pos) |
| #define | ADC_OFR2_OFFSET2_2 (0x0000004UL << ADC_OFR2_OFFSET2_Pos) |
| #define | ADC_OFR2_OFFSET2_3 (0x0000008UL << ADC_OFR2_OFFSET2_Pos) |
| #define | ADC_OFR2_OFFSET2_4 (0x0000010UL << ADC_OFR2_OFFSET2_Pos) |
| #define | ADC_OFR2_OFFSET2_5 (0x0000020UL << ADC_OFR2_OFFSET2_Pos) |
| #define | ADC_OFR2_OFFSET2_6 (0x0000040UL << ADC_OFR2_OFFSET2_Pos) |
| #define | ADC_OFR2_OFFSET2_7 (0x0000080UL << ADC_OFR2_OFFSET2_Pos) |
| #define | ADC_OFR2_OFFSET2_8 (0x0000100UL << ADC_OFR2_OFFSET2_Pos) |
| #define | ADC_OFR2_OFFSET2_9 (0x0000200UL << ADC_OFR2_OFFSET2_Pos) |
| #define | ADC_OFR2_OFFSET2_10 (0x0000400UL << ADC_OFR2_OFFSET2_Pos) |
| #define | ADC_OFR2_OFFSET2_11 (0x0000800UL << ADC_OFR2_OFFSET2_Pos) |
| #define | ADC_OFR2_OFFSET2_12 (0x0001000UL << ADC_OFR2_OFFSET2_Pos) |
| #define | ADC_OFR2_OFFSET2_13 (0x0002000UL << ADC_OFR2_OFFSET2_Pos) |
| #define | ADC_OFR2_OFFSET2_14 (0x0004000UL << ADC_OFR2_OFFSET2_Pos) |
| #define | ADC_OFR2_OFFSET2_15 (0x0008000UL << ADC_OFR2_OFFSET2_Pos) |
| #define | ADC_OFR2_OFFSET2_16 (0x0010000UL << ADC_OFR2_OFFSET2_Pos) |
| #define | ADC_OFR2_OFFSET2_17 (0x0020000UL << ADC_OFR2_OFFSET2_Pos) |
| #define | ADC_OFR2_OFFSET2_18 (0x0040000UL << ADC_OFR2_OFFSET2_Pos) |
| #define | ADC_OFR2_OFFSET2_19 (0x0080000UL << ADC_OFR2_OFFSET2_Pos) |
| #define | ADC_OFR2_OFFSET2_20 (0x0100000UL << ADC_OFR2_OFFSET2_Pos) |
| #define | ADC_OFR2_OFFSET2_21 (0x0200000UL << ADC_OFR2_OFFSET2_Pos) |
| #define | ADC_OFR2_OFFSET2_22 (0x0400000UL << ADC_OFR2_OFFSET2_Pos) |
| #define | ADC_OFR2_OFFSET2_23 (0x0800000UL << ADC_OFR2_OFFSET2_Pos) |
| #define | ADC_OFR2_OFFSET2_24 (0x1000000UL << ADC_OFR2_OFFSET2_Pos) |
| #define | ADC_OFR2_OFFSET2_25 (0x2000000UL << ADC_OFR2_OFFSET2_Pos) |
| #define | ADC_OFR2_OFFSET2_CH_Pos (26U) |
| #define | ADC_OFR2_OFFSET2_CH_Msk (0x1FUL << ADC_OFR2_OFFSET2_CH_Pos) |
| #define | ADC_OFR2_OFFSET2_CH ADC_OFR2_OFFSET2_CH_Msk |
| #define | ADC_OFR2_OFFSET2_CH_0 (0x01UL << ADC_OFR2_OFFSET2_CH_Pos) |
| #define | ADC_OFR2_OFFSET2_CH_1 (0x02UL << ADC_OFR2_OFFSET2_CH_Pos) |
| #define | ADC_OFR2_OFFSET2_CH_2 (0x04UL << ADC_OFR2_OFFSET2_CH_Pos) |
| #define | ADC_OFR2_OFFSET2_CH_3 (0x08UL << ADC_OFR2_OFFSET2_CH_Pos) |
| #define | ADC_OFR2_OFFSET2_CH_4 (0x10UL << ADC_OFR2_OFFSET2_CH_Pos) |
| #define | ADC_OFR2_SSATE_Pos (31U) |
| #define | ADC_OFR2_SSATE_Msk (0x1UL << ADC_OFR2_SSATE_Pos) |
| #define | ADC_OFR2_SSATE ADC_OFR2_SSATE_Msk |
| #define | ADC_OFR3_OFFSET3_Pos (0U) |
| #define | ADC_OFR3_OFFSET3_Msk (0x3FFFFFFUL << ADC_OFR3_OFFSET3_Pos) |
| #define | ADC_OFR3_OFFSET3 ADC_OFR3_OFFSET3_Msk |
| #define | ADC_OFR3_OFFSET3_0 (0x0000001UL << ADC_OFR3_OFFSET3_Pos) |
| #define | ADC_OFR3_OFFSET3_1 (0x0000002UL << ADC_OFR3_OFFSET3_Pos) |
| #define | ADC_OFR3_OFFSET3_2 (0x0000004UL << ADC_OFR3_OFFSET3_Pos) |
| #define | ADC_OFR3_OFFSET3_3 (0x0000008UL << ADC_OFR3_OFFSET3_Pos) |
| #define | ADC_OFR3_OFFSET3_4 (0x0000010UL << ADC_OFR3_OFFSET3_Pos) |
| #define | ADC_OFR3_OFFSET3_5 (0x0000020UL << ADC_OFR3_OFFSET3_Pos) |
| #define | ADC_OFR3_OFFSET3_6 (0x0000040UL << ADC_OFR3_OFFSET3_Pos) |
| #define | ADC_OFR3_OFFSET3_7 (0x0000080UL << ADC_OFR3_OFFSET3_Pos) |
| #define | ADC_OFR3_OFFSET3_8 (0x0000100UL << ADC_OFR3_OFFSET3_Pos) |
| #define | ADC_OFR3_OFFSET3_9 (0x0000200UL << ADC_OFR3_OFFSET3_Pos) |
| #define | ADC_OFR3_OFFSET3_10 (0x0000400UL << ADC_OFR3_OFFSET3_Pos) |
| #define | ADC_OFR3_OFFSET3_11 (0x0000800UL << ADC_OFR3_OFFSET3_Pos) |
| #define | ADC_OFR3_OFFSET3_12 (0x0001000UL << ADC_OFR3_OFFSET3_Pos) |
| #define | ADC_OFR3_OFFSET3_13 (0x0002000UL << ADC_OFR3_OFFSET3_Pos) |
| #define | ADC_OFR3_OFFSET3_14 (0x0004000UL << ADC_OFR3_OFFSET3_Pos) |
| #define | ADC_OFR3_OFFSET3_15 (0x0008000UL << ADC_OFR3_OFFSET3_Pos) |
| #define | ADC_OFR3_OFFSET3_16 (0x0010000UL << ADC_OFR3_OFFSET3_Pos) |
| #define | ADC_OFR3_OFFSET3_17 (0x0020000UL << ADC_OFR3_OFFSET3_Pos) |
| #define | ADC_OFR3_OFFSET3_18 (0x0040000UL << ADC_OFR3_OFFSET3_Pos) |
| #define | ADC_OFR3_OFFSET3_19 (0x0080000UL << ADC_OFR3_OFFSET3_Pos) |
| #define | ADC_OFR3_OFFSET3_20 (0x0100000UL << ADC_OFR3_OFFSET3_Pos) |
| #define | ADC_OFR3_OFFSET3_21 (0x0200000UL << ADC_OFR3_OFFSET3_Pos) |
| #define | ADC_OFR3_OFFSET3_22 (0x0400000UL << ADC_OFR3_OFFSET3_Pos) |
| #define | ADC_OFR3_OFFSET3_23 (0x0800000UL << ADC_OFR3_OFFSET3_Pos) |
| #define | ADC_OFR3_OFFSET3_24 (0x1000000UL << ADC_OFR3_OFFSET3_Pos) |
| #define | ADC_OFR3_OFFSET3_25 (0x2000000UL << ADC_OFR3_OFFSET3_Pos) |
| #define | ADC_OFR3_OFFSET3_CH_Pos (26U) |
| #define | ADC_OFR3_OFFSET3_CH_Msk (0x1FUL << ADC_OFR3_OFFSET3_CH_Pos) |
| #define | ADC_OFR3_OFFSET3_CH ADC_OFR3_OFFSET3_CH_Msk |
| #define | ADC_OFR3_OFFSET3_CH_0 (0x01UL << ADC_OFR3_OFFSET3_CH_Pos) |
| #define | ADC_OFR3_OFFSET3_CH_1 (0x02UL << ADC_OFR3_OFFSET3_CH_Pos) |
| #define | ADC_OFR3_OFFSET3_CH_2 (0x04UL << ADC_OFR3_OFFSET3_CH_Pos) |
| #define | ADC_OFR3_OFFSET3_CH_3 (0x08UL << ADC_OFR3_OFFSET3_CH_Pos) |
| #define | ADC_OFR3_OFFSET3_CH_4 (0x10UL << ADC_OFR3_OFFSET3_CH_Pos) |
| #define | ADC_OFR3_SSATE_Pos (31U) |
| #define | ADC_OFR3_SSATE_Msk (0x1UL << ADC_OFR3_SSATE_Pos) |
| #define | ADC_OFR3_SSATE ADC_OFR3_SSATE_Msk |
| #define | ADC_OFR4_OFFSET4_Pos (0U) |
| #define | ADC_OFR4_OFFSET4_Msk (0x3FFFFFFUL << ADC_OFR4_OFFSET4_Pos) |
| #define | ADC_OFR4_OFFSET4 ADC_OFR4_OFFSET4_Msk |
| #define | ADC_OFR4_OFFSET4_0 (0x0000001UL << ADC_OFR4_OFFSET4_Pos) |
| #define | ADC_OFR4_OFFSET4_1 (0x0000002UL << ADC_OFR4_OFFSET4_Pos) |
| #define | ADC_OFR4_OFFSET4_2 (0x0000004UL << ADC_OFR4_OFFSET4_Pos) |
| #define | ADC_OFR4_OFFSET4_3 (0x0000008UL << ADC_OFR4_OFFSET4_Pos) |
| #define | ADC_OFR4_OFFSET4_4 (0x0000010UL << ADC_OFR4_OFFSET4_Pos) |
| #define | ADC_OFR4_OFFSET4_5 (0x0000020UL << ADC_OFR4_OFFSET4_Pos) |
| #define | ADC_OFR4_OFFSET4_6 (0x0000040UL << ADC_OFR4_OFFSET4_Pos) |
| #define | ADC_OFR4_OFFSET4_7 (0x0000080UL << ADC_OFR4_OFFSET4_Pos) |
| #define | ADC_OFR4_OFFSET4_8 (0x0000100UL << ADC_OFR4_OFFSET4_Pos) |
| #define | ADC_OFR4_OFFSET4_9 (0x0000200UL << ADC_OFR4_OFFSET4_Pos) |
| #define | ADC_OFR4_OFFSET4_10 (0x0000400UL << ADC_OFR4_OFFSET4_Pos) |
| #define | ADC_OFR4_OFFSET4_11 (0x0000800UL << ADC_OFR4_OFFSET4_Pos) |
| #define | ADC_OFR4_OFFSET4_12 (0x0001000UL << ADC_OFR4_OFFSET4_Pos) |
| #define | ADC_OFR4_OFFSET4_13 (0x0002000UL << ADC_OFR4_OFFSET4_Pos) |
| #define | ADC_OFR4_OFFSET4_14 (0x0004000UL << ADC_OFR4_OFFSET4_Pos) |
| #define | ADC_OFR4_OFFSET4_15 (0x0008000UL << ADC_OFR4_OFFSET4_Pos) |
| #define | ADC_OFR4_OFFSET4_16 (0x0010000UL << ADC_OFR4_OFFSET4_Pos) |
| #define | ADC_OFR4_OFFSET4_17 (0x0020000UL << ADC_OFR4_OFFSET4_Pos) |
| #define | ADC_OFR4_OFFSET4_18 (0x0040000UL << ADC_OFR4_OFFSET4_Pos) |
| #define | ADC_OFR4_OFFSET4_19 (0x0080000UL << ADC_OFR4_OFFSET4_Pos) |
| #define | ADC_OFR4_OFFSET4_20 (0x0100000UL << ADC_OFR4_OFFSET4_Pos) |
| #define | ADC_OFR4_OFFSET4_21 (0x0200000UL << ADC_OFR4_OFFSET4_Pos) |
| #define | ADC_OFR4_OFFSET4_22 (0x0400000UL << ADC_OFR4_OFFSET4_Pos) |
| #define | ADC_OFR4_OFFSET4_23 (0x0800000UL << ADC_OFR4_OFFSET4_Pos) |
| #define | ADC_OFR4_OFFSET4_24 (0x1000000UL << ADC_OFR4_OFFSET4_Pos) |
| #define | ADC_OFR4_OFFSET4_25 (0x2000000UL << ADC_OFR4_OFFSET4_Pos) |
| #define | ADC_OFR4_OFFSET4_CH_Pos (26U) |
| #define | ADC_OFR4_OFFSET4_CH_Msk (0x1FUL << ADC_OFR4_OFFSET4_CH_Pos) |
| #define | ADC_OFR4_OFFSET4_CH ADC_OFR4_OFFSET4_CH_Msk |
| #define | ADC_OFR4_OFFSET4_CH_0 (0x01UL << ADC_OFR4_OFFSET4_CH_Pos) |
| #define | ADC_OFR4_OFFSET4_CH_1 (0x02UL << ADC_OFR4_OFFSET4_CH_Pos) |
| #define | ADC_OFR4_OFFSET4_CH_2 (0x04UL << ADC_OFR4_OFFSET4_CH_Pos) |
| #define | ADC_OFR4_OFFSET4_CH_3 (0x08UL << ADC_OFR4_OFFSET4_CH_Pos) |
| #define | ADC_OFR4_OFFSET4_CH_4 (0x10UL << ADC_OFR4_OFFSET4_CH_Pos) |
| #define | ADC_OFR4_SSATE_Pos (31U) |
| #define | ADC_OFR4_SSATE_Msk (0x1UL << ADC_OFR4_SSATE_Pos) |
| #define | ADC_OFR4_SSATE ADC_OFR4_SSATE_Msk |
| #define | ADC_JDR1_JDATA_Pos (0U) |
| #define | ADC_JDR1_JDATA_Msk (0xFFFFFFFFUL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR1_JDATA ADC_JDR1_JDATA_Msk |
| #define | ADC_JDR1_JDATA_0 (0x00000001UL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR1_JDATA_1 (0x00000002UL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR1_JDATA_2 (0x00000004UL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR1_JDATA_3 (0x00000008UL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR1_JDATA_4 (0x00000010UL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR1_JDATA_5 (0x00000020UL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR1_JDATA_6 (0x00000040UL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR1_JDATA_7 (0x00000080UL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR1_JDATA_8 (0x00000100UL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR1_JDATA_9 (0x00000200UL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR1_JDATA_10 (0x00000400UL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR1_JDATA_11 (0x00000800UL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR1_JDATA_12 (0x00001000UL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR1_JDATA_13 (0x00002000UL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR1_JDATA_14 (0x00004000UL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR1_JDATA_15 (0x00008000UL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR1_JDATA_16 (0x00010000UL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR1_JDATA_17 (0x00020000UL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR1_JDATA_18 (0x00040000UL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR1_JDATA_19 (0x00080000UL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR1_JDATA_20 (0x00100000UL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR1_JDATA_21 (0x00200000UL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR1_JDATA_22 (0x00400000UL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR1_JDATA_23 (0x00800000UL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR1_JDATA_24 (0x01000000UL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR1_JDATA_25 (0x02000000UL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR1_JDATA_26 (0x04000000UL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR1_JDATA_27 (0x08000000UL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR1_JDATA_28 (0x10000000UL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR1_JDATA_29 (0x20000000UL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR1_JDATA_30 (0x40000000UL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR1_JDATA_31 (0x80000000UL << ADC_JDR1_JDATA_Pos) |
| #define | ADC_JDR2_JDATA_Pos (0U) |
| #define | ADC_JDR2_JDATA_Msk (0xFFFFFFFFUL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR2_JDATA ADC_JDR2_JDATA_Msk |
| #define | ADC_JDR2_JDATA_0 (0x00000001UL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR2_JDATA_1 (0x00000002UL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR2_JDATA_2 (0x00000004UL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR2_JDATA_3 (0x00000008UL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR2_JDATA_4 (0x00000010UL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR2_JDATA_5 (0x00000020UL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR2_JDATA_6 (0x00000040UL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR2_JDATA_7 (0x00000080UL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR2_JDATA_8 (0x00000100UL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR2_JDATA_9 (0x00000200UL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR2_JDATA_10 (0x00000400UL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR2_JDATA_11 (0x00000800UL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR2_JDATA_12 (0x00001000UL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR2_JDATA_13 (0x00002000UL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR2_JDATA_14 (0x00004000UL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR2_JDATA_15 (0x00008000UL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR2_JDATA_16 (0x00010000UL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR2_JDATA_17 (0x00020000UL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR2_JDATA_18 (0x00040000UL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR2_JDATA_19 (0x00080000UL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR2_JDATA_20 (0x00100000UL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR2_JDATA_21 (0x00200000UL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR2_JDATA_22 (0x00400000UL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR2_JDATA_23 (0x00800000UL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR2_JDATA_24 (0x01000000UL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR2_JDATA_25 (0x02000000UL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR2_JDATA_26 (0x04000000UL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR2_JDATA_27 (0x08000000UL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR2_JDATA_28 (0x10000000UL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR2_JDATA_29 (0x20000000UL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR2_JDATA_30 (0x40000000UL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR2_JDATA_31 (0x80000000UL << ADC_JDR2_JDATA_Pos) |
| #define | ADC_JDR3_JDATA_Pos (0U) |
| #define | ADC_JDR3_JDATA_Msk (0xFFFFFFFFUL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR3_JDATA ADC_JDR3_JDATA_Msk |
| #define | ADC_JDR3_JDATA_0 (0x00000001UL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR3_JDATA_1 (0x00000002UL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR3_JDATA_2 (0x00000004UL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR3_JDATA_3 (0x00000008UL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR3_JDATA_4 (0x00000010UL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR3_JDATA_5 (0x00000020UL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR3_JDATA_6 (0x00000040UL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR3_JDATA_7 (0x00000080UL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR3_JDATA_8 (0x00000100UL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR3_JDATA_9 (0x00000200UL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR3_JDATA_10 (0x00000400UL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR3_JDATA_11 (0x00000800UL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR3_JDATA_12 (0x00001000UL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR3_JDATA_13 (0x00002000UL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR3_JDATA_14 (0x00004000UL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR3_JDATA_15 (0x00008000UL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR3_JDATA_16 (0x00010000UL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR3_JDATA_17 (0x00020000UL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR3_JDATA_18 (0x00040000UL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR3_JDATA_19 (0x00080000UL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR3_JDATA_20 (0x00100000UL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR3_JDATA_21 (0x00200000UL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR3_JDATA_22 (0x00400000UL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR3_JDATA_23 (0x00800000UL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR3_JDATA_24 (0x01000000UL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR3_JDATA_25 (0x02000000UL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR3_JDATA_26 (0x04000000UL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR3_JDATA_27 (0x08000000UL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR3_JDATA_28 (0x10000000UL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR3_JDATA_29 (0x20000000UL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR3_JDATA_30 (0x40000000UL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR3_JDATA_31 (0x80000000UL << ADC_JDR3_JDATA_Pos) |
| #define | ADC_JDR4_JDATA_Pos (0U) |
| #define | ADC_JDR4_JDATA_Msk (0xFFFFFFFFUL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_JDR4_JDATA ADC_JDR4_JDATA_Msk |
| #define | ADC_JDR4_JDATA_0 (0x00000001UL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_JDR4_JDATA_1 (0x00000002UL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_JDR4_JDATA_2 (0x00000004UL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_JDR4_JDATA_3 (0x00000008UL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_JDR4_JDATA_4 (0x00000010UL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_JDR4_JDATA_5 (0x00000020UL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_JDR4_JDATA_6 (0x00000040UL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_JDR4_JDATA_7 (0x00000080UL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_JDR4_JDATA_8 (0x00000100UL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_JDR4_JDATA_9 (0x00000200UL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_JDR4_JDATA_10 (0x00000400UL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_JDR4_JDATA_11 (0x00000800UL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_JDR4_JDATA_12 (0x00001000UL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_JDR4_JDATA_13 (0x00002000UL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_JDR4_JDATA_14 (0x00004000UL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_JDR4_JDATA_15 (0x00008000UL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_JDR4_JDATA_16 (0x00010000UL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_JDR4_JDATA_17 (0x00020000UL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_JDR4_JDATA_18 (0x00040000UL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_JDR4_JDATA_19 (0x00080000UL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_JDR4_JDATA_20 (0x00100000UL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_JDR4_JDATA_21 (0x00200000UL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_JDR4_JDATA_22 (0x00400000UL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_JDR4_JDATA_23 (0x00800000UL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_JDR4_JDATA_24 (0x01000000UL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_JDR4_JDATA_25 (0x02000000UL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_JDR4_JDATA_26 (0x04000000UL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_JDR4_JDATA_27 (0x08000000UL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_JDR4_JDATA_28 (0x10000000UL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_JDR4_JDATA_29 (0x20000000UL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_JDR4_JDATA_30 (0x40000000UL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_JDR4_JDATA_31 (0x80000000UL << ADC_JDR4_JDATA_Pos) |
| #define | ADC_AWD2CR_AWD2CH_Pos (0U) |
| #define | ADC_AWD2CR_AWD2CH_Msk (0xFFFFFUL << ADC_AWD2CR_AWD2CH_Pos) |
| #define | ADC_AWD2CR_AWD2CH ADC_AWD2CR_AWD2CH_Msk |
| #define | ADC_AWD2CR_AWD2CH_0 (0x00001UL << ADC_AWD2CR_AWD2CH_Pos) |
| #define | ADC_AWD2CR_AWD2CH_1 (0x00002UL << ADC_AWD2CR_AWD2CH_Pos) |
| #define | ADC_AWD2CR_AWD2CH_2 (0x00004UL << ADC_AWD2CR_AWD2CH_Pos) |
| #define | ADC_AWD2CR_AWD2CH_3 (0x00008UL << ADC_AWD2CR_AWD2CH_Pos) |
| #define | ADC_AWD2CR_AWD2CH_4 (0x00010UL << ADC_AWD2CR_AWD2CH_Pos) |
| #define | ADC_AWD2CR_AWD2CH_5 (0x00020UL << ADC_AWD2CR_AWD2CH_Pos) |
| #define | ADC_AWD2CR_AWD2CH_6 (0x00040UL << ADC_AWD2CR_AWD2CH_Pos) |
| #define | ADC_AWD2CR_AWD2CH_7 (0x00080UL << ADC_AWD2CR_AWD2CH_Pos) |
| #define | ADC_AWD2CR_AWD2CH_8 (0x00100UL << ADC_AWD2CR_AWD2CH_Pos) |
| #define | ADC_AWD2CR_AWD2CH_9 (0x00200UL << ADC_AWD2CR_AWD2CH_Pos) |
| #define | ADC_AWD2CR_AWD2CH_10 (0x00400UL << ADC_AWD2CR_AWD2CH_Pos) |
| #define | ADC_AWD2CR_AWD2CH_11 (0x00800UL << ADC_AWD2CR_AWD2CH_Pos) |
| #define | ADC_AWD2CR_AWD2CH_12 (0x01000UL << ADC_AWD2CR_AWD2CH_Pos) |
| #define | ADC_AWD2CR_AWD2CH_13 (0x02000UL << ADC_AWD2CR_AWD2CH_Pos) |
| #define | ADC_AWD2CR_AWD2CH_14 (0x04000UL << ADC_AWD2CR_AWD2CH_Pos) |
| #define | ADC_AWD2CR_AWD2CH_15 (0x08000UL << ADC_AWD2CR_AWD2CH_Pos) |
| #define | ADC_AWD2CR_AWD2CH_16 (0x10000UL << ADC_AWD2CR_AWD2CH_Pos) |
| #define | ADC_AWD2CR_AWD2CH_17 (0x20000UL << ADC_AWD2CR_AWD2CH_Pos) |
| #define | ADC_AWD2CR_AWD2CH_18 (0x40000UL << ADC_AWD2CR_AWD2CH_Pos) |
| #define | ADC_AWD2CR_AWD2CH_19 (0x80000UL << ADC_AWD2CR_AWD2CH_Pos) |
| #define | ADC_AWD3CR_AWD3CH_Pos (0U) |
| #define | ADC_AWD3CR_AWD3CH_Msk (0xFFFFFUL << ADC_AWD3CR_AWD3CH_Pos) |
| #define | ADC_AWD3CR_AWD3CH ADC_AWD3CR_AWD3CH_Msk |
| #define | ADC_AWD3CR_AWD3CH_0 (0x00001UL << ADC_AWD3CR_AWD3CH_Pos) |
| #define | ADC_AWD3CR_AWD3CH_1 (0x00002UL << ADC_AWD3CR_AWD3CH_Pos) |
| #define | ADC_AWD3CR_AWD3CH_2 (0x00004UL << ADC_AWD3CR_AWD3CH_Pos) |
| #define | ADC_AWD3CR_AWD3CH_3 (0x00008UL << ADC_AWD3CR_AWD3CH_Pos) |
| #define | ADC_AWD3CR_AWD3CH_4 (0x00010UL << ADC_AWD3CR_AWD3CH_Pos) |
| #define | ADC_AWD3CR_AWD3CH_5 (0x00020UL << ADC_AWD3CR_AWD3CH_Pos) |
| #define | ADC_AWD3CR_AWD3CH_6 (0x00040UL << ADC_AWD3CR_AWD3CH_Pos) |
| #define | ADC_AWD3CR_AWD3CH_7 (0x00080UL << ADC_AWD3CR_AWD3CH_Pos) |
| #define | ADC_AWD3CR_AWD3CH_8 (0x00100UL << ADC_AWD3CR_AWD3CH_Pos) |
| #define | ADC_AWD3CR_AWD3CH_9 (0x00200UL << ADC_AWD3CR_AWD3CH_Pos) |
| #define | ADC_AWD3CR_AWD3CH_10 (0x00400UL << ADC_AWD3CR_AWD3CH_Pos) |
| #define | ADC_AWD3CR_AWD3CH_11 (0x00800UL << ADC_AWD3CR_AWD3CH_Pos) |
| #define | ADC_AWD3CR_AWD3CH_12 (0x01000UL << ADC_AWD3CR_AWD3CH_Pos) |
| #define | ADC_AWD3CR_AWD3CH_13 (0x02000UL << ADC_AWD3CR_AWD3CH_Pos) |
| #define | ADC_AWD3CR_AWD3CH_14 (0x04000UL << ADC_AWD3CR_AWD3CH_Pos) |
| #define | ADC_AWD3CR_AWD3CH_15 (0x08000UL << ADC_AWD3CR_AWD3CH_Pos) |
| #define | ADC_AWD3CR_AWD3CH_16 (0x10000UL << ADC_AWD3CR_AWD3CH_Pos) |
| #define | ADC_AWD3CR_AWD3CH_17 (0x20000UL << ADC_AWD3CR_AWD3CH_Pos) |
| #define | ADC_AWD3CR_AWD3CH_18 (0x40000UL << ADC_AWD3CR_AWD3CH_Pos) |
| #define | ADC_AWD3CR_AWD3CH_19 (0x80000UL << ADC_AWD3CR_AWD3CH_Pos) |
| #define | ADC_DIFSEL_DIFSEL_Pos (0U) |
| #define | ADC_DIFSEL_DIFSEL_Msk (0xFFFFFUL << ADC_DIFSEL_DIFSEL_Pos) |
| #define | ADC_DIFSEL_DIFSEL ADC_DIFSEL_DIFSEL_Msk |
| #define | ADC_DIFSEL_DIFSEL_0 (0x00001UL << ADC_DIFSEL_DIFSEL_Pos) |
| #define | ADC_DIFSEL_DIFSEL_1 (0x00002UL << ADC_DIFSEL_DIFSEL_Pos) |
| #define | ADC_DIFSEL_DIFSEL_2 (0x00004UL << ADC_DIFSEL_DIFSEL_Pos) |
| #define | ADC_DIFSEL_DIFSEL_3 (0x00008UL << ADC_DIFSEL_DIFSEL_Pos) |
| #define | ADC_DIFSEL_DIFSEL_4 (0x00010UL << ADC_DIFSEL_DIFSEL_Pos) |
| #define | ADC_DIFSEL_DIFSEL_5 (0x00020UL << ADC_DIFSEL_DIFSEL_Pos) |
| #define | ADC_DIFSEL_DIFSEL_6 (0x00040UL << ADC_DIFSEL_DIFSEL_Pos) |
| #define | ADC_DIFSEL_DIFSEL_7 (0x00080UL << ADC_DIFSEL_DIFSEL_Pos) |
| #define | ADC_DIFSEL_DIFSEL_8 (0x00100UL << ADC_DIFSEL_DIFSEL_Pos) |
| #define | ADC_DIFSEL_DIFSEL_9 (0x00200UL << ADC_DIFSEL_DIFSEL_Pos) |
| #define | ADC_DIFSEL_DIFSEL_10 (0x00400UL << ADC_DIFSEL_DIFSEL_Pos) |
| #define | ADC_DIFSEL_DIFSEL_11 (0x00800UL << ADC_DIFSEL_DIFSEL_Pos) |
| #define | ADC_DIFSEL_DIFSEL_12 (0x01000UL << ADC_DIFSEL_DIFSEL_Pos) |
| #define | ADC_DIFSEL_DIFSEL_13 (0x02000UL << ADC_DIFSEL_DIFSEL_Pos) |
| #define | ADC_DIFSEL_DIFSEL_14 (0x04000UL << ADC_DIFSEL_DIFSEL_Pos) |
| #define | ADC_DIFSEL_DIFSEL_15 (0x08000UL << ADC_DIFSEL_DIFSEL_Pos) |
| #define | ADC_DIFSEL_DIFSEL_16 (0x10000UL << ADC_DIFSEL_DIFSEL_Pos) |
| #define | ADC_DIFSEL_DIFSEL_17 (0x20000UL << ADC_DIFSEL_DIFSEL_Pos) |
| #define | ADC_DIFSEL_DIFSEL_18 (0x40000UL << ADC_DIFSEL_DIFSEL_Pos) |
| #define | ADC_DIFSEL_DIFSEL_19 (0x80000UL << ADC_DIFSEL_DIFSEL_Pos) |
| #define | ADC_CALFACT_CALFACT_S_Pos (0U) |
| #define | ADC_CALFACT_CALFACT_S_Msk (0x7FFUL << ADC_CALFACT_CALFACT_S_Pos) |
| #define | ADC_CALFACT_CALFACT_S ADC_CALFACT_CALFACT_S_Msk |
| #define | ADC_CALFACT_CALFACT_S_0 (0x001UL << ADC_CALFACT_CALFACT_S_Pos) |
| #define | ADC_CALFACT_CALFACT_S_1 (0x002UL << ADC_CALFACT_CALFACT_S_Pos) |
| #define | ADC_CALFACT_CALFACT_S_2 (0x004UL << ADC_CALFACT_CALFACT_S_Pos) |
| #define | ADC_CALFACT_CALFACT_S_3 (0x008UL << ADC_CALFACT_CALFACT_S_Pos) |
| #define | ADC_CALFACT_CALFACT_S_4 (0x010UL << ADC_CALFACT_CALFACT_S_Pos) |
| #define | ADC_CALFACT_CALFACT_S_5 (0x020UL << ADC_CALFACT_CALFACT_S_Pos) |
| #define | ADC_CALFACT_CALFACT_S_6 (0x040UL << ADC_CALFACT_CALFACT_S_Pos) |
| #define | ADC_CALFACT_CALFACT_S_7 (0x080UL << ADC_CALFACT_CALFACT_S_Pos) |
| #define | ADC_CALFACT_CALFACT_S_8 (0x100UL << ADC_CALFACT_CALFACT_S_Pos) |
| #define | ADC_CALFACT_CALFACT_S_9 (0x200UL << ADC_CALFACT_CALFACT_S_Pos) |
| #define | ADC_CALFACT_CALFACT_S_10 (0x400UL << ADC_CALFACT_CALFACT_S_Pos) |
| #define | ADC_CALFACT_CALFACT_D_Pos (16U) |
| #define | ADC_CALFACT_CALFACT_D_Msk (0x7FFUL << ADC_CALFACT_CALFACT_D_Pos) |
| #define | ADC_CALFACT_CALFACT_D ADC_CALFACT_CALFACT_D_Msk |
| #define | ADC_CALFACT_CALFACT_D_0 (0x001UL << ADC_CALFACT_CALFACT_D_Pos) |
| #define | ADC_CALFACT_CALFACT_D_1 (0x002UL << ADC_CALFACT_CALFACT_D_Pos) |
| #define | ADC_CALFACT_CALFACT_D_2 (0x004UL << ADC_CALFACT_CALFACT_D_Pos) |
| #define | ADC_CALFACT_CALFACT_D_3 (0x008UL << ADC_CALFACT_CALFACT_D_Pos) |
| #define | ADC_CALFACT_CALFACT_D_4 (0x010UL << ADC_CALFACT_CALFACT_D_Pos) |
| #define | ADC_CALFACT_CALFACT_D_5 (0x020UL << ADC_CALFACT_CALFACT_D_Pos) |
| #define | ADC_CALFACT_CALFACT_D_6 (0x040UL << ADC_CALFACT_CALFACT_D_Pos) |
| #define | ADC_CALFACT_CALFACT_D_7 (0x080UL << ADC_CALFACT_CALFACT_D_Pos) |
| #define | ADC_CALFACT_CALFACT_D_8 (0x100UL << ADC_CALFACT_CALFACT_D_Pos) |
| #define | ADC_CALFACT_CALFACT_D_9 (0x200UL << ADC_CALFACT_CALFACT_D_Pos) |
| #define | ADC_CALFACT_CALFACT_D_10 (0x400UL << ADC_CALFACT_CALFACT_D_Pos) |
| #define | ADC_CALFACT2_LINCALFACT_Pos (0U) |
| #define | ADC_CALFACT2_LINCALFACT_Msk (0x3FFFFFFFUL << ADC_CALFACT2_LINCALFACT_Pos) |
| #define | ADC_CALFACT2_LINCALFACT ADC_CALFACT2_LINCALFACT_Msk |
| #define | ADC_CALFACT2_LINCALFACT_0 (0x00000001UL << ADC_CALFACT2_LINCALFACT_Pos) |
| #define | ADC_CALFACT2_LINCALFACT_1 (0x00000002UL << ADC_CALFACT2_LINCALFACT_Pos) |
| #define | ADC_CALFACT2_LINCALFACT_2 (0x00000004UL << ADC_CALFACT2_LINCALFACT_Pos) |
| #define | ADC_CALFACT2_LINCALFACT_3 (0x00000008UL << ADC_CALFACT2_LINCALFACT_Pos) |
| #define | ADC_CALFACT2_LINCALFACT_4 (0x00000010UL << ADC_CALFACT2_LINCALFACT_Pos) |
| #define | ADC_CALFACT2_LINCALFACT_5 (0x00000020UL << ADC_CALFACT2_LINCALFACT_Pos) |
| #define | ADC_CALFACT2_LINCALFACT_6 (0x00000040UL << ADC_CALFACT2_LINCALFACT_Pos) |
| #define | ADC_CALFACT2_LINCALFACT_7 (0x00000080UL << ADC_CALFACT2_LINCALFACT_Pos) |
| #define | ADC_CALFACT2_LINCALFACT_8 (0x00000100UL << ADC_CALFACT2_LINCALFACT_Pos) |
| #define | ADC_CALFACT2_LINCALFACT_9 (0x00000200UL << ADC_CALFACT2_LINCALFACT_Pos) |
| #define | ADC_CALFACT2_LINCALFACT_10 (0x00000400UL << ADC_CALFACT2_LINCALFACT_Pos) |
| #define | ADC_CALFACT2_LINCALFACT_11 (0x00000800UL << ADC_CALFACT2_LINCALFACT_Pos) |
| #define | ADC_CALFACT2_LINCALFACT_12 (0x00001000UL << ADC_CALFACT2_LINCALFACT_Pos) |
| #define | ADC_CALFACT2_LINCALFACT_13 (0x00002000UL << ADC_CALFACT2_LINCALFACT_Pos) |
| #define | ADC_CALFACT2_LINCALFACT_14 (0x00004000UL << ADC_CALFACT2_LINCALFACT_Pos) |
| #define | ADC_CALFACT2_LINCALFACT_15 (0x00008000UL << ADC_CALFACT2_LINCALFACT_Pos) |
| #define | ADC_CALFACT2_LINCALFACT_16 (0x00010000UL << ADC_CALFACT2_LINCALFACT_Pos) |
| #define | ADC_CALFACT2_LINCALFACT_17 (0x00020000UL << ADC_CALFACT2_LINCALFACT_Pos) |
| #define | ADC_CALFACT2_LINCALFACT_18 (0x00040000UL << ADC_CALFACT2_LINCALFACT_Pos) |
| #define | ADC_CALFACT2_LINCALFACT_19 (0x00080000UL << ADC_CALFACT2_LINCALFACT_Pos) |
| #define | ADC_CALFACT2_LINCALFACT_20 (0x00100000UL << ADC_CALFACT2_LINCALFACT_Pos) |
| #define | ADC_CALFACT2_LINCALFACT_21 (0x00200000UL << ADC_CALFACT2_LINCALFACT_Pos) |
| #define | ADC_CALFACT2_LINCALFACT_22 (0x00400000UL << ADC_CALFACT2_LINCALFACT_Pos) |
| #define | ADC_CALFACT2_LINCALFACT_23 (0x00800000UL << ADC_CALFACT2_LINCALFACT_Pos) |
| #define | ADC_CALFACT2_LINCALFACT_24 (0x01000000UL << ADC_CALFACT2_LINCALFACT_Pos) |
| #define | ADC_CALFACT2_LINCALFACT_25 (0x02000000UL << ADC_CALFACT2_LINCALFACT_Pos) |
| #define | ADC_CALFACT2_LINCALFACT_26 (0x04000000UL << ADC_CALFACT2_LINCALFACT_Pos) |
| #define | ADC_CALFACT2_LINCALFACT_27 (0x08000000UL << ADC_CALFACT2_LINCALFACT_Pos) |
| #define | ADC_CALFACT2_LINCALFACT_28 (0x10000000UL << ADC_CALFACT2_LINCALFACT_Pos) |
| #define | ADC_CALFACT2_LINCALFACT_29 (0x20000000UL << ADC_CALFACT2_LINCALFACT_Pos) |
| #define | ADC_CSR_ADRDY_MST_Pos (0U) |
| #define | ADC_CSR_ADRDY_MST_Msk (0x1UL << ADC_CSR_ADRDY_MST_Pos) |
| #define | ADC_CSR_ADRDY_MST ADC_CSR_ADRDY_MST_Msk |
| #define | ADC_CSR_EOSMP_MST_Pos (1U) |
| #define | ADC_CSR_EOSMP_MST_Msk (0x1UL << ADC_CSR_EOSMP_MST_Pos) |
| #define | ADC_CSR_EOSMP_MST ADC_CSR_EOSMP_MST_Msk |
| #define | ADC_CSR_EOC_MST_Pos (2U) |
| #define | ADC_CSR_EOC_MST_Msk (0x1UL << ADC_CSR_EOC_MST_Pos) |
| #define | ADC_CSR_EOC_MST ADC_CSR_EOC_MST_Msk |
| #define | ADC_CSR_EOS_MST_Pos (3U) |
| #define | ADC_CSR_EOS_MST_Msk (0x1UL << ADC_CSR_EOS_MST_Pos) |
| #define | ADC_CSR_EOS_MST ADC_CSR_EOS_MST_Msk |
| #define | ADC_CSR_OVR_MST_Pos (4U) |
| #define | ADC_CSR_OVR_MST_Msk (0x1UL << ADC_CSR_OVR_MST_Pos) |
| #define | ADC_CSR_OVR_MST ADC_CSR_OVR_MST_Msk |
| #define | ADC_CSR_JEOC_MST_Pos (5U) |
| #define | ADC_CSR_JEOC_MST_Msk (0x1UL << ADC_CSR_JEOC_MST_Pos) |
| #define | ADC_CSR_JEOC_MST ADC_CSR_JEOC_MST_Msk |
| #define | ADC_CSR_JEOS_MST_Pos (6U) |
| #define | ADC_CSR_JEOS_MST_Msk (0x1UL << ADC_CSR_JEOS_MST_Pos) |
| #define | ADC_CSR_JEOS_MST ADC_CSR_JEOS_MST_Msk |
| #define | ADC_CSR_AWD1_MST_Pos (7U) |
| #define | ADC_CSR_AWD1_MST_Msk (0x1UL << ADC_CSR_AWD1_MST_Pos) |
| #define | ADC_CSR_AWD1_MST ADC_CSR_AWD1_MST_Msk |
| #define | ADC_CSR_AWD2_MST_Pos (8U) |
| #define | ADC_CSR_AWD2_MST_Msk (0x1UL << ADC_CSR_AWD2_MST_Pos) |
| #define | ADC_CSR_AWD2_MST ADC_CSR_AWD2_MST_Msk |
| #define | ADC_CSR_AWD3_MST_Pos (9U) |
| #define | ADC_CSR_AWD3_MST_Msk (0x1UL << ADC_CSR_AWD3_MST_Pos) |
| #define | ADC_CSR_AWD3_MST ADC_CSR_AWD3_MST_Msk |
| #define | ADC_CSR_JQOVF_MST_Pos (10U) |
| #define | ADC_CSR_JQOVF_MST_Msk (0x1UL << ADC_CSR_JQOVF_MST_Pos) |
| #define | ADC_CSR_JQOVF_MST ADC_CSR_JQOVF_MST_Msk |
| #define | ADC_CSR_ADRDY_SLV_Pos (16U) |
| #define | ADC_CSR_ADRDY_SLV_Msk (0x1UL << ADC_CSR_ADRDY_SLV_Pos) |
| #define | ADC_CSR_ADRDY_SLV ADC_CSR_ADRDY_SLV_Msk |
| #define | ADC_CSR_EOSMP_SLV_Pos (17U) |
| #define | ADC_CSR_EOSMP_SLV_Msk (0x1UL << ADC_CSR_EOSMP_SLV_Pos) |
| #define | ADC_CSR_EOSMP_SLV ADC_CSR_EOSMP_SLV_Msk |
| #define | ADC_CSR_EOC_SLV_Pos (18U) |
| #define | ADC_CSR_EOC_SLV_Msk (0x1UL << ADC_CSR_EOC_SLV_Pos) |
| #define | ADC_CSR_EOC_SLV ADC_CSR_EOC_SLV_Msk |
| #define | ADC_CSR_EOS_SLV_Pos (19U) |
| #define | ADC_CSR_EOS_SLV_Msk (0x1UL << ADC_CSR_EOS_SLV_Pos) |
| #define | ADC_CSR_EOS_SLV ADC_CSR_EOS_SLV_Msk |
| #define | ADC_CSR_OVR_SLV_Pos (20U) |
| #define | ADC_CSR_OVR_SLV_Msk (0x1UL << ADC_CSR_OVR_SLV_Pos) |
| #define | ADC_CSR_OVR_SLV ADC_CSR_OVR_SLV_Msk |
| #define | ADC_CSR_JEOC_SLV_Pos (21U) |
| #define | ADC_CSR_JEOC_SLV_Msk (0x1UL << ADC_CSR_JEOC_SLV_Pos) |
| #define | ADC_CSR_JEOC_SLV ADC_CSR_JEOC_SLV_Msk |
| #define | ADC_CSR_JEOS_SLV_Pos (22U) |
| #define | ADC_CSR_JEOS_SLV_Msk (0x1UL << ADC_CSR_JEOS_SLV_Pos) |
| #define | ADC_CSR_JEOS_SLV ADC_CSR_JEOS_SLV_Msk |
| #define | ADC_CSR_AWD1_SLV_Pos (23U) |
| #define | ADC_CSR_AWD1_SLV_Msk (0x1UL << ADC_CSR_AWD1_SLV_Pos) |
| #define | ADC_CSR_AWD1_SLV ADC_CSR_AWD1_SLV_Msk |
| #define | ADC_CSR_AWD2_SLV_Pos (24U) |
| #define | ADC_CSR_AWD2_SLV_Msk (0x1UL << ADC_CSR_AWD2_SLV_Pos) |
| #define | ADC_CSR_AWD2_SLV ADC_CSR_AWD2_SLV_Msk |
| #define | ADC_CSR_AWD3_SLV_Pos (25U) |
| #define | ADC_CSR_AWD3_SLV_Msk (0x1UL << ADC_CSR_AWD3_SLV_Pos) |
| #define | ADC_CSR_AWD3_SLV ADC_CSR_AWD3_SLV_Msk |
| #define | ADC_CSR_JQOVF_SLV_Pos (26U) |
| #define | ADC_CSR_JQOVF_SLV_Msk (0x1UL << ADC_CSR_JQOVF_SLV_Pos) |
| #define | ADC_CSR_JQOVF_SLV ADC_CSR_JQOVF_SLV_Msk |
| #define | ADC_CCR_DUAL_Pos (0U) |
| #define | ADC_CCR_DUAL_Msk (0x1FUL << ADC_CCR_DUAL_Pos) |
| #define | ADC_CCR_DUAL ADC_CCR_DUAL_Msk |
| #define | ADC_CCR_DUAL_0 (0x01UL << ADC_CCR_DUAL_Pos) |
| #define | ADC_CCR_DUAL_1 (0x02UL << ADC_CCR_DUAL_Pos) |
| #define | ADC_CCR_DUAL_2 (0x04UL << ADC_CCR_DUAL_Pos) |
| #define | ADC_CCR_DUAL_3 (0x08UL << ADC_CCR_DUAL_Pos) |
| #define | ADC_CCR_DUAL_4 (0x10UL << ADC_CCR_DUAL_Pos) |
| #define | ADC_CCR_DELAY_Pos (8U) |
| #define | ADC_CCR_DELAY_Msk (0xFUL << ADC_CCR_DELAY_Pos) |
| #define | ADC_CCR_DELAY ADC_CCR_DELAY_Msk |
| #define | ADC_CCR_DELAY_0 (0x1UL << ADC_CCR_DELAY_Pos) |
| #define | ADC_CCR_DELAY_1 (0x2UL << ADC_CCR_DELAY_Pos) |
| #define | ADC_CCR_DELAY_2 (0x4UL << ADC_CCR_DELAY_Pos) |
| #define | ADC_CCR_DELAY_3 (0x8UL << ADC_CCR_DELAY_Pos) |
| #define | ADC_CCR_DAMDF_Pos (14U) |
| #define | ADC_CCR_DAMDF_Msk (0x3UL << ADC_CCR_DAMDF_Pos) |
| #define | ADC_CCR_DAMDF ADC_CCR_DAMDF_Msk |
| #define | ADC_CCR_DAMDF_0 (0x1UL << ADC_CCR_DAMDF_Pos) |
| #define | ADC_CCR_DAMDF_1 (0x2UL << ADC_CCR_DAMDF_Pos) |
| #define | ADC_CCR_CKMODE_Pos (16U) |
| #define | ADC_CCR_CKMODE_Msk (0x3UL << ADC_CCR_CKMODE_Pos) |
| #define | ADC_CCR_CKMODE ADC_CCR_CKMODE_Msk |
| #define | ADC_CCR_CKMODE_0 (0x1UL << ADC_CCR_CKMODE_Pos) |
| #define | ADC_CCR_CKMODE_1 (0x2UL << ADC_CCR_CKMODE_Pos) |
| #define | ADC_CCR_PRESC_Pos (18U) |
| #define | ADC_CCR_PRESC_Msk (0xFUL << ADC_CCR_PRESC_Pos) |
| #define | ADC_CCR_PRESC ADC_CCR_PRESC_Msk |
| #define | ADC_CCR_PRESC_0 (0x1UL << ADC_CCR_PRESC_Pos) |
| #define | ADC_CCR_PRESC_1 (0x2UL << ADC_CCR_PRESC_Pos) |
| #define | ADC_CCR_PRESC_2 (0x4UL << ADC_CCR_PRESC_Pos) |
| #define | ADC_CCR_PRESC_3 (0x8UL << ADC_CCR_PRESC_Pos) |
| #define | ADC_CCR_VREFEN_Pos (22U) |
| #define | ADC_CCR_VREFEN_Msk (0x1UL << ADC_CCR_VREFEN_Pos) |
| #define | ADC_CCR_VREFEN ADC_CCR_VREFEN_Msk |
| #define | ADC_CCR_TSEN_Pos (23U) |
| #define | ADC_CCR_TSEN_Msk (0x1UL << ADC_CCR_TSEN_Pos) |
| #define | ADC_CCR_TSEN ADC_CCR_TSEN_Msk |
| #define | ADC_CCR_VBATEN_Pos (24U) |
| #define | ADC_CCR_VBATEN_Msk (0x1UL << ADC_CCR_VBATEN_Pos) |
| #define | ADC_CCR_VBATEN ADC_CCR_VBATEN_Msk |
| #define | ADC_CDR_RDATA_MST_Pos (0U) |
| #define | ADC_CDR_RDATA_MST_Msk (0xFFFFUL << ADC_CDR_RDATA_MST_Pos) |
| #define | ADC_CDR_RDATA_MST ADC_CDR_RDATA_MST_Msk |
| #define | ADC_CDR_RDATA_SLV_Pos (16U) |
| #define | ADC_CDR_RDATA_SLV_Msk (0xFFFFUL << ADC_CDR_RDATA_SLV_Pos) |
| #define | ADC_CDR_RDATA_SLV ADC_CDR_RDATA_SLV_Msk |
| #define | ADC_CDR2_RDATA_ALT_Pos (0U) |
| #define | ADC_CDR2_RDATA_ALT_Msk (0xFFFFFFFFUL << ADC_CDR2_RDATA_ALT_Pos) |
| #define | ADC_CDR2_RDATA_ALT ADC_CDR2_RDATA_ALT_Msk |
| #define | VREFBUF_CSR_ENVR_Pos (0U) |
| #define | VREFBUF_CSR_ENVR_Msk (0x1UL << VREFBUF_CSR_ENVR_Pos) |
| #define | VREFBUF_CSR_ENVR VREFBUF_CSR_ENVR_Msk |
| #define | VREFBUF_CSR_HIZ_Pos (1U) |
| #define | VREFBUF_CSR_HIZ_Msk (0x1UL << VREFBUF_CSR_HIZ_Pos) |
| #define | VREFBUF_CSR_HIZ VREFBUF_CSR_HIZ_Msk |
| #define | VREFBUF_CSR_VRR_Pos (3U) |
| #define | VREFBUF_CSR_VRR_Msk (0x1UL << VREFBUF_CSR_VRR_Pos) |
| #define | VREFBUF_CSR_VRR VREFBUF_CSR_VRR_Msk |
| #define | VREFBUF_CSR_VRS_Pos (4U) |
| #define | VREFBUF_CSR_VRS_Msk (0x7UL << VREFBUF_CSR_VRS_Pos) |
| #define | VREFBUF_CSR_VRS VREFBUF_CSR_VRS_Msk |
| #define | VREFBUF_CSR_VRS_OUT1 (0U) |
| #define | VREFBUF_CSR_VRS_OUT2_Pos (4U) |
| #define | VREFBUF_CSR_VRS_OUT2_Msk (0x1UL << VREFBUF_CSR_VRS_OUT2_Pos) |
| #define | VREFBUF_CSR_VRS_OUT2 VREFBUF_CSR_VRS_OUT2_Msk |
| #define | VREFBUF_CSR_VRS_OUT3_Pos (5U) |
| #define | VREFBUF_CSR_VRS_OUT3_Msk (0x1UL << VREFBUF_CSR_VRS_OUT3_Pos) |
| #define | VREFBUF_CSR_VRS_OUT3 VREFBUF_CSR_VRS_OUT3_Msk |
| #define | VREFBUF_CSR_VRS_OUT4_Pos (4U) |
| #define | VREFBUF_CSR_VRS_OUT4_Msk (0x3UL << VREFBUF_CSR_VRS_OUT4_Pos) |
| #define | VREFBUF_CSR_VRS_OUT4 VREFBUF_CSR_VRS_OUT4_Msk |
| #define | VREFBUF_CCR_TRIM_Pos (0U) |
| #define | VREFBUF_CCR_TRIM_Msk (0x3FUL << VREFBUF_CCR_TRIM_Pos) |
| #define | VREFBUF_CCR_TRIM VREFBUF_CCR_TRIM_Msk |
| #define | FDCAN_CREL_DAY_Pos (0U) |
| #define | FDCAN_CREL_DAY_Msk (0xFFUL << FDCAN_CREL_DAY_Pos) |
| #define | FDCAN_CREL_DAY FDCAN_CREL_DAY_Msk |
| #define | FDCAN_CREL_MON_Pos (8U) |
| #define | FDCAN_CREL_MON_Msk (0xFFUL << FDCAN_CREL_MON_Pos) |
| #define | FDCAN_CREL_MON FDCAN_CREL_MON_Msk |
| #define | FDCAN_CREL_YEAR_Pos (16U) |
| #define | FDCAN_CREL_YEAR_Msk (0xFUL << FDCAN_CREL_YEAR_Pos) |
| #define | FDCAN_CREL_YEAR FDCAN_CREL_YEAR_Msk |
| #define | FDCAN_CREL_SUBSTEP_Pos (20U) |
| #define | FDCAN_CREL_SUBSTEP_Msk (0xFUL << FDCAN_CREL_SUBSTEP_Pos) |
| #define | FDCAN_CREL_SUBSTEP FDCAN_CREL_SUBSTEP_Msk |
| #define | FDCAN_CREL_STEP_Pos (24U) |
| #define | FDCAN_CREL_STEP_Msk (0xFUL << FDCAN_CREL_STEP_Pos) |
| #define | FDCAN_CREL_STEP FDCAN_CREL_STEP_Msk |
| #define | FDCAN_CREL_REL_Pos (28U) |
| #define | FDCAN_CREL_REL_Msk (0xFUL << FDCAN_CREL_REL_Pos) |
| #define | FDCAN_CREL_REL FDCAN_CREL_REL_Msk |
| #define | FDCAN_ENDN_ETV_Pos (0U) |
| #define | FDCAN_ENDN_ETV_Msk (0xFFFFFFFFUL << FDCAN_ENDN_ETV_Pos) |
| #define | FDCAN_ENDN_ETV FDCAN_ENDN_ETV_Msk |
| #define | FDCAN_DBTP_DSJW_Pos (0U) |
| #define | FDCAN_DBTP_DSJW_Msk (0xFUL << FDCAN_DBTP_DSJW_Pos) |
| #define | FDCAN_DBTP_DSJW FDCAN_DBTP_DSJW_Msk |
| #define | FDCAN_DBTP_DTSEG2_Pos (4U) |
| #define | FDCAN_DBTP_DTSEG2_Msk (0xFUL << FDCAN_DBTP_DTSEG2_Pos) |
| #define | FDCAN_DBTP_DTSEG2 FDCAN_DBTP_DTSEG2_Msk |
| #define | FDCAN_DBTP_DTSEG1_Pos (8U) |
| #define | FDCAN_DBTP_DTSEG1_Msk (0x1FUL << FDCAN_DBTP_DTSEG1_Pos) |
| #define | FDCAN_DBTP_DTSEG1 FDCAN_DBTP_DTSEG1_Msk |
| #define | FDCAN_DBTP_DBRP_Pos (16U) |
| #define | FDCAN_DBTP_DBRP_Msk (0x1FUL << FDCAN_DBTP_DBRP_Pos) |
| #define | FDCAN_DBTP_DBRP FDCAN_DBTP_DBRP_Msk |
| #define | FDCAN_DBTP_TDC_Pos (23U) |
| #define | FDCAN_DBTP_TDC_Msk (0x1UL << FDCAN_DBTP_TDC_Pos) |
| #define | FDCAN_DBTP_TDC FDCAN_DBTP_TDC_Msk |
| #define | FDCAN_TEST_LBCK_Pos (4U) |
| #define | FDCAN_TEST_LBCK_Msk (0x1UL << FDCAN_TEST_LBCK_Pos) |
| #define | FDCAN_TEST_LBCK FDCAN_TEST_LBCK_Msk |
| #define | FDCAN_TEST_TX_Pos (5U) |
| #define | FDCAN_TEST_TX_Msk (0x3UL << FDCAN_TEST_TX_Pos) |
| #define | FDCAN_TEST_TX FDCAN_TEST_TX_Msk |
| #define | FDCAN_TEST_RX_Pos (7U) |
| #define | FDCAN_TEST_RX_Msk (0x1UL << FDCAN_TEST_RX_Pos) |
| #define | FDCAN_TEST_RX FDCAN_TEST_RX_Msk |
| #define | FDCAN_RWD_WDC_Pos (0U) |
| #define | FDCAN_RWD_WDC_Msk (0xFFUL << FDCAN_RWD_WDC_Pos) |
| #define | FDCAN_RWD_WDC FDCAN_RWD_WDC_Msk |
| #define | FDCAN_RWD_WDV_Pos (8U) |
| #define | FDCAN_RWD_WDV_Msk (0xFFUL << FDCAN_RWD_WDV_Pos) |
| #define | FDCAN_RWD_WDV FDCAN_RWD_WDV_Msk |
| #define | FDCAN_CCCR_INIT_Pos (0U) |
| #define | FDCAN_CCCR_INIT_Msk (0x1UL << FDCAN_CCCR_INIT_Pos) |
| #define | FDCAN_CCCR_INIT FDCAN_CCCR_INIT_Msk |
| #define | FDCAN_CCCR_CCE_Pos (1U) |
| #define | FDCAN_CCCR_CCE_Msk (0x1UL << FDCAN_CCCR_CCE_Pos) |
| #define | FDCAN_CCCR_CCE FDCAN_CCCR_CCE_Msk |
| #define | FDCAN_CCCR_ASM_Pos (2U) |
| #define | FDCAN_CCCR_ASM_Msk (0x1UL << FDCAN_CCCR_ASM_Pos) |
| #define | FDCAN_CCCR_ASM FDCAN_CCCR_ASM_Msk |
| #define | FDCAN_CCCR_CSA_Pos (3U) |
| #define | FDCAN_CCCR_CSA_Msk (0x1UL << FDCAN_CCCR_CSA_Pos) |
| #define | FDCAN_CCCR_CSA FDCAN_CCCR_CSA_Msk |
| #define | FDCAN_CCCR_CSR_Pos (4U) |
| #define | FDCAN_CCCR_CSR_Msk (0x1UL << FDCAN_CCCR_CSR_Pos) |
| #define | FDCAN_CCCR_CSR FDCAN_CCCR_CSR_Msk |
| #define | FDCAN_CCCR_MON_Pos (5U) |
| #define | FDCAN_CCCR_MON_Msk (0x1UL << FDCAN_CCCR_MON_Pos) |
| #define | FDCAN_CCCR_MON FDCAN_CCCR_MON_Msk |
| #define | FDCAN_CCCR_DAR_Pos (6U) |
| #define | FDCAN_CCCR_DAR_Msk (0x1UL << FDCAN_CCCR_DAR_Pos) |
| #define | FDCAN_CCCR_DAR FDCAN_CCCR_DAR_Msk |
| #define | FDCAN_CCCR_TEST_Pos (7U) |
| #define | FDCAN_CCCR_TEST_Msk (0x1UL << FDCAN_CCCR_TEST_Pos) |
| #define | FDCAN_CCCR_TEST FDCAN_CCCR_TEST_Msk |
| #define | FDCAN_CCCR_FDOE_Pos (8U) |
| #define | FDCAN_CCCR_FDOE_Msk (0x1UL << FDCAN_CCCR_FDOE_Pos) |
| #define | FDCAN_CCCR_FDOE FDCAN_CCCR_FDOE_Msk |
| #define | FDCAN_CCCR_BRSE_Pos (9U) |
| #define | FDCAN_CCCR_BRSE_Msk (0x1UL << FDCAN_CCCR_BRSE_Pos) |
| #define | FDCAN_CCCR_BRSE FDCAN_CCCR_BRSE_Msk |
| #define | FDCAN_CCCR_PXHD_Pos (12U) |
| #define | FDCAN_CCCR_PXHD_Msk (0x1UL << FDCAN_CCCR_PXHD_Pos) |
| #define | FDCAN_CCCR_PXHD FDCAN_CCCR_PXHD_Msk |
| #define | FDCAN_CCCR_EFBI_Pos (13U) |
| #define | FDCAN_CCCR_EFBI_Msk (0x1UL << FDCAN_CCCR_EFBI_Pos) |
| #define | FDCAN_CCCR_EFBI FDCAN_CCCR_EFBI_Msk |
| #define | FDCAN_CCCR_TXP_Pos (14U) |
| #define | FDCAN_CCCR_TXP_Msk (0x1UL << FDCAN_CCCR_TXP_Pos) |
| #define | FDCAN_CCCR_TXP FDCAN_CCCR_TXP_Msk |
| #define | FDCAN_CCCR_NISO_Pos (15U) |
| #define | FDCAN_CCCR_NISO_Msk (0x1UL << FDCAN_CCCR_NISO_Pos) |
| #define | FDCAN_CCCR_NISO FDCAN_CCCR_NISO_Msk |
| #define | FDCAN_NBTP_NTSEG2_Pos (0U) |
| #define | FDCAN_NBTP_NTSEG2_Msk (0x7FUL << FDCAN_NBTP_NTSEG2_Pos) |
| #define | FDCAN_NBTP_NTSEG2 FDCAN_NBTP_NTSEG2_Msk |
| #define | FDCAN_NBTP_NTSEG1_Pos (8U) |
| #define | FDCAN_NBTP_NTSEG1_Msk (0xFFUL << FDCAN_NBTP_NTSEG1_Pos) |
| #define | FDCAN_NBTP_NTSEG1 FDCAN_NBTP_NTSEG1_Msk |
| #define | FDCAN_NBTP_NBRP_Pos (16U) |
| #define | FDCAN_NBTP_NBRP_Msk (0x1FFUL << FDCAN_NBTP_NBRP_Pos) |
| #define | FDCAN_NBTP_NBRP FDCAN_NBTP_NBRP_Msk |
| #define | FDCAN_NBTP_NSJW_Pos (25U) |
| #define | FDCAN_NBTP_NSJW_Msk (0x7FUL << FDCAN_NBTP_NSJW_Pos) |
| #define | FDCAN_NBTP_NSJW FDCAN_NBTP_NSJW_Msk |
| #define | FDCAN_TSCC_TSS_Pos (0U) |
| #define | FDCAN_TSCC_TSS_Msk (0x3UL << FDCAN_TSCC_TSS_Pos) |
| #define | FDCAN_TSCC_TSS FDCAN_TSCC_TSS_Msk |
| #define | FDCAN_TSCC_TCP_Pos (16U) |
| #define | FDCAN_TSCC_TCP_Msk (0xFUL << FDCAN_TSCC_TCP_Pos) |
| #define | FDCAN_TSCC_TCP FDCAN_TSCC_TCP_Msk |
| #define | FDCAN_TSCV_TSC_Pos (0U) |
| #define | FDCAN_TSCV_TSC_Msk (0xFFFFUL << FDCAN_TSCV_TSC_Pos) |
| #define | FDCAN_TSCV_TSC FDCAN_TSCV_TSC_Msk |
| #define | FDCAN_TOCC_ETOC_Pos (0U) |
| #define | FDCAN_TOCC_ETOC_Msk (0x1UL << FDCAN_TOCC_ETOC_Pos) |
| #define | FDCAN_TOCC_ETOC FDCAN_TOCC_ETOC_Msk |
| #define | FDCAN_TOCC_TOS_Pos (1U) |
| #define | FDCAN_TOCC_TOS_Msk (0x3UL << FDCAN_TOCC_TOS_Pos) |
| #define | FDCAN_TOCC_TOS FDCAN_TOCC_TOS_Msk |
| #define | FDCAN_TOCC_TOP_Pos (16U) |
| #define | FDCAN_TOCC_TOP_Msk (0xFFFFUL << FDCAN_TOCC_TOP_Pos) |
| #define | FDCAN_TOCC_TOP FDCAN_TOCC_TOP_Msk |
| #define | FDCAN_TOCV_TOC_Pos (0U) |
| #define | FDCAN_TOCV_TOC_Msk (0xFFFFUL << FDCAN_TOCV_TOC_Pos) |
| #define | FDCAN_TOCV_TOC FDCAN_TOCV_TOC_Msk |
| #define | FDCAN_ECR_TEC_Pos (0U) |
| #define | FDCAN_ECR_TEC_Msk (0xFFUL << FDCAN_ECR_TEC_Pos) |
| #define | FDCAN_ECR_TEC FDCAN_ECR_TEC_Msk |
| #define | FDCAN_ECR_REC_Pos (8U) |
| #define | FDCAN_ECR_REC_Msk (0x7FUL << FDCAN_ECR_REC_Pos) |
| #define | FDCAN_ECR_REC FDCAN_ECR_REC_Msk |
| #define | FDCAN_ECR_RP_Pos (15U) |
| #define | FDCAN_ECR_RP_Msk (0x1UL << FDCAN_ECR_RP_Pos) |
| #define | FDCAN_ECR_RP FDCAN_ECR_RP_Msk |
| #define | FDCAN_ECR_CEL_Pos (16U) |
| #define | FDCAN_ECR_CEL_Msk (0xFFUL << FDCAN_ECR_CEL_Pos) |
| #define | FDCAN_ECR_CEL FDCAN_ECR_CEL_Msk |
| #define | FDCAN_PSR_LEC_Pos (0U) |
| #define | FDCAN_PSR_LEC_Msk (0x7UL << FDCAN_PSR_LEC_Pos) |
| #define | FDCAN_PSR_LEC FDCAN_PSR_LEC_Msk |
| #define | FDCAN_PSR_ACT_Pos (3U) |
| #define | FDCAN_PSR_ACT_Msk (0x3UL << FDCAN_PSR_ACT_Pos) |
| #define | FDCAN_PSR_ACT FDCAN_PSR_ACT_Msk |
| #define | FDCAN_PSR_EP_Pos (5U) |
| #define | FDCAN_PSR_EP_Msk (0x1UL << FDCAN_PSR_EP_Pos) |
| #define | FDCAN_PSR_EP FDCAN_PSR_EP_Msk |
| #define | FDCAN_PSR_EW_Pos (6U) |
| #define | FDCAN_PSR_EW_Msk (0x1UL << FDCAN_PSR_EW_Pos) |
| #define | FDCAN_PSR_EW FDCAN_PSR_EW_Msk |
| #define | FDCAN_PSR_BO_Pos (7U) |
| #define | FDCAN_PSR_BO_Msk (0x1UL << FDCAN_PSR_BO_Pos) |
| #define | FDCAN_PSR_BO FDCAN_PSR_BO_Msk |
| #define | FDCAN_PSR_DLEC_Pos (8U) |
| #define | FDCAN_PSR_DLEC_Msk (0x7UL << FDCAN_PSR_DLEC_Pos) |
| #define | FDCAN_PSR_DLEC FDCAN_PSR_DLEC_Msk |
| #define | FDCAN_PSR_RESI_Pos (11U) |
| #define | FDCAN_PSR_RESI_Msk (0x1UL << FDCAN_PSR_RESI_Pos) |
| #define | FDCAN_PSR_RESI FDCAN_PSR_RESI_Msk |
| #define | FDCAN_PSR_RBRS_Pos (12U) |
| #define | FDCAN_PSR_RBRS_Msk (0x1UL << FDCAN_PSR_RBRS_Pos) |
| #define | FDCAN_PSR_RBRS FDCAN_PSR_RBRS_Msk |
| #define | FDCAN_PSR_REDL_Pos (13U) |
| #define | FDCAN_PSR_REDL_Msk (0x1UL << FDCAN_PSR_REDL_Pos) |
| #define | FDCAN_PSR_REDL FDCAN_PSR_REDL_Msk |
| #define | FDCAN_PSR_PXE_Pos (14U) |
| #define | FDCAN_PSR_PXE_Msk (0x1UL << FDCAN_PSR_PXE_Pos) |
| #define | FDCAN_PSR_PXE FDCAN_PSR_PXE_Msk |
| #define | FDCAN_PSR_TDCV_Pos (16U) |
| #define | FDCAN_PSR_TDCV_Msk (0x7FUL << FDCAN_PSR_TDCV_Pos) |
| #define | FDCAN_PSR_TDCV FDCAN_PSR_TDCV_Msk |
| #define | FDCAN_TDCR_TDCF_Pos (0U) |
| #define | FDCAN_TDCR_TDCF_Msk (0x7FUL << FDCAN_TDCR_TDCF_Pos) |
| #define | FDCAN_TDCR_TDCF FDCAN_TDCR_TDCF_Msk |
| #define | FDCAN_TDCR_TDCO_Pos (8U) |
| #define | FDCAN_TDCR_TDCO_Msk (0x7FUL << FDCAN_TDCR_TDCO_Pos) |
| #define | FDCAN_TDCR_TDCO FDCAN_TDCR_TDCO_Msk |
| #define | FDCAN_IR_RF0N_Pos (0U) |
| #define | FDCAN_IR_RF0N_Msk (0x1UL << FDCAN_IR_RF0N_Pos) |
| #define | FDCAN_IR_RF0N FDCAN_IR_RF0N_Msk |
| #define | FDCAN_IR_RF0W_Pos (1U) |
| #define | FDCAN_IR_RF0W_Msk (0x1UL << FDCAN_IR_RF0W_Pos) |
| #define | FDCAN_IR_RF0W FDCAN_IR_RF0W_Msk |
| #define | FDCAN_IR_RF0F_Pos (2U) |
| #define | FDCAN_IR_RF0F_Msk (0x1UL << FDCAN_IR_RF0F_Pos) |
| #define | FDCAN_IR_RF0F FDCAN_IR_RF0F_Msk |
| #define | FDCAN_IR_RF0L_Pos (3U) |
| #define | FDCAN_IR_RF0L_Msk (0x1UL << FDCAN_IR_RF0L_Pos) |
| #define | FDCAN_IR_RF0L FDCAN_IR_RF0L_Msk |
| #define | FDCAN_IR_RF1N_Pos (4U) |
| #define | FDCAN_IR_RF1N_Msk (0x1UL << FDCAN_IR_RF1N_Pos) |
| #define | FDCAN_IR_RF1N FDCAN_IR_RF1N_Msk |
| #define | FDCAN_IR_RF1W_Pos (5U) |
| #define | FDCAN_IR_RF1W_Msk (0x1UL << FDCAN_IR_RF1W_Pos) |
| #define | FDCAN_IR_RF1W FDCAN_IR_RF1W_Msk |
| #define | FDCAN_IR_RF1F_Pos (6U) |
| #define | FDCAN_IR_RF1F_Msk (0x1UL << FDCAN_IR_RF1F_Pos) |
| #define | FDCAN_IR_RF1F FDCAN_IR_RF1F_Msk |
| #define | FDCAN_IR_RF1L_Pos (7U) |
| #define | FDCAN_IR_RF1L_Msk (0x1UL << FDCAN_IR_RF1L_Pos) |
| #define | FDCAN_IR_RF1L FDCAN_IR_RF1L_Msk |
| #define | FDCAN_IR_HPM_Pos (8U) |
| #define | FDCAN_IR_HPM_Msk (0x1UL << FDCAN_IR_HPM_Pos) |
| #define | FDCAN_IR_HPM FDCAN_IR_HPM_Msk |
| #define | FDCAN_IR_TC_Pos (9U) |
| #define | FDCAN_IR_TC_Msk (0x1UL << FDCAN_IR_TC_Pos) |
| #define | FDCAN_IR_TC FDCAN_IR_TC_Msk |
| #define | FDCAN_IR_TCF_Pos (10U) |
| #define | FDCAN_IR_TCF_Msk (0x1UL << FDCAN_IR_TCF_Pos) |
| #define | FDCAN_IR_TCF FDCAN_IR_TCF_Msk |
| #define | FDCAN_IR_TFE_Pos (11U) |
| #define | FDCAN_IR_TFE_Msk (0x1UL << FDCAN_IR_TFE_Pos) |
| #define | FDCAN_IR_TFE FDCAN_IR_TFE_Msk |
| #define | FDCAN_IR_TEFN_Pos (12U) |
| #define | FDCAN_IR_TEFN_Msk (0x1UL << FDCAN_IR_TEFN_Pos) |
| #define | FDCAN_IR_TEFN FDCAN_IR_TEFN_Msk |
| #define | FDCAN_IR_TEFW_Pos (13U) |
| #define | FDCAN_IR_TEFW_Msk (0x1UL << FDCAN_IR_TEFW_Pos) |
| #define | FDCAN_IR_TEFW FDCAN_IR_TEFW_Msk |
| #define | FDCAN_IR_TEFF_Pos (14U) |
| #define | FDCAN_IR_TEFF_Msk (0x1UL << FDCAN_IR_TEFF_Pos) |
| #define | FDCAN_IR_TEFF FDCAN_IR_TEFF_Msk |
| #define | FDCAN_IR_TEFL_Pos (15U) |
| #define | FDCAN_IR_TEFL_Msk (0x1UL << FDCAN_IR_TEFL_Pos) |
| #define | FDCAN_IR_TEFL FDCAN_IR_TEFL_Msk |
| #define | FDCAN_IR_TSW_Pos (16U) |
| #define | FDCAN_IR_TSW_Msk (0x1UL << FDCAN_IR_TSW_Pos) |
| #define | FDCAN_IR_TSW FDCAN_IR_TSW_Msk |
| #define | FDCAN_IR_MRAF_Pos (17U) |
| #define | FDCAN_IR_MRAF_Msk (0x1UL << FDCAN_IR_MRAF_Pos) |
| #define | FDCAN_IR_MRAF FDCAN_IR_MRAF_Msk |
| #define | FDCAN_IR_TOO_Pos (18U) |
| #define | FDCAN_IR_TOO_Msk (0x1UL << FDCAN_IR_TOO_Pos) |
| #define | FDCAN_IR_TOO FDCAN_IR_TOO_Msk |
| #define | FDCAN_IR_DRX_Pos (19U) |
| #define | FDCAN_IR_DRX_Msk (0x1UL << FDCAN_IR_DRX_Pos) |
| #define | FDCAN_IR_DRX FDCAN_IR_DRX_Msk |
| #define | FDCAN_IR_ELO_Pos (22U) |
| #define | FDCAN_IR_ELO_Msk (0x1UL << FDCAN_IR_ELO_Pos) |
| #define | FDCAN_IR_ELO FDCAN_IR_ELO_Msk |
| #define | FDCAN_IR_EP_Pos (23U) |
| #define | FDCAN_IR_EP_Msk (0x1UL << FDCAN_IR_EP_Pos) |
| #define | FDCAN_IR_EP FDCAN_IR_EP_Msk |
| #define | FDCAN_IR_EW_Pos (24U) |
| #define | FDCAN_IR_EW_Msk (0x1UL << FDCAN_IR_EW_Pos) |
| #define | FDCAN_IR_EW FDCAN_IR_EW_Msk |
| #define | FDCAN_IR_BO_Pos (25U) |
| #define | FDCAN_IR_BO_Msk (0x1UL << FDCAN_IR_BO_Pos) |
| #define | FDCAN_IR_BO FDCAN_IR_BO_Msk |
| #define | FDCAN_IR_WDI_Pos (26U) |
| #define | FDCAN_IR_WDI_Msk (0x1UL << FDCAN_IR_WDI_Pos) |
| #define | FDCAN_IR_WDI FDCAN_IR_WDI_Msk |
| #define | FDCAN_IR_PEA_Pos (27U) |
| #define | FDCAN_IR_PEA_Msk (0x1UL << FDCAN_IR_PEA_Pos) |
| #define | FDCAN_IR_PEA FDCAN_IR_PEA_Msk |
| #define | FDCAN_IR_PED_Pos (28U) |
| #define | FDCAN_IR_PED_Msk (0x1UL << FDCAN_IR_PED_Pos) |
| #define | FDCAN_IR_PED FDCAN_IR_PED_Msk |
| #define | FDCAN_IR_ARA_Pos (29U) |
| #define | FDCAN_IR_ARA_Msk (0x1UL << FDCAN_IR_ARA_Pos) |
| #define | FDCAN_IR_ARA FDCAN_IR_ARA_Msk |
| #define | FDCAN_IE_RF0NE_Pos (0U) |
| #define | FDCAN_IE_RF0NE_Msk (0x1UL << FDCAN_IE_RF0NE_Pos) |
| #define | FDCAN_IE_RF0NE FDCAN_IE_RF0NE_Msk |
| #define | FDCAN_IE_RF0WE_Pos (1U) |
| #define | FDCAN_IE_RF0WE_Msk (0x1UL << FDCAN_IE_RF0WE_Pos) |
| #define | FDCAN_IE_RF0WE FDCAN_IE_RF0WE_Msk |
| #define | FDCAN_IE_RF0FE_Pos (2U) |
| #define | FDCAN_IE_RF0FE_Msk (0x1UL << FDCAN_IE_RF0FE_Pos) |
| #define | FDCAN_IE_RF0FE FDCAN_IE_RF0FE_Msk |
| #define | FDCAN_IE_RF0LE_Pos (3U) |
| #define | FDCAN_IE_RF0LE_Msk (0x1UL << FDCAN_IE_RF0LE_Pos) |
| #define | FDCAN_IE_RF0LE FDCAN_IE_RF0LE_Msk |
| #define | FDCAN_IE_RF1NE_Pos (4U) |
| #define | FDCAN_IE_RF1NE_Msk (0x1UL << FDCAN_IE_RF1NE_Pos) |
| #define | FDCAN_IE_RF1NE FDCAN_IE_RF1NE_Msk |
| #define | FDCAN_IE_RF1WE_Pos (5U) |
| #define | FDCAN_IE_RF1WE_Msk (0x1UL << FDCAN_IE_RF1WE_Pos) |
| #define | FDCAN_IE_RF1WE FDCAN_IE_RF1WE_Msk |
| #define | FDCAN_IE_RF1FE_Pos (6U) |
| #define | FDCAN_IE_RF1FE_Msk (0x1UL << FDCAN_IE_RF1FE_Pos) |
| #define | FDCAN_IE_RF1FE FDCAN_IE_RF1FE_Msk |
| #define | FDCAN_IE_RF1LE_Pos (7U) |
| #define | FDCAN_IE_RF1LE_Msk (0x1UL << FDCAN_IE_RF1LE_Pos) |
| #define | FDCAN_IE_RF1LE FDCAN_IE_RF1LE_Msk |
| #define | FDCAN_IE_HPME_Pos (8U) |
| #define | FDCAN_IE_HPME_Msk (0x1UL << FDCAN_IE_HPME_Pos) |
| #define | FDCAN_IE_HPME FDCAN_IE_HPME_Msk |
| #define | FDCAN_IE_TCE_Pos (9U) |
| #define | FDCAN_IE_TCE_Msk (0x1UL << FDCAN_IE_TCE_Pos) |
| #define | FDCAN_IE_TCE FDCAN_IE_TCE_Msk |
| #define | FDCAN_IE_TCFE_Pos (10U) |
| #define | FDCAN_IE_TCFE_Msk (0x1UL << FDCAN_IE_TCFE_Pos) |
| #define | FDCAN_IE_TCFE FDCAN_IE_TCFE_Msk |
| #define | FDCAN_IE_TFEE_Pos (11U) |
| #define | FDCAN_IE_TFEE_Msk (0x1UL << FDCAN_IE_TFEE_Pos) |
| #define | FDCAN_IE_TFEE FDCAN_IE_TFEE_Msk |
| #define | FDCAN_IE_TEFNE_Pos (12U) |
| #define | FDCAN_IE_TEFNE_Msk (0x1UL << FDCAN_IE_TEFNE_Pos) |
| #define | FDCAN_IE_TEFNE FDCAN_IE_TEFNE_Msk |
| #define | FDCAN_IE_TEFWE_Pos (13U) |
| #define | FDCAN_IE_TEFWE_Msk (0x1UL << FDCAN_IE_TEFWE_Pos) |
| #define | FDCAN_IE_TEFWE FDCAN_IE_TEFWE_Msk |
| #define | FDCAN_IE_TEFFE_Pos (14U) |
| #define | FDCAN_IE_TEFFE_Msk (0x1UL << FDCAN_IE_TEFFE_Pos) |
| #define | FDCAN_IE_TEFFE FDCAN_IE_TEFFE_Msk |
| #define | FDCAN_IE_TEFLE_Pos (15U) |
| #define | FDCAN_IE_TEFLE_Msk (0x1UL << FDCAN_IE_TEFLE_Pos) |
| #define | FDCAN_IE_TEFLE FDCAN_IE_TEFLE_Msk |
| #define | FDCAN_IE_TSWE_Pos (16U) |
| #define | FDCAN_IE_TSWE_Msk (0x1UL << FDCAN_IE_TSWE_Pos) |
| #define | FDCAN_IE_TSWE FDCAN_IE_TSWE_Msk |
| #define | FDCAN_IE_MRAFE_Pos (17U) |
| #define | FDCAN_IE_MRAFE_Msk (0x1UL << FDCAN_IE_MRAFE_Pos) |
| #define | FDCAN_IE_MRAFE FDCAN_IE_MRAFE_Msk |
| #define | FDCAN_IE_TOOE_Pos (18U) |
| #define | FDCAN_IE_TOOE_Msk (0x1UL << FDCAN_IE_TOOE_Pos) |
| #define | FDCAN_IE_TOOE FDCAN_IE_TOOE_Msk |
| #define | FDCAN_IE_DRXE_Pos (19U) |
| #define | FDCAN_IE_DRXE_Msk (0x1UL << FDCAN_IE_DRXE_Pos) |
| #define | FDCAN_IE_DRXE FDCAN_IE_DRXE_Msk |
| #define | FDCAN_IE_BECE_Pos (20U) |
| #define | FDCAN_IE_BECE_Msk (0x1UL << FDCAN_IE_BECE_Pos) |
| #define | FDCAN_IE_BECE FDCAN_IE_BECE_Msk |
| #define | FDCAN_IE_BEUE_Pos (21U) |
| #define | FDCAN_IE_BEUE_Msk (0x1UL << FDCAN_IE_BEUE_Pos) |
| #define | FDCAN_IE_BEUE FDCAN_IE_BEUE_Msk |
| #define | FDCAN_IE_ELOE_Pos (22U) |
| #define | FDCAN_IE_ELOE_Msk (0x1UL << FDCAN_IE_ELOE_Pos) |
| #define | FDCAN_IE_ELOE FDCAN_IE_ELOE_Msk |
| #define | FDCAN_IE_EPE_Pos (23U) |
| #define | FDCAN_IE_EPE_Msk (0x1UL << FDCAN_IE_EPE_Pos) |
| #define | FDCAN_IE_EPE FDCAN_IE_EPE_Msk |
| #define | FDCAN_IE_EWE_Pos (24U) |
| #define | FDCAN_IE_EWE_Msk (0x1UL << FDCAN_IE_EWE_Pos) |
| #define | FDCAN_IE_EWE FDCAN_IE_EWE_Msk |
| #define | FDCAN_IE_BOE_Pos (25U) |
| #define | FDCAN_IE_BOE_Msk (0x1UL << FDCAN_IE_BOE_Pos) |
| #define | FDCAN_IE_BOE FDCAN_IE_BOE_Msk |
| #define | FDCAN_IE_WDIE_Pos (26U) |
| #define | FDCAN_IE_WDIE_Msk (0x1UL << FDCAN_IE_WDIE_Pos) |
| #define | FDCAN_IE_WDIE FDCAN_IE_WDIE_Msk |
| #define | FDCAN_IE_PEAE_Pos (27U) |
| #define | FDCAN_IE_PEAE_Msk (0x1UL << FDCAN_IE_PEAE_Pos) |
| #define | FDCAN_IE_PEAE FDCAN_IE_PEAE_Msk |
| #define | FDCAN_IE_PEDE_Pos (28U) |
| #define | FDCAN_IE_PEDE_Msk (0x1UL << FDCAN_IE_PEDE_Pos) |
| #define | FDCAN_IE_PEDE FDCAN_IE_PEDE_Msk |
| #define | FDCAN_IE_ARAE_Pos (29U) |
| #define | FDCAN_IE_ARAE_Msk (0x1UL << FDCAN_IE_ARAE_Pos) |
| #define | FDCAN_IE_ARAE FDCAN_IE_ARAE_Msk |
| #define | FDCAN_ILS_RF0NL_Pos (0U) |
| #define | FDCAN_ILS_RF0NL_Msk (0x1UL << FDCAN_ILS_RF0NL_Pos) |
| #define | FDCAN_ILS_RF0NL FDCAN_ILS_RF0NL_Msk |
| #define | FDCAN_ILS_RF0WL_Pos (1U) |
| #define | FDCAN_ILS_RF0WL_Msk (0x1UL << FDCAN_ILS_RF0WL_Pos) |
| #define | FDCAN_ILS_RF0WL FDCAN_ILS_RF0WL_Msk |
| #define | FDCAN_ILS_RF0FL_Pos (2U) |
| #define | FDCAN_ILS_RF0FL_Msk (0x1UL << FDCAN_ILS_RF0FL_Pos) |
| #define | FDCAN_ILS_RF0FL FDCAN_ILS_RF0FL_Msk |
| #define | FDCAN_ILS_RF0LL_Pos (3U) |
| #define | FDCAN_ILS_RF0LL_Msk (0x1UL << FDCAN_ILS_RF0LL_Pos) |
| #define | FDCAN_ILS_RF0LL FDCAN_ILS_RF0LL_Msk |
| #define | FDCAN_ILS_RF1NL_Pos (4U) |
| #define | FDCAN_ILS_RF1NL_Msk (0x1UL << FDCAN_ILS_RF1NL_Pos) |
| #define | FDCAN_ILS_RF1NL FDCAN_ILS_RF1NL_Msk |
| #define | FDCAN_ILS_RF1WL_Pos (5U) |
| #define | FDCAN_ILS_RF1WL_Msk (0x1UL << FDCAN_ILS_RF1WL_Pos) |
| #define | FDCAN_ILS_RF1WL FDCAN_ILS_RF1WL_Msk |
| #define | FDCAN_ILS_RF1FL_Pos (6U) |
| #define | FDCAN_ILS_RF1FL_Msk (0x1UL << FDCAN_ILS_RF1FL_Pos) |
| #define | FDCAN_ILS_RF1FL FDCAN_ILS_RF1FL_Msk |
| #define | FDCAN_ILS_RF1LL_Pos (7U) |
| #define | FDCAN_ILS_RF1LL_Msk (0x1UL << FDCAN_ILS_RF1LL_Pos) |
| #define | FDCAN_ILS_RF1LL FDCAN_ILS_RF1LL_Msk |
| #define | FDCAN_ILS_HPML_Pos (8U) |
| #define | FDCAN_ILS_HPML_Msk (0x1UL << FDCAN_ILS_HPML_Pos) |
| #define | FDCAN_ILS_HPML FDCAN_ILS_HPML_Msk |
| #define | FDCAN_ILS_TCL_Pos (9U) |
| #define | FDCAN_ILS_TCL_Msk (0x1UL << FDCAN_ILS_TCL_Pos) |
| #define | FDCAN_ILS_TCL FDCAN_ILS_TCL_Msk |
| #define | FDCAN_ILS_TCFL_Pos (10U) |
| #define | FDCAN_ILS_TCFL_Msk (0x1UL << FDCAN_ILS_TCFL_Pos) |
| #define | FDCAN_ILS_TCFL FDCAN_ILS_TCFL_Msk |
| #define | FDCAN_ILS_TFEL_Pos (11U) |
| #define | FDCAN_ILS_TFEL_Msk (0x1UL << FDCAN_ILS_TFEL_Pos) |
| #define | FDCAN_ILS_TFEL FDCAN_ILS_TFEL_Msk |
| #define | FDCAN_ILS_TEFNL_Pos (12U) |
| #define | FDCAN_ILS_TEFNL_Msk (0x1UL << FDCAN_ILS_TEFNL_Pos) |
| #define | FDCAN_ILS_TEFNL FDCAN_ILS_TEFNL_Msk |
| #define | FDCAN_ILS_TEFWL_Pos (13U) |
| #define | FDCAN_ILS_TEFWL_Msk (0x1UL << FDCAN_ILS_TEFWL_Pos) |
| #define | FDCAN_ILS_TEFWL FDCAN_ILS_TEFWL_Msk |
| #define | FDCAN_ILS_TEFFL_Pos (14U) |
| #define | FDCAN_ILS_TEFFL_Msk (0x1UL << FDCAN_ILS_TEFFL_Pos) |
| #define | FDCAN_ILS_TEFFL FDCAN_ILS_TEFFL_Msk |
| #define | FDCAN_ILS_TEFLL_Pos (15U) |
| #define | FDCAN_ILS_TEFLL_Msk (0x1UL << FDCAN_ILS_TEFLL_Pos) |
| #define | FDCAN_ILS_TEFLL FDCAN_ILS_TEFLL_Msk |
| #define | FDCAN_ILS_TSWL_Pos (16U) |
| #define | FDCAN_ILS_TSWL_Msk (0x1UL << FDCAN_ILS_TSWL_Pos) |
| #define | FDCAN_ILS_TSWL FDCAN_ILS_TSWL_Msk |
| #define | FDCAN_ILS_MRAFE_Pos (17U) |
| #define | FDCAN_ILS_MRAFE_Msk (0x1UL << FDCAN_ILS_MRAFE_Pos) |
| #define | FDCAN_ILS_MRAFE FDCAN_ILS_MRAFE_Msk |
| #define | FDCAN_ILS_TOOE_Pos (18U) |
| #define | FDCAN_ILS_TOOE_Msk (0x1UL << FDCAN_ILS_TOOE_Pos) |
| #define | FDCAN_ILS_TOOE FDCAN_ILS_TOOE_Msk |
| #define | FDCAN_ILS_DRXE_Pos (19U) |
| #define | FDCAN_ILS_DRXE_Msk (0x1UL << FDCAN_ILS_DRXE_Pos) |
| #define | FDCAN_ILS_DRXE FDCAN_ILS_DRXE_Msk |
| #define | FDCAN_ILS_BECE_Pos (20U) |
| #define | FDCAN_ILS_BECE_Msk (0x1UL << FDCAN_ILS_BECE_Pos) |
| #define | FDCAN_ILS_BECE FDCAN_ILS_BECE_Msk |
| #define | FDCAN_ILS_BEUE_Pos (21U) |
| #define | FDCAN_ILS_BEUE_Msk (0x1UL << FDCAN_ILS_BEUE_Pos) |
| #define | FDCAN_ILS_BEUE FDCAN_ILS_BEUE_Msk |
| #define | FDCAN_ILS_ELOE_Pos (22U) |
| #define | FDCAN_ILS_ELOE_Msk (0x1UL << FDCAN_ILS_ELOE_Pos) |
| #define | FDCAN_ILS_ELOE FDCAN_ILS_ELOE_Msk |
| #define | FDCAN_ILS_EPE_Pos (23U) |
| #define | FDCAN_ILS_EPE_Msk (0x1UL << FDCAN_ILS_EPE_Pos) |
| #define | FDCAN_ILS_EPE FDCAN_ILS_EPE_Msk |
| #define | FDCAN_ILS_EWE_Pos (24U) |
| #define | FDCAN_ILS_EWE_Msk (0x1UL << FDCAN_ILS_EWE_Pos) |
| #define | FDCAN_ILS_EWE FDCAN_ILS_EWE_Msk |
| #define | FDCAN_ILS_BOE_Pos (25U) |
| #define | FDCAN_ILS_BOE_Msk (0x1UL << FDCAN_ILS_BOE_Pos) |
| #define | FDCAN_ILS_BOE FDCAN_ILS_BOE_Msk |
| #define | FDCAN_ILS_WDIE_Pos (26U) |
| #define | FDCAN_ILS_WDIE_Msk (0x1UL << FDCAN_ILS_WDIE_Pos) |
| #define | FDCAN_ILS_WDIE FDCAN_ILS_WDIE_Msk |
| #define | FDCAN_ILS_PEAE_Pos (27U) |
| #define | FDCAN_ILS_PEAE_Msk (0x1UL << FDCAN_ILS_PEAE_Pos) |
| #define | FDCAN_ILS_PEAE FDCAN_ILS_PEAE_Msk |
| #define | FDCAN_ILS_PEDE_Pos (28U) |
| #define | FDCAN_ILS_PEDE_Msk (0x1UL << FDCAN_ILS_PEDE_Pos) |
| #define | FDCAN_ILS_PEDE FDCAN_ILS_PEDE_Msk |
| #define | FDCAN_ILS_ARAE_Pos (29U) |
| #define | FDCAN_ILS_ARAE_Msk (0x1UL << FDCAN_ILS_ARAE_Pos) |
| #define | FDCAN_ILS_ARAE FDCAN_ILS_ARAE_Msk |
| #define | FDCAN_ILE_EINT0_Pos (0U) |
| #define | FDCAN_ILE_EINT0_Msk (0x1UL << FDCAN_ILE_EINT0_Pos) |
| #define | FDCAN_ILE_EINT0 FDCAN_ILE_EINT0_Msk |
| #define | FDCAN_ILE_EINT1_Pos (1U) |
| #define | FDCAN_ILE_EINT1_Msk (0x1UL << FDCAN_ILE_EINT1_Pos) |
| #define | FDCAN_ILE_EINT1 FDCAN_ILE_EINT1_Msk |
| #define | FDCAN_GFC_RRFE_Pos (0U) |
| #define | FDCAN_GFC_RRFE_Msk (0x1UL << FDCAN_GFC_RRFE_Pos) |
| #define | FDCAN_GFC_RRFE FDCAN_GFC_RRFE_Msk |
| #define | FDCAN_GFC_RRFS_Pos (1U) |
| #define | FDCAN_GFC_RRFS_Msk (0x1UL << FDCAN_GFC_RRFS_Pos) |
| #define | FDCAN_GFC_RRFS FDCAN_GFC_RRFS_Msk |
| #define | FDCAN_GFC_ANFE_Pos (2U) |
| #define | FDCAN_GFC_ANFE_Msk (0x3UL << FDCAN_GFC_ANFE_Pos) |
| #define | FDCAN_GFC_ANFE FDCAN_GFC_ANFE_Msk |
| #define | FDCAN_GFC_ANFS_Pos (4U) |
| #define | FDCAN_GFC_ANFS_Msk (0x3UL << FDCAN_GFC_ANFS_Pos) |
| #define | FDCAN_GFC_ANFS FDCAN_GFC_ANFS_Msk |
| #define | FDCAN_SIDFC_FLSSA_Pos (2U) |
| #define | FDCAN_SIDFC_FLSSA_Msk (0x3FFFUL << FDCAN_SIDFC_FLSSA_Pos) |
| #define | FDCAN_SIDFC_FLSSA FDCAN_SIDFC_FLSSA_Msk |
| #define | FDCAN_SIDFC_LSS_Pos (16U) |
| #define | FDCAN_SIDFC_LSS_Msk (0xFFUL << FDCAN_SIDFC_LSS_Pos) |
| #define | FDCAN_SIDFC_LSS FDCAN_SIDFC_LSS_Msk |
| #define | FDCAN_XIDFC_FLESA_Pos (2U) |
| #define | FDCAN_XIDFC_FLESA_Msk (0x3FFFUL << FDCAN_XIDFC_FLESA_Pos) |
| #define | FDCAN_XIDFC_FLESA FDCAN_XIDFC_FLESA_Msk |
| #define | FDCAN_XIDFC_LSE_Pos (16U) |
| #define | FDCAN_XIDFC_LSE_Msk (0x7FUL << FDCAN_XIDFC_LSE_Pos) |
| #define | FDCAN_XIDFC_LSE FDCAN_XIDFC_LSE_Msk |
| #define | FDCAN_XIDAM_EIDM_Pos (0U) |
| #define | FDCAN_XIDAM_EIDM_Msk (0x1FFFFFFFUL << FDCAN_XIDAM_EIDM_Pos) |
| #define | FDCAN_XIDAM_EIDM FDCAN_XIDAM_EIDM_Msk |
| #define | FDCAN_HPMS_BIDX_Pos (0U) |
| #define | FDCAN_HPMS_BIDX_Msk (0x3FUL << FDCAN_HPMS_BIDX_Pos) |
| #define | FDCAN_HPMS_BIDX FDCAN_HPMS_BIDX_Msk |
| #define | FDCAN_HPMS_MSI_Pos (6U) |
| #define | FDCAN_HPMS_MSI_Msk (0x3UL << FDCAN_HPMS_MSI_Pos) |
| #define | FDCAN_HPMS_MSI FDCAN_HPMS_MSI_Msk |
| #define | FDCAN_HPMS_FIDX_Pos (8U) |
| #define | FDCAN_HPMS_FIDX_Msk (0x7FUL << FDCAN_HPMS_FIDX_Pos) |
| #define | FDCAN_HPMS_FIDX FDCAN_HPMS_FIDX_Msk |
| #define | FDCAN_HPMS_FLST_Pos (15U) |
| #define | FDCAN_HPMS_FLST_Msk (0x1UL << FDCAN_HPMS_FLST_Pos) |
| #define | FDCAN_HPMS_FLST FDCAN_HPMS_FLST_Msk |
| #define | FDCAN_NDAT1_ND0_Pos (0U) |
| #define | FDCAN_NDAT1_ND0_Msk (0x1UL << FDCAN_NDAT1_ND0_Pos) |
| #define | FDCAN_NDAT1_ND0 FDCAN_NDAT1_ND0_Msk |
| #define | FDCAN_NDAT1_ND1_Pos (1U) |
| #define | FDCAN_NDAT1_ND1_Msk (0x1UL << FDCAN_NDAT1_ND1_Pos) |
| #define | FDCAN_NDAT1_ND1 FDCAN_NDAT1_ND1_Msk |
| #define | FDCAN_NDAT1_ND2_Pos (2U) |
| #define | FDCAN_NDAT1_ND2_Msk (0x1UL << FDCAN_NDAT1_ND2_Pos) |
| #define | FDCAN_NDAT1_ND2 FDCAN_NDAT1_ND2_Msk |
| #define | FDCAN_NDAT1_ND3_Pos (3U) |
| #define | FDCAN_NDAT1_ND3_Msk (0x1UL << FDCAN_NDAT1_ND3_Pos) |
| #define | FDCAN_NDAT1_ND3 FDCAN_NDAT1_ND3_Msk |
| #define | FDCAN_NDAT1_ND4_Pos (4U) |
| #define | FDCAN_NDAT1_ND4_Msk (0x1UL << FDCAN_NDAT1_ND4_Pos) |
| #define | FDCAN_NDAT1_ND4 FDCAN_NDAT1_ND4_Msk |
| #define | FDCAN_NDAT1_ND5_Pos (5U) |
| #define | FDCAN_NDAT1_ND5_Msk (0x1UL << FDCAN_NDAT1_ND5_Pos) |
| #define | FDCAN_NDAT1_ND5 FDCAN_NDAT1_ND5_Msk |
| #define | FDCAN_NDAT1_ND6_Pos (6U) |
| #define | FDCAN_NDAT1_ND6_Msk (0x1UL << FDCAN_NDAT1_ND6_Pos) |
| #define | FDCAN_NDAT1_ND6 FDCAN_NDAT1_ND6_Msk |
| #define | FDCAN_NDAT1_ND7_Pos (7U) |
| #define | FDCAN_NDAT1_ND7_Msk (0x1UL << FDCAN_NDAT1_ND7_Pos) |
| #define | FDCAN_NDAT1_ND7 FDCAN_NDAT1_ND7_Msk |
| #define | FDCAN_NDAT1_ND8_Pos (8U) |
| #define | FDCAN_NDAT1_ND8_Msk (0x1UL << FDCAN_NDAT1_ND8_Pos) |
| #define | FDCAN_NDAT1_ND8 FDCAN_NDAT1_ND8_Msk |
| #define | FDCAN_NDAT1_ND9_Pos (9U) |
| #define | FDCAN_NDAT1_ND9_Msk (0x1UL << FDCAN_NDAT1_ND9_Pos) |
| #define | FDCAN_NDAT1_ND9 FDCAN_NDAT1_ND9_Msk |
| #define | FDCAN_NDAT1_ND10_Pos (10U) |
| #define | FDCAN_NDAT1_ND10_Msk (0x1UL << FDCAN_NDAT1_ND10_Pos) |
| #define | FDCAN_NDAT1_ND10 FDCAN_NDAT1_ND10_Msk |
| #define | FDCAN_NDAT1_ND11_Pos (11U) |
| #define | FDCAN_NDAT1_ND11_Msk (0x1UL << FDCAN_NDAT1_ND11_Pos) |
| #define | FDCAN_NDAT1_ND11 FDCAN_NDAT1_ND11_Msk |
| #define | FDCAN_NDAT1_ND12_Pos (12U) |
| #define | FDCAN_NDAT1_ND12_Msk (0x1UL << FDCAN_NDAT1_ND12_Pos) |
| #define | FDCAN_NDAT1_ND12 FDCAN_NDAT1_ND12_Msk |
| #define | FDCAN_NDAT1_ND13_Pos (13U) |
| #define | FDCAN_NDAT1_ND13_Msk (0x1UL << FDCAN_NDAT1_ND13_Pos) |
| #define | FDCAN_NDAT1_ND13 FDCAN_NDAT1_ND13_Msk |
| #define | FDCAN_NDAT1_ND14_Pos (14U) |
| #define | FDCAN_NDAT1_ND14_Msk (0x1UL << FDCAN_NDAT1_ND14_Pos) |
| #define | FDCAN_NDAT1_ND14 FDCAN_NDAT1_ND14_Msk |
| #define | FDCAN_NDAT1_ND15_Pos (15U) |
| #define | FDCAN_NDAT1_ND15_Msk (0x1UL << FDCAN_NDAT1_ND15_Pos) |
| #define | FDCAN_NDAT1_ND15 FDCAN_NDAT1_ND15_Msk |
| #define | FDCAN_NDAT1_ND16_Pos (16U) |
| #define | FDCAN_NDAT1_ND16_Msk (0x1UL << FDCAN_NDAT1_ND16_Pos) |
| #define | FDCAN_NDAT1_ND16 FDCAN_NDAT1_ND16_Msk |
| #define | FDCAN_NDAT1_ND17_Pos (17U) |
| #define | FDCAN_NDAT1_ND17_Msk (0x1UL << FDCAN_NDAT1_ND17_Pos) |
| #define | FDCAN_NDAT1_ND17 FDCAN_NDAT1_ND17_Msk |
| #define | FDCAN_NDAT1_ND18_Pos (18U) |
| #define | FDCAN_NDAT1_ND18_Msk (0x1UL << FDCAN_NDAT1_ND18_Pos) |
| #define | FDCAN_NDAT1_ND18 FDCAN_NDAT1_ND18_Msk |
| #define | FDCAN_NDAT1_ND19_Pos (19U) |
| #define | FDCAN_NDAT1_ND19_Msk (0x1UL << FDCAN_NDAT1_ND19_Pos) |
| #define | FDCAN_NDAT1_ND19 FDCAN_NDAT1_ND19_Msk |
| #define | FDCAN_NDAT1_ND20_Pos (20U) |
| #define | FDCAN_NDAT1_ND20_Msk (0x1UL << FDCAN_NDAT1_ND20_Pos) |
| #define | FDCAN_NDAT1_ND20 FDCAN_NDAT1_ND20_Msk |
| #define | FDCAN_NDAT1_ND21_Pos (21U) |
| #define | FDCAN_NDAT1_ND21_Msk (0x1UL << FDCAN_NDAT1_ND21_Pos) |
| #define | FDCAN_NDAT1_ND21 FDCAN_NDAT1_ND21_Msk |
| #define | FDCAN_NDAT1_ND22_Pos (22U) |
| #define | FDCAN_NDAT1_ND22_Msk (0x1UL << FDCAN_NDAT1_ND22_Pos) |
| #define | FDCAN_NDAT1_ND22 FDCAN_NDAT1_ND22_Msk |
| #define | FDCAN_NDAT1_ND23_Pos (23U) |
| #define | FDCAN_NDAT1_ND23_Msk (0x1UL << FDCAN_NDAT1_ND23_Pos) |
| #define | FDCAN_NDAT1_ND23 FDCAN_NDAT1_ND23_Msk |
| #define | FDCAN_NDAT1_ND24_Pos (24U) |
| #define | FDCAN_NDAT1_ND24_Msk (0x1UL << FDCAN_NDAT1_ND24_Pos) |
| #define | FDCAN_NDAT1_ND24 FDCAN_NDAT1_ND24_Msk |
| #define | FDCAN_NDAT1_ND25_Pos (25U) |
| #define | FDCAN_NDAT1_ND25_Msk (0x1UL << FDCAN_NDAT1_ND25_Pos) |
| #define | FDCAN_NDAT1_ND25 FDCAN_NDAT1_ND25_Msk |
| #define | FDCAN_NDAT1_ND26_Pos (26U) |
| #define | FDCAN_NDAT1_ND26_Msk (0x1UL << FDCAN_NDAT1_ND26_Pos) |
| #define | FDCAN_NDAT1_ND26 FDCAN_NDAT1_ND26_Msk |
| #define | FDCAN_NDAT1_ND27_Pos (27U) |
| #define | FDCAN_NDAT1_ND27_Msk (0x1UL << FDCAN_NDAT1_ND27_Pos) |
| #define | FDCAN_NDAT1_ND27 FDCAN_NDAT1_ND27_Msk |
| #define | FDCAN_NDAT1_ND28_Pos (28U) |
| #define | FDCAN_NDAT1_ND28_Msk (0x1UL << FDCAN_NDAT1_ND28_Pos) |
| #define | FDCAN_NDAT1_ND28 FDCAN_NDAT1_ND28_Msk |
| #define | FDCAN_NDAT1_ND29_Pos (29U) |
| #define | FDCAN_NDAT1_ND29_Msk (0x1UL << FDCAN_NDAT1_ND29_Pos) |
| #define | FDCAN_NDAT1_ND29 FDCAN_NDAT1_ND29_Msk |
| #define | FDCAN_NDAT1_ND30_Pos (30U) |
| #define | FDCAN_NDAT1_ND30_Msk (0x1UL << FDCAN_NDAT1_ND30_Pos) |
| #define | FDCAN_NDAT1_ND30 FDCAN_NDAT1_ND30_Msk |
| #define | FDCAN_NDAT1_ND31_Pos (31U) |
| #define | FDCAN_NDAT1_ND31_Msk (0x1UL << FDCAN_NDAT1_ND31_Pos) |
| #define | FDCAN_NDAT1_ND31 FDCAN_NDAT1_ND31_Msk |
| #define | FDCAN_NDAT2_ND32_Pos (0U) |
| #define | FDCAN_NDAT2_ND32_Msk (0x1UL << FDCAN_NDAT2_ND32_Pos) |
| #define | FDCAN_NDAT2_ND32 FDCAN_NDAT2_ND32_Msk |
| #define | FDCAN_NDAT2_ND33_Pos (1U) |
| #define | FDCAN_NDAT2_ND33_Msk (0x1UL << FDCAN_NDAT2_ND33_Pos) |
| #define | FDCAN_NDAT2_ND33 FDCAN_NDAT2_ND33_Msk |
| #define | FDCAN_NDAT2_ND34_Pos (2U) |
| #define | FDCAN_NDAT2_ND34_Msk (0x1UL << FDCAN_NDAT2_ND34_Pos) |
| #define | FDCAN_NDAT2_ND34 FDCAN_NDAT2_ND34_Msk |
| #define | FDCAN_NDAT2_ND35_Pos (3U) |
| #define | FDCAN_NDAT2_ND35_Msk (0x1UL << FDCAN_NDAT2_ND35_Pos) |
| #define | FDCAN_NDAT2_ND35 FDCAN_NDAT2_ND35_Msk |
| #define | FDCAN_NDAT2_ND36_Pos (4U) |
| #define | FDCAN_NDAT2_ND36_Msk (0x1UL << FDCAN_NDAT2_ND36_Pos) |
| #define | FDCAN_NDAT2_ND36 FDCAN_NDAT2_ND36_Msk |
| #define | FDCAN_NDAT2_ND37_Pos (5U) |
| #define | FDCAN_NDAT2_ND37_Msk (0x1UL << FDCAN_NDAT2_ND37_Pos) |
| #define | FDCAN_NDAT2_ND37 FDCAN_NDAT2_ND37_Msk |
| #define | FDCAN_NDAT2_ND38_Pos (6U) |
| #define | FDCAN_NDAT2_ND38_Msk (0x1UL << FDCAN_NDAT2_ND38_Pos) |
| #define | FDCAN_NDAT2_ND38 FDCAN_NDAT2_ND38_Msk |
| #define | FDCAN_NDAT2_ND39_Pos (7U) |
| #define | FDCAN_NDAT2_ND39_Msk (0x1UL << FDCAN_NDAT2_ND39_Pos) |
| #define | FDCAN_NDAT2_ND39 FDCAN_NDAT2_ND39_Msk |
| #define | FDCAN_NDAT2_ND40_Pos (8U) |
| #define | FDCAN_NDAT2_ND40_Msk (0x1UL << FDCAN_NDAT2_ND40_Pos) |
| #define | FDCAN_NDAT2_ND40 FDCAN_NDAT2_ND40_Msk |
| #define | FDCAN_NDAT2_ND41_Pos (9U) |
| #define | FDCAN_NDAT2_ND41_Msk (0x1UL << FDCAN_NDAT2_ND41_Pos) |
| #define | FDCAN_NDAT2_ND41 FDCAN_NDAT2_ND41_Msk |
| #define | FDCAN_NDAT2_ND42_Pos (10U) |
| #define | FDCAN_NDAT2_ND42_Msk (0x1UL << FDCAN_NDAT2_ND42_Pos) |
| #define | FDCAN_NDAT2_ND42 FDCAN_NDAT2_ND42_Msk |
| #define | FDCAN_NDAT2_ND43_Pos (11U) |
| #define | FDCAN_NDAT2_ND43_Msk (0x1UL << FDCAN_NDAT2_ND43_Pos) |
| #define | FDCAN_NDAT2_ND43 FDCAN_NDAT2_ND43_Msk |
| #define | FDCAN_NDAT2_ND44_Pos (12U) |
| #define | FDCAN_NDAT2_ND44_Msk (0x1UL << FDCAN_NDAT2_ND44_Pos) |
| #define | FDCAN_NDAT2_ND44 FDCAN_NDAT2_ND44_Msk |
| #define | FDCAN_NDAT2_ND45_Pos (13U) |
| #define | FDCAN_NDAT2_ND45_Msk (0x1UL << FDCAN_NDAT2_ND45_Pos) |
| #define | FDCAN_NDAT2_ND45 FDCAN_NDAT2_ND45_Msk |
| #define | FDCAN_NDAT2_ND46_Pos (14U) |
| #define | FDCAN_NDAT2_ND46_Msk (0x1UL << FDCAN_NDAT2_ND46_Pos) |
| #define | FDCAN_NDAT2_ND46 FDCAN_NDAT2_ND46_Msk |
| #define | FDCAN_NDAT2_ND47_Pos (15U) |
| #define | FDCAN_NDAT2_ND47_Msk (0x1UL << FDCAN_NDAT2_ND47_Pos) |
| #define | FDCAN_NDAT2_ND47 FDCAN_NDAT2_ND47_Msk |
| #define | FDCAN_NDAT2_ND48_Pos (16U) |
| #define | FDCAN_NDAT2_ND48_Msk (0x1UL << FDCAN_NDAT2_ND48_Pos) |
| #define | FDCAN_NDAT2_ND48 FDCAN_NDAT2_ND48_Msk |
| #define | FDCAN_NDAT2_ND49_Pos (17U) |
| #define | FDCAN_NDAT2_ND49_Msk (0x1UL << FDCAN_NDAT2_ND49_Pos) |
| #define | FDCAN_NDAT2_ND49 FDCAN_NDAT2_ND49_Msk |
| #define | FDCAN_NDAT2_ND50_Pos (18U) |
| #define | FDCAN_NDAT2_ND50_Msk (0x1UL << FDCAN_NDAT2_ND50_Pos) |
| #define | FDCAN_NDAT2_ND50 FDCAN_NDAT2_ND50_Msk |
| #define | FDCAN_NDAT2_ND51_Pos (19U) |
| #define | FDCAN_NDAT2_ND51_Msk (0x1UL << FDCAN_NDAT2_ND51_Pos) |
| #define | FDCAN_NDAT2_ND51 FDCAN_NDAT2_ND51_Msk |
| #define | FDCAN_NDAT2_ND52_Pos (20U) |
| #define | FDCAN_NDAT2_ND52_Msk (0x1UL << FDCAN_NDAT2_ND52_Pos) |
| #define | FDCAN_NDAT2_ND52 FDCAN_NDAT2_ND52_Msk |
| #define | FDCAN_NDAT2_ND53_Pos (21U) |
| #define | FDCAN_NDAT2_ND53_Msk (0x1UL << FDCAN_NDAT2_ND53_Pos) |
| #define | FDCAN_NDAT2_ND53 FDCAN_NDAT2_ND53_Msk |
| #define | FDCAN_NDAT2_ND54_Pos (22U) |
| #define | FDCAN_NDAT2_ND54_Msk (0x1UL << FDCAN_NDAT2_ND54_Pos) |
| #define | FDCAN_NDAT2_ND54 FDCAN_NDAT2_ND54_Msk |
| #define | FDCAN_NDAT2_ND55_Pos (23U) |
| #define | FDCAN_NDAT2_ND55_Msk (0x1UL << FDCAN_NDAT2_ND55_Pos) |
| #define | FDCAN_NDAT2_ND55 FDCAN_NDAT2_ND55_Msk |
| #define | FDCAN_NDAT2_ND56_Pos (24U) |
| #define | FDCAN_NDAT2_ND56_Msk (0x1UL << FDCAN_NDAT2_ND56_Pos) |
| #define | FDCAN_NDAT2_ND56 FDCAN_NDAT2_ND56_Msk |
| #define | FDCAN_NDAT2_ND57_Pos (25U) |
| #define | FDCAN_NDAT2_ND57_Msk (0x1UL << FDCAN_NDAT2_ND57_Pos) |
| #define | FDCAN_NDAT2_ND57 FDCAN_NDAT2_ND57_Msk |
| #define | FDCAN_NDAT2_ND58_Pos (26U) |
| #define | FDCAN_NDAT2_ND58_Msk (0x1UL << FDCAN_NDAT2_ND58_Pos) |
| #define | FDCAN_NDAT2_ND58 FDCAN_NDAT2_ND58_Msk |
| #define | FDCAN_NDAT2_ND59_Pos (27U) |
| #define | FDCAN_NDAT2_ND59_Msk (0x1UL << FDCAN_NDAT2_ND59_Pos) |
| #define | FDCAN_NDAT2_ND59 FDCAN_NDAT2_ND59_Msk |
| #define | FDCAN_NDAT2_ND60_Pos (28U) |
| #define | FDCAN_NDAT2_ND60_Msk (0x1UL << FDCAN_NDAT2_ND60_Pos) |
| #define | FDCAN_NDAT2_ND60 FDCAN_NDAT2_ND60_Msk |
| #define | FDCAN_NDAT2_ND61_Pos (29U) |
| #define | FDCAN_NDAT2_ND61_Msk (0x1UL << FDCAN_NDAT2_ND61_Pos) |
| #define | FDCAN_NDAT2_ND61 FDCAN_NDAT2_ND61_Msk |
| #define | FDCAN_NDAT2_ND62_Pos (30U) |
| #define | FDCAN_NDAT2_ND62_Msk (0x1UL << FDCAN_NDAT2_ND62_Pos) |
| #define | FDCAN_NDAT2_ND62 FDCAN_NDAT2_ND62_Msk |
| #define | FDCAN_NDAT2_ND63_Pos (31U) |
| #define | FDCAN_NDAT2_ND63_Msk (0x1UL << FDCAN_NDAT2_ND63_Pos) |
| #define | FDCAN_NDAT2_ND63 FDCAN_NDAT2_ND63_Msk |
| #define | FDCAN_RXF0C_F0SA_Pos (2U) |
| #define | FDCAN_RXF0C_F0SA_Msk (0x3FFFUL << FDCAN_RXF0C_F0SA_Pos) |
| #define | FDCAN_RXF0C_F0SA FDCAN_RXF0C_F0SA_Msk |
| #define | FDCAN_RXF0C_F0S_Pos (16U) |
| #define | FDCAN_RXF0C_F0S_Msk (0x7FUL << FDCAN_RXF0C_F0S_Pos) |
| #define | FDCAN_RXF0C_F0S FDCAN_RXF0C_F0S_Msk |
| #define | FDCAN_RXF0C_F0WM_Pos (24U) |
| #define | FDCAN_RXF0C_F0WM_Msk (0x7FUL << FDCAN_RXF0C_F0WM_Pos) |
| #define | FDCAN_RXF0C_F0WM FDCAN_RXF0C_F0WM_Msk |
| #define | FDCAN_RXF0C_F0OM_Pos (31U) |
| #define | FDCAN_RXF0C_F0OM_Msk (0x1UL << FDCAN_RXF0C_F0OM_Pos) |
| #define | FDCAN_RXF0C_F0OM FDCAN_RXF0C_F0OM_Msk |
| #define | FDCAN_RXF0S_F0FL_Pos (0U) |
| #define | FDCAN_RXF0S_F0FL_Msk (0x7FUL << FDCAN_RXF0S_F0FL_Pos) |
| #define | FDCAN_RXF0S_F0FL FDCAN_RXF0S_F0FL_Msk |
| #define | FDCAN_RXF0S_F0GI_Pos (8U) |
| #define | FDCAN_RXF0S_F0GI_Msk (0x3FUL << FDCAN_RXF0S_F0GI_Pos) |
| #define | FDCAN_RXF0S_F0GI FDCAN_RXF0S_F0GI_Msk |
| #define | FDCAN_RXF0S_F0PI_Pos (16U) |
| #define | FDCAN_RXF0S_F0PI_Msk (0x3FUL << FDCAN_RXF0S_F0PI_Pos) |
| #define | FDCAN_RXF0S_F0PI FDCAN_RXF0S_F0PI_Msk |
| #define | FDCAN_RXF0S_F0F_Pos (24U) |
| #define | FDCAN_RXF0S_F0F_Msk (0x1UL << FDCAN_RXF0S_F0F_Pos) |
| #define | FDCAN_RXF0S_F0F FDCAN_RXF0S_F0F_Msk |
| #define | FDCAN_RXF0S_RF0L_Pos (25U) |
| #define | FDCAN_RXF0S_RF0L_Msk (0x1UL << FDCAN_RXF0S_RF0L_Pos) |
| #define | FDCAN_RXF0S_RF0L FDCAN_RXF0S_RF0L_Msk |
| #define | FDCAN_RXF0A_F0AI_Pos (0U) |
| #define | FDCAN_RXF0A_F0AI_Msk (0x3FUL << FDCAN_RXF0A_F0AI_Pos) |
| #define | FDCAN_RXF0A_F0AI FDCAN_RXF0A_F0AI_Msk |
| #define | FDCAN_RXBC_RBSA_Pos (2U) |
| #define | FDCAN_RXBC_RBSA_Msk (0x3FFFUL << FDCAN_RXBC_RBSA_Pos) |
| #define | FDCAN_RXBC_RBSA FDCAN_RXBC_RBSA_Msk |
| #define | FDCAN_RXF1C_F1SA_Pos (2U) |
| #define | FDCAN_RXF1C_F1SA_Msk (0x3FFFUL << FDCAN_RXF1C_F1SA_Pos) |
| #define | FDCAN_RXF1C_F1SA FDCAN_RXF1C_F1SA_Msk |
| #define | FDCAN_RXF1C_F1S_Pos (16U) |
| #define | FDCAN_RXF1C_F1S_Msk (0x7FUL << FDCAN_RXF1C_F1S_Pos) |
| #define | FDCAN_RXF1C_F1S FDCAN_RXF1C_F1S_Msk |
| #define | FDCAN_RXF1C_F1WM_Pos (24U) |
| #define | FDCAN_RXF1C_F1WM_Msk (0x7FUL << FDCAN_RXF1C_F1WM_Pos) |
| #define | FDCAN_RXF1C_F1WM FDCAN_RXF1C_F1WM_Msk |
| #define | FDCAN_RXF1C_F1OM_Pos (31U) |
| #define | FDCAN_RXF1C_F1OM_Msk (0x1UL << FDCAN_RXF1C_F1OM_Pos) |
| #define | FDCAN_RXF1C_F1OM FDCAN_RXF1C_F1OM_Msk |
| #define | FDCAN_RXF1S_F1FL_Pos (0U) |
| #define | FDCAN_RXF1S_F1FL_Msk (0x7FUL << FDCAN_RXF1S_F1FL_Pos) |
| #define | FDCAN_RXF1S_F1FL FDCAN_RXF1S_F1FL_Msk |
| #define | FDCAN_RXF1S_F1GI_Pos (8U) |
| #define | FDCAN_RXF1S_F1GI_Msk (0x3FUL << FDCAN_RXF1S_F1GI_Pos) |
| #define | FDCAN_RXF1S_F1GI FDCAN_RXF1S_F1GI_Msk |
| #define | FDCAN_RXF1S_F1PI_Pos (16U) |
| #define | FDCAN_RXF1S_F1PI_Msk (0x3FUL << FDCAN_RXF1S_F1PI_Pos) |
| #define | FDCAN_RXF1S_F1PI FDCAN_RXF1S_F1PI_Msk |
| #define | FDCAN_RXF1S_F1F_Pos (24U) |
| #define | FDCAN_RXF1S_F1F_Msk (0x1UL << FDCAN_RXF1S_F1F_Pos) |
| #define | FDCAN_RXF1S_F1F FDCAN_RXF1S_F1F_Msk |
| #define | FDCAN_RXF1S_RF1L_Pos (25U) |
| #define | FDCAN_RXF1S_RF1L_Msk (0x1UL << FDCAN_RXF1S_RF1L_Pos) |
| #define | FDCAN_RXF1S_RF1L FDCAN_RXF1S_RF1L_Msk |
| #define | FDCAN_RXF1A_F1AI_Pos (0U) |
| #define | FDCAN_RXF1A_F1AI_Msk (0x3FUL << FDCAN_RXF1A_F1AI_Pos) |
| #define | FDCAN_RXF1A_F1AI FDCAN_RXF1A_F1AI_Msk |
| #define | FDCAN_RXESC_F0DS_Pos (0U) |
| #define | FDCAN_RXESC_F0DS_Msk (0x7UL << FDCAN_RXESC_F0DS_Pos) |
| #define | FDCAN_RXESC_F0DS FDCAN_RXESC_F0DS_Msk |
| #define | FDCAN_RXESC_F1DS_Pos (4U) |
| #define | FDCAN_RXESC_F1DS_Msk (0x7UL << FDCAN_RXESC_F1DS_Pos) |
| #define | FDCAN_RXESC_F1DS FDCAN_RXESC_F1DS_Msk |
| #define | FDCAN_RXESC_RBDS_Pos (8U) |
| #define | FDCAN_RXESC_RBDS_Msk (0x7UL << FDCAN_RXESC_RBDS_Pos) |
| #define | FDCAN_RXESC_RBDS FDCAN_RXESC_RBDS_Msk |
| #define | FDCAN_TXBC_TBSA_Pos (2U) |
| #define | FDCAN_TXBC_TBSA_Msk (0x3FFFUL << FDCAN_TXBC_TBSA_Pos) |
| #define | FDCAN_TXBC_TBSA FDCAN_TXBC_TBSA_Msk |
| #define | FDCAN_TXBC_NDTB_Pos (16U) |
| #define | FDCAN_TXBC_NDTB_Msk (0x3FUL << FDCAN_TXBC_NDTB_Pos) |
| #define | FDCAN_TXBC_NDTB FDCAN_TXBC_NDTB_Msk |
| #define | FDCAN_TXBC_TFQS_Pos (24U) |
| #define | FDCAN_TXBC_TFQS_Msk (0x3FUL << FDCAN_TXBC_TFQS_Pos) |
| #define | FDCAN_TXBC_TFQS FDCAN_TXBC_TFQS_Msk |
| #define | FDCAN_TXBC_TFQM_Pos (30U) |
| #define | FDCAN_TXBC_TFQM_Msk (0x1UL << FDCAN_TXBC_TFQM_Pos) |
| #define | FDCAN_TXBC_TFQM FDCAN_TXBC_TFQM_Msk |
| #define | FDCAN_TXFQS_TFFL_Pos (0U) |
| #define | FDCAN_TXFQS_TFFL_Msk (0x3FUL << FDCAN_TXFQS_TFFL_Pos) |
| #define | FDCAN_TXFQS_TFFL FDCAN_TXFQS_TFFL_Msk |
| #define | FDCAN_TXFQS_TFGI_Pos (8U) |
| #define | FDCAN_TXFQS_TFGI_Msk (0x1FUL << FDCAN_TXFQS_TFGI_Pos) |
| #define | FDCAN_TXFQS_TFGI FDCAN_TXFQS_TFGI_Msk |
| #define | FDCAN_TXFQS_TFQPI_Pos (16U) |
| #define | FDCAN_TXFQS_TFQPI_Msk (0x1FUL << FDCAN_TXFQS_TFQPI_Pos) |
| #define | FDCAN_TXFQS_TFQPI FDCAN_TXFQS_TFQPI_Msk |
| #define | FDCAN_TXFQS_TFQF_Pos (21U) |
| #define | FDCAN_TXFQS_TFQF_Msk (0x1UL << FDCAN_TXFQS_TFQF_Pos) |
| #define | FDCAN_TXFQS_TFQF FDCAN_TXFQS_TFQF_Msk |
| #define | FDCAN_TXESC_TBDS_Pos (0U) |
| #define | FDCAN_TXESC_TBDS_Msk (0x7UL << FDCAN_TXESC_TBDS_Pos) |
| #define | FDCAN_TXESC_TBDS FDCAN_TXESC_TBDS_Msk |
| #define | FDCAN_TXBRP_TRP_Pos (0U) |
| #define | FDCAN_TXBRP_TRP_Msk (0xFFFFFFFFUL << FDCAN_TXBRP_TRP_Pos) |
| #define | FDCAN_TXBRP_TRP FDCAN_TXBRP_TRP_Msk |
| #define | FDCAN_TXBAR_AR_Pos (0U) |
| #define | FDCAN_TXBAR_AR_Msk (0xFFFFFFFFUL << FDCAN_TXBAR_AR_Pos) |
| #define | FDCAN_TXBAR_AR FDCAN_TXBAR_AR_Msk |
| #define | FDCAN_TXBCR_CR_Pos (0U) |
| #define | FDCAN_TXBCR_CR_Msk (0xFFFFFFFFUL << FDCAN_TXBCR_CR_Pos) |
| #define | FDCAN_TXBCR_CR FDCAN_TXBCR_CR_Msk |
| #define | FDCAN_TXBTO_TO_Pos (0U) |
| #define | FDCAN_TXBTO_TO_Msk (0xFFFFFFFFUL << FDCAN_TXBTO_TO_Pos) |
| #define | FDCAN_TXBTO_TO FDCAN_TXBTO_TO_Msk |
| #define | FDCAN_TXBCF_CF_Pos (0U) |
| #define | FDCAN_TXBCF_CF_Msk (0xFFFFFFFFUL << FDCAN_TXBCF_CF_Pos) |
| #define | FDCAN_TXBCF_CF FDCAN_TXBCF_CF_Msk |
| #define | FDCAN_TXBTIE_TIE_Pos (0U) |
| #define | FDCAN_TXBTIE_TIE_Msk (0xFFFFFFFFUL << FDCAN_TXBTIE_TIE_Pos) |
| #define | FDCAN_TXBTIE_TIE FDCAN_TXBTIE_TIE_Msk |
| #define | FDCAN_TXBCIE_CFIE_Pos (0U) |
| #define | FDCAN_TXBCIE_CFIE_Msk (0xFFFFFFFFUL << FDCAN_TXBCIE_CFIE_Pos) |
| #define | FDCAN_TXBCIE_CFIE FDCAN_TXBCIE_CFIE_Msk |
| #define | FDCAN_TXEFC_EFSA_Pos (2U) |
| #define | FDCAN_TXEFC_EFSA_Msk (0x3FFFUL << FDCAN_TXEFC_EFSA_Pos) |
| #define | FDCAN_TXEFC_EFSA FDCAN_TXEFC_EFSA_Msk |
| #define | FDCAN_TXEFC_EFS_Pos (16U) |
| #define | FDCAN_TXEFC_EFS_Msk (0x3FUL << FDCAN_TXEFC_EFS_Pos) |
| #define | FDCAN_TXEFC_EFS FDCAN_TXEFC_EFS_Msk |
| #define | FDCAN_TXEFC_EFWM_Pos (24U) |
| #define | FDCAN_TXEFC_EFWM_Msk (0x3FUL << FDCAN_TXEFC_EFWM_Pos) |
| #define | FDCAN_TXEFC_EFWM FDCAN_TXEFC_EFWM_Msk |
| #define | FDCAN_TXEFS_EFFL_Pos (0U) |
| #define | FDCAN_TXEFS_EFFL_Msk (0x3FUL << FDCAN_TXEFS_EFFL_Pos) |
| #define | FDCAN_TXEFS_EFFL FDCAN_TXEFS_EFFL_Msk |
| #define | FDCAN_TXEFS_EFGI_Pos (8U) |
| #define | FDCAN_TXEFS_EFGI_Msk (0x1FUL << FDCAN_TXEFS_EFGI_Pos) |
| #define | FDCAN_TXEFS_EFGI FDCAN_TXEFS_EFGI_Msk |
| #define | FDCAN_TXEFS_EFPI_Pos (16U) |
| #define | FDCAN_TXEFS_EFPI_Msk (0x1FUL << FDCAN_TXEFS_EFPI_Pos) |
| #define | FDCAN_TXEFS_EFPI FDCAN_TXEFS_EFPI_Msk |
| #define | FDCAN_TXEFS_EFF_Pos (24U) |
| #define | FDCAN_TXEFS_EFF_Msk (0x1UL << FDCAN_TXEFS_EFF_Pos) |
| #define | FDCAN_TXEFS_EFF FDCAN_TXEFS_EFF_Msk |
| #define | FDCAN_TXEFS_TEFL_Pos (25U) |
| #define | FDCAN_TXEFS_TEFL_Msk (0x1UL << FDCAN_TXEFS_TEFL_Pos) |
| #define | FDCAN_TXEFS_TEFL FDCAN_TXEFS_TEFL_Msk |
| #define | FDCAN_TXEFA_EFAI_Pos (0U) |
| #define | FDCAN_TXEFA_EFAI_Msk (0x1FUL << FDCAN_TXEFA_EFAI_Pos) |
| #define | FDCAN_TXEFA_EFAI FDCAN_TXEFA_EFAI_Msk |
| #define | FDCAN_TTTMC_TMSA_Pos (2U) |
| #define | FDCAN_TTTMC_TMSA_Msk (0x3FFFUL << FDCAN_TTTMC_TMSA_Pos) |
| #define | FDCAN_TTTMC_TMSA FDCAN_TTTMC_TMSA_Msk |
| #define | FDCAN_TTTMC_TME_Pos (16U) |
| #define | FDCAN_TTTMC_TME_Msk (0x7FUL << FDCAN_TTTMC_TME_Pos) |
| #define | FDCAN_TTTMC_TME FDCAN_TTTMC_TME_Msk |
| #define | FDCAN_TTRMC_RID_Pos (0U) |
| #define | FDCAN_TTRMC_RID_Msk (0x1FFFFFFFUL << FDCAN_TTRMC_RID_Pos) |
| #define | FDCAN_TTRMC_RID FDCAN_TTRMC_RID_Msk |
| #define | FDCAN_TTRMC_XTD_Pos (30U) |
| #define | FDCAN_TTRMC_XTD_Msk (0x1UL << FDCAN_TTRMC_XTD_Pos) |
| #define | FDCAN_TTRMC_XTD FDCAN_TTRMC_XTD_Msk |
| #define | FDCAN_TTRMC_RMPS_Pos (31U) |
| #define | FDCAN_TTRMC_RMPS_Msk (0x1UL << FDCAN_TTRMC_RMPS_Pos) |
| #define | FDCAN_TTRMC_RMPS FDCAN_TTRMC_RMPS_Msk |
| #define | FDCAN_TTOCF_OM_Pos (0U) |
| #define | FDCAN_TTOCF_OM_Msk (0x3UL << FDCAN_TTOCF_OM_Pos) |
| #define | FDCAN_TTOCF_OM FDCAN_TTOCF_OM_Msk |
| #define | FDCAN_TTOCF_GEN_Pos (3U) |
| #define | FDCAN_TTOCF_GEN_Msk (0x1UL << FDCAN_TTOCF_GEN_Pos) |
| #define | FDCAN_TTOCF_GEN FDCAN_TTOCF_GEN_Msk |
| #define | FDCAN_TTOCF_TM_Pos (4U) |
| #define | FDCAN_TTOCF_TM_Msk (0x1UL << FDCAN_TTOCF_TM_Pos) |
| #define | FDCAN_TTOCF_TM FDCAN_TTOCF_TM_Msk |
| #define | FDCAN_TTOCF_LDSDL_Pos (5U) |
| #define | FDCAN_TTOCF_LDSDL_Msk (0x7UL << FDCAN_TTOCF_LDSDL_Pos) |
| #define | FDCAN_TTOCF_LDSDL FDCAN_TTOCF_LDSDL_Msk |
| #define | FDCAN_TTOCF_IRTO_Pos (8U) |
| #define | FDCAN_TTOCF_IRTO_Msk (0x7FUL << FDCAN_TTOCF_IRTO_Pos) |
| #define | FDCAN_TTOCF_IRTO FDCAN_TTOCF_IRTO_Msk |
| #define | FDCAN_TTOCF_EECS_Pos (15U) |
| #define | FDCAN_TTOCF_EECS_Msk (0x1UL << FDCAN_TTOCF_EECS_Pos) |
| #define | FDCAN_TTOCF_EECS FDCAN_TTOCF_EECS_Msk |
| #define | FDCAN_TTOCF_AWL_Pos (16U) |
| #define | FDCAN_TTOCF_AWL_Msk (0xFFUL << FDCAN_TTOCF_AWL_Pos) |
| #define | FDCAN_TTOCF_AWL FDCAN_TTOCF_AWL_Msk |
| #define | FDCAN_TTOCF_EGTF_Pos (24U) |
| #define | FDCAN_TTOCF_EGTF_Msk (0x1UL << FDCAN_TTOCF_EGTF_Pos) |
| #define | FDCAN_TTOCF_EGTF FDCAN_TTOCF_EGTF_Msk |
| #define | FDCAN_TTOCF_ECC_Pos (25U) |
| #define | FDCAN_TTOCF_ECC_Msk (0x1UL << FDCAN_TTOCF_ECC_Pos) |
| #define | FDCAN_TTOCF_ECC FDCAN_TTOCF_ECC_Msk |
| #define | FDCAN_TTOCF_EVTP_Pos (26U) |
| #define | FDCAN_TTOCF_EVTP_Msk (0x1UL << FDCAN_TTOCF_EVTP_Pos) |
| #define | FDCAN_TTOCF_EVTP FDCAN_TTOCF_EVTP_Msk |
| #define | FDCAN_TTMLM_CCM_Pos (0U) |
| #define | FDCAN_TTMLM_CCM_Msk (0x3FUL << FDCAN_TTMLM_CCM_Pos) |
| #define | FDCAN_TTMLM_CCM FDCAN_TTMLM_CCM_Msk |
| #define | FDCAN_TTMLM_CSS_Pos (6U) |
| #define | FDCAN_TTMLM_CSS_Msk (0x3UL << FDCAN_TTMLM_CSS_Pos) |
| #define | FDCAN_TTMLM_CSS FDCAN_TTMLM_CSS_Msk |
| #define | FDCAN_TTMLM_TXEW_Pos (8U) |
| #define | FDCAN_TTMLM_TXEW_Msk (0xFUL << FDCAN_TTMLM_TXEW_Pos) |
| #define | FDCAN_TTMLM_TXEW FDCAN_TTMLM_TXEW_Msk |
| #define | FDCAN_TTMLM_ENTT_Pos (16U) |
| #define | FDCAN_TTMLM_ENTT_Msk (0xFFFUL << FDCAN_TTMLM_ENTT_Pos) |
| #define | FDCAN_TTMLM_ENTT FDCAN_TTMLM_ENTT_Msk |
| #define | FDCAN_TURCF_NCL_Pos (0U) |
| #define | FDCAN_TURCF_NCL_Msk (0xFFFFUL << FDCAN_TURCF_NCL_Pos) |
| #define | FDCAN_TURCF_NCL FDCAN_TURCF_NCL_Msk |
| #define | FDCAN_TURCF_DC_Pos (16U) |
| #define | FDCAN_TURCF_DC_Msk (0x3FFFUL << FDCAN_TURCF_DC_Pos) |
| #define | FDCAN_TURCF_DC FDCAN_TURCF_DC_Msk |
| #define | FDCAN_TURCF_ELT_Pos (31U) |
| #define | FDCAN_TURCF_ELT_Msk (0x1UL << FDCAN_TURCF_ELT_Pos) |
| #define | FDCAN_TURCF_ELT FDCAN_TURCF_ELT_Msk |
| #define | FDCAN_TTOCN_SGT_Pos (0U) |
| #define | FDCAN_TTOCN_SGT_Msk (0x1UL << FDCAN_TTOCN_SGT_Pos) |
| #define | FDCAN_TTOCN_SGT FDCAN_TTOCN_SGT_Msk |
| #define | FDCAN_TTOCN_ECS_Pos (1U) |
| #define | FDCAN_TTOCN_ECS_Msk (0x1UL << FDCAN_TTOCN_ECS_Pos) |
| #define | FDCAN_TTOCN_ECS FDCAN_TTOCN_ECS_Msk |
| #define | FDCAN_TTOCN_SWP_Pos (2U) |
| #define | FDCAN_TTOCN_SWP_Msk (0x1UL << FDCAN_TTOCN_SWP_Pos) |
| #define | FDCAN_TTOCN_SWP FDCAN_TTOCN_SWP_Msk |
| #define | FDCAN_TTOCN_SWS_Pos (3U) |
| #define | FDCAN_TTOCN_SWS_Msk (0x3UL << FDCAN_TTOCN_SWS_Pos) |
| #define | FDCAN_TTOCN_SWS FDCAN_TTOCN_SWS_Msk |
| #define | FDCAN_TTOCN_RTIE_Pos (5U) |
| #define | FDCAN_TTOCN_RTIE_Msk (0x1UL << FDCAN_TTOCN_RTIE_Pos) |
| #define | FDCAN_TTOCN_RTIE FDCAN_TTOCN_RTIE_Msk |
| #define | FDCAN_TTOCN_TMC_Pos (6U) |
| #define | FDCAN_TTOCN_TMC_Msk (0x3UL << FDCAN_TTOCN_TMC_Pos) |
| #define | FDCAN_TTOCN_TMC FDCAN_TTOCN_TMC_Msk |
| #define | FDCAN_TTOCN_TTIE_Pos (8U) |
| #define | FDCAN_TTOCN_TTIE_Msk (0x1UL << FDCAN_TTOCN_TTIE_Pos) |
| #define | FDCAN_TTOCN_TTIE FDCAN_TTOCN_TTIE_Msk |
| #define | FDCAN_TTOCN_GCS_Pos (9U) |
| #define | FDCAN_TTOCN_GCS_Msk (0x1UL << FDCAN_TTOCN_GCS_Pos) |
| #define | FDCAN_TTOCN_GCS FDCAN_TTOCN_GCS_Msk |
| #define | FDCAN_TTOCN_FGP_Pos (10U) |
| #define | FDCAN_TTOCN_FGP_Msk (0x1UL << FDCAN_TTOCN_FGP_Pos) |
| #define | FDCAN_TTOCN_FGP FDCAN_TTOCN_FGP_Msk |
| #define | FDCAN_TTOCN_TMG_Pos (11U) |
| #define | FDCAN_TTOCN_TMG_Msk (0x1UL << FDCAN_TTOCN_TMG_Pos) |
| #define | FDCAN_TTOCN_TMG FDCAN_TTOCN_TMG_Msk |
| #define | FDCAN_TTOCN_NIG_Pos (12U) |
| #define | FDCAN_TTOCN_NIG_Msk (0x1UL << FDCAN_TTOCN_NIG_Pos) |
| #define | FDCAN_TTOCN_NIG FDCAN_TTOCN_NIG_Msk |
| #define | FDCAN_TTOCN_ESCN_Pos (13U) |
| #define | FDCAN_TTOCN_ESCN_Msk (0x1UL << FDCAN_TTOCN_ESCN_Pos) |
| #define | FDCAN_TTOCN_ESCN FDCAN_TTOCN_ESCN_Msk |
| #define | FDCAN_TTOCN_LCKC_Pos (15U) |
| #define | FDCAN_TTOCN_LCKC_Msk (0x1UL << FDCAN_TTOCN_LCKC_Pos) |
| #define | FDCAN_TTOCN_LCKC FDCAN_TTOCN_LCKC_Msk |
| #define | FDCAN_TTGTP_TP_Pos (0U) |
| #define | FDCAN_TTGTP_TP_Msk (0xFFFFUL << FDCAN_TTGTP_TP_Pos) |
| #define | FDCAN_TTGTP_TP FDCAN_TTGTP_TP_Msk |
| #define | FDCAN_TTGTP_CTP_Pos (16U) |
| #define | FDCAN_TTGTP_CTP_Msk (0xFFFFUL << FDCAN_TTGTP_CTP_Pos) |
| #define | FDCAN_TTGTP_CTP FDCAN_TTGTP_CTP_Msk |
| #define | FDCAN_TTTMK_TM_Pos (0U) |
| #define | FDCAN_TTTMK_TM_Msk (0xFFFFUL << FDCAN_TTTMK_TM_Pos) |
| #define | FDCAN_TTTMK_TM FDCAN_TTTMK_TM_Msk |
| #define | FDCAN_TTTMK_TICC_Pos (16U) |
| #define | FDCAN_TTTMK_TICC_Msk (0x7FUL << FDCAN_TTTMK_TICC_Pos) |
| #define | FDCAN_TTTMK_TICC FDCAN_TTTMK_TICC_Msk |
| #define | FDCAN_TTTMK_LCKM_Pos (31U) |
| #define | FDCAN_TTTMK_LCKM_Msk (0x1UL << FDCAN_TTTMK_LCKM_Pos) |
| #define | FDCAN_TTTMK_LCKM FDCAN_TTTMK_LCKM_Msk |
| #define | FDCAN_TTIR_SBC_Pos (0U) |
| #define | FDCAN_TTIR_SBC_Msk (0x1UL << FDCAN_TTIR_SBC_Pos) |
| #define | FDCAN_TTIR_SBC FDCAN_TTIR_SBC_Msk |
| #define | FDCAN_TTIR_SMC_Pos (1U) |
| #define | FDCAN_TTIR_SMC_Msk (0x1UL << FDCAN_TTIR_SMC_Pos) |
| #define | FDCAN_TTIR_SMC FDCAN_TTIR_SMC_Msk |
| #define | FDCAN_TTIR_CSM_Pos (2U) |
| #define | FDCAN_TTIR_CSM_Msk (0x1UL << FDCAN_TTIR_CSM_Pos) |
| #define | FDCAN_TTIR_CSM FDCAN_TTIR_CSM_Msk |
| #define | FDCAN_TTIR_SOG_Pos (3U) |
| #define | FDCAN_TTIR_SOG_Msk (0x1UL << FDCAN_TTIR_SOG_Pos) |
| #define | FDCAN_TTIR_SOG FDCAN_TTIR_SOG_Msk |
| #define | FDCAN_TTIR_RTMI_Pos (4U) |
| #define | FDCAN_TTIR_RTMI_Msk (0x1UL << FDCAN_TTIR_RTMI_Pos) |
| #define | FDCAN_TTIR_RTMI FDCAN_TTIR_RTMI_Msk |
| #define | FDCAN_TTIR_TTMI_Pos (5U) |
| #define | FDCAN_TTIR_TTMI_Msk (0x1UL << FDCAN_TTIR_TTMI_Pos) |
| #define | FDCAN_TTIR_TTMI FDCAN_TTIR_TTMI_Msk |
| #define | FDCAN_TTIR_SWE_Pos (6U) |
| #define | FDCAN_TTIR_SWE_Msk (0x1UL << FDCAN_TTIR_SWE_Pos) |
| #define | FDCAN_TTIR_SWE FDCAN_TTIR_SWE_Msk |
| #define | FDCAN_TTIR_GTW_Pos (7U) |
| #define | FDCAN_TTIR_GTW_Msk (0x1UL << FDCAN_TTIR_GTW_Pos) |
| #define | FDCAN_TTIR_GTW FDCAN_TTIR_GTW_Msk |
| #define | FDCAN_TTIR_GTD_Pos (8U) |
| #define | FDCAN_TTIR_GTD_Msk (0x1UL << FDCAN_TTIR_GTD_Pos) |
| #define | FDCAN_TTIR_GTD FDCAN_TTIR_GTD_Msk |
| #define | FDCAN_TTIR_GTE_Pos (9U) |
| #define | FDCAN_TTIR_GTE_Msk (0x1UL << FDCAN_TTIR_GTE_Pos) |
| #define | FDCAN_TTIR_GTE FDCAN_TTIR_GTE_Msk |
| #define | FDCAN_TTIR_TXU_Pos (10U) |
| #define | FDCAN_TTIR_TXU_Msk (0x1UL << FDCAN_TTIR_TXU_Pos) |
| #define | FDCAN_TTIR_TXU FDCAN_TTIR_TXU_Msk |
| #define | FDCAN_TTIR_TXO_Pos (11U) |
| #define | FDCAN_TTIR_TXO_Msk (0x1UL << FDCAN_TTIR_TXO_Pos) |
| #define | FDCAN_TTIR_TXO FDCAN_TTIR_TXO_Msk |
| #define | FDCAN_TTIR_SE1_Pos (12U) |
| #define | FDCAN_TTIR_SE1_Msk (0x1UL << FDCAN_TTIR_SE1_Pos) |
| #define | FDCAN_TTIR_SE1 FDCAN_TTIR_SE1_Msk |
| #define | FDCAN_TTIR_SE2_Pos (13U) |
| #define | FDCAN_TTIR_SE2_Msk (0x1UL << FDCAN_TTIR_SE2_Pos) |
| #define | FDCAN_TTIR_SE2 FDCAN_TTIR_SE2_Msk |
| #define | FDCAN_TTIR_ELC_Pos (14U) |
| #define | FDCAN_TTIR_ELC_Msk (0x1UL << FDCAN_TTIR_ELC_Pos) |
| #define | FDCAN_TTIR_ELC FDCAN_TTIR_ELC_Msk |
| #define | FDCAN_TTIR_IWT_Pos (15U) |
| #define | FDCAN_TTIR_IWT_Msk (0x1UL << FDCAN_TTIR_IWT_Pos) |
| #define | FDCAN_TTIR_IWT FDCAN_TTIR_IWT_Msk |
| #define | FDCAN_TTIR_WT_Pos (16U) |
| #define | FDCAN_TTIR_WT_Msk (0x1UL << FDCAN_TTIR_WT_Pos) |
| #define | FDCAN_TTIR_WT FDCAN_TTIR_WT_Msk |
| #define | FDCAN_TTIR_AW_Pos (17U) |
| #define | FDCAN_TTIR_AW_Msk (0x1UL << FDCAN_TTIR_AW_Pos) |
| #define | FDCAN_TTIR_AW FDCAN_TTIR_AW_Msk |
| #define | FDCAN_TTIR_CER_Pos (18U) |
| #define | FDCAN_TTIR_CER_Msk (0x1UL << FDCAN_TTIR_CER_Pos) |
| #define | FDCAN_TTIR_CER FDCAN_TTIR_CER_Msk |
| #define | FDCAN_TTIE_SBCE_Pos (0U) |
| #define | FDCAN_TTIE_SBCE_Msk (0x1UL << FDCAN_TTIE_SBCE_Pos) |
| #define | FDCAN_TTIE_SBCE FDCAN_TTIE_SBCE_Msk |
| #define | FDCAN_TTIE_SMCE_Pos (1U) |
| #define | FDCAN_TTIE_SMCE_Msk (0x1UL << FDCAN_TTIE_SMCE_Pos) |
| #define | FDCAN_TTIE_SMCE FDCAN_TTIE_SMCE_Msk |
| #define | FDCAN_TTIE_CSME_Pos (2U) |
| #define | FDCAN_TTIE_CSME_Msk (0x1UL << FDCAN_TTIE_CSME_Pos) |
| #define | FDCAN_TTIE_CSME FDCAN_TTIE_CSME_Msk |
| #define | FDCAN_TTIE_SOGE_Pos (3U) |
| #define | FDCAN_TTIE_SOGE_Msk (0x1UL << FDCAN_TTIE_SOGE_Pos) |
| #define | FDCAN_TTIE_SOGE FDCAN_TTIE_SOGE_Msk |
| #define | FDCAN_TTIE_RTMIE_Pos (4U) |
| #define | FDCAN_TTIE_RTMIE_Msk (0x1UL << FDCAN_TTIE_RTMIE_Pos) |
| #define | FDCAN_TTIE_RTMIE FDCAN_TTIE_RTMIE_Msk |
| #define | FDCAN_TTIE_TTMIE_Pos (5U) |
| #define | FDCAN_TTIE_TTMIE_Msk (0x1UL << FDCAN_TTIE_TTMIE_Pos) |
| #define | FDCAN_TTIE_TTMIE FDCAN_TTIE_TTMIE_Msk |
| #define | FDCAN_TTIE_SWEE_Pos (6U) |
| #define | FDCAN_TTIE_SWEE_Msk (0x1UL << FDCAN_TTIE_SWEE_Pos) |
| #define | FDCAN_TTIE_SWEE FDCAN_TTIE_SWEE_Msk |
| #define | FDCAN_TTIE_GTWE_Pos (7U) |
| #define | FDCAN_TTIE_GTWE_Msk (0x1UL << FDCAN_TTIE_GTWE_Pos) |
| #define | FDCAN_TTIE_GTWE FDCAN_TTIE_GTWE_Msk |
| #define | FDCAN_TTIE_GTDE_Pos (8U) |
| #define | FDCAN_TTIE_GTDE_Msk (0x1UL << FDCAN_TTIE_GTDE_Pos) |
| #define | FDCAN_TTIE_GTDE FDCAN_TTIE_GTDE_Msk |
| #define | FDCAN_TTIE_GTEE_Pos (9U) |
| #define | FDCAN_TTIE_GTEE_Msk (0x1UL << FDCAN_TTIE_GTEE_Pos) |
| #define | FDCAN_TTIE_GTEE FDCAN_TTIE_GTEE_Msk |
| #define | FDCAN_TTIE_TXUE_Pos (10U) |
| #define | FDCAN_TTIE_TXUE_Msk (0x1UL << FDCAN_TTIE_TXUE_Pos) |
| #define | FDCAN_TTIE_TXUE FDCAN_TTIE_TXUE_Msk |
| #define | FDCAN_TTIE_TXOE_Pos (11U) |
| #define | FDCAN_TTIE_TXOE_Msk (0x1UL << FDCAN_TTIE_TXOE_Pos) |
| #define | FDCAN_TTIE_TXOE FDCAN_TTIE_TXOE_Msk |
| #define | FDCAN_TTIE_SE1E_Pos (12U) |
| #define | FDCAN_TTIE_SE1E_Msk (0x1UL << FDCAN_TTIE_SE1E_Pos) |
| #define | FDCAN_TTIE_SE1E FDCAN_TTIE_SE1E_Msk |
| #define | FDCAN_TTIE_SE2E_Pos (13U) |
| #define | FDCAN_TTIE_SE2E_Msk (0x1UL << FDCAN_TTIE_SE2E_Pos) |
| #define | FDCAN_TTIE_SE2E FDCAN_TTIE_SE2E_Msk |
| #define | FDCAN_TTIE_ELCE_Pos (14U) |
| #define | FDCAN_TTIE_ELCE_Msk (0x1UL << FDCAN_TTIE_ELCE_Pos) |
| #define | FDCAN_TTIE_ELCE FDCAN_TTIE_ELCE_Msk |
| #define | FDCAN_TTIE_IWTE_Pos (15U) |
| #define | FDCAN_TTIE_IWTE_Msk (0x1UL << FDCAN_TTIE_IWTE_Pos) |
| #define | FDCAN_TTIE_IWTE FDCAN_TTIE_IWTE_Msk |
| #define | FDCAN_TTIE_WTE_Pos (16U) |
| #define | FDCAN_TTIE_WTE_Msk (0x1UL << FDCAN_TTIE_WTE_Pos) |
| #define | FDCAN_TTIE_WTE FDCAN_TTIE_WTE_Msk |
| #define | FDCAN_TTIE_AWE_Pos (17U) |
| #define | FDCAN_TTIE_AWE_Msk (0x1UL << FDCAN_TTIE_AWE_Pos) |
| #define | FDCAN_TTIE_AWE FDCAN_TTIE_AWE_Msk |
| #define | FDCAN_TTIE_CERE_Pos (18U) |
| #define | FDCAN_TTIE_CERE_Msk (0x1UL << FDCAN_TTIE_CERE_Pos) |
| #define | FDCAN_TTIE_CERE FDCAN_TTIE_CERE_Msk |
| #define | FDCAN_TTILS_SBCS_Pos (0U) |
| #define | FDCAN_TTILS_SBCS_Msk (0x1UL << FDCAN_TTILS_SBCS_Pos) |
| #define | FDCAN_TTILS_SBCS FDCAN_TTILS_SBCS_Msk |
| #define | FDCAN_TTILS_SMCS_Pos (1U) |
| #define | FDCAN_TTILS_SMCS_Msk (0x1UL << FDCAN_TTILS_SMCS_Pos) |
| #define | FDCAN_TTILS_SMCS FDCAN_TTILS_SMCS_Msk |
| #define | FDCAN_TTILS_CSMS_Pos (2U) |
| #define | FDCAN_TTILS_CSMS_Msk (0x1UL << FDCAN_TTILS_CSMS_Pos) |
| #define | FDCAN_TTILS_CSMS FDCAN_TTILS_CSMS_Msk |
| #define | FDCAN_TTILS_SOGS_Pos (3U) |
| #define | FDCAN_TTILS_SOGS_Msk (0x1UL << FDCAN_TTILS_SOGS_Pos) |
| #define | FDCAN_TTILS_SOGS FDCAN_TTILS_SOGS_Msk |
| #define | FDCAN_TTILS_RTMIS_Pos (4U) |
| #define | FDCAN_TTILS_RTMIS_Msk (0x1UL << FDCAN_TTILS_RTMIS_Pos) |
| #define | FDCAN_TTILS_RTMIS FDCAN_TTILS_RTMIS_Msk |
| #define | FDCAN_TTILS_TTMIS_Pos (5U) |
| #define | FDCAN_TTILS_TTMIS_Msk (0x1UL << FDCAN_TTILS_TTMIS_Pos) |
| #define | FDCAN_TTILS_TTMIS FDCAN_TTILS_TTMIS_Msk |
| #define | FDCAN_TTILS_SWES_Pos (6U) |
| #define | FDCAN_TTILS_SWES_Msk (0x1UL << FDCAN_TTILS_SWES_Pos) |
| #define | FDCAN_TTILS_SWES FDCAN_TTILS_SWES_Msk |
| #define | FDCAN_TTILS_GTWS_Pos (7U) |
| #define | FDCAN_TTILS_GTWS_Msk (0x1UL << FDCAN_TTILS_GTWS_Pos) |
| #define | FDCAN_TTILS_GTWS FDCAN_TTILS_GTWS_Msk |
| #define | FDCAN_TTILS_GTDS_Pos (8U) |
| #define | FDCAN_TTILS_GTDS_Msk (0x1UL << FDCAN_TTILS_GTDS_Pos) |
| #define | FDCAN_TTILS_GTDS FDCAN_TTILS_GTDS_Msk |
| #define | FDCAN_TTILS_GTES_Pos (9U) |
| #define | FDCAN_TTILS_GTES_Msk (0x1UL << FDCAN_TTILS_GTES_Pos) |
| #define | FDCAN_TTILS_GTES FDCAN_TTILS_GTES_Msk |
| #define | FDCAN_TTILS_TXUS_Pos (10U) |
| #define | FDCAN_TTILS_TXUS_Msk (0x1UL << FDCAN_TTILS_TXUS_Pos) |
| #define | FDCAN_TTILS_TXUS FDCAN_TTILS_TXUS_Msk |
| #define | FDCAN_TTILS_TXOS_Pos (11U) |
| #define | FDCAN_TTILS_TXOS_Msk (0x1UL << FDCAN_TTILS_TXOS_Pos) |
| #define | FDCAN_TTILS_TXOS FDCAN_TTILS_TXOS_Msk |
| #define | FDCAN_TTILS_SE1S_Pos (12U) |
| #define | FDCAN_TTILS_SE1S_Msk (0x1UL << FDCAN_TTILS_SE1S_Pos) |
| #define | FDCAN_TTILS_SE1S FDCAN_TTILS_SE1S_Msk |
| #define | FDCAN_TTILS_SE2S_Pos (13U) |
| #define | FDCAN_TTILS_SE2S_Msk (0x1UL << FDCAN_TTILS_SE2S_Pos) |
| #define | FDCAN_TTILS_SE2S FDCAN_TTILS_SE2S_Msk |
| #define | FDCAN_TTILS_ELCS_Pos (14U) |
| #define | FDCAN_TTILS_ELCS_Msk (0x1UL << FDCAN_TTILS_ELCS_Pos) |
| #define | FDCAN_TTILS_ELCS FDCAN_TTILS_ELCS_Msk |
| #define | FDCAN_TTILS_IWTS_Pos (15U) |
| #define | FDCAN_TTILS_IWTS_Msk (0x1UL << FDCAN_TTILS_IWTS_Pos) |
| #define | FDCAN_TTILS_IWTS FDCAN_TTILS_IWTS_Msk |
| #define | FDCAN_TTILS_WTS_Pos (16U) |
| #define | FDCAN_TTILS_WTS_Msk (0x1UL << FDCAN_TTILS_WTS_Pos) |
| #define | FDCAN_TTILS_WTS FDCAN_TTILS_WTS_Msk |
| #define | FDCAN_TTILS_AWS_Pos (17U) |
| #define | FDCAN_TTILS_AWS_Msk (0x1UL << FDCAN_TTILS_AWS_Pos) |
| #define | FDCAN_TTILS_AWS FDCAN_TTILS_AWS_Msk |
| #define | FDCAN_TTILS_CERS_Pos (18U) |
| #define | FDCAN_TTILS_CERS_Msk (0x1UL << FDCAN_TTILS_CERS_Pos) |
| #define | FDCAN_TTILS_CERS FDCAN_TTILS_CERS_Msk |
| #define | FDCAN_TTOST_EL_Pos (0U) |
| #define | FDCAN_TTOST_EL_Msk (0x3UL << FDCAN_TTOST_EL_Pos) |
| #define | FDCAN_TTOST_EL FDCAN_TTOST_EL_Msk |
| #define | FDCAN_TTOST_MS_Pos (2U) |
| #define | FDCAN_TTOST_MS_Msk (0x3UL << FDCAN_TTOST_MS_Pos) |
| #define | FDCAN_TTOST_MS FDCAN_TTOST_MS_Msk |
| #define | FDCAN_TTOST_SYS_Pos (4U) |
| #define | FDCAN_TTOST_SYS_Msk (0x3UL << FDCAN_TTOST_SYS_Pos) |
| #define | FDCAN_TTOST_SYS FDCAN_TTOST_SYS_Msk |
| #define | FDCAN_TTOST_QGTP_Pos (6U) |
| #define | FDCAN_TTOST_QGTP_Msk (0x1UL << FDCAN_TTOST_QGTP_Pos) |
| #define | FDCAN_TTOST_QGTP FDCAN_TTOST_QGTP_Msk |
| #define | FDCAN_TTOST_QCS_Pos (7U) |
| #define | FDCAN_TTOST_QCS_Msk (0x1UL << FDCAN_TTOST_QCS_Pos) |
| #define | FDCAN_TTOST_QCS FDCAN_TTOST_QCS_Msk |
| #define | FDCAN_TTOST_RTO_Pos (8U) |
| #define | FDCAN_TTOST_RTO_Msk (0xFFUL << FDCAN_TTOST_RTO_Pos) |
| #define | FDCAN_TTOST_RTO FDCAN_TTOST_RTO_Msk |
| #define | FDCAN_TTOST_WGTD_Pos (22U) |
| #define | FDCAN_TTOST_WGTD_Msk (0x1UL << FDCAN_TTOST_WGTD_Pos) |
| #define | FDCAN_TTOST_WGTD FDCAN_TTOST_WGTD_Msk |
| #define | FDCAN_TTOST_GFI_Pos (23U) |
| #define | FDCAN_TTOST_GFI_Msk (0x1UL << FDCAN_TTOST_GFI_Pos) |
| #define | FDCAN_TTOST_GFI FDCAN_TTOST_GFI_Msk |
| #define | FDCAN_TTOST_TMP_Pos (24U) |
| #define | FDCAN_TTOST_TMP_Msk (0x7UL << FDCAN_TTOST_TMP_Pos) |
| #define | FDCAN_TTOST_TMP FDCAN_TTOST_TMP_Msk |
| #define | FDCAN_TTOST_GSI_Pos (27U) |
| #define | FDCAN_TTOST_GSI_Msk (0x1UL << FDCAN_TTOST_GSI_Pos) |
| #define | FDCAN_TTOST_GSI FDCAN_TTOST_GSI_Msk |
| #define | FDCAN_TTOST_WFE_Pos (28U) |
| #define | FDCAN_TTOST_WFE_Msk (0x1UL << FDCAN_TTOST_WFE_Pos) |
| #define | FDCAN_TTOST_WFE FDCAN_TTOST_WFE_Msk |
| #define | FDCAN_TTOST_AWE_Pos (29U) |
| #define | FDCAN_TTOST_AWE_Msk (0x1UL << FDCAN_TTOST_AWE_Pos) |
| #define | FDCAN_TTOST_AWE FDCAN_TTOST_AWE_Msk |
| #define | FDCAN_TTOST_WECS_Pos (30U) |
| #define | FDCAN_TTOST_WECS_Msk (0x1UL << FDCAN_TTOST_WECS_Pos) |
| #define | FDCAN_TTOST_WECS FDCAN_TTOST_WECS_Msk |
| #define | FDCAN_TTOST_SPL_Pos (31U) |
| #define | FDCAN_TTOST_SPL_Msk (0x1UL << FDCAN_TTOST_SPL_Pos) |
| #define | FDCAN_TTOST_SPL FDCAN_TTOST_SPL_Msk |
| #define | FDCAN_TURNA_NAV_Pos (0U) |
| #define | FDCAN_TURNA_NAV_Msk (0x3FFFFUL << FDCAN_TURNA_NAV_Pos) |
| #define | FDCAN_TURNA_NAV FDCAN_TURNA_NAV_Msk |
| #define | FDCAN_TTLGT_LT_Pos (0U) |
| #define | FDCAN_TTLGT_LT_Msk (0xFFFFUL << FDCAN_TTLGT_LT_Pos) |
| #define | FDCAN_TTLGT_LT FDCAN_TTLGT_LT_Msk |
| #define | FDCAN_TTLGT_GT_Pos (16U) |
| #define | FDCAN_TTLGT_GT_Msk (0xFFFFUL << FDCAN_TTLGT_GT_Pos) |
| #define | FDCAN_TTLGT_GT FDCAN_TTLGT_GT_Msk |
| #define | FDCAN_TTCTC_CT_Pos (0U) |
| #define | FDCAN_TTCTC_CT_Msk (0xFFFFUL << FDCAN_TTCTC_CT_Pos) |
| #define | FDCAN_TTCTC_CT FDCAN_TTCTC_CT_Msk |
| #define | FDCAN_TTCTC_CC_Pos (16U) |
| #define | FDCAN_TTCTC_CC_Msk (0x3FUL << FDCAN_TTCTC_CC_Pos) |
| #define | FDCAN_TTCTC_CC FDCAN_TTCTC_CC_Msk |
| #define | FDCAN_TTCPT_CCV_Pos (0U) |
| #define | FDCAN_TTCPT_CCV_Msk (0x3FUL << FDCAN_TTCPT_CCV_Pos) |
| #define | FDCAN_TTCPT_CCV FDCAN_TTCPT_CCV_Msk |
| #define | FDCAN_TTCPT_SWV_Pos (16U) |
| #define | FDCAN_TTCPT_SWV_Msk (0xFFFFUL << FDCAN_TTCPT_SWV_Pos) |
| #define | FDCAN_TTCPT_SWV FDCAN_TTCPT_SWV_Msk |
| #define | FDCAN_TTCSM_CSM_Pos (0U) |
| #define | FDCAN_TTCSM_CSM_Msk (0xFFFFUL << FDCAN_TTCSM_CSM_Pos) |
| #define | FDCAN_TTCSM_CSM FDCAN_TTCSM_CSM_Msk |
| #define | FDCAN_TTTS_SWTSEL_Pos (0U) |
| #define | FDCAN_TTTS_SWTSEL_Msk (0x3UL << FDCAN_TTTS_SWTSEL_Pos) |
| #define | FDCAN_TTTS_SWTSEL FDCAN_TTTS_SWTSEL_Msk |
| #define | FDCAN_TTTS_EVTSEL_Pos (4U) |
| #define | FDCAN_TTTS_EVTSEL_Msk (0x3UL << FDCAN_TTTS_EVTSEL_Pos) |
| #define | FDCAN_TTTS_EVTSEL FDCAN_TTTS_EVTSEL_Msk |
| #define | FDCANCCU_CREL_DAY_Pos (0U) |
| #define | FDCANCCU_CREL_DAY_Msk (0xFFUL << FDCANCCU_CREL_DAY_Pos) |
| #define | FDCANCCU_CREL_DAY FDCANCCU_CREL_DAY_Msk |
| #define | FDCANCCU_CREL_MON_Pos (8U) |
| #define | FDCANCCU_CREL_MON_Msk (0xFFUL << FDCANCCU_CREL_MON_Pos) |
| #define | FDCANCCU_CREL_MON FDCANCCU_CREL_MON_Msk |
| #define | FDCANCCU_CREL_YEAR_Pos (16U) |
| #define | FDCANCCU_CREL_YEAR_Msk (0xFUL << FDCANCCU_CREL_YEAR_Pos) |
| #define | FDCANCCU_CREL_YEAR FDCANCCU_CREL_YEAR_Msk |
| #define | FDCANCCU_CREL_SUBSTEP_Pos (20U) |
| #define | FDCANCCU_CREL_SUBSTEP_Msk (0xFUL << FDCANCCU_CREL_SUBSTEP_Pos) |
| #define | FDCANCCU_CREL_SUBSTEP FDCANCCU_CREL_SUBSTEP_Msk |
| #define | FDCANCCU_CREL_STEP_Pos (24U) |
| #define | FDCANCCU_CREL_STEP_Msk (0xFUL << FDCANCCU_CREL_STEP_Pos) |
| #define | FDCANCCU_CREL_STEP FDCANCCU_CREL_STEP_Msk |
| #define | FDCANCCU_CREL_REL_Pos (28U) |
| #define | FDCANCCU_CREL_REL_Msk (0xFUL << FDCANCCU_CREL_REL_Pos) |
| #define | FDCANCCU_CREL_REL FDCANCCU_CREL_REL_Msk |
| #define | FDCANCCU_CCFG_TQBT_Pos (0U) |
| #define | FDCANCCU_CCFG_TQBT_Msk (0x1FUL << FDCANCCU_CCFG_TQBT_Pos) |
| #define | FDCANCCU_CCFG_TQBT FDCANCCU_CCFG_TQBT_Msk |
| #define | FDCANCCU_CCFG_BCC_Pos (6U) |
| #define | FDCANCCU_CCFG_BCC_Msk (0x1UL << FDCANCCU_CCFG_BCC_Pos) |
| #define | FDCANCCU_CCFG_BCC FDCANCCU_CCFG_BCC_Msk |
| #define | FDCANCCU_CCFG_CFL_Pos (7U) |
| #define | FDCANCCU_CCFG_CFL_Msk (0x1UL << FDCANCCU_CCFG_CFL_Pos) |
| #define | FDCANCCU_CCFG_CFL FDCANCCU_CCFG_CFL_Msk |
| #define | FDCANCCU_CCFG_OCPM_Pos (8U) |
| #define | FDCANCCU_CCFG_OCPM_Msk (0xFFUL << FDCANCCU_CCFG_OCPM_Pos) |
| #define | FDCANCCU_CCFG_OCPM FDCANCCU_CCFG_OCPM_Msk |
| #define | FDCANCCU_CCFG_CDIV_Pos (16U) |
| #define | FDCANCCU_CCFG_CDIV_Msk (0xFUL << FDCANCCU_CCFG_CDIV_Pos) |
| #define | FDCANCCU_CCFG_CDIV FDCANCCU_CCFG_CDIV_Msk |
| #define | FDCANCCU_CCFG_SWR_Pos (31U) |
| #define | FDCANCCU_CCFG_SWR_Msk (0x1UL << FDCANCCU_CCFG_SWR_Pos) |
| #define | FDCANCCU_CCFG_SWR FDCANCCU_CCFG_SWR_Msk |
| #define | FDCANCCU_CSTAT_OCPC_Pos (0U) |
| #define | FDCANCCU_CSTAT_OCPC_Msk (0x3FFFFUL << FDCANCCU_CSTAT_OCPC_Pos) |
| #define | FDCANCCU_CSTAT_OCPC FDCANCCU_CSTAT_OCPC_Msk |
| #define | FDCANCCU_CSTAT_TQC_Pos (18U) |
| #define | FDCANCCU_CSTAT_TQC_Msk (0x7FFUL << FDCANCCU_CSTAT_TQC_Pos) |
| #define | FDCANCCU_CSTAT_TQC FDCANCCU_CSTAT_TQC_Msk |
| #define | FDCANCCU_CSTAT_CALS_Pos (30U) |
| #define | FDCANCCU_CSTAT_CALS_Msk (0x3UL << FDCANCCU_CSTAT_CALS_Pos) |
| #define | FDCANCCU_CSTAT_CALS FDCANCCU_CSTAT_CALS_Msk |
| #define | FDCANCCU_CWD_WDC_Pos (0U) |
| #define | FDCANCCU_CWD_WDC_Msk (0xFFFFUL << FDCANCCU_CWD_WDC_Pos) |
| #define | FDCANCCU_CWD_WDC FDCANCCU_CWD_WDC_Msk |
| #define | FDCANCCU_CWD_WDV_Pos (16U) |
| #define | FDCANCCU_CWD_WDV_Msk (0xFFFFUL << FDCANCCU_CWD_WDV_Pos) |
| #define | FDCANCCU_CWD_WDV FDCANCCU_CWD_WDV_Msk |
| #define | FDCANCCU_IR_CWE_Pos (0U) |
| #define | FDCANCCU_IR_CWE_Msk (0x1UL << FDCANCCU_IR_CWE_Pos) |
| #define | FDCANCCU_IR_CWE FDCANCCU_IR_CWE_Msk |
| #define | FDCANCCU_IR_CSC_Pos (1U) |
| #define | FDCANCCU_IR_CSC_Msk (0x1UL << FDCANCCU_IR_CSC_Pos) |
| #define | FDCANCCU_IR_CSC FDCANCCU_IR_CSC_Msk |
| #define | FDCANCCU_IE_CWEE_Pos (0U) |
| #define | FDCANCCU_IE_CWEE_Msk (0x1UL << FDCANCCU_IE_CWEE_Pos) |
| #define | FDCANCCU_IE_CWEE FDCANCCU_IE_CWEE_Msk |
| #define | FDCANCCU_IE_CSCE_Pos (1U) |
| #define | FDCANCCU_IE_CSCE_Msk (0x1UL << FDCANCCU_IE_CSCE_Pos) |
| #define | FDCANCCU_IE_CSCE FDCANCCU_IE_CSCE_Msk |
| #define | CEC_CR_CECEN_Pos (0U) |
| #define | CEC_CR_CECEN_Msk (0x1UL << CEC_CR_CECEN_Pos) |
| #define | CEC_CR_CECEN CEC_CR_CECEN_Msk |
| #define | CEC_CR_TXSOM_Pos (1U) |
| #define | CEC_CR_TXSOM_Msk (0x1UL << CEC_CR_TXSOM_Pos) |
| #define | CEC_CR_TXSOM CEC_CR_TXSOM_Msk |
| #define | CEC_CR_TXEOM_Pos (2U) |
| #define | CEC_CR_TXEOM_Msk (0x1UL << CEC_CR_TXEOM_Pos) |
| #define | CEC_CR_TXEOM CEC_CR_TXEOM_Msk |
| #define | CEC_CFGR_SFT_Pos (0U) |
| #define | CEC_CFGR_SFT_Msk (0x7UL << CEC_CFGR_SFT_Pos) |
| #define | CEC_CFGR_SFT CEC_CFGR_SFT_Msk |
| #define | CEC_CFGR_RXTOL_Pos (3U) |
| #define | CEC_CFGR_RXTOL_Msk (0x1UL << CEC_CFGR_RXTOL_Pos) |
| #define | CEC_CFGR_RXTOL CEC_CFGR_RXTOL_Msk |
| #define | CEC_CFGR_BRESTP_Pos (4U) |
| #define | CEC_CFGR_BRESTP_Msk (0x1UL << CEC_CFGR_BRESTP_Pos) |
| #define | CEC_CFGR_BRESTP CEC_CFGR_BRESTP_Msk |
| #define | CEC_CFGR_BREGEN_Pos (5U) |
| #define | CEC_CFGR_BREGEN_Msk (0x1UL << CEC_CFGR_BREGEN_Pos) |
| #define | CEC_CFGR_BREGEN CEC_CFGR_BREGEN_Msk |
| #define | CEC_CFGR_LBPEGEN_Pos (6U) |
| #define | CEC_CFGR_LBPEGEN_Msk (0x1UL << CEC_CFGR_LBPEGEN_Pos) |
| #define | CEC_CFGR_LBPEGEN CEC_CFGR_LBPEGEN_Msk |
| #define | CEC_CFGR_SFTOPT_Pos (8U) |
| #define | CEC_CFGR_SFTOPT_Msk (0x1UL << CEC_CFGR_SFTOPT_Pos) |
| #define | CEC_CFGR_SFTOPT CEC_CFGR_SFTOPT_Msk |
| #define | CEC_CFGR_BRDNOGEN_Pos (7U) |
| #define | CEC_CFGR_BRDNOGEN_Msk (0x1UL << CEC_CFGR_BRDNOGEN_Pos) |
| #define | CEC_CFGR_BRDNOGEN CEC_CFGR_BRDNOGEN_Msk |
| #define | CEC_CFGR_OAR_Pos (16U) |
| #define | CEC_CFGR_OAR_Msk (0x7FFFUL << CEC_CFGR_OAR_Pos) |
| #define | CEC_CFGR_OAR CEC_CFGR_OAR_Msk |
| #define | CEC_CFGR_LSTN_Pos (31U) |
| #define | CEC_CFGR_LSTN_Msk (0x1UL << CEC_CFGR_LSTN_Pos) |
| #define | CEC_CFGR_LSTN CEC_CFGR_LSTN_Msk |
| #define | CEC_TXDR_TXD_Pos (0U) |
| #define | CEC_TXDR_TXD_Msk (0xFFUL << CEC_TXDR_TXD_Pos) |
| #define | CEC_TXDR_TXD CEC_TXDR_TXD_Msk |
| #define | CEC_RXDR_RXD_Pos (0U) |
| #define | CEC_RXDR_RXD_Msk (0xFFUL << CEC_RXDR_RXD_Pos) |
| #define | CEC_RXDR_RXD CEC_RXDR_RXD_Msk |
| #define | CEC_ISR_RXBR_Pos (0U) |
| #define | CEC_ISR_RXBR_Msk (0x1UL << CEC_ISR_RXBR_Pos) |
| #define | CEC_ISR_RXBR CEC_ISR_RXBR_Msk |
| #define | CEC_ISR_RXEND_Pos (1U) |
| #define | CEC_ISR_RXEND_Msk (0x1UL << CEC_ISR_RXEND_Pos) |
| #define | CEC_ISR_RXEND CEC_ISR_RXEND_Msk |
| #define | CEC_ISR_RXOVR_Pos (2U) |
| #define | CEC_ISR_RXOVR_Msk (0x1UL << CEC_ISR_RXOVR_Pos) |
| #define | CEC_ISR_RXOVR CEC_ISR_RXOVR_Msk |
| #define | CEC_ISR_BRE_Pos (3U) |
| #define | CEC_ISR_BRE_Msk (0x1UL << CEC_ISR_BRE_Pos) |
| #define | CEC_ISR_BRE CEC_ISR_BRE_Msk |
| #define | CEC_ISR_SBPE_Pos (4U) |
| #define | CEC_ISR_SBPE_Msk (0x1UL << CEC_ISR_SBPE_Pos) |
| #define | CEC_ISR_SBPE CEC_ISR_SBPE_Msk |
| #define | CEC_ISR_LBPE_Pos (5U) |
| #define | CEC_ISR_LBPE_Msk (0x1UL << CEC_ISR_LBPE_Pos) |
| #define | CEC_ISR_LBPE CEC_ISR_LBPE_Msk |
| #define | CEC_ISR_RXACKE_Pos (6U) |
| #define | CEC_ISR_RXACKE_Msk (0x1UL << CEC_ISR_RXACKE_Pos) |
| #define | CEC_ISR_RXACKE CEC_ISR_RXACKE_Msk |
| #define | CEC_ISR_ARBLST_Pos (7U) |
| #define | CEC_ISR_ARBLST_Msk (0x1UL << CEC_ISR_ARBLST_Pos) |
| #define | CEC_ISR_ARBLST CEC_ISR_ARBLST_Msk |
| #define | CEC_ISR_TXBR_Pos (8U) |
| #define | CEC_ISR_TXBR_Msk (0x1UL << CEC_ISR_TXBR_Pos) |
| #define | CEC_ISR_TXBR CEC_ISR_TXBR_Msk |
| #define | CEC_ISR_TXEND_Pos (9U) |
| #define | CEC_ISR_TXEND_Msk (0x1UL << CEC_ISR_TXEND_Pos) |
| #define | CEC_ISR_TXEND CEC_ISR_TXEND_Msk |
| #define | CEC_ISR_TXUDR_Pos (10U) |
| #define | CEC_ISR_TXUDR_Msk (0x1UL << CEC_ISR_TXUDR_Pos) |
| #define | CEC_ISR_TXUDR CEC_ISR_TXUDR_Msk |
| #define | CEC_ISR_TXERR_Pos (11U) |
| #define | CEC_ISR_TXERR_Msk (0x1UL << CEC_ISR_TXERR_Pos) |
| #define | CEC_ISR_TXERR CEC_ISR_TXERR_Msk |
| #define | CEC_ISR_TXACKE_Pos (12U) |
| #define | CEC_ISR_TXACKE_Msk (0x1UL << CEC_ISR_TXACKE_Pos) |
| #define | CEC_ISR_TXACKE CEC_ISR_TXACKE_Msk |
| #define | CEC_IER_RXBRIE_Pos (0U) |
| #define | CEC_IER_RXBRIE_Msk (0x1UL << CEC_IER_RXBRIE_Pos) |
| #define | CEC_IER_RXBRIE CEC_IER_RXBRIE_Msk |
| #define | CEC_IER_RXENDIE_Pos (1U) |
| #define | CEC_IER_RXENDIE_Msk (0x1UL << CEC_IER_RXENDIE_Pos) |
| #define | CEC_IER_RXENDIE CEC_IER_RXENDIE_Msk |
| #define | CEC_IER_RXOVRIE_Pos (2U) |
| #define | CEC_IER_RXOVRIE_Msk (0x1UL << CEC_IER_RXOVRIE_Pos) |
| #define | CEC_IER_RXOVRIE CEC_IER_RXOVRIE_Msk |
| #define | CEC_IER_BREIE_Pos (3U) |
| #define | CEC_IER_BREIE_Msk (0x1UL << CEC_IER_BREIE_Pos) |
| #define | CEC_IER_BREIE CEC_IER_BREIE_Msk |
| #define | CEC_IER_SBPEIE_Pos (4U) |
| #define | CEC_IER_SBPEIE_Msk (0x1UL << CEC_IER_SBPEIE_Pos) |
| #define | CEC_IER_SBPEIE CEC_IER_SBPEIE_Msk |
| #define | CEC_IER_LBPEIE_Pos (5U) |
| #define | CEC_IER_LBPEIE_Msk (0x1UL << CEC_IER_LBPEIE_Pos) |
| #define | CEC_IER_LBPEIE CEC_IER_LBPEIE_Msk |
| #define | CEC_IER_RXACKEIE_Pos (6U) |
| #define | CEC_IER_RXACKEIE_Msk (0x1UL << CEC_IER_RXACKEIE_Pos) |
| #define | CEC_IER_RXACKEIE CEC_IER_RXACKEIE_Msk |
| #define | CEC_IER_ARBLSTIE_Pos (7U) |
| #define | CEC_IER_ARBLSTIE_Msk (0x1UL << CEC_IER_ARBLSTIE_Pos) |
| #define | CEC_IER_ARBLSTIE CEC_IER_ARBLSTIE_Msk |
| #define | CEC_IER_TXBRIE_Pos (8U) |
| #define | CEC_IER_TXBRIE_Msk (0x1UL << CEC_IER_TXBRIE_Pos) |
| #define | CEC_IER_TXBRIE CEC_IER_TXBRIE_Msk |
| #define | CEC_IER_TXENDIE_Pos (9U) |
| #define | CEC_IER_TXENDIE_Msk (0x1UL << CEC_IER_TXENDIE_Pos) |
| #define | CEC_IER_TXENDIE CEC_IER_TXENDIE_Msk |
| #define | CEC_IER_TXUDRIE_Pos (10U) |
| #define | CEC_IER_TXUDRIE_Msk (0x1UL << CEC_IER_TXUDRIE_Pos) |
| #define | CEC_IER_TXUDRIE CEC_IER_TXUDRIE_Msk |
| #define | CEC_IER_TXERRIE_Pos (11U) |
| #define | CEC_IER_TXERRIE_Msk (0x1UL << CEC_IER_TXERRIE_Pos) |
| #define | CEC_IER_TXERRIE CEC_IER_TXERRIE_Msk |
| #define | CEC_IER_TXACKEIE_Pos (12U) |
| #define | CEC_IER_TXACKEIE_Msk (0x1UL << CEC_IER_TXACKEIE_Pos) |
| #define | CEC_IER_TXACKEIE CEC_IER_TXACKEIE_Msk |
| #define | CRC_DR_DR_Pos (0U) |
| #define | CRC_DR_DR_Msk (0xFFFFFFFFUL << CRC_DR_DR_Pos) |
| #define | CRC_DR_DR CRC_DR_DR_Msk |
| #define | CRC_IDR_IDR_Pos (0U) |
| #define | CRC_IDR_IDR_Msk (0xFFFFFFFFUL << CRC_IDR_IDR_Pos) |
| #define | CRC_IDR_IDR CRC_IDR_IDR_Msk |
| #define | CRC_CR_RESET_Pos (0U) |
| #define | CRC_CR_RESET_Msk (0x1UL << CRC_CR_RESET_Pos) |
| #define | CRC_CR_RESET CRC_CR_RESET_Msk |
| #define | CRC_CR_POLYSIZE_Pos (3U) |
| #define | CRC_CR_POLYSIZE_Msk (0x3UL << CRC_CR_POLYSIZE_Pos) |
| #define | CRC_CR_POLYSIZE CRC_CR_POLYSIZE_Msk |
| #define | CRC_CR_POLYSIZE_0 (0x1UL << CRC_CR_POLYSIZE_Pos) |
| #define | CRC_CR_POLYSIZE_1 (0x2UL << CRC_CR_POLYSIZE_Pos) |
| #define | CRC_CR_REV_IN_Pos (5U) |
| #define | CRC_CR_REV_IN_Msk (0x3UL << CRC_CR_REV_IN_Pos) |
| #define | CRC_CR_REV_IN CRC_CR_REV_IN_Msk |
| #define | CRC_CR_REV_IN_0 (0x1UL << CRC_CR_REV_IN_Pos) |
| #define | CRC_CR_REV_IN_1 (0x2UL << CRC_CR_REV_IN_Pos) |
| #define | CRC_CR_REV_OUT_Pos (7U) |
| #define | CRC_CR_REV_OUT_Msk (0x1UL << CRC_CR_REV_OUT_Pos) |
| #define | CRC_CR_REV_OUT CRC_CR_REV_OUT_Msk |
| #define | CRC_INIT_INIT_Pos (0U) |
| #define | CRC_INIT_INIT_Msk (0xFFFFFFFFUL << CRC_INIT_INIT_Pos) |
| #define | CRC_INIT_INIT CRC_INIT_INIT_Msk |
| #define | CRC_POL_POL_Pos (0U) |
| #define | CRC_POL_POL_Msk (0xFFFFFFFFUL << CRC_POL_POL_Pos) |
| #define | CRC_POL_POL CRC_POL_POL_Msk |
| #define | CRS_CR_SYNCOKIE_Pos (0U) |
| #define | CRS_CR_SYNCOKIE_Msk (0x1UL << CRS_CR_SYNCOKIE_Pos) |
| #define | CRS_CR_SYNCOKIE CRS_CR_SYNCOKIE_Msk |
| #define | CRS_CR_SYNCWARNIE_Pos (1U) |
| #define | CRS_CR_SYNCWARNIE_Msk (0x1UL << CRS_CR_SYNCWARNIE_Pos) |
| #define | CRS_CR_SYNCWARNIE CRS_CR_SYNCWARNIE_Msk |
| #define | CRS_CR_ERRIE_Pos (2U) |
| #define | CRS_CR_ERRIE_Msk (0x1UL << CRS_CR_ERRIE_Pos) |
| #define | CRS_CR_ERRIE CRS_CR_ERRIE_Msk |
| #define | CRS_CR_ESYNCIE_Pos (3U) |
| #define | CRS_CR_ESYNCIE_Msk (0x1UL << CRS_CR_ESYNCIE_Pos) |
| #define | CRS_CR_ESYNCIE CRS_CR_ESYNCIE_Msk |
| #define | CRS_CR_CEN_Pos (5U) |
| #define | CRS_CR_CEN_Msk (0x1UL << CRS_CR_CEN_Pos) |
| #define | CRS_CR_CEN CRS_CR_CEN_Msk |
| #define | CRS_CR_AUTOTRIMEN_Pos (6U) |
| #define | CRS_CR_AUTOTRIMEN_Msk (0x1UL << CRS_CR_AUTOTRIMEN_Pos) |
| #define | CRS_CR_AUTOTRIMEN CRS_CR_AUTOTRIMEN_Msk |
| #define | CRS_CR_SWSYNC_Pos (7U) |
| #define | CRS_CR_SWSYNC_Msk (0x1UL << CRS_CR_SWSYNC_Pos) |
| #define | CRS_CR_SWSYNC CRS_CR_SWSYNC_Msk |
| #define | CRS_CR_TRIM_Pos (8U) |
| #define | CRS_CR_TRIM_Msk (0x3FUL << CRS_CR_TRIM_Pos) |
| #define | CRS_CR_TRIM CRS_CR_TRIM_Msk |
| #define | CRS_CFGR_RELOAD_Pos (0U) |
| #define | CRS_CFGR_RELOAD_Msk (0xFFFFUL << CRS_CFGR_RELOAD_Pos) |
| #define | CRS_CFGR_RELOAD CRS_CFGR_RELOAD_Msk |
| #define | CRS_CFGR_FELIM_Pos (16U) |
| #define | CRS_CFGR_FELIM_Msk (0xFFUL << CRS_CFGR_FELIM_Pos) |
| #define | CRS_CFGR_FELIM CRS_CFGR_FELIM_Msk |
| #define | CRS_CFGR_SYNCDIV_Pos (24U) |
| #define | CRS_CFGR_SYNCDIV_Msk (0x7UL << CRS_CFGR_SYNCDIV_Pos) |
| #define | CRS_CFGR_SYNCDIV CRS_CFGR_SYNCDIV_Msk |
| #define | CRS_CFGR_SYNCDIV_0 (0x1UL << CRS_CFGR_SYNCDIV_Pos) |
| #define | CRS_CFGR_SYNCDIV_1 (0x2UL << CRS_CFGR_SYNCDIV_Pos) |
| #define | CRS_CFGR_SYNCDIV_2 (0x4UL << CRS_CFGR_SYNCDIV_Pos) |
| #define | CRS_CFGR_SYNCSRC_Pos (28U) |
| #define | CRS_CFGR_SYNCSRC_Msk (0x3UL << CRS_CFGR_SYNCSRC_Pos) |
| #define | CRS_CFGR_SYNCSRC CRS_CFGR_SYNCSRC_Msk |
| #define | CRS_CFGR_SYNCSRC_0 (0x1UL << CRS_CFGR_SYNCSRC_Pos) |
| #define | CRS_CFGR_SYNCSRC_1 (0x2UL << CRS_CFGR_SYNCSRC_Pos) |
| #define | CRS_CFGR_SYNCPOL_Pos (31U) |
| #define | CRS_CFGR_SYNCPOL_Msk (0x1UL << CRS_CFGR_SYNCPOL_Pos) |
| #define | CRS_CFGR_SYNCPOL CRS_CFGR_SYNCPOL_Msk |
| #define | CRS_ISR_SYNCOKF_Pos (0U) |
| #define | CRS_ISR_SYNCOKF_Msk (0x1UL << CRS_ISR_SYNCOKF_Pos) |
| #define | CRS_ISR_SYNCOKF CRS_ISR_SYNCOKF_Msk |
| #define | CRS_ISR_SYNCWARNF_Pos (1U) |
| #define | CRS_ISR_SYNCWARNF_Msk (0x1UL << CRS_ISR_SYNCWARNF_Pos) |
| #define | CRS_ISR_SYNCWARNF CRS_ISR_SYNCWARNF_Msk |
| #define | CRS_ISR_ERRF_Pos (2U) |
| #define | CRS_ISR_ERRF_Msk (0x1UL << CRS_ISR_ERRF_Pos) |
| #define | CRS_ISR_ERRF CRS_ISR_ERRF_Msk |
| #define | CRS_ISR_ESYNCF_Pos (3U) |
| #define | CRS_ISR_ESYNCF_Msk (0x1UL << CRS_ISR_ESYNCF_Pos) |
| #define | CRS_ISR_ESYNCF CRS_ISR_ESYNCF_Msk |
| #define | CRS_ISR_SYNCERR_Pos (8U) |
| #define | CRS_ISR_SYNCERR_Msk (0x1UL << CRS_ISR_SYNCERR_Pos) |
| #define | CRS_ISR_SYNCERR CRS_ISR_SYNCERR_Msk |
| #define | CRS_ISR_SYNCMISS_Pos (9U) |
| #define | CRS_ISR_SYNCMISS_Msk (0x1UL << CRS_ISR_SYNCMISS_Pos) |
| #define | CRS_ISR_SYNCMISS CRS_ISR_SYNCMISS_Msk |
| #define | CRS_ISR_TRIMOVF_Pos (10U) |
| #define | CRS_ISR_TRIMOVF_Msk (0x1UL << CRS_ISR_TRIMOVF_Pos) |
| #define | CRS_ISR_TRIMOVF CRS_ISR_TRIMOVF_Msk |
| #define | CRS_ISR_FEDIR_Pos (15U) |
| #define | CRS_ISR_FEDIR_Msk (0x1UL << CRS_ISR_FEDIR_Pos) |
| #define | CRS_ISR_FEDIR CRS_ISR_FEDIR_Msk |
| #define | CRS_ISR_FECAP_Pos (16U) |
| #define | CRS_ISR_FECAP_Msk (0xFFFFUL << CRS_ISR_FECAP_Pos) |
| #define | CRS_ISR_FECAP CRS_ISR_FECAP_Msk |
| #define | CRS_ICR_SYNCOKC_Pos (0U) |
| #define | CRS_ICR_SYNCOKC_Msk (0x1UL << CRS_ICR_SYNCOKC_Pos) |
| #define | CRS_ICR_SYNCOKC CRS_ICR_SYNCOKC_Msk |
| #define | CRS_ICR_SYNCWARNC_Pos (1U) |
| #define | CRS_ICR_SYNCWARNC_Msk (0x1UL << CRS_ICR_SYNCWARNC_Pos) |
| #define | CRS_ICR_SYNCWARNC CRS_ICR_SYNCWARNC_Msk |
| #define | CRS_ICR_ERRC_Pos (2U) |
| #define | CRS_ICR_ERRC_Msk (0x1UL << CRS_ICR_ERRC_Pos) |
| #define | CRS_ICR_ERRC CRS_ICR_ERRC_Msk |
| #define | CRS_ICR_ESYNCC_Pos (3U) |
| #define | CRS_ICR_ESYNCC_Msk (0x1UL << CRS_ICR_ESYNCC_Pos) |
| #define | CRS_ICR_ESYNCC CRS_ICR_ESYNCC_Msk |
| #define | CRYP_CR_ALGODIR_Pos (2U) |
| #define | CRYP_CR_ALGODIR_Msk (0x1UL << CRYP_CR_ALGODIR_Pos) |
| #define | CRYP_CR_ALGODIR CRYP_CR_ALGODIR_Msk |
| #define | CRYP_CR_ALGOMODE_Pos (3U) |
| #define | CRYP_CR_ALGOMODE_Msk (0x10007UL << CRYP_CR_ALGOMODE_Pos) |
| #define | CRYP_CR_ALGOMODE CRYP_CR_ALGOMODE_Msk |
| #define | CRYP_CR_ALGOMODE_0 (0x00001UL << CRYP_CR_ALGOMODE_Pos) |
| #define | CRYP_CR_ALGOMODE_1 (0x00002UL << CRYP_CR_ALGOMODE_Pos) |
| #define | CRYP_CR_ALGOMODE_2 (0x00004UL << CRYP_CR_ALGOMODE_Pos) |
| #define | CRYP_CR_ALGOMODE_TDES_ECB (0U) |
| #define | CRYP_CR_ALGOMODE_TDES_CBC_Pos (3U) |
| #define | CRYP_CR_ALGOMODE_TDES_CBC_Msk (0x1UL << CRYP_CR_ALGOMODE_TDES_CBC_Pos) |
| #define | CRYP_CR_ALGOMODE_TDES_CBC CRYP_CR_ALGOMODE_TDES_CBC_Msk |
| #define | CRYP_CR_ALGOMODE_DES_ECB_Pos (4U) |
| #define | CRYP_CR_ALGOMODE_DES_ECB_Msk (0x1UL << CRYP_CR_ALGOMODE_DES_ECB_Pos) |
| #define | CRYP_CR_ALGOMODE_DES_ECB CRYP_CR_ALGOMODE_DES_ECB_Msk |
| #define | CRYP_CR_ALGOMODE_DES_CBC_Pos (3U) |
| #define | CRYP_CR_ALGOMODE_DES_CBC_Msk (0x3UL << CRYP_CR_ALGOMODE_DES_CBC_Pos) |
| #define | CRYP_CR_ALGOMODE_DES_CBC CRYP_CR_ALGOMODE_DES_CBC_Msk |
| #define | CRYP_CR_ALGOMODE_AES_ECB_Pos (5U) |
| #define | CRYP_CR_ALGOMODE_AES_ECB_Msk (0x1UL << CRYP_CR_ALGOMODE_AES_ECB_Pos) |
| #define | CRYP_CR_ALGOMODE_AES_ECB CRYP_CR_ALGOMODE_AES_ECB_Msk |
| #define | CRYP_CR_ALGOMODE_AES_CBC_Pos (3U) |
| #define | CRYP_CR_ALGOMODE_AES_CBC_Msk (0x5UL << CRYP_CR_ALGOMODE_AES_CBC_Pos) |
| #define | CRYP_CR_ALGOMODE_AES_CBC CRYP_CR_ALGOMODE_AES_CBC_Msk |
| #define | CRYP_CR_ALGOMODE_AES_CTR_Pos (4U) |
| #define | CRYP_CR_ALGOMODE_AES_CTR_Msk (0x3UL << CRYP_CR_ALGOMODE_AES_CTR_Pos) |
| #define | CRYP_CR_ALGOMODE_AES_CTR CRYP_CR_ALGOMODE_AES_CTR_Msk |
| #define | CRYP_CR_ALGOMODE_AES_KEY_Pos (3U) |
| #define | CRYP_CR_ALGOMODE_AES_KEY_Msk (0x7UL << CRYP_CR_ALGOMODE_AES_KEY_Pos) |
| #define | CRYP_CR_ALGOMODE_AES_KEY CRYP_CR_ALGOMODE_AES_KEY_Msk |
| #define | CRYP_CR_ALGOMODE_AES_GCM_Pos (19U) |
| #define | CRYP_CR_ALGOMODE_AES_GCM_Msk (0x1UL << CRYP_CR_ALGOMODE_AES_GCM_Pos) |
| #define | CRYP_CR_ALGOMODE_AES_GCM CRYP_CR_ALGOMODE_AES_GCM_Msk |
| #define | CRYP_CR_ALGOMODE_AES_CCM_Pos (3U) |
| #define | CRYP_CR_ALGOMODE_AES_CCM_Msk (0x10001UL << CRYP_CR_ALGOMODE_AES_CCM_Pos) |
| #define | CRYP_CR_ALGOMODE_AES_CCM CRYP_CR_ALGOMODE_AES_CCM_Msk |
| #define | CRYP_CR_DATATYPE_Pos (6U) |
| #define | CRYP_CR_DATATYPE_Msk (0x3UL << CRYP_CR_DATATYPE_Pos) |
| #define | CRYP_CR_DATATYPE CRYP_CR_DATATYPE_Msk |
| #define | CRYP_CR_DATATYPE_0 (0x1UL << CRYP_CR_DATATYPE_Pos) |
| #define | CRYP_CR_DATATYPE_1 (0x2UL << CRYP_CR_DATATYPE_Pos) |
| #define | CRYP_CR_KEYSIZE_Pos (8U) |
| #define | CRYP_CR_KEYSIZE_Msk (0x3UL << CRYP_CR_KEYSIZE_Pos) |
| #define | CRYP_CR_KEYSIZE CRYP_CR_KEYSIZE_Msk |
| #define | CRYP_CR_KEYSIZE_0 (0x1UL << CRYP_CR_KEYSIZE_Pos) |
| #define | CRYP_CR_KEYSIZE_1 (0x2UL << CRYP_CR_KEYSIZE_Pos) |
| #define | CRYP_CR_FFLUSH_Pos (14U) |
| #define | CRYP_CR_FFLUSH_Msk (0x1UL << CRYP_CR_FFLUSH_Pos) |
| #define | CRYP_CR_FFLUSH CRYP_CR_FFLUSH_Msk |
| #define | CRYP_CR_CRYPEN_Pos (15U) |
| #define | CRYP_CR_CRYPEN_Msk (0x1UL << CRYP_CR_CRYPEN_Pos) |
| #define | CRYP_CR_CRYPEN CRYP_CR_CRYPEN_Msk |
| #define | CRYP_CR_GCM_CCMPH_Pos (16U) |
| #define | CRYP_CR_GCM_CCMPH_Msk (0x3UL << CRYP_CR_GCM_CCMPH_Pos) |
| #define | CRYP_CR_GCM_CCMPH CRYP_CR_GCM_CCMPH_Msk |
| #define | CRYP_CR_GCM_CCMPH_0 (0x1UL << CRYP_CR_GCM_CCMPH_Pos) |
| #define | CRYP_CR_GCM_CCMPH_1 (0x2UL << CRYP_CR_GCM_CCMPH_Pos) |
| #define | CRYP_CR_ALGOMODE_3 (0x00080000U) |
| #define | CRYP_CR_NPBLB_Pos (20U) |
| #define | CRYP_CR_NPBLB_Msk (0xFUL << CRYP_CR_NPBLB_Pos) |
| #define | CRYP_CR_NPBLB CRYP_CR_NPBLB_Msk |
| #define | CRYP_SR_IFEM_Pos (0U) |
| #define | CRYP_SR_IFEM_Msk (0x1UL << CRYP_SR_IFEM_Pos) |
| #define | CRYP_SR_IFEM CRYP_SR_IFEM_Msk |
| #define | CRYP_SR_IFNF_Pos (1U) |
| #define | CRYP_SR_IFNF_Msk (0x1UL << CRYP_SR_IFNF_Pos) |
| #define | CRYP_SR_IFNF CRYP_SR_IFNF_Msk |
| #define | CRYP_SR_OFNE_Pos (2U) |
| #define | CRYP_SR_OFNE_Msk (0x1UL << CRYP_SR_OFNE_Pos) |
| #define | CRYP_SR_OFNE CRYP_SR_OFNE_Msk |
| #define | CRYP_SR_OFFU_Pos (3U) |
| #define | CRYP_SR_OFFU_Msk (0x1UL << CRYP_SR_OFFU_Pos) |
| #define | CRYP_SR_OFFU CRYP_SR_OFFU_Msk |
| #define | CRYP_SR_BUSY_Pos (4U) |
| #define | CRYP_SR_BUSY_Msk (0x1UL << CRYP_SR_BUSY_Pos) |
| #define | CRYP_SR_BUSY CRYP_SR_BUSY_Msk |
| #define | CRYP_DMACR_DIEN_Pos (0U) |
| #define | CRYP_DMACR_DIEN_Msk (0x1UL << CRYP_DMACR_DIEN_Pos) |
| #define | CRYP_DMACR_DIEN CRYP_DMACR_DIEN_Msk |
| #define | CRYP_DMACR_DOEN_Pos (1U) |
| #define | CRYP_DMACR_DOEN_Msk (0x1UL << CRYP_DMACR_DOEN_Pos) |
| #define | CRYP_DMACR_DOEN CRYP_DMACR_DOEN_Msk |
| #define | CRYP_IMSCR_INIM_Pos (0U) |
| #define | CRYP_IMSCR_INIM_Msk (0x1UL << CRYP_IMSCR_INIM_Pos) |
| #define | CRYP_IMSCR_INIM CRYP_IMSCR_INIM_Msk |
| #define | CRYP_IMSCR_OUTIM_Pos (1U) |
| #define | CRYP_IMSCR_OUTIM_Msk (0x1UL << CRYP_IMSCR_OUTIM_Pos) |
| #define | CRYP_IMSCR_OUTIM CRYP_IMSCR_OUTIM_Msk |
| #define | CRYP_RISR_INRIS_Pos (0U) |
| #define | CRYP_RISR_INRIS_Msk (0x1UL << CRYP_RISR_INRIS_Pos) |
| #define | CRYP_RISR_INRIS CRYP_RISR_INRIS_Msk |
| #define | CRYP_RISR_OUTRIS_Pos (1U) |
| #define | CRYP_RISR_OUTRIS_Msk (0x1UL << CRYP_RISR_OUTRIS_Pos) |
| #define | CRYP_RISR_OUTRIS CRYP_RISR_OUTRIS_Msk |
| #define | CRYP_MISR_INMIS_Pos (0U) |
| #define | CRYP_MISR_INMIS_Msk (0x1UL << CRYP_MISR_INMIS_Pos) |
| #define | CRYP_MISR_INMIS CRYP_MISR_INMIS_Msk |
| #define | CRYP_MISR_OUTMIS_Pos (1U) |
| #define | CRYP_MISR_OUTMIS_Msk (0x1UL << CRYP_MISR_OUTMIS_Pos) |
| #define | CRYP_MISR_OUTMIS CRYP_MISR_OUTMIS_Msk |
| #define | DAC_CR_EN1_Pos (0U) |
| #define | DAC_CR_EN1_Msk (0x1UL << DAC_CR_EN1_Pos) |
| #define | DAC_CR_EN1 DAC_CR_EN1_Msk |
| #define | DAC_CR_TEN1_Pos (1U) |
| #define | DAC_CR_TEN1_Msk (0x1UL << DAC_CR_TEN1_Pos) |
| #define | DAC_CR_TEN1 DAC_CR_TEN1_Msk |
| #define | DAC_CR_TSEL1_Pos (2U) |
| #define | DAC_CR_TSEL1_Msk (0xFUL << DAC_CR_TSEL1_Pos) |
| #define | DAC_CR_TSEL1 DAC_CR_TSEL1_Msk |
| #define | DAC_CR_TSEL1_0 (0x1UL << DAC_CR_TSEL1_Pos) |
| #define | DAC_CR_TSEL1_1 (0x2UL << DAC_CR_TSEL1_Pos) |
| #define | DAC_CR_TSEL1_2 (0x4UL << DAC_CR_TSEL1_Pos) |
| #define | DAC_CR_TSEL1_3 (0x8UL << DAC_CR_TSEL1_Pos) |
| #define | DAC_CR_WAVE1_Pos (6U) |
| #define | DAC_CR_WAVE1_Msk (0x3UL << DAC_CR_WAVE1_Pos) |
| #define | DAC_CR_WAVE1 DAC_CR_WAVE1_Msk |
| #define | DAC_CR_WAVE1_0 (0x1UL << DAC_CR_WAVE1_Pos) |
| #define | DAC_CR_WAVE1_1 (0x2UL << DAC_CR_WAVE1_Pos) |
| #define | DAC_CR_MAMP1_Pos (8U) |
| #define | DAC_CR_MAMP1_Msk (0xFUL << DAC_CR_MAMP1_Pos) |
| #define | DAC_CR_MAMP1 DAC_CR_MAMP1_Msk |
| #define | DAC_CR_MAMP1_0 (0x1UL << DAC_CR_MAMP1_Pos) |
| #define | DAC_CR_MAMP1_1 (0x2UL << DAC_CR_MAMP1_Pos) |
| #define | DAC_CR_MAMP1_2 (0x4UL << DAC_CR_MAMP1_Pos) |
| #define | DAC_CR_MAMP1_3 (0x8UL << DAC_CR_MAMP1_Pos) |
| #define | DAC_CR_DMAEN1_Pos (12U) |
| #define | DAC_CR_DMAEN1_Msk (0x1UL << DAC_CR_DMAEN1_Pos) |
| #define | DAC_CR_DMAEN1 DAC_CR_DMAEN1_Msk |
| #define | DAC_CR_DMAUDRIE1_Pos (13U) |
| #define | DAC_CR_DMAUDRIE1_Msk (0x1UL << DAC_CR_DMAUDRIE1_Pos) |
| #define | DAC_CR_DMAUDRIE1 DAC_CR_DMAUDRIE1_Msk |
| #define | DAC_CR_CEN1_Pos (14U) |
| #define | DAC_CR_CEN1_Msk (0x1UL << DAC_CR_CEN1_Pos) |
| #define | DAC_CR_CEN1 DAC_CR_CEN1_Msk |
| #define | DAC_CR_EN2_Pos (16U) |
| #define | DAC_CR_EN2_Msk (0x1UL << DAC_CR_EN2_Pos) |
| #define | DAC_CR_EN2 DAC_CR_EN2_Msk |
| #define | DAC_CR_TEN2_Pos (17U) |
| #define | DAC_CR_TEN2_Msk (0x1UL << DAC_CR_TEN2_Pos) |
| #define | DAC_CR_TEN2 DAC_CR_TEN2_Msk |
| #define | DAC_CR_TSEL2_Pos (18U) |
| #define | DAC_CR_TSEL2_Msk (0xFUL << DAC_CR_TSEL2_Pos) |
| #define | DAC_CR_TSEL2 DAC_CR_TSEL2_Msk |
| #define | DAC_CR_TSEL2_0 (0x1UL << DAC_CR_TSEL2_Pos) |
| #define | DAC_CR_TSEL2_1 (0x2UL << DAC_CR_TSEL2_Pos) |
| #define | DAC_CR_TSEL2_2 (0x4UL << DAC_CR_TSEL2_Pos) |
| #define | DAC_CR_TSEL2_3 (0x8UL << DAC_CR_TSEL2_Pos) |
| #define | DAC_CR_WAVE2_Pos (22U) |
| #define | DAC_CR_WAVE2_Msk (0x3UL << DAC_CR_WAVE2_Pos) |
| #define | DAC_CR_WAVE2 DAC_CR_WAVE2_Msk |
| #define | DAC_CR_WAVE2_0 (0x1UL << DAC_CR_WAVE2_Pos) |
| #define | DAC_CR_WAVE2_1 (0x2UL << DAC_CR_WAVE2_Pos) |
| #define | DAC_CR_MAMP2_Pos (24U) |
| #define | DAC_CR_MAMP2_Msk (0xFUL << DAC_CR_MAMP2_Pos) |
| #define | DAC_CR_MAMP2 DAC_CR_MAMP2_Msk |
| #define | DAC_CR_MAMP2_0 (0x1UL << DAC_CR_MAMP2_Pos) |
| #define | DAC_CR_MAMP2_1 (0x2UL << DAC_CR_MAMP2_Pos) |
| #define | DAC_CR_MAMP2_2 (0x4UL << DAC_CR_MAMP2_Pos) |
| #define | DAC_CR_MAMP2_3 (0x8UL << DAC_CR_MAMP2_Pos) |
| #define | DAC_CR_DMAEN2_Pos (28U) |
| #define | DAC_CR_DMAEN2_Msk (0x1UL << DAC_CR_DMAEN2_Pos) |
| #define | DAC_CR_DMAEN2 DAC_CR_DMAEN2_Msk |
| #define | DAC_CR_DMAUDRIE2_Pos (29U) |
| #define | DAC_CR_DMAUDRIE2_Msk (0x1UL << DAC_CR_DMAUDRIE2_Pos) |
| #define | DAC_CR_DMAUDRIE2 DAC_CR_DMAUDRIE2_Msk |
| #define | DAC_CR_CEN2_Pos (30U) |
| #define | DAC_CR_CEN2_Msk (0x1UL << DAC_CR_CEN2_Pos) |
| #define | DAC_CR_CEN2 DAC_CR_CEN2_Msk |
| #define | DAC_SWTRIGR_SWTRIG1_Pos (0U) |
| #define | DAC_SWTRIGR_SWTRIG1_Msk (0x1UL << DAC_SWTRIGR_SWTRIG1_Pos) |
| #define | DAC_SWTRIGR_SWTRIG1 DAC_SWTRIGR_SWTRIG1_Msk |
| #define | DAC_SWTRIGR_SWTRIG2_Pos (1U) |
| #define | DAC_SWTRIGR_SWTRIG2_Msk (0x1UL << DAC_SWTRIGR_SWTRIG2_Pos) |
| #define | DAC_SWTRIGR_SWTRIG2 DAC_SWTRIGR_SWTRIG2_Msk |
| #define | DAC_DHR12R1_DACC1DHR_Pos (0U) |
| #define | DAC_DHR12R1_DACC1DHR_Msk (0xFFFUL << DAC_DHR12R1_DACC1DHR_Pos) |
| #define | DAC_DHR12R1_DACC1DHR DAC_DHR12R1_DACC1DHR_Msk |
| #define | DAC_DHR12L1_DACC1DHR_Pos (4U) |
| #define | DAC_DHR12L1_DACC1DHR_Msk (0xFFFUL << DAC_DHR12L1_DACC1DHR_Pos) |
| #define | DAC_DHR12L1_DACC1DHR DAC_DHR12L1_DACC1DHR_Msk |
| #define | DAC_DHR8R1_DACC1DHR_Pos (0U) |
| #define | DAC_DHR8R1_DACC1DHR_Msk (0xFFUL << DAC_DHR8R1_DACC1DHR_Pos) |
| #define | DAC_DHR8R1_DACC1DHR DAC_DHR8R1_DACC1DHR_Msk |
| #define | DAC_DHR12R2_DACC2DHR_Pos (0U) |
| #define | DAC_DHR12R2_DACC2DHR_Msk (0xFFFUL << DAC_DHR12R2_DACC2DHR_Pos) |
| #define | DAC_DHR12R2_DACC2DHR DAC_DHR12R2_DACC2DHR_Msk |
| #define | DAC_DHR12L2_DACC2DHR_Pos (4U) |
| #define | DAC_DHR12L2_DACC2DHR_Msk (0xFFFUL << DAC_DHR12L2_DACC2DHR_Pos) |
| #define | DAC_DHR12L2_DACC2DHR DAC_DHR12L2_DACC2DHR_Msk |
| #define | DAC_DHR8R2_DACC2DHR_Pos (0U) |
| #define | DAC_DHR8R2_DACC2DHR_Msk (0xFFUL << DAC_DHR8R2_DACC2DHR_Pos) |
| #define | DAC_DHR8R2_DACC2DHR DAC_DHR8R2_DACC2DHR_Msk |
| #define | DAC_DHR12RD_DACC1DHR_Pos (0U) |
| #define | DAC_DHR12RD_DACC1DHR_Msk (0xFFFUL << DAC_DHR12RD_DACC1DHR_Pos) |
| #define | DAC_DHR12RD_DACC1DHR DAC_DHR12RD_DACC1DHR_Msk |
| #define | DAC_DHR12RD_DACC2DHR_Pos (16U) |
| #define | DAC_DHR12RD_DACC2DHR_Msk (0xFFFUL << DAC_DHR12RD_DACC2DHR_Pos) |
| #define | DAC_DHR12RD_DACC2DHR DAC_DHR12RD_DACC2DHR_Msk |
| #define | DAC_DHR12LD_DACC1DHR_Pos (4U) |
| #define | DAC_DHR12LD_DACC1DHR_Msk (0xFFFUL << DAC_DHR12LD_DACC1DHR_Pos) |
| #define | DAC_DHR12LD_DACC1DHR DAC_DHR12LD_DACC1DHR_Msk |
| #define | DAC_DHR12LD_DACC2DHR_Pos (20U) |
| #define | DAC_DHR12LD_DACC2DHR_Msk (0xFFFUL << DAC_DHR12LD_DACC2DHR_Pos) |
| #define | DAC_DHR12LD_DACC2DHR DAC_DHR12LD_DACC2DHR_Msk |
| #define | DAC_DHR8RD_DACC1DHR_Pos (0U) |
| #define | DAC_DHR8RD_DACC1DHR_Msk (0xFFUL << DAC_DHR8RD_DACC1DHR_Pos) |
| #define | DAC_DHR8RD_DACC1DHR DAC_DHR8RD_DACC1DHR_Msk |
| #define | DAC_DHR8RD_DACC2DHR_Pos (8U) |
| #define | DAC_DHR8RD_DACC2DHR_Msk (0xFFUL << DAC_DHR8RD_DACC2DHR_Pos) |
| #define | DAC_DHR8RD_DACC2DHR DAC_DHR8RD_DACC2DHR_Msk |
| #define | DAC_DOR1_DACC1DOR_Pos (0U) |
| #define | DAC_DOR1_DACC1DOR_Msk (0xFFFUL << DAC_DOR1_DACC1DOR_Pos) |
| #define | DAC_DOR1_DACC1DOR DAC_DOR1_DACC1DOR_Msk |
| #define | DAC_DOR2_DACC2DOR_Pos (0U) |
| #define | DAC_DOR2_DACC2DOR_Msk (0xFFFUL << DAC_DOR2_DACC2DOR_Pos) |
| #define | DAC_DOR2_DACC2DOR DAC_DOR2_DACC2DOR_Msk |
| #define | DAC_SR_DMAUDR1_Pos (13U) |
| #define | DAC_SR_DMAUDR1_Msk (0x1UL << DAC_SR_DMAUDR1_Pos) |
| #define | DAC_SR_DMAUDR1 DAC_SR_DMAUDR1_Msk |
| #define | DAC_SR_CAL_FLAG1_Pos (14U) |
| #define | DAC_SR_CAL_FLAG1_Msk (0x1UL << DAC_SR_CAL_FLAG1_Pos) |
| #define | DAC_SR_CAL_FLAG1 DAC_SR_CAL_FLAG1_Msk |
| #define | DAC_SR_BWST1_Pos (15U) |
| #define | DAC_SR_BWST1_Msk (0x4001UL << DAC_SR_BWST1_Pos) |
| #define | DAC_SR_BWST1 DAC_SR_BWST1_Msk |
| #define | DAC_SR_DMAUDR2_Pos (29U) |
| #define | DAC_SR_DMAUDR2_Msk (0x1UL << DAC_SR_DMAUDR2_Pos) |
| #define | DAC_SR_DMAUDR2 DAC_SR_DMAUDR2_Msk |
| #define | DAC_SR_CAL_FLAG2_Pos (30U) |
| #define | DAC_SR_CAL_FLAG2_Msk (0x1UL << DAC_SR_CAL_FLAG2_Pos) |
| #define | DAC_SR_CAL_FLAG2 DAC_SR_CAL_FLAG2_Msk |
| #define | DAC_SR_BWST2_Pos (31U) |
| #define | DAC_SR_BWST2_Msk (0x1UL << DAC_SR_BWST2_Pos) |
| #define | DAC_SR_BWST2 DAC_SR_BWST2_Msk |
| #define | DAC_CCR_OTRIM1_Pos (0U) |
| #define | DAC_CCR_OTRIM1_Msk (0x1FUL << DAC_CCR_OTRIM1_Pos) |
| #define | DAC_CCR_OTRIM1 DAC_CCR_OTRIM1_Msk |
| #define | DAC_CCR_OTRIM2_Pos (16U) |
| #define | DAC_CCR_OTRIM2_Msk (0x1FUL << DAC_CCR_OTRIM2_Pos) |
| #define | DAC_CCR_OTRIM2 DAC_CCR_OTRIM2_Msk |
| #define | DAC_MCR_MODE1_Pos (0U) |
| #define | DAC_MCR_MODE1_Msk (0x7UL << DAC_MCR_MODE1_Pos) |
| #define | DAC_MCR_MODE1 DAC_MCR_MODE1_Msk |
| #define | DAC_MCR_MODE1_0 (0x1UL << DAC_MCR_MODE1_Pos) |
| #define | DAC_MCR_MODE1_1 (0x2UL << DAC_MCR_MODE1_Pos) |
| #define | DAC_MCR_MODE1_2 (0x4UL << DAC_MCR_MODE1_Pos) |
| #define | DAC_MCR_MODE2_Pos (16U) |
| #define | DAC_MCR_MODE2_Msk (0x7UL << DAC_MCR_MODE2_Pos) |
| #define | DAC_MCR_MODE2 DAC_MCR_MODE2_Msk |
| #define | DAC_MCR_MODE2_0 (0x1UL << DAC_MCR_MODE2_Pos) |
| #define | DAC_MCR_MODE2_1 (0x2UL << DAC_MCR_MODE2_Pos) |
| #define | DAC_MCR_MODE2_2 (0x4UL << DAC_MCR_MODE2_Pos) |
| #define | DAC_SHSR1_TSAMPLE1_Pos (0U) |
| #define | DAC_SHSR1_TSAMPLE1_Msk (0x3FFUL << DAC_SHSR1_TSAMPLE1_Pos) |
| #define | DAC_SHSR1_TSAMPLE1 DAC_SHSR1_TSAMPLE1_Msk |
| #define | DAC_SHSR2_TSAMPLE2_Pos (0U) |
| #define | DAC_SHSR2_TSAMPLE2_Msk (0x3FFUL << DAC_SHSR2_TSAMPLE2_Pos) |
| #define | DAC_SHSR2_TSAMPLE2 DAC_SHSR2_TSAMPLE2_Msk |
| #define | DAC_SHHR_THOLD1_Pos (0U) |
| #define | DAC_SHHR_THOLD1_Msk (0x3FFUL << DAC_SHHR_THOLD1_Pos) |
| #define | DAC_SHHR_THOLD1 DAC_SHHR_THOLD1_Msk |
| #define | DAC_SHHR_THOLD2_Pos (16U) |
| #define | DAC_SHHR_THOLD2_Msk (0x3FFUL << DAC_SHHR_THOLD2_Pos) |
| #define | DAC_SHHR_THOLD2 DAC_SHHR_THOLD2_Msk |
| #define | DAC_SHRR_TREFRESH1_Pos (0U) |
| #define | DAC_SHRR_TREFRESH1_Msk (0xFFUL << DAC_SHRR_TREFRESH1_Pos) |
| #define | DAC_SHRR_TREFRESH1 DAC_SHRR_TREFRESH1_Msk |
| #define | DAC_SHRR_TREFRESH2_Pos (16U) |
| #define | DAC_SHRR_TREFRESH2_Msk (0xFFUL << DAC_SHRR_TREFRESH2_Pos) |
| #define | DAC_SHRR_TREFRESH2 DAC_SHRR_TREFRESH2_Msk |
| #define | DCMI_CR_CAPTURE_Pos (0U) |
| #define | DCMI_CR_CAPTURE_Msk (0x1UL << DCMI_CR_CAPTURE_Pos) |
| #define | DCMI_CR_CAPTURE DCMI_CR_CAPTURE_Msk |
| #define | DCMI_CR_CM_Pos (1U) |
| #define | DCMI_CR_CM_Msk (0x1UL << DCMI_CR_CM_Pos) |
| #define | DCMI_CR_CM DCMI_CR_CM_Msk |
| #define | DCMI_CR_CROP_Pos (2U) |
| #define | DCMI_CR_CROP_Msk (0x1UL << DCMI_CR_CROP_Pos) |
| #define | DCMI_CR_CROP DCMI_CR_CROP_Msk |
| #define | DCMI_CR_JPEG_Pos (3U) |
| #define | DCMI_CR_JPEG_Msk (0x1UL << DCMI_CR_JPEG_Pos) |
| #define | DCMI_CR_JPEG DCMI_CR_JPEG_Msk |
| #define | DCMI_CR_ESS_Pos (4U) |
| #define | DCMI_CR_ESS_Msk (0x1UL << DCMI_CR_ESS_Pos) |
| #define | DCMI_CR_ESS DCMI_CR_ESS_Msk |
| #define | DCMI_CR_PCKPOL_Pos (5U) |
| #define | DCMI_CR_PCKPOL_Msk (0x1UL << DCMI_CR_PCKPOL_Pos) |
| #define | DCMI_CR_PCKPOL DCMI_CR_PCKPOL_Msk |
| #define | DCMI_CR_HSPOL_Pos (6U) |
| #define | DCMI_CR_HSPOL_Msk (0x1UL << DCMI_CR_HSPOL_Pos) |
| #define | DCMI_CR_HSPOL DCMI_CR_HSPOL_Msk |
| #define | DCMI_CR_VSPOL_Pos (7U) |
| #define | DCMI_CR_VSPOL_Msk (0x1UL << DCMI_CR_VSPOL_Pos) |
| #define | DCMI_CR_VSPOL DCMI_CR_VSPOL_Msk |
| #define | DCMI_CR_FCRC_0 (0x00000100U) |
| #define | DCMI_CR_FCRC_1 (0x00000200U) |
| #define | DCMI_CR_EDM_0 (0x00000400U) |
| #define | DCMI_CR_EDM_1 (0x00000800U) |
| #define | DCMI_CR_CRE_Pos (12U) |
| #define | DCMI_CR_CRE_Msk (0x1UL << DCMI_CR_CRE_Pos) |
| #define | DCMI_CR_CRE DCMI_CR_CRE_Msk |
| #define | DCMI_CR_ENABLE_Pos (14U) |
| #define | DCMI_CR_ENABLE_Msk (0x1UL << DCMI_CR_ENABLE_Pos) |
| #define | DCMI_CR_ENABLE DCMI_CR_ENABLE_Msk |
| #define | DCMI_CR_BSM_Pos (16U) |
| #define | DCMI_CR_BSM_Msk (0x3UL << DCMI_CR_BSM_Pos) |
| #define | DCMI_CR_BSM DCMI_CR_BSM_Msk |
| #define | DCMI_CR_BSM_0 (0x1UL << DCMI_CR_BSM_Pos) |
| #define | DCMI_CR_BSM_1 (0x2UL << DCMI_CR_BSM_Pos) |
| #define | DCMI_CR_OEBS_Pos (18U) |
| #define | DCMI_CR_OEBS_Msk (0x1UL << DCMI_CR_OEBS_Pos) |
| #define | DCMI_CR_OEBS DCMI_CR_OEBS_Msk |
| #define | DCMI_CR_LSM_Pos (19U) |
| #define | DCMI_CR_LSM_Msk (0x1UL << DCMI_CR_LSM_Pos) |
| #define | DCMI_CR_LSM DCMI_CR_LSM_Msk |
| #define | DCMI_CR_OELS_Pos (20U) |
| #define | DCMI_CR_OELS_Msk (0x1UL << DCMI_CR_OELS_Pos) |
| #define | DCMI_CR_OELS DCMI_CR_OELS_Msk |
| #define | DCMI_SR_HSYNC_Pos (0U) |
| #define | DCMI_SR_HSYNC_Msk (0x1UL << DCMI_SR_HSYNC_Pos) |
| #define | DCMI_SR_HSYNC DCMI_SR_HSYNC_Msk |
| #define | DCMI_SR_VSYNC_Pos (1U) |
| #define | DCMI_SR_VSYNC_Msk (0x1UL << DCMI_SR_VSYNC_Pos) |
| #define | DCMI_SR_VSYNC DCMI_SR_VSYNC_Msk |
| #define | DCMI_SR_FNE_Pos (2U) |
| #define | DCMI_SR_FNE_Msk (0x1UL << DCMI_SR_FNE_Pos) |
| #define | DCMI_SR_FNE DCMI_SR_FNE_Msk |
| #define | DCMI_RIS_FRAME_RIS_Pos (0U) |
| #define | DCMI_RIS_FRAME_RIS_Msk (0x1UL << DCMI_RIS_FRAME_RIS_Pos) |
| #define | DCMI_RIS_FRAME_RIS DCMI_RIS_FRAME_RIS_Msk |
| #define | DCMI_RIS_OVR_RIS_Pos (1U) |
| #define | DCMI_RIS_OVR_RIS_Msk (0x1UL << DCMI_RIS_OVR_RIS_Pos) |
| #define | DCMI_RIS_OVR_RIS DCMI_RIS_OVR_RIS_Msk |
| #define | DCMI_RIS_ERR_RIS_Pos (2U) |
| #define | DCMI_RIS_ERR_RIS_Msk (0x1UL << DCMI_RIS_ERR_RIS_Pos) |
| #define | DCMI_RIS_ERR_RIS DCMI_RIS_ERR_RIS_Msk |
| #define | DCMI_RIS_VSYNC_RIS_Pos (3U) |
| #define | DCMI_RIS_VSYNC_RIS_Msk (0x1UL << DCMI_RIS_VSYNC_RIS_Pos) |
| #define | DCMI_RIS_VSYNC_RIS DCMI_RIS_VSYNC_RIS_Msk |
| #define | DCMI_RIS_LINE_RIS_Pos (4U) |
| #define | DCMI_RIS_LINE_RIS_Msk (0x1UL << DCMI_RIS_LINE_RIS_Pos) |
| #define | DCMI_RIS_LINE_RIS DCMI_RIS_LINE_RIS_Msk |
| #define | DCMI_IER_FRAME_IE_Pos (0U) |
| #define | DCMI_IER_FRAME_IE_Msk (0x1UL << DCMI_IER_FRAME_IE_Pos) |
| #define | DCMI_IER_FRAME_IE DCMI_IER_FRAME_IE_Msk |
| #define | DCMI_IER_OVR_IE_Pos (1U) |
| #define | DCMI_IER_OVR_IE_Msk (0x1UL << DCMI_IER_OVR_IE_Pos) |
| #define | DCMI_IER_OVR_IE DCMI_IER_OVR_IE_Msk |
| #define | DCMI_IER_ERR_IE_Pos (2U) |
| #define | DCMI_IER_ERR_IE_Msk (0x1UL << DCMI_IER_ERR_IE_Pos) |
| #define | DCMI_IER_ERR_IE DCMI_IER_ERR_IE_Msk |
| #define | DCMI_IER_VSYNC_IE_Pos (3U) |
| #define | DCMI_IER_VSYNC_IE_Msk (0x1UL << DCMI_IER_VSYNC_IE_Pos) |
| #define | DCMI_IER_VSYNC_IE DCMI_IER_VSYNC_IE_Msk |
| #define | DCMI_IER_LINE_IE_Pos (4U) |
| #define | DCMI_IER_LINE_IE_Msk (0x1UL << DCMI_IER_LINE_IE_Pos) |
| #define | DCMI_IER_LINE_IE DCMI_IER_LINE_IE_Msk |
| #define | DCMI_MIS_FRAME_MIS_Pos (0U) |
| #define | DCMI_MIS_FRAME_MIS_Msk (0x1UL << DCMI_MIS_FRAME_MIS_Pos) |
| #define | DCMI_MIS_FRAME_MIS DCMI_MIS_FRAME_MIS_Msk |
| #define | DCMI_MIS_OVR_MIS_Pos (1U) |
| #define | DCMI_MIS_OVR_MIS_Msk (0x1UL << DCMI_MIS_OVR_MIS_Pos) |
| #define | DCMI_MIS_OVR_MIS DCMI_MIS_OVR_MIS_Msk |
| #define | DCMI_MIS_ERR_MIS_Pos (2U) |
| #define | DCMI_MIS_ERR_MIS_Msk (0x1UL << DCMI_MIS_ERR_MIS_Pos) |
| #define | DCMI_MIS_ERR_MIS DCMI_MIS_ERR_MIS_Msk |
| #define | DCMI_MIS_VSYNC_MIS_Pos (3U) |
| #define | DCMI_MIS_VSYNC_MIS_Msk (0x1UL << DCMI_MIS_VSYNC_MIS_Pos) |
| #define | DCMI_MIS_VSYNC_MIS DCMI_MIS_VSYNC_MIS_Msk |
| #define | DCMI_MIS_LINE_MIS_Pos (4U) |
| #define | DCMI_MIS_LINE_MIS_Msk (0x1UL << DCMI_MIS_LINE_MIS_Pos) |
| #define | DCMI_MIS_LINE_MIS DCMI_MIS_LINE_MIS_Msk |
| #define | DCMI_ICR_FRAME_ISC_Pos (0U) |
| #define | DCMI_ICR_FRAME_ISC_Msk (0x1UL << DCMI_ICR_FRAME_ISC_Pos) |
| #define | DCMI_ICR_FRAME_ISC DCMI_ICR_FRAME_ISC_Msk |
| #define | DCMI_ICR_OVR_ISC_Pos (1U) |
| #define | DCMI_ICR_OVR_ISC_Msk (0x1UL << DCMI_ICR_OVR_ISC_Pos) |
| #define | DCMI_ICR_OVR_ISC DCMI_ICR_OVR_ISC_Msk |
| #define | DCMI_ICR_ERR_ISC_Pos (2U) |
| #define | DCMI_ICR_ERR_ISC_Msk (0x1UL << DCMI_ICR_ERR_ISC_Pos) |
| #define | DCMI_ICR_ERR_ISC DCMI_ICR_ERR_ISC_Msk |
| #define | DCMI_ICR_VSYNC_ISC_Pos (3U) |
| #define | DCMI_ICR_VSYNC_ISC_Msk (0x1UL << DCMI_ICR_VSYNC_ISC_Pos) |
| #define | DCMI_ICR_VSYNC_ISC DCMI_ICR_VSYNC_ISC_Msk |
| #define | DCMI_ICR_LINE_ISC_Pos (4U) |
| #define | DCMI_ICR_LINE_ISC_Msk (0x1UL << DCMI_ICR_LINE_ISC_Pos) |
| #define | DCMI_ICR_LINE_ISC DCMI_ICR_LINE_ISC_Msk |
| #define | DCMI_ESCR_FSC_Pos (0U) |
| #define | DCMI_ESCR_FSC_Msk (0xFFUL << DCMI_ESCR_FSC_Pos) |
| #define | DCMI_ESCR_FSC DCMI_ESCR_FSC_Msk |
| #define | DCMI_ESCR_LSC_Pos (8U) |
| #define | DCMI_ESCR_LSC_Msk (0xFFUL << DCMI_ESCR_LSC_Pos) |
| #define | DCMI_ESCR_LSC DCMI_ESCR_LSC_Msk |
| #define | DCMI_ESCR_LEC_Pos (16U) |
| #define | DCMI_ESCR_LEC_Msk (0xFFUL << DCMI_ESCR_LEC_Pos) |
| #define | DCMI_ESCR_LEC DCMI_ESCR_LEC_Msk |
| #define | DCMI_ESCR_FEC_Pos (24U) |
| #define | DCMI_ESCR_FEC_Msk (0xFFUL << DCMI_ESCR_FEC_Pos) |
| #define | DCMI_ESCR_FEC DCMI_ESCR_FEC_Msk |
| #define | DCMI_ESUR_FSU_Pos (0U) |
| #define | DCMI_ESUR_FSU_Msk (0xFFUL << DCMI_ESUR_FSU_Pos) |
| #define | DCMI_ESUR_FSU DCMI_ESUR_FSU_Msk |
| #define | DCMI_ESUR_LSU_Pos (8U) |
| #define | DCMI_ESUR_LSU_Msk (0xFFUL << DCMI_ESUR_LSU_Pos) |
| #define | DCMI_ESUR_LSU DCMI_ESUR_LSU_Msk |
| #define | DCMI_ESUR_LEU_Pos (16U) |
| #define | DCMI_ESUR_LEU_Msk (0xFFUL << DCMI_ESUR_LEU_Pos) |
| #define | DCMI_ESUR_LEU DCMI_ESUR_LEU_Msk |
| #define | DCMI_ESUR_FEU_Pos (24U) |
| #define | DCMI_ESUR_FEU_Msk (0xFFUL << DCMI_ESUR_FEU_Pos) |
| #define | DCMI_ESUR_FEU DCMI_ESUR_FEU_Msk |
| #define | DCMI_CWSTRT_HOFFCNT_Pos (0U) |
| #define | DCMI_CWSTRT_HOFFCNT_Msk (0x3FFFUL << DCMI_CWSTRT_HOFFCNT_Pos) |
| #define | DCMI_CWSTRT_HOFFCNT DCMI_CWSTRT_HOFFCNT_Msk |
| #define | DCMI_CWSTRT_VST_Pos (16U) |
| #define | DCMI_CWSTRT_VST_Msk (0x1FFFUL << DCMI_CWSTRT_VST_Pos) |
| #define | DCMI_CWSTRT_VST DCMI_CWSTRT_VST_Msk |
| #define | DCMI_CWSIZE_CAPCNT_Pos (0U) |
| #define | DCMI_CWSIZE_CAPCNT_Msk (0x3FFFUL << DCMI_CWSIZE_CAPCNT_Pos) |
| #define | DCMI_CWSIZE_CAPCNT DCMI_CWSIZE_CAPCNT_Msk |
| #define | DCMI_CWSIZE_VLINE_Pos (16U) |
| #define | DCMI_CWSIZE_VLINE_Msk (0x3FFFUL << DCMI_CWSIZE_VLINE_Pos) |
| #define | DCMI_CWSIZE_VLINE DCMI_CWSIZE_VLINE_Msk |
| #define | DCMI_DR_BYTE0_Pos (0U) |
| #define | DCMI_DR_BYTE0_Msk (0xFFUL << DCMI_DR_BYTE0_Pos) |
| #define | DCMI_DR_BYTE0 DCMI_DR_BYTE0_Msk |
| #define | DCMI_DR_BYTE1_Pos (8U) |
| #define | DCMI_DR_BYTE1_Msk (0xFFUL << DCMI_DR_BYTE1_Pos) |
| #define | DCMI_DR_BYTE1 DCMI_DR_BYTE1_Msk |
| #define | DCMI_DR_BYTE2_Pos (16U) |
| #define | DCMI_DR_BYTE2_Msk (0xFFUL << DCMI_DR_BYTE2_Pos) |
| #define | DCMI_DR_BYTE2 DCMI_DR_BYTE2_Msk |
| #define | DCMI_DR_BYTE3_Pos (24U) |
| #define | DCMI_DR_BYTE3_Msk (0xFFUL << DCMI_DR_BYTE3_Pos) |
| #define | DCMI_DR_BYTE3 DCMI_DR_BYTE3_Msk |
| #define | DFSDM_CHCFGR1_DFSDMEN_Pos (31U) |
| #define | DFSDM_CHCFGR1_DFSDMEN_Msk (0x1UL << DFSDM_CHCFGR1_DFSDMEN_Pos) |
| #define | DFSDM_CHCFGR1_DFSDMEN DFSDM_CHCFGR1_DFSDMEN_Msk |
| #define | DFSDM_CHCFGR1_CKOUTSRC_Pos (30U) |
| #define | DFSDM_CHCFGR1_CKOUTSRC_Msk (0x1UL << DFSDM_CHCFGR1_CKOUTSRC_Pos) |
| #define | DFSDM_CHCFGR1_CKOUTSRC DFSDM_CHCFGR1_CKOUTSRC_Msk |
| #define | DFSDM_CHCFGR1_CKOUTDIV_Pos (16U) |
| #define | DFSDM_CHCFGR1_CKOUTDIV_Msk (0xFFUL << DFSDM_CHCFGR1_CKOUTDIV_Pos) |
| #define | DFSDM_CHCFGR1_CKOUTDIV DFSDM_CHCFGR1_CKOUTDIV_Msk |
| #define | DFSDM_CHCFGR1_DATPACK_Pos (14U) |
| #define | DFSDM_CHCFGR1_DATPACK_Msk (0x3UL << DFSDM_CHCFGR1_DATPACK_Pos) |
| #define | DFSDM_CHCFGR1_DATPACK DFSDM_CHCFGR1_DATPACK_Msk |
| #define | DFSDM_CHCFGR1_DATPACK_1 (0x2UL << DFSDM_CHCFGR1_DATPACK_Pos) |
| #define | DFSDM_CHCFGR1_DATPACK_0 (0x1UL << DFSDM_CHCFGR1_DATPACK_Pos) |
| #define | DFSDM_CHCFGR1_DATMPX_Pos (12U) |
| #define | DFSDM_CHCFGR1_DATMPX_Msk (0x3UL << DFSDM_CHCFGR1_DATMPX_Pos) |
| #define | DFSDM_CHCFGR1_DATMPX DFSDM_CHCFGR1_DATMPX_Msk |
| #define | DFSDM_CHCFGR1_DATMPX_1 (0x2UL << DFSDM_CHCFGR1_DATMPX_Pos) |
| #define | DFSDM_CHCFGR1_DATMPX_0 (0x1UL << DFSDM_CHCFGR1_DATMPX_Pos) |
| #define | DFSDM_CHCFGR1_CHINSEL_Pos (8U) |
| #define | DFSDM_CHCFGR1_CHINSEL_Msk (0x1UL << DFSDM_CHCFGR1_CHINSEL_Pos) |
| #define | DFSDM_CHCFGR1_CHINSEL DFSDM_CHCFGR1_CHINSEL_Msk |
| #define | DFSDM_CHCFGR1_CHEN_Pos (7U) |
| #define | DFSDM_CHCFGR1_CHEN_Msk (0x1UL << DFSDM_CHCFGR1_CHEN_Pos) |
| #define | DFSDM_CHCFGR1_CHEN DFSDM_CHCFGR1_CHEN_Msk |
| #define | DFSDM_CHCFGR1_CKABEN_Pos (6U) |
| #define | DFSDM_CHCFGR1_CKABEN_Msk (0x1UL << DFSDM_CHCFGR1_CKABEN_Pos) |
| #define | DFSDM_CHCFGR1_CKABEN DFSDM_CHCFGR1_CKABEN_Msk |
| #define | DFSDM_CHCFGR1_SCDEN_Pos (5U) |
| #define | DFSDM_CHCFGR1_SCDEN_Msk (0x1UL << DFSDM_CHCFGR1_SCDEN_Pos) |
| #define | DFSDM_CHCFGR1_SCDEN DFSDM_CHCFGR1_SCDEN_Msk |
| #define | DFSDM_CHCFGR1_SPICKSEL_Pos (2U) |
| #define | DFSDM_CHCFGR1_SPICKSEL_Msk (0x3UL << DFSDM_CHCFGR1_SPICKSEL_Pos) |
| #define | DFSDM_CHCFGR1_SPICKSEL DFSDM_CHCFGR1_SPICKSEL_Msk |
| #define | DFSDM_CHCFGR1_SPICKSEL_1 (0x2UL << DFSDM_CHCFGR1_SPICKSEL_Pos) |
| #define | DFSDM_CHCFGR1_SPICKSEL_0 (0x1UL << DFSDM_CHCFGR1_SPICKSEL_Pos) |
| #define | DFSDM_CHCFGR1_SITP_Pos (0U) |
| #define | DFSDM_CHCFGR1_SITP_Msk (0x3UL << DFSDM_CHCFGR1_SITP_Pos) |
| #define | DFSDM_CHCFGR1_SITP DFSDM_CHCFGR1_SITP_Msk |
| #define | DFSDM_CHCFGR1_SITP_1 (0x2UL << DFSDM_CHCFGR1_SITP_Pos) |
| #define | DFSDM_CHCFGR1_SITP_0 (0x1UL << DFSDM_CHCFGR1_SITP_Pos) |
| #define | DFSDM_CHCFGR2_OFFSET_Pos (8U) |
| #define | DFSDM_CHCFGR2_OFFSET_Msk (0xFFFFFFUL << DFSDM_CHCFGR2_OFFSET_Pos) |
| #define | DFSDM_CHCFGR2_OFFSET DFSDM_CHCFGR2_OFFSET_Msk |
| #define | DFSDM_CHCFGR2_DTRBS_Pos (3U) |
| #define | DFSDM_CHCFGR2_DTRBS_Msk (0x1FUL << DFSDM_CHCFGR2_DTRBS_Pos) |
| #define | DFSDM_CHCFGR2_DTRBS DFSDM_CHCFGR2_DTRBS_Msk |
| #define | DFSDM_CHAWSCDR_AWFORD_Pos (22U) |
| #define | DFSDM_CHAWSCDR_AWFORD_Msk (0x3UL << DFSDM_CHAWSCDR_AWFORD_Pos) |
| #define | DFSDM_CHAWSCDR_AWFORD DFSDM_CHAWSCDR_AWFORD_Msk |
| #define | DFSDM_CHAWSCDR_AWFORD_1 (0x2UL << DFSDM_CHAWSCDR_AWFORD_Pos) |
| #define | DFSDM_CHAWSCDR_AWFORD_0 (0x1UL << DFSDM_CHAWSCDR_AWFORD_Pos) |
| #define | DFSDM_CHAWSCDR_AWFOSR_Pos (16U) |
| #define | DFSDM_CHAWSCDR_AWFOSR_Msk (0x1FUL << DFSDM_CHAWSCDR_AWFOSR_Pos) |
| #define | DFSDM_CHAWSCDR_AWFOSR DFSDM_CHAWSCDR_AWFOSR_Msk |
| #define | DFSDM_CHAWSCDR_BKSCD_Pos (12U) |
| #define | DFSDM_CHAWSCDR_BKSCD_Msk (0xFUL << DFSDM_CHAWSCDR_BKSCD_Pos) |
| #define | DFSDM_CHAWSCDR_BKSCD DFSDM_CHAWSCDR_BKSCD_Msk |
| #define | DFSDM_CHAWSCDR_SCDT_Pos (0U) |
| #define | DFSDM_CHAWSCDR_SCDT_Msk (0xFFUL << DFSDM_CHAWSCDR_SCDT_Pos) |
| #define | DFSDM_CHAWSCDR_SCDT DFSDM_CHAWSCDR_SCDT_Msk |
| #define | DFSDM_CHWDATR_WDATA_Pos (0U) |
| #define | DFSDM_CHWDATR_WDATA_Msk (0xFFFFUL << DFSDM_CHWDATR_WDATA_Pos) |
| #define | DFSDM_CHWDATR_WDATA DFSDM_CHWDATR_WDATA_Msk |
| #define | DFSDM_CHDATINR_INDAT0_Pos (0U) |
| #define | DFSDM_CHDATINR_INDAT0_Msk (0xFFFFUL << DFSDM_CHDATINR_INDAT0_Pos) |
| #define | DFSDM_CHDATINR_INDAT0 DFSDM_CHDATINR_INDAT0_Msk |
| #define | DFSDM_CHDATINR_INDAT1_Pos (16U) |
| #define | DFSDM_CHDATINR_INDAT1_Msk (0xFFFFUL << DFSDM_CHDATINR_INDAT1_Pos) |
| #define | DFSDM_CHDATINR_INDAT1 DFSDM_CHDATINR_INDAT1_Msk |
| #define | DFSDM_FLTCR1_AWFSEL_Pos (30U) |
| #define | DFSDM_FLTCR1_AWFSEL_Msk (0x1UL << DFSDM_FLTCR1_AWFSEL_Pos) |
| #define | DFSDM_FLTCR1_AWFSEL DFSDM_FLTCR1_AWFSEL_Msk |
| #define | DFSDM_FLTCR1_FAST_Pos (29U) |
| #define | DFSDM_FLTCR1_FAST_Msk (0x1UL << DFSDM_FLTCR1_FAST_Pos) |
| #define | DFSDM_FLTCR1_FAST DFSDM_FLTCR1_FAST_Msk |
| #define | DFSDM_FLTCR1_RCH_Pos (24U) |
| #define | DFSDM_FLTCR1_RCH_Msk (0x7UL << DFSDM_FLTCR1_RCH_Pos) |
| #define | DFSDM_FLTCR1_RCH DFSDM_FLTCR1_RCH_Msk |
| #define | DFSDM_FLTCR1_RDMAEN_Pos (21U) |
| #define | DFSDM_FLTCR1_RDMAEN_Msk (0x1UL << DFSDM_FLTCR1_RDMAEN_Pos) |
| #define | DFSDM_FLTCR1_RDMAEN DFSDM_FLTCR1_RDMAEN_Msk |
| #define | DFSDM_FLTCR1_RSYNC_Pos (19U) |
| #define | DFSDM_FLTCR1_RSYNC_Msk (0x1UL << DFSDM_FLTCR1_RSYNC_Pos) |
| #define | DFSDM_FLTCR1_RSYNC DFSDM_FLTCR1_RSYNC_Msk |
| #define | DFSDM_FLTCR1_RCONT_Pos (18U) |
| #define | DFSDM_FLTCR1_RCONT_Msk (0x1UL << DFSDM_FLTCR1_RCONT_Pos) |
| #define | DFSDM_FLTCR1_RCONT DFSDM_FLTCR1_RCONT_Msk |
| #define | DFSDM_FLTCR1_RSWSTART_Pos (17U) |
| #define | DFSDM_FLTCR1_RSWSTART_Msk (0x1UL << DFSDM_FLTCR1_RSWSTART_Pos) |
| #define | DFSDM_FLTCR1_RSWSTART DFSDM_FLTCR1_RSWSTART_Msk |
| #define | DFSDM_FLTCR1_JEXTEN_Pos (13U) |
| #define | DFSDM_FLTCR1_JEXTEN_Msk (0x3UL << DFSDM_FLTCR1_JEXTEN_Pos) |
| #define | DFSDM_FLTCR1_JEXTEN DFSDM_FLTCR1_JEXTEN_Msk |
| #define | DFSDM_FLTCR1_JEXTEN_1 (0x2UL << DFSDM_FLTCR1_JEXTEN_Pos) |
| #define | DFSDM_FLTCR1_JEXTEN_0 (0x1UL << DFSDM_FLTCR1_JEXTEN_Pos) |
| #define | DFSDM_FLTCR1_JEXTSEL_Pos (8U) |
| #define | DFSDM_FLTCR1_JEXTSEL_Msk (0x1FUL << DFSDM_FLTCR1_JEXTSEL_Pos) |
| #define | DFSDM_FLTCR1_JEXTSEL DFSDM_FLTCR1_JEXTSEL_Msk |
| #define | DFSDM_FLTCR1_JEXTSEL_0 (0x01UL << DFSDM_FLTCR1_JEXTSEL_Pos) |
| #define | DFSDM_FLTCR1_JEXTSEL_1 (0x02UL << DFSDM_FLTCR1_JEXTSEL_Pos) |
| #define | DFSDM_FLTCR1_JEXTSEL_2 (0x04UL << DFSDM_FLTCR1_JEXTSEL_Pos) |
| #define | DFSDM_FLTCR1_JEXTSEL_3 (0x08UL << DFSDM_FLTCR1_JEXTSEL_Pos) |
| #define | DFSDM_FLTCR1_JEXTSEL_4 (0x10UL << DFSDM_FLTCR1_JEXTSEL_Pos) |
| #define | DFSDM_FLTCR1_JDMAEN_Pos (5U) |
| #define | DFSDM_FLTCR1_JDMAEN_Msk (0x1UL << DFSDM_FLTCR1_JDMAEN_Pos) |
| #define | DFSDM_FLTCR1_JDMAEN DFSDM_FLTCR1_JDMAEN_Msk |
| #define | DFSDM_FLTCR1_JSCAN_Pos (4U) |
| #define | DFSDM_FLTCR1_JSCAN_Msk (0x1UL << DFSDM_FLTCR1_JSCAN_Pos) |
| #define | DFSDM_FLTCR1_JSCAN DFSDM_FLTCR1_JSCAN_Msk |
| #define | DFSDM_FLTCR1_JSYNC_Pos (3U) |
| #define | DFSDM_FLTCR1_JSYNC_Msk (0x1UL << DFSDM_FLTCR1_JSYNC_Pos) |
| #define | DFSDM_FLTCR1_JSYNC DFSDM_FLTCR1_JSYNC_Msk |
| #define | DFSDM_FLTCR1_JSWSTART_Pos (1U) |
| #define | DFSDM_FLTCR1_JSWSTART_Msk (0x1UL << DFSDM_FLTCR1_JSWSTART_Pos) |
| #define | DFSDM_FLTCR1_JSWSTART DFSDM_FLTCR1_JSWSTART_Msk |
| #define | DFSDM_FLTCR1_DFEN_Pos (0U) |
| #define | DFSDM_FLTCR1_DFEN_Msk (0x1UL << DFSDM_FLTCR1_DFEN_Pos) |
| #define | DFSDM_FLTCR1_DFEN DFSDM_FLTCR1_DFEN_Msk |
| #define | DFSDM_FLTCR2_AWDCH_Pos (16U) |
| #define | DFSDM_FLTCR2_AWDCH_Msk (0xFFUL << DFSDM_FLTCR2_AWDCH_Pos) |
| #define | DFSDM_FLTCR2_AWDCH DFSDM_FLTCR2_AWDCH_Msk |
| #define | DFSDM_FLTCR2_EXCH_Pos (8U) |
| #define | DFSDM_FLTCR2_EXCH_Msk (0xFFUL << DFSDM_FLTCR2_EXCH_Pos) |
| #define | DFSDM_FLTCR2_EXCH DFSDM_FLTCR2_EXCH_Msk |
| #define | DFSDM_FLTCR2_CKABIE_Pos (6U) |
| #define | DFSDM_FLTCR2_CKABIE_Msk (0x1UL << DFSDM_FLTCR2_CKABIE_Pos) |
| #define | DFSDM_FLTCR2_CKABIE DFSDM_FLTCR2_CKABIE_Msk |
| #define | DFSDM_FLTCR2_SCDIE_Pos (5U) |
| #define | DFSDM_FLTCR2_SCDIE_Msk (0x1UL << DFSDM_FLTCR2_SCDIE_Pos) |
| #define | DFSDM_FLTCR2_SCDIE DFSDM_FLTCR2_SCDIE_Msk |
| #define | DFSDM_FLTCR2_AWDIE_Pos (4U) |
| #define | DFSDM_FLTCR2_AWDIE_Msk (0x1UL << DFSDM_FLTCR2_AWDIE_Pos) |
| #define | DFSDM_FLTCR2_AWDIE DFSDM_FLTCR2_AWDIE_Msk |
| #define | DFSDM_FLTCR2_ROVRIE_Pos (3U) |
| #define | DFSDM_FLTCR2_ROVRIE_Msk (0x1UL << DFSDM_FLTCR2_ROVRIE_Pos) |
| #define | DFSDM_FLTCR2_ROVRIE DFSDM_FLTCR2_ROVRIE_Msk |
| #define | DFSDM_FLTCR2_JOVRIE_Pos (2U) |
| #define | DFSDM_FLTCR2_JOVRIE_Msk (0x1UL << DFSDM_FLTCR2_JOVRIE_Pos) |
| #define | DFSDM_FLTCR2_JOVRIE DFSDM_FLTCR2_JOVRIE_Msk |
| #define | DFSDM_FLTCR2_REOCIE_Pos (1U) |
| #define | DFSDM_FLTCR2_REOCIE_Msk (0x1UL << DFSDM_FLTCR2_REOCIE_Pos) |
| #define | DFSDM_FLTCR2_REOCIE DFSDM_FLTCR2_REOCIE_Msk |
| #define | DFSDM_FLTCR2_JEOCIE_Pos (0U) |
| #define | DFSDM_FLTCR2_JEOCIE_Msk (0x1UL << DFSDM_FLTCR2_JEOCIE_Pos) |
| #define | DFSDM_FLTCR2_JEOCIE DFSDM_FLTCR2_JEOCIE_Msk |
| #define | DFSDM_FLTISR_SCDF_Pos (24U) |
| #define | DFSDM_FLTISR_SCDF_Msk (0xFFUL << DFSDM_FLTISR_SCDF_Pos) |
| #define | DFSDM_FLTISR_SCDF DFSDM_FLTISR_SCDF_Msk |
| #define | DFSDM_FLTISR_CKABF_Pos (16U) |
| #define | DFSDM_FLTISR_CKABF_Msk (0xFFUL << DFSDM_FLTISR_CKABF_Pos) |
| #define | DFSDM_FLTISR_CKABF DFSDM_FLTISR_CKABF_Msk |
| #define | DFSDM_FLTISR_RCIP_Pos (14U) |
| #define | DFSDM_FLTISR_RCIP_Msk (0x1UL << DFSDM_FLTISR_RCIP_Pos) |
| #define | DFSDM_FLTISR_RCIP DFSDM_FLTISR_RCIP_Msk |
| #define | DFSDM_FLTISR_JCIP_Pos (13U) |
| #define | DFSDM_FLTISR_JCIP_Msk (0x1UL << DFSDM_FLTISR_JCIP_Pos) |
| #define | DFSDM_FLTISR_JCIP DFSDM_FLTISR_JCIP_Msk |
| #define | DFSDM_FLTISR_AWDF_Pos (4U) |
| #define | DFSDM_FLTISR_AWDF_Msk (0x1UL << DFSDM_FLTISR_AWDF_Pos) |
| #define | DFSDM_FLTISR_AWDF DFSDM_FLTISR_AWDF_Msk |
| #define | DFSDM_FLTISR_ROVRF_Pos (3U) |
| #define | DFSDM_FLTISR_ROVRF_Msk (0x1UL << DFSDM_FLTISR_ROVRF_Pos) |
| #define | DFSDM_FLTISR_ROVRF DFSDM_FLTISR_ROVRF_Msk |
| #define | DFSDM_FLTISR_JOVRF_Pos (2U) |
| #define | DFSDM_FLTISR_JOVRF_Msk (0x1UL << DFSDM_FLTISR_JOVRF_Pos) |
| #define | DFSDM_FLTISR_JOVRF DFSDM_FLTISR_JOVRF_Msk |
| #define | DFSDM_FLTISR_REOCF_Pos (1U) |
| #define | DFSDM_FLTISR_REOCF_Msk (0x1UL << DFSDM_FLTISR_REOCF_Pos) |
| #define | DFSDM_FLTISR_REOCF DFSDM_FLTISR_REOCF_Msk |
| #define | DFSDM_FLTISR_JEOCF_Pos (0U) |
| #define | DFSDM_FLTISR_JEOCF_Msk (0x1UL << DFSDM_FLTISR_JEOCF_Pos) |
| #define | DFSDM_FLTISR_JEOCF DFSDM_FLTISR_JEOCF_Msk |
| #define | DFSDM_FLTICR_CLRSCDF_Pos (24U) |
| #define | DFSDM_FLTICR_CLRSCDF_Msk (0xFFUL << DFSDM_FLTICR_CLRSCDF_Pos) |
| #define | DFSDM_FLTICR_CLRSCDF DFSDM_FLTICR_CLRSCDF_Msk |
| #define | DFSDM_FLTICR_CLRCKABF_Pos (16U) |
| #define | DFSDM_FLTICR_CLRCKABF_Msk (0xFFUL << DFSDM_FLTICR_CLRCKABF_Pos) |
| #define | DFSDM_FLTICR_CLRCKABF DFSDM_FLTICR_CLRCKABF_Msk |
| #define | DFSDM_FLTICR_CLRROVRF_Pos (3U) |
| #define | DFSDM_FLTICR_CLRROVRF_Msk (0x1UL << DFSDM_FLTICR_CLRROVRF_Pos) |
| #define | DFSDM_FLTICR_CLRROVRF DFSDM_FLTICR_CLRROVRF_Msk |
| #define | DFSDM_FLTICR_CLRJOVRF_Pos (2U) |
| #define | DFSDM_FLTICR_CLRJOVRF_Msk (0x1UL << DFSDM_FLTICR_CLRJOVRF_Pos) |
| #define | DFSDM_FLTICR_CLRJOVRF DFSDM_FLTICR_CLRJOVRF_Msk |
| #define | DFSDM_FLTJCHGR_JCHG_Pos (0U) |
| #define | DFSDM_FLTJCHGR_JCHG_Msk (0xFFUL << DFSDM_FLTJCHGR_JCHG_Pos) |
| #define | DFSDM_FLTJCHGR_JCHG DFSDM_FLTJCHGR_JCHG_Msk |
| #define | DFSDM_FLTFCR_FORD_Pos (29U) |
| #define | DFSDM_FLTFCR_FORD_Msk (0x7UL << DFSDM_FLTFCR_FORD_Pos) |
| #define | DFSDM_FLTFCR_FORD DFSDM_FLTFCR_FORD_Msk |
| #define | DFSDM_FLTFCR_FORD_2 (0x4UL << DFSDM_FLTFCR_FORD_Pos) |
| #define | DFSDM_FLTFCR_FORD_1 (0x2UL << DFSDM_FLTFCR_FORD_Pos) |
| #define | DFSDM_FLTFCR_FORD_0 (0x1UL << DFSDM_FLTFCR_FORD_Pos) |
| #define | DFSDM_FLTFCR_FOSR_Pos (16U) |
| #define | DFSDM_FLTFCR_FOSR_Msk (0x3FFUL << DFSDM_FLTFCR_FOSR_Pos) |
| #define | DFSDM_FLTFCR_FOSR DFSDM_FLTFCR_FOSR_Msk |
| #define | DFSDM_FLTFCR_IOSR_Pos (0U) |
| #define | DFSDM_FLTFCR_IOSR_Msk (0xFFUL << DFSDM_FLTFCR_IOSR_Pos) |
| #define | DFSDM_FLTFCR_IOSR DFSDM_FLTFCR_IOSR_Msk |
| #define | DFSDM_FLTJDATAR_JDATA_Pos (8U) |
| #define | DFSDM_FLTJDATAR_JDATA_Msk (0xFFFFFFUL << DFSDM_FLTJDATAR_JDATA_Pos) |
| #define | DFSDM_FLTJDATAR_JDATA DFSDM_FLTJDATAR_JDATA_Msk |
| #define | DFSDM_FLTJDATAR_JDATACH_Pos (0U) |
| #define | DFSDM_FLTJDATAR_JDATACH_Msk (0x7UL << DFSDM_FLTJDATAR_JDATACH_Pos) |
| #define | DFSDM_FLTJDATAR_JDATACH DFSDM_FLTJDATAR_JDATACH_Msk |
| #define | DFSDM_FLTRDATAR_RDATA_Pos (8U) |
| #define | DFSDM_FLTRDATAR_RDATA_Msk (0xFFFFFFUL << DFSDM_FLTRDATAR_RDATA_Pos) |
| #define | DFSDM_FLTRDATAR_RDATA DFSDM_FLTRDATAR_RDATA_Msk |
| #define | DFSDM_FLTRDATAR_RPEND_Pos (4U) |
| #define | DFSDM_FLTRDATAR_RPEND_Msk (0x1UL << DFSDM_FLTRDATAR_RPEND_Pos) |
| #define | DFSDM_FLTRDATAR_RPEND DFSDM_FLTRDATAR_RPEND_Msk |
| #define | DFSDM_FLTRDATAR_RDATACH_Pos (0U) |
| #define | DFSDM_FLTRDATAR_RDATACH_Msk (0x7UL << DFSDM_FLTRDATAR_RDATACH_Pos) |
| #define | DFSDM_FLTRDATAR_RDATACH DFSDM_FLTRDATAR_RDATACH_Msk |
| #define | DFSDM_FLTAWHTR_AWHT_Pos (8U) |
| #define | DFSDM_FLTAWHTR_AWHT_Msk (0xFFFFFFUL << DFSDM_FLTAWHTR_AWHT_Pos) |
| #define | DFSDM_FLTAWHTR_AWHT DFSDM_FLTAWHTR_AWHT_Msk |
| #define | DFSDM_FLTAWHTR_BKAWH_Pos (0U) |
| #define | DFSDM_FLTAWHTR_BKAWH_Msk (0xFUL << DFSDM_FLTAWHTR_BKAWH_Pos) |
| #define | DFSDM_FLTAWHTR_BKAWH DFSDM_FLTAWHTR_BKAWH_Msk |
| #define | DFSDM_FLTAWLTR_AWLT_Pos (8U) |
| #define | DFSDM_FLTAWLTR_AWLT_Msk (0xFFFFFFUL << DFSDM_FLTAWLTR_AWLT_Pos) |
| #define | DFSDM_FLTAWLTR_AWLT DFSDM_FLTAWLTR_AWLT_Msk |
| #define | DFSDM_FLTAWLTR_BKAWL_Pos (0U) |
| #define | DFSDM_FLTAWLTR_BKAWL_Msk (0xFUL << DFSDM_FLTAWLTR_BKAWL_Pos) |
| #define | DFSDM_FLTAWLTR_BKAWL DFSDM_FLTAWLTR_BKAWL_Msk |
| #define | DFSDM_FLTAWSR_AWHTF_Pos (8U) |
| #define | DFSDM_FLTAWSR_AWHTF_Msk (0xFFUL << DFSDM_FLTAWSR_AWHTF_Pos) |
| #define | DFSDM_FLTAWSR_AWHTF DFSDM_FLTAWSR_AWHTF_Msk |
| #define | DFSDM_FLTAWSR_AWLTF_Pos (0U) |
| #define | DFSDM_FLTAWSR_AWLTF_Msk (0xFFUL << DFSDM_FLTAWSR_AWLTF_Pos) |
| #define | DFSDM_FLTAWSR_AWLTF DFSDM_FLTAWSR_AWLTF_Msk |
| #define | DFSDM_FLTAWCFR_CLRAWHTF_Pos (8U) |
| #define | DFSDM_FLTAWCFR_CLRAWHTF_Msk (0xFFUL << DFSDM_FLTAWCFR_CLRAWHTF_Pos) |
| #define | DFSDM_FLTAWCFR_CLRAWHTF DFSDM_FLTAWCFR_CLRAWHTF_Msk |
| #define | DFSDM_FLTAWCFR_CLRAWLTF_Pos (0U) |
| #define | DFSDM_FLTAWCFR_CLRAWLTF_Msk (0xFFUL << DFSDM_FLTAWCFR_CLRAWLTF_Pos) |
| #define | DFSDM_FLTAWCFR_CLRAWLTF DFSDM_FLTAWCFR_CLRAWLTF_Msk |
| #define | DFSDM_FLTEXMAX_EXMAX_Pos (8U) |
| #define | DFSDM_FLTEXMAX_EXMAX_Msk (0xFFFFFFUL << DFSDM_FLTEXMAX_EXMAX_Pos) |
| #define | DFSDM_FLTEXMAX_EXMAX DFSDM_FLTEXMAX_EXMAX_Msk |
| #define | DFSDM_FLTEXMAX_EXMAXCH_Pos (0U) |
| #define | DFSDM_FLTEXMAX_EXMAXCH_Msk (0x7UL << DFSDM_FLTEXMAX_EXMAXCH_Pos) |
| #define | DFSDM_FLTEXMAX_EXMAXCH DFSDM_FLTEXMAX_EXMAXCH_Msk |
| #define | DFSDM_FLTEXMIN_EXMIN_Pos (8U) |
| #define | DFSDM_FLTEXMIN_EXMIN_Msk (0xFFFFFFUL << DFSDM_FLTEXMIN_EXMIN_Pos) |
| #define | DFSDM_FLTEXMIN_EXMIN DFSDM_FLTEXMIN_EXMIN_Msk |
| #define | DFSDM_FLTEXMIN_EXMINCH_Pos (0U) |
| #define | DFSDM_FLTEXMIN_EXMINCH_Msk (0x7UL << DFSDM_FLTEXMIN_EXMINCH_Pos) |
| #define | DFSDM_FLTEXMIN_EXMINCH DFSDM_FLTEXMIN_EXMINCH_Msk |
| #define | DFSDM_FLTCNVTIMR_CNVCNT_Pos (4U) |
| #define | DFSDM_FLTCNVTIMR_CNVCNT_Msk (0xFFFFFFFUL << DFSDM_FLTCNVTIMR_CNVCNT_Pos) |
| #define | DFSDM_FLTCNVTIMR_CNVCNT DFSDM_FLTCNVTIMR_CNVCNT_Msk |
| #define | BDMA_ISR_GIF0_Pos (0U) |
| #define | BDMA_ISR_GIF0_Msk (0x1UL << BDMA_ISR_GIF0_Pos) |
| #define | BDMA_ISR_GIF0 BDMA_ISR_GIF0_Msk |
| #define | BDMA_ISR_TCIF0_Pos (1U) |
| #define | BDMA_ISR_TCIF0_Msk (0x1UL << BDMA_ISR_TCIF0_Pos) |
| #define | BDMA_ISR_TCIF0 BDMA_ISR_TCIF0_Msk |
| #define | BDMA_ISR_HTIF0_Pos (2U) |
| #define | BDMA_ISR_HTIF0_Msk (0x1UL << BDMA_ISR_HTIF0_Pos) |
| #define | BDMA_ISR_HTIF0 BDMA_ISR_HTIF0_Msk |
| #define | BDMA_ISR_TEIF0_Pos (3U) |
| #define | BDMA_ISR_TEIF0_Msk (0x1UL << BDMA_ISR_TEIF0_Pos) |
| #define | BDMA_ISR_TEIF0 BDMA_ISR_TEIF0_Msk |
| #define | BDMA_ISR_GIF1_Pos (4U) |
| #define | BDMA_ISR_GIF1_Msk (0x1UL << BDMA_ISR_GIF1_Pos) |
| #define | BDMA_ISR_GIF1 BDMA_ISR_GIF1_Msk |
| #define | BDMA_ISR_TCIF1_Pos (5U) |
| #define | BDMA_ISR_TCIF1_Msk (0x1UL << BDMA_ISR_TCIF1_Pos) |
| #define | BDMA_ISR_TCIF1 BDMA_ISR_TCIF1_Msk |
| #define | BDMA_ISR_HTIF1_Pos (6U) |
| #define | BDMA_ISR_HTIF1_Msk (0x1UL << BDMA_ISR_HTIF1_Pos) |
| #define | BDMA_ISR_HTIF1 BDMA_ISR_HTIF1_Msk |
| #define | BDMA_ISR_TEIF1_Pos (7U) |
| #define | BDMA_ISR_TEIF1_Msk (0x1UL << BDMA_ISR_TEIF1_Pos) |
| #define | BDMA_ISR_TEIF1 BDMA_ISR_TEIF1_Msk |
| #define | BDMA_ISR_GIF2_Pos (8U) |
| #define | BDMA_ISR_GIF2_Msk (0x1UL << BDMA_ISR_GIF2_Pos) |
| #define | BDMA_ISR_GIF2 BDMA_ISR_GIF2_Msk |
| #define | BDMA_ISR_TCIF2_Pos (9U) |
| #define | BDMA_ISR_TCIF2_Msk (0x1UL << BDMA_ISR_TCIF2_Pos) |
| #define | BDMA_ISR_TCIF2 BDMA_ISR_TCIF2_Msk |
| #define | BDMA_ISR_HTIF2_Pos (10U) |
| #define | BDMA_ISR_HTIF2_Msk (0x1UL << BDMA_ISR_HTIF2_Pos) |
| #define | BDMA_ISR_HTIF2 BDMA_ISR_HTIF2_Msk |
| #define | BDMA_ISR_TEIF2_Pos (11U) |
| #define | BDMA_ISR_TEIF2_Msk (0x1UL << BDMA_ISR_TEIF2_Pos) |
| #define | BDMA_ISR_TEIF2 BDMA_ISR_TEIF2_Msk |
| #define | BDMA_ISR_GIF3_Pos (12U) |
| #define | BDMA_ISR_GIF3_Msk (0x1UL << BDMA_ISR_GIF3_Pos) |
| #define | BDMA_ISR_GIF3 BDMA_ISR_GIF3_Msk |
| #define | BDMA_ISR_TCIF3_Pos (13U) |
| #define | BDMA_ISR_TCIF3_Msk (0x1UL << BDMA_ISR_TCIF3_Pos) |
| #define | BDMA_ISR_TCIF3 BDMA_ISR_TCIF3_Msk |
| #define | BDMA_ISR_HTIF3_Pos (14U) |
| #define | BDMA_ISR_HTIF3_Msk (0x1UL << BDMA_ISR_HTIF3_Pos) |
| #define | BDMA_ISR_HTIF3 BDMA_ISR_HTIF3_Msk |
| #define | BDMA_ISR_TEIF3_Pos (15U) |
| #define | BDMA_ISR_TEIF3_Msk (0x1UL << BDMA_ISR_TEIF3_Pos) |
| #define | BDMA_ISR_TEIF3 BDMA_ISR_TEIF3_Msk |
| #define | BDMA_ISR_GIF4_Pos (16U) |
| #define | BDMA_ISR_GIF4_Msk (0x1UL << BDMA_ISR_GIF4_Pos) |
| #define | BDMA_ISR_GIF4 BDMA_ISR_GIF4_Msk |
| #define | BDMA_ISR_TCIF4_Pos (17U) |
| #define | BDMA_ISR_TCIF4_Msk (0x1UL << BDMA_ISR_TCIF4_Pos) |
| #define | BDMA_ISR_TCIF4 BDMA_ISR_TCIF4_Msk |
| #define | BDMA_ISR_HTIF4_Pos (18U) |
| #define | BDMA_ISR_HTIF4_Msk (0x1UL << BDMA_ISR_HTIF4_Pos) |
| #define | BDMA_ISR_HTIF4 BDMA_ISR_HTIF4_Msk |
| #define | BDMA_ISR_TEIF4_Pos (19U) |
| #define | BDMA_ISR_TEIF4_Msk (0x1UL << BDMA_ISR_TEIF4_Pos) |
| #define | BDMA_ISR_TEIF4 BDMA_ISR_TEIF4_Msk |
| #define | BDMA_ISR_GIF5_Pos (20U) |
| #define | BDMA_ISR_GIF5_Msk (0x1UL << BDMA_ISR_GIF5_Pos) |
| #define | BDMA_ISR_GIF5 BDMA_ISR_GIF5_Msk |
| #define | BDMA_ISR_TCIF5_Pos (21U) |
| #define | BDMA_ISR_TCIF5_Msk (0x1UL << BDMA_ISR_TCIF5_Pos) |
| #define | BDMA_ISR_TCIF5 BDMA_ISR_TCIF5_Msk |
| #define | BDMA_ISR_HTIF5_Pos (22U) |
| #define | BDMA_ISR_HTIF5_Msk (0x1UL << BDMA_ISR_HTIF5_Pos) |
| #define | BDMA_ISR_HTIF5 BDMA_ISR_HTIF5_Msk |
| #define | BDMA_ISR_TEIF5_Pos (23U) |
| #define | BDMA_ISR_TEIF5_Msk (0x1UL << BDMA_ISR_TEIF5_Pos) |
| #define | BDMA_ISR_TEIF5 BDMA_ISR_TEIF5_Msk |
| #define | BDMA_ISR_GIF6_Pos (24U) |
| #define | BDMA_ISR_GIF6_Msk (0x1UL << BDMA_ISR_GIF6_Pos) |
| #define | BDMA_ISR_GIF6 BDMA_ISR_GIF6_Msk |
| #define | BDMA_ISR_TCIF6_Pos (25U) |
| #define | BDMA_ISR_TCIF6_Msk (0x1UL << BDMA_ISR_TCIF6_Pos) |
| #define | BDMA_ISR_TCIF6 BDMA_ISR_TCIF6_Msk |
| #define | BDMA_ISR_HTIF6_Pos (26U) |
| #define | BDMA_ISR_HTIF6_Msk (0x1UL << BDMA_ISR_HTIF6_Pos) |
| #define | BDMA_ISR_HTIF6 BDMA_ISR_HTIF6_Msk |
| #define | BDMA_ISR_TEIF6_Pos (27U) |
| #define | BDMA_ISR_TEIF6_Msk (0x1UL << BDMA_ISR_TEIF6_Pos) |
| #define | BDMA_ISR_TEIF6 BDMA_ISR_TEIF6_Msk |
| #define | BDMA_ISR_GIF7_Pos (28U) |
| #define | BDMA_ISR_GIF7_Msk (0x1UL << BDMA_ISR_GIF7_Pos) |
| #define | BDMA_ISR_GIF7 BDMA_ISR_GIF7_Msk |
| #define | BDMA_ISR_TCIF7_Pos (29U) |
| #define | BDMA_ISR_TCIF7_Msk (0x1UL << BDMA_ISR_TCIF7_Pos) |
| #define | BDMA_ISR_TCIF7 BDMA_ISR_TCIF7_Msk |
| #define | BDMA_ISR_HTIF7_Pos (30U) |
| #define | BDMA_ISR_HTIF7_Msk (0x1UL << BDMA_ISR_HTIF7_Pos) |
| #define | BDMA_ISR_HTIF7 BDMA_ISR_HTIF7_Msk |
| #define | BDMA_ISR_TEIF7_Pos (31U) |
| #define | BDMA_ISR_TEIF7_Msk (0x1UL << BDMA_ISR_TEIF7_Pos) |
| #define | BDMA_ISR_TEIF7 BDMA_ISR_TEIF7_Msk |
| #define | BDMA_IFCR_CGIF0_Pos (0U) |
| #define | BDMA_IFCR_CGIF0_Msk (0x1UL << BDMA_IFCR_CGIF0_Pos) |
| #define | BDMA_IFCR_CGIF0 BDMA_IFCR_CGIF0_Msk |
| #define | BDMA_IFCR_CTCIF0_Pos (1U) |
| #define | BDMA_IFCR_CTCIF0_Msk (0x1UL << BDMA_IFCR_CTCIF0_Pos) |
| #define | BDMA_IFCR_CTCIF0 BDMA_IFCR_CTCIF0_Msk |
| #define | BDMA_IFCR_CHTIF0_Pos (2U) |
| #define | BDMA_IFCR_CHTIF0_Msk (0x1UL << BDMA_IFCR_CHTIF0_Pos) |
| #define | BDMA_IFCR_CHTIF0 BDMA_IFCR_CHTIF0_Msk |
| #define | BDMA_IFCR_CTEIF0_Pos (3U) |
| #define | BDMA_IFCR_CTEIF0_Msk (0x1UL << BDMA_IFCR_CTEIF0_Pos) |
| #define | BDMA_IFCR_CTEIF0 BDMA_IFCR_CTEIF0_Msk |
| #define | BDMA_IFCR_CGIF1_Pos (4U) |
| #define | BDMA_IFCR_CGIF1_Msk (0x1UL << BDMA_IFCR_CGIF1_Pos) |
| #define | BDMA_IFCR_CGIF1 BDMA_IFCR_CGIF1_Msk |
| #define | BDMA_IFCR_CTCIF1_Pos (5U) |
| #define | BDMA_IFCR_CTCIF1_Msk (0x1UL << BDMA_IFCR_CTCIF1_Pos) |
| #define | BDMA_IFCR_CTCIF1 BDMA_IFCR_CTCIF1_Msk |
| #define | BDMA_IFCR_CHTIF1_Pos (6U) |
| #define | BDMA_IFCR_CHTIF1_Msk (0x1UL << BDMA_IFCR_CHTIF1_Pos) |
| #define | BDMA_IFCR_CHTIF1 BDMA_IFCR_CHTIF1_Msk |
| #define | BDMA_IFCR_CTEIF1_Pos (7U) |
| #define | BDMA_IFCR_CTEIF1_Msk (0x1UL << BDMA_IFCR_CTEIF1_Pos) |
| #define | BDMA_IFCR_CTEIF1 BDMA_IFCR_CTEIF1_Msk |
| #define | BDMA_IFCR_CGIF2_Pos (8U) |
| #define | BDMA_IFCR_CGIF2_Msk (0x1UL << BDMA_IFCR_CGIF2_Pos) |
| #define | BDMA_IFCR_CGIF2 BDMA_IFCR_CGIF2_Msk |
| #define | BDMA_IFCR_CTCIF2_Pos (9U) |
| #define | BDMA_IFCR_CTCIF2_Msk (0x1UL << BDMA_IFCR_CTCIF2_Pos) |
| #define | BDMA_IFCR_CTCIF2 BDMA_IFCR_CTCIF2_Msk |
| #define | BDMA_IFCR_CHTIF2_Pos (10U) |
| #define | BDMA_IFCR_CHTIF2_Msk (0x1UL << BDMA_IFCR_CHTIF2_Pos) |
| #define | BDMA_IFCR_CHTIF2 BDMA_IFCR_CHTIF2_Msk |
| #define | BDMA_IFCR_CTEIF2_Pos (11U) |
| #define | BDMA_IFCR_CTEIF2_Msk (0x1UL << BDMA_IFCR_CTEIF2_Pos) |
| #define | BDMA_IFCR_CTEIF2 BDMA_IFCR_CTEIF2_Msk |
| #define | BDMA_IFCR_CGIF3_Pos (12U) |
| #define | BDMA_IFCR_CGIF3_Msk (0x1UL << BDMA_IFCR_CGIF3_Pos) |
| #define | BDMA_IFCR_CGIF3 BDMA_IFCR_CGIF3_Msk |
| #define | BDMA_IFCR_CTCIF3_Pos (13U) |
| #define | BDMA_IFCR_CTCIF3_Msk (0x1UL << BDMA_IFCR_CTCIF3_Pos) |
| #define | BDMA_IFCR_CTCIF3 BDMA_IFCR_CTCIF3_Msk |
| #define | BDMA_IFCR_CHTIF3_Pos (14U) |
| #define | BDMA_IFCR_CHTIF3_Msk (0x1UL << BDMA_IFCR_CHTIF3_Pos) |
| #define | BDMA_IFCR_CHTIF3 BDMA_IFCR_CHTIF3_Msk |
| #define | BDMA_IFCR_CTEIF3_Pos (15U) |
| #define | BDMA_IFCR_CTEIF3_Msk (0x1UL << BDMA_IFCR_CTEIF3_Pos) |
| #define | BDMA_IFCR_CTEIF3 BDMA_IFCR_CTEIF3_Msk |
| #define | BDMA_IFCR_CGIF4_Pos (16U) |
| #define | BDMA_IFCR_CGIF4_Msk (0x1UL << BDMA_IFCR_CGIF4_Pos) |
| #define | BDMA_IFCR_CGIF4 BDMA_IFCR_CGIF4_Msk |
| #define | BDMA_IFCR_CTCIF4_Pos (17U) |
| #define | BDMA_IFCR_CTCIF4_Msk (0x1UL << BDMA_IFCR_CTCIF4_Pos) |
| #define | BDMA_IFCR_CTCIF4 BDMA_IFCR_CTCIF4_Msk |
| #define | BDMA_IFCR_CHTIF4_Pos (18U) |
| #define | BDMA_IFCR_CHTIF4_Msk (0x1UL << BDMA_IFCR_CHTIF4_Pos) |
| #define | BDMA_IFCR_CHTIF4 BDMA_IFCR_CHTIF4_Msk |
| #define | BDMA_IFCR_CTEIF4_Pos (19U) |
| #define | BDMA_IFCR_CTEIF4_Msk (0x1UL << BDMA_IFCR_CTEIF4_Pos) |
| #define | BDMA_IFCR_CTEIF4 BDMA_IFCR_CTEIF4_Msk |
| #define | BDMA_IFCR_CGIF5_Pos (20U) |
| #define | BDMA_IFCR_CGIF5_Msk (0x1UL << BDMA_IFCR_CGIF5_Pos) |
| #define | BDMA_IFCR_CGIF5 BDMA_IFCR_CGIF5_Msk |
| #define | BDMA_IFCR_CTCIF5_Pos (21U) |
| #define | BDMA_IFCR_CTCIF5_Msk (0x1UL << BDMA_IFCR_CTCIF5_Pos) |
| #define | BDMA_IFCR_CTCIF5 BDMA_IFCR_CTCIF5_Msk |
| #define | BDMA_IFCR_CHTIF5_Pos (22U) |
| #define | BDMA_IFCR_CHTIF5_Msk (0x1UL << BDMA_IFCR_CHTIF5_Pos) |
| #define | BDMA_IFCR_CHTIF5 BDMA_IFCR_CHTIF5_Msk |
| #define | BDMA_IFCR_CTEIF5_Pos (23U) |
| #define | BDMA_IFCR_CTEIF5_Msk (0x1UL << BDMA_IFCR_CTEIF5_Pos) |
| #define | BDMA_IFCR_CTEIF5 BDMA_IFCR_CTEIF5_Msk |
| #define | BDMA_IFCR_CGIF6_Pos (24U) |
| #define | BDMA_IFCR_CGIF6_Msk (0x1UL << BDMA_IFCR_CGIF6_Pos) |
| #define | BDMA_IFCR_CGIF6 BDMA_IFCR_CGIF6_Msk |
| #define | BDMA_IFCR_CTCIF6_Pos (25U) |
| #define | BDMA_IFCR_CTCIF6_Msk (0x1UL << BDMA_IFCR_CTCIF6_Pos) |
| #define | BDMA_IFCR_CTCIF6 BDMA_IFCR_CTCIF6_Msk |
| #define | BDMA_IFCR_CHTIF6_Pos (26U) |
| #define | BDMA_IFCR_CHTIF6_Msk (0x1UL << BDMA_IFCR_CHTIF6_Pos) |
| #define | BDMA_IFCR_CHTIF6 BDMA_IFCR_CHTIF6_Msk |
| #define | BDMA_IFCR_CTEIF6_Pos (27U) |
| #define | BDMA_IFCR_CTEIF6_Msk (0x1UL << BDMA_IFCR_CTEIF6_Pos) |
| #define | BDMA_IFCR_CTEIF6 BDMA_IFCR_CTEIF6_Msk |
| #define | BDMA_IFCR_CGIF7_Pos (28U) |
| #define | BDMA_IFCR_CGIF7_Msk (0x1UL << BDMA_IFCR_CGIF7_Pos) |
| #define | BDMA_IFCR_CGIF7 BDMA_IFCR_CGIF7_Msk |
| #define | BDMA_IFCR_CTCIF7_Pos (29U) |
| #define | BDMA_IFCR_CTCIF7_Msk (0x1UL << BDMA_IFCR_CTCIF7_Pos) |
| #define | BDMA_IFCR_CTCIF7 BDMA_IFCR_CTCIF7_Msk |
| #define | BDMA_IFCR_CHTIF7_Pos (30U) |
| #define | BDMA_IFCR_CHTIF7_Msk (0x1UL << BDMA_IFCR_CHTIF7_Pos) |
| #define | BDMA_IFCR_CHTIF7 BDMA_IFCR_CHTIF7_Msk |
| #define | BDMA_IFCR_CTEIF7_Pos (31U) |
| #define | BDMA_IFCR_CTEIF7_Msk (0x1UL << BDMA_IFCR_CTEIF7_Pos) |
| #define | BDMA_IFCR_CTEIF7 BDMA_IFCR_CTEIF7_Msk |
| #define | BDMA_CCR_EN_Pos (0U) |
| #define | BDMA_CCR_EN_Msk (0x1UL << BDMA_CCR_EN_Pos) |
| #define | BDMA_CCR_EN BDMA_CCR_EN_Msk |
| #define | BDMA_CCR_TCIE_Pos (1U) |
| #define | BDMA_CCR_TCIE_Msk (0x1UL << BDMA_CCR_TCIE_Pos) |
| #define | BDMA_CCR_TCIE BDMA_CCR_TCIE_Msk |
| #define | BDMA_CCR_HTIE_Pos (2U) |
| #define | BDMA_CCR_HTIE_Msk (0x1UL << BDMA_CCR_HTIE_Pos) |
| #define | BDMA_CCR_HTIE BDMA_CCR_HTIE_Msk |
| #define | BDMA_CCR_TEIE_Pos (3U) |
| #define | BDMA_CCR_TEIE_Msk (0x1UL << BDMA_CCR_TEIE_Pos) |
| #define | BDMA_CCR_TEIE BDMA_CCR_TEIE_Msk |
| #define | BDMA_CCR_DIR_Pos (4U) |
| #define | BDMA_CCR_DIR_Msk (0x1UL << BDMA_CCR_DIR_Pos) |
| #define | BDMA_CCR_DIR BDMA_CCR_DIR_Msk |
| #define | BDMA_CCR_CIRC_Pos (5U) |
| #define | BDMA_CCR_CIRC_Msk (0x1UL << BDMA_CCR_CIRC_Pos) |
| #define | BDMA_CCR_CIRC BDMA_CCR_CIRC_Msk |
| #define | BDMA_CCR_PINC_Pos (6U) |
| #define | BDMA_CCR_PINC_Msk (0x1UL << BDMA_CCR_PINC_Pos) |
| #define | BDMA_CCR_PINC BDMA_CCR_PINC_Msk |
| #define | BDMA_CCR_MINC_Pos (7U) |
| #define | BDMA_CCR_MINC_Msk (0x1UL << BDMA_CCR_MINC_Pos) |
| #define | BDMA_CCR_MINC BDMA_CCR_MINC_Msk |
| #define | BDMA_CCR_PSIZE_Pos (8U) |
| #define | BDMA_CCR_PSIZE_Msk (0x3UL << BDMA_CCR_PSIZE_Pos) |
| #define | BDMA_CCR_PSIZE BDMA_CCR_PSIZE_Msk |
| #define | BDMA_CCR_PSIZE_0 (0x1UL << BDMA_CCR_PSIZE_Pos) |
| #define | BDMA_CCR_PSIZE_1 (0x2UL << BDMA_CCR_PSIZE_Pos) |
| #define | BDMA_CCR_MSIZE_Pos (10U) |
| #define | BDMA_CCR_MSIZE_Msk (0x3UL << BDMA_CCR_MSIZE_Pos) |
| #define | BDMA_CCR_MSIZE BDMA_CCR_MSIZE_Msk |
| #define | BDMA_CCR_MSIZE_0 (0x1UL << BDMA_CCR_MSIZE_Pos) |
| #define | BDMA_CCR_MSIZE_1 (0x2UL << BDMA_CCR_MSIZE_Pos) |
| #define | BDMA_CCR_PL_Pos (12U) |
| #define | BDMA_CCR_PL_Msk (0x3UL << BDMA_CCR_PL_Pos) |
| #define | BDMA_CCR_PL BDMA_CCR_PL_Msk |
| #define | BDMA_CCR_PL_0 (0x1UL << BDMA_CCR_PL_Pos) |
| #define | BDMA_CCR_PL_1 (0x2UL << BDMA_CCR_PL_Pos) |
| #define | BDMA_CCR_MEM2MEM_Pos (14U) |
| #define | BDMA_CCR_MEM2MEM_Msk (0x1UL << BDMA_CCR_MEM2MEM_Pos) |
| #define | BDMA_CCR_MEM2MEM BDMA_CCR_MEM2MEM_Msk |
| #define | BDMA_CCR_DBM_Pos (15U) |
| #define | BDMA_CCR_DBM_Msk (0x1UL << BDMA_CCR_DBM_Pos) |
| #define | BDMA_CCR_DBM BDMA_CCR_DBM_Msk |
| #define | BDMA_CCR_CT_Pos (16U) |
| #define | BDMA_CCR_CT_Msk (0x1UL << BDMA_CCR_CT_Pos) |
| #define | BDMA_CCR_CT BDMA_CCR_CT_Msk |
| #define | BDMA_CNDTR_NDT_Pos (0U) |
| #define | BDMA_CNDTR_NDT_Msk (0xFFFFUL << BDMA_CNDTR_NDT_Pos) |
| #define | BDMA_CNDTR_NDT BDMA_CNDTR_NDT_Msk |
| #define | BDMA_CPAR_PA_Pos (0U) |
| #define | BDMA_CPAR_PA_Msk (0xFFFFFFFFUL << BDMA_CPAR_PA_Pos) |
| #define | BDMA_CPAR_PA BDMA_CPAR_PA_Msk |
| #define | BDMA_CM0AR_MA_Pos (0U) |
| #define | BDMA_CM0AR_MA_Msk (0xFFFFFFFFUL << BDMA_CM0AR_MA_Pos) |
| #define | BDMA_CM0AR_MA BDMA_CM0AR_MA_Msk |
| #define | BDMA_CM1AR_MA_Pos (0U) |
| #define | BDMA_CM1AR_MA_Msk (0xFFFFFFFFUL << BDMA_CM1AR_MA_Pos) |
| #define | BDMA_CM1AR_MA BDMA_CM1AR_MA_Msk |
| #define | ETH_MACCR_ARP_Pos (31U) |
| #define | ETH_MACCR_ARP_Msk (0x1UL << ETH_MACCR_ARP_Pos) |
| #define | ETH_MACCR_ARP ETH_MACCR_ARP_Msk /* ARP Offload Enable */ |
| #define | ETH_MACCR_SARC_Pos (28U) |
| #define | ETH_MACCR_SARC_Msk (0x7UL << ETH_MACCR_SARC_Pos) |
| #define | ETH_MACCR_SARC ETH_MACCR_SARC_Msk /* Source Address Insertion or Replacement Control */ |
| #define | ETH_MACCR_SARC_MTIATI (0U) /* The mti_sa_ctrl_i and ati_sa_ctrl_i input signals control the SA field generation. */ |
| #define | ETH_MACCR_SARC_INSADDR0_Pos (29U) |
| #define | ETH_MACCR_SARC_INSADDR0_Msk (0x1UL << ETH_MACCR_SARC_INSADDR0_Pos) |
| #define | ETH_MACCR_SARC_INSADDR0 ETH_MACCR_SARC_INSADDR0_Msk /* Insert MAC Address0 in the SA field of all transmitted packets. */ |
| #define | ETH_MACCR_SARC_INSADDR1_Pos (29U) |
| #define | ETH_MACCR_SARC_INSADDR1_Msk (0x3UL << ETH_MACCR_SARC_INSADDR1_Pos) |
| #define | ETH_MACCR_SARC_INSADDR1 ETH_MACCR_SARC_INSADDR1_Msk /* Insert MAC Address1 in the SA field of all transmitted packets. */ |
| #define | ETH_MACCR_SARC_REPADDR0_Pos (28U) |
| #define | ETH_MACCR_SARC_REPADDR0_Msk (0x3UL << ETH_MACCR_SARC_REPADDR0_Pos) |
| #define | ETH_MACCR_SARC_REPADDR0 ETH_MACCR_SARC_REPADDR0_Msk /* Replace MAC Address0 in the SA field of all transmitted packets. */ |
| #define | ETH_MACCR_SARC_REPADDR1_Pos (28U) |
| #define | ETH_MACCR_SARC_REPADDR1_Msk (0x7UL << ETH_MACCR_SARC_REPADDR1_Pos) |
| #define | ETH_MACCR_SARC_REPADDR1 ETH_MACCR_SARC_REPADDR1_Msk /* Replace MAC Address1 in the SA field of all transmitted packets. */ |
| #define | ETH_MACCR_IPC_Pos (27U) |
| #define | ETH_MACCR_IPC_Msk (0x1UL << ETH_MACCR_IPC_Pos) |
| #define | ETH_MACCR_IPC ETH_MACCR_IPC_Msk /* Checksum Offload */ |
| #define | ETH_MACCR_IPG_Pos (24U) |
| #define | ETH_MACCR_IPG_Msk (0x7UL << ETH_MACCR_IPG_Pos) |
| #define | ETH_MACCR_IPG ETH_MACCR_IPG_Msk /* Inter-Packet Gap */ |
| #define | ETH_MACCR_IPG_96BIT (0U) /* Minimum IFG between Packets during transmission is 96Bit */ |
| #define | ETH_MACCR_IPG_88BIT (0x01000000U) /* Minimum IFG between Packets during transmission is 88Bit */ |
| #define | ETH_MACCR_IPG_80BIT (0x02000000U) /* Minimum IFG between Packets during transmission is 80Bit */ |
| #define | ETH_MACCR_IPG_72BIT (0x03000000U) /* Minimum IFG between Packets during transmission is 72Bit */ |
| #define | ETH_MACCR_IPG_64BIT (0x04000000U) /* Minimum IFG between Packets during transmission is 64Bit */ |
| #define | ETH_MACCR_IPG_56BIT (0x05000000U) /* Minimum IFG between Packets during transmission is 56Bit */ |
| #define | ETH_MACCR_IPG_48BIT (0x06000000U) /* Minimum IFG between Packets during transmission is 48Bit */ |
| #define | ETH_MACCR_IPG_40BIT (0x07000000U) /* Minimum IFG between Packets during transmission is 40Bit */ |
| #define | ETH_MACCR_GPSLCE_Pos (23U) |
| #define | ETH_MACCR_GPSLCE_Msk (0x1UL << ETH_MACCR_GPSLCE_Pos) |
| #define | ETH_MACCR_GPSLCE ETH_MACCR_GPSLCE_Msk /* Giant Packet Size Limit Control Enable */ |
| #define | ETH_MACCR_S2KP_Pos (22U) |
| #define | ETH_MACCR_S2KP_Msk (0x1UL << ETH_MACCR_S2KP_Pos) |
| #define | ETH_MACCR_S2KP ETH_MACCR_S2KP_Msk /* IEEE 802.3as Support for 2K Packets */ |
| #define | ETH_MACCR_CST_Pos (21U) |
| #define | ETH_MACCR_CST_Msk (0x1UL << ETH_MACCR_CST_Pos) |
| #define | ETH_MACCR_CST ETH_MACCR_CST_Msk /* CRC stripping for Type packets */ |
| #define | ETH_MACCR_ACS_Pos (20U) |
| #define | ETH_MACCR_ACS_Msk (0x1UL << ETH_MACCR_ACS_Pos) |
| #define | ETH_MACCR_ACS ETH_MACCR_ACS_Msk /* Automatic Pad or CRC Stripping */ |
| #define | ETH_MACCR_WD_Pos (19U) |
| #define | ETH_MACCR_WD_Msk (0x1UL << ETH_MACCR_WD_Pos) |
| #define | ETH_MACCR_WD ETH_MACCR_WD_Msk /* Watchdog disable */ |
| #define | ETH_MACCR_JD_Pos (17U) |
| #define | ETH_MACCR_JD_Msk (0x1UL << ETH_MACCR_JD_Pos) |
| #define | ETH_MACCR_JD ETH_MACCR_JD_Msk /* Jabber disable */ |
| #define | ETH_MACCR_JE_Pos (16U) |
| #define | ETH_MACCR_JE_Msk (0x1UL << ETH_MACCR_JE_Pos) |
| #define | ETH_MACCR_JE ETH_MACCR_JE_Msk /* Jumbo Packet Enable */ |
| #define | ETH_MACCR_FES_Pos (14U) |
| #define | ETH_MACCR_FES_Msk (0x1UL << ETH_MACCR_FES_Pos) |
| #define | ETH_MACCR_FES ETH_MACCR_FES_Msk /* Fast ethernet speed */ |
| #define | ETH_MACCR_DM_Pos (13U) |
| #define | ETH_MACCR_DM_Msk (0x1UL << ETH_MACCR_DM_Pos) |
| #define | ETH_MACCR_DM ETH_MACCR_DM_Msk /* Duplex mode */ |
| #define | ETH_MACCR_LM_Pos (12U) |
| #define | ETH_MACCR_LM_Msk (0x1UL << ETH_MACCR_LM_Pos) |
| #define | ETH_MACCR_LM ETH_MACCR_LM_Msk /* loopback mode */ |
| #define | ETH_MACCR_ECRSFD_Pos (11U) |
| #define | ETH_MACCR_ECRSFD_Msk (0x1UL << ETH_MACCR_ECRSFD_Pos) |
| #define | ETH_MACCR_ECRSFD ETH_MACCR_ECRSFD_Msk /* Enable Carrier Sense Before Transmission in Full-Duplex Mode */ |
| #define | ETH_MACCR_DO_Pos (10U) |
| #define | ETH_MACCR_DO_Msk (0x1UL << ETH_MACCR_DO_Pos) |
| #define | ETH_MACCR_DO ETH_MACCR_DO_Msk /* Disable Receive own */ |
| #define | ETH_MACCR_DCRS_Pos (9U) |
| #define | ETH_MACCR_DCRS_Msk (0x1UL << ETH_MACCR_DCRS_Pos) |
| #define | ETH_MACCR_DCRS ETH_MACCR_DCRS_Msk /* Disable Carrier Sense During Transmission */ |
| #define | ETH_MACCR_DR_Pos (8U) |
| #define | ETH_MACCR_DR_Msk (0x1UL << ETH_MACCR_DR_Pos) |
| #define | ETH_MACCR_DR ETH_MACCR_DR_Msk /* Disable Retry */ |
| #define | ETH_MACCR_BL_Pos (5U) |
| #define | ETH_MACCR_BL_Msk (0x3UL << ETH_MACCR_BL_Pos) |
| #define | ETH_MACCR_BL ETH_MACCR_BL_Msk /* Back-off limit mask */ |
| #define | ETH_MACCR_BL_10 (0x0UL << ETH_MACCR_BL_Pos) |
| #define | ETH_MACCR_BL_8 (0x1UL << ETH_MACCR_BL_Pos) |
| #define | ETH_MACCR_BL_4 (0x2UL << ETH_MACCR_BL_Pos) |
| #define | ETH_MACCR_BL_1 (0x3UL << ETH_MACCR_BL_Pos) |
| #define | ETH_MACCR_DC_Pos (4U) |
| #define | ETH_MACCR_DC_Msk (0x1UL << ETH_MACCR_DC_Pos) |
| #define | ETH_MACCR_DC ETH_MACCR_DC_Msk /* Defferal check */ |
| #define | ETH_MACCR_PRELEN_Pos (2U) |
| #define | ETH_MACCR_PRELEN_Msk (0x3UL << ETH_MACCR_PRELEN_Pos) |
| #define | ETH_MACCR_PRELEN ETH_MACCR_PRELEN_Msk /* Preamble Length for Transmit packets */ |
| #define | ETH_MACCR_PRELEN_7 (0x0UL << ETH_MACCR_PRELEN_Pos) |
| #define | ETH_MACCR_PRELEN_5 (0x1UL << ETH_MACCR_PRELEN_Pos) |
| #define | ETH_MACCR_PRELEN_3 (0x2UL << ETH_MACCR_PRELEN_Pos) |
| #define | ETH_MACCR_TE_Pos (1U) |
| #define | ETH_MACCR_TE_Msk (0x1UL << ETH_MACCR_TE_Pos) |
| #define | ETH_MACCR_TE ETH_MACCR_TE_Msk /* Transmitter enable */ |
| #define | ETH_MACCR_RE_Pos (0U) |
| #define | ETH_MACCR_RE_Msk (0x1UL << ETH_MACCR_RE_Pos) |
| #define | ETH_MACCR_RE ETH_MACCR_RE_Msk /* Receiver enable */ |
| #define | ETH_MACECR_EIPG_Pos (25U) |
| #define | ETH_MACECR_EIPG_Msk (0x1FUL << ETH_MACECR_EIPG_Pos) |
| #define | ETH_MACECR_EIPG ETH_MACECR_EIPG_Msk /* Extended Inter-Packet Gap */ |
| #define | ETH_MACECR_EIPGEN_Pos (24U) |
| #define | ETH_MACECR_EIPGEN_Msk (0x1UL << ETH_MACECR_EIPGEN_Pos) |
| #define | ETH_MACECR_EIPGEN ETH_MACECR_EIPGEN_Msk /* Extended Inter-Packet Gap Enable */ |
| #define | ETH_MACECR_USP_Pos (18U) |
| #define | ETH_MACECR_USP_Msk (0x1UL << ETH_MACECR_USP_Pos) |
| #define | ETH_MACECR_USP ETH_MACECR_USP_Msk /* Unicast Slow Protocol Packet Detect */ |
| #define | ETH_MACECR_SPEN_Pos (17U) |
| #define | ETH_MACECR_SPEN_Msk (0x1UL << ETH_MACECR_SPEN_Pos) |
| #define | ETH_MACECR_SPEN ETH_MACECR_SPEN_Msk /* Slow Protocol Detection Enable */ |
| #define | ETH_MACECR_DCRCC_Pos (16U) |
| #define | ETH_MACECR_DCRCC_Msk (0x1UL << ETH_MACECR_DCRCC_Pos) |
| #define | ETH_MACECR_DCRCC ETH_MACECR_DCRCC_Msk /* Disable CRC Checking for Received Packets */ |
| #define | ETH_MACECR_GPSL_Pos (0U) |
| #define | ETH_MACECR_GPSL_Msk (0x3FFFUL << ETH_MACECR_GPSL_Pos) |
| #define | ETH_MACECR_GPSL ETH_MACECR_GPSL_Msk /* Giant Packet Size Limit */ |
| #define | ETH_MACPFR_RA_Pos (31U) |
| #define | ETH_MACPFR_RA_Msk (0x1UL << ETH_MACPFR_RA_Pos) |
| #define | ETH_MACPFR_RA ETH_MACPFR_RA_Msk /* Receive all */ |
| #define | ETH_MACPFR_DNTU_Pos (21U) |
| #define | ETH_MACPFR_DNTU_Msk (0x1UL << ETH_MACPFR_DNTU_Pos) |
| #define | ETH_MACPFR_DNTU ETH_MACPFR_DNTU_Msk /* Drop Non-TCP/UDP over IP Packets */ |
| #define | ETH_MACPFR_IPFE_Pos (20U) |
| #define | ETH_MACPFR_IPFE_Msk (0x1UL << ETH_MACPFR_IPFE_Pos) |
| #define | ETH_MACPFR_IPFE ETH_MACPFR_IPFE_Msk /* Layer 3 and Layer 4 Filter Enable */ |
| #define | ETH_MACPFR_VTFE_Pos (16U) |
| #define | ETH_MACPFR_VTFE_Msk (0x1UL << ETH_MACPFR_VTFE_Pos) |
| #define | ETH_MACPFR_VTFE ETH_MACPFR_VTFE_Msk /* VLAN Tag Filter Enable */ |
| #define | ETH_MACPFR_HPF_Pos (10U) |
| #define | ETH_MACPFR_HPF_Msk (0x1UL << ETH_MACPFR_HPF_Pos) |
| #define | ETH_MACPFR_HPF ETH_MACPFR_HPF_Msk /* Hash or perfect filter */ |
| #define | ETH_MACPFR_SAF_Pos (9U) |
| #define | ETH_MACPFR_SAF_Msk (0x1UL << ETH_MACPFR_SAF_Pos) |
| #define | ETH_MACPFR_SAF ETH_MACPFR_SAF_Msk /* Source address filter enable */ |
| #define | ETH_MACPFR_SAIF_Pos (8U) |
| #define | ETH_MACPFR_SAIF_Msk (0x1UL << ETH_MACPFR_SAIF_Pos) |
| #define | ETH_MACPFR_SAIF ETH_MACPFR_SAIF_Msk /* SA inverse filtering */ |
| #define | ETH_MACPFR_PCF_Pos (6U) |
| #define | ETH_MACPFR_PCF_Msk (0x3UL << ETH_MACPFR_PCF_Pos) |
| #define | ETH_MACPFR_PCF ETH_MACPFR_PCF_Msk /* Pass control frames: 4 cases */ |
| #define | ETH_MACPFR_PCF_BLOCKALL (0U) /* MAC filters all control frames from reaching the application */ |
| #define | ETH_MACPFR_PCF_FORWARDALLEXCEPTPA_Pos (6U) |
| #define | ETH_MACPFR_PCF_FORWARDALLEXCEPTPA_Msk (0x1UL << ETH_MACPFR_PCF_FORWARDALLEXCEPTPA_Pos) |
| #define | ETH_MACPFR_PCF_FORWARDALLEXCEPTPA ETH_MACPFR_PCF_FORWARDALLEXCEPTPA_Msk /* MAC forwards all control frames except Pause packets to application even if they fail the Address Filter */ |
| #define | ETH_MACPFR_PCF_FORWARDALL_Pos (7U) |
| #define | ETH_MACPFR_PCF_FORWARDALL_Msk (0x1UL << ETH_MACPFR_PCF_FORWARDALL_Pos) |
| #define | ETH_MACPFR_PCF_FORWARDALL ETH_MACPFR_PCF_FORWARDALL_Msk /* MAC forwards all control frames to application even if they fail the Address Filter */ |
| #define | ETH_MACPFR_PCF_FORWARDPASSEDADDRFILTER_Pos (6U) |
| #define | ETH_MACPFR_PCF_FORWARDPASSEDADDRFILTER_Msk (0x3UL << ETH_MACPFR_PCF_FORWARDPASSEDADDRFILTER_Pos) |
| #define | ETH_MACPFR_PCF_FORWARDPASSEDADDRFILTER ETH_MACPFR_PCF_FORWARDPASSEDADDRFILTER_Msk /* MAC forwards control frames that pass the Address Filter. */ |
| #define | ETH_MACPFR_DBF_Pos (5U) |
| #define | ETH_MACPFR_DBF_Msk (0x1UL << ETH_MACPFR_DBF_Pos) |
| #define | ETH_MACPFR_DBF ETH_MACPFR_DBF_Msk /* Disable Broadcast Packets */ |
| #define | ETH_MACPFR_PM_Pos (4U) |
| #define | ETH_MACPFR_PM_Msk (0x1UL << ETH_MACPFR_PM_Pos) |
| #define | ETH_MACPFR_PM ETH_MACPFR_PM_Msk /* Pass all mutlicast */ |
| #define | ETH_MACPFR_DAIF_Pos (3U) |
| #define | ETH_MACPFR_DAIF_Msk (0x1UL << ETH_MACPFR_DAIF_Pos) |
| #define | ETH_MACPFR_DAIF ETH_MACPFR_DAIF_Msk /* DA Inverse filtering */ |
| #define | ETH_MACPFR_HMC_Pos (2U) |
| #define | ETH_MACPFR_HMC_Msk (0x1UL << ETH_MACPFR_HMC_Pos) |
| #define | ETH_MACPFR_HMC ETH_MACPFR_HMC_Msk /* Hash multicast */ |
| #define | ETH_MACPFR_HUC_Pos (1U) |
| #define | ETH_MACPFR_HUC_Msk (0x1UL << ETH_MACPFR_HUC_Pos) |
| #define | ETH_MACPFR_HUC ETH_MACPFR_HUC_Msk /* Hash unicast */ |
| #define | ETH_MACPFR_PR_Pos (0U) |
| #define | ETH_MACPFR_PR_Msk (0x1UL << ETH_MACPFR_PR_Pos) |
| #define | ETH_MACPFR_PR ETH_MACPFR_PR_Msk /* Promiscuous mode */ |
| #define | ETH_MACWTR_PWE_Pos (8U) |
| #define | ETH_MACWTR_PWE_Msk (0x1UL << ETH_MACWTR_PWE_Pos) |
| #define | ETH_MACWTR_PWE ETH_MACWTR_PWE_Msk /* Programmable Watchdog Enable */ |
| #define | ETH_MACWTR_WTO_Pos (0U) |
| #define | ETH_MACWTR_WTO_Msk (0xFUL << ETH_MACWTR_WTO_Pos) |
| #define | ETH_MACWTR_WTO ETH_MACWTR_WTO_Msk /* Watchdog Timeout */ |
| #define | ETH_MACWTR_WTO_2KB (0U) /* Maximum received packet length 2KB*/ |
| #define | ETH_MACWTR_WTO_3KB (0x00000001U) /* Maximum received packet length 3KB */ |
| #define | ETH_MACWTR_WTO_4KB (0x00000002U) /* Maximum received packet length 4KB */ |
| #define | ETH_MACWTR_WTO_5KB (0x00000003U) /* Maximum received packet length 5KB */ |
| #define | ETH_MACWTR_WTO_6KB (0x00000004U) /* Maximum received packet length 6KB */ |
| #define | ETH_MACWTR_WTO_7KB (0x00000005U) /* Maximum received packet length 7KB */ |
| #define | ETH_MACWTR_WTO_8KB (0x00000006U) /* Maximum received packet length 8KB */ |
| #define | ETH_MACWTR_WTO_9KB (0x00000007U) /* Maximum received packet length 9KB */ |
| #define | ETH_MACWTR_WTO_10KB (0x00000008U) /* Maximum received packet length 10KB */ |
| #define | ETH_MACWTR_WTO_11KB (0x00000009U) /* Maximum received packet length 11KB */ |
| #define | ETH_MACWTR_WTO_12KB (0x0000000AU) /* Maximum received packet length 12KB */ |
| #define | ETH_MACWTR_WTO_13KB (0x0000000BU) /* Maximum received packet length 13KB */ |
| #define | ETH_MACWTR_WTO_14KB (0x0000000CU) /* Maximum received packet length 14KB */ |
| #define | ETH_MACWTR_WTO_15KB (0x0000000DU) /* Maximum received packet length 15KB */ |
| #define | ETH_MACWTR_WTO_16KB (0x0000000EU) /* Maximum received packet length 16KB */ |
| #define | ETH_MACHTHR_HTH_Pos (0U) |
| #define | ETH_MACHTHR_HTH_Msk (0xFFFFFFFFUL << ETH_MACHTHR_HTH_Pos) |
| #define | ETH_MACHTHR_HTH ETH_MACHTHR_HTH_Msk /* Hash table high */ |
| #define | ETH_MACHTLR_HTL_Pos (0U) |
| #define | ETH_MACHTLR_HTL_Msk (0xFFFFFFFFUL << ETH_MACHTLR_HTL_Pos) |
| #define | ETH_MACHTLR_HTL ETH_MACHTLR_HTL_Msk /* Hash table low */ |
| #define | ETH_MACVTR_EIVLRXS_Pos (31U) |
| #define | ETH_MACVTR_EIVLRXS_Msk (0x1UL << ETH_MACVTR_EIVLRXS_Pos) |
| #define | ETH_MACVTR_EIVLRXS ETH_MACVTR_EIVLRXS_Msk /* Enable Inner VLAN Tag in Rx Status */ |
| #define | ETH_MACVTR_EIVLS_Pos (28U) |
| #define | ETH_MACVTR_EIVLS_Msk (0x3UL << ETH_MACVTR_EIVLS_Pos) |
| #define | ETH_MACVTR_EIVLS ETH_MACVTR_EIVLS_Msk /* Enable Inner VLAN Tag Stripping on Receive */ |
| #define | ETH_MACVTR_EIVLS_DONOTSTRIP (0U) /* Do not strip */ |
| #define | ETH_MACVTR_EIVLS_STRIPIFPASS_Pos (28U) |
| #define | ETH_MACVTR_EIVLS_STRIPIFPASS_Msk (0x1UL << ETH_MACVTR_EIVLS_STRIPIFPASS_Pos) |
| #define | ETH_MACVTR_EIVLS_STRIPIFPASS ETH_MACVTR_EIVLS_STRIPIFPASS_Msk /* Strip if VLAN filter passes */ |
| #define | ETH_MACVTR_EIVLS_STRIPIFFAILS_Pos (29U) |
| #define | ETH_MACVTR_EIVLS_STRIPIFFAILS_Msk (0x1UL << ETH_MACVTR_EIVLS_STRIPIFFAILS_Pos) |
| #define | ETH_MACVTR_EIVLS_STRIPIFFAILS ETH_MACVTR_EIVLS_STRIPIFFAILS_Msk /* Strip if VLAN filter fails */ |
| #define | ETH_MACVTR_EIVLS_ALWAYSSTRIP_Pos (28U) |
| #define | ETH_MACVTR_EIVLS_ALWAYSSTRIP_Msk (0x3UL << ETH_MACVTR_EIVLS_ALWAYSSTRIP_Pos) |
| #define | ETH_MACVTR_EIVLS_ALWAYSSTRIP ETH_MACVTR_EIVLS_ALWAYSSTRIP_Msk /* Always strip */ |
| #define | ETH_MACVTR_ERIVLT_Pos (27U) |
| #define | ETH_MACVTR_ERIVLT_Msk (0x1UL << ETH_MACVTR_ERIVLT_Pos) |
| #define | ETH_MACVTR_ERIVLT ETH_MACVTR_ERIVLT_Msk /* Enable Inner VLAN Tag */ |
| #define | ETH_MACVTR_EDVLP_Pos (26U) |
| #define | ETH_MACVTR_EDVLP_Msk (0x1UL << ETH_MACVTR_EDVLP_Pos) |
| #define | ETH_MACVTR_EDVLP ETH_MACVTR_EDVLP_Msk /* Enable Double VLAN Processing */ |
| #define | ETH_MACVTR_VTHM_Pos (25U) |
| #define | ETH_MACVTR_VTHM_Msk (0x1UL << ETH_MACVTR_VTHM_Pos) |
| #define | ETH_MACVTR_VTHM ETH_MACVTR_VTHM_Msk /* VLAN Tag Hash Table Match Enable */ |
| #define | ETH_MACVTR_EVLRXS_Pos (24U) |
| #define | ETH_MACVTR_EVLRXS_Msk (0x1UL << ETH_MACVTR_EVLRXS_Pos) |
| #define | ETH_MACVTR_EVLRXS ETH_MACVTR_EVLRXS_Msk /* Enable VLAN Tag in Rx status */ |
| #define | ETH_MACVTR_EVLS_Pos (21U) |
| #define | ETH_MACVTR_EVLS_Msk (0x3UL << ETH_MACVTR_EVLS_Pos) |
| #define | ETH_MACVTR_EVLS ETH_MACVTR_EVLS_Msk /* Enable VLAN Tag Stripping on Receive */ |
| #define | ETH_MACVTR_EVLS_DONOTSTRIP (0U) /* Do not strip */ |
| #define | ETH_MACVTR_EVLS_STRIPIFPASS_Pos (21U) |
| #define | ETH_MACVTR_EVLS_STRIPIFPASS_Msk (0x1UL << ETH_MACVTR_EVLS_STRIPIFPASS_Pos) |
| #define | ETH_MACVTR_EVLS_STRIPIFPASS ETH_MACVTR_EVLS_STRIPIFPASS_Msk /* Strip if VLAN filter passes */ |
| #define | ETH_MACVTR_EVLS_STRIPIFFAILS_Pos (22U) |
| #define | ETH_MACVTR_EVLS_STRIPIFFAILS_Msk (0x1UL << ETH_MACVTR_EVLS_STRIPIFFAILS_Pos) |
| #define | ETH_MACVTR_EVLS_STRIPIFFAILS ETH_MACVTR_EVLS_STRIPIFFAILS_Msk /* Strip if VLAN filter fails */ |
| #define | ETH_MACVTR_EVLS_ALWAYSSTRIP_Pos (21U) |
| #define | ETH_MACVTR_EVLS_ALWAYSSTRIP_Msk (0x3UL << ETH_MACVTR_EVLS_ALWAYSSTRIP_Pos) |
| #define | ETH_MACVTR_EVLS_ALWAYSSTRIP ETH_MACVTR_EVLS_ALWAYSSTRIP_Msk /* Always strip */ |
| #define | ETH_MACVTR_DOVLTC_Pos (20U) |
| #define | ETH_MACVTR_DOVLTC_Msk (0x1UL << ETH_MACVTR_DOVLTC_Pos) |
| #define | ETH_MACVTR_DOVLTC ETH_MACVTR_DOVLTC_Msk /* Disable VLAN Type Check */ |
| #define | ETH_MACVTR_ERSVLM_Pos (19U) |
| #define | ETH_MACVTR_ERSVLM_Msk (0x1UL << ETH_MACVTR_ERSVLM_Pos) |
| #define | ETH_MACVTR_ERSVLM ETH_MACVTR_ERSVLM_Msk /* Enable Receive S-VLAN Match */ |
| #define | ETH_MACVTR_ESVL_Pos (18U) |
| #define | ETH_MACVTR_ESVL_Msk (0x1UL << ETH_MACVTR_ESVL_Pos) |
| #define | ETH_MACVTR_ESVL ETH_MACVTR_ESVL_Msk /* Enable S-VLAN */ |
| #define | ETH_MACVTR_VTIM_Pos (17U) |
| #define | ETH_MACVTR_VTIM_Msk (0x1UL << ETH_MACVTR_VTIM_Pos) |
| #define | ETH_MACVTR_VTIM ETH_MACVTR_VTIM_Msk /* VLAN Tag Inverse Match Enable */ |
| #define | ETH_MACVTR_ETV_Pos (16U) |
| #define | ETH_MACVTR_ETV_Msk (0x1UL << ETH_MACVTR_ETV_Pos) |
| #define | ETH_MACVTR_ETV ETH_MACVTR_ETV_Msk /* Enable 12-Bit VLAN Tag Comparison */ |
| #define | ETH_MACVTR_VL_Pos (0U) |
| #define | ETH_MACVTR_VL_Msk (0xFFFFUL << ETH_MACVTR_VL_Pos) |
| #define | ETH_MACVTR_VL ETH_MACVTR_VL_Msk /* VLAN Tag Identifier for Receive Packets */ |
| #define | ETH_MACVTR_VL_UP_Pos (13U) |
| #define | ETH_MACVTR_VL_UP_Msk (0x7UL << ETH_MACVTR_VL_UP_Pos) |
| #define | ETH_MACVTR_VL_UP ETH_MACVTR_VL_UP_Msk /* User Priority */ |
| #define | ETH_MACVTR_VL_CFIDEI_Pos (12U) |
| #define | ETH_MACVTR_VL_CFIDEI_Msk (0x1UL << ETH_MACVTR_VL_CFIDEI_Pos) |
| #define | ETH_MACVTR_VL_CFIDEI ETH_MACVTR_VL_CFIDEI_Msk /* Canonical Format Indicator or Drop Eligible Indicator */ |
| #define | ETH_MACVTR_VL_VID_Pos (0U) |
| #define | ETH_MACVTR_VL_VID_Msk (0xFFFUL << ETH_MACVTR_VL_VID_Pos) |
| #define | ETH_MACVTR_VL_VID ETH_MACVTR_VL_VID_Msk /* VLAN Identifier field of VLAN tag */ |
| #define | ETH_MACVHTR_VLHT_Pos (0U) |
| #define | ETH_MACVHTR_VLHT_Msk (0xFFFFUL << ETH_MACVHTR_VLHT_Pos) |
| #define | ETH_MACVHTR_VLHT ETH_MACVHTR_VLHT_Msk /* VLAN Hash Table */ |
| #define | ETH_MACVIR_VLTI_Pos (20U) |
| #define | ETH_MACVIR_VLTI_Msk (0x1UL << ETH_MACVIR_VLTI_Pos) |
| #define | ETH_MACVIR_VLTI ETH_MACVIR_VLTI_Msk /* VLAN Tag Input */ |
| #define | ETH_MACVIR_CSVL_Pos (19U) |
| #define | ETH_MACVIR_CSVL_Msk (0x1UL << ETH_MACVIR_CSVL_Pos) |
| #define | ETH_MACVIR_CSVL ETH_MACVIR_CSVL_Msk /* C-VLAN or S-VLAN */ |
| #define | ETH_MACVIR_VLP_Pos (18U) |
| #define | ETH_MACVIR_VLP_Msk (0x1UL << ETH_MACVIR_VLP_Pos) |
| #define | ETH_MACVIR_VLP ETH_MACVIR_VLP_Msk /* VLAN Priority Control */ |
| #define | ETH_MACVIR_VLC_Pos (16U) |
| #define | ETH_MACVIR_VLC_Msk (0x3UL << ETH_MACVIR_VLC_Pos) |
| #define | ETH_MACVIR_VLC ETH_MACVIR_VLC_Msk /* VLAN Tag Control in Transmit Packets */ |
| #define | ETH_MACVIR_VLC_NOVLANTAG (0U) /* No VLAN tag deletion, insertion, or replacement */ |
| #define | ETH_MACVIR_VLC_VLANTAGDELETE_Pos (16U) |
| #define | ETH_MACVIR_VLC_VLANTAGDELETE_Msk (0x1UL << ETH_MACVIR_VLC_VLANTAGDELETE_Pos) |
| #define | ETH_MACVIR_VLC_VLANTAGDELETE ETH_MACVIR_VLC_VLANTAGDELETE_Msk /* VLAN tag deletion */ |
| #define | ETH_MACVIR_VLC_VLANTAGINSERT_Pos (17U) |
| #define | ETH_MACVIR_VLC_VLANTAGINSERT_Msk (0x1UL << ETH_MACVIR_VLC_VLANTAGINSERT_Pos) |
| #define | ETH_MACVIR_VLC_VLANTAGINSERT ETH_MACVIR_VLC_VLANTAGINSERT_Msk /* VLAN tag insertion */ |
| #define | ETH_MACVIR_VLC_VLANTAGREPLACE_Pos (16U) |
| #define | ETH_MACVIR_VLC_VLANTAGREPLACE_Msk (0x3UL << ETH_MACVIR_VLC_VLANTAGREPLACE_Pos) |
| #define | ETH_MACVIR_VLC_VLANTAGREPLACE ETH_MACVIR_VLC_VLANTAGREPLACE_Msk /* VLAN tag replacement */ |
| #define | ETH_MACVIR_VLT_Pos (0U) |
| #define | ETH_MACVIR_VLT_Msk (0xFFFFUL << ETH_MACVIR_VLT_Pos) |
| #define | ETH_MACVIR_VLT ETH_MACVIR_VLT_Msk /* VLAN Tag for Transmit Packets */ |
| #define | ETH_MACVIR_VLT_UP_Pos (13U) |
| #define | ETH_MACVIR_VLT_UP_Msk (0x7UL << ETH_MACVIR_VLT_UP_Pos) |
| #define | ETH_MACVIR_VLT_UP ETH_MACVIR_VLT_UP_Msk /* User Priority */ |
| #define | ETH_MACVIR_VLT_CFIDEI_Pos (12U) |
| #define | ETH_MACVIR_VLT_CFIDEI_Msk (0x1UL << ETH_MACVIR_VLT_CFIDEI_Pos) |
| #define | ETH_MACVIR_VLT_CFIDEI ETH_MACVIR_VLT_CFIDEI_Msk /* Canonical Format Indicator or Drop Eligible Indicator */ |
| #define | ETH_MACVIR_VLT_VID_Pos (0U) |
| #define | ETH_MACVIR_VLT_VID_Msk (0xFFFUL << ETH_MACVIR_VLT_VID_Pos) |
| #define | ETH_MACVIR_VLT_VID ETH_MACVIR_VLT_VID_Msk /* VLAN Identifier field of VLAN tag */ |
| #define | ETH_MACIVIR_VLTI_Pos (20U) |
| #define | ETH_MACIVIR_VLTI_Msk (0x1UL << ETH_MACIVIR_VLTI_Pos) |
| #define | ETH_MACIVIR_VLTI ETH_MACIVIR_VLTI_Msk /* VLAN Tag Input */ |
| #define | ETH_MACIVIR_CSVL_Pos (19U) |
| #define | ETH_MACIVIR_CSVL_Msk (0x1UL << ETH_MACIVIR_CSVL_Pos) |
| #define | ETH_MACIVIR_CSVL ETH_MACIVIR_CSVL_Msk /* C-VLAN or S-VLAN */ |
| #define | ETH_MACIVIR_VLP_Pos (18U) |
| #define | ETH_MACIVIR_VLP_Msk (0x1UL << ETH_MACIVIR_VLP_Pos) |
| #define | ETH_MACIVIR_VLP ETH_MACIVIR_VLP_Msk /* VLAN Priority Control */ |
| #define | ETH_MACIVIR_VLC_Pos (16U) |
| #define | ETH_MACIVIR_VLC_Msk (0x3UL << ETH_MACIVIR_VLC_Pos) |
| #define | ETH_MACIVIR_VLC ETH_MACIVIR_VLC_Msk /* VLAN Tag Control in Transmit Packets */ |
| #define | ETH_MACIVIR_VLC_NOVLANTAG (0U) /* No VLAN tag deletion, insertion, or replacement */ |
| #define | ETH_MACIVIR_VLC_VLANTAGDELETE_Pos (16U) |
| #define | ETH_MACIVIR_VLC_VLANTAGDELETE_Msk (0x1UL << ETH_MACIVIR_VLC_VLANTAGDELETE_Pos) |
| #define | ETH_MACIVIR_VLC_VLANTAGDELETE ETH_MACIVIR_VLC_VLANTAGDELETE_Msk /* VLAN tag deletion */ |
| #define | ETH_MACIVIR_VLC_VLANTAGINSERT_Pos (17U) |
| #define | ETH_MACIVIR_VLC_VLANTAGINSERT_Msk (0x1UL << ETH_MACIVIR_VLC_VLANTAGINSERT_Pos) |
| #define | ETH_MACIVIR_VLC_VLANTAGINSERT ETH_MACIVIR_VLC_VLANTAGINSERT_Msk /* VLAN tag insertion */ |
| #define | ETH_MACIVIR_VLC_VLANTAGREPLACE_Pos (16U) |
| #define | ETH_MACIVIR_VLC_VLANTAGREPLACE_Msk (0x3UL << ETH_MACIVIR_VLC_VLANTAGREPLACE_Pos) |
| #define | ETH_MACIVIR_VLC_VLANTAGREPLACE ETH_MACIVIR_VLC_VLANTAGREPLACE_Msk /* VLAN tag replacement */ |
| #define | ETH_MACIVIR_VLT_Pos (0U) |
| #define | ETH_MACIVIR_VLT_Msk (0xFFFFUL << ETH_MACIVIR_VLT_Pos) |
| #define | ETH_MACIVIR_VLT ETH_MACIVIR_VLT_Msk /* VLAN Tag for Transmit Packets */ |
| #define | ETH_MACIVIR_VLT_UP_Pos (13U) |
| #define | ETH_MACIVIR_VLT_UP_Msk (0x7UL << ETH_MACIVIR_VLT_UP_Pos) |
| #define | ETH_MACIVIR_VLT_UP ETH_MACIVIR_VLT_UP_Msk /* User Priority */ |
| #define | ETH_MACIVIR_VLT_CFIDEI_Pos (12U) |
| #define | ETH_MACIVIR_VLT_CFIDEI_Msk (0x1UL << ETH_MACIVIR_VLT_CFIDEI_Pos) |
| #define | ETH_MACIVIR_VLT_CFIDEI ETH_MACIVIR_VLT_CFIDEI_Msk /* Canonical Format Indicator or Drop Eligible Indicator */ |
| #define | ETH_MACIVIR_VLT_VID_Pos (0U) |
| #define | ETH_MACIVIR_VLT_VID_Msk (0xFFFUL << ETH_MACIVIR_VLT_VID_Pos) |
| #define | ETH_MACIVIR_VLT_VID ETH_MACIVIR_VLT_VID_Msk /* VLAN Identifier field of VLAN tag */ |
| #define | ETH_MACTFCR_PT_Pos (16U) |
| #define | ETH_MACTFCR_PT_Msk (0xFFFFUL << ETH_MACTFCR_PT_Pos) |
| #define | ETH_MACTFCR_PT ETH_MACTFCR_PT_Msk /* Pause Time */ |
| #define | ETH_MACTFCR_DZPQ_Pos (7U) |
| #define | ETH_MACTFCR_DZPQ_Msk (0x1UL << ETH_MACTFCR_DZPQ_Pos) |
| #define | ETH_MACTFCR_DZPQ ETH_MACTFCR_DZPQ_Msk /* Disable Zero-Quanta Pause */ |
| #define | ETH_MACTFCR_PLT_Pos (4U) |
| #define | ETH_MACTFCR_PLT_Msk (0x7UL << ETH_MACTFCR_PLT_Pos) |
| #define | ETH_MACTFCR_PLT ETH_MACTFCR_PLT_Msk /* Pause Low Threshold */ |
| #define | ETH_MACTFCR_PLT_MINUS4 (0U) /* Pause time minus 4 slot times */ |
| #define | ETH_MACTFCR_PLT_MINUS28_Pos (4U) |
| #define | ETH_MACTFCR_PLT_MINUS28_Msk (0x1UL << ETH_MACTFCR_PLT_MINUS28_Pos) |
| #define | ETH_MACTFCR_PLT_MINUS28 ETH_MACTFCR_PLT_MINUS28_Msk /* Pause time minus 28 slot times */ |
| #define | ETH_MACTFCR_PLT_MINUS36_Pos (5U) |
| #define | ETH_MACTFCR_PLT_MINUS36_Msk (0x1UL << ETH_MACTFCR_PLT_MINUS36_Pos) |
| #define | ETH_MACTFCR_PLT_MINUS36 ETH_MACTFCR_PLT_MINUS36_Msk /* Pause time minus 36 slot times */ |
| #define | ETH_MACTFCR_PLT_MINUS144_Pos (4U) |
| #define | ETH_MACTFCR_PLT_MINUS144_Msk (0x3UL << ETH_MACTFCR_PLT_MINUS144_Pos) |
| #define | ETH_MACTFCR_PLT_MINUS144 ETH_MACTFCR_PLT_MINUS144_Msk /* Pause time minus 144 slot times */ |
| #define | ETH_MACTFCR_PLT_MINUS256_Pos (6U) |
| #define | ETH_MACTFCR_PLT_MINUS256_Msk (0x1UL << ETH_MACTFCR_PLT_MINUS256_Pos) |
| #define | ETH_MACTFCR_PLT_MINUS256 ETH_MACTFCR_PLT_MINUS256_Msk /* Pause time minus 256 slot times */ |
| #define | ETH_MACTFCR_PLT_MINUS512_Pos (4U) |
| #define | ETH_MACTFCR_PLT_MINUS512_Msk (0x5UL << ETH_MACTFCR_PLT_MINUS512_Pos) |
| #define | ETH_MACTFCR_PLT_MINUS512 ETH_MACTFCR_PLT_MINUS512_Msk /* Pause time minus 512 slot times */ |
| #define | ETH_MACTFCR_TFE_Pos (1U) |
| #define | ETH_MACTFCR_TFE_Msk (0x1UL << ETH_MACTFCR_TFE_Pos) |
| #define | ETH_MACTFCR_TFE ETH_MACTFCR_TFE_Msk /* Transmit Flow Control Enable */ |
| #define | ETH_MACTFCR_FCB_Pos (0U) |
| #define | ETH_MACTFCR_FCB_Msk (0x1UL << ETH_MACTFCR_FCB_Pos) |
| #define | ETH_MACTFCR_FCB ETH_MACTFCR_FCB_Msk /* Flow Control Busy or Backpressure Activate */ |
| #define | ETH_MACRFCR_UP_Pos (1U) |
| #define | ETH_MACRFCR_UP_Msk (0x1UL << ETH_MACRFCR_UP_Pos) |
| #define | ETH_MACRFCR_UP ETH_MACRFCR_UP_Msk /* Unicast Pause Packet Detect */ |
| #define | ETH_MACRFCR_RFE_Pos (0U) |
| #define | ETH_MACRFCR_RFE_Msk (0x1UL << ETH_MACRFCR_RFE_Pos) |
| #define | ETH_MACRFCR_RFE ETH_MACRFCR_RFE_Msk /* Receive Flow Control Enable */ |
| #define | ETH_MACISR_RXSTSIS_Pos (14U) |
| #define | ETH_MACISR_RXSTSIS_Msk (0x1UL << ETH_MACISR_RXSTSIS_Pos) |
| #define | ETH_MACISR_RXSTSIS ETH_MACISR_RXSTSIS_Msk /* Receive Status Interrupt */ |
| #define | ETH_MACISR_TXSTSIS_Pos (13U) |
| #define | ETH_MACISR_TXSTSIS_Msk (0x1UL << ETH_MACISR_TXSTSIS_Pos) |
| #define | ETH_MACISR_TXSTSIS ETH_MACISR_TXSTSIS_Msk /* Transmit Status Interrupt */ |
| #define | ETH_MACISR_TSIS_Pos (12U) |
| #define | ETH_MACISR_TSIS_Msk (0x1UL << ETH_MACISR_TSIS_Pos) |
| #define | ETH_MACISR_TSIS ETH_MACISR_TSIS_Msk /* Timestamp Interrupt Status */ |
| #define | ETH_MACISR_MMCTXIS_Pos (10U) |
| #define | ETH_MACISR_MMCTXIS_Msk (0x1UL << ETH_MACISR_MMCTXIS_Pos) |
| #define | ETH_MACISR_MMCTXIS ETH_MACISR_MMCTXIS_Msk /* MMC Transmit Interrupt Status */ |
| #define | ETH_MACISR_MMCRXIS_Pos (9U) |
| #define | ETH_MACISR_MMCRXIS_Msk (0x1UL << ETH_MACISR_MMCRXIS_Pos) |
| #define | ETH_MACISR_MMCRXIS ETH_MACISR_MMCRXIS_Msk /* MMC Receive Interrupt Status */ |
| #define | ETH_MACISR_MMCIS_Pos (8U) |
| #define | ETH_MACISR_MMCIS_Msk (0x1UL << ETH_MACISR_MMCIS_Pos) |
| #define | ETH_MACISR_MMCIS ETH_MACISR_MMCIS_Msk /* MMC Interrupt Status */ |
| #define | ETH_MACISR_LPIIS_Pos (5U) |
| #define | ETH_MACISR_LPIIS_Msk (0x1UL << ETH_MACISR_LPIIS_Pos) |
| #define | ETH_MACISR_LPIIS ETH_MACISR_LPIIS_Msk /* LPI Interrupt Status */ |
| #define | ETH_MACISR_PMTIS_Pos (4U) |
| #define | ETH_MACISR_PMTIS_Msk (0x1UL << ETH_MACISR_PMTIS_Pos) |
| #define | ETH_MACISR_PMTIS ETH_MACISR_PMTIS_Msk /* PMT Interrupt Status */ |
| #define | ETH_MACISR_PHYIS_Pos (3U) |
| #define | ETH_MACISR_PHYIS_Msk (0x1UL << ETH_MACISR_PHYIS_Pos) |
| #define | ETH_MACISR_PHYIS ETH_MACISR_PHYIS_Msk /* PHY Interrupt */ |
| #define | ETH_MACIER_RXSTSIE_Pos (14U) |
| #define | ETH_MACIER_RXSTSIE_Msk (0x1UL << ETH_MACIER_RXSTSIE_Pos) |
| #define | ETH_MACIER_RXSTSIE ETH_MACIER_RXSTSIE_Msk /* Receive Status Interrupt Enable */ |
| #define | ETH_MACIER_TXSTSIE_Pos (13U) |
| #define | ETH_MACIER_TXSTSIE_Msk (0x1UL << ETH_MACIER_TXSTSIE_Pos) |
| #define | ETH_MACIER_TXSTSIE ETH_MACIER_TXSTSIE_Msk /* Transmit Status Interrupt Enable */ |
| #define | ETH_MACIER_TSIE_Pos (12U) |
| #define | ETH_MACIER_TSIE_Msk (0x1UL << ETH_MACIER_TSIE_Pos) |
| #define | ETH_MACIER_TSIE ETH_MACIER_TSIE_Msk /* Timestamp Interrupt Enable */ |
| #define | ETH_MACIER_LPIIE_Pos (5U) |
| #define | ETH_MACIER_LPIIE_Msk (0x1UL << ETH_MACIER_LPIIE_Pos) |
| #define | ETH_MACIER_LPIIE ETH_MACIER_LPIIE_Msk /* LPI Interrupt Enable */ |
| #define | ETH_MACIER_PMTIE_Pos (4U) |
| #define | ETH_MACIER_PMTIE_Msk (0x1UL << ETH_MACIER_PMTIE_Pos) |
| #define | ETH_MACIER_PMTIE ETH_MACIER_PMTIE_Msk /* PMT Interrupt Enable */ |
| #define | ETH_MACIER_PHYIE_Pos (3U) |
| #define | ETH_MACIER_PHYIE_Msk (0x1UL << ETH_MACIER_PHYIE_Pos) |
| #define | ETH_MACIER_PHYIE ETH_MACIER_PHYIE_Msk /* PHY Interrupt Enable */ |
| #define | ETH_MACRXTXSR_RWT_Pos (8U) |
| #define | ETH_MACRXTXSR_RWT_Msk (0x1UL << ETH_MACRXTXSR_RWT_Pos) |
| #define | ETH_MACRXTXSR_RWT ETH_MACRXTXSR_RWT_Msk /* Receive Watchdog Timeout */ |
| #define | ETH_MACRXTXSR_EXCOL_Pos (5U) |
| #define | ETH_MACRXTXSR_EXCOL_Msk (0x1UL << ETH_MACRXTXSR_EXCOL_Pos) |
| #define | ETH_MACRXTXSR_EXCOL ETH_MACRXTXSR_EXCOL_Msk /* Excessive Collisions */ |
| #define | ETH_MACRXTXSR_LCOL_Pos (4U) |
| #define | ETH_MACRXTXSR_LCOL_Msk (0x1UL << ETH_MACRXTXSR_LCOL_Pos) |
| #define | ETH_MACRXTXSR_LCOL ETH_MACRXTXSR_LCOL_Msk /* Late Collision */ |
| #define | ETH_MACRXTXSR_EXDEF_Pos (3U) |
| #define | ETH_MACRXTXSR_EXDEF_Msk (0x1UL << ETH_MACRXTXSR_EXDEF_Pos) |
| #define | ETH_MACRXTXSR_EXDEF ETH_MACRXTXSR_EXDEF_Msk /* Excessive Deferral */ |
| #define | ETH_MACRXTXSR_LCARR_Pos (2U) |
| #define | ETH_MACRXTXSR_LCARR_Msk (0x1UL << ETH_MACRXTXSR_LCARR_Pos) |
| #define | ETH_MACRXTXSR_LCARR ETH_MACRXTXSR_LCARR_Msk /* Loss of Carrier */ |
| #define | ETH_MACRXTXSR_NCARR_Pos (1U) |
| #define | ETH_MACRXTXSR_NCARR_Msk (0x1UL << ETH_MACRXTXSR_NCARR_Pos) |
| #define | ETH_MACRXTXSR_NCARR ETH_MACRXTXSR_NCARR_Msk /* No Carrier */ |
| #define | ETH_MACRXTXSR_TJT_Pos (0U) |
| #define | ETH_MACRXTXSR_TJT_Msk (0x1UL << ETH_MACRXTXSR_TJT_Pos) |
| #define | ETH_MACRXTXSR_TJT ETH_MACRXTXSR_TJT_Msk /* Transmit Jabber Timeout */ |
| #define | ETH_MACPCSR_RWKFILTRST_Pos (31U) |
| #define | ETH_MACPCSR_RWKFILTRST_Msk (0x1UL << ETH_MACPCSR_RWKFILTRST_Pos) |
| #define | ETH_MACPCSR_RWKFILTRST ETH_MACPCSR_RWKFILTRST_Msk /* Remote Wake-Up Packet Filter Register Pointer Reset */ |
| #define | ETH_MACPCSR_RWKPTR_Pos (24U) |
| #define | ETH_MACPCSR_RWKPTR_Msk (0x1FUL << ETH_MACPCSR_RWKPTR_Pos) |
| #define | ETH_MACPCSR_RWKPTR ETH_MACPCSR_RWKPTR_Msk /* Remote Wake-up FIFO Pointer */ |
| #define | ETH_MACPCSR_RWKPFE_Pos (10U) |
| #define | ETH_MACPCSR_RWKPFE_Msk (0x1UL << ETH_MACPCSR_RWKPFE_Pos) |
| #define | ETH_MACPCSR_RWKPFE ETH_MACPCSR_RWKPFE_Msk /* Remote Wake-up Packet Forwarding Enable */ |
| #define | ETH_MACPCSR_GLBLUCAST_Pos (9U) |
| #define | ETH_MACPCSR_GLBLUCAST_Msk (0x1UL << ETH_MACPCSR_GLBLUCAST_Pos) |
| #define | ETH_MACPCSR_GLBLUCAST ETH_MACPCSR_GLBLUCAST_Msk /* Global Unicast */ |
| #define | ETH_MACPCSR_RWKPRCVD_Pos (6U) |
| #define | ETH_MACPCSR_RWKPRCVD_Msk (0x1UL << ETH_MACPCSR_RWKPRCVD_Pos) |
| #define | ETH_MACPCSR_RWKPRCVD ETH_MACPCSR_RWKPRCVD_Msk /* Remote Wake-Up Packet Received */ |
| #define | ETH_MACPCSR_MGKPRCVD_Pos (5U) |
| #define | ETH_MACPCSR_MGKPRCVD_Msk (0x1UL << ETH_MACPCSR_MGKPRCVD_Pos) |
| #define | ETH_MACPCSR_MGKPRCVD ETH_MACPCSR_MGKPRCVD_Msk /* Magic Packet Received */ |
| #define | ETH_MACPCSR_RWKPKTEN_Pos (2U) |
| #define | ETH_MACPCSR_RWKPKTEN_Msk (0x1UL << ETH_MACPCSR_RWKPKTEN_Pos) |
| #define | ETH_MACPCSR_RWKPKTEN ETH_MACPCSR_RWKPKTEN_Msk /* Remote Wake-Up Packet Enable */ |
| #define | ETH_MACPCSR_MGKPKTEN_Pos (1U) |
| #define | ETH_MACPCSR_MGKPKTEN_Msk (0x1UL << ETH_MACPCSR_MGKPKTEN_Pos) |
| #define | ETH_MACPCSR_MGKPKTEN ETH_MACPCSR_MGKPKTEN_Msk /* Magic Packet Enable */ |
| #define | ETH_MACPCSR_PWRDWN_Pos (0U) |
| #define | ETH_MACPCSR_PWRDWN_Msk (0x1UL << ETH_MACPCSR_PWRDWN_Pos) |
| #define | ETH_MACPCSR_PWRDWN ETH_MACPCSR_PWRDWN_Msk /* Power Down */ |
| #define | ETH_MACRWUPFR_D_Pos (0U) |
| #define | ETH_MACRWUPFR_D_Msk (0xFFFFFFFFUL << ETH_MACRWUPFR_D_Pos) |
| #define | ETH_MACRWUPFR_D ETH_MACRWUPFR_D_Msk /* Wake-up Packet filter register data */ |
| #define | ETH_MACLCSR_LPITCSE_Pos (21U) |
| #define | ETH_MACLCSR_LPITCSE_Msk (0x1UL << ETH_MACLCSR_LPITCSE_Pos) |
| #define | ETH_MACLCSR_LPITCSE ETH_MACLCSR_LPITCSE_Msk /* LPI Tx Clock Stop Enable */ |
| #define | ETH_MACLCSR_LPITE_Pos (20U) |
| #define | ETH_MACLCSR_LPITE_Msk (0x1UL << ETH_MACLCSR_LPITE_Pos) |
| #define | ETH_MACLCSR_LPITE ETH_MACLCSR_LPITE_Msk /* LPI Timer Enable */ |
| #define | ETH_MACLCSR_LPITXA_Pos (19U) |
| #define | ETH_MACLCSR_LPITXA_Msk (0x1UL << ETH_MACLCSR_LPITXA_Pos) |
| #define | ETH_MACLCSR_LPITXA ETH_MACLCSR_LPITXA_Msk /* LPI Tx Automate */ |
| #define | ETH_MACLCSR_PLS_Pos (17U) |
| #define | ETH_MACLCSR_PLS_Msk (0x1UL << ETH_MACLCSR_PLS_Pos) |
| #define | ETH_MACLCSR_PLS ETH_MACLCSR_PLS_Msk /* PHY Link Status */ |
| #define | ETH_MACLCSR_LPIEN_Pos (16U) |
| #define | ETH_MACLCSR_LPIEN_Msk (0x1UL << ETH_MACLCSR_LPIEN_Pos) |
| #define | ETH_MACLCSR_LPIEN ETH_MACLCSR_LPIEN_Msk /* LPI Enable */ |
| #define | ETH_MACLCSR_RLPIST_Pos (9U) |
| #define | ETH_MACLCSR_RLPIST_Msk (0x1UL << ETH_MACLCSR_RLPIST_Pos) |
| #define | ETH_MACLCSR_RLPIST ETH_MACLCSR_RLPIST_Msk /* Receive LPI State */ |
| #define | ETH_MACLCSR_TLPIST_Pos (8U) |
| #define | ETH_MACLCSR_TLPIST_Msk (0x1UL << ETH_MACLCSR_TLPIST_Pos) |
| #define | ETH_MACLCSR_TLPIST ETH_MACLCSR_TLPIST_Msk /* Transmit LPI State */ |
| #define | ETH_MACLCSR_RLPIEX_Pos (3U) |
| #define | ETH_MACLCSR_RLPIEX_Msk (0x1UL << ETH_MACLCSR_RLPIEX_Pos) |
| #define | ETH_MACLCSR_RLPIEX ETH_MACLCSR_RLPIEX_Msk /* Receive LPI Exit */ |
| #define | ETH_MACLCSR_RLPIEN_Pos (2U) |
| #define | ETH_MACLCSR_RLPIEN_Msk (0x1UL << ETH_MACLCSR_RLPIEN_Pos) |
| #define | ETH_MACLCSR_RLPIEN ETH_MACLCSR_RLPIEN_Msk /* Receive LPI Entry */ |
| #define | ETH_MACLCSR_TLPIEX_Pos (1U) |
| #define | ETH_MACLCSR_TLPIEX_Msk (0x1UL << ETH_MACLCSR_TLPIEX_Pos) |
| #define | ETH_MACLCSR_TLPIEX ETH_MACLCSR_TLPIEX_Msk /* Transmit LPI Exit */ |
| #define | ETH_MACLCSR_TLPIEN_Pos (0U) |
| #define | ETH_MACLCSR_TLPIEN_Msk (0x1UL << ETH_MACLCSR_TLPIEN_Pos) |
| #define | ETH_MACLCSR_TLPIEN ETH_MACLCSR_TLPIEN_Msk /* Transmit LPI Entry */ |
| #define | ETH_MACLTCR_LST_Pos (16U) |
| #define | ETH_MACLTCR_LST_Msk (0x3FFUL << ETH_MACLTCR_LST_Pos) |
| #define | ETH_MACLTCR_LST ETH_MACLTCR_LST_Msk /* LPI LS TIMER */ |
| #define | ETH_MACLTCR_TWT_Pos (0U) |
| #define | ETH_MACLTCR_TWT_Msk (0xFFFFUL << ETH_MACLTCR_TWT_Pos) |
| #define | ETH_MACLTCR_TWT ETH_MACLTCR_TWT_Msk /* LPI TW TIMER */ |
| #define | ETH_MACLETR_LPIET_Pos (0U) |
| #define | ETH_MACLETR_LPIET_Msk (0xFFFFFUL << ETH_MACLETR_LPIET_Pos) |
| #define | ETH_MACLETR_LPIET ETH_MACLETR_LPIET_Msk /* LPI Entry Timer */ |
| #define | ETH_MAC1USTCR_TIC1USCNTR_Pos (0U) |
| #define | ETH_MAC1USTCR_TIC1USCNTR_Msk (0xFFFUL << ETH_MAC1USTCR_TIC1USCNTR_Pos) |
| #define | ETH_MAC1USTCR_TIC1USCNTR ETH_MAC1USTCR_TIC1USCNTR_Msk /* 1US TIC Counter */ |
| #define | ETH_MACVR_USERVER_Pos (8U) |
| #define | ETH_MACVR_USERVER_Msk (0xFFUL << ETH_MACVR_USERVER_Pos) |
| #define | ETH_MACVR_USERVER ETH_MACVR_USERVER_Msk /* User-defined Version */ |
| #define | ETH_MACVR_SNPSVER_Pos (0U) |
| #define | ETH_MACVR_SNPSVER_Msk (0xFFUL << ETH_MACVR_SNPSVER_Pos) |
| #define | ETH_MACVR_SNPSVER ETH_MACVR_SNPSVER_Msk /* Synopsys-defined Version */ |
| #define | ETH_MACDR_TFCSTS_Pos (17U) |
| #define | ETH_MACDR_TFCSTS_Msk (0x3UL << ETH_MACDR_TFCSTS_Pos) |
| #define | ETH_MACDR_TFCSTS ETH_MACDR_TFCSTS_Msk /* MAC Transmit Packet Controller Status */ |
| #define | ETH_MACDR_TFCSTS_IDLE (0U) /* Idle state */ |
| #define | ETH_MACDR_TFCSTS_WAIT_Pos (17U) |
| #define | ETH_MACDR_TFCSTS_WAIT_Msk (0x1UL << ETH_MACDR_TFCSTS_WAIT_Pos) |
| #define | ETH_MACDR_TFCSTS_WAIT ETH_MACDR_TFCSTS_WAIT_Msk /* Waiting for status of the previous packet, IPG or backoff period to be over */ |
| #define | ETH_MACDR_TFCSTS_GENERATEPCP_Pos (18U) |
| #define | ETH_MACDR_TFCSTS_GENERATEPCP_Msk (0x1UL << ETH_MACDR_TFCSTS_GENERATEPCP_Pos) |
| #define | ETH_MACDR_TFCSTS_GENERATEPCP ETH_MACDR_TFCSTS_GENERATEPCP_Msk /* Generating and transmitting a Pause control packet */ |
| #define | ETH_MACDR_TFCSTS_TRASFERIP_Pos (17U) |
| #define | ETH_MACDR_TFCSTS_TRASFERIP_Msk (0x3UL << ETH_MACDR_TFCSTS_TRASFERIP_Pos) |
| #define | ETH_MACDR_TFCSTS_TRASFERIP ETH_MACDR_TFCSTS_TRASFERIP_Msk /* Transferring input packet for transmission */ |
| #define | ETH_MACDR_TPESTS_Pos (16U) |
| #define | ETH_MACDR_TPESTS_Msk (0x1UL << ETH_MACDR_TPESTS_Pos) |
| #define | ETH_MACDR_TPESTS ETH_MACDR_TPESTS_Msk /* MAC Receive Packet Controller FIFO Status */ |
| #define | ETH_MACDR_RFCFCSTS_Pos (1U) |
| #define | ETH_MACDR_RFCFCSTS_Msk (0x3UL << ETH_MACDR_RFCFCSTS_Pos) |
| #define | ETH_MACDR_RFCFCSTS ETH_MACDR_RFCFCSTS_Msk /* MAC MII Transmit Protocol Engine Status */ |
| #define | ETH_MACDR_RPESTS_Pos (0U) |
| #define | ETH_MACDR_RPESTS_Msk (0x1UL << ETH_MACDR_RPESTS_Pos) |
| #define | ETH_MACDR_RPESTS ETH_MACDR_RPESTS_Msk /* MAC MII Receive Protocol Engine Status */ |
| #define | ETH_MACHWF0R_ACTPHYSEL_Pos (28U) |
| #define | ETH_MACHWF0R_ACTPHYSEL_Msk (0x7UL << ETH_MACHWF0R_ACTPHYSEL_Pos) |
| #define | ETH_MACHWF0R_ACTPHYSEL ETH_MACHWF0R_ACTPHYSEL_Msk /* Active PHY Selected */ |
| #define | ETH_MACHWF0R_ACTPHYSEL_MII (0U) /* MII */ |
| #define | ETH_MACHWF0R_ACTPHYSEL_RMII_Pos (30U) |
| #define | ETH_MACHWF0R_ACTPHYSEL_RMII_Msk (0x1UL << ETH_MACHWF0R_ACTPHYSEL_RMII_Pos) |
| #define | ETH_MACHWF0R_ACTPHYSEL_RMII ETH_MACHWF0R_ACTPHYSEL_RMII_Msk /* RMII */ |
| #define | ETH_MACHWF0R_ACTPHYSEL_REVMII_Pos (28U) |
| #define | ETH_MACHWF0R_ACTPHYSEL_REVMII_Msk (0x7UL << ETH_MACHWF0R_ACTPHYSEL_REVMII_Pos) |
| #define | ETH_MACHWF0R_ACTPHYSEL_REVMII ETH_MACHWF0R_ACTPHYSEL_REVMII_Msk /* RevMII */ |
| #define | ETH_MACHWF0R_SAVLANINS_Pos (27U) |
| #define | ETH_MACHWF0R_SAVLANINS_Msk (0x1UL << ETH_MACHWF0R_SAVLANINS_Pos) |
| #define | ETH_MACHWF0R_SAVLANINS ETH_MACHWF0R_SAVLANINS_Msk /* Source Address or VLAN Insertion Enable */ |
| #define | ETH_MACHWF0R_TSSTSSEL_Pos (25U) |
| #define | ETH_MACHWF0R_TSSTSSEL_Msk (0x3UL << ETH_MACHWF0R_TSSTSSEL_Pos) |
| #define | ETH_MACHWF0R_TSSTSSEL ETH_MACHWF0R_TSSTSSEL_Msk /* Timestamp System Time Source */ |
| #define | ETH_MACHWF0R_TSSTSSEL_INTERNAL_Pos (25U) |
| #define | ETH_MACHWF0R_TSSTSSEL_INTERNAL_Msk (0x1UL << ETH_MACHWF0R_TSSTSSEL_INTERNAL_Pos) |
| #define | ETH_MACHWF0R_TSSTSSEL_INTERNAL ETH_MACHWF0R_TSSTSSEL_INTERNAL_Msk /* Timestamp System Time Source: Internal */ |
| #define | ETH_MACHWF0R_TSSTSSEL_EXTERNAL_Pos (26U) |
| #define | ETH_MACHWF0R_TSSTSSEL_EXTERNAL_Msk (0x1UL << ETH_MACHWF0R_TSSTSSEL_EXTERNAL_Pos) |
| #define | ETH_MACHWF0R_TSSTSSEL_EXTERNAL ETH_MACHWF0R_TSSTSSEL_EXTERNAL_Msk /* Timestamp System Time Source: External */ |
| #define | ETH_MACHWF0R_TSSTSSEL_BOTH_Pos (25U) |
| #define | ETH_MACHWF0R_TSSTSSEL_BOTH_Msk (0x3UL << ETH_MACHWF0R_TSSTSSEL_BOTH_Pos) |
| #define | ETH_MACHWF0R_TSSTSSEL_BOTH ETH_MACHWF0R_TSSTSSEL_BOTH_Msk /* Timestamp System Time Source: Internal & External */ |
| #define | ETH_MACHWF0R_MACADR64SEL_Pos (24U) |
| #define | ETH_MACHWF0R_MACADR64SEL_Msk (0x1UL << ETH_MACHWF0R_MACADR64SEL_Pos) |
| #define | ETH_MACHWF0R_MACADR64SEL ETH_MACHWF0R_MACADR64SEL_Msk /* MAC Addresses 64-127 Selected */ |
| #define | ETH_MACHWF0R_MACADR32SEL_Pos (23U) |
| #define | ETH_MACHWF0R_MACADR32SEL_Msk (0x1UL << ETH_MACHWF0R_MACADR32SEL_Pos) |
| #define | ETH_MACHWF0R_MACADR32SEL ETH_MACHWF0R_MACADR32SEL_Msk /* MAC Addresses 32-63 Selected */ |
| #define | ETH_MACHWF0R_ADDMACADRSEL_Pos (18U) |
| #define | ETH_MACHWF0R_ADDMACADRSEL_Msk (0x1FUL << ETH_MACHWF0R_ADDMACADRSEL_Pos) |
| #define | ETH_MACHWF0R_ADDMACADRSEL ETH_MACHWF0R_ADDMACADRSEL_Msk /* MAC Addresses 1- 31 Selected */ |
| #define | ETH_MACHWF0R_RXCOESEL_Pos (16U) |
| #define | ETH_MACHWF0R_RXCOESEL_Msk (0x1UL << ETH_MACHWF0R_RXCOESEL_Pos) |
| #define | ETH_MACHWF0R_RXCOESEL ETH_MACHWF0R_RXCOESEL_Msk /* Receive Checksum Offload Enabled */ |
| #define | ETH_MACHWF0R_TXCOESEL_Pos (14U) |
| #define | ETH_MACHWF0R_TXCOESEL_Msk (0x1UL << ETH_MACHWF0R_TXCOESEL_Pos) |
| #define | ETH_MACHWF0R_TXCOESEL ETH_MACHWF0R_TXCOESEL_Msk /* Transmit Checksum Offload Enabled */ |
| #define | ETH_MACHWF0R_EEESEL_Pos (13U) |
| #define | ETH_MACHWF0R_EEESEL_Msk (0x1UL << ETH_MACHWF0R_EEESEL_Pos) |
| #define | ETH_MACHWF0R_EEESEL ETH_MACHWF0R_EEESEL_Msk /* Energy Efficient Ethernet Enabled */ |
| #define | ETH_MACHWF0R_TSSEL_Pos (12U) |
| #define | ETH_MACHWF0R_TSSEL_Msk (0x1UL << ETH_MACHWF0R_TSSEL_Pos) |
| #define | ETH_MACHWF0R_TSSEL ETH_MACHWF0R_TSSEL_Msk /* IEEE 1588-2008 Timestamp Enabled */ |
| #define | ETH_MACHWF0R_ARPOFFSEL_Pos (9U) |
| #define | ETH_MACHWF0R_ARPOFFSEL_Msk (0x1UL << ETH_MACHWF0R_ARPOFFSEL_Pos) |
| #define | ETH_MACHWF0R_ARPOFFSEL ETH_MACHWF0R_ARPOFFSEL_Msk /* ARP Offload Enabled */ |
| #define | ETH_MACHWF0R_MMCSEL_Pos (8U) |
| #define | ETH_MACHWF0R_MMCSEL_Msk (0x1UL << ETH_MACHWF0R_MMCSEL_Pos) |
| #define | ETH_MACHWF0R_MMCSEL ETH_MACHWF0R_MMCSEL_Msk /* RMON Module Enable */ |
| #define | ETH_MACHWF0R_MGKSEL_Pos (7U) |
| #define | ETH_MACHWF0R_MGKSEL_Msk (0x1UL << ETH_MACHWF0R_MGKSEL_Pos) |
| #define | ETH_MACHWF0R_MGKSEL ETH_MACHWF0R_MGKSEL_Msk /* PMT Magic Packet Enable */ |
| #define | ETH_MACHWF0R_RWKSEL_Pos (6U) |
| #define | ETH_MACHWF0R_RWKSEL_Msk (0x1UL << ETH_MACHWF0R_RWKSEL_Pos) |
| #define | ETH_MACHWF0R_RWKSEL ETH_MACHWF0R_RWKSEL_Msk /* PMT Remote Wake-up Packet Enable */ |
| #define | ETH_MACHWF0R_SMASEL_Pos (5U) |
| #define | ETH_MACHWF0R_SMASEL_Msk (0x1UL << ETH_MACHWF0R_SMASEL_Pos) |
| #define | ETH_MACHWF0R_SMASEL ETH_MACHWF0R_SMASEL_Msk /* SMA (MDIO) Interface */ |
| #define | ETH_MACHWF0R_VLHASH_Pos (4U) |
| #define | ETH_MACHWF0R_VLHASH_Msk (0x1UL << ETH_MACHWF0R_VLHASH_Pos) |
| #define | ETH_MACHWF0R_VLHASH ETH_MACHWF0R_VLHASH_Msk /* VLAN Hash Filter Selected */ |
| #define | ETH_MACHWF0R_PCSSEL_Pos (3U) |
| #define | ETH_MACHWF0R_PCSSEL_Msk (0x1UL << ETH_MACHWF0R_PCSSEL_Pos) |
| #define | ETH_MACHWF0R_PCSSEL ETH_MACHWF0R_PCSSEL_Msk /* PCS Registers (TBI, SGMII, or RTBI PHY interface) */ |
| #define | ETH_MACHWF0R_HDSEL_Pos (2U) |
| #define | ETH_MACHWF0R_HDSEL_Msk (0x1UL << ETH_MACHWF0R_HDSEL_Pos) |
| #define | ETH_MACHWF0R_HDSEL ETH_MACHWF0R_HDSEL_Msk /* Half-duplex Support */ |
| #define | ETH_MACHWF0R_GMIISEL_Pos (1U) |
| #define | ETH_MACHWF0R_GMIISEL_Msk (0x1UL << ETH_MACHWF0R_GMIISEL_Pos) |
| #define | ETH_MACHWF0R_GMIISEL ETH_MACHWF0R_GMIISEL_Msk /* 1000 Mbps Support */ |
| #define | ETH_MACHWF0R_MIISEL_Pos (0U) |
| #define | ETH_MACHWF0R_MIISEL_Msk (0x1UL << ETH_MACHWF0R_MIISEL_Pos) |
| #define | ETH_MACHWF0R_MIISEL ETH_MACHWF0R_MIISEL_Msk /* 10 or 100 Mbps Support */ |
| #define | ETH_MACHWF1R_L3L4FNUM_Pos (27U) |
| #define | ETH_MACHWF1R_L3L4FNUM_Msk (0xFUL << ETH_MACHWF1R_L3L4FNUM_Pos) |
| #define | ETH_MACHWF1R_L3L4FNUM ETH_MACHWF1R_L3L4FNUM_Msk /* Total number of L3 or L4 Filters */ |
| #define | ETH_MACHWF1R_HASHTBLSZ_Pos (24U) |
| #define | ETH_MACHWF1R_HASHTBLSZ_Msk (0x3UL << ETH_MACHWF1R_HASHTBLSZ_Pos) |
| #define | ETH_MACHWF1R_HASHTBLSZ ETH_MACHWF1R_HASHTBLSZ_Msk /* Hash Table Size */ |
| #define | ETH_MACHWF1R_AVSEL_Pos (20U) |
| #define | ETH_MACHWF1R_AVSEL_Msk (0x1UL << ETH_MACHWF1R_AVSEL_Pos) |
| #define | ETH_MACHWF1R_AVSEL ETH_MACHWF1R_AVSEL_Msk /* AV Feature Enabled */ |
| #define | ETH_MACHWF1R_DBGMEMA_Pos (19U) |
| #define | ETH_MACHWF1R_DBGMEMA_Msk (0x1UL << ETH_MACHWF1R_DBGMEMA_Pos) |
| #define | ETH_MACHWF1R_DBGMEMA ETH_MACHWF1R_DBGMEMA_Msk /* Debug Memory Interface Enabled */ |
| #define | ETH_MACHWF1R_TSOEN_Pos (18U) |
| #define | ETH_MACHWF1R_TSOEN_Msk (0x1UL << ETH_MACHWF1R_TSOEN_Pos) |
| #define | ETH_MACHWF1R_TSOEN ETH_MACHWF1R_TSOEN_Msk /* TCP Segmentation Offload Enable */ |
| #define | ETH_MACHWF1R_SPHEN_Pos (17U) |
| #define | ETH_MACHWF1R_SPHEN_Msk (0x1UL << ETH_MACHWF1R_SPHEN_Pos) |
| #define | ETH_MACHWF1R_SPHEN ETH_MACHWF1R_SPHEN_Msk /* Split Header Feature Enable */ |
| #define | ETH_MACHWF1R_DCBEN_Pos (16U) |
| #define | ETH_MACHWF1R_DCBEN_Msk (0x1UL << ETH_MACHWF1R_DCBEN_Pos) |
| #define | ETH_MACHWF1R_DCBEN ETH_MACHWF1R_DCBEN_Msk /* DCB Feature Enable */ |
| #define | ETH_MACHWF1R_ADDR64_Pos (14U) |
| #define | ETH_MACHWF1R_ADDR64_Msk (0x3UL << ETH_MACHWF1R_ADDR64_Pos) |
| #define | ETH_MACHWF1R_ADDR64 ETH_MACHWF1R_ADDR64_Msk /* Address Width */ |
| #define | ETH_MACHWF1R_ADDR64_32 (0x0UL << ETH_MACHWF1R_ADDR64_Pos) |
| #define | ETH_MACHWF1R_ADDR64_40 (0x1UL << ETH_MACHWF1R_ADDR64_Pos) |
| #define | ETH_MACHWF1R_ADDR64_48 (0x2UL << ETH_MACHWF1R_ADDR64_Pos) |
| #define | ETH_MACHWF1R_ADVTHWORD_Pos (13U) |
| #define | ETH_MACHWF1R_ADVTHWORD_Msk (0x1UL << ETH_MACHWF1R_ADVTHWORD_Pos) |
| #define | ETH_MACHWF1R_ADVTHWORD ETH_MACHWF1R_ADVTHWORD_Msk /* IEEE 1588 High Word Register Enable */ |
| #define | ETH_MACHWF1R_PTOEN_Pos (12U) |
| #define | ETH_MACHWF1R_PTOEN_Msk (0x1UL << ETH_MACHWF1R_PTOEN_Pos) |
| #define | ETH_MACHWF1R_PTOEN ETH_MACHWF1R_PTOEN_Msk /* PTP Offload Enable */ |
| #define | ETH_MACHWF1R_OSTEN_Pos (11U) |
| #define | ETH_MACHWF1R_OSTEN_Msk (0x1UL << ETH_MACHWF1R_OSTEN_Pos) |
| #define | ETH_MACHWF1R_OSTEN ETH_MACHWF1R_OSTEN_Msk /* One-Step Timestamping Enable */ |
| #define | ETH_MACHWF1R_TXFIFOSIZE_Pos (6U) |
| #define | ETH_MACHWF1R_TXFIFOSIZE_Msk (0x1FUL << ETH_MACHWF1R_TXFIFOSIZE_Pos) |
| #define | ETH_MACHWF1R_TXFIFOSIZE ETH_MACHWF1R_TXFIFOSIZE_Msk /* MTL Transmit FIFO Size */ |
| #define | ETH_MACHWF1R_RXFIFOSIZE_Pos (0U) |
| #define | ETH_MACHWF1R_RXFIFOSIZE_Msk (0x1FUL << ETH_MACHWF1R_RXFIFOSIZE_Pos) |
| #define | ETH_MACHWF1R_RXFIFOSIZE ETH_MACHWF1R_RXFIFOSIZE_Msk /* MTL Receive FIFO Size */ |
| #define | ETH_MACHWF2R_AUXSNAPNUM_Pos (28U) |
| #define | ETH_MACHWF2R_AUXSNAPNUM_Msk (0x7UL << ETH_MACHWF2R_AUXSNAPNUM_Pos) |
| #define | ETH_MACHWF2R_AUXSNAPNUM ETH_MACHWF2R_AUXSNAPNUM_Msk /* Number of Auxiliary Snapshot Inputs */ |
| #define | ETH_MACHWF2R_PPSOUTNUM_Pos (24U) |
| #define | ETH_MACHWF2R_PPSOUTNUM_Msk (0x7UL << ETH_MACHWF2R_PPSOUTNUM_Pos) |
| #define | ETH_MACHWF2R_PPSOUTNUM ETH_MACHWF2R_PPSOUTNUM_Msk /* Number of PPS Outputs */ |
| #define | ETH_MACHWF2R_TXCHCNT_Pos (18U) |
| #define | ETH_MACHWF2R_TXCHCNT_Msk (0xFUL << ETH_MACHWF2R_TXCHCNT_Pos) |
| #define | ETH_MACHWF2R_TXCHCNT ETH_MACHWF2R_TXCHCNT_Msk /* Number of DMA Transmit Channels */ |
| #define | ETH_MACHWF2R_RXCHCNT_Pos (13U) |
| #define | ETH_MACHWF2R_RXCHCNT_Msk (0x7UL << ETH_MACHWF2R_RXCHCNT_Pos) |
| #define | ETH_MACHWF2R_RXCHCNT ETH_MACHWF2R_RXCHCNT_Msk /* Number of DMA Receive Channels */ |
| #define | ETH_MACHWF2R_TXQCNT_Pos (6U) |
| #define | ETH_MACHWF2R_TXQCNT_Msk (0xFUL << ETH_MACHWF2R_TXQCNT_Pos) |
| #define | ETH_MACHWF2R_TXQCNT ETH_MACHWF2R_TXQCNT_Msk /* Number of MTL Transmit Queues */ |
| #define | ETH_MACHWF2R_RXQCNT_Pos (0U) |
| #define | ETH_MACHWF2R_RXQCNT_Msk (0xFUL << ETH_MACHWF2R_RXQCNT_Pos) |
| #define | ETH_MACHWF2R_RXQCNT ETH_MACHWF2R_RXQCNT_Msk /* Number of MTL Receive Queues */ |
| #define | ETH_MACMDIOAR_PSE_Pos (27U) |
| #define | ETH_MACMDIOAR_PSE_Msk (0x1UL << ETH_MACMDIOAR_PSE_Pos) |
| #define | ETH_MACMDIOAR_PSE ETH_MACMDIOAR_PSE_Msk /* Preamble Suppression Enable */ |
| #define | ETH_MACMDIOAR_BTB_Pos (26U) |
| #define | ETH_MACMDIOAR_BTB_Msk (0x1UL << ETH_MACMDIOAR_BTB_Pos) |
| #define | ETH_MACMDIOAR_BTB ETH_MACMDIOAR_BTB_Msk /* Back to Back transactions */ |
| #define | ETH_MACMDIOAR_PA_Pos (21U) |
| #define | ETH_MACMDIOAR_PA_Msk (0x1FUL << ETH_MACMDIOAR_PA_Pos) |
| #define | ETH_MACMDIOAR_PA ETH_MACMDIOAR_PA_Msk /* Physical Layer Address */ |
| #define | ETH_MACMDIOAR_RDA_Pos (16U) |
| #define | ETH_MACMDIOAR_RDA_Msk (0x1FUL << ETH_MACMDIOAR_RDA_Pos) |
| #define | ETH_MACMDIOAR_RDA ETH_MACMDIOAR_RDA_Msk /* Register/Device Address */ |
| #define | ETH_MACMDIOAR_NTC_Pos (12U) |
| #define | ETH_MACMDIOAR_NTC_Msk (0x7UL << ETH_MACMDIOAR_NTC_Pos) |
| #define | ETH_MACMDIOAR_NTC ETH_MACMDIOAR_NTC_Msk /* Number of Trailing Clocks */ |
| #define | ETH_MACMDIOAR_CR_Pos (8U) |
| #define | ETH_MACMDIOAR_CR_Msk (0xFUL << ETH_MACMDIOAR_CR_Pos) |
| #define | ETH_MACMDIOAR_CR ETH_MACMDIOAR_CR_Msk /* CSR Clock Range */ |
| #define | ETH_MACMDIOAR_CR_DIV42 (0U) /* CSR clock/42 */ |
| #define | ETH_MACMDIOAR_CR_DIV62_Pos (8U) |
| #define | ETH_MACMDIOAR_CR_DIV62_Msk (0x1UL << ETH_MACMDIOAR_CR_DIV62_Pos) |
| #define | ETH_MACMDIOAR_CR_DIV62 ETH_MACMDIOAR_CR_DIV62_Msk /* CSR clock/62 */ |
| #define | ETH_MACMDIOAR_CR_DIV16_Pos (9U) |
| #define | ETH_MACMDIOAR_CR_DIV16_Msk (0x1UL << ETH_MACMDIOAR_CR_DIV16_Pos) |
| #define | ETH_MACMDIOAR_CR_DIV16 ETH_MACMDIOAR_CR_DIV16_Msk /* CSR clock/16 */ |
| #define | ETH_MACMDIOAR_CR_DIV26_Pos (8U) |
| #define | ETH_MACMDIOAR_CR_DIV26_Msk (0x3UL << ETH_MACMDIOAR_CR_DIV26_Pos) |
| #define | ETH_MACMDIOAR_CR_DIV26 ETH_MACMDIOAR_CR_DIV26_Msk /* CSR clock/26 */ |
| #define | ETH_MACMDIOAR_CR_DIV102_Pos (10U) |
| #define | ETH_MACMDIOAR_CR_DIV102_Msk (0x1UL << ETH_MACMDIOAR_CR_DIV102_Pos) |
| #define | ETH_MACMDIOAR_CR_DIV102 ETH_MACMDIOAR_CR_DIV102_Msk /* CSR clock/102 */ |
| #define | ETH_MACMDIOAR_CR_DIV124_Pos (8U) |
| #define | ETH_MACMDIOAR_CR_DIV124_Msk (0x5UL << ETH_MACMDIOAR_CR_DIV124_Pos) |
| #define | ETH_MACMDIOAR_CR_DIV124 ETH_MACMDIOAR_CR_DIV124_Msk /* CSR clock/124 */ |
| #define | ETH_MACMDIOAR_CR_DIV4AR_Pos (11U) |
| #define | ETH_MACMDIOAR_CR_DIV4AR_Msk (0x1UL << ETH_MACMDIOAR_CR_DIV4AR_Pos) |
| #define | ETH_MACMDIOAR_CR_DIV4AR ETH_MACMDIOAR_CR_DIV4AR_Msk /* CSR clock/4: MDC clock above range specified in IEEE */ |
| #define | ETH_MACMDIOAR_CR_DIV6AR_Pos (8U) |
| #define | ETH_MACMDIOAR_CR_DIV6AR_Msk (0x9UL << ETH_MACMDIOAR_CR_DIV6AR_Pos) |
| #define | ETH_MACMDIOAR_CR_DIV6AR ETH_MACMDIOAR_CR_DIV6AR_Msk /* CSR clock/6: MDC clock above range specified in IEEE */ |
| #define | ETH_MACMDIOAR_CR_DIV8AR_Pos (9U) |
| #define | ETH_MACMDIOAR_CR_DIV8AR_Msk (0x5UL << ETH_MACMDIOAR_CR_DIV8AR_Pos) |
| #define | ETH_MACMDIOAR_CR_DIV8AR ETH_MACMDIOAR_CR_DIV8AR_Msk /* CSR clock/8: MDC clock above range specified in IEEE */ |
| #define | ETH_MACMDIOAR_CR_DIV10AR_Pos (8U) |
| #define | ETH_MACMDIOAR_CR_DIV10AR_Msk (0xBUL << ETH_MACMDIOAR_CR_DIV10AR_Pos) |
| #define | ETH_MACMDIOAR_CR_DIV10AR ETH_MACMDIOAR_CR_DIV10AR_Msk /* CSR clock/10: MDC clock above range specified in IEEE */ |
| #define | ETH_MACMDIOAR_CR_DIV12AR_Pos (10U) |
| #define | ETH_MACMDIOAR_CR_DIV12AR_Msk (0x3UL << ETH_MACMDIOAR_CR_DIV12AR_Pos) |
| #define | ETH_MACMDIOAR_CR_DIV12AR ETH_MACMDIOAR_CR_DIV12AR_Msk /* CSR clock/12: MDC clock above range specified in IEEE */ |
| #define | ETH_MACMDIOAR_CR_DIV14AR_Pos (8U) |
| #define | ETH_MACMDIOAR_CR_DIV14AR_Msk (0xDUL << ETH_MACMDIOAR_CR_DIV14AR_Pos) |
| #define | ETH_MACMDIOAR_CR_DIV14AR ETH_MACMDIOAR_CR_DIV14AR_Msk /* CSR clock/14: MDC clock above range specified in IEEE */ |
| #define | ETH_MACMDIOAR_CR_DIV16AR_Pos (9U) |
| #define | ETH_MACMDIOAR_CR_DIV16AR_Msk (0x7UL << ETH_MACMDIOAR_CR_DIV16AR_Pos) |
| #define | ETH_MACMDIOAR_CR_DIV16AR ETH_MACMDIOAR_CR_DIV16AR_Msk /* CSR clock/16: MDC clock above range specified in IEEE */ |
| #define | ETH_MACMDIOAR_CR_DIV18AR_Pos (8U) |
| #define | ETH_MACMDIOAR_CR_DIV18AR_Msk (0xFUL << ETH_MACMDIOAR_CR_DIV18AR_Pos) |
| #define | ETH_MACMDIOAR_CR_DIV18AR ETH_MACMDIOAR_CR_DIV18AR_Msk /* CSR clock/18: MDC clock above range specified in IEEE */ |
| #define | ETH_MACMDIOAR_SKAP_Pos (4U) |
| #define | ETH_MACMDIOAR_SKAP_Msk (0x1UL << ETH_MACMDIOAR_SKAP_Pos) |
| #define | ETH_MACMDIOAR_SKAP ETH_MACMDIOAR_SKAP_Msk /* Skip Address Packet */ |
| #define | ETH_MACMDIOAR_MOC_Pos (2U) |
| #define | ETH_MACMDIOAR_MOC_Msk (0x3UL << ETH_MACMDIOAR_MOC_Pos) |
| #define | ETH_MACMDIOAR_MOC ETH_MACMDIOAR_MOC_Msk /* MII Operation Command */ |
| #define | ETH_MACMDIOAR_MOC_WR_Pos (2U) |
| #define | ETH_MACMDIOAR_MOC_WR_Msk (0x1UL << ETH_MACMDIOAR_MOC_WR_Pos) |
| #define | ETH_MACMDIOAR_MOC_WR ETH_MACMDIOAR_MOC_WR_Msk /* Write */ |
| #define | ETH_MACMDIOAR_MOC_PRDIA_Pos (3U) |
| #define | ETH_MACMDIOAR_MOC_PRDIA_Msk (0x1UL << ETH_MACMDIOAR_MOC_PRDIA_Pos) |
| #define | ETH_MACMDIOAR_MOC_PRDIA ETH_MACMDIOAR_MOC_PRDIA_Msk /* Post Read Increment Address for Clause 45 PHY */ |
| #define | ETH_MACMDIOAR_MOC_RD_Pos (2U) |
| #define | ETH_MACMDIOAR_MOC_RD_Msk (0x3UL << ETH_MACMDIOAR_MOC_RD_Pos) |
| #define | ETH_MACMDIOAR_MOC_RD ETH_MACMDIOAR_MOC_RD_Msk /* Read */ |
| #define | ETH_MACMDIOAR_C45E_Pos (1U) |
| #define | ETH_MACMDIOAR_C45E_Msk (0x1UL << ETH_MACMDIOAR_C45E_Pos) |
| #define | ETH_MACMDIOAR_C45E ETH_MACMDIOAR_C45E_Msk /* Clause 45 PHY Enable */ |
| #define | ETH_MACMDIOAR_MB_Pos (0U) |
| #define | ETH_MACMDIOAR_MB_Msk (0x1UL << ETH_MACMDIOAR_MB_Pos) |
| #define | ETH_MACMDIOAR_MB ETH_MACMDIOAR_MB_Msk /* MII Busy */ |
| #define | ETH_MACMDIODR_RA_Pos (16U) |
| #define | ETH_MACMDIODR_RA_Msk (0xFFFFUL << ETH_MACMDIODR_RA_Pos) |
| #define | ETH_MACMDIODR_RA ETH_MACMDIODR_RA_Msk /* Register Address */ |
| #define | ETH_MACMDIODR_MD_Pos (0U) |
| #define | ETH_MACMDIODR_MD_Msk (0xFFFFUL << ETH_MACMDIODR_MD_Pos) |
| #define | ETH_MACMDIODR_MD ETH_MACMDIODR_MD_Msk /* MII Data */ |
| #define | ETH_MACARPAR_ARPPA_Pos (0U) |
| #define | ETH_MACARPAR_ARPPA_Msk (0xFFFFFFFFUL << ETH_MACARPAR_ARPPA_Pos) |
| #define | ETH_MACARPAR_ARPPA ETH_MACARPAR_ARPPA_Msk /* ARP Protocol Address */ |
| #define | ETH_MACA0HR_AE_Pos (31U) |
| #define | ETH_MACA0HR_AE_Msk (0x1UL << ETH_MACA0HR_AE_Pos) |
| #define | ETH_MACA0HR_AE ETH_MACA0HR_AE_Msk /* Address Enable*/ |
| #define | ETH_MACA0HR_ADDRHI_Pos (0U) |
| #define | ETH_MACA0HR_ADDRHI_Msk (0xFFFFUL << ETH_MACA0HR_ADDRHI_Pos) |
| #define | ETH_MACA0HR_ADDRHI ETH_MACA0HR_ADDRHI_Msk /* MAC Address 0*/ |
| #define | ETH_MACA0LR_ADDRLO_Pos (0U) |
| #define | ETH_MACA0LR_ADDRLO_Msk (0xFFFFFFFFUL << ETH_MACA0LR_ADDRLO_Pos) |
| #define | ETH_MACA0LR_ADDRLO ETH_MACA0LR_ADDRLO_Msk /* MAC Address 0*/ |
| #define | ETH_MACA1HR_AE_Pos (31U) |
| #define | ETH_MACA1HR_AE_Msk (0x1UL << ETH_MACA1HR_AE_Pos) |
| #define | ETH_MACA1HR_AE ETH_MACA1HR_AE_Msk /* Address Enable*/ |
| #define | ETH_MACA1HR_SA_Pos (30U) |
| #define | ETH_MACA1HR_SA_Msk (0x1UL << ETH_MACA1HR_SA_Pos) |
| #define | ETH_MACA1HR_SA ETH_MACA1HR_SA_Msk /* Source Address */ |
| #define | ETH_MACA1HR_MBC_Pos (24U) |
| #define | ETH_MACA1HR_MBC_Msk (0x3FUL << ETH_MACA1HR_MBC_Pos) |
| #define | ETH_MACA1HR_MBC ETH_MACA1HR_MBC_Msk /* Mask Byte Control */ |
| #define | ETH_MACA1HR_ADDRHI_Pos (0U) |
| #define | ETH_MACA1HR_ADDRHI_Msk (0xFFFFUL << ETH_MACA1HR_ADDRHI_Pos) |
| #define | ETH_MACA1HR_ADDRHI ETH_MACA1HR_ADDRHI_Msk /* MAC Address 1*/ |
| #define | ETH_MACA1LR_ADDRLO_Pos (0U) |
| #define | ETH_MACA1LR_ADDRLO_Msk (0xFFFFFFFFUL << ETH_MACA1LR_ADDRLO_Pos) |
| #define | ETH_MACA1LR_ADDRLO ETH_MACA1LR_ADDRLO_Msk /* MAC Address 1*/ |
| #define | ETH_MACA2HR_AE_Pos (31U) |
| #define | ETH_MACA2HR_AE_Msk (0x1UL << ETH_MACA2HR_AE_Pos) |
| #define | ETH_MACA2HR_AE ETH_MACA2HR_AE_Msk /* Address Enable*/ |
| #define | ETH_MACA2HR_SA_Pos (30U) |
| #define | ETH_MACA2HR_SA_Msk (0x1UL << ETH_MACA2HR_SA_Pos) |
| #define | ETH_MACA2HR_SA ETH_MACA2HR_SA_Msk /* Source Address */ |
| #define | ETH_MACA2HR_MBC_Pos (24U) |
| #define | ETH_MACA2HR_MBC_Msk (0x3FUL << ETH_MACA2HR_MBC_Pos) |
| #define | ETH_MACA2HR_MBC ETH_MACA2HR_MBC_Msk /* Mask Byte Control */ |
| #define | ETH_MACA2HR_ADDRHI_Pos (0U) |
| #define | ETH_MACA2HR_ADDRHI_Msk (0xFFFFUL << ETH_MACA2HR_ADDRHI_Pos) |
| #define | ETH_MACA2HR_ADDRHI ETH_MACA2HR_ADDRHI_Msk /* MAC Address 1*/ |
| #define | ETH_MACA2LR_ADDRLO_Pos (0U) |
| #define | ETH_MACA2LR_ADDRLO_Msk (0xFFFFFFFFUL << ETH_MACA2LR_ADDRLO_Pos) |
| #define | ETH_MACA2LR_ADDRLO ETH_MACA2LR_ADDRLO_Msk /* MAC Address 2*/ |
| #define | ETH_MACA3HR_AE_Pos (31U) |
| #define | ETH_MACA3HR_AE_Msk (0x1UL << ETH_MACA3HR_AE_Pos) |
| #define | ETH_MACA3HR_AE ETH_MACA3HR_AE_Msk /* Address Enable*/ |
| #define | ETH_MACA3HR_SA_Pos (30U) |
| #define | ETH_MACA3HR_SA_Msk (0x1UL << ETH_MACA3HR_SA_Pos) |
| #define | ETH_MACA3HR_SA ETH_MACA3HR_SA_Msk /* Source Address */ |
| #define | ETH_MACA3HR_MBC_Pos (24U) |
| #define | ETH_MACA3HR_MBC_Msk (0x3FUL << ETH_MACA3HR_MBC_Pos) |
| #define | ETH_MACA3HR_MBC ETH_MACA3HR_MBC_Msk /* Mask Byte Control */ |
| #define | ETH_MACA3HR_ADDRHI_Pos (0U) |
| #define | ETH_MACA3HR_ADDRHI_Msk (0xFFFFUL << ETH_MACA3HR_ADDRHI_Pos) |
| #define | ETH_MACA3HR_ADDRHI ETH_MACA3HR_ADDRHI_Msk /* MAC Address 1*/ |
| #define | ETH_MACA3LR_ADDRLO_Pos (0U) |
| #define | ETH_MACA3LR_ADDRLO_Msk (0xFFFFFFFFUL << ETH_MACA3LR_ADDRLO_Pos) |
| #define | ETH_MACA3LR_ADDRLO ETH_MACA3LR_ADDRLO_Msk /* MAC Address 3*/ |
| #define | ETH_MACAHR_AE_Pos (31U) |
| #define | ETH_MACAHR_AE_Msk (0x1UL << ETH_MACAHR_AE_Pos) |
| #define | ETH_MACAHR_AE ETH_MACAHR_AE_Msk /* Address enable */ |
| #define | ETH_MACAHR_SA_Pos (30U) |
| #define | ETH_MACAHR_SA_Msk (0x1UL << ETH_MACAHR_SA_Pos) |
| #define | ETH_MACAHR_SA ETH_MACAHR_SA_Msk /* Source address */ |
| #define | ETH_MACAHR_MBC_Pos (24U) |
| #define | ETH_MACAHR_MBC_Msk (0x3FUL << ETH_MACAHR_MBC_Pos) |
| #define | ETH_MACAHR_MBC ETH_MACAHR_MBC_Msk /* Mask byte control: bits to mask for comparison of the MAC Address bytes */ |
| #define | ETH_MACAHR_MBC_HBITS15_8 (0x20000000U) /* Mask MAC Address high reg bits [15:8] */ |
| #define | ETH_MACAHR_MBC_HBITS7_0 (0x10000000U) /* Mask MAC Address high reg bits [7:0] */ |
| #define | ETH_MACAHR_MBC_LBITS31_24 (0x08000000U) /* Mask MAC Address low reg bits [31:24] */ |
| #define | ETH_MACAHR_MBC_LBITS23_16 (0x04000000U) /* Mask MAC Address low reg bits [23:16] */ |
| #define | ETH_MACAHR_MBC_LBITS15_8 (0x02000000U) /* Mask MAC Address low reg bits [15:8] */ |
| #define | ETH_MACAHR_MBC_LBITS7_0 (0x01000000U) /* Mask MAC Address low reg bits [7:0] */ |
| #define | ETH_MACAHR_MACAH_Pos (0U) |
| #define | ETH_MACAHR_MACAH_Msk (0xFFFFUL << ETH_MACAHR_MACAH_Pos) |
| #define | ETH_MACAHR_MACAH ETH_MACAHR_MACAH_Msk /* MAC address high */ |
| #define | ETH_MACALR_MACAL_Pos (0U) |
| #define | ETH_MACALR_MACAL_Msk (0xFFFFFFFFUL << ETH_MACALR_MACAL_Pos) |
| #define | ETH_MACALR_MACAL ETH_MACALR_MACAL_Msk /* MAC address low */ |
| #define | ETH_MMCCR_UCDBC_Pos (8U) |
| #define | ETH_MMCCR_UCDBC_Msk (0x1UL << ETH_MMCCR_UCDBC_Pos) |
| #define | ETH_MMCCR_UCDBC ETH_MMCCR_UCDBC_Msk /* Update MMC Counters for Dropped Broadcast Packets */ |
| #define | ETH_MMCCR_CNTPRSTLVL_Pos (5U) |
| #define | ETH_MMCCR_CNTPRSTLVL_Msk (0x1UL << ETH_MMCCR_CNTPRSTLVL_Pos) |
| #define | ETH_MMCCR_CNTPRSTLVL ETH_MMCCR_CNTPRSTLVL_Msk /* Full-Half Preset */ |
| #define | ETH_MMCCR_CNTPRST_Pos (4U) |
| #define | ETH_MMCCR_CNTPRST_Msk (0x1UL << ETH_MMCCR_CNTPRST_Pos) |
| #define | ETH_MMCCR_CNTPRST ETH_MMCCR_CNTPRST_Msk /* Counters Reset */ |
| #define | ETH_MMCCR_CNTFREEZ_Pos (3U) |
| #define | ETH_MMCCR_CNTFREEZ_Msk (0x1UL << ETH_MMCCR_CNTFREEZ_Pos) |
| #define | ETH_MMCCR_CNTFREEZ ETH_MMCCR_CNTFREEZ_Msk /* MMC Counter Freeze */ |
| #define | ETH_MMCCR_RSTONRD_Pos (2U) |
| #define | ETH_MMCCR_RSTONRD_Msk (0x1UL << ETH_MMCCR_RSTONRD_Pos) |
| #define | ETH_MMCCR_RSTONRD ETH_MMCCR_RSTONRD_Msk /* Reset On Read */ |
| #define | ETH_MMCCR_CNTSTOPRO_Pos (1U) |
| #define | ETH_MMCCR_CNTSTOPRO_Msk (0x1UL << ETH_MMCCR_CNTSTOPRO_Pos) |
| #define | ETH_MMCCR_CNTSTOPRO ETH_MMCCR_CNTSTOPRO_Msk /* Counter Stop Rollover */ |
| #define | ETH_MMCCR_CNTRST_Pos (0U) |
| #define | ETH_MMCCR_CNTRST_Msk (0x1UL << ETH_MMCCR_CNTRST_Pos) |
| #define | ETH_MMCCR_CNTRST ETH_MMCCR_CNTRST_Msk /* Counters Reset */ |
| #define | ETH_MMCRIR_RXLPITRCIS_Pos (27U) |
| #define | ETH_MMCRIR_RXLPITRCIS_Msk (0x1UL << ETH_MMCRIR_RXLPITRCIS_Pos) |
| #define | ETH_MMCRIR_RXLPITRCIS ETH_MMCRIR_RXLPITRCIS_Msk /* MMC Receive LPI transition counter interrupt status */ |
| #define | ETH_MMCRIR_RXLPIUSCIS_Pos (26U) |
| #define | ETH_MMCRIR_RXLPIUSCIS_Msk (0x1UL << ETH_MMCRIR_RXLPIUSCIS_Pos) |
| #define | ETH_MMCRIR_RXLPIUSCIS ETH_MMCRIR_RXLPIUSCIS_Msk /* MMC Receive LPI microsecond counter interrupt status */ |
| #define | ETH_MMCRIR_RXUCGPIS_Pos (17U) |
| #define | ETH_MMCRIR_RXUCGPIS_Msk (0x1UL << ETH_MMCRIR_RXUCGPIS_Pos) |
| #define | ETH_MMCRIR_RXUCGPIS ETH_MMCRIR_RXUCGPIS_Msk /* MMC Receive Unicast Good Packet Counter Interrupt Status */ |
| #define | ETH_MMCRIR_RXALGNERPIS_Pos (6U) |
| #define | ETH_MMCRIR_RXALGNERPIS_Msk (0x1UL << ETH_MMCRIR_RXALGNERPIS_Pos) |
| #define | ETH_MMCRIR_RXALGNERPIS ETH_MMCRIR_RXALGNERPIS_Msk /* MMC Receive Alignment Error Packet Counter Interrupt Status */ |
| #define | ETH_MMCRIR_RXCRCERPIS_Pos (5U) |
| #define | ETH_MMCRIR_RXCRCERPIS_Msk (0x1UL << ETH_MMCRIR_RXCRCERPIS_Pos) |
| #define | ETH_MMCRIR_RXCRCERPIS ETH_MMCRIR_RXCRCERPIS_Msk /* MMC Receive CRC Error Packet Counter Interrupt Status */ |
| #define | ETH_MMCTIR_TXLPITRCIS_Pos (27U) |
| #define | ETH_MMCTIR_TXLPITRCIS_Msk (0x1UL << ETH_MMCTIR_TXLPITRCIS_Pos) |
| #define | ETH_MMCTIR_TXLPITRCIS ETH_MMCTIR_TXLPITRCIS_Msk /* MMC Transmit LPI transition counter interrupt status */ |
| #define | ETH_MMCTIR_TXLPIUSCIS_Pos (26U) |
| #define | ETH_MMCTIR_TXLPIUSCIS_Msk (0x1UL << ETH_MMCTIR_TXLPIUSCIS_Pos) |
| #define | ETH_MMCTIR_TXLPIUSCIS ETH_MMCTIR_TXLPIUSCIS_Msk /* MMC Transmit LPI microsecond counter interrupt status */ |
| #define | ETH_MMCTIR_TXGPKTIS_Pos (21U) |
| #define | ETH_MMCTIR_TXGPKTIS_Msk (0x1UL << ETH_MMCTIR_TXGPKTIS_Pos) |
| #define | ETH_MMCTIR_TXGPKTIS ETH_MMCTIR_TXGPKTIS_Msk /* MMC Transmit Good Packet Counter Interrupt Status */ |
| #define | ETH_MMCTIR_TXMCOLGPIS_Pos (15U) |
| #define | ETH_MMCTIR_TXMCOLGPIS_Msk (0x1UL << ETH_MMCTIR_TXMCOLGPIS_Pos) |
| #define | ETH_MMCTIR_TXMCOLGPIS ETH_MMCTIR_TXMCOLGPIS_Msk /* MMC Transmit Multiple Collision Good Packet Counter Interrupt Status */ |
| #define | ETH_MMCTIR_TXSCOLGPIS_Pos (14U) |
| #define | ETH_MMCTIR_TXSCOLGPIS_Msk (0x1UL << ETH_MMCTIR_TXSCOLGPIS_Pos) |
| #define | ETH_MMCTIR_TXSCOLGPIS ETH_MMCTIR_TXSCOLGPIS_Msk /* MMC Transmit Single Collision Good Packet Counter Interrupt Status */ |
| #define | ETH_MMCRIMR_RXLPITRCIM_Pos (27U) |
| #define | ETH_MMCRIMR_RXLPITRCIM_Msk (0x1UL << ETH_MMCRIMR_RXLPITRCIM_Pos) |
| #define | ETH_MMCRIMR_RXLPITRCIM ETH_MMCRIMR_RXLPITRCIM_Msk /* MMC Receive LPI transition counter interrupt Mask */ |
| #define | ETH_MMCRIMR_RXLPIUSCIM_Pos (26U) |
| #define | ETH_MMCRIMR_RXLPIUSCIM_Msk (0x1UL << ETH_MMCRIMR_RXLPIUSCIM_Pos) |
| #define | ETH_MMCRIMR_RXLPIUSCIM ETH_MMCRIMR_RXLPIUSCIM_Msk /* MMC Receive LPI microsecond counter interrupt Mask */ |
| #define | ETH_MMCRIMR_RXUCGPIM_Pos (17U) |
| #define | ETH_MMCRIMR_RXUCGPIM_Msk (0x1UL << ETH_MMCRIMR_RXUCGPIM_Pos) |
| #define | ETH_MMCRIMR_RXUCGPIM ETH_MMCRIMR_RXUCGPIM_Msk /* MMC Receive Unicast Good Packet Counter Interrupt Mask */ |
| #define | ETH_MMCRIMR_RXALGNERPIM_Pos (6U) |
| #define | ETH_MMCRIMR_RXALGNERPIM_Msk (0x1UL << ETH_MMCRIMR_RXALGNERPIM_Pos) |
| #define | ETH_MMCRIMR_RXALGNERPIM ETH_MMCRIMR_RXALGNERPIM_Msk /* MMC Receive Alignment Error Packet Counter Interrupt Mask */ |
| #define | ETH_MMCRIMR_RXCRCERPIM_Pos (5U) |
| #define | ETH_MMCRIMR_RXCRCERPIM_Msk (0x1UL << ETH_MMCRIMR_RXCRCERPIM_Pos) |
| #define | ETH_MMCRIMR_RXCRCERPIM ETH_MMCRIMR_RXCRCERPIM_Msk /* MMC Receive CRC Error Packet Counter Interrupt Mask */ |
| #define | ETH_MMCTIMR_TXLPITRCIM_Pos (27U) |
| #define | ETH_MMCTIMR_TXLPITRCIM_Msk (0x1UL << ETH_MMCTIMR_TXLPITRCIM_Pos) |
| #define | ETH_MMCTIMR_TXLPITRCIM ETH_MMCTIMR_TXLPITRCIM_Msk /* MMC Transmit LPI transition counter interrupt Mask*/ |
| #define | ETH_MMCTIMR_TXLPIUSCIM_Pos (26U) |
| #define | ETH_MMCTIMR_TXLPIUSCIM_Msk (0x1UL << ETH_MMCTIMR_TXLPIUSCIM_Pos) |
| #define | ETH_MMCTIMR_TXLPIUSCIM ETH_MMCTIMR_TXLPIUSCIM_Msk /* MMC Transmit LPI microsecond counter interrupt Mask*/ |
| #define | ETH_MMCTIMR_TXGPKTIM_Pos (21U) |
| #define | ETH_MMCTIMR_TXGPKTIM_Msk (0x1UL << ETH_MMCTIMR_TXGPKTIM_Pos) |
| #define | ETH_MMCTIMR_TXGPKTIM ETH_MMCTIMR_TXGPKTIM_Msk /* MMC Transmit Good Packet Counter Interrupt Mask*/ |
| #define | ETH_MMCTIMR_TXMCOLGPIM_Pos (15U) |
| #define | ETH_MMCTIMR_TXMCOLGPIM_Msk (0x1UL << ETH_MMCTIMR_TXMCOLGPIM_Pos) |
| #define | ETH_MMCTIMR_TXMCOLGPIM ETH_MMCTIMR_TXMCOLGPIM_Msk /* MMC Transmit Multiple Collision Good Packet Counter Interrupt Mask */ |
| #define | ETH_MMCTIMR_TXSCOLGPIM_Pos (14U) |
| #define | ETH_MMCTIMR_TXSCOLGPIM_Msk (0x1UL << ETH_MMCTIMR_TXSCOLGPIM_Pos) |
| #define | ETH_MMCTIMR_TXSCOLGPIM ETH_MMCTIMR_TXSCOLGPIM_Msk /* MMC Transmit Single Collision Good Packet Counter Interrupt Mask */ |
| #define | ETH_MMCTSCGPR_TXSNGLCOLG_Pos (0U) |
| #define | ETH_MMCTSCGPR_TXSNGLCOLG_msk (0xFFFFFFFFUL << ETH_MMCTSCGPR_TXSNGLCOLG_Pos) |
| #define | ETH_MMCTSCGPR_TXSNGLCOLG ETH_MMCTSCGPR_TXSNGLCOLG_msk /* Tx Single Collision Good Packets */ |
| #define | ETH_MMCTMCGPR_TXMULTCOLG_Pos (0U) |
| #define | ETH_MMCTMCGPR_TXMULTCOLG_msk (0xFFFFFFFFUL << ETH_MMCTMCGPR_TXMULTCOLG_Pos) |
| #define | ETH_MMCTMCGPR_TXMULTCOLG ETH_MMCTMCGPR_TXMULTCOLG_msk /* Tx Multiple Collision Good Packets */ |
| #define | ETH_MMCTPCGR_TXPKTG_Pos (0U) |
| #define | ETH_MMCTPCGR_TXPKTG_msk (0xFFFFFFFFUL << ETH_MMCTPCGR_TXPKTG_Pos) |
| #define | ETH_MMCTPCGR_TXPKTG ETH_MMCTPCGR_TXPKTG_msk /* Tx Packet Count Good */ |
| #define | ETH_MMCRCRCEPR_RXCRCERR_Pos (0U) |
| #define | ETH_MMCRCRCEPR_RXCRCERR_msk (0xFFFFFFFFUL << ETH_MMCRCRCEPR_RXCRCERR_Pos) |
| #define | ETH_MMCRCRCEPR_RXCRCERR ETH_MMCRCRCEPR_RXCRCERR_msk /* Rx CRC Error Packets */ |
| #define | ETH_MMCRAEPR_RXALGNERR_Pos (0U) |
| #define | ETH_MMCRAEPR_RXALGNERR_msk (0xFFFFFFFFUL << ETH_MMCRAEPR_RXALGNERR_Pos) |
| #define | ETH_MMCRAEPR_RXALGNERR ETH_MMCRAEPR_RXALGNERR_msk /* Rx Alignment Error Packets */ |
| #define | ETH_MMCRUPGR_RXUCASTG_Pos (0U) |
| #define | ETH_MMCRUPGR_RXUCASTG_msk (0xFFFFFFFFUL << ETH_MMCRUPGR_RXUCASTG_Pos) |
| #define | ETH_MMCRUPGR_RXUCASTG ETH_MMCRUPGR_RXUCASTG_msk /* Rx Unicast Packets Good */ |
| #define | ETH_MMCTLPIMSTR_TXLPIUSC_Pos (0U) |
| #define | ETH_MMCTLPIMSTR_TXLPIUSC_msk (0xFFFFFFFFUL << ETH_MMCTLPIMSTR_TXLPIUSC_Pos) |
| #define | ETH_MMCTLPIMSTR_TXLPIUSC ETH_MMCTLPIMSTR_TXLPIUSC_msk /* Tx LPI Microseconds Counter */ |
| #define | ETH_MMCTLPITCR_TXLPITRC_Pos (0U) |
| #define | ETH_MMCTLPITCR_TXLPITRC_msk (0xFFFFFFFFUL << ETH_MMCTLPITCR_TXLPITRC_Pos) |
| #define | ETH_MMCTLPITCR_TXLPITRC ETH_MMCTLPITCR_TXLPITRC_msk /* Tx LPI Transition counter */ |
| #define | ETH_MMCRLPIMSTR_RXLPIUSC_Pos (0U) |
| #define | ETH_MMCRLPIMSTR_RXLPIUSC_msk (0xFFFFFFFFUL << ETH_MMCRLPIMSTR_RXLPIUSC_Pos) |
| #define | ETH_MMCRLPIMSTR_RXLPIUSC ETH_MMCRLPIMSTR_RXLPIUSC_msk /* Rx LPI Microseconds Counter */ |
| #define | ETH_MMCRLPITCR_RXLPITRC_Pos (0U) |
| #define | ETH_MMCRLPITCR_RXLPITRC_msk (0xFFFFFFFFUL << ETH_MMCRLPITCR_RXLPITRC_Pos) |
| #define | ETH_MMCRLPITCR_RXLPITRC ETH_MMCRLPITCR_RXLPITRC_msk /* Rx LPI Transition counter */ |
| #define | ETH_MACL3L4CR_L4DPIM_Pos (21U) |
| #define | ETH_MACL3L4CR_L4DPIM_Msk (0x1UL << ETH_MACL3L4CR_L4DPIM_Pos) |
| #define | ETH_MACL3L4CR_L4DPIM ETH_MACL3L4CR_L4DPIM_Msk /* Layer 4 Destination Port Inverse Match Enable */ |
| #define | ETH_MACL3L4CR_L4DPM_Pos (20U) |
| #define | ETH_MACL3L4CR_L4DPM_Msk (0x1UL << ETH_MACL3L4CR_L4DPM_Pos) |
| #define | ETH_MACL3L4CR_L4DPM ETH_MACL3L4CR_L4DPM_Msk /* Layer 4 Destination Port Match Enable */ |
| #define | ETH_MACL3L4CR_L4SPIM_Pos (19U) |
| #define | ETH_MACL3L4CR_L4SPIM_Msk (0x1UL << ETH_MACL3L4CR_L4SPIM_Pos) |
| #define | ETH_MACL3L4CR_L4SPIM ETH_MACL3L4CR_L4SPIM_Msk /* Layer 4 Source Port Inverse Match Enable */ |
| #define | ETH_MACL3L4CR_L4SPM_Pos (18U) |
| #define | ETH_MACL3L4CR_L4SPM_Msk (0x1UL << ETH_MACL3L4CR_L4SPM_Pos) |
| #define | ETH_MACL3L4CR_L4SPM ETH_MACL3L4CR_L4SPM_Msk /* Layer 4 Source Port Match Enable */ |
| #define | ETH_MACL3L4CR_L4PEN_Pos (16U) |
| #define | ETH_MACL3L4CR_L4PEN_Msk (0x1UL << ETH_MACL3L4CR_L4PEN_Pos) |
| #define | ETH_MACL3L4CR_L4PEN ETH_MACL3L4CR_L4PEN_Msk /* Layer 4 Protocol Enable */ |
| #define | ETH_MACL3L4CR_L3HDBM_Pos (11U) |
| #define | ETH_MACL3L4CR_L3HDBM_Msk (0x1FUL << ETH_MACL3L4CR_L3HDBM_Pos) |
| #define | ETH_MACL3L4CR_L3HDBM ETH_MACL3L4CR_L3HDBM_Msk /* Layer 3 IP DA Higher Bits Match */ |
| #define | ETH_MACL3L4CR_L3HSBM_Pos (6U) |
| #define | ETH_MACL3L4CR_L3HSBM_Msk (0x1FUL << ETH_MACL3L4CR_L3HSBM_Pos) |
| #define | ETH_MACL3L4CR_L3HSBM ETH_MACL3L4CR_L3HSBM_Msk /* Layer 3 IP SA Higher Bits Match */ |
| #define | ETH_MACL3L4CR_L3DAIM_Pos (5U) |
| #define | ETH_MACL3L4CR_L3DAIM_Msk (0x1UL << ETH_MACL3L4CR_L3DAIM_Pos) |
| #define | ETH_MACL3L4CR_L3DAIM ETH_MACL3L4CR_L3DAIM_Msk /* Layer 3 IP DA Inverse Match Enable */ |
| #define | ETH_MACL3L4CR_L3DAM_Pos (4U) |
| #define | ETH_MACL3L4CR_L3DAM_Msk (0x1UL << ETH_MACL3L4CR_L3DAM_Pos) |
| #define | ETH_MACL3L4CR_L3DAM ETH_MACL3L4CR_L3DAM_Msk /* Layer 3 IP DA Match Enable */ |
| #define | ETH_MACL3L4CR_L3SAIM_Pos (3U) |
| #define | ETH_MACL3L4CR_L3SAIM_Msk (0x1UL << ETH_MACL3L4CR_L3SAIM_Pos) |
| #define | ETH_MACL3L4CR_L3SAIM ETH_MACL3L4CR_L3SAIM_Msk /* Layer 3 IP SA Inverse Match Enable */ |
| #define | ETH_MACL3L4CR_L3SAM_Pos (2U) |
| #define | ETH_MACL3L4CR_L3SAM_Msk (0x1UL << ETH_MACL3L4CR_L3SAM_Pos) |
| #define | ETH_MACL3L4CR_L3SAM ETH_MACL3L4CR_L3SAM_Msk /* Layer 3 IP SA Match Enable*/ |
| #define | ETH_MACL3L4CR_L3PEN_Pos (0U) |
| #define | ETH_MACL3L4CR_L3PEN_Msk (0x1UL << ETH_MACL3L4CR_L3PEN_Pos) |
| #define | ETH_MACL3L4CR_L3PEN ETH_MACL3L4CR_L3PEN_Msk /* Layer 3 Protocol Enable */ |
| #define | ETH_MACL4AR_L4DP_Pos (16U) |
| #define | ETH_MACL4AR_L4DP_Msk (0xFFFFUL << ETH_MACL4AR_L4DP_Pos) |
| #define | ETH_MACL4AR_L4DP ETH_MACL4AR_L4DP_Msk /* Layer 4 Destination Port Number Field */ |
| #define | ETH_MACL4AR_L4SP_Pos (0U) |
| #define | ETH_MACL4AR_L4SP_Msk (0xFFFFUL << ETH_MACL4AR_L4SP_Pos) |
| #define | ETH_MACL4AR_L4SP ETH_MACL4AR_L4SP_Msk /* Layer 4 Source Port Number Field */ |
| #define | ETH_MACL3A0R_L3A0_Pos (0U) |
| #define | ETH_MACL3A0R_L3A0_Msk (0xFFFFFFFFUL << ETH_MACL3A0R_L3A0_Pos) |
| #define | ETH_MACL3A0R_L3A0 ETH_MACL3A0R_L3A0_Msk /* Layer 3 Address 0 Field */ |
| #define | ETH_MACL3A1R_L3A1_Pos (0U) |
| #define | ETH_MACL3A1R_L3A1_Msk (0xFFFFFFFFUL << ETH_MACL3A1R_L3A1_Pos) |
| #define | ETH_MACL3A1R_L3A1 ETH_MACL3A1R_L3A1_Msk /* Layer 3 Address 1 Field */ |
| #define | ETH_MACL3A2R_L3A2_Pos (0U) |
| #define | ETH_MACL3A2R_L3A2_Msk (0xFFFFFFFFUL << ETH_MACL3A2R_L3A2_Pos) |
| #define | ETH_MACL3A2R_L3A2 ETH_MACL3A2R_L3A2_Msk /* Layer 3 Address 2 Field */ |
| #define | ETH_MACL3A3R_L3A3_Pos (0U) |
| #define | ETH_MACL3A3R_L3A3_Msk (0xFFFFFFFFUL << ETH_MACL3A3R_L3A3_Pos) |
| #define | ETH_MACL3A3R_L3A3 ETH_MACL3A3R_L3A3_Msk /* Layer 3 Address 3 Field */ |
| #define | ETH_MACTSCR_TXTSSTSM_Pos (24U) |
| #define | ETH_MACTSCR_TXTSSTSM_Msk (0x1UL << ETH_MACTSCR_TXTSSTSM_Pos) |
| #define | ETH_MACTSCR_TXTSSTSM ETH_MACTSCR_TXTSSTSM_Msk /* Transmit Timestamp Status Mode */ |
| #define | ETH_MACTSCR_CSC_Pos (19U) |
| #define | ETH_MACTSCR_CSC_Msk (0x1UL << ETH_MACTSCR_CSC_Pos) |
| #define | ETH_MACTSCR_CSC ETH_MACTSCR_CSC_Msk /* Enable checksum correction during OST for PTP over UDP/IPv4 packets */ |
| #define | ETH_MACTSCR_TSENMACADDR_Pos (18U) |
| #define | ETH_MACTSCR_TSENMACADDR_Msk (0x1UL << ETH_MACTSCR_TSENMACADDR_Pos) |
| #define | ETH_MACTSCR_TSENMACADDR ETH_MACTSCR_TSENMACADDR_Msk /* Enable MAC Address for PTP Packet Filtering */ |
| #define | ETH_MACTSCR_SNAPTYPSEL_Pos (16U) |
| #define | ETH_MACTSCR_SNAPTYPSEL_Msk (0x3UL << ETH_MACTSCR_SNAPTYPSEL_Pos) |
| #define | ETH_MACTSCR_SNAPTYPSEL ETH_MACTSCR_SNAPTYPSEL_Msk /* Select PTP packets for Taking Snapshots */ |
| #define | ETH_MACTSCR_TSMSTRENA_Pos (15U) |
| #define | ETH_MACTSCR_TSMSTRENA_Msk (0x1UL << ETH_MACTSCR_TSMSTRENA_Pos) |
| #define | ETH_MACTSCR_TSMSTRENA ETH_MACTSCR_TSMSTRENA_Msk /* Enable Snapshot for Messages Relevant to Master */ |
| #define | ETH_MACTSCR_TSEVNTENA_Pos (14U) |
| #define | ETH_MACTSCR_TSEVNTENA_Msk (0x1UL << ETH_MACTSCR_TSEVNTENA_Pos) |
| #define | ETH_MACTSCR_TSEVNTENA ETH_MACTSCR_TSEVNTENA_Msk /* Enable Timestamp Snapshot for Event Messages */ |
| #define | ETH_MACTSCR_TSIPV4ENA_Pos (13U) |
| #define | ETH_MACTSCR_TSIPV4ENA_Msk (0x1UL << ETH_MACTSCR_TSIPV4ENA_Pos) |
| #define | ETH_MACTSCR_TSIPV4ENA ETH_MACTSCR_TSIPV4ENA_Msk /* Enable Processing of PTP Packets Sent over IPv4-UDP */ |
| #define | ETH_MACTSCR_TSIPV6ENA_Pos (12U) |
| #define | ETH_MACTSCR_TSIPV6ENA_Msk (0x1UL << ETH_MACTSCR_TSIPV6ENA_Pos) |
| #define | ETH_MACTSCR_TSIPV6ENA ETH_MACTSCR_TSIPV6ENA_Msk /* Enable Processing of PTP Packets Sent over IPv6-UDP */ |
| #define | ETH_MACTSCR_TSIPENA_Pos (11U) |
| #define | ETH_MACTSCR_TSIPENA_Msk (0x1UL << ETH_MACTSCR_TSIPENA_Pos) |
| #define | ETH_MACTSCR_TSIPENA ETH_MACTSCR_TSIPENA_Msk /* Enable Processing of PTP over Ethernet Packets */ |
| #define | ETH_MACTSCR_TSVER2ENA_Pos (10U) |
| #define | ETH_MACTSCR_TSVER2ENA_Msk (0x1UL << ETH_MACTSCR_TSVER2ENA_Pos) |
| #define | ETH_MACTSCR_TSVER2ENA ETH_MACTSCR_TSVER2ENA_Msk /* Enable PTP Packet Processing for Version 2 Format */ |
| #define | ETH_MACTSCR_TSCTRLSSR_Pos (9U) |
| #define | ETH_MACTSCR_TSCTRLSSR_Msk (0x1UL << ETH_MACTSCR_TSCTRLSSR_Pos) |
| #define | ETH_MACTSCR_TSCTRLSSR ETH_MACTSCR_TSCTRLSSR_Msk /* Timestamp Digital or Binary Rollover Control */ |
| #define | ETH_MACTSCR_TSENALL_Pos (8U) |
| #define | ETH_MACTSCR_TSENALL_Msk (0x1UL << ETH_MACTSCR_TSENALL_Pos) |
| #define | ETH_MACTSCR_TSENALL ETH_MACTSCR_TSENALL_Msk /* Enable Timestamp for All Packets */ |
| #define | ETH_MACTSCR_TSADDREG_Pos (5U) |
| #define | ETH_MACTSCR_TSADDREG_Msk (0x1UL << ETH_MACTSCR_TSADDREG_Pos) |
| #define | ETH_MACTSCR_TSADDREG ETH_MACTSCR_TSADDREG_Msk /* Update Addend Register */ |
| #define | ETH_MACTSCR_TSUPDT_Pos (3U) |
| #define | ETH_MACTSCR_TSUPDT_Msk (0x1UL << ETH_MACTSCR_TSUPDT_Pos) |
| #define | ETH_MACTSCR_TSUPDT ETH_MACTSCR_TSUPDT_Msk /* Update Timestamp */ |
| #define | ETH_MACTSCR_TSINIT_Pos (2U) |
| #define | ETH_MACTSCR_TSINIT_Msk (0x1UL << ETH_MACTSCR_TSINIT_Pos) |
| #define | ETH_MACTSCR_TSINIT ETH_MACTSCR_TSINIT_Msk /* Initialize Timestamp */ |
| #define | ETH_MACTSCR_TSCFUPDT_Pos (1U) |
| #define | ETH_MACTSCR_TSCFUPDT_Msk (0x1UL << ETH_MACTSCR_TSCFUPDT_Pos) |
| #define | ETH_MACTSCR_TSCFUPDT ETH_MACTSCR_TSCFUPDT_Msk /* Fine or Coarse Timestamp Update*/ |
| #define | ETH_MACTSCR_TSENA_Pos (0U) |
| #define | ETH_MACTSCR_TSENA_Msk (0x1UL << ETH_MACTSCR_TSENA_Pos) |
| #define | ETH_MACTSCR_TSENA ETH_MACTSCR_TSENA_Msk /* Enable Timestamp */ |
| #define | ETH_MACMACSSIR_SSINC_Pos (16U) |
| #define | ETH_MACMACSSIR_SSINC_Msk (0xFFUL << ETH_MACMACSSIR_SSINC_Pos) |
| #define | ETH_MACMACSSIR_SSINC ETH_MACMACSSIR_SSINC_Msk /* Sub-second Increment Value */ |
| #define | ETH_MACMACSSIR_SNSINC_Pos (8U) |
| #define | ETH_MACMACSSIR_SNSINC_Msk (0xFFUL << ETH_MACMACSSIR_SNSINC_Pos) |
| #define | ETH_MACMACSSIR_SNSINC ETH_MACMACSSIR_SNSINC_Msk /* Sub-nanosecond Increment Value */ |
| #define | ETH_MACSTSR_TSS_Pos (0U) |
| #define | ETH_MACSTSR_TSS_Msk (0xFFFFFFFFUL << ETH_MACSTSR_TSS_Pos) |
| #define | ETH_MACSTSR_TSS ETH_MACSTSR_TSS_Msk /* Timestamp Second */ |
| #define | ETH_MACSTNR_TSSS_Pos (0U) |
| #define | ETH_MACSTNR_TSSS_Msk (0x7FFFFFFFUL << ETH_MACSTNR_TSSS_Pos) |
| #define | ETH_MACSTNR_TSSS ETH_MACSTNR_TSSS_Msk /* Timestamp Sub-seconds */ |
| #define | ETH_MACSTSUR_TSS_Pos (0U) |
| #define | ETH_MACSTSUR_TSS_Msk (0xFFFFFFFFUL << ETH_MACSTSUR_TSS_Pos) |
| #define | ETH_MACSTSUR_TSS ETH_MACSTSUR_TSS_Msk /* Timestamp Seconds */ |
| #define | ETH_MACSTNUR_ADDSUB_Pos (31U) |
| #define | ETH_MACSTNUR_ADDSUB_Msk (0x1UL << ETH_MACSTNUR_ADDSUB_Pos) |
| #define | ETH_MACSTNUR_ADDSUB ETH_MACSTNUR_ADDSUB_Msk /* Add or Subtract Time */ |
| #define | ETH_MACSTNUR_TSSS_Pos (0U) |
| #define | ETH_MACSTNUR_TSSS_Msk (0x7FFFFFFFUL << ETH_MACSTNUR_TSSS_Pos) |
| #define | ETH_MACSTNUR_TSSS ETH_MACSTNUR_TSSS_Msk /* Timestamp Sub-seconds */ |
| #define | ETH_MACTSAR_TSAR_Pos (0U) |
| #define | ETH_MACTSAR_TSAR_Msk (0xFFFFFFFFUL << ETH_MACTSAR_TSAR_Pos) |
| #define | ETH_MACTSAR_TSAR ETH_MACTSAR_TSAR_Msk /* Timestamp Addend Register */ |
| #define | ETH_MACTSSR_ATSNS_Pos (25U) |
| #define | ETH_MACTSSR_ATSNS_Msk (0x1FUL << ETH_MACTSSR_ATSNS_Pos) |
| #define | ETH_MACTSSR_ATSNS ETH_MACTSSR_ATSNS_Msk /* Number of Auxiliary Timestamp Snapshots */ |
| #define | ETH_MACTSSR_ATSSTM_Pos (24U) |
| #define | ETH_MACTSSR_ATSSTM_Msk (0x1UL << ETH_MACTSSR_ATSSTM_Pos) |
| #define | ETH_MACTSSR_ATSSTM ETH_MACTSSR_ATSSTM_Msk /* Auxiliary Timestamp Snapshot Trigger Missed */ |
| #define | ETH_MACTSSR_ATSSTN_Pos (16U) |
| #define | ETH_MACTSSR_ATSSTN_Msk (0xFUL << ETH_MACTSSR_ATSSTN_Pos) |
| #define | ETH_MACTSSR_ATSSTN ETH_MACTSSR_ATSSTN_Msk /* Auxiliary Timestamp Snapshot Trigger Identifier */ |
| #define | ETH_MACTSSR_TXTSSIS_Pos (15U) |
| #define | ETH_MACTSSR_TXTSSIS_Msk (0x1UL << ETH_MACTSSR_TXTSSIS_Pos) |
| #define | ETH_MACTSSR_TXTSSIS ETH_MACTSSR_TXTSSIS_Msk /* Tx Timestamp Status Interrupt Status */ |
| #define | ETH_MACTSSR_TSTRGTERR0_Pos (3U) |
| #define | ETH_MACTSSR_TSTRGTERR0_Msk (0x1UL << ETH_MACTSSR_TSTRGTERR0_Pos) |
| #define | ETH_MACTSSR_TSTRGTERR0 ETH_MACTSSR_TSTRGTERR0_Msk /* Timestamp Target Time Error */ |
| #define | ETH_MACTSSR_AUXTSTRIG_Pos (2U) |
| #define | ETH_MACTSSR_AUXTSTRIG_Msk (0x1UL << ETH_MACTSSR_AUXTSTRIG_Pos) |
| #define | ETH_MACTSSR_AUXTSTRIG ETH_MACTSSR_AUXTSTRIG_Msk /* Auxiliary Timestamp Trigger Snapshot*/ |
| #define | ETH_MACTSSR_TSTARGT0_Pos (1U) |
| #define | ETH_MACTSSR_TSTARGT0_Msk (0x1UL << ETH_MACTSSR_TSTARGT0_Pos) |
| #define | ETH_MACTSSR_TSTARGT0 ETH_MACTSSR_TSTARGT0_Msk /* Timestamp Target Time Reached */ |
| #define | ETH_MACTSSR_TSSOVF_Pos (0U) |
| #define | ETH_MACTSSR_TSSOVF_Msk (0x1UL << ETH_MACTSSR_TSSOVF_Pos) |
| #define | ETH_MACTSSR_TSSOVF ETH_MACTSSR_TSSOVF_Msk /* Timestamp Seconds Overflow */ |
| #define | ETH_MACTTSSNR_TXTSSMIS_Pos (31U) |
| #define | ETH_MACTTSSNR_TXTSSMIS_Msk (0x1UL << ETH_MACTTSSNR_TXTSSMIS_Pos) |
| #define | ETH_MACTTSSNR_TXTSSMIS ETH_MACTTSSNR_TXTSSMIS_Msk /* Transmit Timestamp Status Missed */ |
| #define | ETH_MACTTSSNR_TXTSSLO_Pos (0U) |
| #define | ETH_MACTTSSNR_TXTSSLO_Msk (0x7FFFFFFFUL << ETH_MACTTSSNR_TXTSSLO_Pos) |
| #define | ETH_MACTTSSNR_TXTSSLO ETH_MACTTSSNR_TXTSSLO_Msk /* Transmit Timestamp Status Low */ |
| #define | ETH_MACTTSSSR_TXTSSHI_Pos (0U) |
| #define | ETH_MACTTSSSR_TXTSSHI_Msk (0xFFFFFFFFUL << ETH_MACTTSSSR_TXTSSHI_Pos) |
| #define | ETH_MACTTSSSR_TXTSSHI ETH_MACTTSSSR_TXTSSHI_Msk /* Transmit Timestamp Status High */ |
| #define | ETH_MACACR_ATSEN3_Pos (7U) |
| #define | ETH_MACACR_ATSEN3_Msk (0x1UL << ETH_MACACR_ATSEN3_Pos) |
| #define | ETH_MACACR_ATSEN3 ETH_MACACR_ATSEN3_Msk /* Auxiliary Snapshot 3 Enable */ |
| #define | ETH_MACACR_ATSEN2_Pos (6U) |
| #define | ETH_MACACR_ATSEN2_Msk (0x1UL << ETH_MACACR_ATSEN2_Pos) |
| #define | ETH_MACACR_ATSEN2 ETH_MACACR_ATSEN2_Msk /* Auxiliary Snapshot 2 Enable */ |
| #define | ETH_MACACR_ATSEN1_Pos (5U) |
| #define | ETH_MACACR_ATSEN1_Msk (0x1UL << ETH_MACACR_ATSEN1_Pos) |
| #define | ETH_MACACR_ATSEN1 ETH_MACACR_ATSEN1_Msk /* Auxiliary Snapshot 1 Enable */ |
| #define | ETH_MACACR_ATSEN0_Pos (4U) |
| #define | ETH_MACACR_ATSEN0_Msk (0x1UL << ETH_MACACR_ATSEN0_Pos) |
| #define | ETH_MACACR_ATSEN0 ETH_MACACR_ATSEN0_Msk /* Auxiliary Snapshot 0 Enable */ |
| #define | ETH_MACACR_ATSFC_Pos (0U) |
| #define | ETH_MACACR_ATSFC_Msk (0x1UL << ETH_MACACR_ATSFC_Pos) |
| #define | ETH_MACACR_ATSFC ETH_MACACR_ATSFC_Msk /* Auxiliary Snapshot FIFO Clear */ |
| #define | ETH_MACATSNR_AUXTSLO_Pos (0U) |
| #define | ETH_MACATSNR_AUXTSLO_Msk (0x7FFFFFFFUL << ETH_MACATSNR_AUXTSLO_Pos) |
| #define | ETH_MACATSNR_AUXTSLO ETH_MACATSNR_AUXTSLO_Msk /* Auxiliary Timestamp */ |
| #define | ETH_MACATSSR_AUXTSHI_Pos (0U) |
| #define | ETH_MACATSSR_AUXTSHI_Msk (0xFFFFFFFFUL << ETH_MACATSSR_AUXTSHI_Pos) |
| #define | ETH_MACATSSR_AUXTSHI ETH_MACATSSR_AUXTSHI_Msk /* Auxiliary Timestamp */ |
| #define | ETH_MACTSIACR_OSTIAC_Pos (0U) |
| #define | ETH_MACTSIACR_OSTIAC_Msk (0xFFFFFFFFUL << ETH_MACTSIACR_OSTIAC_Pos) |
| #define | ETH_MACTSIACR_OSTIAC ETH_MACTSIACR_OSTIAC_Msk /* One-Step Timestamp Ingress Asymmetry Correction */ |
| #define | ETH_MACTSEACR_OSTEAC_Pos (0U) |
| #define | ETH_MACTSEACR_OSTEAC_Msk (0xFFFFFFFFUL << ETH_MACTSEACR_OSTEAC_Pos) |
| #define | ETH_MACTSEACR_OSTEAC ETH_MACTSEACR_OSTEAC_Msk /* One-Step Timestamp Egress Asymmetry Correction */ |
| #define | ETH_MACTSICNR_TSIC_Pos (0U) |
| #define | ETH_MACTSICNR_TSIC_Msk (0xFFFFFFFFUL << ETH_MACTSICNR_TSIC_Pos) |
| #define | ETH_MACTSICNR_TSIC ETH_MACTSICNR_TSIC_Msk /* Timestamp Ingress Correction */ |
| #define | ETH_MACTSECNR_TSEC_Pos (0U) |
| #define | ETH_MACTSECNR_TSEC_Msk (0xFFFFFFFFUL << ETH_MACTSECNR_TSEC_Pos) |
| #define | ETH_MACTSECNR_TSEC ETH_MACTSECNR_TSEC_Msk /* Timestamp Egress Correction */ |
| #define | ETH_MACPPSCR_TRGTMODSEL0_Pos (5U) |
| #define | ETH_MACPPSCR_TRGTMODSEL0_Msk (0x3UL << ETH_MACPPSCR_TRGTMODSEL0_Pos) |
| #define | ETH_MACPPSCR_TRGTMODSEL0 ETH_MACPPSCR_TRGTMODSEL0_Msk /* Target Time Register Mode for PPS Output */ |
| #define | ETH_MACPPSCR_PPSEN0_Pos (4U) |
| #define | ETH_MACPPSCR_PPSEN0_Msk (0x1UL << ETH_MACPPSCR_PPSEN0_Pos) |
| #define | ETH_MACPPSCR_PPSEN0 ETH_MACPPSCR_PPSEN0_Msk /* Flexible PPS Output Mode Enable */ |
| #define | ETH_MACPPSCR_PPSCTRL_Pos (0U) |
| #define | ETH_MACPPSCR_PPSCTRL_Msk (0xFUL << ETH_MACPPSCR_PPSCTRL_Pos) |
| #define | ETH_MACPPSCR_PPSCTRL ETH_MACPPSCR_PPSCTRL_Msk /* PPS Output Frequency Control */ |
| #define | ETH_MACPPSTTSR_TSTRH0_Pos (0U) |
| #define | ETH_MACPPSTTSR_TSTRH0_Msk (0xFFFFFFFFUL << ETH_MACPPSTTSR_TSTRH0_Pos) |
| #define | ETH_MACPPSTTSR_TSTRH0 ETH_MACPPSTTSR_TSTRH0_Msk /* PPS Target Time Seconds Register */ |
| #define | ETH_MACPPSTTNR_TRGTBUSY0_Pos (31U) |
| #define | ETH_MACPPSTTNR_TRGTBUSY0_Msk (0x1UL << ETH_MACPPSTTNR_TRGTBUSY0_Pos) |
| #define | ETH_MACPPSTTNR_TRGTBUSY0 ETH_MACPPSTTNR_TRGTBUSY0_Msk /* PPS Target Time Register Busy */ |
| #define | ETH_MACPPSTTNR_TTSL0_Pos (0U) |
| #define | ETH_MACPPSTTNR_TTSL0_Msk (0x7FFFFFFFUL << ETH_MACPPSTTNR_TTSL0_Pos) |
| #define | ETH_MACPPSTTNR_TTSL0 ETH_MACPPSTTNR_TTSL0_Msk /* Target Time Low for PPS Register */ |
| #define | ETH_MACPPSIR_PPSINT0_Pos (0U) |
| #define | ETH_MACPPSIR_PPSINT0_Msk (0xFFFFFFFFUL << ETH_MACPPSIR_PPSINT0_Pos) |
| #define | ETH_MACPPSIR_PPSINT0 ETH_MACPPSIR_PPSINT0_Msk /* PPS Output Signal Interval */ |
| #define | ETH_MACPPSWR_PPSWIDTH0_Pos (0U) |
| #define | ETH_MACPPSWR_PPSWIDTH0_Msk (0xFFFFFFFFUL << ETH_MACPPSWR_PPSWIDTH0_Pos) |
| #define | ETH_MACPPSWR_PPSWIDTH0 ETH_MACPPSWR_PPSWIDTH0_Msk /* PPS Output Signal Width */ |
| #define | ETH_MACPOCR_DN_Pos (8U) |
| #define | ETH_MACPOCR_DN_Msk (0xFFUL << ETH_MACPOCR_DN_Pos) |
| #define | ETH_MACPOCR_DN ETH_MACPOCR_DN_Msk /* Domain Number */ |
| #define | ETH_MACPOCR_DRRDIS_Pos (6U) |
| #define | ETH_MACPOCR_DRRDIS_Msk (0x1UL << ETH_MACPOCR_DRRDIS_Pos) |
| #define | ETH_MACPOCR_DRRDIS ETH_MACPOCR_DRRDIS_Msk /* Disable PTO Delay Request/Response response generation */ |
| #define | ETH_MACPOCR_APDREQTRIG_Pos (5U) |
| #define | ETH_MACPOCR_APDREQTRIG_Msk (0x1UL << ETH_MACPOCR_APDREQTRIG_Pos) |
| #define | ETH_MACPOCR_APDREQTRIG ETH_MACPOCR_APDREQTRIG_Msk /* Automatic PTP Pdelay_Req message Trigger */ |
| #define | ETH_MACPOCR_ASYNCTRIG_Pos (4U) |
| #define | ETH_MACPOCR_ASYNCTRIG_Msk (0x1UL << ETH_MACPOCR_ASYNCTRIG_Pos) |
| #define | ETH_MACPOCR_ASYNCTRIG ETH_MACPOCR_ASYNCTRIG_Msk /* Automatic PTP SYNC message Trigger */ |
| #define | ETH_MACPOCR_APDREQEN_Pos (2U) |
| #define | ETH_MACPOCR_APDREQEN_Msk (0x1UL << ETH_MACPOCR_APDREQEN_Pos) |
| #define | ETH_MACPOCR_APDREQEN ETH_MACPOCR_APDREQEN_Msk /* Automatic PTP Pdelay_Req message Enable */ |
| #define | ETH_MACPOCR_ASYNCEN_Pos (1U) |
| #define | ETH_MACPOCR_ASYNCEN_Msk (0x1UL << ETH_MACPOCR_ASYNCEN_Pos) |
| #define | ETH_MACPOCR_ASYNCEN ETH_MACPOCR_ASYNCEN_Msk /* Automatic PTP SYNC message Enable */ |
| #define | ETH_MACPOCR_PTOEN_Pos (0U) |
| #define | ETH_MACPOCR_PTOEN_Msk (0x1UL << ETH_MACPOCR_PTOEN_Pos) |
| #define | ETH_MACPOCR_PTOEN ETH_MACPOCR_PTOEN_Msk /* PTP Offload Enable */ |
| #define | ETH_MACSPI0R_SPI0_Pos (0U) |
| #define | ETH_MACSPI0R_SPI0_Msk (0xFFFFFFFFUL << ETH_MACSPI0R_SPI0_Pos) |
| #define | ETH_MACSPI0R_SPI0 ETH_MACSPI0R_SPI0_Msk /* Source Port Identity 0 */ |
| #define | ETH_MACSPI1R_SPI1_Pos (0U) |
| #define | ETH_MACSPI1R_SPI1_Msk (0xFFFFFFFFUL << ETH_MACSPI1R_SPI1_Pos) |
| #define | ETH_MACSPI1R_SPI1 ETH_MACSPI1R_SPI1_Msk /* Source Port Identity 1 */ |
| #define | ETH_MACSPI2R_SPI2_Pos (0U) |
| #define | ETH_MACSPI2R_SPI2_Msk (0xFFFFUL << ETH_MACSPI2R_SPI2_Pos) |
| #define | ETH_MACSPI2R_SPI2 ETH_MACSPI2R_SPI2_Msk /* Source Port Identity 2 */ |
| #define | ETH_MACLMIR_LMPDRI_Pos (24U) |
| #define | ETH_MACLMIR_LMPDRI_Msk (0xFFUL << ETH_MACLMIR_LMPDRI_Pos) |
| #define | ETH_MACLMIR_LMPDRI ETH_MACLMIR_LMPDRI_Msk /* Log Min Pdelay_Req Interval */ |
| #define | ETH_MACLMIR_DRSYNCR_Pos (8U) |
| #define | ETH_MACLMIR_DRSYNCR_Msk (0x7UL << ETH_MACLMIR_DRSYNCR_Pos) |
| #define | ETH_MACLMIR_DRSYNCR ETH_MACLMIR_DRSYNCR_Msk /* Delay_Req to SYNC Ratio */ |
| #define | ETH_MACLMIR_LSI_Pos (0U) |
| #define | ETH_MACLMIR_LSI_Msk (0xFFUL << ETH_MACLMIR_LSI_Pos) |
| #define | ETH_MACLMIR_LSI ETH_MACLMIR_LSI_Msk /* Log Sync Interval */ |
| #define | ETH_MTLOMR_CNTCLR_Pos (9U) |
| #define | ETH_MTLOMR_CNTCLR_Msk (0x1UL << ETH_MTLOMR_CNTCLR_Pos) |
| #define | ETH_MTLOMR_CNTCLR ETH_MTLOMR_CNTCLR_Msk /* Counters Reset */ |
| #define | ETH_MTLOMR_CNTPRST_Pos (8U) |
| #define | ETH_MTLOMR_CNTPRST_Msk (0x1UL << ETH_MTLOMR_CNTPRST_Pos) |
| #define | ETH_MTLOMR_CNTPRST ETH_MTLOMR_CNTPRST_Msk /* Counters Preset */ |
| #define | ETH_MTLOMR_DTXSTS_Pos (1U) |
| #define | ETH_MTLOMR_DTXSTS_Msk (0x1UL << ETH_MTLOMR_DTXSTS_Pos) |
| #define | ETH_MTLOMR_DTXSTS ETH_MTLOMR_DTXSTS_Msk /* Drop Transmit Status */ |
| #define | ETH_MTLISR_MACIS_Pos (16U) |
| #define | ETH_MTLISR_MACIS_Msk (0x1UL << ETH_MTLISR_MACIS_Pos) |
| #define | ETH_MTLISR_MACIS ETH_MTLISR_MACIS_Msk /* MAC Interrupt Status */ |
| #define | ETH_MTLISR_QIS_Pos (0U) |
| #define | ETH_MTLISR_QIS_Msk (0x1UL << ETH_MTLISR_QIS_Pos) |
| #define | ETH_MTLISR_QIS ETH_MTLISR_QIS_Msk /* Queue Interrupt status */ |
| #define | ETH_MTLTQOMR_TTC_Pos (4U) |
| #define | ETH_MTLTQOMR_TTC_Msk (0x7UL << ETH_MTLTQOMR_TTC_Pos) |
| #define | ETH_MTLTQOMR_TTC ETH_MTLTQOMR_TTC_Msk /* Transmit Threshold Control */ |
| #define | ETH_MTLTQOMR_TTC_32BITS (0U) /* 32 bits Threshold */ |
| #define | ETH_MTLTQOMR_TTC_64BITS (0x00000010U) /* 64 bits Threshold */ |
| #define | ETH_MTLTQOMR_TTC_96BITS (0x00000020U) /* 96 bits Threshold */ |
| #define | ETH_MTLTQOMR_TTC_128BITS (0x00000030U) /* 128 bits Threshold */ |
| #define | ETH_MTLTQOMR_TTC_192BITS (0x00000040U) /* 192 bits Threshold */ |
| #define | ETH_MTLTQOMR_TTC_256BITS (0x00000050U) /* 256 bits Threshold */ |
| #define | ETH_MTLTQOMR_TTC_384BITS (0x00000060U) /* 384 bits Threshold */ |
| #define | ETH_MTLTQOMR_TTC_512BITS (0x00000070U) /* 512 bits Threshold */ |
| #define | ETH_MTLTQOMR_TSF_Pos (1U) |
| #define | ETH_MTLTQOMR_TSF_Msk (0x1UL << ETH_MTLTQOMR_TSF_Pos) |
| #define | ETH_MTLTQOMR_TSF ETH_MTLTQOMR_TSF_Msk /* Transmit Store and Forward */ |
| #define | ETH_MTLTQOMR_FTQ_Pos (0U) |
| #define | ETH_MTLTQOMR_FTQ_Msk (0x1UL << ETH_MTLTQOMR_FTQ_Pos) |
| #define | ETH_MTLTQOMR_FTQ ETH_MTLTQOMR_FTQ_Msk /* Flush Transmit Queue */ |
| #define | ETH_MTLTQUR_UFCNTOVF_Pos (11U) |
| #define | ETH_MTLTQUR_UFCNTOVF_Msk (0x1UL << ETH_MTLTQUR_UFCNTOVF_Pos) |
| #define | ETH_MTLTQUR_UFCNTOVF ETH_MTLTQUR_UFCNTOVF_Msk /* Overflow Bit for Underflow Packet Counter */ |
| #define | ETH_MTLTQUR_UFPKTCNT_Pos (0U) |
| #define | ETH_MTLTQUR_UFPKTCNT_Msk (0x7FFUL << ETH_MTLTQUR_UFPKTCNT_Pos) |
| #define | ETH_MTLTQUR_UFPKTCNT ETH_MTLTQUR_UFPKTCNT_Msk /* Underflow Packet Counter */ |
| #define | ETH_MTLTQDR_STXSTSF_Pos (20U) |
| #define | ETH_MTLTQDR_STXSTSF_Msk (0x7UL << ETH_MTLTQDR_STXSTSF_Pos) |
| #define | ETH_MTLTQDR_STXSTSF ETH_MTLTQDR_STXSTSF_Msk /* Number of Status Words in the Tx Status FIFO of Queue */ |
| #define | ETH_MTLTQDR_PTXQ_Pos (16U) |
| #define | ETH_MTLTQDR_PTXQ_Msk (0x7UL << ETH_MTLTQDR_PTXQ_Pos) |
| #define | ETH_MTLTQDR_PTXQ ETH_MTLTQDR_PTXQ_Msk /* Number of Packets in the Transmit Queue */ |
| #define | ETH_MTLTQDR_TXSTSFSTS_Pos (5U) |
| #define | ETH_MTLTQDR_TXSTSFSTS_Msk (0x1UL << ETH_MTLTQDR_TXSTSFSTS_Pos) |
| #define | ETH_MTLTQDR_TXSTSFSTS ETH_MTLTQDR_TXSTSFSTS_Msk /* MTL Tx Status FIFO Full Status */ |
| #define | ETH_MTLTQDR_TXQSTS_Pos (4U) |
| #define | ETH_MTLTQDR_TXQSTS_Msk (0x1UL << ETH_MTLTQDR_TXQSTS_Pos) |
| #define | ETH_MTLTQDR_TXQSTS ETH_MTLTQDR_TXQSTS_Msk /* MTL Tx Queue Not Empty Status */ |
| #define | ETH_MTLTQDR_TWCSTS_Pos (3U) |
| #define | ETH_MTLTQDR_TWCSTS_Msk (0x1UL << ETH_MTLTQDR_TWCSTS_Pos) |
| #define | ETH_MTLTQDR_TWCSTS ETH_MTLTQDR_TWCSTS_Msk /* MTL Tx Queue Write Controller Status */ |
| #define | ETH_MTLTQDR_TRCSTS_Pos (1U) |
| #define | ETH_MTLTQDR_TRCSTS_Msk (0x3UL << ETH_MTLTQDR_TRCSTS_Pos) |
| #define | ETH_MTLTQDR_TRCSTS ETH_MTLTQDR_TRCSTS_Msk /* MTL Tx Queue Read Controller Status */ |
| #define | ETH_MTLTQDR_TRCSTS_IDLE (0U) /* Idle state */ |
| #define | ETH_MTLTQDR_TRCSTS_READ (0x00000002U) /* Read state (transferring data to the MAC transmitter) */ |
| #define | ETH_MTLTQDR_TRCSTS_WAITING (0x00000004U) /* Waiting for pending Tx Status from the MAC transmitter */ |
| #define | ETH_MTLTQDR_TRCSTS_FLUSHING (0x00000006U) /* Flushing the Tx queue because of the Packet Abort request from the MAC */ |
| #define | ETH_MTLTQDR_TXQPAUSED_Pos (0U) |
| #define | ETH_MTLTQDR_TXQPAUSED_Msk (0x1UL << ETH_MTLTQDR_TXQPAUSED_Pos) |
| #define | ETH_MTLTQDR_TXQPAUSED ETH_MTLTQDR_TXQPAUSED_Msk /* Transmit Queue in Pause */ |
| #define | ETH_MTLQICSR_RXOIE_Pos (24U) |
| #define | ETH_MTLQICSR_RXOIE_Msk (0x1UL << ETH_MTLQICSR_RXOIE_Pos) |
| #define | ETH_MTLQICSR_RXOIE ETH_MTLQICSR_RXOIE_Msk /* Receive Queue Overflow Interrupt Enable */ |
| #define | ETH_MTLQICSR_RXOVFIS_Pos (16U) |
| #define | ETH_MTLQICSR_RXOVFIS_Msk (0x1UL << ETH_MTLQICSR_RXOVFIS_Pos) |
| #define | ETH_MTLQICSR_RXOVFIS ETH_MTLQICSR_RXOVFIS_Msk /* Receive Queue Overflow Interrupt Status */ |
| #define | ETH_MTLQICSR_TXUIE_Pos (8U) |
| #define | ETH_MTLQICSR_TXUIE_Msk (0x1UL << ETH_MTLQICSR_TXUIE_Pos) |
| #define | ETH_MTLQICSR_TXUIE ETH_MTLQICSR_TXUIE_Msk /* Transmit Queue Underflow Interrupt Enable */ |
| #define | ETH_MTLQICSR_TXUNFIS_Pos (0U) |
| #define | ETH_MTLQICSR_TXUNFIS_Msk (0x1UL << ETH_MTLQICSR_TXUNFIS_Pos) |
| #define | ETH_MTLQICSR_TXUNFIS ETH_MTLQICSR_TXUNFIS_Msk /* Transmit Queue Underflow Interrupt Status */ |
| #define | ETH_MTLRQOMR_RQS_Pos (20U) |
| #define | ETH_MTLRQOMR_RQS_Msk (0x7UL << ETH_MTLRQOMR_RQS_Pos) |
| #define | ETH_MTLRQOMR_RQS ETH_MTLRQOMR_RQS_Msk /* Receive Queue Size */ |
| #define | ETH_MTLRQOMR_RFD_Pos (14U) |
| #define | ETH_MTLRQOMR_RFD_Msk (0x7UL << ETH_MTLRQOMR_RFD_Pos) |
| #define | ETH_MTLRQOMR_RFD ETH_MTLRQOMR_RFD_Msk /* Threshold for Deactivating Flow Control (in half-duplex and full-duplex modes) */ |
| #define | ETH_MTLRQOMR_RFA_Pos (8U) |
| #define | ETH_MTLRQOMR_RFA_Msk (0x7UL << ETH_MTLRQOMR_RFA_Pos) |
| #define | ETH_MTLRQOMR_RFA ETH_MTLRQOMR_RFA_Msk /* Threshold for Activating Flow Control (in half-duplex and full-duplex */ |
| #define | ETH_MTLRQOMR_EHFC_Pos (7U) |
| #define | ETH_MTLRQOMR_EHFC_Msk (0x1UL << ETH_MTLRQOMR_EHFC_Pos) |
| #define | ETH_MTLRQOMR_EHFC ETH_MTLRQOMR_EHFC_Msk /* DEnable Hardware Flow Control */ |
| #define | ETH_MTLRQOMR_DISTCPEF_Pos (6U) |
| #define | ETH_MTLRQOMR_DISTCPEF_Msk (0x1UL << ETH_MTLRQOMR_DISTCPEF_Pos) |
| #define | ETH_MTLRQOMR_DISTCPEF ETH_MTLRQOMR_DISTCPEF_Msk /* Disable Dropping of TCP/IP Checksum Error Packets */ |
| #define | ETH_MTLRQOMR_RSF_Pos (5U) |
| #define | ETH_MTLRQOMR_RSF_Msk (0x1UL << ETH_MTLRQOMR_RSF_Pos) |
| #define | ETH_MTLRQOMR_RSF ETH_MTLRQOMR_RSF_Msk /* Receive Queue Store and Forward */ |
| #define | ETH_MTLRQOMR_FEP_Pos (4U) |
| #define | ETH_MTLRQOMR_FEP_Msk (0x1UL << ETH_MTLRQOMR_FEP_Pos) |
| #define | ETH_MTLRQOMR_FEP ETH_MTLRQOMR_FEP_Msk /* Forward Error Packets */ |
| #define | ETH_MTLRQOMR_FUP_Pos (3U) |
| #define | ETH_MTLRQOMR_FUP_Msk (0x1UL << ETH_MTLRQOMR_FUP_Pos) |
| #define | ETH_MTLRQOMR_FUP ETH_MTLRQOMR_FUP_Msk /* Forward Undersized Good Packets */ |
| #define | ETH_MTLRQOMR_RTC_Pos (0U) |
| #define | ETH_MTLRQOMR_RTC_Msk (0x3UL << ETH_MTLRQOMR_RTC_Pos) |
| #define | ETH_MTLRQOMR_RTC ETH_MTLRQOMR_RTC_Msk /* Receive Queue Threshold Control */ |
| #define | ETH_MTLRQOMR_RTC_64BITS (0U) /* 64 bits Threshold */ |
| #define | ETH_MTLRQOMR_RTC_32BITS (0x00000001U) /* 32 bits Threshold */ |
| #define | ETH_MTLRQOMR_RTC_96BITS (0x00000002U) /* 96 bits Threshold */ |
| #define | ETH_MTLRQOMR_RTC_128BITS (0x00000003U) /* 128 bits Threshold */ |
| #define | ETH_MTLRQMPOCR_MISCNTOVF_Pos (27U) |
| #define | ETH_MTLRQMPOCR_MISCNTOVF_Msk (0x1UL << ETH_MTLRQMPOCR_MISCNTOVF_Pos) |
| #define | ETH_MTLRQMPOCR_MISCNTOVF ETH_MTLRQMPOCR_MISCNTOVF_Msk /* Missed Packet Counter Overflow Bit */ |
| #define | ETH_MTLRQMPOCR_MISPKTCNT_Pos (16U) |
| #define | ETH_MTLRQMPOCR_MISPKTCNT_Msk (0x7FFUL << ETH_MTLRQMPOCR_MISPKTCNT_Pos) |
| #define | ETH_MTLRQMPOCR_MISPKTCNT ETH_MTLRQMPOCR_MISPKTCNT_Msk /* Missed Packet Counter */ |
| #define | ETH_MTLRQMPOCR_OVFCNTOVF_Pos (11U) |
| #define | ETH_MTLRQMPOCR_OVFCNTOVF_Msk (0x1UL << ETH_MTLRQMPOCR_OVFCNTOVF_Pos) |
| #define | ETH_MTLRQMPOCR_OVFCNTOVF ETH_MTLRQMPOCR_OVFCNTOVF_Msk /* Overflow Counter Overflow Bit */ |
| #define | ETH_MTLRQMPOCR_OVFPKTCNT_Pos (0U) |
| #define | ETH_MTLRQMPOCR_OVFPKTCNT_Msk (0x7FFUL << ETH_MTLRQMPOCR_OVFPKTCNT_Pos) |
| #define | ETH_MTLRQMPOCR_OVFPKTCNT ETH_MTLRQMPOCR_OVFPKTCNT_Msk /* Overflow Packet Counter */ |
| #define | ETH_MTLRQDR_PRXQ_Pos (16U) |
| #define | ETH_MTLRQDR_PRXQ_Msk (0x3FFFUL << ETH_MTLRQDR_PRXQ_Pos) |
| #define | ETH_MTLRQDR_PRXQ ETH_MTLRQDR_PRXQ_Msk /* Number of Packets in Receive Queue */ |
| #define | ETH_MTLRQDR_RXQSTS_Pos (4U) |
| #define | ETH_MTLRQDR_RXQSTS_Msk (0x3UL << ETH_MTLRQDR_RXQSTS_Pos) |
| #define | ETH_MTLRQDR_RXQSTS ETH_MTLRQDR_RXQSTS_Msk /* MTL Rx Queue Fill-Level Status */ |
| #define | ETH_MTLRQDR_RXQSTS_EMPTY (0U) /* Rx Queue empty */ |
| #define | ETH_MTLRQDR_RXQSTS_BELOWTHRESHOLD_Pos (4U) |
| #define | ETH_MTLRQDR_RXQSTS_BELOWTHRESHOLD_Msk (0x1UL << ETH_MTLRQDR_RXQSTS_BELOWTHRESHOLD_Pos) |
| #define | ETH_MTLRQDR_RXQSTS_BELOWTHRESHOLD ETH_MTLRQDR_RXQSTS_BELOWTHRESHOLD_Msk /* Rx Queue fill-level below flow-control deactivate threshold */ |
| #define | ETH_MTLRQDR_RXQSTS_ABOVETHRESHOLD_Pos (5U) |
| #define | ETH_MTLRQDR_RXQSTS_ABOVETHRESHOLD_Msk (0x1UL << ETH_MTLRQDR_RXQSTS_ABOVETHRESHOLD_Pos) |
| #define | ETH_MTLRQDR_RXQSTS_ABOVETHRESHOLD ETH_MTLRQDR_RXQSTS_ABOVETHRESHOLD_Msk /* Rx Queue fill-level above flow-control activate threshold */ |
| #define | ETH_MTLRQDR_RXQSTS_FULL_Pos (4U) |
| #define | ETH_MTLRQDR_RXQSTS_FULL_Msk (0x3UL << ETH_MTLRQDR_RXQSTS_FULL_Pos) |
| #define | ETH_MTLRQDR_RXQSTS_FULL ETH_MTLRQDR_RXQSTS_FULL_Msk /* Rx Queue full */ |
| #define | ETH_MTLRQDR_RRCSTS_Pos (1U) |
| #define | ETH_MTLRQDR_RRCSTS_Msk (0x3UL << ETH_MTLRQDR_RRCSTS_Pos) |
| #define | ETH_MTLRQDR_RRCSTS ETH_MTLRQDR_RRCSTS_Msk /* MTL Rx Queue Read Controller State */ |
| #define | ETH_MTLRQDR_RRCSTS_IDLE (0U) /* Idle state */ |
| #define | ETH_MTLRQDR_RRCSTS_READINGDATA_Pos (1U) |
| #define | ETH_MTLRQDR_RRCSTS_READINGDATA_Msk (0x1UL << ETH_MTLRQDR_RRCSTS_READINGDATA_Pos) |
| #define | ETH_MTLRQDR_RRCSTS_READINGDATA ETH_MTLRQDR_RRCSTS_READINGDATA_Msk /* Reading packet data */ |
| #define | ETH_MTLRQDR_RRCSTS_READINGSTATUS_Pos (2U) |
| #define | ETH_MTLRQDR_RRCSTS_READINGSTATUS_Msk (0x1UL << ETH_MTLRQDR_RRCSTS_READINGSTATUS_Pos) |
| #define | ETH_MTLRQDR_RRCSTS_READINGSTATUS ETH_MTLRQDR_RRCSTS_READINGSTATUS_Msk /* Reading packet status (or timestamp) */ |
| #define | ETH_MTLRQDR_RRCSTS_FLUSHING_Pos (1U) |
| #define | ETH_MTLRQDR_RRCSTS_FLUSHING_Msk (0x3UL << ETH_MTLRQDR_RRCSTS_FLUSHING_Pos) |
| #define | ETH_MTLRQDR_RRCSTS_FLUSHING ETH_MTLRQDR_RRCSTS_FLUSHING_Msk /* Flushing the packet data and status */ |
| #define | ETH_MTLRQDR_RWCSTS_Pos (0U) |
| #define | ETH_MTLRQDR_RWCSTS_Msk (0x1UL << ETH_MTLRQDR_RWCSTS_Pos) |
| #define | ETH_MTLRQDR_RWCSTS ETH_MTLRQDR_RWCSTS_Msk /* MTL Rx Queue Write Controller Active Status */ |
| #define | ETH_MTLRQCR_RQPA_Pos (3U) |
| #define | ETH_MTLRQCR_RQPA_Msk (0x1UL << ETH_MTLRQCR_RQPA_Pos) |
| #define | ETH_MTLRQCR_RQPA ETH_MTLRQCR_RQPA_Msk /* Receive Queue Packet Arbitration */ |
| #define | ETH_MTLRQCR_RQW_Pos (0U) |
| #define | ETH_MTLRQCR_RQW_Msk (0x7UL << ETH_MTLRQCR_RQW_Pos) |
| #define | ETH_MTLRQCR_RQW ETH_MTLRQCR_RQW_Msk /* Receive Queue Weight */ |
| #define | ETH_DMAMR_INTM_Pos (16U) |
| #define | ETH_DMAMR_INTM_Msk (0x3UL << ETH_DMAMR_INTM_Pos) |
| #define | ETH_DMAMR_INTM ETH_DMAMR_INTM_Msk /* This field defines the interrupt mode */ |
| #define | ETH_DMAMR_INTM_0 (0x0UL << ETH_DMAMR_INTM_Pos) |
| #define | ETH_DMAMR_INTM_1 (0x1UL << ETH_DMAMR_INTM_Pos) |
| #define | ETH_DMAMR_INTM_2 (0x2UL << ETH_DMAMR_INTM_Pos) |
| #define | ETH_DMAMR_PR_Pos (12U) |
| #define | ETH_DMAMR_PR_Msk (0x7UL << ETH_DMAMR_PR_Pos) |
| #define | ETH_DMAMR_PR ETH_DMAMR_PR_Msk /* Priority Ratio */ |
| #define | ETH_DMAMR_PR_1_1 (0U) /* The priority ratio is 1:1 */ |
| #define | ETH_DMAMR_PR_2_1 (0x00001000U) /* The priority ratio is 2:1 */ |
| #define | ETH_DMAMR_PR_3_1 (0x00002000U) /* The priority ratio is 3:1 */ |
| #define | ETH_DMAMR_PR_4_1 (0x00003000U) /* The priority ratio is 4:1 */ |
| #define | ETH_DMAMR_PR_5_1 (0x00004000U) /* The priority ratio is 5:1 */ |
| #define | ETH_DMAMR_PR_6_1 (0x00005000U) /* The priority ratio is 6:1 */ |
| #define | ETH_DMAMR_PR_7_1 (0x00006000U) /* The priority ratio is 7:1 */ |
| #define | ETH_DMAMR_PR_8_1 (0x00007000U) /* The priority ratio is 8:1 */ |
| #define | ETH_DMAMR_TXPR_Pos (11U) |
| #define | ETH_DMAMR_TXPR_Msk (0x1UL << ETH_DMAMR_TXPR_Pos) |
| #define | ETH_DMAMR_TXPR ETH_DMAMR_TXPR_Msk /* Transmit Priority */ |
| #define | ETH_DMAMR_DA_Pos (1U) |
| #define | ETH_DMAMR_DA_Msk (0x1UL << ETH_DMAMR_DA_Pos) |
| #define | ETH_DMAMR_DA ETH_DMAMR_DA_Msk /* DMA Tx or Rx Arbitration Scheme */ |
| #define | ETH_DMAMR_SWR_Pos (0U) |
| #define | ETH_DMAMR_SWR_Msk (0x1UL << ETH_DMAMR_SWR_Pos) |
| #define | ETH_DMAMR_SWR ETH_DMAMR_SWR_Msk /* Software Reset */ |
| #define | ETH_DMASBMR_RB_Pos (15U) |
| #define | ETH_DMASBMR_RB_Msk (0x1UL << ETH_DMASBMR_RB_Pos) |
| #define | ETH_DMASBMR_RB ETH_DMASBMR_RB_Msk /* Rebuild INCRx Burst */ |
| #define | ETH_DMASBMR_MB_Pos (14U) |
| #define | ETH_DMASBMR_MB_Msk (0x1UL << ETH_DMASBMR_MB_Pos) |
| #define | ETH_DMASBMR_MB ETH_DMASBMR_MB_Msk /* Mixed Burst */ |
| #define | ETH_DMASBMR_AAL_Pos (12U) |
| #define | ETH_DMASBMR_AAL_Msk (0x1UL << ETH_DMASBMR_AAL_Pos) |
| #define | ETH_DMASBMR_AAL ETH_DMASBMR_AAL_Msk /* Address-Aligned Beats */ |
| #define | ETH_DMASBMR_FB_Pos (0U) |
| #define | ETH_DMASBMR_FB_Msk (0x1UL << ETH_DMASBMR_FB_Pos) |
| #define | ETH_DMASBMR_FB ETH_DMASBMR_FB_Msk /* Fixed Burst Length */ |
| #define | ETH_DMAISR_MACIS_Pos (17U) |
| #define | ETH_DMAISR_MACIS_Msk (0x1UL << ETH_DMAISR_MACIS_Pos) |
| #define | ETH_DMAISR_MACIS ETH_DMAISR_MACIS_Msk /* MAC Interrupt Status */ |
| #define | ETH_DMAISR_MTLIS_Pos (16U) |
| #define | ETH_DMAISR_MTLIS_Msk (0x1UL << ETH_DMAISR_MTLIS_Pos) |
| #define | ETH_DMAISR_MTLIS ETH_DMAISR_MTLIS_Msk /* MAC Interrupt Status */ |
| #define | ETH_DMAISR_DMACIS_Pos (0U) |
| #define | ETH_DMAISR_DMACIS_Msk (0x1UL << ETH_DMAISR_DMACIS_Pos) |
| #define | ETH_DMAISR_DMACIS ETH_DMAISR_DMACIS_Msk /* DMA Channel Interrupt Status */ |
| #define | ETH_DMADSR_TPS_Pos (12U) |
| #define | ETH_DMADSR_TPS_Msk (0xFUL << ETH_DMADSR_TPS_Pos) |
| #define | ETH_DMADSR_TPS ETH_DMADSR_TPS_Msk /* DMA Channel Transmit Process State */ |
| #define | ETH_DMADSR_TPS_STOPPED (0U) /* Stopped (Reset or Stop Transmit Command issued) */ |
| #define | ETH_DMADSR_TPS_FETCHING_Pos (12U) |
| #define | ETH_DMADSR_TPS_FETCHING_Msk (0x1UL << ETH_DMADSR_TPS_FETCHING_Pos) |
| #define | ETH_DMADSR_TPS_FETCHING ETH_DMADSR_TPS_FETCHING_Msk /* Running (Fetching Tx Transfer Descriptor) */ |
| #define | ETH_DMADSR_TPS_WAITING_Pos (13U) |
| #define | ETH_DMADSR_TPS_WAITING_Msk (0x1UL << ETH_DMADSR_TPS_WAITING_Pos) |
| #define | ETH_DMADSR_TPS_WAITING ETH_DMADSR_TPS_WAITING_Msk /* Running (Waiting for status) */ |
| #define | ETH_DMADSR_TPS_READING_Pos (12U) |
| #define | ETH_DMADSR_TPS_READING_Msk (0x3UL << ETH_DMADSR_TPS_READING_Pos) |
| #define | ETH_DMADSR_TPS_READING ETH_DMADSR_TPS_READING_Msk /* Running (Reading Data from system memory buffer and queuing it to the Tx buffer (Tx FIFO)) */ |
| #define | ETH_DMADSR_TPS_TIMESTAMP_WR_Pos (14U) |
| #define | ETH_DMADSR_TPS_TIMESTAMP_WR_Msk (0x1UL << ETH_DMADSR_TPS_TIMESTAMP_WR_Pos) |
| #define | ETH_DMADSR_TPS_TIMESTAMP_WR ETH_DMADSR_TPS_TIMESTAMP_WR_Msk /* Timestamp write state */ |
| #define | ETH_DMADSR_TPS_SUSPENDED_Pos (13U) |
| #define | ETH_DMADSR_TPS_SUSPENDED_Msk (0x3UL << ETH_DMADSR_TPS_SUSPENDED_Pos) |
| #define | ETH_DMADSR_TPS_SUSPENDED ETH_DMADSR_TPS_SUSPENDED_Msk /* Suspended (Tx Descriptor Unavailable or Tx Buffer Underflow) */ |
| #define | ETH_DMADSR_TPS_CLOSING_Pos (12U) |
| #define | ETH_DMADSR_TPS_CLOSING_Msk (0x7UL << ETH_DMADSR_TPS_CLOSING_Pos) |
| #define | ETH_DMADSR_TPS_CLOSING ETH_DMADSR_TPS_CLOSING_Msk /* Running (Closing Tx Descriptor) */ |
| #define | ETH_DMADSR_RPS_Pos (8U) |
| #define | ETH_DMADSR_RPS_Msk (0xFUL << ETH_DMADSR_RPS_Pos) |
| #define | ETH_DMADSR_RPS ETH_DMADSR_RPS_Msk /* DMA Channel Receive Process State */ |
| #define | ETH_DMADSR_RPS_STOPPED (0U) /* Stopped (Reset or Stop Receive Command issued) */ |
| #define | ETH_DMADSR_RPS_FETCHING_Pos (12U) |
| #define | ETH_DMADSR_RPS_FETCHING_Msk (0x1UL << ETH_DMADSR_RPS_FETCHING_Pos) |
| #define | ETH_DMADSR_RPS_FETCHING ETH_DMADSR_RPS_FETCHING_Msk /* Running (Fetching Rx Transfer Descriptor) */ |
| #define | ETH_DMADSR_RPS_WAITING_Pos (12U) |
| #define | ETH_DMADSR_RPS_WAITING_Msk (0x3UL << ETH_DMADSR_RPS_WAITING_Pos) |
| #define | ETH_DMADSR_RPS_WAITING ETH_DMADSR_RPS_WAITING_Msk /* Running (Waiting for status) */ |
| #define | ETH_DMADSR_RPS_SUSPENDED_Pos (14U) |
| #define | ETH_DMADSR_RPS_SUSPENDED_Msk (0x1UL << ETH_DMADSR_RPS_SUSPENDED_Pos) |
| #define | ETH_DMADSR_RPS_SUSPENDED ETH_DMADSR_RPS_SUSPENDED_Msk /* Suspended (Rx Descriptor Unavailable) */ |
| #define | ETH_DMADSR_RPS_CLOSING_Pos (12U) |
| #define | ETH_DMADSR_RPS_CLOSING_Msk (0x5UL << ETH_DMADSR_RPS_CLOSING_Pos) |
| #define | ETH_DMADSR_RPS_CLOSING ETH_DMADSR_RPS_CLOSING_Msk /* Running (Closing the Rx Descriptor) */ |
| #define | ETH_DMADSR_RPS_TIMESTAMP_WR_Pos (13U) |
| #define | ETH_DMADSR_RPS_TIMESTAMP_WR_Msk (0x3UL << ETH_DMADSR_RPS_TIMESTAMP_WR_Pos) |
| #define | ETH_DMADSR_RPS_TIMESTAMP_WR ETH_DMADSR_RPS_TIMESTAMP_WR_Msk /* Timestamp write state */ |
| #define | ETH_DMADSR_RPS_TRANSFERRING_Pos (12U) |
| #define | ETH_DMADSR_RPS_TRANSFERRING_Msk (0x7UL << ETH_DMADSR_RPS_TRANSFERRING_Pos) |
| #define | ETH_DMADSR_RPS_TRANSFERRING ETH_DMADSR_RPS_TRANSFERRING_Msk /* Running (Transferring the received packet data from the Rx buffer to the system memory) */ |
| #define | ETH_DMACCR_DSL_Pos (18U) |
| #define | ETH_DMACCR_DSL_Msk (0x7UL << ETH_DMACCR_DSL_Pos) |
| #define | ETH_DMACCR_DSL ETH_DMACCR_DSL_Msk /* Descriptor Skip Length */ |
| #define | ETH_DMACCR_DSL_0BIT (0U) |
| #define | ETH_DMACCR_DSL_32BIT (0x00040000U) |
| #define | ETH_DMACCR_DSL_64BIT (0x00080000U) |
| #define | ETH_DMACCR_DSL_128BIT (0x00100000U) |
| #define | ETH_DMACCR_8PBL (0x00010000U) /* 8xPBL mode */ |
| #define | ETH_DMACCR_MSS_Pos (0U) |
| #define | ETH_DMACCR_MSS_Msk (0x3FFFUL << ETH_DMACCR_MSS_Pos) |
| #define | ETH_DMACCR_MSS ETH_DMACCR_MSS_Msk /* Maximum Segment Size */ |
| #define | ETH_DMACTCR_TPBL_Pos (16U) |
| #define | ETH_DMACTCR_TPBL_Msk (0x3FUL << ETH_DMACTCR_TPBL_Pos) |
| #define | ETH_DMACTCR_TPBL ETH_DMACTCR_TPBL_Msk /* Transmit Programmable Burst Length */ |
| #define | ETH_DMACTCR_TPBL_1PBL (0x00010000U) /* Transmit Programmable Burst Length 1 */ |
| #define | ETH_DMACTCR_TPBL_2PBL (0x00020000U) /* Transmit Programmable Burst Length 2 */ |
| #define | ETH_DMACTCR_TPBL_4PBL (0x00040000U) /* Transmit Programmable Burst Length 4 */ |
| #define | ETH_DMACTCR_TPBL_8PBL (0x00080000U) /* Transmit Programmable Burst Length 8 */ |
| #define | ETH_DMACTCR_TPBL_16PBL (0x00100000U) /* Transmit Programmable Burst Length 16 */ |
| #define | ETH_DMACTCR_TPBL_32PBL (0x00200000U) /* Transmit Programmable Burst Length 32 */ |
| #define | ETH_DMACTCR_TSE_Pos (12U) |
| #define | ETH_DMACTCR_TSE_Msk (0x1UL << ETH_DMACTCR_TSE_Pos) |
| #define | ETH_DMACTCR_TSE ETH_DMACTCR_TSE_Msk /* TCP Segmentation Enabled */ |
| #define | ETH_DMACTCR_OSP_Pos (4U) |
| #define | ETH_DMACTCR_OSP_Msk (0x1UL << ETH_DMACTCR_OSP_Pos) |
| #define | ETH_DMACTCR_OSP ETH_DMACTCR_OSP_Msk /* Operate on Second Packet */ |
| #define | ETH_DMACTCR_ST_Pos (0U) |
| #define | ETH_DMACTCR_ST_Msk (0x1UL << ETH_DMACTCR_ST_Pos) |
| #define | ETH_DMACTCR_ST ETH_DMACTCR_ST_Msk /* Start or Stop Transmission Command */ |
| #define | ETH_DMACRCR_RPF_Pos (31U) |
| #define | ETH_DMACRCR_RPF_Msk (0x1UL << ETH_DMACRCR_RPF_Pos) |
| #define | ETH_DMACRCR_RPF ETH_DMACRCR_RPF_Msk /* Rx Packet Flush */ |
| #define | ETH_DMACRCR_RPBL_Pos (16U) |
| #define | ETH_DMACRCR_RPBL_Msk (0x3FUL << ETH_DMACRCR_RPBL_Pos) |
| #define | ETH_DMACRCR_RPBL ETH_DMACRCR_RPBL_Msk /* Receive Programmable Burst Length */ |
| #define | ETH_DMACRCR_RPBL_1PBL (0x00010000U) /* Receive Programmable Burst Length 1 */ |
| #define | ETH_DMACRCR_RPBL_2PBL (0x00020000U) /* Receive Programmable Burst Length 2 */ |
| #define | ETH_DMACRCR_RPBL_4PBL (0x00040000U) /* Receive Programmable Burst Length 4 */ |
| #define | ETH_DMACRCR_RPBL_8PBL (0x00080000U) /* Receive Programmable Burst Length 8 */ |
| #define | ETH_DMACRCR_RPBL_16PBL (0x00100000U) /* Receive Programmable Burst Length 16 */ |
| #define | ETH_DMACRCR_RPBL_32PBL (0x00200000U) /* Receive Programmable Burst Length 32 */ |
| #define | ETH_DMACRCR_RBSZ_Pos (1U) |
| #define | ETH_DMACRCR_RBSZ_Msk (0x3FFFUL << ETH_DMACRCR_RBSZ_Pos) |
| #define | ETH_DMACRCR_RBSZ ETH_DMACRCR_RBSZ_Msk /* Receive Buffer size */ |
| #define | ETH_DMACRCR_SR_Pos (0U) |
| #define | ETH_DMACRCR_SR_Msk (0x1UL << ETH_DMACRCR_SR_Pos) |
| #define | ETH_DMACRCR_SR ETH_DMACRCR_SR_Msk /* Start or Stop Receive */ |
| #define | ETH_DMACTDLAR_TDESLA_Pos (2U) |
| #define | ETH_DMACTDLAR_TDESLA_Msk (0x3FFFFFFFUL << ETH_DMACTDLAR_TDESLA_Pos) |
| #define | ETH_DMACTDLAR_TDESLA ETH_DMACTDLAR_TDESLA_Msk /* Start of Transmit List */ |
| #define | ETH_DMACRDLAR_RDESLA_Pos (2U) |
| #define | ETH_DMACRDLAR_RDESLA_Msk (0x3FFFFFFFUL << ETH_DMACRDLAR_RDESLA_Pos) |
| #define | ETH_DMACRDLAR_RDESLA ETH_DMACRDLAR_RDESLA_Msk /* Start of Receive List */ |
| #define | ETH_DMACTDTPR_TDT_Pos (2U) |
| #define | ETH_DMACTDTPR_TDT_Msk (0x3FFFFFFFUL << ETH_DMACTDTPR_TDT_Pos) |
| #define | ETH_DMACTDTPR_TDT ETH_DMACTDTPR_TDT_Msk /* Transmit Descriptor Tail Pointer */ |
| #define | ETH_DMACRDTPR_RDT_Pos (2U) |
| #define | ETH_DMACRDTPR_RDT_Msk (0x3FFFFFFFUL << ETH_DMACRDTPR_RDT_Pos) |
| #define | ETH_DMACRDTPR_RDT ETH_DMACRDTPR_RDT_Msk /* Receive Descriptor Tail Pointer */ |
| #define | ETH_DMACTDRLR_TDRL_Pos (0U) |
| #define | ETH_DMACTDRLR_TDRL_Msk (0x3FFUL << ETH_DMACTDRLR_TDRL_Pos) |
| #define | ETH_DMACTDRLR_TDRL ETH_DMACTDRLR_TDRL_Msk /* Transmit Descriptor Ring Length */ |
| #define | ETH_DMACRDRLR_RDRL_Pos (0U) |
| #define | ETH_DMACRDRLR_RDRL_Msk (0x3FFUL << ETH_DMACRDRLR_RDRL_Pos) |
| #define | ETH_DMACRDRLR_RDRL ETH_DMACRDRLR_RDRL_Msk /* Receive Descriptor Ring Length */ |
| #define | ETH_DMACIER_NIE_Pos (15U) |
| #define | ETH_DMACIER_NIE_Msk (0x1UL << ETH_DMACIER_NIE_Pos) |
| #define | ETH_DMACIER_NIE ETH_DMACIER_NIE_Msk /* Normal Interrupt Summary Enable */ |
| #define | ETH_DMACIER_AIE_Pos (14U) |
| #define | ETH_DMACIER_AIE_Msk (0x1UL << ETH_DMACIER_AIE_Pos) |
| #define | ETH_DMACIER_AIE ETH_DMACIER_AIE_Msk /* Abnormal Interrupt Summary Enable */ |
| #define | ETH_DMACIER_CDEE_Pos (13U) |
| #define | ETH_DMACIER_CDEE_Msk (0x1UL << ETH_DMACIER_CDEE_Pos) |
| #define | ETH_DMACIER_CDEE ETH_DMACIER_CDEE_Msk /* Context Descriptor Error Enable */ |
| #define | ETH_DMACIER_FBEE_Pos (12U) |
| #define | ETH_DMACIER_FBEE_Msk (0x1UL << ETH_DMACIER_FBEE_Pos) |
| #define | ETH_DMACIER_FBEE ETH_DMACIER_FBEE_Msk /* Fatal Bus Error Enable */ |
| #define | ETH_DMACIER_ERIE_Pos (11U) |
| #define | ETH_DMACIER_ERIE_Msk (0x1UL << ETH_DMACIER_ERIE_Pos) |
| #define | ETH_DMACIER_ERIE ETH_DMACIER_ERIE_Msk /* Early Receive Interrupt Enable */ |
| #define | ETH_DMACIER_ETIE_Pos (10U) |
| #define | ETH_DMACIER_ETIE_Msk (0x1UL << ETH_DMACIER_ETIE_Pos) |
| #define | ETH_DMACIER_ETIE ETH_DMACIER_ETIE_Msk /* Early Transmit Interrupt Enable */ |
| #define | ETH_DMACIER_RWTE_Pos (9U) |
| #define | ETH_DMACIER_RWTE_Msk (0x1UL << ETH_DMACIER_RWTE_Pos) |
| #define | ETH_DMACIER_RWTE ETH_DMACIER_RWTE_Msk /* Receive Watchdog Timeout Enable */ |
| #define | ETH_DMACIER_RSE_Pos (8U) |
| #define | ETH_DMACIER_RSE_Msk (0x1UL << ETH_DMACIER_RSE_Pos) |
| #define | ETH_DMACIER_RSE ETH_DMACIER_RSE_Msk /* Receive Stopped Enable */ |
| #define | ETH_DMACIER_RBUE_Pos (7U) |
| #define | ETH_DMACIER_RBUE_Msk (0x1UL << ETH_DMACIER_RBUE_Pos) |
| #define | ETH_DMACIER_RBUE ETH_DMACIER_RBUE_Msk /* Receive Buffer Unavailable Enable */ |
| #define | ETH_DMACIER_RIE_Pos (6U) |
| #define | ETH_DMACIER_RIE_Msk (0x1UL << ETH_DMACIER_RIE_Pos) |
| #define | ETH_DMACIER_RIE ETH_DMACIER_RIE_Msk /* Receive Interrupt Enable */ |
| #define | ETH_DMACIER_TBUE_Pos (2U) |
| #define | ETH_DMACIER_TBUE_Msk (0x1UL << ETH_DMACIER_TBUE_Pos) |
| #define | ETH_DMACIER_TBUE ETH_DMACIER_TBUE_Msk /* Transmit Buffer Unavailable Enable */ |
| #define | ETH_DMACIER_TXSE_Pos (1U) |
| #define | ETH_DMACIER_TXSE_Msk (0x1UL << ETH_DMACIER_TXSE_Pos) |
| #define | ETH_DMACIER_TXSE ETH_DMACIER_TXSE_Msk /* Transmit Stopped Enable */ |
| #define | ETH_DMACIER_TIE_Pos (0U) |
| #define | ETH_DMACIER_TIE_Msk (0x1UL << ETH_DMACIER_TIE_Pos) |
| #define | ETH_DMACIER_TIE ETH_DMACIER_TIE_Msk /* Transmit Interrupt Enable */ |
| #define | ETH_DMACRIWTR_RWT_Pos (0U) |
| #define | ETH_DMACRIWTR_RWT_Msk (0xFFUL << ETH_DMACRIWTR_RWT_Pos) |
| #define | ETH_DMACRIWTR_RWT ETH_DMACRIWTR_RWT_Msk /* Receive Interrupt Watchdog Timer Count */ |
| #define | ETH_DMACCATDR_CURTDESAPTR_Pos (0U) |
| #define | ETH_DMACCATDR_CURTDESAPTR_Msk (0xFFFFFFFFUL << ETH_DMACCATDR_CURTDESAPTR_Pos) |
| #define | ETH_DMACCATDR_CURTDESAPTR ETH_DMACCATDR_CURTDESAPTR_Msk /* Application Transmit Descriptor Address Pointer */ |
| #define | ETH_DMACCARDR_CURRDESAPTR_Pos (0U) |
| #define | ETH_DMACCARDR_CURRDESAPTR_Msk (0xFFFFFFFFUL << ETH_DMACCARDR_CURRDESAPTR_Pos) |
| #define | ETH_DMACCARDR_CURRDESAPTR ETH_DMACCARDR_CURRDESAPTR_Msk /* Application Receive Descriptor Address Pointer */ |
| #define | ETH_DMACCATBR_CURTBUFAPTR_Pos (0U) |
| #define | ETH_DMACCATBR_CURTBUFAPTR_Msk (0xFFFFFFFFUL << ETH_DMACCATBR_CURTBUFAPTR_Pos) |
| #define | ETH_DMACCATBR_CURTBUFAPTR ETH_DMACCATBR_CURTBUFAPTR_Msk /* Application Transmit Buffer Address Pointer */ |
| #define | ETH_DMACCARBR_CURRBUFAPTR_Pos (0U) |
| #define | ETH_DMACCARBR_CURRBUFAPTR_Msk (0xFFFFFFFFUL << ETH_DMACCARBR_CURRBUFAPTR_Pos) |
| #define | ETH_DMACCARBR_CURRBUFAPTR ETH_DMACCARBR_CURRBUFAPTR_Msk /* Application Receive Buffer Address Pointer */ |
| #define | ETH_DMACSR_REB_Pos (19U) |
| #define | ETH_DMACSR_REB_Msk (0x7UL << ETH_DMACSR_REB_Pos) |
| #define | ETH_DMACSR_REB ETH_DMACSR_REB_Msk /* Rx DMA Error Bits */ |
| #define | ETH_DMACSR_TEB_Pos (16U) |
| #define | ETH_DMACSR_TEB_Msk (0x7UL << ETH_DMACSR_TEB_Pos) |
| #define | ETH_DMACSR_TEB ETH_DMACSR_TEB_Msk /* Tx DMA Error Bits */ |
| #define | ETH_DMACSR_NIS_Pos (15U) |
| #define | ETH_DMACSR_NIS_Msk (0x1UL << ETH_DMACSR_NIS_Pos) |
| #define | ETH_DMACSR_NIS ETH_DMACSR_NIS_Msk /* Normal Interrupt Summary */ |
| #define | ETH_DMACSR_AIS_Pos (14U) |
| #define | ETH_DMACSR_AIS_Msk (0x1UL << ETH_DMACSR_AIS_Pos) |
| #define | ETH_DMACSR_AIS ETH_DMACSR_AIS_Msk /* Abnormal Interrupt Summary */ |
| #define | ETH_DMACSR_CDE_Pos (13U) |
| #define | ETH_DMACSR_CDE_Msk (0x1UL << ETH_DMACSR_CDE_Pos) |
| #define | ETH_DMACSR_CDE ETH_DMACSR_CDE_Msk /* Context Descriptor Error */ |
| #define | ETH_DMACSR_FBE_Pos (12U) |
| #define | ETH_DMACSR_FBE_Msk (0x1UL << ETH_DMACSR_FBE_Pos) |
| #define | ETH_DMACSR_FBE ETH_DMACSR_FBE_Msk /* Fatal Bus Error */ |
| #define | ETH_DMACSR_ERI_Pos (11U) |
| #define | ETH_DMACSR_ERI_Msk (0x1UL << ETH_DMACSR_ERI_Pos) |
| #define | ETH_DMACSR_ERI ETH_DMACSR_ERI_Msk /* Early Receive Interrupt */ |
| #define | ETH_DMACSR_ETI_Pos (10U) |
| #define | ETH_DMACSR_ETI_Msk (0x1UL << ETH_DMACSR_ETI_Pos) |
| #define | ETH_DMACSR_ETI ETH_DMACSR_ETI_Msk /* Early Transmit Interrupt */ |
| #define | ETH_DMACSR_RWT_Pos (9U) |
| #define | ETH_DMACSR_RWT_Msk (0x1UL << ETH_DMACSR_RWT_Pos) |
| #define | ETH_DMACSR_RWT ETH_DMACSR_RWT_Msk /* Receive Watchdog Timeout */ |
| #define | ETH_DMACSR_RPS_Pos (8U) |
| #define | ETH_DMACSR_RPS_Msk (0x1UL << ETH_DMACSR_RPS_Pos) |
| #define | ETH_DMACSR_RPS ETH_DMACSR_RPS_Msk /* Receive Process Stopped */ |
| #define | ETH_DMACSR_RBU_Pos (7U) |
| #define | ETH_DMACSR_RBU_Msk (0x1UL << ETH_DMACSR_RBU_Pos) |
| #define | ETH_DMACSR_RBU ETH_DMACSR_RBU_Msk /* Receive Buffer Unavailable */ |
| #define | ETH_DMACSR_RI_Pos (6U) |
| #define | ETH_DMACSR_RI_Msk (0x1UL << ETH_DMACSR_RI_Pos) |
| #define | ETH_DMACSR_RI ETH_DMACSR_RI_Msk /* Receive Interrupt */ |
| #define | ETH_DMACSR_TBU_Pos (2U) |
| #define | ETH_DMACSR_TBU_Msk (0x1UL << ETH_DMACSR_TBU_Pos) |
| #define | ETH_DMACSR_TBU ETH_DMACSR_TBU_Msk /* Transmit Buffer Unavailable */ |
| #define | ETH_DMACSR_TPS_Pos (1U) |
| #define | ETH_DMACSR_TPS_Msk (0x1UL << ETH_DMACSR_TPS_Pos) |
| #define | ETH_DMACSR_TPS ETH_DMACSR_TPS_Msk /* Transmit Process Stopped */ |
| #define | ETH_DMACSR_TI_Pos (0U) |
| #define | ETH_DMACSR_TI_Msk (0x1UL << ETH_DMACSR_TI_Pos) |
| #define | ETH_DMACSR_TI ETH_DMACSR_TI_Msk /* Transmit Interrupt */ |
| #define | ETH_DMACMFCR_MFCO_Pos (15U) |
| #define | ETH_DMACMFCR_MFCO_Msk (0x1UL << ETH_DMACMFCR_MFCO_Pos) |
| #define | ETH_DMACMFCR_MFCO ETH_DMACMFCR_MFCO_Msk /* Overflow status of the MFC Counter */ |
| #define | ETH_DMACMFCR_MFC_Pos (0U) |
| #define | ETH_DMACMFCR_MFC_Msk (0x7FFUL << ETH_DMACMFCR_MFC_Pos) |
| #define | ETH_DMACMFCR_MFC ETH_DMACMFCR_MFC_Msk /* The number of packet counters dropped by the DMA */ |
| #define | DMA_SxCR_MBURST_Pos (23U) |
| #define | DMA_SxCR_MBURST_Msk (0x3UL << DMA_SxCR_MBURST_Pos) |
| #define | DMA_SxCR_MBURST DMA_SxCR_MBURST_Msk |
| #define | DMA_SxCR_MBURST_0 (0x1UL << DMA_SxCR_MBURST_Pos) |
| #define | DMA_SxCR_MBURST_1 (0x2UL << DMA_SxCR_MBURST_Pos) |
| #define | DMA_SxCR_PBURST_Pos (21U) |
| #define | DMA_SxCR_PBURST_Msk (0x3UL << DMA_SxCR_PBURST_Pos) |
| #define | DMA_SxCR_PBURST DMA_SxCR_PBURST_Msk |
| #define | DMA_SxCR_PBURST_0 (0x1UL << DMA_SxCR_PBURST_Pos) |
| #define | DMA_SxCR_PBURST_1 (0x2UL << DMA_SxCR_PBURST_Pos) |
| #define | DMA_SxCR_TRBUFF_Pos (20U) |
| #define | DMA_SxCR_TRBUFF_Msk (0x1UL << DMA_SxCR_TRBUFF_Pos) |
| #define | DMA_SxCR_TRBUFF DMA_SxCR_TRBUFF_Msk |
| #define | DMA_SxCR_CT_Pos (19U) |
| #define | DMA_SxCR_CT_Msk (0x1UL << DMA_SxCR_CT_Pos) |
| #define | DMA_SxCR_CT DMA_SxCR_CT_Msk |
| #define | DMA_SxCR_DBM_Pos (18U) |
| #define | DMA_SxCR_DBM_Msk (0x1UL << DMA_SxCR_DBM_Pos) |
| #define | DMA_SxCR_DBM DMA_SxCR_DBM_Msk |
| #define | DMA_SxCR_PL_Pos (16U) |
| #define | DMA_SxCR_PL_Msk (0x3UL << DMA_SxCR_PL_Pos) |
| #define | DMA_SxCR_PL DMA_SxCR_PL_Msk |
| #define | DMA_SxCR_PL_0 (0x1UL << DMA_SxCR_PL_Pos) |
| #define | DMA_SxCR_PL_1 (0x2UL << DMA_SxCR_PL_Pos) |
| #define | DMA_SxCR_PINCOS_Pos (15U) |
| #define | DMA_SxCR_PINCOS_Msk (0x1UL << DMA_SxCR_PINCOS_Pos) |
| #define | DMA_SxCR_PINCOS DMA_SxCR_PINCOS_Msk |
| #define | DMA_SxCR_MSIZE_Pos (13U) |
| #define | DMA_SxCR_MSIZE_Msk (0x3UL << DMA_SxCR_MSIZE_Pos) |
| #define | DMA_SxCR_MSIZE DMA_SxCR_MSIZE_Msk |
| #define | DMA_SxCR_MSIZE_0 (0x1UL << DMA_SxCR_MSIZE_Pos) |
| #define | DMA_SxCR_MSIZE_1 (0x2UL << DMA_SxCR_MSIZE_Pos) |
| #define | DMA_SxCR_PSIZE_Pos (11U) |
| #define | DMA_SxCR_PSIZE_Msk (0x3UL << DMA_SxCR_PSIZE_Pos) |
| #define | DMA_SxCR_PSIZE DMA_SxCR_PSIZE_Msk /*< Peripheral data size */ |
| #define | DMA_SxCR_PSIZE_0 (0x1UL << DMA_SxCR_PSIZE_Pos) |
| #define | DMA_SxCR_PSIZE_1 (0x2UL << DMA_SxCR_PSIZE_Pos) |
| #define | DMA_SxCR_MINC_Pos (10U) |
| #define | DMA_SxCR_MINC_Msk (0x1UL << DMA_SxCR_MINC_Pos) |
| #define | DMA_SxCR_MINC DMA_SxCR_MINC_Msk |
| #define | DMA_SxCR_PINC_Pos (9U) |
| #define | DMA_SxCR_PINC_Msk (0x1UL << DMA_SxCR_PINC_Pos) |
| #define | DMA_SxCR_PINC DMA_SxCR_PINC_Msk |
| #define | DMA_SxCR_CIRC_Pos (8U) |
| #define | DMA_SxCR_CIRC_Msk (0x1UL << DMA_SxCR_CIRC_Pos) |
| #define | DMA_SxCR_CIRC DMA_SxCR_CIRC_Msk |
| #define | DMA_SxCR_DIR_Pos (6U) |
| #define | DMA_SxCR_DIR_Msk (0x3UL << DMA_SxCR_DIR_Pos) |
| #define | DMA_SxCR_DIR DMA_SxCR_DIR_Msk |
| #define | DMA_SxCR_DIR_0 (0x1UL << DMA_SxCR_DIR_Pos) |
| #define | DMA_SxCR_DIR_1 (0x2UL << DMA_SxCR_DIR_Pos) |
| #define | DMA_SxCR_PFCTRL_Pos (5U) |
| #define | DMA_SxCR_PFCTRL_Msk (0x1UL << DMA_SxCR_PFCTRL_Pos) |
| #define | DMA_SxCR_PFCTRL DMA_SxCR_PFCTRL_Msk |
| #define | DMA_SxCR_TCIE_Pos (4U) |
| #define | DMA_SxCR_TCIE_Msk (0x1UL << DMA_SxCR_TCIE_Pos) |
| #define | DMA_SxCR_TCIE DMA_SxCR_TCIE_Msk |
| #define | DMA_SxCR_HTIE_Pos (3U) |
| #define | DMA_SxCR_HTIE_Msk (0x1UL << DMA_SxCR_HTIE_Pos) |
| #define | DMA_SxCR_HTIE DMA_SxCR_HTIE_Msk |
| #define | DMA_SxCR_TEIE_Pos (2U) |
| #define | DMA_SxCR_TEIE_Msk (0x1UL << DMA_SxCR_TEIE_Pos) |
| #define | DMA_SxCR_TEIE DMA_SxCR_TEIE_Msk |
| #define | DMA_SxCR_DMEIE_Pos (1U) |
| #define | DMA_SxCR_DMEIE_Msk (0x1UL << DMA_SxCR_DMEIE_Pos) |
| #define | DMA_SxCR_DMEIE DMA_SxCR_DMEIE_Msk |
| #define | DMA_SxCR_EN_Pos (0U) |
| #define | DMA_SxCR_EN_Msk (0x1UL << DMA_SxCR_EN_Pos) |
| #define | DMA_SxCR_EN DMA_SxCR_EN_Msk |
| #define | DMA_SxNDT_Pos (0U) |
| #define | DMA_SxNDT_Msk (0xFFFFUL << DMA_SxNDT_Pos) |
| #define | DMA_SxNDT DMA_SxNDT_Msk |
| #define | DMA_SxNDT_0 (0x0001UL << DMA_SxNDT_Pos) |
| #define | DMA_SxNDT_1 (0x0002UL << DMA_SxNDT_Pos) |
| #define | DMA_SxNDT_2 (0x0004UL << DMA_SxNDT_Pos) |
| #define | DMA_SxNDT_3 (0x0008UL << DMA_SxNDT_Pos) |
| #define | DMA_SxNDT_4 (0x0010UL << DMA_SxNDT_Pos) |
| #define | DMA_SxNDT_5 (0x0020UL << DMA_SxNDT_Pos) |
| #define | DMA_SxNDT_6 (0x0040UL << DMA_SxNDT_Pos) |
| #define | DMA_SxNDT_7 (0x0080UL << DMA_SxNDT_Pos) |
| #define | DMA_SxNDT_8 (0x0100UL << DMA_SxNDT_Pos) |
| #define | DMA_SxNDT_9 (0x0200UL << DMA_SxNDT_Pos) |
| #define | DMA_SxNDT_10 (0x0400UL << DMA_SxNDT_Pos) |
| #define | DMA_SxNDT_11 (0x0800UL << DMA_SxNDT_Pos) |
| #define | DMA_SxNDT_12 (0x1000UL << DMA_SxNDT_Pos) |
| #define | DMA_SxNDT_13 (0x2000UL << DMA_SxNDT_Pos) |
| #define | DMA_SxNDT_14 (0x4000UL << DMA_SxNDT_Pos) |
| #define | DMA_SxNDT_15 (0x8000UL << DMA_SxNDT_Pos) |
| #define | DMA_SxFCR_FEIE_Pos (7U) |
| #define | DMA_SxFCR_FEIE_Msk (0x1UL << DMA_SxFCR_FEIE_Pos) |
| #define | DMA_SxFCR_FEIE DMA_SxFCR_FEIE_Msk |
| #define | DMA_SxFCR_FS_Pos (3U) |
| #define | DMA_SxFCR_FS_Msk (0x7UL << DMA_SxFCR_FS_Pos) |
| #define | DMA_SxFCR_FS DMA_SxFCR_FS_Msk |
| #define | DMA_SxFCR_FS_0 (0x1UL << DMA_SxFCR_FS_Pos) |
| #define | DMA_SxFCR_FS_1 (0x2UL << DMA_SxFCR_FS_Pos) |
| #define | DMA_SxFCR_FS_2 (0x4UL << DMA_SxFCR_FS_Pos) |
| #define | DMA_SxFCR_DMDIS_Pos (2U) |
| #define | DMA_SxFCR_DMDIS_Msk (0x1UL << DMA_SxFCR_DMDIS_Pos) |
| #define | DMA_SxFCR_DMDIS DMA_SxFCR_DMDIS_Msk |
| #define | DMA_SxFCR_FTH_Pos (0U) |
| #define | DMA_SxFCR_FTH_Msk (0x3UL << DMA_SxFCR_FTH_Pos) |
| #define | DMA_SxFCR_FTH DMA_SxFCR_FTH_Msk |
| #define | DMA_SxFCR_FTH_0 (0x1UL << DMA_SxFCR_FTH_Pos) |
| #define | DMA_SxFCR_FTH_1 (0x2UL << DMA_SxFCR_FTH_Pos) |
| #define | DMA_LISR_TCIF3_Pos (27U) |
| #define | DMA_LISR_TCIF3_Msk (0x1UL << DMA_LISR_TCIF3_Pos) |
| #define | DMA_LISR_TCIF3 DMA_LISR_TCIF3_Msk |
| #define | DMA_LISR_HTIF3_Pos (26U) |
| #define | DMA_LISR_HTIF3_Msk (0x1UL << DMA_LISR_HTIF3_Pos) |
| #define | DMA_LISR_HTIF3 DMA_LISR_HTIF3_Msk |
| #define | DMA_LISR_TEIF3_Pos (25U) |
| #define | DMA_LISR_TEIF3_Msk (0x1UL << DMA_LISR_TEIF3_Pos) |
| #define | DMA_LISR_TEIF3 DMA_LISR_TEIF3_Msk |
| #define | DMA_LISR_DMEIF3_Pos (24U) |
| #define | DMA_LISR_DMEIF3_Msk (0x1UL << DMA_LISR_DMEIF3_Pos) |
| #define | DMA_LISR_DMEIF3 DMA_LISR_DMEIF3_Msk |
| #define | DMA_LISR_FEIF3_Pos (22U) |
| #define | DMA_LISR_FEIF3_Msk (0x1UL << DMA_LISR_FEIF3_Pos) |
| #define | DMA_LISR_FEIF3 DMA_LISR_FEIF3_Msk |
| #define | DMA_LISR_TCIF2_Pos (21U) |
| #define | DMA_LISR_TCIF2_Msk (0x1UL << DMA_LISR_TCIF2_Pos) |
| #define | DMA_LISR_TCIF2 DMA_LISR_TCIF2_Msk |
| #define | DMA_LISR_HTIF2_Pos (20U) |
| #define | DMA_LISR_HTIF2_Msk (0x1UL << DMA_LISR_HTIF2_Pos) |
| #define | DMA_LISR_HTIF2 DMA_LISR_HTIF2_Msk |
| #define | DMA_LISR_TEIF2_Pos (19U) |
| #define | DMA_LISR_TEIF2_Msk (0x1UL << DMA_LISR_TEIF2_Pos) |
| #define | DMA_LISR_TEIF2 DMA_LISR_TEIF2_Msk |
| #define | DMA_LISR_DMEIF2_Pos (18U) |
| #define | DMA_LISR_DMEIF2_Msk (0x1UL << DMA_LISR_DMEIF2_Pos) |
| #define | DMA_LISR_DMEIF2 DMA_LISR_DMEIF2_Msk |
| #define | DMA_LISR_FEIF2_Pos (16U) |
| #define | DMA_LISR_FEIF2_Msk (0x1UL << DMA_LISR_FEIF2_Pos) |
| #define | DMA_LISR_FEIF2 DMA_LISR_FEIF2_Msk |
| #define | DMA_LISR_TCIF1_Pos (11U) |
| #define | DMA_LISR_TCIF1_Msk (0x1UL << DMA_LISR_TCIF1_Pos) |
| #define | DMA_LISR_TCIF1 DMA_LISR_TCIF1_Msk |
| #define | DMA_LISR_HTIF1_Pos (10U) |
| #define | DMA_LISR_HTIF1_Msk (0x1UL << DMA_LISR_HTIF1_Pos) |
| #define | DMA_LISR_HTIF1 DMA_LISR_HTIF1_Msk |
| #define | DMA_LISR_TEIF1_Pos (9U) |
| #define | DMA_LISR_TEIF1_Msk (0x1UL << DMA_LISR_TEIF1_Pos) |
| #define | DMA_LISR_TEIF1 DMA_LISR_TEIF1_Msk |
| #define | DMA_LISR_DMEIF1_Pos (8U) |
| #define | DMA_LISR_DMEIF1_Msk (0x1UL << DMA_LISR_DMEIF1_Pos) |
| #define | DMA_LISR_DMEIF1 DMA_LISR_DMEIF1_Msk |
| #define | DMA_LISR_FEIF1_Pos (6U) |
| #define | DMA_LISR_FEIF1_Msk (0x1UL << DMA_LISR_FEIF1_Pos) |
| #define | DMA_LISR_FEIF1 DMA_LISR_FEIF1_Msk |
| #define | DMA_LISR_TCIF0_Pos (5U) |
| #define | DMA_LISR_TCIF0_Msk (0x1UL << DMA_LISR_TCIF0_Pos) |
| #define | DMA_LISR_TCIF0 DMA_LISR_TCIF0_Msk |
| #define | DMA_LISR_HTIF0_Pos (4U) |
| #define | DMA_LISR_HTIF0_Msk (0x1UL << DMA_LISR_HTIF0_Pos) |
| #define | DMA_LISR_HTIF0 DMA_LISR_HTIF0_Msk |
| #define | DMA_LISR_TEIF0_Pos (3U) |
| #define | DMA_LISR_TEIF0_Msk (0x1UL << DMA_LISR_TEIF0_Pos) |
| #define | DMA_LISR_TEIF0 DMA_LISR_TEIF0_Msk |
| #define | DMA_LISR_DMEIF0_Pos (2U) |
| #define | DMA_LISR_DMEIF0_Msk (0x1UL << DMA_LISR_DMEIF0_Pos) |
| #define | DMA_LISR_DMEIF0 DMA_LISR_DMEIF0_Msk |
| #define | DMA_LISR_FEIF0_Pos (0U) |
| #define | DMA_LISR_FEIF0_Msk (0x1UL << DMA_LISR_FEIF0_Pos) |
| #define | DMA_LISR_FEIF0 DMA_LISR_FEIF0_Msk |
| #define | DMA_HISR_TCIF7_Pos (27U) |
| #define | DMA_HISR_TCIF7_Msk (0x1UL << DMA_HISR_TCIF7_Pos) |
| #define | DMA_HISR_TCIF7 DMA_HISR_TCIF7_Msk |
| #define | DMA_HISR_HTIF7_Pos (26U) |
| #define | DMA_HISR_HTIF7_Msk (0x1UL << DMA_HISR_HTIF7_Pos) |
| #define | DMA_HISR_HTIF7 DMA_HISR_HTIF7_Msk |
| #define | DMA_HISR_TEIF7_Pos (25U) |
| #define | DMA_HISR_TEIF7_Msk (0x1UL << DMA_HISR_TEIF7_Pos) |
| #define | DMA_HISR_TEIF7 DMA_HISR_TEIF7_Msk |
| #define | DMA_HISR_DMEIF7_Pos (24U) |
| #define | DMA_HISR_DMEIF7_Msk (0x1UL << DMA_HISR_DMEIF7_Pos) |
| #define | DMA_HISR_DMEIF7 DMA_HISR_DMEIF7_Msk |
| #define | DMA_HISR_FEIF7_Pos (22U) |
| #define | DMA_HISR_FEIF7_Msk (0x1UL << DMA_HISR_FEIF7_Pos) |
| #define | DMA_HISR_FEIF7 DMA_HISR_FEIF7_Msk |
| #define | DMA_HISR_TCIF6_Pos (21U) |
| #define | DMA_HISR_TCIF6_Msk (0x1UL << DMA_HISR_TCIF6_Pos) |
| #define | DMA_HISR_TCIF6 DMA_HISR_TCIF6_Msk |
| #define | DMA_HISR_HTIF6_Pos (20U) |
| #define | DMA_HISR_HTIF6_Msk (0x1UL << DMA_HISR_HTIF6_Pos) |
| #define | DMA_HISR_HTIF6 DMA_HISR_HTIF6_Msk |
| #define | DMA_HISR_TEIF6_Pos (19U) |
| #define | DMA_HISR_TEIF6_Msk (0x1UL << DMA_HISR_TEIF6_Pos) |
| #define | DMA_HISR_TEIF6 DMA_HISR_TEIF6_Msk |
| #define | DMA_HISR_DMEIF6_Pos (18U) |
| #define | DMA_HISR_DMEIF6_Msk (0x1UL << DMA_HISR_DMEIF6_Pos) |
| #define | DMA_HISR_DMEIF6 DMA_HISR_DMEIF6_Msk |
| #define | DMA_HISR_FEIF6_Pos (16U) |
| #define | DMA_HISR_FEIF6_Msk (0x1UL << DMA_HISR_FEIF6_Pos) |
| #define | DMA_HISR_FEIF6 DMA_HISR_FEIF6_Msk |
| #define | DMA_HISR_TCIF5_Pos (11U) |
| #define | DMA_HISR_TCIF5_Msk (0x1UL << DMA_HISR_TCIF5_Pos) |
| #define | DMA_HISR_TCIF5 DMA_HISR_TCIF5_Msk |
| #define | DMA_HISR_HTIF5_Pos (10U) |
| #define | DMA_HISR_HTIF5_Msk (0x1UL << DMA_HISR_HTIF5_Pos) |
| #define | DMA_HISR_HTIF5 DMA_HISR_HTIF5_Msk |
| #define | DMA_HISR_TEIF5_Pos (9U) |
| #define | DMA_HISR_TEIF5_Msk (0x1UL << DMA_HISR_TEIF5_Pos) |
| #define | DMA_HISR_TEIF5 DMA_HISR_TEIF5_Msk |
| #define | DMA_HISR_DMEIF5_Pos (8U) |
| #define | DMA_HISR_DMEIF5_Msk (0x1UL << DMA_HISR_DMEIF5_Pos) |
| #define | DMA_HISR_DMEIF5 DMA_HISR_DMEIF5_Msk |
| #define | DMA_HISR_FEIF5_Pos (6U) |
| #define | DMA_HISR_FEIF5_Msk (0x1UL << DMA_HISR_FEIF5_Pos) |
| #define | DMA_HISR_FEIF5 DMA_HISR_FEIF5_Msk |
| #define | DMA_HISR_TCIF4_Pos (5U) |
| #define | DMA_HISR_TCIF4_Msk (0x1UL << DMA_HISR_TCIF4_Pos) |
| #define | DMA_HISR_TCIF4 DMA_HISR_TCIF4_Msk |
| #define | DMA_HISR_HTIF4_Pos (4U) |
| #define | DMA_HISR_HTIF4_Msk (0x1UL << DMA_HISR_HTIF4_Pos) |
| #define | DMA_HISR_HTIF4 DMA_HISR_HTIF4_Msk |
| #define | DMA_HISR_TEIF4_Pos (3U) |
| #define | DMA_HISR_TEIF4_Msk (0x1UL << DMA_HISR_TEIF4_Pos) |
| #define | DMA_HISR_TEIF4 DMA_HISR_TEIF4_Msk |
| #define | DMA_HISR_DMEIF4_Pos (2U) |
| #define | DMA_HISR_DMEIF4_Msk (0x1UL << DMA_HISR_DMEIF4_Pos) |
| #define | DMA_HISR_DMEIF4 DMA_HISR_DMEIF4_Msk |
| #define | DMA_HISR_FEIF4_Pos (0U) |
| #define | DMA_HISR_FEIF4_Msk (0x1UL << DMA_HISR_FEIF4_Pos) |
| #define | DMA_HISR_FEIF4 DMA_HISR_FEIF4_Msk |
| #define | DMA_LIFCR_CTCIF3_Pos (27U) |
| #define | DMA_LIFCR_CTCIF3_Msk (0x1UL << DMA_LIFCR_CTCIF3_Pos) |
| #define | DMA_LIFCR_CTCIF3 DMA_LIFCR_CTCIF3_Msk |
| #define | DMA_LIFCR_CHTIF3_Pos (26U) |
| #define | DMA_LIFCR_CHTIF3_Msk (0x1UL << DMA_LIFCR_CHTIF3_Pos) |
| #define | DMA_LIFCR_CHTIF3 DMA_LIFCR_CHTIF3_Msk |
| #define | DMA_LIFCR_CTEIF3_Pos (25U) |
| #define | DMA_LIFCR_CTEIF3_Msk (0x1UL << DMA_LIFCR_CTEIF3_Pos) |
| #define | DMA_LIFCR_CTEIF3 DMA_LIFCR_CTEIF3_Msk |
| #define | DMA_LIFCR_CDMEIF3_Pos (24U) |
| #define | DMA_LIFCR_CDMEIF3_Msk (0x1UL << DMA_LIFCR_CDMEIF3_Pos) |
| #define | DMA_LIFCR_CDMEIF3 DMA_LIFCR_CDMEIF3_Msk |
| #define | DMA_LIFCR_CFEIF3_Pos (22U) |
| #define | DMA_LIFCR_CFEIF3_Msk (0x1UL << DMA_LIFCR_CFEIF3_Pos) |
| #define | DMA_LIFCR_CFEIF3 DMA_LIFCR_CFEIF3_Msk |
| #define | DMA_LIFCR_CTCIF2_Pos (21U) |
| #define | DMA_LIFCR_CTCIF2_Msk (0x1UL << DMA_LIFCR_CTCIF2_Pos) |
| #define | DMA_LIFCR_CTCIF2 DMA_LIFCR_CTCIF2_Msk |
| #define | DMA_LIFCR_CHTIF2_Pos (20U) |
| #define | DMA_LIFCR_CHTIF2_Msk (0x1UL << DMA_LIFCR_CHTIF2_Pos) |
| #define | DMA_LIFCR_CHTIF2 DMA_LIFCR_CHTIF2_Msk |
| #define | DMA_LIFCR_CTEIF2_Pos (19U) |
| #define | DMA_LIFCR_CTEIF2_Msk (0x1UL << DMA_LIFCR_CTEIF2_Pos) |
| #define | DMA_LIFCR_CTEIF2 DMA_LIFCR_CTEIF2_Msk |
| #define | DMA_LIFCR_CDMEIF2_Pos (18U) |
| #define | DMA_LIFCR_CDMEIF2_Msk (0x1UL << DMA_LIFCR_CDMEIF2_Pos) |
| #define | DMA_LIFCR_CDMEIF2 DMA_LIFCR_CDMEIF2_Msk |
| #define | DMA_LIFCR_CFEIF2_Pos (16U) |
| #define | DMA_LIFCR_CFEIF2_Msk (0x1UL << DMA_LIFCR_CFEIF2_Pos) |
| #define | DMA_LIFCR_CFEIF2 DMA_LIFCR_CFEIF2_Msk |
| #define | DMA_LIFCR_CTCIF1_Pos (11U) |
| #define | DMA_LIFCR_CTCIF1_Msk (0x1UL << DMA_LIFCR_CTCIF1_Pos) |
| #define | DMA_LIFCR_CTCIF1 DMA_LIFCR_CTCIF1_Msk |
| #define | DMA_LIFCR_CHTIF1_Pos (10U) |
| #define | DMA_LIFCR_CHTIF1_Msk (0x1UL << DMA_LIFCR_CHTIF1_Pos) |
| #define | DMA_LIFCR_CHTIF1 DMA_LIFCR_CHTIF1_Msk |
| #define | DMA_LIFCR_CTEIF1_Pos (9U) |
| #define | DMA_LIFCR_CTEIF1_Msk (0x1UL << DMA_LIFCR_CTEIF1_Pos) |
| #define | DMA_LIFCR_CTEIF1 DMA_LIFCR_CTEIF1_Msk |
| #define | DMA_LIFCR_CDMEIF1_Pos (8U) |
| #define | DMA_LIFCR_CDMEIF1_Msk (0x1UL << DMA_LIFCR_CDMEIF1_Pos) |
| #define | DMA_LIFCR_CDMEIF1 DMA_LIFCR_CDMEIF1_Msk |
| #define | DMA_LIFCR_CFEIF1_Pos (6U) |
| #define | DMA_LIFCR_CFEIF1_Msk (0x1UL << DMA_LIFCR_CFEIF1_Pos) |
| #define | DMA_LIFCR_CFEIF1 DMA_LIFCR_CFEIF1_Msk |
| #define | DMA_LIFCR_CTCIF0_Pos (5U) |
| #define | DMA_LIFCR_CTCIF0_Msk (0x1UL << DMA_LIFCR_CTCIF0_Pos) |
| #define | DMA_LIFCR_CTCIF0 DMA_LIFCR_CTCIF0_Msk |
| #define | DMA_LIFCR_CHTIF0_Pos (4U) |
| #define | DMA_LIFCR_CHTIF0_Msk (0x1UL << DMA_LIFCR_CHTIF0_Pos) |
| #define | DMA_LIFCR_CHTIF0 DMA_LIFCR_CHTIF0_Msk |
| #define | DMA_LIFCR_CTEIF0_Pos (3U) |
| #define | DMA_LIFCR_CTEIF0_Msk (0x1UL << DMA_LIFCR_CTEIF0_Pos) |
| #define | DMA_LIFCR_CTEIF0 DMA_LIFCR_CTEIF0_Msk |
| #define | DMA_LIFCR_CDMEIF0_Pos (2U) |
| #define | DMA_LIFCR_CDMEIF0_Msk (0x1UL << DMA_LIFCR_CDMEIF0_Pos) |
| #define | DMA_LIFCR_CDMEIF0 DMA_LIFCR_CDMEIF0_Msk |
| #define | DMA_LIFCR_CFEIF0_Pos (0U) |
| #define | DMA_LIFCR_CFEIF0_Msk (0x1UL << DMA_LIFCR_CFEIF0_Pos) |
| #define | DMA_LIFCR_CFEIF0 DMA_LIFCR_CFEIF0_Msk |
| #define | DMA_HIFCR_CTCIF7_Pos (27U) |
| #define | DMA_HIFCR_CTCIF7_Msk (0x1UL << DMA_HIFCR_CTCIF7_Pos) |
| #define | DMA_HIFCR_CTCIF7 DMA_HIFCR_CTCIF7_Msk |
| #define | DMA_HIFCR_CHTIF7_Pos (26U) |
| #define | DMA_HIFCR_CHTIF7_Msk (0x1UL << DMA_HIFCR_CHTIF7_Pos) |
| #define | DMA_HIFCR_CHTIF7 DMA_HIFCR_CHTIF7_Msk |
| #define | DMA_HIFCR_CTEIF7_Pos (25U) |
| #define | DMA_HIFCR_CTEIF7_Msk (0x1UL << DMA_HIFCR_CTEIF7_Pos) |
| #define | DMA_HIFCR_CTEIF7 DMA_HIFCR_CTEIF7_Msk |
| #define | DMA_HIFCR_CDMEIF7_Pos (24U) |
| #define | DMA_HIFCR_CDMEIF7_Msk (0x1UL << DMA_HIFCR_CDMEIF7_Pos) |
| #define | DMA_HIFCR_CDMEIF7 DMA_HIFCR_CDMEIF7_Msk |
| #define | DMA_HIFCR_CFEIF7_Pos (22U) |
| #define | DMA_HIFCR_CFEIF7_Msk (0x1UL << DMA_HIFCR_CFEIF7_Pos) |
| #define | DMA_HIFCR_CFEIF7 DMA_HIFCR_CFEIF7_Msk |
| #define | DMA_HIFCR_CTCIF6_Pos (21U) |
| #define | DMA_HIFCR_CTCIF6_Msk (0x1UL << DMA_HIFCR_CTCIF6_Pos) |
| #define | DMA_HIFCR_CTCIF6 DMA_HIFCR_CTCIF6_Msk |
| #define | DMA_HIFCR_CHTIF6_Pos (20U) |
| #define | DMA_HIFCR_CHTIF6_Msk (0x1UL << DMA_HIFCR_CHTIF6_Pos) |
| #define | DMA_HIFCR_CHTIF6 DMA_HIFCR_CHTIF6_Msk |
| #define | DMA_HIFCR_CTEIF6_Pos (19U) |
| #define | DMA_HIFCR_CTEIF6_Msk (0x1UL << DMA_HIFCR_CTEIF6_Pos) |
| #define | DMA_HIFCR_CTEIF6 DMA_HIFCR_CTEIF6_Msk |
| #define | DMA_HIFCR_CDMEIF6_Pos (18U) |
| #define | DMA_HIFCR_CDMEIF6_Msk (0x1UL << DMA_HIFCR_CDMEIF6_Pos) |
| #define | DMA_HIFCR_CDMEIF6 DMA_HIFCR_CDMEIF6_Msk |
| #define | DMA_HIFCR_CFEIF6_Pos (16U) |
| #define | DMA_HIFCR_CFEIF6_Msk (0x1UL << DMA_HIFCR_CFEIF6_Pos) |
| #define | DMA_HIFCR_CFEIF6 DMA_HIFCR_CFEIF6_Msk |
| #define | DMA_HIFCR_CTCIF5_Pos (11U) |
| #define | DMA_HIFCR_CTCIF5_Msk (0x1UL << DMA_HIFCR_CTCIF5_Pos) |
| #define | DMA_HIFCR_CTCIF5 DMA_HIFCR_CTCIF5_Msk |
| #define | DMA_HIFCR_CHTIF5_Pos (10U) |
| #define | DMA_HIFCR_CHTIF5_Msk (0x1UL << DMA_HIFCR_CHTIF5_Pos) |
| #define | DMA_HIFCR_CHTIF5 DMA_HIFCR_CHTIF5_Msk |
| #define | DMA_HIFCR_CTEIF5_Pos (9U) |
| #define | DMA_HIFCR_CTEIF5_Msk (0x1UL << DMA_HIFCR_CTEIF5_Pos) |
| #define | DMA_HIFCR_CTEIF5 DMA_HIFCR_CTEIF5_Msk |
| #define | DMA_HIFCR_CDMEIF5_Pos (8U) |
| #define | DMA_HIFCR_CDMEIF5_Msk (0x1UL << DMA_HIFCR_CDMEIF5_Pos) |
| #define | DMA_HIFCR_CDMEIF5 DMA_HIFCR_CDMEIF5_Msk |
| #define | DMA_HIFCR_CFEIF5_Pos (6U) |
| #define | DMA_HIFCR_CFEIF5_Msk (0x1UL << DMA_HIFCR_CFEIF5_Pos) |
| #define | DMA_HIFCR_CFEIF5 DMA_HIFCR_CFEIF5_Msk |
| #define | DMA_HIFCR_CTCIF4_Pos (5U) |
| #define | DMA_HIFCR_CTCIF4_Msk (0x1UL << DMA_HIFCR_CTCIF4_Pos) |
| #define | DMA_HIFCR_CTCIF4 DMA_HIFCR_CTCIF4_Msk |
| #define | DMA_HIFCR_CHTIF4_Pos (4U) |
| #define | DMA_HIFCR_CHTIF4_Msk (0x1UL << DMA_HIFCR_CHTIF4_Pos) |
| #define | DMA_HIFCR_CHTIF4 DMA_HIFCR_CHTIF4_Msk |
| #define | DMA_HIFCR_CTEIF4_Pos (3U) |
| #define | DMA_HIFCR_CTEIF4_Msk (0x1UL << DMA_HIFCR_CTEIF4_Pos) |
| #define | DMA_HIFCR_CTEIF4 DMA_HIFCR_CTEIF4_Msk |
| #define | DMA_HIFCR_CDMEIF4_Pos (2U) |
| #define | DMA_HIFCR_CDMEIF4_Msk (0x1UL << DMA_HIFCR_CDMEIF4_Pos) |
| #define | DMA_HIFCR_CDMEIF4 DMA_HIFCR_CDMEIF4_Msk |
| #define | DMA_HIFCR_CFEIF4_Pos (0U) |
| #define | DMA_HIFCR_CFEIF4_Msk (0x1UL << DMA_HIFCR_CFEIF4_Pos) |
| #define | DMA_HIFCR_CFEIF4 DMA_HIFCR_CFEIF4_Msk |
| #define | DMA_SxPAR_PA_Pos (0U) |
| #define | DMA_SxPAR_PA_Msk (0xFFFFFFFFUL << DMA_SxPAR_PA_Pos) |
| #define | DMA_SxPAR_PA DMA_SxPAR_PA_Msk |
| #define | DMA_SxM0AR_M0A_Pos (0U) |
| #define | DMA_SxM0AR_M0A_Msk (0xFFFFFFFFUL << DMA_SxM0AR_M0A_Pos) |
| #define | DMA_SxM0AR_M0A DMA_SxM0AR_M0A_Msk |
| #define | DMA_SxM1AR_M1A_Pos (0U) |
| #define | DMA_SxM1AR_M1A_Msk (0xFFFFFFFFUL << DMA_SxM1AR_M1A_Pos) |
| #define | DMA_SxM1AR_M1A DMA_SxM1AR_M1A_Msk |
| #define | DMAMUX_CxCR_DMAREQ_ID_Pos (0U) |
| #define | DMAMUX_CxCR_DMAREQ_ID_Msk (0xFFUL << DMAMUX_CxCR_DMAREQ_ID_Pos) |
| #define | DMAMUX_CxCR_DMAREQ_ID DMAMUX_CxCR_DMAREQ_ID_Msk |
| #define | DMAMUX_CxCR_DMAREQ_ID_0 (0x01UL << DMAMUX_CxCR_DMAREQ_ID_Pos) |
| #define | DMAMUX_CxCR_DMAREQ_ID_1 (0x02UL << DMAMUX_CxCR_DMAREQ_ID_Pos) |
| #define | DMAMUX_CxCR_DMAREQ_ID_2 (0x04UL << DMAMUX_CxCR_DMAREQ_ID_Pos) |
| #define | DMAMUX_CxCR_DMAREQ_ID_3 (0x08UL << DMAMUX_CxCR_DMAREQ_ID_Pos) |
| #define | DMAMUX_CxCR_DMAREQ_ID_4 (0x10UL << DMAMUX_CxCR_DMAREQ_ID_Pos) |
| #define | DMAMUX_CxCR_DMAREQ_ID_5 (0x20UL << DMAMUX_CxCR_DMAREQ_ID_Pos) |
| #define | DMAMUX_CxCR_DMAREQ_ID_6 (0x40UL << DMAMUX_CxCR_DMAREQ_ID_Pos) |
| #define | DMAMUX_CxCR_DMAREQ_ID_7 (0x80UL << DMAMUX_CxCR_DMAREQ_ID_Pos) |
| #define | DMAMUX_CxCR_SOIE_Pos (8U) |
| #define | DMAMUX_CxCR_SOIE_Msk (0x1UL << DMAMUX_CxCR_SOIE_Pos) |
| #define | DMAMUX_CxCR_SOIE DMAMUX_CxCR_SOIE_Msk |
| #define | DMAMUX_CxCR_EGE_Pos (9U) |
| #define | DMAMUX_CxCR_EGE_Msk (0x1UL << DMAMUX_CxCR_EGE_Pos) |
| #define | DMAMUX_CxCR_EGE DMAMUX_CxCR_EGE_Msk |
| #define | DMAMUX_CxCR_SE_Pos (16U) |
| #define | DMAMUX_CxCR_SE_Msk (0x1UL << DMAMUX_CxCR_SE_Pos) |
| #define | DMAMUX_CxCR_SE DMAMUX_CxCR_SE_Msk |
| #define | DMAMUX_CxCR_SPOL_Pos (17U) |
| #define | DMAMUX_CxCR_SPOL_Msk (0x3UL << DMAMUX_CxCR_SPOL_Pos) |
| #define | DMAMUX_CxCR_SPOL DMAMUX_CxCR_SPOL_Msk |
| #define | DMAMUX_CxCR_SPOL_0 (0x1UL << DMAMUX_CxCR_SPOL_Pos) |
| #define | DMAMUX_CxCR_SPOL_1 (0x2UL << DMAMUX_CxCR_SPOL_Pos) |
| #define | DMAMUX_CxCR_NBREQ_Pos (19U) |
| #define | DMAMUX_CxCR_NBREQ_Msk (0x1FUL << DMAMUX_CxCR_NBREQ_Pos) |
| #define | DMAMUX_CxCR_NBREQ DMAMUX_CxCR_NBREQ_Msk |
| #define | DMAMUX_CxCR_NBREQ_0 (0x01UL << DMAMUX_CxCR_NBREQ_Pos) |
| #define | DMAMUX_CxCR_NBREQ_1 (0x02UL << DMAMUX_CxCR_NBREQ_Pos) |
| #define | DMAMUX_CxCR_NBREQ_2 (0x04UL << DMAMUX_CxCR_NBREQ_Pos) |
| #define | DMAMUX_CxCR_NBREQ_3 (0x08UL << DMAMUX_CxCR_NBREQ_Pos) |
| #define | DMAMUX_CxCR_NBREQ_4 (0x10UL << DMAMUX_CxCR_NBREQ_Pos) |
| #define | DMAMUX_CxCR_SYNC_ID_Pos (24U) |
| #define | DMAMUX_CxCR_SYNC_ID_Msk (0x1FUL << DMAMUX_CxCR_SYNC_ID_Pos) |
| #define | DMAMUX_CxCR_SYNC_ID DMAMUX_CxCR_SYNC_ID_Msk |
| #define | DMAMUX_CxCR_SYNC_ID_0 (0x01UL << DMAMUX_CxCR_SYNC_ID_Pos) |
| #define | DMAMUX_CxCR_SYNC_ID_1 (0x02UL << DMAMUX_CxCR_SYNC_ID_Pos) |
| #define | DMAMUX_CxCR_SYNC_ID_2 (0x04UL << DMAMUX_CxCR_SYNC_ID_Pos) |
| #define | DMAMUX_CxCR_SYNC_ID_3 (0x08UL << DMAMUX_CxCR_SYNC_ID_Pos) |
| #define | DMAMUX_CxCR_SYNC_ID_4 (0x10UL << DMAMUX_CxCR_SYNC_ID_Pos) |
| #define | DMAMUX_CSR_SOF0_Pos (0U) |
| #define | DMAMUX_CSR_SOF0_Msk (0x1UL << DMAMUX_CSR_SOF0_Pos) |
| #define | DMAMUX_CSR_SOF0 DMAMUX_CSR_SOF0_Msk |
| #define | DMAMUX_CSR_SOF1_Pos (1U) |
| #define | DMAMUX_CSR_SOF1_Msk (0x1UL << DMAMUX_CSR_SOF1_Pos) |
| #define | DMAMUX_CSR_SOF1 DMAMUX_CSR_SOF1_Msk |
| #define | DMAMUX_CSR_SOF2_Pos (2U) |
| #define | DMAMUX_CSR_SOF2_Msk (0x1UL << DMAMUX_CSR_SOF2_Pos) |
| #define | DMAMUX_CSR_SOF2 DMAMUX_CSR_SOF2_Msk |
| #define | DMAMUX_CSR_SOF3_Pos (3U) |
| #define | DMAMUX_CSR_SOF3_Msk (0x1UL << DMAMUX_CSR_SOF3_Pos) |
| #define | DMAMUX_CSR_SOF3 DMAMUX_CSR_SOF3_Msk |
| #define | DMAMUX_CSR_SOF4_Pos (4U) |
| #define | DMAMUX_CSR_SOF4_Msk (0x1UL << DMAMUX_CSR_SOF4_Pos) |
| #define | DMAMUX_CSR_SOF4 DMAMUX_CSR_SOF4_Msk |
| #define | DMAMUX_CSR_SOF5_Pos (5U) |
| #define | DMAMUX_CSR_SOF5_Msk (0x1UL << DMAMUX_CSR_SOF5_Pos) |
| #define | DMAMUX_CSR_SOF5 DMAMUX_CSR_SOF5_Msk |
| #define | DMAMUX_CSR_SOF6_Pos (6U) |
| #define | DMAMUX_CSR_SOF6_Msk (0x1UL << DMAMUX_CSR_SOF6_Pos) |
| #define | DMAMUX_CSR_SOF6 DMAMUX_CSR_SOF6_Msk |
| #define | DMAMUX_CSR_SOF7_Pos (7U) |
| #define | DMAMUX_CSR_SOF7_Msk (0x1UL << DMAMUX_CSR_SOF7_Pos) |
| #define | DMAMUX_CSR_SOF7 DMAMUX_CSR_SOF7_Msk |
| #define | DMAMUX_CSR_SOF8_Pos (8U) |
| #define | DMAMUX_CSR_SOF8_Msk (0x1UL << DMAMUX_CSR_SOF8_Pos) |
| #define | DMAMUX_CSR_SOF8 DMAMUX_CSR_SOF8_Msk |
| #define | DMAMUX_CSR_SOF9_Pos (9U) |
| #define | DMAMUX_CSR_SOF9_Msk (0x1UL << DMAMUX_CSR_SOF9_Pos) |
| #define | DMAMUX_CSR_SOF9 DMAMUX_CSR_SOF9_Msk |
| #define | DMAMUX_CSR_SOF10_Pos (10U) |
| #define | DMAMUX_CSR_SOF10_Msk (0x1UL << DMAMUX_CSR_SOF10_Pos) |
| #define | DMAMUX_CSR_SOF10 DMAMUX_CSR_SOF10_Msk |
| #define | DMAMUX_CSR_SOF11_Pos (11U) |
| #define | DMAMUX_CSR_SOF11_Msk (0x1UL << DMAMUX_CSR_SOF11_Pos) |
| #define | DMAMUX_CSR_SOF11 DMAMUX_CSR_SOF11_Msk |
| #define | DMAMUX_CSR_SOF12_Pos (12U) |
| #define | DMAMUX_CSR_SOF12_Msk (0x1UL << DMAMUX_CSR_SOF12_Pos) |
| #define | DMAMUX_CSR_SOF12 DMAMUX_CSR_SOF12_Msk |
| #define | DMAMUX_CSR_SOF13_Pos (13U) |
| #define | DMAMUX_CSR_SOF13_Msk (0x1UL << DMAMUX_CSR_SOF13_Pos) |
| #define | DMAMUX_CSR_SOF13 DMAMUX_CSR_SOF13_Msk |
| #define | DMAMUX_CSR_SOF14_Pos (14U) |
| #define | DMAMUX_CSR_SOF14_Msk (0x1UL << DMAMUX_CSR_SOF14_Pos) |
| #define | DMAMUX_CSR_SOF14 DMAMUX_CSR_SOF14_Msk |
| #define | DMAMUX_CSR_SOF15_Pos (15U) |
| #define | DMAMUX_CSR_SOF15_Msk (0x1UL << DMAMUX_CSR_SOF15_Pos) |
| #define | DMAMUX_CSR_SOF15 DMAMUX_CSR_SOF15_Msk |
| #define | DMAMUX_CFR_CSOF0_Pos (0U) |
| #define | DMAMUX_CFR_CSOF0_Msk (0x1UL << DMAMUX_CFR_CSOF0_Pos) |
| #define | DMAMUX_CFR_CSOF0 DMAMUX_CFR_CSOF0_Msk |
| #define | DMAMUX_CFR_CSOF1_Pos (1U) |
| #define | DMAMUX_CFR_CSOF1_Msk (0x1UL << DMAMUX_CFR_CSOF1_Pos) |
| #define | DMAMUX_CFR_CSOF1 DMAMUX_CFR_CSOF1_Msk |
| #define | DMAMUX_CFR_CSOF2_Pos (2U) |
| #define | DMAMUX_CFR_CSOF2_Msk (0x1UL << DMAMUX_CFR_CSOF2_Pos) |
| #define | DMAMUX_CFR_CSOF2 DMAMUX_CFR_CSOF2_Msk |
| #define | DMAMUX_CFR_CSOF3_Pos (3U) |
| #define | DMAMUX_CFR_CSOF3_Msk (0x1UL << DMAMUX_CFR_CSOF3_Pos) |
| #define | DMAMUX_CFR_CSOF3 DMAMUX_CFR_CSOF3_Msk |
| #define | DMAMUX_CFR_CSOF4_Pos (4U) |
| #define | DMAMUX_CFR_CSOF4_Msk (0x1UL << DMAMUX_CFR_CSOF4_Pos) |
| #define | DMAMUX_CFR_CSOF4 DMAMUX_CFR_CSOF4_Msk |
| #define | DMAMUX_CFR_CSOF5_Pos (5U) |
| #define | DMAMUX_CFR_CSOF5_Msk (0x1UL << DMAMUX_CFR_CSOF5_Pos) |
| #define | DMAMUX_CFR_CSOF5 DMAMUX_CFR_CSOF5_Msk |
| #define | DMAMUX_CFR_CSOF6_Pos (6U) |
| #define | DMAMUX_CFR_CSOF6_Msk (0x1UL << DMAMUX_CFR_CSOF6_Pos) |
| #define | DMAMUX_CFR_CSOF6 DMAMUX_CFR_CSOF6_Msk |
| #define | DMAMUX_CFR_CSOF7_Pos (7U) |
| #define | DMAMUX_CFR_CSOF7_Msk (0x1UL << DMAMUX_CFR_CSOF7_Pos) |
| #define | DMAMUX_CFR_CSOF7 DMAMUX_CFR_CSOF7_Msk |
| #define | DMAMUX_CFR_CSOF8_Pos (8U) |
| #define | DMAMUX_CFR_CSOF8_Msk (0x1UL << DMAMUX_CFR_CSOF8_Pos) |
| #define | DMAMUX_CFR_CSOF8 DMAMUX_CFR_CSOF8_Msk |
| #define | DMAMUX_CFR_CSOF9_Pos (9U) |
| #define | DMAMUX_CFR_CSOF9_Msk (0x1UL << DMAMUX_CFR_CSOF9_Pos) |
| #define | DMAMUX_CFR_CSOF9 DMAMUX_CFR_CSOF9_Msk |
| #define | DMAMUX_CFR_CSOF10_Pos (10U) |
| #define | DMAMUX_CFR_CSOF10_Msk (0x1UL << DMAMUX_CFR_CSOF10_Pos) |
| #define | DMAMUX_CFR_CSOF10 DMAMUX_CFR_CSOF10_Msk |
| #define | DMAMUX_CFR_CSOF11_Pos (11U) |
| #define | DMAMUX_CFR_CSOF11_Msk (0x1UL << DMAMUX_CFR_CSOF11_Pos) |
| #define | DMAMUX_CFR_CSOF11 DMAMUX_CFR_CSOF11_Msk |
| #define | DMAMUX_CFR_CSOF12_Pos (12U) |
| #define | DMAMUX_CFR_CSOF12_Msk (0x1UL << DMAMUX_CFR_CSOF12_Pos) |
| #define | DMAMUX_CFR_CSOF12 DMAMUX_CFR_CSOF12_Msk |
| #define | DMAMUX_CFR_CSOF13_Pos (13U) |
| #define | DMAMUX_CFR_CSOF13_Msk (0x1UL << DMAMUX_CFR_CSOF13_Pos) |
| #define | DMAMUX_CFR_CSOF13 DMAMUX_CFR_CSOF13_Msk |
| #define | DMAMUX_CFR_CSOF14_Pos (14U) |
| #define | DMAMUX_CFR_CSOF14_Msk (0x1UL << DMAMUX_CFR_CSOF14_Pos) |
| #define | DMAMUX_CFR_CSOF14 DMAMUX_CFR_CSOF14_Msk |
| #define | DMAMUX_CFR_CSOF15_Pos (15U) |
| #define | DMAMUX_CFR_CSOF15_Msk (0x1UL << DMAMUX_CFR_CSOF15_Pos) |
| #define | DMAMUX_CFR_CSOF15 DMAMUX_CFR_CSOF15_Msk |
| #define | DMAMUX_RGxCR_SIG_ID_Pos (0U) |
| #define | DMAMUX_RGxCR_SIG_ID_Msk (0x1FUL << DMAMUX_RGxCR_SIG_ID_Pos) |
| #define | DMAMUX_RGxCR_SIG_ID DMAMUX_RGxCR_SIG_ID_Msk |
| #define | DMAMUX_RGxCR_SIG_ID_0 (0x01UL << DMAMUX_RGxCR_SIG_ID_Pos) |
| #define | DMAMUX_RGxCR_SIG_ID_1 (0x02UL << DMAMUX_RGxCR_SIG_ID_Pos) |
| #define | DMAMUX_RGxCR_SIG_ID_2 (0x04UL << DMAMUX_RGxCR_SIG_ID_Pos) |
| #define | DMAMUX_RGxCR_SIG_ID_3 (0x08UL << DMAMUX_RGxCR_SIG_ID_Pos) |
| #define | DMAMUX_RGxCR_SIG_ID_4 (0x10UL << DMAMUX_RGxCR_SIG_ID_Pos) |
| #define | DMAMUX_RGxCR_OIE_Pos (8U) |
| #define | DMAMUX_RGxCR_OIE_Msk (0x1UL << DMAMUX_RGxCR_OIE_Pos) |
| #define | DMAMUX_RGxCR_OIE DMAMUX_RGxCR_OIE_Msk |
| #define | DMAMUX_RGxCR_GE_Pos (16U) |
| #define | DMAMUX_RGxCR_GE_Msk (0x1UL << DMAMUX_RGxCR_GE_Pos) |
| #define | DMAMUX_RGxCR_GE DMAMUX_RGxCR_GE_Msk |
| #define | DMAMUX_RGxCR_GPOL_Pos (17U) |
| #define | DMAMUX_RGxCR_GPOL_Msk (0x3UL << DMAMUX_RGxCR_GPOL_Pos) |
| #define | DMAMUX_RGxCR_GPOL DMAMUX_RGxCR_GPOL_Msk |
| #define | DMAMUX_RGxCR_GPOL_0 (0x1UL << DMAMUX_RGxCR_GPOL_Pos) |
| #define | DMAMUX_RGxCR_GPOL_1 (0x2UL << DMAMUX_RGxCR_GPOL_Pos) |
| #define | DMAMUX_RGxCR_GNBREQ_Pos (19U) |
| #define | DMAMUX_RGxCR_GNBREQ_Msk (0x1FUL << DMAMUX_RGxCR_GNBREQ_Pos) |
| #define | DMAMUX_RGxCR_GNBREQ DMAMUX_RGxCR_GNBREQ_Msk |
| #define | DMAMUX_RGxCR_GNBREQ_0 (0x01UL << DMAMUX_RGxCR_GNBREQ_Pos) |
| #define | DMAMUX_RGxCR_GNBREQ_1 (0x02UL << DMAMUX_RGxCR_GNBREQ_Pos) |
| #define | DMAMUX_RGxCR_GNBREQ_2 (0x04UL << DMAMUX_RGxCR_GNBREQ_Pos) |
| #define | DMAMUX_RGxCR_GNBREQ_3 (0x08UL << DMAMUX_RGxCR_GNBREQ_Pos) |
| #define | DMAMUX_RGxCR_GNBREQ_4 (0x10UL << DMAMUX_RGxCR_GNBREQ_Pos) |
| #define | DMAMUX_RGSR_OF0_Pos (0U) |
| #define | DMAMUX_RGSR_OF0_Msk (0x1UL << DMAMUX_RGSR_OF0_Pos) |
| #define | DMAMUX_RGSR_OF0 DMAMUX_RGSR_OF0_Msk |
| #define | DMAMUX_RGSR_OF1_Pos (1U) |
| #define | DMAMUX_RGSR_OF1_Msk (0x1UL << DMAMUX_RGSR_OF1_Pos) |
| #define | DMAMUX_RGSR_OF1 DMAMUX_RGSR_OF1_Msk |
| #define | DMAMUX_RGSR_OF2_Pos (2U) |
| #define | DMAMUX_RGSR_OF2_Msk (0x1UL << DMAMUX_RGSR_OF2_Pos) |
| #define | DMAMUX_RGSR_OF2 DMAMUX_RGSR_OF2_Msk |
| #define | DMAMUX_RGSR_OF3_Pos (3U) |
| #define | DMAMUX_RGSR_OF3_Msk (0x1UL << DMAMUX_RGSR_OF3_Pos) |
| #define | DMAMUX_RGSR_OF3 DMAMUX_RGSR_OF3_Msk |
| #define | DMAMUX_RGSR_OF4_Pos (4U) |
| #define | DMAMUX_RGSR_OF4_Msk (0x1UL << DMAMUX_RGSR_OF4_Pos) |
| #define | DMAMUX_RGSR_OF4 DMAMUX_RGSR_OF4_Msk |
| #define | DMAMUX_RGSR_OF5_Pos (5U) |
| #define | DMAMUX_RGSR_OF5_Msk (0x1UL << DMAMUX_RGSR_OF5_Pos) |
| #define | DMAMUX_RGSR_OF5 DMAMUX_RGSR_OF5_Msk |
| #define | DMAMUX_RGSR_OF6_Pos (6U) |
| #define | DMAMUX_RGSR_OF6_Msk (0x1UL << DMAMUX_RGSR_OF6_Pos) |
| #define | DMAMUX_RGSR_OF6 DMAMUX_RGSR_OF6_Msk |
| #define | DMAMUX_RGSR_OF7_Pos (7U) |
| #define | DMAMUX_RGSR_OF7_Msk (0x1UL << DMAMUX_RGSR_OF7_Pos) |
| #define | DMAMUX_RGSR_OF7 DMAMUX_RGSR_OF7_Msk |
| #define | DMAMUX_RGCFR_COF0_Pos (0U) |
| #define | DMAMUX_RGCFR_COF0_Msk (0x1UL << DMAMUX_RGCFR_COF0_Pos) |
| #define | DMAMUX_RGCFR_COF0 DMAMUX_RGCFR_COF0_Msk |
| #define | DMAMUX_RGCFR_COF1_Pos (1U) |
| #define | DMAMUX_RGCFR_COF1_Msk (0x1UL << DMAMUX_RGCFR_COF1_Pos) |
| #define | DMAMUX_RGCFR_COF1 DMAMUX_RGCFR_COF1_Msk |
| #define | DMAMUX_RGCFR_COF2_Pos (2U) |
| #define | DMAMUX_RGCFR_COF2_Msk (0x1UL << DMAMUX_RGCFR_COF2_Pos) |
| #define | DMAMUX_RGCFR_COF2 DMAMUX_RGCFR_COF2_Msk |
| #define | DMAMUX_RGCFR_COF3_Pos (3U) |
| #define | DMAMUX_RGCFR_COF3_Msk (0x1UL << DMAMUX_RGCFR_COF3_Pos) |
| #define | DMAMUX_RGCFR_COF3 DMAMUX_RGCFR_COF3_Msk |
| #define | DMAMUX_RGCFR_COF4_Pos (4U) |
| #define | DMAMUX_RGCFR_COF4_Msk (0x1UL << DMAMUX_RGCFR_COF4_Pos) |
| #define | DMAMUX_RGCFR_COF4 DMAMUX_RGCFR_COF4_Msk |
| #define | DMAMUX_RGCFR_COF5_Pos (5U) |
| #define | DMAMUX_RGCFR_COF5_Msk (0x1UL << DMAMUX_RGCFR_COF5_Pos) |
| #define | DMAMUX_RGCFR_COF5 DMAMUX_RGCFR_COF5_Msk |
| #define | DMAMUX_RGCFR_COF6_Pos (6U) |
| #define | DMAMUX_RGCFR_COF6_Msk (0x1UL << DMAMUX_RGCFR_COF6_Pos) |
| #define | DMAMUX_RGCFR_COF6 DMAMUX_RGCFR_COF6_Msk |
| #define | DMAMUX_RGCFR_COF7_Pos (7U) |
| #define | DMAMUX_RGCFR_COF7_Msk (0x1UL << DMAMUX_RGCFR_COF7_Pos) |
| #define | DMAMUX_RGCFR_COF7 DMAMUX_RGCFR_COF7_Msk |
| #define | DMA2D_CR_START_Pos (0U) |
| #define | DMA2D_CR_START_Msk (0x1UL << DMA2D_CR_START_Pos) |
| #define | DMA2D_CR_START DMA2D_CR_START_Msk |
| #define | DMA2D_CR_SUSP_Pos (1U) |
| #define | DMA2D_CR_SUSP_Msk (0x1UL << DMA2D_CR_SUSP_Pos) |
| #define | DMA2D_CR_SUSP DMA2D_CR_SUSP_Msk |
| #define | DMA2D_CR_ABORT_Pos (2U) |
| #define | DMA2D_CR_ABORT_Msk (0x1UL << DMA2D_CR_ABORT_Pos) |
| #define | DMA2D_CR_ABORT DMA2D_CR_ABORT_Msk |
| #define | DMA2D_CR_LOM_Pos (6U) |
| #define | DMA2D_CR_LOM_Msk (0x1UL << DMA2D_CR_LOM_Pos) |
| #define | DMA2D_CR_LOM DMA2D_CR_LOM_Msk |
| #define | DMA2D_CR_TEIE_Pos (8U) |
| #define | DMA2D_CR_TEIE_Msk (0x1UL << DMA2D_CR_TEIE_Pos) |
| #define | DMA2D_CR_TEIE DMA2D_CR_TEIE_Msk |
| #define | DMA2D_CR_TCIE_Pos (9U) |
| #define | DMA2D_CR_TCIE_Msk (0x1UL << DMA2D_CR_TCIE_Pos) |
| #define | DMA2D_CR_TCIE DMA2D_CR_TCIE_Msk |
| #define | DMA2D_CR_TWIE_Pos (10U) |
| #define | DMA2D_CR_TWIE_Msk (0x1UL << DMA2D_CR_TWIE_Pos) |
| #define | DMA2D_CR_TWIE DMA2D_CR_TWIE_Msk |
| #define | DMA2D_CR_CAEIE_Pos (11U) |
| #define | DMA2D_CR_CAEIE_Msk (0x1UL << DMA2D_CR_CAEIE_Pos) |
| #define | DMA2D_CR_CAEIE DMA2D_CR_CAEIE_Msk |
| #define | DMA2D_CR_CTCIE_Pos (12U) |
| #define | DMA2D_CR_CTCIE_Msk (0x1UL << DMA2D_CR_CTCIE_Pos) |
| #define | DMA2D_CR_CTCIE DMA2D_CR_CTCIE_Msk |
| #define | DMA2D_CR_CEIE_Pos (13U) |
| #define | DMA2D_CR_CEIE_Msk (0x1UL << DMA2D_CR_CEIE_Pos) |
| #define | DMA2D_CR_CEIE DMA2D_CR_CEIE_Msk |
| #define | DMA2D_CR_MODE_Pos (16U) |
| #define | DMA2D_CR_MODE_Msk (0x7UL << DMA2D_CR_MODE_Pos) |
| #define | DMA2D_CR_MODE DMA2D_CR_MODE_Msk |
| #define | DMA2D_CR_MODE_0 (0x1UL << DMA2D_CR_MODE_Pos) |
| #define | DMA2D_CR_MODE_1 (0x2UL << DMA2D_CR_MODE_Pos) |
| #define | DMA2D_CR_MODE_2 (0x4UL << DMA2D_CR_MODE_Pos) |
| #define | DMA2D_ISR_TEIF_Pos (0U) |
| #define | DMA2D_ISR_TEIF_Msk (0x1UL << DMA2D_ISR_TEIF_Pos) |
| #define | DMA2D_ISR_TEIF DMA2D_ISR_TEIF_Msk |
| #define | DMA2D_ISR_TCIF_Pos (1U) |
| #define | DMA2D_ISR_TCIF_Msk (0x1UL << DMA2D_ISR_TCIF_Pos) |
| #define | DMA2D_ISR_TCIF DMA2D_ISR_TCIF_Msk |
| #define | DMA2D_ISR_TWIF_Pos (2U) |
| #define | DMA2D_ISR_TWIF_Msk (0x1UL << DMA2D_ISR_TWIF_Pos) |
| #define | DMA2D_ISR_TWIF DMA2D_ISR_TWIF_Msk |
| #define | DMA2D_ISR_CAEIF_Pos (3U) |
| #define | DMA2D_ISR_CAEIF_Msk (0x1UL << DMA2D_ISR_CAEIF_Pos) |
| #define | DMA2D_ISR_CAEIF DMA2D_ISR_CAEIF_Msk |
| #define | DMA2D_ISR_CTCIF_Pos (4U) |
| #define | DMA2D_ISR_CTCIF_Msk (0x1UL << DMA2D_ISR_CTCIF_Pos) |
| #define | DMA2D_ISR_CTCIF DMA2D_ISR_CTCIF_Msk |
| #define | DMA2D_ISR_CEIF_Pos (5U) |
| #define | DMA2D_ISR_CEIF_Msk (0x1UL << DMA2D_ISR_CEIF_Pos) |
| #define | DMA2D_ISR_CEIF DMA2D_ISR_CEIF_Msk |
| #define | DMA2D_IFCR_CTEIF_Pos (0U) |
| #define | DMA2D_IFCR_CTEIF_Msk (0x1UL << DMA2D_IFCR_CTEIF_Pos) |
| #define | DMA2D_IFCR_CTEIF DMA2D_IFCR_CTEIF_Msk |
| #define | DMA2D_IFCR_CTCIF_Pos (1U) |
| #define | DMA2D_IFCR_CTCIF_Msk (0x1UL << DMA2D_IFCR_CTCIF_Pos) |
| #define | DMA2D_IFCR_CTCIF DMA2D_IFCR_CTCIF_Msk |
| #define | DMA2D_IFCR_CTWIF_Pos (2U) |
| #define | DMA2D_IFCR_CTWIF_Msk (0x1UL << DMA2D_IFCR_CTWIF_Pos) |
| #define | DMA2D_IFCR_CTWIF DMA2D_IFCR_CTWIF_Msk |
| #define | DMA2D_IFCR_CAECIF_Pos (3U) |
| #define | DMA2D_IFCR_CAECIF_Msk (0x1UL << DMA2D_IFCR_CAECIF_Pos) |
| #define | DMA2D_IFCR_CAECIF DMA2D_IFCR_CAECIF_Msk |
| #define | DMA2D_IFCR_CCTCIF_Pos (4U) |
| #define | DMA2D_IFCR_CCTCIF_Msk (0x1UL << DMA2D_IFCR_CCTCIF_Pos) |
| #define | DMA2D_IFCR_CCTCIF DMA2D_IFCR_CCTCIF_Msk |
| #define | DMA2D_IFCR_CCEIF_Pos (5U) |
| #define | DMA2D_IFCR_CCEIF_Msk (0x1UL << DMA2D_IFCR_CCEIF_Pos) |
| #define | DMA2D_IFCR_CCEIF DMA2D_IFCR_CCEIF_Msk |
| #define | DMA2D_FGMAR_MA_Pos (0U) |
| #define | DMA2D_FGMAR_MA_Msk (0xFFFFFFFFUL << DMA2D_FGMAR_MA_Pos) |
| #define | DMA2D_FGMAR_MA DMA2D_FGMAR_MA_Msk |
| #define | DMA2D_FGOR_LO_Pos (0U) |
| #define | DMA2D_FGOR_LO_Msk (0xFFFFUL << DMA2D_FGOR_LO_Pos) |
| #define | DMA2D_FGOR_LO DMA2D_FGOR_LO_Msk |
| #define | DMA2D_BGMAR_MA_Pos (0U) |
| #define | DMA2D_BGMAR_MA_Msk (0xFFFFFFFFUL << DMA2D_BGMAR_MA_Pos) |
| #define | DMA2D_BGMAR_MA DMA2D_BGMAR_MA_Msk |
| #define | DMA2D_BGOR_LO_Pos (0U) |
| #define | DMA2D_BGOR_LO_Msk (0xFFFFUL << DMA2D_BGOR_LO_Pos) |
| #define | DMA2D_BGOR_LO DMA2D_BGOR_LO_Msk |
| #define | DMA2D_FGPFCCR_CM_Pos (0U) |
| #define | DMA2D_FGPFCCR_CM_Msk (0xFUL << DMA2D_FGPFCCR_CM_Pos) |
| #define | DMA2D_FGPFCCR_CM DMA2D_FGPFCCR_CM_Msk |
| #define | DMA2D_FGPFCCR_CM_0 (0x1UL << DMA2D_FGPFCCR_CM_Pos) |
| #define | DMA2D_FGPFCCR_CM_1 (0x2UL << DMA2D_FGPFCCR_CM_Pos) |
| #define | DMA2D_FGPFCCR_CM_2 (0x4UL << DMA2D_FGPFCCR_CM_Pos) |
| #define | DMA2D_FGPFCCR_CM_3 (0x8UL << DMA2D_FGPFCCR_CM_Pos) |
| #define | DMA2D_FGPFCCR_CCM_Pos (4U) |
| #define | DMA2D_FGPFCCR_CCM_Msk (0x1UL << DMA2D_FGPFCCR_CCM_Pos) |
| #define | DMA2D_FGPFCCR_CCM DMA2D_FGPFCCR_CCM_Msk |
| #define | DMA2D_FGPFCCR_START_Pos (5U) |
| #define | DMA2D_FGPFCCR_START_Msk (0x1UL << DMA2D_FGPFCCR_START_Pos) |
| #define | DMA2D_FGPFCCR_START DMA2D_FGPFCCR_START_Msk |
| #define | DMA2D_FGPFCCR_CS_Pos (8U) |
| #define | DMA2D_FGPFCCR_CS_Msk (0xFFUL << DMA2D_FGPFCCR_CS_Pos) |
| #define | DMA2D_FGPFCCR_CS DMA2D_FGPFCCR_CS_Msk |
| #define | DMA2D_FGPFCCR_AM_Pos (16U) |
| #define | DMA2D_FGPFCCR_AM_Msk (0x3UL << DMA2D_FGPFCCR_AM_Pos) |
| #define | DMA2D_FGPFCCR_AM DMA2D_FGPFCCR_AM_Msk |
| #define | DMA2D_FGPFCCR_AM_0 (0x1UL << DMA2D_FGPFCCR_AM_Pos) |
| #define | DMA2D_FGPFCCR_AM_1 (0x2UL << DMA2D_FGPFCCR_AM_Pos) |
| #define | DMA2D_FGPFCCR_CSS_Pos (18U) |
| #define | DMA2D_FGPFCCR_CSS_Msk (0x3UL << DMA2D_FGPFCCR_CSS_Pos) |
| #define | DMA2D_FGPFCCR_CSS DMA2D_FGPFCCR_CSS_Msk /* !< Chroma Sub-Sampling */ |
| #define | DMA2D_FGPFCCR_CSS_0 (0x1UL << DMA2D_FGPFCCR_CSS_Pos) |
| #define | DMA2D_FGPFCCR_CSS_1 (0x2UL << DMA2D_FGPFCCR_CSS_Pos) |
| #define | DMA2D_FGPFCCR_AI_Pos (20U) |
| #define | DMA2D_FGPFCCR_AI_Msk (0x1UL << DMA2D_FGPFCCR_AI_Pos) |
| #define | DMA2D_FGPFCCR_AI DMA2D_FGPFCCR_AI_Msk |
| #define | DMA2D_FGPFCCR_RBS_Pos (21U) |
| #define | DMA2D_FGPFCCR_RBS_Msk (0x1UL << DMA2D_FGPFCCR_RBS_Pos) |
| #define | DMA2D_FGPFCCR_RBS DMA2D_FGPFCCR_RBS_Msk |
| #define | DMA2D_FGPFCCR_ALPHA_Pos (24U) |
| #define | DMA2D_FGPFCCR_ALPHA_Msk (0xFFUL << DMA2D_FGPFCCR_ALPHA_Pos) |
| #define | DMA2D_FGPFCCR_ALPHA DMA2D_FGPFCCR_ALPHA_Msk |
| #define | DMA2D_FGCOLR_BLUE_Pos (0U) |
| #define | DMA2D_FGCOLR_BLUE_Msk (0xFFUL << DMA2D_FGCOLR_BLUE_Pos) |
| #define | DMA2D_FGCOLR_BLUE DMA2D_FGCOLR_BLUE_Msk |
| #define | DMA2D_FGCOLR_GREEN_Pos (8U) |
| #define | DMA2D_FGCOLR_GREEN_Msk (0xFFUL << DMA2D_FGCOLR_GREEN_Pos) |
| #define | DMA2D_FGCOLR_GREEN DMA2D_FGCOLR_GREEN_Msk |
| #define | DMA2D_FGCOLR_RED_Pos (16U) |
| #define | DMA2D_FGCOLR_RED_Msk (0xFFUL << DMA2D_FGCOLR_RED_Pos) |
| #define | DMA2D_FGCOLR_RED DMA2D_FGCOLR_RED_Msk |
| #define | DMA2D_BGPFCCR_CM_Pos (0U) |
| #define | DMA2D_BGPFCCR_CM_Msk (0xFUL << DMA2D_BGPFCCR_CM_Pos) |
| #define | DMA2D_BGPFCCR_CM DMA2D_BGPFCCR_CM_Msk |
| #define | DMA2D_BGPFCCR_CM_0 (0x1UL << DMA2D_BGPFCCR_CM_Pos) |
| #define | DMA2D_BGPFCCR_CM_1 (0x2UL << DMA2D_BGPFCCR_CM_Pos) |
| #define | DMA2D_BGPFCCR_CM_2 (0x4UL << DMA2D_BGPFCCR_CM_Pos) |
| #define | DMA2D_BGPFCCR_CM_3 (0x8UL << DMA2D_BGPFCCR_CM_Pos) |
| #define | DMA2D_BGPFCCR_CCM_Pos (4U) |
| #define | DMA2D_BGPFCCR_CCM_Msk (0x1UL << DMA2D_BGPFCCR_CCM_Pos) |
| #define | DMA2D_BGPFCCR_CCM DMA2D_BGPFCCR_CCM_Msk |
| #define | DMA2D_BGPFCCR_START_Pos (5U) |
| #define | DMA2D_BGPFCCR_START_Msk (0x1UL << DMA2D_BGPFCCR_START_Pos) |
| #define | DMA2D_BGPFCCR_START DMA2D_BGPFCCR_START_Msk |
| #define | DMA2D_BGPFCCR_CS_Pos (8U) |
| #define | DMA2D_BGPFCCR_CS_Msk (0xFFUL << DMA2D_BGPFCCR_CS_Pos) |
| #define | DMA2D_BGPFCCR_CS DMA2D_BGPFCCR_CS_Msk |
| #define | DMA2D_BGPFCCR_AM_Pos (16U) |
| #define | DMA2D_BGPFCCR_AM_Msk (0x3UL << DMA2D_BGPFCCR_AM_Pos) |
| #define | DMA2D_BGPFCCR_AM DMA2D_BGPFCCR_AM_Msk |
| #define | DMA2D_BGPFCCR_AM_0 (0x1UL << DMA2D_BGPFCCR_AM_Pos) |
| #define | DMA2D_BGPFCCR_AM_1 (0x2UL << DMA2D_BGPFCCR_AM_Pos) |
| #define | DMA2D_BGPFCCR_AI_Pos (20U) |
| #define | DMA2D_BGPFCCR_AI_Msk (0x1UL << DMA2D_BGPFCCR_AI_Pos) |
| #define | DMA2D_BGPFCCR_AI DMA2D_BGPFCCR_AI_Msk |
| #define | DMA2D_BGPFCCR_RBS_Pos (21U) |
| #define | DMA2D_BGPFCCR_RBS_Msk (0x1UL << DMA2D_BGPFCCR_RBS_Pos) |
| #define | DMA2D_BGPFCCR_RBS DMA2D_BGPFCCR_RBS_Msk |
| #define | DMA2D_BGPFCCR_ALPHA_Pos (24U) |
| #define | DMA2D_BGPFCCR_ALPHA_Msk (0xFFUL << DMA2D_BGPFCCR_ALPHA_Pos) |
| #define | DMA2D_BGPFCCR_ALPHA DMA2D_BGPFCCR_ALPHA_Msk |
| #define | DMA2D_BGCOLR_BLUE_Pos (0U) |
| #define | DMA2D_BGCOLR_BLUE_Msk (0xFFUL << DMA2D_BGCOLR_BLUE_Pos) |
| #define | DMA2D_BGCOLR_BLUE DMA2D_BGCOLR_BLUE_Msk |
| #define | DMA2D_BGCOLR_GREEN_Pos (8U) |
| #define | DMA2D_BGCOLR_GREEN_Msk (0xFFUL << DMA2D_BGCOLR_GREEN_Pos) |
| #define | DMA2D_BGCOLR_GREEN DMA2D_BGCOLR_GREEN_Msk |
| #define | DMA2D_BGCOLR_RED_Pos (16U) |
| #define | DMA2D_BGCOLR_RED_Msk (0xFFUL << DMA2D_BGCOLR_RED_Pos) |
| #define | DMA2D_BGCOLR_RED DMA2D_BGCOLR_RED_Msk |
| #define | DMA2D_FGCMAR_MA_Pos (0U) |
| #define | DMA2D_FGCMAR_MA_Msk (0xFFFFFFFFUL << DMA2D_FGCMAR_MA_Pos) |
| #define | DMA2D_FGCMAR_MA DMA2D_FGCMAR_MA_Msk |
| #define | DMA2D_BGCMAR_MA_Pos (0U) |
| #define | DMA2D_BGCMAR_MA_Msk (0xFFFFFFFFUL << DMA2D_BGCMAR_MA_Pos) |
| #define | DMA2D_BGCMAR_MA DMA2D_BGCMAR_MA_Msk |
| #define | DMA2D_OPFCCR_CM_Pos (0U) |
| #define | DMA2D_OPFCCR_CM_Msk (0x7UL << DMA2D_OPFCCR_CM_Pos) |
| #define | DMA2D_OPFCCR_CM DMA2D_OPFCCR_CM_Msk |
| #define | DMA2D_OPFCCR_CM_0 (0x1UL << DMA2D_OPFCCR_CM_Pos) |
| #define | DMA2D_OPFCCR_CM_1 (0x2UL << DMA2D_OPFCCR_CM_Pos) |
| #define | DMA2D_OPFCCR_CM_2 (0x4UL << DMA2D_OPFCCR_CM_Pos) |
| #define | DMA2D_OPFCCR_SB_Pos (8U) |
| #define | DMA2D_OPFCCR_SB_Msk (0x1UL << DMA2D_OPFCCR_SB_Pos) |
| #define | DMA2D_OPFCCR_SB DMA2D_OPFCCR_SB_Msk |
| #define | DMA2D_OPFCCR_AI_Pos (20U) |
| #define | DMA2D_OPFCCR_AI_Msk (0x1UL << DMA2D_OPFCCR_AI_Pos) |
| #define | DMA2D_OPFCCR_AI DMA2D_OPFCCR_AI_Msk |
| #define | DMA2D_OPFCCR_RBS_Pos (21U) |
| #define | DMA2D_OPFCCR_RBS_Msk (0x1UL << DMA2D_OPFCCR_RBS_Pos) |
| #define | DMA2D_OPFCCR_RBS DMA2D_OPFCCR_RBS_Msk |
| #define | DMA2D_OCOLR_BLUE_1_Pos (0U) |
| #define | DMA2D_OCOLR_BLUE_1_Msk (0xFFUL <<DMA2D_OCOLR_BLUE_1_Pos) /*0x000000FFU*/ |
| #define | DMA2D_OCOLR_BLUE_1 DMA2D_OCOLR_BLUE_1_Msk |
| #define | DMA2D_OCOLR_GREEN_1_Pos (8U) |
| #define | DMA2D_OCOLR_GREEN_1_Msk (0xFFUL<<DMA2D_OCOLR_GREEN_1_Pos) /*0x0000FF00U)*/ |
| #define | DMA2D_OCOLR_GREEN_1 DMA2D_OCOLR_GREEN_1_Msk |
| #define | DMA2D_OCOLR_RED_1_Pos (16U) |
| #define | DMA2D_OCOLR_RED_1_Msk (0xFFUL << DMA2D_OCOLR_RED_1_Pos) /*0x00FF0000U */ |
| #define | DMA2D_OCOLR_RED_1 DMA2D_OCOLR_RED_1_Msk |
| #define | DMA2D_OCOLR_ALPHA_1_Pos (24U) |
| #define | DMA2D_OCOLR_ALPHA_1_Msk (0xFFUL << DMA2D_OCOLR_ALPHA_1_Pos) /*0xFF000000U*/ |
| #define | DMA2D_OCOLR_ALPHA_1 DMA2D_OCOLR_ALPHA_1_Msk |
| #define | DMA2D_OCOLR_BLUE_2_Pos (0U) |
| #define | DMA2D_OCOLR_BLUE_2_Msk (0x1FUL <<DMA2D_OCOLR_BLUE_2_Pos) /*0x0000001FU*/ |
| #define | DMA2D_OCOLR_BLUE_2 DMA2D_OCOLR_BLUE_2_Msk |
| #define | DMA2D_OCOLR_GREEN_2_Pos (5U) |
| #define | DMA2D_OCOLR_GREEN_2_Msk (0x7EUL << DMA2D_OCOLR_GREEN_2_Pos) /* 0x000007E0U */ |
| #define | DMA2D_OCOLR_GREEN_2 DMA2D_OCOLR_GREEN_2_Msk |
| #define | DMA2D_OCOLR_RED_2_Pos (11U) |
| #define | DMA2D_OCOLR_RED_2_Msk (0xF8UL<<DMA2D_OCOLR_RED_2_Pos) /*0x0000F800U*/ |
| #define | DMA2D_OCOLR_RED_2 DMA2D_OCOLR_RED_2_Msk |
| #define | DMA2D_OCOLR_BLUE_3_Pos (0U) |
| #define | DMA2D_OCOLR_BLUE_3_Msk (0x1FUL << DMA2D_OCOLR_BLUE_3_Pos) /*0x0000001FU*/ |
| #define | DMA2D_OCOLR_BLUE_3 DMA2D_OCOLR_BLUE_3_Msk |
| #define | DMA2D_OCOLR_GREEN_3_Pos (5U) |
| #define | DMA2D_OCOLR_GREEN_3_Msk (0x3EUL << DMA2D_OCOLR_GREEN_3_Pos) /*0x000003E0U*/ |
| #define | DMA2D_OCOLR_GREEN_3 DMA2D_OCOLR_GREEN_3_Msk |
| #define | DMA2D_OCOLR_RED_3_Pos (10U) |
| #define | DMA2D_OCOLR_RED_3_Msk (0x7CUL << DMA2D_OCOLR_RED_3_Pos) /* 0x00007C00U*/ |
| #define | DMA2D_OCOLR_RED_3 DMA2D_OCOLR_RED_3_Msk |
| #define | DMA2D_OCOLR_ALPHA_3_Pos (15U) |
| #define | DMA2D_OCOLR_ALPHA_3_Msk (0x1UL << DMA2D_OCOLR_ALPHA_3_Pos) /*0x00008000U*/ |
| #define | DMA2D_OCOLR_ALPHA_3 DMA2D_OCOLR_ALPHA_3_Msk |
| #define | DMA2D_OCOLR_BLUE_4_Pos (0U) |
| #define | DMA2D_OCOLR_BLUE_4_Msk (0xFUL << DMA2D_OCOLR_BLUE_4_Pos) /*0x0000000FU*/ |
| #define | DMA2D_OCOLR_BLUE_4 DMA2D_OCOLR_BLUE_4_Msk |
| #define | DMA2D_OCOLR_GREEN_4_Pos (4U) |
| #define | DMA2D_OCOLR_GREEN_4_Msk (0xFUL << DMA2D_OCOLR_GREEN_4_Pos) /*0x000000F0U*/ |
| #define | DMA2D_OCOLR_GREEN_4 DMA2D_OCOLR_GREEN_4_Msk |
| #define | DMA2D_OCOLR_RED_4_Pos (8U) |
| #define | DMA2D_OCOLR_RED_4_Msk (0xFUL << DMA2D_OCOLR_RED_4_Pos) /*0x00000F00U*/ |
| #define | DMA2D_OCOLR_RED_4 DMA2D_OCOLR_RED_4_Msk |
| #define | DMA2D_OCOLR_ALPHA_4_Pos (12U) |
| #define | DMA2D_OCOLR_ALPHA_4_Msk (0xFUL << DMA2D_OCOLR_ALPHA_4_Pos) /*0x0000F000U*/ |
| #define | DMA2D_OCOLR_ALPHA_4 DMA2D_OCOLR_ALPHA_4_Msk |
| #define | DMA2D_OMAR_MA_Pos (0U) |
| #define | DMA2D_OMAR_MA_Msk (0xFFFFFFFFUL << DMA2D_OMAR_MA_Pos) |
| #define | DMA2D_OMAR_MA DMA2D_OMAR_MA_Msk |
| #define | DMA2D_OOR_LO_Pos (0U) |
| #define | DMA2D_OOR_LO_Msk (0xFFFFUL << DMA2D_OOR_LO_Pos) |
| #define | DMA2D_OOR_LO DMA2D_OOR_LO_Msk |
| #define | DMA2D_NLR_NL_Pos (0U) |
| #define | DMA2D_NLR_NL_Msk (0xFFFFUL << DMA2D_NLR_NL_Pos) |
| #define | DMA2D_NLR_NL DMA2D_NLR_NL_Msk |
| #define | DMA2D_NLR_PL_Pos (16U) |
| #define | DMA2D_NLR_PL_Msk (0x3FFFUL << DMA2D_NLR_PL_Pos) |
| #define | DMA2D_NLR_PL DMA2D_NLR_PL_Msk |
| #define | DMA2D_LWR_LW_Pos (0U) |
| #define | DMA2D_LWR_LW_Msk (0xFFFFUL << DMA2D_LWR_LW_Pos) |
| #define | DMA2D_LWR_LW DMA2D_LWR_LW_Msk |
| #define | DMA2D_AMTCR_EN_Pos (0U) |
| #define | DMA2D_AMTCR_EN_Msk (0x1UL << DMA2D_AMTCR_EN_Pos) |
| #define | DMA2D_AMTCR_EN DMA2D_AMTCR_EN_Msk |
| #define | DMA2D_AMTCR_DT_Pos (8U) |
| #define | DMA2D_AMTCR_DT_Msk (0xFFUL << DMA2D_AMTCR_DT_Pos) |
| #define | DMA2D_AMTCR_DT DMA2D_AMTCR_DT_Msk |
| #define | EXTI_RTSR1_TR_Pos (0U) |
| #define | EXTI_RTSR1_TR_Msk (0x3FFFFFUL << EXTI_RTSR1_TR_Pos) |
| #define | EXTI_RTSR1_TR EXTI_RTSR1_TR_Msk |
| #define | EXTI_RTSR1_TR0_Pos (0U) |
| #define | EXTI_RTSR1_TR0_Msk (0x1UL << EXTI_RTSR1_TR0_Pos) |
| #define | EXTI_RTSR1_TR0 EXTI_RTSR1_TR0_Msk |
| #define | EXTI_RTSR1_TR1_Pos (1U) |
| #define | EXTI_RTSR1_TR1_Msk (0x1UL << EXTI_RTSR1_TR1_Pos) |
| #define | EXTI_RTSR1_TR1 EXTI_RTSR1_TR1_Msk |
| #define | EXTI_RTSR1_TR2_Pos (2U) |
| #define | EXTI_RTSR1_TR2_Msk (0x1UL << EXTI_RTSR1_TR2_Pos) |
| #define | EXTI_RTSR1_TR2 EXTI_RTSR1_TR2_Msk |
| #define | EXTI_RTSR1_TR3_Pos (3U) |
| #define | EXTI_RTSR1_TR3_Msk (0x1UL << EXTI_RTSR1_TR3_Pos) |
| #define | EXTI_RTSR1_TR3 EXTI_RTSR1_TR3_Msk |
| #define | EXTI_RTSR1_TR4_Pos (4U) |
| #define | EXTI_RTSR1_TR4_Msk (0x1UL << EXTI_RTSR1_TR4_Pos) |
| #define | EXTI_RTSR1_TR4 EXTI_RTSR1_TR4_Msk |
| #define | EXTI_RTSR1_TR5_Pos (5U) |
| #define | EXTI_RTSR1_TR5_Msk (0x1UL << EXTI_RTSR1_TR5_Pos) |
| #define | EXTI_RTSR1_TR5 EXTI_RTSR1_TR5_Msk |
| #define | EXTI_RTSR1_TR6_Pos (6U) |
| #define | EXTI_RTSR1_TR6_Msk (0x1UL << EXTI_RTSR1_TR6_Pos) |
| #define | EXTI_RTSR1_TR6 EXTI_RTSR1_TR6_Msk |
| #define | EXTI_RTSR1_TR7_Pos (7U) |
| #define | EXTI_RTSR1_TR7_Msk (0x1UL << EXTI_RTSR1_TR7_Pos) |
| #define | EXTI_RTSR1_TR7 EXTI_RTSR1_TR7_Msk |
| #define | EXTI_RTSR1_TR8_Pos (8U) |
| #define | EXTI_RTSR1_TR8_Msk (0x1UL << EXTI_RTSR1_TR8_Pos) |
| #define | EXTI_RTSR1_TR8 EXTI_RTSR1_TR8_Msk |
| #define | EXTI_RTSR1_TR9_Pos (9U) |
| #define | EXTI_RTSR1_TR9_Msk (0x1UL << EXTI_RTSR1_TR9_Pos) |
| #define | EXTI_RTSR1_TR9 EXTI_RTSR1_TR9_Msk |
| #define | EXTI_RTSR1_TR10_Pos (10U) |
| #define | EXTI_RTSR1_TR10_Msk (0x1UL << EXTI_RTSR1_TR10_Pos) |
| #define | EXTI_RTSR1_TR10 EXTI_RTSR1_TR10_Msk |
| #define | EXTI_RTSR1_TR11_Pos (11U) |
| #define | EXTI_RTSR1_TR11_Msk (0x1UL << EXTI_RTSR1_TR11_Pos) |
| #define | EXTI_RTSR1_TR11 EXTI_RTSR1_TR11_Msk |
| #define | EXTI_RTSR1_TR12_Pos (12U) |
| #define | EXTI_RTSR1_TR12_Msk (0x1UL << EXTI_RTSR1_TR12_Pos) |
| #define | EXTI_RTSR1_TR12 EXTI_RTSR1_TR12_Msk |
| #define | EXTI_RTSR1_TR13_Pos (13U) |
| #define | EXTI_RTSR1_TR13_Msk (0x1UL << EXTI_RTSR1_TR13_Pos) |
| #define | EXTI_RTSR1_TR13 EXTI_RTSR1_TR13_Msk |
| #define | EXTI_RTSR1_TR14_Pos (14U) |
| #define | EXTI_RTSR1_TR14_Msk (0x1UL << EXTI_RTSR1_TR14_Pos) |
| #define | EXTI_RTSR1_TR14 EXTI_RTSR1_TR14_Msk |
| #define | EXTI_RTSR1_TR15_Pos (15U) |
| #define | EXTI_RTSR1_TR15_Msk (0x1UL << EXTI_RTSR1_TR15_Pos) |
| #define | EXTI_RTSR1_TR15 EXTI_RTSR1_TR15_Msk |
| #define | EXTI_RTSR1_TR16_Pos (16U) |
| #define | EXTI_RTSR1_TR16_Msk (0x1UL << EXTI_RTSR1_TR16_Pos) |
| #define | EXTI_RTSR1_TR16 EXTI_RTSR1_TR16_Msk |
| #define | EXTI_RTSR1_TR17_Pos (17U) |
| #define | EXTI_RTSR1_TR17_Msk (0x1UL << EXTI_RTSR1_TR17_Pos) |
| #define | EXTI_RTSR1_TR17 EXTI_RTSR1_TR17_Msk |
| #define | EXTI_RTSR1_TR18_Pos (18U) |
| #define | EXTI_RTSR1_TR18_Msk (0x1UL << EXTI_RTSR1_TR18_Pos) |
| #define | EXTI_RTSR1_TR18 EXTI_RTSR1_TR18_Msk |
| #define | EXTI_RTSR1_TR19_Pos (19U) |
| #define | EXTI_RTSR1_TR19_Msk (0x1UL << EXTI_RTSR1_TR19_Pos) |
| #define | EXTI_RTSR1_TR19 EXTI_RTSR1_TR19_Msk |
| #define | EXTI_RTSR1_TR20_Pos (20U) |
| #define | EXTI_RTSR1_TR20_Msk (0x1UL << EXTI_RTSR1_TR20_Pos) |
| #define | EXTI_RTSR1_TR20 EXTI_RTSR1_TR20_Msk |
| #define | EXTI_RTSR1_TR21_Pos (21U) |
| #define | EXTI_RTSR1_TR21_Msk (0x1UL << EXTI_RTSR1_TR21_Pos) |
| #define | EXTI_RTSR1_TR21 EXTI_RTSR1_TR21_Msk |
| #define | EXTI_FTSR1_TR_Pos (0U) |
| #define | EXTI_FTSR1_TR_Msk (0x3FFFFFUL << EXTI_FTSR1_TR_Pos) |
| #define | EXTI_FTSR1_TR EXTI_FTSR1_TR_Msk |
| #define | EXTI_FTSR1_TR0_Pos (0U) |
| #define | EXTI_FTSR1_TR0_Msk (0x1UL << EXTI_FTSR1_TR0_Pos) |
| #define | EXTI_FTSR1_TR0 EXTI_FTSR1_TR0_Msk |
| #define | EXTI_FTSR1_TR1_Pos (1U) |
| #define | EXTI_FTSR1_TR1_Msk (0x1UL << EXTI_FTSR1_TR1_Pos) |
| #define | EXTI_FTSR1_TR1 EXTI_FTSR1_TR1_Msk |
| #define | EXTI_FTSR1_TR2_Pos (2U) |
| #define | EXTI_FTSR1_TR2_Msk (0x1UL << EXTI_FTSR1_TR2_Pos) |
| #define | EXTI_FTSR1_TR2 EXTI_FTSR1_TR2_Msk |
| #define | EXTI_FTSR1_TR3_Pos (3U) |
| #define | EXTI_FTSR1_TR3_Msk (0x1UL << EXTI_FTSR1_TR3_Pos) |
| #define | EXTI_FTSR1_TR3 EXTI_FTSR1_TR3_Msk |
| #define | EXTI_FTSR1_TR4_Pos (4U) |
| #define | EXTI_FTSR1_TR4_Msk (0x1UL << EXTI_FTSR1_TR4_Pos) |
| #define | EXTI_FTSR1_TR4 EXTI_FTSR1_TR4_Msk |
| #define | EXTI_FTSR1_TR5_Pos (5U) |
| #define | EXTI_FTSR1_TR5_Msk (0x1UL << EXTI_FTSR1_TR5_Pos) |
| #define | EXTI_FTSR1_TR5 EXTI_FTSR1_TR5_Msk |
| #define | EXTI_FTSR1_TR6_Pos (6U) |
| #define | EXTI_FTSR1_TR6_Msk (0x1UL << EXTI_FTSR1_TR6_Pos) |
| #define | EXTI_FTSR1_TR6 EXTI_FTSR1_TR6_Msk |
| #define | EXTI_FTSR1_TR7_Pos (7U) |
| #define | EXTI_FTSR1_TR7_Msk (0x1UL << EXTI_FTSR1_TR7_Pos) |
| #define | EXTI_FTSR1_TR7 EXTI_FTSR1_TR7_Msk |
| #define | EXTI_FTSR1_TR8_Pos (8U) |
| #define | EXTI_FTSR1_TR8_Msk (0x1UL << EXTI_FTSR1_TR8_Pos) |
| #define | EXTI_FTSR1_TR8 EXTI_FTSR1_TR8_Msk |
| #define | EXTI_FTSR1_TR9_Pos (9U) |
| #define | EXTI_FTSR1_TR9_Msk (0x1UL << EXTI_FTSR1_TR9_Pos) |
| #define | EXTI_FTSR1_TR9 EXTI_FTSR1_TR9_Msk |
| #define | EXTI_FTSR1_TR10_Pos (10U) |
| #define | EXTI_FTSR1_TR10_Msk (0x1UL << EXTI_FTSR1_TR10_Pos) |
| #define | EXTI_FTSR1_TR10 EXTI_FTSR1_TR10_Msk |
| #define | EXTI_FTSR1_TR11_Pos (11U) |
| #define | EXTI_FTSR1_TR11_Msk (0x1UL << EXTI_FTSR1_TR11_Pos) |
| #define | EXTI_FTSR1_TR11 EXTI_FTSR1_TR11_Msk |
| #define | EXTI_FTSR1_TR12_Pos (12U) |
| #define | EXTI_FTSR1_TR12_Msk (0x1UL << EXTI_FTSR1_TR12_Pos) |
| #define | EXTI_FTSR1_TR12 EXTI_FTSR1_TR12_Msk |
| #define | EXTI_FTSR1_TR13_Pos (13U) |
| #define | EXTI_FTSR1_TR13_Msk (0x1UL << EXTI_FTSR1_TR13_Pos) |
| #define | EXTI_FTSR1_TR13 EXTI_FTSR1_TR13_Msk |
| #define | EXTI_FTSR1_TR14_Pos (14U) |
| #define | EXTI_FTSR1_TR14_Msk (0x1UL << EXTI_FTSR1_TR14_Pos) |
| #define | EXTI_FTSR1_TR14 EXTI_FTSR1_TR14_Msk |
| #define | EXTI_FTSR1_TR15_Pos (15U) |
| #define | EXTI_FTSR1_TR15_Msk (0x1UL << EXTI_FTSR1_TR15_Pos) |
| #define | EXTI_FTSR1_TR15 EXTI_FTSR1_TR15_Msk |
| #define | EXTI_FTSR1_TR16_Pos (16U) |
| #define | EXTI_FTSR1_TR16_Msk (0x1UL << EXTI_FTSR1_TR16_Pos) |
| #define | EXTI_FTSR1_TR16 EXTI_FTSR1_TR16_Msk |
| #define | EXTI_FTSR1_TR17_Pos (17U) |
| #define | EXTI_FTSR1_TR17_Msk (0x1UL << EXTI_FTSR1_TR17_Pos) |
| #define | EXTI_FTSR1_TR17 EXTI_FTSR1_TR17_Msk |
| #define | EXTI_FTSR1_TR18_Pos (18U) |
| #define | EXTI_FTSR1_TR18_Msk (0x1UL << EXTI_FTSR1_TR18_Pos) |
| #define | EXTI_FTSR1_TR18 EXTI_FTSR1_TR18_Msk |
| #define | EXTI_FTSR1_TR19_Pos (19U) |
| #define | EXTI_FTSR1_TR19_Msk (0x1UL << EXTI_FTSR1_TR19_Pos) |
| #define | EXTI_FTSR1_TR19 EXTI_FTSR1_TR19_Msk |
| #define | EXTI_FTSR1_TR20_Pos (20U) |
| #define | EXTI_FTSR1_TR20_Msk (0x1UL << EXTI_FTSR1_TR20_Pos) |
| #define | EXTI_FTSR1_TR20 EXTI_FTSR1_TR20_Msk |
| #define | EXTI_FTSR1_TR21_Pos (21U) |
| #define | EXTI_FTSR1_TR21_Msk (0x1UL << EXTI_FTSR1_TR21_Pos) |
| #define | EXTI_FTSR1_TR21 EXTI_FTSR1_TR21_Msk |
| #define | EXTI_SWIER1_SWIER0_Pos (0U) |
| #define | EXTI_SWIER1_SWIER0_Msk (0x1UL << EXTI_SWIER1_SWIER0_Pos) |
| #define | EXTI_SWIER1_SWIER0 EXTI_SWIER1_SWIER0_Msk |
| #define | EXTI_SWIER1_SWIER1_Pos (1U) |
| #define | EXTI_SWIER1_SWIER1_Msk (0x1UL << EXTI_SWIER1_SWIER1_Pos) |
| #define | EXTI_SWIER1_SWIER1 EXTI_SWIER1_SWIER1_Msk |
| #define | EXTI_SWIER1_SWIER2_Pos (2U) |
| #define | EXTI_SWIER1_SWIER2_Msk (0x1UL << EXTI_SWIER1_SWIER2_Pos) |
| #define | EXTI_SWIER1_SWIER2 EXTI_SWIER1_SWIER2_Msk |
| #define | EXTI_SWIER1_SWIER3_Pos (3U) |
| #define | EXTI_SWIER1_SWIER3_Msk (0x1UL << EXTI_SWIER1_SWIER3_Pos) |
| #define | EXTI_SWIER1_SWIER3 EXTI_SWIER1_SWIER3_Msk |
| #define | EXTI_SWIER1_SWIER4_Pos (4U) |
| #define | EXTI_SWIER1_SWIER4_Msk (0x1UL << EXTI_SWIER1_SWIER4_Pos) |
| #define | EXTI_SWIER1_SWIER4 EXTI_SWIER1_SWIER4_Msk |
| #define | EXTI_SWIER1_SWIER5_Pos (5U) |
| #define | EXTI_SWIER1_SWIER5_Msk (0x1UL << EXTI_SWIER1_SWIER5_Pos) |
| #define | EXTI_SWIER1_SWIER5 EXTI_SWIER1_SWIER5_Msk |
| #define | EXTI_SWIER1_SWIER6_Pos (6U) |
| #define | EXTI_SWIER1_SWIER6_Msk (0x1UL << EXTI_SWIER1_SWIER6_Pos) |
| #define | EXTI_SWIER1_SWIER6 EXTI_SWIER1_SWIER6_Msk |
| #define | EXTI_SWIER1_SWIER7_Pos (7U) |
| #define | EXTI_SWIER1_SWIER7_Msk (0x1UL << EXTI_SWIER1_SWIER7_Pos) |
| #define | EXTI_SWIER1_SWIER7 EXTI_SWIER1_SWIER7_Msk |
| #define | EXTI_SWIER1_SWIER8_Pos (8U) |
| #define | EXTI_SWIER1_SWIER8_Msk (0x1UL << EXTI_SWIER1_SWIER8_Pos) |
| #define | EXTI_SWIER1_SWIER8 EXTI_SWIER1_SWIER8_Msk |
| #define | EXTI_SWIER1_SWIER9_Pos (9U) |
| #define | EXTI_SWIER1_SWIER9_Msk (0x1UL << EXTI_SWIER1_SWIER9_Pos) |
| #define | EXTI_SWIER1_SWIER9 EXTI_SWIER1_SWIER9_Msk |
| #define | EXTI_SWIER1_SWIER10_Pos (10U) |
| #define | EXTI_SWIER1_SWIER10_Msk (0x1UL << EXTI_SWIER1_SWIER10_Pos) |
| #define | EXTI_SWIER1_SWIER10 EXTI_SWIER1_SWIER10_Msk |
| #define | EXTI_SWIER1_SWIER11_Pos (11U) |
| #define | EXTI_SWIER1_SWIER11_Msk (0x1UL << EXTI_SWIER1_SWIER11_Pos) |
| #define | EXTI_SWIER1_SWIER11 EXTI_SWIER1_SWIER11_Msk |
| #define | EXTI_SWIER1_SWIER12_Pos (12U) |
| #define | EXTI_SWIER1_SWIER12_Msk (0x1UL << EXTI_SWIER1_SWIER12_Pos) |
| #define | EXTI_SWIER1_SWIER12 EXTI_SWIER1_SWIER12_Msk |
| #define | EXTI_SWIER1_SWIER13_Pos (13U) |
| #define | EXTI_SWIER1_SWIER13_Msk (0x1UL << EXTI_SWIER1_SWIER13_Pos) |
| #define | EXTI_SWIER1_SWIER13 EXTI_SWIER1_SWIER13_Msk |
| #define | EXTI_SWIER1_SWIER14_Pos (14U) |
| #define | EXTI_SWIER1_SWIER14_Msk (0x1UL << EXTI_SWIER1_SWIER14_Pos) |
| #define | EXTI_SWIER1_SWIER14 EXTI_SWIER1_SWIER14_Msk |
| #define | EXTI_SWIER1_SWIER15_Pos (15U) |
| #define | EXTI_SWIER1_SWIER15_Msk (0x1UL << EXTI_SWIER1_SWIER15_Pos) |
| #define | EXTI_SWIER1_SWIER15 EXTI_SWIER1_SWIER15_Msk |
| #define | EXTI_SWIER1_SWIER16_Pos (16U) |
| #define | EXTI_SWIER1_SWIER16_Msk (0x1UL << EXTI_SWIER1_SWIER16_Pos) |
| #define | EXTI_SWIER1_SWIER16 EXTI_SWIER1_SWIER16_Msk |
| #define | EXTI_SWIER1_SWIER17_Pos (17U) |
| #define | EXTI_SWIER1_SWIER17_Msk (0x1UL << EXTI_SWIER1_SWIER17_Pos) |
| #define | EXTI_SWIER1_SWIER17 EXTI_SWIER1_SWIER17_Msk |
| #define | EXTI_SWIER1_SWIER18_Pos (18U) |
| #define | EXTI_SWIER1_SWIER18_Msk (0x1UL << EXTI_SWIER1_SWIER18_Pos) |
| #define | EXTI_SWIER1_SWIER18 EXTI_SWIER1_SWIER18_Msk |
| #define | EXTI_SWIER1_SWIER19_Pos (19U) |
| #define | EXTI_SWIER1_SWIER19_Msk (0x1UL << EXTI_SWIER1_SWIER19_Pos) |
| #define | EXTI_SWIER1_SWIER19 EXTI_SWIER1_SWIER19_Msk |
| #define | EXTI_SWIER1_SWIER20_Pos (20U) |
| #define | EXTI_SWIER1_SWIER20_Msk (0x1UL << EXTI_SWIER1_SWIER20_Pos) |
| #define | EXTI_SWIER1_SWIER20 EXTI_SWIER1_SWIER20_Msk |
| #define | EXTI_SWIER1_SWIER21_Pos (21U) |
| #define | EXTI_SWIER1_SWIER21_Msk (0x1UL << EXTI_SWIER1_SWIER21_Pos) |
| #define | EXTI_SWIER1_SWIER21 EXTI_SWIER1_SWIER21_Msk |
| #define | EXTI_D3PMR1_MR0_Pos (0U) |
| #define | EXTI_D3PMR1_MR0_Msk (0x1UL << EXTI_D3PMR1_MR0_Pos) |
| #define | EXTI_D3PMR1_MR0 EXTI_D3PMR1_MR0_Msk |
| #define | EXTI_D3PMR1_MR1_Pos (1U) |
| #define | EXTI_D3PMR1_MR1_Msk (0x1UL << EXTI_D3PMR1_MR1_Pos) |
| #define | EXTI_D3PMR1_MR1 EXTI_D3PMR1_MR1_Msk |
| #define | EXTI_D3PMR1_MR2_Pos (2U) |
| #define | EXTI_D3PMR1_MR2_Msk (0x1UL << EXTI_D3PMR1_MR2_Pos) |
| #define | EXTI_D3PMR1_MR2 EXTI_D3PMR1_MR2_Msk |
| #define | EXTI_D3PMR1_MR3_Pos (3U) |
| #define | EXTI_D3PMR1_MR3_Msk (0x1UL << EXTI_D3PMR1_MR3_Pos) |
| #define | EXTI_D3PMR1_MR3 EXTI_D3PMR1_MR3_Msk |
| #define | EXTI_D3PMR1_MR4_Pos (4U) |
| #define | EXTI_D3PMR1_MR4_Msk (0x1UL << EXTI_D3PMR1_MR4_Pos) |
| #define | EXTI_D3PMR1_MR4 EXTI_D3PMR1_MR4_Msk |
| #define | EXTI_D3PMR1_MR5_Pos (5U) |
| #define | EXTI_D3PMR1_MR5_Msk (0x1UL << EXTI_D3PMR1_MR5_Pos) |
| #define | EXTI_D3PMR1_MR5 EXTI_D3PMR1_MR5_Msk |
| #define | EXTI_D3PMR1_MR6_Pos (6U) |
| #define | EXTI_D3PMR1_MR6_Msk (0x1UL << EXTI_D3PMR1_MR6_Pos) |
| #define | EXTI_D3PMR1_MR6 EXTI_D3PMR1_MR6_Msk |
| #define | EXTI_D3PMR1_MR7_Pos (7U) |
| #define | EXTI_D3PMR1_MR7_Msk (0x1UL << EXTI_D3PMR1_MR7_Pos) |
| #define | EXTI_D3PMR1_MR7 EXTI_D3PMR1_MR7_Msk |
| #define | EXTI_D3PMR1_MR8_Pos (8U) |
| #define | EXTI_D3PMR1_MR8_Msk (0x1UL << EXTI_D3PMR1_MR8_Pos) |
| #define | EXTI_D3PMR1_MR8 EXTI_D3PMR1_MR8_Msk |
| #define | EXTI_D3PMR1_MR9_Pos (9U) |
| #define | EXTI_D3PMR1_MR9_Msk (0x1UL << EXTI_D3PMR1_MR9_Pos) |
| #define | EXTI_D3PMR1_MR9 EXTI_D3PMR1_MR9_Msk |
| #define | EXTI_D3PMR1_MR10_Pos (10U) |
| #define | EXTI_D3PMR1_MR10_Msk (0x1UL << EXTI_D3PMR1_MR10_Pos) |
| #define | EXTI_D3PMR1_MR10 EXTI_D3PMR1_MR10_Msk |
| #define | EXTI_D3PMR1_MR11_Pos (11U) |
| #define | EXTI_D3PMR1_MR11_Msk (0x1UL << EXTI_D3PMR1_MR11_Pos) |
| #define | EXTI_D3PMR1_MR11 EXTI_D3PMR1_MR11_Msk |
| #define | EXTI_D3PMR1_MR12_Pos (12U) |
| #define | EXTI_D3PMR1_MR12_Msk (0x1UL << EXTI_D3PMR1_MR12_Pos) |
| #define | EXTI_D3PMR1_MR12 EXTI_D3PMR1_MR12_Msk |
| #define | EXTI_D3PMR1_MR13_Pos (13U) |
| #define | EXTI_D3PMR1_MR13_Msk (0x1UL << EXTI_D3PMR1_MR13_Pos) |
| #define | EXTI_D3PMR1_MR13 EXTI_D3PMR1_MR13_Msk |
| #define | EXTI_D3PMR1_MR14_Pos (14U) |
| #define | EXTI_D3PMR1_MR14_Msk (0x1UL << EXTI_D3PMR1_MR14_Pos) |
| #define | EXTI_D3PMR1_MR14 EXTI_D3PMR1_MR14_Msk |
| #define | EXTI_D3PMR1_MR15_Pos (15U) |
| #define | EXTI_D3PMR1_MR15_Msk (0x1UL << EXTI_D3PMR1_MR15_Pos) |
| #define | EXTI_D3PMR1_MR15 EXTI_D3PMR1_MR15_Msk |
| #define | EXTI_D3PMR1_MR19_Pos (19U) |
| #define | EXTI_D3PMR1_MR19_Msk (0x1UL << EXTI_D3PMR1_MR19_Pos) |
| #define | EXTI_D3PMR1_MR19 EXTI_D3PMR1_MR19_Msk |
| #define | EXTI_D3PMR1_MR20_Pos (20U) |
| #define | EXTI_D3PMR1_MR20_Msk (0x1UL << EXTI_D3PMR1_MR20_Pos) |
| #define | EXTI_D3PMR1_MR20 EXTI_D3PMR1_MR20_Msk |
| #define | EXTI_D3PMR1_MR21_Pos (21U) |
| #define | EXTI_D3PMR1_MR21_Msk (0x1UL << EXTI_D3PMR1_MR21_Pos) |
| #define | EXTI_D3PMR1_MR21 EXTI_D3PMR1_MR21_Msk |
| #define | EXTI_D3PMR1_MR25_Pos (24U) |
| #define | EXTI_D3PMR1_MR25_Msk (0x1UL << EXTI_D3PMR1_MR25_Pos) |
| #define | EXTI_D3PMR1_MR25 EXTI_D3PMR1_MR25_Msk |
| #define | EXTI_D3PCR1L_PCS0_Pos (0U) |
| #define | EXTI_D3PCR1L_PCS0_Msk (0x3UL << EXTI_D3PCR1L_PCS0_Pos) |
| #define | EXTI_D3PCR1L_PCS0 EXTI_D3PCR1L_PCS0_Msk |
| #define | EXTI_D3PCR1L_PCS1_Pos (2U) |
| #define | EXTI_D3PCR1L_PCS1_Msk (0x3UL << EXTI_D3PCR1L_PCS1_Pos) |
| #define | EXTI_D3PCR1L_PCS1 EXTI_D3PCR1L_PCS1_Msk |
| #define | EXTI_D3PCR1L_PCS2_Pos (4U) |
| #define | EXTI_D3PCR1L_PCS2_Msk (0x3UL << EXTI_D3PCR1L_PCS2_Pos) |
| #define | EXTI_D3PCR1L_PCS2 EXTI_D3PCR1L_PCS2_Msk |
| #define | EXTI_D3PCR1L_PCS3_Pos (6U) |
| #define | EXTI_D3PCR1L_PCS3_Msk (0x3UL << EXTI_D3PCR1L_PCS3_Pos) |
| #define | EXTI_D3PCR1L_PCS3 EXTI_D3PCR1L_PCS3_Msk |
| #define | EXTI_D3PCR1L_PCS4_Pos (8U) |
| #define | EXTI_D3PCR1L_PCS4_Msk (0x3UL << EXTI_D3PCR1L_PCS4_Pos) |
| #define | EXTI_D3PCR1L_PCS4 EXTI_D3PCR1L_PCS4_Msk |
| #define | EXTI_D3PCR1L_PCS5_Pos (10U) |
| #define | EXTI_D3PCR1L_PCS5_Msk (0x3UL << EXTI_D3PCR1L_PCS5_Pos) |
| #define | EXTI_D3PCR1L_PCS5 EXTI_D3PCR1L_PCS5_Msk |
| #define | EXTI_D3PCR1L_PCS6_Pos (12U) |
| #define | EXTI_D3PCR1L_PCS6_Msk (0x3UL << EXTI_D3PCR1L_PCS6_Pos) |
| #define | EXTI_D3PCR1L_PCS6 EXTI_D3PCR1L_PCS6_Msk |
| #define | EXTI_D3PCR1L_PCS7_Pos (14U) |
| #define | EXTI_D3PCR1L_PCS7_Msk (0x3UL << EXTI_D3PCR1L_PCS7_Pos) |
| #define | EXTI_D3PCR1L_PCS7 EXTI_D3PCR1L_PCS7_Msk |
| #define | EXTI_D3PCR1L_PCS8_Pos (16U) |
| #define | EXTI_D3PCR1L_PCS8_Msk (0x3UL << EXTI_D3PCR1L_PCS8_Pos) |
| #define | EXTI_D3PCR1L_PCS8 EXTI_D3PCR1L_PCS8_Msk |
| #define | EXTI_D3PCR1L_PCS9_Pos (18U) |
| #define | EXTI_D3PCR1L_PCS9_Msk (0x3UL << EXTI_D3PCR1L_PCS9_Pos) |
| #define | EXTI_D3PCR1L_PCS9 EXTI_D3PCR1L_PCS9_Msk |
| #define | EXTI_D3PCR1L_PCS10_Pos (20U) |
| #define | EXTI_D3PCR1L_PCS10_Msk (0x3UL << EXTI_D3PCR1L_PCS10_Pos) |
| #define | EXTI_D3PCR1L_PCS10 EXTI_D3PCR1L_PCS10_Msk |
| #define | EXTI_D3PCR1L_PCS11_Pos (22U) |
| #define | EXTI_D3PCR1L_PCS11_Msk (0x3UL << EXTI_D3PCR1L_PCS11_Pos) |
| #define | EXTI_D3PCR1L_PCS11 EXTI_D3PCR1L_PCS11_Msk |
| #define | EXTI_D3PCR1L_PCS12_Pos (24U) |
| #define | EXTI_D3PCR1L_PCS12_Msk (0x3UL << EXTI_D3PCR1L_PCS12_Pos) |
| #define | EXTI_D3PCR1L_PCS12 EXTI_D3PCR1L_PCS12_Msk |
| #define | EXTI_D3PCR1L_PCS13_Pos (26U) |
| #define | EXTI_D3PCR1L_PCS13_Msk (0x3UL << EXTI_D3PCR1L_PCS13_Pos) |
| #define | EXTI_D3PCR1L_PCS13 EXTI_D3PCR1L_PCS13_Msk |
| #define | EXTI_D3PCR1L_PCS14_Pos (28U) |
| #define | EXTI_D3PCR1L_PCS14_Msk (0x3UL << EXTI_D3PCR1L_PCS14_Pos) |
| #define | EXTI_D3PCR1L_PCS14 EXTI_D3PCR1L_PCS14_Msk |
| #define | EXTI_D3PCR1L_PCS15_Pos (30U) |
| #define | EXTI_D3PCR1L_PCS15_Msk (0x3UL << EXTI_D3PCR1L_PCS15_Pos) |
| #define | EXTI_D3PCR1L_PCS15 EXTI_D3PCR1L_PCS15_Msk |
| #define | EXTI_D3PCR1H_PCS19_Pos (6U) |
| #define | EXTI_D3PCR1H_PCS19_Msk (0x3UL << EXTI_D3PCR1H_PCS19_Pos) |
| #define | EXTI_D3PCR1H_PCS19 EXTI_D3PCR1H_PCS19_Msk |
| #define | EXTI_D3PCR1H_PCS20_Pos (8U) |
| #define | EXTI_D3PCR1H_PCS20_Msk (0x3UL << EXTI_D3PCR1H_PCS20_Pos) |
| #define | EXTI_D3PCR1H_PCS20 EXTI_D3PCR1H_PCS20_Msk |
| #define | EXTI_D3PCR1H_PCS21_Pos (10U) |
| #define | EXTI_D3PCR1H_PCS21_Msk (0x3UL << EXTI_D3PCR1H_PCS21_Pos) |
| #define | EXTI_D3PCR1H_PCS21 EXTI_D3PCR1H_PCS21_Msk |
| #define | EXTI_D3PCR1H_PCS25_Pos (18U) |
| #define | EXTI_D3PCR1H_PCS25_Msk (0x3UL << EXTI_D3PCR1H_PCS25_Pos) |
| #define | EXTI_D3PCR1H_PCS25 EXTI_D3PCR1H_PCS25_Msk |
| #define | EXTI_RTSR2_TR_Pos (17U) |
| #define | EXTI_RTSR2_TR_Msk (0x5UL << EXTI_RTSR2_TR_Pos) |
| #define | EXTI_RTSR2_TR EXTI_RTSR2_TR_Msk |
| #define | EXTI_RTSR2_TR49_Pos (17U) |
| #define | EXTI_RTSR2_TR49_Msk (0x1UL << EXTI_RTSR2_TR49_Pos) |
| #define | EXTI_RTSR2_TR49 EXTI_RTSR2_TR49_Msk |
| #define | EXTI_RTSR2_TR51_Pos (19U) |
| #define | EXTI_RTSR2_TR51_Msk (0x1UL << EXTI_RTSR2_TR51_Pos) |
| #define | EXTI_RTSR2_TR51 EXTI_RTSR2_TR51_Msk |
| #define | EXTI_FTSR2_TR_Pos (17U) |
| #define | EXTI_FTSR2_TR_Msk (0x5UL << EXTI_FTSR2_TR_Pos) |
| #define | EXTI_FTSR2_TR EXTI_FTSR2_TR_Msk |
| #define | EXTI_FTSR2_TR49_Pos (17U) |
| #define | EXTI_FTSR2_TR49_Msk (0x1UL << EXTI_FTSR2_TR49_Pos) |
| #define | EXTI_FTSR2_TR49 EXTI_FTSR2_TR49_Msk |
| #define | EXTI_FTSR2_TR51_Pos (19U) |
| #define | EXTI_FTSR2_TR51_Msk (0x1UL << EXTI_FTSR2_TR51_Pos) |
| #define | EXTI_FTSR2_TR51 EXTI_FTSR2_TR51_Msk |
| #define | EXTI_SWIER2_SWIER49_Pos (17U) |
| #define | EXTI_SWIER2_SWIER49_Msk (0x1UL << EXTI_SWIER2_SWIER49_Pos) |
| #define | EXTI_SWIER2_SWIER49 EXTI_SWIER2_SWIER49_Msk |
| #define | EXTI_SWIER2_SWIER51_Pos (19U) |
| #define | EXTI_SWIER2_SWIER51_Msk (0x1UL << EXTI_SWIER2_SWIER51_Pos) |
| #define | EXTI_SWIER2_SWIER51 EXTI_SWIER2_SWIER51_Msk |
| #define | EXTI_D3PMR2_MR34_Pos (2U) |
| #define | EXTI_D3PMR2_MR34_Msk (0x1UL << EXTI_D3PMR2_MR34_Pos) |
| #define | EXTI_D3PMR2_MR34 EXTI_D3PMR2_MR34_Msk |
| #define | EXTI_D3PMR2_MR35_Pos (3U) |
| #define | EXTI_D3PMR2_MR35_Msk (0x1UL << EXTI_D3PMR2_MR35_Pos) |
| #define | EXTI_D3PMR2_MR35 EXTI_D3PMR2_MR35_Msk |
| #define | EXTI_D3PMR2_MR41_Pos (9U) |
| #define | EXTI_D3PMR2_MR41_Msk (0x1UL << EXTI_D3PMR2_MR41_Pos) |
| #define | EXTI_D3PMR2_MR41 EXTI_D3PMR2_MR41_Msk |
| #define | EXTI_D3PMR2_MR48_Pos (16U) |
| #define | EXTI_D3PMR2_MR48_Msk (0x1UL << EXTI_D3PMR2_MR48_Pos) |
| #define | EXTI_D3PMR2_MR48 EXTI_D3PMR2_MR48_Msk |
| #define | EXTI_D3PMR2_MR49_Pos (17U) |
| #define | EXTI_D3PMR2_MR49_Msk (0x1UL << EXTI_D3PMR2_MR49_Pos) |
| #define | EXTI_D3PMR2_MR49 EXTI_D3PMR2_MR49_Msk |
| #define | EXTI_D3PMR2_MR50_Pos (18U) |
| #define | EXTI_D3PMR2_MR50_Msk (0x1UL << EXTI_D3PMR2_MR50_Pos) |
| #define | EXTI_D3PMR2_MR50 EXTI_D3PMR2_MR50_Msk |
| #define | EXTI_D3PMR2_MR51_Pos (19U) |
| #define | EXTI_D3PMR2_MR51_Msk (0x1UL << EXTI_D3PMR2_MR51_Pos) |
| #define | EXTI_D3PMR2_MR51 EXTI_D3PMR2_MR51_Msk |
| #define | EXTI_D3PMR2_MR52_Pos (20U) |
| #define | EXTI_D3PMR2_MR52_Msk (0x1UL << EXTI_D3PMR2_MR52_Pos) |
| #define | EXTI_D3PMR2_MR52 EXTI_D3PMR2_MR52_Msk |
| #define | EXTI_D3PMR2_MR53_Pos (21U) |
| #define | EXTI_D3PMR2_MR53_Msk (0x1UL << EXTI_D3PMR2_MR53_Pos) |
| #define | EXTI_D3PMR2_MR53 EXTI_D3PMR2_MR53_Msk |
| #define | EXTI_D3PCR2L_PCS34_Pos (4U) |
| #define | EXTI_D3PCR2L_PCS34_Msk (0x3UL << EXTI_D3PCR2L_PCS34_Pos) |
| #define | EXTI_D3PCR2L_PCS34 EXTI_D3PCR2L_PCS34_Msk |
| #define | EXTI_D3PCR2L_PCS35_Pos (6U) |
| #define | EXTI_D3PCR2L_PCS35_Msk (0x3UL << EXTI_D3PCR2L_PCS35_Pos) |
| #define | EXTI_D3PCR2L_PCS35 EXTI_D3PCR2L_PCS35_Msk |
| #define | EXTI_D3PCR2L_PCS41_Pos (18U) |
| #define | EXTI_D3PCR2L_PCS41_Msk (0x3UL << EXTI_D3PCR2L_PCS41_Pos) |
| #define | EXTI_D3PCR2L_PCS41 EXTI_D3PCR2L_PCS41_Msk |
| #define | EXTI_D3PCR2H_PCS48_Pos (0U) |
| #define | EXTI_D3PCR2H_PCS48_Msk (0x3UL << EXTI_D3PCR2H_PCS48_Pos) |
| #define | EXTI_D3PCR2H_PCS48 EXTI_D3PCR2H_PCS48_Msk |
| #define | EXTI_D3PCR2H_PCS49_Pos (2U) |
| #define | EXTI_D3PCR2H_PCS49_Msk (0x3UL << EXTI_D3PCR2H_PCS49_Pos) |
| #define | EXTI_D3PCR2H_PCS49 EXTI_D3PCR2H_PCS49_Msk |
| #define | EXTI_D3PCR2H_PCS50_Pos (4U) |
| #define | EXTI_D3PCR2H_PCS50_Msk (0x3UL << EXTI_D3PCR2H_PCS50_Pos) |
| #define | EXTI_D3PCR2H_PCS50 EXTI_D3PCR2H_PCS50_Msk |
| #define | EXTI_D3PCR2H_PCS51_Pos (6U) |
| #define | EXTI_D3PCR2H_PCS51_Msk (0x3UL << EXTI_D3PCR2H_PCS51_Pos) |
| #define | EXTI_D3PCR2H_PCS51 EXTI_D3PCR2H_PCS51_Msk |
| #define | EXTI_D3PCR2H_PCS52_Pos (8U) |
| #define | EXTI_D3PCR2H_PCS52_Msk (0x3UL << EXTI_D3PCR2H_PCS52_Pos) |
| #define | EXTI_D3PCR2H_PCS52 EXTI_D3PCR2H_PCS52_Msk |
| #define | EXTI_D3PCR2H_PCS53_Pos (10U) |
| #define | EXTI_D3PCR2H_PCS53_Msk (0x3UL << EXTI_D3PCR2H_PCS53_Pos) |
| #define | EXTI_D3PCR2H_PCS53 EXTI_D3PCR2H_PCS53_Msk |
| #define | EXTI_RTSR3_TR_Pos (18U) |
| #define | EXTI_RTSR3_TR_Msk (0x1DUL << EXTI_RTSR3_TR_Pos) |
| #define | EXTI_RTSR3_TR EXTI_RTSR3_TR_Msk |
| #define | EXTI_RTSR3_TR82_Pos (18U) |
| #define | EXTI_RTSR3_TR82_Msk (0x1UL << EXTI_RTSR3_TR82_Pos) |
| #define | EXTI_RTSR3_TR82 EXTI_RTSR3_TR82_Msk |
| #define | EXTI_RTSR3_TR84_Pos (20U) |
| #define | EXTI_RTSR3_TR84_Msk (0x1UL << EXTI_RTSR3_TR84_Pos) |
| #define | EXTI_RTSR3_TR84 EXTI_RTSR3_TR84_Msk |
| #define | EXTI_RTSR3_TR85_Pos (21U) |
| #define | EXTI_RTSR3_TR85_Msk (0x1UL << EXTI_RTSR3_TR85_Pos) |
| #define | EXTI_RTSR3_TR85 EXTI_RTSR3_TR85_Msk |
| #define | EXTI_RTSR3_TR86_Pos (22U) |
| #define | EXTI_RTSR3_TR86_Msk (0x1UL << EXTI_RTSR3_TR86_Pos) |
| #define | EXTI_RTSR3_TR86 EXTI_RTSR3_TR86_Msk |
| #define | EXTI_FTSR3_TR_Pos (18U) |
| #define | EXTI_FTSR3_TR_Msk (0x1DUL << EXTI_FTSR3_TR_Pos) |
| #define | EXTI_FTSR3_TR EXTI_FTSR3_TR_Msk |
| #define | EXTI_FTSR3_TR82_Pos (18U) |
| #define | EXTI_FTSR3_TR82_Msk (0x1UL << EXTI_FTSR3_TR82_Pos) |
| #define | EXTI_FTSR3_TR82 EXTI_FTSR3_TR82_Msk |
| #define | EXTI_FTSR3_TR84_Pos (20U) |
| #define | EXTI_FTSR3_TR84_Msk (0x1UL << EXTI_FTSR3_TR84_Pos) |
| #define | EXTI_FTSR3_TR84 EXTI_FTSR3_TR84_Msk |
| #define | EXTI_FTSR3_TR85_Pos (21U) |
| #define | EXTI_FTSR3_TR85_Msk (0x1UL << EXTI_FTSR3_TR85_Pos) |
| #define | EXTI_FTSR3_TR85 EXTI_FTSR3_TR85_Msk |
| #define | EXTI_FTSR3_TR86_Pos (22U) |
| #define | EXTI_FTSR3_TR86_Msk (0x1UL << EXTI_FTSR3_TR86_Pos) |
| #define | EXTI_FTSR3_TR86 EXTI_FTSR3_TR86_Msk |
| #define | EXTI_SWIER3_SWI_Pos (18U) |
| #define | EXTI_SWIER3_SWI_Msk (0x1DUL << EXTI_SWIER3_SWI_Pos) |
| #define | EXTI_SWIER3_SWI EXTI_SWIER3_SWI_Msk |
| #define | EXTI_SWIER3_SWIER82_Pos (18U) |
| #define | EXTI_SWIER3_SWIER82_Msk (0x1UL << EXTI_SWIER3_SWIER82_Pos) |
| #define | EXTI_SWIER3_SWIER82 EXTI_SWIER3_SWIER82_Msk |
| #define | EXTI_SWIER3_SWIER84_Pos (20U) |
| #define | EXTI_SWIER3_SWIER84_Msk (0x1UL << EXTI_SWIER3_SWIER84_Pos) |
| #define | EXTI_SWIER3_SWIER84 EXTI_SWIER3_SWIER84_Msk |
| #define | EXTI_SWIER3_SWIER85_Pos (21U) |
| #define | EXTI_SWIER3_SWIER85_Msk (0x1UL << EXTI_SWIER3_SWIER85_Pos) |
| #define | EXTI_SWIER3_SWIER85 EXTI_SWIER3_SWIER85_Msk |
| #define | EXTI_SWIER3_SWIER86_Pos (22U) |
| #define | EXTI_SWIER3_SWIER86_Msk (0x1UL << EXTI_SWIER3_SWIER86_Pos) |
| #define | EXTI_SWIER3_SWIER86 EXTI_SWIER3_SWIER86_Msk |
| #define | EXTI_IMR1_IM_Pos (0U) |
| #define | EXTI_IMR1_IM_Msk (0xFFFFFFFFUL << EXTI_IMR1_IM_Pos) |
| #define | EXTI_IMR1_IM EXTI_IMR1_IM_Msk |
| #define | EXTI_IMR1_IM0_Pos (0U) |
| #define | EXTI_IMR1_IM0_Msk (0x1UL << EXTI_IMR1_IM0_Pos) |
| #define | EXTI_IMR1_IM0 EXTI_IMR1_IM0_Msk |
| #define | EXTI_IMR1_IM1_Pos (1U) |
| #define | EXTI_IMR1_IM1_Msk (0x1UL << EXTI_IMR1_IM1_Pos) |
| #define | EXTI_IMR1_IM1 EXTI_IMR1_IM1_Msk |
| #define | EXTI_IMR1_IM2_Pos (2U) |
| #define | EXTI_IMR1_IM2_Msk (0x1UL << EXTI_IMR1_IM2_Pos) |
| #define | EXTI_IMR1_IM2 EXTI_IMR1_IM2_Msk |
| #define | EXTI_IMR1_IM3_Pos (3U) |
| #define | EXTI_IMR1_IM3_Msk (0x1UL << EXTI_IMR1_IM3_Pos) |
| #define | EXTI_IMR1_IM3 EXTI_IMR1_IM3_Msk |
| #define | EXTI_IMR1_IM4_Pos (4U) |
| #define | EXTI_IMR1_IM4_Msk (0x1UL << EXTI_IMR1_IM4_Pos) |
| #define | EXTI_IMR1_IM4 EXTI_IMR1_IM4_Msk |
| #define | EXTI_IMR1_IM5_Pos (5U) |
| #define | EXTI_IMR1_IM5_Msk (0x1UL << EXTI_IMR1_IM5_Pos) |
| #define | EXTI_IMR1_IM5 EXTI_IMR1_IM5_Msk |
| #define | EXTI_IMR1_IM6_Pos (6U) |
| #define | EXTI_IMR1_IM6_Msk (0x1UL << EXTI_IMR1_IM6_Pos) |
| #define | EXTI_IMR1_IM6 EXTI_IMR1_IM6_Msk |
| #define | EXTI_IMR1_IM7_Pos (7U) |
| #define | EXTI_IMR1_IM7_Msk (0x1UL << EXTI_IMR1_IM7_Pos) |
| #define | EXTI_IMR1_IM7 EXTI_IMR1_IM7_Msk |
| #define | EXTI_IMR1_IM8_Pos (8U) |
| #define | EXTI_IMR1_IM8_Msk (0x1UL << EXTI_IMR1_IM8_Pos) |
| #define | EXTI_IMR1_IM8 EXTI_IMR1_IM8_Msk |
| #define | EXTI_IMR1_IM9_Pos (9U) |
| #define | EXTI_IMR1_IM9_Msk (0x1UL << EXTI_IMR1_IM9_Pos) |
| #define | EXTI_IMR1_IM9 EXTI_IMR1_IM9_Msk |
| #define | EXTI_IMR1_IM10_Pos (10U) |
| #define | EXTI_IMR1_IM10_Msk (0x1UL << EXTI_IMR1_IM10_Pos) |
| #define | EXTI_IMR1_IM10 EXTI_IMR1_IM10_Msk |
| #define | EXTI_IMR1_IM11_Pos (11U) |
| #define | EXTI_IMR1_IM11_Msk (0x1UL << EXTI_IMR1_IM11_Pos) |
| #define | EXTI_IMR1_IM11 EXTI_IMR1_IM11_Msk |
| #define | EXTI_IMR1_IM12_Pos (12U) |
| #define | EXTI_IMR1_IM12_Msk (0x1UL << EXTI_IMR1_IM12_Pos) |
| #define | EXTI_IMR1_IM12 EXTI_IMR1_IM12_Msk |
| #define | EXTI_IMR1_IM13_Pos (13U) |
| #define | EXTI_IMR1_IM13_Msk (0x1UL << EXTI_IMR1_IM13_Pos) |
| #define | EXTI_IMR1_IM13 EXTI_IMR1_IM13_Msk |
| #define | EXTI_IMR1_IM14_Pos (14U) |
| #define | EXTI_IMR1_IM14_Msk (0x1UL << EXTI_IMR1_IM14_Pos) |
| #define | EXTI_IMR1_IM14 EXTI_IMR1_IM14_Msk |
| #define | EXTI_IMR1_IM15_Pos (15U) |
| #define | EXTI_IMR1_IM15_Msk (0x1UL << EXTI_IMR1_IM15_Pos) |
| #define | EXTI_IMR1_IM15 EXTI_IMR1_IM15_Msk |
| #define | EXTI_IMR1_IM16_Pos (16U) |
| #define | EXTI_IMR1_IM16_Msk (0x1UL << EXTI_IMR1_IM16_Pos) |
| #define | EXTI_IMR1_IM16 EXTI_IMR1_IM16_Msk |
| #define | EXTI_IMR1_IM17_Pos (17U) |
| #define | EXTI_IMR1_IM17_Msk (0x1UL << EXTI_IMR1_IM17_Pos) |
| #define | EXTI_IMR1_IM17 EXTI_IMR1_IM17_Msk |
| #define | EXTI_IMR1_IM18_Pos (18U) |
| #define | EXTI_IMR1_IM18_Msk (0x1UL << EXTI_IMR1_IM18_Pos) |
| #define | EXTI_IMR1_IM18 EXTI_IMR1_IM18_Msk |
| #define | EXTI_IMR1_IM19_Pos (19U) |
| #define | EXTI_IMR1_IM19_Msk (0x1UL << EXTI_IMR1_IM19_Pos) |
| #define | EXTI_IMR1_IM19 EXTI_IMR1_IM19_Msk |
| #define | EXTI_IMR1_IM20_Pos (20U) |
| #define | EXTI_IMR1_IM20_Msk (0x1UL << EXTI_IMR1_IM20_Pos) |
| #define | EXTI_IMR1_IM20 EXTI_IMR1_IM20_Msk |
| #define | EXTI_IMR1_IM21_Pos (21U) |
| #define | EXTI_IMR1_IM21_Msk (0x1UL << EXTI_IMR1_IM21_Pos) |
| #define | EXTI_IMR1_IM21 EXTI_IMR1_IM21_Msk |
| #define | EXTI_IMR1_IM22_Pos (22U) |
| #define | EXTI_IMR1_IM22_Msk (0x1UL << EXTI_IMR1_IM22_Pos) |
| #define | EXTI_IMR1_IM22 EXTI_IMR1_IM22_Msk |
| #define | EXTI_IMR1_IM23_Pos (23U) |
| #define | EXTI_IMR1_IM23_Msk (0x1UL << EXTI_IMR1_IM23_Pos) |
| #define | EXTI_IMR1_IM23 EXTI_IMR1_IM23_Msk |
| #define | EXTI_IMR1_IM24_Pos (24U) |
| #define | EXTI_IMR1_IM24_Msk (0x1UL << EXTI_IMR1_IM24_Pos) |
| #define | EXTI_IMR1_IM24 EXTI_IMR1_IM24_Msk |
| #define | EXTI_IMR1_IM25_Pos (25U) |
| #define | EXTI_IMR1_IM25_Msk (0x1UL << EXTI_IMR1_IM25_Pos) |
| #define | EXTI_IMR1_IM25 EXTI_IMR1_IM25_Msk |
| #define | EXTI_IMR1_IM26_Pos (26U) |
| #define | EXTI_IMR1_IM26_Msk (0x1UL << EXTI_IMR1_IM26_Pos) |
| #define | EXTI_IMR1_IM26 EXTI_IMR1_IM26_Msk |
| #define | EXTI_IMR1_IM27_Pos (27U) |
| #define | EXTI_IMR1_IM27_Msk (0x1UL << EXTI_IMR1_IM27_Pos) |
| #define | EXTI_IMR1_IM27 EXTI_IMR1_IM27_Msk |
| #define | EXTI_IMR1_IM28_Pos (28U) |
| #define | EXTI_IMR1_IM28_Msk (0x1UL << EXTI_IMR1_IM28_Pos) |
| #define | EXTI_IMR1_IM28 EXTI_IMR1_IM28_Msk |
| #define | EXTI_IMR1_IM29_Pos (29U) |
| #define | EXTI_IMR1_IM29_Msk (0x1UL << EXTI_IMR1_IM29_Pos) |
| #define | EXTI_IMR1_IM29 EXTI_IMR1_IM29_Msk |
| #define | EXTI_IMR1_IM30_Pos (30U) |
| #define | EXTI_IMR1_IM30_Msk (0x1UL << EXTI_IMR1_IM30_Pos) |
| #define | EXTI_IMR1_IM30 EXTI_IMR1_IM30_Msk |
| #define | EXTI_IMR1_IM31_Pos (31U) |
| #define | EXTI_IMR1_IM31_Msk (0x1UL << EXTI_IMR1_IM31_Pos) |
| #define | EXTI_IMR1_IM31 EXTI_IMR1_IM31_Msk |
| #define | EXTI_EMR1_EM_Pos (0U) |
| #define | EXTI_EMR1_EM_Msk (0xFFFFFFFFUL << EXTI_EMR1_EM_Pos) |
| #define | EXTI_EMR1_EM EXTI_EMR1_EM_Msk |
| #define | EXTI_EMR1_EM0_Pos (0U) |
| #define | EXTI_EMR1_EM0_Msk (0x1UL << EXTI_EMR1_EM0_Pos) |
| #define | EXTI_EMR1_EM0 EXTI_EMR1_EM0_Msk |
| #define | EXTI_EMR1_EM1_Pos (1U) |
| #define | EXTI_EMR1_EM1_Msk (0x1UL << EXTI_EMR1_EM1_Pos) |
| #define | EXTI_EMR1_EM1 EXTI_EMR1_EM1_Msk |
| #define | EXTI_EMR1_EM2_Pos (2U) |
| #define | EXTI_EMR1_EM2_Msk (0x1UL << EXTI_EMR1_EM2_Pos) |
| #define | EXTI_EMR1_EM2 EXTI_EMR1_EM2_Msk |
| #define | EXTI_EMR1_EM3_Pos (3U) |
| #define | EXTI_EMR1_EM3_Msk (0x1UL << EXTI_EMR1_EM3_Pos) |
| #define | EXTI_EMR1_EM3 EXTI_EMR1_EM3_Msk |
| #define | EXTI_EMR1_EM4_Pos (4U) |
| #define | EXTI_EMR1_EM4_Msk (0x1UL << EXTI_EMR1_EM4_Pos) |
| #define | EXTI_EMR1_EM4 EXTI_EMR1_EM4_Msk |
| #define | EXTI_EMR1_EM5_Pos (5U) |
| #define | EXTI_EMR1_EM5_Msk (0x1UL << EXTI_EMR1_EM5_Pos) |
| #define | EXTI_EMR1_EM5 EXTI_EMR1_EM5_Msk |
| #define | EXTI_EMR1_EM6_Pos (6U) |
| #define | EXTI_EMR1_EM6_Msk (0x1UL << EXTI_EMR1_EM6_Pos) |
| #define | EXTI_EMR1_EM6 EXTI_EMR1_EM6_Msk |
| #define | EXTI_EMR1_EM7_Pos (7U) |
| #define | EXTI_EMR1_EM7_Msk (0x1UL << EXTI_EMR1_EM7_Pos) |
| #define | EXTI_EMR1_EM7 EXTI_EMR1_EM7_Msk |
| #define | EXTI_EMR1_EM8_Pos (8U) |
| #define | EXTI_EMR1_EM8_Msk (0x1UL << EXTI_EMR1_EM8_Pos) |
| #define | EXTI_EMR1_EM8 EXTI_EMR1_EM8_Msk |
| #define | EXTI_EMR1_EM9_Pos (9U) |
| #define | EXTI_EMR1_EM9_Msk (0x1UL << EXTI_EMR1_EM9_Pos) |
| #define | EXTI_EMR1_EM9 EXTI_EMR1_EM9_Msk |
| #define | EXTI_EMR1_EM10_Pos (10U) |
| #define | EXTI_EMR1_EM10_Msk (0x1UL << EXTI_EMR1_EM10_Pos) |
| #define | EXTI_EMR1_EM10 EXTI_EMR1_EM10_Msk |
| #define | EXTI_EMR1_EM11_Pos (11U) |
| #define | EXTI_EMR1_EM11_Msk (0x1UL << EXTI_EMR1_EM11_Pos) |
| #define | EXTI_EMR1_EM11 EXTI_EMR1_EM11_Msk |
| #define | EXTI_EMR1_EM12_Pos (12U) |
| #define | EXTI_EMR1_EM12_Msk (0x1UL << EXTI_EMR1_EM12_Pos) |
| #define | EXTI_EMR1_EM12 EXTI_EMR1_EM12_Msk |
| #define | EXTI_EMR1_EM13_Pos (13U) |
| #define | EXTI_EMR1_EM13_Msk (0x1UL << EXTI_EMR1_EM13_Pos) |
| #define | EXTI_EMR1_EM13 EXTI_EMR1_EM13_Msk |
| #define | EXTI_EMR1_EM14_Pos (14U) |
| #define | EXTI_EMR1_EM14_Msk (0x1UL << EXTI_EMR1_EM14_Pos) |
| #define | EXTI_EMR1_EM14 EXTI_EMR1_EM14_Msk |
| #define | EXTI_EMR1_EM15_Pos (15U) |
| #define | EXTI_EMR1_EM15_Msk (0x1UL << EXTI_EMR1_EM15_Pos) |
| #define | EXTI_EMR1_EM15 EXTI_EMR1_EM15_Msk |
| #define | EXTI_EMR1_EM16_Pos (16U) |
| #define | EXTI_EMR1_EM16_Msk (0x1UL << EXTI_EMR1_EM16_Pos) |
| #define | EXTI_EMR1_EM16 EXTI_EMR1_EM16_Msk |
| #define | EXTI_EMR1_EM17_Pos (17U) |
| #define | EXTI_EMR1_EM17_Msk (0x1UL << EXTI_EMR1_EM17_Pos) |
| #define | EXTI_EMR1_EM17 EXTI_EMR1_EM17_Msk |
| #define | EXTI_EMR1_EM18_Pos (18U) |
| #define | EXTI_EMR1_EM18_Msk (0x1UL << EXTI_EMR1_EM18_Pos) |
| #define | EXTI_EMR1_EM18 EXTI_EMR1_EM18_Msk |
| #define | EXTI_EMR1_EM20_Pos (20U) |
| #define | EXTI_EMR1_EM20_Msk (0x1UL << EXTI_EMR1_EM20_Pos) |
| #define | EXTI_EMR1_EM20 EXTI_EMR1_EM20_Msk |
| #define | EXTI_EMR1_EM21_Pos (21U) |
| #define | EXTI_EMR1_EM21_Msk (0x1UL << EXTI_EMR1_EM21_Pos) |
| #define | EXTI_EMR1_EM21 EXTI_EMR1_EM21_Msk |
| #define | EXTI_EMR1_EM22_Pos (22U) |
| #define | EXTI_EMR1_EM22_Msk (0x1UL << EXTI_EMR1_EM22_Pos) |
| #define | EXTI_EMR1_EM22 EXTI_EMR1_EM22_Msk |
| #define | EXTI_EMR1_EM23_Pos (23U) |
| #define | EXTI_EMR1_EM23_Msk (0x1UL << EXTI_EMR1_EM23_Pos) |
| #define | EXTI_EMR1_EM23 EXTI_EMR1_EM23_Msk |
| #define | EXTI_EMR1_EM24_Pos (24U) |
| #define | EXTI_EMR1_EM24_Msk (0x1UL << EXTI_EMR1_EM24_Pos) |
| #define | EXTI_EMR1_EM24 EXTI_EMR1_EM24_Msk |
| #define | EXTI_EMR1_EM25_Pos (25U) |
| #define | EXTI_EMR1_EM25_Msk (0x1UL << EXTI_EMR1_EM25_Pos) |
| #define | EXTI_EMR1_EM25 EXTI_EMR1_EM25_Msk |
| #define | EXTI_EMR1_EM26_Pos (26U) |
| #define | EXTI_EMR1_EM26_Msk (0x1UL << EXTI_EMR1_EM26_Pos) |
| #define | EXTI_EMR1_EM26 EXTI_EMR1_EM26_Msk |
| #define | EXTI_EMR1_EM27_Pos (27U) |
| #define | EXTI_EMR1_EM27_Msk (0x1UL << EXTI_EMR1_EM27_Pos) |
| #define | EXTI_EMR1_EM27 EXTI_EMR1_EM27_Msk |
| #define | EXTI_EMR1_EM28_Pos (28U) |
| #define | EXTI_EMR1_EM28_Msk (0x1UL << EXTI_EMR1_EM28_Pos) |
| #define | EXTI_EMR1_EM28 EXTI_EMR1_EM28_Msk |
| #define | EXTI_EMR1_EM29_Pos (29U) |
| #define | EXTI_EMR1_EM29_Msk (0x1UL << EXTI_EMR1_EM29_Pos) |
| #define | EXTI_EMR1_EM29 EXTI_EMR1_EM29_Msk |
| #define | EXTI_EMR1_EM30_Pos (30U) |
| #define | EXTI_EMR1_EM30_Msk (0x1UL << EXTI_EMR1_EM30_Pos) |
| #define | EXTI_EMR1_EM30 EXTI_EMR1_EM30_Msk |
| #define | EXTI_EMR1_EM31_Pos (31U) |
| #define | EXTI_EMR1_EM31_Msk (0x1UL << EXTI_EMR1_EM31_Pos) |
| #define | EXTI_EMR1_EM31 EXTI_EMR1_EM31_Msk |
| #define | EXTI_PR1_PR_Pos (0U) |
| #define | EXTI_PR1_PR_Msk (0x3FFFFFUL << EXTI_PR1_PR_Pos) |
| #define | EXTI_PR1_PR EXTI_PR1_PR_Msk |
| #define | EXTI_PR1_PR0_Pos (0U) |
| #define | EXTI_PR1_PR0_Msk (0x1UL << EXTI_PR1_PR0_Pos) |
| #define | EXTI_PR1_PR0 EXTI_PR1_PR0_Msk |
| #define | EXTI_PR1_PR1_Pos (1U) |
| #define | EXTI_PR1_PR1_Msk (0x1UL << EXTI_PR1_PR1_Pos) |
| #define | EXTI_PR1_PR1 EXTI_PR1_PR1_Msk |
| #define | EXTI_PR1_PR2_Pos (2U) |
| #define | EXTI_PR1_PR2_Msk (0x1UL << EXTI_PR1_PR2_Pos) |
| #define | EXTI_PR1_PR2 EXTI_PR1_PR2_Msk |
| #define | EXTI_PR1_PR3_Pos (3U) |
| #define | EXTI_PR1_PR3_Msk (0x1UL << EXTI_PR1_PR3_Pos) |
| #define | EXTI_PR1_PR3 EXTI_PR1_PR3_Msk |
| #define | EXTI_PR1_PR4_Pos (4U) |
| #define | EXTI_PR1_PR4_Msk (0x1UL << EXTI_PR1_PR4_Pos) |
| #define | EXTI_PR1_PR4 EXTI_PR1_PR4_Msk |
| #define | EXTI_PR1_PR5_Pos (5U) |
| #define | EXTI_PR1_PR5_Msk (0x1UL << EXTI_PR1_PR5_Pos) |
| #define | EXTI_PR1_PR5 EXTI_PR1_PR5_Msk |
| #define | EXTI_PR1_PR6_Pos (6U) |
| #define | EXTI_PR1_PR6_Msk (0x1UL << EXTI_PR1_PR6_Pos) |
| #define | EXTI_PR1_PR6 EXTI_PR1_PR6_Msk |
| #define | EXTI_PR1_PR7_Pos (7U) |
| #define | EXTI_PR1_PR7_Msk (0x1UL << EXTI_PR1_PR7_Pos) |
| #define | EXTI_PR1_PR7 EXTI_PR1_PR7_Msk |
| #define | EXTI_PR1_PR8_Pos (8U) |
| #define | EXTI_PR1_PR8_Msk (0x1UL << EXTI_PR1_PR8_Pos) |
| #define | EXTI_PR1_PR8 EXTI_PR1_PR8_Msk |
| #define | EXTI_PR1_PR9_Pos (9U) |
| #define | EXTI_PR1_PR9_Msk (0x1UL << EXTI_PR1_PR9_Pos) |
| #define | EXTI_PR1_PR9 EXTI_PR1_PR9_Msk |
| #define | EXTI_PR1_PR10_Pos (10U) |
| #define | EXTI_PR1_PR10_Msk (0x1UL << EXTI_PR1_PR10_Pos) |
| #define | EXTI_PR1_PR10 EXTI_PR1_PR10_Msk |
| #define | EXTI_PR1_PR11_Pos (11U) |
| #define | EXTI_PR1_PR11_Msk (0x1UL << EXTI_PR1_PR11_Pos) |
| #define | EXTI_PR1_PR11 EXTI_PR1_PR11_Msk |
| #define | EXTI_PR1_PR12_Pos (12U) |
| #define | EXTI_PR1_PR12_Msk (0x1UL << EXTI_PR1_PR12_Pos) |
| #define | EXTI_PR1_PR12 EXTI_PR1_PR12_Msk |
| #define | EXTI_PR1_PR13_Pos (13U) |
| #define | EXTI_PR1_PR13_Msk (0x1UL << EXTI_PR1_PR13_Pos) |
| #define | EXTI_PR1_PR13 EXTI_PR1_PR13_Msk |
| #define | EXTI_PR1_PR14_Pos (14U) |
| #define | EXTI_PR1_PR14_Msk (0x1UL << EXTI_PR1_PR14_Pos) |
| #define | EXTI_PR1_PR14 EXTI_PR1_PR14_Msk |
| #define | EXTI_PR1_PR15_Pos (15U) |
| #define | EXTI_PR1_PR15_Msk (0x1UL << EXTI_PR1_PR15_Pos) |
| #define | EXTI_PR1_PR15 EXTI_PR1_PR15_Msk |
| #define | EXTI_PR1_PR16_Pos (16U) |
| #define | EXTI_PR1_PR16_Msk (0x1UL << EXTI_PR1_PR16_Pos) |
| #define | EXTI_PR1_PR16 EXTI_PR1_PR16_Msk |
| #define | EXTI_PR1_PR17_Pos (17U) |
| #define | EXTI_PR1_PR17_Msk (0x1UL << EXTI_PR1_PR17_Pos) |
| #define | EXTI_PR1_PR17 EXTI_PR1_PR17_Msk |
| #define | EXTI_PR1_PR18_Pos (18U) |
| #define | EXTI_PR1_PR18_Msk (0x1UL << EXTI_PR1_PR18_Pos) |
| #define | EXTI_PR1_PR18 EXTI_PR1_PR18_Msk |
| #define | EXTI_PR1_PR19_Pos (19U) |
| #define | EXTI_PR1_PR19_Msk (0x1UL << EXTI_PR1_PR19_Pos) |
| #define | EXTI_PR1_PR19 EXTI_PR1_PR19_Msk |
| #define | EXTI_PR1_PR20_Pos (20U) |
| #define | EXTI_PR1_PR20_Msk (0x1UL << EXTI_PR1_PR20_Pos) |
| #define | EXTI_PR1_PR20 EXTI_PR1_PR20_Msk |
| #define | EXTI_PR1_PR21_Pos (21U) |
| #define | EXTI_PR1_PR21_Msk (0x1UL << EXTI_PR1_PR21_Pos) |
| #define | EXTI_PR1_PR21 EXTI_PR1_PR21_Msk |
| #define | EXTI_IMR2_IM_Pos (0U) |
| #define | EXTI_IMR2_IM_Msk (0xFFFFDFFFUL << EXTI_IMR2_IM_Pos) |
| #define | EXTI_IMR2_IM EXTI_IMR2_IM_Msk |
| #define | EXTI_IMR2_IM32_Pos (0U) |
| #define | EXTI_IMR2_IM32_Msk (0x1UL << EXTI_IMR2_IM32_Pos) |
| #define | EXTI_IMR2_IM32 EXTI_IMR2_IM32_Msk |
| #define | EXTI_IMR2_IM33_Pos (1U) |
| #define | EXTI_IMR2_IM33_Msk (0x1UL << EXTI_IMR2_IM33_Pos) |
| #define | EXTI_IMR2_IM33 EXTI_IMR2_IM33_Msk |
| #define | EXTI_IMR2_IM34_Pos (2U) |
| #define | EXTI_IMR2_IM34_Msk (0x1UL << EXTI_IMR2_IM34_Pos) |
| #define | EXTI_IMR2_IM34 EXTI_IMR2_IM34_Msk |
| #define | EXTI_IMR2_IM35_Pos (3U) |
| #define | EXTI_IMR2_IM35_Msk (0x1UL << EXTI_IMR2_IM35_Pos) |
| #define | EXTI_IMR2_IM35 EXTI_IMR2_IM35_Msk |
| #define | EXTI_IMR2_IM36_Pos (4U) |
| #define | EXTI_IMR2_IM36_Msk (0x1UL << EXTI_IMR2_IM36_Pos) |
| #define | EXTI_IMR2_IM36 EXTI_IMR2_IM36_Msk |
| #define | EXTI_IMR2_IM37_Pos (5U) |
| #define | EXTI_IMR2_IM37_Msk (0x1UL << EXTI_IMR2_IM37_Pos) |
| #define | EXTI_IMR2_IM37 EXTI_IMR2_IM37_Msk |
| #define | EXTI_IMR2_IM38_Pos (6U) |
| #define | EXTI_IMR2_IM38_Msk (0x1UL << EXTI_IMR2_IM38_Pos) |
| #define | EXTI_IMR2_IM38 EXTI_IMR2_IM38_Msk |
| #define | EXTI_IMR2_IM39_Pos (7U) |
| #define | EXTI_IMR2_IM39_Msk (0x1UL << EXTI_IMR2_IM39_Pos) |
| #define | EXTI_IMR2_IM39 EXTI_IMR2_IM39_Msk |
| #define | EXTI_IMR2_IM40_Pos (8U) |
| #define | EXTI_IMR2_IM40_Msk (0x1UL << EXTI_IMR2_IM40_Pos) |
| #define | EXTI_IMR2_IM40 EXTI_IMR2_IM40_Msk |
| #define | EXTI_IMR2_IM41_Pos (9U) |
| #define | EXTI_IMR2_IM41_Msk (0x1UL << EXTI_IMR2_IM41_Pos) |
| #define | EXTI_IMR2_IM41 EXTI_IMR2_IM41_Msk |
| #define | EXTI_IMR2_IM42_Pos (10U) |
| #define | EXTI_IMR2_IM42_Msk (0x1UL << EXTI_IMR2_IM42_Pos) |
| #define | EXTI_IMR2_IM42 EXTI_IMR2_IM42_Msk |
| #define | EXTI_IMR2_IM43_Pos (11U) |
| #define | EXTI_IMR2_IM43_Msk (0x1UL << EXTI_IMR2_IM43_Pos) |
| #define | EXTI_IMR2_IM43 EXTI_IMR2_IM43_Msk |
| #define | EXTI_IMR2_IM44_Pos (12U) |
| #define | EXTI_IMR2_IM44_Msk (0x1UL << EXTI_IMR2_IM44_Pos) |
| #define | EXTI_IMR2_IM44 EXTI_IMR2_IM44_Msk |
| #define | EXTI_IMR2_IM46_Pos (14U) |
| #define | EXTI_IMR2_IM46_Msk (0x1UL << EXTI_IMR2_IM46_Pos) |
| #define | EXTI_IMR2_IM46 EXTI_IMR2_IM46_Msk |
| #define | EXTI_IMR2_IM47_Pos (15U) |
| #define | EXTI_IMR2_IM47_Msk (0x1UL << EXTI_IMR2_IM47_Pos) |
| #define | EXTI_IMR2_IM47 EXTI_IMR2_IM47_Msk |
| #define | EXTI_IMR2_IM48_Pos (16U) |
| #define | EXTI_IMR2_IM48_Msk (0x1UL << EXTI_IMR2_IM48_Pos) |
| #define | EXTI_IMR2_IM48 EXTI_IMR2_IM48_Msk |
| #define | EXTI_IMR2_IM49_Pos (17U) |
| #define | EXTI_IMR2_IM49_Msk (0x1UL << EXTI_IMR2_IM49_Pos) |
| #define | EXTI_IMR2_IM49 EXTI_IMR2_IM49_Msk |
| #define | EXTI_IMR2_IM50_Pos (18U) |
| #define | EXTI_IMR2_IM50_Msk (0x1UL << EXTI_IMR2_IM50_Pos) |
| #define | EXTI_IMR2_IM50 EXTI_IMR2_IM50_Msk |
| #define | EXTI_IMR2_IM51_Pos (19U) |
| #define | EXTI_IMR2_IM51_Msk (0x1UL << EXTI_IMR2_IM51_Pos) |
| #define | EXTI_IMR2_IM51 EXTI_IMR2_IM51_Msk |
| #define | EXTI_IMR2_IM52_Pos (20U) |
| #define | EXTI_IMR2_IM52_Msk (0x1UL << EXTI_IMR2_IM52_Pos) |
| #define | EXTI_IMR2_IM52 EXTI_IMR2_IM52_Msk |
| #define | EXTI_IMR2_IM53_Pos (21U) |
| #define | EXTI_IMR2_IM53_Msk (0x1UL << EXTI_IMR2_IM53_Pos) |
| #define | EXTI_IMR2_IM53 EXTI_IMR2_IM53_Msk |
| #define | EXTI_IMR2_IM54_Pos (22U) |
| #define | EXTI_IMR2_IM54_Msk (0x1UL << EXTI_IMR2_IM54_Pos) |
| #define | EXTI_IMR2_IM54 EXTI_IMR2_IM54_Msk |
| #define | EXTI_IMR2_IM55_Pos (23U) |
| #define | EXTI_IMR2_IM55_Msk (0x1UL << EXTI_IMR2_IM55_Pos) |
| #define | EXTI_IMR2_IM55 EXTI_IMR2_IM55_Msk |
| #define | EXTI_IMR2_IM56_Pos (24U) |
| #define | EXTI_IMR2_IM56_Msk (0x1UL << EXTI_IMR2_IM56_Pos) |
| #define | EXTI_IMR2_IM56 EXTI_IMR2_IM56_Msk |
| #define | EXTI_IMR2_IM57_Pos (25U) |
| #define | EXTI_IMR2_IM57_Msk (0x1UL << EXTI_IMR2_IM57_Pos) |
| #define | EXTI_IMR2_IM57 EXTI_IMR2_IM57_Msk |
| #define | EXTI_IMR2_IM58_Pos (26U) |
| #define | EXTI_IMR2_IM58_Msk (0x1UL << EXTI_IMR2_IM58_Pos) |
| #define | EXTI_IMR2_IM58 EXTI_IMR2_IM58_Msk |
| #define | EXTI_IMR2_IM59_Pos (27U) |
| #define | EXTI_IMR2_IM59_Msk (0x1UL << EXTI_IMR2_IM59_Pos) |
| #define | EXTI_IMR2_IM59 EXTI_IMR2_IM59_Msk |
| #define | EXTI_IMR2_IM60_Pos (28U) |
| #define | EXTI_IMR2_IM60_Msk (0x1UL << EXTI_IMR2_IM60_Pos) |
| #define | EXTI_IMR2_IM60 EXTI_IMR2_IM60_Msk |
| #define | EXTI_IMR2_IM61_Pos (29U) |
| #define | EXTI_IMR2_IM61_Msk (0x1UL << EXTI_IMR2_IM61_Pos) |
| #define | EXTI_IMR2_IM61 EXTI_IMR2_IM61_Msk |
| #define | EXTI_IMR2_IM62_Pos (30U) |
| #define | EXTI_IMR2_IM62_Msk (0x1UL << EXTI_IMR2_IM62_Pos) |
| #define | EXTI_IMR2_IM62 EXTI_IMR2_IM62_Msk |
| #define | EXTI_IMR2_IM63_Pos (31U) |
| #define | EXTI_IMR2_IM63_Msk (0x1UL << EXTI_IMR2_IM63_Pos) |
| #define | EXTI_IMR2_IM63 EXTI_IMR2_IM63_Msk |
| #define | EXTI_EMR2_EM_Pos (0U) |
| #define | EXTI_EMR2_EM_Msk (0xFFFFDFFFUL << EXTI_EMR2_EM_Pos) |
| #define | EXTI_EMR2_EM EXTI_EMR2_EM_Msk |
| #define | EXTI_EMR2_EM32_Pos (0U) |
| #define | EXTI_EMR2_EM32_Msk (0x1UL << EXTI_EMR2_EM32_Pos) |
| #define | EXTI_EMR2_EM32 EXTI_EMR2_EM32_Msk |
| #define | EXTI_EMR2_EM33_Pos (1U) |
| #define | EXTI_EMR2_EM33_Msk (0x1UL << EXTI_EMR2_EM33_Pos) |
| #define | EXTI_EMR2_EM33 EXTI_EMR2_EM33_Msk |
| #define | EXTI_EMR2_EM34_Pos (2U) |
| #define | EXTI_EMR2_EM34_Msk (0x1UL << EXTI_EMR2_EM34_Pos) |
| #define | EXTI_EMR2_EM34 EXTI_EMR2_EM34_Msk |
| #define | EXTI_EMR2_EM35_Pos (3U) |
| #define | EXTI_EMR2_EM35_Msk (0x1UL << EXTI_EMR2_EM35_Pos) |
| #define | EXTI_EMR2_EM35 EXTI_EMR2_EM35_Msk |
| #define | EXTI_EMR2_EM36_Pos (4U) |
| #define | EXTI_EMR2_EM36_Msk (0x1UL << EXTI_EMR2_EM36_Pos) |
| #define | EXTI_EMR2_EM36 EXTI_EMR2_EM36_Msk |
| #define | EXTI_EMR2_EM37_Pos (5U) |
| #define | EXTI_EMR2_EM37_Msk (0x1UL << EXTI_EMR2_EM37_Pos) |
| #define | EXTI_EMR2_EM37 EXTI_EMR2_EM37_Msk |
| #define | EXTI_EMR2_EM38_Pos (6U) |
| #define | EXTI_EMR2_EM38_Msk (0x1UL << EXTI_EMR2_EM38_Pos) |
| #define | EXTI_EMR2_EM38 EXTI_EMR2_EM38_Msk |
| #define | EXTI_EMR2_EM39_Pos (7U) |
| #define | EXTI_EMR2_EM39_Msk (0x1UL << EXTI_EMR2_EM39_Pos) |
| #define | EXTI_EMR2_EM39 EXTI_EMR2_EM39_Msk |
| #define | EXTI_EMR2_EM40_Pos (8U) |
| #define | EXTI_EMR2_EM40_Msk (0x1UL << EXTI_EMR2_EM40_Pos) |
| #define | EXTI_EMR2_EM40 EXTI_EMR2_EM40_Msk |
| #define | EXTI_EMR2_EM41_Pos (9U) |
| #define | EXTI_EMR2_EM41_Msk (0x1UL << EXTI_EMR2_EM41_Pos) |
| #define | EXTI_EMR2_EM41 EXTI_EMR2_EM41_Msk |
| #define | EXTI_EMR2_EM42_Pos (10U) |
| #define | EXTI_EMR2_EM42_Msk (0x1UL << EXTI_EMR2_EM42_Pos) |
| #define | EXTI_EMR2_EM42 EXTI_EMR2_EM42_Msk |
| #define | EXTI_EMR2_EM43_Pos (11U) |
| #define | EXTI_EMR2_EM43_Msk (0x1UL << EXTI_EMR2_EM43_Pos) |
| #define | EXTI_EMR2_EM43 EXTI_EMR2_EM43_Msk |
| #define | EXTI_EMR2_EM44_Pos (12U) |
| #define | EXTI_EMR2_EM44_Msk (0x1UL << EXTI_EMR2_EM44_Pos) |
| #define | EXTI_EMR2_EM44 EXTI_EMR2_EM44_Msk |
| #define | EXTI_EMR2_EM46_Pos (14U) |
| #define | EXTI_EMR2_EM46_Msk (0x1UL << EXTI_EMR2_EM46_Pos) |
| #define | EXTI_EMR2_EM46 EXTI_EMR2_EM46_Msk |
| #define | EXTI_EMR2_EM47_Pos (15U) |
| #define | EXTI_EMR2_EM47_Msk (0x1UL << EXTI_EMR2_EM47_Pos) |
| #define | EXTI_EMR2_EM47 EXTI_EMR2_EM47_Msk |
| #define | EXTI_EMR2_EM48_Pos (16U) |
| #define | EXTI_EMR2_EM48_Msk (0x1UL << EXTI_EMR2_EM48_Pos) |
| #define | EXTI_EMR2_EM48 EXTI_EMR2_EM48_Msk |
| #define | EXTI_EMR2_EM49_Pos (17U) |
| #define | EXTI_EMR2_EM49_Msk (0x1UL << EXTI_EMR2_EM49_Pos) |
| #define | EXTI_EMR2_EM49 EXTI_EMR2_EM49_Msk |
| #define | EXTI_EMR2_EM50_Pos (18U) |
| #define | EXTI_EMR2_EM50_Msk (0x1UL << EXTI_EMR2_EM50_Pos) |
| #define | EXTI_EMR2_EM50 EXTI_EMR2_EM50_Msk |
| #define | EXTI_EMR2_EM51_Pos (19U) |
| #define | EXTI_EMR2_EM51_Msk (0x1UL << EXTI_EMR2_EM51_Pos) |
| #define | EXTI_EMR2_EM51 EXTI_EMR2_EM51_Msk |
| #define | EXTI_EMR2_EM52_Pos (20U) |
| #define | EXTI_EMR2_EM52_Msk (0x1UL << EXTI_EMR2_EM52_Pos) |
| #define | EXTI_EMR2_EM52 EXTI_EMR2_EM52_Msk |
| #define | EXTI_EMR2_EM53_Pos (21U) |
| #define | EXTI_EMR2_EM53_Msk (0x1UL << EXTI_EMR2_EM53_Pos) |
| #define | EXTI_EMR2_EM53 EXTI_EMR2_EM53_Msk |
| #define | EXTI_EMR2_EM54_Pos (22U) |
| #define | EXTI_EMR2_EM54_Msk (0x1UL << EXTI_EMR2_EM54_Pos) |
| #define | EXTI_EMR2_EM54 EXTI_EMR2_EM54_Msk |
| #define | EXTI_EMR2_EM55_Pos (23U) |
| #define | EXTI_EMR2_EM55_Msk (0x1UL << EXTI_EMR2_EM55_Pos) |
| #define | EXTI_EMR2_EM55 EXTI_EMR2_EM55_Msk |
| #define | EXTI_EMR2_EM56_Pos (24U) |
| #define | EXTI_EMR2_EM56_Msk (0x1UL << EXTI_EMR2_EM56_Pos) |
| #define | EXTI_EMR2_EM56 EXTI_EMR2_EM56_Msk |
| #define | EXTI_EMR2_EM57_Pos (25U) |
| #define | EXTI_EMR2_EM57_Msk (0x1UL << EXTI_EMR2_EM57_Pos) |
| #define | EXTI_EMR2_EM57 EXTI_EMR2_EM57_Msk |
| #define | EXTI_EMR2_EM58_Pos (26U) |
| #define | EXTI_EMR2_EM58_Msk (0x1UL << EXTI_EMR2_EM58_Pos) |
| #define | EXTI_EMR2_EM58 EXTI_EMR2_EM58_Msk |
| #define | EXTI_EMR2_EM59_Pos (27U) |
| #define | EXTI_EMR2_EM59_Msk (0x1UL << EXTI_EMR2_EM59_Pos) |
| #define | EXTI_EMR2_EM59 EXTI_EMR2_EM59_Msk |
| #define | EXTI_EMR2_EM60_Pos (28U) |
| #define | EXTI_EMR2_EM60_Msk (0x1UL << EXTI_EMR2_EM60_Pos) |
| #define | EXTI_EMR2_EM60 EXTI_EMR2_EM60_Msk |
| #define | EXTI_EMR2_EM61_Pos (29U) |
| #define | EXTI_EMR2_EM61_Msk (0x1UL << EXTI_EMR2_EM61_Pos) |
| #define | EXTI_EMR2_EM61 EXTI_EMR2_EM61_Msk |
| #define | EXTI_EMR2_EM62_Pos (30U) |
| #define | EXTI_EMR2_EM62_Msk (0x1UL << EXTI_EMR2_EM62_Pos) |
| #define | EXTI_EMR2_EM62 EXTI_EMR2_EM62_Msk |
| #define | EXTI_EMR2_EM63_Pos (31U) |
| #define | EXTI_EMR2_EM63_Msk (0x1UL << EXTI_EMR2_EM63_Pos) |
| #define | EXTI_EMR2_EM63 EXTI_EMR2_EM63_Msk |
| #define | EXTI_PR2_PR_Pos (17U) |
| #define | EXTI_PR2_PR_Msk (0x5UL << EXTI_PR2_PR_Pos) |
| #define | EXTI_PR2_PR EXTI_PR2_PR_Msk |
| #define | EXTI_PR2_PR49_Pos (17U) |
| #define | EXTI_PR2_PR49_Msk (0x1UL << EXTI_PR2_PR49_Pos) |
| #define | EXTI_PR2_PR49 EXTI_PR2_PR49_Msk |
| #define | EXTI_PR2_PR51_Pos (19U) |
| #define | EXTI_PR2_PR51_Msk (0x1UL << EXTI_PR2_PR51_Pos) |
| #define | EXTI_PR2_PR51 EXTI_PR2_PR51_Msk |
| #define | EXTI_IMR3_IM_Pos (0U) |
| #define | EXTI_IMR3_IM_Msk (0x00F5FFFFUL << EXTI_IMR3_IM_Pos) |
| #define | EXTI_IMR3_IM EXTI_IMR3_IM_Msk |
| #define | EXTI_IMR3_IM64_Pos (0U) |
| #define | EXTI_IMR3_IM64_Msk (0x1UL << EXTI_IMR3_IM64_Pos) |
| #define | EXTI_IMR3_IM64 EXTI_IMR3_IM64_Msk |
| #define | EXTI_IMR3_IM65_Pos (1U) |
| #define | EXTI_IMR3_IM65_Msk (0x1UL << EXTI_IMR3_IM65_Pos) |
| #define | EXTI_IMR3_IM65 EXTI_IMR3_IM65_Msk |
| #define | EXTI_IMR3_IM66_Pos (2U) |
| #define | EXTI_IMR3_IM66_Msk (0x1UL << EXTI_IMR3_IM66_Pos) |
| #define | EXTI_IMR3_IM66 EXTI_IMR3_IM66_Msk |
| #define | EXTI_IMR3_IM67_Pos (3U) |
| #define | EXTI_IMR3_IM67_Msk (0x1UL << EXTI_IMR3_IM67_Pos) |
| #define | EXTI_IMR3_IM67 EXTI_IMR3_IM67_Msk |
| #define | EXTI_IMR3_IM68_Pos (4U) |
| #define | EXTI_IMR3_IM68_Msk (0x1UL << EXTI_IMR3_IM68_Pos) |
| #define | EXTI_IMR3_IM68 EXTI_IMR3_IM68_Msk |
| #define | EXTI_IMR3_IM69_Pos (5U) |
| #define | EXTI_IMR3_IM69_Msk (0x1UL << EXTI_IMR3_IM69_Pos) |
| #define | EXTI_IMR3_IM69 EXTI_IMR3_IM69_Msk |
| #define | EXTI_IMR3_IM70_Pos (6U) |
| #define | EXTI_IMR3_IM70_Msk (0x1UL << EXTI_IMR3_IM70_Pos) |
| #define | EXTI_IMR3_IM70 EXTI_IMR3_IM70_Msk |
| #define | EXTI_IMR3_IM71_Pos (7U) |
| #define | EXTI_IMR3_IM71_Msk (0x1UL << EXTI_IMR3_IM71_Pos) |
| #define | EXTI_IMR3_IM71 EXTI_IMR3_IM71_Msk |
| #define | EXTI_IMR3_IM72_Pos (8U) |
| #define | EXTI_IMR3_IM72_Msk (0x1UL << EXTI_IMR3_IM72_Pos) |
| #define | EXTI_IMR3_IM72 EXTI_IMR3_IM72_Msk |
| #define | EXTI_IMR3_IM73_Pos (9U) |
| #define | EXTI_IMR3_IM73_Msk (0x1UL << EXTI_IMR3_IM73_Pos) |
| #define | EXTI_IMR3_IM73 EXTI_IMR3_IM73_Msk |
| #define | EXTI_IMR3_IM74_Pos (10U) |
| #define | EXTI_IMR3_IM74_Msk (0x1UL << EXTI_IMR3_IM74_Pos) |
| #define | EXTI_IMR3_IM74 EXTI_IMR3_IM74_Msk |
| #define | EXTI_IMR3_IM75_Pos (11U) |
| #define | EXTI_IMR3_IM75_Msk (0x1UL << EXTI_IMR3_IM75_Pos) |
| #define | EXTI_IMR3_IM75 EXTI_IMR3_IM75_Msk |
| #define | EXTI_IMR3_IM76_Pos (12U) |
| #define | EXTI_IMR3_IM76_Msk (0x1UL << EXTI_IMR3_IM76_Pos) |
| #define | EXTI_IMR3_IM76 EXTI_IMR3_IM76_Msk |
| #define | EXTI_IMR3_IM77_Pos (13U) |
| #define | EXTI_IMR3_IM77_Msk (0x1UL << EXTI_IMR3_IM77_Pos) |
| #define | EXTI_IMR3_IM77 EXTI_IMR3_IM77_Msk |
| #define | EXTI_IMR3_IM78_Pos (14U) |
| #define | EXTI_IMR3_IM78_Msk (0x1UL << EXTI_IMR3_IM78_Pos) |
| #define | EXTI_IMR3_IM78 EXTI_IMR3_IM78_Msk |
| #define | EXTI_IMR3_IM79_Pos (15U) |
| #define | EXTI_IMR3_IM79_Msk (0x1UL << EXTI_IMR3_IM79_Pos) |
| #define | EXTI_IMR3_IM79 EXTI_IMR3_IM79_Msk |
| #define | EXTI_IMR3_IM80_Pos (16U) |
| #define | EXTI_IMR3_IM80_Msk (0x1UL << EXTI_IMR3_IM80_Pos) |
| #define | EXTI_IMR3_IM80 EXTI_IMR3_IM80_Msk |
| #define | EXTI_IMR3_IM82_Pos (18U) |
| #define | EXTI_IMR3_IM82_Msk (0x1UL << EXTI_IMR3_IM82_Pos) |
| #define | EXTI_IMR3_IM82 EXTI_IMR3_IM82_Msk |
| #define | EXTI_IMR3_IM84_Pos (20U) |
| #define | EXTI_IMR3_IM84_Msk (0x1UL << EXTI_IMR3_IM84_Pos) |
| #define | EXTI_IMR3_IM84 EXTI_IMR3_IM84_Msk |
| #define | EXTI_IMR3_IM85_Pos (21U) |
| #define | EXTI_IMR3_IM85_Msk (0x1UL << EXTI_IMR3_IM85_Pos) |
| #define | EXTI_IMR3_IM85 EXTI_IMR3_IM85_Msk |
| #define | EXTI_IMR3_IM86_Pos (22U) |
| #define | EXTI_IMR3_IM86_Msk (0x1UL << EXTI_IMR3_IM86_Pos) |
| #define | EXTI_IMR3_IM86 EXTI_IMR3_IM86_Msk |
| #define | EXTI_IMR3_IM87_Pos (23U) |
| #define | EXTI_IMR3_IM87_Msk (0x1UL << EXTI_IMR3_IM87_Pos) |
| #define | EXTI_IMR3_IM87 EXTI_IMR3_IM87_Msk |
| #define | EXTI_EMR3_EM_Pos (0U) |
| #define | EXTI_EMR3_EM_Msk (0x00F5FFFFUL << EXTI_EMR3_EM_Pos) |
| #define | EXTI_EMR3_EM EXTI_EMR3_EM_Msk |
| #define | EXTI_EMR3_EM64_Pos (0U) |
| #define | EXTI_EMR3_EM64_Msk (0x1UL << EXTI_EMR3_EM64_Pos) |
| #define | EXTI_EMR3_EM64 EXTI_EMR3_EM64_Msk |
| #define | EXTI_EMR3_EM65_Pos (1U) |
| #define | EXTI_EMR3_EM65_Msk (0x1UL << EXTI_EMR3_EM65_Pos) |
| #define | EXTI_EMR3_EM65 EXTI_EMR3_EM65_Msk |
| #define | EXTI_EMR3_EM66_Pos (2U) |
| #define | EXTI_EMR3_EM66_Msk (0x1UL << EXTI_EMR3_EM66_Pos) |
| #define | EXTI_EMR3_EM66 EXTI_EMR3_EM66_Msk |
| #define | EXTI_EMR3_EM67_Pos (3U) |
| #define | EXTI_EMR3_EM67_Msk (0x1UL << EXTI_EMR3_EM67_Pos) |
| #define | EXTI_EMR3_EM67 EXTI_EMR3_EM67_Msk |
| #define | EXTI_EMR3_EM68_Pos (4U) |
| #define | EXTI_EMR3_EM68_Msk (0x1UL << EXTI_EMR3_EM68_Pos) |
| #define | EXTI_EMR3_EM68 EXTI_EMR3_EM68_Msk |
| #define | EXTI_EMR3_EM69_Pos (5U) |
| #define | EXTI_EMR3_EM69_Msk (0x1UL << EXTI_EMR3_EM69_Pos) |
| #define | EXTI_EMR3_EM69 EXTI_EMR3_EM69_Msk |
| #define | EXTI_EMR3_EM70_Pos (6U) |
| #define | EXTI_EMR3_EM70_Msk (0x1UL << EXTI_EMR3_EM70_Pos) |
| #define | EXTI_EMR3_EM70 EXTI_EMR3_EM70_Msk |
| #define | EXTI_EMR3_EM71_Pos (7U) |
| #define | EXTI_EMR3_EM71_Msk (0x1UL << EXTI_EMR3_EM71_Pos) |
| #define | EXTI_EMR3_EM71 EXTI_EMR3_EM71_Msk |
| #define | EXTI_EMR3_EM72_Pos (8U) |
| #define | EXTI_EMR3_EM72_Msk (0x1UL << EXTI_EMR3_EM72_Pos) |
| #define | EXTI_EMR3_EM72 EXTI_EMR3_EM72_Msk |
| #define | EXTI_EMR3_EM73_Pos (9U) |
| #define | EXTI_EMR3_EM73_Msk (0x1UL << EXTI_EMR3_EM73_Pos) |
| #define | EXTI_EMR3_EM73 EXTI_EMR3_EM73_Msk |
| #define | EXTI_EMR3_EM74_Pos (10U) |
| #define | EXTI_EMR3_EM74_Msk (0x1UL << EXTI_EMR3_EM74_Pos) |
| #define | EXTI_EMR3_EM74 EXTI_EMR3_EM74_Msk |
| #define | EXTI_EMR3_EM75_Pos (11U) |
| #define | EXTI_EMR3_EM75_Msk (0x1UL << EXTI_EMR3_EM75_Pos) |
| #define | EXTI_EMR3_EM75 EXTI_EMR3_EM75_Msk |
| #define | EXTI_EMR3_EM76_Pos (12U) |
| #define | EXTI_EMR3_EM76_Msk (0x1UL << EXTI_EMR3_EM76_Pos) |
| #define | EXTI_EMR3_EM76 EXTI_EMR3_EM76_Msk |
| #define | EXTI_EMR3_EM77_Pos (13U) |
| #define | EXTI_EMR3_EM77_Msk (0x1UL << EXTI_EMR3_EM77_Pos) |
| #define | EXTI_EMR3_EM77 EXTI_EMR3_EM77_Msk |
| #define | EXTI_EMR3_EM78_Pos (14U) |
| #define | EXTI_EMR3_EM78_Msk (0x1UL << EXTI_EMR3_EM78_Pos) |
| #define | EXTI_EMR3_EM78 EXTI_EMR3_EM78_Msk |
| #define | EXTI_EMR3_EM79_Pos (15U) |
| #define | EXTI_EMR3_EM79_Msk (0x1UL << EXTI_EMR3_EM79_Pos) |
| #define | EXTI_EMR3_EM79 EXTI_EMR3_EM79_Msk |
| #define | EXTI_EMR3_EM80_Pos (16U) |
| #define | EXTI_EMR3_EM80_Msk (0x1UL << EXTI_EMR3_EM80_Pos) |
| #define | EXTI_EMR3_EM80 EXTI_EMR3_EM80_Msk |
| #define | EXTI_EMR3_EM81_Pos (17U) |
| #define | EXTI_EMR3_EM81_Msk (0x1UL << EXTI_EMR3_EM81_Pos) |
| #define | EXTI_EMR3_EM81 EXTI_EMR3_EM81_Msk |
| #define | EXTI_EMR3_EM82_Pos (18U) |
| #define | EXTI_EMR3_EM82_Msk (0x1UL << EXTI_EMR3_EM82_Pos) |
| #define | EXTI_EMR3_EM82 EXTI_EMR3_EM82_Msk |
| #define | EXTI_EMR3_EM84_Pos (20U) |
| #define | EXTI_EMR3_EM84_Msk (0x1UL << EXTI_EMR3_EM84_Pos) |
| #define | EXTI_EMR3_EM84 EXTI_EMR3_EM84_Msk |
| #define | EXTI_EMR3_EM85_Pos (21U) |
| #define | EXTI_EMR3_EM85_Msk (0x1UL << EXTI_EMR3_EM85_Pos) |
| #define | EXTI_EMR3_EM85 EXTI_EMR3_EM85_Msk |
| #define | EXTI_EMR3_EM86_Pos (22U) |
| #define | EXTI_EMR3_EM86_Msk (0x1UL << EXTI_EMR3_EM86_Pos) |
| #define | EXTI_EMR3_EM86 EXTI_EMR3_EM86_Msk |
| #define | EXTI_EMR3_EM87_Pos (23U) |
| #define | EXTI_EMR3_EM87_Msk (0x1UL << EXTI_EMR3_EM87_Pos) |
| #define | EXTI_EMR3_EM87 EXTI_EMR3_EM87_Msk |
| #define | EXTI_PR3_PR_Pos (18U) |
| #define | EXTI_PR3_PR_Msk (0x1DUL << EXTI_PR3_PR_Pos) |
| #define | EXTI_PR3_PR EXTI_PR3_PR_Msk |
| #define | EXTI_PR3_PR82_Pos (18U) |
| #define | EXTI_PR3_PR82_Msk (0x1UL << EXTI_PR3_PR82_Pos) |
| #define | EXTI_PR3_PR82 EXTI_PR3_PR82_Msk |
| #define | EXTI_PR3_PR84_Pos (20U) |
| #define | EXTI_PR3_PR84_Msk (0x1UL << EXTI_PR3_PR84_Pos) |
| #define | EXTI_PR3_PR84 EXTI_PR3_PR84_Msk |
| #define | EXTI_PR3_PR85_Pos (21U) |
| #define | EXTI_PR3_PR85_Msk (0x1UL << EXTI_PR3_PR85_Pos) |
| #define | EXTI_PR3_PR85 EXTI_PR3_PR85_Msk |
| #define | EXTI_PR3_PR86_Pos (22U) |
| #define | EXTI_PR3_PR86_Msk (0x1UL << EXTI_PR3_PR86_Pos) |
| #define | EXTI_PR3_PR86 EXTI_PR3_PR86_Msk |
| #define | FLASH_SIZE_DATA_REGISTER 0x1FF1E880U |
| #define | FLASH_SECTOR_TOTAL 8U /* 8 sectors */ |
| #define | FLASH_SIZE |
| #define | FLASH_BANK_SIZE (FLASH_SIZE >> 1) /* 1 MB */ |
| #define | FLASH_SECTOR_SIZE 0x00020000UL /* 128 KB */ |
| #define | FLASH_LATENCY_DEFAULT FLASH_ACR_LATENCY_7WS /* FLASH Seven Latency cycles */ |
| #define | FLASH_NB_32BITWORD_IN_FLASHWORD 8U /* 256 bits */ |
| #define | DUAL_BANK /* Dual-bank Flash */ |
| #define | FLASH_ACR_LATENCY_Pos (0U) |
| #define | FLASH_ACR_LATENCY_Msk (0xFUL << FLASH_ACR_LATENCY_Pos) |
| #define | FLASH_ACR_LATENCY FLASH_ACR_LATENCY_Msk |
| #define | FLASH_ACR_LATENCY_0WS (0x00000000UL) |
| #define | FLASH_ACR_LATENCY_1WS (0x00000001UL) |
| #define | FLASH_ACR_LATENCY_2WS (0x00000002UL) |
| #define | FLASH_ACR_LATENCY_3WS (0x00000003UL) |
| #define | FLASH_ACR_LATENCY_4WS (0x00000004UL) |
| #define | FLASH_ACR_LATENCY_5WS (0x00000005UL) |
| #define | FLASH_ACR_LATENCY_6WS (0x00000006UL) |
| #define | FLASH_ACR_LATENCY_7WS (0x00000007UL) |
| #define | FLASH_ACR_WRHIGHFREQ_Pos (4U) |
| #define | FLASH_ACR_WRHIGHFREQ_Msk (0x3UL << FLASH_ACR_WRHIGHFREQ_Pos) |
| #define | FLASH_ACR_WRHIGHFREQ FLASH_ACR_WRHIGHFREQ_Msk |
| #define | FLASH_ACR_WRHIGHFREQ_0 (0x1UL << FLASH_ACR_WRHIGHFREQ_Pos) |
| #define | FLASH_ACR_WRHIGHFREQ_1 (0x2UL << FLASH_ACR_WRHIGHFREQ_Pos) |
| #define | FLASH_ACR_LATENCY_8WS (0x00000008UL) |
| #define | FLASH_ACR_LATENCY_9WS (0x00000009UL) |
| #define | FLASH_ACR_LATENCY_10WS (0x0000000AUL) |
| #define | FLASH_ACR_LATENCY_11WS (0x0000000BUL) |
| #define | FLASH_ACR_LATENCY_12WS (0x0000000CUL) |
| #define | FLASH_ACR_LATENCY_13WS (0x0000000DUL) |
| #define | FLASH_ACR_LATENCY_14WS (0x0000000EUL) |
| #define | FLASH_ACR_LATENCY_15WS (0x0000000FUL) |
| #define | FLASH_CR_LOCK_Pos (0U) |
| #define | FLASH_CR_LOCK_Msk (0x1UL << FLASH_CR_LOCK_Pos) |
| #define | FLASH_CR_LOCK FLASH_CR_LOCK_Msk |
| #define | FLASH_CR_PG_Pos (1U) |
| #define | FLASH_CR_PG_Msk (0x1UL << FLASH_CR_PG_Pos) |
| #define | FLASH_CR_PG FLASH_CR_PG_Msk |
| #define | FLASH_CR_SER_Pos (2U) |
| #define | FLASH_CR_SER_Msk (0x1UL << FLASH_CR_SER_Pos) |
| #define | FLASH_CR_SER FLASH_CR_SER_Msk |
| #define | FLASH_CR_BER_Pos (3U) |
| #define | FLASH_CR_BER_Msk (0x1UL << FLASH_CR_BER_Pos) |
| #define | FLASH_CR_BER FLASH_CR_BER_Msk |
| #define | FLASH_CR_PSIZE_Pos (4U) |
| #define | FLASH_CR_PSIZE_Msk (0x3UL << FLASH_CR_PSIZE_Pos) |
| #define | FLASH_CR_PSIZE FLASH_CR_PSIZE_Msk |
| #define | FLASH_CR_PSIZE_0 (0x1UL << FLASH_CR_PSIZE_Pos) |
| #define | FLASH_CR_PSIZE_1 (0x2UL << FLASH_CR_PSIZE_Pos) |
| #define | FLASH_CR_FW_Pos (6U) |
| #define | FLASH_CR_FW_Msk (0x1UL << FLASH_CR_FW_Pos) |
| #define | FLASH_CR_FW FLASH_CR_FW_Msk |
| #define | FLASH_CR_START_Pos (7U) |
| #define | FLASH_CR_START_Msk (0x1UL << FLASH_CR_START_Pos) |
| #define | FLASH_CR_START FLASH_CR_START_Msk |
| #define | FLASH_CR_SNB_Pos (8U) |
| #define | FLASH_CR_SNB_Msk (0x7UL << FLASH_CR_SNB_Pos) |
| #define | FLASH_CR_SNB FLASH_CR_SNB_Msk |
| #define | FLASH_CR_SNB_0 (0x1UL << FLASH_CR_SNB_Pos) |
| #define | FLASH_CR_SNB_1 (0x2UL << FLASH_CR_SNB_Pos) |
| #define | FLASH_CR_SNB_2 (0x4UL << FLASH_CR_SNB_Pos) |
| #define | FLASH_CR_CRC_EN_Pos (15U) |
| #define | FLASH_CR_CRC_EN_Msk (0x1UL << FLASH_CR_CRC_EN_Pos) |
| #define | FLASH_CR_CRC_EN FLASH_CR_CRC_EN_Msk |
| #define | FLASH_CR_EOPIE_Pos (16U) |
| #define | FLASH_CR_EOPIE_Msk (0x1UL << FLASH_CR_EOPIE_Pos) |
| #define | FLASH_CR_EOPIE FLASH_CR_EOPIE_Msk |
| #define | FLASH_CR_WRPERRIE_Pos (17U) |
| #define | FLASH_CR_WRPERRIE_Msk (0x1UL << FLASH_CR_WRPERRIE_Pos) |
| #define | FLASH_CR_WRPERRIE FLASH_CR_WRPERRIE_Msk |
| #define | FLASH_CR_PGSERRIE_Pos (18U) |
| #define | FLASH_CR_PGSERRIE_Msk (0x1UL << FLASH_CR_PGSERRIE_Pos) |
| #define | FLASH_CR_PGSERRIE FLASH_CR_PGSERRIE_Msk |
| #define | FLASH_CR_STRBERRIE_Pos (19U) |
| #define | FLASH_CR_STRBERRIE_Msk (0x1UL << FLASH_CR_STRBERRIE_Pos) |
| #define | FLASH_CR_STRBERRIE FLASH_CR_STRBERRIE_Msk |
| #define | FLASH_CR_INCERRIE_Pos (21U) |
| #define | FLASH_CR_INCERRIE_Msk (0x1UL << FLASH_CR_INCERRIE_Pos) |
| #define | FLASH_CR_INCERRIE FLASH_CR_INCERRIE_Msk |
| #define | FLASH_CR_OPERRIE_Pos (22U) |
| #define | FLASH_CR_OPERRIE_Msk (0x1UL << FLASH_CR_OPERRIE_Pos) |
| #define | FLASH_CR_OPERRIE FLASH_CR_OPERRIE_Msk |
| #define | FLASH_CR_RDPERRIE_Pos (23U) |
| #define | FLASH_CR_RDPERRIE_Msk (0x1UL << FLASH_CR_RDPERRIE_Pos) |
| #define | FLASH_CR_RDPERRIE FLASH_CR_RDPERRIE_Msk |
| #define | FLASH_CR_RDSERRIE_Pos (24U) |
| #define | FLASH_CR_RDSERRIE_Msk (0x1UL << FLASH_CR_RDSERRIE_Pos) |
| #define | FLASH_CR_RDSERRIE FLASH_CR_RDSERRIE_Msk |
| #define | FLASH_CR_SNECCERRIE_Pos (25U) |
| #define | FLASH_CR_SNECCERRIE_Msk (0x1UL << FLASH_CR_SNECCERRIE_Pos) |
| #define | FLASH_CR_SNECCERRIE FLASH_CR_SNECCERRIE_Msk |
| #define | FLASH_CR_DBECCERRIE_Pos (26U) |
| #define | FLASH_CR_DBECCERRIE_Msk (0x1UL << FLASH_CR_DBECCERRIE_Pos) |
| #define | FLASH_CR_DBECCERRIE FLASH_CR_DBECCERRIE_Msk |
| #define | FLASH_CR_CRCENDIE_Pos (27U) |
| #define | FLASH_CR_CRCENDIE_Msk (0x1UL << FLASH_CR_CRCENDIE_Pos) |
| #define | FLASH_CR_CRCENDIE FLASH_CR_CRCENDIE_Msk |
| #define | FLASH_CR_CRCRDERRIE_Pos (28U) |
| #define | FLASH_CR_CRCRDERRIE_Msk (0x1UL << FLASH_CR_CRCRDERRIE_Pos) |
| #define | FLASH_CR_CRCRDERRIE FLASH_CR_CRCRDERRIE_Msk |
| #define | FLASH_SR_BSY_Pos (0U) |
| #define | FLASH_SR_BSY_Msk (0x1UL << FLASH_SR_BSY_Pos) |
| #define | FLASH_SR_BSY FLASH_SR_BSY_Msk |
| #define | FLASH_SR_WBNE_Pos (1U) |
| #define | FLASH_SR_WBNE_Msk (0x1UL << FLASH_SR_WBNE_Pos) |
| #define | FLASH_SR_WBNE FLASH_SR_WBNE_Msk |
| #define | FLASH_SR_QW_Pos (2U) |
| #define | FLASH_SR_QW_Msk (0x1UL << FLASH_SR_QW_Pos) |
| #define | FLASH_SR_QW FLASH_SR_QW_Msk |
| #define | FLASH_SR_CRC_BUSY_Pos (3U) |
| #define | FLASH_SR_CRC_BUSY_Msk (0x1UL << FLASH_SR_CRC_BUSY_Pos) |
| #define | FLASH_SR_CRC_BUSY FLASH_SR_CRC_BUSY_Msk |
| #define | FLASH_SR_EOP_Pos (16U) |
| #define | FLASH_SR_EOP_Msk (0x1UL << FLASH_SR_EOP_Pos) |
| #define | FLASH_SR_EOP FLASH_SR_EOP_Msk |
| #define | FLASH_SR_WRPERR_Pos (17U) |
| #define | FLASH_SR_WRPERR_Msk (0x1UL << FLASH_SR_WRPERR_Pos) |
| #define | FLASH_SR_WRPERR FLASH_SR_WRPERR_Msk |
| #define | FLASH_SR_PGSERR_Pos (18U) |
| #define | FLASH_SR_PGSERR_Msk (0x1UL << FLASH_SR_PGSERR_Pos) |
| #define | FLASH_SR_PGSERR FLASH_SR_PGSERR_Msk |
| #define | FLASH_SR_STRBERR_Pos (19U) |
| #define | FLASH_SR_STRBERR_Msk (0x1UL << FLASH_SR_STRBERR_Pos) |
| #define | FLASH_SR_STRBERR FLASH_SR_STRBERR_Msk |
| #define | FLASH_SR_INCERR_Pos (21U) |
| #define | FLASH_SR_INCERR_Msk (0x1UL << FLASH_SR_INCERR_Pos) |
| #define | FLASH_SR_INCERR FLASH_SR_INCERR_Msk |
| #define | FLASH_SR_OPERR_Pos (22U) |
| #define | FLASH_SR_OPERR_Msk (0x1UL << FLASH_SR_OPERR_Pos) |
| #define | FLASH_SR_OPERR FLASH_SR_OPERR_Msk |
| #define | FLASH_SR_RDPERR_Pos (23U) |
| #define | FLASH_SR_RDPERR_Msk (0x1UL << FLASH_SR_RDPERR_Pos) |
| #define | FLASH_SR_RDPERR FLASH_SR_RDPERR_Msk |
| #define | FLASH_SR_RDSERR_Pos (24U) |
| #define | FLASH_SR_RDSERR_Msk (0x1UL << FLASH_SR_RDSERR_Pos) |
| #define | FLASH_SR_RDSERR FLASH_SR_RDSERR_Msk |
| #define | FLASH_SR_SNECCERR_Pos (25U) |
| #define | FLASH_SR_SNECCERR_Msk (0x1UL << FLASH_SR_SNECCERR_Pos) |
| #define | FLASH_SR_SNECCERR FLASH_SR_SNECCERR_Msk |
| #define | FLASH_SR_DBECCERR_Pos (26U) |
| #define | FLASH_SR_DBECCERR_Msk (0x1UL << FLASH_SR_DBECCERR_Pos) |
| #define | FLASH_SR_DBECCERR FLASH_SR_DBECCERR_Msk |
| #define | FLASH_SR_CRCEND_Pos (27U) |
| #define | FLASH_SR_CRCEND_Msk (0x1UL << FLASH_SR_CRCEND_Pos) |
| #define | FLASH_SR_CRCEND FLASH_SR_CRCEND_Msk |
| #define | FLASH_SR_CRCRDERR_Pos (28U) |
| #define | FLASH_SR_CRCRDERR_Msk (0x1UL << FLASH_SR_CRCRDERR_Pos) |
| #define | FLASH_SR_CRCRDERR FLASH_SR_CRCRDERR_Msk |
| #define | FLASH_CCR_CLR_EOP_Pos (16U) |
| #define | FLASH_CCR_CLR_EOP_Msk (0x1UL << FLASH_CCR_CLR_EOP_Pos) |
| #define | FLASH_CCR_CLR_EOP FLASH_CCR_CLR_EOP_Msk |
| #define | FLASH_CCR_CLR_WRPERR_Pos (17U) |
| #define | FLASH_CCR_CLR_WRPERR_Msk (0x1UL << FLASH_CCR_CLR_WRPERR_Pos) |
| #define | FLASH_CCR_CLR_WRPERR FLASH_CCR_CLR_WRPERR_Msk |
| #define | FLASH_CCR_CLR_PGSERR_Pos (18U) |
| #define | FLASH_CCR_CLR_PGSERR_Msk (0x1UL << FLASH_CCR_CLR_PGSERR_Pos) |
| #define | FLASH_CCR_CLR_PGSERR FLASH_CCR_CLR_PGSERR_Msk |
| #define | FLASH_CCR_CLR_STRBERR_Pos (19U) |
| #define | FLASH_CCR_CLR_STRBERR_Msk (0x1UL << FLASH_CCR_CLR_STRBERR_Pos) |
| #define | FLASH_CCR_CLR_STRBERR FLASH_CCR_CLR_STRBERR_Msk |
| #define | FLASH_CCR_CLR_INCERR_Pos (21U) |
| #define | FLASH_CCR_CLR_INCERR_Msk (0x1UL << FLASH_CCR_CLR_INCERR_Pos) |
| #define | FLASH_CCR_CLR_INCERR FLASH_CCR_CLR_INCERR_Msk |
| #define | FLASH_CCR_CLR_OPERR_Pos (22U) |
| #define | FLASH_CCR_CLR_OPERR_Msk (0x1UL << FLASH_CCR_CLR_OPERR_Pos) |
| #define | FLASH_CCR_CLR_OPERR FLASH_CCR_CLR_OPERR_Msk |
| #define | FLASH_CCR_CLR_RDPERR_Pos (23U) |
| #define | FLASH_CCR_CLR_RDPERR_Msk (0x1UL << FLASH_CCR_CLR_RDPERR_Pos) |
| #define | FLASH_CCR_CLR_RDPERR FLASH_CCR_CLR_RDPERR_Msk |
| #define | FLASH_CCR_CLR_RDSERR_Pos (24U) |
| #define | FLASH_CCR_CLR_RDSERR_Msk (0x1UL << FLASH_CCR_CLR_RDSERR_Pos) |
| #define | FLASH_CCR_CLR_RDSERR FLASH_CCR_CLR_RDSERR_Msk |
| #define | FLASH_CCR_CLR_SNECCERR_Pos (25U) |
| #define | FLASH_CCR_CLR_SNECCERR_Msk (0x1UL << FLASH_CCR_CLR_SNECCERR_Pos) |
| #define | FLASH_CCR_CLR_SNECCERR FLASH_CCR_CLR_SNECCERR_Msk |
| #define | FLASH_CCR_CLR_DBECCERR_Pos (26U) |
| #define | FLASH_CCR_CLR_DBECCERR_Msk (0x1UL << FLASH_CCR_CLR_DBECCERR_Pos) |
| #define | FLASH_CCR_CLR_DBECCERR FLASH_CCR_CLR_DBECCERR_Msk |
| #define | FLASH_CCR_CLR_CRCEND_Pos (27U) |
| #define | FLASH_CCR_CLR_CRCEND_Msk (0x1UL << FLASH_CCR_CLR_CRCEND_Pos) |
| #define | FLASH_CCR_CLR_CRCEND FLASH_CCR_CLR_CRCEND_Msk |
| #define | FLASH_CCR_CLR_CRCRDERR_Pos (28U) |
| #define | FLASH_CCR_CLR_CRCRDERR_Msk (0x1UL << FLASH_CCR_CLR_CRCRDERR_Pos) |
| #define | FLASH_CCR_CLR_CRCRDERR FLASH_CCR_CLR_CRCRDERR_Msk |
| #define | FLASH_OPTCR_OPTLOCK_Pos (0U) |
| #define | FLASH_OPTCR_OPTLOCK_Msk (0x1UL << FLASH_OPTCR_OPTLOCK_Pos) |
| #define | FLASH_OPTCR_OPTLOCK FLASH_OPTCR_OPTLOCK_Msk |
| #define | FLASH_OPTCR_OPTSTART_Pos (1U) |
| #define | FLASH_OPTCR_OPTSTART_Msk (0x1UL << FLASH_OPTCR_OPTSTART_Pos) |
| #define | FLASH_OPTCR_OPTSTART FLASH_OPTCR_OPTSTART_Msk |
| #define | FLASH_OPTCR_MER_Pos (4U) |
| #define | FLASH_OPTCR_MER_Msk (0x1UL << FLASH_OPTCR_MER_Pos) |
| #define | FLASH_OPTCR_MER FLASH_OPTCR_MER_Msk |
| #define | FLASH_OPTCR_OPTCHANGEERRIE_Pos (30U) |
| #define | FLASH_OPTCR_OPTCHANGEERRIE_Msk (0x1UL << FLASH_OPTCR_OPTCHANGEERRIE_Pos) |
| #define | FLASH_OPTCR_OPTCHANGEERRIE FLASH_OPTCR_OPTCHANGEERRIE_Msk |
| #define | FLASH_OPTCR_SWAP_BANK_Pos (31U) |
| #define | FLASH_OPTCR_SWAP_BANK_Msk (0x1UL << FLASH_OPTCR_SWAP_BANK_Pos) |
| #define | FLASH_OPTCR_SWAP_BANK FLASH_OPTCR_SWAP_BANK_Msk |
| #define | FLASH_OPTSR_OPT_BUSY_Pos (0U) |
| #define | FLASH_OPTSR_OPT_BUSY_Msk (0x1UL << FLASH_OPTSR_OPT_BUSY_Pos) |
| #define | FLASH_OPTSR_OPT_BUSY FLASH_OPTSR_OPT_BUSY_Msk |
| #define | FLASH_OPTSR_BOR_LEV_Pos (2U) |
| #define | FLASH_OPTSR_BOR_LEV_Msk (0x3UL << FLASH_OPTSR_BOR_LEV_Pos) |
| #define | FLASH_OPTSR_BOR_LEV FLASH_OPTSR_BOR_LEV_Msk |
| #define | FLASH_OPTSR_BOR_LEV_0 (0x1UL << FLASH_OPTSR_BOR_LEV_Pos) |
| #define | FLASH_OPTSR_BOR_LEV_1 (0x2UL << FLASH_OPTSR_BOR_LEV_Pos) |
| #define | FLASH_OPTSR_IWDG1_SW_Pos (4U) |
| #define | FLASH_OPTSR_IWDG1_SW_Msk (0x1UL << FLASH_OPTSR_IWDG1_SW_Pos) |
| #define | FLASH_OPTSR_IWDG1_SW FLASH_OPTSR_IWDG1_SW_Msk |
| #define | FLASH_OPTSR_NRST_STOP_D1_Pos (6U) |
| #define | FLASH_OPTSR_NRST_STOP_D1_Msk (0x1UL << FLASH_OPTSR_NRST_STOP_D1_Pos) |
| #define | FLASH_OPTSR_NRST_STOP_D1 FLASH_OPTSR_NRST_STOP_D1_Msk |
| #define | FLASH_OPTSR_NRST_STBY_D1_Pos (7U) |
| #define | FLASH_OPTSR_NRST_STBY_D1_Msk (0x1UL << FLASH_OPTSR_NRST_STBY_D1_Pos) |
| #define | FLASH_OPTSR_NRST_STBY_D1 FLASH_OPTSR_NRST_STBY_D1_Msk |
| #define | FLASH_OPTSR_RDP_Pos (8U) |
| #define | FLASH_OPTSR_RDP_Msk (0xFFUL << FLASH_OPTSR_RDP_Pos) |
| #define | FLASH_OPTSR_RDP FLASH_OPTSR_RDP_Msk |
| #define | FLASH_OPTSR_FZ_IWDG_STOP_Pos (17U) |
| #define | FLASH_OPTSR_FZ_IWDG_STOP_Msk (0x1UL << FLASH_OPTSR_FZ_IWDG_STOP_Pos) |
| #define | FLASH_OPTSR_FZ_IWDG_STOP FLASH_OPTSR_FZ_IWDG_STOP_Msk |
| #define | FLASH_OPTSR_FZ_IWDG_SDBY_Pos (18U) |
| #define | FLASH_OPTSR_FZ_IWDG_SDBY_Msk (0x1UL << FLASH_OPTSR_FZ_IWDG_SDBY_Pos) |
| #define | FLASH_OPTSR_FZ_IWDG_SDBY FLASH_OPTSR_FZ_IWDG_SDBY_Msk |
| #define | FLASH_OPTSR_ST_RAM_SIZE_Pos (19U) |
| #define | FLASH_OPTSR_ST_RAM_SIZE_Msk (0x3UL << FLASH_OPTSR_ST_RAM_SIZE_Pos) |
| #define | FLASH_OPTSR_ST_RAM_SIZE FLASH_OPTSR_ST_RAM_SIZE_Msk |
| #define | FLASH_OPTSR_ST_RAM_SIZE_0 (0x1UL << FLASH_OPTSR_ST_RAM_SIZE_Pos) |
| #define | FLASH_OPTSR_ST_RAM_SIZE_1 (0x2UL << FLASH_OPTSR_ST_RAM_SIZE_Pos) |
| #define | FLASH_OPTSR_SECURITY_Pos (21U) |
| #define | FLASH_OPTSR_SECURITY_Msk (0x1UL << FLASH_OPTSR_SECURITY_Pos) |
| #define | FLASH_OPTSR_SECURITY FLASH_OPTSR_SECURITY_Msk |
| #define | FLASH_OPTSR_IO_HSLV_Pos (29U) |
| #define | FLASH_OPTSR_IO_HSLV_Msk (0x1UL << FLASH_OPTSR_IO_HSLV_Pos) |
| #define | FLASH_OPTSR_IO_HSLV FLASH_OPTSR_IO_HSLV_Msk |
| #define | FLASH_OPTSR_OPTCHANGEERR_Pos (30U) |
| #define | FLASH_OPTSR_OPTCHANGEERR_Msk (0x1UL << FLASH_OPTSR_OPTCHANGEERR_Pos) |
| #define | FLASH_OPTSR_OPTCHANGEERR FLASH_OPTSR_OPTCHANGEERR_Msk |
| #define | FLASH_OPTSR_SWAP_BANK_OPT_Pos (31U) |
| #define | FLASH_OPTSR_SWAP_BANK_OPT_Msk (0x1UL << FLASH_OPTSR_SWAP_BANK_OPT_Pos) |
| #define | FLASH_OPTSR_SWAP_BANK_OPT FLASH_OPTSR_SWAP_BANK_OPT_Msk |
| #define | FLASH_OPTCCR_CLR_OPTCHANGEERR_Pos (30U) |
| #define | FLASH_OPTCCR_CLR_OPTCHANGEERR_Msk (0x1UL << FLASH_OPTCCR_CLR_OPTCHANGEERR_Pos) |
| #define | FLASH_OPTCCR_CLR_OPTCHANGEERR FLASH_OPTCCR_CLR_OPTCHANGEERR_Msk |
| #define | FLASH_PRAR_PROT_AREA_START_Pos (0U) |
| #define | FLASH_PRAR_PROT_AREA_START_Msk (0xFFFUL << FLASH_PRAR_PROT_AREA_START_Pos) |
| #define | FLASH_PRAR_PROT_AREA_START FLASH_PRAR_PROT_AREA_START_Msk |
| #define | FLASH_PRAR_PROT_AREA_END_Pos (16U) |
| #define | FLASH_PRAR_PROT_AREA_END_Msk (0xFFFUL << FLASH_PRAR_PROT_AREA_END_Pos) |
| #define | FLASH_PRAR_PROT_AREA_END FLASH_PRAR_PROT_AREA_END_Msk |
| #define | FLASH_PRAR_DMEP_Pos (31U) |
| #define | FLASH_PRAR_DMEP_Msk (0x1UL << FLASH_PRAR_DMEP_Pos) |
| #define | FLASH_PRAR_DMEP FLASH_PRAR_DMEP_Msk |
| #define | FLASH_SCAR_SEC_AREA_START_Pos (0U) |
| #define | FLASH_SCAR_SEC_AREA_START_Msk (0xFFFUL << FLASH_SCAR_SEC_AREA_START_Pos) |
| #define | FLASH_SCAR_SEC_AREA_START FLASH_SCAR_SEC_AREA_START_Msk |
| #define | FLASH_SCAR_SEC_AREA_END_Pos (16U) |
| #define | FLASH_SCAR_SEC_AREA_END_Msk (0xFFFUL << FLASH_SCAR_SEC_AREA_END_Pos) |
| #define | FLASH_SCAR_SEC_AREA_END FLASH_SCAR_SEC_AREA_END_Msk |
| #define | FLASH_SCAR_DMES_Pos (31U) |
| #define | FLASH_SCAR_DMES_Msk (0x1UL << FLASH_SCAR_DMES_Pos) |
| #define | FLASH_SCAR_DMES FLASH_SCAR_DMES_Msk |
| #define | FLASH_WPSN_WRPSN_Pos (0U) |
| #define | FLASH_WPSN_WRPSN_Msk (0xFFUL << FLASH_WPSN_WRPSN_Pos) |
| #define | FLASH_WPSN_WRPSN FLASH_WPSN_WRPSN_Msk |
| #define | FLASH_BOOT_ADD0_Pos (0U) |
| #define | FLASH_BOOT_ADD0_Msk (0xFFFFUL << FLASH_BOOT_ADD0_Pos) |
| #define | FLASH_BOOT_ADD0 FLASH_BOOT_ADD0_Msk |
| #define | FLASH_BOOT_ADD1_Pos (16U) |
| #define | FLASH_BOOT_ADD1_Msk (0xFFFFUL << FLASH_BOOT_ADD1_Pos) |
| #define | FLASH_BOOT_ADD1 FLASH_BOOT_ADD1_Msk |
| #define | FLASH_CRCCR_CRC_SECT_Pos (0U) |
| #define | FLASH_CRCCR_CRC_SECT_Msk (0x7UL << FLASH_CRCCR_CRC_SECT_Pos) |
| #define | FLASH_CRCCR_CRC_SECT FLASH_CRCCR_CRC_SECT_Msk |
| #define | FLASH_CRCCR_CRC_BY_SECT_Pos (8U) |
| #define | FLASH_CRCCR_CRC_BY_SECT_Msk (0x1UL << FLASH_CRCCR_CRC_BY_SECT_Pos) |
| #define | FLASH_CRCCR_CRC_BY_SECT FLASH_CRCCR_CRC_BY_SECT_Msk |
| #define | FLASH_CRCCR_ADD_SECT_Pos (9U) |
| #define | FLASH_CRCCR_ADD_SECT_Msk (0x1UL << FLASH_CRCCR_ADD_SECT_Pos) |
| #define | FLASH_CRCCR_ADD_SECT FLASH_CRCCR_ADD_SECT_Msk |
| #define | FLASH_CRCCR_CLEAN_SECT_Pos (10U) |
| #define | FLASH_CRCCR_CLEAN_SECT_Msk (0x1UL << FLASH_CRCCR_CLEAN_SECT_Pos) |
| #define | FLASH_CRCCR_CLEAN_SECT FLASH_CRCCR_CLEAN_SECT_Msk |
| #define | FLASH_CRCCR_START_CRC_Pos (16U) |
| #define | FLASH_CRCCR_START_CRC_Msk (0x1UL << FLASH_CRCCR_START_CRC_Pos) |
| #define | FLASH_CRCCR_START_CRC FLASH_CRCCR_START_CRC_Msk |
| #define | FLASH_CRCCR_CLEAN_CRC_Pos (17U) |
| #define | FLASH_CRCCR_CLEAN_CRC_Msk (0x1UL << FLASH_CRCCR_CLEAN_CRC_Pos) |
| #define | FLASH_CRCCR_CLEAN_CRC FLASH_CRCCR_CLEAN_CRC_Msk |
| #define | FLASH_CRCCR_CRC_BURST_Pos (20U) |
| #define | FLASH_CRCCR_CRC_BURST_Msk (0x3UL << FLASH_CRCCR_CRC_BURST_Pos) |
| #define | FLASH_CRCCR_CRC_BURST FLASH_CRCCR_CRC_BURST_Msk |
| #define | FLASH_CRCCR_CRC_BURST_0 (0x1UL << FLASH_CRCCR_CRC_BURST_Pos) |
| #define | FLASH_CRCCR_CRC_BURST_1 (0x2UL << FLASH_CRCCR_CRC_BURST_Pos) |
| #define | FLASH_CRCCR_ALL_BANK_Pos (22U) |
| #define | FLASH_CRCCR_ALL_BANK_Msk (0x1UL << FLASH_CRCCR_ALL_BANK_Pos) |
| #define | FLASH_CRCCR_ALL_BANK FLASH_CRCCR_ALL_BANK_Msk |
| #define | FLASH_CRCSADD_CRC_START_ADDR_Pos (0U) |
| #define | FLASH_CRCSADD_CRC_START_ADDR_Msk (0xFFFFFFFFUL << FLASH_CRCSADD_CRC_START_ADDR_Pos) |
| #define | FLASH_CRCSADD_CRC_START_ADDR FLASH_CRCSADD_CRC_START_ADDR_Msk |
| #define | FLASH_CRCEADD_CRC_END_ADDR_Pos (0U) |
| #define | FLASH_CRCEADD_CRC_END_ADDR_Msk (0xFFFFFFFFUL << FLASH_CRCEADD_CRC_END_ADDR_Pos) |
| #define | FLASH_CRCEADD_CRC_END_ADDR FLASH_CRCEADD_CRC_END_ADDR_Msk |
| #define | FLASH_CRCDATA_CRC_DATA_Pos (0U) |
| #define | FLASH_CRCDATA_CRC_DATA_Msk (0xFFFFFFFFUL << FLASH_CRCDATA_CRC_DATA_Pos) |
| #define | FLASH_CRCDATA_CRC_DATA FLASH_CRCDATA_CRC_DATA_Msk |
| #define | FLASH_ECC_FA_FAIL_ECC_ADDR_Pos (0U) |
| #define | FLASH_ECC_FA_FAIL_ECC_ADDR_Msk (0x7FFFUL << FLASH_ECC_FA_FAIL_ECC_ADDR_Pos) |
| #define | FLASH_ECC_FA_FAIL_ECC_ADDR FLASH_ECC_FA_FAIL_ECC_ADDR_Msk |
| #define | FMC_BCR1_CCLKEN_Pos (20U) |
| #define | FMC_BCR1_CCLKEN_Msk (0x1UL << FMC_BCR1_CCLKEN_Pos) |
| #define | FMC_BCR1_CCLKEN FMC_BCR1_CCLKEN_Msk |
| #define | FMC_BCR1_WFDIS_Pos (21U) |
| #define | FMC_BCR1_WFDIS_Msk (0x1UL << FMC_BCR1_WFDIS_Pos) |
| #define | FMC_BCR1_WFDIS FMC_BCR1_WFDIS_Msk |
| #define | FMC_BCR1_BMAP_Pos (24U) |
| #define | FMC_BCR1_BMAP_Msk (0x3UL << FMC_BCR1_BMAP_Pos) |
| #define | FMC_BCR1_BMAP FMC_BCR1_BMAP_Msk |
| #define | FMC_BCR1_BMAP_0 (0x1UL << FMC_BCR1_BMAP_Pos) |
| #define | FMC_BCR1_BMAP_1 (0x2UL << FMC_BCR1_BMAP_Pos) |
| #define | FMC_BCR1_FMCEN_Pos (31U) |
| #define | FMC_BCR1_FMCEN_Msk (0x1UL << FMC_BCR1_FMCEN_Pos) |
| #define | FMC_BCR1_FMCEN FMC_BCR1_FMCEN_Msk |
| #define | FMC_BCRx_MBKEN_Pos (0U) |
| #define | FMC_BCRx_MBKEN_Msk (0x1UL << FMC_BCRx_MBKEN_Pos) |
| #define | FMC_BCRx_MBKEN FMC_BCRx_MBKEN_Msk |
| #define | FMC_BCRx_MUXEN_Pos (1U) |
| #define | FMC_BCRx_MUXEN_Msk (0x1UL << FMC_BCRx_MUXEN_Pos) |
| #define | FMC_BCRx_MUXEN FMC_BCRx_MUXEN_Msk |
| #define | FMC_BCRx_MTYP_Pos (2U) |
| #define | FMC_BCRx_MTYP_Msk (0x3UL << FMC_BCRx_MTYP_Pos) |
| #define | FMC_BCRx_MTYP FMC_BCRx_MTYP_Msk |
| #define | FMC_BCRx_MTYP_0 (0x1UL << FMC_BCRx_MTYP_Pos) |
| #define | FMC_BCRx_MTYP_1 (0x2UL << FMC_BCRx_MTYP_Pos) |
| #define | FMC_BCRx_MWID_Pos (4U) |
| #define | FMC_BCRx_MWID_Msk (0x3UL << FMC_BCRx_MWID_Pos) |
| #define | FMC_BCRx_MWID FMC_BCRx_MWID_Msk |
| #define | FMC_BCRx_MWID_0 (0x1UL << FMC_BCRx_MWID_Pos) |
| #define | FMC_BCRx_MWID_1 (0x2UL << FMC_BCRx_MWID_Pos) |
| #define | FMC_BCRx_FACCEN_Pos (6U) |
| #define | FMC_BCRx_FACCEN_Msk (0x1UL << FMC_BCRx_FACCEN_Pos) |
| #define | FMC_BCRx_FACCEN FMC_BCRx_FACCEN_Msk |
| #define | FMC_BCRx_BURSTEN_Pos (8U) |
| #define | FMC_BCRx_BURSTEN_Msk (0x1UL << FMC_BCRx_BURSTEN_Pos) |
| #define | FMC_BCRx_BURSTEN FMC_BCRx_BURSTEN_Msk |
| #define | FMC_BCRx_WAITPOL_Pos (9U) |
| #define | FMC_BCRx_WAITPOL_Msk (0x1UL << FMC_BCRx_WAITPOL_Pos) |
| #define | FMC_BCRx_WAITPOL FMC_BCRx_WAITPOL_Msk |
| #define | FMC_BCRx_WAITCFG_Pos (11U) |
| #define | FMC_BCRx_WAITCFG_Msk (0x1UL << FMC_BCRx_WAITCFG_Pos) |
| #define | FMC_BCRx_WAITCFG FMC_BCRx_WAITCFG_Msk |
| #define | FMC_BCRx_WREN_Pos (12U) |
| #define | FMC_BCRx_WREN_Msk (0x1UL << FMC_BCRx_WREN_Pos) |
| #define | FMC_BCRx_WREN FMC_BCRx_WREN_Msk |
| #define | FMC_BCRx_WAITEN_Pos (13U) |
| #define | FMC_BCRx_WAITEN_Msk (0x1UL << FMC_BCRx_WAITEN_Pos) |
| #define | FMC_BCRx_WAITEN FMC_BCRx_WAITEN_Msk |
| #define | FMC_BCRx_EXTMOD_Pos (14U) |
| #define | FMC_BCRx_EXTMOD_Msk (0x1UL << FMC_BCRx_EXTMOD_Pos) |
| #define | FMC_BCRx_EXTMOD FMC_BCRx_EXTMOD_Msk |
| #define | FMC_BCRx_ASYNCWAIT_Pos (15U) |
| #define | FMC_BCRx_ASYNCWAIT_Msk (0x1UL << FMC_BCRx_ASYNCWAIT_Pos) |
| #define | FMC_BCRx_ASYNCWAIT FMC_BCRx_ASYNCWAIT_Msk |
| #define | FMC_BCRx_CPSIZE_Pos (16U) |
| #define | FMC_BCRx_CPSIZE_Msk (0x7UL << FMC_BCRx_CPSIZE_Pos) |
| #define | FMC_BCRx_CPSIZE FMC_BCRx_CPSIZE_Msk |
| #define | FMC_BCRx_CPSIZE_0 (0x1UL << FMC_BCRx_CPSIZE_Pos) |
| #define | FMC_BCRx_CPSIZE_1 (0x2UL << FMC_BCRx_CPSIZE_Pos) |
| #define | FMC_BCRx_CPSIZE_2 (0x4UL << FMC_BCRx_CPSIZE_Pos) |
| #define | FMC_BCRx_CBURSTRW_Pos (19U) |
| #define | FMC_BCRx_CBURSTRW_Msk (0x1UL << FMC_BCRx_CBURSTRW_Pos) |
| #define | FMC_BCRx_CBURSTRW FMC_BCRx_CBURSTRW_Msk |
| #define | FMC_BTRx_ADDSET_Pos (0U) |
| #define | FMC_BTRx_ADDSET_Msk (0xFUL << FMC_BTRx_ADDSET_Pos) |
| #define | FMC_BTRx_ADDSET FMC_BTRx_ADDSET_Msk |
| #define | FMC_BTRx_ADDSET_0 (0x1UL << FMC_BTRx_ADDSET_Pos) |
| #define | FMC_BTRx_ADDSET_1 (0x2UL << FMC_BTRx_ADDSET_Pos) |
| #define | FMC_BTRx_ADDSET_2 (0x4UL << FMC_BTRx_ADDSET_Pos) |
| #define | FMC_BTRx_ADDSET_3 (0x8UL << FMC_BTRx_ADDSET_Pos) |
| #define | FMC_BTRx_ADDHLD_Pos (4U) |
| #define | FMC_BTRx_ADDHLD_Msk (0xFUL << FMC_BTRx_ADDHLD_Pos) |
| #define | FMC_BTRx_ADDHLD FMC_BTRx_ADDHLD_Msk |
| #define | FMC_BTRx_ADDHLD_0 (0x1UL << FMC_BTRx_ADDHLD_Pos) |
| #define | FMC_BTRx_ADDHLD_1 (0x2UL << FMC_BTRx_ADDHLD_Pos) |
| #define | FMC_BTRx_ADDHLD_2 (0x4UL << FMC_BTRx_ADDHLD_Pos) |
| #define | FMC_BTRx_ADDHLD_3 (0x8UL << FMC_BTRx_ADDHLD_Pos) |
| #define | FMC_BTRx_DATAST_Pos (8U) |
| #define | FMC_BTRx_DATAST_Msk (0xFFUL << FMC_BTRx_DATAST_Pos) |
| #define | FMC_BTRx_DATAST FMC_BTRx_DATAST_Msk |
| #define | FMC_BTRx_DATAST_0 (0x01UL << FMC_BTRx_DATAST_Pos) |
| #define | FMC_BTRx_DATAST_1 (0x02UL << FMC_BTRx_DATAST_Pos) |
| #define | FMC_BTRx_DATAST_2 (0x04UL << FMC_BTRx_DATAST_Pos) |
| #define | FMC_BTRx_DATAST_3 (0x08UL << FMC_BTRx_DATAST_Pos) |
| #define | FMC_BTRx_DATAST_4 (0x10UL << FMC_BTRx_DATAST_Pos) |
| #define | FMC_BTRx_DATAST_5 (0x20UL << FMC_BTRx_DATAST_Pos) |
| #define | FMC_BTRx_DATAST_6 (0x40UL << FMC_BTRx_DATAST_Pos) |
| #define | FMC_BTRx_DATAST_7 (0x80UL << FMC_BTRx_DATAST_Pos) |
| #define | FMC_BTRx_BUSTURN_Pos (16U) |
| #define | FMC_BTRx_BUSTURN_Msk (0xFUL << FMC_BTRx_BUSTURN_Pos) |
| #define | FMC_BTRx_BUSTURN FMC_BTRx_BUSTURN_Msk |
| #define | FMC_BTRx_BUSTURN_0 (0x1UL << FMC_BTRx_BUSTURN_Pos) |
| #define | FMC_BTRx_BUSTURN_1 (0x2UL << FMC_BTRx_BUSTURN_Pos) |
| #define | FMC_BTRx_BUSTURN_2 (0x4UL << FMC_BTRx_BUSTURN_Pos) |
| #define | FMC_BTRx_BUSTURN_3 (0x8UL << FMC_BTRx_BUSTURN_Pos) |
| #define | FMC_BTRx_CLKDIV_Pos (20U) |
| #define | FMC_BTRx_CLKDIV_Msk (0xFUL << FMC_BTRx_CLKDIV_Pos) |
| #define | FMC_BTRx_CLKDIV FMC_BTRx_CLKDIV_Msk |
| #define | FMC_BTRx_CLKDIV_0 (0x1UL << FMC_BTRx_CLKDIV_Pos) |
| #define | FMC_BTRx_CLKDIV_1 (0x2UL << FMC_BTRx_CLKDIV_Pos) |
| #define | FMC_BTRx_CLKDIV_2 (0x4UL << FMC_BTRx_CLKDIV_Pos) |
| #define | FMC_BTRx_CLKDIV_3 (0x8UL << FMC_BTRx_CLKDIV_Pos) |
| #define | FMC_BTRx_DATLAT_Pos (24U) |
| #define | FMC_BTRx_DATLAT_Msk (0xFUL << FMC_BTRx_DATLAT_Pos) |
| #define | FMC_BTRx_DATLAT FMC_BTRx_DATLAT_Msk |
| #define | FMC_BTRx_DATLAT_0 (0x1UL << FMC_BTRx_DATLAT_Pos) |
| #define | FMC_BTRx_DATLAT_1 (0x2UL << FMC_BTRx_DATLAT_Pos) |
| #define | FMC_BTRx_DATLAT_2 (0x4UL << FMC_BTRx_DATLAT_Pos) |
| #define | FMC_BTRx_DATLAT_3 (0x8UL << FMC_BTRx_DATLAT_Pos) |
| #define | FMC_BTRx_ACCMOD_Pos (28U) |
| #define | FMC_BTRx_ACCMOD_Msk (0x3UL << FMC_BTRx_ACCMOD_Pos) |
| #define | FMC_BTRx_ACCMOD FMC_BTRx_ACCMOD_Msk |
| #define | FMC_BTRx_ACCMOD_0 (0x1UL << FMC_BTRx_ACCMOD_Pos) |
| #define | FMC_BTRx_ACCMOD_1 (0x2UL << FMC_BTRx_ACCMOD_Pos) |
| #define | FMC_BWTRx_ADDSET_Pos (0U) |
| #define | FMC_BWTRx_ADDSET_Msk (0xFUL << FMC_BWTRx_ADDSET_Pos) |
| #define | FMC_BWTRx_ADDSET FMC_BWTRx_ADDSET_Msk |
| #define | FMC_BWTRx_ADDSET_0 (0x1UL << FMC_BWTRx_ADDSET_Pos) |
| #define | FMC_BWTRx_ADDSET_1 (0x2UL << FMC_BWTRx_ADDSET_Pos) |
| #define | FMC_BWTRx_ADDSET_2 (0x4UL << FMC_BWTRx_ADDSET_Pos) |
| #define | FMC_BWTRx_ADDSET_3 (0x8UL << FMC_BWTRx_ADDSET_Pos) |
| #define | FMC_BWTRx_ADDHLD_Pos (4U) |
| #define | FMC_BWTRx_ADDHLD_Msk (0xFUL << FMC_BWTRx_ADDHLD_Pos) |
| #define | FMC_BWTRx_ADDHLD FMC_BWTRx_ADDHLD_Msk |
| #define | FMC_BWTRx_ADDHLD_0 (0x1UL << FMC_BWTRx_ADDHLD_Pos) |
| #define | FMC_BWTRx_ADDHLD_1 (0x2UL << FMC_BWTRx_ADDHLD_Pos) |
| #define | FMC_BWTRx_ADDHLD_2 (0x4UL << FMC_BWTRx_ADDHLD_Pos) |
| #define | FMC_BWTRx_ADDHLD_3 (0x8UL << FMC_BWTRx_ADDHLD_Pos) |
| #define | FMC_BWTRx_DATAST_Pos (8U) |
| #define | FMC_BWTRx_DATAST_Msk (0xFFUL << FMC_BWTRx_DATAST_Pos) |
| #define | FMC_BWTRx_DATAST FMC_BWTRx_DATAST_Msk |
| #define | FMC_BWTRx_DATAST_0 (0x01UL << FMC_BWTRx_DATAST_Pos) |
| #define | FMC_BWTRx_DATAST_1 (0x02UL << FMC_BWTRx_DATAST_Pos) |
| #define | FMC_BWTRx_DATAST_2 (0x04UL << FMC_BWTRx_DATAST_Pos) |
| #define | FMC_BWTRx_DATAST_3 (0x08UL << FMC_BWTRx_DATAST_Pos) |
| #define | FMC_BWTRx_DATAST_4 (0x10UL << FMC_BWTRx_DATAST_Pos) |
| #define | FMC_BWTRx_DATAST_5 (0x20UL << FMC_BWTRx_DATAST_Pos) |
| #define | FMC_BWTRx_DATAST_6 (0x40UL << FMC_BWTRx_DATAST_Pos) |
| #define | FMC_BWTRx_DATAST_7 (0x80UL << FMC_BWTRx_DATAST_Pos) |
| #define | FMC_BWTRx_BUSTURN_Pos (16U) |
| #define | FMC_BWTRx_BUSTURN_Msk (0xFUL << FMC_BWTRx_BUSTURN_Pos) |
| #define | FMC_BWTRx_BUSTURN FMC_BWTRx_BUSTURN_Msk |
| #define | FMC_BWTRx_BUSTURN_0 (0x1UL << FMC_BWTRx_BUSTURN_Pos) |
| #define | FMC_BWTRx_BUSTURN_1 (0x2UL << FMC_BWTRx_BUSTURN_Pos) |
| #define | FMC_BWTRx_BUSTURN_2 (0x4UL << FMC_BWTRx_BUSTURN_Pos) |
| #define | FMC_BWTRx_BUSTURN_3 (0x8UL << FMC_BWTRx_BUSTURN_Pos) |
| #define | FMC_BWTRx_ACCMOD_Pos (28U) |
| #define | FMC_BWTRx_ACCMOD_Msk (0x3UL << FMC_BWTRx_ACCMOD_Pos) |
| #define | FMC_BWTRx_ACCMOD FMC_BWTRx_ACCMOD_Msk |
| #define | FMC_BWTRx_ACCMOD_0 (0x1UL << FMC_BWTRx_ACCMOD_Pos) |
| #define | FMC_BWTRx_ACCMOD_1 (0x2UL << FMC_BWTRx_ACCMOD_Pos) |
| #define | FMC_PCR_PWAITEN_Pos (1U) |
| #define | FMC_PCR_PWAITEN_Msk (0x1UL << FMC_PCR_PWAITEN_Pos) |
| #define | FMC_PCR_PWAITEN FMC_PCR_PWAITEN_Msk |
| #define | FMC_PCR_PBKEN_Pos (2U) |
| #define | FMC_PCR_PBKEN_Msk (0x1UL << FMC_PCR_PBKEN_Pos) |
| #define | FMC_PCR_PBKEN FMC_PCR_PBKEN_Msk |
| #define | FMC_PCR_PWID_Pos (4U) |
| #define | FMC_PCR_PWID_Msk (0x3UL << FMC_PCR_PWID_Pos) |
| #define | FMC_PCR_PWID FMC_PCR_PWID_Msk |
| #define | FMC_PCR_PWID_0 (0x1UL << FMC_PCR_PWID_Pos) |
| #define | FMC_PCR_PWID_1 (0x2UL << FMC_PCR_PWID_Pos) |
| #define | FMC_PCR_ECCEN_Pos (6U) |
| #define | FMC_PCR_ECCEN_Msk (0x1UL << FMC_PCR_ECCEN_Pos) |
| #define | FMC_PCR_ECCEN FMC_PCR_ECCEN_Msk |
| #define | FMC_PCR_TCLR_Pos (9U) |
| #define | FMC_PCR_TCLR_Msk (0xFUL << FMC_PCR_TCLR_Pos) |
| #define | FMC_PCR_TCLR FMC_PCR_TCLR_Msk |
| #define | FMC_PCR_TCLR_0 (0x1UL << FMC_PCR_TCLR_Pos) |
| #define | FMC_PCR_TCLR_1 (0x2UL << FMC_PCR_TCLR_Pos) |
| #define | FMC_PCR_TCLR_2 (0x4UL << FMC_PCR_TCLR_Pos) |
| #define | FMC_PCR_TCLR_3 (0x8UL << FMC_PCR_TCLR_Pos) |
| #define | FMC_PCR_TAR_Pos (13U) |
| #define | FMC_PCR_TAR_Msk (0xFUL << FMC_PCR_TAR_Pos) |
| #define | FMC_PCR_TAR FMC_PCR_TAR_Msk |
| #define | FMC_PCR_TAR_0 (0x1UL << FMC_PCR_TAR_Pos) |
| #define | FMC_PCR_TAR_1 (0x2UL << FMC_PCR_TAR_Pos) |
| #define | FMC_PCR_TAR_2 (0x4UL << FMC_PCR_TAR_Pos) |
| #define | FMC_PCR_TAR_3 (0x8UL << FMC_PCR_TAR_Pos) |
| #define | FMC_PCR_ECCPS_Pos (17U) |
| #define | FMC_PCR_ECCPS_Msk (0x7UL << FMC_PCR_ECCPS_Pos) |
| #define | FMC_PCR_ECCPS FMC_PCR_ECCPS_Msk |
| #define | FMC_PCR_ECCPS_0 (0x1UL << FMC_PCR_ECCPS_Pos) |
| #define | FMC_PCR_ECCPS_1 (0x2UL << FMC_PCR_ECCPS_Pos) |
| #define | FMC_PCR_ECCPS_2 (0x4UL << FMC_PCR_ECCPS_Pos) |
| #define | FMC_SR_IRS_Pos (0U) |
| #define | FMC_SR_IRS_Msk (0x1UL << FMC_SR_IRS_Pos) |
| #define | FMC_SR_IRS FMC_SR_IRS_Msk |
| #define | FMC_SR_ILS_Pos (1U) |
| #define | FMC_SR_ILS_Msk (0x1UL << FMC_SR_ILS_Pos) |
| #define | FMC_SR_ILS FMC_SR_ILS_Msk |
| #define | FMC_SR_IFS_Pos (2U) |
| #define | FMC_SR_IFS_Msk (0x1UL << FMC_SR_IFS_Pos) |
| #define | FMC_SR_IFS FMC_SR_IFS_Msk |
| #define | FMC_SR_IREN_Pos (3U) |
| #define | FMC_SR_IREN_Msk (0x1UL << FMC_SR_IREN_Pos) |
| #define | FMC_SR_IREN FMC_SR_IREN_Msk |
| #define | FMC_SR_ILEN_Pos (4U) |
| #define | FMC_SR_ILEN_Msk (0x1UL << FMC_SR_ILEN_Pos) |
| #define | FMC_SR_ILEN FMC_SR_ILEN_Msk |
| #define | FMC_SR_IFEN_Pos (5U) |
| #define | FMC_SR_IFEN_Msk (0x1UL << FMC_SR_IFEN_Pos) |
| #define | FMC_SR_IFEN FMC_SR_IFEN_Msk |
| #define | FMC_SR_FEMPT_Pos (6U) |
| #define | FMC_SR_FEMPT_Msk (0x1UL << FMC_SR_FEMPT_Pos) |
| #define | FMC_SR_FEMPT FMC_SR_FEMPT_Msk |
| #define | FMC_PMEM_MEMSET_Pos (0U) |
| #define | FMC_PMEM_MEMSET_Msk (0xFFUL << FMC_PMEM_MEMSET_Pos) |
| #define | FMC_PMEM_MEMSET FMC_PMEM_MEMSET_Msk |
| #define | FMC_PMEM_MEMSET_0 (0x01UL << FMC_PMEM_MEMSET_Pos) |
| #define | FMC_PMEM_MEMSET_1 (0x02UL << FMC_PMEM_MEMSET_Pos) |
| #define | FMC_PMEM_MEMSET_2 (0x04UL << FMC_PMEM_MEMSET_Pos) |
| #define | FMC_PMEM_MEMSET_3 (0x08UL << FMC_PMEM_MEMSET_Pos) |
| #define | FMC_PMEM_MEMSET_4 (0x10UL << FMC_PMEM_MEMSET_Pos) |
| #define | FMC_PMEM_MEMSET_5 (0x20UL << FMC_PMEM_MEMSET_Pos) |
| #define | FMC_PMEM_MEMSET_6 (0x40UL << FMC_PMEM_MEMSET_Pos) |
| #define | FMC_PMEM_MEMSET_7 (0x80UL << FMC_PMEM_MEMSET_Pos) |
| #define | FMC_PMEM_MEMWAIT_Pos (8U) |
| #define | FMC_PMEM_MEMWAIT_Msk (0xFFUL << FMC_PMEM_MEMWAIT_Pos) |
| #define | FMC_PMEM_MEMWAIT FMC_PMEM_MEMWAIT_Msk |
| #define | FMC_PMEM_MEMWAIT_0 (0x01UL << FMC_PMEM_MEMWAIT_Pos) |
| #define | FMC_PMEM_MEMWAIT_1 (0x02UL << FMC_PMEM_MEMWAIT_Pos) |
| #define | FMC_PMEM_MEMWAIT_2 (0x04UL << FMC_PMEM_MEMWAIT_Pos) |
| #define | FMC_PMEM_MEMWAIT_3 (0x08UL << FMC_PMEM_MEMWAIT_Pos) |
| #define | FMC_PMEM_MEMWAIT_4 (0x10UL << FMC_PMEM_MEMWAIT_Pos) |
| #define | FMC_PMEM_MEMWAIT_5 (0x20UL << FMC_PMEM_MEMWAIT_Pos) |
| #define | FMC_PMEM_MEMWAIT_6 (0x40UL << FMC_PMEM_MEMWAIT_Pos) |
| #define | FMC_PMEM_MEMWAIT_7 (0x80UL << FMC_PMEM_MEMWAIT_Pos) |
| #define | FMC_PMEM_MEMHOLD_Pos (16U) |
| #define | FMC_PMEM_MEMHOLD_Msk (0xFFUL << FMC_PMEM_MEMHOLD_Pos) |
| #define | FMC_PMEM_MEMHOLD FMC_PMEM_MEMHOLD_Msk |
| #define | FMC_PMEM_MEMHOLD_0 (0x01UL << FMC_PMEM_MEMHOLD_Pos) |
| #define | FMC_PMEM_MEMHOLD_1 (0x02UL << FMC_PMEM_MEMHOLD_Pos) |
| #define | FMC_PMEM_MEMHOLD_2 (0x04UL << FMC_PMEM_MEMHOLD_Pos) |
| #define | FMC_PMEM_MEMHOLD_3 (0x08UL << FMC_PMEM_MEMHOLD_Pos) |
| #define | FMC_PMEM_MEMHOLD_4 (0x10UL << FMC_PMEM_MEMHOLD_Pos) |
| #define | FMC_PMEM_MEMHOLD_5 (0x20UL << FMC_PMEM_MEMHOLD_Pos) |
| #define | FMC_PMEM_MEMHOLD_6 (0x40UL << FMC_PMEM_MEMHOLD_Pos) |
| #define | FMC_PMEM_MEMHOLD_7 (0x80UL << FMC_PMEM_MEMHOLD_Pos) |
| #define | FMC_PMEM_MEMHIZ_Pos (24U) |
| #define | FMC_PMEM_MEMHIZ_Msk (0xFFUL << FMC_PMEM_MEMHIZ_Pos) |
| #define | FMC_PMEM_MEMHIZ FMC_PMEM_MEMHIZ_Msk |
| #define | FMC_PMEM_MEMHIZ_0 (0x01UL << FMC_PMEM_MEMHIZ_Pos) |
| #define | FMC_PMEM_MEMHIZ_1 (0x02UL << FMC_PMEM_MEMHIZ_Pos) |
| #define | FMC_PMEM_MEMHIZ_2 (0x04UL << FMC_PMEM_MEMHIZ_Pos) |
| #define | FMC_PMEM_MEMHIZ_3 (0x08UL << FMC_PMEM_MEMHIZ_Pos) |
| #define | FMC_PMEM_MEMHIZ_4 (0x10UL << FMC_PMEM_MEMHIZ_Pos) |
| #define | FMC_PMEM_MEMHIZ_5 (0x20UL << FMC_PMEM_MEMHIZ_Pos) |
| #define | FMC_PMEM_MEMHIZ_6 (0x40UL << FMC_PMEM_MEMHIZ_Pos) |
| #define | FMC_PMEM_MEMHIZ_7 (0x80UL << FMC_PMEM_MEMHIZ_Pos) |
| #define | FMC_PATT_ATTSET_Pos (0U) |
| #define | FMC_PATT_ATTSET_Msk (0xFFUL << FMC_PATT_ATTSET_Pos) |
| #define | FMC_PATT_ATTSET FMC_PATT_ATTSET_Msk |
| #define | FMC_PATT_ATTSET_0 (0x01UL << FMC_PATT_ATTSET_Pos) |
| #define | FMC_PATT_ATTSET_1 (0x02UL << FMC_PATT_ATTSET_Pos) |
| #define | FMC_PATT_ATTSET_2 (0x04UL << FMC_PATT_ATTSET_Pos) |
| #define | FMC_PATT_ATTSET_3 (0x08UL << FMC_PATT_ATTSET_Pos) |
| #define | FMC_PATT_ATTSET_4 (0x10UL << FMC_PATT_ATTSET_Pos) |
| #define | FMC_PATT_ATTSET_5 (0x20UL << FMC_PATT_ATTSET_Pos) |
| #define | FMC_PATT_ATTSET_6 (0x40UL << FMC_PATT_ATTSET_Pos) |
| #define | FMC_PATT_ATTSET_7 (0x80UL << FMC_PATT_ATTSET_Pos) |
| #define | FMC_PATT_ATTWAIT_Pos (8U) |
| #define | FMC_PATT_ATTWAIT_Msk (0xFFUL << FMC_PATT_ATTWAIT_Pos) |
| #define | FMC_PATT_ATTWAIT FMC_PATT_ATTWAIT_Msk |
| #define | FMC_PATT_ATTWAIT_0 (0x01UL << FMC_PATT_ATTWAIT_Pos) |
| #define | FMC_PATT_ATTWAIT_1 (0x02UL << FMC_PATT_ATTWAIT_Pos) |
| #define | FMC_PATT_ATTWAIT_2 (0x04UL << FMC_PATT_ATTWAIT_Pos) |
| #define | FMC_PATT_ATTWAIT_3 (0x08UL << FMC_PATT_ATTWAIT_Pos) |
| #define | FMC_PATT_ATTWAIT_4 (0x10UL << FMC_PATT_ATTWAIT_Pos) |
| #define | FMC_PATT_ATTWAIT_5 (0x20UL << FMC_PATT_ATTWAIT_Pos) |
| #define | FMC_PATT_ATTWAIT_6 (0x40UL << FMC_PATT_ATTWAIT_Pos) |
| #define | FMC_PATT_ATTWAIT_7 (0x80UL << FMC_PATT_ATTWAIT_Pos) |
| #define | FMC_PATT_ATTHOLD_Pos (16U) |
| #define | FMC_PATT_ATTHOLD_Msk (0xFFUL << FMC_PATT_ATTHOLD_Pos) |
| #define | FMC_PATT_ATTHOLD FMC_PATT_ATTHOLD_Msk |
| #define | FMC_PATT_ATTHOLD_0 (0x01UL << FMC_PATT_ATTHOLD_Pos) |
| #define | FMC_PATT_ATTHOLD_1 (0x02UL << FMC_PATT_ATTHOLD_Pos) |
| #define | FMC_PATT_ATTHOLD_2 (0x04UL << FMC_PATT_ATTHOLD_Pos) |
| #define | FMC_PATT_ATTHOLD_3 (0x08UL << FMC_PATT_ATTHOLD_Pos) |
| #define | FMC_PATT_ATTHOLD_4 (0x10UL << FMC_PATT_ATTHOLD_Pos) |
| #define | FMC_PATT_ATTHOLD_5 (0x20UL << FMC_PATT_ATTHOLD_Pos) |
| #define | FMC_PATT_ATTHOLD_6 (0x40UL << FMC_PATT_ATTHOLD_Pos) |
| #define | FMC_PATT_ATTHOLD_7 (0x80UL << FMC_PATT_ATTHOLD_Pos) |
| #define | FMC_PATT_ATTHIZ_Pos (24U) |
| #define | FMC_PATT_ATTHIZ_Msk (0xFFUL << FMC_PATT_ATTHIZ_Pos) |
| #define | FMC_PATT_ATTHIZ FMC_PATT_ATTHIZ_Msk |
| #define | FMC_PATT_ATTHIZ_0 (0x01UL << FMC_PATT_ATTHIZ_Pos) |
| #define | FMC_PATT_ATTHIZ_1 (0x02UL << FMC_PATT_ATTHIZ_Pos) |
| #define | FMC_PATT_ATTHIZ_2 (0x04UL << FMC_PATT_ATTHIZ_Pos) |
| #define | FMC_PATT_ATTHIZ_3 (0x08UL << FMC_PATT_ATTHIZ_Pos) |
| #define | FMC_PATT_ATTHIZ_4 (0x10UL << FMC_PATT_ATTHIZ_Pos) |
| #define | FMC_PATT_ATTHIZ_5 (0x20UL << FMC_PATT_ATTHIZ_Pos) |
| #define | FMC_PATT_ATTHIZ_6 (0x40UL << FMC_PATT_ATTHIZ_Pos) |
| #define | FMC_PATT_ATTHIZ_7 (0x80UL << FMC_PATT_ATTHIZ_Pos) |
| #define | FMC_ECCR3_ECC3_Pos (0U) |
| #define | FMC_ECCR3_ECC3_Msk (0xFFFFFFFFUL << FMC_ECCR3_ECC3_Pos) |
| #define | FMC_ECCR3_ECC3 FMC_ECCR3_ECC3_Msk |
| #define | FMC_SDCRx_NC_Pos (0U) |
| #define | FMC_SDCRx_NC_Msk (0x3UL << FMC_SDCRx_NC_Pos) |
| #define | FMC_SDCRx_NC FMC_SDCRx_NC_Msk |
| #define | FMC_SDCRx_NC_0 (0x1UL << FMC_SDCRx_NC_Pos) |
| #define | FMC_SDCRx_NC_1 (0x2UL << FMC_SDCRx_NC_Pos) |
| #define | FMC_SDCRx_NR_Pos (2U) |
| #define | FMC_SDCRx_NR_Msk (0x3UL << FMC_SDCRx_NR_Pos) |
| #define | FMC_SDCRx_NR FMC_SDCRx_NR_Msk |
| #define | FMC_SDCRx_NR_0 (0x1UL << FMC_SDCRx_NR_Pos) |
| #define | FMC_SDCRx_NR_1 (0x2UL << FMC_SDCRx_NR_Pos) |
| #define | FMC_SDCRx_MWID_Pos (4U) |
| #define | FMC_SDCRx_MWID_Msk (0x3UL << FMC_SDCRx_MWID_Pos) |
| #define | FMC_SDCRx_MWID FMC_SDCRx_MWID_Msk |
| #define | FMC_SDCRx_MWID_0 (0x1UL << FMC_SDCRx_MWID_Pos) |
| #define | FMC_SDCRx_MWID_1 (0x2UL << FMC_SDCRx_MWID_Pos) |
| #define | FMC_SDCRx_NB_Pos (6U) |
| #define | FMC_SDCRx_NB_Msk (0x1UL << FMC_SDCRx_NB_Pos) |
| #define | FMC_SDCRx_NB FMC_SDCRx_NB_Msk |
| #define | FMC_SDCRx_CAS_Pos (7U) |
| #define | FMC_SDCRx_CAS_Msk (0x3UL << FMC_SDCRx_CAS_Pos) |
| #define | FMC_SDCRx_CAS FMC_SDCRx_CAS_Msk |
| #define | FMC_SDCRx_CAS_0 (0x1UL << FMC_SDCRx_CAS_Pos) |
| #define | FMC_SDCRx_CAS_1 (0x2UL << FMC_SDCRx_CAS_Pos) |
| #define | FMC_SDCRx_WP_Pos (9U) |
| #define | FMC_SDCRx_WP_Msk (0x1UL << FMC_SDCRx_WP_Pos) |
| #define | FMC_SDCRx_WP FMC_SDCRx_WP_Msk |
| #define | FMC_SDCRx_SDCLK_Pos (10U) |
| #define | FMC_SDCRx_SDCLK_Msk (0x3UL << FMC_SDCRx_SDCLK_Pos) |
| #define | FMC_SDCRx_SDCLK FMC_SDCRx_SDCLK_Msk |
| #define | FMC_SDCRx_SDCLK_0 (0x1UL << FMC_SDCRx_SDCLK_Pos) |
| #define | FMC_SDCRx_SDCLK_1 (0x2UL << FMC_SDCRx_SDCLK_Pos) |
| #define | FMC_SDCRx_RBURST_Pos (12U) |
| #define | FMC_SDCRx_RBURST_Msk (0x1UL << FMC_SDCRx_RBURST_Pos) |
| #define | FMC_SDCRx_RBURST FMC_SDCRx_RBURST_Msk |
| #define | FMC_SDCRx_RPIPE_Pos (13U) |
| #define | FMC_SDCRx_RPIPE_Msk (0x3UL << FMC_SDCRx_RPIPE_Pos) |
| #define | FMC_SDCRx_RPIPE FMC_SDCRx_RPIPE_Msk |
| #define | FMC_SDCRx_RPIPE_0 (0x1UL << FMC_SDCRx_RPIPE_Pos) |
| #define | FMC_SDCRx_RPIPE_1 (0x2UL << FMC_SDCRx_RPIPE_Pos) |
| #define | FMC_SDTRx_TMRD_Pos (0U) |
| #define | FMC_SDTRx_TMRD_Msk (0xFUL << FMC_SDTRx_TMRD_Pos) |
| #define | FMC_SDTRx_TMRD FMC_SDTRx_TMRD_Msk |
| #define | FMC_SDTRx_TMRD_0 (0x1UL << FMC_SDTRx_TMRD_Pos) |
| #define | FMC_SDTRx_TMRD_1 (0x2UL << FMC_SDTRx_TMRD_Pos) |
| #define | FMC_SDTRx_TMRD_2 (0x4UL << FMC_SDTRx_TMRD_Pos) |
| #define | FMC_SDTRx_TMRD_3 (0x8UL << FMC_SDTRx_TMRD_Pos) |
| #define | FMC_SDTRx_TXSR_Pos (4U) |
| #define | FMC_SDTRx_TXSR_Msk (0xFUL << FMC_SDTRx_TXSR_Pos) |
| #define | FMC_SDTRx_TXSR FMC_SDTRx_TXSR_Msk |
| #define | FMC_SDTRx_TXSR_0 (0x1UL << FMC_SDTRx_TXSR_Pos) |
| #define | FMC_SDTRx_TXSR_1 (0x2UL << FMC_SDTRx_TXSR_Pos) |
| #define | FMC_SDTRx_TXSR_2 (0x4UL << FMC_SDTRx_TXSR_Pos) |
| #define | FMC_SDTRx_TXSR_3 (0x8UL << FMC_SDTRx_TXSR_Pos) |
| #define | FMC_SDTRx_TRAS_Pos (8U) |
| #define | FMC_SDTRx_TRAS_Msk (0xFUL << FMC_SDTRx_TRAS_Pos) |
| #define | FMC_SDTRx_TRAS FMC_SDTRx_TRAS_Msk |
| #define | FMC_SDTRx_TRAS_0 (0x1UL << FMC_SDTRx_TRAS_Pos) |
| #define | FMC_SDTRx_TRAS_1 (0x2UL << FMC_SDTRx_TRAS_Pos) |
| #define | FMC_SDTRx_TRAS_2 (0x4UL << FMC_SDTRx_TRAS_Pos) |
| #define | FMC_SDTRx_TRAS_3 (0x8UL << FMC_SDTRx_TRAS_Pos) |
| #define | FMC_SDTRx_TRC_Pos (12U) |
| #define | FMC_SDTRx_TRC_Msk (0xFUL << FMC_SDTRx_TRC_Pos) |
| #define | FMC_SDTRx_TRC FMC_SDTRx_TRC_Msk |
| #define | FMC_SDTRx_TRC_0 (0x1UL << FMC_SDTRx_TRC_Pos) |
| #define | FMC_SDTRx_TRC_1 (0x2UL << FMC_SDTRx_TRC_Pos) |
| #define | FMC_SDTRx_TRC_2 (0x4UL << FMC_SDTRx_TRC_Pos) |
| #define | FMC_SDTRx_TWR_Pos (16U) |
| #define | FMC_SDTRx_TWR_Msk (0xFUL << FMC_SDTRx_TWR_Pos) |
| #define | FMC_SDTRx_TWR FMC_SDTRx_TWR_Msk |
| #define | FMC_SDTRx_TWR_0 (0x1UL << FMC_SDTRx_TWR_Pos) |
| #define | FMC_SDTRx_TWR_1 (0x2UL << FMC_SDTRx_TWR_Pos) |
| #define | FMC_SDTRx_TWR_2 (0x4UL << FMC_SDTRx_TWR_Pos) |
| #define | FMC_SDTRx_TRP_Pos (20U) |
| #define | FMC_SDTRx_TRP_Msk (0xFUL << FMC_SDTRx_TRP_Pos) |
| #define | FMC_SDTRx_TRP FMC_SDTRx_TRP_Msk |
| #define | FMC_SDTRx_TRP_0 (0x1UL << FMC_SDTRx_TRP_Pos) |
| #define | FMC_SDTRx_TRP_1 (0x2UL << FMC_SDTRx_TRP_Pos) |
| #define | FMC_SDTRx_TRP_2 (0x4UL << FMC_SDTRx_TRP_Pos) |
| #define | FMC_SDTRx_TRCD_Pos (24U) |
| #define | FMC_SDTRx_TRCD_Msk (0xFUL << FMC_SDTRx_TRCD_Pos) |
| #define | FMC_SDTRx_TRCD FMC_SDTRx_TRCD_Msk |
| #define | FMC_SDTRx_TRCD_0 (0x1UL << FMC_SDTRx_TRCD_Pos) |
| #define | FMC_SDTRx_TRCD_1 (0x2UL << FMC_SDTRx_TRCD_Pos) |
| #define | FMC_SDTRx_TRCD_2 (0x4UL << FMC_SDTRx_TRCD_Pos) |
| #define | FMC_SDCMR_MODE_Pos (0U) |
| #define | FMC_SDCMR_MODE_Msk (0x7UL << FMC_SDCMR_MODE_Pos) |
| #define | FMC_SDCMR_MODE FMC_SDCMR_MODE_Msk |
| #define | FMC_SDCMR_MODE_0 (0x1UL << FMC_SDCMR_MODE_Pos) |
| #define | FMC_SDCMR_MODE_1 (0x2UL << FMC_SDCMR_MODE_Pos) |
| #define | FMC_SDCMR_MODE_2 (0x4UL << FMC_SDCMR_MODE_Pos) |
| #define | FMC_SDCMR_CTB2_Pos (3U) |
| #define | FMC_SDCMR_CTB2_Msk (0x1UL << FMC_SDCMR_CTB2_Pos) |
| #define | FMC_SDCMR_CTB2 FMC_SDCMR_CTB2_Msk |
| #define | FMC_SDCMR_CTB1_Pos (4U) |
| #define | FMC_SDCMR_CTB1_Msk (0x1UL << FMC_SDCMR_CTB1_Pos) |
| #define | FMC_SDCMR_CTB1 FMC_SDCMR_CTB1_Msk |
| #define | FMC_SDCMR_NRFS_Pos (5U) |
| #define | FMC_SDCMR_NRFS_Msk (0xFUL << FMC_SDCMR_NRFS_Pos) |
| #define | FMC_SDCMR_NRFS FMC_SDCMR_NRFS_Msk |
| #define | FMC_SDCMR_NRFS_0 (0x1UL << FMC_SDCMR_NRFS_Pos) |
| #define | FMC_SDCMR_NRFS_1 (0x2UL << FMC_SDCMR_NRFS_Pos) |
| #define | FMC_SDCMR_NRFS_2 (0x4UL << FMC_SDCMR_NRFS_Pos) |
| #define | FMC_SDCMR_NRFS_3 (0x8UL << FMC_SDCMR_NRFS_Pos) |
| #define | FMC_SDCMR_MRD_Pos (9U) |
| #define | FMC_SDCMR_MRD_Msk (0x1FFFUL << FMC_SDCMR_MRD_Pos) |
| #define | FMC_SDCMR_MRD FMC_SDCMR_MRD_Msk |
| #define | FMC_SDRTR_CRE_Pos (0U) |
| #define | FMC_SDRTR_CRE_Msk (0x1UL << FMC_SDRTR_CRE_Pos) |
| #define | FMC_SDRTR_CRE FMC_SDRTR_CRE_Msk |
| #define | FMC_SDRTR_COUNT_Pos (1U) |
| #define | FMC_SDRTR_COUNT_Msk (0x1FFFUL << FMC_SDRTR_COUNT_Pos) |
| #define | FMC_SDRTR_COUNT FMC_SDRTR_COUNT_Msk |
| #define | FMC_SDRTR_REIE_Pos (14U) |
| #define | FMC_SDRTR_REIE_Msk (0x1UL << FMC_SDRTR_REIE_Pos) |
| #define | FMC_SDRTR_REIE FMC_SDRTR_REIE_Msk |
| #define | FMC_SDSR_RE_Pos (0U) |
| #define | FMC_SDSR_RE_Msk (0x1UL << FMC_SDSR_RE_Pos) |
| #define | FMC_SDSR_RE FMC_SDSR_RE_Msk |
| #define | FMC_SDSR_MODES1_Pos (1U) |
| #define | FMC_SDSR_MODES1_Msk (0x3UL << FMC_SDSR_MODES1_Pos) |
| #define | FMC_SDSR_MODES1 FMC_SDSR_MODES1_Msk |
| #define | FMC_SDSR_MODES1_0 (0x1UL << FMC_SDSR_MODES1_Pos) |
| #define | FMC_SDSR_MODES1_1 (0x2UL << FMC_SDSR_MODES1_Pos) |
| #define | FMC_SDSR_MODES2_Pos (3U) |
| #define | FMC_SDSR_MODES2_Msk (0x3UL << FMC_SDSR_MODES2_Pos) |
| #define | FMC_SDSR_MODES2 FMC_SDSR_MODES2_Msk |
| #define | FMC_SDSR_MODES2_0 (0x1UL << FMC_SDSR_MODES2_Pos) |
| #define | FMC_SDSR_MODES2_1 (0x2UL << FMC_SDSR_MODES2_Pos) |
| #define | GPIO_MODER_MODE0_Pos (0U) |
| #define | GPIO_MODER_MODE0_Msk (0x3UL << GPIO_MODER_MODE0_Pos) |
| #define | GPIO_MODER_MODE0 GPIO_MODER_MODE0_Msk |
| #define | GPIO_MODER_MODE0_0 (0x1UL << GPIO_MODER_MODE0_Pos) |
| #define | GPIO_MODER_MODE0_1 (0x2UL << GPIO_MODER_MODE0_Pos) |
| #define | GPIO_MODER_MODE1_Pos (2U) |
| #define | GPIO_MODER_MODE1_Msk (0x3UL << GPIO_MODER_MODE1_Pos) |
| #define | GPIO_MODER_MODE1 GPIO_MODER_MODE1_Msk |
| #define | GPIO_MODER_MODE1_0 (0x1UL << GPIO_MODER_MODE1_Pos) |
| #define | GPIO_MODER_MODE1_1 (0x2UL << GPIO_MODER_MODE1_Pos) |
| #define | GPIO_MODER_MODE2_Pos (4U) |
| #define | GPIO_MODER_MODE2_Msk (0x3UL << GPIO_MODER_MODE2_Pos) |
| #define | GPIO_MODER_MODE2 GPIO_MODER_MODE2_Msk |
| #define | GPIO_MODER_MODE2_0 (0x1UL << GPIO_MODER_MODE2_Pos) |
| #define | GPIO_MODER_MODE2_1 (0x2UL << GPIO_MODER_MODE2_Pos) |
| #define | GPIO_MODER_MODE3_Pos (6U) |
| #define | GPIO_MODER_MODE3_Msk (0x3UL << GPIO_MODER_MODE3_Pos) |
| #define | GPIO_MODER_MODE3 GPIO_MODER_MODE3_Msk |
| #define | GPIO_MODER_MODE3_0 (0x1UL << GPIO_MODER_MODE3_Pos) |
| #define | GPIO_MODER_MODE3_1 (0x2UL << GPIO_MODER_MODE3_Pos) |
| #define | GPIO_MODER_MODE4_Pos (8U) |
| #define | GPIO_MODER_MODE4_Msk (0x3UL << GPIO_MODER_MODE4_Pos) |
| #define | GPIO_MODER_MODE4 GPIO_MODER_MODE4_Msk |
| #define | GPIO_MODER_MODE4_0 (0x1UL << GPIO_MODER_MODE4_Pos) |
| #define | GPIO_MODER_MODE4_1 (0x2UL << GPIO_MODER_MODE4_Pos) |
| #define | GPIO_MODER_MODE5_Pos (10U) |
| #define | GPIO_MODER_MODE5_Msk (0x3UL << GPIO_MODER_MODE5_Pos) |
| #define | GPIO_MODER_MODE5 GPIO_MODER_MODE5_Msk |
| #define | GPIO_MODER_MODE5_0 (0x1UL << GPIO_MODER_MODE5_Pos) |
| #define | GPIO_MODER_MODE5_1 (0x2UL << GPIO_MODER_MODE5_Pos) |
| #define | GPIO_MODER_MODE6_Pos (12U) |
| #define | GPIO_MODER_MODE6_Msk (0x3UL << GPIO_MODER_MODE6_Pos) |
| #define | GPIO_MODER_MODE6 GPIO_MODER_MODE6_Msk |
| #define | GPIO_MODER_MODE6_0 (0x1UL << GPIO_MODER_MODE6_Pos) |
| #define | GPIO_MODER_MODE6_1 (0x2UL << GPIO_MODER_MODE6_Pos) |
| #define | GPIO_MODER_MODE7_Pos (14U) |
| #define | GPIO_MODER_MODE7_Msk (0x3UL << GPIO_MODER_MODE7_Pos) |
| #define | GPIO_MODER_MODE7 GPIO_MODER_MODE7_Msk |
| #define | GPIO_MODER_MODE7_0 (0x1UL << GPIO_MODER_MODE7_Pos) |
| #define | GPIO_MODER_MODE7_1 (0x2UL << GPIO_MODER_MODE7_Pos) |
| #define | GPIO_MODER_MODE8_Pos (16U) |
| #define | GPIO_MODER_MODE8_Msk (0x3UL << GPIO_MODER_MODE8_Pos) |
| #define | GPIO_MODER_MODE8 GPIO_MODER_MODE8_Msk |
| #define | GPIO_MODER_MODE8_0 (0x1UL << GPIO_MODER_MODE8_Pos) |
| #define | GPIO_MODER_MODE8_1 (0x2UL << GPIO_MODER_MODE8_Pos) |
| #define | GPIO_MODER_MODE9_Pos (18U) |
| #define | GPIO_MODER_MODE9_Msk (0x3UL << GPIO_MODER_MODE9_Pos) |
| #define | GPIO_MODER_MODE9 GPIO_MODER_MODE9_Msk |
| #define | GPIO_MODER_MODE9_0 (0x1UL << GPIO_MODER_MODE9_Pos) |
| #define | GPIO_MODER_MODE9_1 (0x2UL << GPIO_MODER_MODE9_Pos) |
| #define | GPIO_MODER_MODE10_Pos (20U) |
| #define | GPIO_MODER_MODE10_Msk (0x3UL << GPIO_MODER_MODE10_Pos) |
| #define | GPIO_MODER_MODE10 GPIO_MODER_MODE10_Msk |
| #define | GPIO_MODER_MODE10_0 (0x1UL << GPIO_MODER_MODE10_Pos) |
| #define | GPIO_MODER_MODE10_1 (0x2UL << GPIO_MODER_MODE10_Pos) |
| #define | GPIO_MODER_MODE11_Pos (22U) |
| #define | GPIO_MODER_MODE11_Msk (0x3UL << GPIO_MODER_MODE11_Pos) |
| #define | GPIO_MODER_MODE11 GPIO_MODER_MODE11_Msk |
| #define | GPIO_MODER_MODE11_0 (0x1UL << GPIO_MODER_MODE11_Pos) |
| #define | GPIO_MODER_MODE11_1 (0x2UL << GPIO_MODER_MODE11_Pos) |
| #define | GPIO_MODER_MODE12_Pos (24U) |
| #define | GPIO_MODER_MODE12_Msk (0x3UL << GPIO_MODER_MODE12_Pos) |
| #define | GPIO_MODER_MODE12 GPIO_MODER_MODE12_Msk |
| #define | GPIO_MODER_MODE12_0 (0x1UL << GPIO_MODER_MODE12_Pos) |
| #define | GPIO_MODER_MODE12_1 (0x2UL << GPIO_MODER_MODE12_Pos) |
| #define | GPIO_MODER_MODE13_Pos (26U) |
| #define | GPIO_MODER_MODE13_Msk (0x3UL << GPIO_MODER_MODE13_Pos) |
| #define | GPIO_MODER_MODE13 GPIO_MODER_MODE13_Msk |
| #define | GPIO_MODER_MODE13_0 (0x1UL << GPIO_MODER_MODE13_Pos) |
| #define | GPIO_MODER_MODE13_1 (0x2UL << GPIO_MODER_MODE13_Pos) |
| #define | GPIO_MODER_MODE14_Pos (28U) |
| #define | GPIO_MODER_MODE14_Msk (0x3UL << GPIO_MODER_MODE14_Pos) |
| #define | GPIO_MODER_MODE14 GPIO_MODER_MODE14_Msk |
| #define | GPIO_MODER_MODE14_0 (0x1UL << GPIO_MODER_MODE14_Pos) |
| #define | GPIO_MODER_MODE14_1 (0x2UL << GPIO_MODER_MODE14_Pos) |
| #define | GPIO_MODER_MODE15_Pos (30U) |
| #define | GPIO_MODER_MODE15_Msk (0x3UL << GPIO_MODER_MODE15_Pos) |
| #define | GPIO_MODER_MODE15 GPIO_MODER_MODE15_Msk |
| #define | GPIO_MODER_MODE15_0 (0x1UL << GPIO_MODER_MODE15_Pos) |
| #define | GPIO_MODER_MODE15_1 (0x2UL << GPIO_MODER_MODE15_Pos) |
| #define | GPIO_OTYPER_OT0_Pos (0U) |
| #define | GPIO_OTYPER_OT0_Msk (0x1UL << GPIO_OTYPER_OT0_Pos) |
| #define | GPIO_OTYPER_OT0 GPIO_OTYPER_OT0_Msk |
| #define | GPIO_OTYPER_OT1_Pos (1U) |
| #define | GPIO_OTYPER_OT1_Msk (0x1UL << GPIO_OTYPER_OT1_Pos) |
| #define | GPIO_OTYPER_OT1 GPIO_OTYPER_OT1_Msk |
| #define | GPIO_OTYPER_OT2_Pos (2U) |
| #define | GPIO_OTYPER_OT2_Msk (0x1UL << GPIO_OTYPER_OT2_Pos) |
| #define | GPIO_OTYPER_OT2 GPIO_OTYPER_OT2_Msk |
| #define | GPIO_OTYPER_OT3_Pos (3U) |
| #define | GPIO_OTYPER_OT3_Msk (0x1UL << GPIO_OTYPER_OT3_Pos) |
| #define | GPIO_OTYPER_OT3 GPIO_OTYPER_OT3_Msk |
| #define | GPIO_OTYPER_OT4_Pos (4U) |
| #define | GPIO_OTYPER_OT4_Msk (0x1UL << GPIO_OTYPER_OT4_Pos) |
| #define | GPIO_OTYPER_OT4 GPIO_OTYPER_OT4_Msk |
| #define | GPIO_OTYPER_OT5_Pos (5U) |
| #define | GPIO_OTYPER_OT5_Msk (0x1UL << GPIO_OTYPER_OT5_Pos) |
| #define | GPIO_OTYPER_OT5 GPIO_OTYPER_OT5_Msk |
| #define | GPIO_OTYPER_OT6_Pos (6U) |
| #define | GPIO_OTYPER_OT6_Msk (0x1UL << GPIO_OTYPER_OT6_Pos) |
| #define | GPIO_OTYPER_OT6 GPIO_OTYPER_OT6_Msk |
| #define | GPIO_OTYPER_OT7_Pos (7U) |
| #define | GPIO_OTYPER_OT7_Msk (0x1UL << GPIO_OTYPER_OT7_Pos) |
| #define | GPIO_OTYPER_OT7 GPIO_OTYPER_OT7_Msk |
| #define | GPIO_OTYPER_OT8_Pos (8U) |
| #define | GPIO_OTYPER_OT8_Msk (0x1UL << GPIO_OTYPER_OT8_Pos) |
| #define | GPIO_OTYPER_OT8 GPIO_OTYPER_OT8_Msk |
| #define | GPIO_OTYPER_OT9_Pos (9U) |
| #define | GPIO_OTYPER_OT9_Msk (0x1UL << GPIO_OTYPER_OT9_Pos) |
| #define | GPIO_OTYPER_OT9 GPIO_OTYPER_OT9_Msk |
| #define | GPIO_OTYPER_OT10_Pos (10U) |
| #define | GPIO_OTYPER_OT10_Msk (0x1UL << GPIO_OTYPER_OT10_Pos) |
| #define | GPIO_OTYPER_OT10 GPIO_OTYPER_OT10_Msk |
| #define | GPIO_OTYPER_OT11_Pos (11U) |
| #define | GPIO_OTYPER_OT11_Msk (0x1UL << GPIO_OTYPER_OT11_Pos) |
| #define | GPIO_OTYPER_OT11 GPIO_OTYPER_OT11_Msk |
| #define | GPIO_OTYPER_OT12_Pos (12U) |
| #define | GPIO_OTYPER_OT12_Msk (0x1UL << GPIO_OTYPER_OT12_Pos) |
| #define | GPIO_OTYPER_OT12 GPIO_OTYPER_OT12_Msk |
| #define | GPIO_OTYPER_OT13_Pos (13U) |
| #define | GPIO_OTYPER_OT13_Msk (0x1UL << GPIO_OTYPER_OT13_Pos) |
| #define | GPIO_OTYPER_OT13 GPIO_OTYPER_OT13_Msk |
| #define | GPIO_OTYPER_OT14_Pos (14U) |
| #define | GPIO_OTYPER_OT14_Msk (0x1UL << GPIO_OTYPER_OT14_Pos) |
| #define | GPIO_OTYPER_OT14 GPIO_OTYPER_OT14_Msk |
| #define | GPIO_OTYPER_OT15_Pos (15U) |
| #define | GPIO_OTYPER_OT15_Msk (0x1UL << GPIO_OTYPER_OT15_Pos) |
| #define | GPIO_OTYPER_OT15 GPIO_OTYPER_OT15_Msk |
| #define | GPIO_OSPEEDR_OSPEED0_Pos (0U) |
| #define | GPIO_OSPEEDR_OSPEED0_Msk (0x3UL << GPIO_OSPEEDR_OSPEED0_Pos) |
| #define | GPIO_OSPEEDR_OSPEED0 GPIO_OSPEEDR_OSPEED0_Msk |
| #define | GPIO_OSPEEDR_OSPEED0_0 (0x1UL << GPIO_OSPEEDR_OSPEED0_Pos) |
| #define | GPIO_OSPEEDR_OSPEED0_1 (0x2UL << GPIO_OSPEEDR_OSPEED0_Pos) |
| #define | GPIO_OSPEEDR_OSPEED1_Pos (2U) |
| #define | GPIO_OSPEEDR_OSPEED1_Msk (0x3UL << GPIO_OSPEEDR_OSPEED1_Pos) |
| #define | GPIO_OSPEEDR_OSPEED1 GPIO_OSPEEDR_OSPEED1_Msk |
| #define | GPIO_OSPEEDR_OSPEED1_0 (0x1UL << GPIO_OSPEEDR_OSPEED1_Pos) |
| #define | GPIO_OSPEEDR_OSPEED1_1 (0x2UL << GPIO_OSPEEDR_OSPEED1_Pos) |
| #define | GPIO_OSPEEDR_OSPEED2_Pos (4U) |
| #define | GPIO_OSPEEDR_OSPEED2_Msk (0x3UL << GPIO_OSPEEDR_OSPEED2_Pos) |
| #define | GPIO_OSPEEDR_OSPEED2 GPIO_OSPEEDR_OSPEED2_Msk |
| #define | GPIO_OSPEEDR_OSPEED2_0 (0x1UL << GPIO_OSPEEDR_OSPEED2_Pos) |
| #define | GPIO_OSPEEDR_OSPEED2_1 (0x2UL << GPIO_OSPEEDR_OSPEED2_Pos) |
| #define | GPIO_OSPEEDR_OSPEED3_Pos (6U) |
| #define | GPIO_OSPEEDR_OSPEED3_Msk (0x3UL << GPIO_OSPEEDR_OSPEED3_Pos) |
| #define | GPIO_OSPEEDR_OSPEED3 GPIO_OSPEEDR_OSPEED3_Msk |
| #define | GPIO_OSPEEDR_OSPEED3_0 (0x1UL << GPIO_OSPEEDR_OSPEED3_Pos) |
| #define | GPIO_OSPEEDR_OSPEED3_1 (0x2UL << GPIO_OSPEEDR_OSPEED3_Pos) |
| #define | GPIO_OSPEEDR_OSPEED4_Pos (8U) |
| #define | GPIO_OSPEEDR_OSPEED4_Msk (0x3UL << GPIO_OSPEEDR_OSPEED4_Pos) |
| #define | GPIO_OSPEEDR_OSPEED4 GPIO_OSPEEDR_OSPEED4_Msk |
| #define | GPIO_OSPEEDR_OSPEED4_0 (0x1UL << GPIO_OSPEEDR_OSPEED4_Pos) |
| #define | GPIO_OSPEEDR_OSPEED4_1 (0x2UL << GPIO_OSPEEDR_OSPEED4_Pos) |
| #define | GPIO_OSPEEDR_OSPEED5_Pos (10U) |
| #define | GPIO_OSPEEDR_OSPEED5_Msk (0x3UL << GPIO_OSPEEDR_OSPEED5_Pos) |
| #define | GPIO_OSPEEDR_OSPEED5 GPIO_OSPEEDR_OSPEED5_Msk |
| #define | GPIO_OSPEEDR_OSPEED5_0 (0x1UL << GPIO_OSPEEDR_OSPEED5_Pos) |
| #define | GPIO_OSPEEDR_OSPEED5_1 (0x2UL << GPIO_OSPEEDR_OSPEED5_Pos) |
| #define | GPIO_OSPEEDR_OSPEED6_Pos (12U) |
| #define | GPIO_OSPEEDR_OSPEED6_Msk (0x3UL << GPIO_OSPEEDR_OSPEED6_Pos) |
| #define | GPIO_OSPEEDR_OSPEED6 GPIO_OSPEEDR_OSPEED6_Msk |
| #define | GPIO_OSPEEDR_OSPEED6_0 (0x1UL << GPIO_OSPEEDR_OSPEED6_Pos) |
| #define | GPIO_OSPEEDR_OSPEED6_1 (0x2UL << GPIO_OSPEEDR_OSPEED6_Pos) |
| #define | GPIO_OSPEEDR_OSPEED7_Pos (14U) |
| #define | GPIO_OSPEEDR_OSPEED7_Msk (0x3UL << GPIO_OSPEEDR_OSPEED7_Pos) |
| #define | GPIO_OSPEEDR_OSPEED7 GPIO_OSPEEDR_OSPEED7_Msk |
| #define | GPIO_OSPEEDR_OSPEED7_0 (0x1UL << GPIO_OSPEEDR_OSPEED7_Pos) |
| #define | GPIO_OSPEEDR_OSPEED7_1 (0x2UL << GPIO_OSPEEDR_OSPEED7_Pos) |
| #define | GPIO_OSPEEDR_OSPEED8_Pos (16U) |
| #define | GPIO_OSPEEDR_OSPEED8_Msk (0x3UL << GPIO_OSPEEDR_OSPEED8_Pos) |
| #define | GPIO_OSPEEDR_OSPEED8 GPIO_OSPEEDR_OSPEED8_Msk |
| #define | GPIO_OSPEEDR_OSPEED8_0 (0x1UL << GPIO_OSPEEDR_OSPEED8_Pos) |
| #define | GPIO_OSPEEDR_OSPEED8_1 (0x2UL << GPIO_OSPEEDR_OSPEED8_Pos) |
| #define | GPIO_OSPEEDR_OSPEED9_Pos (18U) |
| #define | GPIO_OSPEEDR_OSPEED9_Msk (0x3UL << GPIO_OSPEEDR_OSPEED9_Pos) |
| #define | GPIO_OSPEEDR_OSPEED9 GPIO_OSPEEDR_OSPEED9_Msk |
| #define | GPIO_OSPEEDR_OSPEED9_0 (0x1UL << GPIO_OSPEEDR_OSPEED9_Pos) |
| #define | GPIO_OSPEEDR_OSPEED9_1 (0x2UL << GPIO_OSPEEDR_OSPEED9_Pos) |
| #define | GPIO_OSPEEDR_OSPEED10_Pos (20U) |
| #define | GPIO_OSPEEDR_OSPEED10_Msk (0x3UL << GPIO_OSPEEDR_OSPEED10_Pos) |
| #define | GPIO_OSPEEDR_OSPEED10 GPIO_OSPEEDR_OSPEED10_Msk |
| #define | GPIO_OSPEEDR_OSPEED10_0 (0x1UL << GPIO_OSPEEDR_OSPEED10_Pos) |
| #define | GPIO_OSPEEDR_OSPEED10_1 (0x2UL << GPIO_OSPEEDR_OSPEED10_Pos) |
| #define | GPIO_OSPEEDR_OSPEED11_Pos (22U) |
| #define | GPIO_OSPEEDR_OSPEED11_Msk (0x3UL << GPIO_OSPEEDR_OSPEED11_Pos) |
| #define | GPIO_OSPEEDR_OSPEED11 GPIO_OSPEEDR_OSPEED11_Msk |
| #define | GPIO_OSPEEDR_OSPEED11_0 (0x1UL << GPIO_OSPEEDR_OSPEED11_Pos) |
| #define | GPIO_OSPEEDR_OSPEED11_1 (0x2UL << GPIO_OSPEEDR_OSPEED11_Pos) |
| #define | GPIO_OSPEEDR_OSPEED12_Pos (24U) |
| #define | GPIO_OSPEEDR_OSPEED12_Msk (0x3UL << GPIO_OSPEEDR_OSPEED12_Pos) |
| #define | GPIO_OSPEEDR_OSPEED12 GPIO_OSPEEDR_OSPEED12_Msk |
| #define | GPIO_OSPEEDR_OSPEED12_0 (0x1UL << GPIO_OSPEEDR_OSPEED12_Pos) |
| #define | GPIO_OSPEEDR_OSPEED12_1 (0x2UL << GPIO_OSPEEDR_OSPEED12_Pos) |
| #define | GPIO_OSPEEDR_OSPEED13_Pos (26U) |
| #define | GPIO_OSPEEDR_OSPEED13_Msk (0x3UL << GPIO_OSPEEDR_OSPEED13_Pos) |
| #define | GPIO_OSPEEDR_OSPEED13 GPIO_OSPEEDR_OSPEED13_Msk |
| #define | GPIO_OSPEEDR_OSPEED13_0 (0x1UL << GPIO_OSPEEDR_OSPEED13_Pos) |
| #define | GPIO_OSPEEDR_OSPEED13_1 (0x2UL << GPIO_OSPEEDR_OSPEED13_Pos) |
| #define | GPIO_OSPEEDR_OSPEED14_Pos (28U) |
| #define | GPIO_OSPEEDR_OSPEED14_Msk (0x3UL << GPIO_OSPEEDR_OSPEED14_Pos) |
| #define | GPIO_OSPEEDR_OSPEED14 GPIO_OSPEEDR_OSPEED14_Msk |
| #define | GPIO_OSPEEDR_OSPEED14_0 (0x1UL << GPIO_OSPEEDR_OSPEED14_Pos) |
| #define | GPIO_OSPEEDR_OSPEED14_1 (0x2UL << GPIO_OSPEEDR_OSPEED14_Pos) |
| #define | GPIO_OSPEEDR_OSPEED15_Pos (30U) |
| #define | GPIO_OSPEEDR_OSPEED15_Msk (0x3UL << GPIO_OSPEEDR_OSPEED15_Pos) |
| #define | GPIO_OSPEEDR_OSPEED15 GPIO_OSPEEDR_OSPEED15_Msk |
| #define | GPIO_OSPEEDR_OSPEED15_0 (0x1UL << GPIO_OSPEEDR_OSPEED15_Pos) |
| #define | GPIO_OSPEEDR_OSPEED15_1 (0x2UL << GPIO_OSPEEDR_OSPEED15_Pos) |
| #define | GPIO_PUPDR_PUPD0_Pos (0U) |
| #define | GPIO_PUPDR_PUPD0_Msk (0x3UL << GPIO_PUPDR_PUPD0_Pos) |
| #define | GPIO_PUPDR_PUPD0 GPIO_PUPDR_PUPD0_Msk |
| #define | GPIO_PUPDR_PUPD0_0 (0x1UL << GPIO_PUPDR_PUPD0_Pos) |
| #define | GPIO_PUPDR_PUPD0_1 (0x2UL << GPIO_PUPDR_PUPD0_Pos) |
| #define | GPIO_PUPDR_PUPD1_Pos (2U) |
| #define | GPIO_PUPDR_PUPD1_Msk (0x3UL << GPIO_PUPDR_PUPD1_Pos) |
| #define | GPIO_PUPDR_PUPD1 GPIO_PUPDR_PUPD1_Msk |
| #define | GPIO_PUPDR_PUPD1_0 (0x1UL << GPIO_PUPDR_PUPD1_Pos) |
| #define | GPIO_PUPDR_PUPD1_1 (0x2UL << GPIO_PUPDR_PUPD1_Pos) |
| #define | GPIO_PUPDR_PUPD2_Pos (4U) |
| #define | GPIO_PUPDR_PUPD2_Msk (0x3UL << GPIO_PUPDR_PUPD2_Pos) |
| #define | GPIO_PUPDR_PUPD2 GPIO_PUPDR_PUPD2_Msk |
| #define | GPIO_PUPDR_PUPD2_0 (0x1UL << GPIO_PUPDR_PUPD2_Pos) |
| #define | GPIO_PUPDR_PUPD2_1 (0x2UL << GPIO_PUPDR_PUPD2_Pos) |
| #define | GPIO_PUPDR_PUPD3_Pos (6U) |
| #define | GPIO_PUPDR_PUPD3_Msk (0x3UL << GPIO_PUPDR_PUPD3_Pos) |
| #define | GPIO_PUPDR_PUPD3 GPIO_PUPDR_PUPD3_Msk |
| #define | GPIO_PUPDR_PUPD3_0 (0x1UL << GPIO_PUPDR_PUPD3_Pos) |
| #define | GPIO_PUPDR_PUPD3_1 (0x2UL << GPIO_PUPDR_PUPD3_Pos) |
| #define | GPIO_PUPDR_PUPD4_Pos (8U) |
| #define | GPIO_PUPDR_PUPD4_Msk (0x3UL << GPIO_PUPDR_PUPD4_Pos) |
| #define | GPIO_PUPDR_PUPD4 GPIO_PUPDR_PUPD4_Msk |
| #define | GPIO_PUPDR_PUPD4_0 (0x1UL << GPIO_PUPDR_PUPD4_Pos) |
| #define | GPIO_PUPDR_PUPD4_1 (0x2UL << GPIO_PUPDR_PUPD4_Pos) |
| #define | GPIO_PUPDR_PUPD5_Pos (10U) |
| #define | GPIO_PUPDR_PUPD5_Msk (0x3UL << GPIO_PUPDR_PUPD5_Pos) |
| #define | GPIO_PUPDR_PUPD5 GPIO_PUPDR_PUPD5_Msk |
| #define | GPIO_PUPDR_PUPD5_0 (0x1UL << GPIO_PUPDR_PUPD5_Pos) |
| #define | GPIO_PUPDR_PUPD5_1 (0x2UL << GPIO_PUPDR_PUPD5_Pos) |
| #define | GPIO_PUPDR_PUPD6_Pos (12U) |
| #define | GPIO_PUPDR_PUPD6_Msk (0x3UL << GPIO_PUPDR_PUPD6_Pos) |
| #define | GPIO_PUPDR_PUPD6 GPIO_PUPDR_PUPD6_Msk |
| #define | GPIO_PUPDR_PUPD6_0 (0x1UL << GPIO_PUPDR_PUPD6_Pos) |
| #define | GPIO_PUPDR_PUPD6_1 (0x2UL << GPIO_PUPDR_PUPD6_Pos) |
| #define | GPIO_PUPDR_PUPD7_Pos (14U) |
| #define | GPIO_PUPDR_PUPD7_Msk (0x3UL << GPIO_PUPDR_PUPD7_Pos) |
| #define | GPIO_PUPDR_PUPD7 GPIO_PUPDR_PUPD7_Msk |
| #define | GPIO_PUPDR_PUPD7_0 (0x1UL << GPIO_PUPDR_PUPD7_Pos) |
| #define | GPIO_PUPDR_PUPD7_1 (0x2UL << GPIO_PUPDR_PUPD7_Pos) |
| #define | GPIO_PUPDR_PUPD8_Pos (16U) |
| #define | GPIO_PUPDR_PUPD8_Msk (0x3UL << GPIO_PUPDR_PUPD8_Pos) |
| #define | GPIO_PUPDR_PUPD8 GPIO_PUPDR_PUPD8_Msk |
| #define | GPIO_PUPDR_PUPD8_0 (0x1UL << GPIO_PUPDR_PUPD8_Pos) |
| #define | GPIO_PUPDR_PUPD8_1 (0x2UL << GPIO_PUPDR_PUPD8_Pos) |
| #define | GPIO_PUPDR_PUPD9_Pos (18U) |
| #define | GPIO_PUPDR_PUPD9_Msk (0x3UL << GPIO_PUPDR_PUPD9_Pos) |
| #define | GPIO_PUPDR_PUPD9 GPIO_PUPDR_PUPD9_Msk |
| #define | GPIO_PUPDR_PUPD9_0 (0x1UL << GPIO_PUPDR_PUPD9_Pos) |
| #define | GPIO_PUPDR_PUPD9_1 (0x2UL << GPIO_PUPDR_PUPD9_Pos) |
| #define | GPIO_PUPDR_PUPD10_Pos (20U) |
| #define | GPIO_PUPDR_PUPD10_Msk (0x3UL << GPIO_PUPDR_PUPD10_Pos) |
| #define | GPIO_PUPDR_PUPD10 GPIO_PUPDR_PUPD10_Msk |
| #define | GPIO_PUPDR_PUPD10_0 (0x1UL << GPIO_PUPDR_PUPD10_Pos) |
| #define | GPIO_PUPDR_PUPD10_1 (0x2UL << GPIO_PUPDR_PUPD10_Pos) |
| #define | GPIO_PUPDR_PUPD11_Pos (22U) |
| #define | GPIO_PUPDR_PUPD11_Msk (0x3UL << GPIO_PUPDR_PUPD11_Pos) |
| #define | GPIO_PUPDR_PUPD11 GPIO_PUPDR_PUPD11_Msk |
| #define | GPIO_PUPDR_PUPD11_0 (0x1UL << GPIO_PUPDR_PUPD11_Pos) |
| #define | GPIO_PUPDR_PUPD11_1 (0x2UL << GPIO_PUPDR_PUPD11_Pos) |
| #define | GPIO_PUPDR_PUPD12_Pos (24U) |
| #define | GPIO_PUPDR_PUPD12_Msk (0x3UL << GPIO_PUPDR_PUPD12_Pos) |
| #define | GPIO_PUPDR_PUPD12 GPIO_PUPDR_PUPD12_Msk |
| #define | GPIO_PUPDR_PUPD12_0 (0x1UL << GPIO_PUPDR_PUPD12_Pos) |
| #define | GPIO_PUPDR_PUPD12_1 (0x2UL << GPIO_PUPDR_PUPD12_Pos) |
| #define | GPIO_PUPDR_PUPD13_Pos (26U) |
| #define | GPIO_PUPDR_PUPD13_Msk (0x3UL << GPIO_PUPDR_PUPD13_Pos) |
| #define | GPIO_PUPDR_PUPD13 GPIO_PUPDR_PUPD13_Msk |
| #define | GPIO_PUPDR_PUPD13_0 (0x1UL << GPIO_PUPDR_PUPD13_Pos) |
| #define | GPIO_PUPDR_PUPD13_1 (0x2UL << GPIO_PUPDR_PUPD13_Pos) |
| #define | GPIO_PUPDR_PUPD14_Pos (28U) |
| #define | GPIO_PUPDR_PUPD14_Msk (0x3UL << GPIO_PUPDR_PUPD14_Pos) |
| #define | GPIO_PUPDR_PUPD14 GPIO_PUPDR_PUPD14_Msk |
| #define | GPIO_PUPDR_PUPD14_0 (0x1UL << GPIO_PUPDR_PUPD14_Pos) |
| #define | GPIO_PUPDR_PUPD14_1 (0x2UL << GPIO_PUPDR_PUPD14_Pos) |
| #define | GPIO_PUPDR_PUPD15_Pos (30U) |
| #define | GPIO_PUPDR_PUPD15_Msk (0x3UL << GPIO_PUPDR_PUPD15_Pos) |
| #define | GPIO_PUPDR_PUPD15 GPIO_PUPDR_PUPD15_Msk |
| #define | GPIO_PUPDR_PUPD15_0 (0x1UL << GPIO_PUPDR_PUPD15_Pos) |
| #define | GPIO_PUPDR_PUPD15_1 (0x2UL << GPIO_PUPDR_PUPD15_Pos) |
| #define | GPIO_IDR_ID0_Pos (0U) |
| #define | GPIO_IDR_ID0_Msk (0x1UL << GPIO_IDR_ID0_Pos) |
| #define | GPIO_IDR_ID0 GPIO_IDR_ID0_Msk |
| #define | GPIO_IDR_ID1_Pos (1U) |
| #define | GPIO_IDR_ID1_Msk (0x1UL << GPIO_IDR_ID1_Pos) |
| #define | GPIO_IDR_ID1 GPIO_IDR_ID1_Msk |
| #define | GPIO_IDR_ID2_Pos (2U) |
| #define | GPIO_IDR_ID2_Msk (0x1UL << GPIO_IDR_ID2_Pos) |
| #define | GPIO_IDR_ID2 GPIO_IDR_ID2_Msk |
| #define | GPIO_IDR_ID3_Pos (3U) |
| #define | GPIO_IDR_ID3_Msk (0x1UL << GPIO_IDR_ID3_Pos) |
| #define | GPIO_IDR_ID3 GPIO_IDR_ID3_Msk |
| #define | GPIO_IDR_ID4_Pos (4U) |
| #define | GPIO_IDR_ID4_Msk (0x1UL << GPIO_IDR_ID4_Pos) |
| #define | GPIO_IDR_ID4 GPIO_IDR_ID4_Msk |
| #define | GPIO_IDR_ID5_Pos (5U) |
| #define | GPIO_IDR_ID5_Msk (0x1UL << GPIO_IDR_ID5_Pos) |
| #define | GPIO_IDR_ID5 GPIO_IDR_ID5_Msk |
| #define | GPIO_IDR_ID6_Pos (6U) |
| #define | GPIO_IDR_ID6_Msk (0x1UL << GPIO_IDR_ID6_Pos) |
| #define | GPIO_IDR_ID6 GPIO_IDR_ID6_Msk |
| #define | GPIO_IDR_ID7_Pos (7U) |
| #define | GPIO_IDR_ID7_Msk (0x1UL << GPIO_IDR_ID7_Pos) |
| #define | GPIO_IDR_ID7 GPIO_IDR_ID7_Msk |
| #define | GPIO_IDR_ID8_Pos (8U) |
| #define | GPIO_IDR_ID8_Msk (0x1UL << GPIO_IDR_ID8_Pos) |
| #define | GPIO_IDR_ID8 GPIO_IDR_ID8_Msk |
| #define | GPIO_IDR_ID9_Pos (9U) |
| #define | GPIO_IDR_ID9_Msk (0x1UL << GPIO_IDR_ID9_Pos) |
| #define | GPIO_IDR_ID9 GPIO_IDR_ID9_Msk |
| #define | GPIO_IDR_ID10_Pos (10U) |
| #define | GPIO_IDR_ID10_Msk (0x1UL << GPIO_IDR_ID10_Pos) |
| #define | GPIO_IDR_ID10 GPIO_IDR_ID10_Msk |
| #define | GPIO_IDR_ID11_Pos (11U) |
| #define | GPIO_IDR_ID11_Msk (0x1UL << GPIO_IDR_ID11_Pos) |
| #define | GPIO_IDR_ID11 GPIO_IDR_ID11_Msk |
| #define | GPIO_IDR_ID12_Pos (12U) |
| #define | GPIO_IDR_ID12_Msk (0x1UL << GPIO_IDR_ID12_Pos) |
| #define | GPIO_IDR_ID12 GPIO_IDR_ID12_Msk |
| #define | GPIO_IDR_ID13_Pos (13U) |
| #define | GPIO_IDR_ID13_Msk (0x1UL << GPIO_IDR_ID13_Pos) |
| #define | GPIO_IDR_ID13 GPIO_IDR_ID13_Msk |
| #define | GPIO_IDR_ID14_Pos (14U) |
| #define | GPIO_IDR_ID14_Msk (0x1UL << GPIO_IDR_ID14_Pos) |
| #define | GPIO_IDR_ID14 GPIO_IDR_ID14_Msk |
| #define | GPIO_IDR_ID15_Pos (15U) |
| #define | GPIO_IDR_ID15_Msk (0x1UL << GPIO_IDR_ID15_Pos) |
| #define | GPIO_IDR_ID15 GPIO_IDR_ID15_Msk |
| #define | GPIO_ODR_OD0_Pos (0U) |
| #define | GPIO_ODR_OD0_Msk (0x1UL << GPIO_ODR_OD0_Pos) |
| #define | GPIO_ODR_OD0 GPIO_ODR_OD0_Msk |
| #define | GPIO_ODR_OD1_Pos (1U) |
| #define | GPIO_ODR_OD1_Msk (0x1UL << GPIO_ODR_OD1_Pos) |
| #define | GPIO_ODR_OD1 GPIO_ODR_OD1_Msk |
| #define | GPIO_ODR_OD2_Pos (2U) |
| #define | GPIO_ODR_OD2_Msk (0x1UL << GPIO_ODR_OD2_Pos) |
| #define | GPIO_ODR_OD2 GPIO_ODR_OD2_Msk |
| #define | GPIO_ODR_OD3_Pos (3U) |
| #define | GPIO_ODR_OD3_Msk (0x1UL << GPIO_ODR_OD3_Pos) |
| #define | GPIO_ODR_OD3 GPIO_ODR_OD3_Msk |
| #define | GPIO_ODR_OD4_Pos (4U) |
| #define | GPIO_ODR_OD4_Msk (0x1UL << GPIO_ODR_OD4_Pos) |
| #define | GPIO_ODR_OD4 GPIO_ODR_OD4_Msk |
| #define | GPIO_ODR_OD5_Pos (5U) |
| #define | GPIO_ODR_OD5_Msk (0x1UL << GPIO_ODR_OD5_Pos) |
| #define | GPIO_ODR_OD5 GPIO_ODR_OD5_Msk |
| #define | GPIO_ODR_OD6_Pos (6U) |
| #define | GPIO_ODR_OD6_Msk (0x1UL << GPIO_ODR_OD6_Pos) |
| #define | GPIO_ODR_OD6 GPIO_ODR_OD6_Msk |
| #define | GPIO_ODR_OD7_Pos (7U) |
| #define | GPIO_ODR_OD7_Msk (0x1UL << GPIO_ODR_OD7_Pos) |
| #define | GPIO_ODR_OD7 GPIO_ODR_OD7_Msk |
| #define | GPIO_ODR_OD8_Pos (8U) |
| #define | GPIO_ODR_OD8_Msk (0x1UL << GPIO_ODR_OD8_Pos) |
| #define | GPIO_ODR_OD8 GPIO_ODR_OD8_Msk |
| #define | GPIO_ODR_OD9_Pos (9U) |
| #define | GPIO_ODR_OD9_Msk (0x1UL << GPIO_ODR_OD9_Pos) |
| #define | GPIO_ODR_OD9 GPIO_ODR_OD9_Msk |
| #define | GPIO_ODR_OD10_Pos (10U) |
| #define | GPIO_ODR_OD10_Msk (0x1UL << GPIO_ODR_OD10_Pos) |
| #define | GPIO_ODR_OD10 GPIO_ODR_OD10_Msk |
| #define | GPIO_ODR_OD11_Pos (11U) |
| #define | GPIO_ODR_OD11_Msk (0x1UL << GPIO_ODR_OD11_Pos) |
| #define | GPIO_ODR_OD11 GPIO_ODR_OD11_Msk |
| #define | GPIO_ODR_OD12_Pos (12U) |
| #define | GPIO_ODR_OD12_Msk (0x1UL << GPIO_ODR_OD12_Pos) |
| #define | GPIO_ODR_OD12 GPIO_ODR_OD12_Msk |
| #define | GPIO_ODR_OD13_Pos (13U) |
| #define | GPIO_ODR_OD13_Msk (0x1UL << GPIO_ODR_OD13_Pos) |
| #define | GPIO_ODR_OD13 GPIO_ODR_OD13_Msk |
| #define | GPIO_ODR_OD14_Pos (14U) |
| #define | GPIO_ODR_OD14_Msk (0x1UL << GPIO_ODR_OD14_Pos) |
| #define | GPIO_ODR_OD14 GPIO_ODR_OD14_Msk |
| #define | GPIO_ODR_OD15_Pos (15U) |
| #define | GPIO_ODR_OD15_Msk (0x1UL << GPIO_ODR_OD15_Pos) |
| #define | GPIO_ODR_OD15 GPIO_ODR_OD15_Msk |
| #define | GPIO_BSRR_BS0_Pos (0U) |
| #define | GPIO_BSRR_BS0_Msk (0x1UL << GPIO_BSRR_BS0_Pos) |
| #define | GPIO_BSRR_BS0 GPIO_BSRR_BS0_Msk |
| #define | GPIO_BSRR_BS1_Pos (1U) |
| #define | GPIO_BSRR_BS1_Msk (0x1UL << GPIO_BSRR_BS1_Pos) |
| #define | GPIO_BSRR_BS1 GPIO_BSRR_BS1_Msk |
| #define | GPIO_BSRR_BS2_Pos (2U) |
| #define | GPIO_BSRR_BS2_Msk (0x1UL << GPIO_BSRR_BS2_Pos) |
| #define | GPIO_BSRR_BS2 GPIO_BSRR_BS2_Msk |
| #define | GPIO_BSRR_BS3_Pos (3U) |
| #define | GPIO_BSRR_BS3_Msk (0x1UL << GPIO_BSRR_BS3_Pos) |
| #define | GPIO_BSRR_BS3 GPIO_BSRR_BS3_Msk |
| #define | GPIO_BSRR_BS4_Pos (4U) |
| #define | GPIO_BSRR_BS4_Msk (0x1UL << GPIO_BSRR_BS4_Pos) |
| #define | GPIO_BSRR_BS4 GPIO_BSRR_BS4_Msk |
| #define | GPIO_BSRR_BS5_Pos (5U) |
| #define | GPIO_BSRR_BS5_Msk (0x1UL << GPIO_BSRR_BS5_Pos) |
| #define | GPIO_BSRR_BS5 GPIO_BSRR_BS5_Msk |
| #define | GPIO_BSRR_BS6_Pos (6U) |
| #define | GPIO_BSRR_BS6_Msk (0x1UL << GPIO_BSRR_BS6_Pos) |
| #define | GPIO_BSRR_BS6 GPIO_BSRR_BS6_Msk |
| #define | GPIO_BSRR_BS7_Pos (7U) |
| #define | GPIO_BSRR_BS7_Msk (0x1UL << GPIO_BSRR_BS7_Pos) |
| #define | GPIO_BSRR_BS7 GPIO_BSRR_BS7_Msk |
| #define | GPIO_BSRR_BS8_Pos (8U) |
| #define | GPIO_BSRR_BS8_Msk (0x1UL << GPIO_BSRR_BS8_Pos) |
| #define | GPIO_BSRR_BS8 GPIO_BSRR_BS8_Msk |
| #define | GPIO_BSRR_BS9_Pos (9U) |
| #define | GPIO_BSRR_BS9_Msk (0x1UL << GPIO_BSRR_BS9_Pos) |
| #define | GPIO_BSRR_BS9 GPIO_BSRR_BS9_Msk |
| #define | GPIO_BSRR_BS10_Pos (10U) |
| #define | GPIO_BSRR_BS10_Msk (0x1UL << GPIO_BSRR_BS10_Pos) |
| #define | GPIO_BSRR_BS10 GPIO_BSRR_BS10_Msk |
| #define | GPIO_BSRR_BS11_Pos (11U) |
| #define | GPIO_BSRR_BS11_Msk (0x1UL << GPIO_BSRR_BS11_Pos) |
| #define | GPIO_BSRR_BS11 GPIO_BSRR_BS11_Msk |
| #define | GPIO_BSRR_BS12_Pos (12U) |
| #define | GPIO_BSRR_BS12_Msk (0x1UL << GPIO_BSRR_BS12_Pos) |
| #define | GPIO_BSRR_BS12 GPIO_BSRR_BS12_Msk |
| #define | GPIO_BSRR_BS13_Pos (13U) |
| #define | GPIO_BSRR_BS13_Msk (0x1UL << GPIO_BSRR_BS13_Pos) |
| #define | GPIO_BSRR_BS13 GPIO_BSRR_BS13_Msk |
| #define | GPIO_BSRR_BS14_Pos (14U) |
| #define | GPIO_BSRR_BS14_Msk (0x1UL << GPIO_BSRR_BS14_Pos) |
| #define | GPIO_BSRR_BS14 GPIO_BSRR_BS14_Msk |
| #define | GPIO_BSRR_BS15_Pos (15U) |
| #define | GPIO_BSRR_BS15_Msk (0x1UL << GPIO_BSRR_BS15_Pos) |
| #define | GPIO_BSRR_BS15 GPIO_BSRR_BS15_Msk |
| #define | GPIO_BSRR_BR0_Pos (16U) |
| #define | GPIO_BSRR_BR0_Msk (0x1UL << GPIO_BSRR_BR0_Pos) |
| #define | GPIO_BSRR_BR0 GPIO_BSRR_BR0_Msk |
| #define | GPIO_BSRR_BR1_Pos (17U) |
| #define | GPIO_BSRR_BR1_Msk (0x1UL << GPIO_BSRR_BR1_Pos) |
| #define | GPIO_BSRR_BR1 GPIO_BSRR_BR1_Msk |
| #define | GPIO_BSRR_BR2_Pos (18U) |
| #define | GPIO_BSRR_BR2_Msk (0x1UL << GPIO_BSRR_BR2_Pos) |
| #define | GPIO_BSRR_BR2 GPIO_BSRR_BR2_Msk |
| #define | GPIO_BSRR_BR3_Pos (19U) |
| #define | GPIO_BSRR_BR3_Msk (0x1UL << GPIO_BSRR_BR3_Pos) |
| #define | GPIO_BSRR_BR3 GPIO_BSRR_BR3_Msk |
| #define | GPIO_BSRR_BR4_Pos (20U) |
| #define | GPIO_BSRR_BR4_Msk (0x1UL << GPIO_BSRR_BR4_Pos) |
| #define | GPIO_BSRR_BR4 GPIO_BSRR_BR4_Msk |
| #define | GPIO_BSRR_BR5_Pos (21U) |
| #define | GPIO_BSRR_BR5_Msk (0x1UL << GPIO_BSRR_BR5_Pos) |
| #define | GPIO_BSRR_BR5 GPIO_BSRR_BR5_Msk |
| #define | GPIO_BSRR_BR6_Pos (22U) |
| #define | GPIO_BSRR_BR6_Msk (0x1UL << GPIO_BSRR_BR6_Pos) |
| #define | GPIO_BSRR_BR6 GPIO_BSRR_BR6_Msk |
| #define | GPIO_BSRR_BR7_Pos (23U) |
| #define | GPIO_BSRR_BR7_Msk (0x1UL << GPIO_BSRR_BR7_Pos) |
| #define | GPIO_BSRR_BR7 GPIO_BSRR_BR7_Msk |
| #define | GPIO_BSRR_BR8_Pos (24U) |
| #define | GPIO_BSRR_BR8_Msk (0x1UL << GPIO_BSRR_BR8_Pos) |
| #define | GPIO_BSRR_BR8 GPIO_BSRR_BR8_Msk |
| #define | GPIO_BSRR_BR9_Pos (25U) |
| #define | GPIO_BSRR_BR9_Msk (0x1UL << GPIO_BSRR_BR9_Pos) |
| #define | GPIO_BSRR_BR9 GPIO_BSRR_BR9_Msk |
| #define | GPIO_BSRR_BR10_Pos (26U) |
| #define | GPIO_BSRR_BR10_Msk (0x1UL << GPIO_BSRR_BR10_Pos) |
| #define | GPIO_BSRR_BR10 GPIO_BSRR_BR10_Msk |
| #define | GPIO_BSRR_BR11_Pos (27U) |
| #define | GPIO_BSRR_BR11_Msk (0x1UL << GPIO_BSRR_BR11_Pos) |
| #define | GPIO_BSRR_BR11 GPIO_BSRR_BR11_Msk |
| #define | GPIO_BSRR_BR12_Pos (28U) |
| #define | GPIO_BSRR_BR12_Msk (0x1UL << GPIO_BSRR_BR12_Pos) |
| #define | GPIO_BSRR_BR12 GPIO_BSRR_BR12_Msk |
| #define | GPIO_BSRR_BR13_Pos (29U) |
| #define | GPIO_BSRR_BR13_Msk (0x1UL << GPIO_BSRR_BR13_Pos) |
| #define | GPIO_BSRR_BR13 GPIO_BSRR_BR13_Msk |
| #define | GPIO_BSRR_BR14_Pos (30U) |
| #define | GPIO_BSRR_BR14_Msk (0x1UL << GPIO_BSRR_BR14_Pos) |
| #define | GPIO_BSRR_BR14 GPIO_BSRR_BR14_Msk |
| #define | GPIO_BSRR_BR15_Pos (31U) |
| #define | GPIO_BSRR_BR15_Msk (0x1UL << GPIO_BSRR_BR15_Pos) |
| #define | GPIO_BSRR_BR15 GPIO_BSRR_BR15_Msk |
| #define | GPIO_LCKR_LCK0_Pos (0U) |
| #define | GPIO_LCKR_LCK0_Msk (0x1UL << GPIO_LCKR_LCK0_Pos) |
| #define | GPIO_LCKR_LCK0 GPIO_LCKR_LCK0_Msk |
| #define | GPIO_LCKR_LCK1_Pos (1U) |
| #define | GPIO_LCKR_LCK1_Msk (0x1UL << GPIO_LCKR_LCK1_Pos) |
| #define | GPIO_LCKR_LCK1 GPIO_LCKR_LCK1_Msk |
| #define | GPIO_LCKR_LCK2_Pos (2U) |
| #define | GPIO_LCKR_LCK2_Msk (0x1UL << GPIO_LCKR_LCK2_Pos) |
| #define | GPIO_LCKR_LCK2 GPIO_LCKR_LCK2_Msk |
| #define | GPIO_LCKR_LCK3_Pos (3U) |
| #define | GPIO_LCKR_LCK3_Msk (0x1UL << GPIO_LCKR_LCK3_Pos) |
| #define | GPIO_LCKR_LCK3 GPIO_LCKR_LCK3_Msk |
| #define | GPIO_LCKR_LCK4_Pos (4U) |
| #define | GPIO_LCKR_LCK4_Msk (0x1UL << GPIO_LCKR_LCK4_Pos) |
| #define | GPIO_LCKR_LCK4 GPIO_LCKR_LCK4_Msk |
| #define | GPIO_LCKR_LCK5_Pos (5U) |
| #define | GPIO_LCKR_LCK5_Msk (0x1UL << GPIO_LCKR_LCK5_Pos) |
| #define | GPIO_LCKR_LCK5 GPIO_LCKR_LCK5_Msk |
| #define | GPIO_LCKR_LCK6_Pos (6U) |
| #define | GPIO_LCKR_LCK6_Msk (0x1UL << GPIO_LCKR_LCK6_Pos) |
| #define | GPIO_LCKR_LCK6 GPIO_LCKR_LCK6_Msk |
| #define | GPIO_LCKR_LCK7_Pos (7U) |
| #define | GPIO_LCKR_LCK7_Msk (0x1UL << GPIO_LCKR_LCK7_Pos) |
| #define | GPIO_LCKR_LCK7 GPIO_LCKR_LCK7_Msk |
| #define | GPIO_LCKR_LCK8_Pos (8U) |
| #define | GPIO_LCKR_LCK8_Msk (0x1UL << GPIO_LCKR_LCK8_Pos) |
| #define | GPIO_LCKR_LCK8 GPIO_LCKR_LCK8_Msk |
| #define | GPIO_LCKR_LCK9_Pos (9U) |
| #define | GPIO_LCKR_LCK9_Msk (0x1UL << GPIO_LCKR_LCK9_Pos) |
| #define | GPIO_LCKR_LCK9 GPIO_LCKR_LCK9_Msk |
| #define | GPIO_LCKR_LCK10_Pos (10U) |
| #define | GPIO_LCKR_LCK10_Msk (0x1UL << GPIO_LCKR_LCK10_Pos) |
| #define | GPIO_LCKR_LCK10 GPIO_LCKR_LCK10_Msk |
| #define | GPIO_LCKR_LCK11_Pos (11U) |
| #define | GPIO_LCKR_LCK11_Msk (0x1UL << GPIO_LCKR_LCK11_Pos) |
| #define | GPIO_LCKR_LCK11 GPIO_LCKR_LCK11_Msk |
| #define | GPIO_LCKR_LCK12_Pos (12U) |
| #define | GPIO_LCKR_LCK12_Msk (0x1UL << GPIO_LCKR_LCK12_Pos) |
| #define | GPIO_LCKR_LCK12 GPIO_LCKR_LCK12_Msk |
| #define | GPIO_LCKR_LCK13_Pos (13U) |
| #define | GPIO_LCKR_LCK13_Msk (0x1UL << GPIO_LCKR_LCK13_Pos) |
| #define | GPIO_LCKR_LCK13 GPIO_LCKR_LCK13_Msk |
| #define | GPIO_LCKR_LCK14_Pos (14U) |
| #define | GPIO_LCKR_LCK14_Msk (0x1UL << GPIO_LCKR_LCK14_Pos) |
| #define | GPIO_LCKR_LCK14 GPIO_LCKR_LCK14_Msk |
| #define | GPIO_LCKR_LCK15_Pos (15U) |
| #define | GPIO_LCKR_LCK15_Msk (0x1UL << GPIO_LCKR_LCK15_Pos) |
| #define | GPIO_LCKR_LCK15 GPIO_LCKR_LCK15_Msk |
| #define | GPIO_LCKR_LCKK_Pos (16U) |
| #define | GPIO_LCKR_LCKK_Msk (0x1UL << GPIO_LCKR_LCKK_Pos) |
| #define | GPIO_LCKR_LCKK GPIO_LCKR_LCKK_Msk |
| #define | GPIO_AFRL_AFSEL0_Pos (0U) |
| #define | GPIO_AFRL_AFSEL0_Msk (0xFUL << GPIO_AFRL_AFSEL0_Pos) |
| #define | GPIO_AFRL_AFSEL0 GPIO_AFRL_AFSEL0_Msk |
| #define | GPIO_AFRL_AFSEL0_0 (0x1UL << GPIO_AFRL_AFSEL0_Pos) |
| #define | GPIO_AFRL_AFSEL0_1 (0x2UL << GPIO_AFRL_AFSEL0_Pos) |
| #define | GPIO_AFRL_AFSEL0_2 (0x4UL << GPIO_AFRL_AFSEL0_Pos) |
| #define | GPIO_AFRL_AFSEL0_3 (0x8UL << GPIO_AFRL_AFSEL0_Pos) |
| #define | GPIO_AFRL_AFSEL1_Pos (4U) |
| #define | GPIO_AFRL_AFSEL1_Msk (0xFUL << GPIO_AFRL_AFSEL1_Pos) |
| #define | GPIO_AFRL_AFSEL1 GPIO_AFRL_AFSEL1_Msk |
| #define | GPIO_AFRL_AFSEL1_0 (0x1UL << GPIO_AFRL_AFSEL1_Pos) |
| #define | GPIO_AFRL_AFSEL1_1 (0x2UL << GPIO_AFRL_AFSEL1_Pos) |
| #define | GPIO_AFRL_AFSEL1_2 (0x4UL << GPIO_AFRL_AFSEL1_Pos) |
| #define | GPIO_AFRL_AFSEL1_3 (0x8UL << GPIO_AFRL_AFSEL1_Pos) |
| #define | GPIO_AFRL_AFSEL2_Pos (8U) |
| #define | GPIO_AFRL_AFSEL2_Msk (0xFUL << GPIO_AFRL_AFSEL2_Pos) |
| #define | GPIO_AFRL_AFSEL2 GPIO_AFRL_AFSEL2_Msk |
| #define | GPIO_AFRL_AFSEL2_0 (0x1UL << GPIO_AFRL_AFSEL2_Pos) |
| #define | GPIO_AFRL_AFSEL2_1 (0x2UL << GPIO_AFRL_AFSEL2_Pos) |
| #define | GPIO_AFRL_AFSEL2_2 (0x4UL << GPIO_AFRL_AFSEL2_Pos) |
| #define | GPIO_AFRL_AFSEL2_3 (0x8UL << GPIO_AFRL_AFSEL2_Pos) |
| #define | GPIO_AFRL_AFSEL3_Pos (12U) |
| #define | GPIO_AFRL_AFSEL3_Msk (0xFUL << GPIO_AFRL_AFSEL3_Pos) |
| #define | GPIO_AFRL_AFSEL3 GPIO_AFRL_AFSEL3_Msk |
| #define | GPIO_AFRL_AFSEL3_0 (0x1UL << GPIO_AFRL_AFSEL3_Pos) |
| #define | GPIO_AFRL_AFSEL3_1 (0x2UL << GPIO_AFRL_AFSEL3_Pos) |
| #define | GPIO_AFRL_AFSEL3_2 (0x4UL << GPIO_AFRL_AFSEL3_Pos) |
| #define | GPIO_AFRL_AFSEL3_3 (0x8UL << GPIO_AFRL_AFSEL3_Pos) |
| #define | GPIO_AFRL_AFSEL4_Pos (16U) |
| #define | GPIO_AFRL_AFSEL4_Msk (0xFUL << GPIO_AFRL_AFSEL4_Pos) |
| #define | GPIO_AFRL_AFSEL4 GPIO_AFRL_AFSEL4_Msk |
| #define | GPIO_AFRL_AFSEL4_0 (0x1UL << GPIO_AFRL_AFSEL4_Pos) |
| #define | GPIO_AFRL_AFSEL4_1 (0x2UL << GPIO_AFRL_AFSEL4_Pos) |
| #define | GPIO_AFRL_AFSEL4_2 (0x4UL << GPIO_AFRL_AFSEL4_Pos) |
| #define | GPIO_AFRL_AFSEL4_3 (0x8UL << GPIO_AFRL_AFSEL4_Pos) |
| #define | GPIO_AFRL_AFSEL5_Pos (20U) |
| #define | GPIO_AFRL_AFSEL5_Msk (0xFUL << GPIO_AFRL_AFSEL5_Pos) |
| #define | GPIO_AFRL_AFSEL5 GPIO_AFRL_AFSEL5_Msk |
| #define | GPIO_AFRL_AFSEL5_0 (0x1UL << GPIO_AFRL_AFSEL5_Pos) |
| #define | GPIO_AFRL_AFSEL5_1 (0x2UL << GPIO_AFRL_AFSEL5_Pos) |
| #define | GPIO_AFRL_AFSEL5_2 (0x4UL << GPIO_AFRL_AFSEL5_Pos) |
| #define | GPIO_AFRL_AFSEL5_3 (0x8UL << GPIO_AFRL_AFSEL5_Pos) |
| #define | GPIO_AFRL_AFSEL6_Pos (24U) |
| #define | GPIO_AFRL_AFSEL6_Msk (0xFUL << GPIO_AFRL_AFSEL6_Pos) |
| #define | GPIO_AFRL_AFSEL6 GPIO_AFRL_AFSEL6_Msk |
| #define | GPIO_AFRL_AFSEL6_0 (0x1UL << GPIO_AFRL_AFSEL6_Pos) |
| #define | GPIO_AFRL_AFSEL6_1 (0x2UL << GPIO_AFRL_AFSEL6_Pos) |
| #define | GPIO_AFRL_AFSEL6_2 (0x4UL << GPIO_AFRL_AFSEL6_Pos) |
| #define | GPIO_AFRL_AFSEL6_3 (0x8UL << GPIO_AFRL_AFSEL6_Pos) |
| #define | GPIO_AFRL_AFSEL7_Pos (28U) |
| #define | GPIO_AFRL_AFSEL7_Msk (0xFUL << GPIO_AFRL_AFSEL7_Pos) |
| #define | GPIO_AFRL_AFSEL7 GPIO_AFRL_AFSEL7_Msk |
| #define | GPIO_AFRL_AFSEL7_0 (0x1UL << GPIO_AFRL_AFSEL7_Pos) |
| #define | GPIO_AFRL_AFSEL7_1 (0x2UL << GPIO_AFRL_AFSEL7_Pos) |
| #define | GPIO_AFRL_AFSEL7_2 (0x4UL << GPIO_AFRL_AFSEL7_Pos) |
| #define | GPIO_AFRL_AFSEL7_3 (0x8UL << GPIO_AFRL_AFSEL7_Pos) |
| #define | GPIO_AFRL_AFRL0 GPIO_AFRL_AFSEL0 |
| #define | GPIO_AFRL_AFRL1 GPIO_AFRL_AFSEL1 |
| #define | GPIO_AFRL_AFRL2 GPIO_AFRL_AFSEL2 |
| #define | GPIO_AFRL_AFRL3 GPIO_AFRL_AFSEL3 |
| #define | GPIO_AFRL_AFRL4 GPIO_AFRL_AFSEL4 |
| #define | GPIO_AFRL_AFRL5 GPIO_AFRL_AFSEL5 |
| #define | GPIO_AFRL_AFRL6 GPIO_AFRL_AFSEL6 |
| #define | GPIO_AFRL_AFRL7 GPIO_AFRL_AFSEL7 |
| #define | GPIO_AFRH_AFSEL8_Pos (0U) |
| #define | GPIO_AFRH_AFSEL8_Msk (0xFUL << GPIO_AFRH_AFSEL8_Pos) |
| #define | GPIO_AFRH_AFSEL8 GPIO_AFRH_AFSEL8_Msk |
| #define | GPIO_AFRH_AFSEL8_0 (0x1UL << GPIO_AFRH_AFSEL8_Pos) |
| #define | GPIO_AFRH_AFSEL8_1 (0x2UL << GPIO_AFRH_AFSEL8_Pos) |
| #define | GPIO_AFRH_AFSEL8_2 (0x4UL << GPIO_AFRH_AFSEL8_Pos) |
| #define | GPIO_AFRH_AFSEL8_3 (0x8UL << GPIO_AFRH_AFSEL8_Pos) |
| #define | GPIO_AFRH_AFSEL9_Pos (4U) |
| #define | GPIO_AFRH_AFSEL9_Msk (0xFUL << GPIO_AFRH_AFSEL9_Pos) |
| #define | GPIO_AFRH_AFSEL9 GPIO_AFRH_AFSEL9_Msk |
| #define | GPIO_AFRH_AFSEL9_0 (0x1UL << GPIO_AFRH_AFSEL9_Pos) |
| #define | GPIO_AFRH_AFSEL9_1 (0x2UL << GPIO_AFRH_AFSEL9_Pos) |
| #define | GPIO_AFRH_AFSEL9_2 (0x4UL << GPIO_AFRH_AFSEL9_Pos) |
| #define | GPIO_AFRH_AFSEL9_3 (0x8UL << GPIO_AFRH_AFSEL9_Pos) |
| #define | GPIO_AFRH_AFSEL10_Pos (8U) |
| #define | GPIO_AFRH_AFSEL10_Msk (0xFUL << GPIO_AFRH_AFSEL10_Pos) |
| #define | GPIO_AFRH_AFSEL10 GPIO_AFRH_AFSEL10_Msk |
| #define | GPIO_AFRH_AFSEL10_0 (0x1UL << GPIO_AFRH_AFSEL10_Pos) |
| #define | GPIO_AFRH_AFSEL10_1 (0x2UL << GPIO_AFRH_AFSEL10_Pos) |
| #define | GPIO_AFRH_AFSEL10_2 (0x4UL << GPIO_AFRH_AFSEL10_Pos) |
| #define | GPIO_AFRH_AFSEL10_3 (0x8UL << GPIO_AFRH_AFSEL10_Pos) |
| #define | GPIO_AFRH_AFSEL11_Pos (12U) |
| #define | GPIO_AFRH_AFSEL11_Msk (0xFUL << GPIO_AFRH_AFSEL11_Pos) |
| #define | GPIO_AFRH_AFSEL11 GPIO_AFRH_AFSEL11_Msk |
| #define | GPIO_AFRH_AFSEL11_0 (0x1UL << GPIO_AFRH_AFSEL11_Pos) |
| #define | GPIO_AFRH_AFSEL11_1 (0x2UL << GPIO_AFRH_AFSEL11_Pos) |
| #define | GPIO_AFRH_AFSEL11_2 (0x4UL << GPIO_AFRH_AFSEL11_Pos) |
| #define | GPIO_AFRH_AFSEL11_3 (0x8UL << GPIO_AFRH_AFSEL11_Pos) |
| #define | GPIO_AFRH_AFSEL12_Pos (16U) |
| #define | GPIO_AFRH_AFSEL12_Msk (0xFUL << GPIO_AFRH_AFSEL12_Pos) |
| #define | GPIO_AFRH_AFSEL12 GPIO_AFRH_AFSEL12_Msk |
| #define | GPIO_AFRH_AFSEL12_0 (0x1UL << GPIO_AFRH_AFSEL12_Pos) |
| #define | GPIO_AFRH_AFSEL12_1 (0x2UL << GPIO_AFRH_AFSEL12_Pos) |
| #define | GPIO_AFRH_AFSEL12_2 (0x4UL << GPIO_AFRH_AFSEL12_Pos) |
| #define | GPIO_AFRH_AFSEL12_3 (0x8UL << GPIO_AFRH_AFSEL12_Pos) |
| #define | GPIO_AFRH_AFSEL13_Pos (20U) |
| #define | GPIO_AFRH_AFSEL13_Msk (0xFUL << GPIO_AFRH_AFSEL13_Pos) |
| #define | GPIO_AFRH_AFSEL13 GPIO_AFRH_AFSEL13_Msk |
| #define | GPIO_AFRH_AFSEL13_0 (0x1UL << GPIO_AFRH_AFSEL13_Pos) |
| #define | GPIO_AFRH_AFSEL13_1 (0x2UL << GPIO_AFRH_AFSEL13_Pos) |
| #define | GPIO_AFRH_AFSEL13_2 (0x4UL << GPIO_AFRH_AFSEL13_Pos) |
| #define | GPIO_AFRH_AFSEL13_3 (0x8UL << GPIO_AFRH_AFSEL13_Pos) |
| #define | GPIO_AFRH_AFSEL14_Pos (24U) |
| #define | GPIO_AFRH_AFSEL14_Msk (0xFUL << GPIO_AFRH_AFSEL14_Pos) |
| #define | GPIO_AFRH_AFSEL14 GPIO_AFRH_AFSEL14_Msk |
| #define | GPIO_AFRH_AFSEL14_0 (0x1UL << GPIO_AFRH_AFSEL14_Pos) |
| #define | GPIO_AFRH_AFSEL14_1 (0x2UL << GPIO_AFRH_AFSEL14_Pos) |
| #define | GPIO_AFRH_AFSEL14_2 (0x4UL << GPIO_AFRH_AFSEL14_Pos) |
| #define | GPIO_AFRH_AFSEL14_3 (0x8UL << GPIO_AFRH_AFSEL14_Pos) |
| #define | GPIO_AFRH_AFSEL15_Pos (28U) |
| #define | GPIO_AFRH_AFSEL15_Msk (0xFUL << GPIO_AFRH_AFSEL15_Pos) |
| #define | GPIO_AFRH_AFSEL15 GPIO_AFRH_AFSEL15_Msk |
| #define | GPIO_AFRH_AFSEL15_0 (0x1UL << GPIO_AFRH_AFSEL15_Pos) |
| #define | GPIO_AFRH_AFSEL15_1 (0x2UL << GPIO_AFRH_AFSEL15_Pos) |
| #define | GPIO_AFRH_AFSEL15_2 (0x4UL << GPIO_AFRH_AFSEL15_Pos) |
| #define | GPIO_AFRH_AFSEL15_3 (0x8UL << GPIO_AFRH_AFSEL15_Pos) |
| #define | GPIO_AFRH_AFRH0 GPIO_AFRH_AFSEL8 |
| #define | GPIO_AFRH_AFRH1 GPIO_AFRH_AFSEL9 |
| #define | GPIO_AFRH_AFRH2 GPIO_AFRH_AFSEL10 |
| #define | GPIO_AFRH_AFRH3 GPIO_AFRH_AFSEL11 |
| #define | GPIO_AFRH_AFRH4 GPIO_AFRH_AFSEL12 |
| #define | GPIO_AFRH_AFRH5 GPIO_AFRH_AFSEL13 |
| #define | GPIO_AFRH_AFRH6 GPIO_AFRH_AFSEL14 |
| #define | GPIO_AFRH_AFRH7 GPIO_AFRH_AFSEL15 |
| #define | HSEM_R_PROCID_Pos (0U) |
| #define | HSEM_R_PROCID_Msk (0xFFUL << HSEM_R_PROCID_Pos) |
| #define | HSEM_R_PROCID HSEM_R_PROCID_Msk |
| #define | HSEM_R_COREID_Pos (8U) |
| #define | HSEM_R_COREID_Msk (0xFFUL << HSEM_R_COREID_Pos) |
| #define | HSEM_R_COREID HSEM_R_COREID_Msk |
| #define | HSEM_R_LOCK_Pos (31U) |
| #define | HSEM_R_LOCK_Msk (0x1UL << HSEM_R_LOCK_Pos) |
| #define | HSEM_R_LOCK HSEM_R_LOCK_Msk |
| #define | HSEM_RLR_PROCID_Pos (0U) |
| #define | HSEM_RLR_PROCID_Msk (0xFFUL << HSEM_RLR_PROCID_Pos) |
| #define | HSEM_RLR_PROCID HSEM_RLR_PROCID_Msk |
| #define | HSEM_RLR_COREID_Pos (8U) |
| #define | HSEM_RLR_COREID_Msk (0xFFUL << HSEM_RLR_COREID_Pos) |
| #define | HSEM_RLR_COREID HSEM_RLR_COREID_Msk |
| #define | HSEM_RLR_LOCK_Pos (31U) |
| #define | HSEM_RLR_LOCK_Msk (0x1UL << HSEM_RLR_LOCK_Pos) |
| #define | HSEM_RLR_LOCK HSEM_RLR_LOCK_Msk |
| #define | HSEM_C1IER_ISE0_Pos (0U) |
| #define | HSEM_C1IER_ISE0_Msk (0x1UL << HSEM_C1IER_ISE0_Pos) |
| #define | HSEM_C1IER_ISE0 HSEM_C1IER_ISE0_Msk |
| #define | HSEM_C1IER_ISE1_Pos (1U) |
| #define | HSEM_C1IER_ISE1_Msk (0x1UL << HSEM_C1IER_ISE1_Pos) |
| #define | HSEM_C1IER_ISE1 HSEM_C1IER_ISE1_Msk |
| #define | HSEM_C1IER_ISE2_Pos (2U) |
| #define | HSEM_C1IER_ISE2_Msk (0x1UL << HSEM_C1IER_ISE2_Pos) |
| #define | HSEM_C1IER_ISE2 HSEM_C1IER_ISE2_Msk |
| #define | HSEM_C1IER_ISE3_Pos (3U) |
| #define | HSEM_C1IER_ISE3_Msk (0x1UL << HSEM_C1IER_ISE3_Pos) |
| #define | HSEM_C1IER_ISE3 HSEM_C1IER_ISE3_Msk |
| #define | HSEM_C1IER_ISE4_Pos (4U) |
| #define | HSEM_C1IER_ISE4_Msk (0x1UL << HSEM_C1IER_ISE4_Pos) |
| #define | HSEM_C1IER_ISE4 HSEM_C1IER_ISE4_Msk |
| #define | HSEM_C1IER_ISE5_Pos (5U) |
| #define | HSEM_C1IER_ISE5_Msk (0x1UL << HSEM_C1IER_ISE5_Pos) |
| #define | HSEM_C1IER_ISE5 HSEM_C1IER_ISE5_Msk |
| #define | HSEM_C1IER_ISE6_Pos (6U) |
| #define | HSEM_C1IER_ISE6_Msk (0x1UL << HSEM_C1IER_ISE6_Pos) |
| #define | HSEM_C1IER_ISE6 HSEM_C1IER_ISE6_Msk |
| #define | HSEM_C1IER_ISE7_Pos (7U) |
| #define | HSEM_C1IER_ISE7_Msk (0x1UL << HSEM_C1IER_ISE7_Pos) |
| #define | HSEM_C1IER_ISE7 HSEM_C1IER_ISE7_Msk |
| #define | HSEM_C1IER_ISE8_Pos (8U) |
| #define | HSEM_C1IER_ISE8_Msk (0x1UL << HSEM_C1IER_ISE8_Pos) |
| #define | HSEM_C1IER_ISE8 HSEM_C1IER_ISE8_Msk |
| #define | HSEM_C1IER_ISE9_Pos (9U) |
| #define | HSEM_C1IER_ISE9_Msk (0x1UL << HSEM_C1IER_ISE9_Pos) |
| #define | HSEM_C1IER_ISE9 HSEM_C1IER_ISE9_Msk |
| #define | HSEM_C1IER_ISE10_Pos (10U) |
| #define | HSEM_C1IER_ISE10_Msk (0x1UL << HSEM_C1IER_ISE10_Pos) |
| #define | HSEM_C1IER_ISE10 HSEM_C1IER_ISE10_Msk |
| #define | HSEM_C1IER_ISE11_Pos (11U) |
| #define | HSEM_C1IER_ISE11_Msk (0x1UL << HSEM_C1IER_ISE11_Pos) |
| #define | HSEM_C1IER_ISE11 HSEM_C1IER_ISE11_Msk |
| #define | HSEM_C1IER_ISE12_Pos (12U) |
| #define | HSEM_C1IER_ISE12_Msk (0x1UL << HSEM_C1IER_ISE12_Pos) |
| #define | HSEM_C1IER_ISE12 HSEM_C1IER_ISE12_Msk |
| #define | HSEM_C1IER_ISE13_Pos (13U) |
| #define | HSEM_C1IER_ISE13_Msk (0x1UL << HSEM_C1IER_ISE13_Pos) |
| #define | HSEM_C1IER_ISE13 HSEM_C1IER_ISE13_Msk |
| #define | HSEM_C1IER_ISE14_Pos (14U) |
| #define | HSEM_C1IER_ISE14_Msk (0x1UL << HSEM_C1IER_ISE14_Pos) |
| #define | HSEM_C1IER_ISE14 HSEM_C1IER_ISE14_Msk |
| #define | HSEM_C1IER_ISE15_Pos (15U) |
| #define | HSEM_C1IER_ISE15_Msk (0x1UL << HSEM_C1IER_ISE15_Pos) |
| #define | HSEM_C1IER_ISE15 HSEM_C1IER_ISE15_Msk |
| #define | HSEM_C1IER_ISE16_Pos (16U) |
| #define | HSEM_C1IER_ISE16_Msk (0x1UL << HSEM_C1IER_ISE16_Pos) |
| #define | HSEM_C1IER_ISE16 HSEM_C1IER_ISE16_Msk |
| #define | HSEM_C1IER_ISE17_Pos (17U) |
| #define | HSEM_C1IER_ISE17_Msk (0x1UL << HSEM_C1IER_ISE17_Pos) |
| #define | HSEM_C1IER_ISE17 HSEM_C1IER_ISE17_Msk |
| #define | HSEM_C1IER_ISE18_Pos (18U) |
| #define | HSEM_C1IER_ISE18_Msk (0x1UL << HSEM_C1IER_ISE18_Pos) |
| #define | HSEM_C1IER_ISE18 HSEM_C1IER_ISE18_Msk |
| #define | HSEM_C1IER_ISE19_Pos (19U) |
| #define | HSEM_C1IER_ISE19_Msk (0x1UL << HSEM_C1IER_ISE19_Pos) |
| #define | HSEM_C1IER_ISE19 HSEM_C1IER_ISE19_Msk |
| #define | HSEM_C1IER_ISE20_Pos (20U) |
| #define | HSEM_C1IER_ISE20_Msk (0x1UL << HSEM_C1IER_ISE20_Pos) |
| #define | HSEM_C1IER_ISE20 HSEM_C1IER_ISE20_Msk |
| #define | HSEM_C1IER_ISE21_Pos (21U) |
| #define | HSEM_C1IER_ISE21_Msk (0x1UL << HSEM_C1IER_ISE21_Pos) |
| #define | HSEM_C1IER_ISE21 HSEM_C1IER_ISE21_Msk |
| #define | HSEM_C1IER_ISE22_Pos (22U) |
| #define | HSEM_C1IER_ISE22_Msk (0x1UL << HSEM_C1IER_ISE22_Pos) |
| #define | HSEM_C1IER_ISE22 HSEM_C1IER_ISE22_Msk |
| #define | HSEM_C1IER_ISE23_Pos (23U) |
| #define | HSEM_C1IER_ISE23_Msk (0x1UL << HSEM_C1IER_ISE23_Pos) |
| #define | HSEM_C1IER_ISE23 HSEM_C1IER_ISE23_Msk |
| #define | HSEM_C1IER_ISE24_Pos (24U) |
| #define | HSEM_C1IER_ISE24_Msk (0x1UL << HSEM_C1IER_ISE24_Pos) |
| #define | HSEM_C1IER_ISE24 HSEM_C1IER_ISE24_Msk |
| #define | HSEM_C1IER_ISE25_Pos (25U) |
| #define | HSEM_C1IER_ISE25_Msk (0x1UL << HSEM_C1IER_ISE25_Pos) |
| #define | HSEM_C1IER_ISE25 HSEM_C1IER_ISE25_Msk |
| #define | HSEM_C1IER_ISE26_Pos (26U) |
| #define | HSEM_C1IER_ISE26_Msk (0x1UL << HSEM_C1IER_ISE26_Pos) |
| #define | HSEM_C1IER_ISE26 HSEM_C1IER_ISE26_Msk |
| #define | HSEM_C1IER_ISE27_Pos (27U) |
| #define | HSEM_C1IER_ISE27_Msk (0x1UL << HSEM_C1IER_ISE27_Pos) |
| #define | HSEM_C1IER_ISE27 HSEM_C1IER_ISE27_Msk |
| #define | HSEM_C1IER_ISE28_Pos (28U) |
| #define | HSEM_C1IER_ISE28_Msk (0x1UL << HSEM_C1IER_ISE28_Pos) |
| #define | HSEM_C1IER_ISE28 HSEM_C1IER_ISE28_Msk |
| #define | HSEM_C1IER_ISE29_Pos (29U) |
| #define | HSEM_C1IER_ISE29_Msk (0x1UL << HSEM_C1IER_ISE29_Pos) |
| #define | HSEM_C1IER_ISE29 HSEM_C1IER_ISE29_Msk |
| #define | HSEM_C1IER_ISE30_Pos (30U) |
| #define | HSEM_C1IER_ISE30_Msk (0x1UL << HSEM_C1IER_ISE30_Pos) |
| #define | HSEM_C1IER_ISE30 HSEM_C1IER_ISE30_Msk |
| #define | HSEM_C1IER_ISE31_Pos (31U) |
| #define | HSEM_C1IER_ISE31_Msk (0x1UL << HSEM_C1IER_ISE31_Pos) |
| #define | HSEM_C1IER_ISE31 HSEM_C1IER_ISE31_Msk |
| #define | HSEM_C1ICR_ISC0_Pos (0U) |
| #define | HSEM_C1ICR_ISC0_Msk (0x1UL << HSEM_C1ICR_ISC0_Pos) |
| #define | HSEM_C1ICR_ISC0 HSEM_C1ICR_ISC0_Msk |
| #define | HSEM_C1ICR_ISC1_Pos (1U) |
| #define | HSEM_C1ICR_ISC1_Msk (0x1UL << HSEM_C1ICR_ISC1_Pos) |
| #define | HSEM_C1ICR_ISC1 HSEM_C1ICR_ISC1_Msk |
| #define | HSEM_C1ICR_ISC2_Pos (2U) |
| #define | HSEM_C1ICR_ISC2_Msk (0x1UL << HSEM_C1ICR_ISC2_Pos) |
| #define | HSEM_C1ICR_ISC2 HSEM_C1ICR_ISC2_Msk |
| #define | HSEM_C1ICR_ISC3_Pos (3U) |
| #define | HSEM_C1ICR_ISC3_Msk (0x1UL << HSEM_C1ICR_ISC3_Pos) |
| #define | HSEM_C1ICR_ISC3 HSEM_C1ICR_ISC3_Msk |
| #define | HSEM_C1ICR_ISC4_Pos (4U) |
| #define | HSEM_C1ICR_ISC4_Msk (0x1UL << HSEM_C1ICR_ISC4_Pos) |
| #define | HSEM_C1ICR_ISC4 HSEM_C1ICR_ISC4_Msk |
| #define | HSEM_C1ICR_ISC5_Pos (5U) |
| #define | HSEM_C1ICR_ISC5_Msk (0x1UL << HSEM_C1ICR_ISC5_Pos) |
| #define | HSEM_C1ICR_ISC5 HSEM_C1ICR_ISC5_Msk |
| #define | HSEM_C1ICR_ISC6_Pos (6U) |
| #define | HSEM_C1ICR_ISC6_Msk (0x1UL << HSEM_C1ICR_ISC6_Pos) |
| #define | HSEM_C1ICR_ISC6 HSEM_C1ICR_ISC6_Msk |
| #define | HSEM_C1ICR_ISC7_Pos (7U) |
| #define | HSEM_C1ICR_ISC7_Msk (0x1UL << HSEM_C1ICR_ISC7_Pos) |
| #define | HSEM_C1ICR_ISC7 HSEM_C1ICR_ISC7_Msk |
| #define | HSEM_C1ICR_ISC8_Pos (8U) |
| #define | HSEM_C1ICR_ISC8_Msk (0x1UL << HSEM_C1ICR_ISC8_Pos) |
| #define | HSEM_C1ICR_ISC8 HSEM_C1ICR_ISC8_Msk |
| #define | HSEM_C1ICR_ISC9_Pos (9U) |
| #define | HSEM_C1ICR_ISC9_Msk (0x1UL << HSEM_C1ICR_ISC9_Pos) |
| #define | HSEM_C1ICR_ISC9 HSEM_C1ICR_ISC9_Msk |
| #define | HSEM_C1ICR_ISC10_Pos (10U) |
| #define | HSEM_C1ICR_ISC10_Msk (0x1UL << HSEM_C1ICR_ISC10_Pos) |
| #define | HSEM_C1ICR_ISC10 HSEM_C1ICR_ISC10_Msk |
| #define | HSEM_C1ICR_ISC11_Pos (11U) |
| #define | HSEM_C1ICR_ISC11_Msk (0x1UL << HSEM_C1ICR_ISC11_Pos) |
| #define | HSEM_C1ICR_ISC11 HSEM_C1ICR_ISC11_Msk |
| #define | HSEM_C1ICR_ISC12_Pos (12U) |
| #define | HSEM_C1ICR_ISC12_Msk (0x1UL << HSEM_C1ICR_ISC12_Pos) |
| #define | HSEM_C1ICR_ISC12 HSEM_C1ICR_ISC12_Msk |
| #define | HSEM_C1ICR_ISC13_Pos (13U) |
| #define | HSEM_C1ICR_ISC13_Msk (0x1UL << HSEM_C1ICR_ISC13_Pos) |
| #define | HSEM_C1ICR_ISC13 HSEM_C1ICR_ISC13_Msk |
| #define | HSEM_C1ICR_ISC14_Pos (14U) |
| #define | HSEM_C1ICR_ISC14_Msk (0x1UL << HSEM_C1ICR_ISC14_Pos) |
| #define | HSEM_C1ICR_ISC14 HSEM_C1ICR_ISC14_Msk |
| #define | HSEM_C1ICR_ISC15_Pos (15U) |
| #define | HSEM_C1ICR_ISC15_Msk (0x1UL << HSEM_C1ICR_ISC15_Pos) |
| #define | HSEM_C1ICR_ISC15 HSEM_C1ICR_ISC15_Msk |
| #define | HSEM_C1ICR_ISC16_Pos (16U) |
| #define | HSEM_C1ICR_ISC16_Msk (0x1UL << HSEM_C1ICR_ISC16_Pos) |
| #define | HSEM_C1ICR_ISC16 HSEM_C1ICR_ISC16_Msk |
| #define | HSEM_C1ICR_ISC17_Pos (17U) |
| #define | HSEM_C1ICR_ISC17_Msk (0x1UL << HSEM_C1ICR_ISC17_Pos) |
| #define | HSEM_C1ICR_ISC17 HSEM_C1ICR_ISC17_Msk |
| #define | HSEM_C1ICR_ISC18_Pos (18U) |
| #define | HSEM_C1ICR_ISC18_Msk (0x1UL << HSEM_C1ICR_ISC18_Pos) |
| #define | HSEM_C1ICR_ISC18 HSEM_C1ICR_ISC18_Msk |
| #define | HSEM_C1ICR_ISC19_Pos (19U) |
| #define | HSEM_C1ICR_ISC19_Msk (0x1UL << HSEM_C1ICR_ISC19_Pos) |
| #define | HSEM_C1ICR_ISC19 HSEM_C1ICR_ISC19_Msk |
| #define | HSEM_C1ICR_ISC20_Pos (20U) |
| #define | HSEM_C1ICR_ISC20_Msk (0x1UL << HSEM_C1ICR_ISC20_Pos) |
| #define | HSEM_C1ICR_ISC20 HSEM_C1ICR_ISC20_Msk |
| #define | HSEM_C1ICR_ISC21_Pos (21U) |
| #define | HSEM_C1ICR_ISC21_Msk (0x1UL << HSEM_C1ICR_ISC21_Pos) |
| #define | HSEM_C1ICR_ISC21 HSEM_C1ICR_ISC21_Msk |
| #define | HSEM_C1ICR_ISC22_Pos (22U) |
| #define | HSEM_C1ICR_ISC22_Msk (0x1UL << HSEM_C1ICR_ISC22_Pos) |
| #define | HSEM_C1ICR_ISC22 HSEM_C1ICR_ISC22_Msk |
| #define | HSEM_C1ICR_ISC23_Pos (23U) |
| #define | HSEM_C1ICR_ISC23_Msk (0x1UL << HSEM_C1ICR_ISC23_Pos) |
| #define | HSEM_C1ICR_ISC23 HSEM_C1ICR_ISC23_Msk |
| #define | HSEM_C1ICR_ISC24_Pos (24U) |
| #define | HSEM_C1ICR_ISC24_Msk (0x1UL << HSEM_C1ICR_ISC24_Pos) |
| #define | HSEM_C1ICR_ISC24 HSEM_C1ICR_ISC24_Msk |
| #define | HSEM_C1ICR_ISC25_Pos (25U) |
| #define | HSEM_C1ICR_ISC25_Msk (0x1UL << HSEM_C1ICR_ISC25_Pos) |
| #define | HSEM_C1ICR_ISC25 HSEM_C1ICR_ISC25_Msk |
| #define | HSEM_C1ICR_ISC26_Pos (26U) |
| #define | HSEM_C1ICR_ISC26_Msk (0x1UL << HSEM_C1ICR_ISC26_Pos) |
| #define | HSEM_C1ICR_ISC26 HSEM_C1ICR_ISC26_Msk |
| #define | HSEM_C1ICR_ISC27_Pos (27U) |
| #define | HSEM_C1ICR_ISC27_Msk (0x1UL << HSEM_C1ICR_ISC27_Pos) |
| #define | HSEM_C1ICR_ISC27 HSEM_C1ICR_ISC27_Msk |
| #define | HSEM_C1ICR_ISC28_Pos (28U) |
| #define | HSEM_C1ICR_ISC28_Msk (0x1UL << HSEM_C1ICR_ISC28_Pos) |
| #define | HSEM_C1ICR_ISC28 HSEM_C1ICR_ISC28_Msk |
| #define | HSEM_C1ICR_ISC29_Pos (29U) |
| #define | HSEM_C1ICR_ISC29_Msk (0x1UL << HSEM_C1ICR_ISC29_Pos) |
| #define | HSEM_C1ICR_ISC29 HSEM_C1ICR_ISC29_Msk |
| #define | HSEM_C1ICR_ISC30_Pos (30U) |
| #define | HSEM_C1ICR_ISC30_Msk (0x1UL << HSEM_C1ICR_ISC30_Pos) |
| #define | HSEM_C1ICR_ISC30 HSEM_C1ICR_ISC30_Msk |
| #define | HSEM_C1ICR_ISC31_Pos (31U) |
| #define | HSEM_C1ICR_ISC31_Msk (0x1UL << HSEM_C1ICR_ISC31_Pos) |
| #define | HSEM_C1ICR_ISC31 HSEM_C1ICR_ISC31_Msk |
| #define | HSEM_C1ISR_ISF0_Pos (0U) |
| #define | HSEM_C1ISR_ISF0_Msk (0x1UL << HSEM_C1ISR_ISF0_Pos) |
| #define | HSEM_C1ISR_ISF0 HSEM_C1ISR_ISF0_Msk |
| #define | HSEM_C1ISR_ISF1_Pos (1U) |
| #define | HSEM_C1ISR_ISF1_Msk (0x1UL << HSEM_C1ISR_ISF1_Pos) |
| #define | HSEM_C1ISR_ISF1 HSEM_C1ISR_ISF1_Msk |
| #define | HSEM_C1ISR_ISF2_Pos (2U) |
| #define | HSEM_C1ISR_ISF2_Msk (0x1UL << HSEM_C1ISR_ISF2_Pos) |
| #define | HSEM_C1ISR_ISF2 HSEM_C1ISR_ISF2_Msk |
| #define | HSEM_C1ISR_ISF3_Pos (3U) |
| #define | HSEM_C1ISR_ISF3_Msk (0x1UL << HSEM_C1ISR_ISF3_Pos) |
| #define | HSEM_C1ISR_ISF3 HSEM_C1ISR_ISF3_Msk |
| #define | HSEM_C1ISR_ISF4_Pos (4U) |
| #define | HSEM_C1ISR_ISF4_Msk (0x1UL << HSEM_C1ISR_ISF4_Pos) |
| #define | HSEM_C1ISR_ISF4 HSEM_C1ISR_ISF4_Msk |
| #define | HSEM_C1ISR_ISF5_Pos (5U) |
| #define | HSEM_C1ISR_ISF5_Msk (0x1UL << HSEM_C1ISR_ISF5_Pos) |
| #define | HSEM_C1ISR_ISF5 HSEM_C1ISR_ISF5_Msk |
| #define | HSEM_C1ISR_ISF6_Pos (6U) |
| #define | HSEM_C1ISR_ISF6_Msk (0x1UL << HSEM_C1ISR_ISF6_Pos) |
| #define | HSEM_C1ISR_ISF6 HSEM_C1ISR_ISF6_Msk |
| #define | HSEM_C1ISR_ISF7_Pos (7U) |
| #define | HSEM_C1ISR_ISF7_Msk (0x1UL << HSEM_C1ISR_ISF7_Pos) |
| #define | HSEM_C1ISR_ISF7 HSEM_C1ISR_ISF7_Msk |
| #define | HSEM_C1ISR_ISF8_Pos (8U) |
| #define | HSEM_C1ISR_ISF8_Msk (0x1UL << HSEM_C1ISR_ISF8_Pos) |
| #define | HSEM_C1ISR_ISF8 HSEM_C1ISR_ISF8_Msk |
| #define | HSEM_C1ISR_ISF9_Pos (9U) |
| #define | HSEM_C1ISR_ISF9_Msk (0x1UL << HSEM_C1ISR_ISF9_Pos) |
| #define | HSEM_C1ISR_ISF9 HSEM_C1ISR_ISF9_Msk |
| #define | HSEM_C1ISR_ISF10_Pos (10U) |
| #define | HSEM_C1ISR_ISF10_Msk (0x1UL << HSEM_C1ISR_ISF10_Pos) |
| #define | HSEM_C1ISR_ISF10 HSEM_C1ISR_ISF10_Msk |
| #define | HSEM_C1ISR_ISF11_Pos (11U) |
| #define | HSEM_C1ISR_ISF11_Msk (0x1UL << HSEM_C1ISR_ISF11_Pos) |
| #define | HSEM_C1ISR_ISF11 HSEM_C1ISR_ISF11_Msk |
| #define | HSEM_C1ISR_ISF12_Pos (12U) |
| #define | HSEM_C1ISR_ISF12_Msk (0x1UL << HSEM_C1ISR_ISF12_Pos) |
| #define | HSEM_C1ISR_ISF12 HSEM_C1ISR_ISF12_Msk |
| #define | HSEM_C1ISR_ISF13_Pos (13U) |
| #define | HSEM_C1ISR_ISF13_Msk (0x1UL << HSEM_C1ISR_ISF13_Pos) |
| #define | HSEM_C1ISR_ISF13 HSEM_C1ISR_ISF13_Msk |
| #define | HSEM_C1ISR_ISF14_Pos (14U) |
| #define | HSEM_C1ISR_ISF14_Msk (0x1UL << HSEM_C1ISR_ISF14_Pos) |
| #define | HSEM_C1ISR_ISF14 HSEM_C1ISR_ISF14_Msk |
| #define | HSEM_C1ISR_ISF15_Pos (15U) |
| #define | HSEM_C1ISR_ISF15_Msk (0x1UL << HSEM_C1ISR_ISF15_Pos) |
| #define | HSEM_C1ISR_ISF15 HSEM_C1ISR_ISF15_Msk |
| #define | HSEM_C1ISR_ISF16_Pos (16U) |
| #define | HSEM_C1ISR_ISF16_Msk (0x1UL << HSEM_C1ISR_ISF16_Pos) |
| #define | HSEM_C1ISR_ISF16 HSEM_C1ISR_ISF16_Msk |
| #define | HSEM_C1ISR_ISF17_Pos (17U) |
| #define | HSEM_C1ISR_ISF17_Msk (0x1UL << HSEM_C1ISR_ISF17_Pos) |
| #define | HSEM_C1ISR_ISF17 HSEM_C1ISR_ISF17_Msk |
| #define | HSEM_C1ISR_ISF18_Pos (18U) |
| #define | HSEM_C1ISR_ISF18_Msk (0x1UL << HSEM_C1ISR_ISF18_Pos) |
| #define | HSEM_C1ISR_ISF18 HSEM_C1ISR_ISF18_Msk |
| #define | HSEM_C1ISR_ISF19_Pos (19U) |
| #define | HSEM_C1ISR_ISF19_Msk (0x1UL << HSEM_C1ISR_ISF19_Pos) |
| #define | HSEM_C1ISR_ISF19 HSEM_C1ISR_ISF19_Msk |
| #define | HSEM_C1ISR_ISF20_Pos (20U) |
| #define | HSEM_C1ISR_ISF20_Msk (0x1UL << HSEM_C1ISR_ISF20_Pos) |
| #define | HSEM_C1ISR_ISF20 HSEM_C1ISR_ISF20_Msk |
| #define | HSEM_C1ISR_ISF21_Pos (21U) |
| #define | HSEM_C1ISR_ISF21_Msk (0x1UL << HSEM_C1ISR_ISF21_Pos) |
| #define | HSEM_C1ISR_ISF21 HSEM_C1ISR_ISF21_Msk |
| #define | HSEM_C1ISR_ISF22_Pos (22U) |
| #define | HSEM_C1ISR_ISF22_Msk (0x1UL << HSEM_C1ISR_ISF22_Pos) |
| #define | HSEM_C1ISR_ISF22 HSEM_C1ISR_ISF22_Msk |
| #define | HSEM_C1ISR_ISF23_Pos (23U) |
| #define | HSEM_C1ISR_ISF23_Msk (0x1UL << HSEM_C1ISR_ISF23_Pos) |
| #define | HSEM_C1ISR_ISF23 HSEM_C1ISR_ISF23_Msk |
| #define | HSEM_C1ISR_ISF24_Pos (24U) |
| #define | HSEM_C1ISR_ISF24_Msk (0x1UL << HSEM_C1ISR_ISF24_Pos) |
| #define | HSEM_C1ISR_ISF24 HSEM_C1ISR_ISF24_Msk |
| #define | HSEM_C1ISR_ISF25_Pos (25U) |
| #define | HSEM_C1ISR_ISF25_Msk (0x1UL << HSEM_C1ISR_ISF25_Pos) |
| #define | HSEM_C1ISR_ISF25 HSEM_C1ISR_ISF25_Msk |
| #define | HSEM_C1ISR_ISF26_Pos (26U) |
| #define | HSEM_C1ISR_ISF26_Msk (0x1UL << HSEM_C1ISR_ISF26_Pos) |
| #define | HSEM_C1ISR_ISF26 HSEM_C1ISR_ISF26_Msk |
| #define | HSEM_C1ISR_ISF27_Pos (27U) |
| #define | HSEM_C1ISR_ISF27_Msk (0x1UL << HSEM_C1ISR_ISF27_Pos) |
| #define | HSEM_C1ISR_ISF27 HSEM_C1ISR_ISF27_Msk |
| #define | HSEM_C1ISR_ISF28_Pos (28U) |
| #define | HSEM_C1ISR_ISF28_Msk (0x1UL << HSEM_C1ISR_ISF28_Pos) |
| #define | HSEM_C1ISR_ISF28 HSEM_C1ISR_ISF28_Msk |
| #define | HSEM_C1ISR_ISF29_Pos (29U) |
| #define | HSEM_C1ISR_ISF29_Msk (0x1UL << HSEM_C1ISR_ISF29_Pos) |
| #define | HSEM_C1ISR_ISF29 HSEM_C1ISR_ISF29_Msk |
| #define | HSEM_C1ISR_ISF30_Pos (30U) |
| #define | HSEM_C1ISR_ISF30_Msk (0x1UL << HSEM_C1ISR_ISF30_Pos) |
| #define | HSEM_C1ISR_ISF30 HSEM_C1ISR_ISF30_Msk |
| #define | HSEM_C1ISR_ISF31_Pos (31U) |
| #define | HSEM_C1ISR_ISF31_Msk (0x1UL << HSEM_C1ISR_ISF31_Pos) |
| #define | HSEM_C1ISR_ISF31 HSEM_C1ISR_ISF31_Msk |
| #define | HSEM_C1MISR_MISF0_Pos (0U) |
| #define | HSEM_C1MISR_MISF0_Msk (0x1UL << HSEM_C1MISR_MISF0_Pos) |
| #define | HSEM_C1MISR_MISF0 HSEM_C1MISR_MISF0_Msk |
| #define | HSEM_C1MISR_MISF1_Pos (1U) |
| #define | HSEM_C1MISR_MISF1_Msk (0x1UL << HSEM_C1MISR_MISF1_Pos) |
| #define | HSEM_C1MISR_MISF1 HSEM_C1MISR_MISF1_Msk |
| #define | HSEM_C1MISR_MISF2_Pos (2U) |
| #define | HSEM_C1MISR_MISF2_Msk (0x1UL << HSEM_C1MISR_MISF2_Pos) |
| #define | HSEM_C1MISR_MISF2 HSEM_C1MISR_MISF2_Msk |
| #define | HSEM_C1MISR_MISF3_Pos (3U) |
| #define | HSEM_C1MISR_MISF3_Msk (0x1UL << HSEM_C1MISR_MISF3_Pos) |
| #define | HSEM_C1MISR_MISF3 HSEM_C1MISR_MISF3_Msk |
| #define | HSEM_C1MISR_MISF4_Pos (4U) |
| #define | HSEM_C1MISR_MISF4_Msk (0x1UL << HSEM_C1MISR_MISF4_Pos) |
| #define | HSEM_C1MISR_MISF4 HSEM_C1MISR_MISF4_Msk |
| #define | HSEM_C1MISR_MISF5_Pos (5U) |
| #define | HSEM_C1MISR_MISF5_Msk (0x1UL << HSEM_C1MISR_MISF5_Pos) |
| #define | HSEM_C1MISR_MISF5 HSEM_C1MISR_MISF5_Msk |
| #define | HSEM_C1MISR_MISF6_Pos (6U) |
| #define | HSEM_C1MISR_MISF6_Msk (0x1UL << HSEM_C1MISR_MISF6_Pos) |
| #define | HSEM_C1MISR_MISF6 HSEM_C1MISR_MISF6_Msk |
| #define | HSEM_C1MISR_MISF7_Pos (7U) |
| #define | HSEM_C1MISR_MISF7_Msk (0x1UL << HSEM_C1MISR_MISF7_Pos) |
| #define | HSEM_C1MISR_MISF7 HSEM_C1MISR_MISF7_Msk |
| #define | HSEM_C1MISR_MISF8_Pos (8U) |
| #define | HSEM_C1MISR_MISF8_Msk (0x1UL << HSEM_C1MISR_MISF8_Pos) |
| #define | HSEM_C1MISR_MISF8 HSEM_C1MISR_MISF8_Msk |
| #define | HSEM_C1MISR_MISF9_Pos (9U) |
| #define | HSEM_C1MISR_MISF9_Msk (0x1UL << HSEM_C1MISR_MISF9_Pos) |
| #define | HSEM_C1MISR_MISF9 HSEM_C1MISR_MISF9_Msk |
| #define | HSEM_C1MISR_MISF10_Pos (10U) |
| #define | HSEM_C1MISR_MISF10_Msk (0x1UL << HSEM_C1MISR_MISF10_Pos) |
| #define | HSEM_C1MISR_MISF10 HSEM_C1MISR_MISF10_Msk |
| #define | HSEM_C1MISR_MISF11_Pos (11U) |
| #define | HSEM_C1MISR_MISF11_Msk (0x1UL << HSEM_C1MISR_MISF11_Pos) |
| #define | HSEM_C1MISR_MISF11 HSEM_C1MISR_MISF11_Msk |
| #define | HSEM_C1MISR_MISF12_Pos (12U) |
| #define | HSEM_C1MISR_MISF12_Msk (0x1UL << HSEM_C1MISR_MISF12_Pos) |
| #define | HSEM_C1MISR_MISF12 HSEM_C1MISR_MISF12_Msk |
| #define | HSEM_C1MISR_MISF13_Pos (13U) |
| #define | HSEM_C1MISR_MISF13_Msk (0x1UL << HSEM_C1MISR_MISF13_Pos) |
| #define | HSEM_C1MISR_MISF13 HSEM_C1MISR_MISF13_Msk |
| #define | HSEM_C1MISR_MISF14_Pos (14U) |
| #define | HSEM_C1MISR_MISF14_Msk (0x1UL << HSEM_C1MISR_MISF14_Pos) |
| #define | HSEM_C1MISR_MISF14 HSEM_C1MISR_MISF14_Msk |
| #define | HSEM_C1MISR_MISF15_Pos (15U) |
| #define | HSEM_C1MISR_MISF15_Msk (0x1UL << HSEM_C1MISR_MISF15_Pos) |
| #define | HSEM_C1MISR_MISF15 HSEM_C1MISR_MISF15_Msk |
| #define | HSEM_C1MISR_MISF16_Pos (16U) |
| #define | HSEM_C1MISR_MISF16_Msk (0x1UL << HSEM_C1MISR_MISF16_Pos) |
| #define | HSEM_C1MISR_MISF16 HSEM_C1MISR_MISF16_Msk |
| #define | HSEM_C1MISR_MISF17_Pos (17U) |
| #define | HSEM_C1MISR_MISF17_Msk (0x1UL << HSEM_C1MISR_MISF17_Pos) |
| #define | HSEM_C1MISR_MISF17 HSEM_C1MISR_MISF17_Msk |
| #define | HSEM_C1MISR_MISF18_Pos (18U) |
| #define | HSEM_C1MISR_MISF18_Msk (0x1UL << HSEM_C1MISR_MISF18_Pos) |
| #define | HSEM_C1MISR_MISF18 HSEM_C1MISR_MISF18_Msk |
| #define | HSEM_C1MISR_MISF19_Pos (19U) |
| #define | HSEM_C1MISR_MISF19_Msk (0x1UL << HSEM_C1MISR_MISF19_Pos) |
| #define | HSEM_C1MISR_MISF19 HSEM_C1MISR_MISF19_Msk |
| #define | HSEM_C1MISR_MISF20_Pos (20U) |
| #define | HSEM_C1MISR_MISF20_Msk (0x1UL << HSEM_C1MISR_MISF20_Pos) |
| #define | HSEM_C1MISR_MISF20 HSEM_C1MISR_MISF20_Msk |
| #define | HSEM_C1MISR_MISF21_Pos (21U) |
| #define | HSEM_C1MISR_MISF21_Msk (0x1UL << HSEM_C1MISR_MISF21_Pos) |
| #define | HSEM_C1MISR_MISF21 HSEM_C1MISR_MISF21_Msk |
| #define | HSEM_C1MISR_MISF22_Pos (22U) |
| #define | HSEM_C1MISR_MISF22_Msk (0x1UL << HSEM_C1MISR_MISF22_Pos) |
| #define | HSEM_C1MISR_MISF22 HSEM_C1MISR_MISF22_Msk |
| #define | HSEM_C1MISR_MISF23_Pos (23U) |
| #define | HSEM_C1MISR_MISF23_Msk (0x1UL << HSEM_C1MISR_MISF23_Pos) |
| #define | HSEM_C1MISR_MISF23 HSEM_C1MISR_MISF23_Msk |
| #define | HSEM_C1MISR_MISF24_Pos (24U) |
| #define | HSEM_C1MISR_MISF24_Msk (0x1UL << HSEM_C1MISR_MISF24_Pos) |
| #define | HSEM_C1MISR_MISF24 HSEM_C1MISR_MISF24_Msk |
| #define | HSEM_C1MISR_MISF25_Pos (25U) |
| #define | HSEM_C1MISR_MISF25_Msk (0x1UL << HSEM_C1MISR_MISF25_Pos) |
| #define | HSEM_C1MISR_MISF25 HSEM_C1MISR_MISF25_Msk |
| #define | HSEM_C1MISR_MISF26_Pos (26U) |
| #define | HSEM_C1MISR_MISF26_Msk (0x1UL << HSEM_C1MISR_MISF26_Pos) |
| #define | HSEM_C1MISR_MISF26 HSEM_C1MISR_MISF26_Msk |
| #define | HSEM_C1MISR_MISF27_Pos (27U) |
| #define | HSEM_C1MISR_MISF27_Msk (0x1UL << HSEM_C1MISR_MISF27_Pos) |
| #define | HSEM_C1MISR_MISF27 HSEM_C1MISR_MISF27_Msk |
| #define | HSEM_C1MISR_MISF28_Pos (28U) |
| #define | HSEM_C1MISR_MISF28_Msk (0x1UL << HSEM_C1MISR_MISF28_Pos) |
| #define | HSEM_C1MISR_MISF28 HSEM_C1MISR_MISF28_Msk |
| #define | HSEM_C1MISR_MISF29_Pos (29U) |
| #define | HSEM_C1MISR_MISF29_Msk (0x1UL << HSEM_C1MISR_MISF29_Pos) |
| #define | HSEM_C1MISR_MISF29 HSEM_C1MISR_MISF29_Msk |
| #define | HSEM_C1MISR_MISF30_Pos (30U) |
| #define | HSEM_C1MISR_MISF30_Msk (0x1UL << HSEM_C1MISR_MISF30_Pos) |
| #define | HSEM_C1MISR_MISF30 HSEM_C1MISR_MISF30_Msk |
| #define | HSEM_C1MISR_MISF31_Pos (31U) |
| #define | HSEM_C1MISR_MISF31_Msk (0x1UL << HSEM_C1MISR_MISF31_Pos) |
| #define | HSEM_C1MISR_MISF31 HSEM_C1MISR_MISF31_Msk |
| #define | HSEM_CR_COREID_Pos (8U) |
| #define | HSEM_CR_COREID_Msk (0xFFUL << HSEM_CR_COREID_Pos) |
| #define | HSEM_CR_COREID HSEM_CR_COREID_Msk |
| #define | HSEM_CR_KEY_Pos (16U) |
| #define | HSEM_CR_KEY_Msk (0xFFFFUL << HSEM_CR_KEY_Pos) |
| #define | HSEM_CR_KEY HSEM_CR_KEY_Msk |
| #define | HSEM_KEYR_KEY_Pos (16U) |
| #define | HSEM_KEYR_KEY_Msk (0xFFFFUL << HSEM_KEYR_KEY_Pos) |
| #define | HSEM_KEYR_KEY HSEM_KEYR_KEY_Msk |
| #define | HASH_CR_INIT_Pos (2U) |
| #define | HASH_CR_INIT_Msk (0x1UL << HASH_CR_INIT_Pos) |
| #define | HASH_CR_INIT HASH_CR_INIT_Msk |
| #define | HASH_CR_DMAE_Pos (3U) |
| #define | HASH_CR_DMAE_Msk (0x1UL << HASH_CR_DMAE_Pos) |
| #define | HASH_CR_DMAE HASH_CR_DMAE_Msk |
| #define | HASH_CR_DATATYPE_Pos (4U) |
| #define | HASH_CR_DATATYPE_Msk (0x3UL << HASH_CR_DATATYPE_Pos) |
| #define | HASH_CR_DATATYPE HASH_CR_DATATYPE_Msk |
| #define | HASH_CR_DATATYPE_0 (0x1UL << HASH_CR_DATATYPE_Pos) |
| #define | HASH_CR_DATATYPE_1 (0x2UL << HASH_CR_DATATYPE_Pos) |
| #define | HASH_CR_MODE_Pos (6U) |
| #define | HASH_CR_MODE_Msk (0x1UL << HASH_CR_MODE_Pos) |
| #define | HASH_CR_MODE HASH_CR_MODE_Msk |
| #define | HASH_CR_ALGO_Pos (7U) |
| #define | HASH_CR_ALGO_Msk (0x801UL << HASH_CR_ALGO_Pos) |
| #define | HASH_CR_ALGO HASH_CR_ALGO_Msk |
| #define | HASH_CR_ALGO_0 (0x001UL << HASH_CR_ALGO_Pos) |
| #define | HASH_CR_ALGO_1 (0x800UL << HASH_CR_ALGO_Pos) |
| #define | HASH_CR_NBW_Pos (8U) |
| #define | HASH_CR_NBW_Msk (0xFUL << HASH_CR_NBW_Pos) |
| #define | HASH_CR_NBW HASH_CR_NBW_Msk |
| #define | HASH_CR_NBW_0 (0x1UL << HASH_CR_NBW_Pos) |
| #define | HASH_CR_NBW_1 (0x2UL << HASH_CR_NBW_Pos) |
| #define | HASH_CR_NBW_2 (0x4UL << HASH_CR_NBW_Pos) |
| #define | HASH_CR_NBW_3 (0x8UL << HASH_CR_NBW_Pos) |
| #define | HASH_CR_DINNE_Pos (12U) |
| #define | HASH_CR_DINNE_Msk (0x1UL << HASH_CR_DINNE_Pos) |
| #define | HASH_CR_DINNE HASH_CR_DINNE_Msk |
| #define | HASH_CR_MDMAT_Pos (13U) |
| #define | HASH_CR_MDMAT_Msk (0x1UL << HASH_CR_MDMAT_Pos) |
| #define | HASH_CR_MDMAT HASH_CR_MDMAT_Msk |
| #define | HASH_CR_LKEY_Pos (16U) |
| #define | HASH_CR_LKEY_Msk (0x1UL << HASH_CR_LKEY_Pos) |
| #define | HASH_CR_LKEY HASH_CR_LKEY_Msk |
| #define | HASH_STR_NBLW_Pos (0U) |
| #define | HASH_STR_NBLW_Msk (0x1FUL << HASH_STR_NBLW_Pos) |
| #define | HASH_STR_NBLW HASH_STR_NBLW_Msk |
| #define | HASH_STR_NBLW_0 (0x01UL << HASH_STR_NBLW_Pos) |
| #define | HASH_STR_NBLW_1 (0x02UL << HASH_STR_NBLW_Pos) |
| #define | HASH_STR_NBLW_2 (0x04UL << HASH_STR_NBLW_Pos) |
| #define | HASH_STR_NBLW_3 (0x08UL << HASH_STR_NBLW_Pos) |
| #define | HASH_STR_NBLW_4 (0x10UL << HASH_STR_NBLW_Pos) |
| #define | HASH_STR_DCAL_Pos (8U) |
| #define | HASH_STR_DCAL_Msk (0x1UL << HASH_STR_DCAL_Pos) |
| #define | HASH_STR_DCAL HASH_STR_DCAL_Msk |
| #define | HASH_IMR_DINIE_Pos (0U) |
| #define | HASH_IMR_DINIE_Msk (0x1UL << HASH_IMR_DINIE_Pos) |
| #define | HASH_IMR_DINIE HASH_IMR_DINIE_Msk |
| #define | HASH_IMR_DCIE_Pos (1U) |
| #define | HASH_IMR_DCIE_Msk (0x1UL << HASH_IMR_DCIE_Pos) |
| #define | HASH_IMR_DCIE HASH_IMR_DCIE_Msk |
| #define | HASH_SR_DINIS_Pos (0U) |
| #define | HASH_SR_DINIS_Msk (0x1UL << HASH_SR_DINIS_Pos) |
| #define | HASH_SR_DINIS HASH_SR_DINIS_Msk |
| #define | HASH_SR_DCIS_Pos (1U) |
| #define | HASH_SR_DCIS_Msk (0x1UL << HASH_SR_DCIS_Pos) |
| #define | HASH_SR_DCIS HASH_SR_DCIS_Msk |
| #define | HASH_SR_DMAS_Pos (2U) |
| #define | HASH_SR_DMAS_Msk (0x1UL << HASH_SR_DMAS_Pos) |
| #define | HASH_SR_DMAS HASH_SR_DMAS_Msk |
| #define | HASH_SR_BUSY_Pos (3U) |
| #define | HASH_SR_BUSY_Msk (0x1UL << HASH_SR_BUSY_Pos) |
| #define | HASH_SR_BUSY HASH_SR_BUSY_Msk |
| #define | I2C_CR1_PE_Pos (0U) |
| #define | I2C_CR1_PE_Msk (0x1UL << I2C_CR1_PE_Pos) |
| #define | I2C_CR1_PE I2C_CR1_PE_Msk |
| #define | I2C_CR1_TXIE_Pos (1U) |
| #define | I2C_CR1_TXIE_Msk (0x1UL << I2C_CR1_TXIE_Pos) |
| #define | I2C_CR1_TXIE I2C_CR1_TXIE_Msk |
| #define | I2C_CR1_RXIE_Pos (2U) |
| #define | I2C_CR1_RXIE_Msk (0x1UL << I2C_CR1_RXIE_Pos) |
| #define | I2C_CR1_RXIE I2C_CR1_RXIE_Msk |
| #define | I2C_CR1_ADDRIE_Pos (3U) |
| #define | I2C_CR1_ADDRIE_Msk (0x1UL << I2C_CR1_ADDRIE_Pos) |
| #define | I2C_CR1_ADDRIE I2C_CR1_ADDRIE_Msk |
| #define | I2C_CR1_NACKIE_Pos (4U) |
| #define | I2C_CR1_NACKIE_Msk (0x1UL << I2C_CR1_NACKIE_Pos) |
| #define | I2C_CR1_NACKIE I2C_CR1_NACKIE_Msk |
| #define | I2C_CR1_STOPIE_Pos (5U) |
| #define | I2C_CR1_STOPIE_Msk (0x1UL << I2C_CR1_STOPIE_Pos) |
| #define | I2C_CR1_STOPIE I2C_CR1_STOPIE_Msk |
| #define | I2C_CR1_TCIE_Pos (6U) |
| #define | I2C_CR1_TCIE_Msk (0x1UL << I2C_CR1_TCIE_Pos) |
| #define | I2C_CR1_TCIE I2C_CR1_TCIE_Msk |
| #define | I2C_CR1_ERRIE_Pos (7U) |
| #define | I2C_CR1_ERRIE_Msk (0x1UL << I2C_CR1_ERRIE_Pos) |
| #define | I2C_CR1_ERRIE I2C_CR1_ERRIE_Msk |
| #define | I2C_CR1_DNF_Pos (8U) |
| #define | I2C_CR1_DNF_Msk (0xFUL << I2C_CR1_DNF_Pos) |
| #define | I2C_CR1_DNF I2C_CR1_DNF_Msk |
| #define | I2C_CR1_ANFOFF_Pos (12U) |
| #define | I2C_CR1_ANFOFF_Msk (0x1UL << I2C_CR1_ANFOFF_Pos) |
| #define | I2C_CR1_ANFOFF I2C_CR1_ANFOFF_Msk |
| #define | I2C_CR1_TXDMAEN_Pos (14U) |
| #define | I2C_CR1_TXDMAEN_Msk (0x1UL << I2C_CR1_TXDMAEN_Pos) |
| #define | I2C_CR1_TXDMAEN I2C_CR1_TXDMAEN_Msk |
| #define | I2C_CR1_RXDMAEN_Pos (15U) |
| #define | I2C_CR1_RXDMAEN_Msk (0x1UL << I2C_CR1_RXDMAEN_Pos) |
| #define | I2C_CR1_RXDMAEN I2C_CR1_RXDMAEN_Msk |
| #define | I2C_CR1_SBC_Pos (16U) |
| #define | I2C_CR1_SBC_Msk (0x1UL << I2C_CR1_SBC_Pos) |
| #define | I2C_CR1_SBC I2C_CR1_SBC_Msk |
| #define | I2C_CR1_NOSTRETCH_Pos (17U) |
| #define | I2C_CR1_NOSTRETCH_Msk (0x1UL << I2C_CR1_NOSTRETCH_Pos) |
| #define | I2C_CR1_NOSTRETCH I2C_CR1_NOSTRETCH_Msk |
| #define | I2C_CR1_WUPEN_Pos (18U) |
| #define | I2C_CR1_WUPEN_Msk (0x1UL << I2C_CR1_WUPEN_Pos) |
| #define | I2C_CR1_WUPEN I2C_CR1_WUPEN_Msk |
| #define | I2C_CR1_GCEN_Pos (19U) |
| #define | I2C_CR1_GCEN_Msk (0x1UL << I2C_CR1_GCEN_Pos) |
| #define | I2C_CR1_GCEN I2C_CR1_GCEN_Msk |
| #define | I2C_CR1_SMBHEN_Pos (20U) |
| #define | I2C_CR1_SMBHEN_Msk (0x1UL << I2C_CR1_SMBHEN_Pos) |
| #define | I2C_CR1_SMBHEN I2C_CR1_SMBHEN_Msk |
| #define | I2C_CR1_SMBDEN_Pos (21U) |
| #define | I2C_CR1_SMBDEN_Msk (0x1UL << I2C_CR1_SMBDEN_Pos) |
| #define | I2C_CR1_SMBDEN I2C_CR1_SMBDEN_Msk |
| #define | I2C_CR1_ALERTEN_Pos (22U) |
| #define | I2C_CR1_ALERTEN_Msk (0x1UL << I2C_CR1_ALERTEN_Pos) |
| #define | I2C_CR1_ALERTEN I2C_CR1_ALERTEN_Msk |
| #define | I2C_CR1_PECEN_Pos (23U) |
| #define | I2C_CR1_PECEN_Msk (0x1UL << I2C_CR1_PECEN_Pos) |
| #define | I2C_CR1_PECEN I2C_CR1_PECEN_Msk |
| #define | I2C_CR2_SADD_Pos (0U) |
| #define | I2C_CR2_SADD_Msk (0x3FFUL << I2C_CR2_SADD_Pos) |
| #define | I2C_CR2_SADD I2C_CR2_SADD_Msk |
| #define | I2C_CR2_RD_WRN_Pos (10U) |
| #define | I2C_CR2_RD_WRN_Msk (0x1UL << I2C_CR2_RD_WRN_Pos) |
| #define | I2C_CR2_RD_WRN I2C_CR2_RD_WRN_Msk |
| #define | I2C_CR2_ADD10_Pos (11U) |
| #define | I2C_CR2_ADD10_Msk (0x1UL << I2C_CR2_ADD10_Pos) |
| #define | I2C_CR2_ADD10 I2C_CR2_ADD10_Msk |
| #define | I2C_CR2_HEAD10R_Pos (12U) |
| #define | I2C_CR2_HEAD10R_Msk (0x1UL << I2C_CR2_HEAD10R_Pos) |
| #define | I2C_CR2_HEAD10R I2C_CR2_HEAD10R_Msk |
| #define | I2C_CR2_START_Pos (13U) |
| #define | I2C_CR2_START_Msk (0x1UL << I2C_CR2_START_Pos) |
| #define | I2C_CR2_START I2C_CR2_START_Msk |
| #define | I2C_CR2_STOP_Pos (14U) |
| #define | I2C_CR2_STOP_Msk (0x1UL << I2C_CR2_STOP_Pos) |
| #define | I2C_CR2_STOP I2C_CR2_STOP_Msk |
| #define | I2C_CR2_NACK_Pos (15U) |
| #define | I2C_CR2_NACK_Msk (0x1UL << I2C_CR2_NACK_Pos) |
| #define | I2C_CR2_NACK I2C_CR2_NACK_Msk |
| #define | I2C_CR2_NBYTES_Pos (16U) |
| #define | I2C_CR2_NBYTES_Msk (0xFFUL << I2C_CR2_NBYTES_Pos) |
| #define | I2C_CR2_NBYTES I2C_CR2_NBYTES_Msk |
| #define | I2C_CR2_RELOAD_Pos (24U) |
| #define | I2C_CR2_RELOAD_Msk (0x1UL << I2C_CR2_RELOAD_Pos) |
| #define | I2C_CR2_RELOAD I2C_CR2_RELOAD_Msk |
| #define | I2C_CR2_AUTOEND_Pos (25U) |
| #define | I2C_CR2_AUTOEND_Msk (0x1UL << I2C_CR2_AUTOEND_Pos) |
| #define | I2C_CR2_AUTOEND I2C_CR2_AUTOEND_Msk |
| #define | I2C_CR2_PECBYTE_Pos (26U) |
| #define | I2C_CR2_PECBYTE_Msk (0x1UL << I2C_CR2_PECBYTE_Pos) |
| #define | I2C_CR2_PECBYTE I2C_CR2_PECBYTE_Msk |
| #define | I2C_OAR1_OA1_Pos (0U) |
| #define | I2C_OAR1_OA1_Msk (0x3FFUL << I2C_OAR1_OA1_Pos) |
| #define | I2C_OAR1_OA1 I2C_OAR1_OA1_Msk |
| #define | I2C_OAR1_OA1MODE_Pos (10U) |
| #define | I2C_OAR1_OA1MODE_Msk (0x1UL << I2C_OAR1_OA1MODE_Pos) |
| #define | I2C_OAR1_OA1MODE I2C_OAR1_OA1MODE_Msk |
| #define | I2C_OAR1_OA1EN_Pos (15U) |
| #define | I2C_OAR1_OA1EN_Msk (0x1UL << I2C_OAR1_OA1EN_Pos) |
| #define | I2C_OAR1_OA1EN I2C_OAR1_OA1EN_Msk |
| #define | I2C_OAR2_OA2_Pos (1U) |
| #define | I2C_OAR2_OA2_Msk (0x7FUL << I2C_OAR2_OA2_Pos) |
| #define | I2C_OAR2_OA2 I2C_OAR2_OA2_Msk |
| #define | I2C_OAR2_OA2MSK_Pos (8U) |
| #define | I2C_OAR2_OA2MSK_Msk (0x7UL << I2C_OAR2_OA2MSK_Pos) |
| #define | I2C_OAR2_OA2MSK I2C_OAR2_OA2MSK_Msk |
| #define | I2C_OAR2_OA2NOMASK 0x00000000UL |
| #define | I2C_OAR2_OA2MASK01_Pos (8U) |
| #define | I2C_OAR2_OA2MASK01_Msk (0x1UL << I2C_OAR2_OA2MASK01_Pos) |
| #define | I2C_OAR2_OA2MASK01 I2C_OAR2_OA2MASK01_Msk |
| #define | I2C_OAR2_OA2MASK02_Pos (9U) |
| #define | I2C_OAR2_OA2MASK02_Msk (0x1UL << I2C_OAR2_OA2MASK02_Pos) |
| #define | I2C_OAR2_OA2MASK02 I2C_OAR2_OA2MASK02_Msk |
| #define | I2C_OAR2_OA2MASK03_Pos (8U) |
| #define | I2C_OAR2_OA2MASK03_Msk (0x3UL << I2C_OAR2_OA2MASK03_Pos) |
| #define | I2C_OAR2_OA2MASK03 I2C_OAR2_OA2MASK03_Msk |
| #define | I2C_OAR2_OA2MASK04_Pos (10U) |
| #define | I2C_OAR2_OA2MASK04_Msk (0x1UL << I2C_OAR2_OA2MASK04_Pos) |
| #define | I2C_OAR2_OA2MASK04 I2C_OAR2_OA2MASK04_Msk |
| #define | I2C_OAR2_OA2MASK05_Pos (8U) |
| #define | I2C_OAR2_OA2MASK05_Msk (0x5UL << I2C_OAR2_OA2MASK05_Pos) |
| #define | I2C_OAR2_OA2MASK05 I2C_OAR2_OA2MASK05_Msk |
| #define | I2C_OAR2_OA2MASK06_Pos (9U) |
| #define | I2C_OAR2_OA2MASK06_Msk (0x3UL << I2C_OAR2_OA2MASK06_Pos) |
| #define | I2C_OAR2_OA2MASK06 I2C_OAR2_OA2MASK06_Msk |
| #define | I2C_OAR2_OA2MASK07_Pos (8U) |
| #define | I2C_OAR2_OA2MASK07_Msk (0x7UL << I2C_OAR2_OA2MASK07_Pos) |
| #define | I2C_OAR2_OA2MASK07 I2C_OAR2_OA2MASK07_Msk |
| #define | I2C_OAR2_OA2EN_Pos (15U) |
| #define | I2C_OAR2_OA2EN_Msk (0x1UL << I2C_OAR2_OA2EN_Pos) |
| #define | I2C_OAR2_OA2EN I2C_OAR2_OA2EN_Msk |
| #define | I2C_TIMINGR_SCLL_Pos (0U) |
| #define | I2C_TIMINGR_SCLL_Msk (0xFFUL << I2C_TIMINGR_SCLL_Pos) |
| #define | I2C_TIMINGR_SCLL I2C_TIMINGR_SCLL_Msk |
| #define | I2C_TIMINGR_SCLH_Pos (8U) |
| #define | I2C_TIMINGR_SCLH_Msk (0xFFUL << I2C_TIMINGR_SCLH_Pos) |
| #define | I2C_TIMINGR_SCLH I2C_TIMINGR_SCLH_Msk |
| #define | I2C_TIMINGR_SDADEL_Pos (16U) |
| #define | I2C_TIMINGR_SDADEL_Msk (0xFUL << I2C_TIMINGR_SDADEL_Pos) |
| #define | I2C_TIMINGR_SDADEL I2C_TIMINGR_SDADEL_Msk |
| #define | I2C_TIMINGR_SCLDEL_Pos (20U) |
| #define | I2C_TIMINGR_SCLDEL_Msk (0xFUL << I2C_TIMINGR_SCLDEL_Pos) |
| #define | I2C_TIMINGR_SCLDEL I2C_TIMINGR_SCLDEL_Msk |
| #define | I2C_TIMINGR_PRESC_Pos (28U) |
| #define | I2C_TIMINGR_PRESC_Msk (0xFUL << I2C_TIMINGR_PRESC_Pos) |
| #define | I2C_TIMINGR_PRESC I2C_TIMINGR_PRESC_Msk |
| #define | I2C_TIMEOUTR_TIMEOUTA_Pos (0U) |
| #define | I2C_TIMEOUTR_TIMEOUTA_Msk (0xFFFUL << I2C_TIMEOUTR_TIMEOUTA_Pos) |
| #define | I2C_TIMEOUTR_TIMEOUTA I2C_TIMEOUTR_TIMEOUTA_Msk |
| #define | I2C_TIMEOUTR_TIDLE_Pos (12U) |
| #define | I2C_TIMEOUTR_TIDLE_Msk (0x1UL << I2C_TIMEOUTR_TIDLE_Pos) |
| #define | I2C_TIMEOUTR_TIDLE I2C_TIMEOUTR_TIDLE_Msk |
| #define | I2C_TIMEOUTR_TIMOUTEN_Pos (15U) |
| #define | I2C_TIMEOUTR_TIMOUTEN_Msk (0x1UL << I2C_TIMEOUTR_TIMOUTEN_Pos) |
| #define | I2C_TIMEOUTR_TIMOUTEN I2C_TIMEOUTR_TIMOUTEN_Msk |
| #define | I2C_TIMEOUTR_TIMEOUTB_Pos (16U) |
| #define | I2C_TIMEOUTR_TIMEOUTB_Msk (0xFFFUL << I2C_TIMEOUTR_TIMEOUTB_Pos) |
| #define | I2C_TIMEOUTR_TIMEOUTB I2C_TIMEOUTR_TIMEOUTB_Msk |
| #define | I2C_TIMEOUTR_TEXTEN_Pos (31U) |
| #define | I2C_TIMEOUTR_TEXTEN_Msk (0x1UL << I2C_TIMEOUTR_TEXTEN_Pos) |
| #define | I2C_TIMEOUTR_TEXTEN I2C_TIMEOUTR_TEXTEN_Msk |
| #define | I2C_ISR_TXE_Pos (0U) |
| #define | I2C_ISR_TXE_Msk (0x1UL << I2C_ISR_TXE_Pos) |
| #define | I2C_ISR_TXE I2C_ISR_TXE_Msk |
| #define | I2C_ISR_TXIS_Pos (1U) |
| #define | I2C_ISR_TXIS_Msk (0x1UL << I2C_ISR_TXIS_Pos) |
| #define | I2C_ISR_TXIS I2C_ISR_TXIS_Msk |
| #define | I2C_ISR_RXNE_Pos (2U) |
| #define | I2C_ISR_RXNE_Msk (0x1UL << I2C_ISR_RXNE_Pos) |
| #define | I2C_ISR_RXNE I2C_ISR_RXNE_Msk |
| #define | I2C_ISR_ADDR_Pos (3U) |
| #define | I2C_ISR_ADDR_Msk (0x1UL << I2C_ISR_ADDR_Pos) |
| #define | I2C_ISR_ADDR I2C_ISR_ADDR_Msk |
| #define | I2C_ISR_NACKF_Pos (4U) |
| #define | I2C_ISR_NACKF_Msk (0x1UL << I2C_ISR_NACKF_Pos) |
| #define | I2C_ISR_NACKF I2C_ISR_NACKF_Msk |
| #define | I2C_ISR_STOPF_Pos (5U) |
| #define | I2C_ISR_STOPF_Msk (0x1UL << I2C_ISR_STOPF_Pos) |
| #define | I2C_ISR_STOPF I2C_ISR_STOPF_Msk |
| #define | I2C_ISR_TC_Pos (6U) |
| #define | I2C_ISR_TC_Msk (0x1UL << I2C_ISR_TC_Pos) |
| #define | I2C_ISR_TC I2C_ISR_TC_Msk |
| #define | I2C_ISR_TCR_Pos (7U) |
| #define | I2C_ISR_TCR_Msk (0x1UL << I2C_ISR_TCR_Pos) |
| #define | I2C_ISR_TCR I2C_ISR_TCR_Msk |
| #define | I2C_ISR_BERR_Pos (8U) |
| #define | I2C_ISR_BERR_Msk (0x1UL << I2C_ISR_BERR_Pos) |
| #define | I2C_ISR_BERR I2C_ISR_BERR_Msk |
| #define | I2C_ISR_ARLO_Pos (9U) |
| #define | I2C_ISR_ARLO_Msk (0x1UL << I2C_ISR_ARLO_Pos) |
| #define | I2C_ISR_ARLO I2C_ISR_ARLO_Msk |
| #define | I2C_ISR_OVR_Pos (10U) |
| #define | I2C_ISR_OVR_Msk (0x1UL << I2C_ISR_OVR_Pos) |
| #define | I2C_ISR_OVR I2C_ISR_OVR_Msk |
| #define | I2C_ISR_PECERR_Pos (11U) |
| #define | I2C_ISR_PECERR_Msk (0x1UL << I2C_ISR_PECERR_Pos) |
| #define | I2C_ISR_PECERR I2C_ISR_PECERR_Msk |
| #define | I2C_ISR_TIMEOUT_Pos (12U) |
| #define | I2C_ISR_TIMEOUT_Msk (0x1UL << I2C_ISR_TIMEOUT_Pos) |
| #define | I2C_ISR_TIMEOUT I2C_ISR_TIMEOUT_Msk |
| #define | I2C_ISR_ALERT_Pos (13U) |
| #define | I2C_ISR_ALERT_Msk (0x1UL << I2C_ISR_ALERT_Pos) |
| #define | I2C_ISR_ALERT I2C_ISR_ALERT_Msk |
| #define | I2C_ISR_BUSY_Pos (15U) |
| #define | I2C_ISR_BUSY_Msk (0x1UL << I2C_ISR_BUSY_Pos) |
| #define | I2C_ISR_BUSY I2C_ISR_BUSY_Msk |
| #define | I2C_ISR_DIR_Pos (16U) |
| #define | I2C_ISR_DIR_Msk (0x1UL << I2C_ISR_DIR_Pos) |
| #define | I2C_ISR_DIR I2C_ISR_DIR_Msk |
| #define | I2C_ISR_ADDCODE_Pos (17U) |
| #define | I2C_ISR_ADDCODE_Msk (0x7FUL << I2C_ISR_ADDCODE_Pos) |
| #define | I2C_ISR_ADDCODE I2C_ISR_ADDCODE_Msk |
| #define | I2C_ICR_ADDRCF_Pos (3U) |
| #define | I2C_ICR_ADDRCF_Msk (0x1UL << I2C_ICR_ADDRCF_Pos) |
| #define | I2C_ICR_ADDRCF I2C_ICR_ADDRCF_Msk |
| #define | I2C_ICR_NACKCF_Pos (4U) |
| #define | I2C_ICR_NACKCF_Msk (0x1UL << I2C_ICR_NACKCF_Pos) |
| #define | I2C_ICR_NACKCF I2C_ICR_NACKCF_Msk |
| #define | I2C_ICR_STOPCF_Pos (5U) |
| #define | I2C_ICR_STOPCF_Msk (0x1UL << I2C_ICR_STOPCF_Pos) |
| #define | I2C_ICR_STOPCF I2C_ICR_STOPCF_Msk |
| #define | I2C_ICR_BERRCF_Pos (8U) |
| #define | I2C_ICR_BERRCF_Msk (0x1UL << I2C_ICR_BERRCF_Pos) |
| #define | I2C_ICR_BERRCF I2C_ICR_BERRCF_Msk |
| #define | I2C_ICR_ARLOCF_Pos (9U) |
| #define | I2C_ICR_ARLOCF_Msk (0x1UL << I2C_ICR_ARLOCF_Pos) |
| #define | I2C_ICR_ARLOCF I2C_ICR_ARLOCF_Msk |
| #define | I2C_ICR_OVRCF_Pos (10U) |
| #define | I2C_ICR_OVRCF_Msk (0x1UL << I2C_ICR_OVRCF_Pos) |
| #define | I2C_ICR_OVRCF I2C_ICR_OVRCF_Msk |
| #define | I2C_ICR_PECCF_Pos (11U) |
| #define | I2C_ICR_PECCF_Msk (0x1UL << I2C_ICR_PECCF_Pos) |
| #define | I2C_ICR_PECCF I2C_ICR_PECCF_Msk |
| #define | I2C_ICR_TIMOUTCF_Pos (12U) |
| #define | I2C_ICR_TIMOUTCF_Msk (0x1UL << I2C_ICR_TIMOUTCF_Pos) |
| #define | I2C_ICR_TIMOUTCF I2C_ICR_TIMOUTCF_Msk |
| #define | I2C_ICR_ALERTCF_Pos (13U) |
| #define | I2C_ICR_ALERTCF_Msk (0x1UL << I2C_ICR_ALERTCF_Pos) |
| #define | I2C_ICR_ALERTCF I2C_ICR_ALERTCF_Msk |
| #define | I2C_PECR_PEC_Pos (0U) |
| #define | I2C_PECR_PEC_Msk (0xFFUL << I2C_PECR_PEC_Pos) |
| #define | I2C_PECR_PEC I2C_PECR_PEC_Msk |
| #define | I2C_RXDR_RXDATA_Pos (0U) |
| #define | I2C_RXDR_RXDATA_Msk (0xFFUL << I2C_RXDR_RXDATA_Pos) |
| #define | I2C_RXDR_RXDATA I2C_RXDR_RXDATA_Msk |
| #define | I2C_TXDR_TXDATA_Pos (0U) |
| #define | I2C_TXDR_TXDATA_Msk (0xFFUL << I2C_TXDR_TXDATA_Pos) |
| #define | I2C_TXDR_TXDATA I2C_TXDR_TXDATA_Msk |
| #define | IWDG_KR_KEY_Pos (0U) |
| #define | IWDG_KR_KEY_Msk (0xFFFFUL << IWDG_KR_KEY_Pos) |
| #define | IWDG_KR_KEY IWDG_KR_KEY_Msk |
| #define | IWDG_PR_PR_Pos (0U) |
| #define | IWDG_PR_PR_Msk (0x7UL << IWDG_PR_PR_Pos) |
| #define | IWDG_PR_PR IWDG_PR_PR_Msk |
| #define | IWDG_PR_PR_0 (0x1UL << IWDG_PR_PR_Pos) |
| #define | IWDG_PR_PR_1 (0x2UL << IWDG_PR_PR_Pos) |
| #define | IWDG_PR_PR_2 (0x4UL << IWDG_PR_PR_Pos) |
| #define | IWDG_RLR_RL_Pos (0U) |
| #define | IWDG_RLR_RL_Msk (0xFFFUL << IWDG_RLR_RL_Pos) |
| #define | IWDG_RLR_RL IWDG_RLR_RL_Msk |
| #define | IWDG_SR_PVU_Pos (0U) |
| #define | IWDG_SR_PVU_Msk (0x1UL << IWDG_SR_PVU_Pos) |
| #define | IWDG_SR_PVU IWDG_SR_PVU_Msk |
| #define | IWDG_SR_RVU_Pos (1U) |
| #define | IWDG_SR_RVU_Msk (0x1UL << IWDG_SR_RVU_Pos) |
| #define | IWDG_SR_RVU IWDG_SR_RVU_Msk |
| #define | IWDG_SR_WVU_Pos (2U) |
| #define | IWDG_SR_WVU_Msk (0x1UL << IWDG_SR_WVU_Pos) |
| #define | IWDG_SR_WVU IWDG_SR_WVU_Msk |
| #define | IWDG_WINR_WIN_Pos (0U) |
| #define | IWDG_WINR_WIN_Msk (0xFFFUL << IWDG_WINR_WIN_Pos) |
| #define | IWDG_WINR_WIN IWDG_WINR_WIN_Msk |
| #define | JPEG_CONFR0_START_Pos (0U) |
| #define | JPEG_CONFR0_START_Msk (0x1UL << JPEG_CONFR0_START_Pos) |
| #define | JPEG_CONFR0_START JPEG_CONFR0_START_Msk |
| #define | JPEG_CONFR1_NF_Pos (0U) |
| #define | JPEG_CONFR1_NF_Msk (0x3UL << JPEG_CONFR1_NF_Pos) |
| #define | JPEG_CONFR1_NF JPEG_CONFR1_NF_Msk |
| #define | JPEG_CONFR1_NF_0 (0x1UL << JPEG_CONFR1_NF_Pos) |
| #define | JPEG_CONFR1_NF_1 (0x2UL << JPEG_CONFR1_NF_Pos) |
| #define | JPEG_CONFR1_DE_Pos (3U) |
| #define | JPEG_CONFR1_DE_Msk (0x1UL << JPEG_CONFR1_DE_Pos) |
| #define | JPEG_CONFR1_DE JPEG_CONFR1_DE_Msk |
| #define | JPEG_CONFR1_COLORSPACE_Pos (4U) |
| #define | JPEG_CONFR1_COLORSPACE_Msk (0x3UL << JPEG_CONFR1_COLORSPACE_Pos) |
| #define | JPEG_CONFR1_COLORSPACE JPEG_CONFR1_COLORSPACE_Msk |
| #define | JPEG_CONFR1_COLORSPACE_0 (0x1UL << JPEG_CONFR1_COLORSPACE_Pos) |
| #define | JPEG_CONFR1_COLORSPACE_1 (0x2UL << JPEG_CONFR1_COLORSPACE_Pos) |
| #define | JPEG_CONFR1_NS_Pos (6U) |
| #define | JPEG_CONFR1_NS_Msk (0x3UL << JPEG_CONFR1_NS_Pos) |
| #define | JPEG_CONFR1_NS JPEG_CONFR1_NS_Msk |
| #define | JPEG_CONFR1_NS_0 (0x1UL << JPEG_CONFR1_NS_Pos) |
| #define | JPEG_CONFR1_NS_1 (0x2UL << JPEG_CONFR1_NS_Pos) |
| #define | JPEG_CONFR1_HDR_Pos (8U) |
| #define | JPEG_CONFR1_HDR_Msk (0x1UL << JPEG_CONFR1_HDR_Pos) |
| #define | JPEG_CONFR1_HDR JPEG_CONFR1_HDR_Msk |
| #define | JPEG_CONFR1_YSIZE_Pos (16U) |
| #define | JPEG_CONFR1_YSIZE_Msk (0xFFFFUL << JPEG_CONFR1_YSIZE_Pos) |
| #define | JPEG_CONFR1_YSIZE JPEG_CONFR1_YSIZE_Msk |
| #define | JPEG_CONFR2_NMCU_Pos (0U) |
| #define | JPEG_CONFR2_NMCU_Msk (0x3FFFFFFUL << JPEG_CONFR2_NMCU_Pos) |
| #define | JPEG_CONFR2_NMCU JPEG_CONFR2_NMCU_Msk |
| #define | JPEG_CONFR3_XSIZE_Pos (16U) |
| #define | JPEG_CONFR3_XSIZE_Msk (0xFFFFUL << JPEG_CONFR3_XSIZE_Pos) |
| #define | JPEG_CONFR3_XSIZE JPEG_CONFR3_XSIZE_Msk |
| #define | JPEG_CONFR4_HD_Pos (0U) |
| #define | JPEG_CONFR4_HD_Msk (0x1UL << JPEG_CONFR4_HD_Pos) |
| #define | JPEG_CONFR4_HD JPEG_CONFR4_HD_Msk |
| #define | JPEG_CONFR4_HA_Pos (1U) |
| #define | JPEG_CONFR4_HA_Msk (0x1UL << JPEG_CONFR4_HA_Pos) |
| #define | JPEG_CONFR4_HA JPEG_CONFR4_HA_Msk |
| #define | JPEG_CONFR4_QT_Pos (2U) |
| #define | JPEG_CONFR4_QT_Msk (0x3UL << JPEG_CONFR4_QT_Pos) |
| #define | JPEG_CONFR4_QT JPEG_CONFR4_QT_Msk |
| #define | JPEG_CONFR4_QT_0 (0x1UL << JPEG_CONFR4_QT_Pos) |
| #define | JPEG_CONFR4_QT_1 (0x2UL << JPEG_CONFR4_QT_Pos) |
| #define | JPEG_CONFR4_NB_Pos (4U) |
| #define | JPEG_CONFR4_NB_Msk (0xFUL << JPEG_CONFR4_NB_Pos) |
| #define | JPEG_CONFR4_NB JPEG_CONFR4_NB_Msk |
| #define | JPEG_CONFR4_NB_0 (0x1UL << JPEG_CONFR4_NB_Pos) |
| #define | JPEG_CONFR4_NB_1 (0x2UL << JPEG_CONFR4_NB_Pos) |
| #define | JPEG_CONFR4_NB_2 (0x4UL << JPEG_CONFR4_NB_Pos) |
| #define | JPEG_CONFR4_NB_3 (0x8UL << JPEG_CONFR4_NB_Pos) |
| #define | JPEG_CONFR4_VSF_Pos (8U) |
| #define | JPEG_CONFR4_VSF_Msk (0xFUL << JPEG_CONFR4_VSF_Pos) |
| #define | JPEG_CONFR4_VSF JPEG_CONFR4_VSF_Msk |
| #define | JPEG_CONFR4_VSF_0 (0x1UL << JPEG_CONFR4_VSF_Pos) |
| #define | JPEG_CONFR4_VSF_1 (0x2UL << JPEG_CONFR4_VSF_Pos) |
| #define | JPEG_CONFR4_VSF_2 (0x4UL << JPEG_CONFR4_VSF_Pos) |
| #define | JPEG_CONFR4_VSF_3 (0x8UL << JPEG_CONFR4_VSF_Pos) |
| #define | JPEG_CONFR4_HSF_Pos (12U) |
| #define | JPEG_CONFR4_HSF_Msk (0xFUL << JPEG_CONFR4_HSF_Pos) |
| #define | JPEG_CONFR4_HSF JPEG_CONFR4_HSF_Msk |
| #define | JPEG_CONFR4_HSF_0 (0x1UL << JPEG_CONFR4_HSF_Pos) |
| #define | JPEG_CONFR4_HSF_1 (0x2UL << JPEG_CONFR4_HSF_Pos) |
| #define | JPEG_CONFR4_HSF_2 (0x4UL << JPEG_CONFR4_HSF_Pos) |
| #define | JPEG_CONFR4_HSF_3 (0x8UL << JPEG_CONFR4_HSF_Pos) |
| #define | JPEG_CONFR5_HD_Pos (0U) |
| #define | JPEG_CONFR5_HD_Msk (0x1UL << JPEG_CONFR5_HD_Pos) |
| #define | JPEG_CONFR5_HD JPEG_CONFR5_HD_Msk |
| #define | JPEG_CONFR5_HA_Pos (1U) |
| #define | JPEG_CONFR5_HA_Msk (0x1UL << JPEG_CONFR5_HA_Pos) |
| #define | JPEG_CONFR5_HA JPEG_CONFR5_HA_Msk |
| #define | JPEG_CONFR5_QT_Pos (2U) |
| #define | JPEG_CONFR5_QT_Msk (0x3UL << JPEG_CONFR5_QT_Pos) |
| #define | JPEG_CONFR5_QT JPEG_CONFR5_QT_Msk |
| #define | JPEG_CONFR5_QT_0 (0x1UL << JPEG_CONFR5_QT_Pos) |
| #define | JPEG_CONFR5_QT_1 (0x2UL << JPEG_CONFR5_QT_Pos) |
| #define | JPEG_CONFR5_NB_Pos (4U) |
| #define | JPEG_CONFR5_NB_Msk (0xFUL << JPEG_CONFR5_NB_Pos) |
| #define | JPEG_CONFR5_NB JPEG_CONFR5_NB_Msk |
| #define | JPEG_CONFR5_NB_0 (0x1UL << JPEG_CONFR5_NB_Pos) |
| #define | JPEG_CONFR5_NB_1 (0x2UL << JPEG_CONFR5_NB_Pos) |
| #define | JPEG_CONFR5_NB_2 (0x4UL << JPEG_CONFR5_NB_Pos) |
| #define | JPEG_CONFR5_NB_3 (0x8UL << JPEG_CONFR5_NB_Pos) |
| #define | JPEG_CONFR5_VSF_Pos (8U) |
| #define | JPEG_CONFR5_VSF_Msk (0xFUL << JPEG_CONFR5_VSF_Pos) |
| #define | JPEG_CONFR5_VSF JPEG_CONFR5_VSF_Msk |
| #define | JPEG_CONFR5_VSF_0 (0x1UL << JPEG_CONFR5_VSF_Pos) |
| #define | JPEG_CONFR5_VSF_1 (0x2UL << JPEG_CONFR5_VSF_Pos) |
| #define | JPEG_CONFR5_VSF_2 (0x4UL << JPEG_CONFR5_VSF_Pos) |
| #define | JPEG_CONFR5_VSF_3 (0x8UL << JPEG_CONFR5_VSF_Pos) |
| #define | JPEG_CONFR5_HSF_Pos (12U) |
| #define | JPEG_CONFR5_HSF_Msk (0xFUL << JPEG_CONFR5_HSF_Pos) |
| #define | JPEG_CONFR5_HSF JPEG_CONFR5_HSF_Msk |
| #define | JPEG_CONFR5_HSF_0 (0x1UL << JPEG_CONFR5_HSF_Pos) |
| #define | JPEG_CONFR5_HSF_1 (0x2UL << JPEG_CONFR5_HSF_Pos) |
| #define | JPEG_CONFR5_HSF_2 (0x4UL << JPEG_CONFR5_HSF_Pos) |
| #define | JPEG_CONFR5_HSF_3 (0x8UL << JPEG_CONFR5_HSF_Pos) |
| #define | JPEG_CONFR6_HD_Pos (0U) |
| #define | JPEG_CONFR6_HD_Msk (0x1UL << JPEG_CONFR6_HD_Pos) |
| #define | JPEG_CONFR6_HD JPEG_CONFR6_HD_Msk |
| #define | JPEG_CONFR6_HA_Pos (1U) |
| #define | JPEG_CONFR6_HA_Msk (0x1UL << JPEG_CONFR6_HA_Pos) |
| #define | JPEG_CONFR6_HA JPEG_CONFR6_HA_Msk |
| #define | JPEG_CONFR6_QT_Pos (2U) |
| #define | JPEG_CONFR6_QT_Msk (0x3UL << JPEG_CONFR6_QT_Pos) |
| #define | JPEG_CONFR6_QT JPEG_CONFR6_QT_Msk |
| #define | JPEG_CONFR6_QT_0 (0x1UL << JPEG_CONFR6_QT_Pos) |
| #define | JPEG_CONFR6_QT_1 (0x2UL << JPEG_CONFR6_QT_Pos) |
| #define | JPEG_CONFR6_NB_Pos (4U) |
| #define | JPEG_CONFR6_NB_Msk (0xFUL << JPEG_CONFR6_NB_Pos) |
| #define | JPEG_CONFR6_NB JPEG_CONFR6_NB_Msk |
| #define | JPEG_CONFR6_NB_0 (0x1UL << JPEG_CONFR6_NB_Pos) |
| #define | JPEG_CONFR6_NB_1 (0x2UL << JPEG_CONFR6_NB_Pos) |
| #define | JPEG_CONFR6_NB_2 (0x4UL << JPEG_CONFR6_NB_Pos) |
| #define | JPEG_CONFR6_NB_3 (0x8UL << JPEG_CONFR6_NB_Pos) |
| #define | JPEG_CONFR6_VSF_Pos (8U) |
| #define | JPEG_CONFR6_VSF_Msk (0xFUL << JPEG_CONFR6_VSF_Pos) |
| #define | JPEG_CONFR6_VSF JPEG_CONFR6_VSF_Msk |
| #define | JPEG_CONFR6_VSF_0 (0x1UL << JPEG_CONFR6_VSF_Pos) |
| #define | JPEG_CONFR6_VSF_1 (0x2UL << JPEG_CONFR6_VSF_Pos) |
| #define | JPEG_CONFR6_VSF_2 (0x4UL << JPEG_CONFR6_VSF_Pos) |
| #define | JPEG_CONFR6_VSF_3 (0x8UL << JPEG_CONFR6_VSF_Pos) |
| #define | JPEG_CONFR6_HSF_Pos (12U) |
| #define | JPEG_CONFR6_HSF_Msk (0xFUL << JPEG_CONFR6_HSF_Pos) |
| #define | JPEG_CONFR6_HSF JPEG_CONFR6_HSF_Msk |
| #define | JPEG_CONFR6_HSF_0 (0x1UL << JPEG_CONFR6_HSF_Pos) |
| #define | JPEG_CONFR6_HSF_1 (0x2UL << JPEG_CONFR6_HSF_Pos) |
| #define | JPEG_CONFR6_HSF_2 (0x4UL << JPEG_CONFR6_HSF_Pos) |
| #define | JPEG_CONFR6_HSF_3 (0x8UL << JPEG_CONFR6_HSF_Pos) |
| #define | JPEG_CONFR7_HD_Pos (0U) |
| #define | JPEG_CONFR7_HD_Msk (0x1UL << JPEG_CONFR7_HD_Pos) |
| #define | JPEG_CONFR7_HD JPEG_CONFR7_HD_Msk |
| #define | JPEG_CONFR7_HA_Pos (1U) |
| #define | JPEG_CONFR7_HA_Msk (0x1UL << JPEG_CONFR7_HA_Pos) |
| #define | JPEG_CONFR7_HA JPEG_CONFR7_HA_Msk |
| #define | JPEG_CONFR7_QT_Pos (2U) |
| #define | JPEG_CONFR7_QT_Msk (0x3UL << JPEG_CONFR7_QT_Pos) |
| #define | JPEG_CONFR7_QT JPEG_CONFR7_QT_Msk |
| #define | JPEG_CONFR7_QT_0 (0x1UL << JPEG_CONFR7_QT_Pos) |
| #define | JPEG_CONFR7_QT_1 (0x2UL << JPEG_CONFR7_QT_Pos) |
| #define | JPEG_CONFR7_NB_Pos (4U) |
| #define | JPEG_CONFR7_NB_Msk (0xFUL << JPEG_CONFR7_NB_Pos) |
| #define | JPEG_CONFR7_NB JPEG_CONFR7_NB_Msk |
| #define | JPEG_CONFR7_NB_0 (0x1UL << JPEG_CONFR7_NB_Pos) |
| #define | JPEG_CONFR7_NB_1 (0x2UL << JPEG_CONFR7_NB_Pos) |
| #define | JPEG_CONFR7_NB_2 (0x4UL << JPEG_CONFR7_NB_Pos) |
| #define | JPEG_CONFR7_NB_3 (0x8UL << JPEG_CONFR7_NB_Pos) |
| #define | JPEG_CONFR7_VSF_Pos (8U) |
| #define | JPEG_CONFR7_VSF_Msk (0xFUL << JPEG_CONFR7_VSF_Pos) |
| #define | JPEG_CONFR7_VSF JPEG_CONFR7_VSF_Msk |
| #define | JPEG_CONFR7_VSF_0 (0x1UL << JPEG_CONFR7_VSF_Pos) |
| #define | JPEG_CONFR7_VSF_1 (0x2UL << JPEG_CONFR7_VSF_Pos) |
| #define | JPEG_CONFR7_VSF_2 (0x4UL << JPEG_CONFR7_VSF_Pos) |
| #define | JPEG_CONFR7_VSF_3 (0x8UL << JPEG_CONFR7_VSF_Pos) |
| #define | JPEG_CONFR7_HSF_Pos (12U) |
| #define | JPEG_CONFR7_HSF_Msk (0xFUL << JPEG_CONFR7_HSF_Pos) |
| #define | JPEG_CONFR7_HSF JPEG_CONFR7_HSF_Msk |
| #define | JPEG_CONFR7_HSF_0 (0x1UL << JPEG_CONFR7_HSF_Pos) |
| #define | JPEG_CONFR7_HSF_1 (0x2UL << JPEG_CONFR7_HSF_Pos) |
| #define | JPEG_CONFR7_HSF_2 (0x4UL << JPEG_CONFR7_HSF_Pos) |
| #define | JPEG_CONFR7_HSF_3 (0x8UL << JPEG_CONFR7_HSF_Pos) |
| #define | JPEG_CR_JCEN_Pos (0U) |
| #define | JPEG_CR_JCEN_Msk (0x1UL << JPEG_CR_JCEN_Pos) |
| #define | JPEG_CR_JCEN JPEG_CR_JCEN_Msk |
| #define | JPEG_CR_IFTIE_Pos (1U) |
| #define | JPEG_CR_IFTIE_Msk (0x1UL << JPEG_CR_IFTIE_Pos) |
| #define | JPEG_CR_IFTIE JPEG_CR_IFTIE_Msk |
| #define | JPEG_CR_IFNFIE_Pos (2U) |
| #define | JPEG_CR_IFNFIE_Msk (0x1UL << JPEG_CR_IFNFIE_Pos) |
| #define | JPEG_CR_IFNFIE JPEG_CR_IFNFIE_Msk |
| #define | JPEG_CR_OFTIE_Pos (3U) |
| #define | JPEG_CR_OFTIE_Msk (0x1UL << JPEG_CR_OFTIE_Pos) |
| #define | JPEG_CR_OFTIE JPEG_CR_OFTIE_Msk |
| #define | JPEG_CR_OFNEIE_Pos (4U) |
| #define | JPEG_CR_OFNEIE_Msk (0x1UL << JPEG_CR_OFNEIE_Pos) |
| #define | JPEG_CR_OFNEIE JPEG_CR_OFNEIE_Msk |
| #define | JPEG_CR_EOCIE_Pos (5U) |
| #define | JPEG_CR_EOCIE_Msk (0x1UL << JPEG_CR_EOCIE_Pos) |
| #define | JPEG_CR_EOCIE JPEG_CR_EOCIE_Msk |
| #define | JPEG_CR_HPDIE_Pos (6U) |
| #define | JPEG_CR_HPDIE_Msk (0x1UL << JPEG_CR_HPDIE_Pos) |
| #define | JPEG_CR_HPDIE JPEG_CR_HPDIE_Msk |
| #define | JPEG_CR_IFF_Pos (13U) |
| #define | JPEG_CR_IFF_Msk (0x1UL << JPEG_CR_IFF_Pos) |
| #define | JPEG_CR_IFF JPEG_CR_IFF_Msk |
| #define | JPEG_CR_OFF_Pos (14U) |
| #define | JPEG_CR_OFF_Msk (0x1UL << JPEG_CR_OFF_Pos) |
| #define | JPEG_CR_OFF JPEG_CR_OFF_Msk |
| #define | JPEG_SR_IFTF_Pos (1U) |
| #define | JPEG_SR_IFTF_Msk (0x1UL << JPEG_SR_IFTF_Pos) |
| #define | JPEG_SR_IFTF JPEG_SR_IFTF_Msk |
| #define | JPEG_SR_IFNFF_Pos (2U) |
| #define | JPEG_SR_IFNFF_Msk (0x1UL << JPEG_SR_IFNFF_Pos) |
| #define | JPEG_SR_IFNFF JPEG_SR_IFNFF_Msk |
| #define | JPEG_SR_OFTF_Pos (3U) |
| #define | JPEG_SR_OFTF_Msk (0x1UL << JPEG_SR_OFTF_Pos) |
| #define | JPEG_SR_OFTF JPEG_SR_OFTF_Msk |
| #define | JPEG_SR_OFNEF_Pos (4U) |
| #define | JPEG_SR_OFNEF_Msk (0x1UL << JPEG_SR_OFNEF_Pos) |
| #define | JPEG_SR_OFNEF JPEG_SR_OFNEF_Msk |
| #define | JPEG_SR_EOCF_Pos (5U) |
| #define | JPEG_SR_EOCF_Msk (0x1UL << JPEG_SR_EOCF_Pos) |
| #define | JPEG_SR_EOCF JPEG_SR_EOCF_Msk |
| #define | JPEG_SR_HPDF_Pos (6U) |
| #define | JPEG_SR_HPDF_Msk (0x1UL << JPEG_SR_HPDF_Pos) |
| #define | JPEG_SR_HPDF JPEG_SR_HPDF_Msk |
| #define | JPEG_SR_COF_Pos (7U) |
| #define | JPEG_SR_COF_Msk (0x1UL << JPEG_SR_COF_Pos) |
| #define | JPEG_SR_COF JPEG_SR_COF_Msk |
| #define | JPEG_CFR_CEOCF_Pos (4U) |
| #define | JPEG_CFR_CEOCF_Msk (0x1UL << JPEG_CFR_CEOCF_Pos) |
| #define | JPEG_CFR_CEOCF JPEG_CFR_CEOCF_Msk |
| #define | JPEG_CFR_CHPDF_Pos (5U) |
| #define | JPEG_CFR_CHPDF_Msk (0x1UL << JPEG_CFR_CHPDF_Pos) |
| #define | JPEG_CFR_CHPDF JPEG_CFR_CHPDF_Msk |
| #define | JPEG_DIR_DATAIN_Pos (0U) |
| #define | JPEG_DIR_DATAIN_Msk (0xFFFFFFFFUL << JPEG_DIR_DATAIN_Pos) |
| #define | JPEG_DIR_DATAIN JPEG_DIR_DATAIN_Msk |
| #define | JPEG_DOR_DATAOUT_Pos (0U) |
| #define | JPEG_DOR_DATAOUT_Msk (0xFFFFFFFFUL << JPEG_DOR_DATAOUT_Pos) |
| #define | JPEG_DOR_DATAOUT JPEG_DOR_DATAOUT_Msk |
| #define | LTDC_SSCR_VSH_Pos (0U) |
| #define | LTDC_SSCR_VSH_Msk (0x7FFUL << LTDC_SSCR_VSH_Pos) |
| #define | LTDC_SSCR_VSH LTDC_SSCR_VSH_Msk |
| #define | LTDC_SSCR_HSW_Pos (16U) |
| #define | LTDC_SSCR_HSW_Msk (0xFFFUL << LTDC_SSCR_HSW_Pos) |
| #define | LTDC_SSCR_HSW LTDC_SSCR_HSW_Msk |
| #define | LTDC_BPCR_AVBP_Pos (0U) |
| #define | LTDC_BPCR_AVBP_Msk (0x7FFUL << LTDC_BPCR_AVBP_Pos) |
| #define | LTDC_BPCR_AVBP LTDC_BPCR_AVBP_Msk |
| #define | LTDC_BPCR_AHBP_Pos (16U) |
| #define | LTDC_BPCR_AHBP_Msk (0xFFFUL << LTDC_BPCR_AHBP_Pos) |
| #define | LTDC_BPCR_AHBP LTDC_BPCR_AHBP_Msk |
| #define | LTDC_AWCR_AAH_Pos (0U) |
| #define | LTDC_AWCR_AAH_Msk (0x7FFUL << LTDC_AWCR_AAH_Pos) |
| #define | LTDC_AWCR_AAH LTDC_AWCR_AAH_Msk |
| #define | LTDC_AWCR_AAW_Pos (16U) |
| #define | LTDC_AWCR_AAW_Msk (0xFFFUL << LTDC_AWCR_AAW_Pos) |
| #define | LTDC_AWCR_AAW LTDC_AWCR_AAW_Msk |
| #define | LTDC_TWCR_TOTALH_Pos (0U) |
| #define | LTDC_TWCR_TOTALH_Msk (0x7FFUL << LTDC_TWCR_TOTALH_Pos) |
| #define | LTDC_TWCR_TOTALH LTDC_TWCR_TOTALH_Msk |
| #define | LTDC_TWCR_TOTALW_Pos (16U) |
| #define | LTDC_TWCR_TOTALW_Msk (0xFFFUL << LTDC_TWCR_TOTALW_Pos) |
| #define | LTDC_TWCR_TOTALW LTDC_TWCR_TOTALW_Msk |
| #define | LTDC_GCR_LTDCEN_Pos (0U) |
| #define | LTDC_GCR_LTDCEN_Msk (0x1UL << LTDC_GCR_LTDCEN_Pos) |
| #define | LTDC_GCR_LTDCEN LTDC_GCR_LTDCEN_Msk |
| #define | LTDC_GCR_DBW_Pos (4U) |
| #define | LTDC_GCR_DBW_Msk (0x7UL << LTDC_GCR_DBW_Pos) |
| #define | LTDC_GCR_DBW LTDC_GCR_DBW_Msk |
| #define | LTDC_GCR_DGW_Pos (8U) |
| #define | LTDC_GCR_DGW_Msk (0x7UL << LTDC_GCR_DGW_Pos) |
| #define | LTDC_GCR_DGW LTDC_GCR_DGW_Msk |
| #define | LTDC_GCR_DRW_Pos (12U) |
| #define | LTDC_GCR_DRW_Msk (0x7UL << LTDC_GCR_DRW_Pos) |
| #define | LTDC_GCR_DRW LTDC_GCR_DRW_Msk |
| #define | LTDC_GCR_DEN_Pos (16U) |
| #define | LTDC_GCR_DEN_Msk (0x1UL << LTDC_GCR_DEN_Pos) |
| #define | LTDC_GCR_DEN LTDC_GCR_DEN_Msk |
| #define | LTDC_GCR_PCPOL_Pos (28U) |
| #define | LTDC_GCR_PCPOL_Msk (0x1UL << LTDC_GCR_PCPOL_Pos) |
| #define | LTDC_GCR_PCPOL LTDC_GCR_PCPOL_Msk |
| #define | LTDC_GCR_DEPOL_Pos (29U) |
| #define | LTDC_GCR_DEPOL_Msk (0x1UL << LTDC_GCR_DEPOL_Pos) |
| #define | LTDC_GCR_DEPOL LTDC_GCR_DEPOL_Msk |
| #define | LTDC_GCR_VSPOL_Pos (30U) |
| #define | LTDC_GCR_VSPOL_Msk (0x1UL << LTDC_GCR_VSPOL_Pos) |
| #define | LTDC_GCR_VSPOL LTDC_GCR_VSPOL_Msk |
| #define | LTDC_GCR_HSPOL_Pos (31U) |
| #define | LTDC_GCR_HSPOL_Msk (0x1UL << LTDC_GCR_HSPOL_Pos) |
| #define | LTDC_GCR_HSPOL LTDC_GCR_HSPOL_Msk |
| #define | LTDC_SRCR_IMR_Pos (0U) |
| #define | LTDC_SRCR_IMR_Msk (0x1UL << LTDC_SRCR_IMR_Pos) |
| #define | LTDC_SRCR_IMR LTDC_SRCR_IMR_Msk |
| #define | LTDC_SRCR_VBR_Pos (1U) |
| #define | LTDC_SRCR_VBR_Msk (0x1UL << LTDC_SRCR_VBR_Pos) |
| #define | LTDC_SRCR_VBR LTDC_SRCR_VBR_Msk |
| #define | LTDC_BCCR_BCBLUE_Pos (0U) |
| #define | LTDC_BCCR_BCBLUE_Msk (0xFFUL << LTDC_BCCR_BCBLUE_Pos) |
| #define | LTDC_BCCR_BCBLUE LTDC_BCCR_BCBLUE_Msk |
| #define | LTDC_BCCR_BCGREEN_Pos (8U) |
| #define | LTDC_BCCR_BCGREEN_Msk (0xFFUL << LTDC_BCCR_BCGREEN_Pos) |
| #define | LTDC_BCCR_BCGREEN LTDC_BCCR_BCGREEN_Msk |
| #define | LTDC_BCCR_BCRED_Pos (16U) |
| #define | LTDC_BCCR_BCRED_Msk (0xFFUL << LTDC_BCCR_BCRED_Pos) |
| #define | LTDC_BCCR_BCRED LTDC_BCCR_BCRED_Msk |
| #define | LTDC_IER_LIE_Pos (0U) |
| #define | LTDC_IER_LIE_Msk (0x1UL << LTDC_IER_LIE_Pos) |
| #define | LTDC_IER_LIE LTDC_IER_LIE_Msk |
| #define | LTDC_IER_FUIE_Pos (1U) |
| #define | LTDC_IER_FUIE_Msk (0x1UL << LTDC_IER_FUIE_Pos) |
| #define | LTDC_IER_FUIE LTDC_IER_FUIE_Msk |
| #define | LTDC_IER_TERRIE_Pos (2U) |
| #define | LTDC_IER_TERRIE_Msk (0x1UL << LTDC_IER_TERRIE_Pos) |
| #define | LTDC_IER_TERRIE LTDC_IER_TERRIE_Msk |
| #define | LTDC_IER_RRIE_Pos (3U) |
| #define | LTDC_IER_RRIE_Msk (0x1UL << LTDC_IER_RRIE_Pos) |
| #define | LTDC_IER_RRIE LTDC_IER_RRIE_Msk |
| #define | LTDC_ISR_LIF_Pos (0U) |
| #define | LTDC_ISR_LIF_Msk (0x1UL << LTDC_ISR_LIF_Pos) |
| #define | LTDC_ISR_LIF LTDC_ISR_LIF_Msk |
| #define | LTDC_ISR_FUIF_Pos (1U) |
| #define | LTDC_ISR_FUIF_Msk (0x1UL << LTDC_ISR_FUIF_Pos) |
| #define | LTDC_ISR_FUIF LTDC_ISR_FUIF_Msk |
| #define | LTDC_ISR_TERRIF_Pos (2U) |
| #define | LTDC_ISR_TERRIF_Msk (0x1UL << LTDC_ISR_TERRIF_Pos) |
| #define | LTDC_ISR_TERRIF LTDC_ISR_TERRIF_Msk |
| #define | LTDC_ISR_RRIF_Pos (3U) |
| #define | LTDC_ISR_RRIF_Msk (0x1UL << LTDC_ISR_RRIF_Pos) |
| #define | LTDC_ISR_RRIF LTDC_ISR_RRIF_Msk |
| #define | LTDC_ICR_CLIF_Pos (0U) |
| #define | LTDC_ICR_CLIF_Msk (0x1UL << LTDC_ICR_CLIF_Pos) |
| #define | LTDC_ICR_CLIF LTDC_ICR_CLIF_Msk |
| #define | LTDC_ICR_CFUIF_Pos (1U) |
| #define | LTDC_ICR_CFUIF_Msk (0x1UL << LTDC_ICR_CFUIF_Pos) |
| #define | LTDC_ICR_CFUIF LTDC_ICR_CFUIF_Msk |
| #define | LTDC_ICR_CTERRIF_Pos (2U) |
| #define | LTDC_ICR_CTERRIF_Msk (0x1UL << LTDC_ICR_CTERRIF_Pos) |
| #define | LTDC_ICR_CTERRIF LTDC_ICR_CTERRIF_Msk |
| #define | LTDC_ICR_CRRIF_Pos (3U) |
| #define | LTDC_ICR_CRRIF_Msk (0x1UL << LTDC_ICR_CRRIF_Pos) |
| #define | LTDC_ICR_CRRIF LTDC_ICR_CRRIF_Msk |
| #define | LTDC_LIPCR_LIPOS_Pos (0U) |
| #define | LTDC_LIPCR_LIPOS_Msk (0x7FFUL << LTDC_LIPCR_LIPOS_Pos) |
| #define | LTDC_LIPCR_LIPOS LTDC_LIPCR_LIPOS_Msk |
| #define | LTDC_CPSR_CYPOS_Pos (0U) |
| #define | LTDC_CPSR_CYPOS_Msk (0xFFFFUL << LTDC_CPSR_CYPOS_Pos) |
| #define | LTDC_CPSR_CYPOS LTDC_CPSR_CYPOS_Msk |
| #define | LTDC_CPSR_CXPOS_Pos (16U) |
| #define | LTDC_CPSR_CXPOS_Msk (0xFFFFUL << LTDC_CPSR_CXPOS_Pos) |
| #define | LTDC_CPSR_CXPOS LTDC_CPSR_CXPOS_Msk |
| #define | LTDC_CDSR_VDES_Pos (0U) |
| #define | LTDC_CDSR_VDES_Msk (0x1UL << LTDC_CDSR_VDES_Pos) |
| #define | LTDC_CDSR_VDES LTDC_CDSR_VDES_Msk |
| #define | LTDC_CDSR_HDES_Pos (1U) |
| #define | LTDC_CDSR_HDES_Msk (0x1UL << LTDC_CDSR_HDES_Pos) |
| #define | LTDC_CDSR_HDES LTDC_CDSR_HDES_Msk |
| #define | LTDC_CDSR_VSYNCS_Pos (2U) |
| #define | LTDC_CDSR_VSYNCS_Msk (0x1UL << LTDC_CDSR_VSYNCS_Pos) |
| #define | LTDC_CDSR_VSYNCS LTDC_CDSR_VSYNCS_Msk |
| #define | LTDC_CDSR_HSYNCS_Pos (3U) |
| #define | LTDC_CDSR_HSYNCS_Msk (0x1UL << LTDC_CDSR_HSYNCS_Pos) |
| #define | LTDC_CDSR_HSYNCS LTDC_CDSR_HSYNCS_Msk |
| #define | LTDC_LxCR_LEN_Pos (0U) |
| #define | LTDC_LxCR_LEN_Msk (0x1UL << LTDC_LxCR_LEN_Pos) |
| #define | LTDC_LxCR_LEN LTDC_LxCR_LEN_Msk |
| #define | LTDC_LxCR_COLKEN_Pos (1U) |
| #define | LTDC_LxCR_COLKEN_Msk (0x1UL << LTDC_LxCR_COLKEN_Pos) |
| #define | LTDC_LxCR_COLKEN LTDC_LxCR_COLKEN_Msk |
| #define | LTDC_LxCR_CLUTEN_Pos (4U) |
| #define | LTDC_LxCR_CLUTEN_Msk (0x1UL << LTDC_LxCR_CLUTEN_Pos) |
| #define | LTDC_LxCR_CLUTEN LTDC_LxCR_CLUTEN_Msk |
| #define | LTDC_LxWHPCR_WHSTPOS_Pos (0U) |
| #define | LTDC_LxWHPCR_WHSTPOS_Msk (0xFFFUL << LTDC_LxWHPCR_WHSTPOS_Pos) |
| #define | LTDC_LxWHPCR_WHSTPOS LTDC_LxWHPCR_WHSTPOS_Msk |
| #define | LTDC_LxWHPCR_WHSPPOS_Pos (16U) |
| #define | LTDC_LxWHPCR_WHSPPOS_Msk (0xFFFFUL << LTDC_LxWHPCR_WHSPPOS_Pos) |
| #define | LTDC_LxWHPCR_WHSPPOS LTDC_LxWHPCR_WHSPPOS_Msk |
| #define | LTDC_LxWVPCR_WVSTPOS_Pos (0U) |
| #define | LTDC_LxWVPCR_WVSTPOS_Msk (0xFFFUL << LTDC_LxWVPCR_WVSTPOS_Pos) |
| #define | LTDC_LxWVPCR_WVSTPOS LTDC_LxWVPCR_WVSTPOS_Msk |
| #define | LTDC_LxWVPCR_WVSPPOS_Pos (16U) |
| #define | LTDC_LxWVPCR_WVSPPOS_Msk (0xFFFFUL << LTDC_LxWVPCR_WVSPPOS_Pos) |
| #define | LTDC_LxWVPCR_WVSPPOS LTDC_LxWVPCR_WVSPPOS_Msk |
| #define | LTDC_LxCKCR_CKBLUE_Pos (0U) |
| #define | LTDC_LxCKCR_CKBLUE_Msk (0xFFUL << LTDC_LxCKCR_CKBLUE_Pos) |
| #define | LTDC_LxCKCR_CKBLUE LTDC_LxCKCR_CKBLUE_Msk |
| #define | LTDC_LxCKCR_CKGREEN_Pos (8U) |
| #define | LTDC_LxCKCR_CKGREEN_Msk (0xFFUL << LTDC_LxCKCR_CKGREEN_Pos) |
| #define | LTDC_LxCKCR_CKGREEN LTDC_LxCKCR_CKGREEN_Msk |
| #define | LTDC_LxCKCR_CKRED_Pos (16U) |
| #define | LTDC_LxCKCR_CKRED_Msk (0xFFUL << LTDC_LxCKCR_CKRED_Pos) |
| #define | LTDC_LxCKCR_CKRED LTDC_LxCKCR_CKRED_Msk |
| #define | LTDC_LxPFCR_PF_Pos (0U) |
| #define | LTDC_LxPFCR_PF_Msk (0x7UL << LTDC_LxPFCR_PF_Pos) |
| #define | LTDC_LxPFCR_PF LTDC_LxPFCR_PF_Msk |
| #define | LTDC_LxCACR_CONSTA_Pos (0U) |
| #define | LTDC_LxCACR_CONSTA_Msk (0xFFUL << LTDC_LxCACR_CONSTA_Pos) |
| #define | LTDC_LxCACR_CONSTA LTDC_LxCACR_CONSTA_Msk |
| #define | LTDC_LxDCCR_DCBLUE_Pos (0U) |
| #define | LTDC_LxDCCR_DCBLUE_Msk (0xFFUL << LTDC_LxDCCR_DCBLUE_Pos) |
| #define | LTDC_LxDCCR_DCBLUE LTDC_LxDCCR_DCBLUE_Msk |
| #define | LTDC_LxDCCR_DCGREEN_Pos (8U) |
| #define | LTDC_LxDCCR_DCGREEN_Msk (0xFFUL << LTDC_LxDCCR_DCGREEN_Pos) |
| #define | LTDC_LxDCCR_DCGREEN LTDC_LxDCCR_DCGREEN_Msk |
| #define | LTDC_LxDCCR_DCRED_Pos (16U) |
| #define | LTDC_LxDCCR_DCRED_Msk (0xFFUL << LTDC_LxDCCR_DCRED_Pos) |
| #define | LTDC_LxDCCR_DCRED LTDC_LxDCCR_DCRED_Msk |
| #define | LTDC_LxDCCR_DCALPHA_Pos (24U) |
| #define | LTDC_LxDCCR_DCALPHA_Msk (0xFFUL << LTDC_LxDCCR_DCALPHA_Pos) |
| #define | LTDC_LxDCCR_DCALPHA LTDC_LxDCCR_DCALPHA_Msk |
| #define | LTDC_LxBFCR_BF2_Pos (0U) |
| #define | LTDC_LxBFCR_BF2_Msk (0x7UL << LTDC_LxBFCR_BF2_Pos) |
| #define | LTDC_LxBFCR_BF2 LTDC_LxBFCR_BF2_Msk |
| #define | LTDC_LxBFCR_BF1_Pos (8U) |
| #define | LTDC_LxBFCR_BF1_Msk (0x7UL << LTDC_LxBFCR_BF1_Pos) |
| #define | LTDC_LxBFCR_BF1 LTDC_LxBFCR_BF1_Msk |
| #define | LTDC_LxCFBAR_CFBADD_Pos (0U) |
| #define | LTDC_LxCFBAR_CFBADD_Msk (0xFFFFFFFFUL << LTDC_LxCFBAR_CFBADD_Pos) |
| #define | LTDC_LxCFBAR_CFBADD LTDC_LxCFBAR_CFBADD_Msk |
| #define | LTDC_LxCFBLR_CFBLL_Pos (0U) |
| #define | LTDC_LxCFBLR_CFBLL_Msk (0x1FFFUL << LTDC_LxCFBLR_CFBLL_Pos) |
| #define | LTDC_LxCFBLR_CFBLL LTDC_LxCFBLR_CFBLL_Msk |
| #define | LTDC_LxCFBLR_CFBP_Pos (16U) |
| #define | LTDC_LxCFBLR_CFBP_Msk (0x1FFFUL << LTDC_LxCFBLR_CFBP_Pos) |
| #define | LTDC_LxCFBLR_CFBP LTDC_LxCFBLR_CFBP_Msk |
| #define | LTDC_LxCFBLNR_CFBLNBR_Pos (0U) |
| #define | LTDC_LxCFBLNR_CFBLNBR_Msk (0x7FFUL << LTDC_LxCFBLNR_CFBLNBR_Pos) |
| #define | LTDC_LxCFBLNR_CFBLNBR LTDC_LxCFBLNR_CFBLNBR_Msk |
| #define | LTDC_LxCLUTWR_BLUE_Pos (0U) |
| #define | LTDC_LxCLUTWR_BLUE_Msk (0xFFUL << LTDC_LxCLUTWR_BLUE_Pos) |
| #define | LTDC_LxCLUTWR_BLUE LTDC_LxCLUTWR_BLUE_Msk |
| #define | LTDC_LxCLUTWR_GREEN_Pos (8U) |
| #define | LTDC_LxCLUTWR_GREEN_Msk (0xFFUL << LTDC_LxCLUTWR_GREEN_Pos) |
| #define | LTDC_LxCLUTWR_GREEN LTDC_LxCLUTWR_GREEN_Msk |
| #define | LTDC_LxCLUTWR_RED_Pos (16U) |
| #define | LTDC_LxCLUTWR_RED_Msk (0xFFUL << LTDC_LxCLUTWR_RED_Pos) |
| #define | LTDC_LxCLUTWR_RED LTDC_LxCLUTWR_RED_Msk |
| #define | LTDC_LxCLUTWR_CLUTADD_Pos (24U) |
| #define | LTDC_LxCLUTWR_CLUTADD_Msk (0xFFUL << LTDC_LxCLUTWR_CLUTADD_Pos) |
| #define | LTDC_LxCLUTWR_CLUTADD LTDC_LxCLUTWR_CLUTADD_Msk |
| #define | MDMA_GISR0_GIF0_Pos (0U) |
| #define | MDMA_GISR0_GIF0_Msk (0x1UL << MDMA_GISR0_GIF0_Pos) |
| #define | MDMA_GISR0_GIF0 MDMA_GISR0_GIF0_Msk |
| #define | MDMA_GISR0_GIF1_Pos (1U) |
| #define | MDMA_GISR0_GIF1_Msk (0x1UL << MDMA_GISR0_GIF1_Pos) |
| #define | MDMA_GISR0_GIF1 MDMA_GISR0_GIF1_Msk |
| #define | MDMA_GISR0_GIF2_Pos (2U) |
| #define | MDMA_GISR0_GIF2_Msk (0x1UL << MDMA_GISR0_GIF2_Pos) |
| #define | MDMA_GISR0_GIF2 MDMA_GISR0_GIF2_Msk |
| #define | MDMA_GISR0_GIF3_Pos (3U) |
| #define | MDMA_GISR0_GIF3_Msk (0x1UL << MDMA_GISR0_GIF3_Pos) |
| #define | MDMA_GISR0_GIF3 MDMA_GISR0_GIF3_Msk |
| #define | MDMA_GISR0_GIF4_Pos (4U) |
| #define | MDMA_GISR0_GIF4_Msk (0x1UL << MDMA_GISR0_GIF4_Pos) |
| #define | MDMA_GISR0_GIF4 MDMA_GISR0_GIF4_Msk |
| #define | MDMA_GISR0_GIF5_Pos (5U) |
| #define | MDMA_GISR0_GIF5_Msk (0x1UL << MDMA_GISR0_GIF5_Pos) |
| #define | MDMA_GISR0_GIF5 MDMA_GISR0_GIF5_Msk |
| #define | MDMA_GISR0_GIF6_Pos (6U) |
| #define | MDMA_GISR0_GIF6_Msk (0x1UL << MDMA_GISR0_GIF6_Pos) |
| #define | MDMA_GISR0_GIF6 MDMA_GISR0_GIF6_Msk |
| #define | MDMA_GISR0_GIF7_Pos (7U) |
| #define | MDMA_GISR0_GIF7_Msk (0x1UL << MDMA_GISR0_GIF7_Pos) |
| #define | MDMA_GISR0_GIF7 MDMA_GISR0_GIF7_Msk |
| #define | MDMA_GISR0_GIF8_Pos (8U) |
| #define | MDMA_GISR0_GIF8_Msk (0x1UL << MDMA_GISR0_GIF8_Pos) |
| #define | MDMA_GISR0_GIF8 MDMA_GISR0_GIF8_Msk |
| #define | MDMA_GISR0_GIF9_Pos (9U) |
| #define | MDMA_GISR0_GIF9_Msk (0x1UL << MDMA_GISR0_GIF9_Pos) |
| #define | MDMA_GISR0_GIF9 MDMA_GISR0_GIF9_Msk |
| #define | MDMA_GISR0_GIF10_Pos (10U) |
| #define | MDMA_GISR0_GIF10_Msk (0x1UL << MDMA_GISR0_GIF10_Pos) |
| #define | MDMA_GISR0_GIF10 MDMA_GISR0_GIF10_Msk |
| #define | MDMA_GISR0_GIF11_Pos (11U) |
| #define | MDMA_GISR0_GIF11_Msk (0x1UL << MDMA_GISR0_GIF11_Pos) |
| #define | MDMA_GISR0_GIF11 MDMA_GISR0_GIF11_Msk |
| #define | MDMA_GISR0_GIF12_Pos (12U) |
| #define | MDMA_GISR0_GIF12_Msk (0x1UL << MDMA_GISR0_GIF12_Pos) |
| #define | MDMA_GISR0_GIF12 MDMA_GISR0_GIF12_Msk |
| #define | MDMA_GISR0_GIF13_Pos (13U) |
| #define | MDMA_GISR0_GIF13_Msk (0x1UL << MDMA_GISR0_GIF13_Pos) |
| #define | MDMA_GISR0_GIF13 MDMA_GISR0_GIF13_Msk |
| #define | MDMA_GISR0_GIF14_Pos (14U) |
| #define | MDMA_GISR0_GIF14_Msk (0x1UL << MDMA_GISR0_GIF14_Pos) |
| #define | MDMA_GISR0_GIF14 MDMA_GISR0_GIF14_Msk |
| #define | MDMA_GISR0_GIF15_Pos (15U) |
| #define | MDMA_GISR0_GIF15_Msk (0x1UL << MDMA_GISR0_GIF15_Pos) |
| #define | MDMA_GISR0_GIF15 MDMA_GISR0_GIF15_Msk |
| #define | MDMA_CISR_TEIF_Pos (0U) |
| #define | MDMA_CISR_TEIF_Msk (0x1UL << MDMA_CISR_TEIF_Pos) |
| #define | MDMA_CISR_TEIF MDMA_CISR_TEIF_Msk |
| #define | MDMA_CISR_CTCIF_Pos (1U) |
| #define | MDMA_CISR_CTCIF_Msk (0x1UL << MDMA_CISR_CTCIF_Pos) |
| #define | MDMA_CISR_CTCIF MDMA_CISR_CTCIF_Msk |
| #define | MDMA_CISR_BRTIF_Pos (2U) |
| #define | MDMA_CISR_BRTIF_Msk (0x1UL << MDMA_CISR_BRTIF_Pos) |
| #define | MDMA_CISR_BRTIF MDMA_CISR_BRTIF_Msk |
| #define | MDMA_CISR_BTIF_Pos (3U) |
| #define | MDMA_CISR_BTIF_Msk (0x1UL << MDMA_CISR_BTIF_Pos) |
| #define | MDMA_CISR_BTIF MDMA_CISR_BTIF_Msk |
| #define | MDMA_CISR_TCIF_Pos (4U) |
| #define | MDMA_CISR_TCIF_Msk (0x1UL << MDMA_CISR_TCIF_Pos) |
| #define | MDMA_CISR_TCIF MDMA_CISR_TCIF_Msk |
| #define | MDMA_CISR_CRQA_Pos (16U) |
| #define | MDMA_CISR_CRQA_Msk (0x1UL << MDMA_CISR_CRQA_Pos) |
| #define | MDMA_CISR_CRQA MDMA_CISR_CRQA_Msk |
| #define | MDMA_CIFCR_CTEIF_Pos (0U) |
| #define | MDMA_CIFCR_CTEIF_Msk (0x1UL << MDMA_CIFCR_CTEIF_Pos) |
| #define | MDMA_CIFCR_CTEIF MDMA_CIFCR_CTEIF_Msk |
| #define | MDMA_CIFCR_CCTCIF_Pos (1U) |
| #define | MDMA_CIFCR_CCTCIF_Msk (0x1UL << MDMA_CIFCR_CCTCIF_Pos) |
| #define | MDMA_CIFCR_CCTCIF MDMA_CIFCR_CCTCIF_Msk |
| #define | MDMA_CIFCR_CBRTIF_Pos (2U) |
| #define | MDMA_CIFCR_CBRTIF_Msk (0x1UL << MDMA_CIFCR_CBRTIF_Pos) |
| #define | MDMA_CIFCR_CBRTIF MDMA_CIFCR_CBRTIF_Msk |
| #define | MDMA_CIFCR_CBTIF_Pos (3U) |
| #define | MDMA_CIFCR_CBTIF_Msk (0x1UL << MDMA_CIFCR_CBTIF_Pos) |
| #define | MDMA_CIFCR_CBTIF MDMA_CIFCR_CBTIF_Msk |
| #define | MDMA_CIFCR_CLTCIF_Pos (4U) |
| #define | MDMA_CIFCR_CLTCIF_Msk (0x1UL << MDMA_CIFCR_CLTCIF_Pos) |
| #define | MDMA_CIFCR_CLTCIF MDMA_CIFCR_CLTCIF_Msk |
| #define | MDMA_CESR_TEA_Pos (0U) |
| #define | MDMA_CESR_TEA_Msk (0x7FUL << MDMA_CESR_TEA_Pos) |
| #define | MDMA_CESR_TEA MDMA_CESR_TEA_Msk |
| #define | MDMA_CESR_TED_Pos (7U) |
| #define | MDMA_CESR_TED_Msk (0x1UL << MDMA_CESR_TED_Pos) |
| #define | MDMA_CESR_TED MDMA_CESR_TED_Msk |
| #define | MDMA_CESR_TELD_Pos (8U) |
| #define | MDMA_CESR_TELD_Msk (0x1UL << MDMA_CESR_TELD_Pos) |
| #define | MDMA_CESR_TELD MDMA_CESR_TELD_Msk |
| #define | MDMA_CESR_TEMD_Pos (9U) |
| #define | MDMA_CESR_TEMD_Msk (0x1UL << MDMA_CESR_TEMD_Pos) |
| #define | MDMA_CESR_TEMD MDMA_CESR_TEMD_Msk |
| #define | MDMA_CESR_ASE_Pos (10U) |
| #define | MDMA_CESR_ASE_Msk (0x1UL << MDMA_CESR_ASE_Pos) |
| #define | MDMA_CESR_ASE MDMA_CESR_ASE_Msk |
| #define | MDMA_CESR_BSE_Pos (11U) |
| #define | MDMA_CESR_BSE_Msk (0x1UL << MDMA_CESR_BSE_Pos) |
| #define | MDMA_CESR_BSE MDMA_CESR_BSE_Msk |
| #define | MDMA_CCR_EN_Pos (0U) |
| #define | MDMA_CCR_EN_Msk (0x1UL << MDMA_CCR_EN_Pos) |
| #define | MDMA_CCR_EN MDMA_CCR_EN_Msk |
| #define | MDMA_CCR_TEIE_Pos (1U) |
| #define | MDMA_CCR_TEIE_Msk (0x1UL << MDMA_CCR_TEIE_Pos) |
| #define | MDMA_CCR_TEIE MDMA_CCR_TEIE_Msk |
| #define | MDMA_CCR_CTCIE_Pos (2U) |
| #define | MDMA_CCR_CTCIE_Msk (0x1UL << MDMA_CCR_CTCIE_Pos) |
| #define | MDMA_CCR_CTCIE MDMA_CCR_CTCIE_Msk |
| #define | MDMA_CCR_BRTIE_Pos (3U) |
| #define | MDMA_CCR_BRTIE_Msk (0x1UL << MDMA_CCR_BRTIE_Pos) |
| #define | MDMA_CCR_BRTIE MDMA_CCR_BRTIE_Msk |
| #define | MDMA_CCR_BTIE_Pos (4U) |
| #define | MDMA_CCR_BTIE_Msk (0x1UL << MDMA_CCR_BTIE_Pos) |
| #define | MDMA_CCR_BTIE MDMA_CCR_BTIE_Msk |
| #define | MDMA_CCR_TCIE_Pos (5U) |
| #define | MDMA_CCR_TCIE_Msk (0x1UL << MDMA_CCR_TCIE_Pos) |
| #define | MDMA_CCR_TCIE MDMA_CCR_TCIE_Msk |
| #define | MDMA_CCR_PL_Pos (6U) |
| #define | MDMA_CCR_PL_Msk (0x3UL << MDMA_CCR_PL_Pos) |
| #define | MDMA_CCR_PL MDMA_CCR_PL_Msk |
| #define | MDMA_CCR_PL_0 (0x1UL << MDMA_CCR_PL_Pos) |
| #define | MDMA_CCR_PL_1 (0x2UL << MDMA_CCR_PL_Pos) |
| #define | MDMA_CCR_BEX_Pos (12U) |
| #define | MDMA_CCR_BEX_Msk (0x1UL << MDMA_CCR_BEX_Pos) |
| #define | MDMA_CCR_BEX MDMA_CCR_BEX_Msk |
| #define | MDMA_CCR_HEX_Pos (13U) |
| #define | MDMA_CCR_HEX_Msk (0x1UL << MDMA_CCR_HEX_Pos) |
| #define | MDMA_CCR_HEX MDMA_CCR_HEX_Msk |
| #define | MDMA_CCR_WEX_Pos (14U) |
| #define | MDMA_CCR_WEX_Msk (0x1UL << MDMA_CCR_WEX_Pos) |
| #define | MDMA_CCR_WEX MDMA_CCR_WEX_Msk |
| #define | MDMA_CCR_SWRQ_Pos (16U) |
| #define | MDMA_CCR_SWRQ_Msk (0x1UL << MDMA_CCR_SWRQ_Pos) |
| #define | MDMA_CCR_SWRQ MDMA_CCR_SWRQ_Msk |
| #define | MDMA_CTCR_SINC_Pos (0U) |
| #define | MDMA_CTCR_SINC_Msk (0x3UL << MDMA_CTCR_SINC_Pos) |
| #define | MDMA_CTCR_SINC MDMA_CTCR_SINC_Msk |
| #define | MDMA_CTCR_SINC_0 (0x1UL << MDMA_CTCR_SINC_Pos) |
| #define | MDMA_CTCR_SINC_1 (0x2UL << MDMA_CTCR_SINC_Pos) |
| #define | MDMA_CTCR_DINC_Pos (2U) |
| #define | MDMA_CTCR_DINC_Msk (0x3UL << MDMA_CTCR_DINC_Pos) |
| #define | MDMA_CTCR_DINC MDMA_CTCR_DINC_Msk |
| #define | MDMA_CTCR_DINC_0 (0x1UL << MDMA_CTCR_DINC_Pos) |
| #define | MDMA_CTCR_DINC_1 (0x2UL << MDMA_CTCR_DINC_Pos) |
| #define | MDMA_CTCR_SSIZE_Pos (4U) |
| #define | MDMA_CTCR_SSIZE_Msk (0x3UL << MDMA_CTCR_SSIZE_Pos) |
| #define | MDMA_CTCR_SSIZE MDMA_CTCR_SSIZE_Msk |
| #define | MDMA_CTCR_SSIZE_0 (0x1UL << MDMA_CTCR_SSIZE_Pos) |
| #define | MDMA_CTCR_SSIZE_1 (0x2UL << MDMA_CTCR_SSIZE_Pos) |
| #define | MDMA_CTCR_DSIZE_Pos (6U) |
| #define | MDMA_CTCR_DSIZE_Msk (0x3UL << MDMA_CTCR_DSIZE_Pos) |
| #define | MDMA_CTCR_DSIZE MDMA_CTCR_DSIZE_Msk |
| #define | MDMA_CTCR_DSIZE_0 (0x1UL << MDMA_CTCR_DSIZE_Pos) |
| #define | MDMA_CTCR_DSIZE_1 (0x2UL << MDMA_CTCR_DSIZE_Pos) |
| #define | MDMA_CTCR_SINCOS_Pos (8U) |
| #define | MDMA_CTCR_SINCOS_Msk (0x3UL << MDMA_CTCR_SINCOS_Pos) |
| #define | MDMA_CTCR_SINCOS MDMA_CTCR_SINCOS_Msk |
| #define | MDMA_CTCR_SINCOS_0 (0x1UL << MDMA_CTCR_SINCOS_Pos) |
| #define | MDMA_CTCR_SINCOS_1 (0x2UL << MDMA_CTCR_SINCOS_Pos) |
| #define | MDMA_CTCR_DINCOS_Pos (10U) |
| #define | MDMA_CTCR_DINCOS_Msk (0x3UL << MDMA_CTCR_DINCOS_Pos) |
| #define | MDMA_CTCR_DINCOS MDMA_CTCR_DINCOS_Msk |
| #define | MDMA_CTCR_DINCOS_0 (0x1UL << MDMA_CTCR_DINCOS_Pos) |
| #define | MDMA_CTCR_DINCOS_1 (0x2UL << MDMA_CTCR_DINCOS_Pos) |
| #define | MDMA_CTCR_SBURST_Pos (12U) |
| #define | MDMA_CTCR_SBURST_Msk (0x7UL << MDMA_CTCR_SBURST_Pos) |
| #define | MDMA_CTCR_SBURST MDMA_CTCR_SBURST_Msk |
| #define | MDMA_CTCR_SBURST_0 (0x1UL << MDMA_CTCR_SBURST_Pos) |
| #define | MDMA_CTCR_SBURST_1 (0x2UL << MDMA_CTCR_SBURST_Pos) |
| #define | MDMA_CTCR_SBURST_2 (0x4UL << MDMA_CTCR_SBURST_Pos) |
| #define | MDMA_CTCR_DBURST_Pos (15U) |
| #define | MDMA_CTCR_DBURST_Msk (0x7UL << MDMA_CTCR_DBURST_Pos) |
| #define | MDMA_CTCR_DBURST MDMA_CTCR_DBURST_Msk |
| #define | MDMA_CTCR_DBURST_0 (0x1UL << MDMA_CTCR_DBURST_Pos) |
| #define | MDMA_CTCR_DBURST_1 (0x2UL << MDMA_CTCR_DBURST_Pos) |
| #define | MDMA_CTCR_DBURST_2 (0x4UL << MDMA_CTCR_DBURST_Pos) |
| #define | MDMA_CTCR_TLEN_Pos (18U) |
| #define | MDMA_CTCR_TLEN_Msk (0x7FUL << MDMA_CTCR_TLEN_Pos) |
| #define | MDMA_CTCR_TLEN MDMA_CTCR_TLEN_Msk |
| #define | MDMA_CTCR_PKE_Pos (25U) |
| #define | MDMA_CTCR_PKE_Msk (0x1UL << MDMA_CTCR_PKE_Pos) |
| #define | MDMA_CTCR_PKE MDMA_CTCR_PKE_Msk |
| #define | MDMA_CTCR_PAM_Pos (26U) |
| #define | MDMA_CTCR_PAM_Msk (0x3UL << MDMA_CTCR_PAM_Pos) |
| #define | MDMA_CTCR_PAM MDMA_CTCR_PAM_Msk |
| #define | MDMA_CTCR_PAM_0 (0x1UL << MDMA_CTCR_PAM_Pos) |
| #define | MDMA_CTCR_PAM_1 (0x2UL << MDMA_CTCR_PAM_Pos) |
| #define | MDMA_CTCR_TRGM_Pos (28U) |
| #define | MDMA_CTCR_TRGM_Msk (0x3UL << MDMA_CTCR_TRGM_Pos) |
| #define | MDMA_CTCR_TRGM MDMA_CTCR_TRGM_Msk |
| #define | MDMA_CTCR_TRGM_0 (0x1UL << MDMA_CTCR_TRGM_Pos) |
| #define | MDMA_CTCR_TRGM_1 (0x2UL << MDMA_CTCR_TRGM_Pos) |
| #define | MDMA_CTCR_SWRM_Pos (30U) |
| #define | MDMA_CTCR_SWRM_Msk (0x1UL << MDMA_CTCR_SWRM_Pos) |
| #define | MDMA_CTCR_SWRM MDMA_CTCR_SWRM_Msk |
| #define | MDMA_CTCR_BWM_Pos (31U) |
| #define | MDMA_CTCR_BWM_Msk (0x1UL << MDMA_CTCR_BWM_Pos) |
| #define | MDMA_CTCR_BWM MDMA_CTCR_BWM_Msk |
| #define | MDMA_CBNDTR_BNDT_Pos (0U) |
| #define | MDMA_CBNDTR_BNDT_Msk (0x1FFFFUL << MDMA_CBNDTR_BNDT_Pos) |
| #define | MDMA_CBNDTR_BNDT MDMA_CBNDTR_BNDT_Msk |
| #define | MDMA_CBNDTR_BRSUM_Pos (18U) |
| #define | MDMA_CBNDTR_BRSUM_Msk (0x1UL << MDMA_CBNDTR_BRSUM_Pos) |
| #define | MDMA_CBNDTR_BRSUM MDMA_CBNDTR_BRSUM_Msk |
| #define | MDMA_CBNDTR_BRDUM_Pos (19U) |
| #define | MDMA_CBNDTR_BRDUM_Msk (0x1UL << MDMA_CBNDTR_BRDUM_Pos) |
| #define | MDMA_CBNDTR_BRDUM MDMA_CBNDTR_BRDUM_Msk |
| #define | MDMA_CBNDTR_BRC_Pos (20U) |
| #define | MDMA_CBNDTR_BRC_Msk (0xFFFUL << MDMA_CBNDTR_BRC_Pos) |
| #define | MDMA_CBNDTR_BRC MDMA_CBNDTR_BRC_Msk |
| #define | MDMA_CSAR_SAR_Pos (0U) |
| #define | MDMA_CSAR_SAR_Msk (0xFFFFFFFFUL << MDMA_CSAR_SAR_Pos) |
| #define | MDMA_CSAR_SAR MDMA_CSAR_SAR_Msk |
| #define | MDMA_CDAR_DAR_Pos (0U) |
| #define | MDMA_CDAR_DAR_Msk (0xFFFFFFFFUL << MDMA_CDAR_DAR_Pos) |
| #define | MDMA_CDAR_DAR MDMA_CDAR_DAR_Msk |
| #define | MDMA_CBRUR_SUV_Pos (0U) |
| #define | MDMA_CBRUR_SUV_Msk (0xFFFFUL << MDMA_CBRUR_SUV_Pos) |
| #define | MDMA_CBRUR_SUV MDMA_CBRUR_SUV_Msk |
| #define | MDMA_CBRUR_DUV_Pos (16U) |
| #define | MDMA_CBRUR_DUV_Msk (0xFFFFUL << MDMA_CBRUR_DUV_Pos) |
| #define | MDMA_CBRUR_DUV MDMA_CBRUR_DUV_Msk |
| #define | MDMA_CLAR_LAR_Pos (0U) |
| #define | MDMA_CLAR_LAR_Msk (0xFFFFFFFFUL << MDMA_CLAR_LAR_Pos) |
| #define | MDMA_CLAR_LAR MDMA_CLAR_LAR_Msk |
| #define | MDMA_CTBR_TSEL_Pos (0U) |
| #define | MDMA_CTBR_TSEL_Msk (0xFFUL << MDMA_CTBR_TSEL_Pos) |
| #define | MDMA_CTBR_TSEL MDMA_CTBR_TSEL_Msk |
| #define | MDMA_CTBR_SBUS_Pos (16U) |
| #define | MDMA_CTBR_SBUS_Msk (0x1UL << MDMA_CTBR_SBUS_Pos) |
| #define | MDMA_CTBR_SBUS MDMA_CTBR_SBUS_Msk |
| #define | MDMA_CTBR_DBUS_Pos (17U) |
| #define | MDMA_CTBR_DBUS_Msk (0x1UL << MDMA_CTBR_DBUS_Pos) |
| #define | MDMA_CTBR_DBUS MDMA_CTBR_DBUS_Msk |
| #define | MDMA_CMAR_MAR_Pos (0U) |
| #define | MDMA_CMAR_MAR_Msk (0xFFFFFFFFUL << MDMA_CMAR_MAR_Pos) |
| #define | MDMA_CMAR_MAR MDMA_CMAR_MAR_Msk |
| #define | MDMA_CMDR_MDR_Pos (0U) |
| #define | MDMA_CMDR_MDR_Msk (0xFFFFFFFFUL << MDMA_CMDR_MDR_Pos) |
| #define | MDMA_CMDR_MDR MDMA_CMDR_MDR_Msk |
| #define | OPAMP_CSR_OPAMPxEN_Pos (0U) |
| #define | OPAMP_CSR_OPAMPxEN_Msk (0x1UL << OPAMP_CSR_OPAMPxEN_Pos) |
| #define | OPAMP_CSR_OPAMPxEN OPAMP_CSR_OPAMPxEN_Msk |
| #define | OPAMP_CSR_FORCEVP_Pos (1U) |
| #define | OPAMP_CSR_FORCEVP_Msk (0x1UL << OPAMP_CSR_FORCEVP_Pos) |
| #define | OPAMP_CSR_FORCEVP OPAMP_CSR_FORCEVP_Msk |
| #define | OPAMP_CSR_VPSEL_Pos (2U) |
| #define | OPAMP_CSR_VPSEL_Msk (0x3UL << OPAMP_CSR_VPSEL_Pos) |
| #define | OPAMP_CSR_VPSEL OPAMP_CSR_VPSEL_Msk |
| #define | OPAMP_CSR_VPSEL_0 (0x1UL << OPAMP_CSR_VPSEL_Pos) |
| #define | OPAMP_CSR_VPSEL_1 (0x2UL << OPAMP_CSR_VPSEL_Pos) |
| #define | OPAMP_CSR_VMSEL_Pos (5U) |
| #define | OPAMP_CSR_VMSEL_Msk (0x3UL << OPAMP_CSR_VMSEL_Pos) |
| #define | OPAMP_CSR_VMSEL OPAMP_CSR_VMSEL_Msk |
| #define | OPAMP_CSR_VMSEL_0 (0x1UL << OPAMP_CSR_VMSEL_Pos) |
| #define | OPAMP_CSR_VMSEL_1 (0x2UL << OPAMP_CSR_VMSEL_Pos) |
| #define | OPAMP_CSR_OPAHSM_Pos (8U) |
| #define | OPAMP_CSR_OPAHSM_Msk (0x1UL << OPAMP_CSR_OPAHSM_Pos) |
| #define | OPAMP_CSR_OPAHSM OPAMP_CSR_OPAHSM_Msk |
| #define | OPAMP_CSR_CALON_Pos (11U) |
| #define | OPAMP_CSR_CALON_Msk (0x1UL << OPAMP_CSR_CALON_Pos) |
| #define | OPAMP_CSR_CALON OPAMP_CSR_CALON_Msk |
| #define | OPAMP_CSR_CALSEL_Pos (12U) |
| #define | OPAMP_CSR_CALSEL_Msk (0x3UL << OPAMP_CSR_CALSEL_Pos) |
| #define | OPAMP_CSR_CALSEL OPAMP_CSR_CALSEL_Msk |
| #define | OPAMP_CSR_CALSEL_0 (0x1UL << OPAMP_CSR_CALSEL_Pos) |
| #define | OPAMP_CSR_CALSEL_1 (0x2UL << OPAMP_CSR_CALSEL_Pos) |
| #define | OPAMP_CSR_PGGAIN_Pos (14U) |
| #define | OPAMP_CSR_PGGAIN_Msk (0xFUL << OPAMP_CSR_PGGAIN_Pos) |
| #define | OPAMP_CSR_PGGAIN OPAMP_CSR_PGGAIN_Msk |
| #define | OPAMP_CSR_PGGAIN_0 (0x1UL << OPAMP_CSR_PGGAIN_Pos) |
| #define | OPAMP_CSR_PGGAIN_1 (0x2UL << OPAMP_CSR_PGGAIN_Pos) |
| #define | OPAMP_CSR_PGGAIN_2 (0x4UL << OPAMP_CSR_PGGAIN_Pos) |
| #define | OPAMP_CSR_PGGAIN_3 (0x8UL << OPAMP_CSR_PGGAIN_Pos) |
| #define | OPAMP_CSR_USERTRIM_Pos (18U) |
| #define | OPAMP_CSR_USERTRIM_Msk (0x1UL << OPAMP_CSR_USERTRIM_Pos) |
| #define | OPAMP_CSR_USERTRIM OPAMP_CSR_USERTRIM_Msk |
| #define | OPAMP_CSR_TSTREF_Pos (29U) |
| #define | OPAMP_CSR_TSTREF_Msk (0x1UL << OPAMP_CSR_TSTREF_Pos) |
| #define | OPAMP_CSR_TSTREF OPAMP_CSR_TSTREF_Msk |
| #define | OPAMP_CSR_CALOUT_Pos (30U) |
| #define | OPAMP_CSR_CALOUT_Msk (0x1UL << OPAMP_CSR_CALOUT_Pos) |
| #define | OPAMP_CSR_CALOUT OPAMP_CSR_CALOUT_Msk |
| #define | OPAMP1_CSR_OPAEN_Pos (0U) |
| #define | OPAMP1_CSR_OPAEN_Msk (0x1UL << OPAMP1_CSR_OPAEN_Pos) |
| #define | OPAMP1_CSR_OPAEN OPAMP1_CSR_OPAEN_Msk |
| #define | OPAMP1_CSR_FORCEVP_Pos (1U) |
| #define | OPAMP1_CSR_FORCEVP_Msk (0x1UL << OPAMP1_CSR_FORCEVP_Pos) |
| #define | OPAMP1_CSR_FORCEVP OPAMP1_CSR_FORCEVP_Msk |
| #define | OPAMP1_CSR_VPSEL_Pos (2U) |
| #define | OPAMP1_CSR_VPSEL_Msk (0x3UL << OPAMP1_CSR_VPSEL_Pos) |
| #define | OPAMP1_CSR_VPSEL OPAMP1_CSR_VPSEL_Msk |
| #define | OPAMP1_CSR_VPSEL_0 (0x1UL << OPAMP1_CSR_VPSEL_Pos) |
| #define | OPAMP1_CSR_VPSEL_1 (0x2UL << OPAMP1_CSR_VPSEL_Pos) |
| #define | OPAMP1_CSR_VMSEL_Pos (5U) |
| #define | OPAMP1_CSR_VMSEL_Msk (0x3UL << OPAMP1_CSR_VMSEL_Pos) |
| #define | OPAMP1_CSR_VMSEL OPAMP1_CSR_VMSEL_Msk |
| #define | OPAMP1_CSR_VMSEL_0 (0x1UL << OPAMP1_CSR_VMSEL_Pos) |
| #define | OPAMP1_CSR_VMSEL_1 (0x2UL << OPAMP1_CSR_VMSEL_Pos) |
| #define | OPAMP1_CSR_OPAHSM_Pos (8U) |
| #define | OPAMP1_CSR_OPAHSM_Msk (0x1UL << OPAMP1_CSR_OPAHSM_Pos) |
| #define | OPAMP1_CSR_OPAHSM OPAMP1_CSR_OPAHSM_Msk |
| #define | OPAMP1_CSR_CALON_Pos (11U) |
| #define | OPAMP1_CSR_CALON_Msk (0x1UL << OPAMP1_CSR_CALON_Pos) |
| #define | OPAMP1_CSR_CALON OPAMP1_CSR_CALON_Msk |
| #define | OPAMP1_CSR_CALSEL_Pos (12U) |
| #define | OPAMP1_CSR_CALSEL_Msk (0x3UL << OPAMP1_CSR_CALSEL_Pos) |
| #define | OPAMP1_CSR_CALSEL OPAMP1_CSR_CALSEL_Msk |
| #define | OPAMP1_CSR_CALSEL_0 (0x1UL << OPAMP1_CSR_CALSEL_Pos) |
| #define | OPAMP1_CSR_CALSEL_1 (0x2UL << OPAMP1_CSR_CALSEL_Pos) |
| #define | OPAMP1_CSR_PGGAIN_Pos (14U) |
| #define | OPAMP1_CSR_PGGAIN_Msk (0xFUL << OPAMP1_CSR_PGGAIN_Pos) |
| #define | OPAMP1_CSR_PGGAIN OPAMP1_CSR_PGGAIN_Msk |
| #define | OPAMP1_CSR_PGGAIN_0 (0x1UL << OPAMP1_CSR_PGGAIN_Pos) |
| #define | OPAMP1_CSR_PGGAIN_1 (0x2UL << OPAMP1_CSR_PGGAIN_Pos) |
| #define | OPAMP1_CSR_PGGAIN_2 (0x4UL << OPAMP1_CSR_PGGAIN_Pos) |
| #define | OPAMP1_CSR_PGGAIN_3 (0x8UL << OPAMP1_CSR_PGGAIN_Pos) |
| #define | OPAMP1_CSR_USERTRIM_Pos (18U) |
| #define | OPAMP1_CSR_USERTRIM_Msk (0x1UL << OPAMP1_CSR_USERTRIM_Pos) |
| #define | OPAMP1_CSR_USERTRIM OPAMP1_CSR_USERTRIM_Msk |
| #define | OPAMP1_CSR_TSTREF_Pos (29U) |
| #define | OPAMP1_CSR_TSTREF_Msk (0x1UL << OPAMP1_CSR_TSTREF_Pos) |
| #define | OPAMP1_CSR_TSTREF OPAMP1_CSR_TSTREF_Msk |
| #define | OPAMP1_CSR_CALOUT_Pos (30U) |
| #define | OPAMP1_CSR_CALOUT_Msk (0x1UL << OPAMP1_CSR_CALOUT_Pos) |
| #define | OPAMP1_CSR_CALOUT OPAMP1_CSR_CALOUT_Msk |
| #define | OPAMP2_CSR_OPAEN_Pos (0U) |
| #define | OPAMP2_CSR_OPAEN_Msk (0x1UL << OPAMP2_CSR_OPAEN_Pos) |
| #define | OPAMP2_CSR_OPAEN OPAMP2_CSR_OPAEN_Msk |
| #define | OPAMP2_CSR_FORCEVP_Pos (1U) |
| #define | OPAMP2_CSR_FORCEVP_Msk (0x1UL << OPAMP2_CSR_FORCEVP_Pos) |
| #define | OPAMP2_CSR_FORCEVP OPAMP2_CSR_FORCEVP_Msk |
| #define | OPAMP2_CSR_VPSEL_Pos (2U) |
| #define | OPAMP2_CSR_VPSEL_Msk (0x3UL << OPAMP2_CSR_VPSEL_Pos) |
| #define | OPAMP2_CSR_VPSEL OPAMP2_CSR_VPSEL_Msk |
| #define | OPAMP2_CSR_VPSEL_0 (0x1UL << OPAMP2_CSR_VPSEL_Pos) |
| #define | OPAMP2_CSR_VPSEL_1 (0x2UL << OPAMP2_CSR_VPSEL_Pos) |
| #define | OPAMP2_CSR_VMSEL_Pos (5U) |
| #define | OPAMP2_CSR_VMSEL_Msk (0x3UL << OPAMP2_CSR_VMSEL_Pos) |
| #define | OPAMP2_CSR_VMSEL OPAMP2_CSR_VMSEL_Msk |
| #define | OPAMP2_CSR_VMSEL_0 (0x1UL << OPAMP2_CSR_VMSEL_Pos) |
| #define | OPAMP2_CSR_VMSEL_1 (0x2UL << OPAMP2_CSR_VMSEL_Pos) |
| #define | OPAMP2_CSR_OPAHSM_Pos (8U) |
| #define | OPAMP2_CSR_OPAHSM_Msk (0x1UL << OPAMP2_CSR_OPAHSM_Pos) |
| #define | OPAMP2_CSR_OPAHSM OPAMP2_CSR_OPAHSM_Msk |
| #define | OPAMP2_CSR_CALON_Pos (11U) |
| #define | OPAMP2_CSR_CALON_Msk (0x1UL << OPAMP2_CSR_CALON_Pos) |
| #define | OPAMP2_CSR_CALON OPAMP2_CSR_CALON_Msk |
| #define | OPAMP2_CSR_CALSEL_Pos (12U) |
| #define | OPAMP2_CSR_CALSEL_Msk (0x3UL << OPAMP2_CSR_CALSEL_Pos) |
| #define | OPAMP2_CSR_CALSEL OPAMP2_CSR_CALSEL_Msk |
| #define | OPAMP2_CSR_CALSEL_0 (0x1UL << OPAMP2_CSR_CALSEL_Pos) |
| #define | OPAMP2_CSR_CALSEL_1 (0x2UL << OPAMP2_CSR_CALSEL_Pos) |
| #define | OPAMP2_CSR_PGGAIN_Pos (14U) |
| #define | OPAMP2_CSR_PGGAIN_Msk (0xFUL << OPAMP2_CSR_PGGAIN_Pos) |
| #define | OPAMP2_CSR_PGGAIN OPAMP2_CSR_PGGAIN_Msk |
| #define | OPAMP2_CSR_PGGAIN_0 (0x1UL << OPAMP2_CSR_PGGAIN_Pos) |
| #define | OPAMP2_CSR_PGGAIN_1 (0x2UL << OPAMP2_CSR_PGGAIN_Pos) |
| #define | OPAMP2_CSR_PGGAIN_2 (0x4UL << OPAMP2_CSR_PGGAIN_Pos) |
| #define | OPAMP2_CSR_PGGAIN_3 (0x8UL << OPAMP2_CSR_PGGAIN_Pos) |
| #define | OPAMP2_CSR_USERTRIM_Pos (18U) |
| #define | OPAMP2_CSR_USERTRIM_Msk (0x1UL << OPAMP2_CSR_USERTRIM_Pos) |
| #define | OPAMP2_CSR_USERTRIM OPAMP2_CSR_USERTRIM_Msk |
| #define | OPAMP2_CSR_TSTREF_Pos (29U) |
| #define | OPAMP2_CSR_TSTREF_Msk (0x1UL << OPAMP2_CSR_TSTREF_Pos) |
| #define | OPAMP2_CSR_TSTREF OPAMP2_CSR_TSTREF_Msk |
| #define | OPAMP2_CSR_CALOUT_Pos (30U) |
| #define | OPAMP2_CSR_CALOUT_Msk (0x1UL << OPAMP2_CSR_CALOUT_Pos) |
| #define | OPAMP2_CSR_CALOUT OPAMP2_CSR_CALOUT_Msk |
| #define | OPAMP_OTR_TRIMOFFSETN_Pos (0U) |
| #define | OPAMP_OTR_TRIMOFFSETN_Msk (0x1FUL << OPAMP_OTR_TRIMOFFSETN_Pos) |
| #define | OPAMP_OTR_TRIMOFFSETN OPAMP_OTR_TRIMOFFSETN_Msk |
| #define | OPAMP_OTR_TRIMOFFSETP_Pos (8U) |
| #define | OPAMP_OTR_TRIMOFFSETP_Msk (0x1FUL << OPAMP_OTR_TRIMOFFSETP_Pos) |
| #define | OPAMP_OTR_TRIMOFFSETP OPAMP_OTR_TRIMOFFSETP_Msk |
| #define | OPAMP1_OTR_TRIMOFFSETN_Pos (0U) |
| #define | OPAMP1_OTR_TRIMOFFSETN_Msk (0x1FUL << OPAMP1_OTR_TRIMOFFSETN_Pos) |
| #define | OPAMP1_OTR_TRIMOFFSETN OPAMP1_OTR_TRIMOFFSETN_Msk |
| #define | OPAMP1_OTR_TRIMOFFSETP_Pos (8U) |
| #define | OPAMP1_OTR_TRIMOFFSETP_Msk (0x1FUL << OPAMP1_OTR_TRIMOFFSETP_Pos) |
| #define | OPAMP1_OTR_TRIMOFFSETP OPAMP1_OTR_TRIMOFFSETP_Msk |
| #define | OPAMP2_OTR_TRIMOFFSETN_Pos (0U) |
| #define | OPAMP2_OTR_TRIMOFFSETN_Msk (0x1FUL << OPAMP2_OTR_TRIMOFFSETN_Pos) |
| #define | OPAMP2_OTR_TRIMOFFSETN OPAMP2_OTR_TRIMOFFSETN_Msk |
| #define | OPAMP2_OTR_TRIMOFFSETP_Pos (8U) |
| #define | OPAMP2_OTR_TRIMOFFSETP_Msk (0x1FUL << OPAMP2_OTR_TRIMOFFSETP_Pos) |
| #define | OPAMP2_OTR_TRIMOFFSETP OPAMP2_OTR_TRIMOFFSETP_Msk |
| #define | OPAMP_HSOTR_TRIMHSOFFSETN_Pos (0U) |
| #define | OPAMP_HSOTR_TRIMHSOFFSETN_Msk (0x1FUL << OPAMP_HSOTR_TRIMHSOFFSETN_Pos) |
| #define | OPAMP_HSOTR_TRIMHSOFFSETN OPAMP_HSOTR_TRIMHSOFFSETN_Msk |
| #define | OPAMP_HSOTR_TRIMHSOFFSETP_Pos (8U) |
| #define | OPAMP_HSOTR_TRIMHSOFFSETP_Msk (0x1FUL << OPAMP_HSOTR_TRIMHSOFFSETP_Pos) |
| #define | OPAMP_HSOTR_TRIMHSOFFSETP OPAMP_HSOTR_TRIMHSOFFSETP_Msk |
| #define | OPAMP1_HSOTR_TRIMHSOFFSETN_Pos (0U) |
| #define | OPAMP1_HSOTR_TRIMHSOFFSETN_Msk (0x1FUL << OPAMP1_HSOTR_TRIMHSOFFSETN_Pos) |
| #define | OPAMP1_HSOTR_TRIMHSOFFSETN OPAMP1_HSOTR_TRIMHSOFFSETN_Msk |
| #define | OPAMP1_HSOTR_TRIMHSOFFSETP_Pos (8U) |
| #define | OPAMP1_HSOTR_TRIMHSOFFSETP_Msk (0x1FUL << OPAMP1_HSOTR_TRIMHSOFFSETP_Pos) |
| #define | OPAMP1_HSOTR_TRIMHSOFFSETP OPAMP1_HSOTR_TRIMHSOFFSETP_Msk |
| #define | OPAMP2_HSOTR_TRIMHSOFFSETN_Pos (0U) |
| #define | OPAMP2_HSOTR_TRIMHSOFFSETN_Msk (0x1FUL << OPAMP2_HSOTR_TRIMHSOFFSETN_Pos) |
| #define | OPAMP2_HSOTR_TRIMHSOFFSETN OPAMP2_HSOTR_TRIMHSOFFSETN_Msk |
| #define | OPAMP2_HSOTR_TRIMHSOFFSETP_Pos (8U) |
| #define | OPAMP2_HSOTR_TRIMHSOFFSETP_Msk (0x1FUL << OPAMP2_HSOTR_TRIMHSOFFSETP_Pos) |
| #define | OPAMP2_HSOTR_TRIMHSOFFSETP OPAMP2_HSOTR_TRIMHSOFFSETP_Msk |
| #define | POWER_DOMAINS_NUMBER 3U |
| #define | PWR_CR1_ALS_Pos (17U) |
| #define | PWR_CR1_ALS_Msk (0x3UL << PWR_CR1_ALS_Pos) |
| #define | PWR_CR1_ALS PWR_CR1_ALS_Msk |
| #define | PWR_CR1_ALS_0 (0x1UL << PWR_CR1_ALS_Pos) |
| #define | PWR_CR1_ALS_1 (0x2UL << PWR_CR1_ALS_Pos) |
| #define | PWR_CR1_AVDEN_Pos (16U) |
| #define | PWR_CR1_AVDEN_Msk (0x1UL << PWR_CR1_AVDEN_Pos) |
| #define | PWR_CR1_AVDEN PWR_CR1_AVDEN_Msk |
| #define | PWR_CR1_SVOS_Pos (14U) |
| #define | PWR_CR1_SVOS_Msk (0x3UL << PWR_CR1_SVOS_Pos) |
| #define | PWR_CR1_SVOS PWR_CR1_SVOS_Msk |
| #define | PWR_CR1_SVOS_0 (0x1UL << PWR_CR1_SVOS_Pos) |
| #define | PWR_CR1_SVOS_1 (0x2UL << PWR_CR1_SVOS_Pos) |
| #define | PWR_CR1_FLPS_Pos (9U) |
| #define | PWR_CR1_FLPS_Msk (0x1UL << PWR_CR1_FLPS_Pos) |
| #define | PWR_CR1_FLPS PWR_CR1_FLPS_Msk |
| #define | PWR_CR1_DBP_Pos (8U) |
| #define | PWR_CR1_DBP_Msk (0x1UL << PWR_CR1_DBP_Pos) |
| #define | PWR_CR1_DBP PWR_CR1_DBP_Msk |
| #define | PWR_CR1_PLS_Pos (5U) |
| #define | PWR_CR1_PLS_Msk (0x7UL << PWR_CR1_PLS_Pos) |
| #define | PWR_CR1_PLS PWR_CR1_PLS_Msk |
| #define | PWR_CR1_PLS_0 (0x1UL << PWR_CR1_PLS_Pos) |
| #define | PWR_CR1_PLS_1 (0x2UL << PWR_CR1_PLS_Pos) |
| #define | PWR_CR1_PLS_2 (0x4UL << PWR_CR1_PLS_Pos) |
| #define | PWR_CR1_PVDEN_Pos (4U) |
| #define | PWR_CR1_PVDEN_Msk (0x1UL << PWR_CR1_PVDEN_Pos) |
| #define | PWR_CR1_PVDEN PWR_CR1_PVDEN_Msk |
| #define | PWR_CR1_LPDS_Pos (0U) |
| #define | PWR_CR1_LPDS_Msk (0x1UL << PWR_CR1_LPDS_Pos) |
| #define | PWR_CR1_LPDS PWR_CR1_LPDS_Msk |
| #define | PWR_CR1_PLS_LEV0 (0UL) |
| #define | PWR_CR1_PLS_LEV1_Pos (5U) |
| #define | PWR_CR1_PLS_LEV1_Msk (0x1UL << PWR_CR1_PLS_LEV1_Pos) |
| #define | PWR_CR1_PLS_LEV1 PWR_CR1_PLS_LEV1_Msk |
| #define | PWR_CR1_PLS_LEV2_Pos (6U) |
| #define | PWR_CR1_PLS_LEV2_Msk (0x1UL << PWR_CR1_PLS_LEV2_Pos) |
| #define | PWR_CR1_PLS_LEV2 PWR_CR1_PLS_LEV2_Msk |
| #define | PWR_CR1_PLS_LEV3_Pos (5U) |
| #define | PWR_CR1_PLS_LEV3_Msk (0x3UL << PWR_CR1_PLS_LEV3_Pos) |
| #define | PWR_CR1_PLS_LEV3 PWR_CR1_PLS_LEV3_Msk |
| #define | PWR_CR1_PLS_LEV4_Pos (7U) |
| #define | PWR_CR1_PLS_LEV4_Msk (0x1UL << PWR_CR1_PLS_LEV4_Pos) |
| #define | PWR_CR1_PLS_LEV4 PWR_CR1_PLS_LEV4_Msk |
| #define | PWR_CR1_PLS_LEV5_Pos (5U) |
| #define | PWR_CR1_PLS_LEV5_Msk (0x5UL << PWR_CR1_PLS_LEV5_Pos) |
| #define | PWR_CR1_PLS_LEV5 PWR_CR1_PLS_LEV5_Msk |
| #define | PWR_CR1_PLS_LEV6_Pos (6U) |
| #define | PWR_CR1_PLS_LEV6_Msk (0x3UL << PWR_CR1_PLS_LEV6_Pos) |
| #define | PWR_CR1_PLS_LEV6 PWR_CR1_PLS_LEV6_Msk |
| #define | PWR_CR1_PLS_LEV7_Pos (5U) |
| #define | PWR_CR1_PLS_LEV7_Msk (0x7UL << PWR_CR1_PLS_LEV7_Pos) |
| #define | PWR_CR1_PLS_LEV7 PWR_CR1_PLS_LEV7_Msk |
| #define | PWR_CR1_ALS_LEV0 (0UL) |
| #define | PWR_CR1_ALS_LEV1_Pos (17U) |
| #define | PWR_CR1_ALS_LEV1_Msk (0x1UL << PWR_CR1_ALS_LEV1_Pos) |
| #define | PWR_CR1_ALS_LEV1 PWR_CR1_ALS_LEV1_Msk |
| #define | PWR_CR1_ALS_LEV2_Pos (18U) |
| #define | PWR_CR1_ALS_LEV2_Msk (0x1UL << PWR_CR1_ALS_LEV2_Pos) |
| #define | PWR_CR1_ALS_LEV2 PWR_CR1_ALS_LEV2_Msk |
| #define | PWR_CR1_ALS_LEV3_Pos (17U) |
| #define | PWR_CR1_ALS_LEV3_Msk (0x3UL << PWR_CR1_ALS_LEV3_Pos) |
| #define | PWR_CR1_ALS_LEV3 PWR_CR1_ALS_LEV3_Msk |
| #define | PWR_CSR1_AVDO_Pos (16U) |
| #define | PWR_CSR1_AVDO_Msk (0x1UL << PWR_CSR1_AVDO_Pos) |
| #define | PWR_CSR1_AVDO PWR_CSR1_AVDO_Msk |
| #define | PWR_CSR1_ACTVOS_Pos (14U) |
| #define | PWR_CSR1_ACTVOS_Msk (0x3UL << PWR_CSR1_ACTVOS_Pos) |
| #define | PWR_CSR1_ACTVOS PWR_CSR1_ACTVOS_Msk |
| #define | PWR_CSR1_ACTVOS_0 (0x1UL << PWR_CSR1_ACTVOS_Pos) |
| #define | PWR_CSR1_ACTVOS_1 (0x2UL << PWR_CSR1_ACTVOS_Pos) |
| #define | PWR_CSR1_ACTVOSRDY_Pos (13U) |
| #define | PWR_CSR1_ACTVOSRDY_Msk (0x1UL << PWR_CSR1_ACTVOSRDY_Pos) |
| #define | PWR_CSR1_ACTVOSRDY PWR_CSR1_ACTVOSRDY_Msk |
| #define | PWR_CSR1_PVDO_Pos (4U) |
| #define | PWR_CSR1_PVDO_Msk (0x1UL << PWR_CSR1_PVDO_Pos) |
| #define | PWR_CSR1_PVDO PWR_CSR1_PVDO_Msk |
| #define | PWR_CR2_TEMPH_Pos (23U) |
| #define | PWR_CR2_TEMPH_Msk (0x1UL << PWR_CR2_TEMPH_Pos) |
| #define | PWR_CR2_TEMPH PWR_CR2_TEMPH_Msk |
| #define | PWR_CR2_TEMPL_Pos (22U) |
| #define | PWR_CR2_TEMPL_Msk (0x1UL << PWR_CR2_TEMPL_Pos) |
| #define | PWR_CR2_TEMPL PWR_CR2_TEMPL_Msk |
| #define | PWR_CR2_VBATH_Pos (21U) |
| #define | PWR_CR2_VBATH_Msk (0x1UL << PWR_CR2_VBATH_Pos) |
| #define | PWR_CR2_VBATH PWR_CR2_VBATH_Msk |
| #define | PWR_CR2_VBATL_Pos (20U) |
| #define | PWR_CR2_VBATL_Msk (0x1UL << PWR_CR2_VBATL_Pos) |
| #define | PWR_CR2_VBATL PWR_CR2_VBATL_Msk |
| #define | PWR_CR2_BRRDY_Pos (16U) |
| #define | PWR_CR2_BRRDY_Msk (0x1UL << PWR_CR2_BRRDY_Pos) |
| #define | PWR_CR2_BRRDY PWR_CR2_BRRDY_Msk |
| #define | PWR_CR2_MONEN_Pos (4U) |
| #define | PWR_CR2_MONEN_Msk (0x1UL << PWR_CR2_MONEN_Pos) |
| #define | PWR_CR2_MONEN PWR_CR2_MONEN_Msk |
| #define | PWR_CR2_BREN_Pos (0U) |
| #define | PWR_CR2_BREN_Msk (0x1UL << PWR_CR2_BREN_Pos) |
| #define | PWR_CR2_BREN PWR_CR2_BREN_Msk |
| #define | PWR_CR3_USB33RDY_Pos (26U) |
| #define | PWR_CR3_USB33RDY_Msk (0x1UL << PWR_CR3_USB33RDY_Pos) |
| #define | PWR_CR3_USB33RDY PWR_CR3_USB33RDY_Msk |
| #define | PWR_CR3_USBREGEN_Pos (25U) |
| #define | PWR_CR3_USBREGEN_Msk (0x1UL << PWR_CR3_USBREGEN_Pos) |
| #define | PWR_CR3_USBREGEN PWR_CR3_USBREGEN_Msk |
| #define | PWR_CR3_USB33DEN_Pos (24U) |
| #define | PWR_CR3_USB33DEN_Msk (0x1UL << PWR_CR3_USB33DEN_Pos) |
| #define | PWR_CR3_USB33DEN PWR_CR3_USB33DEN_Msk |
| #define | PWR_CR3_VBRS_Pos (9U) |
| #define | PWR_CR3_VBRS_Msk (0x1UL << PWR_CR3_VBRS_Pos) |
| #define | PWR_CR3_VBRS PWR_CR3_VBRS_Msk |
| #define | PWR_CR3_VBE_Pos (8U) |
| #define | PWR_CR3_VBE_Msk (0x1UL << PWR_CR3_VBE_Pos) |
| #define | PWR_CR3_VBE PWR_CR3_VBE_Msk |
| #define | PWR_CR3_SCUEN_Pos (2U) |
| #define | PWR_CR3_SCUEN_Msk (0x1UL << PWR_CR3_SCUEN_Pos) |
| #define | PWR_CR3_SCUEN PWR_CR3_SCUEN_Msk |
| #define | PWR_CR3_LDOEN_Pos (1U) |
| #define | PWR_CR3_LDOEN_Msk (0x1UL << PWR_CR3_LDOEN_Pos) |
| #define | PWR_CR3_LDOEN PWR_CR3_LDOEN_Msk |
| #define | PWR_CR3_BYPASS_Pos (0U) |
| #define | PWR_CR3_BYPASS_Msk (0x1UL << PWR_CR3_BYPASS_Pos) |
| #define | PWR_CR3_BYPASS PWR_CR3_BYPASS_Msk |
| #define | PWR_CPUCR_RUN_D3_Pos (11U) |
| #define | PWR_CPUCR_RUN_D3_Msk (0x1UL << PWR_CPUCR_RUN_D3_Pos) |
| #define | PWR_CPUCR_RUN_D3 PWR_CPUCR_RUN_D3_Msk |
| #define | PWR_CPUCR_CSSF_Pos (9U) |
| #define | PWR_CPUCR_CSSF_Msk (0x1UL << PWR_CPUCR_CSSF_Pos) |
| #define | PWR_CPUCR_CSSF PWR_CPUCR_CSSF_Msk |
| #define | PWR_CPUCR_SBF_D2_Pos (8U) |
| #define | PWR_CPUCR_SBF_D2_Msk (0x1UL << PWR_CPUCR_SBF_D2_Pos) |
| #define | PWR_CPUCR_SBF_D2 PWR_CPUCR_SBF_D2_Msk |
| #define | PWR_CPUCR_SBF_D1_Pos (7U) |
| #define | PWR_CPUCR_SBF_D1_Msk (0x1UL << PWR_CPUCR_SBF_D1_Pos) |
| #define | PWR_CPUCR_SBF_D1 PWR_CPUCR_SBF_D1_Msk |
| #define | PWR_CPUCR_SBF_Pos (6U) |
| #define | PWR_CPUCR_SBF_Msk (0x1UL << PWR_CPUCR_SBF_Pos) |
| #define | PWR_CPUCR_SBF PWR_CPUCR_SBF_Msk |
| #define | PWR_CPUCR_STOPF_Pos (5U) |
| #define | PWR_CPUCR_STOPF_Msk (0x1UL << PWR_CPUCR_STOPF_Pos) |
| #define | PWR_CPUCR_STOPF PWR_CPUCR_STOPF_Msk |
| #define | PWR_CPUCR_PDDS_D3_Pos (2U) |
| #define | PWR_CPUCR_PDDS_D3_Msk (0x1UL << PWR_CPUCR_PDDS_D3_Pos) |
| #define | PWR_CPUCR_PDDS_D3 PWR_CPUCR_PDDS_D3_Msk |
| #define | PWR_CPUCR_PDDS_D2_Pos (1U) |
| #define | PWR_CPUCR_PDDS_D2_Msk (0x1UL << PWR_CPUCR_PDDS_D2_Pos) |
| #define | PWR_CPUCR_PDDS_D2 PWR_CPUCR_PDDS_D2_Msk |
| #define | PWR_CPUCR_PDDS_D1_Pos (0U) |
| #define | PWR_CPUCR_PDDS_D1_Msk (0x1UL << PWR_CPUCR_PDDS_D1_Pos) |
| #define | PWR_CPUCR_PDDS_D1 PWR_CPUCR_PDDS_D1_Msk |
| #define | PWR_D3CR_VOS_Pos (14U) |
| #define | PWR_D3CR_VOS_Msk (0x3UL << PWR_D3CR_VOS_Pos) |
| #define | PWR_D3CR_VOS PWR_D3CR_VOS_Msk |
| #define | PWR_D3CR_VOS_0 (0x1UL << PWR_D3CR_VOS_Pos) |
| #define | PWR_D3CR_VOS_1 (0x2UL << PWR_D3CR_VOS_Pos) |
| #define | PWR_D3CR_VOSRDY_Pos (13U) |
| #define | PWR_D3CR_VOSRDY_Msk (0x1UL << PWR_D3CR_VOSRDY_Pos) |
| #define | PWR_D3CR_VOSRDY PWR_D3CR_VOSRDY_Msk |
| #define | PWR_WKUPCR_WKUPC6_Pos (5U) |
| #define | PWR_WKUPCR_WKUPC6_Msk (0x1UL << PWR_WKUPCR_WKUPC6_Pos) |
| #define | PWR_WKUPCR_WKUPC6 PWR_WKUPCR_WKUPC6_Msk |
| #define | PWR_WKUPCR_WKUPC5_Pos (4U) |
| #define | PWR_WKUPCR_WKUPC5_Msk (0x1UL << PWR_WKUPCR_WKUPC5_Pos) |
| #define | PWR_WKUPCR_WKUPC5 PWR_WKUPCR_WKUPC5_Msk |
| #define | PWR_WKUPCR_WKUPC4_Pos (3U) |
| #define | PWR_WKUPCR_WKUPC4_Msk (0x1UL << PWR_WKUPCR_WKUPC4_Pos) |
| #define | PWR_WKUPCR_WKUPC4 PWR_WKUPCR_WKUPC4_Msk |
| #define | PWR_WKUPCR_WKUPC3_Pos (2U) |
| #define | PWR_WKUPCR_WKUPC3_Msk (0x1UL << PWR_WKUPCR_WKUPC3_Pos) |
| #define | PWR_WKUPCR_WKUPC3 PWR_WKUPCR_WKUPC3_Msk |
| #define | PWR_WKUPCR_WKUPC2_Pos (1U) |
| #define | PWR_WKUPCR_WKUPC2_Msk (0x1UL << PWR_WKUPCR_WKUPC2_Pos) |
| #define | PWR_WKUPCR_WKUPC2 PWR_WKUPCR_WKUPC2_Msk |
| #define | PWR_WKUPCR_WKUPC1_Pos (0U) |
| #define | PWR_WKUPCR_WKUPC1_Msk (0x1UL << PWR_WKUPCR_WKUPC1_Pos) |
| #define | PWR_WKUPCR_WKUPC1 PWR_WKUPCR_WKUPC1_Msk |
| #define | PWR_WKUPFR_WKUPF6_Pos (5U) |
| #define | PWR_WKUPFR_WKUPF6_Msk (0x1UL << PWR_WKUPFR_WKUPF6_Pos) |
| #define | PWR_WKUPFR_WKUPF6 PWR_WKUPFR_WKUPF6_Msk |
| #define | PWR_WKUPFR_WKUPF5_Pos (4U) |
| #define | PWR_WKUPFR_WKUPF5_Msk (0x1UL << PWR_WKUPFR_WKUPF5_Pos) |
| #define | PWR_WKUPFR_WKUPF5 PWR_WKUPFR_WKUPF5_Msk |
| #define | PWR_WKUPFR_WKUPF4_Pos (3U) |
| #define | PWR_WKUPFR_WKUPF4_Msk (0x1UL << PWR_WKUPFR_WKUPF4_Pos) |
| #define | PWR_WKUPFR_WKUPF4 PWR_WKUPFR_WKUPF4_Msk |
| #define | PWR_WKUPFR_WKUPF3_Pos (2U) |
| #define | PWR_WKUPFR_WKUPF3_Msk (0x1UL << PWR_WKUPFR_WKUPF3_Pos) |
| #define | PWR_WKUPFR_WKUPF3 PWR_WKUPFR_WKUPF3_Msk |
| #define | PWR_WKUPFR_WKUPF2_Pos (1U) |
| #define | PWR_WKUPFR_WKUPF2_Msk (0x1UL << PWR_WKUPFR_WKUPF2_Pos) |
| #define | PWR_WKUPFR_WKUPF2 PWR_WKUPFR_WKUPF2_Msk |
| #define | PWR_WKUPFR_WKUPF1_Pos (0U) |
| #define | PWR_WKUPFR_WKUPF1_Msk (0x1UL << PWR_WKUPFR_WKUPF1_Pos) |
| #define | PWR_WKUPFR_WKUPF1 PWR_WKUPFR_WKUPF1_Msk |
| #define | PWR_WKUPEPR_WKUPPUPD6_Pos (26U) |
| #define | PWR_WKUPEPR_WKUPPUPD6_Msk (0x3UL << PWR_WKUPEPR_WKUPPUPD6_Pos) |
| #define | PWR_WKUPEPR_WKUPPUPD6 PWR_WKUPEPR_WKUPPUPD6_Msk |
| #define | PWR_WKUPEPR_WKUPPUPD6_0 (0x1UL << PWR_WKUPEPR_WKUPPUPD6_Pos) |
| #define | PWR_WKUPEPR_WKUPPUPD6_1 (0x2UL << PWR_WKUPEPR_WKUPPUPD6_Pos) |
| #define | PWR_WKUPEPR_WKUPPUPD5_Pos (24U) |
| #define | PWR_WKUPEPR_WKUPPUPD5_Msk (0x3UL << PWR_WKUPEPR_WKUPPUPD5_Pos) |
| #define | PWR_WKUPEPR_WKUPPUPD5 PWR_WKUPEPR_WKUPPUPD5_Msk |
| #define | PWR_WKUPEPR_WKUPPUPD5_0 (0x1UL << PWR_WKUPEPR_WKUPPUPD5_Pos) |
| #define | PWR_WKUPEPR_WKUPPUPD5_1 (0x2UL << PWR_WKUPEPR_WKUPPUPD5_Pos) |
| #define | PWR_WKUPEPR_WKUPPUPD4_Pos (22U) |
| #define | PWR_WKUPEPR_WKUPPUPD4_Msk (0x3UL << PWR_WKUPEPR_WKUPPUPD4_Pos) |
| #define | PWR_WKUPEPR_WKUPPUPD4 PWR_WKUPEPR_WKUPPUPD4_Msk |
| #define | PWR_WKUPEPR_WKUPPUPD4_0 (0x1UL << PWR_WKUPEPR_WKUPPUPD4_Pos) |
| #define | PWR_WKUPEPR_WKUPPUPD4_1 (0x2UL << PWR_WKUPEPR_WKUPPUPD4_Pos) |
| #define | PWR_WKUPEPR_WKUPPUPD3_Pos (20U) |
| #define | PWR_WKUPEPR_WKUPPUPD3_Msk (0x3UL << PWR_WKUPEPR_WKUPPUPD3_Pos) |
| #define | PWR_WKUPEPR_WKUPPUPD3 PWR_WKUPEPR_WKUPPUPD3_Msk |
| #define | PWR_WKUPEPR_WKUPPUPD3_0 (0x1UL << PWR_WKUPEPR_WKUPPUPD3_Pos) |
| #define | PWR_WKUPEPR_WKUPPUPD3_1 (0x2UL << PWR_WKUPEPR_WKUPPUPD3_Pos) |
| #define | PWR_WKUPEPR_WKUPPUPD2_Pos (18U) |
| #define | PWR_WKUPEPR_WKUPPUPD2_Msk (0x3UL << PWR_WKUPEPR_WKUPPUPD2_Pos) |
| #define | PWR_WKUPEPR_WKUPPUPD2 PWR_WKUPEPR_WKUPPUPD2_Msk |
| #define | PWR_WKUPEPR_WKUPPUPD2_0 (0x1UL << PWR_WKUPEPR_WKUPPUPD2_Pos) |
| #define | PWR_WKUPEPR_WKUPPUPD2_1 (0x2UL << PWR_WKUPEPR_WKUPPUPD2_Pos) |
| #define | PWR_WKUPEPR_WKUPPUPD1_Pos (16U) |
| #define | PWR_WKUPEPR_WKUPPUPD1_Msk (0x3UL << PWR_WKUPEPR_WKUPPUPD1_Pos) |
| #define | PWR_WKUPEPR_WKUPPUPD1 PWR_WKUPEPR_WKUPPUPD1_Msk |
| #define | PWR_WKUPEPR_WKUPPUPD1_0 (0x1UL << PWR_WKUPEPR_WKUPPUPD1_Pos) |
| #define | PWR_WKUPEPR_WKUPPUPD1_1 (0x2UL << PWR_WKUPEPR_WKUPPUPD1_Pos) |
| #define | PWR_WKUPEPR_WKUPP6_Pos (13U) |
| #define | PWR_WKUPEPR_WKUPP6_Msk (0x1UL << PWR_WKUPEPR_WKUPP6_Pos) |
| #define | PWR_WKUPEPR_WKUPP6 PWR_WKUPEPR_WKUPP6_Msk |
| #define | PWR_WKUPEPR_WKUPP5_Pos (12U) |
| #define | PWR_WKUPEPR_WKUPP5_Msk (0x1UL << PWR_WKUPEPR_WKUPP5_Pos) |
| #define | PWR_WKUPEPR_WKUPP5 PWR_WKUPEPR_WKUPP5_Msk |
| #define | PWR_WKUPEPR_WKUPP4_Pos (11U) |
| #define | PWR_WKUPEPR_WKUPP4_Msk (0x1UL << PWR_WKUPEPR_WKUPP4_Pos) |
| #define | PWR_WKUPEPR_WKUPP4 PWR_WKUPEPR_WKUPP4_Msk |
| #define | PWR_WKUPEPR_WKUPP3_Pos (10U) |
| #define | PWR_WKUPEPR_WKUPP3_Msk (0x1UL << PWR_WKUPEPR_WKUPP3_Pos) |
| #define | PWR_WKUPEPR_WKUPP3 PWR_WKUPEPR_WKUPP3_Msk |
| #define | PWR_WKUPEPR_WKUPP2_Pos (9U) |
| #define | PWR_WKUPEPR_WKUPP2_Msk (0x1UL << PWR_WKUPEPR_WKUPP2_Pos) |
| #define | PWR_WKUPEPR_WKUPP2 PWR_WKUPEPR_WKUPP2_Msk |
| #define | PWR_WKUPEPR_WKUPP1_Pos (8U) |
| #define | PWR_WKUPEPR_WKUPP1_Msk (0x1UL << PWR_WKUPEPR_WKUPP1_Pos) |
| #define | PWR_WKUPEPR_WKUPP1 PWR_WKUPEPR_WKUPP1_Msk |
| #define | PWR_WKUPEPR_WKUPEN6_Pos (5U) |
| #define | PWR_WKUPEPR_WKUPEN6_Msk (0x1UL << PWR_WKUPEPR_WKUPEN6_Pos) |
| #define | PWR_WKUPEPR_WKUPEN6 PWR_WKUPEPR_WKUPEN6_Msk |
| #define | PWR_WKUPEPR_WKUPEN5_Pos (4U) |
| #define | PWR_WKUPEPR_WKUPEN5_Msk (0x1UL << PWR_WKUPEPR_WKUPEN5_Pos) |
| #define | PWR_WKUPEPR_WKUPEN5 PWR_WKUPEPR_WKUPEN5_Msk |
| #define | PWR_WKUPEPR_WKUPEN4_Pos (3U) |
| #define | PWR_WKUPEPR_WKUPEN4_Msk (0x1UL << PWR_WKUPEPR_WKUPEN4_Pos) |
| #define | PWR_WKUPEPR_WKUPEN4 PWR_WKUPEPR_WKUPEN4_Msk |
| #define | PWR_WKUPEPR_WKUPEN3_Pos (2U) |
| #define | PWR_WKUPEPR_WKUPEN3_Msk (0x1UL << PWR_WKUPEPR_WKUPEN3_Pos) |
| #define | PWR_WKUPEPR_WKUPEN3 PWR_WKUPEPR_WKUPEN3_Msk |
| #define | PWR_WKUPEPR_WKUPEN2_Pos (1U) |
| #define | PWR_WKUPEPR_WKUPEN2_Msk (0x1UL << PWR_WKUPEPR_WKUPEN2_Pos) |
| #define | PWR_WKUPEPR_WKUPEN2 PWR_WKUPEPR_WKUPEN2_Msk |
| #define | PWR_WKUPEPR_WKUPEN1_Pos (0U) |
| #define | PWR_WKUPEPR_WKUPEN1_Msk (0x1UL << PWR_WKUPEPR_WKUPEN1_Pos) |
| #define | PWR_WKUPEPR_WKUPEN1 PWR_WKUPEPR_WKUPEN1_Msk |
| #define | PWR_WKUPEPR_WKUPEN_Pos (0U) |
| #define | PWR_WKUPEPR_WKUPEN_Msk (0x3FUL << PWR_WKUPEPR_WKUPEN_Pos) |
| #define | PWR_WKUPEPR_WKUPEN PWR_WKUPEPR_WKUPEN_Msk |
| #define | RCC_VER_X |
| #define | RCC_CR_HSION_Pos (0U) |
| #define | RCC_CR_HSION_Msk (0x1UL << RCC_CR_HSION_Pos) |
| #define | RCC_CR_HSION RCC_CR_HSION_Msk |
| #define | RCC_CR_HSIKERON_Pos (1U) |
| #define | RCC_CR_HSIKERON_Msk (0x1UL << RCC_CR_HSIKERON_Pos) |
| #define | RCC_CR_HSIKERON RCC_CR_HSIKERON_Msk |
| #define | RCC_CR_HSIRDY_Pos (2U) |
| #define | RCC_CR_HSIRDY_Msk (0x1UL << RCC_CR_HSIRDY_Pos) |
| #define | RCC_CR_HSIRDY RCC_CR_HSIRDY_Msk |
| #define | RCC_CR_HSIDIV_Pos (3U) |
| #define | RCC_CR_HSIDIV_Msk (0x3UL << RCC_CR_HSIDIV_Pos) |
| #define | RCC_CR_HSIDIV RCC_CR_HSIDIV_Msk |
| #define | RCC_CR_HSIDIV_1 (0x0UL << RCC_CR_HSIDIV_Pos) |
| #define | RCC_CR_HSIDIV_2 (0x1UL << RCC_CR_HSIDIV_Pos) |
| #define | RCC_CR_HSIDIV_4 (0x2UL << RCC_CR_HSIDIV_Pos) |
| #define | RCC_CR_HSIDIV_8 (0x3UL << RCC_CR_HSIDIV_Pos) |
| #define | RCC_CR_HSIDIVF_Pos (5U) |
| #define | RCC_CR_HSIDIVF_Msk (0x1UL << RCC_CR_HSIDIVF_Pos) |
| #define | RCC_CR_HSIDIVF RCC_CR_HSIDIVF_Msk |
| #define | RCC_CR_CSION_Pos (7U) |
| #define | RCC_CR_CSION_Msk (0x1UL << RCC_CR_CSION_Pos) |
| #define | RCC_CR_CSION RCC_CR_CSION_Msk |
| #define | RCC_CR_CSIRDY_Pos (8U) |
| #define | RCC_CR_CSIRDY_Msk (0x1UL << RCC_CR_CSIRDY_Pos) |
| #define | RCC_CR_CSIRDY RCC_CR_CSIRDY_Msk |
| #define | RCC_CR_CSIKERON_Pos (9U) |
| #define | RCC_CR_CSIKERON_Msk (0x1UL << RCC_CR_CSIKERON_Pos) |
| #define | RCC_CR_CSIKERON RCC_CR_CSIKERON_Msk |
| #define | RCC_CR_HSI48ON_Pos (12U) |
| #define | RCC_CR_HSI48ON_Msk (0x1UL << RCC_CR_HSI48ON_Pos) |
| #define | RCC_CR_HSI48ON RCC_CR_HSI48ON_Msk |
| #define | RCC_CR_HSI48RDY_Pos (13U) |
| #define | RCC_CR_HSI48RDY_Msk (0x1UL << RCC_CR_HSI48RDY_Pos) |
| #define | RCC_CR_HSI48RDY RCC_CR_HSI48RDY_Msk |
| #define | RCC_CR_D1CKRDY_Pos (14U) |
| #define | RCC_CR_D1CKRDY_Msk (0x1UL << RCC_CR_D1CKRDY_Pos) |
| #define | RCC_CR_D1CKRDY RCC_CR_D1CKRDY_Msk |
| #define | RCC_CR_D2CKRDY_Pos (15U) |
| #define | RCC_CR_D2CKRDY_Msk (0x1UL << RCC_CR_D2CKRDY_Pos) |
| #define | RCC_CR_D2CKRDY RCC_CR_D2CKRDY_Msk |
| #define | RCC_CR_HSEON_Pos (16U) |
| #define | RCC_CR_HSEON_Msk (0x1UL << RCC_CR_HSEON_Pos) |
| #define | RCC_CR_HSEON RCC_CR_HSEON_Msk |
| #define | RCC_CR_HSERDY_Pos (17U) |
| #define | RCC_CR_HSERDY_Msk (0x1UL << RCC_CR_HSERDY_Pos) |
| #define | RCC_CR_HSERDY RCC_CR_HSERDY_Msk |
| #define | RCC_CR_HSEBYP_Pos (18U) |
| #define | RCC_CR_HSEBYP_Msk (0x1UL << RCC_CR_HSEBYP_Pos) |
| #define | RCC_CR_HSEBYP RCC_CR_HSEBYP_Msk |
| #define | RCC_CR_CSSHSEON_Pos (19U) |
| #define | RCC_CR_CSSHSEON_Msk (0x1UL << RCC_CR_CSSHSEON_Pos) |
| #define | RCC_CR_CSSHSEON RCC_CR_CSSHSEON_Msk |
| #define | RCC_CR_PLL1ON_Pos (24U) |
| #define | RCC_CR_PLL1ON_Msk (0x1UL << RCC_CR_PLL1ON_Pos) |
| #define | RCC_CR_PLL1ON RCC_CR_PLL1ON_Msk |
| #define | RCC_CR_PLL1RDY_Pos (25U) |
| #define | RCC_CR_PLL1RDY_Msk (0x1UL << RCC_CR_PLL1RDY_Pos) |
| #define | RCC_CR_PLL1RDY RCC_CR_PLL1RDY_Msk |
| #define | RCC_CR_PLL2ON_Pos (26U) |
| #define | RCC_CR_PLL2ON_Msk (0x1UL << RCC_CR_PLL2ON_Pos) |
| #define | RCC_CR_PLL2ON RCC_CR_PLL2ON_Msk |
| #define | RCC_CR_PLL2RDY_Pos (27U) |
| #define | RCC_CR_PLL2RDY_Msk (0x1UL << RCC_CR_PLL2RDY_Pos) |
| #define | RCC_CR_PLL2RDY RCC_CR_PLL2RDY_Msk |
| #define | RCC_CR_PLL3ON_Pos (28U) |
| #define | RCC_CR_PLL3ON_Msk (0x1UL << RCC_CR_PLL3ON_Pos) |
| #define | RCC_CR_PLL3ON RCC_CR_PLL3ON_Msk |
| #define | RCC_CR_PLL3RDY_Pos (29U) |
| #define | RCC_CR_PLL3RDY_Msk (0x1UL << RCC_CR_PLL3RDY_Pos) |
| #define | RCC_CR_PLL3RDY RCC_CR_PLL3RDY_Msk |
| #define | RCC_CR_PLLON_Pos (24U) |
| #define | RCC_CR_PLLON_Msk (0x1UL << RCC_CR_PLLON_Pos) |
| #define | RCC_CR_PLLON RCC_CR_PLLON_Msk |
| #define | RCC_CR_PLLRDY_Pos (25U) |
| #define | RCC_CR_PLLRDY_Msk (0x1UL << RCC_CR_PLLRDY_Pos) |
| #define | RCC_CR_PLLRDY RCC_CR_PLLRDY_Msk |
| #define | RCC_HSICFGR_HSICAL_Pos (0U) |
| #define | RCC_HSICFGR_HSICAL_Msk (0xFFFUL << RCC_HSICFGR_HSICAL_Pos) |
| #define | RCC_HSICFGR_HSICAL RCC_HSICFGR_HSICAL_Msk |
| #define | RCC_HSICFGR_HSICAL_0 (0x001UL << RCC_HSICFGR_HSICAL_Pos) |
| #define | RCC_HSICFGR_HSICAL_1 (0x002UL << RCC_HSICFGR_HSICAL_Pos) |
| #define | RCC_HSICFGR_HSICAL_2 (0x004UL << RCC_HSICFGR_HSICAL_Pos) |
| #define | RCC_HSICFGR_HSICAL_3 (0x008UL << RCC_HSICFGR_HSICAL_Pos) |
| #define | RCC_HSICFGR_HSICAL_4 (0x010UL << RCC_HSICFGR_HSICAL_Pos) |
| #define | RCC_HSICFGR_HSICAL_5 (0x020UL << RCC_HSICFGR_HSICAL_Pos) |
| #define | RCC_HSICFGR_HSICAL_6 (0x040UL << RCC_HSICFGR_HSICAL_Pos) |
| #define | RCC_HSICFGR_HSICAL_7 (0x080UL << RCC_HSICFGR_HSICAL_Pos) |
| #define | RCC_HSICFGR_HSICAL_8 (0x100UL << RCC_HSICFGR_HSICAL_Pos) |
| #define | RCC_HSICFGR_HSICAL_9 (0x200UL << RCC_HSICFGR_HSICAL_Pos) |
| #define | RCC_HSICFGR_HSICAL_10 (0x400UL << RCC_HSICFGR_HSICAL_Pos) |
| #define | RCC_HSICFGR_HSICAL_11 (0x800UL << RCC_HSICFGR_HSICAL_Pos) |
| #define | RCC_HSICFGR_HSITRIM_Pos (24U) |
| #define | RCC_HSICFGR_HSITRIM_Msk (0x7FUL << RCC_HSICFGR_HSITRIM_Pos) |
| #define | RCC_HSICFGR_HSITRIM RCC_HSICFGR_HSITRIM_Msk |
| #define | RCC_HSICFGR_HSITRIM_0 (0x01UL << RCC_HSICFGR_HSITRIM_Pos) |
| #define | RCC_HSICFGR_HSITRIM_1 (0x02UL << RCC_HSICFGR_HSITRIM_Pos) |
| #define | RCC_HSICFGR_HSITRIM_2 (0x04UL << RCC_HSICFGR_HSITRIM_Pos) |
| #define | RCC_HSICFGR_HSITRIM_3 (0x08UL << RCC_HSICFGR_HSITRIM_Pos) |
| #define | RCC_HSICFGR_HSITRIM_4 (0x10UL << RCC_HSICFGR_HSITRIM_Pos) |
| #define | RCC_HSICFGR_HSITRIM_5 (0x20UL << RCC_HSICFGR_HSITRIM_Pos) |
| #define | RCC_HSICFGR_HSITRIM_6 (0x40UL << RCC_HSICFGR_HSITRIM_Pos) |
| #define | RCC_CRRCR_HSI48CAL_Pos (0U) |
| #define | RCC_CRRCR_HSI48CAL_Msk (0x3FFUL << RCC_CRRCR_HSI48CAL_Pos) |
| #define | RCC_CRRCR_HSI48CAL RCC_CRRCR_HSI48CAL_Msk |
| #define | RCC_CRRCR_HSI48CAL_0 (0x001UL << RCC_CRRCR_HSI48CAL_Pos) |
| #define | RCC_CRRCR_HSI48CAL_1 (0x002UL << RCC_CRRCR_HSI48CAL_Pos) |
| #define | RCC_CRRCR_HSI48CAL_2 (0x004UL << RCC_CRRCR_HSI48CAL_Pos) |
| #define | RCC_CRRCR_HSI48CAL_3 (0x008UL << RCC_CRRCR_HSI48CAL_Pos) |
| #define | RCC_CRRCR_HSI48CAL_4 (0x010UL << RCC_CRRCR_HSI48CAL_Pos) |
| #define | RCC_CRRCR_HSI48CAL_5 (0x020UL << RCC_CRRCR_HSI48CAL_Pos) |
| #define | RCC_CRRCR_HSI48CAL_6 (0x040UL << RCC_CRRCR_HSI48CAL_Pos) |
| #define | RCC_CRRCR_HSI48CAL_7 (0x080UL << RCC_CRRCR_HSI48CAL_Pos) |
| #define | RCC_CRRCR_HSI48CAL_8 (0x100UL << RCC_CRRCR_HSI48CAL_Pos) |
| #define | RCC_CRRCR_HSI48CAL_9 (0x200UL << RCC_CRRCR_HSI48CAL_Pos) |
| #define | RCC_CSICFGR_CSICAL_Pos (0U) |
| #define | RCC_CSICFGR_CSICAL_Msk (0xFFUL << RCC_CSICFGR_CSICAL_Pos) |
| #define | RCC_CSICFGR_CSICAL RCC_CSICFGR_CSICAL_Msk |
| #define | RCC_CSICFGR_CSICAL_0 (0x01UL << RCC_CSICFGR_CSICAL_Pos) |
| #define | RCC_CSICFGR_CSICAL_1 (0x02UL << RCC_CSICFGR_CSICAL_Pos) |
| #define | RCC_CSICFGR_CSICAL_2 (0x04UL << RCC_CSICFGR_CSICAL_Pos) |
| #define | RCC_CSICFGR_CSICAL_3 (0x08UL << RCC_CSICFGR_CSICAL_Pos) |
| #define | RCC_CSICFGR_CSICAL_4 (0x10UL << RCC_CSICFGR_CSICAL_Pos) |
| #define | RCC_CSICFGR_CSICAL_5 (0x20UL << RCC_CSICFGR_CSICAL_Pos) |
| #define | RCC_CSICFGR_CSICAL_6 (0x40UL << RCC_CSICFGR_CSICAL_Pos) |
| #define | RCC_CSICFGR_CSICAL_7 (0x80UL << RCC_CSICFGR_CSICAL_Pos) |
| #define | RCC_CSICFGR_CSITRIM_Pos (24U) |
| #define | RCC_CSICFGR_CSITRIM_Msk (0x3FUL << RCC_CSICFGR_CSITRIM_Pos) |
| #define | RCC_CSICFGR_CSITRIM RCC_CSICFGR_CSITRIM_Msk |
| #define | RCC_CSICFGR_CSITRIM_0 (0x01UL << RCC_CSICFGR_CSITRIM_Pos) |
| #define | RCC_CSICFGR_CSITRIM_1 (0x02UL << RCC_CSICFGR_CSITRIM_Pos) |
| #define | RCC_CSICFGR_CSITRIM_2 (0x04UL << RCC_CSICFGR_CSITRIM_Pos) |
| #define | RCC_CSICFGR_CSITRIM_3 (0x08UL << RCC_CSICFGR_CSITRIM_Pos) |
| #define | RCC_CSICFGR_CSITRIM_4 (0x10UL << RCC_CSICFGR_CSITRIM_Pos) |
| #define | RCC_CSICFGR_CSITRIM_5 (0x20UL << RCC_CSICFGR_CSITRIM_Pos) |
| #define | RCC_CFGR_SW_Pos (0U) |
| #define | RCC_CFGR_SW_Msk (0x7UL << RCC_CFGR_SW_Pos) |
| #define | RCC_CFGR_SW RCC_CFGR_SW_Msk |
| #define | RCC_CFGR_SW_0 (0x1UL << RCC_CFGR_SW_Pos) |
| #define | RCC_CFGR_SW_1 (0x2UL << RCC_CFGR_SW_Pos) |
| #define | RCC_CFGR_SW_2 (0x4UL << RCC_CFGR_SW_Pos) |
| #define | RCC_CFGR_SW_HSI (0x00000000UL) |
| #define | RCC_CFGR_SW_CSI (0x00000001UL) |
| #define | RCC_CFGR_SW_HSE (0x00000002UL) |
| #define | RCC_CFGR_SW_PLL1 (0x00000003UL) |
| #define | RCC_CFGR_SWS_Pos (3U) |
| #define | RCC_CFGR_SWS_Msk (0x7UL << RCC_CFGR_SWS_Pos) |
| #define | RCC_CFGR_SWS RCC_CFGR_SWS_Msk |
| #define | RCC_CFGR_SWS_0 (0x1UL << RCC_CFGR_SWS_Pos) |
| #define | RCC_CFGR_SWS_1 (0x2UL << RCC_CFGR_SWS_Pos) |
| #define | RCC_CFGR_SWS_2 (0x4UL << RCC_CFGR_SWS_Pos) |
| #define | RCC_CFGR_SWS_HSI (0x00000000UL) |
| #define | RCC_CFGR_SWS_CSI (0x00000008UL) |
| #define | RCC_CFGR_SWS_HSE (0x00000010UL) |
| #define | RCC_CFGR_SWS_PLL1 (0x00000018UL) |
| #define | RCC_CFGR_STOPWUCK_Pos (6U) |
| #define | RCC_CFGR_STOPWUCK_Msk (0x1UL << RCC_CFGR_STOPWUCK_Pos) |
| #define | RCC_CFGR_STOPWUCK RCC_CFGR_STOPWUCK_Msk |
| #define | RCC_CFGR_STOPKERWUCK_Pos (7U) |
| #define | RCC_CFGR_STOPKERWUCK_Msk (0x1UL << RCC_CFGR_STOPKERWUCK_Pos) |
| #define | RCC_CFGR_STOPKERWUCK RCC_CFGR_STOPKERWUCK_Msk |
| #define | RCC_CFGR_RTCPRE_Pos (8U) |
| #define | RCC_CFGR_RTCPRE_Msk (0x3FUL << RCC_CFGR_RTCPRE_Pos) |
| #define | RCC_CFGR_RTCPRE RCC_CFGR_RTCPRE_Msk |
| #define | RCC_CFGR_RTCPRE_0 (0x1UL << RCC_CFGR_RTCPRE_Pos) |
| #define | RCC_CFGR_RTCPRE_1 (0x2UL << RCC_CFGR_RTCPRE_Pos) |
| #define | RCC_CFGR_RTCPRE_2 (0x4UL << RCC_CFGR_RTCPRE_Pos) |
| #define | RCC_CFGR_RTCPRE_3 (0x8UL << RCC_CFGR_RTCPRE_Pos) |
| #define | RCC_CFGR_RTCPRE_4 (0x10UL << RCC_CFGR_RTCPRE_Pos) |
| #define | RCC_CFGR_RTCPRE_5 (0x20UL << RCC_CFGR_RTCPRE_Pos) |
| #define | RCC_CFGR_HRTIMSEL_Pos (14U) |
| #define | RCC_CFGR_HRTIMSEL_Msk (0x1UL << RCC_CFGR_HRTIMSEL_Pos) |
| #define | RCC_CFGR_HRTIMSEL RCC_CFGR_HRTIMSEL_Msk |
| #define | RCC_CFGR_TIMPRE_Pos (15U) |
| #define | RCC_CFGR_TIMPRE_Msk (0x1UL << RCC_CFGR_TIMPRE_Pos) |
| #define | RCC_CFGR_TIMPRE RCC_CFGR_TIMPRE_Msk |
| #define | RCC_CFGR_MCO1_Pos (22U) |
| #define | RCC_CFGR_MCO1_Msk (0x7UL << RCC_CFGR_MCO1_Pos) |
| #define | RCC_CFGR_MCO1 RCC_CFGR_MCO1_Msk |
| #define | RCC_CFGR_MCO1_0 (0x1UL << RCC_CFGR_MCO1_Pos) |
| #define | RCC_CFGR_MCO1_1 (0x2UL << RCC_CFGR_MCO1_Pos) |
| #define | RCC_CFGR_MCO1_2 (0x4UL << RCC_CFGR_MCO1_Pos) |
| #define | RCC_CFGR_MCO1PRE_Pos (18U) |
| #define | RCC_CFGR_MCO1PRE_Msk (0xFUL << RCC_CFGR_MCO1PRE_Pos) |
| #define | RCC_CFGR_MCO1PRE RCC_CFGR_MCO1PRE_Msk |
| #define | RCC_CFGR_MCO1PRE_0 (0x1UL << RCC_CFGR_MCO1PRE_Pos) |
| #define | RCC_CFGR_MCO1PRE_1 (0x2UL << RCC_CFGR_MCO1PRE_Pos) |
| #define | RCC_CFGR_MCO1PRE_2 (0x4UL << RCC_CFGR_MCO1PRE_Pos) |
| #define | RCC_CFGR_MCO1PRE_3 (0x8UL << RCC_CFGR_MCO1PRE_Pos) |
| #define | RCC_CFGR_MCO2PRE_Pos (25U) |
| #define | RCC_CFGR_MCO2PRE_Msk (0xFUL << RCC_CFGR_MCO2PRE_Pos) |
| #define | RCC_CFGR_MCO2PRE RCC_CFGR_MCO2PRE_Msk |
| #define | RCC_CFGR_MCO2PRE_0 (0x1UL << RCC_CFGR_MCO2PRE_Pos) |
| #define | RCC_CFGR_MCO2PRE_1 (0x2UL << RCC_CFGR_MCO2PRE_Pos) |
| #define | RCC_CFGR_MCO2PRE_2 (0x4UL << RCC_CFGR_MCO2PRE_Pos) |
| #define | RCC_CFGR_MCO2PRE_3 (0x8UL << RCC_CFGR_MCO2PRE_Pos) |
| #define | RCC_CFGR_MCO2_Pos (29U) |
| #define | RCC_CFGR_MCO2_Msk (0x7UL << RCC_CFGR_MCO2_Pos) |
| #define | RCC_CFGR_MCO2 RCC_CFGR_MCO2_Msk |
| #define | RCC_CFGR_MCO2_0 (0x1UL << RCC_CFGR_MCO2_Pos) |
| #define | RCC_CFGR_MCO2_1 (0x2UL << RCC_CFGR_MCO2_Pos) |
| #define | RCC_CFGR_MCO2_2 (0x4UL << RCC_CFGR_MCO2_Pos) |
| #define | RCC_D1CFGR_HPRE_Pos (0U) |
| #define | RCC_D1CFGR_HPRE_Msk (0xFUL << RCC_D1CFGR_HPRE_Pos) |
| #define | RCC_D1CFGR_HPRE RCC_D1CFGR_HPRE_Msk |
| #define | RCC_D1CFGR_HPRE_0 (0x1UL << RCC_D1CFGR_HPRE_Pos) |
| #define | RCC_D1CFGR_HPRE_1 (0x2UL << RCC_D1CFGR_HPRE_Pos) |
| #define | RCC_D1CFGR_HPRE_2 (0x4UL << RCC_D1CFGR_HPRE_Pos) |
| #define | RCC_D1CFGR_HPRE_3 (0x8UL << RCC_D1CFGR_HPRE_Pos) |
| #define | RCC_D1CFGR_HPRE_DIV1 (0U) |
| #define | RCC_D1CFGR_HPRE_DIV2_Pos (3U) |
| #define | RCC_D1CFGR_HPRE_DIV2_Msk (0x1UL << RCC_D1CFGR_HPRE_DIV2_Pos) |
| #define | RCC_D1CFGR_HPRE_DIV2 RCC_D1CFGR_HPRE_DIV2_Msk |
| #define | RCC_D1CFGR_HPRE_DIV4_Pos (0U) |
| #define | RCC_D1CFGR_HPRE_DIV4_Msk (0x9UL << RCC_D1CFGR_HPRE_DIV4_Pos) |
| #define | RCC_D1CFGR_HPRE_DIV4 RCC_D1CFGR_HPRE_DIV4_Msk |
| #define | RCC_D1CFGR_HPRE_DIV8_Pos (1U) |
| #define | RCC_D1CFGR_HPRE_DIV8_Msk (0x5UL << RCC_D1CFGR_HPRE_DIV8_Pos) |
| #define | RCC_D1CFGR_HPRE_DIV8 RCC_D1CFGR_HPRE_DIV8_Msk |
| #define | RCC_D1CFGR_HPRE_DIV16_Pos (0U) |
| #define | RCC_D1CFGR_HPRE_DIV16_Msk (0xBUL << RCC_D1CFGR_HPRE_DIV16_Pos) |
| #define | RCC_D1CFGR_HPRE_DIV16 RCC_D1CFGR_HPRE_DIV16_Msk |
| #define | RCC_D1CFGR_HPRE_DIV64_Pos (2U) |
| #define | RCC_D1CFGR_HPRE_DIV64_Msk (0x3UL << RCC_D1CFGR_HPRE_DIV64_Pos) |
| #define | RCC_D1CFGR_HPRE_DIV64 RCC_D1CFGR_HPRE_DIV64_Msk |
| #define | RCC_D1CFGR_HPRE_DIV128_Pos (0U) |
| #define | RCC_D1CFGR_HPRE_DIV128_Msk (0xDUL << RCC_D1CFGR_HPRE_DIV128_Pos) |
| #define | RCC_D1CFGR_HPRE_DIV128 RCC_D1CFGR_HPRE_DIV128_Msk |
| #define | RCC_D1CFGR_HPRE_DIV256_Pos (1U) |
| #define | RCC_D1CFGR_HPRE_DIV256_Msk (0x7UL << RCC_D1CFGR_HPRE_DIV256_Pos) |
| #define | RCC_D1CFGR_HPRE_DIV256 RCC_D1CFGR_HPRE_DIV256_Msk |
| #define | RCC_D1CFGR_HPRE_DIV512_Pos (0U) |
| #define | RCC_D1CFGR_HPRE_DIV512_Msk (0xFUL << RCC_D1CFGR_HPRE_DIV512_Pos) |
| #define | RCC_D1CFGR_HPRE_DIV512 RCC_D1CFGR_HPRE_DIV512_Msk |
| #define | RCC_D1CFGR_D1PPRE_Pos (4U) |
| #define | RCC_D1CFGR_D1PPRE_Msk (0x7UL << RCC_D1CFGR_D1PPRE_Pos) |
| #define | RCC_D1CFGR_D1PPRE RCC_D1CFGR_D1PPRE_Msk |
| #define | RCC_D1CFGR_D1PPRE_0 (0x1UL << RCC_D1CFGR_D1PPRE_Pos) |
| #define | RCC_D1CFGR_D1PPRE_1 (0x2UL << RCC_D1CFGR_D1PPRE_Pos) |
| #define | RCC_D1CFGR_D1PPRE_2 (0x4UL << RCC_D1CFGR_D1PPRE_Pos) |
| #define | RCC_D1CFGR_D1PPRE_DIV1 (0U) |
| #define | RCC_D1CFGR_D1PPRE_DIV2_Pos (6U) |
| #define | RCC_D1CFGR_D1PPRE_DIV2_Msk (0x1UL << RCC_D1CFGR_D1PPRE_DIV2_Pos) |
| #define | RCC_D1CFGR_D1PPRE_DIV2 RCC_D1CFGR_D1PPRE_DIV2_Msk |
| #define | RCC_D1CFGR_D1PPRE_DIV4_Pos (4U) |
| #define | RCC_D1CFGR_D1PPRE_DIV4_Msk (0x5UL << RCC_D1CFGR_D1PPRE_DIV4_Pos) |
| #define | RCC_D1CFGR_D1PPRE_DIV4 RCC_D1CFGR_D1PPRE_DIV4_Msk |
| #define | RCC_D1CFGR_D1PPRE_DIV8_Pos (5U) |
| #define | RCC_D1CFGR_D1PPRE_DIV8_Msk (0x3UL << RCC_D1CFGR_D1PPRE_DIV8_Pos) |
| #define | RCC_D1CFGR_D1PPRE_DIV8 RCC_D1CFGR_D1PPRE_DIV8_Msk |
| #define | RCC_D1CFGR_D1PPRE_DIV16_Pos (4U) |
| #define | RCC_D1CFGR_D1PPRE_DIV16_Msk (0x7UL << RCC_D1CFGR_D1PPRE_DIV16_Pos) |
| #define | RCC_D1CFGR_D1PPRE_DIV16 RCC_D1CFGR_D1PPRE_DIV16_Msk |
| #define | RCC_D1CFGR_D1CPRE_Pos (8U) |
| #define | RCC_D1CFGR_D1CPRE_Msk (0xFUL << RCC_D1CFGR_D1CPRE_Pos) |
| #define | RCC_D1CFGR_D1CPRE RCC_D1CFGR_D1CPRE_Msk |
| #define | RCC_D1CFGR_D1CPRE_0 (0x1UL << RCC_D1CFGR_D1CPRE_Pos) |
| #define | RCC_D1CFGR_D1CPRE_1 (0x2UL << RCC_D1CFGR_D1CPRE_Pos) |
| #define | RCC_D1CFGR_D1CPRE_2 (0x4UL << RCC_D1CFGR_D1CPRE_Pos) |
| #define | RCC_D1CFGR_D1CPRE_3 (0x8UL << RCC_D1CFGR_D1CPRE_Pos) |
| #define | RCC_D1CFGR_D1CPRE_DIV1 (0U) |
| #define | RCC_D1CFGR_D1CPRE_DIV2_Pos (11U) |
| #define | RCC_D1CFGR_D1CPRE_DIV2_Msk (0x1UL << RCC_D1CFGR_D1CPRE_DIV2_Pos) |
| #define | RCC_D1CFGR_D1CPRE_DIV2 RCC_D1CFGR_D1CPRE_DIV2_Msk |
| #define | RCC_D1CFGR_D1CPRE_DIV4_Pos (8U) |
| #define | RCC_D1CFGR_D1CPRE_DIV4_Msk (0x9UL << RCC_D1CFGR_D1CPRE_DIV4_Pos) |
| #define | RCC_D1CFGR_D1CPRE_DIV4 RCC_D1CFGR_D1CPRE_DIV4_Msk |
| #define | RCC_D1CFGR_D1CPRE_DIV8_Pos (9U) |
| #define | RCC_D1CFGR_D1CPRE_DIV8_Msk (0x5UL << RCC_D1CFGR_D1CPRE_DIV8_Pos) |
| #define | RCC_D1CFGR_D1CPRE_DIV8 RCC_D1CFGR_D1CPRE_DIV8_Msk |
| #define | RCC_D1CFGR_D1CPRE_DIV16_Pos (8U) |
| #define | RCC_D1CFGR_D1CPRE_DIV16_Msk (0xBUL << RCC_D1CFGR_D1CPRE_DIV16_Pos) |
| #define | RCC_D1CFGR_D1CPRE_DIV16 RCC_D1CFGR_D1CPRE_DIV16_Msk |
| #define | RCC_D1CFGR_D1CPRE_DIV64_Pos (10U) |
| #define | RCC_D1CFGR_D1CPRE_DIV64_Msk (0x3UL << RCC_D1CFGR_D1CPRE_DIV64_Pos) |
| #define | RCC_D1CFGR_D1CPRE_DIV64 RCC_D1CFGR_D1CPRE_DIV64_Msk |
| #define | RCC_D1CFGR_D1CPRE_DIV128_Pos (8U) |
| #define | RCC_D1CFGR_D1CPRE_DIV128_Msk (0xDUL << RCC_D1CFGR_D1CPRE_DIV128_Pos) |
| #define | RCC_D1CFGR_D1CPRE_DIV128 RCC_D1CFGR_D1CPRE_DIV128_Msk |
| #define | RCC_D1CFGR_D1CPRE_DIV256_Pos (9U) |
| #define | RCC_D1CFGR_D1CPRE_DIV256_Msk (0x7UL << RCC_D1CFGR_D1CPRE_DIV256_Pos) |
| #define | RCC_D1CFGR_D1CPRE_DIV256 RCC_D1CFGR_D1CPRE_DIV256_Msk |
| #define | RCC_D1CFGR_D1CPRE_DIV512_Pos (8U) |
| #define | RCC_D1CFGR_D1CPRE_DIV512_Msk (0xFUL << RCC_D1CFGR_D1CPRE_DIV512_Pos) |
| #define | RCC_D1CFGR_D1CPRE_DIV512 RCC_D1CFGR_D1CPRE_DIV512_Msk |
| #define | RCC_D2CFGR_D2PPRE1_Pos (4U) |
| #define | RCC_D2CFGR_D2PPRE1_Msk (0x7UL << RCC_D2CFGR_D2PPRE1_Pos) |
| #define | RCC_D2CFGR_D2PPRE1 RCC_D2CFGR_D2PPRE1_Msk |
| #define | RCC_D2CFGR_D2PPRE1_0 (0x1UL << RCC_D2CFGR_D2PPRE1_Pos) |
| #define | RCC_D2CFGR_D2PPRE1_1 (0x2UL << RCC_D2CFGR_D2PPRE1_Pos) |
| #define | RCC_D2CFGR_D2PPRE1_2 (0x4UL << RCC_D2CFGR_D2PPRE1_Pos) |
| #define | RCC_D2CFGR_D2PPRE1_DIV1 (0U) |
| #define | RCC_D2CFGR_D2PPRE1_DIV2_Pos (6U) |
| #define | RCC_D2CFGR_D2PPRE1_DIV2_Msk (0x1UL << RCC_D2CFGR_D2PPRE1_DIV2_Pos) |
| #define | RCC_D2CFGR_D2PPRE1_DIV2 RCC_D2CFGR_D2PPRE1_DIV2_Msk |
| #define | RCC_D2CFGR_D2PPRE1_DIV4_Pos (4U) |
| #define | RCC_D2CFGR_D2PPRE1_DIV4_Msk (0x5UL << RCC_D2CFGR_D2PPRE1_DIV4_Pos) |
| #define | RCC_D2CFGR_D2PPRE1_DIV4 RCC_D2CFGR_D2PPRE1_DIV4_Msk |
| #define | RCC_D2CFGR_D2PPRE1_DIV8_Pos (5U) |
| #define | RCC_D2CFGR_D2PPRE1_DIV8_Msk (0x3UL << RCC_D2CFGR_D2PPRE1_DIV8_Pos) |
| #define | RCC_D2CFGR_D2PPRE1_DIV8 RCC_D2CFGR_D2PPRE1_DIV8_Msk |
| #define | RCC_D2CFGR_D2PPRE1_DIV16_Pos (4U) |
| #define | RCC_D2CFGR_D2PPRE1_DIV16_Msk (0x7UL << RCC_D2CFGR_D2PPRE1_DIV16_Pos) |
| #define | RCC_D2CFGR_D2PPRE1_DIV16 RCC_D2CFGR_D2PPRE1_DIV16_Msk |
| #define | RCC_D2CFGR_D2PPRE2_Pos (8U) |
| #define | RCC_D2CFGR_D2PPRE2_Msk (0x7UL << RCC_D2CFGR_D2PPRE2_Pos) |
| #define | RCC_D2CFGR_D2PPRE2 RCC_D2CFGR_D2PPRE2_Msk |
| #define | RCC_D2CFGR_D2PPRE2_0 (0x1UL << RCC_D2CFGR_D2PPRE2_Pos) |
| #define | RCC_D2CFGR_D2PPRE2_1 (0x2UL << RCC_D2CFGR_D2PPRE2_Pos) |
| #define | RCC_D2CFGR_D2PPRE2_2 (0x4UL << RCC_D2CFGR_D2PPRE2_Pos) |
| #define | RCC_D2CFGR_D2PPRE2_DIV1 (0U) |
| #define | RCC_D2CFGR_D2PPRE2_DIV2_Pos (10U) |
| #define | RCC_D2CFGR_D2PPRE2_DIV2_Msk (0x1UL << RCC_D2CFGR_D2PPRE2_DIV2_Pos) |
| #define | RCC_D2CFGR_D2PPRE2_DIV2 RCC_D2CFGR_D2PPRE2_DIV2_Msk |
| #define | RCC_D2CFGR_D2PPRE2_DIV4_Pos (8U) |
| #define | RCC_D2CFGR_D2PPRE2_DIV4_Msk (0x5UL << RCC_D2CFGR_D2PPRE2_DIV4_Pos) |
| #define | RCC_D2CFGR_D2PPRE2_DIV4 RCC_D2CFGR_D2PPRE2_DIV4_Msk |
| #define | RCC_D2CFGR_D2PPRE2_DIV8_Pos (9U) |
| #define | RCC_D2CFGR_D2PPRE2_DIV8_Msk (0x3UL << RCC_D2CFGR_D2PPRE2_DIV8_Pos) |
| #define | RCC_D2CFGR_D2PPRE2_DIV8 RCC_D2CFGR_D2PPRE2_DIV8_Msk |
| #define | RCC_D2CFGR_D2PPRE2_DIV16_Pos (8U) |
| #define | RCC_D2CFGR_D2PPRE2_DIV16_Msk (0x7UL << RCC_D2CFGR_D2PPRE2_DIV16_Pos) |
| #define | RCC_D2CFGR_D2PPRE2_DIV16 RCC_D2CFGR_D2PPRE2_DIV16_Msk |
| #define | RCC_D3CFGR_D3PPRE_Pos (4U) |
| #define | RCC_D3CFGR_D3PPRE_Msk (0x7UL << RCC_D3CFGR_D3PPRE_Pos) |
| #define | RCC_D3CFGR_D3PPRE RCC_D3CFGR_D3PPRE_Msk |
| #define | RCC_D3CFGR_D3PPRE_0 (0x1UL << RCC_D3CFGR_D3PPRE_Pos) |
| #define | RCC_D3CFGR_D3PPRE_1 (0x2UL << RCC_D3CFGR_D3PPRE_Pos) |
| #define | RCC_D3CFGR_D3PPRE_2 (0x4UL << RCC_D3CFGR_D3PPRE_Pos) |
| #define | RCC_D3CFGR_D3PPRE_DIV1 (0U) |
| #define | RCC_D3CFGR_D3PPRE_DIV2_Pos (6U) |
| #define | RCC_D3CFGR_D3PPRE_DIV2_Msk (0x1UL << RCC_D3CFGR_D3PPRE_DIV2_Pos) |
| #define | RCC_D3CFGR_D3PPRE_DIV2 RCC_D3CFGR_D3PPRE_DIV2_Msk |
| #define | RCC_D3CFGR_D3PPRE_DIV4_Pos (4U) |
| #define | RCC_D3CFGR_D3PPRE_DIV4_Msk (0x5UL << RCC_D3CFGR_D3PPRE_DIV4_Pos) |
| #define | RCC_D3CFGR_D3PPRE_DIV4 RCC_D3CFGR_D3PPRE_DIV4_Msk |
| #define | RCC_D3CFGR_D3PPRE_DIV8_Pos (5U) |
| #define | RCC_D3CFGR_D3PPRE_DIV8_Msk (0x3UL << RCC_D3CFGR_D3PPRE_DIV8_Pos) |
| #define | RCC_D3CFGR_D3PPRE_DIV8 RCC_D3CFGR_D3PPRE_DIV8_Msk |
| #define | RCC_D3CFGR_D3PPRE_DIV16_Pos (4U) |
| #define | RCC_D3CFGR_D3PPRE_DIV16_Msk (0x7UL << RCC_D3CFGR_D3PPRE_DIV16_Pos) |
| #define | RCC_D3CFGR_D3PPRE_DIV16 RCC_D3CFGR_D3PPRE_DIV16_Msk |
| #define | RCC_PLLCKSELR_PLLSRC_Pos (0U) |
| #define | RCC_PLLCKSELR_PLLSRC_Msk (0x3UL << RCC_PLLCKSELR_PLLSRC_Pos) |
| #define | RCC_PLLCKSELR_PLLSRC RCC_PLLCKSELR_PLLSRC_Msk |
| #define | RCC_PLLCKSELR_PLLSRC_HSI (0U) |
| #define | RCC_PLLCKSELR_PLLSRC_CSI_Pos (0U) |
| #define | RCC_PLLCKSELR_PLLSRC_CSI_Msk (0x1UL << RCC_PLLCKSELR_PLLSRC_CSI_Pos) |
| #define | RCC_PLLCKSELR_PLLSRC_CSI RCC_PLLCKSELR_PLLSRC_CSI_Msk |
| #define | RCC_PLLCKSELR_PLLSRC_HSE_Pos (1U) |
| #define | RCC_PLLCKSELR_PLLSRC_HSE_Msk (0x1UL << RCC_PLLCKSELR_PLLSRC_HSE_Pos) |
| #define | RCC_PLLCKSELR_PLLSRC_HSE RCC_PLLCKSELR_PLLSRC_HSE_Msk |
| #define | RCC_PLLCKSELR_PLLSRC_NONE_Pos (0U) |
| #define | RCC_PLLCKSELR_PLLSRC_NONE_Msk (0x3UL << RCC_PLLCKSELR_PLLSRC_NONE_Pos) |
| #define | RCC_PLLCKSELR_PLLSRC_NONE RCC_PLLCKSELR_PLLSRC_NONE_Msk |
| #define | RCC_PLLCKSELR_DIVM1_Pos (4U) |
| #define | RCC_PLLCKSELR_DIVM1_Msk (0x3FUL << RCC_PLLCKSELR_DIVM1_Pos) |
| #define | RCC_PLLCKSELR_DIVM1 RCC_PLLCKSELR_DIVM1_Msk |
| #define | RCC_PLLCKSELR_DIVM1_0 (0x01UL << RCC_PLLCKSELR_DIVM1_Pos) |
| #define | RCC_PLLCKSELR_DIVM1_1 (0x02UL << RCC_PLLCKSELR_DIVM1_Pos) |
| #define | RCC_PLLCKSELR_DIVM1_2 (0x04UL << RCC_PLLCKSELR_DIVM1_Pos) |
| #define | RCC_PLLCKSELR_DIVM1_3 (0x08UL << RCC_PLLCKSELR_DIVM1_Pos) |
| #define | RCC_PLLCKSELR_DIVM1_4 (0x10UL << RCC_PLLCKSELR_DIVM1_Pos) |
| #define | RCC_PLLCKSELR_DIVM1_5 (0x20UL << RCC_PLLCKSELR_DIVM1_Pos) |
| #define | RCC_PLLCKSELR_DIVM2_Pos (12U) |
| #define | RCC_PLLCKSELR_DIVM2_Msk (0x3FUL << RCC_PLLCKSELR_DIVM2_Pos) |
| #define | RCC_PLLCKSELR_DIVM2 RCC_PLLCKSELR_DIVM2_Msk |
| #define | RCC_PLLCKSELR_DIVM2_0 (0x01UL << RCC_PLLCKSELR_DIVM2_Pos) |
| #define | RCC_PLLCKSELR_DIVM2_1 (0x02UL << RCC_PLLCKSELR_DIVM2_Pos) |
| #define | RCC_PLLCKSELR_DIVM2_2 (0x04UL << RCC_PLLCKSELR_DIVM2_Pos) |
| #define | RCC_PLLCKSELR_DIVM2_3 (0x08UL << RCC_PLLCKSELR_DIVM2_Pos) |
| #define | RCC_PLLCKSELR_DIVM2_4 (0x10UL << RCC_PLLCKSELR_DIVM2_Pos) |
| #define | RCC_PLLCKSELR_DIVM2_5 (0x20UL << RCC_PLLCKSELR_DIVM2_Pos) |
| #define | RCC_PLLCKSELR_DIVM3_Pos (20U) |
| #define | RCC_PLLCKSELR_DIVM3_Msk (0x3FUL << RCC_PLLCKSELR_DIVM3_Pos) |
| #define | RCC_PLLCKSELR_DIVM3 RCC_PLLCKSELR_DIVM3_Msk |
| #define | RCC_PLLCKSELR_DIVM3_0 (0x01UL << RCC_PLLCKSELR_DIVM3_Pos) |
| #define | RCC_PLLCKSELR_DIVM3_1 (0x02UL << RCC_PLLCKSELR_DIVM3_Pos) |
| #define | RCC_PLLCKSELR_DIVM3_2 (0x04UL << RCC_PLLCKSELR_DIVM3_Pos) |
| #define | RCC_PLLCKSELR_DIVM3_3 (0x08UL << RCC_PLLCKSELR_DIVM3_Pos) |
| #define | RCC_PLLCKSELR_DIVM3_4 (0x10UL << RCC_PLLCKSELR_DIVM3_Pos) |
| #define | RCC_PLLCKSELR_DIVM3_5 (0x20UL << RCC_PLLCKSELR_DIVM3_Pos) |
| #define | RCC_PLLCFGR_PLL1FRACEN_Pos (0U) |
| #define | RCC_PLLCFGR_PLL1FRACEN_Msk (0x1UL << RCC_PLLCFGR_PLL1FRACEN_Pos) |
| #define | RCC_PLLCFGR_PLL1FRACEN RCC_PLLCFGR_PLL1FRACEN_Msk |
| #define | RCC_PLLCFGR_PLL1VCOSEL_Pos (1U) |
| #define | RCC_PLLCFGR_PLL1VCOSEL_Msk (0x1UL << RCC_PLLCFGR_PLL1VCOSEL_Pos) |
| #define | RCC_PLLCFGR_PLL1VCOSEL RCC_PLLCFGR_PLL1VCOSEL_Msk |
| #define | RCC_PLLCFGR_PLL1RGE_Pos (2U) |
| #define | RCC_PLLCFGR_PLL1RGE_Msk (0x3UL << RCC_PLLCFGR_PLL1RGE_Pos) |
| #define | RCC_PLLCFGR_PLL1RGE RCC_PLLCFGR_PLL1RGE_Msk |
| #define | RCC_PLLCFGR_PLL1RGE_0 (0x0UL << RCC_PLLCFGR_PLL1RGE_Pos) |
| #define | RCC_PLLCFGR_PLL1RGE_1 (0x1UL << RCC_PLLCFGR_PLL1RGE_Pos) |
| #define | RCC_PLLCFGR_PLL1RGE_2 (0x2UL << RCC_PLLCFGR_PLL1RGE_Pos) |
| #define | RCC_PLLCFGR_PLL1RGE_3 (0x3UL << RCC_PLLCFGR_PLL1RGE_Pos) |
| #define | RCC_PLLCFGR_PLL2FRACEN_Pos (4U) |
| #define | RCC_PLLCFGR_PLL2FRACEN_Msk (0x1UL << RCC_PLLCFGR_PLL2FRACEN_Pos) |
| #define | RCC_PLLCFGR_PLL2FRACEN RCC_PLLCFGR_PLL2FRACEN_Msk |
| #define | RCC_PLLCFGR_PLL2VCOSEL_Pos (5U) |
| #define | RCC_PLLCFGR_PLL2VCOSEL_Msk (0x1UL << RCC_PLLCFGR_PLL2VCOSEL_Pos) |
| #define | RCC_PLLCFGR_PLL2VCOSEL RCC_PLLCFGR_PLL2VCOSEL_Msk |
| #define | RCC_PLLCFGR_PLL2RGE_Pos (6U) |
| #define | RCC_PLLCFGR_PLL2RGE_Msk (0x3UL << RCC_PLLCFGR_PLL2RGE_Pos) |
| #define | RCC_PLLCFGR_PLL2RGE RCC_PLLCFGR_PLL2RGE_Msk |
| #define | RCC_PLLCFGR_PLL2RGE_0 (0x0UL << RCC_PLLCFGR_PLL2RGE_Pos) |
| #define | RCC_PLLCFGR_PLL2RGE_1 (0x1UL << RCC_PLLCFGR_PLL2RGE_Pos) |
| #define | RCC_PLLCFGR_PLL2RGE_2 (0x2UL << RCC_PLLCFGR_PLL2RGE_Pos) |
| #define | RCC_PLLCFGR_PLL2RGE_3 (0x3UL << RCC_PLLCFGR_PLL2RGE_Pos) |
| #define | RCC_PLLCFGR_PLL3FRACEN_Pos (8U) |
| #define | RCC_PLLCFGR_PLL3FRACEN_Msk (0x1UL << RCC_PLLCFGR_PLL3FRACEN_Pos) |
| #define | RCC_PLLCFGR_PLL3FRACEN RCC_PLLCFGR_PLL3FRACEN_Msk |
| #define | RCC_PLLCFGR_PLL3VCOSEL_Pos (9U) |
| #define | RCC_PLLCFGR_PLL3VCOSEL_Msk (0x1UL << RCC_PLLCFGR_PLL3VCOSEL_Pos) |
| #define | RCC_PLLCFGR_PLL3VCOSEL RCC_PLLCFGR_PLL3VCOSEL_Msk |
| #define | RCC_PLLCFGR_PLL3RGE_Pos (10U) |
| #define | RCC_PLLCFGR_PLL3RGE_Msk (0x3UL << RCC_PLLCFGR_PLL3RGE_Pos) |
| #define | RCC_PLLCFGR_PLL3RGE RCC_PLLCFGR_PLL3RGE_Msk |
| #define | RCC_PLLCFGR_PLL3RGE_0 (0x0UL << RCC_PLLCFGR_PLL3RGE_Pos) |
| #define | RCC_PLLCFGR_PLL3RGE_1 (0x1UL << RCC_PLLCFGR_PLL3RGE_Pos) |
| #define | RCC_PLLCFGR_PLL3RGE_2 (0x2UL << RCC_PLLCFGR_PLL3RGE_Pos) |
| #define | RCC_PLLCFGR_PLL3RGE_3 (0x3UL << RCC_PLLCFGR_PLL3RGE_Pos) |
| #define | RCC_PLLCFGR_DIVP1EN_Pos (16U) |
| #define | RCC_PLLCFGR_DIVP1EN_Msk (0x1UL << RCC_PLLCFGR_DIVP1EN_Pos) |
| #define | RCC_PLLCFGR_DIVP1EN RCC_PLLCFGR_DIVP1EN_Msk |
| #define | RCC_PLLCFGR_DIVQ1EN_Pos (17U) |
| #define | RCC_PLLCFGR_DIVQ1EN_Msk (0x1UL << RCC_PLLCFGR_DIVQ1EN_Pos) |
| #define | RCC_PLLCFGR_DIVQ1EN RCC_PLLCFGR_DIVQ1EN_Msk |
| #define | RCC_PLLCFGR_DIVR1EN_Pos (18U) |
| #define | RCC_PLLCFGR_DIVR1EN_Msk (0x1UL << RCC_PLLCFGR_DIVR1EN_Pos) |
| #define | RCC_PLLCFGR_DIVR1EN RCC_PLLCFGR_DIVR1EN_Msk |
| #define | RCC_PLLCFGR_DIVP2EN_Pos (19U) |
| #define | RCC_PLLCFGR_DIVP2EN_Msk (0x1UL << RCC_PLLCFGR_DIVP2EN_Pos) |
| #define | RCC_PLLCFGR_DIVP2EN RCC_PLLCFGR_DIVP2EN_Msk |
| #define | RCC_PLLCFGR_DIVQ2EN_Pos (20U) |
| #define | RCC_PLLCFGR_DIVQ2EN_Msk (0x1UL << RCC_PLLCFGR_DIVQ2EN_Pos) |
| #define | RCC_PLLCFGR_DIVQ2EN RCC_PLLCFGR_DIVQ2EN_Msk |
| #define | RCC_PLLCFGR_DIVR2EN_Pos (21U) |
| #define | RCC_PLLCFGR_DIVR2EN_Msk (0x1UL << RCC_PLLCFGR_DIVR2EN_Pos) |
| #define | RCC_PLLCFGR_DIVR2EN RCC_PLLCFGR_DIVR2EN_Msk |
| #define | RCC_PLLCFGR_DIVP3EN_Pos (22U) |
| #define | RCC_PLLCFGR_DIVP3EN_Msk (0x1UL << RCC_PLLCFGR_DIVP3EN_Pos) |
| #define | RCC_PLLCFGR_DIVP3EN RCC_PLLCFGR_DIVP3EN_Msk |
| #define | RCC_PLLCFGR_DIVQ3EN_Pos (23U) |
| #define | RCC_PLLCFGR_DIVQ3EN_Msk (0x1UL << RCC_PLLCFGR_DIVQ3EN_Pos) |
| #define | RCC_PLLCFGR_DIVQ3EN RCC_PLLCFGR_DIVQ3EN_Msk |
| #define | RCC_PLLCFGR_DIVR3EN_Pos (24U) |
| #define | RCC_PLLCFGR_DIVR3EN_Msk (0x1UL << RCC_PLLCFGR_DIVR3EN_Pos) |
| #define | RCC_PLLCFGR_DIVR3EN RCC_PLLCFGR_DIVR3EN_Msk |
| #define | RCC_PLL1DIVR_N1_Pos (0U) |
| #define | RCC_PLL1DIVR_N1_Msk (0x1FFUL << RCC_PLL1DIVR_N1_Pos) |
| #define | RCC_PLL1DIVR_N1 RCC_PLL1DIVR_N1_Msk |
| #define | RCC_PLL1DIVR_P1_Pos (9U) |
| #define | RCC_PLL1DIVR_P1_Msk (0x7FUL << RCC_PLL1DIVR_P1_Pos) |
| #define | RCC_PLL1DIVR_P1 RCC_PLL1DIVR_P1_Msk |
| #define | RCC_PLL1DIVR_Q1_Pos (16U) |
| #define | RCC_PLL1DIVR_Q1_Msk (0x7FUL << RCC_PLL1DIVR_Q1_Pos) |
| #define | RCC_PLL1DIVR_Q1 RCC_PLL1DIVR_Q1_Msk |
| #define | RCC_PLL1DIVR_R1_Pos (24U) |
| #define | RCC_PLL1DIVR_R1_Msk (0x7FUL << RCC_PLL1DIVR_R1_Pos) |
| #define | RCC_PLL1DIVR_R1 RCC_PLL1DIVR_R1_Msk |
| #define | RCC_PLL1FRACR_FRACN1_Pos (3U) |
| #define | RCC_PLL1FRACR_FRACN1_Msk (0x1FFFUL << RCC_PLL1FRACR_FRACN1_Pos) |
| #define | RCC_PLL1FRACR_FRACN1 RCC_PLL1FRACR_FRACN1_Msk |
| #define | RCC_PLL2DIVR_N2_Pos (0U) |
| #define | RCC_PLL2DIVR_N2_Msk (0x1FFUL << RCC_PLL2DIVR_N2_Pos) |
| #define | RCC_PLL2DIVR_N2 RCC_PLL2DIVR_N2_Msk |
| #define | RCC_PLL2DIVR_P2_Pos (9U) |
| #define | RCC_PLL2DIVR_P2_Msk (0x7FUL << RCC_PLL2DIVR_P2_Pos) |
| #define | RCC_PLL2DIVR_P2 RCC_PLL2DIVR_P2_Msk |
| #define | RCC_PLL2DIVR_Q2_Pos (16U) |
| #define | RCC_PLL2DIVR_Q2_Msk (0x7FUL << RCC_PLL2DIVR_Q2_Pos) |
| #define | RCC_PLL2DIVR_Q2 RCC_PLL2DIVR_Q2_Msk |
| #define | RCC_PLL2DIVR_R2_Pos (24U) |
| #define | RCC_PLL2DIVR_R2_Msk (0x7FUL << RCC_PLL2DIVR_R2_Pos) |
| #define | RCC_PLL2DIVR_R2 RCC_PLL2DIVR_R2_Msk |
| #define | RCC_PLL2FRACR_FRACN2_Pos (3U) |
| #define | RCC_PLL2FRACR_FRACN2_Msk (0x1FFFUL << RCC_PLL2FRACR_FRACN2_Pos) |
| #define | RCC_PLL2FRACR_FRACN2 RCC_PLL2FRACR_FRACN2_Msk |
| #define | RCC_PLL3DIVR_N3_Pos (0U) |
| #define | RCC_PLL3DIVR_N3_Msk (0x1FFUL << RCC_PLL3DIVR_N3_Pos) |
| #define | RCC_PLL3DIVR_N3 RCC_PLL3DIVR_N3_Msk |
| #define | RCC_PLL3DIVR_P3_Pos (9U) |
| #define | RCC_PLL3DIVR_P3_Msk (0x7FUL << RCC_PLL3DIVR_P3_Pos) |
| #define | RCC_PLL3DIVR_P3 RCC_PLL3DIVR_P3_Msk |
| #define | RCC_PLL3DIVR_Q3_Pos (16U) |
| #define | RCC_PLL3DIVR_Q3_Msk (0x7FUL << RCC_PLL3DIVR_Q3_Pos) |
| #define | RCC_PLL3DIVR_Q3 RCC_PLL3DIVR_Q3_Msk |
| #define | RCC_PLL3DIVR_R3_Pos (24U) |
| #define | RCC_PLL3DIVR_R3_Msk (0x7FUL << RCC_PLL3DIVR_R3_Pos) |
| #define | RCC_PLL3DIVR_R3 RCC_PLL3DIVR_R3_Msk |
| #define | RCC_PLL3FRACR_FRACN3_Pos (3U) |
| #define | RCC_PLL3FRACR_FRACN3_Msk (0x1FFFUL << RCC_PLL3FRACR_FRACN3_Pos) |
| #define | RCC_PLL3FRACR_FRACN3 RCC_PLL3FRACR_FRACN3_Msk |
| #define | RCC_D1CCIPR_FMCSEL_Pos (0U) |
| #define | RCC_D1CCIPR_FMCSEL_Msk (0x3UL << RCC_D1CCIPR_FMCSEL_Pos) |
| #define | RCC_D1CCIPR_FMCSEL RCC_D1CCIPR_FMCSEL_Msk |
| #define | RCC_D1CCIPR_FMCSEL_0 (0x1UL << RCC_D1CCIPR_FMCSEL_Pos) |
| #define | RCC_D1CCIPR_FMCSEL_1 (0x2UL << RCC_D1CCIPR_FMCSEL_Pos) |
| #define | RCC_D1CCIPR_QSPISEL_Pos (4U) |
| #define | RCC_D1CCIPR_QSPISEL_Msk (0x3UL << RCC_D1CCIPR_QSPISEL_Pos) |
| #define | RCC_D1CCIPR_QSPISEL RCC_D1CCIPR_QSPISEL_Msk |
| #define | RCC_D1CCIPR_QSPISEL_0 (0x1UL << RCC_D1CCIPR_QSPISEL_Pos) |
| #define | RCC_D1CCIPR_QSPISEL_1 (0x2UL << RCC_D1CCIPR_QSPISEL_Pos) |
| #define | RCC_D1CCIPR_SDMMCSEL_Pos (16U) |
| #define | RCC_D1CCIPR_SDMMCSEL_Msk (0x1UL << RCC_D1CCIPR_SDMMCSEL_Pos) |
| #define | RCC_D1CCIPR_SDMMCSEL RCC_D1CCIPR_SDMMCSEL_Msk |
| #define | RCC_D1CCIPR_CKPERSEL_Pos (28U) |
| #define | RCC_D1CCIPR_CKPERSEL_Msk (0x3UL << RCC_D1CCIPR_CKPERSEL_Pos) |
| #define | RCC_D1CCIPR_CKPERSEL RCC_D1CCIPR_CKPERSEL_Msk |
| #define | RCC_D1CCIPR_CKPERSEL_0 (0x1UL << RCC_D1CCIPR_CKPERSEL_Pos) |
| #define | RCC_D1CCIPR_CKPERSEL_1 (0x2UL << RCC_D1CCIPR_CKPERSEL_Pos) |
| #define | RCC_D2CCIP1R_SAI1SEL_Pos (0U) |
| #define | RCC_D2CCIP1R_SAI1SEL_Msk (0x7UL << RCC_D2CCIP1R_SAI1SEL_Pos) |
| #define | RCC_D2CCIP1R_SAI1SEL RCC_D2CCIP1R_SAI1SEL_Msk |
| #define | RCC_D2CCIP1R_SAI1SEL_0 (0x1UL << RCC_D2CCIP1R_SAI1SEL_Pos) |
| #define | RCC_D2CCIP1R_SAI1SEL_1 (0x2UL << RCC_D2CCIP1R_SAI1SEL_Pos) |
| #define | RCC_D2CCIP1R_SAI1SEL_2 (0x4UL << RCC_D2CCIP1R_SAI1SEL_Pos) |
| #define | RCC_D2CCIP1R_SAI23SEL_Pos (6U) |
| #define | RCC_D2CCIP1R_SAI23SEL_Msk (0x7UL << RCC_D2CCIP1R_SAI23SEL_Pos) |
| #define | RCC_D2CCIP1R_SAI23SEL RCC_D2CCIP1R_SAI23SEL_Msk |
| #define | RCC_D2CCIP1R_SAI23SEL_0 (0x1UL << RCC_D2CCIP1R_SAI23SEL_Pos) |
| #define | RCC_D2CCIP1R_SAI23SEL_1 (0x2UL << RCC_D2CCIP1R_SAI23SEL_Pos) |
| #define | RCC_D2CCIP1R_SAI23SEL_2 (0x4UL << RCC_D2CCIP1R_SAI23SEL_Pos) |
| #define | RCC_D2CCIP1R_SPI123SEL_Pos (12U) |
| #define | RCC_D2CCIP1R_SPI123SEL_Msk (0x7UL << RCC_D2CCIP1R_SPI123SEL_Pos) |
| #define | RCC_D2CCIP1R_SPI123SEL RCC_D2CCIP1R_SPI123SEL_Msk |
| #define | RCC_D2CCIP1R_SPI123SEL_0 (0x1UL << RCC_D2CCIP1R_SPI123SEL_Pos) |
| #define | RCC_D2CCIP1R_SPI123SEL_1 (0x2UL << RCC_D2CCIP1R_SPI123SEL_Pos) |
| #define | RCC_D2CCIP1R_SPI123SEL_2 (0x4UL << RCC_D2CCIP1R_SPI123SEL_Pos) |
| #define | RCC_D2CCIP1R_SPI45SEL_Pos (16U) |
| #define | RCC_D2CCIP1R_SPI45SEL_Msk (0x7UL << RCC_D2CCIP1R_SPI45SEL_Pos) |
| #define | RCC_D2CCIP1R_SPI45SEL RCC_D2CCIP1R_SPI45SEL_Msk |
| #define | RCC_D2CCIP1R_SPI45SEL_0 (0x1UL << RCC_D2CCIP1R_SPI45SEL_Pos) |
| #define | RCC_D2CCIP1R_SPI45SEL_1 (0x2UL << RCC_D2CCIP1R_SPI45SEL_Pos) |
| #define | RCC_D2CCIP1R_SPI45SEL_2 (0x4UL << RCC_D2CCIP1R_SPI45SEL_Pos) |
| #define | RCC_D2CCIP1R_SPDIFSEL_Pos (20U) |
| #define | RCC_D2CCIP1R_SPDIFSEL_Msk (0x3UL << RCC_D2CCIP1R_SPDIFSEL_Pos) |
| #define | RCC_D2CCIP1R_SPDIFSEL RCC_D2CCIP1R_SPDIFSEL_Msk |
| #define | RCC_D2CCIP1R_SPDIFSEL_0 (0x1UL << RCC_D2CCIP1R_SPDIFSEL_Pos) |
| #define | RCC_D2CCIP1R_SPDIFSEL_1 (0x2UL << RCC_D2CCIP1R_SPDIFSEL_Pos) |
| #define | RCC_D2CCIP1R_DFSDM1SEL_Pos (24U) |
| #define | RCC_D2CCIP1R_DFSDM1SEL_Msk (0x1UL << RCC_D2CCIP1R_DFSDM1SEL_Pos) |
| #define | RCC_D2CCIP1R_DFSDM1SEL RCC_D2CCIP1R_DFSDM1SEL_Msk |
| #define | RCC_D2CCIP1R_FDCANSEL_Pos (28U) |
| #define | RCC_D2CCIP1R_FDCANSEL_Msk (0x3UL << RCC_D2CCIP1R_FDCANSEL_Pos) |
| #define | RCC_D2CCIP1R_FDCANSEL RCC_D2CCIP1R_FDCANSEL_Msk |
| #define | RCC_D2CCIP1R_FDCANSEL_0 (0x1UL << RCC_D2CCIP1R_FDCANSEL_Pos) |
| #define | RCC_D2CCIP1R_FDCANSEL_1 (0x2UL << RCC_D2CCIP1R_FDCANSEL_Pos) |
| #define | RCC_D2CCIP1R_SWPSEL_Pos (31U) |
| #define | RCC_D2CCIP1R_SWPSEL_Msk (0x1UL << RCC_D2CCIP1R_SWPSEL_Pos) |
| #define | RCC_D2CCIP1R_SWPSEL RCC_D2CCIP1R_SWPSEL_Msk |
| #define | RCC_D2CCIP2R_USART16SEL_Pos (3U) |
| #define | RCC_D2CCIP2R_USART16SEL_Msk (0x7UL << RCC_D2CCIP2R_USART16SEL_Pos) |
| #define | RCC_D2CCIP2R_USART16SEL RCC_D2CCIP2R_USART16SEL_Msk |
| #define | RCC_D2CCIP2R_USART16SEL_0 (0x1UL << RCC_D2CCIP2R_USART16SEL_Pos) |
| #define | RCC_D2CCIP2R_USART16SEL_1 (0x2UL << RCC_D2CCIP2R_USART16SEL_Pos) |
| #define | RCC_D2CCIP2R_USART16SEL_2 (0x4UL << RCC_D2CCIP2R_USART16SEL_Pos) |
| #define | RCC_D2CCIP2R_USART28SEL_Pos (0U) |
| #define | RCC_D2CCIP2R_USART28SEL_Msk (0x7UL << RCC_D2CCIP2R_USART28SEL_Pos) |
| #define | RCC_D2CCIP2R_USART28SEL RCC_D2CCIP2R_USART28SEL_Msk |
| #define | RCC_D2CCIP2R_USART28SEL_0 (0x1UL << RCC_D2CCIP2R_USART28SEL_Pos) |
| #define | RCC_D2CCIP2R_USART28SEL_1 (0x2UL << RCC_D2CCIP2R_USART28SEL_Pos) |
| #define | RCC_D2CCIP2R_USART28SEL_2 (0x4UL << RCC_D2CCIP2R_USART28SEL_Pos) |
| #define | RCC_D2CCIP2R_RNGSEL_Pos (8U) |
| #define | RCC_D2CCIP2R_RNGSEL_Msk (0x3UL << RCC_D2CCIP2R_RNGSEL_Pos) |
| #define | RCC_D2CCIP2R_RNGSEL RCC_D2CCIP2R_RNGSEL_Msk |
| #define | RCC_D2CCIP2R_RNGSEL_0 (0x1UL << RCC_D2CCIP2R_RNGSEL_Pos) |
| #define | RCC_D2CCIP2R_RNGSEL_1 (0x2UL << RCC_D2CCIP2R_RNGSEL_Pos) |
| #define | RCC_D2CCIP2R_I2C123SEL_Pos (12U) |
| #define | RCC_D2CCIP2R_I2C123SEL_Msk (0x3UL << RCC_D2CCIP2R_I2C123SEL_Pos) |
| #define | RCC_D2CCIP2R_I2C123SEL RCC_D2CCIP2R_I2C123SEL_Msk |
| #define | RCC_D2CCIP2R_I2C123SEL_0 (0x1UL << RCC_D2CCIP2R_I2C123SEL_Pos) |
| #define | RCC_D2CCIP2R_I2C123SEL_1 (0x2UL << RCC_D2CCIP2R_I2C123SEL_Pos) |
| #define | RCC_D2CCIP2R_USBSEL_Pos (20U) |
| #define | RCC_D2CCIP2R_USBSEL_Msk (0x3UL << RCC_D2CCIP2R_USBSEL_Pos) |
| #define | RCC_D2CCIP2R_USBSEL RCC_D2CCIP2R_USBSEL_Msk |
| #define | RCC_D2CCIP2R_USBSEL_0 (0x1UL << RCC_D2CCIP2R_USBSEL_Pos) |
| #define | RCC_D2CCIP2R_USBSEL_1 (0x2UL << RCC_D2CCIP2R_USBSEL_Pos) |
| #define | RCC_D2CCIP2R_CECSEL_Pos (22U) |
| #define | RCC_D2CCIP2R_CECSEL_Msk (0x3UL << RCC_D2CCIP2R_CECSEL_Pos) |
| #define | RCC_D2CCIP2R_CECSEL RCC_D2CCIP2R_CECSEL_Msk |
| #define | RCC_D2CCIP2R_CECSEL_0 (0x1UL << RCC_D2CCIP2R_CECSEL_Pos) |
| #define | RCC_D2CCIP2R_CECSEL_1 (0x2UL << RCC_D2CCIP2R_CECSEL_Pos) |
| #define | RCC_D2CCIP2R_LPTIM1SEL_Pos (28U) |
| #define | RCC_D2CCIP2R_LPTIM1SEL_Msk (0x7UL << RCC_D2CCIP2R_LPTIM1SEL_Pos) |
| #define | RCC_D2CCIP2R_LPTIM1SEL RCC_D2CCIP2R_LPTIM1SEL_Msk |
| #define | RCC_D2CCIP2R_LPTIM1SEL_0 (0x1UL << RCC_D2CCIP2R_LPTIM1SEL_Pos) |
| #define | RCC_D2CCIP2R_LPTIM1SEL_1 (0x2UL << RCC_D2CCIP2R_LPTIM1SEL_Pos) |
| #define | RCC_D2CCIP2R_LPTIM1SEL_2 (0x4UL << RCC_D2CCIP2R_LPTIM1SEL_Pos) |
| #define | RCC_D3CCIPR_LPUART1SEL_Pos (0U) |
| #define | RCC_D3CCIPR_LPUART1SEL_Msk (0x7UL << RCC_D3CCIPR_LPUART1SEL_Pos) |
| #define | RCC_D3CCIPR_LPUART1SEL RCC_D3CCIPR_LPUART1SEL_Msk |
| #define | RCC_D3CCIPR_LPUART1SEL_0 (0x1UL << RCC_D3CCIPR_LPUART1SEL_Pos) |
| #define | RCC_D3CCIPR_LPUART1SEL_1 (0x2UL << RCC_D3CCIPR_LPUART1SEL_Pos) |
| #define | RCC_D3CCIPR_LPUART1SEL_2 (0x4UL << RCC_D3CCIPR_LPUART1SEL_Pos) |
| #define | RCC_D3CCIPR_I2C4SEL_Pos (8U) |
| #define | RCC_D3CCIPR_I2C4SEL_Msk (0x3UL << RCC_D3CCIPR_I2C4SEL_Pos) |
| #define | RCC_D3CCIPR_I2C4SEL RCC_D3CCIPR_I2C4SEL_Msk |
| #define | RCC_D3CCIPR_I2C4SEL_0 (0x1UL << RCC_D3CCIPR_I2C4SEL_Pos) |
| #define | RCC_D3CCIPR_I2C4SEL_1 (0x2UL << RCC_D3CCIPR_I2C4SEL_Pos) |
| #define | RCC_D3CCIPR_LPTIM2SEL_Pos (10U) |
| #define | RCC_D3CCIPR_LPTIM2SEL_Msk (0x7UL << RCC_D3CCIPR_LPTIM2SEL_Pos) |
| #define | RCC_D3CCIPR_LPTIM2SEL RCC_D3CCIPR_LPTIM2SEL_Msk |
| #define | RCC_D3CCIPR_LPTIM2SEL_0 (0x1UL << RCC_D3CCIPR_LPTIM2SEL_Pos) |
| #define | RCC_D3CCIPR_LPTIM2SEL_1 (0x2UL << RCC_D3CCIPR_LPTIM2SEL_Pos) |
| #define | RCC_D3CCIPR_LPTIM2SEL_2 (0x4UL << RCC_D3CCIPR_LPTIM2SEL_Pos) |
| #define | RCC_D3CCIPR_LPTIM345SEL_Pos (13U) |
| #define | RCC_D3CCIPR_LPTIM345SEL_Msk (0x7UL << RCC_D3CCIPR_LPTIM345SEL_Pos) |
| #define | RCC_D3CCIPR_LPTIM345SEL RCC_D3CCIPR_LPTIM345SEL_Msk |
| #define | RCC_D3CCIPR_LPTIM345SEL_0 (0x1UL << RCC_D3CCIPR_LPTIM345SEL_Pos) |
| #define | RCC_D3CCIPR_LPTIM345SEL_1 (0x2UL << RCC_D3CCIPR_LPTIM345SEL_Pos) |
| #define | RCC_D3CCIPR_LPTIM345SEL_2 (0x4UL << RCC_D3CCIPR_LPTIM345SEL_Pos) |
| #define | RCC_D3CCIPR_SAI4ASEL_Pos (21U) |
| #define | RCC_D3CCIPR_SAI4ASEL_Msk (0x7UL << RCC_D3CCIPR_SAI4ASEL_Pos) |
| #define | RCC_D3CCIPR_SAI4ASEL RCC_D3CCIPR_SAI4ASEL_Msk |
| #define | RCC_D3CCIPR_SAI4ASEL_0 (0x1UL << RCC_D3CCIPR_SAI4ASEL_Pos) |
| #define | RCC_D3CCIPR_SAI4ASEL_1 (0x2UL << RCC_D3CCIPR_SAI4ASEL_Pos) |
| #define | RCC_D3CCIPR_SAI4ASEL_2 (0x4UL << RCC_D3CCIPR_SAI4ASEL_Pos) |
| #define | RCC_D3CCIPR_SAI4BSEL_Pos (24U) |
| #define | RCC_D3CCIPR_SAI4BSEL_Msk (0x7UL << RCC_D3CCIPR_SAI4BSEL_Pos) |
| #define | RCC_D3CCIPR_SAI4BSEL RCC_D3CCIPR_SAI4BSEL_Msk |
| #define | RCC_D3CCIPR_SAI4BSEL_0 (0x1UL << RCC_D3CCIPR_SAI4BSEL_Pos) |
| #define | RCC_D3CCIPR_SAI4BSEL_1 (0x2UL << RCC_D3CCIPR_SAI4BSEL_Pos) |
| #define | RCC_D3CCIPR_SAI4BSEL_2 (0x4UL << RCC_D3CCIPR_SAI4BSEL_Pos) |
| #define | RCC_D3CCIPR_ADCSEL_Pos (16U) |
| #define | RCC_D3CCIPR_ADCSEL_Msk (0x3UL << RCC_D3CCIPR_ADCSEL_Pos) |
| #define | RCC_D3CCIPR_ADCSEL RCC_D3CCIPR_ADCSEL_Msk |
| #define | RCC_D3CCIPR_ADCSEL_0 (0x1UL << RCC_D3CCIPR_ADCSEL_Pos) |
| #define | RCC_D3CCIPR_ADCSEL_1 (0x2UL << RCC_D3CCIPR_ADCSEL_Pos) |
| #define | RCC_D3CCIPR_SPI6SEL_Pos (28U) |
| #define | RCC_D3CCIPR_SPI6SEL_Msk (0x7UL << RCC_D3CCIPR_SPI6SEL_Pos) |
| #define | RCC_D3CCIPR_SPI6SEL RCC_D3CCIPR_SPI6SEL_Msk |
| #define | RCC_D3CCIPR_SPI6SEL_0 (0x1UL << RCC_D3CCIPR_SPI6SEL_Pos) |
| #define | RCC_D3CCIPR_SPI6SEL_1 (0x2UL << RCC_D3CCIPR_SPI6SEL_Pos) |
| #define | RCC_D3CCIPR_SPI6SEL_2 (0x4UL << RCC_D3CCIPR_SPI6SEL_Pos) |
| #define | RCC_CIER_LSIRDYIE_Pos (0U) |
| #define | RCC_CIER_LSIRDYIE_Msk (0x1UL << RCC_CIER_LSIRDYIE_Pos) |
| #define | RCC_CIER_LSIRDYIE RCC_CIER_LSIRDYIE_Msk |
| #define | RCC_CIER_LSERDYIE_Pos (1U) |
| #define | RCC_CIER_LSERDYIE_Msk (0x1UL << RCC_CIER_LSERDYIE_Pos) |
| #define | RCC_CIER_LSERDYIE RCC_CIER_LSERDYIE_Msk |
| #define | RCC_CIER_HSIRDYIE_Pos (2U) |
| #define | RCC_CIER_HSIRDYIE_Msk (0x1UL << RCC_CIER_HSIRDYIE_Pos) |
| #define | RCC_CIER_HSIRDYIE RCC_CIER_HSIRDYIE_Msk |
| #define | RCC_CIER_HSERDYIE_Pos (3U) |
| #define | RCC_CIER_HSERDYIE_Msk (0x1UL << RCC_CIER_HSERDYIE_Pos) |
| #define | RCC_CIER_HSERDYIE RCC_CIER_HSERDYIE_Msk |
| #define | RCC_CIER_CSIRDYIE_Pos (4U) |
| #define | RCC_CIER_CSIRDYIE_Msk (0x1UL << RCC_CIER_CSIRDYIE_Pos) |
| #define | RCC_CIER_CSIRDYIE RCC_CIER_CSIRDYIE_Msk |
| #define | RCC_CIER_HSI48RDYIE_Pos (5U) |
| #define | RCC_CIER_HSI48RDYIE_Msk (0x1UL << RCC_CIER_HSI48RDYIE_Pos) |
| #define | RCC_CIER_HSI48RDYIE RCC_CIER_HSI48RDYIE_Msk |
| #define | RCC_CIER_PLL1RDYIE_Pos (6U) |
| #define | RCC_CIER_PLL1RDYIE_Msk (0x1UL << RCC_CIER_PLL1RDYIE_Pos) |
| #define | RCC_CIER_PLL1RDYIE RCC_CIER_PLL1RDYIE_Msk |
| #define | RCC_CIER_PLL2RDYIE_Pos (7U) |
| #define | RCC_CIER_PLL2RDYIE_Msk (0x1UL << RCC_CIER_PLL2RDYIE_Pos) |
| #define | RCC_CIER_PLL2RDYIE RCC_CIER_PLL2RDYIE_Msk |
| #define | RCC_CIER_PLL3RDYIE_Pos (8U) |
| #define | RCC_CIER_PLL3RDYIE_Msk (0x1UL << RCC_CIER_PLL3RDYIE_Pos) |
| #define | RCC_CIER_PLL3RDYIE RCC_CIER_PLL3RDYIE_Msk |
| #define | RCC_CIER_LSECSSIE_Pos (9U) |
| #define | RCC_CIER_LSECSSIE_Msk (0x1UL << RCC_CIER_LSECSSIE_Pos) |
| #define | RCC_CIER_LSECSSIE RCC_CIER_LSECSSIE_Msk |
| #define | RCC_CIFR_LSIRDYF_Pos (0U) |
| #define | RCC_CIFR_LSIRDYF_Msk (0x1UL << RCC_CIFR_LSIRDYF_Pos) |
| #define | RCC_CIFR_LSIRDYF RCC_CIFR_LSIRDYF_Msk |
| #define | RCC_CIFR_LSERDYF_Pos (1U) |
| #define | RCC_CIFR_LSERDYF_Msk (0x1UL << RCC_CIFR_LSERDYF_Pos) |
| #define | RCC_CIFR_LSERDYF RCC_CIFR_LSERDYF_Msk |
| #define | RCC_CIFR_HSIRDYF_Pos (2U) |
| #define | RCC_CIFR_HSIRDYF_Msk (0x1UL << RCC_CIFR_HSIRDYF_Pos) |
| #define | RCC_CIFR_HSIRDYF RCC_CIFR_HSIRDYF_Msk |
| #define | RCC_CIFR_HSERDYF_Pos (3U) |
| #define | RCC_CIFR_HSERDYF_Msk (0x1UL << RCC_CIFR_HSERDYF_Pos) |
| #define | RCC_CIFR_HSERDYF RCC_CIFR_HSERDYF_Msk |
| #define | RCC_CIFR_CSIRDYF_Pos (4U) |
| #define | RCC_CIFR_CSIRDYF_Msk (0x1UL << RCC_CIFR_CSIRDYF_Pos) |
| #define | RCC_CIFR_CSIRDYF RCC_CIFR_CSIRDYF_Msk |
| #define | RCC_CIFR_HSI48RDYF_Pos (5U) |
| #define | RCC_CIFR_HSI48RDYF_Msk (0x1UL << RCC_CIFR_HSI48RDYF_Pos) |
| #define | RCC_CIFR_HSI48RDYF RCC_CIFR_HSI48RDYF_Msk |
| #define | RCC_CIFR_PLLRDYF_Pos (6U) |
| #define | RCC_CIFR_PLLRDYF_Msk (0x1UL << RCC_CIFR_PLLRDYF_Pos) |
| #define | RCC_CIFR_PLLRDYF RCC_CIFR_PLLRDYF_Msk |
| #define | RCC_CIFR_PLL2RDYF_Pos (7U) |
| #define | RCC_CIFR_PLL2RDYF_Msk (0x1UL << RCC_CIFR_PLL2RDYF_Pos) |
| #define | RCC_CIFR_PLL2RDYF RCC_CIFR_PLL2RDYF_Msk |
| #define | RCC_CIFR_PLL3RDYF_Pos (8U) |
| #define | RCC_CIFR_PLL3RDYF_Msk (0x1UL << RCC_CIFR_PLL3RDYF_Pos) |
| #define | RCC_CIFR_PLL3RDYF RCC_CIFR_PLL3RDYF_Msk |
| #define | RCC_CIFR_LSECSSF_Pos (9U) |
| #define | RCC_CIFR_LSECSSF_Msk (0x1UL << RCC_CIFR_LSECSSF_Pos) |
| #define | RCC_CIFR_LSECSSF RCC_CIFR_LSECSSF_Msk |
| #define | RCC_CIFR_HSECSSF_Pos (10U) |
| #define | RCC_CIFR_HSECSSF_Msk (0x1UL << RCC_CIFR_HSECSSF_Pos) |
| #define | RCC_CIFR_HSECSSF RCC_CIFR_HSECSSF_Msk |
| #define | RCC_CICR_LSIRDYC_Pos (0U) |
| #define | RCC_CICR_LSIRDYC_Msk (0x1UL << RCC_CICR_LSIRDYC_Pos) |
| #define | RCC_CICR_LSIRDYC RCC_CICR_LSIRDYC_Msk |
| #define | RCC_CICR_LSERDYC_Pos (1U) |
| #define | RCC_CICR_LSERDYC_Msk (0x1UL << RCC_CICR_LSERDYC_Pos) |
| #define | RCC_CICR_LSERDYC RCC_CICR_LSERDYC_Msk |
| #define | RCC_CICR_HSIRDYC_Pos (2U) |
| #define | RCC_CICR_HSIRDYC_Msk (0x1UL << RCC_CICR_HSIRDYC_Pos) |
| #define | RCC_CICR_HSIRDYC RCC_CICR_HSIRDYC_Msk |
| #define | RCC_CICR_HSERDYC_Pos (3U) |
| #define | RCC_CICR_HSERDYC_Msk (0x1UL << RCC_CICR_HSERDYC_Pos) |
| #define | RCC_CICR_HSERDYC RCC_CICR_HSERDYC_Msk |
| #define | RCC_CICR_CSIRDYC_Pos (4U) |
| #define | RCC_CICR_CSIRDYC_Msk (0x1UL << RCC_CICR_CSIRDYC_Pos) |
| #define | RCC_CICR_CSIRDYC RCC_CICR_CSIRDYC_Msk |
| #define | RCC_CICR_HSI48RDYC_Pos (5U) |
| #define | RCC_CICR_HSI48RDYC_Msk (0x1UL << RCC_CICR_HSI48RDYC_Pos) |
| #define | RCC_CICR_HSI48RDYC RCC_CICR_HSI48RDYC_Msk |
| #define | RCC_CICR_PLLRDYC_Pos (6U) |
| #define | RCC_CICR_PLLRDYC_Msk (0x1UL << RCC_CICR_PLLRDYC_Pos) |
| #define | RCC_CICR_PLLRDYC RCC_CICR_PLLRDYC_Msk |
| #define | RCC_CICR_PLL2RDYC_Pos (7U) |
| #define | RCC_CICR_PLL2RDYC_Msk (0x1UL << RCC_CICR_PLL2RDYC_Pos) |
| #define | RCC_CICR_PLL2RDYC RCC_CICR_PLL2RDYC_Msk |
| #define | RCC_CICR_PLL3RDYC_Pos (8U) |
| #define | RCC_CICR_PLL3RDYC_Msk (0x1UL << RCC_CICR_PLL3RDYC_Pos) |
| #define | RCC_CICR_PLL3RDYC RCC_CICR_PLL3RDYC_Msk |
| #define | RCC_CICR_LSECSSC_Pos (9U) |
| #define | RCC_CICR_LSECSSC_Msk (0x1UL << RCC_CICR_LSECSSC_Pos) |
| #define | RCC_CICR_LSECSSC RCC_CICR_LSECSSC_Msk |
| #define | RCC_CICR_HSECSSC_Pos (10U) |
| #define | RCC_CICR_HSECSSC_Msk (0x1UL << RCC_CICR_HSECSSC_Pos) |
| #define | RCC_CICR_HSECSSC RCC_CICR_HSECSSC_Msk |
| #define | RCC_BDCR_LSEON_Pos (0U) |
| #define | RCC_BDCR_LSEON_Msk (0x1UL << RCC_BDCR_LSEON_Pos) |
| #define | RCC_BDCR_LSEON RCC_BDCR_LSEON_Msk |
| #define | RCC_BDCR_LSERDY_Pos (1U) |
| #define | RCC_BDCR_LSERDY_Msk (0x1UL << RCC_BDCR_LSERDY_Pos) |
| #define | RCC_BDCR_LSERDY RCC_BDCR_LSERDY_Msk |
| #define | RCC_BDCR_LSEBYP_Pos (2U) |
| #define | RCC_BDCR_LSEBYP_Msk (0x1UL << RCC_BDCR_LSEBYP_Pos) |
| #define | RCC_BDCR_LSEBYP RCC_BDCR_LSEBYP_Msk |
| #define | RCC_BDCR_LSEDRV_Pos (3U) |
| #define | RCC_BDCR_LSEDRV_Msk (0x3UL << RCC_BDCR_LSEDRV_Pos) |
| #define | RCC_BDCR_LSEDRV RCC_BDCR_LSEDRV_Msk |
| #define | RCC_BDCR_LSEDRV_0 (0x1UL << RCC_BDCR_LSEDRV_Pos) |
| #define | RCC_BDCR_LSEDRV_1 (0x2UL << RCC_BDCR_LSEDRV_Pos) |
| #define | RCC_BDCR_LSECSSON_Pos (5U) |
| #define | RCC_BDCR_LSECSSON_Msk (0x1UL << RCC_BDCR_LSECSSON_Pos) |
| #define | RCC_BDCR_LSECSSON RCC_BDCR_LSECSSON_Msk |
| #define | RCC_BDCR_LSECSSD_Pos (6U) |
| #define | RCC_BDCR_LSECSSD_Msk (0x1UL << RCC_BDCR_LSECSSD_Pos) |
| #define | RCC_BDCR_LSECSSD RCC_BDCR_LSECSSD_Msk |
| #define | RCC_BDCR_RTCSEL_Pos (8U) |
| #define | RCC_BDCR_RTCSEL_Msk (0x3UL << RCC_BDCR_RTCSEL_Pos) |
| #define | RCC_BDCR_RTCSEL RCC_BDCR_RTCSEL_Msk |
| #define | RCC_BDCR_RTCSEL_0 (0x1UL << RCC_BDCR_RTCSEL_Pos) |
| #define | RCC_BDCR_RTCSEL_1 (0x2UL << RCC_BDCR_RTCSEL_Pos) |
| #define | RCC_BDCR_RTCEN_Pos (15U) |
| #define | RCC_BDCR_RTCEN_Msk (0x1UL << RCC_BDCR_RTCEN_Pos) |
| #define | RCC_BDCR_RTCEN RCC_BDCR_RTCEN_Msk |
| #define | RCC_BDCR_BDRST_Pos (16U) |
| #define | RCC_BDCR_BDRST_Msk (0x1UL << RCC_BDCR_BDRST_Pos) |
| #define | RCC_BDCR_BDRST RCC_BDCR_BDRST_Msk |
| #define | RCC_CSR_LSION_Pos (0U) |
| #define | RCC_CSR_LSION_Msk (0x1UL << RCC_CSR_LSION_Pos) |
| #define | RCC_CSR_LSION RCC_CSR_LSION_Msk |
| #define | RCC_CSR_LSIRDY_Pos (1U) |
| #define | RCC_CSR_LSIRDY_Msk (0x1UL << RCC_CSR_LSIRDY_Pos) |
| #define | RCC_CSR_LSIRDY RCC_CSR_LSIRDY_Msk |
| #define | RCC_AHB3ENR_MDMAEN_Pos (0U) |
| #define | RCC_AHB3ENR_MDMAEN_Msk (0x1UL << RCC_AHB3ENR_MDMAEN_Pos) |
| #define | RCC_AHB3ENR_MDMAEN RCC_AHB3ENR_MDMAEN_Msk |
| #define | RCC_AHB3ENR_DMA2DEN_Pos (4U) |
| #define | RCC_AHB3ENR_DMA2DEN_Msk (0x1UL << RCC_AHB3ENR_DMA2DEN_Pos) |
| #define | RCC_AHB3ENR_DMA2DEN RCC_AHB3ENR_DMA2DEN_Msk |
| #define | RCC_AHB3ENR_JPGDECEN_Pos (5U) |
| #define | RCC_AHB3ENR_JPGDECEN_Msk (0x1UL << RCC_AHB3ENR_JPGDECEN_Pos) |
| #define | RCC_AHB3ENR_JPGDECEN RCC_AHB3ENR_JPGDECEN_Msk |
| #define | RCC_AHB3ENR_FMCEN_Pos (12U) |
| #define | RCC_AHB3ENR_FMCEN_Msk (0x1UL << RCC_AHB3ENR_FMCEN_Pos) |
| #define | RCC_AHB3ENR_FMCEN RCC_AHB3ENR_FMCEN_Msk |
| #define | RCC_AHB3ENR_QSPIEN_Pos (14U) |
| #define | RCC_AHB3ENR_QSPIEN_Msk (0x1UL << RCC_AHB3ENR_QSPIEN_Pos) |
| #define | RCC_AHB3ENR_QSPIEN RCC_AHB3ENR_QSPIEN_Msk |
| #define | RCC_AHB3ENR_SDMMC1EN_Pos (16U) |
| #define | RCC_AHB3ENR_SDMMC1EN_Msk (0x1UL << RCC_AHB3ENR_SDMMC1EN_Pos) |
| #define | RCC_AHB3ENR_SDMMC1EN RCC_AHB3ENR_SDMMC1EN_Msk |
| #define | RCC_AHB1ENR_DMA1EN_Pos (0U) |
| #define | RCC_AHB1ENR_DMA1EN_Msk (0x1UL << RCC_AHB1ENR_DMA1EN_Pos) |
| #define | RCC_AHB1ENR_DMA1EN RCC_AHB1ENR_DMA1EN_Msk |
| #define | RCC_AHB1ENR_DMA2EN_Pos (1U) |
| #define | RCC_AHB1ENR_DMA2EN_Msk (0x1UL << RCC_AHB1ENR_DMA2EN_Pos) |
| #define | RCC_AHB1ENR_DMA2EN RCC_AHB1ENR_DMA2EN_Msk |
| #define | RCC_AHB1ENR_ADC12EN_Pos (5U) |
| #define | RCC_AHB1ENR_ADC12EN_Msk (0x1UL << RCC_AHB1ENR_ADC12EN_Pos) |
| #define | RCC_AHB1ENR_ADC12EN RCC_AHB1ENR_ADC12EN_Msk |
| #define | RCC_AHB1ENR_ETH1MACEN_Pos (15U) |
| #define | RCC_AHB1ENR_ETH1MACEN_Msk (0x1UL << RCC_AHB1ENR_ETH1MACEN_Pos) |
| #define | RCC_AHB1ENR_ETH1MACEN RCC_AHB1ENR_ETH1MACEN_Msk |
| #define | RCC_AHB1ENR_ETH1TXEN_Pos (16U) |
| #define | RCC_AHB1ENR_ETH1TXEN_Msk (0x1UL << RCC_AHB1ENR_ETH1TXEN_Pos) |
| #define | RCC_AHB1ENR_ETH1TXEN RCC_AHB1ENR_ETH1TXEN_Msk |
| #define | RCC_AHB1ENR_ETH1RXEN_Pos (17U) |
| #define | RCC_AHB1ENR_ETH1RXEN_Msk (0x1UL << RCC_AHB1ENR_ETH1RXEN_Pos) |
| #define | RCC_AHB1ENR_ETH1RXEN RCC_AHB1ENR_ETH1RXEN_Msk |
| #define | RCC_AHB1ENR_USB1OTGHSEN_Pos (25U) |
| #define | RCC_AHB1ENR_USB1OTGHSEN_Msk (0x1UL << RCC_AHB1ENR_USB1OTGHSEN_Pos) |
| #define | RCC_AHB1ENR_USB1OTGHSEN RCC_AHB1ENR_USB1OTGHSEN_Msk |
| #define | RCC_AHB1ENR_USB1OTGHSULPIEN_Pos (26U) |
| #define | RCC_AHB1ENR_USB1OTGHSULPIEN_Msk (0x1UL << RCC_AHB1ENR_USB1OTGHSULPIEN_Pos) |
| #define | RCC_AHB1ENR_USB1OTGHSULPIEN RCC_AHB1ENR_USB1OTGHSULPIEN_Msk |
| #define | RCC_AHB1ENR_USB2OTGFSEN_Pos (27U) |
| #define | RCC_AHB1ENR_USB2OTGFSEN_Msk (0x1UL << RCC_AHB1ENR_USB2OTGFSEN_Pos) |
| #define | RCC_AHB1ENR_USB2OTGFSEN RCC_AHB1ENR_USB2OTGFSEN_Msk |
| #define | RCC_AHB1ENR_USB2OTGFSULPIEN_Pos (28U) |
| #define | RCC_AHB1ENR_USB2OTGFSULPIEN_Msk (0x1UL << RCC_AHB1ENR_USB2OTGFSULPIEN_Pos) |
| #define | RCC_AHB1ENR_USB2OTGFSULPIEN RCC_AHB1ENR_USB2OTGFSULPIEN_Msk |
| #define | RCC_AHB1ENR_USB2OTGHSEN_Pos RCC_AHB1ENR_USB2OTGFSEN_Pos |
| #define | RCC_AHB1ENR_USB2OTGHSEN_Msk RCC_AHB1ENR_USB2OTGFSEN_Msk |
| #define | RCC_AHB1ENR_USB2OTGHSEN RCC_AHB1ENR_USB2OTGFSEN |
| #define | RCC_AHB1ENR_USB2OTGHSULPIEN_Pos RCC_AHB1ENR_USB2OTGFSULPIEN_Pos |
| #define | RCC_AHB1ENR_USB2OTGHSULPIEN_Msk RCC_AHB1ENR_USB2OTGFSULPIEN_Msk |
| #define | RCC_AHB1ENR_USB2OTGHSULPIEN RCC_AHB1ENR_USB2OTGFSULPIEN |
| #define | RCC_AHB2ENR_DCMIEN_Pos (0U) |
| #define | RCC_AHB2ENR_DCMIEN_Msk (0x1UL << RCC_AHB2ENR_DCMIEN_Pos) |
| #define | RCC_AHB2ENR_DCMIEN RCC_AHB2ENR_DCMIEN_Msk |
| #define | RCC_AHB2ENR_CRYPEN_Pos (4U) |
| #define | RCC_AHB2ENR_CRYPEN_Msk (0x1UL << RCC_AHB2ENR_CRYPEN_Pos) |
| #define | RCC_AHB2ENR_CRYPEN RCC_AHB2ENR_CRYPEN_Msk |
| #define | RCC_AHB2ENR_HASHEN_Pos (5U) |
| #define | RCC_AHB2ENR_HASHEN_Msk (0x1UL << RCC_AHB2ENR_HASHEN_Pos) |
| #define | RCC_AHB2ENR_HASHEN RCC_AHB2ENR_HASHEN_Msk |
| #define | RCC_AHB2ENR_RNGEN_Pos (6U) |
| #define | RCC_AHB2ENR_RNGEN_Msk (0x1UL << RCC_AHB2ENR_RNGEN_Pos) |
| #define | RCC_AHB2ENR_RNGEN RCC_AHB2ENR_RNGEN_Msk |
| #define | RCC_AHB2ENR_SDMMC2EN_Pos (9U) |
| #define | RCC_AHB2ENR_SDMMC2EN_Msk (0x1UL << RCC_AHB2ENR_SDMMC2EN_Pos) |
| #define | RCC_AHB2ENR_SDMMC2EN RCC_AHB2ENR_SDMMC2EN_Msk |
| #define | RCC_AHB2ENR_SRAM1EN_Pos (29U) |
| #define | RCC_AHB2ENR_SRAM1EN_Msk (0x1UL << RCC_AHB2ENR_SRAM1EN_Pos) |
| #define | RCC_AHB2ENR_SRAM1EN RCC_AHB2ENR_SRAM1EN_Msk |
| #define | RCC_AHB2ENR_SRAM2EN_Pos (30U) |
| #define | RCC_AHB2ENR_SRAM2EN_Msk (0x1UL << RCC_AHB2ENR_SRAM2EN_Pos) |
| #define | RCC_AHB2ENR_SRAM2EN RCC_AHB2ENR_SRAM2EN_Msk |
| #define | RCC_AHB2ENR_SRAM3EN_Pos (31U) |
| #define | RCC_AHB2ENR_SRAM3EN_Msk (0x1UL << RCC_AHB2ENR_SRAM3EN_Pos) |
| #define | RCC_AHB2ENR_SRAM3EN RCC_AHB2ENR_SRAM3EN_Msk |
| #define | RCC_AHB2ENR_D2SRAM1EN_Pos RCC_AHB2ENR_SRAM1EN_Pos |
| #define | RCC_AHB2ENR_D2SRAM1EN_Msk RCC_AHB2ENR_SRAM1EN_Msk |
| #define | RCC_AHB2ENR_D2SRAM1EN RCC_AHB2ENR_SRAM1EN |
| #define | RCC_AHB2ENR_D2SRAM2EN_Pos RCC_AHB2ENR_SRAM2EN_Pos |
| #define | RCC_AHB2ENR_D2SRAM2EN_Msk RCC_AHB2ENR_SRAM2EN_Msk |
| #define | RCC_AHB2ENR_D2SRAM2EN RCC_AHB2ENR_SRAM2EN |
| #define | RCC_AHB2ENR_D2SRAM3EN_Pos RCC_AHB2ENR_SRAM3EN_Pos |
| #define | RCC_AHB2ENR_D2SRAM3EN_Msk RCC_AHB2ENR_SRAM3EN_Msk |
| #define | RCC_AHB2ENR_D2SRAM3EN RCC_AHB2ENR_SRAM3EN |
| #define | RCC_AHB4ENR_GPIOAEN_Pos (0U) |
| #define | RCC_AHB4ENR_GPIOAEN_Msk (0x1UL << RCC_AHB4ENR_GPIOAEN_Pos) |
| #define | RCC_AHB4ENR_GPIOAEN RCC_AHB4ENR_GPIOAEN_Msk |
| #define | RCC_AHB4ENR_GPIOBEN_Pos (1U) |
| #define | RCC_AHB4ENR_GPIOBEN_Msk (0x1UL << RCC_AHB4ENR_GPIOBEN_Pos) |
| #define | RCC_AHB4ENR_GPIOBEN RCC_AHB4ENR_GPIOBEN_Msk |
| #define | RCC_AHB4ENR_GPIOCEN_Pos (2U) |
| #define | RCC_AHB4ENR_GPIOCEN_Msk (0x1UL << RCC_AHB4ENR_GPIOCEN_Pos) |
| #define | RCC_AHB4ENR_GPIOCEN RCC_AHB4ENR_GPIOCEN_Msk |
| #define | RCC_AHB4ENR_GPIODEN_Pos (3U) |
| #define | RCC_AHB4ENR_GPIODEN_Msk (0x1UL << RCC_AHB4ENR_GPIODEN_Pos) |
| #define | RCC_AHB4ENR_GPIODEN RCC_AHB4ENR_GPIODEN_Msk |
| #define | RCC_AHB4ENR_GPIOEEN_Pos (4U) |
| #define | RCC_AHB4ENR_GPIOEEN_Msk (0x1UL << RCC_AHB4ENR_GPIOEEN_Pos) |
| #define | RCC_AHB4ENR_GPIOEEN RCC_AHB4ENR_GPIOEEN_Msk |
| #define | RCC_AHB4ENR_GPIOFEN_Pos (5U) |
| #define | RCC_AHB4ENR_GPIOFEN_Msk (0x1UL << RCC_AHB4ENR_GPIOFEN_Pos) |
| #define | RCC_AHB4ENR_GPIOFEN RCC_AHB4ENR_GPIOFEN_Msk |
| #define | RCC_AHB4ENR_GPIOGEN_Pos (6U) |
| #define | RCC_AHB4ENR_GPIOGEN_Msk (0x1UL << RCC_AHB4ENR_GPIOGEN_Pos) |
| #define | RCC_AHB4ENR_GPIOGEN RCC_AHB4ENR_GPIOGEN_Msk |
| #define | RCC_AHB4ENR_GPIOHEN_Pos (7U) |
| #define | RCC_AHB4ENR_GPIOHEN_Msk (0x1UL << RCC_AHB4ENR_GPIOHEN_Pos) |
| #define | RCC_AHB4ENR_GPIOHEN RCC_AHB4ENR_GPIOHEN_Msk |
| #define | RCC_AHB4ENR_GPIOIEN_Pos (8U) |
| #define | RCC_AHB4ENR_GPIOIEN_Msk (0x1UL << RCC_AHB4ENR_GPIOIEN_Pos) |
| #define | RCC_AHB4ENR_GPIOIEN RCC_AHB4ENR_GPIOIEN_Msk |
| #define | RCC_AHB4ENR_GPIOJEN_Pos (9U) |
| #define | RCC_AHB4ENR_GPIOJEN_Msk (0x1UL << RCC_AHB4ENR_GPIOJEN_Pos) |
| #define | RCC_AHB4ENR_GPIOJEN RCC_AHB4ENR_GPIOJEN_Msk |
| #define | RCC_AHB4ENR_GPIOKEN_Pos (10U) |
| #define | RCC_AHB4ENR_GPIOKEN_Msk (0x1UL << RCC_AHB4ENR_GPIOKEN_Pos) |
| #define | RCC_AHB4ENR_GPIOKEN RCC_AHB4ENR_GPIOKEN_Msk |
| #define | RCC_AHB4ENR_CRCEN_Pos (19U) |
| #define | RCC_AHB4ENR_CRCEN_Msk (0x1UL << RCC_AHB4ENR_CRCEN_Pos) |
| #define | RCC_AHB4ENR_CRCEN RCC_AHB4ENR_CRCEN_Msk |
| #define | RCC_AHB4ENR_BDMAEN_Pos (21U) |
| #define | RCC_AHB4ENR_BDMAEN_Msk (0x1UL << RCC_AHB4ENR_BDMAEN_Pos) |
| #define | RCC_AHB4ENR_BDMAEN RCC_AHB4ENR_BDMAEN_Msk |
| #define | RCC_AHB4ENR_ADC3EN_Pos (24U) |
| #define | RCC_AHB4ENR_ADC3EN_Msk (0x1UL << RCC_AHB4ENR_ADC3EN_Pos) |
| #define | RCC_AHB4ENR_ADC3EN RCC_AHB4ENR_ADC3EN_Msk |
| #define | RCC_AHB4ENR_HSEMEN_Pos (25U) |
| #define | RCC_AHB4ENR_HSEMEN_Msk (0x1UL << RCC_AHB4ENR_HSEMEN_Pos) |
| #define | RCC_AHB4ENR_HSEMEN RCC_AHB4ENR_HSEMEN_Msk |
| #define | RCC_AHB4ENR_BKPRAMEN_Pos (28U) |
| #define | RCC_AHB4ENR_BKPRAMEN_Msk (0x1UL << RCC_AHB4ENR_BKPRAMEN_Pos) |
| #define | RCC_AHB4ENR_BKPRAMEN RCC_AHB4ENR_BKPRAMEN_Msk |
| #define | RCC_APB3ENR_LTDCEN_Pos (3U) |
| #define | RCC_APB3ENR_LTDCEN_Msk (0x1UL << RCC_APB3ENR_LTDCEN_Pos) |
| #define | RCC_APB3ENR_LTDCEN RCC_APB3ENR_LTDCEN_Msk |
| #define | RCC_APB3ENR_WWDG1EN_Pos (6U) |
| #define | RCC_APB3ENR_WWDG1EN_Msk (0x1UL << RCC_APB3ENR_WWDG1EN_Pos) |
| #define | RCC_APB3ENR_WWDG1EN RCC_APB3ENR_WWDG1EN_Msk |
| #define | RCC_APB1LENR_TIM2EN_Pos (0U) |
| #define | RCC_APB1LENR_TIM2EN_Msk (0x1UL << RCC_APB1LENR_TIM2EN_Pos) |
| #define | RCC_APB1LENR_TIM2EN RCC_APB1LENR_TIM2EN_Msk |
| #define | RCC_APB1LENR_TIM3EN_Pos (1U) |
| #define | RCC_APB1LENR_TIM3EN_Msk (0x1UL << RCC_APB1LENR_TIM3EN_Pos) |
| #define | RCC_APB1LENR_TIM3EN RCC_APB1LENR_TIM3EN_Msk |
| #define | RCC_APB1LENR_TIM4EN_Pos (2U) |
| #define | RCC_APB1LENR_TIM4EN_Msk (0x1UL << RCC_APB1LENR_TIM4EN_Pos) |
| #define | RCC_APB1LENR_TIM4EN RCC_APB1LENR_TIM4EN_Msk |
| #define | RCC_APB1LENR_TIM5EN_Pos (3U) |
| #define | RCC_APB1LENR_TIM5EN_Msk (0x1UL << RCC_APB1LENR_TIM5EN_Pos) |
| #define | RCC_APB1LENR_TIM5EN RCC_APB1LENR_TIM5EN_Msk |
| #define | RCC_APB1LENR_TIM6EN_Pos (4U) |
| #define | RCC_APB1LENR_TIM6EN_Msk (0x1UL << RCC_APB1LENR_TIM6EN_Pos) |
| #define | RCC_APB1LENR_TIM6EN RCC_APB1LENR_TIM6EN_Msk |
| #define | RCC_APB1LENR_TIM7EN_Pos (5U) |
| #define | RCC_APB1LENR_TIM7EN_Msk (0x1UL << RCC_APB1LENR_TIM7EN_Pos) |
| #define | RCC_APB1LENR_TIM7EN RCC_APB1LENR_TIM7EN_Msk |
| #define | RCC_APB1LENR_TIM12EN_Pos (6U) |
| #define | RCC_APB1LENR_TIM12EN_Msk (0x1UL << RCC_APB1LENR_TIM12EN_Pos) |
| #define | RCC_APB1LENR_TIM12EN RCC_APB1LENR_TIM12EN_Msk |
| #define | RCC_APB1LENR_TIM13EN_Pos (7U) |
| #define | RCC_APB1LENR_TIM13EN_Msk (0x1UL << RCC_APB1LENR_TIM13EN_Pos) |
| #define | RCC_APB1LENR_TIM13EN RCC_APB1LENR_TIM13EN_Msk |
| #define | RCC_APB1LENR_TIM14EN_Pos (8U) |
| #define | RCC_APB1LENR_TIM14EN_Msk (0x1UL << RCC_APB1LENR_TIM14EN_Pos) |
| #define | RCC_APB1LENR_TIM14EN RCC_APB1LENR_TIM14EN_Msk |
| #define | RCC_APB1LENR_LPTIM1EN_Pos (9U) |
| #define | RCC_APB1LENR_LPTIM1EN_Msk (0x1UL << RCC_APB1LENR_LPTIM1EN_Pos) |
| #define | RCC_APB1LENR_LPTIM1EN RCC_APB1LENR_LPTIM1EN_Msk |
| #define | RCC_APB1LENR_SPI2EN_Pos (14U) |
| #define | RCC_APB1LENR_SPI2EN_Msk (0x1UL << RCC_APB1LENR_SPI2EN_Pos) |
| #define | RCC_APB1LENR_SPI2EN RCC_APB1LENR_SPI2EN_Msk |
| #define | RCC_APB1LENR_SPI3EN_Pos (15U) |
| #define | RCC_APB1LENR_SPI3EN_Msk (0x1UL << RCC_APB1LENR_SPI3EN_Pos) |
| #define | RCC_APB1LENR_SPI3EN RCC_APB1LENR_SPI3EN_Msk |
| #define | RCC_APB1LENR_SPDIFRXEN_Pos (16U) |
| #define | RCC_APB1LENR_SPDIFRXEN_Msk (0x1UL << RCC_APB1LENR_SPDIFRXEN_Pos) |
| #define | RCC_APB1LENR_SPDIFRXEN RCC_APB1LENR_SPDIFRXEN_Msk |
| #define | RCC_APB1LENR_USART2EN_Pos (17U) |
| #define | RCC_APB1LENR_USART2EN_Msk (0x1UL << RCC_APB1LENR_USART2EN_Pos) |
| #define | RCC_APB1LENR_USART2EN RCC_APB1LENR_USART2EN_Msk |
| #define | RCC_APB1LENR_USART3EN_Pos (18U) |
| #define | RCC_APB1LENR_USART3EN_Msk (0x1UL << RCC_APB1LENR_USART3EN_Pos) |
| #define | RCC_APB1LENR_USART3EN RCC_APB1LENR_USART3EN_Msk |
| #define | RCC_APB1LENR_UART4EN_Pos (19U) |
| #define | RCC_APB1LENR_UART4EN_Msk (0x1UL << RCC_APB1LENR_UART4EN_Pos) |
| #define | RCC_APB1LENR_UART4EN RCC_APB1LENR_UART4EN_Msk |
| #define | RCC_APB1LENR_UART5EN_Pos (20U) |
| #define | RCC_APB1LENR_UART5EN_Msk (0x1UL << RCC_APB1LENR_UART5EN_Pos) |
| #define | RCC_APB1LENR_UART5EN RCC_APB1LENR_UART5EN_Msk |
| #define | RCC_APB1LENR_I2C1EN_Pos (21U) |
| #define | RCC_APB1LENR_I2C1EN_Msk (0x1UL << RCC_APB1LENR_I2C1EN_Pos) |
| #define | RCC_APB1LENR_I2C1EN RCC_APB1LENR_I2C1EN_Msk |
| #define | RCC_APB1LENR_I2C2EN_Pos (22U) |
| #define | RCC_APB1LENR_I2C2EN_Msk (0x1UL << RCC_APB1LENR_I2C2EN_Pos) |
| #define | RCC_APB1LENR_I2C2EN RCC_APB1LENR_I2C2EN_Msk |
| #define | RCC_APB1LENR_I2C3EN_Pos (23U) |
| #define | RCC_APB1LENR_I2C3EN_Msk (0x1UL << RCC_APB1LENR_I2C3EN_Pos) |
| #define | RCC_APB1LENR_I2C3EN RCC_APB1LENR_I2C3EN_Msk |
| #define | RCC_APB1LENR_CECEN_Pos (27U) |
| #define | RCC_APB1LENR_CECEN_Msk (0x1UL << RCC_APB1LENR_CECEN_Pos) |
| #define | RCC_APB1LENR_CECEN RCC_APB1LENR_CECEN_Msk |
| #define | RCC_APB1LENR_DAC12EN_Pos (29U) |
| #define | RCC_APB1LENR_DAC12EN_Msk (0x1UL << RCC_APB1LENR_DAC12EN_Pos) |
| #define | RCC_APB1LENR_DAC12EN RCC_APB1LENR_DAC12EN_Msk |
| #define | RCC_APB1LENR_UART7EN_Pos (30U) |
| #define | RCC_APB1LENR_UART7EN_Msk (0x1UL << RCC_APB1LENR_UART7EN_Pos) |
| #define | RCC_APB1LENR_UART7EN RCC_APB1LENR_UART7EN_Msk |
| #define | RCC_APB1LENR_UART8EN_Pos (31U) |
| #define | RCC_APB1LENR_UART8EN_Msk (0x1UL << RCC_APB1LENR_UART8EN_Pos) |
| #define | RCC_APB1LENR_UART8EN RCC_APB1LENR_UART8EN_Msk |
| #define | RCC_APB1LENR_HDMICECEN_Pos RCC_APB1LENR_CECEN_Pos |
| #define | RCC_APB1LENR_HDMICECEN_Msk RCC_APB1LENR_CECEN_Msk |
| #define | RCC_APB1LENR_HDMICECEN RCC_APB1LENR_CECEN |
| #define | RCC_APB1HENR_CRSEN_Pos (1U) |
| #define | RCC_APB1HENR_CRSEN_Msk (0x1UL << RCC_APB1HENR_CRSEN_Pos) |
| #define | RCC_APB1HENR_CRSEN RCC_APB1HENR_CRSEN_Msk |
| #define | RCC_APB1HENR_SWPMIEN_Pos (2U) |
| #define | RCC_APB1HENR_SWPMIEN_Msk (0x1UL << RCC_APB1HENR_SWPMIEN_Pos) |
| #define | RCC_APB1HENR_SWPMIEN RCC_APB1HENR_SWPMIEN_Msk |
| #define | RCC_APB1HENR_OPAMPEN_Pos (4U) |
| #define | RCC_APB1HENR_OPAMPEN_Msk (0x1UL << RCC_APB1HENR_OPAMPEN_Pos) |
| #define | RCC_APB1HENR_OPAMPEN RCC_APB1HENR_OPAMPEN_Msk |
| #define | RCC_APB1HENR_MDIOSEN_Pos (5U) |
| #define | RCC_APB1HENR_MDIOSEN_Msk (0x1UL << RCC_APB1HENR_MDIOSEN_Pos) |
| #define | RCC_APB1HENR_MDIOSEN RCC_APB1HENR_MDIOSEN_Msk |
| #define | RCC_APB1HENR_FDCANEN_Pos (8U) |
| #define | RCC_APB1HENR_FDCANEN_Msk (0x1UL << RCC_APB1HENR_FDCANEN_Pos) |
| #define | RCC_APB1HENR_FDCANEN RCC_APB1HENR_FDCANEN_Msk |
| #define | RCC_APB2ENR_TIM1EN_Pos (0U) |
| #define | RCC_APB2ENR_TIM1EN_Msk (0x1UL << RCC_APB2ENR_TIM1EN_Pos) |
| #define | RCC_APB2ENR_TIM1EN RCC_APB2ENR_TIM1EN_Msk |
| #define | RCC_APB2ENR_TIM8EN_Pos (1U) |
| #define | RCC_APB2ENR_TIM8EN_Msk (0x1UL << RCC_APB2ENR_TIM8EN_Pos) |
| #define | RCC_APB2ENR_TIM8EN RCC_APB2ENR_TIM8EN_Msk |
| #define | RCC_APB2ENR_USART1EN_Pos (4U) |
| #define | RCC_APB2ENR_USART1EN_Msk (0x1UL << RCC_APB2ENR_USART1EN_Pos) |
| #define | RCC_APB2ENR_USART1EN RCC_APB2ENR_USART1EN_Msk |
| #define | RCC_APB2ENR_USART6EN_Pos (5U) |
| #define | RCC_APB2ENR_USART6EN_Msk (0x1UL << RCC_APB2ENR_USART6EN_Pos) |
| #define | RCC_APB2ENR_USART6EN RCC_APB2ENR_USART6EN_Msk |
| #define | RCC_APB2ENR_SPI1EN_Pos (12U) |
| #define | RCC_APB2ENR_SPI1EN_Msk (0x1UL << RCC_APB2ENR_SPI1EN_Pos) |
| #define | RCC_APB2ENR_SPI1EN RCC_APB2ENR_SPI1EN_Msk |
| #define | RCC_APB2ENR_SPI4EN_Pos (13U) |
| #define | RCC_APB2ENR_SPI4EN_Msk (0x1UL << RCC_APB2ENR_SPI4EN_Pos) |
| #define | RCC_APB2ENR_SPI4EN RCC_APB2ENR_SPI4EN_Msk |
| #define | RCC_APB2ENR_TIM15EN_Pos (16U) |
| #define | RCC_APB2ENR_TIM15EN_Msk (0x1UL << RCC_APB2ENR_TIM15EN_Pos) |
| #define | RCC_APB2ENR_TIM15EN RCC_APB2ENR_TIM15EN_Msk |
| #define | RCC_APB2ENR_TIM16EN_Pos (17U) |
| #define | RCC_APB2ENR_TIM16EN_Msk (0x1UL << RCC_APB2ENR_TIM16EN_Pos) |
| #define | RCC_APB2ENR_TIM16EN RCC_APB2ENR_TIM16EN_Msk |
| #define | RCC_APB2ENR_TIM17EN_Pos (18U) |
| #define | RCC_APB2ENR_TIM17EN_Msk (0x1UL << RCC_APB2ENR_TIM17EN_Pos) |
| #define | RCC_APB2ENR_TIM17EN RCC_APB2ENR_TIM17EN_Msk |
| #define | RCC_APB2ENR_SPI5EN_Pos (20U) |
| #define | RCC_APB2ENR_SPI5EN_Msk (0x1UL << RCC_APB2ENR_SPI5EN_Pos) |
| #define | RCC_APB2ENR_SPI5EN RCC_APB2ENR_SPI5EN_Msk |
| #define | RCC_APB2ENR_SAI1EN_Pos (22U) |
| #define | RCC_APB2ENR_SAI1EN_Msk (0x1UL << RCC_APB2ENR_SAI1EN_Pos) |
| #define | RCC_APB2ENR_SAI1EN RCC_APB2ENR_SAI1EN_Msk |
| #define | RCC_APB2ENR_SAI2EN_Pos (23U) |
| #define | RCC_APB2ENR_SAI2EN_Msk (0x1UL << RCC_APB2ENR_SAI2EN_Pos) |
| #define | RCC_APB2ENR_SAI2EN RCC_APB2ENR_SAI2EN_Msk |
| #define | RCC_APB2ENR_SAI3EN_Pos (24U) |
| #define | RCC_APB2ENR_SAI3EN_Msk (0x1UL << RCC_APB2ENR_SAI3EN_Pos) |
| #define | RCC_APB2ENR_SAI3EN RCC_APB2ENR_SAI3EN_Msk |
| #define | RCC_APB2ENR_DFSDM1EN_Pos (28U) |
| #define | RCC_APB2ENR_DFSDM1EN_Msk (0x1UL << RCC_APB2ENR_DFSDM1EN_Pos) |
| #define | RCC_APB2ENR_DFSDM1EN RCC_APB2ENR_DFSDM1EN_Msk |
| #define | RCC_APB2ENR_HRTIMEN_Pos (29U) |
| #define | RCC_APB2ENR_HRTIMEN_Msk (0x1UL << RCC_APB2ENR_HRTIMEN_Pos) |
| #define | RCC_APB2ENR_HRTIMEN RCC_APB2ENR_HRTIMEN_Msk |
| #define | RCC_APB4ENR_SYSCFGEN_Pos (1U) |
| #define | RCC_APB4ENR_SYSCFGEN_Msk (0x1UL << RCC_APB4ENR_SYSCFGEN_Pos) |
| #define | RCC_APB4ENR_SYSCFGEN RCC_APB4ENR_SYSCFGEN_Msk |
| #define | RCC_APB4ENR_LPUART1EN_Pos (3U) |
| #define | RCC_APB4ENR_LPUART1EN_Msk (0x1UL << RCC_APB4ENR_LPUART1EN_Pos) |
| #define | RCC_APB4ENR_LPUART1EN RCC_APB4ENR_LPUART1EN_Msk |
| #define | RCC_APB4ENR_SPI6EN_Pos (5U) |
| #define | RCC_APB4ENR_SPI6EN_Msk (0x1UL << RCC_APB4ENR_SPI6EN_Pos) |
| #define | RCC_APB4ENR_SPI6EN RCC_APB4ENR_SPI6EN_Msk |
| #define | RCC_APB4ENR_I2C4EN_Pos (7U) |
| #define | RCC_APB4ENR_I2C4EN_Msk (0x1UL << RCC_APB4ENR_I2C4EN_Pos) |
| #define | RCC_APB4ENR_I2C4EN RCC_APB4ENR_I2C4EN_Msk |
| #define | RCC_APB4ENR_LPTIM2EN_Pos (9U) |
| #define | RCC_APB4ENR_LPTIM2EN_Msk (0x1UL << RCC_APB4ENR_LPTIM2EN_Pos) |
| #define | RCC_APB4ENR_LPTIM2EN RCC_APB4ENR_LPTIM2EN_Msk |
| #define | RCC_APB4ENR_LPTIM3EN_Pos (10U) |
| #define | RCC_APB4ENR_LPTIM3EN_Msk (0x1UL << RCC_APB4ENR_LPTIM3EN_Pos) |
| #define | RCC_APB4ENR_LPTIM3EN RCC_APB4ENR_LPTIM3EN_Msk |
| #define | RCC_APB4ENR_LPTIM4EN_Pos (11U) |
| #define | RCC_APB4ENR_LPTIM4EN_Msk (0x1UL << RCC_APB4ENR_LPTIM4EN_Pos) |
| #define | RCC_APB4ENR_LPTIM4EN RCC_APB4ENR_LPTIM4EN_Msk |
| #define | RCC_APB4ENR_LPTIM5EN_Pos (12U) |
| #define | RCC_APB4ENR_LPTIM5EN_Msk (0x1UL << RCC_APB4ENR_LPTIM5EN_Pos) |
| #define | RCC_APB4ENR_LPTIM5EN RCC_APB4ENR_LPTIM5EN_Msk |
| #define | RCC_APB4ENR_COMP12EN_Pos (14U) |
| #define | RCC_APB4ENR_COMP12EN_Msk (0x1UL << RCC_APB4ENR_COMP12EN_Pos) |
| #define | RCC_APB4ENR_COMP12EN RCC_APB4ENR_COMP12EN_Msk |
| #define | RCC_APB4ENR_VREFEN_Pos (15U) |
| #define | RCC_APB4ENR_VREFEN_Msk (0x1UL << RCC_APB4ENR_VREFEN_Pos) |
| #define | RCC_APB4ENR_VREFEN RCC_APB4ENR_VREFEN_Msk |
| #define | RCC_APB4ENR_RTCAPBEN_Pos (16U) |
| #define | RCC_APB4ENR_RTCAPBEN_Msk (0x1UL << RCC_APB4ENR_RTCAPBEN_Pos) |
| #define | RCC_APB4ENR_RTCAPBEN RCC_APB4ENR_RTCAPBEN_Msk |
| #define | RCC_APB4ENR_SAI4EN_Pos (21U) |
| #define | RCC_APB4ENR_SAI4EN_Msk (0x1UL << RCC_APB4ENR_SAI4EN_Pos) |
| #define | RCC_APB4ENR_SAI4EN RCC_APB4ENR_SAI4EN_Msk |
| #define | RCC_AHB3RSTR_MDMARST_Pos (0U) |
| #define | RCC_AHB3RSTR_MDMARST_Msk (0x1UL << RCC_AHB3RSTR_MDMARST_Pos) |
| #define | RCC_AHB3RSTR_MDMARST RCC_AHB3RSTR_MDMARST_Msk |
| #define | RCC_AHB3RSTR_DMA2DRST_Pos (4U) |
| #define | RCC_AHB3RSTR_DMA2DRST_Msk (0x1UL << RCC_AHB3RSTR_DMA2DRST_Pos) |
| #define | RCC_AHB3RSTR_DMA2DRST RCC_AHB3RSTR_DMA2DRST_Msk |
| #define | RCC_AHB3RSTR_JPGDECRST_Pos (5U) |
| #define | RCC_AHB3RSTR_JPGDECRST_Msk (0x1UL << RCC_AHB3RSTR_JPGDECRST_Pos) |
| #define | RCC_AHB3RSTR_JPGDECRST RCC_AHB3RSTR_JPGDECRST_Msk |
| #define | RCC_AHB3RSTR_FMCRST_Pos (12U) |
| #define | RCC_AHB3RSTR_FMCRST_Msk (0x1UL << RCC_AHB3RSTR_FMCRST_Pos) |
| #define | RCC_AHB3RSTR_FMCRST RCC_AHB3RSTR_FMCRST_Msk |
| #define | RCC_AHB3RSTR_QSPIRST_Pos (14U) |
| #define | RCC_AHB3RSTR_QSPIRST_Msk (0x1UL << RCC_AHB3RSTR_QSPIRST_Pos) |
| #define | RCC_AHB3RSTR_QSPIRST RCC_AHB3RSTR_QSPIRST_Msk |
| #define | RCC_AHB3RSTR_SDMMC1RST_Pos (16U) |
| #define | RCC_AHB3RSTR_SDMMC1RST_Msk (0x1UL << RCC_AHB3RSTR_SDMMC1RST_Pos) |
| #define | RCC_AHB3RSTR_SDMMC1RST RCC_AHB3RSTR_SDMMC1RST_Msk |
| #define | RCC_AHB1RSTR_DMA1RST_Pos (0U) |
| #define | RCC_AHB1RSTR_DMA1RST_Msk (0x1UL << RCC_AHB1RSTR_DMA1RST_Pos) |
| #define | RCC_AHB1RSTR_DMA1RST RCC_AHB1RSTR_DMA1RST_Msk |
| #define | RCC_AHB1RSTR_DMA2RST_Pos (1U) |
| #define | RCC_AHB1RSTR_DMA2RST_Msk (0x1UL << RCC_AHB1RSTR_DMA2RST_Pos) |
| #define | RCC_AHB1RSTR_DMA2RST RCC_AHB1RSTR_DMA2RST_Msk |
| #define | RCC_AHB1RSTR_ADC12RST_Pos (5U) |
| #define | RCC_AHB1RSTR_ADC12RST_Msk (0x1UL << RCC_AHB1RSTR_ADC12RST_Pos) |
| #define | RCC_AHB1RSTR_ADC12RST RCC_AHB1RSTR_ADC12RST_Msk |
| #define | RCC_AHB1RSTR_ETH1MACRST_Pos (15U) |
| #define | RCC_AHB1RSTR_ETH1MACRST_Msk (0x1UL << RCC_AHB1RSTR_ETH1MACRST_Pos) |
| #define | RCC_AHB1RSTR_ETH1MACRST RCC_AHB1RSTR_ETH1MACRST_Msk |
| #define | RCC_AHB1RSTR_USB1OTGHSRST_Pos (25U) |
| #define | RCC_AHB1RSTR_USB1OTGHSRST_Msk (0x1UL << RCC_AHB1RSTR_USB1OTGHSRST_Pos) |
| #define | RCC_AHB1RSTR_USB1OTGHSRST RCC_AHB1RSTR_USB1OTGHSRST_Msk |
| #define | RCC_AHB1RSTR_USB2OTGFSRST_Pos (27U) |
| #define | RCC_AHB1RSTR_USB2OTGFSRST_Msk (0x1UL << RCC_AHB1RSTR_USB2OTGFSRST_Pos) |
| #define | RCC_AHB1RSTR_USB2OTGFSRST RCC_AHB1RSTR_USB2OTGFSRST_Msk |
| #define | RCC_AHB1RSTR_USB2OTGHSRST_Pos RCC_AHB1RSTR_USB2OTGFSRST_Pos |
| #define | RCC_AHB1RSTR_USB2OTGHSRST_Msk RCC_AHB1RSTR_USB2OTGFSRST_Msk |
| #define | RCC_AHB1RSTR_USB2OTGHSRST RCC_AHB1RSTR_USB2OTGFSRST |
| #define | RCC_AHB2RSTR_DCMIRST_Pos (0U) |
| #define | RCC_AHB2RSTR_DCMIRST_Msk (0x1UL << RCC_AHB2RSTR_DCMIRST_Pos) |
| #define | RCC_AHB2RSTR_DCMIRST RCC_AHB2RSTR_DCMIRST_Msk |
| #define | RCC_AHB2RSTR_CRYPRST_Pos (4U) |
| #define | RCC_AHB2RSTR_CRYPRST_Msk (0x1UL << RCC_AHB2RSTR_CRYPRST_Pos) |
| #define | RCC_AHB2RSTR_CRYPRST RCC_AHB2RSTR_CRYPRST_Msk |
| #define | RCC_AHB2RSTR_HASHRST_Pos (5U) |
| #define | RCC_AHB2RSTR_HASHRST_Msk (0x1UL << RCC_AHB2RSTR_HASHRST_Pos) |
| #define | RCC_AHB2RSTR_HASHRST RCC_AHB2RSTR_HASHRST_Msk |
| #define | RCC_AHB2RSTR_RNGRST_Pos (6U) |
| #define | RCC_AHB2RSTR_RNGRST_Msk (0x1UL << RCC_AHB2RSTR_RNGRST_Pos) |
| #define | RCC_AHB2RSTR_RNGRST RCC_AHB2RSTR_RNGRST_Msk |
| #define | RCC_AHB2RSTR_SDMMC2RST_Pos (9U) |
| #define | RCC_AHB2RSTR_SDMMC2RST_Msk (0x1UL << RCC_AHB2RSTR_SDMMC2RST_Pos) |
| #define | RCC_AHB2RSTR_SDMMC2RST RCC_AHB2RSTR_SDMMC2RST_Msk |
| #define | RCC_AHB4RSTR_GPIOARST_Pos (0U) |
| #define | RCC_AHB4RSTR_GPIOARST_Msk (0x1UL << RCC_AHB4RSTR_GPIOARST_Pos) |
| #define | RCC_AHB4RSTR_GPIOARST RCC_AHB4RSTR_GPIOARST_Msk |
| #define | RCC_AHB4RSTR_GPIOBRST_Pos (1U) |
| #define | RCC_AHB4RSTR_GPIOBRST_Msk (0x1UL << RCC_AHB4RSTR_GPIOBRST_Pos) |
| #define | RCC_AHB4RSTR_GPIOBRST RCC_AHB4RSTR_GPIOBRST_Msk |
| #define | RCC_AHB4RSTR_GPIOCRST_Pos (2U) |
| #define | RCC_AHB4RSTR_GPIOCRST_Msk (0x1UL << RCC_AHB4RSTR_GPIOCRST_Pos) |
| #define | RCC_AHB4RSTR_GPIOCRST RCC_AHB4RSTR_GPIOCRST_Msk |
| #define | RCC_AHB4RSTR_GPIODRST_Pos (3U) |
| #define | RCC_AHB4RSTR_GPIODRST_Msk (0x1UL << RCC_AHB4RSTR_GPIODRST_Pos) |
| #define | RCC_AHB4RSTR_GPIODRST RCC_AHB4RSTR_GPIODRST_Msk |
| #define | RCC_AHB4RSTR_GPIOERST_Pos (4U) |
| #define | RCC_AHB4RSTR_GPIOERST_Msk (0x1UL << RCC_AHB4RSTR_GPIOERST_Pos) |
| #define | RCC_AHB4RSTR_GPIOERST RCC_AHB4RSTR_GPIOERST_Msk |
| #define | RCC_AHB4RSTR_GPIOFRST_Pos (5U) |
| #define | RCC_AHB4RSTR_GPIOFRST_Msk (0x1UL << RCC_AHB4RSTR_GPIOFRST_Pos) |
| #define | RCC_AHB4RSTR_GPIOFRST RCC_AHB4RSTR_GPIOFRST_Msk |
| #define | RCC_AHB4RSTR_GPIOGRST_Pos (6U) |
| #define | RCC_AHB4RSTR_GPIOGRST_Msk (0x1UL << RCC_AHB4RSTR_GPIOGRST_Pos) |
| #define | RCC_AHB4RSTR_GPIOGRST RCC_AHB4RSTR_GPIOGRST_Msk |
| #define | RCC_AHB4RSTR_GPIOHRST_Pos (7U) |
| #define | RCC_AHB4RSTR_GPIOHRST_Msk (0x1UL << RCC_AHB4RSTR_GPIOHRST_Pos) |
| #define | RCC_AHB4RSTR_GPIOHRST RCC_AHB4RSTR_GPIOHRST_Msk |
| #define | RCC_AHB4RSTR_GPIOIRST_Pos (8U) |
| #define | RCC_AHB4RSTR_GPIOIRST_Msk (0x1UL << RCC_AHB4RSTR_GPIOIRST_Pos) |
| #define | RCC_AHB4RSTR_GPIOIRST RCC_AHB4RSTR_GPIOIRST_Msk |
| #define | RCC_AHB4RSTR_GPIOJRST_Pos (9U) |
| #define | RCC_AHB4RSTR_GPIOJRST_Msk (0x1UL << RCC_AHB4RSTR_GPIOJRST_Pos) |
| #define | RCC_AHB4RSTR_GPIOJRST RCC_AHB4RSTR_GPIOJRST_Msk |
| #define | RCC_AHB4RSTR_GPIOKRST_Pos (10U) |
| #define | RCC_AHB4RSTR_GPIOKRST_Msk (0x1UL << RCC_AHB4RSTR_GPIOKRST_Pos) |
| #define | RCC_AHB4RSTR_GPIOKRST RCC_AHB4RSTR_GPIOKRST_Msk |
| #define | RCC_AHB4RSTR_CRCRST_Pos (19U) |
| #define | RCC_AHB4RSTR_CRCRST_Msk (0x1UL << RCC_AHB4RSTR_CRCRST_Pos) |
| #define | RCC_AHB4RSTR_CRCRST RCC_AHB4RSTR_CRCRST_Msk |
| #define | RCC_AHB4RSTR_BDMARST_Pos (21U) |
| #define | RCC_AHB4RSTR_BDMARST_Msk (0x1UL << RCC_AHB4RSTR_BDMARST_Pos) |
| #define | RCC_AHB4RSTR_BDMARST RCC_AHB4RSTR_BDMARST_Msk |
| #define | RCC_AHB4RSTR_ADC3RST_Pos (24U) |
| #define | RCC_AHB4RSTR_ADC3RST_Msk (0x1UL << RCC_AHB4RSTR_ADC3RST_Pos) |
| #define | RCC_AHB4RSTR_ADC3RST RCC_AHB4RSTR_ADC3RST_Msk |
| #define | RCC_AHB4RSTR_HSEMRST_Pos (25U) |
| #define | RCC_AHB4RSTR_HSEMRST_Msk (0x1UL << RCC_AHB4RSTR_HSEMRST_Pos) |
| #define | RCC_AHB4RSTR_HSEMRST RCC_AHB4RSTR_HSEMRST_Msk |
| #define | RCC_APB3RSTR_LTDCRST_Pos (3U) |
| #define | RCC_APB3RSTR_LTDCRST_Msk (0x1UL << RCC_APB3RSTR_LTDCRST_Pos) |
| #define | RCC_APB3RSTR_LTDCRST RCC_APB3RSTR_LTDCRST_Msk |
| #define | RCC_APB1LRSTR_TIM2RST_Pos (0U) |
| #define | RCC_APB1LRSTR_TIM2RST_Msk (0x1UL << RCC_APB1LRSTR_TIM2RST_Pos) |
| #define | RCC_APB1LRSTR_TIM2RST RCC_APB1LRSTR_TIM2RST_Msk |
| #define | RCC_APB1LRSTR_TIM3RST_Pos (1U) |
| #define | RCC_APB1LRSTR_TIM3RST_Msk (0x1UL << RCC_APB1LRSTR_TIM3RST_Pos) |
| #define | RCC_APB1LRSTR_TIM3RST RCC_APB1LRSTR_TIM3RST_Msk |
| #define | RCC_APB1LRSTR_TIM4RST_Pos (2U) |
| #define | RCC_APB1LRSTR_TIM4RST_Msk (0x1UL << RCC_APB1LRSTR_TIM4RST_Pos) |
| #define | RCC_APB1LRSTR_TIM4RST RCC_APB1LRSTR_TIM4RST_Msk |
| #define | RCC_APB1LRSTR_TIM5RST_Pos (3U) |
| #define | RCC_APB1LRSTR_TIM5RST_Msk (0x1UL << RCC_APB1LRSTR_TIM5RST_Pos) |
| #define | RCC_APB1LRSTR_TIM5RST RCC_APB1LRSTR_TIM5RST_Msk |
| #define | RCC_APB1LRSTR_TIM6RST_Pos (4U) |
| #define | RCC_APB1LRSTR_TIM6RST_Msk (0x1UL << RCC_APB1LRSTR_TIM6RST_Pos) |
| #define | RCC_APB1LRSTR_TIM6RST RCC_APB1LRSTR_TIM6RST_Msk |
| #define | RCC_APB1LRSTR_TIM7RST_Pos (5U) |
| #define | RCC_APB1LRSTR_TIM7RST_Msk (0x1UL << RCC_APB1LRSTR_TIM7RST_Pos) |
| #define | RCC_APB1LRSTR_TIM7RST RCC_APB1LRSTR_TIM7RST_Msk |
| #define | RCC_APB1LRSTR_TIM12RST_Pos (6U) |
| #define | RCC_APB1LRSTR_TIM12RST_Msk (0x1UL << RCC_APB1LRSTR_TIM12RST_Pos) |
| #define | RCC_APB1LRSTR_TIM12RST RCC_APB1LRSTR_TIM12RST_Msk |
| #define | RCC_APB1LRSTR_TIM13RST_Pos (7U) |
| #define | RCC_APB1LRSTR_TIM13RST_Msk (0x1UL << RCC_APB1LRSTR_TIM13RST_Pos) |
| #define | RCC_APB1LRSTR_TIM13RST RCC_APB1LRSTR_TIM13RST_Msk |
| #define | RCC_APB1LRSTR_TIM14RST_Pos (8U) |
| #define | RCC_APB1LRSTR_TIM14RST_Msk (0x1UL << RCC_APB1LRSTR_TIM14RST_Pos) |
| #define | RCC_APB1LRSTR_TIM14RST RCC_APB1LRSTR_TIM14RST_Msk |
| #define | RCC_APB1LRSTR_LPTIM1RST_Pos (9U) |
| #define | RCC_APB1LRSTR_LPTIM1RST_Msk (0x1UL << RCC_APB1LRSTR_LPTIM1RST_Pos) |
| #define | RCC_APB1LRSTR_LPTIM1RST RCC_APB1LRSTR_LPTIM1RST_Msk |
| #define | RCC_APB1LRSTR_SPI2RST_Pos (14U) |
| #define | RCC_APB1LRSTR_SPI2RST_Msk (0x1UL << RCC_APB1LRSTR_SPI2RST_Pos) |
| #define | RCC_APB1LRSTR_SPI2RST RCC_APB1LRSTR_SPI2RST_Msk |
| #define | RCC_APB1LRSTR_SPI3RST_Pos (15U) |
| #define | RCC_APB1LRSTR_SPI3RST_Msk (0x1UL << RCC_APB1LRSTR_SPI3RST_Pos) |
| #define | RCC_APB1LRSTR_SPI3RST RCC_APB1LRSTR_SPI3RST_Msk |
| #define | RCC_APB1LRSTR_SPDIFRXRST_Pos (16U) |
| #define | RCC_APB1LRSTR_SPDIFRXRST_Msk (0x1UL << RCC_APB1LRSTR_SPDIFRXRST_Pos) |
| #define | RCC_APB1LRSTR_SPDIFRXRST RCC_APB1LRSTR_SPDIFRXRST_Msk |
| #define | RCC_APB1LRSTR_USART2RST_Pos (17U) |
| #define | RCC_APB1LRSTR_USART2RST_Msk (0x1UL << RCC_APB1LRSTR_USART2RST_Pos) |
| #define | RCC_APB1LRSTR_USART2RST RCC_APB1LRSTR_USART2RST_Msk |
| #define | RCC_APB1LRSTR_USART3RST_Pos (18U) |
| #define | RCC_APB1LRSTR_USART3RST_Msk (0x1UL << RCC_APB1LRSTR_USART3RST_Pos) |
| #define | RCC_APB1LRSTR_USART3RST RCC_APB1LRSTR_USART3RST_Msk |
| #define | RCC_APB1LRSTR_UART4RST_Pos (19U) |
| #define | RCC_APB1LRSTR_UART4RST_Msk (0x1UL << RCC_APB1LRSTR_UART4RST_Pos) |
| #define | RCC_APB1LRSTR_UART4RST RCC_APB1LRSTR_UART4RST_Msk |
| #define | RCC_APB1LRSTR_UART5RST_Pos (20U) |
| #define | RCC_APB1LRSTR_UART5RST_Msk (0x1UL << RCC_APB1LRSTR_UART5RST_Pos) |
| #define | RCC_APB1LRSTR_UART5RST RCC_APB1LRSTR_UART5RST_Msk |
| #define | RCC_APB1LRSTR_I2C1RST_Pos (21U) |
| #define | RCC_APB1LRSTR_I2C1RST_Msk (0x1UL << RCC_APB1LRSTR_I2C1RST_Pos) |
| #define | RCC_APB1LRSTR_I2C1RST RCC_APB1LRSTR_I2C1RST_Msk |
| #define | RCC_APB1LRSTR_I2C2RST_Pos (22U) |
| #define | RCC_APB1LRSTR_I2C2RST_Msk (0x1UL << RCC_APB1LRSTR_I2C2RST_Pos) |
| #define | RCC_APB1LRSTR_I2C2RST RCC_APB1LRSTR_I2C2RST_Msk |
| #define | RCC_APB1LRSTR_I2C3RST_Pos (23U) |
| #define | RCC_APB1LRSTR_I2C3RST_Msk (0x1UL << RCC_APB1LRSTR_I2C3RST_Pos) |
| #define | RCC_APB1LRSTR_I2C3RST RCC_APB1LRSTR_I2C3RST_Msk |
| #define | RCC_APB1LRSTR_CECRST_Pos (27U) |
| #define | RCC_APB1LRSTR_CECRST_Msk (0x1UL << RCC_APB1LRSTR_CECRST_Pos) |
| #define | RCC_APB1LRSTR_CECRST RCC_APB1LRSTR_CECRST_Msk |
| #define | RCC_APB1LRSTR_DAC12RST_Pos (29U) |
| #define | RCC_APB1LRSTR_DAC12RST_Msk (0x1UL << RCC_APB1LRSTR_DAC12RST_Pos) |
| #define | RCC_APB1LRSTR_DAC12RST RCC_APB1LRSTR_DAC12RST_Msk |
| #define | RCC_APB1LRSTR_UART7RST_Pos (30U) |
| #define | RCC_APB1LRSTR_UART7RST_Msk (0x1UL << RCC_APB1LRSTR_UART7RST_Pos) |
| #define | RCC_APB1LRSTR_UART7RST RCC_APB1LRSTR_UART7RST_Msk |
| #define | RCC_APB1LRSTR_UART8RST_Pos (31U) |
| #define | RCC_APB1LRSTR_UART8RST_Msk (0x1UL << RCC_APB1LRSTR_UART8RST_Pos) |
| #define | RCC_APB1LRSTR_UART8RST RCC_APB1LRSTR_UART8RST_Msk |
| #define | RCC_APB1LRSTR_HDMICECRST_Pos RCC_APB1LRSTR_CECRST_Pos |
| #define | RCC_APB1LRSTR_HDMICECRST_Msk RCC_APB1LRSTR_CECRST_Msk |
| #define | RCC_APB1LRSTR_HDMICECRST RCC_APB1LRSTR_CECRST |
| #define | RCC_APB1HRSTR_CRSRST_Pos (1U) |
| #define | RCC_APB1HRSTR_CRSRST_Msk (0x1UL << RCC_APB1HRSTR_CRSRST_Pos) |
| #define | RCC_APB1HRSTR_CRSRST RCC_APB1HRSTR_CRSRST_Msk |
| #define | RCC_APB1HRSTR_SWPMIRST_Pos (2U) |
| #define | RCC_APB1HRSTR_SWPMIRST_Msk (0x1UL << RCC_APB1HRSTR_SWPMIRST_Pos) |
| #define | RCC_APB1HRSTR_SWPMIRST RCC_APB1HRSTR_SWPMIRST_Msk |
| #define | RCC_APB1HRSTR_OPAMPRST_Pos (4U) |
| #define | RCC_APB1HRSTR_OPAMPRST_Msk (0x1UL << RCC_APB1HRSTR_OPAMPRST_Pos) |
| #define | RCC_APB1HRSTR_OPAMPRST RCC_APB1HRSTR_OPAMPRST_Msk |
| #define | RCC_APB1HRSTR_MDIOSRST_Pos (5U) |
| #define | RCC_APB1HRSTR_MDIOSRST_Msk (0x1UL << RCC_APB1HRSTR_MDIOSRST_Pos) |
| #define | RCC_APB1HRSTR_MDIOSRST RCC_APB1HRSTR_MDIOSRST_Msk |
| #define | RCC_APB1HRSTR_FDCANRST_Pos (8U) |
| #define | RCC_APB1HRSTR_FDCANRST_Msk (0x1UL << RCC_APB1HRSTR_FDCANRST_Pos) |
| #define | RCC_APB1HRSTR_FDCANRST RCC_APB1HRSTR_FDCANRST_Msk |
| #define | RCC_APB2RSTR_TIM1RST_Pos (0U) |
| #define | RCC_APB2RSTR_TIM1RST_Msk (0x1UL << RCC_APB2RSTR_TIM1RST_Pos) |
| #define | RCC_APB2RSTR_TIM1RST RCC_APB2RSTR_TIM1RST_Msk |
| #define | RCC_APB2RSTR_TIM8RST_Pos (1U) |
| #define | RCC_APB2RSTR_TIM8RST_Msk (0x1UL << RCC_APB2RSTR_TIM8RST_Pos) |
| #define | RCC_APB2RSTR_TIM8RST RCC_APB2RSTR_TIM8RST_Msk |
| #define | RCC_APB2RSTR_USART1RST_Pos (4U) |
| #define | RCC_APB2RSTR_USART1RST_Msk (0x1UL << RCC_APB2RSTR_USART1RST_Pos) |
| #define | RCC_APB2RSTR_USART1RST RCC_APB2RSTR_USART1RST_Msk |
| #define | RCC_APB2RSTR_USART6RST_Pos (5U) |
| #define | RCC_APB2RSTR_USART6RST_Msk (0x1UL << RCC_APB2RSTR_USART6RST_Pos) |
| #define | RCC_APB2RSTR_USART6RST RCC_APB2RSTR_USART6RST_Msk |
| #define | RCC_APB2RSTR_SPI1RST_Pos (12U) |
| #define | RCC_APB2RSTR_SPI1RST_Msk (0x1UL << RCC_APB2RSTR_SPI1RST_Pos) |
| #define | RCC_APB2RSTR_SPI1RST RCC_APB2RSTR_SPI1RST_Msk |
| #define | RCC_APB2RSTR_SPI4RST_Pos (13U) |
| #define | RCC_APB2RSTR_SPI4RST_Msk (0x1UL << RCC_APB2RSTR_SPI4RST_Pos) |
| #define | RCC_APB2RSTR_SPI4RST RCC_APB2RSTR_SPI4RST_Msk |
| #define | RCC_APB2RSTR_TIM15RST_Pos (16U) |
| #define | RCC_APB2RSTR_TIM15RST_Msk (0x1UL << RCC_APB2RSTR_TIM15RST_Pos) |
| #define | RCC_APB2RSTR_TIM15RST RCC_APB2RSTR_TIM15RST_Msk |
| #define | RCC_APB2RSTR_TIM16RST_Pos (17U) |
| #define | RCC_APB2RSTR_TIM16RST_Msk (0x1UL << RCC_APB2RSTR_TIM16RST_Pos) |
| #define | RCC_APB2RSTR_TIM16RST RCC_APB2RSTR_TIM16RST_Msk |
| #define | RCC_APB2RSTR_TIM17RST_Pos (18U) |
| #define | RCC_APB2RSTR_TIM17RST_Msk (0x1UL << RCC_APB2RSTR_TIM17RST_Pos) |
| #define | RCC_APB2RSTR_TIM17RST RCC_APB2RSTR_TIM17RST_Msk |
| #define | RCC_APB2RSTR_SPI5RST_Pos (20U) |
| #define | RCC_APB2RSTR_SPI5RST_Msk (0x1UL << RCC_APB2RSTR_SPI5RST_Pos) |
| #define | RCC_APB2RSTR_SPI5RST RCC_APB2RSTR_SPI5RST_Msk |
| #define | RCC_APB2RSTR_SAI1RST_Pos (22U) |
| #define | RCC_APB2RSTR_SAI1RST_Msk (0x1UL << RCC_APB2RSTR_SAI1RST_Pos) |
| #define | RCC_APB2RSTR_SAI1RST RCC_APB2RSTR_SAI1RST_Msk |
| #define | RCC_APB2RSTR_SAI2RST_Pos (23U) |
| #define | RCC_APB2RSTR_SAI2RST_Msk (0x1UL << RCC_APB2RSTR_SAI2RST_Pos) |
| #define | RCC_APB2RSTR_SAI2RST RCC_APB2RSTR_SAI2RST_Msk |
| #define | RCC_APB2RSTR_SAI3RST_Pos (24U) |
| #define | RCC_APB2RSTR_SAI3RST_Msk (0x1UL << RCC_APB2RSTR_SAI3RST_Pos) |
| #define | RCC_APB2RSTR_SAI3RST RCC_APB2RSTR_SAI3RST_Msk |
| #define | RCC_APB2RSTR_DFSDM1RST_Pos (28U) |
| #define | RCC_APB2RSTR_DFSDM1RST_Msk (0x1UL << RCC_APB2RSTR_DFSDM1RST_Pos) |
| #define | RCC_APB2RSTR_DFSDM1RST RCC_APB2RSTR_DFSDM1RST_Msk |
| #define | RCC_APB2RSTR_HRTIMRST_Pos (29U) |
| #define | RCC_APB2RSTR_HRTIMRST_Msk (0x1UL << RCC_APB2RSTR_HRTIMRST_Pos) |
| #define | RCC_APB2RSTR_HRTIMRST RCC_APB2RSTR_HRTIMRST_Msk |
| #define | RCC_APB4RSTR_SYSCFGRST_Pos (1U) |
| #define | RCC_APB4RSTR_SYSCFGRST_Msk (0x1UL << RCC_APB4RSTR_SYSCFGRST_Pos) |
| #define | RCC_APB4RSTR_SYSCFGRST RCC_APB4RSTR_SYSCFGRST_Msk |
| #define | RCC_APB4RSTR_LPUART1RST_Pos (3U) |
| #define | RCC_APB4RSTR_LPUART1RST_Msk (0x1UL << RCC_APB4RSTR_LPUART1RST_Pos) |
| #define | RCC_APB4RSTR_LPUART1RST RCC_APB4RSTR_LPUART1RST_Msk |
| #define | RCC_APB4RSTR_SPI6RST_Pos (5U) |
| #define | RCC_APB4RSTR_SPI6RST_Msk (0x1UL << RCC_APB4RSTR_SPI6RST_Pos) |
| #define | RCC_APB4RSTR_SPI6RST RCC_APB4RSTR_SPI6RST_Msk |
| #define | RCC_APB4RSTR_I2C4RST_Pos (7U) |
| #define | RCC_APB4RSTR_I2C4RST_Msk (0x1UL << RCC_APB4RSTR_I2C4RST_Pos) |
| #define | RCC_APB4RSTR_I2C4RST RCC_APB4RSTR_I2C4RST_Msk |
| #define | RCC_APB4RSTR_LPTIM2RST_Pos (9U) |
| #define | RCC_APB4RSTR_LPTIM2RST_Msk (0x1UL << RCC_APB4RSTR_LPTIM2RST_Pos) |
| #define | RCC_APB4RSTR_LPTIM2RST RCC_APB4RSTR_LPTIM2RST_Msk |
| #define | RCC_APB4RSTR_LPTIM3RST_Pos (10U) |
| #define | RCC_APB4RSTR_LPTIM3RST_Msk (0x1UL << RCC_APB4RSTR_LPTIM3RST_Pos) |
| #define | RCC_APB4RSTR_LPTIM3RST RCC_APB4RSTR_LPTIM3RST_Msk |
| #define | RCC_APB4RSTR_LPTIM4RST_Pos (11U) |
| #define | RCC_APB4RSTR_LPTIM4RST_Msk (0x1UL << RCC_APB4RSTR_LPTIM4RST_Pos) |
| #define | RCC_APB4RSTR_LPTIM4RST RCC_APB4RSTR_LPTIM4RST_Msk |
| #define | RCC_APB4RSTR_LPTIM5RST_Pos (12U) |
| #define | RCC_APB4RSTR_LPTIM5RST_Msk (0x1UL << RCC_APB4RSTR_LPTIM5RST_Pos) |
| #define | RCC_APB4RSTR_LPTIM5RST RCC_APB4RSTR_LPTIM5RST_Msk |
| #define | RCC_APB4RSTR_COMP12RST_Pos (14U) |
| #define | RCC_APB4RSTR_COMP12RST_Msk (0x1UL << RCC_APB4RSTR_COMP12RST_Pos) |
| #define | RCC_APB4RSTR_COMP12RST RCC_APB4RSTR_COMP12RST_Msk |
| #define | RCC_APB4RSTR_VREFRST_Pos (15U) |
| #define | RCC_APB4RSTR_VREFRST_Msk (0x1UL << RCC_APB4RSTR_VREFRST_Pos) |
| #define | RCC_APB4RSTR_VREFRST RCC_APB4RSTR_VREFRST_Msk |
| #define | RCC_APB4RSTR_SAI4RST_Pos (21U) |
| #define | RCC_APB4RSTR_SAI4RST_Msk (0x1UL << RCC_APB4RSTR_SAI4RST_Pos) |
| #define | RCC_APB4RSTR_SAI4RST RCC_APB4RSTR_SAI4RST_Msk |
| #define | RCC_GCR_WW1RSC_Pos (0U) |
| #define | RCC_GCR_WW1RSC_Msk (0x1UL << RCC_GCR_WW1RSC_Pos) |
| #define | RCC_GCR_WW1RSC RCC_GCR_WW1RSC_Msk |
| #define | RCC_D3AMR_BDMAAMEN_Pos (0U) |
| #define | RCC_D3AMR_BDMAAMEN_Msk (0x1UL << RCC_D3AMR_BDMAAMEN_Pos) |
| #define | RCC_D3AMR_BDMAAMEN RCC_D3AMR_BDMAAMEN_Msk |
| #define | RCC_D3AMR_LPUART1AMEN_Pos (3U) |
| #define | RCC_D3AMR_LPUART1AMEN_Msk (0x1UL << RCC_D3AMR_LPUART1AMEN_Pos) |
| #define | RCC_D3AMR_LPUART1AMEN RCC_D3AMR_LPUART1AMEN_Msk |
| #define | RCC_D3AMR_SPI6AMEN_Pos (5U) |
| #define | RCC_D3AMR_SPI6AMEN_Msk (0x1UL << RCC_D3AMR_SPI6AMEN_Pos) |
| #define | RCC_D3AMR_SPI6AMEN RCC_D3AMR_SPI6AMEN_Msk |
| #define | RCC_D3AMR_I2C4AMEN_Pos (7U) |
| #define | RCC_D3AMR_I2C4AMEN_Msk (0x1UL << RCC_D3AMR_I2C4AMEN_Pos) |
| #define | RCC_D3AMR_I2C4AMEN RCC_D3AMR_I2C4AMEN_Msk |
| #define | RCC_D3AMR_LPTIM2AMEN_Pos (9U) |
| #define | RCC_D3AMR_LPTIM2AMEN_Msk (0x1UL << RCC_D3AMR_LPTIM2AMEN_Pos) |
| #define | RCC_D3AMR_LPTIM2AMEN RCC_D3AMR_LPTIM2AMEN_Msk |
| #define | RCC_D3AMR_LPTIM3AMEN_Pos (10U) |
| #define | RCC_D3AMR_LPTIM3AMEN_Msk (0x1UL << RCC_D3AMR_LPTIM3AMEN_Pos) |
| #define | RCC_D3AMR_LPTIM3AMEN RCC_D3AMR_LPTIM3AMEN_Msk |
| #define | RCC_D3AMR_LPTIM4AMEN_Pos (11U) |
| #define | RCC_D3AMR_LPTIM4AMEN_Msk (0x1UL << RCC_D3AMR_LPTIM4AMEN_Pos) |
| #define | RCC_D3AMR_LPTIM4AMEN RCC_D3AMR_LPTIM4AMEN_Msk |
| #define | RCC_D3AMR_LPTIM5AMEN_Pos (12U) |
| #define | RCC_D3AMR_LPTIM5AMEN_Msk (0x1UL << RCC_D3AMR_LPTIM5AMEN_Pos) |
| #define | RCC_D3AMR_LPTIM5AMEN RCC_D3AMR_LPTIM5AMEN_Msk |
| #define | RCC_D3AMR_COMP12AMEN_Pos (14U) |
| #define | RCC_D3AMR_COMP12AMEN_Msk (0x1UL << RCC_D3AMR_COMP12AMEN_Pos) |
| #define | RCC_D3AMR_COMP12AMEN RCC_D3AMR_COMP12AMEN_Msk |
| #define | RCC_D3AMR_VREFAMEN_Pos (15U) |
| #define | RCC_D3AMR_VREFAMEN_Msk (0x1UL << RCC_D3AMR_VREFAMEN_Pos) |
| #define | RCC_D3AMR_VREFAMEN RCC_D3AMR_VREFAMEN_Msk |
| #define | RCC_D3AMR_RTCAMEN_Pos (16U) |
| #define | RCC_D3AMR_RTCAMEN_Msk (0x1UL << RCC_D3AMR_RTCAMEN_Pos) |
| #define | RCC_D3AMR_RTCAMEN RCC_D3AMR_RTCAMEN_Msk |
| #define | RCC_D3AMR_CRCAMEN_Pos (19U) |
| #define | RCC_D3AMR_CRCAMEN_Msk (0x1UL << RCC_D3AMR_CRCAMEN_Pos) |
| #define | RCC_D3AMR_CRCAMEN RCC_D3AMR_CRCAMEN_Msk |
| #define | RCC_D3AMR_SAI4AMEN_Pos (21U) |
| #define | RCC_D3AMR_SAI4AMEN_Msk (0x1UL << RCC_D3AMR_SAI4AMEN_Pos) |
| #define | RCC_D3AMR_SAI4AMEN RCC_D3AMR_SAI4AMEN_Msk |
| #define | RCC_D3AMR_ADC3AMEN_Pos (24U) |
| #define | RCC_D3AMR_ADC3AMEN_Msk (0x1UL << RCC_D3AMR_ADC3AMEN_Pos) |
| #define | RCC_D3AMR_ADC3AMEN RCC_D3AMR_ADC3AMEN_Msk |
| #define | RCC_D3AMR_BKPRAMAMEN_Pos (28U) |
| #define | RCC_D3AMR_BKPRAMAMEN_Msk (0x1UL << RCC_D3AMR_BKPRAMAMEN_Pos) |
| #define | RCC_D3AMR_BKPRAMAMEN RCC_D3AMR_BKPRAMAMEN_Msk |
| #define | RCC_D3AMR_SRAM4AMEN_Pos (29U) |
| #define | RCC_D3AMR_SRAM4AMEN_Msk (0x1UL << RCC_D3AMR_SRAM4AMEN_Pos) |
| #define | RCC_D3AMR_SRAM4AMEN RCC_D3AMR_SRAM4AMEN_Msk |
| #define | RCC_AHB3LPENR_MDMALPEN_Pos (0U) |
| #define | RCC_AHB3LPENR_MDMALPEN_Msk (0x1UL << RCC_AHB3LPENR_MDMALPEN_Pos) |
| #define | RCC_AHB3LPENR_MDMALPEN RCC_AHB3LPENR_MDMALPEN_Msk |
| #define | RCC_AHB3LPENR_DMA2DLPEN_Pos (4U) |
| #define | RCC_AHB3LPENR_DMA2DLPEN_Msk (0x1UL << RCC_AHB3LPENR_DMA2DLPEN_Pos) |
| #define | RCC_AHB3LPENR_DMA2DLPEN RCC_AHB3LPENR_DMA2DLPEN_Msk |
| #define | RCC_AHB3LPENR_JPGDECLPEN_Pos (5U) |
| #define | RCC_AHB3LPENR_JPGDECLPEN_Msk (0x1UL << RCC_AHB3LPENR_JPGDECLPEN_Pos) |
| #define | RCC_AHB3LPENR_JPGDECLPEN RCC_AHB3LPENR_JPGDECLPEN_Msk |
| #define | RCC_AHB3LPENR_FLASHLPEN_Pos (8U) |
| #define | RCC_AHB3LPENR_FLASHLPEN_Msk (0x1UL << RCC_AHB3LPENR_FLASHLPEN_Pos) |
| #define | RCC_AHB3LPENR_FLASHLPEN RCC_AHB3LPENR_FLASHLPEN_Msk |
| #define | RCC_AHB3LPENR_FMCLPEN_Pos (12U) |
| #define | RCC_AHB3LPENR_FMCLPEN_Msk (0x1UL << RCC_AHB3LPENR_FMCLPEN_Pos) |
| #define | RCC_AHB3LPENR_FMCLPEN RCC_AHB3LPENR_FMCLPEN_Msk |
| #define | RCC_AHB3LPENR_QSPILPEN_Pos (14U) |
| #define | RCC_AHB3LPENR_QSPILPEN_Msk (0x1UL << RCC_AHB3LPENR_QSPILPEN_Pos) |
| #define | RCC_AHB3LPENR_QSPILPEN RCC_AHB3LPENR_QSPILPEN_Msk |
| #define | RCC_AHB3LPENR_SDMMC1LPEN_Pos (16U) |
| #define | RCC_AHB3LPENR_SDMMC1LPEN_Msk (0x1UL << RCC_AHB3LPENR_SDMMC1LPEN_Pos) |
| #define | RCC_AHB3LPENR_SDMMC1LPEN RCC_AHB3LPENR_SDMMC1LPEN_Msk |
| #define | RCC_AHB3LPENR_DTCM1LPEN_Pos (28U) |
| #define | RCC_AHB3LPENR_DTCM1LPEN_Msk (0x1UL << RCC_AHB3LPENR_DTCM1LPEN_Pos) |
| #define | RCC_AHB3LPENR_DTCM1LPEN RCC_AHB3LPENR_DTCM1LPEN_Msk |
| #define | RCC_AHB3LPENR_DTCM2LPEN_Pos (29U) |
| #define | RCC_AHB3LPENR_DTCM2LPEN_Msk (0x1UL << RCC_AHB3LPENR_DTCM2LPEN_Pos) |
| #define | RCC_AHB3LPENR_DTCM2LPEN RCC_AHB3LPENR_DTCM2LPEN_Msk |
| #define | RCC_AHB3LPENR_ITCMLPEN_Pos (30U) |
| #define | RCC_AHB3LPENR_ITCMLPEN_Msk (0x1UL << RCC_AHB3LPENR_ITCMLPEN_Pos) |
| #define | RCC_AHB3LPENR_ITCMLPEN RCC_AHB3LPENR_ITCMLPEN_Msk |
| #define | RCC_AHB3LPENR_AXISRAMLPEN_Pos (31U) |
| #define | RCC_AHB3LPENR_AXISRAMLPEN_Msk (0x1UL << RCC_AHB3LPENR_AXISRAMLPEN_Pos) |
| #define | RCC_AHB3LPENR_AXISRAMLPEN RCC_AHB3LPENR_AXISRAMLPEN_Msk |
| #define | RCC_AHB1LPENR_DMA1LPEN_Pos (0U) |
| #define | RCC_AHB1LPENR_DMA1LPEN_Msk (0x1UL << RCC_AHB1LPENR_DMA1LPEN_Pos) |
| #define | RCC_AHB1LPENR_DMA1LPEN RCC_AHB1LPENR_DMA1LPEN_Msk |
| #define | RCC_AHB1LPENR_DMA2LPEN_Pos (1U) |
| #define | RCC_AHB1LPENR_DMA2LPEN_Msk (0x1UL << RCC_AHB1LPENR_DMA2LPEN_Pos) |
| #define | RCC_AHB1LPENR_DMA2LPEN RCC_AHB1LPENR_DMA2LPEN_Msk |
| #define | RCC_AHB1LPENR_ADC12LPEN_Pos (5U) |
| #define | RCC_AHB1LPENR_ADC12LPEN_Msk (0x1UL << RCC_AHB1LPENR_ADC12LPEN_Pos) |
| #define | RCC_AHB1LPENR_ADC12LPEN RCC_AHB1LPENR_ADC12LPEN_Msk |
| #define | RCC_AHB1LPENR_ETH1MACLPEN_Pos (15U) |
| #define | RCC_AHB1LPENR_ETH1MACLPEN_Msk (0x1UL << RCC_AHB1LPENR_ETH1MACLPEN_Pos) |
| #define | RCC_AHB1LPENR_ETH1MACLPEN RCC_AHB1LPENR_ETH1MACLPEN_Msk |
| #define | RCC_AHB1LPENR_ETH1TXLPEN_Pos (16U) |
| #define | RCC_AHB1LPENR_ETH1TXLPEN_Msk (0x1UL << RCC_AHB1LPENR_ETH1TXLPEN_Pos) |
| #define | RCC_AHB1LPENR_ETH1TXLPEN RCC_AHB1LPENR_ETH1TXLPEN_Msk |
| #define | RCC_AHB1LPENR_ETH1RXLPEN_Pos (17U) |
| #define | RCC_AHB1LPENR_ETH1RXLPEN_Msk (0x1UL << RCC_AHB1LPENR_ETH1RXLPEN_Pos) |
| #define | RCC_AHB1LPENR_ETH1RXLPEN RCC_AHB1LPENR_ETH1RXLPEN_Msk |
| #define | RCC_AHB1LPENR_USB1OTGHSLPEN_Pos (25U) |
| #define | RCC_AHB1LPENR_USB1OTGHSLPEN_Msk (0x1UL << RCC_AHB1LPENR_USB1OTGHSLPEN_Pos) |
| #define | RCC_AHB1LPENR_USB1OTGHSLPEN RCC_AHB1LPENR_USB1OTGHSLPEN_Msk |
| #define | RCC_AHB1LPENR_USB1OTGHSULPILPEN_Pos (26U) |
| #define | RCC_AHB1LPENR_USB1OTGHSULPILPEN_Msk (0x1UL << RCC_AHB1LPENR_USB1OTGHSULPILPEN_Pos) |
| #define | RCC_AHB1LPENR_USB1OTGHSULPILPEN RCC_AHB1LPENR_USB1OTGHSULPILPEN_Msk |
| #define | RCC_AHB1LPENR_USB2OTGFSLPEN_Pos (27U) |
| #define | RCC_AHB1LPENR_USB2OTGFSLPEN_Msk (0x1UL << RCC_AHB1LPENR_USB2OTGFSLPEN_Pos) |
| #define | RCC_AHB1LPENR_USB2OTGFSLPEN RCC_AHB1LPENR_USB2OTGFSLPEN_Msk |
| #define | RCC_AHB1LPENR_USB2OTGFSULPILPEN_Pos (28U) |
| #define | RCC_AHB1LPENR_USB2OTGFSULPILPEN_Msk (0x1UL << RCC_AHB1LPENR_USB2OTGFSULPILPEN_Pos) |
| #define | RCC_AHB1LPENR_USB2OTGFSULPILPEN RCC_AHB1LPENR_USB2OTGFSULPILPEN_Msk |
| #define | RCC_AHB1LPENR_USB2OTGHSLPEN_Pos RCC_AHB1LPENR_USB2OTGFSLPEN_Pos |
| #define | RCC_AHB1LPENR_USB2OTGHSLPEN_Msk RCC_AHB1LPENR_USB2OTGFSLPEN_Msk |
| #define | RCC_AHB1LPENR_USB2OTGHSLPEN RCC_AHB1LPENR_USB2OTGFSLPEN |
| #define | RCC_AHB1LPENR_USB2OTGHSULPILPEN_Pos RCC_AHB1LPENR_USB2OTGFSULPILPEN_Pos |
| #define | RCC_AHB1LPENR_USB2OTGHSULPILPEN_Msk RCC_AHB1LPENR_USB2OTGFSULPILPEN_Msk |
| #define | RCC_AHB1LPENR_USB2OTGHSULPILPEN RCC_AHB1LPENR_USB2OTGFSULPILPEN |
| #define | RCC_AHB2LPENR_DCMILPEN_Pos (0U) |
| #define | RCC_AHB2LPENR_DCMILPEN_Msk (0x1UL << RCC_AHB2LPENR_DCMILPEN_Pos) |
| #define | RCC_AHB2LPENR_DCMILPEN RCC_AHB2LPENR_DCMILPEN_Msk |
| #define | RCC_AHB2LPENR_CRYPLPEN_Pos (4U) |
| #define | RCC_AHB2LPENR_CRYPLPEN_Msk (0x1UL << RCC_AHB2LPENR_CRYPLPEN_Pos) |
| #define | RCC_AHB2LPENR_CRYPLPEN RCC_AHB2LPENR_CRYPLPEN_Msk |
| #define | RCC_AHB2LPENR_HASHLPEN_Pos (5U) |
| #define | RCC_AHB2LPENR_HASHLPEN_Msk (0x1UL << RCC_AHB2LPENR_HASHLPEN_Pos) |
| #define | RCC_AHB2LPENR_HASHLPEN RCC_AHB2LPENR_HASHLPEN_Msk |
| #define | RCC_AHB2LPENR_RNGLPEN_Pos (6U) |
| #define | RCC_AHB2LPENR_RNGLPEN_Msk (0x1UL << RCC_AHB2LPENR_RNGLPEN_Pos) |
| #define | RCC_AHB2LPENR_RNGLPEN RCC_AHB2LPENR_RNGLPEN_Msk |
| #define | RCC_AHB2LPENR_SDMMC2LPEN_Pos (9U) |
| #define | RCC_AHB2LPENR_SDMMC2LPEN_Msk (0x1UL << RCC_AHB2LPENR_SDMMC2LPEN_Pos) |
| #define | RCC_AHB2LPENR_SDMMC2LPEN RCC_AHB2LPENR_SDMMC2LPEN_Msk |
| #define | RCC_AHB2LPENR_SRAM1LPEN_Pos (29U) |
| #define | RCC_AHB2LPENR_SRAM1LPEN_Msk (0x1UL << RCC_AHB2LPENR_SRAM1LPEN_Pos) |
| #define | RCC_AHB2LPENR_SRAM1LPEN RCC_AHB2LPENR_SRAM1LPEN_Msk |
| #define | RCC_AHB2LPENR_SRAM2LPEN_Pos (30U) |
| #define | RCC_AHB2LPENR_SRAM2LPEN_Msk (0x1UL << RCC_AHB2LPENR_SRAM2LPEN_Pos) |
| #define | RCC_AHB2LPENR_SRAM2LPEN RCC_AHB2LPENR_SRAM2LPEN_Msk |
| #define | RCC_AHB2LPENR_SRAM3LPEN_Pos (31U) |
| #define | RCC_AHB2LPENR_SRAM3LPEN_Msk (0x1UL << RCC_AHB2LPENR_SRAM3LPEN_Pos) |
| #define | RCC_AHB2LPENR_SRAM3LPEN RCC_AHB2LPENR_SRAM3LPEN_Msk |
| #define | RCC_AHB2LPENR_D2SRAM1LPEN_Pos RCC_AHB2LPENR_SRAM1LPEN_Pos |
| #define | RCC_AHB2LPENR_D2SRAM1LPEN_Msk RCC_AHB2LPENR_SRAM1LPEN_Msk |
| #define | RCC_AHB2LPENR_D2SRAM1LPEN RCC_AHB2LPENR_SRAM1LPEN |
| #define | RCC_AHB2LPENR_D2SRAM2LPEN_Pos RCC_AHB2LPENR_SRAM2LPEN_Pos |
| #define | RCC_AHB2LPENR_D2SRAM2LPEN_Msk RCC_AHB2LPENR_SRAM2LPEN_Msk |
| #define | RCC_AHB2LPENR_D2SRAM2LPEN RCC_AHB2LPENR_SRAM2LPEN |
| #define | RCC_AHB2LPENR_D2SRAM3LPEN_Pos RCC_AHB2LPENR_SRAM3LPEN_Pos |
| #define | RCC_AHB2LPENR_D2SRAM3LPEN_Msk RCC_AHB2LPENR_SRAM3LPEN_Msk |
| #define | RCC_AHB2LPENR_D2SRAM3LPEN RCC_AHB2LPENR_SRAM3LPEN |
| #define | RCC_AHB4LPENR_GPIOALPEN_Pos (0U) |
| #define | RCC_AHB4LPENR_GPIOALPEN_Msk (0x1UL << RCC_AHB4LPENR_GPIOALPEN_Pos) |
| #define | RCC_AHB4LPENR_GPIOALPEN RCC_AHB4LPENR_GPIOALPEN_Msk |
| #define | RCC_AHB4LPENR_GPIOBLPEN_Pos (1U) |
| #define | RCC_AHB4LPENR_GPIOBLPEN_Msk (0x1UL << RCC_AHB4LPENR_GPIOBLPEN_Pos) |
| #define | RCC_AHB4LPENR_GPIOBLPEN RCC_AHB4LPENR_GPIOBLPEN_Msk |
| #define | RCC_AHB4LPENR_GPIOCLPEN_Pos (2U) |
| #define | RCC_AHB4LPENR_GPIOCLPEN_Msk (0x1UL << RCC_AHB4LPENR_GPIOCLPEN_Pos) |
| #define | RCC_AHB4LPENR_GPIOCLPEN RCC_AHB4LPENR_GPIOCLPEN_Msk |
| #define | RCC_AHB4LPENR_GPIODLPEN_Pos (3U) |
| #define | RCC_AHB4LPENR_GPIODLPEN_Msk (0x1UL << RCC_AHB4LPENR_GPIODLPEN_Pos) |
| #define | RCC_AHB4LPENR_GPIODLPEN RCC_AHB4LPENR_GPIODLPEN_Msk |
| #define | RCC_AHB4LPENR_GPIOELPEN_Pos (4U) |
| #define | RCC_AHB4LPENR_GPIOELPEN_Msk (0x1UL << RCC_AHB4LPENR_GPIOELPEN_Pos) |
| #define | RCC_AHB4LPENR_GPIOELPEN RCC_AHB4LPENR_GPIOELPEN_Msk |
| #define | RCC_AHB4LPENR_GPIOFLPEN_Pos (5U) |
| #define | RCC_AHB4LPENR_GPIOFLPEN_Msk (0x1UL << RCC_AHB4LPENR_GPIOFLPEN_Pos) |
| #define | RCC_AHB4LPENR_GPIOFLPEN RCC_AHB4LPENR_GPIOFLPEN_Msk |
| #define | RCC_AHB4LPENR_GPIOGLPEN_Pos (6U) |
| #define | RCC_AHB4LPENR_GPIOGLPEN_Msk (0x1UL << RCC_AHB4LPENR_GPIOGLPEN_Pos) |
| #define | RCC_AHB4LPENR_GPIOGLPEN RCC_AHB4LPENR_GPIOGLPEN_Msk |
| #define | RCC_AHB4LPENR_GPIOHLPEN_Pos (7U) |
| #define | RCC_AHB4LPENR_GPIOHLPEN_Msk (0x1UL << RCC_AHB4LPENR_GPIOHLPEN_Pos) |
| #define | RCC_AHB4LPENR_GPIOHLPEN RCC_AHB4LPENR_GPIOHLPEN_Msk |
| #define | RCC_AHB4LPENR_GPIOILPEN_Pos (8U) |
| #define | RCC_AHB4LPENR_GPIOILPEN_Msk (0x1UL << RCC_AHB4LPENR_GPIOILPEN_Pos) |
| #define | RCC_AHB4LPENR_GPIOILPEN RCC_AHB4LPENR_GPIOILPEN_Msk |
| #define | RCC_AHB4LPENR_GPIOJLPEN_Pos (9U) |
| #define | RCC_AHB4LPENR_GPIOJLPEN_Msk (0x1UL << RCC_AHB4LPENR_GPIOJLPEN_Pos) |
| #define | RCC_AHB4LPENR_GPIOJLPEN RCC_AHB4LPENR_GPIOJLPEN_Msk |
| #define | RCC_AHB4LPENR_GPIOKLPEN_Pos (10U) |
| #define | RCC_AHB4LPENR_GPIOKLPEN_Msk (0x1UL << RCC_AHB4LPENR_GPIOKLPEN_Pos) |
| #define | RCC_AHB4LPENR_GPIOKLPEN RCC_AHB4LPENR_GPIOKLPEN_Msk |
| #define | RCC_AHB4LPENR_CRCLPEN_Pos (19U) |
| #define | RCC_AHB4LPENR_CRCLPEN_Msk (0x1UL << RCC_AHB4LPENR_CRCLPEN_Pos) |
| #define | RCC_AHB4LPENR_CRCLPEN RCC_AHB4LPENR_CRCLPEN_Msk |
| #define | RCC_AHB4LPENR_BDMALPEN_Pos (21U) |
| #define | RCC_AHB4LPENR_BDMALPEN_Msk (0x1UL << RCC_AHB4LPENR_BDMALPEN_Pos) |
| #define | RCC_AHB4LPENR_BDMALPEN RCC_AHB4LPENR_BDMALPEN_Msk |
| #define | RCC_AHB4LPENR_ADC3LPEN_Pos (24U) |
| #define | RCC_AHB4LPENR_ADC3LPEN_Msk (0x1UL << RCC_AHB4LPENR_ADC3LPEN_Pos) |
| #define | RCC_AHB4LPENR_ADC3LPEN RCC_AHB4LPENR_ADC3LPEN_Msk |
| #define | RCC_AHB4LPENR_BKPRAMLPEN_Pos (28U) |
| #define | RCC_AHB4LPENR_BKPRAMLPEN_Msk (0x1UL << RCC_AHB4LPENR_BKPRAMLPEN_Pos) |
| #define | RCC_AHB4LPENR_BKPRAMLPEN RCC_AHB4LPENR_BKPRAMLPEN_Msk |
| #define | RCC_AHB4LPENR_SRAM4LPEN_Pos (29U) |
| #define | RCC_AHB4LPENR_SRAM4LPEN_Msk (0x1UL << RCC_AHB4LPENR_SRAM4LPEN_Pos) |
| #define | RCC_AHB4LPENR_SRAM4LPEN RCC_AHB4LPENR_SRAM4LPEN_Msk |
| #define | RCC_AHB4LPENR_D3SRAM1LPEN_Pos RCC_AHB4LPENR_SRAM4LPEN_Pos |
| #define | RCC_AHB4LPENR_D3SRAM1LPEN_Msk RCC_AHB4LPENR_SRAM4LPEN_Msk |
| #define | RCC_AHB4LPENR_D3SRAM1LPEN RCC_AHB4LPENR_SRAM4LPEN |
| #define | RCC_APB3LPENR_LTDCLPEN_Pos (3U) |
| #define | RCC_APB3LPENR_LTDCLPEN_Msk (0x1UL << RCC_APB3LPENR_LTDCLPEN_Pos) |
| #define | RCC_APB3LPENR_LTDCLPEN RCC_APB3LPENR_LTDCLPEN_Msk |
| #define | RCC_APB3LPENR_WWDG1LPEN_Pos (6U) |
| #define | RCC_APB3LPENR_WWDG1LPEN_Msk (0x1UL << RCC_APB3LPENR_WWDG1LPEN_Pos) |
| #define | RCC_APB3LPENR_WWDG1LPEN RCC_APB3LPENR_WWDG1LPEN_Msk |
| #define | RCC_APB1LLPENR_TIM2LPEN_Pos (0U) |
| #define | RCC_APB1LLPENR_TIM2LPEN_Msk (0x1UL << RCC_APB1LLPENR_TIM2LPEN_Pos) |
| #define | RCC_APB1LLPENR_TIM2LPEN RCC_APB1LLPENR_TIM2LPEN_Msk |
| #define | RCC_APB1LLPENR_TIM3LPEN_Pos (1U) |
| #define | RCC_APB1LLPENR_TIM3LPEN_Msk (0x1UL << RCC_APB1LLPENR_TIM3LPEN_Pos) |
| #define | RCC_APB1LLPENR_TIM3LPEN RCC_APB1LLPENR_TIM3LPEN_Msk |
| #define | RCC_APB1LLPENR_TIM4LPEN_Pos (2U) |
| #define | RCC_APB1LLPENR_TIM4LPEN_Msk (0x1UL << RCC_APB1LLPENR_TIM4LPEN_Pos) |
| #define | RCC_APB1LLPENR_TIM4LPEN RCC_APB1LLPENR_TIM4LPEN_Msk |
| #define | RCC_APB1LLPENR_TIM5LPEN_Pos (3U) |
| #define | RCC_APB1LLPENR_TIM5LPEN_Msk (0x1UL << RCC_APB1LLPENR_TIM5LPEN_Pos) |
| #define | RCC_APB1LLPENR_TIM5LPEN RCC_APB1LLPENR_TIM5LPEN_Msk |
| #define | RCC_APB1LLPENR_TIM6LPEN_Pos (4U) |
| #define | RCC_APB1LLPENR_TIM6LPEN_Msk (0x1UL << RCC_APB1LLPENR_TIM6LPEN_Pos) |
| #define | RCC_APB1LLPENR_TIM6LPEN RCC_APB1LLPENR_TIM6LPEN_Msk |
| #define | RCC_APB1LLPENR_TIM7LPEN_Pos (5U) |
| #define | RCC_APB1LLPENR_TIM7LPEN_Msk (0x1UL << RCC_APB1LLPENR_TIM7LPEN_Pos) |
| #define | RCC_APB1LLPENR_TIM7LPEN RCC_APB1LLPENR_TIM7LPEN_Msk |
| #define | RCC_APB1LLPENR_TIM12LPEN_Pos (6U) |
| #define | RCC_APB1LLPENR_TIM12LPEN_Msk (0x1UL << RCC_APB1LLPENR_TIM12LPEN_Pos) |
| #define | RCC_APB1LLPENR_TIM12LPEN RCC_APB1LLPENR_TIM12LPEN_Msk |
| #define | RCC_APB1LLPENR_TIM13LPEN_Pos (7U) |
| #define | RCC_APB1LLPENR_TIM13LPEN_Msk (0x1UL << RCC_APB1LLPENR_TIM13LPEN_Pos) |
| #define | RCC_APB1LLPENR_TIM13LPEN RCC_APB1LLPENR_TIM13LPEN_Msk |
| #define | RCC_APB1LLPENR_TIM14LPEN_Pos (8U) |
| #define | RCC_APB1LLPENR_TIM14LPEN_Msk (0x1UL << RCC_APB1LLPENR_TIM14LPEN_Pos) |
| #define | RCC_APB1LLPENR_TIM14LPEN RCC_APB1LLPENR_TIM14LPEN_Msk |
| #define | RCC_APB1LLPENR_LPTIM1LPEN_Pos (9U) |
| #define | RCC_APB1LLPENR_LPTIM1LPEN_Msk (0x1UL << RCC_APB1LLPENR_LPTIM1LPEN_Pos) |
| #define | RCC_APB1LLPENR_LPTIM1LPEN RCC_APB1LLPENR_LPTIM1LPEN_Msk |
| #define | RCC_APB1LLPENR_SPI2LPEN_Pos (14U) |
| #define | RCC_APB1LLPENR_SPI2LPEN_Msk (0x1UL << RCC_APB1LLPENR_SPI2LPEN_Pos) |
| #define | RCC_APB1LLPENR_SPI2LPEN RCC_APB1LLPENR_SPI2LPEN_Msk |
| #define | RCC_APB1LLPENR_SPI3LPEN_Pos (15U) |
| #define | RCC_APB1LLPENR_SPI3LPEN_Msk (0x1UL << RCC_APB1LLPENR_SPI3LPEN_Pos) |
| #define | RCC_APB1LLPENR_SPI3LPEN RCC_APB1LLPENR_SPI3LPEN_Msk |
| #define | RCC_APB1LLPENR_SPDIFRXLPEN_Pos (16U) |
| #define | RCC_APB1LLPENR_SPDIFRXLPEN_Msk (0x1UL << RCC_APB1LLPENR_SPDIFRXLPEN_Pos) |
| #define | RCC_APB1LLPENR_SPDIFRXLPEN RCC_APB1LLPENR_SPDIFRXLPEN_Msk |
| #define | RCC_APB1LLPENR_USART2LPEN_Pos (17U) |
| #define | RCC_APB1LLPENR_USART2LPEN_Msk (0x1UL << RCC_APB1LLPENR_USART2LPEN_Pos) |
| #define | RCC_APB1LLPENR_USART2LPEN RCC_APB1LLPENR_USART2LPEN_Msk |
| #define | RCC_APB1LLPENR_USART3LPEN_Pos (18U) |
| #define | RCC_APB1LLPENR_USART3LPEN_Msk (0x1UL << RCC_APB1LLPENR_USART3LPEN_Pos) |
| #define | RCC_APB1LLPENR_USART3LPEN RCC_APB1LLPENR_USART3LPEN_Msk |
| #define | RCC_APB1LLPENR_UART4LPEN_Pos (19U) |
| #define | RCC_APB1LLPENR_UART4LPEN_Msk (0x1UL << RCC_APB1LLPENR_UART4LPEN_Pos) |
| #define | RCC_APB1LLPENR_UART4LPEN RCC_APB1LLPENR_UART4LPEN_Msk |
| #define | RCC_APB1LLPENR_UART5LPEN_Pos (20U) |
| #define | RCC_APB1LLPENR_UART5LPEN_Msk (0x1UL << RCC_APB1LLPENR_UART5LPEN_Pos) |
| #define | RCC_APB1LLPENR_UART5LPEN RCC_APB1LLPENR_UART5LPEN_Msk |
| #define | RCC_APB1LLPENR_I2C1LPEN_Pos (21U) |
| #define | RCC_APB1LLPENR_I2C1LPEN_Msk (0x1UL << RCC_APB1LLPENR_I2C1LPEN_Pos) |
| #define | RCC_APB1LLPENR_I2C1LPEN RCC_APB1LLPENR_I2C1LPEN_Msk |
| #define | RCC_APB1LLPENR_I2C2LPEN_Pos (22U) |
| #define | RCC_APB1LLPENR_I2C2LPEN_Msk (0x1UL << RCC_APB1LLPENR_I2C2LPEN_Pos) |
| #define | RCC_APB1LLPENR_I2C2LPEN RCC_APB1LLPENR_I2C2LPEN_Msk |
| #define | RCC_APB1LLPENR_I2C3LPEN_Pos (23U) |
| #define | RCC_APB1LLPENR_I2C3LPEN_Msk (0x1UL << RCC_APB1LLPENR_I2C3LPEN_Pos) |
| #define | RCC_APB1LLPENR_I2C3LPEN RCC_APB1LLPENR_I2C3LPEN_Msk |
| #define | RCC_APB1LLPENR_CECLPEN_Pos (27U) |
| #define | RCC_APB1LLPENR_CECLPEN_Msk (0x1UL << RCC_APB1LLPENR_CECLPEN_Pos) |
| #define | RCC_APB1LLPENR_CECLPEN RCC_APB1LLPENR_CECLPEN_Msk |
| #define | RCC_APB1LLPENR_DAC12LPEN_Pos (29U) |
| #define | RCC_APB1LLPENR_DAC12LPEN_Msk (0x1UL << RCC_APB1LLPENR_DAC12LPEN_Pos) |
| #define | RCC_APB1LLPENR_DAC12LPEN RCC_APB1LLPENR_DAC12LPEN_Msk |
| #define | RCC_APB1LLPENR_UART7LPEN_Pos (30U) |
| #define | RCC_APB1LLPENR_UART7LPEN_Msk (0x1UL << RCC_APB1LLPENR_UART7LPEN_Pos) |
| #define | RCC_APB1LLPENR_UART7LPEN RCC_APB1LLPENR_UART7LPEN_Msk |
| #define | RCC_APB1LLPENR_UART8LPEN_Pos (31U) |
| #define | RCC_APB1LLPENR_UART8LPEN_Msk (0x1UL << RCC_APB1LLPENR_UART8LPEN_Pos) |
| #define | RCC_APB1LLPENR_UART8LPEN RCC_APB1LLPENR_UART8LPEN_Msk |
| #define | RCC_APB1LLPENR_HDMICECEN_Pos RCC_APB1LLPENR_CECLPEN_Pos |
| #define | RCC_APB1LLPENR_HDMICECEN_Msk RCC_APB1LLPENR_CECLPEN_Msk |
| #define | RCC_APB1LLPENR_HDMICECEN RCC_APB1LLPENR_CECLPEN |
| #define | RCC_APB1HLPENR_CRSLPEN_Pos (1U) |
| #define | RCC_APB1HLPENR_CRSLPEN_Msk (0x1UL << RCC_APB1HLPENR_CRSLPEN_Pos) |
| #define | RCC_APB1HLPENR_CRSLPEN RCC_APB1HLPENR_CRSLPEN_Msk |
| #define | RCC_APB1HLPENR_SWPMILPEN_Pos (2U) |
| #define | RCC_APB1HLPENR_SWPMILPEN_Msk (0x1UL << RCC_APB1HLPENR_SWPMILPEN_Pos) |
| #define | RCC_APB1HLPENR_SWPMILPEN RCC_APB1HLPENR_SWPMILPEN_Msk |
| #define | RCC_APB1HLPENR_OPAMPLPEN_Pos (4U) |
| #define | RCC_APB1HLPENR_OPAMPLPEN_Msk (0x1UL << RCC_APB1HLPENR_OPAMPLPEN_Pos) |
| #define | RCC_APB1HLPENR_OPAMPLPEN RCC_APB1HLPENR_OPAMPLPEN_Msk |
| #define | RCC_APB1HLPENR_MDIOSLPEN_Pos (5U) |
| #define | RCC_APB1HLPENR_MDIOSLPEN_Msk (0x1UL << RCC_APB1HLPENR_MDIOSLPEN_Pos) |
| #define | RCC_APB1HLPENR_MDIOSLPEN RCC_APB1HLPENR_MDIOSLPEN_Msk |
| #define | RCC_APB1HLPENR_FDCANLPEN_Pos (8U) |
| #define | RCC_APB1HLPENR_FDCANLPEN_Msk (0x1UL << RCC_APB1HLPENR_FDCANLPEN_Pos) |
| #define | RCC_APB1HLPENR_FDCANLPEN RCC_APB1HLPENR_FDCANLPEN_Msk |
| #define | RCC_APB2LPENR_TIM1LPEN_Pos (0U) |
| #define | RCC_APB2LPENR_TIM1LPEN_Msk (0x1UL << RCC_APB2LPENR_TIM1LPEN_Pos) |
| #define | RCC_APB2LPENR_TIM1LPEN RCC_APB2LPENR_TIM1LPEN_Msk |
| #define | RCC_APB2LPENR_TIM8LPEN_Pos (1U) |
| #define | RCC_APB2LPENR_TIM8LPEN_Msk (0x1UL << RCC_APB2LPENR_TIM8LPEN_Pos) |
| #define | RCC_APB2LPENR_TIM8LPEN RCC_APB2LPENR_TIM8LPEN_Msk |
| #define | RCC_APB2LPENR_USART1LPEN_Pos (4U) |
| #define | RCC_APB2LPENR_USART1LPEN_Msk (0x1UL << RCC_APB2LPENR_USART1LPEN_Pos) |
| #define | RCC_APB2LPENR_USART1LPEN RCC_APB2LPENR_USART1LPEN_Msk |
| #define | RCC_APB2LPENR_USART6LPEN_Pos (5U) |
| #define | RCC_APB2LPENR_USART6LPEN_Msk (0x1UL << RCC_APB2LPENR_USART6LPEN_Pos) |
| #define | RCC_APB2LPENR_USART6LPEN RCC_APB2LPENR_USART6LPEN_Msk |
| #define | RCC_APB2LPENR_SPI1LPEN_Pos (12U) |
| #define | RCC_APB2LPENR_SPI1LPEN_Msk (0x1UL << RCC_APB2LPENR_SPI1LPEN_Pos) |
| #define | RCC_APB2LPENR_SPI1LPEN RCC_APB2LPENR_SPI1LPEN_Msk |
| #define | RCC_APB2LPENR_SPI4LPEN_Pos (13U) |
| #define | RCC_APB2LPENR_SPI4LPEN_Msk (0x1UL << RCC_APB2LPENR_SPI4LPEN_Pos) |
| #define | RCC_APB2LPENR_SPI4LPEN RCC_APB2LPENR_SPI4LPEN_Msk |
| #define | RCC_APB2LPENR_TIM15LPEN_Pos (16U) |
| #define | RCC_APB2LPENR_TIM15LPEN_Msk (0x1UL << RCC_APB2LPENR_TIM15LPEN_Pos) |
| #define | RCC_APB2LPENR_TIM15LPEN RCC_APB2LPENR_TIM15LPEN_Msk |
| #define | RCC_APB2LPENR_TIM16LPEN_Pos (17U) |
| #define | RCC_APB2LPENR_TIM16LPEN_Msk (0x1UL << RCC_APB2LPENR_TIM16LPEN_Pos) |
| #define | RCC_APB2LPENR_TIM16LPEN RCC_APB2LPENR_TIM16LPEN_Msk |
| #define | RCC_APB2LPENR_TIM17LPEN_Pos (18U) |
| #define | RCC_APB2LPENR_TIM17LPEN_Msk (0x1UL << RCC_APB2LPENR_TIM17LPEN_Pos) |
| #define | RCC_APB2LPENR_TIM17LPEN RCC_APB2LPENR_TIM17LPEN_Msk |
| #define | RCC_APB2LPENR_SPI5LPEN_Pos (20U) |
| #define | RCC_APB2LPENR_SPI5LPEN_Msk (0x1UL << RCC_APB2LPENR_SPI5LPEN_Pos) |
| #define | RCC_APB2LPENR_SPI5LPEN RCC_APB2LPENR_SPI5LPEN_Msk |
| #define | RCC_APB2LPENR_SAI1LPEN_Pos (22U) |
| #define | RCC_APB2LPENR_SAI1LPEN_Msk (0x1UL << RCC_APB2LPENR_SAI1LPEN_Pos) |
| #define | RCC_APB2LPENR_SAI1LPEN RCC_APB2LPENR_SAI1LPEN_Msk |
| #define | RCC_APB2LPENR_SAI2LPEN_Pos (23U) |
| #define | RCC_APB2LPENR_SAI2LPEN_Msk (0x1UL << RCC_APB2LPENR_SAI2LPEN_Pos) |
| #define | RCC_APB2LPENR_SAI2LPEN RCC_APB2LPENR_SAI2LPEN_Msk |
| #define | RCC_APB2LPENR_SAI3LPEN_Pos (24U) |
| #define | RCC_APB2LPENR_SAI3LPEN_Msk (0x1UL << RCC_APB2LPENR_SAI3LPEN_Pos) |
| #define | RCC_APB2LPENR_SAI3LPEN RCC_APB2LPENR_SAI3LPEN_Msk |
| #define | RCC_APB2LPENR_DFSDM1LPEN_Pos (28U) |
| #define | RCC_APB2LPENR_DFSDM1LPEN_Msk (0x1UL << RCC_APB2LPENR_DFSDM1LPEN_Pos) |
| #define | RCC_APB2LPENR_DFSDM1LPEN RCC_APB2LPENR_DFSDM1LPEN_Msk |
| #define | RCC_APB2LPENR_HRTIMLPEN_Pos (29U) |
| #define | RCC_APB2LPENR_HRTIMLPEN_Msk (0x1UL << RCC_APB2LPENR_HRTIMLPEN_Pos) |
| #define | RCC_APB2LPENR_HRTIMLPEN RCC_APB2LPENR_HRTIMLPEN_Msk |
| #define | RCC_APB4LPENR_SYSCFGLPEN_Pos (1U) |
| #define | RCC_APB4LPENR_SYSCFGLPEN_Msk (0x1UL << RCC_APB4LPENR_SYSCFGLPEN_Pos) |
| #define | RCC_APB4LPENR_SYSCFGLPEN RCC_APB4LPENR_SYSCFGLPEN_Msk |
| #define | RCC_APB4LPENR_LPUART1LPEN_Pos (3U) |
| #define | RCC_APB4LPENR_LPUART1LPEN_Msk (0x1UL << RCC_APB4LPENR_LPUART1LPEN_Pos) |
| #define | RCC_APB4LPENR_LPUART1LPEN RCC_APB4LPENR_LPUART1LPEN_Msk |
| #define | RCC_APB4LPENR_SPI6LPEN_Pos (5U) |
| #define | RCC_APB4LPENR_SPI6LPEN_Msk (0x1UL << RCC_APB4LPENR_SPI6LPEN_Pos) |
| #define | RCC_APB4LPENR_SPI6LPEN RCC_APB4LPENR_SPI6LPEN_Msk |
| #define | RCC_APB4LPENR_I2C4LPEN_Pos (7U) |
| #define | RCC_APB4LPENR_I2C4LPEN_Msk (0x1UL << RCC_APB4LPENR_I2C4LPEN_Pos) |
| #define | RCC_APB4LPENR_I2C4LPEN RCC_APB4LPENR_I2C4LPEN_Msk |
| #define | RCC_APB4LPENR_LPTIM2LPEN_Pos (9U) |
| #define | RCC_APB4LPENR_LPTIM2LPEN_Msk (0x1UL << RCC_APB4LPENR_LPTIM2LPEN_Pos) |
| #define | RCC_APB4LPENR_LPTIM2LPEN RCC_APB4LPENR_LPTIM2LPEN_Msk |
| #define | RCC_APB4LPENR_LPTIM3LPEN_Pos (10U) |
| #define | RCC_APB4LPENR_LPTIM3LPEN_Msk (0x1UL << RCC_APB4LPENR_LPTIM3LPEN_Pos) |
| #define | RCC_APB4LPENR_LPTIM3LPEN RCC_APB4LPENR_LPTIM3LPEN_Msk |
| #define | RCC_APB4LPENR_LPTIM4LPEN_Pos (11U) |
| #define | RCC_APB4LPENR_LPTIM4LPEN_Msk (0x1UL << RCC_APB4LPENR_LPTIM4LPEN_Pos) |
| #define | RCC_APB4LPENR_LPTIM4LPEN RCC_APB4LPENR_LPTIM4LPEN_Msk |
| #define | RCC_APB4LPENR_LPTIM5LPEN_Pos (12U) |
| #define | RCC_APB4LPENR_LPTIM5LPEN_Msk (0x1UL << RCC_APB4LPENR_LPTIM5LPEN_Pos) |
| #define | RCC_APB4LPENR_LPTIM5LPEN RCC_APB4LPENR_LPTIM5LPEN_Msk |
| #define | RCC_APB4LPENR_COMP12LPEN_Pos (14U) |
| #define | RCC_APB4LPENR_COMP12LPEN_Msk (0x1UL << RCC_APB4LPENR_COMP12LPEN_Pos) |
| #define | RCC_APB4LPENR_COMP12LPEN RCC_APB4LPENR_COMP12LPEN_Msk |
| #define | RCC_APB4LPENR_VREFLPEN_Pos (15U) |
| #define | RCC_APB4LPENR_VREFLPEN_Msk (0x1UL << RCC_APB4LPENR_VREFLPEN_Pos) |
| #define | RCC_APB4LPENR_VREFLPEN RCC_APB4LPENR_VREFLPEN_Msk |
| #define | RCC_APB4LPENR_RTCAPBLPEN_Pos (16U) |
| #define | RCC_APB4LPENR_RTCAPBLPEN_Msk (0x1UL << RCC_APB4LPENR_RTCAPBLPEN_Pos) |
| #define | RCC_APB4LPENR_RTCAPBLPEN RCC_APB4LPENR_RTCAPBLPEN_Msk |
| #define | RCC_APB4LPENR_SAI4LPEN_Pos (21U) |
| #define | RCC_APB4LPENR_SAI4LPEN_Msk (0x1UL << RCC_APB4LPENR_SAI4LPEN_Pos) |
| #define | RCC_APB4LPENR_SAI4LPEN RCC_APB4LPENR_SAI4LPEN_Msk |
| #define | RCC_RSR_RMVF_Pos (16U) |
| #define | RCC_RSR_RMVF_Msk (0x1UL << RCC_RSR_RMVF_Pos) |
| #define | RCC_RSR_RMVF RCC_RSR_RMVF_Msk |
| #define | RCC_RSR_CPURSTF_Pos (17U) |
| #define | RCC_RSR_CPURSTF_Msk (0x1UL << RCC_RSR_CPURSTF_Pos) |
| #define | RCC_RSR_CPURSTF RCC_RSR_CPURSTF_Msk |
| #define | RCC_RSR_D1RSTF_Pos (19U) |
| #define | RCC_RSR_D1RSTF_Msk (0x1UL << RCC_RSR_D1RSTF_Pos) |
| #define | RCC_RSR_D1RSTF RCC_RSR_D1RSTF_Msk |
| #define | RCC_RSR_D2RSTF_Pos (20U) |
| #define | RCC_RSR_D2RSTF_Msk (0x1UL << RCC_RSR_D2RSTF_Pos) |
| #define | RCC_RSR_D2RSTF RCC_RSR_D2RSTF_Msk |
| #define | RCC_RSR_BORRSTF_Pos (21U) |
| #define | RCC_RSR_BORRSTF_Msk (0x1UL << RCC_RSR_BORRSTF_Pos) |
| #define | RCC_RSR_BORRSTF RCC_RSR_BORRSTF_Msk |
| #define | RCC_RSR_PINRSTF_Pos (22U) |
| #define | RCC_RSR_PINRSTF_Msk (0x1UL << RCC_RSR_PINRSTF_Pos) |
| #define | RCC_RSR_PINRSTF RCC_RSR_PINRSTF_Msk |
| #define | RCC_RSR_PORRSTF_Pos (23U) |
| #define | RCC_RSR_PORRSTF_Msk (0x1UL << RCC_RSR_PORRSTF_Pos) |
| #define | RCC_RSR_PORRSTF RCC_RSR_PORRSTF_Msk |
| #define | RCC_RSR_SFTRSTF_Pos (24U) |
| #define | RCC_RSR_SFTRSTF_Msk (0x1UL << RCC_RSR_SFTRSTF_Pos) |
| #define | RCC_RSR_SFTRSTF RCC_RSR_SFTRSTF_Msk |
| #define | RCC_RSR_IWDG1RSTF_Pos (26U) |
| #define | RCC_RSR_IWDG1RSTF_Msk (0x1UL << RCC_RSR_IWDG1RSTF_Pos) |
| #define | RCC_RSR_IWDG1RSTF RCC_RSR_IWDG1RSTF_Msk |
| #define | RCC_RSR_WWDG1RSTF_Pos (28U) |
| #define | RCC_RSR_WWDG1RSTF_Msk (0x1UL << RCC_RSR_WWDG1RSTF_Pos) |
| #define | RCC_RSR_WWDG1RSTF RCC_RSR_WWDG1RSTF_Msk |
| #define | RCC_RSR_LPWRRSTF_Pos (30U) |
| #define | RCC_RSR_LPWRRSTF_Msk (0x1UL << RCC_RSR_LPWRRSTF_Pos) |
| #define | RCC_RSR_LPWRRSTF RCC_RSR_LPWRRSTF_Msk |
| #define | RNG_CR_RNGEN_Pos (2U) |
| #define | RNG_CR_RNGEN_Msk (0x1UL << RNG_CR_RNGEN_Pos) |
| #define | RNG_CR_RNGEN RNG_CR_RNGEN_Msk |
| #define | RNG_CR_IE_Pos (3U) |
| #define | RNG_CR_IE_Msk (0x1UL << RNG_CR_IE_Pos) |
| #define | RNG_CR_IE RNG_CR_IE_Msk |
| #define | RNG_CR_CED_Pos (5U) |
| #define | RNG_CR_CED_Msk (0x1UL << RNG_CR_CED_Pos) |
| #define | RNG_CR_CED RNG_CR_CED_Msk |
| #define | RNG_SR_DRDY_Pos (0U) |
| #define | RNG_SR_DRDY_Msk (0x1UL << RNG_SR_DRDY_Pos) |
| #define | RNG_SR_DRDY RNG_SR_DRDY_Msk |
| #define | RNG_SR_CECS_Pos (1U) |
| #define | RNG_SR_CECS_Msk (0x1UL << RNG_SR_CECS_Pos) |
| #define | RNG_SR_CECS RNG_SR_CECS_Msk |
| #define | RNG_SR_SECS_Pos (2U) |
| #define | RNG_SR_SECS_Msk (0x1UL << RNG_SR_SECS_Pos) |
| #define | RNG_SR_SECS RNG_SR_SECS_Msk |
| #define | RNG_SR_CEIS_Pos (5U) |
| #define | RNG_SR_CEIS_Msk (0x1UL << RNG_SR_CEIS_Pos) |
| #define | RNG_SR_CEIS RNG_SR_CEIS_Msk |
| #define | RNG_SR_SEIS_Pos (6U) |
| #define | RNG_SR_SEIS_Msk (0x1UL << RNG_SR_SEIS_Pos) |
| #define | RNG_SR_SEIS RNG_SR_SEIS_Msk |
| #define | RTC_TR_PM_Pos (22U) |
| #define | RTC_TR_PM_Msk (0x1UL << RTC_TR_PM_Pos) |
| #define | RTC_TR_PM RTC_TR_PM_Msk |
| #define | RTC_TR_HT_Pos (20U) |
| #define | RTC_TR_HT_Msk (0x3UL << RTC_TR_HT_Pos) |
| #define | RTC_TR_HT RTC_TR_HT_Msk |
| #define | RTC_TR_HT_0 (0x1UL << RTC_TR_HT_Pos) |
| #define | RTC_TR_HT_1 (0x2UL << RTC_TR_HT_Pos) |
| #define | RTC_TR_HU_Pos (16U) |
| #define | RTC_TR_HU_Msk (0xFUL << RTC_TR_HU_Pos) |
| #define | RTC_TR_HU RTC_TR_HU_Msk |
| #define | RTC_TR_HU_0 (0x1UL << RTC_TR_HU_Pos) |
| #define | RTC_TR_HU_1 (0x2UL << RTC_TR_HU_Pos) |
| #define | RTC_TR_HU_2 (0x4UL << RTC_TR_HU_Pos) |
| #define | RTC_TR_HU_3 (0x8UL << RTC_TR_HU_Pos) |
| #define | RTC_TR_MNT_Pos (12U) |
| #define | RTC_TR_MNT_Msk (0x7UL << RTC_TR_MNT_Pos) |
| #define | RTC_TR_MNT RTC_TR_MNT_Msk |
| #define | RTC_TR_MNT_0 (0x1UL << RTC_TR_MNT_Pos) |
| #define | RTC_TR_MNT_1 (0x2UL << RTC_TR_MNT_Pos) |
| #define | RTC_TR_MNT_2 (0x4UL << RTC_TR_MNT_Pos) |
| #define | RTC_TR_MNU_Pos (8U) |
| #define | RTC_TR_MNU_Msk (0xFUL << RTC_TR_MNU_Pos) |
| #define | RTC_TR_MNU RTC_TR_MNU_Msk |
| #define | RTC_TR_MNU_0 (0x1UL << RTC_TR_MNU_Pos) |
| #define | RTC_TR_MNU_1 (0x2UL << RTC_TR_MNU_Pos) |
| #define | RTC_TR_MNU_2 (0x4UL << RTC_TR_MNU_Pos) |
| #define | RTC_TR_MNU_3 (0x8UL << RTC_TR_MNU_Pos) |
| #define | RTC_TR_ST_Pos (4U) |
| #define | RTC_TR_ST_Msk (0x7UL << RTC_TR_ST_Pos) |
| #define | RTC_TR_ST RTC_TR_ST_Msk |
| #define | RTC_TR_ST_0 (0x1UL << RTC_TR_ST_Pos) |
| #define | RTC_TR_ST_1 (0x2UL << RTC_TR_ST_Pos) |
| #define | RTC_TR_ST_2 (0x4UL << RTC_TR_ST_Pos) |
| #define | RTC_TR_SU_Pos (0U) |
| #define | RTC_TR_SU_Msk (0xFUL << RTC_TR_SU_Pos) |
| #define | RTC_TR_SU RTC_TR_SU_Msk |
| #define | RTC_TR_SU_0 (0x1UL << RTC_TR_SU_Pos) |
| #define | RTC_TR_SU_1 (0x2UL << RTC_TR_SU_Pos) |
| #define | RTC_TR_SU_2 (0x4UL << RTC_TR_SU_Pos) |
| #define | RTC_TR_SU_3 (0x8UL << RTC_TR_SU_Pos) |
| #define | RTC_DR_YT_Pos (20U) |
| #define | RTC_DR_YT_Msk (0xFUL << RTC_DR_YT_Pos) |
| #define | RTC_DR_YT RTC_DR_YT_Msk |
| #define | RTC_DR_YT_0 (0x1UL << RTC_DR_YT_Pos) |
| #define | RTC_DR_YT_1 (0x2UL << RTC_DR_YT_Pos) |
| #define | RTC_DR_YT_2 (0x4UL << RTC_DR_YT_Pos) |
| #define | RTC_DR_YT_3 (0x8UL << RTC_DR_YT_Pos) |
| #define | RTC_DR_YU_Pos (16U) |
| #define | RTC_DR_YU_Msk (0xFUL << RTC_DR_YU_Pos) |
| #define | RTC_DR_YU RTC_DR_YU_Msk |
| #define | RTC_DR_YU_0 (0x1UL << RTC_DR_YU_Pos) |
| #define | RTC_DR_YU_1 (0x2UL << RTC_DR_YU_Pos) |
| #define | RTC_DR_YU_2 (0x4UL << RTC_DR_YU_Pos) |
| #define | RTC_DR_YU_3 (0x8UL << RTC_DR_YU_Pos) |
| #define | RTC_DR_WDU_Pos (13U) |
| #define | RTC_DR_WDU_Msk (0x7UL << RTC_DR_WDU_Pos) |
| #define | RTC_DR_WDU RTC_DR_WDU_Msk |
| #define | RTC_DR_WDU_0 (0x1UL << RTC_DR_WDU_Pos) |
| #define | RTC_DR_WDU_1 (0x2UL << RTC_DR_WDU_Pos) |
| #define | RTC_DR_WDU_2 (0x4UL << RTC_DR_WDU_Pos) |
| #define | RTC_DR_MT_Pos (12U) |
| #define | RTC_DR_MT_Msk (0x1UL << RTC_DR_MT_Pos) |
| #define | RTC_DR_MT RTC_DR_MT_Msk |
| #define | RTC_DR_MU_Pos (8U) |
| #define | RTC_DR_MU_Msk (0xFUL << RTC_DR_MU_Pos) |
| #define | RTC_DR_MU RTC_DR_MU_Msk |
| #define | RTC_DR_MU_0 (0x1UL << RTC_DR_MU_Pos) |
| #define | RTC_DR_MU_1 (0x2UL << RTC_DR_MU_Pos) |
| #define | RTC_DR_MU_2 (0x4UL << RTC_DR_MU_Pos) |
| #define | RTC_DR_MU_3 (0x8UL << RTC_DR_MU_Pos) |
| #define | RTC_DR_DT_Pos (4U) |
| #define | RTC_DR_DT_Msk (0x3UL << RTC_DR_DT_Pos) |
| #define | RTC_DR_DT RTC_DR_DT_Msk |
| #define | RTC_DR_DT_0 (0x1UL << RTC_DR_DT_Pos) |
| #define | RTC_DR_DT_1 (0x2UL << RTC_DR_DT_Pos) |
| #define | RTC_DR_DU_Pos (0U) |
| #define | RTC_DR_DU_Msk (0xFUL << RTC_DR_DU_Pos) |
| #define | RTC_DR_DU RTC_DR_DU_Msk |
| #define | RTC_DR_DU_0 (0x1UL << RTC_DR_DU_Pos) |
| #define | RTC_DR_DU_1 (0x2UL << RTC_DR_DU_Pos) |
| #define | RTC_DR_DU_2 (0x4UL << RTC_DR_DU_Pos) |
| #define | RTC_DR_DU_3 (0x8UL << RTC_DR_DU_Pos) |
| #define | RTC_CR_ITSE_Pos (24U) |
| #define | RTC_CR_ITSE_Msk (0x1UL << RTC_CR_ITSE_Pos) |
| #define | RTC_CR_ITSE RTC_CR_ITSE_Msk |
| #define | RTC_CR_COE_Pos (23U) |
| #define | RTC_CR_COE_Msk (0x1UL << RTC_CR_COE_Pos) |
| #define | RTC_CR_COE RTC_CR_COE_Msk |
| #define | RTC_CR_OSEL_Pos (21U) |
| #define | RTC_CR_OSEL_Msk (0x3UL << RTC_CR_OSEL_Pos) |
| #define | RTC_CR_OSEL RTC_CR_OSEL_Msk |
| #define | RTC_CR_OSEL_0 (0x1UL << RTC_CR_OSEL_Pos) |
| #define | RTC_CR_OSEL_1 (0x2UL << RTC_CR_OSEL_Pos) |
| #define | RTC_CR_POL_Pos (20U) |
| #define | RTC_CR_POL_Msk (0x1UL << RTC_CR_POL_Pos) |
| #define | RTC_CR_POL RTC_CR_POL_Msk |
| #define | RTC_CR_COSEL_Pos (19U) |
| #define | RTC_CR_COSEL_Msk (0x1UL << RTC_CR_COSEL_Pos) |
| #define | RTC_CR_COSEL RTC_CR_COSEL_Msk |
| #define | RTC_CR_BKP_Pos (18U) |
| #define | RTC_CR_BKP_Msk (0x1UL << RTC_CR_BKP_Pos) |
| #define | RTC_CR_BKP RTC_CR_BKP_Msk |
| #define | RTC_CR_SUB1H_Pos (17U) |
| #define | RTC_CR_SUB1H_Msk (0x1UL << RTC_CR_SUB1H_Pos) |
| #define | RTC_CR_SUB1H RTC_CR_SUB1H_Msk |
| #define | RTC_CR_ADD1H_Pos (16U) |
| #define | RTC_CR_ADD1H_Msk (0x1UL << RTC_CR_ADD1H_Pos) |
| #define | RTC_CR_ADD1H RTC_CR_ADD1H_Msk |
| #define | RTC_CR_TSIE_Pos (15U) |
| #define | RTC_CR_TSIE_Msk (0x1UL << RTC_CR_TSIE_Pos) |
| #define | RTC_CR_TSIE RTC_CR_TSIE_Msk |
| #define | RTC_CR_WUTIE_Pos (14U) |
| #define | RTC_CR_WUTIE_Msk (0x1UL << RTC_CR_WUTIE_Pos) |
| #define | RTC_CR_WUTIE RTC_CR_WUTIE_Msk |
| #define | RTC_CR_ALRBIE_Pos (13U) |
| #define | RTC_CR_ALRBIE_Msk (0x1UL << RTC_CR_ALRBIE_Pos) |
| #define | RTC_CR_ALRBIE RTC_CR_ALRBIE_Msk |
| #define | RTC_CR_ALRAIE_Pos (12U) |
| #define | RTC_CR_ALRAIE_Msk (0x1UL << RTC_CR_ALRAIE_Pos) |
| #define | RTC_CR_ALRAIE RTC_CR_ALRAIE_Msk |
| #define | RTC_CR_TSE_Pos (11U) |
| #define | RTC_CR_TSE_Msk (0x1UL << RTC_CR_TSE_Pos) |
| #define | RTC_CR_TSE RTC_CR_TSE_Msk |
| #define | RTC_CR_WUTE_Pos (10U) |
| #define | RTC_CR_WUTE_Msk (0x1UL << RTC_CR_WUTE_Pos) |
| #define | RTC_CR_WUTE RTC_CR_WUTE_Msk |
| #define | RTC_CR_ALRBE_Pos (9U) |
| #define | RTC_CR_ALRBE_Msk (0x1UL << RTC_CR_ALRBE_Pos) |
| #define | RTC_CR_ALRBE RTC_CR_ALRBE_Msk |
| #define | RTC_CR_ALRAE_Pos (8U) |
| #define | RTC_CR_ALRAE_Msk (0x1UL << RTC_CR_ALRAE_Pos) |
| #define | RTC_CR_ALRAE RTC_CR_ALRAE_Msk |
| #define | RTC_CR_FMT_Pos (6U) |
| #define | RTC_CR_FMT_Msk (0x1UL << RTC_CR_FMT_Pos) |
| #define | RTC_CR_FMT RTC_CR_FMT_Msk |
| #define | RTC_CR_BYPSHAD_Pos (5U) |
| #define | RTC_CR_BYPSHAD_Msk (0x1UL << RTC_CR_BYPSHAD_Pos) |
| #define | RTC_CR_BYPSHAD RTC_CR_BYPSHAD_Msk |
| #define | RTC_CR_REFCKON_Pos (4U) |
| #define | RTC_CR_REFCKON_Msk (0x1UL << RTC_CR_REFCKON_Pos) |
| #define | RTC_CR_REFCKON RTC_CR_REFCKON_Msk |
| #define | RTC_CR_TSEDGE_Pos (3U) |
| #define | RTC_CR_TSEDGE_Msk (0x1UL << RTC_CR_TSEDGE_Pos) |
| #define | RTC_CR_TSEDGE RTC_CR_TSEDGE_Msk |
| #define | RTC_CR_WUCKSEL_Pos (0U) |
| #define | RTC_CR_WUCKSEL_Msk (0x7UL << RTC_CR_WUCKSEL_Pos) |
| #define | RTC_CR_WUCKSEL RTC_CR_WUCKSEL_Msk |
| #define | RTC_CR_WUCKSEL_0 (0x1UL << RTC_CR_WUCKSEL_Pos) |
| #define | RTC_CR_WUCKSEL_1 (0x2UL << RTC_CR_WUCKSEL_Pos) |
| #define | RTC_CR_WUCKSEL_2 (0x4UL << RTC_CR_WUCKSEL_Pos) |
| #define | RTC_ISR_ITSF_Pos (17U) |
| #define | RTC_ISR_ITSF_Msk (0x1UL << RTC_ISR_ITSF_Pos) |
| #define | RTC_ISR_ITSF RTC_ISR_ITSF_Msk |
| #define | RTC_ISR_RECALPF_Pos (16U) |
| #define | RTC_ISR_RECALPF_Msk (0x1UL << RTC_ISR_RECALPF_Pos) |
| #define | RTC_ISR_RECALPF RTC_ISR_RECALPF_Msk |
| #define | RTC_ISR_TAMP3F_Pos (15U) |
| #define | RTC_ISR_TAMP3F_Msk (0x1UL << RTC_ISR_TAMP3F_Pos) |
| #define | RTC_ISR_TAMP3F RTC_ISR_TAMP3F_Msk |
| #define | RTC_ISR_TAMP2F_Pos (14U) |
| #define | RTC_ISR_TAMP2F_Msk (0x1UL << RTC_ISR_TAMP2F_Pos) |
| #define | RTC_ISR_TAMP2F RTC_ISR_TAMP2F_Msk |
| #define | RTC_ISR_TAMP1F_Pos (13U) |
| #define | RTC_ISR_TAMP1F_Msk (0x1UL << RTC_ISR_TAMP1F_Pos) |
| #define | RTC_ISR_TAMP1F RTC_ISR_TAMP1F_Msk |
| #define | RTC_ISR_TSOVF_Pos (12U) |
| #define | RTC_ISR_TSOVF_Msk (0x1UL << RTC_ISR_TSOVF_Pos) |
| #define | RTC_ISR_TSOVF RTC_ISR_TSOVF_Msk |
| #define | RTC_ISR_TSF_Pos (11U) |
| #define | RTC_ISR_TSF_Msk (0x1UL << RTC_ISR_TSF_Pos) |
| #define | RTC_ISR_TSF RTC_ISR_TSF_Msk |
| #define | RTC_ISR_WUTF_Pos (10U) |
| #define | RTC_ISR_WUTF_Msk (0x1UL << RTC_ISR_WUTF_Pos) |
| #define | RTC_ISR_WUTF RTC_ISR_WUTF_Msk |
| #define | RTC_ISR_ALRBF_Pos (9U) |
| #define | RTC_ISR_ALRBF_Msk (0x1UL << RTC_ISR_ALRBF_Pos) |
| #define | RTC_ISR_ALRBF RTC_ISR_ALRBF_Msk |
| #define | RTC_ISR_ALRAF_Pos (8U) |
| #define | RTC_ISR_ALRAF_Msk (0x1UL << RTC_ISR_ALRAF_Pos) |
| #define | RTC_ISR_ALRAF RTC_ISR_ALRAF_Msk |
| #define | RTC_ISR_INIT_Pos (7U) |
| #define | RTC_ISR_INIT_Msk (0x1UL << RTC_ISR_INIT_Pos) |
| #define | RTC_ISR_INIT RTC_ISR_INIT_Msk |
| #define | RTC_ISR_INITF_Pos (6U) |
| #define | RTC_ISR_INITF_Msk (0x1UL << RTC_ISR_INITF_Pos) |
| #define | RTC_ISR_INITF RTC_ISR_INITF_Msk |
| #define | RTC_ISR_RSF_Pos (5U) |
| #define | RTC_ISR_RSF_Msk (0x1UL << RTC_ISR_RSF_Pos) |
| #define | RTC_ISR_RSF RTC_ISR_RSF_Msk |
| #define | RTC_ISR_INITS_Pos (4U) |
| #define | RTC_ISR_INITS_Msk (0x1UL << RTC_ISR_INITS_Pos) |
| #define | RTC_ISR_INITS RTC_ISR_INITS_Msk |
| #define | RTC_ISR_SHPF_Pos (3U) |
| #define | RTC_ISR_SHPF_Msk (0x1UL << RTC_ISR_SHPF_Pos) |
| #define | RTC_ISR_SHPF RTC_ISR_SHPF_Msk |
| #define | RTC_ISR_WUTWF_Pos (2U) |
| #define | RTC_ISR_WUTWF_Msk (0x1UL << RTC_ISR_WUTWF_Pos) |
| #define | RTC_ISR_WUTWF RTC_ISR_WUTWF_Msk |
| #define | RTC_ISR_ALRBWF_Pos (1U) |
| #define | RTC_ISR_ALRBWF_Msk (0x1UL << RTC_ISR_ALRBWF_Pos) |
| #define | RTC_ISR_ALRBWF RTC_ISR_ALRBWF_Msk |
| #define | RTC_ISR_ALRAWF_Pos (0U) |
| #define | RTC_ISR_ALRAWF_Msk (0x1UL << RTC_ISR_ALRAWF_Pos) |
| #define | RTC_ISR_ALRAWF RTC_ISR_ALRAWF_Msk |
| #define | RTC_PRER_PREDIV_A_Pos (16U) |
| #define | RTC_PRER_PREDIV_A_Msk (0x7FUL << RTC_PRER_PREDIV_A_Pos) |
| #define | RTC_PRER_PREDIV_A RTC_PRER_PREDIV_A_Msk |
| #define | RTC_PRER_PREDIV_S_Pos (0U) |
| #define | RTC_PRER_PREDIV_S_Msk (0x7FFFUL << RTC_PRER_PREDIV_S_Pos) |
| #define | RTC_PRER_PREDIV_S RTC_PRER_PREDIV_S_Msk |
| #define | RTC_WUTR_WUT_Pos (0U) |
| #define | RTC_WUTR_WUT_Msk (0xFFFFUL << RTC_WUTR_WUT_Pos) |
| #define | RTC_WUTR_WUT RTC_WUTR_WUT_Msk |
| #define | RTC_ALRMAR_MSK4_Pos (31U) |
| #define | RTC_ALRMAR_MSK4_Msk (0x1UL << RTC_ALRMAR_MSK4_Pos) |
| #define | RTC_ALRMAR_MSK4 RTC_ALRMAR_MSK4_Msk |
| #define | RTC_ALRMAR_WDSEL_Pos (30U) |
| #define | RTC_ALRMAR_WDSEL_Msk (0x1UL << RTC_ALRMAR_WDSEL_Pos) |
| #define | RTC_ALRMAR_WDSEL RTC_ALRMAR_WDSEL_Msk |
| #define | RTC_ALRMAR_DT_Pos (28U) |
| #define | RTC_ALRMAR_DT_Msk (0x3UL << RTC_ALRMAR_DT_Pos) |
| #define | RTC_ALRMAR_DT RTC_ALRMAR_DT_Msk |
| #define | RTC_ALRMAR_DT_0 (0x1UL << RTC_ALRMAR_DT_Pos) |
| #define | RTC_ALRMAR_DT_1 (0x2UL << RTC_ALRMAR_DT_Pos) |
| #define | RTC_ALRMAR_DU_Pos (24U) |
| #define | RTC_ALRMAR_DU_Msk (0xFUL << RTC_ALRMAR_DU_Pos) |
| #define | RTC_ALRMAR_DU RTC_ALRMAR_DU_Msk |
| #define | RTC_ALRMAR_DU_0 (0x1UL << RTC_ALRMAR_DU_Pos) |
| #define | RTC_ALRMAR_DU_1 (0x2UL << RTC_ALRMAR_DU_Pos) |
| #define | RTC_ALRMAR_DU_2 (0x4UL << RTC_ALRMAR_DU_Pos) |
| #define | RTC_ALRMAR_DU_3 (0x8UL << RTC_ALRMAR_DU_Pos) |
| #define | RTC_ALRMAR_MSK3_Pos (23U) |
| #define | RTC_ALRMAR_MSK3_Msk (0x1UL << RTC_ALRMAR_MSK3_Pos) |
| #define | RTC_ALRMAR_MSK3 RTC_ALRMAR_MSK3_Msk |
| #define | RTC_ALRMAR_PM_Pos (22U) |
| #define | RTC_ALRMAR_PM_Msk (0x1UL << RTC_ALRMAR_PM_Pos) |
| #define | RTC_ALRMAR_PM RTC_ALRMAR_PM_Msk |
| #define | RTC_ALRMAR_HT_Pos (20U) |
| #define | RTC_ALRMAR_HT_Msk (0x3UL << RTC_ALRMAR_HT_Pos) |
| #define | RTC_ALRMAR_HT RTC_ALRMAR_HT_Msk |
| #define | RTC_ALRMAR_HT_0 (0x1UL << RTC_ALRMAR_HT_Pos) |
| #define | RTC_ALRMAR_HT_1 (0x2UL << RTC_ALRMAR_HT_Pos) |
| #define | RTC_ALRMAR_HU_Pos (16U) |
| #define | RTC_ALRMAR_HU_Msk (0xFUL << RTC_ALRMAR_HU_Pos) |
| #define | RTC_ALRMAR_HU RTC_ALRMAR_HU_Msk |
| #define | RTC_ALRMAR_HU_0 (0x1UL << RTC_ALRMAR_HU_Pos) |
| #define | RTC_ALRMAR_HU_1 (0x2UL << RTC_ALRMAR_HU_Pos) |
| #define | RTC_ALRMAR_HU_2 (0x4UL << RTC_ALRMAR_HU_Pos) |
| #define | RTC_ALRMAR_HU_3 (0x8UL << RTC_ALRMAR_HU_Pos) |
| #define | RTC_ALRMAR_MSK2_Pos (15U) |
| #define | RTC_ALRMAR_MSK2_Msk (0x1UL << RTC_ALRMAR_MSK2_Pos) |
| #define | RTC_ALRMAR_MSK2 RTC_ALRMAR_MSK2_Msk |
| #define | RTC_ALRMAR_MNT_Pos (12U) |
| #define | RTC_ALRMAR_MNT_Msk (0x7UL << RTC_ALRMAR_MNT_Pos) |
| #define | RTC_ALRMAR_MNT RTC_ALRMAR_MNT_Msk |
| #define | RTC_ALRMAR_MNT_0 (0x1UL << RTC_ALRMAR_MNT_Pos) |
| #define | RTC_ALRMAR_MNT_1 (0x2UL << RTC_ALRMAR_MNT_Pos) |
| #define | RTC_ALRMAR_MNT_2 (0x4UL << RTC_ALRMAR_MNT_Pos) |
| #define | RTC_ALRMAR_MNU_Pos (8U) |
| #define | RTC_ALRMAR_MNU_Msk (0xFUL << RTC_ALRMAR_MNU_Pos) |
| #define | RTC_ALRMAR_MNU RTC_ALRMAR_MNU_Msk |
| #define | RTC_ALRMAR_MNU_0 (0x1UL << RTC_ALRMAR_MNU_Pos) |
| #define | RTC_ALRMAR_MNU_1 (0x2UL << RTC_ALRMAR_MNU_Pos) |
| #define | RTC_ALRMAR_MNU_2 (0x4UL << RTC_ALRMAR_MNU_Pos) |
| #define | RTC_ALRMAR_MNU_3 (0x8UL << RTC_ALRMAR_MNU_Pos) |
| #define | RTC_ALRMAR_MSK1_Pos (7U) |
| #define | RTC_ALRMAR_MSK1_Msk (0x1UL << RTC_ALRMAR_MSK1_Pos) |
| #define | RTC_ALRMAR_MSK1 RTC_ALRMAR_MSK1_Msk |
| #define | RTC_ALRMAR_ST_Pos (4U) |
| #define | RTC_ALRMAR_ST_Msk (0x7UL << RTC_ALRMAR_ST_Pos) |
| #define | RTC_ALRMAR_ST RTC_ALRMAR_ST_Msk |
| #define | RTC_ALRMAR_ST_0 (0x1UL << RTC_ALRMAR_ST_Pos) |
| #define | RTC_ALRMAR_ST_1 (0x2UL << RTC_ALRMAR_ST_Pos) |
| #define | RTC_ALRMAR_ST_2 (0x4UL << RTC_ALRMAR_ST_Pos) |
| #define | RTC_ALRMAR_SU_Pos (0U) |
| #define | RTC_ALRMAR_SU_Msk (0xFUL << RTC_ALRMAR_SU_Pos) |
| #define | RTC_ALRMAR_SU RTC_ALRMAR_SU_Msk |
| #define | RTC_ALRMAR_SU_0 (0x1UL << RTC_ALRMAR_SU_Pos) |
| #define | RTC_ALRMAR_SU_1 (0x2UL << RTC_ALRMAR_SU_Pos) |
| #define | RTC_ALRMAR_SU_2 (0x4UL << RTC_ALRMAR_SU_Pos) |
| #define | RTC_ALRMAR_SU_3 (0x8UL << RTC_ALRMAR_SU_Pos) |
| #define | RTC_ALRMBR_MSK4_Pos (31U) |
| #define | RTC_ALRMBR_MSK4_Msk (0x1UL << RTC_ALRMBR_MSK4_Pos) |
| #define | RTC_ALRMBR_MSK4 RTC_ALRMBR_MSK4_Msk |
| #define | RTC_ALRMBR_WDSEL_Pos (30U) |
| #define | RTC_ALRMBR_WDSEL_Msk (0x1UL << RTC_ALRMBR_WDSEL_Pos) |
| #define | RTC_ALRMBR_WDSEL RTC_ALRMBR_WDSEL_Msk |
| #define | RTC_ALRMBR_DT_Pos (28U) |
| #define | RTC_ALRMBR_DT_Msk (0x3UL << RTC_ALRMBR_DT_Pos) |
| #define | RTC_ALRMBR_DT RTC_ALRMBR_DT_Msk |
| #define | RTC_ALRMBR_DT_0 (0x1UL << RTC_ALRMBR_DT_Pos) |
| #define | RTC_ALRMBR_DT_1 (0x2UL << RTC_ALRMBR_DT_Pos) |
| #define | RTC_ALRMBR_DU_Pos (24U) |
| #define | RTC_ALRMBR_DU_Msk (0xFUL << RTC_ALRMBR_DU_Pos) |
| #define | RTC_ALRMBR_DU RTC_ALRMBR_DU_Msk |
| #define | RTC_ALRMBR_DU_0 (0x1UL << RTC_ALRMBR_DU_Pos) |
| #define | RTC_ALRMBR_DU_1 (0x2UL << RTC_ALRMBR_DU_Pos) |
| #define | RTC_ALRMBR_DU_2 (0x4UL << RTC_ALRMBR_DU_Pos) |
| #define | RTC_ALRMBR_DU_3 (0x8UL << RTC_ALRMBR_DU_Pos) |
| #define | RTC_ALRMBR_MSK3_Pos (23U) |
| #define | RTC_ALRMBR_MSK3_Msk (0x1UL << RTC_ALRMBR_MSK3_Pos) |
| #define | RTC_ALRMBR_MSK3 RTC_ALRMBR_MSK3_Msk |
| #define | RTC_ALRMBR_PM_Pos (22U) |
| #define | RTC_ALRMBR_PM_Msk (0x1UL << RTC_ALRMBR_PM_Pos) |
| #define | RTC_ALRMBR_PM RTC_ALRMBR_PM_Msk |
| #define | RTC_ALRMBR_HT_Pos (20U) |
| #define | RTC_ALRMBR_HT_Msk (0x3UL << RTC_ALRMBR_HT_Pos) |
| #define | RTC_ALRMBR_HT RTC_ALRMBR_HT_Msk |
| #define | RTC_ALRMBR_HT_0 (0x1UL << RTC_ALRMBR_HT_Pos) |
| #define | RTC_ALRMBR_HT_1 (0x2UL << RTC_ALRMBR_HT_Pos) |
| #define | RTC_ALRMBR_HU_Pos (16U) |
| #define | RTC_ALRMBR_HU_Msk (0xFUL << RTC_ALRMBR_HU_Pos) |
| #define | RTC_ALRMBR_HU RTC_ALRMBR_HU_Msk |
| #define | RTC_ALRMBR_HU_0 (0x1UL << RTC_ALRMBR_HU_Pos) |
| #define | RTC_ALRMBR_HU_1 (0x2UL << RTC_ALRMBR_HU_Pos) |
| #define | RTC_ALRMBR_HU_2 (0x4UL << RTC_ALRMBR_HU_Pos) |
| #define | RTC_ALRMBR_HU_3 (0x8UL << RTC_ALRMBR_HU_Pos) |
| #define | RTC_ALRMBR_MSK2_Pos (15U) |
| #define | RTC_ALRMBR_MSK2_Msk (0x1UL << RTC_ALRMBR_MSK2_Pos) |
| #define | RTC_ALRMBR_MSK2 RTC_ALRMBR_MSK2_Msk |
| #define | RTC_ALRMBR_MNT_Pos (12U) |
| #define | RTC_ALRMBR_MNT_Msk (0x7UL << RTC_ALRMBR_MNT_Pos) |
| #define | RTC_ALRMBR_MNT RTC_ALRMBR_MNT_Msk |
| #define | RTC_ALRMBR_MNT_0 (0x1UL << RTC_ALRMBR_MNT_Pos) |
| #define | RTC_ALRMBR_MNT_1 (0x2UL << RTC_ALRMBR_MNT_Pos) |
| #define | RTC_ALRMBR_MNT_2 (0x4UL << RTC_ALRMBR_MNT_Pos) |
| #define | RTC_ALRMBR_MNU_Pos (8U) |
| #define | RTC_ALRMBR_MNU_Msk (0xFUL << RTC_ALRMBR_MNU_Pos) |
| #define | RTC_ALRMBR_MNU RTC_ALRMBR_MNU_Msk |
| #define | RTC_ALRMBR_MNU_0 (0x1UL << RTC_ALRMBR_MNU_Pos) |
| #define | RTC_ALRMBR_MNU_1 (0x2UL << RTC_ALRMBR_MNU_Pos) |
| #define | RTC_ALRMBR_MNU_2 (0x4UL << RTC_ALRMBR_MNU_Pos) |
| #define | RTC_ALRMBR_MNU_3 (0x8UL << RTC_ALRMBR_MNU_Pos) |
| #define | RTC_ALRMBR_MSK1_Pos (7U) |
| #define | RTC_ALRMBR_MSK1_Msk (0x1UL << RTC_ALRMBR_MSK1_Pos) |
| #define | RTC_ALRMBR_MSK1 RTC_ALRMBR_MSK1_Msk |
| #define | RTC_ALRMBR_ST_Pos (4U) |
| #define | RTC_ALRMBR_ST_Msk (0x7UL << RTC_ALRMBR_ST_Pos) |
| #define | RTC_ALRMBR_ST RTC_ALRMBR_ST_Msk |
| #define | RTC_ALRMBR_ST_0 (0x1UL << RTC_ALRMBR_ST_Pos) |
| #define | RTC_ALRMBR_ST_1 (0x2UL << RTC_ALRMBR_ST_Pos) |
| #define | RTC_ALRMBR_ST_2 (0x4UL << RTC_ALRMBR_ST_Pos) |
| #define | RTC_ALRMBR_SU_Pos (0U) |
| #define | RTC_ALRMBR_SU_Msk (0xFUL << RTC_ALRMBR_SU_Pos) |
| #define | RTC_ALRMBR_SU RTC_ALRMBR_SU_Msk |
| #define | RTC_ALRMBR_SU_0 (0x1UL << RTC_ALRMBR_SU_Pos) |
| #define | RTC_ALRMBR_SU_1 (0x2UL << RTC_ALRMBR_SU_Pos) |
| #define | RTC_ALRMBR_SU_2 (0x4UL << RTC_ALRMBR_SU_Pos) |
| #define | RTC_ALRMBR_SU_3 (0x8UL << RTC_ALRMBR_SU_Pos) |
| #define | RTC_WPR_KEY_Pos (0U) |
| #define | RTC_WPR_KEY_Msk (0xFFUL << RTC_WPR_KEY_Pos) |
| #define | RTC_WPR_KEY RTC_WPR_KEY_Msk |
| #define | RTC_SSR_SS_Pos (0U) |
| #define | RTC_SSR_SS_Msk (0xFFFFUL << RTC_SSR_SS_Pos) |
| #define | RTC_SSR_SS RTC_SSR_SS_Msk |
| #define | RTC_SHIFTR_SUBFS_Pos (0U) |
| #define | RTC_SHIFTR_SUBFS_Msk (0x7FFFUL << RTC_SHIFTR_SUBFS_Pos) |
| #define | RTC_SHIFTR_SUBFS RTC_SHIFTR_SUBFS_Msk |
| #define | RTC_SHIFTR_ADD1S_Pos (31U) |
| #define | RTC_SHIFTR_ADD1S_Msk (0x1UL << RTC_SHIFTR_ADD1S_Pos) |
| #define | RTC_SHIFTR_ADD1S RTC_SHIFTR_ADD1S_Msk |
| #define | RTC_TSTR_PM_Pos (22U) |
| #define | RTC_TSTR_PM_Msk (0x1UL << RTC_TSTR_PM_Pos) |
| #define | RTC_TSTR_PM RTC_TSTR_PM_Msk |
| #define | RTC_TSTR_HT_Pos (20U) |
| #define | RTC_TSTR_HT_Msk (0x3UL << RTC_TSTR_HT_Pos) |
| #define | RTC_TSTR_HT RTC_TSTR_HT_Msk |
| #define | RTC_TSTR_HT_0 (0x1UL << RTC_TSTR_HT_Pos) |
| #define | RTC_TSTR_HT_1 (0x2UL << RTC_TSTR_HT_Pos) |
| #define | RTC_TSTR_HU_Pos (16U) |
| #define | RTC_TSTR_HU_Msk (0xFUL << RTC_TSTR_HU_Pos) |
| #define | RTC_TSTR_HU RTC_TSTR_HU_Msk |
| #define | RTC_TSTR_HU_0 (0x1UL << RTC_TSTR_HU_Pos) |
| #define | RTC_TSTR_HU_1 (0x2UL << RTC_TSTR_HU_Pos) |
| #define | RTC_TSTR_HU_2 (0x4UL << RTC_TSTR_HU_Pos) |
| #define | RTC_TSTR_HU_3 (0x8UL << RTC_TSTR_HU_Pos) |
| #define | RTC_TSTR_MNT_Pos (12U) |
| #define | RTC_TSTR_MNT_Msk (0x7UL << RTC_TSTR_MNT_Pos) |
| #define | RTC_TSTR_MNT RTC_TSTR_MNT_Msk |
| #define | RTC_TSTR_MNT_0 (0x1UL << RTC_TSTR_MNT_Pos) |
| #define | RTC_TSTR_MNT_1 (0x2UL << RTC_TSTR_MNT_Pos) |
| #define | RTC_TSTR_MNT_2 (0x4UL << RTC_TSTR_MNT_Pos) |
| #define | RTC_TSTR_MNU_Pos (8U) |
| #define | RTC_TSTR_MNU_Msk (0xFUL << RTC_TSTR_MNU_Pos) |
| #define | RTC_TSTR_MNU RTC_TSTR_MNU_Msk |
| #define | RTC_TSTR_MNU_0 (0x1UL << RTC_TSTR_MNU_Pos) |
| #define | RTC_TSTR_MNU_1 (0x2UL << RTC_TSTR_MNU_Pos) |
| #define | RTC_TSTR_MNU_2 (0x4UL << RTC_TSTR_MNU_Pos) |
| #define | RTC_TSTR_MNU_3 (0x8UL << RTC_TSTR_MNU_Pos) |
| #define | RTC_TSTR_ST_Pos (4U) |
| #define | RTC_TSTR_ST_Msk (0x7UL << RTC_TSTR_ST_Pos) |
| #define | RTC_TSTR_ST RTC_TSTR_ST_Msk |
| #define | RTC_TSTR_ST_0 (0x1UL << RTC_TSTR_ST_Pos) |
| #define | RTC_TSTR_ST_1 (0x2UL << RTC_TSTR_ST_Pos) |
| #define | RTC_TSTR_ST_2 (0x4UL << RTC_TSTR_ST_Pos) |
| #define | RTC_TSTR_SU_Pos (0U) |
| #define | RTC_TSTR_SU_Msk (0xFUL << RTC_TSTR_SU_Pos) |
| #define | RTC_TSTR_SU RTC_TSTR_SU_Msk |
| #define | RTC_TSTR_SU_0 (0x1UL << RTC_TSTR_SU_Pos) |
| #define | RTC_TSTR_SU_1 (0x2UL << RTC_TSTR_SU_Pos) |
| #define | RTC_TSTR_SU_2 (0x4UL << RTC_TSTR_SU_Pos) |
| #define | RTC_TSTR_SU_3 (0x8UL << RTC_TSTR_SU_Pos) |
| #define | RTC_TSDR_WDU_Pos (13U) |
| #define | RTC_TSDR_WDU_Msk (0x7UL << RTC_TSDR_WDU_Pos) |
| #define | RTC_TSDR_WDU RTC_TSDR_WDU_Msk |
| #define | RTC_TSDR_WDU_0 (0x1UL << RTC_TSDR_WDU_Pos) |
| #define | RTC_TSDR_WDU_1 (0x2UL << RTC_TSDR_WDU_Pos) |
| #define | RTC_TSDR_WDU_2 (0x4UL << RTC_TSDR_WDU_Pos) |
| #define | RTC_TSDR_MT_Pos (12U) |
| #define | RTC_TSDR_MT_Msk (0x1UL << RTC_TSDR_MT_Pos) |
| #define | RTC_TSDR_MT RTC_TSDR_MT_Msk |
| #define | RTC_TSDR_MU_Pos (8U) |
| #define | RTC_TSDR_MU_Msk (0xFUL << RTC_TSDR_MU_Pos) |
| #define | RTC_TSDR_MU RTC_TSDR_MU_Msk |
| #define | RTC_TSDR_MU_0 (0x1UL << RTC_TSDR_MU_Pos) |
| #define | RTC_TSDR_MU_1 (0x2UL << RTC_TSDR_MU_Pos) |
| #define | RTC_TSDR_MU_2 (0x4UL << RTC_TSDR_MU_Pos) |
| #define | RTC_TSDR_MU_3 (0x8UL << RTC_TSDR_MU_Pos) |
| #define | RTC_TSDR_DT_Pos (4U) |
| #define | RTC_TSDR_DT_Msk (0x3UL << RTC_TSDR_DT_Pos) |
| #define | RTC_TSDR_DT RTC_TSDR_DT_Msk |
| #define | RTC_TSDR_DT_0 (0x1UL << RTC_TSDR_DT_Pos) |
| #define | RTC_TSDR_DT_1 (0x2UL << RTC_TSDR_DT_Pos) |
| #define | RTC_TSDR_DU_Pos (0U) |
| #define | RTC_TSDR_DU_Msk (0xFUL << RTC_TSDR_DU_Pos) |
| #define | RTC_TSDR_DU RTC_TSDR_DU_Msk |
| #define | RTC_TSDR_DU_0 (0x1UL << RTC_TSDR_DU_Pos) |
| #define | RTC_TSDR_DU_1 (0x2UL << RTC_TSDR_DU_Pos) |
| #define | RTC_TSDR_DU_2 (0x4UL << RTC_TSDR_DU_Pos) |
| #define | RTC_TSDR_DU_3 (0x8UL << RTC_TSDR_DU_Pos) |
| #define | RTC_TSSSR_SS_Pos (0U) |
| #define | RTC_TSSSR_SS_Msk (0xFFFFUL << RTC_TSSSR_SS_Pos) |
| #define | RTC_TSSSR_SS RTC_TSSSR_SS_Msk |
| #define | RTC_CALR_CALP_Pos (15U) |
| #define | RTC_CALR_CALP_Msk (0x1UL << RTC_CALR_CALP_Pos) |
| #define | RTC_CALR_CALP RTC_CALR_CALP_Msk |
| #define | RTC_CALR_CALW8_Pos (14U) |
| #define | RTC_CALR_CALW8_Msk (0x1UL << RTC_CALR_CALW8_Pos) |
| #define | RTC_CALR_CALW8 RTC_CALR_CALW8_Msk |
| #define | RTC_CALR_CALW16_Pos (13U) |
| #define | RTC_CALR_CALW16_Msk (0x1UL << RTC_CALR_CALW16_Pos) |
| #define | RTC_CALR_CALW16 RTC_CALR_CALW16_Msk |
| #define | RTC_CALR_CALM_Pos (0U) |
| #define | RTC_CALR_CALM_Msk (0x1FFUL << RTC_CALR_CALM_Pos) |
| #define | RTC_CALR_CALM RTC_CALR_CALM_Msk |
| #define | RTC_CALR_CALM_0 (0x001UL << RTC_CALR_CALM_Pos) |
| #define | RTC_CALR_CALM_1 (0x002UL << RTC_CALR_CALM_Pos) |
| #define | RTC_CALR_CALM_2 (0x004UL << RTC_CALR_CALM_Pos) |
| #define | RTC_CALR_CALM_3 (0x008UL << RTC_CALR_CALM_Pos) |
| #define | RTC_CALR_CALM_4 (0x010UL << RTC_CALR_CALM_Pos) |
| #define | RTC_CALR_CALM_5 (0x020UL << RTC_CALR_CALM_Pos) |
| #define | RTC_CALR_CALM_6 (0x040UL << RTC_CALR_CALM_Pos) |
| #define | RTC_CALR_CALM_7 (0x080UL << RTC_CALR_CALM_Pos) |
| #define | RTC_CALR_CALM_8 (0x100UL << RTC_CALR_CALM_Pos) |
| #define | RTC_TAMPCR_TAMP3MF_Pos (24U) |
| #define | RTC_TAMPCR_TAMP3MF_Msk (0x1UL << RTC_TAMPCR_TAMP3MF_Pos) |
| #define | RTC_TAMPCR_TAMP3MF RTC_TAMPCR_TAMP3MF_Msk |
| #define | RTC_TAMPCR_TAMP3NOERASE_Pos (23U) |
| #define | RTC_TAMPCR_TAMP3NOERASE_Msk (0x1UL << RTC_TAMPCR_TAMP3NOERASE_Pos) |
| #define | RTC_TAMPCR_TAMP3NOERASE RTC_TAMPCR_TAMP3NOERASE_Msk |
| #define | RTC_TAMPCR_TAMP3IE_Pos (22U) |
| #define | RTC_TAMPCR_TAMP3IE_Msk (0x1UL << RTC_TAMPCR_TAMP3IE_Pos) |
| #define | RTC_TAMPCR_TAMP3IE RTC_TAMPCR_TAMP3IE_Msk |
| #define | RTC_TAMPCR_TAMP2MF_Pos (21U) |
| #define | RTC_TAMPCR_TAMP2MF_Msk (0x1UL << RTC_TAMPCR_TAMP2MF_Pos) |
| #define | RTC_TAMPCR_TAMP2MF RTC_TAMPCR_TAMP2MF_Msk |
| #define | RTC_TAMPCR_TAMP2NOERASE_Pos (20U) |
| #define | RTC_TAMPCR_TAMP2NOERASE_Msk (0x1UL << RTC_TAMPCR_TAMP2NOERASE_Pos) |
| #define | RTC_TAMPCR_TAMP2NOERASE RTC_TAMPCR_TAMP2NOERASE_Msk |
| #define | RTC_TAMPCR_TAMP2IE_Pos (19U) |
| #define | RTC_TAMPCR_TAMP2IE_Msk (0x1UL << RTC_TAMPCR_TAMP2IE_Pos) |
| #define | RTC_TAMPCR_TAMP2IE RTC_TAMPCR_TAMP2IE_Msk |
| #define | RTC_TAMPCR_TAMP1MF_Pos (18U) |
| #define | RTC_TAMPCR_TAMP1MF_Msk (0x1UL << RTC_TAMPCR_TAMP1MF_Pos) |
| #define | RTC_TAMPCR_TAMP1MF RTC_TAMPCR_TAMP1MF_Msk |
| #define | RTC_TAMPCR_TAMP1NOERASE_Pos (17U) |
| #define | RTC_TAMPCR_TAMP1NOERASE_Msk (0x1UL << RTC_TAMPCR_TAMP1NOERASE_Pos) |
| #define | RTC_TAMPCR_TAMP1NOERASE RTC_TAMPCR_TAMP1NOERASE_Msk |
| #define | RTC_TAMPCR_TAMP1IE_Pos (16U) |
| #define | RTC_TAMPCR_TAMP1IE_Msk (0x1UL << RTC_TAMPCR_TAMP1IE_Pos) |
| #define | RTC_TAMPCR_TAMP1IE RTC_TAMPCR_TAMP1IE_Msk |
| #define | RTC_TAMPCR_TAMPPUDIS_Pos (15U) |
| #define | RTC_TAMPCR_TAMPPUDIS_Msk (0x1UL << RTC_TAMPCR_TAMPPUDIS_Pos) |
| #define | RTC_TAMPCR_TAMPPUDIS RTC_TAMPCR_TAMPPUDIS_Msk |
| #define | RTC_TAMPCR_TAMPPRCH_Pos (13U) |
| #define | RTC_TAMPCR_TAMPPRCH_Msk (0x3UL << RTC_TAMPCR_TAMPPRCH_Pos) |
| #define | RTC_TAMPCR_TAMPPRCH RTC_TAMPCR_TAMPPRCH_Msk |
| #define | RTC_TAMPCR_TAMPPRCH_0 (0x1UL << RTC_TAMPCR_TAMPPRCH_Pos) |
| #define | RTC_TAMPCR_TAMPPRCH_1 (0x2UL << RTC_TAMPCR_TAMPPRCH_Pos) |
| #define | RTC_TAMPCR_TAMPFLT_Pos (11U) |
| #define | RTC_TAMPCR_TAMPFLT_Msk (0x3UL << RTC_TAMPCR_TAMPFLT_Pos) |
| #define | RTC_TAMPCR_TAMPFLT RTC_TAMPCR_TAMPFLT_Msk |
| #define | RTC_TAMPCR_TAMPFLT_0 (0x1UL << RTC_TAMPCR_TAMPFLT_Pos) |
| #define | RTC_TAMPCR_TAMPFLT_1 (0x2UL << RTC_TAMPCR_TAMPFLT_Pos) |
| #define | RTC_TAMPCR_TAMPFREQ_Pos (8U) |
| #define | RTC_TAMPCR_TAMPFREQ_Msk (0x7UL << RTC_TAMPCR_TAMPFREQ_Pos) |
| #define | RTC_TAMPCR_TAMPFREQ RTC_TAMPCR_TAMPFREQ_Msk |
| #define | RTC_TAMPCR_TAMPFREQ_0 (0x1UL << RTC_TAMPCR_TAMPFREQ_Pos) |
| #define | RTC_TAMPCR_TAMPFREQ_1 (0x2UL << RTC_TAMPCR_TAMPFREQ_Pos) |
| #define | RTC_TAMPCR_TAMPFREQ_2 (0x4UL << RTC_TAMPCR_TAMPFREQ_Pos) |
| #define | RTC_TAMPCR_TAMPTS_Pos (7U) |
| #define | RTC_TAMPCR_TAMPTS_Msk (0x1UL << RTC_TAMPCR_TAMPTS_Pos) |
| #define | RTC_TAMPCR_TAMPTS RTC_TAMPCR_TAMPTS_Msk |
| #define | RTC_TAMPCR_TAMP3TRG_Pos (6U) |
| #define | RTC_TAMPCR_TAMP3TRG_Msk (0x1UL << RTC_TAMPCR_TAMP3TRG_Pos) |
| #define | RTC_TAMPCR_TAMP3TRG RTC_TAMPCR_TAMP3TRG_Msk |
| #define | RTC_TAMPCR_TAMP3E_Pos (5U) |
| #define | RTC_TAMPCR_TAMP3E_Msk (0x1UL << RTC_TAMPCR_TAMP3E_Pos) |
| #define | RTC_TAMPCR_TAMP3E RTC_TAMPCR_TAMP3E_Msk |
| #define | RTC_TAMPCR_TAMP2TRG_Pos (4U) |
| #define | RTC_TAMPCR_TAMP2TRG_Msk (0x1UL << RTC_TAMPCR_TAMP2TRG_Pos) |
| #define | RTC_TAMPCR_TAMP2TRG RTC_TAMPCR_TAMP2TRG_Msk |
| #define | RTC_TAMPCR_TAMP2E_Pos (3U) |
| #define | RTC_TAMPCR_TAMP2E_Msk (0x1UL << RTC_TAMPCR_TAMP2E_Pos) |
| #define | RTC_TAMPCR_TAMP2E RTC_TAMPCR_TAMP2E_Msk |
| #define | RTC_TAMPCR_TAMPIE_Pos (2U) |
| #define | RTC_TAMPCR_TAMPIE_Msk (0x1UL << RTC_TAMPCR_TAMPIE_Pos) |
| #define | RTC_TAMPCR_TAMPIE RTC_TAMPCR_TAMPIE_Msk |
| #define | RTC_TAMPCR_TAMP1TRG_Pos (1U) |
| #define | RTC_TAMPCR_TAMP1TRG_Msk (0x1UL << RTC_TAMPCR_TAMP1TRG_Pos) |
| #define | RTC_TAMPCR_TAMP1TRG RTC_TAMPCR_TAMP1TRG_Msk |
| #define | RTC_TAMPCR_TAMP1E_Pos (0U) |
| #define | RTC_TAMPCR_TAMP1E_Msk (0x1UL << RTC_TAMPCR_TAMP1E_Pos) |
| #define | RTC_TAMPCR_TAMP1E RTC_TAMPCR_TAMP1E_Msk |
| #define | RTC_ALRMASSR_MASKSS_Pos (24U) |
| #define | RTC_ALRMASSR_MASKSS_Msk (0xFUL << RTC_ALRMASSR_MASKSS_Pos) |
| #define | RTC_ALRMASSR_MASKSS RTC_ALRMASSR_MASKSS_Msk |
| #define | RTC_ALRMASSR_MASKSS_0 (0x1UL << RTC_ALRMASSR_MASKSS_Pos) |
| #define | RTC_ALRMASSR_MASKSS_1 (0x2UL << RTC_ALRMASSR_MASKSS_Pos) |
| #define | RTC_ALRMASSR_MASKSS_2 (0x4UL << RTC_ALRMASSR_MASKSS_Pos) |
| #define | RTC_ALRMASSR_MASKSS_3 (0x8UL << RTC_ALRMASSR_MASKSS_Pos) |
| #define | RTC_ALRMASSR_SS_Pos (0U) |
| #define | RTC_ALRMASSR_SS_Msk (0x7FFFUL << RTC_ALRMASSR_SS_Pos) |
| #define | RTC_ALRMASSR_SS RTC_ALRMASSR_SS_Msk |
| #define | RTC_ALRMBSSR_MASKSS_Pos (24U) |
| #define | RTC_ALRMBSSR_MASKSS_Msk (0xFUL << RTC_ALRMBSSR_MASKSS_Pos) |
| #define | RTC_ALRMBSSR_MASKSS RTC_ALRMBSSR_MASKSS_Msk |
| #define | RTC_ALRMBSSR_MASKSS_0 (0x1UL << RTC_ALRMBSSR_MASKSS_Pos) |
| #define | RTC_ALRMBSSR_MASKSS_1 (0x2UL << RTC_ALRMBSSR_MASKSS_Pos) |
| #define | RTC_ALRMBSSR_MASKSS_2 (0x4UL << RTC_ALRMBSSR_MASKSS_Pos) |
| #define | RTC_ALRMBSSR_MASKSS_3 (0x8UL << RTC_ALRMBSSR_MASKSS_Pos) |
| #define | RTC_ALRMBSSR_SS_Pos (0U) |
| #define | RTC_ALRMBSSR_SS_Msk (0x7FFFUL << RTC_ALRMBSSR_SS_Pos) |
| #define | RTC_ALRMBSSR_SS RTC_ALRMBSSR_SS_Msk |
| #define | RTC_OR_OUT_RMP_Pos (1U) |
| #define | RTC_OR_OUT_RMP_Msk (0x1UL << RTC_OR_OUT_RMP_Pos) |
| #define | RTC_OR_OUT_RMP RTC_OR_OUT_RMP_Msk |
| #define | RTC_OR_ALARMOUTTYPE_Pos (0U) |
| #define | RTC_OR_ALARMOUTTYPE_Msk (0x1UL << RTC_OR_ALARMOUTTYPE_Pos) |
| #define | RTC_OR_ALARMOUTTYPE RTC_OR_ALARMOUTTYPE_Msk |
| #define | RTC_BKP0R_Pos (0U) |
| #define | RTC_BKP0R_Msk (0xFFFFFFFFUL << RTC_BKP0R_Pos) |
| #define | RTC_BKP0R RTC_BKP0R_Msk |
| #define | RTC_BKP1R_Pos (0U) |
| #define | RTC_BKP1R_Msk (0xFFFFFFFFUL << RTC_BKP1R_Pos) |
| #define | RTC_BKP1R RTC_BKP1R_Msk |
| #define | RTC_BKP2R_Pos (0U) |
| #define | RTC_BKP2R_Msk (0xFFFFFFFFUL << RTC_BKP2R_Pos) |
| #define | RTC_BKP2R RTC_BKP2R_Msk |
| #define | RTC_BKP3R_Pos (0U) |
| #define | RTC_BKP3R_Msk (0xFFFFFFFFUL << RTC_BKP3R_Pos) |
| #define | RTC_BKP3R RTC_BKP3R_Msk |
| #define | RTC_BKP4R_Pos (0U) |
| #define | RTC_BKP4R_Msk (0xFFFFFFFFUL << RTC_BKP4R_Pos) |
| #define | RTC_BKP4R RTC_BKP4R_Msk |
| #define | RTC_BKP5R_Pos (0U) |
| #define | RTC_BKP5R_Msk (0xFFFFFFFFUL << RTC_BKP5R_Pos) |
| #define | RTC_BKP5R RTC_BKP5R_Msk |
| #define | RTC_BKP6R_Pos (0U) |
| #define | RTC_BKP6R_Msk (0xFFFFFFFFUL << RTC_BKP6R_Pos) |
| #define | RTC_BKP6R RTC_BKP6R_Msk |
| #define | RTC_BKP7R_Pos (0U) |
| #define | RTC_BKP7R_Msk (0xFFFFFFFFUL << RTC_BKP7R_Pos) |
| #define | RTC_BKP7R RTC_BKP7R_Msk |
| #define | RTC_BKP8R_Pos (0U) |
| #define | RTC_BKP8R_Msk (0xFFFFFFFFUL << RTC_BKP8R_Pos) |
| #define | RTC_BKP8R RTC_BKP8R_Msk |
| #define | RTC_BKP9R_Pos (0U) |
| #define | RTC_BKP9R_Msk (0xFFFFFFFFUL << RTC_BKP9R_Pos) |
| #define | RTC_BKP9R RTC_BKP9R_Msk |
| #define | RTC_BKP10R_Pos (0U) |
| #define | RTC_BKP10R_Msk (0xFFFFFFFFUL << RTC_BKP10R_Pos) |
| #define | RTC_BKP10R RTC_BKP10R_Msk |
| #define | RTC_BKP11R_Pos (0U) |
| #define | RTC_BKP11R_Msk (0xFFFFFFFFUL << RTC_BKP11R_Pos) |
| #define | RTC_BKP11R RTC_BKP11R_Msk |
| #define | RTC_BKP12R_Pos (0U) |
| #define | RTC_BKP12R_Msk (0xFFFFFFFFUL << RTC_BKP12R_Pos) |
| #define | RTC_BKP12R RTC_BKP12R_Msk |
| #define | RTC_BKP13R_Pos (0U) |
| #define | RTC_BKP13R_Msk (0xFFFFFFFFUL << RTC_BKP13R_Pos) |
| #define | RTC_BKP13R RTC_BKP13R_Msk |
| #define | RTC_BKP14R_Pos (0U) |
| #define | RTC_BKP14R_Msk (0xFFFFFFFFUL << RTC_BKP14R_Pos) |
| #define | RTC_BKP14R RTC_BKP14R_Msk |
| #define | RTC_BKP15R_Pos (0U) |
| #define | RTC_BKP15R_Msk (0xFFFFFFFFUL << RTC_BKP15R_Pos) |
| #define | RTC_BKP15R RTC_BKP15R_Msk |
| #define | RTC_BKP16R_Pos (0U) |
| #define | RTC_BKP16R_Msk (0xFFFFFFFFUL << RTC_BKP16R_Pos) |
| #define | RTC_BKP16R RTC_BKP16R_Msk |
| #define | RTC_BKP17R_Pos (0U) |
| #define | RTC_BKP17R_Msk (0xFFFFFFFFUL << RTC_BKP17R_Pos) |
| #define | RTC_BKP17R RTC_BKP17R_Msk |
| #define | RTC_BKP18R_Pos (0U) |
| #define | RTC_BKP18R_Msk (0xFFFFFFFFUL << RTC_BKP18R_Pos) |
| #define | RTC_BKP18R RTC_BKP18R_Msk |
| #define | RTC_BKP19R_Pos (0U) |
| #define | RTC_BKP19R_Msk (0xFFFFFFFFUL << RTC_BKP19R_Pos) |
| #define | RTC_BKP19R RTC_BKP19R_Msk |
| #define | RTC_BKP20R_Pos (0U) |
| #define | RTC_BKP20R_Msk (0xFFFFFFFFUL << RTC_BKP20R_Pos) |
| #define | RTC_BKP20R RTC_BKP20R_Msk |
| #define | RTC_BKP21R_Pos (0U) |
| #define | RTC_BKP21R_Msk (0xFFFFFFFFUL << RTC_BKP21R_Pos) |
| #define | RTC_BKP21R RTC_BKP21R_Msk |
| #define | RTC_BKP22R_Pos (0U) |
| #define | RTC_BKP22R_Msk (0xFFFFFFFFUL << RTC_BKP22R_Pos) |
| #define | RTC_BKP22R RTC_BKP22R_Msk |
| #define | RTC_BKP23R_Pos (0U) |
| #define | RTC_BKP23R_Msk (0xFFFFFFFFUL << RTC_BKP23R_Pos) |
| #define | RTC_BKP23R RTC_BKP23R_Msk |
| #define | RTC_BKP24R_Pos (0U) |
| #define | RTC_BKP24R_Msk (0xFFFFFFFFUL << RTC_BKP24R_Pos) |
| #define | RTC_BKP24R RTC_BKP24R_Msk |
| #define | RTC_BKP25R_Pos (0U) |
| #define | RTC_BKP25R_Msk (0xFFFFFFFFUL << RTC_BKP25R_Pos) |
| #define | RTC_BKP25R RTC_BKP25R_Msk |
| #define | RTC_BKP26R_Pos (0U) |
| #define | RTC_BKP26R_Msk (0xFFFFFFFFUL << RTC_BKP26R_Pos) |
| #define | RTC_BKP26R RTC_BKP26R_Msk |
| #define | RTC_BKP27R_Pos (0U) |
| #define | RTC_BKP27R_Msk (0xFFFFFFFFUL << RTC_BKP27R_Pos) |
| #define | RTC_BKP27R RTC_BKP27R_Msk |
| #define | RTC_BKP28R_Pos (0U) |
| #define | RTC_BKP28R_Msk (0xFFFFFFFFUL << RTC_BKP28R_Pos) |
| #define | RTC_BKP28R RTC_BKP28R_Msk |
| #define | RTC_BKP29R_Pos (0U) |
| #define | RTC_BKP29R_Msk (0xFFFFFFFFUL << RTC_BKP29R_Pos) |
| #define | RTC_BKP29R RTC_BKP29R_Msk |
| #define | RTC_BKP30R_Pos (0U) |
| #define | RTC_BKP30R_Msk (0xFFFFFFFFUL << RTC_BKP30R_Pos) |
| #define | RTC_BKP30R RTC_BKP30R_Msk |
| #define | RTC_BKP31R_Pos (0U) |
| #define | RTC_BKP31R_Msk (0xFFFFFFFFUL << RTC_BKP31R_Pos) |
| #define | RTC_BKP31R RTC_BKP31R_Msk |
| #define | RTC_BKP_NUMBER_Pos (5U) |
| #define | RTC_BKP_NUMBER_Msk (0x1UL << RTC_BKP_NUMBER_Pos) |
| #define | RTC_BKP_NUMBER RTC_BKP_NUMBER_Msk |
| #define | SPDIFRX_CR_SPDIFEN_Pos (0U) |
| #define | SPDIFRX_CR_SPDIFEN_Msk (0x3UL << SPDIFRX_CR_SPDIFEN_Pos) |
| #define | SPDIFRX_CR_SPDIFEN SPDIFRX_CR_SPDIFEN_Msk |
| #define | SPDIFRX_CR_RXDMAEN_Pos (2U) |
| #define | SPDIFRX_CR_RXDMAEN_Msk (0x1UL << SPDIFRX_CR_RXDMAEN_Pos) |
| #define | SPDIFRX_CR_RXDMAEN SPDIFRX_CR_RXDMAEN_Msk |
| #define | SPDIFRX_CR_RXSTEO_Pos (3U) |
| #define | SPDIFRX_CR_RXSTEO_Msk (0x1UL << SPDIFRX_CR_RXSTEO_Pos) |
| #define | SPDIFRX_CR_RXSTEO SPDIFRX_CR_RXSTEO_Msk |
| #define | SPDIFRX_CR_DRFMT_Pos (4U) |
| #define | SPDIFRX_CR_DRFMT_Msk (0x3UL << SPDIFRX_CR_DRFMT_Pos) |
| #define | SPDIFRX_CR_DRFMT SPDIFRX_CR_DRFMT_Msk |
| #define | SPDIFRX_CR_PMSK_Pos (6U) |
| #define | SPDIFRX_CR_PMSK_Msk (0x1UL << SPDIFRX_CR_PMSK_Pos) |
| #define | SPDIFRX_CR_PMSK SPDIFRX_CR_PMSK_Msk |
| #define | SPDIFRX_CR_VMSK_Pos (7U) |
| #define | SPDIFRX_CR_VMSK_Msk (0x1UL << SPDIFRX_CR_VMSK_Pos) |
| #define | SPDIFRX_CR_VMSK SPDIFRX_CR_VMSK_Msk |
| #define | SPDIFRX_CR_CUMSK_Pos (8U) |
| #define | SPDIFRX_CR_CUMSK_Msk (0x1UL << SPDIFRX_CR_CUMSK_Pos) |
| #define | SPDIFRX_CR_CUMSK SPDIFRX_CR_CUMSK_Msk |
| #define | SPDIFRX_CR_PTMSK_Pos (9U) |
| #define | SPDIFRX_CR_PTMSK_Msk (0x1UL << SPDIFRX_CR_PTMSK_Pos) |
| #define | SPDIFRX_CR_PTMSK SPDIFRX_CR_PTMSK_Msk |
| #define | SPDIFRX_CR_CBDMAEN_Pos (10U) |
| #define | SPDIFRX_CR_CBDMAEN_Msk (0x1UL << SPDIFRX_CR_CBDMAEN_Pos) |
| #define | SPDIFRX_CR_CBDMAEN SPDIFRX_CR_CBDMAEN_Msk |
| #define | SPDIFRX_CR_CHSEL_Pos (11U) |
| #define | SPDIFRX_CR_CHSEL_Msk (0x1UL << SPDIFRX_CR_CHSEL_Pos) |
| #define | SPDIFRX_CR_CHSEL SPDIFRX_CR_CHSEL_Msk |
| #define | SPDIFRX_CR_NBTR_Pos (12U) |
| #define | SPDIFRX_CR_NBTR_Msk (0x3UL << SPDIFRX_CR_NBTR_Pos) |
| #define | SPDIFRX_CR_NBTR SPDIFRX_CR_NBTR_Msk |
| #define | SPDIFRX_CR_WFA_Pos (14U) |
| #define | SPDIFRX_CR_WFA_Msk (0x1UL << SPDIFRX_CR_WFA_Pos) |
| #define | SPDIFRX_CR_WFA SPDIFRX_CR_WFA_Msk |
| #define | SPDIFRX_CR_INSEL_Pos (16U) |
| #define | SPDIFRX_CR_INSEL_Msk (0x7UL << SPDIFRX_CR_INSEL_Pos) |
| #define | SPDIFRX_CR_INSEL SPDIFRX_CR_INSEL_Msk |
| #define | SPDIFRX_CR_CKSEN_Pos (20U) |
| #define | SPDIFRX_CR_CKSEN_Msk (0x1UL << SPDIFRX_CR_CKSEN_Pos) |
| #define | SPDIFRX_CR_CKSEN SPDIFRX_CR_CKSEN_Msk |
| #define | SPDIFRX_CR_CKSBKPEN_Pos (21U) |
| #define | SPDIFRX_CR_CKSBKPEN_Msk (0x1UL << SPDIFRX_CR_CKSBKPEN_Pos) |
| #define | SPDIFRX_CR_CKSBKPEN SPDIFRX_CR_CKSBKPEN_Msk |
| #define | SPDIFRX_IMR_RXNEIE_Pos (0U) |
| #define | SPDIFRX_IMR_RXNEIE_Msk (0x1UL << SPDIFRX_IMR_RXNEIE_Pos) |
| #define | SPDIFRX_IMR_RXNEIE SPDIFRX_IMR_RXNEIE_Msk |
| #define | SPDIFRX_IMR_CSRNEIE_Pos (1U) |
| #define | SPDIFRX_IMR_CSRNEIE_Msk (0x1UL << SPDIFRX_IMR_CSRNEIE_Pos) |
| #define | SPDIFRX_IMR_CSRNEIE SPDIFRX_IMR_CSRNEIE_Msk |
| #define | SPDIFRX_IMR_PERRIE_Pos (2U) |
| #define | SPDIFRX_IMR_PERRIE_Msk (0x1UL << SPDIFRX_IMR_PERRIE_Pos) |
| #define | SPDIFRX_IMR_PERRIE SPDIFRX_IMR_PERRIE_Msk |
| #define | SPDIFRX_IMR_OVRIE_Pos (3U) |
| #define | SPDIFRX_IMR_OVRIE_Msk (0x1UL << SPDIFRX_IMR_OVRIE_Pos) |
| #define | SPDIFRX_IMR_OVRIE SPDIFRX_IMR_OVRIE_Msk |
| #define | SPDIFRX_IMR_SBLKIE_Pos (4U) |
| #define | SPDIFRX_IMR_SBLKIE_Msk (0x1UL << SPDIFRX_IMR_SBLKIE_Pos) |
| #define | SPDIFRX_IMR_SBLKIE SPDIFRX_IMR_SBLKIE_Msk |
| #define | SPDIFRX_IMR_SYNCDIE_Pos (5U) |
| #define | SPDIFRX_IMR_SYNCDIE_Msk (0x1UL << SPDIFRX_IMR_SYNCDIE_Pos) |
| #define | SPDIFRX_IMR_SYNCDIE SPDIFRX_IMR_SYNCDIE_Msk |
| #define | SPDIFRX_IMR_IFEIE_Pos (6U) |
| #define | SPDIFRX_IMR_IFEIE_Msk (0x1UL << SPDIFRX_IMR_IFEIE_Pos) |
| #define | SPDIFRX_IMR_IFEIE SPDIFRX_IMR_IFEIE_Msk |
| #define | SPDIFRX_SR_RXNE_Pos (0U) |
| #define | SPDIFRX_SR_RXNE_Msk (0x1UL << SPDIFRX_SR_RXNE_Pos) |
| #define | SPDIFRX_SR_RXNE SPDIFRX_SR_RXNE_Msk |
| #define | SPDIFRX_SR_CSRNE_Pos (1U) |
| #define | SPDIFRX_SR_CSRNE_Msk (0x1UL << SPDIFRX_SR_CSRNE_Pos) |
| #define | SPDIFRX_SR_CSRNE SPDIFRX_SR_CSRNE_Msk |
| #define | SPDIFRX_SR_PERR_Pos (2U) |
| #define | SPDIFRX_SR_PERR_Msk (0x1UL << SPDIFRX_SR_PERR_Pos) |
| #define | SPDIFRX_SR_PERR SPDIFRX_SR_PERR_Msk |
| #define | SPDIFRX_SR_OVR_Pos (3U) |
| #define | SPDIFRX_SR_OVR_Msk (0x1UL << SPDIFRX_SR_OVR_Pos) |
| #define | SPDIFRX_SR_OVR SPDIFRX_SR_OVR_Msk |
| #define | SPDIFRX_SR_SBD_Pos (4U) |
| #define | SPDIFRX_SR_SBD_Msk (0x1UL << SPDIFRX_SR_SBD_Pos) |
| #define | SPDIFRX_SR_SBD SPDIFRX_SR_SBD_Msk |
| #define | SPDIFRX_SR_SYNCD_Pos (5U) |
| #define | SPDIFRX_SR_SYNCD_Msk (0x1UL << SPDIFRX_SR_SYNCD_Pos) |
| #define | SPDIFRX_SR_SYNCD SPDIFRX_SR_SYNCD_Msk |
| #define | SPDIFRX_SR_FERR_Pos (6U) |
| #define | SPDIFRX_SR_FERR_Msk (0x1UL << SPDIFRX_SR_FERR_Pos) |
| #define | SPDIFRX_SR_FERR SPDIFRX_SR_FERR_Msk |
| #define | SPDIFRX_SR_SERR_Pos (7U) |
| #define | SPDIFRX_SR_SERR_Msk (0x1UL << SPDIFRX_SR_SERR_Pos) |
| #define | SPDIFRX_SR_SERR SPDIFRX_SR_SERR_Msk |
| #define | SPDIFRX_SR_TERR_Pos (8U) |
| #define | SPDIFRX_SR_TERR_Msk (0x1UL << SPDIFRX_SR_TERR_Pos) |
| #define | SPDIFRX_SR_TERR SPDIFRX_SR_TERR_Msk |
| #define | SPDIFRX_SR_WIDTH5_Pos (16U) |
| #define | SPDIFRX_SR_WIDTH5_Msk (0x7FFFUL << SPDIFRX_SR_WIDTH5_Pos) |
| #define | SPDIFRX_SR_WIDTH5 SPDIFRX_SR_WIDTH5_Msk |
| #define | SPDIFRX_IFCR_PERRCF_Pos (2U) |
| #define | SPDIFRX_IFCR_PERRCF_Msk (0x1UL << SPDIFRX_IFCR_PERRCF_Pos) |
| #define | SPDIFRX_IFCR_PERRCF SPDIFRX_IFCR_PERRCF_Msk |
| #define | SPDIFRX_IFCR_OVRCF_Pos (3U) |
| #define | SPDIFRX_IFCR_OVRCF_Msk (0x1UL << SPDIFRX_IFCR_OVRCF_Pos) |
| #define | SPDIFRX_IFCR_OVRCF SPDIFRX_IFCR_OVRCF_Msk |
| #define | SPDIFRX_IFCR_SBDCF_Pos (4U) |
| #define | SPDIFRX_IFCR_SBDCF_Msk (0x1UL << SPDIFRX_IFCR_SBDCF_Pos) |
| #define | SPDIFRX_IFCR_SBDCF SPDIFRX_IFCR_SBDCF_Msk |
| #define | SPDIFRX_IFCR_SYNCDCF_Pos (5U) |
| #define | SPDIFRX_IFCR_SYNCDCF_Msk (0x1UL << SPDIFRX_IFCR_SYNCDCF_Pos) |
| #define | SPDIFRX_IFCR_SYNCDCF SPDIFRX_IFCR_SYNCDCF_Msk |
| #define | SPDIFRX_DR0_DR_Pos (0U) |
| #define | SPDIFRX_DR0_DR_Msk (0xFFFFFFUL << SPDIFRX_DR0_DR_Pos) |
| #define | SPDIFRX_DR0_DR SPDIFRX_DR0_DR_Msk |
| #define | SPDIFRX_DR0_PE_Pos (24U) |
| #define | SPDIFRX_DR0_PE_Msk (0x1UL << SPDIFRX_DR0_PE_Pos) |
| #define | SPDIFRX_DR0_PE SPDIFRX_DR0_PE_Msk |
| #define | SPDIFRX_DR0_V_Pos (25U) |
| #define | SPDIFRX_DR0_V_Msk (0x1UL << SPDIFRX_DR0_V_Pos) |
| #define | SPDIFRX_DR0_V SPDIFRX_DR0_V_Msk |
| #define | SPDIFRX_DR0_U_Pos (26U) |
| #define | SPDIFRX_DR0_U_Msk (0x1UL << SPDIFRX_DR0_U_Pos) |
| #define | SPDIFRX_DR0_U SPDIFRX_DR0_U_Msk |
| #define | SPDIFRX_DR0_C_Pos (27U) |
| #define | SPDIFRX_DR0_C_Msk (0x1UL << SPDIFRX_DR0_C_Pos) |
| #define | SPDIFRX_DR0_C SPDIFRX_DR0_C_Msk |
| #define | SPDIFRX_DR0_PT_Pos (28U) |
| #define | SPDIFRX_DR0_PT_Msk (0x3UL << SPDIFRX_DR0_PT_Pos) |
| #define | SPDIFRX_DR0_PT SPDIFRX_DR0_PT_Msk |
| #define | SPDIFRX_DR1_DR_Pos (8U) |
| #define | SPDIFRX_DR1_DR_Msk (0xFFFFFFUL << SPDIFRX_DR1_DR_Pos) |
| #define | SPDIFRX_DR1_DR SPDIFRX_DR1_DR_Msk |
| #define | SPDIFRX_DR1_PT_Pos (4U) |
| #define | SPDIFRX_DR1_PT_Msk (0x3UL << SPDIFRX_DR1_PT_Pos) |
| #define | SPDIFRX_DR1_PT SPDIFRX_DR1_PT_Msk |
| #define | SPDIFRX_DR1_C_Pos (3U) |
| #define | SPDIFRX_DR1_C_Msk (0x1UL << SPDIFRX_DR1_C_Pos) |
| #define | SPDIFRX_DR1_C SPDIFRX_DR1_C_Msk |
| #define | SPDIFRX_DR1_U_Pos (2U) |
| #define | SPDIFRX_DR1_U_Msk (0x1UL << SPDIFRX_DR1_U_Pos) |
| #define | SPDIFRX_DR1_U SPDIFRX_DR1_U_Msk |
| #define | SPDIFRX_DR1_V_Pos (1U) |
| #define | SPDIFRX_DR1_V_Msk (0x1UL << SPDIFRX_DR1_V_Pos) |
| #define | SPDIFRX_DR1_V SPDIFRX_DR1_V_Msk |
| #define | SPDIFRX_DR1_PE_Pos (0U) |
| #define | SPDIFRX_DR1_PE_Msk (0x1UL << SPDIFRX_DR1_PE_Pos) |
| #define | SPDIFRX_DR1_PE SPDIFRX_DR1_PE_Msk |
| #define | SPDIFRX_DR1_DRNL1_Pos (16U) |
| #define | SPDIFRX_DR1_DRNL1_Msk (0xFFFFUL << SPDIFRX_DR1_DRNL1_Pos) |
| #define | SPDIFRX_DR1_DRNL1 SPDIFRX_DR1_DRNL1_Msk |
| #define | SPDIFRX_DR1_DRNL2_Pos (0U) |
| #define | SPDIFRX_DR1_DRNL2_Msk (0xFFFFUL << SPDIFRX_DR1_DRNL2_Pos) |
| #define | SPDIFRX_DR1_DRNL2 SPDIFRX_DR1_DRNL2_Msk |
| #define | SPDIFRX_CSR_USR_Pos (0U) |
| #define | SPDIFRX_CSR_USR_Msk (0xFFFFUL << SPDIFRX_CSR_USR_Pos) |
| #define | SPDIFRX_CSR_USR SPDIFRX_CSR_USR_Msk |
| #define | SPDIFRX_CSR_CS_Pos (16U) |
| #define | SPDIFRX_CSR_CS_Msk (0xFFUL << SPDIFRX_CSR_CS_Pos) |
| #define | SPDIFRX_CSR_CS SPDIFRX_CSR_CS_Msk |
| #define | SPDIFRX_CSR_SOB_Pos (24U) |
| #define | SPDIFRX_CSR_SOB_Msk (0x1UL << SPDIFRX_CSR_SOB_Pos) |
| #define | SPDIFRX_CSR_SOB SPDIFRX_CSR_SOB_Msk |
| #define | SPDIFRX_DIR_THI_Pos (0U) |
| #define | SPDIFRX_DIR_THI_Msk (0x1FFFUL << SPDIFRX_DIR_THI_Pos) |
| #define | SPDIFRX_DIR_THI SPDIFRX_DIR_THI_Msk |
| #define | SPDIFRX_DIR_TLO_Pos (16U) |
| #define | SPDIFRX_DIR_TLO_Msk (0x1FFFUL << SPDIFRX_DIR_TLO_Pos) |
| #define | SPDIFRX_DIR_TLO SPDIFRX_DIR_TLO_Msk |
| #define | SPDIFRX_VERR_MINREV_Pos (0U) |
| #define | SPDIFRX_VERR_MINREV_Msk (0xFUL << SPDIFRX_VERR_MINREV_Pos) |
| #define | SPDIFRX_VERR_MINREV SPDIFRX_VERR_MINREV_Msk |
| #define | SPDIFRX_VERR_MAJREV_Pos (4U) |
| #define | SPDIFRX_VERR_MAJREV_Msk (0xFUL << SPDIFRX_VERR_MAJREV_Pos) |
| #define | SPDIFRX_VERR_MAJREV SPDIFRX_VERR_MAJREV_Msk |
| #define | SPDIFRX_IDR_ID_Pos (0U) |
| #define | SPDIFRX_IDR_ID_Msk (0xFFFFFFFFUL << SPDIFRX_IDR_ID_Pos) |
| #define | SPDIFRX_IDR_ID SPDIFRX_IDR_ID_Msk |
| #define | SPDIFRX_SIDR_SID_Pos (0U) |
| #define | SPDIFRX_SIDR_SID_Msk (0xFFFFFFFFUL << SPDIFRX_SIDR_SID_Pos) |
| #define | SPDIFRX_SIDR_SID SPDIFRX_SIDR_SID_Msk |
| #define | SAI_VER_V2_X |
| #define | SAI_GCR_SYNCIN_Pos (0U) |
| #define | SAI_GCR_SYNCIN_Msk (0x3UL << SAI_GCR_SYNCIN_Pos) |
| #define | SAI_GCR_SYNCIN SAI_GCR_SYNCIN_Msk |
| #define | SAI_GCR_SYNCIN_0 (0x1UL << SAI_GCR_SYNCIN_Pos) |
| #define | SAI_GCR_SYNCIN_1 (0x2UL << SAI_GCR_SYNCIN_Pos) |
| #define | SAI_GCR_SYNCOUT_Pos (4U) |
| #define | SAI_GCR_SYNCOUT_Msk (0x3UL << SAI_GCR_SYNCOUT_Pos) |
| #define | SAI_GCR_SYNCOUT SAI_GCR_SYNCOUT_Msk |
| #define | SAI_GCR_SYNCOUT_0 (0x1UL << SAI_GCR_SYNCOUT_Pos) |
| #define | SAI_GCR_SYNCOUT_1 (0x2UL << SAI_GCR_SYNCOUT_Pos) |
| #define | SAI_xCR1_MODE_Pos (0U) |
| #define | SAI_xCR1_MODE_Msk (0x3UL << SAI_xCR1_MODE_Pos) |
| #define | SAI_xCR1_MODE SAI_xCR1_MODE_Msk |
| #define | SAI_xCR1_MODE_0 (0x1UL << SAI_xCR1_MODE_Pos) |
| #define | SAI_xCR1_MODE_1 (0x2UL << SAI_xCR1_MODE_Pos) |
| #define | SAI_xCR1_PRTCFG_Pos (2U) |
| #define | SAI_xCR1_PRTCFG_Msk (0x3UL << SAI_xCR1_PRTCFG_Pos) |
| #define | SAI_xCR1_PRTCFG SAI_xCR1_PRTCFG_Msk |
| #define | SAI_xCR1_PRTCFG_0 (0x1UL << SAI_xCR1_PRTCFG_Pos) |
| #define | SAI_xCR1_PRTCFG_1 (0x2UL << SAI_xCR1_PRTCFG_Pos) |
| #define | SAI_xCR1_DS_Pos (5U) |
| #define | SAI_xCR1_DS_Msk (0x7UL << SAI_xCR1_DS_Pos) |
| #define | SAI_xCR1_DS SAI_xCR1_DS_Msk |
| #define | SAI_xCR1_DS_0 (0x1UL << SAI_xCR1_DS_Pos) |
| #define | SAI_xCR1_DS_1 (0x2UL << SAI_xCR1_DS_Pos) |
| #define | SAI_xCR1_DS_2 (0x4UL << SAI_xCR1_DS_Pos) |
| #define | SAI_xCR1_LSBFIRST_Pos (8U) |
| #define | SAI_xCR1_LSBFIRST_Msk (0x1UL << SAI_xCR1_LSBFIRST_Pos) |
| #define | SAI_xCR1_LSBFIRST SAI_xCR1_LSBFIRST_Msk |
| #define | SAI_xCR1_CKSTR_Pos (9U) |
| #define | SAI_xCR1_CKSTR_Msk (0x1UL << SAI_xCR1_CKSTR_Pos) |
| #define | SAI_xCR1_CKSTR SAI_xCR1_CKSTR_Msk |
| #define | SAI_xCR1_SYNCEN_Pos (10U) |
| #define | SAI_xCR1_SYNCEN_Msk (0x3UL << SAI_xCR1_SYNCEN_Pos) |
| #define | SAI_xCR1_SYNCEN SAI_xCR1_SYNCEN_Msk |
| #define | SAI_xCR1_SYNCEN_0 (0x1UL << SAI_xCR1_SYNCEN_Pos) |
| #define | SAI_xCR1_SYNCEN_1 (0x2UL << SAI_xCR1_SYNCEN_Pos) |
| #define | SAI_xCR1_MONO_Pos (12U) |
| #define | SAI_xCR1_MONO_Msk (0x1UL << SAI_xCR1_MONO_Pos) |
| #define | SAI_xCR1_MONO SAI_xCR1_MONO_Msk |
| #define | SAI_xCR1_OUTDRIV_Pos (13U) |
| #define | SAI_xCR1_OUTDRIV_Msk (0x1UL << SAI_xCR1_OUTDRIV_Pos) |
| #define | SAI_xCR1_OUTDRIV SAI_xCR1_OUTDRIV_Msk |
| #define | SAI_xCR1_SAIEN_Pos (16U) |
| #define | SAI_xCR1_SAIEN_Msk (0x1UL << SAI_xCR1_SAIEN_Pos) |
| #define | SAI_xCR1_SAIEN SAI_xCR1_SAIEN_Msk |
| #define | SAI_xCR1_DMAEN_Pos (17U) |
| #define | SAI_xCR1_DMAEN_Msk (0x1UL << SAI_xCR1_DMAEN_Pos) |
| #define | SAI_xCR1_DMAEN SAI_xCR1_DMAEN_Msk |
| #define | SAI_xCR1_NODIV_Pos (19U) |
| #define | SAI_xCR1_NODIV_Msk (0x1UL << SAI_xCR1_NODIV_Pos) |
| #define | SAI_xCR1_NODIV SAI_xCR1_NODIV_Msk |
| #define | SAI_xCR1_MCKDIV_Pos (20U) |
| #define | SAI_xCR1_MCKDIV_Msk (0x3FUL << SAI_xCR1_MCKDIV_Pos) |
| #define | SAI_xCR1_MCKDIV SAI_xCR1_MCKDIV_Msk |
| #define | SAI_xCR1_MCKDIV_0 (0x01UL << SAI_xCR1_MCKDIV_Pos) |
| #define | SAI_xCR1_MCKDIV_1 (0x02UL << SAI_xCR1_MCKDIV_Pos) |
| #define | SAI_xCR1_MCKDIV_2 (0x04UL << SAI_xCR1_MCKDIV_Pos) |
| #define | SAI_xCR1_MCKDIV_3 (0x08UL << SAI_xCR1_MCKDIV_Pos) |
| #define | SAI_xCR1_MCKDIV_4 (0x10UL << SAI_xCR1_MCKDIV_Pos) |
| #define | SAI_xCR1_MCKDIV_5 (0x20UL << SAI_xCR1_MCKDIV_Pos) |
| #define | SAI_xCR1_MCKEN_Pos (27U) |
| #define | SAI_xCR1_MCKEN_Msk (0x1UL << SAI_xCR1_MCKEN_Pos) |
| #define | SAI_xCR1_MCKEN SAI_xCR1_MCKEN_Msk |
| #define | SAI_xCR1_OSR_Pos (26U) |
| #define | SAI_xCR1_OSR_Msk (0x1UL << SAI_xCR1_OSR_Pos) |
| #define | SAI_xCR1_OSR SAI_xCR1_OSR_Msk |
| #define | SAI_xCR1_NOMCK SAI_xCR1_NODIV |
| #define | SAI_xCR2_FTH_Pos (0U) |
| #define | SAI_xCR2_FTH_Msk (0x7UL << SAI_xCR2_FTH_Pos) |
| #define | SAI_xCR2_FTH SAI_xCR2_FTH_Msk |
| #define | SAI_xCR2_FTH_0 (0x1UL << SAI_xCR2_FTH_Pos) |
| #define | SAI_xCR2_FTH_1 (0x2UL << SAI_xCR2_FTH_Pos) |
| #define | SAI_xCR2_FTH_2 (0x4UL << SAI_xCR2_FTH_Pos) |
| #define | SAI_xCR2_FFLUSH_Pos (3U) |
| #define | SAI_xCR2_FFLUSH_Msk (0x1UL << SAI_xCR2_FFLUSH_Pos) |
| #define | SAI_xCR2_FFLUSH SAI_xCR2_FFLUSH_Msk |
| #define | SAI_xCR2_TRIS_Pos (4U) |
| #define | SAI_xCR2_TRIS_Msk (0x1UL << SAI_xCR2_TRIS_Pos) |
| #define | SAI_xCR2_TRIS SAI_xCR2_TRIS_Msk |
| #define | SAI_xCR2_MUTE_Pos (5U) |
| #define | SAI_xCR2_MUTE_Msk (0x1UL << SAI_xCR2_MUTE_Pos) |
| #define | SAI_xCR2_MUTE SAI_xCR2_MUTE_Msk |
| #define | SAI_xCR2_MUTEVAL_Pos (6U) |
| #define | SAI_xCR2_MUTEVAL_Msk (0x1UL << SAI_xCR2_MUTEVAL_Pos) |
| #define | SAI_xCR2_MUTEVAL SAI_xCR2_MUTEVAL_Msk |
| #define | SAI_xCR2_MUTECNT_Pos (7U) |
| #define | SAI_xCR2_MUTECNT_Msk (0x3FUL << SAI_xCR2_MUTECNT_Pos) |
| #define | SAI_xCR2_MUTECNT SAI_xCR2_MUTECNT_Msk |
| #define | SAI_xCR2_MUTECNT_0 (0x01UL << SAI_xCR2_MUTECNT_Pos) |
| #define | SAI_xCR2_MUTECNT_1 (0x02UL << SAI_xCR2_MUTECNT_Pos) |
| #define | SAI_xCR2_MUTECNT_2 (0x04UL << SAI_xCR2_MUTECNT_Pos) |
| #define | SAI_xCR2_MUTECNT_3 (0x08UL << SAI_xCR2_MUTECNT_Pos) |
| #define | SAI_xCR2_MUTECNT_4 (0x10UL << SAI_xCR2_MUTECNT_Pos) |
| #define | SAI_xCR2_MUTECNT_5 (0x20UL << SAI_xCR2_MUTECNT_Pos) |
| #define | SAI_xCR2_CPL_Pos (13U) |
| #define | SAI_xCR2_CPL_Msk (0x1UL << SAI_xCR2_CPL_Pos) |
| #define | SAI_xCR2_CPL SAI_xCR2_CPL_Msk |
| #define | SAI_xCR2_COMP_Pos (14U) |
| #define | SAI_xCR2_COMP_Msk (0x3UL << SAI_xCR2_COMP_Pos) |
| #define | SAI_xCR2_COMP SAI_xCR2_COMP_Msk |
| #define | SAI_xCR2_COMP_0 (0x1UL << SAI_xCR2_COMP_Pos) |
| #define | SAI_xCR2_COMP_1 (0x2UL << SAI_xCR2_COMP_Pos) |
| #define | SAI_xFRCR_FRL_Pos (0U) |
| #define | SAI_xFRCR_FRL_Msk (0xFFUL << SAI_xFRCR_FRL_Pos) |
| #define | SAI_xFRCR_FRL SAI_xFRCR_FRL_Msk |
| #define | SAI_xFRCR_FRL_0 (0x01UL << SAI_xFRCR_FRL_Pos) |
| #define | SAI_xFRCR_FRL_1 (0x02UL << SAI_xFRCR_FRL_Pos) |
| #define | SAI_xFRCR_FRL_2 (0x04UL << SAI_xFRCR_FRL_Pos) |
| #define | SAI_xFRCR_FRL_3 (0x08UL << SAI_xFRCR_FRL_Pos) |
| #define | SAI_xFRCR_FRL_4 (0x10UL << SAI_xFRCR_FRL_Pos) |
| #define | SAI_xFRCR_FRL_5 (0x20UL << SAI_xFRCR_FRL_Pos) |
| #define | SAI_xFRCR_FRL_6 (0x40UL << SAI_xFRCR_FRL_Pos) |
| #define | SAI_xFRCR_FRL_7 (0x80UL << SAI_xFRCR_FRL_Pos) |
| #define | SAI_xFRCR_FSALL_Pos (8U) |
| #define | SAI_xFRCR_FSALL_Msk (0x7FUL << SAI_xFRCR_FSALL_Pos) |
| #define | SAI_xFRCR_FSALL SAI_xFRCR_FSALL_Msk |
| #define | SAI_xFRCR_FSALL_0 (0x01UL << SAI_xFRCR_FSALL_Pos) |
| #define | SAI_xFRCR_FSALL_1 (0x02UL << SAI_xFRCR_FSALL_Pos) |
| #define | SAI_xFRCR_FSALL_2 (0x04UL << SAI_xFRCR_FSALL_Pos) |
| #define | SAI_xFRCR_FSALL_3 (0x08UL << SAI_xFRCR_FSALL_Pos) |
| #define | SAI_xFRCR_FSALL_4 (0x10UL << SAI_xFRCR_FSALL_Pos) |
| #define | SAI_xFRCR_FSALL_5 (0x20UL << SAI_xFRCR_FSALL_Pos) |
| #define | SAI_xFRCR_FSALL_6 (0x40UL << SAI_xFRCR_FSALL_Pos) |
| #define | SAI_xFRCR_FSDEF_Pos (16U) |
| #define | SAI_xFRCR_FSDEF_Msk (0x1UL << SAI_xFRCR_FSDEF_Pos) |
| #define | SAI_xFRCR_FSDEF SAI_xFRCR_FSDEF_Msk |
| #define | SAI_xFRCR_FSPOL_Pos (17U) |
| #define | SAI_xFRCR_FSPOL_Msk (0x1UL << SAI_xFRCR_FSPOL_Pos) |
| #define | SAI_xFRCR_FSPOL SAI_xFRCR_FSPOL_Msk |
| #define | SAI_xFRCR_FSOFF_Pos (18U) |
| #define | SAI_xFRCR_FSOFF_Msk (0x1UL << SAI_xFRCR_FSOFF_Pos) |
| #define | SAI_xFRCR_FSOFF SAI_xFRCR_FSOFF_Msk |
| #define | SAI_xFRCR_FSPO SAI_xFRCR_FSPOL |
| #define | SAI_xSLOTR_FBOFF_Pos (0U) |
| #define | SAI_xSLOTR_FBOFF_Msk (0x1FUL << SAI_xSLOTR_FBOFF_Pos) |
| #define | SAI_xSLOTR_FBOFF SAI_xSLOTR_FBOFF_Msk |
| #define | SAI_xSLOTR_FBOFF_0 (0x01UL << SAI_xSLOTR_FBOFF_Pos) |
| #define | SAI_xSLOTR_FBOFF_1 (0x02UL << SAI_xSLOTR_FBOFF_Pos) |
| #define | SAI_xSLOTR_FBOFF_2 (0x04UL << SAI_xSLOTR_FBOFF_Pos) |
| #define | SAI_xSLOTR_FBOFF_3 (0x08UL << SAI_xSLOTR_FBOFF_Pos) |
| #define | SAI_xSLOTR_FBOFF_4 (0x10UL << SAI_xSLOTR_FBOFF_Pos) |
| #define | SAI_xSLOTR_SLOTSZ_Pos (6U) |
| #define | SAI_xSLOTR_SLOTSZ_Msk (0x3UL << SAI_xSLOTR_SLOTSZ_Pos) |
| #define | SAI_xSLOTR_SLOTSZ SAI_xSLOTR_SLOTSZ_Msk |
| #define | SAI_xSLOTR_SLOTSZ_0 (0x1UL << SAI_xSLOTR_SLOTSZ_Pos) |
| #define | SAI_xSLOTR_SLOTSZ_1 (0x2UL << SAI_xSLOTR_SLOTSZ_Pos) |
| #define | SAI_xSLOTR_NBSLOT_Pos (8U) |
| #define | SAI_xSLOTR_NBSLOT_Msk (0xFUL << SAI_xSLOTR_NBSLOT_Pos) |
| #define | SAI_xSLOTR_NBSLOT SAI_xSLOTR_NBSLOT_Msk |
| #define | SAI_xSLOTR_NBSLOT_0 (0x1UL << SAI_xSLOTR_NBSLOT_Pos) |
| #define | SAI_xSLOTR_NBSLOT_1 (0x2UL << SAI_xSLOTR_NBSLOT_Pos) |
| #define | SAI_xSLOTR_NBSLOT_2 (0x4UL << SAI_xSLOTR_NBSLOT_Pos) |
| #define | SAI_xSLOTR_NBSLOT_3 (0x8UL << SAI_xSLOTR_NBSLOT_Pos) |
| #define | SAI_xSLOTR_SLOTEN_Pos (16U) |
| #define | SAI_xSLOTR_SLOTEN_Msk (0xFFFFUL << SAI_xSLOTR_SLOTEN_Pos) |
| #define | SAI_xSLOTR_SLOTEN SAI_xSLOTR_SLOTEN_Msk |
| #define | SAI_xIMR_OVRUDRIE_Pos (0U) |
| #define | SAI_xIMR_OVRUDRIE_Msk (0x1UL << SAI_xIMR_OVRUDRIE_Pos) |
| #define | SAI_xIMR_OVRUDRIE SAI_xIMR_OVRUDRIE_Msk |
| #define | SAI_xIMR_MUTEDETIE_Pos (1U) |
| #define | SAI_xIMR_MUTEDETIE_Msk (0x1UL << SAI_xIMR_MUTEDETIE_Pos) |
| #define | SAI_xIMR_MUTEDETIE SAI_xIMR_MUTEDETIE_Msk |
| #define | SAI_xIMR_WCKCFGIE_Pos (2U) |
| #define | SAI_xIMR_WCKCFGIE_Msk (0x1UL << SAI_xIMR_WCKCFGIE_Pos) |
| #define | SAI_xIMR_WCKCFGIE SAI_xIMR_WCKCFGIE_Msk |
| #define | SAI_xIMR_FREQIE_Pos (3U) |
| #define | SAI_xIMR_FREQIE_Msk (0x1UL << SAI_xIMR_FREQIE_Pos) |
| #define | SAI_xIMR_FREQIE SAI_xIMR_FREQIE_Msk |
| #define | SAI_xIMR_CNRDYIE_Pos (4U) |
| #define | SAI_xIMR_CNRDYIE_Msk (0x1UL << SAI_xIMR_CNRDYIE_Pos) |
| #define | SAI_xIMR_CNRDYIE SAI_xIMR_CNRDYIE_Msk |
| #define | SAI_xIMR_AFSDETIE_Pos (5U) |
| #define | SAI_xIMR_AFSDETIE_Msk (0x1UL << SAI_xIMR_AFSDETIE_Pos) |
| #define | SAI_xIMR_AFSDETIE SAI_xIMR_AFSDETIE_Msk |
| #define | SAI_xIMR_LFSDETIE_Pos (6U) |
| #define | SAI_xIMR_LFSDETIE_Msk (0x1UL << SAI_xIMR_LFSDETIE_Pos) |
| #define | SAI_xIMR_LFSDETIE SAI_xIMR_LFSDETIE_Msk |
| #define | SAI_xSR_OVRUDR_Pos (0U) |
| #define | SAI_xSR_OVRUDR_Msk (0x1UL << SAI_xSR_OVRUDR_Pos) |
| #define | SAI_xSR_OVRUDR SAI_xSR_OVRUDR_Msk |
| #define | SAI_xSR_MUTEDET_Pos (1U) |
| #define | SAI_xSR_MUTEDET_Msk (0x1UL << SAI_xSR_MUTEDET_Pos) |
| #define | SAI_xSR_MUTEDET SAI_xSR_MUTEDET_Msk |
| #define | SAI_xSR_WCKCFG_Pos (2U) |
| #define | SAI_xSR_WCKCFG_Msk (0x1UL << SAI_xSR_WCKCFG_Pos) |
| #define | SAI_xSR_WCKCFG SAI_xSR_WCKCFG_Msk |
| #define | SAI_xSR_FREQ_Pos (3U) |
| #define | SAI_xSR_FREQ_Msk (0x1UL << SAI_xSR_FREQ_Pos) |
| #define | SAI_xSR_FREQ SAI_xSR_FREQ_Msk |
| #define | SAI_xSR_CNRDY_Pos (4U) |
| #define | SAI_xSR_CNRDY_Msk (0x1UL << SAI_xSR_CNRDY_Pos) |
| #define | SAI_xSR_CNRDY SAI_xSR_CNRDY_Msk |
| #define | SAI_xSR_AFSDET_Pos (5U) |
| #define | SAI_xSR_AFSDET_Msk (0x1UL << SAI_xSR_AFSDET_Pos) |
| #define | SAI_xSR_AFSDET SAI_xSR_AFSDET_Msk |
| #define | SAI_xSR_LFSDET_Pos (6U) |
| #define | SAI_xSR_LFSDET_Msk (0x1UL << SAI_xSR_LFSDET_Pos) |
| #define | SAI_xSR_LFSDET SAI_xSR_LFSDET_Msk |
| #define | SAI_xSR_FLVL_Pos (16U) |
| #define | SAI_xSR_FLVL_Msk (0x7UL << SAI_xSR_FLVL_Pos) |
| #define | SAI_xSR_FLVL SAI_xSR_FLVL_Msk |
| #define | SAI_xSR_FLVL_0 (0x1UL << SAI_xSR_FLVL_Pos) |
| #define | SAI_xSR_FLVL_1 (0x2UL << SAI_xSR_FLVL_Pos) |
| #define | SAI_xSR_FLVL_2 (0x4UL << SAI_xSR_FLVL_Pos) |
| #define | SAI_xCLRFR_COVRUDR_Pos (0U) |
| #define | SAI_xCLRFR_COVRUDR_Msk (0x1UL << SAI_xCLRFR_COVRUDR_Pos) |
| #define | SAI_xCLRFR_COVRUDR SAI_xCLRFR_COVRUDR_Msk |
| #define | SAI_xCLRFR_CMUTEDET_Pos (1U) |
| #define | SAI_xCLRFR_CMUTEDET_Msk (0x1UL << SAI_xCLRFR_CMUTEDET_Pos) |
| #define | SAI_xCLRFR_CMUTEDET SAI_xCLRFR_CMUTEDET_Msk |
| #define | SAI_xCLRFR_CWCKCFG_Pos (2U) |
| #define | SAI_xCLRFR_CWCKCFG_Msk (0x1UL << SAI_xCLRFR_CWCKCFG_Pos) |
| #define | SAI_xCLRFR_CWCKCFG SAI_xCLRFR_CWCKCFG_Msk |
| #define | SAI_xCLRFR_CFREQ_Pos (3U) |
| #define | SAI_xCLRFR_CFREQ_Msk (0x1UL << SAI_xCLRFR_CFREQ_Pos) |
| #define | SAI_xCLRFR_CFREQ SAI_xCLRFR_CFREQ_Msk |
| #define | SAI_xCLRFR_CCNRDY_Pos (4U) |
| #define | SAI_xCLRFR_CCNRDY_Msk (0x1UL << SAI_xCLRFR_CCNRDY_Pos) |
| #define | SAI_xCLRFR_CCNRDY SAI_xCLRFR_CCNRDY_Msk |
| #define | SAI_xCLRFR_CAFSDET_Pos (5U) |
| #define | SAI_xCLRFR_CAFSDET_Msk (0x1UL << SAI_xCLRFR_CAFSDET_Pos) |
| #define | SAI_xCLRFR_CAFSDET SAI_xCLRFR_CAFSDET_Msk |
| #define | SAI_xCLRFR_CLFSDET_Pos (6U) |
| #define | SAI_xCLRFR_CLFSDET_Msk (0x1UL << SAI_xCLRFR_CLFSDET_Pos) |
| #define | SAI_xCLRFR_CLFSDET SAI_xCLRFR_CLFSDET_Msk |
| #define | SAI_xDR_DATA_Pos (0U) |
| #define | SAI_xDR_DATA_Msk (0xFFFFFFFFUL << SAI_xDR_DATA_Pos) |
| #define | SAI_xDR_DATA SAI_xDR_DATA_Msk |
| #define | SAI_PDMCR_PDMEN_Pos (0U) |
| #define | SAI_PDMCR_PDMEN_Msk (0x1UL << SAI_PDMCR_PDMEN_Pos) |
| #define | SAI_PDMCR_PDMEN SAI_PDMCR_PDMEN_Msk |
| #define | SAI_PDMCR_MICNBR_Pos (4U) |
| #define | SAI_PDMCR_MICNBR_Msk (0x3UL << SAI_PDMCR_MICNBR_Pos) |
| #define | SAI_PDMCR_MICNBR SAI_PDMCR_MICNBR_Msk |
| #define | SAI_PDMCR_MICNBR_0 (0x1UL << SAI_PDMCR_MICNBR_Pos) |
| #define | SAI_PDMCR_MICNBR_1 (0x2UL << SAI_PDMCR_MICNBR_Pos) |
| #define | SAI_PDMCR_CKEN1_Pos (8U) |
| #define | SAI_PDMCR_CKEN1_Msk (0x1UL << SAI_PDMCR_CKEN1_Pos) |
| #define | SAI_PDMCR_CKEN1 SAI_PDMCR_CKEN1_Msk |
| #define | SAI_PDMCR_CKEN2_Pos (9U) |
| #define | SAI_PDMCR_CKEN2_Msk (0x1UL << SAI_PDMCR_CKEN2_Pos) |
| #define | SAI_PDMCR_CKEN2 SAI_PDMCR_CKEN2_Msk |
| #define | SAI_PDMCR_CKEN3_Pos (10U) |
| #define | SAI_PDMCR_CKEN3_Msk (0x1UL << SAI_PDMCR_CKEN3_Pos) |
| #define | SAI_PDMCR_CKEN3 SAI_PDMCR_CKEN3_Msk |
| #define | SAI_PDMCR_CKEN4_Pos (11U) |
| #define | SAI_PDMCR_CKEN4_Msk (0x1UL << SAI_PDMCR_CKEN4_Pos) |
| #define | SAI_PDMCR_CKEN4 SAI_PDMCR_CKEN4_Msk |
| #define | SAI_PDMDLY_DLYM1L_Pos (0U) |
| #define | SAI_PDMDLY_DLYM1L_Msk (0x7UL << SAI_PDMDLY_DLYM1L_Pos) |
| #define | SAI_PDMDLY_DLYM1L SAI_PDMDLY_DLYM1L_Msk |
| #define | SAI_PDMDLY_DLYM1L_0 (0x1UL << SAI_PDMDLY_DLYM1L_Pos) |
| #define | SAI_PDMDLY_DLYM1L_1 (0x2UL << SAI_PDMDLY_DLYM1L_Pos) |
| #define | SAI_PDMDLY_DLYM1L_2 (0x4UL << SAI_PDMDLY_DLYM1L_Pos) |
| #define | SAI_PDMDLY_DLYM1R_Pos (4U) |
| #define | SAI_PDMDLY_DLYM1R_Msk (0x7UL << SAI_PDMDLY_DLYM1R_Pos) |
| #define | SAI_PDMDLY_DLYM1R SAI_PDMDLY_DLYM1R_Msk |
| #define | SAI_PDMDLY_DLYM1R_0 (0x1UL << SAI_PDMDLY_DLYM1R_Pos) |
| #define | SAI_PDMDLY_DLYM1R_1 (0x2UL << SAI_PDMDLY_DLYM1R_Pos) |
| #define | SAI_PDMDLY_DLYM1R_2 (0x4UL << SAI_PDMDLY_DLYM1R_Pos) |
| #define | SAI_PDMDLY_DLYM2L_Pos (8U) |
| #define | SAI_PDMDLY_DLYM2L_Msk (0x7UL << SAI_PDMDLY_DLYM2L_Pos) |
| #define | SAI_PDMDLY_DLYM2L SAI_PDMDLY_DLYM2L_Msk |
| #define | SAI_PDMDLY_DLYM2L_0 (0x1UL << SAI_PDMDLY_DLYM2L_Pos) |
| #define | SAI_PDMDLY_DLYM2L_1 (0x2UL << SAI_PDMDLY_DLYM2L_Pos) |
| #define | SAI_PDMDLY_DLYM2L_2 (0x4UL << SAI_PDMDLY_DLYM2L_Pos) |
| #define | SAI_PDMDLY_DLYM2R_Pos (12U) |
| #define | SAI_PDMDLY_DLYM2R_Msk (0x7UL << SAI_PDMDLY_DLYM2R_Pos) |
| #define | SAI_PDMDLY_DLYM2R SAI_PDMDLY_DLYM2R_Msk |
| #define | SAI_PDMDLY_DLYM2R_0 (0x1UL << SAI_PDMDLY_DLYM2R_Pos) |
| #define | SAI_PDMDLY_DLYM2R_1 (0x2UL << SAI_PDMDLY_DLYM2R_Pos) |
| #define | SAI_PDMDLY_DLYM2R_2 (0x4UL << SAI_PDMDLY_DLYM2R_Pos) |
| #define | SAI_PDMDLY_DLYM3L_Pos (16U) |
| #define | SAI_PDMDLY_DLYM3L_Msk (0x7UL << SAI_PDMDLY_DLYM3L_Pos) |
| #define | SAI_PDMDLY_DLYM3L SAI_PDMDLY_DLYM3L_Msk |
| #define | SAI_PDMDLY_DLYM3L_0 (0x1UL << SAI_PDMDLY_DLYM3L_Pos) |
| #define | SAI_PDMDLY_DLYM3L_1 (0x2UL << SAI_PDMDLY_DLYM3L_Pos) |
| #define | SAI_PDMDLY_DLYM3L_2 (0x4UL << SAI_PDMDLY_DLYM3L_Pos) |
| #define | SAI_PDMDLY_DLYM3R_Pos (20U) |
| #define | SAI_PDMDLY_DLYM3R_Msk (0x7UL << SAI_PDMDLY_DLYM3R_Pos) |
| #define | SAI_PDMDLY_DLYM3R SAI_PDMDLY_DLYM3R_Msk |
| #define | SAI_PDMDLY_DLYM3R_0 (0x1UL << SAI_PDMDLY_DLYM3R_Pos) |
| #define | SAI_PDMDLY_DLYM3R_1 (0x2UL << SAI_PDMDLY_DLYM3R_Pos) |
| #define | SAI_PDMDLY_DLYM3R_2 (0x4UL << SAI_PDMDLY_DLYM3R_Pos) |
| #define | SAI_PDMDLY_DLYM4L_Pos (24U) |
| #define | SAI_PDMDLY_DLYM4L_Msk (0x7UL << SAI_PDMDLY_DLYM4L_Pos) |
| #define | SAI_PDMDLY_DLYM4L SAI_PDMDLY_DLYM4L_Msk |
| #define | SAI_PDMDLY_DLYM4L_0 (0x1UL << SAI_PDMDLY_DLYM4L_Pos) |
| #define | SAI_PDMDLY_DLYM4L_1 (0x2UL << SAI_PDMDLY_DLYM4L_Pos) |
| #define | SAI_PDMDLY_DLYM4L_2 (0x4UL << SAI_PDMDLY_DLYM4L_Pos) |
| #define | SAI_PDMDLY_DLYM4R_Pos (28U) |
| #define | SAI_PDMDLY_DLYM4R_Msk (0x7UL << SAI_PDMDLY_DLYM4R_Pos) |
| #define | SAI_PDMDLY_DLYM4R SAI_PDMDLY_DLYM4R_Msk |
| #define | SAI_PDMDLY_DLYM4R_0 (0x1UL << SAI_PDMDLY_DLYM4R_Pos) |
| #define | SAI_PDMDLY_DLYM4R_1 (0x2UL << SAI_PDMDLY_DLYM4R_Pos) |
| #define | SAI_PDMDLY_DLYM4R_2 (0x4UL << SAI_PDMDLY_DLYM4R_Pos) |
| #define | SDMMC_POWER_PWRCTRL_Pos (0U) |
| #define | SDMMC_POWER_PWRCTRL_Msk (0x3UL << SDMMC_POWER_PWRCTRL_Pos) |
| #define | SDMMC_POWER_PWRCTRL SDMMC_POWER_PWRCTRL_Msk |
| #define | SDMMC_POWER_PWRCTRL_0 (0x1UL << SDMMC_POWER_PWRCTRL_Pos) |
| #define | SDMMC_POWER_PWRCTRL_1 (0x2UL << SDMMC_POWER_PWRCTRL_Pos) |
| #define | SDMMC_POWER_VSWITCH_Pos (2U) |
| #define | SDMMC_POWER_VSWITCH_Msk (0x1UL << SDMMC_POWER_VSWITCH_Pos) |
| #define | SDMMC_POWER_VSWITCH SDMMC_POWER_VSWITCH_Msk |
| #define | SDMMC_POWER_VSWITCHEN_Pos (3U) |
| #define | SDMMC_POWER_VSWITCHEN_Msk (0x1UL << SDMMC_POWER_VSWITCHEN_Pos) |
| #define | SDMMC_POWER_VSWITCHEN SDMMC_POWER_VSWITCHEN_Msk |
| #define | SDMMC_POWER_DIRPOL_Pos (4U) |
| #define | SDMMC_POWER_DIRPOL_Msk (0x1UL << SDMMC_POWER_DIRPOL_Pos) |
| #define | SDMMC_POWER_DIRPOL SDMMC_POWER_DIRPOL_Msk |
| #define | SDMMC_CLKCR_CLKDIV_Pos (0U) |
| #define | SDMMC_CLKCR_CLKDIV_Msk (0x3FFUL << SDMMC_CLKCR_CLKDIV_Pos) |
| #define | SDMMC_CLKCR_CLKDIV SDMMC_CLKCR_CLKDIV_Msk |
| #define | SDMMC_CLKCR_PWRSAV_Pos (12U) |
| #define | SDMMC_CLKCR_PWRSAV_Msk (0x1UL << SDMMC_CLKCR_PWRSAV_Pos) |
| #define | SDMMC_CLKCR_PWRSAV SDMMC_CLKCR_PWRSAV_Msk |
| #define | SDMMC_CLKCR_WIDBUS_Pos (14U) |
| #define | SDMMC_CLKCR_WIDBUS_Msk (0x3UL << SDMMC_CLKCR_WIDBUS_Pos) |
| #define | SDMMC_CLKCR_WIDBUS SDMMC_CLKCR_WIDBUS_Msk |
| #define | SDMMC_CLKCR_WIDBUS_0 (0x1UL << SDMMC_CLKCR_WIDBUS_Pos) |
| #define | SDMMC_CLKCR_WIDBUS_1 (0x2UL << SDMMC_CLKCR_WIDBUS_Pos) |
| #define | SDMMC_CLKCR_NEGEDGE_Pos (16U) |
| #define | SDMMC_CLKCR_NEGEDGE_Msk (0x1UL << SDMMC_CLKCR_NEGEDGE_Pos) |
| #define | SDMMC_CLKCR_NEGEDGE SDMMC_CLKCR_NEGEDGE_Msk |
| #define | SDMMC_CLKCR_HWFC_EN_Pos (17U) |
| #define | SDMMC_CLKCR_HWFC_EN_Msk (0x1UL << SDMMC_CLKCR_HWFC_EN_Pos) |
| #define | SDMMC_CLKCR_HWFC_EN SDMMC_CLKCR_HWFC_EN_Msk |
| #define | SDMMC_CLKCR_DDR_Pos (18U) |
| #define | SDMMC_CLKCR_DDR_Msk (0x1UL << SDMMC_CLKCR_DDR_Pos) |
| #define | SDMMC_CLKCR_DDR SDMMC_CLKCR_DDR_Msk |
| #define | SDMMC_CLKCR_BUSSPEED_Pos (19U) |
| #define | SDMMC_CLKCR_BUSSPEED_Msk (0x1UL << SDMMC_CLKCR_BUSSPEED_Pos) |
| #define | SDMMC_CLKCR_BUSSPEED SDMMC_CLKCR_BUSSPEED_Msk |
| #define | SDMMC_CLKCR_SELCLKRX_Pos (20U) |
| #define | SDMMC_CLKCR_SELCLKRX_Msk (0x3UL << SDMMC_CLKCR_SELCLKRX_Pos) |
| #define | SDMMC_CLKCR_SELCLKRX SDMMC_CLKCR_SELCLKRX_Msk |
| #define | SDMMC_CLKCR_SELCLKRX_0 (0x1UL << SDMMC_CLKCR_SELCLKRX_Pos) |
| #define | SDMMC_CLKCR_SELCLKRX_1 (0x2UL << SDMMC_CLKCR_SELCLKRX_Pos) |
| #define | SDMMC_ARG_CMDARG_Pos (0U) |
| #define | SDMMC_ARG_CMDARG_Msk (0xFFFFFFFFUL << SDMMC_ARG_CMDARG_Pos) |
| #define | SDMMC_ARG_CMDARG SDMMC_ARG_CMDARG_Msk |
| #define | SDMMC_CMD_CMDINDEX_Pos (0U) |
| #define | SDMMC_CMD_CMDINDEX_Msk (0x3FUL << SDMMC_CMD_CMDINDEX_Pos) |
| #define | SDMMC_CMD_CMDINDEX SDMMC_CMD_CMDINDEX_Msk |
| #define | SDMMC_CMD_CMDTRANS_Pos (6U) |
| #define | SDMMC_CMD_CMDTRANS_Msk (0x1UL << SDMMC_CMD_CMDTRANS_Pos) |
| #define | SDMMC_CMD_CMDTRANS SDMMC_CMD_CMDTRANS_Msk |
| #define | SDMMC_CMD_CMDSTOP_Pos (7U) |
| #define | SDMMC_CMD_CMDSTOP_Msk (0x1UL << SDMMC_CMD_CMDSTOP_Pos) |
| #define | SDMMC_CMD_CMDSTOP SDMMC_CMD_CMDSTOP_Msk |
| #define | SDMMC_CMD_WAITRESP_Pos (8U) |
| #define | SDMMC_CMD_WAITRESP_Msk (0x3UL << SDMMC_CMD_WAITRESP_Pos) |
| #define | SDMMC_CMD_WAITRESP SDMMC_CMD_WAITRESP_Msk |
| #define | SDMMC_CMD_WAITRESP_0 (0x1UL << SDMMC_CMD_WAITRESP_Pos) |
| #define | SDMMC_CMD_WAITRESP_1 (0x2UL << SDMMC_CMD_WAITRESP_Pos) |
| #define | SDMMC_CMD_WAITINT_Pos (10U) |
| #define | SDMMC_CMD_WAITINT_Msk (0x1UL << SDMMC_CMD_WAITINT_Pos) |
| #define | SDMMC_CMD_WAITINT SDMMC_CMD_WAITINT_Msk |
| #define | SDMMC_CMD_WAITPEND_Pos (11U) |
| #define | SDMMC_CMD_WAITPEND_Msk (0x1UL << SDMMC_CMD_WAITPEND_Pos) |
| #define | SDMMC_CMD_WAITPEND SDMMC_CMD_WAITPEND_Msk |
| #define | SDMMC_CMD_CPSMEN_Pos (12U) |
| #define | SDMMC_CMD_CPSMEN_Msk (0x1UL << SDMMC_CMD_CPSMEN_Pos) |
| #define | SDMMC_CMD_CPSMEN SDMMC_CMD_CPSMEN_Msk |
| #define | SDMMC_CMD_DTHOLD_Pos (13U) |
| #define | SDMMC_CMD_DTHOLD_Msk (0x1UL << SDMMC_CMD_DTHOLD_Pos) |
| #define | SDMMC_CMD_DTHOLD SDMMC_CMD_DTHOLD_Msk |
| #define | SDMMC_CMD_BOOTMODE_Pos (14U) |
| #define | SDMMC_CMD_BOOTMODE_Msk (0x1UL << SDMMC_CMD_BOOTMODE_Pos) |
| #define | SDMMC_CMD_BOOTMODE SDMMC_CMD_BOOTMODE_Msk |
| #define | SDMMC_CMD_BOOTEN_Pos (15U) |
| #define | SDMMC_CMD_BOOTEN_Msk (0x1UL << SDMMC_CMD_BOOTEN_Pos) |
| #define | SDMMC_CMD_BOOTEN SDMMC_CMD_BOOTEN_Msk |
| #define | SDMMC_CMD_CMDSUSPEND_Pos (16U) |
| #define | SDMMC_CMD_CMDSUSPEND_Msk (0x1UL << SDMMC_CMD_CMDSUSPEND_Pos) |
| #define | SDMMC_CMD_CMDSUSPEND SDMMC_CMD_CMDSUSPEND_Msk |
| #define | SDMMC_RESPCMD_RESPCMD_Pos (0U) |
| #define | SDMMC_RESPCMD_RESPCMD_Msk (0x3FUL << SDMMC_RESPCMD_RESPCMD_Pos) |
| #define | SDMMC_RESPCMD_RESPCMD SDMMC_RESPCMD_RESPCMD_Msk |
| #define | SDMMC_RESP0_CARDSTATUS0_Pos (0U) |
| #define | SDMMC_RESP0_CARDSTATUS0_Msk (0xFFFFFFFFUL << SDMMC_RESP0_CARDSTATUS0_Pos) |
| #define | SDMMC_RESP0_CARDSTATUS0 SDMMC_RESP0_CARDSTATUS0_Msk |
| #define | SDMMC_RESP1_CARDSTATUS1_Pos (0U) |
| #define | SDMMC_RESP1_CARDSTATUS1_Msk (0xFFFFFFFFUL << SDMMC_RESP1_CARDSTATUS1_Pos) |
| #define | SDMMC_RESP1_CARDSTATUS1 SDMMC_RESP1_CARDSTATUS1_Msk |
| #define | SDMMC_RESP2_CARDSTATUS2_Pos (0U) |
| #define | SDMMC_RESP2_CARDSTATUS2_Msk (0xFFFFFFFFUL << SDMMC_RESP2_CARDSTATUS2_Pos) |
| #define | SDMMC_RESP2_CARDSTATUS2 SDMMC_RESP2_CARDSTATUS2_Msk |
| #define | SDMMC_RESP3_CARDSTATUS3_Pos (0U) |
| #define | SDMMC_RESP3_CARDSTATUS3_Msk (0xFFFFFFFFUL << SDMMC_RESP3_CARDSTATUS3_Pos) |
| #define | SDMMC_RESP3_CARDSTATUS3 SDMMC_RESP3_CARDSTATUS3_Msk |
| #define | SDMMC_RESP4_CARDSTATUS4_Pos (0U) |
| #define | SDMMC_RESP4_CARDSTATUS4_Msk (0xFFFFFFFFUL << SDMMC_RESP4_CARDSTATUS4_Pos) |
| #define | SDMMC_RESP4_CARDSTATUS4 SDMMC_RESP4_CARDSTATUS4_Msk |
| #define | SDMMC_DTIMER_DATATIME_Pos (0U) |
| #define | SDMMC_DTIMER_DATATIME_Msk (0xFFFFFFFFUL << SDMMC_DTIMER_DATATIME_Pos) |
| #define | SDMMC_DTIMER_DATATIME SDMMC_DTIMER_DATATIME_Msk |
| #define | SDMMC_DLEN_DATALENGTH_Pos (0U) |
| #define | SDMMC_DLEN_DATALENGTH_Msk (0x1FFFFFFUL << SDMMC_DLEN_DATALENGTH_Pos) |
| #define | SDMMC_DLEN_DATALENGTH SDMMC_DLEN_DATALENGTH_Msk |
| #define | SDMMC_DCTRL_DTEN_Pos (0U) |
| #define | SDMMC_DCTRL_DTEN_Msk (0x1UL << SDMMC_DCTRL_DTEN_Pos) |
| #define | SDMMC_DCTRL_DTEN SDMMC_DCTRL_DTEN_Msk |
| #define | SDMMC_DCTRL_DTDIR_Pos (1U) |
| #define | SDMMC_DCTRL_DTDIR_Msk (0x1UL << SDMMC_DCTRL_DTDIR_Pos) |
| #define | SDMMC_DCTRL_DTDIR SDMMC_DCTRL_DTDIR_Msk |
| #define | SDMMC_DCTRL_DTMODE_Pos (2U) |
| #define | SDMMC_DCTRL_DTMODE_Msk (0x3UL << SDMMC_DCTRL_DTMODE_Pos) |
| #define | SDMMC_DCTRL_DTMODE SDMMC_DCTRL_DTMODE_Msk |
| #define | SDMMC_DCTRL_DTMODE_0 (0x1UL << SDMMC_DCTRL_DTMODE_Pos) |
| #define | SDMMC_DCTRL_DTMODE_1 (0x2UL << SDMMC_DCTRL_DTMODE_Pos) |
| #define | SDMMC_DCTRL_DBLOCKSIZE_Pos (4U) |
| #define | SDMMC_DCTRL_DBLOCKSIZE_Msk (0xFUL << SDMMC_DCTRL_DBLOCKSIZE_Pos) |
| #define | SDMMC_DCTRL_DBLOCKSIZE SDMMC_DCTRL_DBLOCKSIZE_Msk |
| #define | SDMMC_DCTRL_DBLOCKSIZE_0 (0x1UL << SDMMC_DCTRL_DBLOCKSIZE_Pos) |
| #define | SDMMC_DCTRL_DBLOCKSIZE_1 (0x2UL << SDMMC_DCTRL_DBLOCKSIZE_Pos) |
| #define | SDMMC_DCTRL_DBLOCKSIZE_2 (0x4UL << SDMMC_DCTRL_DBLOCKSIZE_Pos) |
| #define | SDMMC_DCTRL_DBLOCKSIZE_3 (0x8UL << SDMMC_DCTRL_DBLOCKSIZE_Pos) |
| #define | SDMMC_DCTRL_RWSTART_Pos (8U) |
| #define | SDMMC_DCTRL_RWSTART_Msk (0x1UL << SDMMC_DCTRL_RWSTART_Pos) |
| #define | SDMMC_DCTRL_RWSTART SDMMC_DCTRL_RWSTART_Msk |
| #define | SDMMC_DCTRL_RWSTOP_Pos (9U) |
| #define | SDMMC_DCTRL_RWSTOP_Msk (0x1UL << SDMMC_DCTRL_RWSTOP_Pos) |
| #define | SDMMC_DCTRL_RWSTOP SDMMC_DCTRL_RWSTOP_Msk |
| #define | SDMMC_DCTRL_RWMOD_Pos (10U) |
| #define | SDMMC_DCTRL_RWMOD_Msk (0x1UL << SDMMC_DCTRL_RWMOD_Pos) |
| #define | SDMMC_DCTRL_RWMOD SDMMC_DCTRL_RWMOD_Msk |
| #define | SDMMC_DCTRL_SDIOEN_Pos (11U) |
| #define | SDMMC_DCTRL_SDIOEN_Msk (0x1UL << SDMMC_DCTRL_SDIOEN_Pos) |
| #define | SDMMC_DCTRL_SDIOEN SDMMC_DCTRL_SDIOEN_Msk |
| #define | SDMMC_DCTRL_BOOTACKEN_Pos (12U) |
| #define | SDMMC_DCTRL_BOOTACKEN_Msk (0x1UL << SDMMC_DCTRL_BOOTACKEN_Pos) |
| #define | SDMMC_DCTRL_BOOTACKEN SDMMC_DCTRL_BOOTACKEN_Msk |
| #define | SDMMC_DCTRL_FIFORST_Pos (13U) |
| #define | SDMMC_DCTRL_FIFORST_Msk (0x1UL << SDMMC_DCTRL_FIFORST_Pos) |
| #define | SDMMC_DCTRL_FIFORST SDMMC_DCTRL_FIFORST_Msk |
| #define | SDMMC_DCOUNT_DATACOUNT_Pos (0U) |
| #define | SDMMC_DCOUNT_DATACOUNT_Msk (0x1FFFFFFUL << SDMMC_DCOUNT_DATACOUNT_Pos) |
| #define | SDMMC_DCOUNT_DATACOUNT SDMMC_DCOUNT_DATACOUNT_Msk |
| #define | SDMMC_STA_CCRCFAIL_Pos (0U) |
| #define | SDMMC_STA_CCRCFAIL_Msk (0x1UL << SDMMC_STA_CCRCFAIL_Pos) |
| #define | SDMMC_STA_CCRCFAIL SDMMC_STA_CCRCFAIL_Msk |
| #define | SDMMC_STA_DCRCFAIL_Pos (1U) |
| #define | SDMMC_STA_DCRCFAIL_Msk (0x1UL << SDMMC_STA_DCRCFAIL_Pos) |
| #define | SDMMC_STA_DCRCFAIL SDMMC_STA_DCRCFAIL_Msk |
| #define | SDMMC_STA_CTIMEOUT_Pos (2U) |
| #define | SDMMC_STA_CTIMEOUT_Msk (0x1UL << SDMMC_STA_CTIMEOUT_Pos) |
| #define | SDMMC_STA_CTIMEOUT SDMMC_STA_CTIMEOUT_Msk |
| #define | SDMMC_STA_DTIMEOUT_Pos (3U) |
| #define | SDMMC_STA_DTIMEOUT_Msk (0x1UL << SDMMC_STA_DTIMEOUT_Pos) |
| #define | SDMMC_STA_DTIMEOUT SDMMC_STA_DTIMEOUT_Msk |
| #define | SDMMC_STA_TXUNDERR_Pos (4U) |
| #define | SDMMC_STA_TXUNDERR_Msk (0x1UL << SDMMC_STA_TXUNDERR_Pos) |
| #define | SDMMC_STA_TXUNDERR SDMMC_STA_TXUNDERR_Msk |
| #define | SDMMC_STA_RXOVERR_Pos (5U) |
| #define | SDMMC_STA_RXOVERR_Msk (0x1UL << SDMMC_STA_RXOVERR_Pos) |
| #define | SDMMC_STA_RXOVERR SDMMC_STA_RXOVERR_Msk |
| #define | SDMMC_STA_CMDREND_Pos (6U) |
| #define | SDMMC_STA_CMDREND_Msk (0x1UL << SDMMC_STA_CMDREND_Pos) |
| #define | SDMMC_STA_CMDREND SDMMC_STA_CMDREND_Msk |
| #define | SDMMC_STA_CMDSENT_Pos (7U) |
| #define | SDMMC_STA_CMDSENT_Msk (0x1UL << SDMMC_STA_CMDSENT_Pos) |
| #define | SDMMC_STA_CMDSENT SDMMC_STA_CMDSENT_Msk |
| #define | SDMMC_STA_DATAEND_Pos (8U) |
| #define | SDMMC_STA_DATAEND_Msk (0x1UL << SDMMC_STA_DATAEND_Pos) |
| #define | SDMMC_STA_DATAEND SDMMC_STA_DATAEND_Msk |
| #define | SDMMC_STA_DHOLD_Pos (9U) |
| #define | SDMMC_STA_DHOLD_Msk (0x1UL << SDMMC_STA_DHOLD_Pos) |
| #define | SDMMC_STA_DHOLD SDMMC_STA_DHOLD_Msk |
| #define | SDMMC_STA_DBCKEND_Pos (10U) |
| #define | SDMMC_STA_DBCKEND_Msk (0x1UL << SDMMC_STA_DBCKEND_Pos) |
| #define | SDMMC_STA_DBCKEND SDMMC_STA_DBCKEND_Msk |
| #define | SDMMC_STA_DABORT_Pos (11U) |
| #define | SDMMC_STA_DABORT_Msk (0x1UL << SDMMC_STA_DABORT_Pos) |
| #define | SDMMC_STA_DABORT SDMMC_STA_DABORT_Msk |
| #define | SDMMC_STA_DPSMACT_Pos (12U) |
| #define | SDMMC_STA_DPSMACT_Msk (0x1UL << SDMMC_STA_DPSMACT_Pos) |
| #define | SDMMC_STA_DPSMACT SDMMC_STA_DPSMACT_Msk |
| #define | SDMMC_STA_CPSMACT_Pos (13U) |
| #define | SDMMC_STA_CPSMACT_Msk (0x1UL << SDMMC_STA_CPSMACT_Pos) |
| #define | SDMMC_STA_CPSMACT SDMMC_STA_CPSMACT_Msk |
| #define | SDMMC_STA_TXFIFOHE_Pos (14U) |
| #define | SDMMC_STA_TXFIFOHE_Msk (0x1UL << SDMMC_STA_TXFIFOHE_Pos) |
| #define | SDMMC_STA_TXFIFOHE SDMMC_STA_TXFIFOHE_Msk |
| #define | SDMMC_STA_RXFIFOHF_Pos (15U) |
| #define | SDMMC_STA_RXFIFOHF_Msk (0x1UL << SDMMC_STA_RXFIFOHF_Pos) |
| #define | SDMMC_STA_RXFIFOHF SDMMC_STA_RXFIFOHF_Msk |
| #define | SDMMC_STA_TXFIFOF_Pos (16U) |
| #define | SDMMC_STA_TXFIFOF_Msk (0x1UL << SDMMC_STA_TXFIFOF_Pos) |
| #define | SDMMC_STA_TXFIFOF SDMMC_STA_TXFIFOF_Msk |
| #define | SDMMC_STA_RXFIFOF_Pos (17U) |
| #define | SDMMC_STA_RXFIFOF_Msk (0x1UL << SDMMC_STA_RXFIFOF_Pos) |
| #define | SDMMC_STA_RXFIFOF SDMMC_STA_RXFIFOF_Msk |
| #define | SDMMC_STA_TXFIFOE_Pos (18U) |
| #define | SDMMC_STA_TXFIFOE_Msk (0x1UL << SDMMC_STA_TXFIFOE_Pos) |
| #define | SDMMC_STA_TXFIFOE SDMMC_STA_TXFIFOE_Msk |
| #define | SDMMC_STA_RXFIFOE_Pos (19U) |
| #define | SDMMC_STA_RXFIFOE_Msk (0x1UL << SDMMC_STA_RXFIFOE_Pos) |
| #define | SDMMC_STA_RXFIFOE SDMMC_STA_RXFIFOE_Msk |
| #define | SDMMC_STA_BUSYD0_Pos (20U) |
| #define | SDMMC_STA_BUSYD0_Msk (0x1UL << SDMMC_STA_BUSYD0_Pos) |
| #define | SDMMC_STA_BUSYD0 SDMMC_STA_BUSYD0_Msk |
| #define | SDMMC_STA_BUSYD0END_Pos (21U) |
| #define | SDMMC_STA_BUSYD0END_Msk (0x1UL << SDMMC_STA_BUSYD0END_Pos) |
| #define | SDMMC_STA_BUSYD0END SDMMC_STA_BUSYD0END_Msk |
| #define | SDMMC_STA_SDIOIT_Pos (22U) |
| #define | SDMMC_STA_SDIOIT_Msk (0x1UL << SDMMC_STA_SDIOIT_Pos) |
| #define | SDMMC_STA_SDIOIT SDMMC_STA_SDIOIT_Msk |
| #define | SDMMC_STA_ACKFAIL_Pos (23U) |
| #define | SDMMC_STA_ACKFAIL_Msk (0x1UL << SDMMC_STA_ACKFAIL_Pos) |
| #define | SDMMC_STA_ACKFAIL SDMMC_STA_ACKFAIL_Msk |
| #define | SDMMC_STA_ACKTIMEOUT_Pos (24U) |
| #define | SDMMC_STA_ACKTIMEOUT_Msk (0x1UL << SDMMC_STA_ACKTIMEOUT_Pos) |
| #define | SDMMC_STA_ACKTIMEOUT SDMMC_STA_ACKTIMEOUT_Msk |
| #define | SDMMC_STA_VSWEND_Pos (25U) |
| #define | SDMMC_STA_VSWEND_Msk (0x1UL << SDMMC_STA_VSWEND_Pos) |
| #define | SDMMC_STA_VSWEND SDMMC_STA_VSWEND_Msk |
| #define | SDMMC_STA_CKSTOP_Pos (26U) |
| #define | SDMMC_STA_CKSTOP_Msk (0x1UL << SDMMC_STA_CKSTOP_Pos) |
| #define | SDMMC_STA_CKSTOP SDMMC_STA_CKSTOP_Msk |
| #define | SDMMC_STA_IDMATE_Pos (27U) |
| #define | SDMMC_STA_IDMATE_Msk (0x1UL << SDMMC_STA_IDMATE_Pos) |
| #define | SDMMC_STA_IDMATE SDMMC_STA_IDMATE_Msk |
| #define | SDMMC_STA_IDMABTC_Pos (28U) |
| #define | SDMMC_STA_IDMABTC_Msk (0x1UL << SDMMC_STA_IDMABTC_Pos) |
| #define | SDMMC_STA_IDMABTC SDMMC_STA_IDMABTC_Msk |
| #define | SDMMC_ICR_CCRCFAILC_Pos (0U) |
| #define | SDMMC_ICR_CCRCFAILC_Msk (0x1UL << SDMMC_ICR_CCRCFAILC_Pos) |
| #define | SDMMC_ICR_CCRCFAILC SDMMC_ICR_CCRCFAILC_Msk |
| #define | SDMMC_ICR_DCRCFAILC_Pos (1U) |
| #define | SDMMC_ICR_DCRCFAILC_Msk (0x1UL << SDMMC_ICR_DCRCFAILC_Pos) |
| #define | SDMMC_ICR_DCRCFAILC SDMMC_ICR_DCRCFAILC_Msk |
| #define | SDMMC_ICR_CTIMEOUTC_Pos (2U) |
| #define | SDMMC_ICR_CTIMEOUTC_Msk (0x1UL << SDMMC_ICR_CTIMEOUTC_Pos) |
| #define | SDMMC_ICR_CTIMEOUTC SDMMC_ICR_CTIMEOUTC_Msk |
| #define | SDMMC_ICR_DTIMEOUTC_Pos (3U) |
| #define | SDMMC_ICR_DTIMEOUTC_Msk (0x1UL << SDMMC_ICR_DTIMEOUTC_Pos) |
| #define | SDMMC_ICR_DTIMEOUTC SDMMC_ICR_DTIMEOUTC_Msk |
| #define | SDMMC_ICR_TXUNDERRC_Pos (4U) |
| #define | SDMMC_ICR_TXUNDERRC_Msk (0x1UL << SDMMC_ICR_TXUNDERRC_Pos) |
| #define | SDMMC_ICR_TXUNDERRC SDMMC_ICR_TXUNDERRC_Msk |
| #define | SDMMC_ICR_RXOVERRC_Pos (5U) |
| #define | SDMMC_ICR_RXOVERRC_Msk (0x1UL << SDMMC_ICR_RXOVERRC_Pos) |
| #define | SDMMC_ICR_RXOVERRC SDMMC_ICR_RXOVERRC_Msk |
| #define | SDMMC_ICR_CMDRENDC_Pos (6U) |
| #define | SDMMC_ICR_CMDRENDC_Msk (0x1UL << SDMMC_ICR_CMDRENDC_Pos) |
| #define | SDMMC_ICR_CMDRENDC SDMMC_ICR_CMDRENDC_Msk |
| #define | SDMMC_ICR_CMDSENTC_Pos (7U) |
| #define | SDMMC_ICR_CMDSENTC_Msk (0x1UL << SDMMC_ICR_CMDSENTC_Pos) |
| #define | SDMMC_ICR_CMDSENTC SDMMC_ICR_CMDSENTC_Msk |
| #define | SDMMC_ICR_DATAENDC_Pos (8U) |
| #define | SDMMC_ICR_DATAENDC_Msk (0x1UL << SDMMC_ICR_DATAENDC_Pos) |
| #define | SDMMC_ICR_DATAENDC SDMMC_ICR_DATAENDC_Msk |
| #define | SDMMC_ICR_DHOLDC_Pos (9U) |
| #define | SDMMC_ICR_DHOLDC_Msk (0x1UL << SDMMC_ICR_DHOLDC_Pos) |
| #define | SDMMC_ICR_DHOLDC SDMMC_ICR_DHOLDC_Msk |
| #define | SDMMC_ICR_DBCKENDC_Pos (10U) |
| #define | SDMMC_ICR_DBCKENDC_Msk (0x1UL << SDMMC_ICR_DBCKENDC_Pos) |
| #define | SDMMC_ICR_DBCKENDC SDMMC_ICR_DBCKENDC_Msk |
| #define | SDMMC_ICR_DABORTC_Pos (11U) |
| #define | SDMMC_ICR_DABORTC_Msk (0x1UL << SDMMC_ICR_DABORTC_Pos) |
| #define | SDMMC_ICR_DABORTC SDMMC_ICR_DABORTC_Msk |
| #define | SDMMC_ICR_BUSYD0ENDC_Pos (21U) |
| #define | SDMMC_ICR_BUSYD0ENDC_Msk (0x1UL << SDMMC_ICR_BUSYD0ENDC_Pos) |
| #define | SDMMC_ICR_BUSYD0ENDC SDMMC_ICR_BUSYD0ENDC_Msk |
| #define | SDMMC_ICR_SDIOITC_Pos (22U) |
| #define | SDMMC_ICR_SDIOITC_Msk (0x1UL << SDMMC_ICR_SDIOITC_Pos) |
| #define | SDMMC_ICR_SDIOITC SDMMC_ICR_SDIOITC_Msk |
| #define | SDMMC_ICR_ACKFAILC_Pos (23U) |
| #define | SDMMC_ICR_ACKFAILC_Msk (0x1UL << SDMMC_ICR_ACKFAILC_Pos) |
| #define | SDMMC_ICR_ACKFAILC SDMMC_ICR_ACKFAILC_Msk |
| #define | SDMMC_ICR_ACKTIMEOUTC_Pos (24U) |
| #define | SDMMC_ICR_ACKTIMEOUTC_Msk (0x1UL << SDMMC_ICR_ACKTIMEOUTC_Pos) |
| #define | SDMMC_ICR_ACKTIMEOUTC SDMMC_ICR_ACKTIMEOUTC_Msk |
| #define | SDMMC_ICR_VSWENDC_Pos (25U) |
| #define | SDMMC_ICR_VSWENDC_Msk (0x1UL << SDMMC_ICR_VSWENDC_Pos) |
| #define | SDMMC_ICR_VSWENDC SDMMC_ICR_VSWENDC_Msk |
| #define | SDMMC_ICR_CKSTOPC_Pos (26U) |
| #define | SDMMC_ICR_CKSTOPC_Msk (0x1UL << SDMMC_ICR_CKSTOPC_Pos) |
| #define | SDMMC_ICR_CKSTOPC SDMMC_ICR_CKSTOPC_Msk |
| #define | SDMMC_ICR_IDMATEC_Pos (27U) |
| #define | SDMMC_ICR_IDMATEC_Msk (0x1UL << SDMMC_ICR_IDMATEC_Pos) |
| #define | SDMMC_ICR_IDMATEC SDMMC_ICR_IDMATEC_Msk |
| #define | SDMMC_ICR_IDMABTCC_Pos (28U) |
| #define | SDMMC_ICR_IDMABTCC_Msk (0x1UL << SDMMC_ICR_IDMABTCC_Pos) |
| #define | SDMMC_ICR_IDMABTCC SDMMC_ICR_IDMABTCC_Msk |
| #define | SDMMC_MASK_CCRCFAILIE_Pos (0U) |
| #define | SDMMC_MASK_CCRCFAILIE_Msk (0x1UL << SDMMC_MASK_CCRCFAILIE_Pos) |
| #define | SDMMC_MASK_CCRCFAILIE SDMMC_MASK_CCRCFAILIE_Msk |
| #define | SDMMC_MASK_DCRCFAILIE_Pos (1U) |
| #define | SDMMC_MASK_DCRCFAILIE_Msk (0x1UL << SDMMC_MASK_DCRCFAILIE_Pos) |
| #define | SDMMC_MASK_DCRCFAILIE SDMMC_MASK_DCRCFAILIE_Msk |
| #define | SDMMC_MASK_CTIMEOUTIE_Pos (2U) |
| #define | SDMMC_MASK_CTIMEOUTIE_Msk (0x1UL << SDMMC_MASK_CTIMEOUTIE_Pos) |
| #define | SDMMC_MASK_CTIMEOUTIE SDMMC_MASK_CTIMEOUTIE_Msk |
| #define | SDMMC_MASK_DTIMEOUTIE_Pos (3U) |
| #define | SDMMC_MASK_DTIMEOUTIE_Msk (0x1UL << SDMMC_MASK_DTIMEOUTIE_Pos) |
| #define | SDMMC_MASK_DTIMEOUTIE SDMMC_MASK_DTIMEOUTIE_Msk |
| #define | SDMMC_MASK_TXUNDERRIE_Pos (4U) |
| #define | SDMMC_MASK_TXUNDERRIE_Msk (0x1UL << SDMMC_MASK_TXUNDERRIE_Pos) |
| #define | SDMMC_MASK_TXUNDERRIE SDMMC_MASK_TXUNDERRIE_Msk |
| #define | SDMMC_MASK_RXOVERRIE_Pos (5U) |
| #define | SDMMC_MASK_RXOVERRIE_Msk (0x1UL << SDMMC_MASK_RXOVERRIE_Pos) |
| #define | SDMMC_MASK_RXOVERRIE SDMMC_MASK_RXOVERRIE_Msk |
| #define | SDMMC_MASK_CMDRENDIE_Pos (6U) |
| #define | SDMMC_MASK_CMDRENDIE_Msk (0x1UL << SDMMC_MASK_CMDRENDIE_Pos) |
| #define | SDMMC_MASK_CMDRENDIE SDMMC_MASK_CMDRENDIE_Msk |
| #define | SDMMC_MASK_CMDSENTIE_Pos (7U) |
| #define | SDMMC_MASK_CMDSENTIE_Msk (0x1UL << SDMMC_MASK_CMDSENTIE_Pos) |
| #define | SDMMC_MASK_CMDSENTIE SDMMC_MASK_CMDSENTIE_Msk |
| #define | SDMMC_MASK_DATAENDIE_Pos (8U) |
| #define | SDMMC_MASK_DATAENDIE_Msk (0x1UL << SDMMC_MASK_DATAENDIE_Pos) |
| #define | SDMMC_MASK_DATAENDIE SDMMC_MASK_DATAENDIE_Msk |
| #define | SDMMC_MASK_DHOLDIE_Pos (9U) |
| #define | SDMMC_MASK_DHOLDIE_Msk (0x1UL << SDMMC_MASK_DHOLDIE_Pos) |
| #define | SDMMC_MASK_DHOLDIE SDMMC_MASK_DHOLDIE_Msk |
| #define | SDMMC_MASK_DBCKENDIE_Pos (10U) |
| #define | SDMMC_MASK_DBCKENDIE_Msk (0x1UL << SDMMC_MASK_DBCKENDIE_Pos) |
| #define | SDMMC_MASK_DBCKENDIE SDMMC_MASK_DBCKENDIE_Msk |
| #define | SDMMC_MASK_DABORTIE_Pos (11U) |
| #define | SDMMC_MASK_DABORTIE_Msk (0x1UL << SDMMC_MASK_DABORTIE_Pos) |
| #define | SDMMC_MASK_DABORTIE SDMMC_MASK_DABORTIE_Msk |
| #define | SDMMC_MASK_TXFIFOHEIE_Pos (14U) |
| #define | SDMMC_MASK_TXFIFOHEIE_Msk (0x1UL << SDMMC_MASK_TXFIFOHEIE_Pos) |
| #define | SDMMC_MASK_TXFIFOHEIE SDMMC_MASK_TXFIFOHEIE_Msk |
| #define | SDMMC_MASK_RXFIFOHFIE_Pos (15U) |
| #define | SDMMC_MASK_RXFIFOHFIE_Msk (0x1UL << SDMMC_MASK_RXFIFOHFIE_Pos) |
| #define | SDMMC_MASK_RXFIFOHFIE SDMMC_MASK_RXFIFOHFIE_Msk |
| #define | SDMMC_MASK_RXFIFOFIE_Pos (17U) |
| #define | SDMMC_MASK_RXFIFOFIE_Msk (0x1UL << SDMMC_MASK_RXFIFOFIE_Pos) |
| #define | SDMMC_MASK_RXFIFOFIE SDMMC_MASK_RXFIFOFIE_Msk |
| #define | SDMMC_MASK_TXFIFOEIE_Pos (18U) |
| #define | SDMMC_MASK_TXFIFOEIE_Msk (0x1UL << SDMMC_MASK_TXFIFOEIE_Pos) |
| #define | SDMMC_MASK_TXFIFOEIE SDMMC_MASK_TXFIFOEIE_Msk |
| #define | SDMMC_MASK_BUSYD0ENDIE_Pos (21U) |
| #define | SDMMC_MASK_BUSYD0ENDIE_Msk (0x1UL << SDMMC_MASK_BUSYD0ENDIE_Pos) |
| #define | SDMMC_MASK_BUSYD0ENDIE SDMMC_MASK_BUSYD0ENDIE_Msk |
| #define | SDMMC_MASK_SDIOITIE_Pos (22U) |
| #define | SDMMC_MASK_SDIOITIE_Msk (0x1UL << SDMMC_MASK_SDIOITIE_Pos) |
| #define | SDMMC_MASK_SDIOITIE SDMMC_MASK_SDIOITIE_Msk |
| #define | SDMMC_MASK_ACKFAILIE_Pos (23U) |
| #define | SDMMC_MASK_ACKFAILIE_Msk (0x1UL << SDMMC_MASK_ACKFAILIE_Pos) |
| #define | SDMMC_MASK_ACKFAILIE SDMMC_MASK_ACKFAILIE_Msk |
| #define | SDMMC_MASK_ACKTIMEOUTIE_Pos (24U) |
| #define | SDMMC_MASK_ACKTIMEOUTIE_Msk (0x1UL << SDMMC_MASK_ACKTIMEOUTIE_Pos) |
| #define | SDMMC_MASK_ACKTIMEOUTIE SDMMC_MASK_ACKTIMEOUTIE_Msk |
| #define | SDMMC_MASK_VSWENDIE_Pos (25U) |
| #define | SDMMC_MASK_VSWENDIE_Msk (0x1UL << SDMMC_MASK_VSWENDIE_Pos) |
| #define | SDMMC_MASK_VSWENDIE SDMMC_MASK_VSWENDIE_Msk |
| #define | SDMMC_MASK_CKSTOPIE_Pos (26U) |
| #define | SDMMC_MASK_CKSTOPIE_Msk (0x1UL << SDMMC_MASK_CKSTOPIE_Pos) |
| #define | SDMMC_MASK_CKSTOPIE SDMMC_MASK_CKSTOPIE_Msk |
| #define | SDMMC_MASK_IDMABTCIE_Pos (28U) |
| #define | SDMMC_MASK_IDMABTCIE_Msk (0x1UL << SDMMC_MASK_IDMABTCIE_Pos) |
| #define | SDMMC_MASK_IDMABTCIE SDMMC_MASK_IDMABTCIE_Msk |
| #define | SDMMC_ACKTIME_ACKTIME_Pos (0U) |
| #define | SDMMC_ACKTIME_ACKTIME_Msk (0x1FFFFFFUL << SDMMC_ACKTIME_ACKTIME_Pos) |
| #define | SDMMC_ACKTIME_ACKTIME SDMMC_ACKTIME_ACKTIME_Msk |
| #define | SDMMC_FIFO_FIFODATA_Pos (0U) |
| #define | SDMMC_FIFO_FIFODATA_Msk (0xFFFFFFFFUL << SDMMC_FIFO_FIFODATA_Pos) |
| #define | SDMMC_FIFO_FIFODATA SDMMC_FIFO_FIFODATA_Msk |
| #define | SDMMC_IDMA_IDMAEN_Pos (0U) |
| #define | SDMMC_IDMA_IDMAEN_Msk (0x1UL << SDMMC_IDMA_IDMAEN_Pos) |
| #define | SDMMC_IDMA_IDMAEN SDMMC_IDMA_IDMAEN_Msk |
| #define | SDMMC_IDMA_IDMABMODE_Pos (1U) |
| #define | SDMMC_IDMA_IDMABMODE_Msk (0x1UL << SDMMC_IDMA_IDMABMODE_Pos) |
| #define | SDMMC_IDMA_IDMABMODE SDMMC_IDMA_IDMABMODE_Msk |
| #define | SDMMC_IDMA_IDMABACT_Pos (2U) |
| #define | SDMMC_IDMA_IDMABACT_Msk (0x1UL << SDMMC_IDMA_IDMABACT_Pos) |
| #define | SDMMC_IDMA_IDMABACT SDMMC_IDMA_IDMABACT_Msk |
| #define | SDMMC_IDMABSIZE_IDMABNDT_Pos (5U) |
| #define | SDMMC_IDMABSIZE_IDMABNDT_Msk (0xFFUL << SDMMC_IDMABSIZE_IDMABNDT_Pos) |
| #define | SDMMC_IDMABSIZE_IDMABNDT SDMMC_IDMABSIZE_IDMABNDT_Msk |
| #define | SDMMC_IDMABASE0_IDMABASE0 (0xFFFFFFFFU) |
| #define | SDMMC_IDMABASE1_IDMABASE1 (0xFFFFFFFFU) |
| #define | DLYB_CR_DEN_Pos (0U) |
| #define | DLYB_CR_DEN_Msk (0x1UL << DLYB_CR_DEN_Pos) |
| #define | DLYB_CR_DEN DLYB_CR_DEN_Msk |
| #define | DLYB_CR_SEN_Pos (1U) |
| #define | DLYB_CR_SEN_Msk (0x1UL << DLYB_CR_SEN_Pos) |
| #define | DLYB_CR_SEN DLYB_CR_SEN_Msk |
| #define | DLYB_CFGR_SEL_Pos (0U) |
| #define | DLYB_CFGR_SEL_Msk (0xFUL << DLYB_CFGR_SEL_Pos) |
| #define | DLYB_CFGR_SEL DLYB_CFGR_SEL_Msk |
| #define | DLYB_CFGR_SEL_0 (0x1UL << DLYB_CFGR_SEL_Pos) |
| #define | DLYB_CFGR_SEL_1 (0x2UL << DLYB_CFGR_SEL_Pos) |
| #define | DLYB_CFGR_SEL_2 (0x3UL << DLYB_CFGR_SEL_Pos) |
| #define | DLYB_CFGR_SEL_3 (0x8UL << DLYB_CFGR_SEL_Pos) |
| #define | DLYB_CFGR_UNIT_Pos (8U) |
| #define | DLYB_CFGR_UNIT_Msk (0x7FUL << DLYB_CFGR_UNIT_Pos) |
| #define | DLYB_CFGR_UNIT DLYB_CFGR_UNIT_Msk |
| #define | DLYB_CFGR_UNIT_0 (0x01UL << DLYB_CFGR_UNIT_Pos) |
| #define | DLYB_CFGR_UNIT_1 (0x02UL << DLYB_CFGR_UNIT_Pos) |
| #define | DLYB_CFGR_UNIT_2 (0x04UL << DLYB_CFGR_UNIT_Pos) |
| #define | DLYB_CFGR_UNIT_3 (0x08UL << DLYB_CFGR_UNIT_Pos) |
| #define | DLYB_CFGR_UNIT_4 (0x10UL << DLYB_CFGR_UNIT_Pos) |
| #define | DLYB_CFGR_UNIT_5 (0x20UL << DLYB_CFGR_UNIT_Pos) |
| #define | DLYB_CFGR_UNIT_6 (0x40UL << DLYB_CFGR_UNIT_Pos) |
| #define | DLYB_CFGR_LNG_Pos (16U) |
| #define | DLYB_CFGR_LNG_Msk (0xFFFUL << DLYB_CFGR_LNG_Pos) |
| #define | DLYB_CFGR_LNG DLYB_CFGR_LNG_Msk |
| #define | DLYB_CFGR_LNG_0 (0x001UL << DLYB_CFGR_LNG_Pos) |
| #define | DLYB_CFGR_LNG_1 (0x002UL << DLYB_CFGR_LNG_Pos) |
| #define | DLYB_CFGR_LNG_2 (0x004UL << DLYB_CFGR_LNG_Pos) |
| #define | DLYB_CFGR_LNG_3 (0x008UL << DLYB_CFGR_LNG_Pos) |
| #define | DLYB_CFGR_LNG_4 (0x010UL << DLYB_CFGR_LNG_Pos) |
| #define | DLYB_CFGR_LNG_5 (0x020UL << DLYB_CFGR_LNG_Pos) |
| #define | DLYB_CFGR_LNG_6 (0x040UL << DLYB_CFGR_LNG_Pos) |
| #define | DLYB_CFGR_LNG_7 (0x080UL << DLYB_CFGR_LNG_Pos) |
| #define | DLYB_CFGR_LNG_8 (0x100UL << DLYB_CFGR_LNG_Pos) |
| #define | DLYB_CFGR_LNG_9 (0x200UL << DLYB_CFGR_LNG_Pos) |
| #define | DLYB_CFGR_LNG_10 (0x400UL << DLYB_CFGR_LNG_Pos) |
| #define | DLYB_CFGR_LNG_11 (0x800UL << DLYB_CFGR_LNG_Pos) |
| #define | DLYB_CFGR_LNGF_Pos (31U) |
| #define | DLYB_CFGR_LNGF_Msk (0x1UL << DLYB_CFGR_LNGF_Pos) |
| #define | DLYB_CFGR_LNGF DLYB_CFGR_LNGF_Msk |
| #define | SPI_CR1_SPE_Pos (0U) |
| #define | SPI_CR1_SPE_Msk (0x1UL << SPI_CR1_SPE_Pos) |
| #define | SPI_CR1_SPE SPI_CR1_SPE_Msk |
| #define | SPI_CR1_MASRX_Pos (8U) |
| #define | SPI_CR1_MASRX_Msk (0x1UL << SPI_CR1_MASRX_Pos) |
| #define | SPI_CR1_MASRX SPI_CR1_MASRX_Msk |
| #define | SPI_CR1_CSTART_Pos (9U) |
| #define | SPI_CR1_CSTART_Msk (0x1UL << SPI_CR1_CSTART_Pos) |
| #define | SPI_CR1_CSTART SPI_CR1_CSTART_Msk |
| #define | SPI_CR1_CSUSP_Pos (10U) |
| #define | SPI_CR1_CSUSP_Msk (0x1UL << SPI_CR1_CSUSP_Pos) |
| #define | SPI_CR1_CSUSP SPI_CR1_CSUSP_Msk |
| #define | SPI_CR1_HDDIR_Pos (11U) |
| #define | SPI_CR1_HDDIR_Msk (0x1UL << SPI_CR1_HDDIR_Pos) |
| #define | SPI_CR1_HDDIR SPI_CR1_HDDIR_Msk |
| #define | SPI_CR1_SSI_Pos (12U) |
| #define | SPI_CR1_SSI_Msk (0x1UL << SPI_CR1_SSI_Pos) |
| #define | SPI_CR1_SSI SPI_CR1_SSI_Msk |
| #define | SPI_CR1_CRC33_17_Pos (13U) |
| #define | SPI_CR1_CRC33_17_Msk (0x1UL << SPI_CR1_CRC33_17_Pos) |
| #define | SPI_CR1_CRC33_17 SPI_CR1_CRC33_17_Msk |
| #define | SPI_CR1_RCRCINI_Pos (14U) |
| #define | SPI_CR1_RCRCINI_Msk (0x1UL << SPI_CR1_RCRCINI_Pos) |
| #define | SPI_CR1_RCRCINI SPI_CR1_RCRCINI_Msk |
| #define | SPI_CR1_TCRCINI_Pos (15U) |
| #define | SPI_CR1_TCRCINI_Msk (0x1UL << SPI_CR1_TCRCINI_Pos) |
| #define | SPI_CR1_TCRCINI SPI_CR1_TCRCINI_Msk |
| #define | SPI_CR1_IOLOCK_Pos (16U) |
| #define | SPI_CR1_IOLOCK_Msk (0x1UL << SPI_CR1_IOLOCK_Pos) |
| #define | SPI_CR1_IOLOCK SPI_CR1_IOLOCK_Msk |
| #define | SPI_CR2_TSER_Pos (16U) |
| #define | SPI_CR2_TSER_Msk (0xFFFFUL << SPI_CR2_TSER_Pos) |
| #define | SPI_CR2_TSER SPI_CR2_TSER_Msk |
| #define | SPI_CR2_TSIZE_Pos (0U) |
| #define | SPI_CR2_TSIZE_Msk (0xFFFFUL << SPI_CR2_TSIZE_Pos) |
| #define | SPI_CR2_TSIZE SPI_CR2_TSIZE_Msk |
| #define | SPI_CFG1_DSIZE_Pos (0U) |
| #define | SPI_CFG1_DSIZE_Msk (0x1FUL << SPI_CFG1_DSIZE_Pos) |
| #define | SPI_CFG1_DSIZE SPI_CFG1_DSIZE_Msk |
| #define | SPI_CFG1_DSIZE_0 (0x01UL << SPI_CFG1_DSIZE_Pos) |
| #define | SPI_CFG1_DSIZE_1 (0x02UL << SPI_CFG1_DSIZE_Pos) |
| #define | SPI_CFG1_DSIZE_2 (0x04UL << SPI_CFG1_DSIZE_Pos) |
| #define | SPI_CFG1_DSIZE_3 (0x08UL << SPI_CFG1_DSIZE_Pos) |
| #define | SPI_CFG1_DSIZE_4 (0x10UL << SPI_CFG1_DSIZE_Pos) |
| #define | SPI_CFG1_FTHLV_Pos (5U) |
| #define | SPI_CFG1_FTHLV_Msk (0xFUL << SPI_CFG1_FTHLV_Pos) |
| #define | SPI_CFG1_FTHLV SPI_CFG1_FTHLV_Msk |
| #define | SPI_CFG1_FTHLV_0 (0x1UL << SPI_CFG1_FTHLV_Pos) |
| #define | SPI_CFG1_FTHLV_1 (0x2UL << SPI_CFG1_FTHLV_Pos) |
| #define | SPI_CFG1_FTHLV_2 (0x4UL << SPI_CFG1_FTHLV_Pos) |
| #define | SPI_CFG1_FTHLV_3 (0x8UL << SPI_CFG1_FTHLV_Pos) |
| #define | SPI_CFG1_UDRCFG_Pos (9U) |
| #define | SPI_CFG1_UDRCFG_Msk (0x3UL << SPI_CFG1_UDRCFG_Pos) |
| #define | SPI_CFG1_UDRCFG SPI_CFG1_UDRCFG_Msk |
| #define | SPI_CFG1_UDRCFG_0 (0x1UL << SPI_CFG1_UDRCFG_Pos) |
| #define | SPI_CFG1_UDRCFG_1 (0x2UL << SPI_CFG1_UDRCFG_Pos) |
| #define | SPI_CFG1_UDRDET_Pos (11U) |
| #define | SPI_CFG1_UDRDET_Msk (0x3UL << SPI_CFG1_UDRDET_Pos) |
| #define | SPI_CFG1_UDRDET SPI_CFG1_UDRDET_Msk |
| #define | SPI_CFG1_UDRDET_0 (0x1UL << SPI_CFG1_UDRDET_Pos) |
| #define | SPI_CFG1_UDRDET_1 (0x2UL << SPI_CFG1_UDRDET_Pos) |
| #define | SPI_CFG1_RXDMAEN_Pos (14U) |
| #define | SPI_CFG1_RXDMAEN_Msk (0x1UL << SPI_CFG1_RXDMAEN_Pos) |
| #define | SPI_CFG1_RXDMAEN SPI_CFG1_RXDMAEN_Msk |
| #define | SPI_CFG1_TXDMAEN_Pos (15U) |
| #define | SPI_CFG1_TXDMAEN_Msk (0x1UL << SPI_CFG1_TXDMAEN_Pos) |
| #define | SPI_CFG1_TXDMAEN SPI_CFG1_TXDMAEN_Msk |
| #define | SPI_CFG1_CRCSIZE_Pos (16U) |
| #define | SPI_CFG1_CRCSIZE_Msk (0x1FUL << SPI_CFG1_CRCSIZE_Pos) |
| #define | SPI_CFG1_CRCSIZE SPI_CFG1_CRCSIZE_Msk |
| #define | SPI_CFG1_CRCSIZE_0 (0x01UL << SPI_CFG1_CRCSIZE_Pos) |
| #define | SPI_CFG1_CRCSIZE_1 (0x02UL << SPI_CFG1_CRCSIZE_Pos) |
| #define | SPI_CFG1_CRCSIZE_2 (0x04UL << SPI_CFG1_CRCSIZE_Pos) |
| #define | SPI_CFG1_CRCSIZE_3 (0x08UL << SPI_CFG1_CRCSIZE_Pos) |
| #define | SPI_CFG1_CRCSIZE_4 (0x10UL << SPI_CFG1_CRCSIZE_Pos) |
| #define | SPI_CFG1_CRCEN_Pos (22U) |
| #define | SPI_CFG1_CRCEN_Msk (0x1UL << SPI_CFG1_CRCEN_Pos) |
| #define | SPI_CFG1_CRCEN SPI_CFG1_CRCEN_Msk |
| #define | SPI_CFG1_MBR_Pos (28U) |
| #define | SPI_CFG1_MBR_Msk (0x7UL << SPI_CFG1_MBR_Pos) |
| #define | SPI_CFG1_MBR SPI_CFG1_MBR_Msk |
| #define | SPI_CFG1_MBR_0 (0x1UL << SPI_CFG1_MBR_Pos) |
| #define | SPI_CFG1_MBR_1 (0x2UL << SPI_CFG1_MBR_Pos) |
| #define | SPI_CFG1_MBR_2 (0x4UL << SPI_CFG1_MBR_Pos) |
| #define | SPI_CFG2_MSSI_Pos (0U) |
| #define | SPI_CFG2_MSSI_Msk (0xFUL << SPI_CFG2_MSSI_Pos) |
| #define | SPI_CFG2_MSSI SPI_CFG2_MSSI_Msk |
| #define | SPI_CFG2_MSSI_0 (0x1UL << SPI_CFG2_MSSI_Pos) |
| #define | SPI_CFG2_MSSI_1 (0x2UL << SPI_CFG2_MSSI_Pos) |
| #define | SPI_CFG2_MSSI_2 (0x4UL << SPI_CFG2_MSSI_Pos) |
| #define | SPI_CFG2_MSSI_3 (0x8UL << SPI_CFG2_MSSI_Pos) |
| #define | SPI_CFG2_MIDI_Pos (4U) |
| #define | SPI_CFG2_MIDI_Msk (0xFUL << SPI_CFG2_MIDI_Pos) |
| #define | SPI_CFG2_MIDI SPI_CFG2_MIDI_Msk |
| #define | SPI_CFG2_MIDI_0 (0x1UL << SPI_CFG2_MIDI_Pos) |
| #define | SPI_CFG2_MIDI_1 (0x2UL << SPI_CFG2_MIDI_Pos) |
| #define | SPI_CFG2_MIDI_2 (0x4UL << SPI_CFG2_MIDI_Pos) |
| #define | SPI_CFG2_MIDI_3 (0x8UL << SPI_CFG2_MIDI_Pos) |
| #define | SPI_CFG2_IOSWP_Pos (15U) |
| #define | SPI_CFG2_IOSWP_Msk (0x1UL << SPI_CFG2_IOSWP_Pos) |
| #define | SPI_CFG2_IOSWP SPI_CFG2_IOSWP_Msk |
| #define | SPI_CFG2_COMM_Pos (17U) |
| #define | SPI_CFG2_COMM_Msk (0x3UL << SPI_CFG2_COMM_Pos) |
| #define | SPI_CFG2_COMM SPI_CFG2_COMM_Msk |
| #define | SPI_CFG2_COMM_0 (0x1UL << SPI_CFG2_COMM_Pos) |
| #define | SPI_CFG2_COMM_1 (0x2UL << SPI_CFG2_COMM_Pos) |
| #define | SPI_CFG2_SP_Pos (19U) |
| #define | SPI_CFG2_SP_Msk (0x7UL << SPI_CFG2_SP_Pos) |
| #define | SPI_CFG2_SP SPI_CFG2_SP_Msk |
| #define | SPI_CFG2_SP_0 (0x1UL << SPI_CFG2_SP_Pos) |
| #define | SPI_CFG2_SP_1 (0x2UL << SPI_CFG2_SP_Pos) |
| #define | SPI_CFG2_SP_2 (0x4UL << SPI_CFG2_SP_Pos) |
| #define | SPI_CFG2_MASTER_Pos (22U) |
| #define | SPI_CFG2_MASTER_Msk (0x1UL << SPI_CFG2_MASTER_Pos) |
| #define | SPI_CFG2_MASTER SPI_CFG2_MASTER_Msk |
| #define | SPI_CFG2_LSBFRST_Pos (23U) |
| #define | SPI_CFG2_LSBFRST_Msk (0x1UL << SPI_CFG2_LSBFRST_Pos) |
| #define | SPI_CFG2_LSBFRST SPI_CFG2_LSBFRST_Msk |
| #define | SPI_CFG2_CPHA_Pos (24U) |
| #define | SPI_CFG2_CPHA_Msk (0x1UL << SPI_CFG2_CPHA_Pos) |
| #define | SPI_CFG2_CPHA SPI_CFG2_CPHA_Msk |
| #define | SPI_CFG2_CPOL_Pos (25U) |
| #define | SPI_CFG2_CPOL_Msk (0x1UL << SPI_CFG2_CPOL_Pos) |
| #define | SPI_CFG2_CPOL SPI_CFG2_CPOL_Msk |
| #define | SPI_CFG2_SSM_Pos (26U) |
| #define | SPI_CFG2_SSM_Msk (0x1UL << SPI_CFG2_SSM_Pos) |
| #define | SPI_CFG2_SSM SPI_CFG2_SSM_Msk |
| #define | SPI_CFG2_SSIOP_Pos (28U) |
| #define | SPI_CFG2_SSIOP_Msk (0x1UL << SPI_CFG2_SSIOP_Pos) |
| #define | SPI_CFG2_SSIOP SPI_CFG2_SSIOP_Msk |
| #define | SPI_CFG2_SSOE_Pos (29U) |
| #define | SPI_CFG2_SSOE_Msk (0x1UL << SPI_CFG2_SSOE_Pos) |
| #define | SPI_CFG2_SSOE SPI_CFG2_SSOE_Msk |
| #define | SPI_CFG2_SSOM_Pos (30U) |
| #define | SPI_CFG2_SSOM_Msk (0x1UL << SPI_CFG2_SSOM_Pos) |
| #define | SPI_CFG2_SSOM SPI_CFG2_SSOM_Msk |
| #define | SPI_CFG2_AFCNTR_Pos (31U) |
| #define | SPI_CFG2_AFCNTR_Msk (0x1UL << SPI_CFG2_AFCNTR_Pos) |
| #define | SPI_CFG2_AFCNTR SPI_CFG2_AFCNTR_Msk |
| #define | SPI_IER_RXPIE_Pos (0U) |
| #define | SPI_IER_RXPIE_Msk (0x1UL << SPI_IER_RXPIE_Pos) |
| #define | SPI_IER_RXPIE SPI_IER_RXPIE_Msk |
| #define | SPI_IER_TXPIE_Pos (1U) |
| #define | SPI_IER_TXPIE_Msk (0x1UL << SPI_IER_TXPIE_Pos) |
| #define | SPI_IER_TXPIE SPI_IER_TXPIE_Msk |
| #define | SPI_IER_DXPIE_Pos (2U) |
| #define | SPI_IER_DXPIE_Msk (0x1UL << SPI_IER_DXPIE_Pos) |
| #define | SPI_IER_DXPIE SPI_IER_DXPIE_Msk |
| #define | SPI_IER_EOTIE_Pos (3U) |
| #define | SPI_IER_EOTIE_Msk (0x1UL << SPI_IER_EOTIE_Pos) |
| #define | SPI_IER_EOTIE SPI_IER_EOTIE_Msk |
| #define | SPI_IER_TXTFIE_Pos (4U) |
| #define | SPI_IER_TXTFIE_Msk (0x1UL << SPI_IER_TXTFIE_Pos) |
| #define | SPI_IER_TXTFIE SPI_IER_TXTFIE_Msk |
| #define | SPI_IER_UDRIE_Pos (5U) |
| #define | SPI_IER_UDRIE_Msk (0x1UL << SPI_IER_UDRIE_Pos) |
| #define | SPI_IER_UDRIE SPI_IER_UDRIE_Msk |
| #define | SPI_IER_OVRIE_Pos (6U) |
| #define | SPI_IER_OVRIE_Msk (0x1UL << SPI_IER_OVRIE_Pos) |
| #define | SPI_IER_OVRIE SPI_IER_OVRIE_Msk |
| #define | SPI_IER_CRCEIE_Pos (7U) |
| #define | SPI_IER_CRCEIE_Msk (0x1UL << SPI_IER_CRCEIE_Pos) |
| #define | SPI_IER_CRCEIE SPI_IER_CRCEIE_Msk |
| #define | SPI_IER_TIFREIE_Pos (8U) |
| #define | SPI_IER_TIFREIE_Msk (0x1UL << SPI_IER_TIFREIE_Pos) |
| #define | SPI_IER_TIFREIE SPI_IER_TIFREIE_Msk |
| #define | SPI_IER_MODFIE_Pos (9U) |
| #define | SPI_IER_MODFIE_Msk (0x1UL << SPI_IER_MODFIE_Pos) |
| #define | SPI_IER_MODFIE SPI_IER_MODFIE_Msk |
| #define | SPI_IER_TSERFIE_Pos (10U) |
| #define | SPI_IER_TSERFIE_Msk (0x1UL << SPI_IER_TSERFIE_Pos) |
| #define | SPI_IER_TSERFIE SPI_IER_TSERFIE_Msk |
| #define | SPI_SR_RXP_Pos (0U) |
| #define | SPI_SR_RXP_Msk (0x1UL << SPI_SR_RXP_Pos) |
| #define | SPI_SR_RXP SPI_SR_RXP_Msk |
| #define | SPI_SR_TXP_Pos (1U) |
| #define | SPI_SR_TXP_Msk (0x1UL << SPI_SR_TXP_Pos) |
| #define | SPI_SR_TXP SPI_SR_TXP_Msk |
| #define | SPI_SR_DXP_Pos (2U) |
| #define | SPI_SR_DXP_Msk (0x1UL << SPI_SR_DXP_Pos) |
| #define | SPI_SR_DXP SPI_SR_DXP_Msk |
| #define | SPI_SR_EOT_Pos (3U) |
| #define | SPI_SR_EOT_Msk (0x1UL << SPI_SR_EOT_Pos) |
| #define | SPI_SR_EOT SPI_SR_EOT_Msk |
| #define | SPI_SR_TXTF_Pos (4U) |
| #define | SPI_SR_TXTF_Msk (0x1UL << SPI_SR_TXTF_Pos) |
| #define | SPI_SR_TXTF SPI_SR_TXTF_Msk |
| #define | SPI_SR_UDR_Pos (5U) |
| #define | SPI_SR_UDR_Msk (0x1UL << SPI_SR_UDR_Pos) |
| #define | SPI_SR_UDR SPI_SR_UDR_Msk |
| #define | SPI_SR_OVR_Pos (6U) |
| #define | SPI_SR_OVR_Msk (0x1UL << SPI_SR_OVR_Pos) |
| #define | SPI_SR_OVR SPI_SR_OVR_Msk |
| #define | SPI_SR_CRCE_Pos (7U) |
| #define | SPI_SR_CRCE_Msk (0x1UL << SPI_SR_CRCE_Pos) |
| #define | SPI_SR_CRCE SPI_SR_CRCE_Msk |
| #define | SPI_SR_TIFRE_Pos (8U) |
| #define | SPI_SR_TIFRE_Msk (0x1UL << SPI_SR_TIFRE_Pos) |
| #define | SPI_SR_TIFRE SPI_SR_TIFRE_Msk |
| #define | SPI_SR_MODF_Pos (9U) |
| #define | SPI_SR_MODF_Msk (0x1UL << SPI_SR_MODF_Pos) |
| #define | SPI_SR_MODF SPI_SR_MODF_Msk |
| #define | SPI_SR_TSERF_Pos (10U) |
| #define | SPI_SR_TSERF_Msk (0x1UL << SPI_SR_TSERF_Pos) |
| #define | SPI_SR_TSERF SPI_SR_TSERF_Msk |
| #define | SPI_SR_SUSP_Pos (11U) |
| #define | SPI_SR_SUSP_Msk (0x1UL << SPI_SR_SUSP_Pos) |
| #define | SPI_SR_SUSP SPI_SR_SUSP_Msk |
| #define | SPI_SR_TXC_Pos (12U) |
| #define | SPI_SR_TXC_Msk (0x1UL << SPI_SR_TXC_Pos) |
| #define | SPI_SR_TXC SPI_SR_TXC_Msk |
| #define | SPI_SR_RXPLVL_Pos (13U) |
| #define | SPI_SR_RXPLVL_Msk (0x3UL << SPI_SR_RXPLVL_Pos) |
| #define | SPI_SR_RXPLVL SPI_SR_RXPLVL_Msk |
| #define | SPI_SR_RXPLVL_0 (0x1UL << SPI_SR_RXPLVL_Pos) |
| #define | SPI_SR_RXPLVL_1 (0x2UL << SPI_SR_RXPLVL_Pos) |
| #define | SPI_SR_RXWNE_Pos (15U) |
| #define | SPI_SR_RXWNE_Msk (0x1UL << SPI_SR_RXWNE_Pos) |
| #define | SPI_SR_RXWNE SPI_SR_RXWNE_Msk |
| #define | SPI_SR_CTSIZE_Pos (16U) |
| #define | SPI_SR_CTSIZE_Msk (0xFFFFUL << SPI_SR_CTSIZE_Pos) |
| #define | SPI_SR_CTSIZE SPI_SR_CTSIZE_Msk |
| #define | SPI_IFCR_EOTC_Pos (3U) |
| #define | SPI_IFCR_EOTC_Msk (0x1UL << SPI_IFCR_EOTC_Pos) |
| #define | SPI_IFCR_EOTC SPI_IFCR_EOTC_Msk |
| #define | SPI_IFCR_TXTFC_Pos (4U) |
| #define | SPI_IFCR_TXTFC_Msk (0x1UL << SPI_IFCR_TXTFC_Pos) |
| #define | SPI_IFCR_TXTFC SPI_IFCR_TXTFC_Msk |
| #define | SPI_IFCR_UDRC_Pos (5U) |
| #define | SPI_IFCR_UDRC_Msk (0x1UL << SPI_IFCR_UDRC_Pos) |
| #define | SPI_IFCR_UDRC SPI_IFCR_UDRC_Msk |
| #define | SPI_IFCR_OVRC_Pos (6U) |
| #define | SPI_IFCR_OVRC_Msk (0x1UL << SPI_IFCR_OVRC_Pos) |
| #define | SPI_IFCR_OVRC SPI_IFCR_OVRC_Msk |
| #define | SPI_IFCR_CRCEC_Pos (7U) |
| #define | SPI_IFCR_CRCEC_Msk (0x1UL << SPI_IFCR_CRCEC_Pos) |
| #define | SPI_IFCR_CRCEC SPI_IFCR_CRCEC_Msk |
| #define | SPI_IFCR_TIFREC_Pos (8U) |
| #define | SPI_IFCR_TIFREC_Msk (0x1UL << SPI_IFCR_TIFREC_Pos) |
| #define | SPI_IFCR_TIFREC SPI_IFCR_TIFREC_Msk |
| #define | SPI_IFCR_MODFC_Pos (9U) |
| #define | SPI_IFCR_MODFC_Msk (0x1UL << SPI_IFCR_MODFC_Pos) |
| #define | SPI_IFCR_MODFC SPI_IFCR_MODFC_Msk |
| #define | SPI_IFCR_TSERFC_Pos (10U) |
| #define | SPI_IFCR_TSERFC_Msk (0x1UL << SPI_IFCR_TSERFC_Pos) |
| #define | SPI_IFCR_TSERFC SPI_IFCR_TSERFC_Msk |
| #define | SPI_IFCR_SUSPC_Pos (11U) |
| #define | SPI_IFCR_SUSPC_Msk (0x1UL << SPI_IFCR_SUSPC_Pos) |
| #define | SPI_IFCR_SUSPC SPI_IFCR_SUSPC_Msk |
| #define | SPI_TXDR_TXDR_Pos (0U) |
| #define | SPI_TXDR_TXDR_Msk (0xFFFFFFFFUL << SPI_TXDR_TXDR_Pos) |
| #define | SPI_TXDR_TXDR SPI_TXDR_TXDR_Msk /* Transmit Data Register */ |
| #define | SPI_RXDR_RXDR_Pos (0U) |
| #define | SPI_RXDR_RXDR_Msk (0xFFFFFFFFUL << SPI_RXDR_RXDR_Pos) |
| #define | SPI_RXDR_RXDR SPI_RXDR_RXDR_Msk /* Receive Data Register */ |
| #define | SPI_CRCPOLY_CRCPOLY_Pos (0U) |
| #define | SPI_CRCPOLY_CRCPOLY_Msk (0xFFFFFFFFUL << SPI_CRCPOLY_CRCPOLY_Pos) |
| #define | SPI_CRCPOLY_CRCPOLY SPI_CRCPOLY_CRCPOLY_Msk /* CRC Polynomial register */ |
| #define | SPI_TXCRC_TXCRC_Pos (0U) |
| #define | SPI_TXCRC_TXCRC_Msk (0xFFFFFFFFUL << SPI_TXCRC_TXCRC_Pos) |
| #define | SPI_TXCRC_TXCRC SPI_TXCRC_TXCRC_Msk /* CRCRegister for transmitter */ |
| #define | SPI_RXCRC_RXCRC_Pos (0U) |
| #define | SPI_RXCRC_RXCRC_Msk (0xFFFFFFFFUL << SPI_RXCRC_RXCRC_Pos) |
| #define | SPI_RXCRC_RXCRC SPI_RXCRC_RXCRC_Msk /* CRCRegister for receiver */ |
| #define | SPI_UDRDR_UDRDR_Pos (0U) |
| #define | SPI_UDRDR_UDRDR_Msk (0xFFFFFFFFUL << SPI_UDRDR_UDRDR_Pos) |
| #define | SPI_UDRDR_UDRDR SPI_UDRDR_UDRDR_Msk /* Data at slave underrun condition */ |
| #define | SPI_I2SCFGR_I2SMOD_Pos (0U) |
| #define | SPI_I2SCFGR_I2SMOD_Msk (0x1UL << SPI_I2SCFGR_I2SMOD_Pos) |
| #define | SPI_I2SCFGR_I2SMOD SPI_I2SCFGR_I2SMOD_Msk |
| #define | SPI_I2SCFGR_I2SCFG_Pos (1U) |
| #define | SPI_I2SCFGR_I2SCFG_Msk (0x7UL << SPI_I2SCFGR_I2SCFG_Pos) |
| #define | SPI_I2SCFGR_I2SCFG SPI_I2SCFGR_I2SCFG_Msk |
| #define | SPI_I2SCFGR_I2SCFG_0 (0x1UL << SPI_I2SCFGR_I2SCFG_Pos) |
| #define | SPI_I2SCFGR_I2SCFG_1 (0x2UL << SPI_I2SCFGR_I2SCFG_Pos) |
| #define | SPI_I2SCFGR_I2SCFG_2 (0x4UL << SPI_I2SCFGR_I2SCFG_Pos) |
| #define | SPI_I2SCFGR_I2SSTD_Pos (4U) |
| #define | SPI_I2SCFGR_I2SSTD_Msk (0x3UL << SPI_I2SCFGR_I2SSTD_Pos) |
| #define | SPI_I2SCFGR_I2SSTD SPI_I2SCFGR_I2SSTD_Msk |
| #define | SPI_I2SCFGR_I2SSTD_0 (0x1UL << SPI_I2SCFGR_I2SSTD_Pos) |
| #define | SPI_I2SCFGR_I2SSTD_1 (0x2UL << SPI_I2SCFGR_I2SSTD_Pos) |
| #define | SPI_I2SCFGR_PCMSYNC_Pos (7U) |
| #define | SPI_I2SCFGR_PCMSYNC_Msk (0x1UL << SPI_I2SCFGR_PCMSYNC_Pos) |
| #define | SPI_I2SCFGR_PCMSYNC SPI_I2SCFGR_PCMSYNC_Msk |
| #define | SPI_I2SCFGR_DATLEN_Pos (8U) |
| #define | SPI_I2SCFGR_DATLEN_Msk (0x3UL << SPI_I2SCFGR_DATLEN_Pos) |
| #define | SPI_I2SCFGR_DATLEN SPI_I2SCFGR_DATLEN_Msk |
| #define | SPI_I2SCFGR_DATLEN_0 (0x1UL << SPI_I2SCFGR_DATLEN_Pos) |
| #define | SPI_I2SCFGR_DATLEN_1 (0x2UL << SPI_I2SCFGR_DATLEN_Pos) |
| #define | SPI_I2SCFGR_CHLEN_Pos (10U) |
| #define | SPI_I2SCFGR_CHLEN_Msk (0x1UL << SPI_I2SCFGR_CHLEN_Pos) |
| #define | SPI_I2SCFGR_CHLEN SPI_I2SCFGR_CHLEN_Msk |
| #define | SPI_I2SCFGR_CKPOL_Pos (11U) |
| #define | SPI_I2SCFGR_CKPOL_Msk (0x1UL << SPI_I2SCFGR_CKPOL_Pos) |
| #define | SPI_I2SCFGR_CKPOL SPI_I2SCFGR_CKPOL_Msk |
| #define | SPI_I2SCFGR_FIXCH_Pos (12U) |
| #define | SPI_I2SCFGR_FIXCH_Msk (0x1UL << SPI_I2SCFGR_FIXCH_Pos) |
| #define | SPI_I2SCFGR_FIXCH SPI_I2SCFGR_FIXCH_Msk |
| #define | SPI_I2SCFGR_WSINV_Pos (13U) |
| #define | SPI_I2SCFGR_WSINV_Msk (0x1UL << SPI_I2SCFGR_WSINV_Pos) |
| #define | SPI_I2SCFGR_WSINV SPI_I2SCFGR_WSINV_Msk |
| #define | SPI_I2SCFGR_DATFMT_Pos (14U) |
| #define | SPI_I2SCFGR_DATFMT_Msk (0x1UL << SPI_I2SCFGR_DATFMT_Pos) |
| #define | SPI_I2SCFGR_DATFMT SPI_I2SCFGR_DATFMT_Msk |
| #define | SPI_I2SCFGR_I2SDIV_Pos (16U) |
| #define | SPI_I2SCFGR_I2SDIV_Msk (0xFFUL << SPI_I2SCFGR_I2SDIV_Pos) |
| #define | SPI_I2SCFGR_I2SDIV SPI_I2SCFGR_I2SDIV_Msk |
| #define | SPI_I2SCFGR_ODD_Pos (24U) |
| #define | SPI_I2SCFGR_ODD_Msk (0x1UL << SPI_I2SCFGR_ODD_Pos) |
| #define | SPI_I2SCFGR_ODD SPI_I2SCFGR_ODD_Msk |
| #define | SPI_I2SCFGR_MCKOE_Pos (25U) |
| #define | SPI_I2SCFGR_MCKOE_Msk (0x1UL << SPI_I2SCFGR_MCKOE_Pos) |
| #define | SPI_I2SCFGR_MCKOE SPI_I2SCFGR_MCKOE_Msk |
| #define | QUADSPI_CR_EN_Pos (0U) |
| #define | QUADSPI_CR_EN_Msk (0x1UL << QUADSPI_CR_EN_Pos) |
| #define | QUADSPI_CR_EN QUADSPI_CR_EN_Msk |
| #define | QUADSPI_CR_ABORT_Pos (1U) |
| #define | QUADSPI_CR_ABORT_Msk (0x1UL << QUADSPI_CR_ABORT_Pos) |
| #define | QUADSPI_CR_ABORT QUADSPI_CR_ABORT_Msk |
| #define | QUADSPI_CR_DMAEN_Pos (2U) |
| #define | QUADSPI_CR_DMAEN_Msk (0x1UL << QUADSPI_CR_DMAEN_Pos) |
| #define | QUADSPI_CR_DMAEN QUADSPI_CR_DMAEN_Msk |
| #define | QUADSPI_CR_TCEN_Pos (3U) |
| #define | QUADSPI_CR_TCEN_Msk (0x1UL << QUADSPI_CR_TCEN_Pos) |
| #define | QUADSPI_CR_TCEN QUADSPI_CR_TCEN_Msk |
| #define | QUADSPI_CR_SSHIFT_Pos (4U) |
| #define | QUADSPI_CR_SSHIFT_Msk (0x1UL << QUADSPI_CR_SSHIFT_Pos) |
| #define | QUADSPI_CR_SSHIFT QUADSPI_CR_SSHIFT_Msk |
| #define | QUADSPI_CR_DFM_Pos (6U) |
| #define | QUADSPI_CR_DFM_Msk (0x1UL << QUADSPI_CR_DFM_Pos) |
| #define | QUADSPI_CR_DFM QUADSPI_CR_DFM_Msk |
| #define | QUADSPI_CR_FSEL_Pos (7U) |
| #define | QUADSPI_CR_FSEL_Msk (0x1UL << QUADSPI_CR_FSEL_Pos) |
| #define | QUADSPI_CR_FSEL QUADSPI_CR_FSEL_Msk |
| #define | QUADSPI_CR_FTHRES_Pos (8U) |
| #define | QUADSPI_CR_FTHRES_Msk (0x1FUL << QUADSPI_CR_FTHRES_Pos) |
| #define | QUADSPI_CR_FTHRES QUADSPI_CR_FTHRES_Msk |
| #define | QUADSPI_CR_FTHRES_0 (0x1UL << QUADSPI_CR_FTHRES_Pos) |
| #define | QUADSPI_CR_FTHRES_1 (0x2UL << QUADSPI_CR_FTHRES_Pos) |
| #define | QUADSPI_CR_FTHRES_2 (0x4UL << QUADSPI_CR_FTHRES_Pos) |
| #define | QUADSPI_CR_FTHRES_3 (0x8UL << QUADSPI_CR_FTHRES_Pos) |
| #define | QUADSPI_CR_FTHRES_4 (0x10UL << QUADSPI_CR_FTHRES_Pos) |
| #define | QUADSPI_CR_TEIE_Pos (16U) |
| #define | QUADSPI_CR_TEIE_Msk (0x1UL << QUADSPI_CR_TEIE_Pos) |
| #define | QUADSPI_CR_TEIE QUADSPI_CR_TEIE_Msk |
| #define | QUADSPI_CR_TCIE_Pos (17U) |
| #define | QUADSPI_CR_TCIE_Msk (0x1UL << QUADSPI_CR_TCIE_Pos) |
| #define | QUADSPI_CR_TCIE QUADSPI_CR_TCIE_Msk |
| #define | QUADSPI_CR_FTIE_Pos (18U) |
| #define | QUADSPI_CR_FTIE_Msk (0x1UL << QUADSPI_CR_FTIE_Pos) |
| #define | QUADSPI_CR_FTIE QUADSPI_CR_FTIE_Msk |
| #define | QUADSPI_CR_SMIE_Pos (19U) |
| #define | QUADSPI_CR_SMIE_Msk (0x1UL << QUADSPI_CR_SMIE_Pos) |
| #define | QUADSPI_CR_SMIE QUADSPI_CR_SMIE_Msk |
| #define | QUADSPI_CR_TOIE_Pos (20U) |
| #define | QUADSPI_CR_TOIE_Msk (0x1UL << QUADSPI_CR_TOIE_Pos) |
| #define | QUADSPI_CR_TOIE QUADSPI_CR_TOIE_Msk |
| #define | QUADSPI_CR_APMS_Pos (22U) |
| #define | QUADSPI_CR_APMS_Msk (0x1UL << QUADSPI_CR_APMS_Pos) |
| #define | QUADSPI_CR_APMS QUADSPI_CR_APMS_Msk |
| #define | QUADSPI_CR_PMM_Pos (23U) |
| #define | QUADSPI_CR_PMM_Msk (0x1UL << QUADSPI_CR_PMM_Pos) |
| #define | QUADSPI_CR_PMM QUADSPI_CR_PMM_Msk |
| #define | QUADSPI_CR_PRESCALER_Pos (24U) |
| #define | QUADSPI_CR_PRESCALER_Msk (0xFFUL << QUADSPI_CR_PRESCALER_Pos) |
| #define | QUADSPI_CR_PRESCALER QUADSPI_CR_PRESCALER_Msk |
| #define | QUADSPI_CR_PRESCALER_0 (0x01UL << QUADSPI_CR_PRESCALER_Pos) |
| #define | QUADSPI_CR_PRESCALER_1 (0x02UL << QUADSPI_CR_PRESCALER_Pos) |
| #define | QUADSPI_CR_PRESCALER_2 (0x04UL << QUADSPI_CR_PRESCALER_Pos) |
| #define | QUADSPI_CR_PRESCALER_3 (0x08UL << QUADSPI_CR_PRESCALER_Pos) |
| #define | QUADSPI_CR_PRESCALER_4 (0x10UL << QUADSPI_CR_PRESCALER_Pos) |
| #define | QUADSPI_CR_PRESCALER_5 (0x20UL << QUADSPI_CR_PRESCALER_Pos) |
| #define | QUADSPI_CR_PRESCALER_6 (0x40UL << QUADSPI_CR_PRESCALER_Pos) |
| #define | QUADSPI_CR_PRESCALER_7 (0x80UL << QUADSPI_CR_PRESCALER_Pos) |
| #define | QUADSPI_DCR_CKMODE_Pos (0U) |
| #define | QUADSPI_DCR_CKMODE_Msk (0x1UL << QUADSPI_DCR_CKMODE_Pos) |
| #define | QUADSPI_DCR_CKMODE QUADSPI_DCR_CKMODE_Msk |
| #define | QUADSPI_DCR_CSHT_Pos (8U) |
| #define | QUADSPI_DCR_CSHT_Msk (0x7UL << QUADSPI_DCR_CSHT_Pos) |
| #define | QUADSPI_DCR_CSHT QUADSPI_DCR_CSHT_Msk |
| #define | QUADSPI_DCR_CSHT_0 (0x1UL << QUADSPI_DCR_CSHT_Pos) |
| #define | QUADSPI_DCR_CSHT_1 (0x2UL << QUADSPI_DCR_CSHT_Pos) |
| #define | QUADSPI_DCR_CSHT_2 (0x4UL << QUADSPI_DCR_CSHT_Pos) |
| #define | QUADSPI_DCR_FSIZE_Pos (16U) |
| #define | QUADSPI_DCR_FSIZE_Msk (0x1FUL << QUADSPI_DCR_FSIZE_Pos) |
| #define | QUADSPI_DCR_FSIZE QUADSPI_DCR_FSIZE_Msk |
| #define | QUADSPI_DCR_FSIZE_0 (0x01UL << QUADSPI_DCR_FSIZE_Pos) |
| #define | QUADSPI_DCR_FSIZE_1 (0x02UL << QUADSPI_DCR_FSIZE_Pos) |
| #define | QUADSPI_DCR_FSIZE_2 (0x04UL << QUADSPI_DCR_FSIZE_Pos) |
| #define | QUADSPI_DCR_FSIZE_3 (0x08UL << QUADSPI_DCR_FSIZE_Pos) |
| #define | QUADSPI_DCR_FSIZE_4 (0x10UL << QUADSPI_DCR_FSIZE_Pos) |
| #define | QUADSPI_SR_TEF_Pos (0U) |
| #define | QUADSPI_SR_TEF_Msk (0x1UL << QUADSPI_SR_TEF_Pos) |
| #define | QUADSPI_SR_TEF QUADSPI_SR_TEF_Msk |
| #define | QUADSPI_SR_TCF_Pos (1U) |
| #define | QUADSPI_SR_TCF_Msk (0x1UL << QUADSPI_SR_TCF_Pos) |
| #define | QUADSPI_SR_TCF QUADSPI_SR_TCF_Msk |
| #define | QUADSPI_SR_FTF_Pos (2U) |
| #define | QUADSPI_SR_FTF_Msk (0x1UL << QUADSPI_SR_FTF_Pos) |
| #define | QUADSPI_SR_FTF QUADSPI_SR_FTF_Msk |
| #define | QUADSPI_SR_SMF_Pos (3U) |
| #define | QUADSPI_SR_SMF_Msk (0x1UL << QUADSPI_SR_SMF_Pos) |
| #define | QUADSPI_SR_SMF QUADSPI_SR_SMF_Msk |
| #define | QUADSPI_SR_TOF_Pos (4U) |
| #define | QUADSPI_SR_TOF_Msk (0x1UL << QUADSPI_SR_TOF_Pos) |
| #define | QUADSPI_SR_TOF QUADSPI_SR_TOF_Msk |
| #define | QUADSPI_SR_BUSY_Pos (5U) |
| #define | QUADSPI_SR_BUSY_Msk (0x1UL << QUADSPI_SR_BUSY_Pos) |
| #define | QUADSPI_SR_BUSY QUADSPI_SR_BUSY_Msk |
| #define | QUADSPI_SR_FLEVEL_Pos (8U) |
| #define | QUADSPI_SR_FLEVEL_Msk (0x3FUL << QUADSPI_SR_FLEVEL_Pos) |
| #define | QUADSPI_SR_FLEVEL QUADSPI_SR_FLEVEL_Msk |
| #define | QUADSPI_SR_FLEVEL_0 (0x01UL << QUADSPI_SR_FLEVEL_Pos) |
| #define | QUADSPI_SR_FLEVEL_1 (0x02UL << QUADSPI_SR_FLEVEL_Pos) |
| #define | QUADSPI_SR_FLEVEL_2 (0x04UL << QUADSPI_SR_FLEVEL_Pos) |
| #define | QUADSPI_SR_FLEVEL_3 (0x08UL << QUADSPI_SR_FLEVEL_Pos) |
| #define | QUADSPI_SR_FLEVEL_4 (0x10UL << QUADSPI_SR_FLEVEL_Pos) |
| #define | QUADSPI_SR_FLEVEL_5 (0x20UL << QUADSPI_SR_FLEVEL_Pos) |
| #define | QUADSPI_FCR_CTEF_Pos (0U) |
| #define | QUADSPI_FCR_CTEF_Msk (0x1UL << QUADSPI_FCR_CTEF_Pos) |
| #define | QUADSPI_FCR_CTEF QUADSPI_FCR_CTEF_Msk |
| #define | QUADSPI_FCR_CTCF_Pos (1U) |
| #define | QUADSPI_FCR_CTCF_Msk (0x1UL << QUADSPI_FCR_CTCF_Pos) |
| #define | QUADSPI_FCR_CTCF QUADSPI_FCR_CTCF_Msk |
| #define | QUADSPI_FCR_CSMF_Pos (3U) |
| #define | QUADSPI_FCR_CSMF_Msk (0x1UL << QUADSPI_FCR_CSMF_Pos) |
| #define | QUADSPI_FCR_CSMF QUADSPI_FCR_CSMF_Msk |
| #define | QUADSPI_FCR_CTOF_Pos (4U) |
| #define | QUADSPI_FCR_CTOF_Msk (0x1UL << QUADSPI_FCR_CTOF_Pos) |
| #define | QUADSPI_FCR_CTOF QUADSPI_FCR_CTOF_Msk |
| #define | QUADSPI_DLR_DL_Pos (0U) |
| #define | QUADSPI_DLR_DL_Msk (0xFFFFFFFFUL << QUADSPI_DLR_DL_Pos) |
| #define | QUADSPI_DLR_DL QUADSPI_DLR_DL_Msk |
| #define | QUADSPI_CCR_INSTRUCTION_Pos (0U) |
| #define | QUADSPI_CCR_INSTRUCTION_Msk (0xFFUL << QUADSPI_CCR_INSTRUCTION_Pos) |
| #define | QUADSPI_CCR_INSTRUCTION QUADSPI_CCR_INSTRUCTION_Msk |
| #define | QUADSPI_CCR_INSTRUCTION_0 (0x01UL << QUADSPI_CCR_INSTRUCTION_Pos) |
| #define | QUADSPI_CCR_INSTRUCTION_1 (0x02UL << QUADSPI_CCR_INSTRUCTION_Pos) |
| #define | QUADSPI_CCR_INSTRUCTION_2 (0x04UL << QUADSPI_CCR_INSTRUCTION_Pos) |
| #define | QUADSPI_CCR_INSTRUCTION_3 (0x08UL << QUADSPI_CCR_INSTRUCTION_Pos) |
| #define | QUADSPI_CCR_INSTRUCTION_4 (0x10UL << QUADSPI_CCR_INSTRUCTION_Pos) |
| #define | QUADSPI_CCR_INSTRUCTION_5 (0x20UL << QUADSPI_CCR_INSTRUCTION_Pos) |
| #define | QUADSPI_CCR_INSTRUCTION_6 (0x40UL << QUADSPI_CCR_INSTRUCTION_Pos) |
| #define | QUADSPI_CCR_INSTRUCTION_7 (0x80UL << QUADSPI_CCR_INSTRUCTION_Pos) |
| #define | QUADSPI_CCR_IMODE_Pos (8U) |
| #define | QUADSPI_CCR_IMODE_Msk (0x3UL << QUADSPI_CCR_IMODE_Pos) |
| #define | QUADSPI_CCR_IMODE QUADSPI_CCR_IMODE_Msk |
| #define | QUADSPI_CCR_IMODE_0 (0x1UL << QUADSPI_CCR_IMODE_Pos) |
| #define | QUADSPI_CCR_IMODE_1 (0x2UL << QUADSPI_CCR_IMODE_Pos) |
| #define | QUADSPI_CCR_ADMODE_Pos (10U) |
| #define | QUADSPI_CCR_ADMODE_Msk (0x3UL << QUADSPI_CCR_ADMODE_Pos) |
| #define | QUADSPI_CCR_ADMODE QUADSPI_CCR_ADMODE_Msk |
| #define | QUADSPI_CCR_ADMODE_0 (0x1UL << QUADSPI_CCR_ADMODE_Pos) |
| #define | QUADSPI_CCR_ADMODE_1 (0x2UL << QUADSPI_CCR_ADMODE_Pos) |
| #define | QUADSPI_CCR_ADSIZE_Pos (12U) |
| #define | QUADSPI_CCR_ADSIZE_Msk (0x3UL << QUADSPI_CCR_ADSIZE_Pos) |
| #define | QUADSPI_CCR_ADSIZE QUADSPI_CCR_ADSIZE_Msk |
| #define | QUADSPI_CCR_ADSIZE_0 (0x1UL << QUADSPI_CCR_ADSIZE_Pos) |
| #define | QUADSPI_CCR_ADSIZE_1 (0x2UL << QUADSPI_CCR_ADSIZE_Pos) |
| #define | QUADSPI_CCR_ABMODE_Pos (14U) |
| #define | QUADSPI_CCR_ABMODE_Msk (0x3UL << QUADSPI_CCR_ABMODE_Pos) |
| #define | QUADSPI_CCR_ABMODE QUADSPI_CCR_ABMODE_Msk |
| #define | QUADSPI_CCR_ABMODE_0 (0x1UL << QUADSPI_CCR_ABMODE_Pos) |
| #define | QUADSPI_CCR_ABMODE_1 (0x2UL << QUADSPI_CCR_ABMODE_Pos) |
| #define | QUADSPI_CCR_ABSIZE_Pos (16U) |
| #define | QUADSPI_CCR_ABSIZE_Msk (0x3UL << QUADSPI_CCR_ABSIZE_Pos) |
| #define | QUADSPI_CCR_ABSIZE QUADSPI_CCR_ABSIZE_Msk |
| #define | QUADSPI_CCR_ABSIZE_0 (0x1UL << QUADSPI_CCR_ABSIZE_Pos) |
| #define | QUADSPI_CCR_ABSIZE_1 (0x2UL << QUADSPI_CCR_ABSIZE_Pos) |
| #define | QUADSPI_CCR_DCYC_Pos (18U) |
| #define | QUADSPI_CCR_DCYC_Msk (0x1FUL << QUADSPI_CCR_DCYC_Pos) |
| #define | QUADSPI_CCR_DCYC QUADSPI_CCR_DCYC_Msk |
| #define | QUADSPI_CCR_DCYC_0 (0x01UL << QUADSPI_CCR_DCYC_Pos) |
| #define | QUADSPI_CCR_DCYC_1 (0x02UL << QUADSPI_CCR_DCYC_Pos) |
| #define | QUADSPI_CCR_DCYC_2 (0x04UL << QUADSPI_CCR_DCYC_Pos) |
| #define | QUADSPI_CCR_DCYC_3 (0x08UL << QUADSPI_CCR_DCYC_Pos) |
| #define | QUADSPI_CCR_DCYC_4 (0x10UL << QUADSPI_CCR_DCYC_Pos) |
| #define | QUADSPI_CCR_DMODE_Pos (24U) |
| #define | QUADSPI_CCR_DMODE_Msk (0x3UL << QUADSPI_CCR_DMODE_Pos) |
| #define | QUADSPI_CCR_DMODE QUADSPI_CCR_DMODE_Msk |
| #define | QUADSPI_CCR_DMODE_0 (0x1UL << QUADSPI_CCR_DMODE_Pos) |
| #define | QUADSPI_CCR_DMODE_1 (0x2UL << QUADSPI_CCR_DMODE_Pos) |
| #define | QUADSPI_CCR_FMODE_Pos (26U) |
| #define | QUADSPI_CCR_FMODE_Msk (0x3UL << QUADSPI_CCR_FMODE_Pos) |
| #define | QUADSPI_CCR_FMODE QUADSPI_CCR_FMODE_Msk |
| #define | QUADSPI_CCR_FMODE_0 (0x1UL << QUADSPI_CCR_FMODE_Pos) |
| #define | QUADSPI_CCR_FMODE_1 (0x2UL << QUADSPI_CCR_FMODE_Pos) |
| #define | QUADSPI_CCR_SIOO_Pos (28U) |
| #define | QUADSPI_CCR_SIOO_Msk (0x1UL << QUADSPI_CCR_SIOO_Pos) |
| #define | QUADSPI_CCR_SIOO QUADSPI_CCR_SIOO_Msk |
| #define | QUADSPI_CCR_DHHC_Pos (30U) |
| #define | QUADSPI_CCR_DHHC_Msk (0x1UL << QUADSPI_CCR_DHHC_Pos) |
| #define | QUADSPI_CCR_DHHC QUADSPI_CCR_DHHC_Msk |
| #define | QUADSPI_CCR_DDRM_Pos (31U) |
| #define | QUADSPI_CCR_DDRM_Msk (0x1UL << QUADSPI_CCR_DDRM_Pos) |
| #define | QUADSPI_CCR_DDRM QUADSPI_CCR_DDRM_Msk |
| #define | QUADSPI_AR_ADDRESS_Pos (0U) |
| #define | QUADSPI_AR_ADDRESS_Msk (0xFFFFFFFFUL << QUADSPI_AR_ADDRESS_Pos) |
| #define | QUADSPI_AR_ADDRESS QUADSPI_AR_ADDRESS_Msk |
| #define | QUADSPI_ABR_ALTERNATE_Pos (0U) |
| #define | QUADSPI_ABR_ALTERNATE_Msk (0xFFFFFFFFUL << QUADSPI_ABR_ALTERNATE_Pos) |
| #define | QUADSPI_ABR_ALTERNATE QUADSPI_ABR_ALTERNATE_Msk |
| #define | QUADSPI_DR_DATA_Pos (0U) |
| #define | QUADSPI_DR_DATA_Msk (0xFFFFFFFFUL << QUADSPI_DR_DATA_Pos) |
| #define | QUADSPI_DR_DATA QUADSPI_DR_DATA_Msk |
| #define | QUADSPI_PSMKR_MASK_Pos (0U) |
| #define | QUADSPI_PSMKR_MASK_Msk (0xFFFFFFFFUL << QUADSPI_PSMKR_MASK_Pos) |
| #define | QUADSPI_PSMKR_MASK QUADSPI_PSMKR_MASK_Msk |
| #define | QUADSPI_PSMAR_MATCH_Pos (0U) |
| #define | QUADSPI_PSMAR_MATCH_Msk (0xFFFFFFFFUL << QUADSPI_PSMAR_MATCH_Pos) |
| #define | QUADSPI_PSMAR_MATCH QUADSPI_PSMAR_MATCH_Msk |
| #define | QUADSPI_PIR_INTERVAL_Pos (0U) |
| #define | QUADSPI_PIR_INTERVAL_Msk (0xFFFFUL << QUADSPI_PIR_INTERVAL_Pos) |
| #define | QUADSPI_PIR_INTERVAL QUADSPI_PIR_INTERVAL_Msk |
| #define | QUADSPI_LPTR_TIMEOUT_Pos (0U) |
| #define | QUADSPI_LPTR_TIMEOUT_Msk (0xFFFFUL << QUADSPI_LPTR_TIMEOUT_Pos) |
| #define | QUADSPI_LPTR_TIMEOUT QUADSPI_LPTR_TIMEOUT_Msk |
| #define | SYSCFG_PMCR_I2C1_FMP_Pos (0U) |
| #define | SYSCFG_PMCR_I2C1_FMP_Msk (0x1UL << SYSCFG_PMCR_I2C1_FMP_Pos) |
| #define | SYSCFG_PMCR_I2C1_FMP SYSCFG_PMCR_I2C1_FMP_Msk |
| #define | SYSCFG_PMCR_I2C2_FMP_Pos (1U) |
| #define | SYSCFG_PMCR_I2C2_FMP_Msk (0x1UL << SYSCFG_PMCR_I2C2_FMP_Pos) |
| #define | SYSCFG_PMCR_I2C2_FMP SYSCFG_PMCR_I2C2_FMP_Msk |
| #define | SYSCFG_PMCR_I2C3_FMP_Pos (2U) |
| #define | SYSCFG_PMCR_I2C3_FMP_Msk (0x1UL << SYSCFG_PMCR_I2C3_FMP_Pos) |
| #define | SYSCFG_PMCR_I2C3_FMP SYSCFG_PMCR_I2C3_FMP_Msk |
| #define | SYSCFG_PMCR_I2C4_FMP_Pos (3U) |
| #define | SYSCFG_PMCR_I2C4_FMP_Msk (0x1UL << SYSCFG_PMCR_I2C4_FMP_Pos) |
| #define | SYSCFG_PMCR_I2C4_FMP SYSCFG_PMCR_I2C4_FMP_Msk |
| #define | SYSCFG_PMCR_I2C_PB6_FMP_Pos (4U) |
| #define | SYSCFG_PMCR_I2C_PB6_FMP_Msk (0x1UL << SYSCFG_PMCR_I2C_PB6_FMP_Pos) |
| #define | SYSCFG_PMCR_I2C_PB6_FMP SYSCFG_PMCR_I2C_PB6_FMP_Msk |
| #define | SYSCFG_PMCR_I2C_PB7_FMP_Pos (5U) |
| #define | SYSCFG_PMCR_I2C_PB7_FMP_Msk (0x1UL << SYSCFG_PMCR_I2C_PB7_FMP_Pos) |
| #define | SYSCFG_PMCR_I2C_PB7_FMP SYSCFG_PMCR_I2C_PB7_FMP_Msk |
| #define | SYSCFG_PMCR_I2C_PB8_FMP_Pos (6U) |
| #define | SYSCFG_PMCR_I2C_PB8_FMP_Msk (0x1UL << SYSCFG_PMCR_I2C_PB8_FMP_Pos) |
| #define | SYSCFG_PMCR_I2C_PB8_FMP SYSCFG_PMCR_I2C_PB8_FMP_Msk |
| #define | SYSCFG_PMCR_I2C_PB9_FMP_Pos (7U) |
| #define | SYSCFG_PMCR_I2C_PB9_FMP_Msk (0x1UL << SYSCFG_PMCR_I2C_PB9_FMP_Pos) |
| #define | SYSCFG_PMCR_I2C_PB9_FMP SYSCFG_PMCR_I2C_PB9_FMP_Msk |
| #define | SYSCFG_PMCR_BOOSTEN_Pos (8U) |
| #define | SYSCFG_PMCR_BOOSTEN_Msk (0x1UL << SYSCFG_PMCR_BOOSTEN_Pos) |
| #define | SYSCFG_PMCR_BOOSTEN SYSCFG_PMCR_BOOSTEN_Msk |
| #define | SYSCFG_PMCR_BOOSTVDDSEL_Pos (9U) |
| #define | SYSCFG_PMCR_BOOSTVDDSEL_Msk (0x1UL << SYSCFG_PMCR_BOOSTVDDSEL_Pos) |
| #define | SYSCFG_PMCR_BOOSTVDDSEL SYSCFG_PMCR_BOOSTVDDSEL_Msk |
| #define | SYSCFG_PMCR_EPIS_SEL_Pos (21U) |
| #define | SYSCFG_PMCR_EPIS_SEL_Msk (0x7UL << SYSCFG_PMCR_EPIS_SEL_Pos) |
| #define | SYSCFG_PMCR_EPIS_SEL SYSCFG_PMCR_EPIS_SEL_Msk |
| #define | SYSCFG_PMCR_EPIS_SEL_0 (0x1UL << SYSCFG_PMCR_EPIS_SEL_Pos) |
| #define | SYSCFG_PMCR_EPIS_SEL_1 (0x2UL << SYSCFG_PMCR_EPIS_SEL_Pos) |
| #define | SYSCFG_PMCR_EPIS_SEL_2 (0x4UL << SYSCFG_PMCR_EPIS_SEL_Pos) |
| #define | SYSCFG_PMCR_PA0SO_Pos (24U) |
| #define | SYSCFG_PMCR_PA0SO_Msk (0x1UL << SYSCFG_PMCR_PA0SO_Pos) |
| #define | SYSCFG_PMCR_PA0SO SYSCFG_PMCR_PA0SO_Msk |
| #define | SYSCFG_PMCR_PA1SO_Pos (25U) |
| #define | SYSCFG_PMCR_PA1SO_Msk (0x1UL << SYSCFG_PMCR_PA1SO_Pos) |
| #define | SYSCFG_PMCR_PA1SO SYSCFG_PMCR_PA1SO_Msk |
| #define | SYSCFG_PMCR_PC2SO_Pos (26U) |
| #define | SYSCFG_PMCR_PC2SO_Msk (0x1UL << SYSCFG_PMCR_PC2SO_Pos) |
| #define | SYSCFG_PMCR_PC2SO SYSCFG_PMCR_PC2SO_Msk |
| #define | SYSCFG_PMCR_PC3SO_Pos (27U) |
| #define | SYSCFG_PMCR_PC3SO_Msk (0x1UL << SYSCFG_PMCR_PC3SO_Pos) |
| #define | SYSCFG_PMCR_PC3SO SYSCFG_PMCR_PC3SO_Msk |
| #define | SYSCFG_EXTICR1_EXTI0_Pos (0U) |
| #define | SYSCFG_EXTICR1_EXTI0_Msk (0xFUL << SYSCFG_EXTICR1_EXTI0_Pos) |
| #define | SYSCFG_EXTICR1_EXTI0 SYSCFG_EXTICR1_EXTI0_Msk |
| #define | SYSCFG_EXTICR1_EXTI1_Pos (4U) |
| #define | SYSCFG_EXTICR1_EXTI1_Msk (0xFUL << SYSCFG_EXTICR1_EXTI1_Pos) |
| #define | SYSCFG_EXTICR1_EXTI1 SYSCFG_EXTICR1_EXTI1_Msk |
| #define | SYSCFG_EXTICR1_EXTI2_Pos (8U) |
| #define | SYSCFG_EXTICR1_EXTI2_Msk (0xFUL << SYSCFG_EXTICR1_EXTI2_Pos) |
| #define | SYSCFG_EXTICR1_EXTI2 SYSCFG_EXTICR1_EXTI2_Msk |
| #define | SYSCFG_EXTICR1_EXTI3_Pos (12U) |
| #define | SYSCFG_EXTICR1_EXTI3_Msk (0xFUL << SYSCFG_EXTICR1_EXTI3_Pos) |
| #define | SYSCFG_EXTICR1_EXTI3 SYSCFG_EXTICR1_EXTI3_Msk |
| #define | SYSCFG_EXTICR1_EXTI0_PA (0U) |
| EXTI0 configuration. | |
| #define | SYSCFG_EXTICR1_EXTI0_PB (0x00000001U) |
| #define | SYSCFG_EXTICR1_EXTI0_PC (0x00000002U) |
| #define | SYSCFG_EXTICR1_EXTI0_PD (0x00000003U) |
| #define | SYSCFG_EXTICR1_EXTI0_PE (0x00000004U) |
| #define | SYSCFG_EXTICR1_EXTI0_PF (0x00000005U) |
| #define | SYSCFG_EXTICR1_EXTI0_PG (0x00000006U) |
| #define | SYSCFG_EXTICR1_EXTI0_PH (0x00000007U) |
| #define | SYSCFG_EXTICR1_EXTI0_PI (0x00000008U) |
| #define | SYSCFG_EXTICR1_EXTI0_PJ (0x00000009U) |
| #define | SYSCFG_EXTICR1_EXTI0_PK (0x0000000AU) |
| #define | SYSCFG_EXTICR1_EXTI1_PA (0U) |
| EXTI1 configuration. | |
| #define | SYSCFG_EXTICR1_EXTI1_PB (0x00000010U) |
| #define | SYSCFG_EXTICR1_EXTI1_PC (0x00000020U) |
| #define | SYSCFG_EXTICR1_EXTI1_PD (0x00000030U) |
| #define | SYSCFG_EXTICR1_EXTI1_PE (0x00000040U) |
| #define | SYSCFG_EXTICR1_EXTI1_PF (0x00000050U) |
| #define | SYSCFG_EXTICR1_EXTI1_PG (0x00000060U) |
| #define | SYSCFG_EXTICR1_EXTI1_PH (0x00000070U) |
| #define | SYSCFG_EXTICR1_EXTI1_PI (0x00000080U) |
| #define | SYSCFG_EXTICR1_EXTI1_PJ (0x00000090U) |
| #define | SYSCFG_EXTICR1_EXTI1_PK (0x000000A0U) |
| #define | SYSCFG_EXTICR1_EXTI2_PA (0U) |
| EXTI2 configuration. | |
| #define | SYSCFG_EXTICR1_EXTI2_PB (0x00000100U) |
| #define | SYSCFG_EXTICR1_EXTI2_PC (0x00000200U) |
| #define | SYSCFG_EXTICR1_EXTI2_PD (0x00000300U) |
| #define | SYSCFG_EXTICR1_EXTI2_PE (0x00000400U) |
| #define | SYSCFG_EXTICR1_EXTI2_PF (0x00000500U) |
| #define | SYSCFG_EXTICR1_EXTI2_PG (0x00000600U) |
| #define | SYSCFG_EXTICR1_EXTI2_PH (0x00000700U) |
| #define | SYSCFG_EXTICR1_EXTI2_PI (0x00000800U) |
| #define | SYSCFG_EXTICR1_EXTI2_PJ (0x00000900U) |
| #define | SYSCFG_EXTICR1_EXTI2_PK (0x00000A00U) |
| #define | SYSCFG_EXTICR1_EXTI3_PA (0U) |
| EXTI3 configuration. | |
| #define | SYSCFG_EXTICR1_EXTI3_PB (0x00001000U) |
| #define | SYSCFG_EXTICR1_EXTI3_PC (0x00002000U) |
| #define | SYSCFG_EXTICR1_EXTI3_PD (0x00003000U) |
| #define | SYSCFG_EXTICR1_EXTI3_PE (0x00004000U) |
| #define | SYSCFG_EXTICR1_EXTI3_PF (0x00005000U) |
| #define | SYSCFG_EXTICR1_EXTI3_PG (0x00006000U) |
| #define | SYSCFG_EXTICR1_EXTI3_PH (0x00007000U) |
| #define | SYSCFG_EXTICR1_EXTI3_PI (0x00008000U) |
| #define | SYSCFG_EXTICR1_EXTI3_PJ (0x00009000U) |
| #define | SYSCFG_EXTICR1_EXTI3_PK (0x0000A000U) |
| #define | SYSCFG_EXTICR2_EXTI4_Pos (0U) |
| #define | SYSCFG_EXTICR2_EXTI4_Msk (0xFUL << SYSCFG_EXTICR2_EXTI4_Pos) |
| #define | SYSCFG_EXTICR2_EXTI4 SYSCFG_EXTICR2_EXTI4_Msk |
| #define | SYSCFG_EXTICR2_EXTI5_Pos (4U) |
| #define | SYSCFG_EXTICR2_EXTI5_Msk (0xFUL << SYSCFG_EXTICR2_EXTI5_Pos) |
| #define | SYSCFG_EXTICR2_EXTI5 SYSCFG_EXTICR2_EXTI5_Msk |
| #define | SYSCFG_EXTICR2_EXTI6_Pos (8U) |
| #define | SYSCFG_EXTICR2_EXTI6_Msk (0xFUL << SYSCFG_EXTICR2_EXTI6_Pos) |
| #define | SYSCFG_EXTICR2_EXTI6 SYSCFG_EXTICR2_EXTI6_Msk |
| #define | SYSCFG_EXTICR2_EXTI7_Pos (12U) |
| #define | SYSCFG_EXTICR2_EXTI7_Msk (0xFUL << SYSCFG_EXTICR2_EXTI7_Pos) |
| #define | SYSCFG_EXTICR2_EXTI7 SYSCFG_EXTICR2_EXTI7_Msk |
| #define | SYSCFG_EXTICR2_EXTI4_PA (0U) |
| EXTI4 configuration. | |
| #define | SYSCFG_EXTICR2_EXTI4_PB (0x00000001U) |
| #define | SYSCFG_EXTICR2_EXTI4_PC (0x00000002U) |
| #define | SYSCFG_EXTICR2_EXTI4_PD (0x00000003U) |
| #define | SYSCFG_EXTICR2_EXTI4_PE (0x00000004U) |
| #define | SYSCFG_EXTICR2_EXTI4_PF (0x00000005U) |
| #define | SYSCFG_EXTICR2_EXTI4_PG (0x00000006U) |
| #define | SYSCFG_EXTICR2_EXTI4_PH (0x00000007U) |
| #define | SYSCFG_EXTICR2_EXTI4_PI (0x00000008U) |
| #define | SYSCFG_EXTICR2_EXTI4_PJ (0x00000009U) |
| #define | SYSCFG_EXTICR2_EXTI4_PK (0x0000000AU) |
| #define | SYSCFG_EXTICR2_EXTI5_PA (0U) |
| EXTI5 configuration. | |
| #define | SYSCFG_EXTICR2_EXTI5_PB (0x00000010U) |
| #define | SYSCFG_EXTICR2_EXTI5_PC (0x00000020U) |
| #define | SYSCFG_EXTICR2_EXTI5_PD (0x00000030U) |
| #define | SYSCFG_EXTICR2_EXTI5_PE (0x00000040U) |
| #define | SYSCFG_EXTICR2_EXTI5_PF (0x00000050U) |
| #define | SYSCFG_EXTICR2_EXTI5_PG (0x00000060U) |
| #define | SYSCFG_EXTICR2_EXTI5_PH (0x00000070U) |
| #define | SYSCFG_EXTICR2_EXTI5_PI (0x00000080U) |
| #define | SYSCFG_EXTICR2_EXTI5_PJ (0x00000090U) |
| #define | SYSCFG_EXTICR2_EXTI5_PK (0x000000A0U) |
| #define | SYSCFG_EXTICR2_EXTI6_PA (0U) |
| EXTI6 configuration. | |
| #define | SYSCFG_EXTICR2_EXTI6_PB (0x00000100U) |
| #define | SYSCFG_EXTICR2_EXTI6_PC (0x00000200U) |
| #define | SYSCFG_EXTICR2_EXTI6_PD (0x00000300U) |
| #define | SYSCFG_EXTICR2_EXTI6_PE (0x00000400U) |
| #define | SYSCFG_EXTICR2_EXTI6_PF (0x00000500U) |
| #define | SYSCFG_EXTICR2_EXTI6_PG (0x00000600U) |
| #define | SYSCFG_EXTICR2_EXTI6_PH (0x00000700U) |
| #define | SYSCFG_EXTICR2_EXTI6_PI (0x00000800U) |
| #define | SYSCFG_EXTICR2_EXTI6_PJ (0x00000900U) |
| #define | SYSCFG_EXTICR2_EXTI6_PK (0x00000A00U) |
| #define | SYSCFG_EXTICR2_EXTI7_PA (0U) |
| EXTI7 configuration. | |
| #define | SYSCFG_EXTICR2_EXTI7_PB (0x00001000U) |
| #define | SYSCFG_EXTICR2_EXTI7_PC (0x00002000U) |
| #define | SYSCFG_EXTICR2_EXTI7_PD (0x00003000U) |
| #define | SYSCFG_EXTICR2_EXTI7_PE (0x00004000U) |
| #define | SYSCFG_EXTICR2_EXTI7_PF (0x00005000U) |
| #define | SYSCFG_EXTICR2_EXTI7_PG (0x00006000U) |
| #define | SYSCFG_EXTICR2_EXTI7_PH (0x00007000U) |
| #define | SYSCFG_EXTICR2_EXTI7_PI (0x00008000U) |
| #define | SYSCFG_EXTICR2_EXTI7_PJ (0x00009000U) |
| #define | SYSCFG_EXTICR2_EXTI7_PK (0x0000A000U) |
| #define | SYSCFG_EXTICR3_EXTI8_Pos (0U) |
| #define | SYSCFG_EXTICR3_EXTI8_Msk (0xFUL << SYSCFG_EXTICR3_EXTI8_Pos) |
| #define | SYSCFG_EXTICR3_EXTI8 SYSCFG_EXTICR3_EXTI8_Msk |
| #define | SYSCFG_EXTICR3_EXTI9_Pos (4U) |
| #define | SYSCFG_EXTICR3_EXTI9_Msk (0xFUL << SYSCFG_EXTICR3_EXTI9_Pos) |
| #define | SYSCFG_EXTICR3_EXTI9 SYSCFG_EXTICR3_EXTI9_Msk |
| #define | SYSCFG_EXTICR3_EXTI10_Pos (8U) |
| #define | SYSCFG_EXTICR3_EXTI10_Msk (0xFUL << SYSCFG_EXTICR3_EXTI10_Pos) |
| #define | SYSCFG_EXTICR3_EXTI10 SYSCFG_EXTICR3_EXTI10_Msk |
| #define | SYSCFG_EXTICR3_EXTI11_Pos (12U) |
| #define | SYSCFG_EXTICR3_EXTI11_Msk (0xFUL << SYSCFG_EXTICR3_EXTI11_Pos) |
| #define | SYSCFG_EXTICR3_EXTI11 SYSCFG_EXTICR3_EXTI11_Msk |
| #define | SYSCFG_EXTICR3_EXTI8_PA (0U) |
| EXTI8 configuration. | |
| #define | SYSCFG_EXTICR3_EXTI8_PB (0x00000001U) |
| #define | SYSCFG_EXTICR3_EXTI8_PC (0x00000002U) |
| #define | SYSCFG_EXTICR3_EXTI8_PD (0x00000003U) |
| #define | SYSCFG_EXTICR3_EXTI8_PE (0x00000004U) |
| #define | SYSCFG_EXTICR3_EXTI8_PF (0x00000005U) |
| #define | SYSCFG_EXTICR3_EXTI8_PG (0x00000006U) |
| #define | SYSCFG_EXTICR3_EXTI8_PH (0x00000007U) |
| #define | SYSCFG_EXTICR3_EXTI8_PI (0x00000008U) |
| #define | SYSCFG_EXTICR3_EXTI8_PJ (0x00000009U) |
| #define | SYSCFG_EXTICR3_EXTI8_PK (0x0000000AU) |
| #define | SYSCFG_EXTICR3_EXTI9_PA (0U) |
| EXTI9 configuration. | |
| #define | SYSCFG_EXTICR3_EXTI9_PB (0x00000010U) |
| #define | SYSCFG_EXTICR3_EXTI9_PC (0x00000020U) |
| #define | SYSCFG_EXTICR3_EXTI9_PD (0x00000030U) |
| #define | SYSCFG_EXTICR3_EXTI9_PE (0x00000040U) |
| #define | SYSCFG_EXTICR3_EXTI9_PF (0x00000050U) |
| #define | SYSCFG_EXTICR3_EXTI9_PG (0x00000060U) |
| #define | SYSCFG_EXTICR3_EXTI9_PH (0x00000070U) |
| #define | SYSCFG_EXTICR3_EXTI9_PI (0x00000080U) |
| #define | SYSCFG_EXTICR3_EXTI9_PJ (0x00000090U) |
| #define | SYSCFG_EXTICR3_EXTI9_PK (0x000000A0U) |
| #define | SYSCFG_EXTICR3_EXTI10_PA (0U) |
| EXTI10 configuration. | |
| #define | SYSCFG_EXTICR3_EXTI10_PB (0x00000100U) |
| #define | SYSCFG_EXTICR3_EXTI10_PC (0x00000200U) |
| #define | SYSCFG_EXTICR3_EXTI10_PD (0x00000300U) |
| #define | SYSCFG_EXTICR3_EXTI10_PE (0x00000400U) |
| #define | SYSCFG_EXTICR3_EXTI10_PF (0x00000500U) |
| #define | SYSCFG_EXTICR3_EXTI10_PG (0x00000600U) |
| #define | SYSCFG_EXTICR3_EXTI10_PH (0x00000700U) |
| #define | SYSCFG_EXTICR3_EXTI10_PI (0x00000800U) |
| #define | SYSCFG_EXTICR3_EXTI10_PJ (0x00000900U) |
| #define | SYSCFG_EXTICR3_EXTI10_PK (0x00000A00U) |
| #define | SYSCFG_EXTICR3_EXTI11_PA (0U) |
| EXTI11 configuration. | |
| #define | SYSCFG_EXTICR3_EXTI11_PB (0x00001000U) |
| #define | SYSCFG_EXTICR3_EXTI11_PC (0x00002000U) |
| #define | SYSCFG_EXTICR3_EXTI11_PD (0x00003000U) |
| #define | SYSCFG_EXTICR3_EXTI11_PE (0x00004000U) |
| #define | SYSCFG_EXTICR3_EXTI11_PF (0x00005000U) |
| #define | SYSCFG_EXTICR3_EXTI11_PG (0x00006000U) |
| #define | SYSCFG_EXTICR3_EXTI11_PH (0x00007000U) |
| #define | SYSCFG_EXTICR3_EXTI11_PI (0x00008000U) |
| #define | SYSCFG_EXTICR3_EXTI11_PJ (0x00009000U) |
| #define | SYSCFG_EXTICR3_EXTI11_PK (0x0000A000U) |
| #define | SYSCFG_EXTICR4_EXTI12_Pos (0U) |
| #define | SYSCFG_EXTICR4_EXTI12_Msk (0xFUL << SYSCFG_EXTICR4_EXTI12_Pos) |
| #define | SYSCFG_EXTICR4_EXTI12 SYSCFG_EXTICR4_EXTI12_Msk |
| #define | SYSCFG_EXTICR4_EXTI13_Pos (4U) |
| #define | SYSCFG_EXTICR4_EXTI13_Msk (0xFUL << SYSCFG_EXTICR4_EXTI13_Pos) |
| #define | SYSCFG_EXTICR4_EXTI13 SYSCFG_EXTICR4_EXTI13_Msk |
| #define | SYSCFG_EXTICR4_EXTI14_Pos (8U) |
| #define | SYSCFG_EXTICR4_EXTI14_Msk (0xFUL << SYSCFG_EXTICR4_EXTI14_Pos) |
| #define | SYSCFG_EXTICR4_EXTI14 SYSCFG_EXTICR4_EXTI14_Msk |
| #define | SYSCFG_EXTICR4_EXTI15_Pos (12U) |
| #define | SYSCFG_EXTICR4_EXTI15_Msk (0xFUL << SYSCFG_EXTICR4_EXTI15_Pos) |
| #define | SYSCFG_EXTICR4_EXTI15 SYSCFG_EXTICR4_EXTI15_Msk |
| #define | SYSCFG_EXTICR4_EXTI12_PA (0U) |
| EXTI12 configuration. | |
| #define | SYSCFG_EXTICR4_EXTI12_PB (0x00000001U) |
| #define | SYSCFG_EXTICR4_EXTI12_PC (0x00000002U) |
| #define | SYSCFG_EXTICR4_EXTI12_PD (0x00000003U) |
| #define | SYSCFG_EXTICR4_EXTI12_PE (0x00000004U) |
| #define | SYSCFG_EXTICR4_EXTI12_PF (0x00000005U) |
| #define | SYSCFG_EXTICR4_EXTI12_PG (0x00000006U) |
| #define | SYSCFG_EXTICR4_EXTI12_PH (0x00000007U) |
| #define | SYSCFG_EXTICR4_EXTI12_PI (0x00000008U) |
| #define | SYSCFG_EXTICR4_EXTI12_PJ (0x00000009U) |
| #define | SYSCFG_EXTICR4_EXTI12_PK (0x0000000AU) |
| #define | SYSCFG_EXTICR4_EXTI13_PA (0U) |
| EXTI13 configuration. | |
| #define | SYSCFG_EXTICR4_EXTI13_PB (0x00000010U) |
| #define | SYSCFG_EXTICR4_EXTI13_PC (0x00000020U) |
| #define | SYSCFG_EXTICR4_EXTI13_PD (0x00000030U) |
| #define | SYSCFG_EXTICR4_EXTI13_PE (0x00000040U) |
| #define | SYSCFG_EXTICR4_EXTI13_PF (0x00000050U) |
| #define | SYSCFG_EXTICR4_EXTI13_PG (0x00000060U) |
| #define | SYSCFG_EXTICR4_EXTI13_PH (0x00000070U) |
| #define | SYSCFG_EXTICR4_EXTI13_PI (0x00000080U) |
| #define | SYSCFG_EXTICR4_EXTI13_PJ (0x00000090U) |
| #define | SYSCFG_EXTICR4_EXTI13_PK (0x000000A0U) |
| #define | SYSCFG_EXTICR4_EXTI14_PA (0U) |
| EXTI14 configuration. | |
| #define | SYSCFG_EXTICR4_EXTI14_PB (0x00000100U) |
| #define | SYSCFG_EXTICR4_EXTI14_PC (0x00000200U) |
| #define | SYSCFG_EXTICR4_EXTI14_PD (0x00000300U) |
| #define | SYSCFG_EXTICR4_EXTI14_PE (0x00000400U) |
| #define | SYSCFG_EXTICR4_EXTI14_PF (0x00000500U) |
| #define | SYSCFG_EXTICR4_EXTI14_PG (0x00000600U) |
| #define | SYSCFG_EXTICR4_EXTI14_PH (0x00000700U) |
| #define | SYSCFG_EXTICR4_EXTI14_PI (0x00000800U) |
| #define | SYSCFG_EXTICR4_EXTI14_PJ (0x00000900U) |
| #define | SYSCFG_EXTICR4_EXTI14_PK (0x00000A00U) |
| #define | SYSCFG_EXTICR4_EXTI15_PA (0U) |
| EXTI15 configuration. | |
| #define | SYSCFG_EXTICR4_EXTI15_PB (0x00001000U) |
| #define | SYSCFG_EXTICR4_EXTI15_PC (0x00002000U) |
| #define | SYSCFG_EXTICR4_EXTI15_PD (0x00003000U) |
| #define | SYSCFG_EXTICR4_EXTI15_PE (0x00004000U) |
| #define | SYSCFG_EXTICR4_EXTI15_PF (0x00005000U) |
| #define | SYSCFG_EXTICR4_EXTI15_PG (0x00006000U) |
| #define | SYSCFG_EXTICR4_EXTI15_PH (0x00007000U) |
| #define | SYSCFG_EXTICR4_EXTI15_PI (0x00008000U) |
| #define | SYSCFG_EXTICR4_EXTI15_PJ (0x00009000U) |
| #define | SYSCFG_EXTICR4_EXTI15_PK (0x0000A000U) |
| #define | SYSCFG_CFGR_PVDL_Pos (2U) |
| #define | SYSCFG_CFGR_PVDL_Msk (0x1UL << SYSCFG_CFGR_PVDL_Pos) |
| #define | SYSCFG_CFGR_PVDL SYSCFG_CFGR_PVDL_Msk |
| #define | SYSCFG_CFGR_FLASHL_Pos (3U) |
| #define | SYSCFG_CFGR_FLASHL_Msk (0x1UL << SYSCFG_CFGR_FLASHL_Pos) |
| #define | SYSCFG_CFGR_FLASHL SYSCFG_CFGR_FLASHL_Msk |
| #define | SYSCFG_CFGR_CM7L_Pos (6U) |
| #define | SYSCFG_CFGR_CM7L_Msk (0x1UL << SYSCFG_CFGR_CM7L_Pos) |
| #define | SYSCFG_CFGR_CM7L SYSCFG_CFGR_CM7L_Msk |
| #define | SYSCFG_CFGR_BKRAML_Pos (7U) |
| #define | SYSCFG_CFGR_BKRAML_Msk (0x1UL << SYSCFG_CFGR_BKRAML_Pos) |
| #define | SYSCFG_CFGR_BKRAML SYSCFG_CFGR_BKRAML_Msk |
| #define | SYSCFG_CFGR_SRAM4L_Pos (9U) |
| #define | SYSCFG_CFGR_SRAM4L_Msk (0x1UL << SYSCFG_CFGR_SRAM4L_Pos) |
| #define | SYSCFG_CFGR_SRAM4L SYSCFG_CFGR_SRAM4L_Msk |
| #define | SYSCFG_CFGR_SRAM3L_Pos (10U) |
| #define | SYSCFG_CFGR_SRAM3L_Msk (0x1UL << SYSCFG_CFGR_SRAM3L_Pos) |
| #define | SYSCFG_CFGR_SRAM3L SYSCFG_CFGR_SRAM3L_Msk |
| #define | SYSCFG_CFGR_SRAM2L_Pos (11U) |
| #define | SYSCFG_CFGR_SRAM2L_Msk (0x1UL << SYSCFG_CFGR_SRAM2L_Pos) |
| #define | SYSCFG_CFGR_SRAM2L SYSCFG_CFGR_SRAM2L_Msk |
| #define | SYSCFG_CFGR_SRAM1L_Pos (12U) |
| #define | SYSCFG_CFGR_SRAM1L_Msk (0x1UL << SYSCFG_CFGR_SRAM1L_Pos) |
| #define | SYSCFG_CFGR_SRAM1L SYSCFG_CFGR_SRAM1L_Msk |
| #define | SYSCFG_CFGR_DTCML_Pos (13U) |
| #define | SYSCFG_CFGR_DTCML_Msk (0x1UL << SYSCFG_CFGR_DTCML_Pos) |
| #define | SYSCFG_CFGR_DTCML SYSCFG_CFGR_DTCML_Msk |
| #define | SYSCFG_CFGR_ITCML_Pos (14U) |
| #define | SYSCFG_CFGR_ITCML_Msk (0x1UL << SYSCFG_CFGR_ITCML_Pos) |
| #define | SYSCFG_CFGR_ITCML SYSCFG_CFGR_ITCML_Msk |
| #define | SYSCFG_CFGR_AXISRAML_Pos (15U) |
| #define | SYSCFG_CFGR_AXISRAML_Msk (0x1UL << SYSCFG_CFGR_AXISRAML_Pos) |
| #define | SYSCFG_CFGR_AXISRAML SYSCFG_CFGR_AXISRAML_Msk |
| #define | SYSCFG_CCCSR_EN_Pos (0U) |
| #define | SYSCFG_CCCSR_EN_Msk (0x1UL << SYSCFG_CCCSR_EN_Pos) |
| #define | SYSCFG_CCCSR_EN SYSCFG_CCCSR_EN_Msk |
| #define | SYSCFG_CCCSR_CS_Pos (1U) |
| #define | SYSCFG_CCCSR_CS_Msk (0x1UL << SYSCFG_CCCSR_CS_Pos) |
| #define | SYSCFG_CCCSR_CS SYSCFG_CCCSR_CS_Msk |
| #define | SYSCFG_CCCSR_READY_Pos (8U) |
| #define | SYSCFG_CCCSR_READY_Msk (0x1UL << SYSCFG_CCCSR_READY_Pos) |
| #define | SYSCFG_CCCSR_READY SYSCFG_CCCSR_READY_Msk |
| #define | SYSCFG_CCCSR_HSLV_Pos (16U) |
| #define | SYSCFG_CCCSR_HSLV_Msk (0x1UL << SYSCFG_CCCSR_HSLV_Pos) |
| #define | SYSCFG_CCCSR_HSLV SYSCFG_CCCSR_HSLV_Msk |
| #define | SYSCFG_CCVR_NCV_Pos (0U) |
| #define | SYSCFG_CCVR_NCV_Msk (0xFUL << SYSCFG_CCVR_NCV_Pos) |
| #define | SYSCFG_CCVR_NCV SYSCFG_CCVR_NCV_Msk |
| #define | SYSCFG_CCVR_PCV_Pos (4U) |
| #define | SYSCFG_CCVR_PCV_Msk (0xFUL << SYSCFG_CCVR_PCV_Pos) |
| #define | SYSCFG_CCVR_PCV SYSCFG_CCVR_PCV_Msk |
| #define | SYSCFG_CCCR_NCC_Pos (0U) |
| #define | SYSCFG_CCCR_NCC_Msk (0xFUL << SYSCFG_CCCR_NCC_Pos) |
| #define | SYSCFG_CCCR_NCC SYSCFG_CCCR_NCC_Msk |
| #define | SYSCFG_CCCR_PCC_Pos (4U) |
| #define | SYSCFG_CCCR_PCC_Msk (0xFUL << SYSCFG_CCCR_PCC_Pos) |
| #define | SYSCFG_CCCR_PCC SYSCFG_CCCR_PCC_Msk |
| #define | SYSCFG_PWRCR_ODEN_Pos (0U) |
| #define | SYSCFG_PWRCR_ODEN_Msk (0x1UL << SYSCFG_PWRCR_ODEN_Pos) |
| #define | SYSCFG_PWRCR_ODEN SYSCFG_PWRCR_ODEN_Msk |
| #define | SYSCFG_PKGR_PKG_Pos (0U) |
| #define | SYSCFG_PKGR_PKG_Msk (0xFUL << SYSCFG_PKGR_PKG_Pos) |
| #define | SYSCFG_PKGR_PKG SYSCFG_PKGR_PKG_Msk |
| #define | SYSCFG_UR0_BKS_Pos (0U) |
| #define | SYSCFG_UR0_BKS_Msk (0x1UL << SYSCFG_UR0_BKS_Pos) |
| #define | SYSCFG_UR0_BKS SYSCFG_UR0_BKS_Msk |
| #define | SYSCFG_UR0_RDP_Pos (16U) |
| #define | SYSCFG_UR0_RDP_Msk (0xFFUL << SYSCFG_UR0_RDP_Pos) |
| #define | SYSCFG_UR0_RDP SYSCFG_UR0_RDP_Msk |
| #define | SYSCFG_UR2_BORH_Pos (0U) |
| #define | SYSCFG_UR2_BORH_Msk (0x3UL << SYSCFG_UR2_BORH_Pos) |
| #define | SYSCFG_UR2_BORH SYSCFG_UR2_BORH_Msk |
| #define | SYSCFG_UR2_BORH_0 (0x1UL << SYSCFG_UR2_BORH_Pos) |
| #define | SYSCFG_UR2_BORH_1 (0x2UL << SYSCFG_UR2_BORH_Pos) |
| #define | SYSCFG_UR2_BOOT_ADD0_Pos (16U) |
| #define | SYSCFG_UR2_BOOT_ADD0_Msk (0xFFFFUL << SYSCFG_UR2_BOOT_ADD0_Pos) |
| #define | SYSCFG_UR2_BOOT_ADD0 SYSCFG_UR2_BOOT_ADD0_Msk |
| #define | SYSCFG_UR3_BOOT_ADD1_Pos (0U) |
| #define | SYSCFG_UR3_BOOT_ADD1_Msk (0xFFFFUL << SYSCFG_UR3_BOOT_ADD1_Pos) |
| #define | SYSCFG_UR3_BOOT_ADD1 SYSCFG_UR3_BOOT_ADD1_Msk |
| #define | SYSCFG_UR4_MEPAD_BANK1_Pos (16U) |
| #define | SYSCFG_UR4_MEPAD_BANK1_Msk (0x1UL << SYSCFG_UR4_MEPAD_BANK1_Pos) |
| #define | SYSCFG_UR4_MEPAD_BANK1 SYSCFG_UR4_MEPAD_BANK1_Msk |
| #define | SYSCFG_UR5_MESAD_BANK1_Pos (0U) |
| #define | SYSCFG_UR5_MESAD_BANK1_Msk (0x1UL << SYSCFG_UR5_MESAD_BANK1_Pos) |
| #define | SYSCFG_UR5_MESAD_BANK1 SYSCFG_UR5_MESAD_BANK1_Msk |
| #define | SYSCFG_UR5_WRPN_BANK1_Pos (16U) |
| #define | SYSCFG_UR5_WRPN_BANK1_Msk (0xFFUL << SYSCFG_UR5_WRPN_BANK1_Pos) |
| #define | SYSCFG_UR5_WRPN_BANK1 SYSCFG_UR5_WRPN_BANK1_Msk |
| #define | SYSCFG_UR6_PABEG_BANK1_Pos (0U) |
| #define | SYSCFG_UR6_PABEG_BANK1_Msk (0xFFFUL << SYSCFG_UR6_PABEG_BANK1_Pos) |
| #define | SYSCFG_UR6_PABEG_BANK1 SYSCFG_UR6_PABEG_BANK1_Msk |
| #define | SYSCFG_UR6_PAEND_BANK1_Pos (16U) |
| #define | SYSCFG_UR6_PAEND_BANK1_Msk (0xFFFUL << SYSCFG_UR6_PAEND_BANK1_Pos) |
| #define | SYSCFG_UR6_PAEND_BANK1 SYSCFG_UR6_PAEND_BANK1_Msk |
| #define | SYSCFG_UR7_SABEG_BANK1_Pos (0U) |
| #define | SYSCFG_UR7_SABEG_BANK1_Msk (0xFFFUL << SYSCFG_UR7_SABEG_BANK1_Pos) |
| #define | SYSCFG_UR7_SABEG_BANK1 SYSCFG_UR7_SABEG_BANK1_Msk |
| #define | SYSCFG_UR7_SAEND_BANK1_Pos (16U) |
| #define | SYSCFG_UR7_SAEND_BANK1_Msk (0xFFFUL << SYSCFG_UR7_SAEND_BANK1_Pos) |
| #define | SYSCFG_UR7_SAEND_BANK1 SYSCFG_UR7_SAEND_BANK1_Msk |
| #define | SYSCFG_UR8_MEPAD_BANK2_Pos (0U) |
| #define | SYSCFG_UR8_MEPAD_BANK2_Msk (0x1UL << SYSCFG_UR8_MEPAD_BANK2_Pos) |
| #define | SYSCFG_UR8_MEPAD_BANK2 SYSCFG_UR8_MEPAD_BANK2_Msk |
| #define | SYSCFG_UR8_MESAD_BANK2_Pos (16U) |
| #define | SYSCFG_UR8_MESAD_BANK2_Msk (0x1UL << SYSCFG_UR8_MESAD_BANK2_Pos) |
| #define | SYSCFG_UR8_MESAD_BANK2 SYSCFG_UR8_MESAD_BANK2_Msk |
| #define | SYSCFG_UR9_WRPN_BANK2_Pos (0U) |
| #define | SYSCFG_UR9_WRPN_BANK2_Msk (0xFFUL << SYSCFG_UR9_WRPN_BANK2_Pos) |
| #define | SYSCFG_UR9_WRPN_BANK2 SYSCFG_UR9_WRPN_BANK2_Msk |
| #define | SYSCFG_UR9_PABEG_BANK2_Pos (16U) |
| #define | SYSCFG_UR9_PABEG_BANK2_Msk (0xFFFUL << SYSCFG_UR9_PABEG_BANK2_Pos) |
| #define | SYSCFG_UR9_PABEG_BANK2 SYSCFG_UR9_PABEG_BANK2_Msk |
| #define | SYSCFG_UR10_PAEND_BANK2_Pos (0U) |
| #define | SYSCFG_UR10_PAEND_BANK2_Msk (0xFFFUL << SYSCFG_UR10_PAEND_BANK2_Pos) |
| #define | SYSCFG_UR10_PAEND_BANK2 SYSCFG_UR10_PAEND_BANK2_Msk |
| #define | SYSCFG_UR10_SABEG_BANK2_Pos (16U) |
| #define | SYSCFG_UR10_SABEG_BANK2_Msk (0xFFFUL << SYSCFG_UR10_SABEG_BANK2_Pos) |
| #define | SYSCFG_UR10_SABEG_BANK2 SYSCFG_UR10_SABEG_BANK2_Msk |
| #define | SYSCFG_UR11_SAEND_BANK2_Pos (0U) |
| #define | SYSCFG_UR11_SAEND_BANK2_Msk (0xFFFUL << SYSCFG_UR11_SAEND_BANK2_Pos) |
| #define | SYSCFG_UR11_SAEND_BANK2 SYSCFG_UR11_SAEND_BANK2_Msk |
| #define | SYSCFG_UR11_IWDG1M_Pos (16U) |
| #define | SYSCFG_UR11_IWDG1M_Msk (0x1UL << SYSCFG_UR11_IWDG1M_Pos) |
| #define | SYSCFG_UR11_IWDG1M SYSCFG_UR11_IWDG1M_Msk |
| #define | SYSCFG_UR12_SECURE_Pos (16U) |
| #define | SYSCFG_UR12_SECURE_Msk (0x1UL << SYSCFG_UR12_SECURE_Pos) |
| #define | SYSCFG_UR12_SECURE SYSCFG_UR12_SECURE_Msk |
| #define | SYSCFG_UR13_SDRS_Pos (0U) |
| #define | SYSCFG_UR13_SDRS_Msk (0x3UL << SYSCFG_UR13_SDRS_Pos) |
| #define | SYSCFG_UR13_SDRS SYSCFG_UR13_SDRS_Msk |
| #define | SYSCFG_UR13_D1SBRST_Pos (16U) |
| #define | SYSCFG_UR13_D1SBRST_Msk (0x1UL << SYSCFG_UR13_D1SBRST_Pos) |
| #define | SYSCFG_UR13_D1SBRST SYSCFG_UR13_D1SBRST_Msk |
| #define | SYSCFG_UR14_D1STPRST_Pos (0U) |
| #define | SYSCFG_UR14_D1STPRST_Msk (0x1UL << SYSCFG_UR14_D1STPRST_Pos) |
| #define | SYSCFG_UR14_D1STPRST SYSCFG_UR14_D1STPRST_Msk |
| #define | SYSCFG_UR15_FZIWDGSTB_Pos (16U) |
| #define | SYSCFG_UR15_FZIWDGSTB_Msk (0x1UL << SYSCFG_UR15_FZIWDGSTB_Pos) |
| #define | SYSCFG_UR15_FZIWDGSTB SYSCFG_UR15_FZIWDGSTB_Msk |
| #define | SYSCFG_UR16_FZIWDGSTP_Pos (0U) |
| #define | SYSCFG_UR16_FZIWDGSTP_Msk (0x1UL << SYSCFG_UR16_FZIWDGSTP_Pos) |
| #define | SYSCFG_UR16_FZIWDGSTP SYSCFG_UR16_FZIWDGSTP_Msk |
| #define | SYSCFG_UR16_PKP_Pos (16U) |
| #define | SYSCFG_UR16_PKP_Msk (0x1UL << SYSCFG_UR16_PKP_Pos) |
| #define | SYSCFG_UR16_PKP SYSCFG_UR16_PKP_Msk |
| #define | SYSCFG_UR17_IOHSLV_Pos (0U) |
| #define | SYSCFG_UR17_IOHSLV_Msk (0x1UL << SYSCFG_UR17_IOHSLV_Pos) |
| #define | SYSCFG_UR17_IOHSLV SYSCFG_UR17_IOHSLV_Msk |
| #define | TIM_BREAK_INPUT_SUPPORT |
| #define | TIM_CR1_CEN_Pos (0U) |
| #define | TIM_CR1_CEN_Msk (0x1UL << TIM_CR1_CEN_Pos) |
| #define | TIM_CR1_CEN TIM_CR1_CEN_Msk |
| #define | TIM_CR1_UDIS_Pos (1U) |
| #define | TIM_CR1_UDIS_Msk (0x1UL << TIM_CR1_UDIS_Pos) |
| #define | TIM_CR1_UDIS TIM_CR1_UDIS_Msk |
| #define | TIM_CR1_URS_Pos (2U) |
| #define | TIM_CR1_URS_Msk (0x1UL << TIM_CR1_URS_Pos) |
| #define | TIM_CR1_URS TIM_CR1_URS_Msk |
| #define | TIM_CR1_OPM_Pos (3U) |
| #define | TIM_CR1_OPM_Msk (0x1UL << TIM_CR1_OPM_Pos) |
| #define | TIM_CR1_OPM TIM_CR1_OPM_Msk |
| #define | TIM_CR1_DIR_Pos (4U) |
| #define | TIM_CR1_DIR_Msk (0x1UL << TIM_CR1_DIR_Pos) |
| #define | TIM_CR1_DIR TIM_CR1_DIR_Msk |
| #define | TIM_CR1_CMS_Pos (5U) |
| #define | TIM_CR1_CMS_Msk (0x3UL << TIM_CR1_CMS_Pos) |
| #define | TIM_CR1_CMS TIM_CR1_CMS_Msk |
| #define | TIM_CR1_CMS_0 (0x1UL << TIM_CR1_CMS_Pos) |
| #define | TIM_CR1_CMS_1 (0x2UL << TIM_CR1_CMS_Pos) |
| #define | TIM_CR1_ARPE_Pos (7U) |
| #define | TIM_CR1_ARPE_Msk (0x1UL << TIM_CR1_ARPE_Pos) |
| #define | TIM_CR1_ARPE TIM_CR1_ARPE_Msk |
| #define | TIM_CR1_CKD_Pos (8U) |
| #define | TIM_CR1_CKD_Msk (0x3UL << TIM_CR1_CKD_Pos) |
| #define | TIM_CR1_CKD TIM_CR1_CKD_Msk |
| #define | TIM_CR1_CKD_0 (0x1UL << TIM_CR1_CKD_Pos) |
| #define | TIM_CR1_CKD_1 (0x2UL << TIM_CR1_CKD_Pos) |
| #define | TIM_CR1_UIFREMAP_Pos (11U) |
| #define | TIM_CR1_UIFREMAP_Msk (0x1UL << TIM_CR1_UIFREMAP_Pos) |
| #define | TIM_CR1_UIFREMAP TIM_CR1_UIFREMAP_Msk |
| #define | TIM_CR2_CCPC_Pos (0U) |
| #define | TIM_CR2_CCPC_Msk (0x1UL << TIM_CR2_CCPC_Pos) |
| #define | TIM_CR2_CCPC TIM_CR2_CCPC_Msk |
| #define | TIM_CR2_CCUS_Pos (2U) |
| #define | TIM_CR2_CCUS_Msk (0x1UL << TIM_CR2_CCUS_Pos) |
| #define | TIM_CR2_CCUS TIM_CR2_CCUS_Msk |
| #define | TIM_CR2_CCDS_Pos (3U) |
| #define | TIM_CR2_CCDS_Msk (0x1UL << TIM_CR2_CCDS_Pos) |
| #define | TIM_CR2_CCDS TIM_CR2_CCDS_Msk |
| #define | TIM_CR2_MMS_Pos (4U) |
| #define | TIM_CR2_MMS_Msk (0x7UL << TIM_CR2_MMS_Pos) |
| #define | TIM_CR2_MMS TIM_CR2_MMS_Msk |
| #define | TIM_CR2_MMS_0 (0x1UL << TIM_CR2_MMS_Pos) |
| #define | TIM_CR2_MMS_1 (0x2UL << TIM_CR2_MMS_Pos) |
| #define | TIM_CR2_MMS_2 (0x4UL << TIM_CR2_MMS_Pos) |
| #define | TIM_CR2_TI1S_Pos (7U) |
| #define | TIM_CR2_TI1S_Msk (0x1UL << TIM_CR2_TI1S_Pos) |
| #define | TIM_CR2_TI1S TIM_CR2_TI1S_Msk |
| #define | TIM_CR2_OIS1_Pos (8U) |
| #define | TIM_CR2_OIS1_Msk (0x1UL << TIM_CR2_OIS1_Pos) |
| #define | TIM_CR2_OIS1 TIM_CR2_OIS1_Msk |
| #define | TIM_CR2_OIS1N_Pos (9U) |
| #define | TIM_CR2_OIS1N_Msk (0x1UL << TIM_CR2_OIS1N_Pos) |
| #define | TIM_CR2_OIS1N TIM_CR2_OIS1N_Msk |
| #define | TIM_CR2_OIS2_Pos (10U) |
| #define | TIM_CR2_OIS2_Msk (0x1UL << TIM_CR2_OIS2_Pos) |
| #define | TIM_CR2_OIS2 TIM_CR2_OIS2_Msk |
| #define | TIM_CR2_OIS2N_Pos (11U) |
| #define | TIM_CR2_OIS2N_Msk (0x1UL << TIM_CR2_OIS2N_Pos) |
| #define | TIM_CR2_OIS2N TIM_CR2_OIS2N_Msk |
| #define | TIM_CR2_OIS3_Pos (12U) |
| #define | TIM_CR2_OIS3_Msk (0x1UL << TIM_CR2_OIS3_Pos) |
| #define | TIM_CR2_OIS3 TIM_CR2_OIS3_Msk |
| #define | TIM_CR2_OIS3N_Pos (13U) |
| #define | TIM_CR2_OIS3N_Msk (0x1UL << TIM_CR2_OIS3N_Pos) |
| #define | TIM_CR2_OIS3N TIM_CR2_OIS3N_Msk |
| #define | TIM_CR2_OIS4_Pos (14U) |
| #define | TIM_CR2_OIS4_Msk (0x1UL << TIM_CR2_OIS4_Pos) |
| #define | TIM_CR2_OIS4 TIM_CR2_OIS4_Msk |
| #define | TIM_CR2_OIS5_Pos (16U) |
| #define | TIM_CR2_OIS5_Msk (0x1UL << TIM_CR2_OIS5_Pos) |
| #define | TIM_CR2_OIS5 TIM_CR2_OIS5_Msk |
| #define | TIM_CR2_OIS6_Pos (18U) |
| #define | TIM_CR2_OIS6_Msk (0x1UL << TIM_CR2_OIS6_Pos) |
| #define | TIM_CR2_OIS6 TIM_CR2_OIS6_Msk |
| #define | TIM_CR2_MMS2_Pos (20U) |
| #define | TIM_CR2_MMS2_Msk (0xFUL << TIM_CR2_MMS2_Pos) |
| #define | TIM_CR2_MMS2 TIM_CR2_MMS2_Msk |
| #define | TIM_CR2_MMS2_0 (0x1UL << TIM_CR2_MMS2_Pos) |
| #define | TIM_CR2_MMS2_1 (0x2UL << TIM_CR2_MMS2_Pos) |
| #define | TIM_CR2_MMS2_2 (0x4UL << TIM_CR2_MMS2_Pos) |
| #define | TIM_CR2_MMS2_3 (0x8UL << TIM_CR2_MMS2_Pos) |
| #define | TIM_SMCR_SMS_Pos (0U) |
| #define | TIM_SMCR_SMS_Msk (0x10007UL << TIM_SMCR_SMS_Pos) |
| #define | TIM_SMCR_SMS TIM_SMCR_SMS_Msk |
| #define | TIM_SMCR_SMS_0 (0x00001UL << TIM_SMCR_SMS_Pos) |
| #define | TIM_SMCR_SMS_1 (0x00002UL << TIM_SMCR_SMS_Pos) |
| #define | TIM_SMCR_SMS_2 (0x00004UL << TIM_SMCR_SMS_Pos) |
| #define | TIM_SMCR_SMS_3 (0x10000UL << TIM_SMCR_SMS_Pos) |
| #define | TIM_SMCR_TS_Pos (4U) |
| #define | TIM_SMCR_TS_Msk (0x30007UL << TIM_SMCR_TS_Pos) |
| #define | TIM_SMCR_TS TIM_SMCR_TS_Msk |
| #define | TIM_SMCR_TS_0 (0x00001UL << TIM_SMCR_TS_Pos) |
| #define | TIM_SMCR_TS_1 (0x00002UL << TIM_SMCR_TS_Pos) |
| #define | TIM_SMCR_TS_2 (0x00004UL << TIM_SMCR_TS_Pos) |
| #define | TIM_SMCR_TS_3 (0x10000UL << TIM_SMCR_TS_Pos) |
| #define | TIM_SMCR_TS_4 (0x20000UL << TIM_SMCR_TS_Pos) |
| #define | TIM_SMCR_MSM_Pos (7U) |
| #define | TIM_SMCR_MSM_Msk (0x1UL << TIM_SMCR_MSM_Pos) |
| #define | TIM_SMCR_MSM TIM_SMCR_MSM_Msk |
| #define | TIM_SMCR_ETF_Pos (8U) |
| #define | TIM_SMCR_ETF_Msk (0xFUL << TIM_SMCR_ETF_Pos) |
| #define | TIM_SMCR_ETF TIM_SMCR_ETF_Msk |
| #define | TIM_SMCR_ETF_0 (0x1UL << TIM_SMCR_ETF_Pos) |
| #define | TIM_SMCR_ETF_1 (0x2UL << TIM_SMCR_ETF_Pos) |
| #define | TIM_SMCR_ETF_2 (0x4UL << TIM_SMCR_ETF_Pos) |
| #define | TIM_SMCR_ETF_3 (0x8UL << TIM_SMCR_ETF_Pos) |
| #define | TIM_SMCR_ETPS_Pos (12U) |
| #define | TIM_SMCR_ETPS_Msk (0x3UL << TIM_SMCR_ETPS_Pos) |
| #define | TIM_SMCR_ETPS TIM_SMCR_ETPS_Msk |
| #define | TIM_SMCR_ETPS_0 (0x1UL << TIM_SMCR_ETPS_Pos) |
| #define | TIM_SMCR_ETPS_1 (0x2UL << TIM_SMCR_ETPS_Pos) |
| #define | TIM_SMCR_ECE_Pos (14U) |
| #define | TIM_SMCR_ECE_Msk (0x1UL << TIM_SMCR_ECE_Pos) |
| #define | TIM_SMCR_ECE TIM_SMCR_ECE_Msk |
| #define | TIM_SMCR_ETP_Pos (15U) |
| #define | TIM_SMCR_ETP_Msk (0x1UL << TIM_SMCR_ETP_Pos) |
| #define | TIM_SMCR_ETP TIM_SMCR_ETP_Msk |
| #define | TIM_DIER_UIE_Pos (0U) |
| #define | TIM_DIER_UIE_Msk (0x1UL << TIM_DIER_UIE_Pos) |
| #define | TIM_DIER_UIE TIM_DIER_UIE_Msk |
| #define | TIM_DIER_CC1IE_Pos (1U) |
| #define | TIM_DIER_CC1IE_Msk (0x1UL << TIM_DIER_CC1IE_Pos) |
| #define | TIM_DIER_CC1IE TIM_DIER_CC1IE_Msk |
| #define | TIM_DIER_CC2IE_Pos (2U) |
| #define | TIM_DIER_CC2IE_Msk (0x1UL << TIM_DIER_CC2IE_Pos) |
| #define | TIM_DIER_CC2IE TIM_DIER_CC2IE_Msk |
| #define | TIM_DIER_CC3IE_Pos (3U) |
| #define | TIM_DIER_CC3IE_Msk (0x1UL << TIM_DIER_CC3IE_Pos) |
| #define | TIM_DIER_CC3IE TIM_DIER_CC3IE_Msk |
| #define | TIM_DIER_CC4IE_Pos (4U) |
| #define | TIM_DIER_CC4IE_Msk (0x1UL << TIM_DIER_CC4IE_Pos) |
| #define | TIM_DIER_CC4IE TIM_DIER_CC4IE_Msk |
| #define | TIM_DIER_COMIE_Pos (5U) |
| #define | TIM_DIER_COMIE_Msk (0x1UL << TIM_DIER_COMIE_Pos) |
| #define | TIM_DIER_COMIE TIM_DIER_COMIE_Msk |
| #define | TIM_DIER_TIE_Pos (6U) |
| #define | TIM_DIER_TIE_Msk (0x1UL << TIM_DIER_TIE_Pos) |
| #define | TIM_DIER_TIE TIM_DIER_TIE_Msk |
| #define | TIM_DIER_BIE_Pos (7U) |
| #define | TIM_DIER_BIE_Msk (0x1UL << TIM_DIER_BIE_Pos) |
| #define | TIM_DIER_BIE TIM_DIER_BIE_Msk |
| #define | TIM_DIER_UDE_Pos (8U) |
| #define | TIM_DIER_UDE_Msk (0x1UL << TIM_DIER_UDE_Pos) |
| #define | TIM_DIER_UDE TIM_DIER_UDE_Msk |
| #define | TIM_DIER_CC1DE_Pos (9U) |
| #define | TIM_DIER_CC1DE_Msk (0x1UL << TIM_DIER_CC1DE_Pos) |
| #define | TIM_DIER_CC1DE TIM_DIER_CC1DE_Msk |
| #define | TIM_DIER_CC2DE_Pos (10U) |
| #define | TIM_DIER_CC2DE_Msk (0x1UL << TIM_DIER_CC2DE_Pos) |
| #define | TIM_DIER_CC2DE TIM_DIER_CC2DE_Msk |
| #define | TIM_DIER_CC3DE_Pos (11U) |
| #define | TIM_DIER_CC3DE_Msk (0x1UL << TIM_DIER_CC3DE_Pos) |
| #define | TIM_DIER_CC3DE TIM_DIER_CC3DE_Msk |
| #define | TIM_DIER_CC4DE_Pos (12U) |
| #define | TIM_DIER_CC4DE_Msk (0x1UL << TIM_DIER_CC4DE_Pos) |
| #define | TIM_DIER_CC4DE TIM_DIER_CC4DE_Msk |
| #define | TIM_DIER_COMDE_Pos (13U) |
| #define | TIM_DIER_COMDE_Msk (0x1UL << TIM_DIER_COMDE_Pos) |
| #define | TIM_DIER_COMDE TIM_DIER_COMDE_Msk |
| #define | TIM_DIER_TDE_Pos (14U) |
| #define | TIM_DIER_TDE_Msk (0x1UL << TIM_DIER_TDE_Pos) |
| #define | TIM_DIER_TDE TIM_DIER_TDE_Msk |
| #define | TIM_SR_UIF_Pos (0U) |
| #define | TIM_SR_UIF_Msk (0x1UL << TIM_SR_UIF_Pos) |
| #define | TIM_SR_UIF TIM_SR_UIF_Msk |
| #define | TIM_SR_CC1IF_Pos (1U) |
| #define | TIM_SR_CC1IF_Msk (0x1UL << TIM_SR_CC1IF_Pos) |
| #define | TIM_SR_CC1IF TIM_SR_CC1IF_Msk |
| #define | TIM_SR_CC2IF_Pos (2U) |
| #define | TIM_SR_CC2IF_Msk (0x1UL << TIM_SR_CC2IF_Pos) |
| #define | TIM_SR_CC2IF TIM_SR_CC2IF_Msk |
| #define | TIM_SR_CC3IF_Pos (3U) |
| #define | TIM_SR_CC3IF_Msk (0x1UL << TIM_SR_CC3IF_Pos) |
| #define | TIM_SR_CC3IF TIM_SR_CC3IF_Msk |
| #define | TIM_SR_CC4IF_Pos (4U) |
| #define | TIM_SR_CC4IF_Msk (0x1UL << TIM_SR_CC4IF_Pos) |
| #define | TIM_SR_CC4IF TIM_SR_CC4IF_Msk |
| #define | TIM_SR_COMIF_Pos (5U) |
| #define | TIM_SR_COMIF_Msk (0x1UL << TIM_SR_COMIF_Pos) |
| #define | TIM_SR_COMIF TIM_SR_COMIF_Msk |
| #define | TIM_SR_TIF_Pos (6U) |
| #define | TIM_SR_TIF_Msk (0x1UL << TIM_SR_TIF_Pos) |
| #define | TIM_SR_TIF TIM_SR_TIF_Msk |
| #define | TIM_SR_BIF_Pos (7U) |
| #define | TIM_SR_BIF_Msk (0x1UL << TIM_SR_BIF_Pos) |
| #define | TIM_SR_BIF TIM_SR_BIF_Msk |
| #define | TIM_SR_B2IF_Pos (8U) |
| #define | TIM_SR_B2IF_Msk (0x1UL << TIM_SR_B2IF_Pos) |
| #define | TIM_SR_B2IF TIM_SR_B2IF_Msk |
| #define | TIM_SR_CC1OF_Pos (9U) |
| #define | TIM_SR_CC1OF_Msk (0x1UL << TIM_SR_CC1OF_Pos) |
| #define | TIM_SR_CC1OF TIM_SR_CC1OF_Msk |
| #define | TIM_SR_CC2OF_Pos (10U) |
| #define | TIM_SR_CC2OF_Msk (0x1UL << TIM_SR_CC2OF_Pos) |
| #define | TIM_SR_CC2OF TIM_SR_CC2OF_Msk |
| #define | TIM_SR_CC3OF_Pos (11U) |
| #define | TIM_SR_CC3OF_Msk (0x1UL << TIM_SR_CC3OF_Pos) |
| #define | TIM_SR_CC3OF TIM_SR_CC3OF_Msk |
| #define | TIM_SR_CC4OF_Pos (12U) |
| #define | TIM_SR_CC4OF_Msk (0x1UL << TIM_SR_CC4OF_Pos) |
| #define | TIM_SR_CC4OF TIM_SR_CC4OF_Msk |
| #define | TIM_SR_CC5IF_Pos (16U) |
| #define | TIM_SR_CC5IF_Msk (0x1UL << TIM_SR_CC5IF_Pos) |
| #define | TIM_SR_CC5IF TIM_SR_CC5IF_Msk |
| #define | TIM_SR_CC6IF_Pos (17U) |
| #define | TIM_SR_CC6IF_Msk (0x1UL << TIM_SR_CC6IF_Pos) |
| #define | TIM_SR_CC6IF TIM_SR_CC6IF_Msk |
| #define | TIM_SR_SBIF_Pos (13U) |
| #define | TIM_SR_SBIF_Msk (0x1UL << TIM_SR_SBIF_Pos) |
| #define | TIM_SR_SBIF TIM_SR_SBIF_Msk |
| #define | TIM_EGR_UG_Pos (0U) |
| #define | TIM_EGR_UG_Msk (0x1UL << TIM_EGR_UG_Pos) |
| #define | TIM_EGR_UG TIM_EGR_UG_Msk |
| #define | TIM_EGR_CC1G_Pos (1U) |
| #define | TIM_EGR_CC1G_Msk (0x1UL << TIM_EGR_CC1G_Pos) |
| #define | TIM_EGR_CC1G TIM_EGR_CC1G_Msk |
| #define | TIM_EGR_CC2G_Pos (2U) |
| #define | TIM_EGR_CC2G_Msk (0x1UL << TIM_EGR_CC2G_Pos) |
| #define | TIM_EGR_CC2G TIM_EGR_CC2G_Msk |
| #define | TIM_EGR_CC3G_Pos (3U) |
| #define | TIM_EGR_CC3G_Msk (0x1UL << TIM_EGR_CC3G_Pos) |
| #define | TIM_EGR_CC3G TIM_EGR_CC3G_Msk |
| #define | TIM_EGR_CC4G_Pos (4U) |
| #define | TIM_EGR_CC4G_Msk (0x1UL << TIM_EGR_CC4G_Pos) |
| #define | TIM_EGR_CC4G TIM_EGR_CC4G_Msk |
| #define | TIM_EGR_COMG_Pos (5U) |
| #define | TIM_EGR_COMG_Msk (0x1UL << TIM_EGR_COMG_Pos) |
| #define | TIM_EGR_COMG TIM_EGR_COMG_Msk |
| #define | TIM_EGR_TG_Pos (6U) |
| #define | TIM_EGR_TG_Msk (0x1UL << TIM_EGR_TG_Pos) |
| #define | TIM_EGR_TG TIM_EGR_TG_Msk |
| #define | TIM_EGR_BG_Pos (7U) |
| #define | TIM_EGR_BG_Msk (0x1UL << TIM_EGR_BG_Pos) |
| #define | TIM_EGR_BG TIM_EGR_BG_Msk |
| #define | TIM_EGR_B2G_Pos (8U) |
| #define | TIM_EGR_B2G_Msk (0x1UL << TIM_EGR_B2G_Pos) |
| #define | TIM_EGR_B2G TIM_EGR_B2G_Msk |
| #define | TIM_CCMR1_CC1S_Pos (0U) |
| #define | TIM_CCMR1_CC1S_Msk (0x3UL << TIM_CCMR1_CC1S_Pos) |
| #define | TIM_CCMR1_CC1S TIM_CCMR1_CC1S_Msk |
| #define | TIM_CCMR1_CC1S_0 (0x1UL << TIM_CCMR1_CC1S_Pos) |
| #define | TIM_CCMR1_CC1S_1 (0x2UL << TIM_CCMR1_CC1S_Pos) |
| #define | TIM_CCMR1_OC1FE_Pos (2U) |
| #define | TIM_CCMR1_OC1FE_Msk (0x1UL << TIM_CCMR1_OC1FE_Pos) |
| #define | TIM_CCMR1_OC1FE TIM_CCMR1_OC1FE_Msk |
| #define | TIM_CCMR1_OC1PE_Pos (3U) |
| #define | TIM_CCMR1_OC1PE_Msk (0x1UL << TIM_CCMR1_OC1PE_Pos) |
| #define | TIM_CCMR1_OC1PE TIM_CCMR1_OC1PE_Msk |
| #define | TIM_CCMR1_OC1M_Pos (4U) |
| #define | TIM_CCMR1_OC1M_Msk (0x1007UL << TIM_CCMR1_OC1M_Pos) |
| #define | TIM_CCMR1_OC1M TIM_CCMR1_OC1M_Msk |
| #define | TIM_CCMR1_OC1M_0 (0x0001UL << TIM_CCMR1_OC1M_Pos) |
| #define | TIM_CCMR1_OC1M_1 (0x0002UL << TIM_CCMR1_OC1M_Pos) |
| #define | TIM_CCMR1_OC1M_2 (0x0004UL << TIM_CCMR1_OC1M_Pos) |
| #define | TIM_CCMR1_OC1M_3 (0x1000UL << TIM_CCMR1_OC1M_Pos) |
| #define | TIM_CCMR1_OC1CE_Pos (7U) |
| #define | TIM_CCMR1_OC1CE_Msk (0x1UL << TIM_CCMR1_OC1CE_Pos) |
| #define | TIM_CCMR1_OC1CE TIM_CCMR1_OC1CE_Msk |
| #define | TIM_CCMR1_CC2S_Pos (8U) |
| #define | TIM_CCMR1_CC2S_Msk (0x3UL << TIM_CCMR1_CC2S_Pos) |
| #define | TIM_CCMR1_CC2S TIM_CCMR1_CC2S_Msk |
| #define | TIM_CCMR1_CC2S_0 (0x1UL << TIM_CCMR1_CC2S_Pos) |
| #define | TIM_CCMR1_CC2S_1 (0x2UL << TIM_CCMR1_CC2S_Pos) |
| #define | TIM_CCMR1_OC2FE_Pos (10U) |
| #define | TIM_CCMR1_OC2FE_Msk (0x1UL << TIM_CCMR1_OC2FE_Pos) |
| #define | TIM_CCMR1_OC2FE TIM_CCMR1_OC2FE_Msk |
| #define | TIM_CCMR1_OC2PE_Pos (11U) |
| #define | TIM_CCMR1_OC2PE_Msk (0x1UL << TIM_CCMR1_OC2PE_Pos) |
| #define | TIM_CCMR1_OC2PE TIM_CCMR1_OC2PE_Msk |
| #define | TIM_CCMR1_OC2M_Pos (12U) |
| #define | TIM_CCMR1_OC2M_Msk (0x1007UL << TIM_CCMR1_OC2M_Pos) |
| #define | TIM_CCMR1_OC2M TIM_CCMR1_OC2M_Msk |
| #define | TIM_CCMR1_OC2M_0 (0x0001UL << TIM_CCMR1_OC2M_Pos) |
| #define | TIM_CCMR1_OC2M_1 (0x0002UL << TIM_CCMR1_OC2M_Pos) |
| #define | TIM_CCMR1_OC2M_2 (0x0004UL << TIM_CCMR1_OC2M_Pos) |
| #define | TIM_CCMR1_OC2M_3 (0x1000UL << TIM_CCMR1_OC2M_Pos) |
| #define | TIM_CCMR1_OC2CE_Pos (15U) |
| #define | TIM_CCMR1_OC2CE_Msk (0x1UL << TIM_CCMR1_OC2CE_Pos) |
| #define | TIM_CCMR1_OC2CE TIM_CCMR1_OC2CE_Msk |
| #define | TIM_CCMR1_IC1PSC_Pos (2U) |
| #define | TIM_CCMR1_IC1PSC_Msk (0x3UL << TIM_CCMR1_IC1PSC_Pos) |
| #define | TIM_CCMR1_IC1PSC TIM_CCMR1_IC1PSC_Msk |
| #define | TIM_CCMR1_IC1PSC_0 (0x1UL << TIM_CCMR1_IC1PSC_Pos) |
| #define | TIM_CCMR1_IC1PSC_1 (0x2UL << TIM_CCMR1_IC1PSC_Pos) |
| #define | TIM_CCMR1_IC1F_Pos (4U) |
| #define | TIM_CCMR1_IC1F_Msk (0xFUL << TIM_CCMR1_IC1F_Pos) |
| #define | TIM_CCMR1_IC1F TIM_CCMR1_IC1F_Msk |
| #define | TIM_CCMR1_IC1F_0 (0x1UL << TIM_CCMR1_IC1F_Pos) |
| #define | TIM_CCMR1_IC1F_1 (0x2UL << TIM_CCMR1_IC1F_Pos) |
| #define | TIM_CCMR1_IC1F_2 (0x4UL << TIM_CCMR1_IC1F_Pos) |
| #define | TIM_CCMR1_IC1F_3 (0x8UL << TIM_CCMR1_IC1F_Pos) |
| #define | TIM_CCMR1_IC2PSC_Pos (10U) |
| #define | TIM_CCMR1_IC2PSC_Msk (0x3UL << TIM_CCMR1_IC2PSC_Pos) |
| #define | TIM_CCMR1_IC2PSC TIM_CCMR1_IC2PSC_Msk |
| #define | TIM_CCMR1_IC2PSC_0 (0x1UL << TIM_CCMR1_IC2PSC_Pos) |
| #define | TIM_CCMR1_IC2PSC_1 (0x2UL << TIM_CCMR1_IC2PSC_Pos) |
| #define | TIM_CCMR1_IC2F_Pos (12U) |
| #define | TIM_CCMR1_IC2F_Msk (0xFUL << TIM_CCMR1_IC2F_Pos) |
| #define | TIM_CCMR1_IC2F TIM_CCMR1_IC2F_Msk |
| #define | TIM_CCMR1_IC2F_0 (0x1UL << TIM_CCMR1_IC2F_Pos) |
| #define | TIM_CCMR1_IC2F_1 (0x2UL << TIM_CCMR1_IC2F_Pos) |
| #define | TIM_CCMR1_IC2F_2 (0x4UL << TIM_CCMR1_IC2F_Pos) |
| #define | TIM_CCMR1_IC2F_3 (0x8UL << TIM_CCMR1_IC2F_Pos) |
| #define | TIM_CCMR2_CC3S_Pos (0U) |
| #define | TIM_CCMR2_CC3S_Msk (0x3UL << TIM_CCMR2_CC3S_Pos) |
| #define | TIM_CCMR2_CC3S TIM_CCMR2_CC3S_Msk |
| #define | TIM_CCMR2_CC3S_0 (0x1UL << TIM_CCMR2_CC3S_Pos) |
| #define | TIM_CCMR2_CC3S_1 (0x2UL << TIM_CCMR2_CC3S_Pos) |
| #define | TIM_CCMR2_OC3FE_Pos (2U) |
| #define | TIM_CCMR2_OC3FE_Msk (0x1UL << TIM_CCMR2_OC3FE_Pos) |
| #define | TIM_CCMR2_OC3FE TIM_CCMR2_OC3FE_Msk |
| #define | TIM_CCMR2_OC3PE_Pos (3U) |
| #define | TIM_CCMR2_OC3PE_Msk (0x1UL << TIM_CCMR2_OC3PE_Pos) |
| #define | TIM_CCMR2_OC3PE TIM_CCMR2_OC3PE_Msk |
| #define | TIM_CCMR2_OC3M_Pos (4U) |
| #define | TIM_CCMR2_OC3M_Msk (0x1007UL << TIM_CCMR2_OC3M_Pos) |
| #define | TIM_CCMR2_OC3M TIM_CCMR2_OC3M_Msk |
| #define | TIM_CCMR2_OC3M_0 (0x1UL << TIM_CCMR2_OC3M_Pos) |
| #define | TIM_CCMR2_OC3M_1 (0x2UL << TIM_CCMR2_OC3M_Pos) |
| #define | TIM_CCMR2_OC3M_2 (0x4UL << TIM_CCMR2_OC3M_Pos) |
| #define | TIM_CCMR2_OC3M_3 (0x1000UL << TIM_CCMR2_OC3M_Pos) |
| #define | TIM_CCMR2_OC3CE_Pos (7U) |
| #define | TIM_CCMR2_OC3CE_Msk (0x1UL << TIM_CCMR2_OC3CE_Pos) |
| #define | TIM_CCMR2_OC3CE TIM_CCMR2_OC3CE_Msk |
| #define | TIM_CCMR2_CC4S_Pos (8U) |
| #define | TIM_CCMR2_CC4S_Msk (0x3UL << TIM_CCMR2_CC4S_Pos) |
| #define | TIM_CCMR2_CC4S TIM_CCMR2_CC4S_Msk |
| #define | TIM_CCMR2_CC4S_0 (0x1UL << TIM_CCMR2_CC4S_Pos) |
| #define | TIM_CCMR2_CC4S_1 (0x2UL << TIM_CCMR2_CC4S_Pos) |
| #define | TIM_CCMR2_OC4FE_Pos (10U) |
| #define | TIM_CCMR2_OC4FE_Msk (0x1UL << TIM_CCMR2_OC4FE_Pos) |
| #define | TIM_CCMR2_OC4FE TIM_CCMR2_OC4FE_Msk |
| #define | TIM_CCMR2_OC4PE_Pos (11U) |
| #define | TIM_CCMR2_OC4PE_Msk (0x1UL << TIM_CCMR2_OC4PE_Pos) |
| #define | TIM_CCMR2_OC4PE TIM_CCMR2_OC4PE_Msk |
| #define | TIM_CCMR2_OC4M_Pos (12U) |
| #define | TIM_CCMR2_OC4M_Msk (0x1007UL << TIM_CCMR2_OC4M_Pos) |
| #define | TIM_CCMR2_OC4M TIM_CCMR2_OC4M_Msk |
| #define | TIM_CCMR2_OC4M_0 (0x1UL << TIM_CCMR2_OC4M_Pos) |
| #define | TIM_CCMR2_OC4M_1 (0x2UL << TIM_CCMR2_OC4M_Pos) |
| #define | TIM_CCMR2_OC4M_2 (0x4UL << TIM_CCMR2_OC4M_Pos) |
| #define | TIM_CCMR2_OC4M_3 (0x1000UL << TIM_CCMR2_OC4M_Pos) |
| #define | TIM_CCMR2_OC4CE_Pos (15U) |
| #define | TIM_CCMR2_OC4CE_Msk (0x1UL << TIM_CCMR2_OC4CE_Pos) |
| #define | TIM_CCMR2_OC4CE TIM_CCMR2_OC4CE_Msk |
| #define | TIM_CCMR2_IC3PSC_Pos (2U) |
| #define | TIM_CCMR2_IC3PSC_Msk (0x3UL << TIM_CCMR2_IC3PSC_Pos) |
| #define | TIM_CCMR2_IC3PSC TIM_CCMR2_IC3PSC_Msk |
| #define | TIM_CCMR2_IC3PSC_0 (0x1UL << TIM_CCMR2_IC3PSC_Pos) |
| #define | TIM_CCMR2_IC3PSC_1 (0x2UL << TIM_CCMR2_IC3PSC_Pos) |
| #define | TIM_CCMR2_IC3F_Pos (4U) |
| #define | TIM_CCMR2_IC3F_Msk (0xFUL << TIM_CCMR2_IC3F_Pos) |
| #define | TIM_CCMR2_IC3F TIM_CCMR2_IC3F_Msk |
| #define | TIM_CCMR2_IC3F_0 (0x1UL << TIM_CCMR2_IC3F_Pos) |
| #define | TIM_CCMR2_IC3F_1 (0x2UL << TIM_CCMR2_IC3F_Pos) |
| #define | TIM_CCMR2_IC3F_2 (0x4UL << TIM_CCMR2_IC3F_Pos) |
| #define | TIM_CCMR2_IC3F_3 (0x8UL << TIM_CCMR2_IC3F_Pos) |
| #define | TIM_CCMR2_IC4PSC_Pos (10U) |
| #define | TIM_CCMR2_IC4PSC_Msk (0x3UL << TIM_CCMR2_IC4PSC_Pos) |
| #define | TIM_CCMR2_IC4PSC TIM_CCMR2_IC4PSC_Msk |
| #define | TIM_CCMR2_IC4PSC_0 (0x1UL << TIM_CCMR2_IC4PSC_Pos) |
| #define | TIM_CCMR2_IC4PSC_1 (0x2UL << TIM_CCMR2_IC4PSC_Pos) |
| #define | TIM_CCMR2_IC4F_Pos (12U) |
| #define | TIM_CCMR2_IC4F_Msk (0xFUL << TIM_CCMR2_IC4F_Pos) |
| #define | TIM_CCMR2_IC4F TIM_CCMR2_IC4F_Msk |
| #define | TIM_CCMR2_IC4F_0 (0x1UL << TIM_CCMR2_IC4F_Pos) |
| #define | TIM_CCMR2_IC4F_1 (0x2UL << TIM_CCMR2_IC4F_Pos) |
| #define | TIM_CCMR2_IC4F_2 (0x4UL << TIM_CCMR2_IC4F_Pos) |
| #define | TIM_CCMR2_IC4F_3 (0x8UL << TIM_CCMR2_IC4F_Pos) |
| #define | TIM_CCER_CC1E_Pos (0U) |
| #define | TIM_CCER_CC1E_Msk (0x1UL << TIM_CCER_CC1E_Pos) |
| #define | TIM_CCER_CC1E TIM_CCER_CC1E_Msk |
| #define | TIM_CCER_CC1P_Pos (1U) |
| #define | TIM_CCER_CC1P_Msk (0x1UL << TIM_CCER_CC1P_Pos) |
| #define | TIM_CCER_CC1P TIM_CCER_CC1P_Msk |
| #define | TIM_CCER_CC1NE_Pos (2U) |
| #define | TIM_CCER_CC1NE_Msk (0x1UL << TIM_CCER_CC1NE_Pos) |
| #define | TIM_CCER_CC1NE TIM_CCER_CC1NE_Msk |
| #define | TIM_CCER_CC1NP_Pos (3U) |
| #define | TIM_CCER_CC1NP_Msk (0x1UL << TIM_CCER_CC1NP_Pos) |
| #define | TIM_CCER_CC1NP TIM_CCER_CC1NP_Msk |
| #define | TIM_CCER_CC2E_Pos (4U) |
| #define | TIM_CCER_CC2E_Msk (0x1UL << TIM_CCER_CC2E_Pos) |
| #define | TIM_CCER_CC2E TIM_CCER_CC2E_Msk |
| #define | TIM_CCER_CC2P_Pos (5U) |
| #define | TIM_CCER_CC2P_Msk (0x1UL << TIM_CCER_CC2P_Pos) |
| #define | TIM_CCER_CC2P TIM_CCER_CC2P_Msk |
| #define | TIM_CCER_CC2NE_Pos (6U) |
| #define | TIM_CCER_CC2NE_Msk (0x1UL << TIM_CCER_CC2NE_Pos) |
| #define | TIM_CCER_CC2NE TIM_CCER_CC2NE_Msk |
| #define | TIM_CCER_CC2NP_Pos (7U) |
| #define | TIM_CCER_CC2NP_Msk (0x1UL << TIM_CCER_CC2NP_Pos) |
| #define | TIM_CCER_CC2NP TIM_CCER_CC2NP_Msk |
| #define | TIM_CCER_CC3E_Pos (8U) |
| #define | TIM_CCER_CC3E_Msk (0x1UL << TIM_CCER_CC3E_Pos) |
| #define | TIM_CCER_CC3E TIM_CCER_CC3E_Msk |
| #define | TIM_CCER_CC3P_Pos (9U) |
| #define | TIM_CCER_CC3P_Msk (0x1UL << TIM_CCER_CC3P_Pos) |
| #define | TIM_CCER_CC3P TIM_CCER_CC3P_Msk |
| #define | TIM_CCER_CC3NE_Pos (10U) |
| #define | TIM_CCER_CC3NE_Msk (0x1UL << TIM_CCER_CC3NE_Pos) |
| #define | TIM_CCER_CC3NE TIM_CCER_CC3NE_Msk |
| #define | TIM_CCER_CC3NP_Pos (11U) |
| #define | TIM_CCER_CC3NP_Msk (0x1UL << TIM_CCER_CC3NP_Pos) |
| #define | TIM_CCER_CC3NP TIM_CCER_CC3NP_Msk |
| #define | TIM_CCER_CC4E_Pos (12U) |
| #define | TIM_CCER_CC4E_Msk (0x1UL << TIM_CCER_CC4E_Pos) |
| #define | TIM_CCER_CC4E TIM_CCER_CC4E_Msk |
| #define | TIM_CCER_CC4P_Pos (13U) |
| #define | TIM_CCER_CC4P_Msk (0x1UL << TIM_CCER_CC4P_Pos) |
| #define | TIM_CCER_CC4P TIM_CCER_CC4P_Msk |
| #define | TIM_CCER_CC4NP_Pos (15U) |
| #define | TIM_CCER_CC4NP_Msk (0x1UL << TIM_CCER_CC4NP_Pos) |
| #define | TIM_CCER_CC4NP TIM_CCER_CC4NP_Msk |
| #define | TIM_CCER_CC5E_Pos (16U) |
| #define | TIM_CCER_CC5E_Msk (0x1UL << TIM_CCER_CC5E_Pos) |
| #define | TIM_CCER_CC5E TIM_CCER_CC5E_Msk |
| #define | TIM_CCER_CC5P_Pos (17U) |
| #define | TIM_CCER_CC5P_Msk (0x1UL << TIM_CCER_CC5P_Pos) |
| #define | TIM_CCER_CC5P TIM_CCER_CC5P_Msk |
| #define | TIM_CCER_CC6E_Pos (20U) |
| #define | TIM_CCER_CC6E_Msk (0x1UL << TIM_CCER_CC6E_Pos) |
| #define | TIM_CCER_CC6E TIM_CCER_CC6E_Msk |
| #define | TIM_CCER_CC6P_Pos (21U) |
| #define | TIM_CCER_CC6P_Msk (0x1UL << TIM_CCER_CC6P_Pos) |
| #define | TIM_CCER_CC6P TIM_CCER_CC6P_Msk |
| #define | TIM_CNT_CNT_Pos (0U) |
| #define | TIM_CNT_CNT_Msk (0xFFFFFFFFUL << TIM_CNT_CNT_Pos) |
| #define | TIM_CNT_CNT TIM_CNT_CNT_Msk |
| #define | TIM_CNT_UIFCPY_Pos (31U) |
| #define | TIM_CNT_UIFCPY_Msk (0x1UL << TIM_CNT_UIFCPY_Pos) |
| #define | TIM_CNT_UIFCPY TIM_CNT_UIFCPY_Msk |
| #define | TIM_PSC_PSC_Pos (0U) |
| #define | TIM_PSC_PSC_Msk (0xFFFFUL << TIM_PSC_PSC_Pos) |
| #define | TIM_PSC_PSC TIM_PSC_PSC_Msk |
| #define | TIM_ARR_ARR_Pos (0U) |
| #define | TIM_ARR_ARR_Msk (0xFFFFFFFFUL << TIM_ARR_ARR_Pos) |
| #define | TIM_ARR_ARR TIM_ARR_ARR_Msk |
| #define | TIM_RCR_REP_Pos (0U) |
| #define | TIM_RCR_REP_Msk (0xFFUL << TIM_RCR_REP_Pos) |
| #define | TIM_RCR_REP TIM_RCR_REP_Msk |
| #define | TIM_CCR1_CCR1_Pos (0U) |
| #define | TIM_CCR1_CCR1_Msk (0xFFFFUL << TIM_CCR1_CCR1_Pos) |
| #define | TIM_CCR1_CCR1 TIM_CCR1_CCR1_Msk |
| #define | TIM_CCR2_CCR2_Pos (0U) |
| #define | TIM_CCR2_CCR2_Msk (0xFFFFUL << TIM_CCR2_CCR2_Pos) |
| #define | TIM_CCR2_CCR2 TIM_CCR2_CCR2_Msk |
| #define | TIM_CCR3_CCR3_Pos (0U) |
| #define | TIM_CCR3_CCR3_Msk (0xFFFFUL << TIM_CCR3_CCR3_Pos) |
| #define | TIM_CCR3_CCR3 TIM_CCR3_CCR3_Msk |
| #define | TIM_CCR4_CCR4_Pos (0U) |
| #define | TIM_CCR4_CCR4_Msk (0xFFFFUL << TIM_CCR4_CCR4_Pos) |
| #define | TIM_CCR4_CCR4 TIM_CCR4_CCR4_Msk |
| #define | TIM_CCR5_CCR5_Pos (0U) |
| #define | TIM_CCR5_CCR5_Msk (0xFFFFFFFFUL << TIM_CCR5_CCR5_Pos) |
| #define | TIM_CCR5_CCR5 TIM_CCR5_CCR5_Msk |
| #define | TIM_CCR5_GC5C1_Pos (29U) |
| #define | TIM_CCR5_GC5C1_Msk (0x1UL << TIM_CCR5_GC5C1_Pos) |
| #define | TIM_CCR5_GC5C1 TIM_CCR5_GC5C1_Msk |
| #define | TIM_CCR5_GC5C2_Pos (30U) |
| #define | TIM_CCR5_GC5C2_Msk (0x1UL << TIM_CCR5_GC5C2_Pos) |
| #define | TIM_CCR5_GC5C2 TIM_CCR5_GC5C2_Msk |
| #define | TIM_CCR5_GC5C3_Pos (31U) |
| #define | TIM_CCR5_GC5C3_Msk (0x1UL << TIM_CCR5_GC5C3_Pos) |
| #define | TIM_CCR5_GC5C3 TIM_CCR5_GC5C3_Msk |
| #define | TIM_CCR6_CCR6_Pos (0U) |
| #define | TIM_CCR6_CCR6_Msk (0xFFFFUL << TIM_CCR6_CCR6_Pos) |
| #define | TIM_CCR6_CCR6 TIM_CCR6_CCR6_Msk |
| #define | TIM_BDTR_DTG_Pos (0U) |
| #define | TIM_BDTR_DTG_Msk (0xFFUL << TIM_BDTR_DTG_Pos) |
| #define | TIM_BDTR_DTG TIM_BDTR_DTG_Msk |
| #define | TIM_BDTR_DTG_0 (0x01UL << TIM_BDTR_DTG_Pos) |
| #define | TIM_BDTR_DTG_1 (0x02UL << TIM_BDTR_DTG_Pos) |
| #define | TIM_BDTR_DTG_2 (0x04UL << TIM_BDTR_DTG_Pos) |
| #define | TIM_BDTR_DTG_3 (0x08UL << TIM_BDTR_DTG_Pos) |
| #define | TIM_BDTR_DTG_4 (0x10UL << TIM_BDTR_DTG_Pos) |
| #define | TIM_BDTR_DTG_5 (0x20UL << TIM_BDTR_DTG_Pos) |
| #define | TIM_BDTR_DTG_6 (0x40UL << TIM_BDTR_DTG_Pos) |
| #define | TIM_BDTR_DTG_7 (0x80UL << TIM_BDTR_DTG_Pos) |
| #define | TIM_BDTR_LOCK_Pos (8U) |
| #define | TIM_BDTR_LOCK_Msk (0x3UL << TIM_BDTR_LOCK_Pos) |
| #define | TIM_BDTR_LOCK TIM_BDTR_LOCK_Msk |
| #define | TIM_BDTR_LOCK_0 (0x1UL << TIM_BDTR_LOCK_Pos) |
| #define | TIM_BDTR_LOCK_1 (0x2UL << TIM_BDTR_LOCK_Pos) |
| #define | TIM_BDTR_OSSI_Pos (10U) |
| #define | TIM_BDTR_OSSI_Msk (0x1UL << TIM_BDTR_OSSI_Pos) |
| #define | TIM_BDTR_OSSI TIM_BDTR_OSSI_Msk |
| #define | TIM_BDTR_OSSR_Pos (11U) |
| #define | TIM_BDTR_OSSR_Msk (0x1UL << TIM_BDTR_OSSR_Pos) |
| #define | TIM_BDTR_OSSR TIM_BDTR_OSSR_Msk |
| #define | TIM_BDTR_BKE_Pos (12U) |
| #define | TIM_BDTR_BKE_Msk (0x1UL << TIM_BDTR_BKE_Pos) |
| #define | TIM_BDTR_BKE TIM_BDTR_BKE_Msk |
| #define | TIM_BDTR_BKP_Pos (13U) |
| #define | TIM_BDTR_BKP_Msk (0x1UL << TIM_BDTR_BKP_Pos) |
| #define | TIM_BDTR_BKP TIM_BDTR_BKP_Msk |
| #define | TIM_BDTR_AOE_Pos (14U) |
| #define | TIM_BDTR_AOE_Msk (0x1UL << TIM_BDTR_AOE_Pos) |
| #define | TIM_BDTR_AOE TIM_BDTR_AOE_Msk |
| #define | TIM_BDTR_MOE_Pos (15U) |
| #define | TIM_BDTR_MOE_Msk (0x1UL << TIM_BDTR_MOE_Pos) |
| #define | TIM_BDTR_MOE TIM_BDTR_MOE_Msk |
| #define | TIM_BDTR_BKF_Pos (16U) |
| #define | TIM_BDTR_BKF_Msk (0xFUL << TIM_BDTR_BKF_Pos) |
| #define | TIM_BDTR_BKF TIM_BDTR_BKF_Msk |
| #define | TIM_BDTR_BK2F_Pos (20U) |
| #define | TIM_BDTR_BK2F_Msk (0xFUL << TIM_BDTR_BK2F_Pos) |
| #define | TIM_BDTR_BK2F TIM_BDTR_BK2F_Msk |
| #define | TIM_BDTR_BK2E_Pos (24U) |
| #define | TIM_BDTR_BK2E_Msk (0x1UL << TIM_BDTR_BK2E_Pos) |
| #define | TIM_BDTR_BK2E TIM_BDTR_BK2E_Msk |
| #define | TIM_BDTR_BK2P_Pos (25U) |
| #define | TIM_BDTR_BK2P_Msk (0x1UL << TIM_BDTR_BK2P_Pos) |
| #define | TIM_BDTR_BK2P TIM_BDTR_BK2P_Msk |
| #define | TIM_DCR_DBA_Pos (0U) |
| #define | TIM_DCR_DBA_Msk (0x1FUL << TIM_DCR_DBA_Pos) |
| #define | TIM_DCR_DBA TIM_DCR_DBA_Msk |
| #define | TIM_DCR_DBA_0 (0x01UL << TIM_DCR_DBA_Pos) |
| #define | TIM_DCR_DBA_1 (0x02UL << TIM_DCR_DBA_Pos) |
| #define | TIM_DCR_DBA_2 (0x04UL << TIM_DCR_DBA_Pos) |
| #define | TIM_DCR_DBA_3 (0x08UL << TIM_DCR_DBA_Pos) |
| #define | TIM_DCR_DBA_4 (0x10UL << TIM_DCR_DBA_Pos) |
| #define | TIM_DCR_DBL_Pos (8U) |
| #define | TIM_DCR_DBL_Msk (0x1FUL << TIM_DCR_DBL_Pos) |
| #define | TIM_DCR_DBL TIM_DCR_DBL_Msk |
| #define | TIM_DCR_DBL_0 (0x01UL << TIM_DCR_DBL_Pos) |
| #define | TIM_DCR_DBL_1 (0x02UL << TIM_DCR_DBL_Pos) |
| #define | TIM_DCR_DBL_2 (0x04UL << TIM_DCR_DBL_Pos) |
| #define | TIM_DCR_DBL_3 (0x08UL << TIM_DCR_DBL_Pos) |
| #define | TIM_DCR_DBL_4 (0x10UL << TIM_DCR_DBL_Pos) |
| #define | TIM_DMAR_DMAB_Pos (0U) |
| #define | TIM_DMAR_DMAB_Msk (0xFFFFUL << TIM_DMAR_DMAB_Pos) |
| #define | TIM_DMAR_DMAB TIM_DMAR_DMAB_Msk |
| #define | TIM_CCMR3_OC5FE_Pos (2U) |
| #define | TIM_CCMR3_OC5FE_Msk (0x1UL << TIM_CCMR3_OC5FE_Pos) |
| #define | TIM_CCMR3_OC5FE TIM_CCMR3_OC5FE_Msk |
| #define | TIM_CCMR3_OC5PE_Pos (3U) |
| #define | TIM_CCMR3_OC5PE_Msk (0x1UL << TIM_CCMR3_OC5PE_Pos) |
| #define | TIM_CCMR3_OC5PE TIM_CCMR3_OC5PE_Msk |
| #define | TIM_CCMR3_OC5M_Pos (4U) |
| #define | TIM_CCMR3_OC5M_Msk (0x1007UL << TIM_CCMR3_OC5M_Pos) |
| #define | TIM_CCMR3_OC5M TIM_CCMR3_OC5M_Msk |
| #define | TIM_CCMR3_OC5M_0 (0x1UL << TIM_CCMR3_OC5M_Pos) |
| #define | TIM_CCMR3_OC5M_1 (0x2UL << TIM_CCMR3_OC5M_Pos) |
| #define | TIM_CCMR3_OC5M_2 (0x4UL << TIM_CCMR3_OC5M_Pos) |
| #define | TIM_CCMR3_OC5M_3 (0x1000UL << TIM_CCMR3_OC5M_Pos) |
| #define | TIM_CCMR3_OC5CE_Pos (7U) |
| #define | TIM_CCMR3_OC5CE_Msk (0x1UL << TIM_CCMR3_OC5CE_Pos) |
| #define | TIM_CCMR3_OC5CE TIM_CCMR3_OC5CE_Msk |
| #define | TIM_CCMR3_OC6FE_Pos (10U) |
| #define | TIM_CCMR3_OC6FE_Msk (0x1UL << TIM_CCMR3_OC6FE_Pos) |
| #define | TIM_CCMR3_OC6FE TIM_CCMR3_OC6FE_Msk |
| #define | TIM_CCMR3_OC6PE_Pos (11U) |
| #define | TIM_CCMR3_OC6PE_Msk (0x1UL << TIM_CCMR3_OC6PE_Pos) |
| #define | TIM_CCMR3_OC6PE TIM_CCMR3_OC6PE_Msk |
| #define | TIM_CCMR3_OC6M_Pos (12U) |
| #define | TIM_CCMR3_OC6M_Msk (0x1007UL << TIM_CCMR3_OC6M_Pos) |
| #define | TIM_CCMR3_OC6M TIM_CCMR3_OC6M_Msk |
| #define | TIM_CCMR3_OC6M_0 (0x1UL << TIM_CCMR3_OC6M_Pos) |
| #define | TIM_CCMR3_OC6M_1 (0x2UL << TIM_CCMR3_OC6M_Pos) |
| #define | TIM_CCMR3_OC6M_2 (0x4UL << TIM_CCMR3_OC6M_Pos) |
| #define | TIM_CCMR3_OC6M_3 (0x1000UL << TIM_CCMR3_OC6M_Pos) |
| #define | TIM_CCMR3_OC6CE_Pos (15U) |
| #define | TIM_CCMR3_OC6CE_Msk (0x1UL << TIM_CCMR3_OC6CE_Pos) |
| #define | TIM_CCMR3_OC6CE TIM_CCMR3_OC6CE_Msk |
| #define | TIM1_AF1_BKINE_Pos (0U) |
| #define | TIM1_AF1_BKINE_Msk (0x1UL << TIM1_AF1_BKINE_Pos) |
| #define | TIM1_AF1_BKINE TIM1_AF1_BKINE_Msk |
| #define | TIM1_AF1_BKCMP1E_Pos (1U) |
| #define | TIM1_AF1_BKCMP1E_Msk (0x1UL << TIM1_AF1_BKCMP1E_Pos) |
| #define | TIM1_AF1_BKCMP1E TIM1_AF1_BKCMP1E_Msk |
| #define | TIM1_AF1_BKCMP2E_Pos (2U) |
| #define | TIM1_AF1_BKCMP2E_Msk (0x1UL << TIM1_AF1_BKCMP2E_Pos) |
| #define | TIM1_AF1_BKCMP2E TIM1_AF1_BKCMP2E_Msk |
| #define | TIM1_AF1_BKDF1BK0E_Pos (8U) |
| #define | TIM1_AF1_BKDF1BK0E_Msk (0x1UL << TIM1_AF1_BKDF1BK0E_Pos) |
| #define | TIM1_AF1_BKDF1BK0E TIM1_AF1_BKDF1BK0E_Msk |
| #define | TIM1_AF1_BKINP_Pos (9U) |
| #define | TIM1_AF1_BKINP_Msk (0x1UL << TIM1_AF1_BKINP_Pos) |
| #define | TIM1_AF1_BKINP TIM1_AF1_BKINP_Msk |
| #define | TIM1_AF1_BKCMP1P_Pos (10U) |
| #define | TIM1_AF1_BKCMP1P_Msk (0x1UL << TIM1_AF1_BKCMP1P_Pos) |
| #define | TIM1_AF1_BKCMP1P TIM1_AF1_BKCMP1P_Msk |
| #define | TIM1_AF1_BKCMP2P_Pos (11U) |
| #define | TIM1_AF1_BKCMP2P_Msk (0x1UL << TIM1_AF1_BKCMP2P_Pos) |
| #define | TIM1_AF1_BKCMP2P TIM1_AF1_BKCMP2P_Msk |
| #define | TIM1_AF1_ETRSEL_Pos (14U) |
| #define | TIM1_AF1_ETRSEL_Msk (0xFUL << TIM1_AF1_ETRSEL_Pos) |
| #define | TIM1_AF1_ETRSEL TIM1_AF1_ETRSEL_Msk |
| #define | TIM1_AF1_ETRSEL_0 (0x1UL << TIM1_AF1_ETRSEL_Pos) |
| #define | TIM1_AF1_ETRSEL_1 (0x2UL << TIM1_AF1_ETRSEL_Pos) |
| #define | TIM1_AF1_ETRSEL_2 (0x4UL << TIM1_AF1_ETRSEL_Pos) |
| #define | TIM1_AF1_ETRSEL_3 (0x8UL << TIM1_AF1_ETRSEL_Pos) |
| #define | TIM1_AF2_BK2INE_Pos (0U) |
| #define | TIM1_AF2_BK2INE_Msk (0x1UL << TIM1_AF2_BK2INE_Pos) |
| #define | TIM1_AF2_BK2INE TIM1_AF2_BK2INE_Msk |
| #define | TIM1_AF2_BK2CMP1E_Pos (1U) |
| #define | TIM1_AF2_BK2CMP1E_Msk (0x1UL << TIM1_AF2_BK2CMP1E_Pos) |
| #define | TIM1_AF2_BK2CMP1E TIM1_AF2_BK2CMP1E_Msk |
| #define | TIM1_AF2_BK2CMP2E_Pos (2U) |
| #define | TIM1_AF2_BK2CMP2E_Msk (0x1UL << TIM1_AF2_BK2CMP2E_Pos) |
| #define | TIM1_AF2_BK2CMP2E TIM1_AF2_BK2CMP2E_Msk |
| #define | TIM1_AF2_BK2DFBK1E_Pos (8U) |
| #define | TIM1_AF2_BK2DFBK1E_Msk (0x1UL << TIM1_AF2_BK2DFBK1E_Pos) |
| #define | TIM1_AF2_BK2DFBK1E TIM1_AF2_BK2DFBK1E_Msk |
| #define | TIM1_AF2_BK2INP_Pos (9U) |
| #define | TIM1_AF2_BK2INP_Msk (0x1UL << TIM1_AF2_BK2INP_Pos) |
| #define | TIM1_AF2_BK2INP TIM1_AF2_BK2INP_Msk |
| #define | TIM1_AF2_BK2CMP1P_Pos (10U) |
| #define | TIM1_AF2_BK2CMP1P_Msk (0x1UL << TIM1_AF2_BK2CMP1P_Pos) |
| #define | TIM1_AF2_BK2CMP1P TIM1_AF2_BK2CMP1P_Msk |
| #define | TIM1_AF2_BK2CMP2P_Pos (11U) |
| #define | TIM1_AF2_BK2CMP2P_Msk (0x1UL << TIM1_AF2_BK2CMP2P_Pos) |
| #define | TIM1_AF2_BK2CMP2P TIM1_AF2_BK2CMP2P_Msk |
| #define | TIM_TISEL_TI1SEL_Pos (0U) |
| #define | TIM_TISEL_TI1SEL_Msk (0xFUL << TIM_TISEL_TI1SEL_Pos) |
| #define | TIM_TISEL_TI1SEL TIM_TISEL_TI1SEL_Msk |
| #define | TIM_TISEL_TI1SEL_0 (0x1UL << TIM_TISEL_TI1SEL_Pos) |
| #define | TIM_TISEL_TI1SEL_1 (0x2UL << TIM_TISEL_TI1SEL_Pos) |
| #define | TIM_TISEL_TI1SEL_2 (0x4UL << TIM_TISEL_TI1SEL_Pos) |
| #define | TIM_TISEL_TI1SEL_3 (0x8UL << TIM_TISEL_TI1SEL_Pos) |
| #define | TIM_TISEL_TI2SEL_Pos (8U) |
| #define | TIM_TISEL_TI2SEL_Msk (0xFUL << TIM_TISEL_TI2SEL_Pos) |
| #define | TIM_TISEL_TI2SEL TIM_TISEL_TI2SEL_Msk |
| #define | TIM_TISEL_TI2SEL_0 (0x1UL << TIM_TISEL_TI2SEL_Pos) |
| #define | TIM_TISEL_TI2SEL_1 (0x2UL << TIM_TISEL_TI2SEL_Pos) |
| #define | TIM_TISEL_TI2SEL_2 (0x4UL << TIM_TISEL_TI2SEL_Pos) |
| #define | TIM_TISEL_TI2SEL_3 (0x8UL << TIM_TISEL_TI2SEL_Pos) |
| #define | TIM_TISEL_TI3SEL_Pos (16U) |
| #define | TIM_TISEL_TI3SEL_Msk (0xFUL << TIM_TISEL_TI3SEL_Pos) |
| #define | TIM_TISEL_TI3SEL TIM_TISEL_TI3SEL_Msk |
| #define | TIM_TISEL_TI3SEL_0 (0x1UL << TIM_TISEL_TI3SEL_Pos) |
| #define | TIM_TISEL_TI3SEL_1 (0x2UL << TIM_TISEL_TI3SEL_Pos) |
| #define | TIM_TISEL_TI3SEL_2 (0x4UL << TIM_TISEL_TI3SEL_Pos) |
| #define | TIM_TISEL_TI3SEL_3 (0x8UL << TIM_TISEL_TI3SEL_Pos) |
| #define | TIM_TISEL_TI4SEL_Pos (24U) |
| #define | TIM_TISEL_TI4SEL_Msk (0xFUL << TIM_TISEL_TI4SEL_Pos) |
| #define | TIM_TISEL_TI4SEL TIM_TISEL_TI4SEL_Msk |
| #define | TIM_TISEL_TI4SEL_0 (0x1UL << TIM_TISEL_TI4SEL_Pos) |
| #define | TIM_TISEL_TI4SEL_1 (0x2UL << TIM_TISEL_TI4SEL_Pos) |
| #define | TIM_TISEL_TI4SEL_2 (0x4UL << TIM_TISEL_TI4SEL_Pos) |
| #define | TIM_TISEL_TI4SEL_3 (0x8UL << TIM_TISEL_TI4SEL_Pos) |
| #define | TIM8_AF1_BKINE_Pos (0U) |
| #define | TIM8_AF1_BKINE_Msk (0x1UL << TIM8_AF1_BKINE_Pos) |
| #define | TIM8_AF1_BKINE TIM8_AF1_BKINE_Msk |
| #define | TIM8_AF1_BKCMP1E_Pos (1U) |
| #define | TIM8_AF1_BKCMP1E_Msk (0x1UL << TIM8_AF1_BKCMP1E_Pos) |
| #define | TIM8_AF1_BKCMP1E TIM8_AF1_BKCMP1E_Msk |
| #define | TIM8_AF1_BKCMP2E_Pos (2U) |
| #define | TIM8_AF1_BKCMP2E_Msk (0x1UL << TIM8_AF1_BKCMP2E_Pos) |
| #define | TIM8_AF1_BKCMP2E TIM8_AF1_BKCMP2E_Msk |
| #define | TIM8_AF1_BKDFBK2E_Pos (8U) |
| #define | TIM8_AF1_BKDFBK2E_Msk (0x1UL << TIM8_AF1_BKDFBK2E_Pos) |
| #define | TIM8_AF1_BKDFBK2E TIM8_AF1_BKDFBK2E_Msk |
| #define | TIM8_AF1_BKINP_Pos (9U) |
| #define | TIM8_AF1_BKINP_Msk (0x1UL << TIM8_AF1_BKINP_Pos) |
| #define | TIM8_AF1_BKINP TIM8_AF1_BKINP_Msk |
| #define | TIM8_AF1_BKCMP1P_Pos (10U) |
| #define | TIM8_AF1_BKCMP1P_Msk (0x1UL << TIM8_AF1_BKCMP1P_Pos) |
| #define | TIM8_AF1_BKCMP1P TIM8_AF1_BKCMP1P_Msk |
| #define | TIM8_AF1_BKCMP2P_Pos (11U) |
| #define | TIM8_AF1_BKCMP2P_Msk (0x1UL << TIM8_AF1_BKCMP2P_Pos) |
| #define | TIM8_AF1_BKCMP2P TIM8_AF1_BKCMP2P_Msk |
| #define | TIM8_AF1_ETRSEL_Pos (14U) |
| #define | TIM8_AF1_ETRSEL_Msk (0xFUL << TIM8_AF1_ETRSEL_Pos) |
| #define | TIM8_AF1_ETRSEL TIM8_AF1_ETRSEL_Msk |
| #define | TIM8_AF1_ETRSEL_0 (0x1UL << TIM8_AF1_ETRSEL_Pos) |
| #define | TIM8_AF1_ETRSEL_1 (0x2UL << TIM8_AF1_ETRSEL_Pos) |
| #define | TIM8_AF1_ETRSEL_2 (0x4UL << TIM8_AF1_ETRSEL_Pos) |
| #define | TIM8_AF1_ETRSEL_3 (0x8UL << TIM8_AF1_ETRSEL_Pos) |
| #define | TIM8_AF2_BK2INE_Pos (0U) |
| #define | TIM8_AF2_BK2INE_Msk (0x1UL << TIM8_AF2_BK2INE_Pos) |
| #define | TIM8_AF2_BK2INE TIM8_AF2_BK2INE_Msk |
| #define | TIM8_AF2_BK2CMP1E_Pos (1U) |
| #define | TIM8_AF2_BK2CMP1E_Msk (0x1UL << TIM8_AF2_BK2CMP1E_Pos) |
| #define | TIM8_AF2_BK2CMP1E TIM8_AF2_BK2CMP1E_Msk |
| #define | TIM8_AF2_BK2CMP2E_Pos (2U) |
| #define | TIM8_AF2_BK2CMP2E_Msk (0x1UL << TIM8_AF2_BK2CMP2E_Pos) |
| #define | TIM8_AF2_BK2CMP2E TIM8_AF2_BK2CMP2E_Msk |
| #define | TIM8_AF2_BK2DFBK3E_Pos (8U) |
| #define | TIM8_AF2_BK2DFBK3E_Msk (0x1UL << TIM8_AF2_BK2DFBK3E_Pos) |
| #define | TIM8_AF2_BK2DFBK3E TIM8_AF2_BK2DFBK3E_Msk |
| #define | TIM8_AF2_BK2INP_Pos (9U) |
| #define | TIM8_AF2_BK2INP_Msk (0x1UL << TIM8_AF2_BK2INP_Pos) |
| #define | TIM8_AF2_BK2INP TIM8_AF2_BK2INP_Msk |
| #define | TIM8_AF2_BK2CMP1P_Pos (10U) |
| #define | TIM8_AF2_BK2CMP1P_Msk (0x1UL << TIM8_AF2_BK2CMP1P_Pos) |
| #define | TIM8_AF2_BK2CMP1P TIM8_AF2_BK2CMP1P_Msk |
| #define | TIM8_AF2_BK2CMP2P_Pos (11U) |
| #define | TIM8_AF2_BK2CMP2P_Msk (0x1UL << TIM8_AF2_BK2CMP2P_Pos) |
| #define | TIM8_AF2_BK2CMP2P TIM8_AF2_BK2CMP2P_Msk |
| #define | TIM2_AF1_ETRSEL_Pos (14U) |
| #define | TIM2_AF1_ETRSEL_Msk (0xFUL << TIM2_AF1_ETRSEL_Pos) |
| #define | TIM2_AF1_ETRSEL TIM2_AF1_ETRSEL_Msk |
| #define | TIM2_AF1_ETRSEL_0 (0x1UL << TIM2_AF1_ETRSEL_Pos) |
| #define | TIM2_AF1_ETRSEL_1 (0x2UL << TIM2_AF1_ETRSEL_Pos) |
| #define | TIM2_AF1_ETRSEL_2 (0x4UL << TIM2_AF1_ETRSEL_Pos) |
| #define | TIM2_AF1_ETRSEL_3 (0x8UL << TIM2_AF1_ETRSEL_Pos) |
| #define | TIM3_AF1_ETRSEL_Pos (14U) |
| #define | TIM3_AF1_ETRSEL_Msk (0xFUL << TIM3_AF1_ETRSEL_Pos) |
| #define | TIM3_AF1_ETRSEL TIM3_AF1_ETRSEL_Msk |
| #define | TIM3_AF1_ETRSEL_0 (0x1UL << TIM3_AF1_ETRSEL_Pos) |
| #define | TIM3_AF1_ETRSEL_1 (0x2UL << TIM3_AF1_ETRSEL_Pos) |
| #define | TIM3_AF1_ETRSEL_2 (0x4UL << TIM3_AF1_ETRSEL_Pos) |
| #define | TIM3_AF1_ETRSEL_3 (0x8UL << TIM3_AF1_ETRSEL_Pos) |
| #define | TIM5_AF1_ETRSEL_Pos (14U) |
| #define | TIM5_AF1_ETRSEL_Msk (0xFUL << TIM5_AF1_ETRSEL_Pos) |
| #define | TIM5_AF1_ETRSEL TIM5_AF1_ETRSEL_Msk |
| #define | TIM5_AF1_ETRSEL_0 (0x1UL << TIM5_AF1_ETRSEL_Pos) |
| #define | TIM5_AF1_ETRSEL_1 (0x2UL << TIM5_AF1_ETRSEL_Pos) |
| #define | TIM5_AF1_ETRSEL_2 (0x4UL << TIM5_AF1_ETRSEL_Pos) |
| #define | TIM5_AF1_ETRSEL_3 (0x8UL << TIM5_AF1_ETRSEL_Pos) |
| #define | TIM15_AF1_BKINE_Pos (0U) |
| #define | TIM15_AF1_BKINE_Msk (0x1UL << TIM15_AF1_BKINE_Pos) |
| #define | TIM15_AF1_BKINE TIM15_AF1_BKINE_Msk |
| #define | TIM15_AF1_BKCMP1E_Pos (1U) |
| #define | TIM15_AF1_BKCMP1E_Msk (0x1UL << TIM15_AF1_BKCMP1E_Pos) |
| #define | TIM15_AF1_BKCMP1E TIM15_AF1_BKCMP1E_Msk |
| #define | TIM15_AF1_BKCMP2E_Pos (2U) |
| #define | TIM15_AF1_BKCMP2E_Msk (0x1UL << TIM15_AF1_BKCMP2E_Pos) |
| #define | TIM15_AF1_BKCMP2E TIM15_AF1_BKCMP2E_Msk |
| #define | TIM15_AF1_BKDF1BK2E_Pos (8U) |
| #define | TIM15_AF1_BKDF1BK2E_Msk (0x1UL << TIM15_AF1_BKDF1BK2E_Pos) |
| #define | TIM15_AF1_BKDF1BK2E TIM15_AF1_BKDF1BK2E_Msk |
| #define | TIM15_AF1_BKINP_Pos (9U) |
| #define | TIM15_AF1_BKINP_Msk (0x1UL << TIM15_AF1_BKINP_Pos) |
| #define | TIM15_AF1_BKINP TIM15_AF1_BKINP_Msk |
| #define | TIM15_AF1_BKCMP1P_Pos (10U) |
| #define | TIM15_AF1_BKCMP1P_Msk (0x1UL << TIM15_AF1_BKCMP1P_Pos) |
| #define | TIM15_AF1_BKCMP1P TIM15_AF1_BKCMP1P_Msk |
| #define | TIM15_AF1_BKCMP2P_Pos (11U) |
| #define | TIM15_AF1_BKCMP2P_Msk (0x1UL << TIM15_AF1_BKCMP2P_Pos) |
| #define | TIM15_AF1_BKCMP2P TIM15_AF1_BKCMP2P_Msk |
| #define | TIM16_AF1_BKINE_Pos (0U) |
| #define | TIM16_AF1_BKINE_Msk (0x1UL << TIM16_AF1_BKINE_Pos) |
| #define | TIM16_AF1_BKINE TIM16_AF1_BKINE_Msk |
| #define | TIM16_AF1_BKCMP1E_Pos (1U) |
| #define | TIM16_AF1_BKCMP1E_Msk (0x1UL << TIM16_AF1_BKCMP1E_Pos) |
| #define | TIM16_AF1_BKCMP1E TIM16_AF1_BKCMP1E_Msk |
| #define | TIM16_AF1_BKCMP2E_Pos (2U) |
| #define | TIM16_AF1_BKCMP2E_Msk (0x1UL << TIM16_AF1_BKCMP2E_Pos) |
| #define | TIM16_AF1_BKCMP2E TIM16_AF1_BKCMP2E_Msk |
| #define | TIM16_AF1_BKDF1BK2E_Pos (8U) |
| #define | TIM16_AF1_BKDF1BK2E_Msk (0x1UL << TIM16_AF1_BKDF1BK2E_Pos) |
| #define | TIM16_AF1_BKDF1BK2E TIM16_AF1_BKDF1BK2E_Msk |
| #define | TIM16_AF1_BKINP_Pos (9U) |
| #define | TIM16_AF1_BKINP_Msk (0x1UL << TIM16_AF1_BKINP_Pos) |
| #define | TIM16_AF1_BKINP TIM16_AF1_BKINP_Msk |
| #define | TIM16_AF1_BKCMP1P_Pos (10U) |
| #define | TIM16_AF1_BKCMP1P_Msk (0x1UL << TIM16_AF1_BKCMP1P_Pos) |
| #define | TIM16_AF1_BKCMP1P TIM16_AF1_BKCMP1P_Msk |
| #define | TIM16_AF1_BKCMP2P_Pos (11U) |
| #define | TIM16_AF1_BKCMP2P_Msk (0x1UL << TIM16_AF1_BKCMP2P_Pos) |
| #define | TIM16_AF1_BKCMP2P TIM16_AF1_BKCMP2P_Msk |
| #define | TIM17_AF1_BKINE_Pos (0U) |
| #define | TIM17_AF1_BKINE_Msk (0x1UL << TIM17_AF1_BKINE_Pos) |
| #define | TIM17_AF1_BKINE TIM17_AF1_BKINE_Msk |
| #define | TIM17_AF1_BKCMP1E_Pos (1U) |
| #define | TIM17_AF1_BKCMP1E_Msk (0x1UL << TIM17_AF1_BKCMP1E_Pos) |
| #define | TIM17_AF1_BKCMP1E TIM17_AF1_BKCMP1E_Msk |
| #define | TIM17_AF1_BKCMP2E_Pos (2U) |
| #define | TIM17_AF1_BKCMP2E_Msk (0x1UL << TIM17_AF1_BKCMP2E_Pos) |
| #define | TIM17_AF1_BKCMP2E TIM17_AF1_BKCMP2E_Msk |
| #define | TIM17_AF1_BKDF1BK2E_Pos (8U) |
| #define | TIM17_AF1_BKDF1BK2E_Msk (0x1UL << TIM17_AF1_BKDF1BK2E_Pos) |
| #define | TIM17_AF1_BKDF1BK2E TIM17_AF1_BKDF1BK2E_Msk |
| #define | TIM17_AF1_BKINP_Pos (9U) |
| #define | TIM17_AF1_BKINP_Msk (0x1UL << TIM17_AF1_BKINP_Pos) |
| #define | TIM17_AF1_BKINP TIM17_AF1_BKINP_Msk |
| #define | TIM17_AF1_BKCMP1P_Pos (10U) |
| #define | TIM17_AF1_BKCMP1P_Msk (0x1UL << TIM17_AF1_BKCMP1P_Pos) |
| #define | TIM17_AF1_BKCMP1P TIM17_AF1_BKCMP1P_Msk |
| #define | TIM17_AF1_BKCMP2P_Pos (11U) |
| #define | TIM17_AF1_BKCMP2P_Msk (0x1UL << TIM17_AF1_BKCMP2P_Pos) |
| #define | TIM17_AF1_BKCMP2P TIM17_AF1_BKCMP2P_Msk |
| #define | LPTIM_ISR_CMPM_Pos (0U) |
| #define | LPTIM_ISR_CMPM_Msk (0x1UL << LPTIM_ISR_CMPM_Pos) |
| #define | LPTIM_ISR_CMPM LPTIM_ISR_CMPM_Msk |
| #define | LPTIM_ISR_ARRM_Pos (1U) |
| #define | LPTIM_ISR_ARRM_Msk (0x1UL << LPTIM_ISR_ARRM_Pos) |
| #define | LPTIM_ISR_ARRM LPTIM_ISR_ARRM_Msk |
| #define | LPTIM_ISR_EXTTRIG_Pos (2U) |
| #define | LPTIM_ISR_EXTTRIG_Msk (0x1UL << LPTIM_ISR_EXTTRIG_Pos) |
| #define | LPTIM_ISR_EXTTRIG LPTIM_ISR_EXTTRIG_Msk |
| #define | LPTIM_ISR_CMPOK_Pos (3U) |
| #define | LPTIM_ISR_CMPOK_Msk (0x1UL << LPTIM_ISR_CMPOK_Pos) |
| #define | LPTIM_ISR_CMPOK LPTIM_ISR_CMPOK_Msk |
| #define | LPTIM_ISR_ARROK_Pos (4U) |
| #define | LPTIM_ISR_ARROK_Msk (0x1UL << LPTIM_ISR_ARROK_Pos) |
| #define | LPTIM_ISR_ARROK LPTIM_ISR_ARROK_Msk |
| #define | LPTIM_ISR_UP_Pos (5U) |
| #define | LPTIM_ISR_UP_Msk (0x1UL << LPTIM_ISR_UP_Pos) |
| #define | LPTIM_ISR_UP LPTIM_ISR_UP_Msk |
| #define | LPTIM_ISR_DOWN_Pos (6U) |
| #define | LPTIM_ISR_DOWN_Msk (0x1UL << LPTIM_ISR_DOWN_Pos) |
| #define | LPTIM_ISR_DOWN LPTIM_ISR_DOWN_Msk |
| #define | LPTIM_ICR_CMPMCF_Pos (0U) |
| #define | LPTIM_ICR_CMPMCF_Msk (0x1UL << LPTIM_ICR_CMPMCF_Pos) |
| #define | LPTIM_ICR_CMPMCF LPTIM_ICR_CMPMCF_Msk |
| #define | LPTIM_ICR_ARRMCF_Pos (1U) |
| #define | LPTIM_ICR_ARRMCF_Msk (0x1UL << LPTIM_ICR_ARRMCF_Pos) |
| #define | LPTIM_ICR_ARRMCF LPTIM_ICR_ARRMCF_Msk |
| #define | LPTIM_ICR_EXTTRIGCF_Pos (2U) |
| #define | LPTIM_ICR_EXTTRIGCF_Msk (0x1UL << LPTIM_ICR_EXTTRIGCF_Pos) |
| #define | LPTIM_ICR_EXTTRIGCF LPTIM_ICR_EXTTRIGCF_Msk |
| #define | LPTIM_ICR_CMPOKCF_Pos (3U) |
| #define | LPTIM_ICR_CMPOKCF_Msk (0x1UL << LPTIM_ICR_CMPOKCF_Pos) |
| #define | LPTIM_ICR_CMPOKCF LPTIM_ICR_CMPOKCF_Msk |
| #define | LPTIM_ICR_ARROKCF_Pos (4U) |
| #define | LPTIM_ICR_ARROKCF_Msk (0x1UL << LPTIM_ICR_ARROKCF_Pos) |
| #define | LPTIM_ICR_ARROKCF LPTIM_ICR_ARROKCF_Msk |
| #define | LPTIM_ICR_UPCF_Pos (5U) |
| #define | LPTIM_ICR_UPCF_Msk (0x1UL << LPTIM_ICR_UPCF_Pos) |
| #define | LPTIM_ICR_UPCF LPTIM_ICR_UPCF_Msk |
| #define | LPTIM_ICR_DOWNCF_Pos (6U) |
| #define | LPTIM_ICR_DOWNCF_Msk (0x1UL << LPTIM_ICR_DOWNCF_Pos) |
| #define | LPTIM_ICR_DOWNCF LPTIM_ICR_DOWNCF_Msk |
| #define | LPTIM_IER_CMPMIE_Pos (0U) |
| #define | LPTIM_IER_CMPMIE_Msk (0x1UL << LPTIM_IER_CMPMIE_Pos) |
| #define | LPTIM_IER_CMPMIE LPTIM_IER_CMPMIE_Msk |
| #define | LPTIM_IER_ARRMIE_Pos (1U) |
| #define | LPTIM_IER_ARRMIE_Msk (0x1UL << LPTIM_IER_ARRMIE_Pos) |
| #define | LPTIM_IER_ARRMIE LPTIM_IER_ARRMIE_Msk |
| #define | LPTIM_IER_EXTTRIGIE_Pos (2U) |
| #define | LPTIM_IER_EXTTRIGIE_Msk (0x1UL << LPTIM_IER_EXTTRIGIE_Pos) |
| #define | LPTIM_IER_EXTTRIGIE LPTIM_IER_EXTTRIGIE_Msk |
| #define | LPTIM_IER_CMPOKIE_Pos (3U) |
| #define | LPTIM_IER_CMPOKIE_Msk (0x1UL << LPTIM_IER_CMPOKIE_Pos) |
| #define | LPTIM_IER_CMPOKIE LPTIM_IER_CMPOKIE_Msk |
| #define | LPTIM_IER_ARROKIE_Pos (4U) |
| #define | LPTIM_IER_ARROKIE_Msk (0x1UL << LPTIM_IER_ARROKIE_Pos) |
| #define | LPTIM_IER_ARROKIE LPTIM_IER_ARROKIE_Msk |
| #define | LPTIM_IER_UPIE_Pos (5U) |
| #define | LPTIM_IER_UPIE_Msk (0x1UL << LPTIM_IER_UPIE_Pos) |
| #define | LPTIM_IER_UPIE LPTIM_IER_UPIE_Msk |
| #define | LPTIM_IER_DOWNIE_Pos (6U) |
| #define | LPTIM_IER_DOWNIE_Msk (0x1UL << LPTIM_IER_DOWNIE_Pos) |
| #define | LPTIM_IER_DOWNIE LPTIM_IER_DOWNIE_Msk |
| #define | LPTIM_CFGR_CKSEL_Pos (0U) |
| #define | LPTIM_CFGR_CKSEL_Msk (0x1UL << LPTIM_CFGR_CKSEL_Pos) |
| #define | LPTIM_CFGR_CKSEL LPTIM_CFGR_CKSEL_Msk |
| #define | LPTIM_CFGR_CKPOL_Pos (1U) |
| #define | LPTIM_CFGR_CKPOL_Msk (0x3UL << LPTIM_CFGR_CKPOL_Pos) |
| #define | LPTIM_CFGR_CKPOL LPTIM_CFGR_CKPOL_Msk |
| #define | LPTIM_CFGR_CKPOL_0 (0x1UL << LPTIM_CFGR_CKPOL_Pos) |
| #define | LPTIM_CFGR_CKPOL_1 (0x2UL << LPTIM_CFGR_CKPOL_Pos) |
| #define | LPTIM_CFGR_CKFLT_Pos (3U) |
| #define | LPTIM_CFGR_CKFLT_Msk (0x3UL << LPTIM_CFGR_CKFLT_Pos) |
| #define | LPTIM_CFGR_CKFLT LPTIM_CFGR_CKFLT_Msk |
| #define | LPTIM_CFGR_CKFLT_0 (0x1UL << LPTIM_CFGR_CKFLT_Pos) |
| #define | LPTIM_CFGR_CKFLT_1 (0x2UL << LPTIM_CFGR_CKFLT_Pos) |
| #define | LPTIM_CFGR_TRGFLT_Pos (6U) |
| #define | LPTIM_CFGR_TRGFLT_Msk (0x3UL << LPTIM_CFGR_TRGFLT_Pos) |
| #define | LPTIM_CFGR_TRGFLT LPTIM_CFGR_TRGFLT_Msk |
| #define | LPTIM_CFGR_TRGFLT_0 (0x1UL << LPTIM_CFGR_TRGFLT_Pos) |
| #define | LPTIM_CFGR_TRGFLT_1 (0x2UL << LPTIM_CFGR_TRGFLT_Pos) |
| #define | LPTIM_CFGR_PRESC_Pos (9U) |
| #define | LPTIM_CFGR_PRESC_Msk (0x7UL << LPTIM_CFGR_PRESC_Pos) |
| #define | LPTIM_CFGR_PRESC LPTIM_CFGR_PRESC_Msk |
| #define | LPTIM_CFGR_PRESC_0 (0x1UL << LPTIM_CFGR_PRESC_Pos) |
| #define | LPTIM_CFGR_PRESC_1 (0x2UL << LPTIM_CFGR_PRESC_Pos) |
| #define | LPTIM_CFGR_PRESC_2 (0x4UL << LPTIM_CFGR_PRESC_Pos) |
| #define | LPTIM_CFGR_TRIGSEL_Pos (13U) |
| #define | LPTIM_CFGR_TRIGSEL_Msk (0x7UL << LPTIM_CFGR_TRIGSEL_Pos) |
| #define | LPTIM_CFGR_TRIGSEL LPTIM_CFGR_TRIGSEL_Msk |
| #define | LPTIM_CFGR_TRIGSEL_0 (0x1UL << LPTIM_CFGR_TRIGSEL_Pos) |
| #define | LPTIM_CFGR_TRIGSEL_1 (0x2UL << LPTIM_CFGR_TRIGSEL_Pos) |
| #define | LPTIM_CFGR_TRIGSEL_2 (0x4UL << LPTIM_CFGR_TRIGSEL_Pos) |
| #define | LPTIM_CFGR_TRIGEN_Pos (17U) |
| #define | LPTIM_CFGR_TRIGEN_Msk (0x3UL << LPTIM_CFGR_TRIGEN_Pos) |
| #define | LPTIM_CFGR_TRIGEN LPTIM_CFGR_TRIGEN_Msk |
| #define | LPTIM_CFGR_TRIGEN_0 (0x1UL << LPTIM_CFGR_TRIGEN_Pos) |
| #define | LPTIM_CFGR_TRIGEN_1 (0x2UL << LPTIM_CFGR_TRIGEN_Pos) |
| #define | LPTIM_CFGR_TIMOUT_Pos (19U) |
| #define | LPTIM_CFGR_TIMOUT_Msk (0x1UL << LPTIM_CFGR_TIMOUT_Pos) |
| #define | LPTIM_CFGR_TIMOUT LPTIM_CFGR_TIMOUT_Msk |
| #define | LPTIM_CFGR_WAVE_Pos (20U) |
| #define | LPTIM_CFGR_WAVE_Msk (0x1UL << LPTIM_CFGR_WAVE_Pos) |
| #define | LPTIM_CFGR_WAVE LPTIM_CFGR_WAVE_Msk |
| #define | LPTIM_CFGR_WAVPOL_Pos (21U) |
| #define | LPTIM_CFGR_WAVPOL_Msk (0x1UL << LPTIM_CFGR_WAVPOL_Pos) |
| #define | LPTIM_CFGR_WAVPOL LPTIM_CFGR_WAVPOL_Msk |
| #define | LPTIM_CFGR_PRELOAD_Pos (22U) |
| #define | LPTIM_CFGR_PRELOAD_Msk (0x1UL << LPTIM_CFGR_PRELOAD_Pos) |
| #define | LPTIM_CFGR_PRELOAD LPTIM_CFGR_PRELOAD_Msk |
| #define | LPTIM_CFGR_COUNTMODE_Pos (23U) |
| #define | LPTIM_CFGR_COUNTMODE_Msk (0x1UL << LPTIM_CFGR_COUNTMODE_Pos) |
| #define | LPTIM_CFGR_COUNTMODE LPTIM_CFGR_COUNTMODE_Msk |
| #define | LPTIM_CFGR_ENC_Pos (24U) |
| #define | LPTIM_CFGR_ENC_Msk (0x1UL << LPTIM_CFGR_ENC_Pos) |
| #define | LPTIM_CFGR_ENC LPTIM_CFGR_ENC_Msk |
| #define | LPTIM_CR_ENABLE_Pos (0U) |
| #define | LPTIM_CR_ENABLE_Msk (0x1UL << LPTIM_CR_ENABLE_Pos) |
| #define | LPTIM_CR_ENABLE LPTIM_CR_ENABLE_Msk |
| #define | LPTIM_CR_SNGSTRT_Pos (1U) |
| #define | LPTIM_CR_SNGSTRT_Msk (0x40001UL << LPTIM_CR_SNGSTRT_Pos) |
| #define | LPTIM_CR_SNGSTRT LPTIM_CR_SNGSTRT_Msk |
| #define | LPTIM_CR_CNTSTRT_Pos (2U) |
| #define | LPTIM_CR_CNTSTRT_Msk (0x1UL << LPTIM_CR_CNTSTRT_Pos) |
| #define | LPTIM_CR_CNTSTRT LPTIM_CR_CNTSTRT_Msk |
| #define | LPTIM_CR_COUNTRST_Pos (3U) |
| #define | LPTIM_CR_COUNTRST_Msk (0x1UL << LPTIM_CR_COUNTRST_Pos) |
| #define | LPTIM_CR_COUNTRST LPTIM_CR_COUNTRST_Msk |
| #define | LPTIM_CR_RSTARE_Pos (4U) |
| #define | LPTIM_CR_RSTARE_Msk (0x1UL << LPTIM_CR_RSTARE_Pos) |
| #define | LPTIM_CR_RSTARE LPTIM_CR_RSTARE_Msk |
| #define | LPTIM_CMP_CMP_Pos (0U) |
| #define | LPTIM_CMP_CMP_Msk (0xFFFFUL << LPTIM_CMP_CMP_Pos) |
| #define | LPTIM_CMP_CMP LPTIM_CMP_CMP_Msk |
| #define | LPTIM_ARR_ARR_Pos (0U) |
| #define | LPTIM_ARR_ARR_Msk (0xFFFFUL << LPTIM_ARR_ARR_Pos) |
| #define | LPTIM_ARR_ARR LPTIM_ARR_ARR_Msk |
| #define | LPTIM_CNT_CNT_Pos (0U) |
| #define | LPTIM_CNT_CNT_Msk (0xFFFFUL << LPTIM_CNT_CNT_Pos) |
| #define | LPTIM_CNT_CNT LPTIM_CNT_CNT_Msk |
| #define | LPTIM_CFGR2_IN1SEL_Pos (0U) |
| #define | LPTIM_CFGR2_IN1SEL_Msk (0x3UL << LPTIM_CFGR2_IN1SEL_Pos) |
| #define | LPTIM_CFGR2_IN1SEL LPTIM_CFGR2_IN1SEL_Msk |
| #define | LPTIM_CFGR2_IN1SEL_0 (0x1UL << LPTIM_CFGR2_IN1SEL_Pos) |
| #define | LPTIM_CFGR2_IN1SEL_1 (0x2UL << LPTIM_CFGR2_IN1SEL_Pos) |
| #define | LPTIM_CFGR2_IN2SEL_Pos (4U) |
| #define | LPTIM_CFGR2_IN2SEL_Msk (0x3UL << LPTIM_CFGR2_IN2SEL_Pos) |
| #define | LPTIM_CFGR2_IN2SEL LPTIM_CFGR2_IN2SEL_Msk |
| #define | LPTIM_CFGR2_IN2SEL_0 (0x1UL << LPTIM_CFGR2_IN2SEL_Pos) |
| #define | LPTIM_CFGR2_IN2SEL_1 (0x2UL << LPTIM_CFGR2_IN2SEL_Pos) |
| #define | COMP_SR_C1VAL_Pos (0U) |
| #define | COMP_SR_C1VAL_Msk (0x1UL << COMP_SR_C1VAL_Pos) |
| #define | COMP_SR_C1VAL COMP_SR_C1VAL_Msk |
| #define | COMP_SR_C2VAL_Pos (1U) |
| #define | COMP_SR_C2VAL_Msk (0x1UL << COMP_SR_C2VAL_Pos) |
| #define | COMP_SR_C2VAL COMP_SR_C2VAL_Msk |
| #define | COMP_SR_C1IF_Pos (16U) |
| #define | COMP_SR_C1IF_Msk (0x1UL << COMP_SR_C1IF_Pos) |
| #define | COMP_SR_C1IF COMP_SR_C1IF_Msk |
| #define | COMP_SR_C2IF_Pos (17U) |
| #define | COMP_SR_C2IF_Msk (0x1UL << COMP_SR_C2IF_Pos) |
| #define | COMP_SR_C2IF COMP_SR_C2IF_Msk |
| #define | COMP_ICFR_C1IF_Pos (16U) |
| #define | COMP_ICFR_C1IF_Msk (0x1UL << COMP_ICFR_C1IF_Pos) |
| #define | COMP_ICFR_C1IF COMP_ICFR_C1IF_Msk |
| #define | COMP_ICFR_C2IF_Pos (17U) |
| #define | COMP_ICFR_C2IF_Msk (0x1UL << COMP_ICFR_C2IF_Pos) |
| #define | COMP_ICFR_C2IF COMP_ICFR_C2IF_Msk |
| #define | COMP_OR_AFOPA6_Pos (0U) |
| #define | COMP_OR_AFOPA6_Msk (0x1UL << COMP_OR_AFOPA6_Pos) |
| #define | COMP_OR_AFOPA6 COMP_OR_AFOPA6_Msk |
| #define | COMP_OR_AFOPA8_Pos (1U) |
| #define | COMP_OR_AFOPA8_Msk (0x1UL << COMP_OR_AFOPA8_Pos) |
| #define | COMP_OR_AFOPA8 COMP_OR_AFOPA8_Msk |
| #define | COMP_OR_AFOPB12_Pos (2U) |
| #define | COMP_OR_AFOPB12_Msk (0x1UL << COMP_OR_AFOPB12_Pos) |
| #define | COMP_OR_AFOPB12 COMP_OR_AFOPB12_Msk |
| #define | COMP_OR_AFOPE6_Pos (3U) |
| #define | COMP_OR_AFOPE6_Msk (0x1UL << COMP_OR_AFOPE6_Pos) |
| #define | COMP_OR_AFOPE6 COMP_OR_AFOPE6_Msk |
| #define | COMP_OR_AFOPE15_Pos (4U) |
| #define | COMP_OR_AFOPE15_Msk (0x1UL << COMP_OR_AFOPE15_Pos) |
| #define | COMP_OR_AFOPE15 COMP_OR_AFOPE15_Msk |
| #define | COMP_OR_AFOPG2_Pos (5U) |
| #define | COMP_OR_AFOPG2_Msk (0x1UL << COMP_OR_AFOPG2_Pos) |
| #define | COMP_OR_AFOPG2 COMP_OR_AFOPG2_Msk |
| #define | COMP_OR_AFOPG3_Pos (6U) |
| #define | COMP_OR_AFOPG3_Msk (0x1UL << COMP_OR_AFOPG3_Pos) |
| #define | COMP_OR_AFOPG3 COMP_OR_AFOPG3_Msk |
| #define | COMP_OR_AFOPG4_Pos (7U) |
| #define | COMP_OR_AFOPG4_Msk (0x1UL << COMP_OR_AFOPG4_Pos) |
| #define | COMP_OR_AFOPG4 COMP_OR_AFOPG4_Msk |
| #define | COMP_OR_AFOPI1_Pos (8U) |
| #define | COMP_OR_AFOPI1_Msk (0x1UL << COMP_OR_AFOPI1_Pos) |
| #define | COMP_OR_AFOPI1 COMP_OR_AFOPI1_Msk |
| #define | COMP_OR_AFOPI4_Pos (9U) |
| #define | COMP_OR_AFOPI4_Msk (0x1UL << COMP_OR_AFOPI4_Pos) |
| #define | COMP_OR_AFOPI4 COMP_OR_AFOPI4_Msk |
| #define | COMP_OR_AFOPK2_Pos (10U) |
| #define | COMP_OR_AFOPK2_Msk (0x1UL << COMP_OR_AFOPK2_Pos) |
| #define | COMP_OR_AFOPK2 COMP_OR_AFOPK2_Msk |
| #define | COMP_CFGRx_EN_Pos (0U) |
| #define | COMP_CFGRx_EN_Msk (0x1UL << COMP_CFGRx_EN_Pos) |
| #define | COMP_CFGRx_EN COMP_CFGRx_EN_Msk |
| #define | COMP_CFGRx_BRGEN_Pos (1U) |
| #define | COMP_CFGRx_BRGEN_Msk (0x1UL << COMP_CFGRx_BRGEN_Pos) |
| #define | COMP_CFGRx_BRGEN COMP_CFGRx_BRGEN_Msk |
| #define | COMP_CFGRx_SCALEN_Pos (2U) |
| #define | COMP_CFGRx_SCALEN_Msk (0x1UL << COMP_CFGRx_SCALEN_Pos) |
| #define | COMP_CFGRx_SCALEN COMP_CFGRx_SCALEN_Msk |
| #define | COMP_CFGRx_POLARITY_Pos (3U) |
| #define | COMP_CFGRx_POLARITY_Msk (0x1UL << COMP_CFGRx_POLARITY_Pos) |
| #define | COMP_CFGRx_POLARITY COMP_CFGRx_POLARITY_Msk |
| #define | COMP_CFGRx_WINMODE_Pos (4U) |
| #define | COMP_CFGRx_WINMODE_Msk (0x1UL << COMP_CFGRx_WINMODE_Pos) |
| #define | COMP_CFGRx_WINMODE COMP_CFGRx_WINMODE_Msk |
| #define | COMP_CFGRx_ITEN_Pos (6U) |
| #define | COMP_CFGRx_ITEN_Msk (0x1UL << COMP_CFGRx_ITEN_Pos) |
| #define | COMP_CFGRx_ITEN COMP_CFGRx_ITEN_Msk |
| #define | COMP_CFGRx_HYST_Pos (8U) |
| #define | COMP_CFGRx_HYST_Msk (0x3UL << COMP_CFGRx_HYST_Pos) |
| #define | COMP_CFGRx_HYST COMP_CFGRx_HYST_Msk |
| #define | COMP_CFGRx_HYST_0 (0x1UL << COMP_CFGRx_HYST_Pos) |
| #define | COMP_CFGRx_HYST_1 (0x2UL << COMP_CFGRx_HYST_Pos) |
| #define | COMP_CFGRx_PWRMODE_Pos (12U) |
| #define | COMP_CFGRx_PWRMODE_Msk (0x3UL << COMP_CFGRx_PWRMODE_Pos) |
| #define | COMP_CFGRx_PWRMODE COMP_CFGRx_PWRMODE_Msk |
| #define | COMP_CFGRx_PWRMODE_0 (0x1UL << COMP_CFGRx_PWRMODE_Pos) |
| #define | COMP_CFGRx_PWRMODE_1 (0x2UL << COMP_CFGRx_PWRMODE_Pos) |
| #define | COMP_CFGRx_INMSEL_Pos (16U) |
| #define | COMP_CFGRx_INMSEL_Msk (0x7UL << COMP_CFGRx_INMSEL_Pos) |
| #define | COMP_CFGRx_INMSEL COMP_CFGRx_INMSEL_Msk |
| #define | COMP_CFGRx_INMSEL_0 (0x1UL << COMP_CFGRx_INMSEL_Pos) |
| #define | COMP_CFGRx_INMSEL_1 (0x2UL << COMP_CFGRx_INMSEL_Pos) |
| #define | COMP_CFGRx_INMSEL_2 (0x4UL << COMP_CFGRx_INMSEL_Pos) |
| #define | COMP_CFGRx_INPSEL_Pos (20U) |
| #define | COMP_CFGRx_INPSEL_Msk (0x1UL << COMP_CFGRx_INPSEL_Pos) |
| #define | COMP_CFGRx_INPSEL COMP_CFGRx_INPSEL_Msk |
| #define | COMP_CFGRx_BLANKING_Pos (24U) |
| #define | COMP_CFGRx_BLANKING_Msk (0xFUL << COMP_CFGRx_BLANKING_Pos) |
| #define | COMP_CFGRx_BLANKING COMP_CFGRx_BLANKING_Msk |
| #define | COMP_CFGRx_BLANKING_0 (0x1UL << COMP_CFGRx_BLANKING_Pos) |
| #define | COMP_CFGRx_BLANKING_1 (0x2UL << COMP_CFGRx_BLANKING_Pos) |
| #define | COMP_CFGRx_BLANKING_2 (0x4UL << COMP_CFGRx_BLANKING_Pos) |
| #define | COMP_CFGRx_LOCK_Pos (31U) |
| #define | COMP_CFGRx_LOCK_Msk (0x1UL << COMP_CFGRx_LOCK_Pos) |
| #define | COMP_CFGRx_LOCK COMP_CFGRx_LOCK_Msk |
| #define | USART_CR1_UE_Pos (0U) |
| #define | USART_CR1_UE_Msk (0x1UL << USART_CR1_UE_Pos) |
| #define | USART_CR1_UE USART_CR1_UE_Msk |
| #define | USART_CR1_UESM_Pos (1U) |
| #define | USART_CR1_UESM_Msk (0x1UL << USART_CR1_UESM_Pos) |
| #define | USART_CR1_UESM USART_CR1_UESM_Msk |
| #define | USART_CR1_RE_Pos (2U) |
| #define | USART_CR1_RE_Msk (0x1UL << USART_CR1_RE_Pos) |
| #define | USART_CR1_RE USART_CR1_RE_Msk |
| #define | USART_CR1_TE_Pos (3U) |
| #define | USART_CR1_TE_Msk (0x1UL << USART_CR1_TE_Pos) |
| #define | USART_CR1_TE USART_CR1_TE_Msk |
| #define | USART_CR1_IDLEIE_Pos (4U) |
| #define | USART_CR1_IDLEIE_Msk (0x1UL << USART_CR1_IDLEIE_Pos) |
| #define | USART_CR1_IDLEIE USART_CR1_IDLEIE_Msk |
| #define | USART_CR1_RXNEIE_RXFNEIE_Pos (5U) |
| #define | USART_CR1_RXNEIE_RXFNEIE_Msk (0x1UL << USART_CR1_RXNEIE_RXFNEIE_Pos) |
| #define | USART_CR1_RXNEIE_RXFNEIE USART_CR1_RXNEIE_RXFNEIE_Msk |
| #define | USART_CR1_TCIE_Pos (6U) |
| #define | USART_CR1_TCIE_Msk (0x1UL << USART_CR1_TCIE_Pos) |
| #define | USART_CR1_TCIE USART_CR1_TCIE_Msk |
| #define | USART_CR1_TXEIE_TXFNFIE_Pos (7U) |
| #define | USART_CR1_TXEIE_TXFNFIE_Msk (0x1UL << USART_CR1_TXEIE_TXFNFIE_Pos) |
| #define | USART_CR1_TXEIE_TXFNFIE USART_CR1_TXEIE_TXFNFIE_Msk |
| #define | USART_CR1_PEIE_Pos (8U) |
| #define | USART_CR1_PEIE_Msk (0x1UL << USART_CR1_PEIE_Pos) |
| #define | USART_CR1_PEIE USART_CR1_PEIE_Msk |
| #define | USART_CR1_PS_Pos (9U) |
| #define | USART_CR1_PS_Msk (0x1UL << USART_CR1_PS_Pos) |
| #define | USART_CR1_PS USART_CR1_PS_Msk |
| #define | USART_CR1_PCE_Pos (10U) |
| #define | USART_CR1_PCE_Msk (0x1UL << USART_CR1_PCE_Pos) |
| #define | USART_CR1_PCE USART_CR1_PCE_Msk |
| #define | USART_CR1_WAKE_Pos (11U) |
| #define | USART_CR1_WAKE_Msk (0x1UL << USART_CR1_WAKE_Pos) |
| #define | USART_CR1_WAKE USART_CR1_WAKE_Msk |
| #define | USART_CR1_M_Pos (12U) |
| #define | USART_CR1_M_Msk (0x10001UL << USART_CR1_M_Pos) |
| #define | USART_CR1_M USART_CR1_M_Msk |
| #define | USART_CR1_M0_Pos (12U) |
| #define | USART_CR1_M0_Msk (0x1UL << USART_CR1_M0_Pos) |
| #define | USART_CR1_M0 USART_CR1_M0_Msk |
| #define | USART_CR1_MME_Pos (13U) |
| #define | USART_CR1_MME_Msk (0x1UL << USART_CR1_MME_Pos) |
| #define | USART_CR1_MME USART_CR1_MME_Msk |
| #define | USART_CR1_CMIE_Pos (14U) |
| #define | USART_CR1_CMIE_Msk (0x1UL << USART_CR1_CMIE_Pos) |
| #define | USART_CR1_CMIE USART_CR1_CMIE_Msk |
| #define | USART_CR1_OVER8_Pos (15U) |
| #define | USART_CR1_OVER8_Msk (0x1UL << USART_CR1_OVER8_Pos) |
| #define | USART_CR1_OVER8 USART_CR1_OVER8_Msk |
| #define | USART_CR1_DEDT_Pos (16U) |
| #define | USART_CR1_DEDT_Msk (0x1FUL << USART_CR1_DEDT_Pos) |
| #define | USART_CR1_DEDT USART_CR1_DEDT_Msk |
| #define | USART_CR1_DEDT_0 (0x01UL << USART_CR1_DEDT_Pos) |
| #define | USART_CR1_DEDT_1 (0x02UL << USART_CR1_DEDT_Pos) |
| #define | USART_CR1_DEDT_2 (0x04UL << USART_CR1_DEDT_Pos) |
| #define | USART_CR1_DEDT_3 (0x08UL << USART_CR1_DEDT_Pos) |
| #define | USART_CR1_DEDT_4 (0x10UL << USART_CR1_DEDT_Pos) |
| #define | USART_CR1_DEAT_Pos (21U) |
| #define | USART_CR1_DEAT_Msk (0x1FUL << USART_CR1_DEAT_Pos) |
| #define | USART_CR1_DEAT USART_CR1_DEAT_Msk |
| #define | USART_CR1_DEAT_0 (0x01UL << USART_CR1_DEAT_Pos) |
| #define | USART_CR1_DEAT_1 (0x02UL << USART_CR1_DEAT_Pos) |
| #define | USART_CR1_DEAT_2 (0x04UL << USART_CR1_DEAT_Pos) |
| #define | USART_CR1_DEAT_3 (0x08UL << USART_CR1_DEAT_Pos) |
| #define | USART_CR1_DEAT_4 (0x10UL << USART_CR1_DEAT_Pos) |
| #define | USART_CR1_RTOIE_Pos (26U) |
| #define | USART_CR1_RTOIE_Msk (0x1UL << USART_CR1_RTOIE_Pos) |
| #define | USART_CR1_RTOIE USART_CR1_RTOIE_Msk |
| #define | USART_CR1_EOBIE_Pos (27U) |
| #define | USART_CR1_EOBIE_Msk (0x1UL << USART_CR1_EOBIE_Pos) |
| #define | USART_CR1_EOBIE USART_CR1_EOBIE_Msk |
| #define | USART_CR1_M1_Pos (28U) |
| #define | USART_CR1_M1_Msk (0x1UL << USART_CR1_M1_Pos) |
| #define | USART_CR1_M1 USART_CR1_M1_Msk |
| #define | USART_CR1_FIFOEN_Pos (29U) |
| #define | USART_CR1_FIFOEN_Msk (0x1UL << USART_CR1_FIFOEN_Pos) |
| #define | USART_CR1_FIFOEN USART_CR1_FIFOEN_Msk |
| #define | USART_CR1_TXFEIE_Pos (30U) |
| #define | USART_CR1_TXFEIE_Msk (0x1UL << USART_CR1_TXFEIE_Pos) |
| #define | USART_CR1_TXFEIE USART_CR1_TXFEIE_Msk |
| #define | USART_CR1_RXFFIE_Pos (31U) |
| #define | USART_CR1_RXFFIE_Msk (0x1UL << USART_CR1_RXFFIE_Pos) |
| #define | USART_CR1_RXFFIE USART_CR1_RXFFIE_Msk |
| #define | USART_CR1_RXNEIE USART_CR1_RXNEIE_RXFNEIE |
| #define | USART_CR1_TXEIE USART_CR1_TXEIE_TXFNFIE |
| #define | USART_CR2_SLVEN_Pos (0U) |
| #define | USART_CR2_SLVEN_Msk (0x1UL << USART_CR2_SLVEN_Pos) |
| #define | USART_CR2_SLVEN USART_CR2_SLVEN_Msk |
| #define | USART_CR2_DIS_NSS_Pos (3U) |
| #define | USART_CR2_DIS_NSS_Msk (0x1UL << USART_CR2_DIS_NSS_Pos) |
| #define | USART_CR2_DIS_NSS USART_CR2_DIS_NSS_Msk |
| #define | USART_CR2_ADDM7_Pos (4U) |
| #define | USART_CR2_ADDM7_Msk (0x1UL << USART_CR2_ADDM7_Pos) |
| #define | USART_CR2_ADDM7 USART_CR2_ADDM7_Msk |
| #define | USART_CR2_LBDL_Pos (5U) |
| #define | USART_CR2_LBDL_Msk (0x1UL << USART_CR2_LBDL_Pos) |
| #define | USART_CR2_LBDL USART_CR2_LBDL_Msk |
| #define | USART_CR2_LBDIE_Pos (6U) |
| #define | USART_CR2_LBDIE_Msk (0x1UL << USART_CR2_LBDIE_Pos) |
| #define | USART_CR2_LBDIE USART_CR2_LBDIE_Msk |
| #define | USART_CR2_LBCL_Pos (8U) |
| #define | USART_CR2_LBCL_Msk (0x1UL << USART_CR2_LBCL_Pos) |
| #define | USART_CR2_LBCL USART_CR2_LBCL_Msk |
| #define | USART_CR2_CPHA_Pos (9U) |
| #define | USART_CR2_CPHA_Msk (0x1UL << USART_CR2_CPHA_Pos) |
| #define | USART_CR2_CPHA USART_CR2_CPHA_Msk |
| #define | USART_CR2_CPOL_Pos (10U) |
| #define | USART_CR2_CPOL_Msk (0x1UL << USART_CR2_CPOL_Pos) |
| #define | USART_CR2_CPOL USART_CR2_CPOL_Msk |
| #define | USART_CR2_CLKEN_Pos (11U) |
| #define | USART_CR2_CLKEN_Msk (0x1UL << USART_CR2_CLKEN_Pos) |
| #define | USART_CR2_CLKEN USART_CR2_CLKEN_Msk |
| #define | USART_CR2_STOP_Pos (12U) |
| #define | USART_CR2_STOP_Msk (0x3UL << USART_CR2_STOP_Pos) |
| #define | USART_CR2_STOP USART_CR2_STOP_Msk |
| #define | USART_CR2_STOP_0 (0x1UL << USART_CR2_STOP_Pos) |
| #define | USART_CR2_STOP_1 (0x2UL << USART_CR2_STOP_Pos) |
| #define | USART_CR2_LINEN_Pos (14U) |
| #define | USART_CR2_LINEN_Msk (0x1UL << USART_CR2_LINEN_Pos) |
| #define | USART_CR2_LINEN USART_CR2_LINEN_Msk |
| #define | USART_CR2_SWAP_Pos (15U) |
| #define | USART_CR2_SWAP_Msk (0x1UL << USART_CR2_SWAP_Pos) |
| #define | USART_CR2_SWAP USART_CR2_SWAP_Msk |
| #define | USART_CR2_RXINV_Pos (16U) |
| #define | USART_CR2_RXINV_Msk (0x1UL << USART_CR2_RXINV_Pos) |
| #define | USART_CR2_RXINV USART_CR2_RXINV_Msk |
| #define | USART_CR2_TXINV_Pos (17U) |
| #define | USART_CR2_TXINV_Msk (0x1UL << USART_CR2_TXINV_Pos) |
| #define | USART_CR2_TXINV USART_CR2_TXINV_Msk |
| #define | USART_CR2_DATAINV_Pos (18U) |
| #define | USART_CR2_DATAINV_Msk (0x1UL << USART_CR2_DATAINV_Pos) |
| #define | USART_CR2_DATAINV USART_CR2_DATAINV_Msk |
| #define | USART_CR2_MSBFIRST_Pos (19U) |
| #define | USART_CR2_MSBFIRST_Msk (0x1UL << USART_CR2_MSBFIRST_Pos) |
| #define | USART_CR2_MSBFIRST USART_CR2_MSBFIRST_Msk |
| #define | USART_CR2_ABREN_Pos (20U) |
| #define | USART_CR2_ABREN_Msk (0x1UL << USART_CR2_ABREN_Pos) |
| #define | USART_CR2_ABREN USART_CR2_ABREN_Msk |
| #define | USART_CR2_ABRMODE_Pos (21U) |
| #define | USART_CR2_ABRMODE_Msk (0x3UL << USART_CR2_ABRMODE_Pos) |
| #define | USART_CR2_ABRMODE USART_CR2_ABRMODE_Msk |
| #define | USART_CR2_ABRMODE_0 (0x1UL << USART_CR2_ABRMODE_Pos) |
| #define | USART_CR2_ABRMODE_1 (0x2UL << USART_CR2_ABRMODE_Pos) |
| #define | USART_CR2_RTOEN_Pos (23U) |
| #define | USART_CR2_RTOEN_Msk (0x1UL << USART_CR2_RTOEN_Pos) |
| #define | USART_CR2_RTOEN USART_CR2_RTOEN_Msk |
| #define | USART_CR2_ADD_Pos (24U) |
| #define | USART_CR2_ADD_Msk (0xFFUL << USART_CR2_ADD_Pos) |
| #define | USART_CR2_ADD USART_CR2_ADD_Msk |
| #define | USART_CR3_EIE_Pos (0U) |
| #define | USART_CR3_EIE_Msk (0x1UL << USART_CR3_EIE_Pos) |
| #define | USART_CR3_EIE USART_CR3_EIE_Msk |
| #define | USART_CR3_IREN_Pos (1U) |
| #define | USART_CR3_IREN_Msk (0x1UL << USART_CR3_IREN_Pos) |
| #define | USART_CR3_IREN USART_CR3_IREN_Msk |
| #define | USART_CR3_IRLP_Pos (2U) |
| #define | USART_CR3_IRLP_Msk (0x1UL << USART_CR3_IRLP_Pos) |
| #define | USART_CR3_IRLP USART_CR3_IRLP_Msk |
| #define | USART_CR3_HDSEL_Pos (3U) |
| #define | USART_CR3_HDSEL_Msk (0x1UL << USART_CR3_HDSEL_Pos) |
| #define | USART_CR3_HDSEL USART_CR3_HDSEL_Msk |
| #define | USART_CR3_NACK_Pos (4U) |
| #define | USART_CR3_NACK_Msk (0x1UL << USART_CR3_NACK_Pos) |
| #define | USART_CR3_NACK USART_CR3_NACK_Msk |
| #define | USART_CR3_SCEN_Pos (5U) |
| #define | USART_CR3_SCEN_Msk (0x1UL << USART_CR3_SCEN_Pos) |
| #define | USART_CR3_SCEN USART_CR3_SCEN_Msk |
| #define | USART_CR3_DMAR_Pos (6U) |
| #define | USART_CR3_DMAR_Msk (0x1UL << USART_CR3_DMAR_Pos) |
| #define | USART_CR3_DMAR USART_CR3_DMAR_Msk |
| #define | USART_CR3_DMAT_Pos (7U) |
| #define | USART_CR3_DMAT_Msk (0x1UL << USART_CR3_DMAT_Pos) |
| #define | USART_CR3_DMAT USART_CR3_DMAT_Msk |
| #define | USART_CR3_RTSE_Pos (8U) |
| #define | USART_CR3_RTSE_Msk (0x1UL << USART_CR3_RTSE_Pos) |
| #define | USART_CR3_RTSE USART_CR3_RTSE_Msk |
| #define | USART_CR3_CTSE_Pos (9U) |
| #define | USART_CR3_CTSE_Msk (0x1UL << USART_CR3_CTSE_Pos) |
| #define | USART_CR3_CTSE USART_CR3_CTSE_Msk |
| #define | USART_CR3_CTSIE_Pos (10U) |
| #define | USART_CR3_CTSIE_Msk (0x1UL << USART_CR3_CTSIE_Pos) |
| #define | USART_CR3_CTSIE USART_CR3_CTSIE_Msk |
| #define | USART_CR3_ONEBIT_Pos (11U) |
| #define | USART_CR3_ONEBIT_Msk (0x1UL << USART_CR3_ONEBIT_Pos) |
| #define | USART_CR3_ONEBIT USART_CR3_ONEBIT_Msk |
| #define | USART_CR3_OVRDIS_Pos (12U) |
| #define | USART_CR3_OVRDIS_Msk (0x1UL << USART_CR3_OVRDIS_Pos) |
| #define | USART_CR3_OVRDIS USART_CR3_OVRDIS_Msk |
| #define | USART_CR3_DDRE_Pos (13U) |
| #define | USART_CR3_DDRE_Msk (0x1UL << USART_CR3_DDRE_Pos) |
| #define | USART_CR3_DDRE USART_CR3_DDRE_Msk |
| #define | USART_CR3_DEM_Pos (14U) |
| #define | USART_CR3_DEM_Msk (0x1UL << USART_CR3_DEM_Pos) |
| #define | USART_CR3_DEM USART_CR3_DEM_Msk |
| #define | USART_CR3_DEP_Pos (15U) |
| #define | USART_CR3_DEP_Msk (0x1UL << USART_CR3_DEP_Pos) |
| #define | USART_CR3_DEP USART_CR3_DEP_Msk |
| #define | USART_CR3_SCARCNT_Pos (17U) |
| #define | USART_CR3_SCARCNT_Msk (0x7UL << USART_CR3_SCARCNT_Pos) |
| #define | USART_CR3_SCARCNT USART_CR3_SCARCNT_Msk |
| #define | USART_CR3_SCARCNT_0 (0x1UL << USART_CR3_SCARCNT_Pos) |
| #define | USART_CR3_SCARCNT_1 (0x2UL << USART_CR3_SCARCNT_Pos) |
| #define | USART_CR3_SCARCNT_2 (0x4UL << USART_CR3_SCARCNT_Pos) |
| #define | USART_CR3_WUS_Pos (20U) |
| #define | USART_CR3_WUS_Msk (0x3UL << USART_CR3_WUS_Pos) |
| #define | USART_CR3_WUS USART_CR3_WUS_Msk |
| #define | USART_CR3_WUS_0 (0x1UL << USART_CR3_WUS_Pos) |
| #define | USART_CR3_WUS_1 (0x2UL << USART_CR3_WUS_Pos) |
| #define | USART_CR3_WUFIE_Pos (22U) |
| #define | USART_CR3_WUFIE_Msk (0x1UL << USART_CR3_WUFIE_Pos) |
| #define | USART_CR3_WUFIE USART_CR3_WUFIE_Msk |
| #define | USART_CR3_TXFTIE_Pos (23U) |
| #define | USART_CR3_TXFTIE_Msk (0x1UL << USART_CR3_TXFTIE_Pos) |
| #define | USART_CR3_TXFTIE USART_CR3_TXFTIE_Msk |
| #define | USART_CR3_TCBGTIE_Pos (24U) |
| #define | USART_CR3_TCBGTIE_Msk (0x1UL << USART_CR3_TCBGTIE_Pos) |
| #define | USART_CR3_TCBGTIE USART_CR3_TCBGTIE_Msk |
| #define | USART_CR3_RXFTCFG_Pos (25U) |
| #define | USART_CR3_RXFTCFG_Msk (0x7UL << USART_CR3_RXFTCFG_Pos) |
| #define | USART_CR3_RXFTCFG USART_CR3_RXFTCFG_Msk |
| #define | USART_CR3_RXFTCFG_0 (0x1UL << USART_CR3_RXFTCFG_Pos) |
| #define | USART_CR3_RXFTCFG_1 (0x2UL << USART_CR3_RXFTCFG_Pos) |
| #define | USART_CR3_RXFTCFG_2 (0x4UL << USART_CR3_RXFTCFG_Pos) |
| #define | USART_CR3_RXFTIE_Pos (28U) |
| #define | USART_CR3_RXFTIE_Msk (0x1UL << USART_CR3_RXFTIE_Pos) |
| #define | USART_CR3_RXFTIE USART_CR3_RXFTIE_Msk |
| #define | USART_CR3_TXFTCFG_Pos (29U) |
| #define | USART_CR3_TXFTCFG_Msk (0x7UL << USART_CR3_TXFTCFG_Pos) |
| #define | USART_CR3_TXFTCFG USART_CR3_TXFTCFG_Msk |
| #define | USART_CR3_TXFTCFG_0 (0x1UL << USART_CR3_TXFTCFG_Pos) |
| #define | USART_CR3_TXFTCFG_1 (0x2UL << USART_CR3_TXFTCFG_Pos) |
| #define | USART_CR3_TXFTCFG_2 (0x4UL << USART_CR3_TXFTCFG_Pos) |
| #define | USART_BRR_DIV_FRACTION_Pos (0U) |
| #define | USART_BRR_DIV_FRACTION_Msk (0xFUL << USART_BRR_DIV_FRACTION_Pos) |
| #define | USART_BRR_DIV_FRACTION USART_BRR_DIV_FRACTION_Msk |
| #define | USART_BRR_DIV_MANTISSA_Pos (4U) |
| #define | USART_BRR_DIV_MANTISSA_Msk (0xFFFUL << USART_BRR_DIV_MANTISSA_Pos) |
| #define | USART_BRR_DIV_MANTISSA USART_BRR_DIV_MANTISSA_Msk |
| #define | USART_GTPR_PSC_Pos (0U) |
| #define | USART_GTPR_PSC_Msk (0xFFUL << USART_GTPR_PSC_Pos) |
| #define | USART_GTPR_PSC USART_GTPR_PSC_Msk |
| #define | USART_GTPR_GT_Pos (8U) |
| #define | USART_GTPR_GT_Msk (0xFFUL << USART_GTPR_GT_Pos) |
| #define | USART_GTPR_GT USART_GTPR_GT_Msk |
| #define | USART_RTOR_RTO_Pos (0U) |
| #define | USART_RTOR_RTO_Msk (0xFFFFFFUL << USART_RTOR_RTO_Pos) |
| #define | USART_RTOR_RTO USART_RTOR_RTO_Msk |
| #define | USART_RTOR_BLEN_Pos (24U) |
| #define | USART_RTOR_BLEN_Msk (0xFFUL << USART_RTOR_BLEN_Pos) |
| #define | USART_RTOR_BLEN USART_RTOR_BLEN_Msk |
| #define | USART_RQR_ABRRQ_Pos (0U) |
| #define | USART_RQR_ABRRQ_Msk (0x1UL << USART_RQR_ABRRQ_Pos) |
| #define | USART_RQR_ABRRQ USART_RQR_ABRRQ_Msk |
| #define | USART_RQR_SBKRQ_Pos (1U) |
| #define | USART_RQR_SBKRQ_Msk (0x1UL << USART_RQR_SBKRQ_Pos) |
| #define | USART_RQR_SBKRQ USART_RQR_SBKRQ_Msk |
| #define | USART_RQR_MMRQ_Pos (2U) |
| #define | USART_RQR_MMRQ_Msk (0x1UL << USART_RQR_MMRQ_Pos) |
| #define | USART_RQR_MMRQ USART_RQR_MMRQ_Msk |
| #define | USART_RQR_RXFRQ_Pos (3U) |
| #define | USART_RQR_RXFRQ_Msk (0x1UL << USART_RQR_RXFRQ_Pos) |
| #define | USART_RQR_RXFRQ USART_RQR_RXFRQ_Msk |
| #define | USART_RQR_TXFRQ_Pos (4U) |
| #define | USART_RQR_TXFRQ_Msk (0x1UL << USART_RQR_TXFRQ_Pos) |
| #define | USART_RQR_TXFRQ USART_RQR_TXFRQ_Msk |
| #define | USART_ISR_PE_Pos (0U) |
| #define | USART_ISR_PE_Msk (0x1UL << USART_ISR_PE_Pos) |
| #define | USART_ISR_PE USART_ISR_PE_Msk |
| #define | USART_ISR_FE_Pos (1U) |
| #define | USART_ISR_FE_Msk (0x1UL << USART_ISR_FE_Pos) |
| #define | USART_ISR_FE USART_ISR_FE_Msk |
| #define | USART_ISR_NE_Pos (2U) |
| #define | USART_ISR_NE_Msk (0x1UL << USART_ISR_NE_Pos) |
| #define | USART_ISR_NE USART_ISR_NE_Msk |
| #define | USART_ISR_ORE_Pos (3U) |
| #define | USART_ISR_ORE_Msk (0x1UL << USART_ISR_ORE_Pos) |
| #define | USART_ISR_ORE USART_ISR_ORE_Msk |
| #define | USART_ISR_IDLE_Pos (4U) |
| #define | USART_ISR_IDLE_Msk (0x1UL << USART_ISR_IDLE_Pos) |
| #define | USART_ISR_IDLE USART_ISR_IDLE_Msk |
| #define | USART_ISR_RXNE_RXFNE_Pos (5U) |
| #define | USART_ISR_RXNE_RXFNE_Msk (0x1UL << USART_ISR_RXNE_RXFNE_Pos) |
| #define | USART_ISR_RXNE_RXFNE USART_ISR_RXNE_RXFNE_Msk |
| #define | USART_ISR_TC_Pos (6U) |
| #define | USART_ISR_TC_Msk (0x1UL << USART_ISR_TC_Pos) |
| #define | USART_ISR_TC USART_ISR_TC_Msk |
| #define | USART_ISR_TXE_TXFNF_Pos (7U) |
| #define | USART_ISR_TXE_TXFNF_Msk (0x1UL << USART_ISR_TXE_TXFNF_Pos) |
| #define | USART_ISR_TXE_TXFNF USART_ISR_TXE_TXFNF_Msk |
| #define | USART_ISR_LBDF_Pos (8U) |
| #define | USART_ISR_LBDF_Msk (0x1UL << USART_ISR_LBDF_Pos) |
| #define | USART_ISR_LBDF USART_ISR_LBDF_Msk |
| #define | USART_ISR_CTSIF_Pos (9U) |
| #define | USART_ISR_CTSIF_Msk (0x1UL << USART_ISR_CTSIF_Pos) |
| #define | USART_ISR_CTSIF USART_ISR_CTSIF_Msk |
| #define | USART_ISR_CTS_Pos (10U) |
| #define | USART_ISR_CTS_Msk (0x1UL << USART_ISR_CTS_Pos) |
| #define | USART_ISR_CTS USART_ISR_CTS_Msk |
| #define | USART_ISR_RTOF_Pos (11U) |
| #define | USART_ISR_RTOF_Msk (0x1UL << USART_ISR_RTOF_Pos) |
| #define | USART_ISR_RTOF USART_ISR_RTOF_Msk |
| #define | USART_ISR_EOBF_Pos (12U) |
| #define | USART_ISR_EOBF_Msk (0x1UL << USART_ISR_EOBF_Pos) |
| #define | USART_ISR_EOBF USART_ISR_EOBF_Msk |
| #define | USART_ISR_UDR_Pos (13U) |
| #define | USART_ISR_UDR_Msk (0x1UL << USART_ISR_UDR_Pos) |
| #define | USART_ISR_UDR USART_ISR_UDR_Msk |
| #define | USART_ISR_ABRE_Pos (14U) |
| #define | USART_ISR_ABRE_Msk (0x1UL << USART_ISR_ABRE_Pos) |
| #define | USART_ISR_ABRE USART_ISR_ABRE_Msk |
| #define | USART_ISR_ABRF_Pos (15U) |
| #define | USART_ISR_ABRF_Msk (0x1UL << USART_ISR_ABRF_Pos) |
| #define | USART_ISR_ABRF USART_ISR_ABRF_Msk |
| #define | USART_ISR_BUSY_Pos (16U) |
| #define | USART_ISR_BUSY_Msk (0x1UL << USART_ISR_BUSY_Pos) |
| #define | USART_ISR_BUSY USART_ISR_BUSY_Msk |
| #define | USART_ISR_CMF_Pos (17U) |
| #define | USART_ISR_CMF_Msk (0x1UL << USART_ISR_CMF_Pos) |
| #define | USART_ISR_CMF USART_ISR_CMF_Msk |
| #define | USART_ISR_SBKF_Pos (18U) |
| #define | USART_ISR_SBKF_Msk (0x1UL << USART_ISR_SBKF_Pos) |
| #define | USART_ISR_SBKF USART_ISR_SBKF_Msk |
| #define | USART_ISR_RWU_Pos (19U) |
| #define | USART_ISR_RWU_Msk (0x1UL << USART_ISR_RWU_Pos) |
| #define | USART_ISR_RWU USART_ISR_RWU_Msk |
| #define | USART_ISR_WUF_Pos (20U) |
| #define | USART_ISR_WUF_Msk (0x1UL << USART_ISR_WUF_Pos) |
| #define | USART_ISR_WUF USART_ISR_WUF_Msk |
| #define | USART_ISR_TEACK_Pos (21U) |
| #define | USART_ISR_TEACK_Msk (0x1UL << USART_ISR_TEACK_Pos) |
| #define | USART_ISR_TEACK USART_ISR_TEACK_Msk |
| #define | USART_ISR_REACK_Pos (22U) |
| #define | USART_ISR_REACK_Msk (0x1UL << USART_ISR_REACK_Pos) |
| #define | USART_ISR_REACK USART_ISR_REACK_Msk |
| #define | USART_ISR_TXFE_Pos (23U) |
| #define | USART_ISR_TXFE_Msk (0x1UL << USART_ISR_TXFE_Pos) |
| #define | USART_ISR_TXFE USART_ISR_TXFE_Msk |
| #define | USART_ISR_RXFF_Pos (24U) |
| #define | USART_ISR_RXFF_Msk (0x1UL << USART_ISR_RXFF_Pos) |
| #define | USART_ISR_RXFF USART_ISR_RXFF_Msk |
| #define | USART_ISR_TCBGT_Pos (25U) |
| #define | USART_ISR_TCBGT_Msk (0x1UL << USART_ISR_TCBGT_Pos) |
| #define | USART_ISR_TCBGT USART_ISR_TCBGT_Msk |
| #define | USART_ISR_RXFT_Pos (26U) |
| #define | USART_ISR_RXFT_Msk (0x1UL << USART_ISR_RXFT_Pos) |
| #define | USART_ISR_RXFT USART_ISR_RXFT_Msk |
| #define | USART_ISR_TXFT_Pos (27U) |
| #define | USART_ISR_TXFT_Msk (0x1UL << USART_ISR_TXFT_Pos) |
| #define | USART_ISR_TXFT USART_ISR_TXFT_Msk |
| #define | USART_ICR_PECF_Pos (0U) |
| #define | USART_ICR_PECF_Msk (0x1UL << USART_ICR_PECF_Pos) |
| #define | USART_ICR_PECF USART_ICR_PECF_Msk |
| #define | USART_ICR_FECF_Pos (1U) |
| #define | USART_ICR_FECF_Msk (0x1UL << USART_ICR_FECF_Pos) |
| #define | USART_ICR_FECF USART_ICR_FECF_Msk |
| #define | USART_ICR_NECF_Pos (2U) |
| #define | USART_ICR_NECF_Msk (0x1UL << USART_ICR_NECF_Pos) |
| #define | USART_ICR_NECF USART_ICR_NECF_Msk |
| #define | USART_ICR_ORECF_Pos (3U) |
| #define | USART_ICR_ORECF_Msk (0x1UL << USART_ICR_ORECF_Pos) |
| #define | USART_ICR_ORECF USART_ICR_ORECF_Msk |
| #define | USART_ICR_IDLECF_Pos (4U) |
| #define | USART_ICR_IDLECF_Msk (0x1UL << USART_ICR_IDLECF_Pos) |
| #define | USART_ICR_IDLECF USART_ICR_IDLECF_Msk |
| #define | USART_ICR_TXFECF_Pos (5U) |
| #define | USART_ICR_TXFECF_Msk (0x1UL << USART_ICR_TXFECF_Pos) |
| #define | USART_ICR_TXFECF USART_ICR_TXFECF_Msk |
| #define | USART_ICR_TCCF_Pos (6U) |
| #define | USART_ICR_TCCF_Msk (0x1UL << USART_ICR_TCCF_Pos) |
| #define | USART_ICR_TCCF USART_ICR_TCCF_Msk |
| #define | USART_ICR_TCBGTCF_Pos (7U) |
| #define | USART_ICR_TCBGTCF_Msk (0x1UL << USART_ICR_TCBGTCF_Pos) |
| #define | USART_ICR_TCBGTCF USART_ICR_TCBGTCF_Msk |
| #define | USART_ICR_LBDCF_Pos (8U) |
| #define | USART_ICR_LBDCF_Msk (0x1UL << USART_ICR_LBDCF_Pos) |
| #define | USART_ICR_LBDCF USART_ICR_LBDCF_Msk |
| #define | USART_ICR_CTSCF_Pos (9U) |
| #define | USART_ICR_CTSCF_Msk (0x1UL << USART_ICR_CTSCF_Pos) |
| #define | USART_ICR_CTSCF USART_ICR_CTSCF_Msk |
| #define | USART_ICR_RTOCF_Pos (11U) |
| #define | USART_ICR_RTOCF_Msk (0x1UL << USART_ICR_RTOCF_Pos) |
| #define | USART_ICR_RTOCF USART_ICR_RTOCF_Msk |
| #define | USART_ICR_EOBCF_Pos (12U) |
| #define | USART_ICR_EOBCF_Msk (0x1UL << USART_ICR_EOBCF_Pos) |
| #define | USART_ICR_EOBCF USART_ICR_EOBCF_Msk |
| #define | USART_ICR_UDRCF_Pos (13U) |
| #define | USART_ICR_UDRCF_Msk (0x1UL << USART_ICR_UDRCF_Pos) |
| #define | USART_ICR_UDRCF USART_ICR_UDRCF_Msk |
| #define | USART_ICR_CMCF_Pos (17U) |
| #define | USART_ICR_CMCF_Msk (0x1UL << USART_ICR_CMCF_Pos) |
| #define | USART_ICR_CMCF USART_ICR_CMCF_Msk |
| #define | USART_ICR_WUCF_Pos (20U) |
| #define | USART_ICR_WUCF_Msk (0x1UL << USART_ICR_WUCF_Pos) |
| #define | USART_ICR_WUCF USART_ICR_WUCF_Msk |
| #define | USART_RDR_RDR_Pos (0U) |
| #define | USART_RDR_RDR_Msk (0x1FFUL << USART_RDR_RDR_Pos) |
| #define | USART_RDR_RDR USART_RDR_RDR_Msk |
| #define | USART_TDR_TDR_Pos (0U) |
| #define | USART_TDR_TDR_Msk (0x1FFUL << USART_TDR_TDR_Pos) |
| #define | USART_TDR_TDR USART_TDR_TDR_Msk |
| #define | USART_PRESC_PRESCALER_Pos (0U) |
| #define | USART_PRESC_PRESCALER_Msk (0xFUL << USART_PRESC_PRESCALER_Pos) |
| #define | USART_PRESC_PRESCALER USART_PRESC_PRESCALER_Msk |
| #define | USART_PRESC_PRESCALER_0 (0x1UL << USART_PRESC_PRESCALER_Pos) |
| #define | USART_PRESC_PRESCALER_1 (0x2UL << USART_PRESC_PRESCALER_Pos) |
| #define | USART_PRESC_PRESCALER_2 (0x4UL << USART_PRESC_PRESCALER_Pos) |
| #define | USART_PRESC_PRESCALER_3 (0x8UL << USART_PRESC_PRESCALER_Pos) |
| #define | SWPMI_CR_RXDMA_Pos (0U) |
| #define | SWPMI_CR_RXDMA_Msk (0x1UL << SWPMI_CR_RXDMA_Pos) |
| #define | SWPMI_CR_RXDMA SWPMI_CR_RXDMA_Msk |
| #define | SWPMI_CR_TXDMA_Pos (1U) |
| #define | SWPMI_CR_TXDMA_Msk (0x1UL << SWPMI_CR_TXDMA_Pos) |
| #define | SWPMI_CR_TXDMA SWPMI_CR_TXDMA_Msk |
| #define | SWPMI_CR_RXMODE_Pos (2U) |
| #define | SWPMI_CR_RXMODE_Msk (0x1UL << SWPMI_CR_RXMODE_Pos) |
| #define | SWPMI_CR_RXMODE SWPMI_CR_RXMODE_Msk |
| #define | SWPMI_CR_TXMODE_Pos (3U) |
| #define | SWPMI_CR_TXMODE_Msk (0x1UL << SWPMI_CR_TXMODE_Pos) |
| #define | SWPMI_CR_TXMODE SWPMI_CR_TXMODE_Msk |
| #define | SWPMI_CR_LPBK_Pos (4U) |
| #define | SWPMI_CR_LPBK_Msk (0x1UL << SWPMI_CR_LPBK_Pos) |
| #define | SWPMI_CR_LPBK SWPMI_CR_LPBK_Msk |
| #define | SWPMI_CR_SWPACT_Pos (5U) |
| #define | SWPMI_CR_SWPACT_Msk (0x1UL << SWPMI_CR_SWPACT_Pos) |
| #define | SWPMI_CR_SWPACT SWPMI_CR_SWPACT_Msk |
| #define | SWPMI_CR_DEACT_Pos (10U) |
| #define | SWPMI_CR_DEACT_Msk (0x1UL << SWPMI_CR_DEACT_Pos) |
| #define | SWPMI_CR_DEACT SWPMI_CR_DEACT_Msk |
| #define | SWPMI_CR_SWPEN_Pos (11U) |
| #define | SWPMI_CR_SWPEN_Msk (0x1UL << SWPMI_CR_SWPEN_Pos) |
| #define | SWPMI_CR_SWPEN SWPMI_CR_SWPEN_Msk |
| #define | SWPMI_BRR_BR_Pos (0U) |
| #define | SWPMI_BRR_BR_Msk (0xFFUL << SWPMI_BRR_BR_Pos) |
| #define | SWPMI_BRR_BR SWPMI_BRR_BR_Msk |
| #define | SWPMI_ISR_RXBFF_Pos (0U) |
| #define | SWPMI_ISR_RXBFF_Msk (0x1UL << SWPMI_ISR_RXBFF_Pos) |
| #define | SWPMI_ISR_RXBFF SWPMI_ISR_RXBFF_Msk |
| #define | SWPMI_ISR_TXBEF_Pos (1U) |
| #define | SWPMI_ISR_TXBEF_Msk (0x1UL << SWPMI_ISR_TXBEF_Pos) |
| #define | SWPMI_ISR_TXBEF SWPMI_ISR_TXBEF_Msk |
| #define | SWPMI_ISR_RXBERF_Pos (2U) |
| #define | SWPMI_ISR_RXBERF_Msk (0x1UL << SWPMI_ISR_RXBERF_Pos) |
| #define | SWPMI_ISR_RXBERF SWPMI_ISR_RXBERF_Msk |
| #define | SWPMI_ISR_RXOVRF_Pos (3U) |
| #define | SWPMI_ISR_RXOVRF_Msk (0x1UL << SWPMI_ISR_RXOVRF_Pos) |
| #define | SWPMI_ISR_RXOVRF SWPMI_ISR_RXOVRF_Msk |
| #define | SWPMI_ISR_TXUNRF_Pos (4U) |
| #define | SWPMI_ISR_TXUNRF_Msk (0x1UL << SWPMI_ISR_TXUNRF_Pos) |
| #define | SWPMI_ISR_TXUNRF SWPMI_ISR_TXUNRF_Msk |
| #define | SWPMI_ISR_RXNE_Pos (5U) |
| #define | SWPMI_ISR_RXNE_Msk (0x1UL << SWPMI_ISR_RXNE_Pos) |
| #define | SWPMI_ISR_RXNE SWPMI_ISR_RXNE_Msk |
| #define | SWPMI_ISR_TXE_Pos (6U) |
| #define | SWPMI_ISR_TXE_Msk (0x1UL << SWPMI_ISR_TXE_Pos) |
| #define | SWPMI_ISR_TXE SWPMI_ISR_TXE_Msk |
| #define | SWPMI_ISR_TCF_Pos (7U) |
| #define | SWPMI_ISR_TCF_Msk (0x1UL << SWPMI_ISR_TCF_Pos) |
| #define | SWPMI_ISR_TCF SWPMI_ISR_TCF_Msk |
| #define | SWPMI_ISR_SRF_Pos (8U) |
| #define | SWPMI_ISR_SRF_Msk (0x1UL << SWPMI_ISR_SRF_Pos) |
| #define | SWPMI_ISR_SRF SWPMI_ISR_SRF_Msk |
| #define | SWPMI_ISR_SUSP_Pos (9U) |
| #define | SWPMI_ISR_SUSP_Msk (0x1UL << SWPMI_ISR_SUSP_Pos) |
| #define | SWPMI_ISR_SUSP SWPMI_ISR_SUSP_Msk |
| #define | SWPMI_ISR_DEACTF_Pos (10U) |
| #define | SWPMI_ISR_DEACTF_Msk (0x1UL << SWPMI_ISR_DEACTF_Pos) |
| #define | SWPMI_ISR_DEACTF SWPMI_ISR_DEACTF_Msk |
| #define | SWPMI_ISR_RDYF_Pos (11U) |
| #define | SWPMI_ISR_RDYF_Msk (0x1UL << SWPMI_ISR_RDYF_Pos) |
| #define | SWPMI_ISR_RDYF SWPMI_ISR_RDYF_Msk |
| #define | SWPMI_ICR_CRXBFF_Pos (0U) |
| #define | SWPMI_ICR_CRXBFF_Msk (0x1UL << SWPMI_ICR_CRXBFF_Pos) |
| #define | SWPMI_ICR_CRXBFF SWPMI_ICR_CRXBFF_Msk |
| #define | SWPMI_ICR_CTXBEF_Pos (1U) |
| #define | SWPMI_ICR_CTXBEF_Msk (0x1UL << SWPMI_ICR_CTXBEF_Pos) |
| #define | SWPMI_ICR_CTXBEF SWPMI_ICR_CTXBEF_Msk |
| #define | SWPMI_ICR_CRXBERF_Pos (2U) |
| #define | SWPMI_ICR_CRXBERF_Msk (0x1UL << SWPMI_ICR_CRXBERF_Pos) |
| #define | SWPMI_ICR_CRXBERF SWPMI_ICR_CRXBERF_Msk |
| #define | SWPMI_ICR_CRXOVRF_Pos (3U) |
| #define | SWPMI_ICR_CRXOVRF_Msk (0x1UL << SWPMI_ICR_CRXOVRF_Pos) |
| #define | SWPMI_ICR_CRXOVRF SWPMI_ICR_CRXOVRF_Msk |
| #define | SWPMI_ICR_CTXUNRF_Pos (4U) |
| #define | SWPMI_ICR_CTXUNRF_Msk (0x1UL << SWPMI_ICR_CTXUNRF_Pos) |
| #define | SWPMI_ICR_CTXUNRF SWPMI_ICR_CTXUNRF_Msk |
| #define | SWPMI_ICR_CTCF_Pos (7U) |
| #define | SWPMI_ICR_CTCF_Msk (0x1UL << SWPMI_ICR_CTCF_Pos) |
| #define | SWPMI_ICR_CTCF SWPMI_ICR_CTCF_Msk |
| #define | SWPMI_ICR_CSRF_Pos (8U) |
| #define | SWPMI_ICR_CSRF_Msk (0x1UL << SWPMI_ICR_CSRF_Pos) |
| #define | SWPMI_ICR_CSRF SWPMI_ICR_CSRF_Msk |
| #define | SWPMI_ICR_CRDYF_Pos (11U) |
| #define | SWPMI_ICR_CRDYF_Msk (0x1UL << SWPMI_ICR_CRDYF_Pos) |
| #define | SWPMI_ICR_CRDYF SWPMI_ICR_CRDYF_Msk |
| #define | SWPMI_IER_RXBFIE_Pos (0U) |
| #define | SWPMI_IER_RXBFIE_Msk (0x1UL << SWPMI_IER_RXBFIE_Pos) |
| #define | SWPMI_IER_RXBFIE SWPMI_IER_RXBFIE_Msk |
| #define | SWPMI_IER_TXBEIE_Pos (1U) |
| #define | SWPMI_IER_TXBEIE_Msk (0x1UL << SWPMI_IER_TXBEIE_Pos) |
| #define | SWPMI_IER_TXBEIE SWPMI_IER_TXBEIE_Msk |
| #define | SWPMI_IER_RXBERIE_Pos (2U) |
| #define | SWPMI_IER_RXBERIE_Msk (0x1UL << SWPMI_IER_RXBERIE_Pos) |
| #define | SWPMI_IER_RXBERIE SWPMI_IER_RXBERIE_Msk |
| #define | SWPMI_IER_RXOVRIE_Pos (3U) |
| #define | SWPMI_IER_RXOVRIE_Msk (0x1UL << SWPMI_IER_RXOVRIE_Pos) |
| #define | SWPMI_IER_RXOVRIE SWPMI_IER_RXOVRIE_Msk |
| #define | SWPMI_IER_TXUNRIE_Pos (4U) |
| #define | SWPMI_IER_TXUNRIE_Msk (0x1UL << SWPMI_IER_TXUNRIE_Pos) |
| #define | SWPMI_IER_TXUNRIE SWPMI_IER_TXUNRIE_Msk |
| #define | SWPMI_IER_RIE_Pos (5U) |
| #define | SWPMI_IER_RIE_Msk (0x1UL << SWPMI_IER_RIE_Pos) |
| #define | SWPMI_IER_RIE SWPMI_IER_RIE_Msk |
| #define | SWPMI_IER_TIE_Pos (6U) |
| #define | SWPMI_IER_TIE_Msk (0x1UL << SWPMI_IER_TIE_Pos) |
| #define | SWPMI_IER_TIE SWPMI_IER_TIE_Msk |
| #define | SWPMI_IER_TCIE_Pos (7U) |
| #define | SWPMI_IER_TCIE_Msk (0x1UL << SWPMI_IER_TCIE_Pos) |
| #define | SWPMI_IER_TCIE SWPMI_IER_TCIE_Msk |
| #define | SWPMI_IER_SRIE_Pos (8U) |
| #define | SWPMI_IER_SRIE_Msk (0x1UL << SWPMI_IER_SRIE_Pos) |
| #define | SWPMI_IER_SRIE SWPMI_IER_SRIE_Msk |
| #define | SWPMI_IER_RDYIE_Pos (11U) |
| #define | SWPMI_IER_RDYIE_Msk (0x1UL << SWPMI_IER_RDYIE_Pos) |
| #define | SWPMI_IER_RDYIE SWPMI_IER_RDYIE_Msk |
| #define | SWPMI_RFL_RFL_Pos (0U) |
| #define | SWPMI_RFL_RFL_Msk (0x1FUL << SWPMI_RFL_RFL_Pos) |
| #define | SWPMI_RFL_RFL SWPMI_RFL_RFL_Msk |
| #define | SWPMI_RFL_RFL_0_1 (0x00000003U) |
| #define | SWPMI_TDR_TD_Pos (0U) |
| #define | SWPMI_TDR_TD_Msk (0xFFFFFFFFUL << SWPMI_TDR_TD_Pos) |
| #define | SWPMI_TDR_TD SWPMI_TDR_TD_Msk |
| #define | SWPMI_RDR_RD_Pos (0U) |
| #define | SWPMI_RDR_RD_Msk (0xFFFFFFFFUL << SWPMI_RDR_RD_Pos) |
| #define | SWPMI_RDR_RD SWPMI_RDR_RD_Msk |
| #define | SWPMI_OR_TBYP_Pos (0U) |
| #define | SWPMI_OR_TBYP_Msk (0x1UL << SWPMI_OR_TBYP_Pos) |
| #define | SWPMI_OR_TBYP SWPMI_OR_TBYP_Msk |
| #define | SWPMI_OR_CLASS_Pos (1U) |
| #define | SWPMI_OR_CLASS_Msk (0x1UL << SWPMI_OR_CLASS_Pos) |
| #define | SWPMI_OR_CLASS SWPMI_OR_CLASS_Msk |
| #define | WWDG_CR_T_Pos (0U) |
| #define | WWDG_CR_T_Msk (0x7FUL << WWDG_CR_T_Pos) |
| #define | WWDG_CR_T WWDG_CR_T_Msk |
| #define | WWDG_CR_T_0 (0x01UL << WWDG_CR_T_Pos) |
| #define | WWDG_CR_T_1 (0x02UL << WWDG_CR_T_Pos) |
| #define | WWDG_CR_T_2 (0x04UL << WWDG_CR_T_Pos) |
| #define | WWDG_CR_T_3 (0x08UL << WWDG_CR_T_Pos) |
| #define | WWDG_CR_T_4 (0x10UL << WWDG_CR_T_Pos) |
| #define | WWDG_CR_T_5 (0x20UL << WWDG_CR_T_Pos) |
| #define | WWDG_CR_T_6 (0x40UL << WWDG_CR_T_Pos) |
| #define | WWDG_CR_WDGA_Pos (7U) |
| #define | WWDG_CR_WDGA_Msk (0x1UL << WWDG_CR_WDGA_Pos) |
| #define | WWDG_CR_WDGA WWDG_CR_WDGA_Msk |
| #define | WWDG_CFR_W_Pos (0U) |
| #define | WWDG_CFR_W_Msk (0x7FUL << WWDG_CFR_W_Pos) |
| #define | WWDG_CFR_W WWDG_CFR_W_Msk |
| #define | WWDG_CFR_W_0 (0x01UL << WWDG_CFR_W_Pos) |
| #define | WWDG_CFR_W_1 (0x02UL << WWDG_CFR_W_Pos) |
| #define | WWDG_CFR_W_2 (0x04UL << WWDG_CFR_W_Pos) |
| #define | WWDG_CFR_W_3 (0x08UL << WWDG_CFR_W_Pos) |
| #define | WWDG_CFR_W_4 (0x10UL << WWDG_CFR_W_Pos) |
| #define | WWDG_CFR_W_5 (0x20UL << WWDG_CFR_W_Pos) |
| #define | WWDG_CFR_W_6 (0x40UL << WWDG_CFR_W_Pos) |
| #define | WWDG_CFR_EWI_Pos (9U) |
| #define | WWDG_CFR_EWI_Msk (0x1UL << WWDG_CFR_EWI_Pos) |
| #define | WWDG_CFR_EWI WWDG_CFR_EWI_Msk |
| #define | WWDG_CFR_WDGTB_Pos (11U) |
| #define | WWDG_CFR_WDGTB_Msk (0x7UL << WWDG_CFR_WDGTB_Pos) |
| #define | WWDG_CFR_WDGTB WWDG_CFR_WDGTB_Msk |
| #define | WWDG_CFR_WDGTB_0 (0x1UL << WWDG_CFR_WDGTB_Pos) |
| #define | WWDG_CFR_WDGTB_1 (0x2UL << WWDG_CFR_WDGTB_Pos) |
| #define | WWDG_CFR_WDGTB_2 (0x4UL << WWDG_CFR_WDGTB_Pos) |
| #define | WWDG_SR_EWIF_Pos (0U) |
| #define | WWDG_SR_EWIF_Msk (0x1UL << WWDG_SR_EWIF_Pos) |
| #define | WWDG_SR_EWIF WWDG_SR_EWIF_Msk |
| #define | STM32H7_DEV_ID 0x450UL |
| #define | DBGMCU_IDCODE_DEV_ID_Pos (0U) |
| #define | DBGMCU_IDCODE_DEV_ID_Msk (0xFFFUL << DBGMCU_IDCODE_DEV_ID_Pos) |
| #define | DBGMCU_IDCODE_DEV_ID DBGMCU_IDCODE_DEV_ID_Msk |
| #define | DBGMCU_IDCODE_REV_ID_Pos (16U) |
| #define | DBGMCU_IDCODE_REV_ID_Msk (0xFFFFUL << DBGMCU_IDCODE_REV_ID_Pos) |
| #define | DBGMCU_IDCODE_REV_ID DBGMCU_IDCODE_REV_ID_Msk |
| #define | DBGMCU_CR_DBG_SLEEPD1_Pos (0U) |
| #define | DBGMCU_CR_DBG_SLEEPD1_Msk (0x1UL << DBGMCU_CR_DBG_SLEEPD1_Pos) |
| #define | DBGMCU_CR_DBG_SLEEPD1 DBGMCU_CR_DBG_SLEEPD1_Msk |
| #define | DBGMCU_CR_DBG_STOPD1_Pos (1U) |
| #define | DBGMCU_CR_DBG_STOPD1_Msk (0x1UL << DBGMCU_CR_DBG_STOPD1_Pos) |
| #define | DBGMCU_CR_DBG_STOPD1 DBGMCU_CR_DBG_STOPD1_Msk |
| #define | DBGMCU_CR_DBG_STANDBYD1_Pos (2U) |
| #define | DBGMCU_CR_DBG_STANDBYD1_Msk (0x1UL << DBGMCU_CR_DBG_STANDBYD1_Pos) |
| #define | DBGMCU_CR_DBG_STANDBYD1 DBGMCU_CR_DBG_STANDBYD1_Msk |
| #define | DBGMCU_CR_DBG_TRACECKEN_Pos (20U) |
| #define | DBGMCU_CR_DBG_TRACECKEN_Msk (0x1UL << DBGMCU_CR_DBG_TRACECKEN_Pos) |
| #define | DBGMCU_CR_DBG_TRACECKEN DBGMCU_CR_DBG_TRACECKEN_Msk |
| #define | DBGMCU_CR_DBG_CKD1EN_Pos (21U) |
| #define | DBGMCU_CR_DBG_CKD1EN_Msk (0x1UL << DBGMCU_CR_DBG_CKD1EN_Pos) |
| #define | DBGMCU_CR_DBG_CKD1EN DBGMCU_CR_DBG_CKD1EN_Msk |
| #define | DBGMCU_CR_DBG_CKD3EN_Pos (22U) |
| #define | DBGMCU_CR_DBG_CKD3EN_Msk (0x1UL << DBGMCU_CR_DBG_CKD3EN_Pos) |
| #define | DBGMCU_CR_DBG_CKD3EN DBGMCU_CR_DBG_CKD3EN_Msk |
| #define | DBGMCU_CR_DBG_TRGOEN_Pos (28U) |
| #define | DBGMCU_CR_DBG_TRGOEN_Msk (0x1UL << DBGMCU_CR_DBG_TRGOEN_Pos) |
| #define | DBGMCU_CR_DBG_TRGOEN DBGMCU_CR_DBG_TRGOEN_Msk |
| #define | DBGMCU_APB3FZ1_DBG_WWDG1_Pos (6U) |
| #define | DBGMCU_APB3FZ1_DBG_WWDG1_Msk (0x1UL << DBGMCU_APB3FZ1_DBG_WWDG1_Pos) |
| #define | DBGMCU_APB3FZ1_DBG_WWDG1 DBGMCU_APB3FZ1_DBG_WWDG1_Msk |
| #define | DBGMCU_APB1LFZ1_DBG_TIM2_Pos (0U) |
| #define | DBGMCU_APB1LFZ1_DBG_TIM2_Msk (0x1UL << DBGMCU_APB1LFZ1_DBG_TIM2_Pos) |
| #define | DBGMCU_APB1LFZ1_DBG_TIM2 DBGMCU_APB1LFZ1_DBG_TIM2_Msk |
| #define | DBGMCU_APB1LFZ1_DBG_TIM3_Pos (1U) |
| #define | DBGMCU_APB1LFZ1_DBG_TIM3_Msk (0x1UL << DBGMCU_APB1LFZ1_DBG_TIM3_Pos) |
| #define | DBGMCU_APB1LFZ1_DBG_TIM3 DBGMCU_APB1LFZ1_DBG_TIM3_Msk |
| #define | DBGMCU_APB1LFZ1_DBG_TIM4_Pos (2U) |
| #define | DBGMCU_APB1LFZ1_DBG_TIM4_Msk (0x1UL << DBGMCU_APB1LFZ1_DBG_TIM4_Pos) |
| #define | DBGMCU_APB1LFZ1_DBG_TIM4 DBGMCU_APB1LFZ1_DBG_TIM4_Msk |
| #define | DBGMCU_APB1LFZ1_DBG_TIM5_Pos (3U) |
| #define | DBGMCU_APB1LFZ1_DBG_TIM5_Msk (0x1UL << DBGMCU_APB1LFZ1_DBG_TIM5_Pos) |
| #define | DBGMCU_APB1LFZ1_DBG_TIM5 DBGMCU_APB1LFZ1_DBG_TIM5_Msk |
| #define | DBGMCU_APB1LFZ1_DBG_TIM6_Pos (4U) |
| #define | DBGMCU_APB1LFZ1_DBG_TIM6_Msk (0x1UL << DBGMCU_APB1LFZ1_DBG_TIM6_Pos) |
| #define | DBGMCU_APB1LFZ1_DBG_TIM6 DBGMCU_APB1LFZ1_DBG_TIM6_Msk |
| #define | DBGMCU_APB1LFZ1_DBG_TIM7_Pos (5U) |
| #define | DBGMCU_APB1LFZ1_DBG_TIM7_Msk (0x1UL << DBGMCU_APB1LFZ1_DBG_TIM7_Pos) |
| #define | DBGMCU_APB1LFZ1_DBG_TIM7 DBGMCU_APB1LFZ1_DBG_TIM7_Msk |
| #define | DBGMCU_APB1LFZ1_DBG_TIM12_Pos (6U) |
| #define | DBGMCU_APB1LFZ1_DBG_TIM12_Msk (0x1UL << DBGMCU_APB1LFZ1_DBG_TIM12_Pos) |
| #define | DBGMCU_APB1LFZ1_DBG_TIM12 DBGMCU_APB1LFZ1_DBG_TIM12_Msk |
| #define | DBGMCU_APB1LFZ1_DBG_TIM13_Pos (7U) |
| #define | DBGMCU_APB1LFZ1_DBG_TIM13_Msk (0x1UL << DBGMCU_APB1LFZ1_DBG_TIM13_Pos) |
| #define | DBGMCU_APB1LFZ1_DBG_TIM13 DBGMCU_APB1LFZ1_DBG_TIM13_Msk |
| #define | DBGMCU_APB1LFZ1_DBG_TIM14_Pos (8U) |
| #define | DBGMCU_APB1LFZ1_DBG_TIM14_Msk (0x1UL << DBGMCU_APB1LFZ1_DBG_TIM14_Pos) |
| #define | DBGMCU_APB1LFZ1_DBG_TIM14 DBGMCU_APB1LFZ1_DBG_TIM14_Msk |
| #define | DBGMCU_APB1LFZ1_DBG_LPTIM1_Pos (9U) |
| #define | DBGMCU_APB1LFZ1_DBG_LPTIM1_Msk (0x1UL << DBGMCU_APB1LFZ1_DBG_LPTIM1_Pos) |
| #define | DBGMCU_APB1LFZ1_DBG_LPTIM1 DBGMCU_APB1LFZ1_DBG_LPTIM1_Msk |
| #define | DBGMCU_APB1LFZ1_DBG_I2C1_Pos (21U) |
| #define | DBGMCU_APB1LFZ1_DBG_I2C1_Msk (0x1UL << DBGMCU_APB1LFZ1_DBG_I2C1_Pos) |
| #define | DBGMCU_APB1LFZ1_DBG_I2C1 DBGMCU_APB1LFZ1_DBG_I2C1_Msk |
| #define | DBGMCU_APB1LFZ1_DBG_I2C2_Pos (22U) |
| #define | DBGMCU_APB1LFZ1_DBG_I2C2_Msk (0x1UL << DBGMCU_APB1LFZ1_DBG_I2C2_Pos) |
| #define | DBGMCU_APB1LFZ1_DBG_I2C2 DBGMCU_APB1LFZ1_DBG_I2C2_Msk |
| #define | DBGMCU_APB1LFZ1_DBG_I2C3_Pos (23U) |
| #define | DBGMCU_APB1LFZ1_DBG_I2C3_Msk (0x1UL << DBGMCU_APB1LFZ1_DBG_I2C3_Pos) |
| #define | DBGMCU_APB1LFZ1_DBG_I2C3 DBGMCU_APB1LFZ1_DBG_I2C3_Msk |
| #define | DBGMCU_APB1HFZ1_DBG_FDCAN_Pos (8U) |
| #define | DBGMCU_APB1HFZ1_DBG_FDCAN_Msk (0x1UL << DBGMCU_APB1HFZ1_DBG_FDCAN_Pos) |
| #define | DBGMCU_APB1HFZ1_DBG_FDCAN DBGMCU_APB1HFZ1_DBG_FDCAN_Msk |
| #define | DBGMCU_APB2FZ1_DBG_TIM1_Pos (0U) |
| #define | DBGMCU_APB2FZ1_DBG_TIM1_Msk (0x1UL << DBGMCU_APB2FZ1_DBG_TIM1_Pos) |
| #define | DBGMCU_APB2FZ1_DBG_TIM1 DBGMCU_APB2FZ1_DBG_TIM1_Msk |
| #define | DBGMCU_APB2FZ1_DBG_TIM8_Pos (1U) |
| #define | DBGMCU_APB2FZ1_DBG_TIM8_Msk (0x1UL << DBGMCU_APB2FZ1_DBG_TIM8_Pos) |
| #define | DBGMCU_APB2FZ1_DBG_TIM8 DBGMCU_APB2FZ1_DBG_TIM8_Msk |
| #define | DBGMCU_APB2FZ1_DBG_TIM15_Pos (16U) |
| #define | DBGMCU_APB2FZ1_DBG_TIM15_Msk (0x1UL << DBGMCU_APB2FZ1_DBG_TIM15_Pos) |
| #define | DBGMCU_APB2FZ1_DBG_TIM15 DBGMCU_APB2FZ1_DBG_TIM15_Msk |
| #define | DBGMCU_APB2FZ1_DBG_TIM16_Pos (17U) |
| #define | DBGMCU_APB2FZ1_DBG_TIM16_Msk (0x1UL << DBGMCU_APB2FZ1_DBG_TIM16_Pos) |
| #define | DBGMCU_APB2FZ1_DBG_TIM16 DBGMCU_APB2FZ1_DBG_TIM16_Msk |
| #define | DBGMCU_APB2FZ1_DBG_TIM17_Pos (18U) |
| #define | DBGMCU_APB2FZ1_DBG_TIM17_Msk (0x1UL << DBGMCU_APB2FZ1_DBG_TIM17_Pos) |
| #define | DBGMCU_APB2FZ1_DBG_TIM17 DBGMCU_APB2FZ1_DBG_TIM17_Msk |
| #define | DBGMCU_APB2FZ1_DBG_HRTIM_Pos (29U) |
| #define | DBGMCU_APB2FZ1_DBG_HRTIM_Msk (0x1UL << DBGMCU_APB2FZ1_DBG_HRTIM_Pos) |
| #define | DBGMCU_APB2FZ1_DBG_HRTIM DBGMCU_APB2FZ1_DBG_HRTIM_Msk |
| #define | DBGMCU_APB4FZ1_DBG_I2C4_Pos (7U) |
| #define | DBGMCU_APB4FZ1_DBG_I2C4_Msk (0x1UL << DBGMCU_APB4FZ1_DBG_I2C4_Pos) |
| #define | DBGMCU_APB4FZ1_DBG_I2C4 DBGMCU_APB4FZ1_DBG_I2C4_Msk |
| #define | DBGMCU_APB4FZ1_DBG_LPTIM2_Pos (9U) |
| #define | DBGMCU_APB4FZ1_DBG_LPTIM2_Msk (0x1UL << DBGMCU_APB4FZ1_DBG_LPTIM2_Pos) |
| #define | DBGMCU_APB4FZ1_DBG_LPTIM2 DBGMCU_APB4FZ1_DBG_LPTIM2_Msk |
| #define | DBGMCU_APB4FZ1_DBG_LPTIM3_Pos (10U) |
| #define | DBGMCU_APB4FZ1_DBG_LPTIM3_Msk (0x1UL << DBGMCU_APB4FZ1_DBG_LPTIM3_Pos) |
| #define | DBGMCU_APB4FZ1_DBG_LPTIM3 DBGMCU_APB4FZ1_DBG_LPTIM3_Msk |
| #define | DBGMCU_APB4FZ1_DBG_LPTIM4_Pos (11U) |
| #define | DBGMCU_APB4FZ1_DBG_LPTIM4_Msk (0x1UL << DBGMCU_APB4FZ1_DBG_LPTIM4_Pos) |
| #define | DBGMCU_APB4FZ1_DBG_LPTIM4 DBGMCU_APB4FZ1_DBG_LPTIM4_Msk |
| #define | DBGMCU_APB4FZ1_DBG_LPTIM5_Pos (12U) |
| #define | DBGMCU_APB4FZ1_DBG_LPTIM5_Msk (0x1UL << DBGMCU_APB4FZ1_DBG_LPTIM5_Pos) |
| #define | DBGMCU_APB4FZ1_DBG_LPTIM5 DBGMCU_APB4FZ1_DBG_LPTIM5_Msk |
| #define | DBGMCU_APB4FZ1_DBG_RTC_Pos (16U) |
| #define | DBGMCU_APB4FZ1_DBG_RTC_Msk (0x1UL << DBGMCU_APB4FZ1_DBG_RTC_Pos) |
| #define | DBGMCU_APB4FZ1_DBG_RTC DBGMCU_APB4FZ1_DBG_RTC_Msk |
| #define | DBGMCU_APB4FZ1_DBG_IWDG1_Pos (18U) |
| #define | DBGMCU_APB4FZ1_DBG_IWDG1_Msk (0x1UL << DBGMCU_APB4FZ1_DBG_IWDG1_Pos) |
| #define | DBGMCU_APB4FZ1_DBG_IWDG1 DBGMCU_APB4FZ1_DBG_IWDG1_Msk |
| #define | HRTIM_MCR_CK_PSC_Pos (0U) |
| #define | HRTIM_MCR_CK_PSC_Msk (0x7UL << HRTIM_MCR_CK_PSC_Pos) |
| #define | HRTIM_MCR_CK_PSC HRTIM_MCR_CK_PSC_Msk |
| #define | HRTIM_MCR_CK_PSC_0 (0x1UL << HRTIM_MCR_CK_PSC_Pos) |
| #define | HRTIM_MCR_CK_PSC_1 (0x2UL << HRTIM_MCR_CK_PSC_Pos) |
| #define | HRTIM_MCR_CK_PSC_2 (0x4UL << HRTIM_MCR_CK_PSC_Pos) |
| #define | HRTIM_MCR_CONT_Pos (3U) |
| #define | HRTIM_MCR_CONT_Msk (0x1UL << HRTIM_MCR_CONT_Pos) |
| #define | HRTIM_MCR_CONT HRTIM_MCR_CONT_Msk |
| #define | HRTIM_MCR_RETRIG_Pos (4U) |
| #define | HRTIM_MCR_RETRIG_Msk (0x1UL << HRTIM_MCR_RETRIG_Pos) |
| #define | HRTIM_MCR_RETRIG HRTIM_MCR_RETRIG_Msk |
| #define | HRTIM_MCR_HALF_Pos (5U) |
| #define | HRTIM_MCR_HALF_Msk (0x1UL << HRTIM_MCR_HALF_Pos) |
| #define | HRTIM_MCR_HALF HRTIM_MCR_HALF_Msk |
| #define | HRTIM_MCR_SYNC_IN_Pos (8U) |
| #define | HRTIM_MCR_SYNC_IN_Msk (0x3UL << HRTIM_MCR_SYNC_IN_Pos) |
| #define | HRTIM_MCR_SYNC_IN HRTIM_MCR_SYNC_IN_Msk |
| #define | HRTIM_MCR_SYNC_IN_0 (0x1UL << HRTIM_MCR_SYNC_IN_Pos) |
| #define | HRTIM_MCR_SYNC_IN_1 (0x2UL << HRTIM_MCR_SYNC_IN_Pos) |
| #define | HRTIM_MCR_SYNCRSTM_Pos (10U) |
| #define | HRTIM_MCR_SYNCRSTM_Msk (0x1UL << HRTIM_MCR_SYNCRSTM_Pos) |
| #define | HRTIM_MCR_SYNCRSTM HRTIM_MCR_SYNCRSTM_Msk |
| #define | HRTIM_MCR_SYNCSTRTM_Pos (11U) |
| #define | HRTIM_MCR_SYNCSTRTM_Msk (0x1UL << HRTIM_MCR_SYNCSTRTM_Pos) |
| #define | HRTIM_MCR_SYNCSTRTM HRTIM_MCR_SYNCSTRTM_Msk |
| #define | HRTIM_MCR_SYNC_OUT_Pos (12U) |
| #define | HRTIM_MCR_SYNC_OUT_Msk (0x3UL << HRTIM_MCR_SYNC_OUT_Pos) |
| #define | HRTIM_MCR_SYNC_OUT HRTIM_MCR_SYNC_OUT_Msk |
| #define | HRTIM_MCR_SYNC_OUT_0 (0x1UL << HRTIM_MCR_SYNC_OUT_Pos) |
| #define | HRTIM_MCR_SYNC_OUT_1 (0x2UL << HRTIM_MCR_SYNC_OUT_Pos) |
| #define | HRTIM_MCR_SYNC_SRC_Pos (14U) |
| #define | HRTIM_MCR_SYNC_SRC_Msk (0x3UL << HRTIM_MCR_SYNC_SRC_Pos) |
| #define | HRTIM_MCR_SYNC_SRC HRTIM_MCR_SYNC_SRC_Msk |
| #define | HRTIM_MCR_SYNC_SRC_0 (0x1UL << HRTIM_MCR_SYNC_SRC_Pos) |
| #define | HRTIM_MCR_SYNC_SRC_1 (0x2UL << HRTIM_MCR_SYNC_SRC_Pos) |
| #define | HRTIM_MCR_MCEN_Pos (16U) |
| #define | HRTIM_MCR_MCEN_Msk (0x1UL << HRTIM_MCR_MCEN_Pos) |
| #define | HRTIM_MCR_MCEN HRTIM_MCR_MCEN_Msk |
| #define | HRTIM_MCR_TACEN_Pos (17U) |
| #define | HRTIM_MCR_TACEN_Msk (0x1UL << HRTIM_MCR_TACEN_Pos) |
| #define | HRTIM_MCR_TACEN HRTIM_MCR_TACEN_Msk |
| #define | HRTIM_MCR_TBCEN_Pos (18U) |
| #define | HRTIM_MCR_TBCEN_Msk (0x1UL << HRTIM_MCR_TBCEN_Pos) |
| #define | HRTIM_MCR_TBCEN HRTIM_MCR_TBCEN_Msk |
| #define | HRTIM_MCR_TCCEN_Pos (19U) |
| #define | HRTIM_MCR_TCCEN_Msk (0x1UL << HRTIM_MCR_TCCEN_Pos) |
| #define | HRTIM_MCR_TCCEN HRTIM_MCR_TCCEN_Msk |
| #define | HRTIM_MCR_TDCEN_Pos (20U) |
| #define | HRTIM_MCR_TDCEN_Msk (0x1UL << HRTIM_MCR_TDCEN_Pos) |
| #define | HRTIM_MCR_TDCEN HRTIM_MCR_TDCEN_Msk |
| #define | HRTIM_MCR_TECEN_Pos (21U) |
| #define | HRTIM_MCR_TECEN_Msk (0x1UL << HRTIM_MCR_TECEN_Pos) |
| #define | HRTIM_MCR_TECEN HRTIM_MCR_TECEN_Msk |
| #define | HRTIM_MCR_DACSYNC_Pos (25U) |
| #define | HRTIM_MCR_DACSYNC_Msk (0x3UL << HRTIM_MCR_DACSYNC_Pos) |
| #define | HRTIM_MCR_DACSYNC HRTIM_MCR_DACSYNC_Msk |
| #define | HRTIM_MCR_DACSYNC_0 (0x1UL << HRTIM_MCR_DACSYNC_Pos) |
| #define | HRTIM_MCR_DACSYNC_1 (0x2UL << HRTIM_MCR_DACSYNC_Pos) |
| #define | HRTIM_MCR_PREEN_Pos (27U) |
| #define | HRTIM_MCR_PREEN_Msk (0x1UL << HRTIM_MCR_PREEN_Pos) |
| #define | HRTIM_MCR_PREEN HRTIM_MCR_PREEN_Msk |
| #define | HRTIM_MCR_MREPU_Pos (29U) |
| #define | HRTIM_MCR_MREPU_Msk (0x1UL << HRTIM_MCR_MREPU_Pos) |
| #define | HRTIM_MCR_MREPU HRTIM_MCR_MREPU_Msk |
| #define | HRTIM_MCR_BRSTDMA_Pos (30U) |
| #define | HRTIM_MCR_BRSTDMA_Msk (0x3UL << HRTIM_MCR_BRSTDMA_Pos) |
| #define | HRTIM_MCR_BRSTDMA HRTIM_MCR_BRSTDMA_Msk |
| #define | HRTIM_MCR_BRSTDMA_0 (0x1UL << HRTIM_MCR_BRSTDMA_Pos) |
| #define | HRTIM_MCR_BRSTDMA_1 (0x2UL << HRTIM_MCR_BRSTDMA_Pos) |
| #define | HRTIM_MISR_MCMP1_Pos (0U) |
| #define | HRTIM_MISR_MCMP1_Msk (0x1UL << HRTIM_MISR_MCMP1_Pos) |
| #define | HRTIM_MISR_MCMP1 HRTIM_MISR_MCMP1_Msk |
| #define | HRTIM_MISR_MCMP2_Pos (1U) |
| #define | HRTIM_MISR_MCMP2_Msk (0x1UL << HRTIM_MISR_MCMP2_Pos) |
| #define | HRTIM_MISR_MCMP2 HRTIM_MISR_MCMP2_Msk |
| #define | HRTIM_MISR_MCMP3_Pos (2U) |
| #define | HRTIM_MISR_MCMP3_Msk (0x1UL << HRTIM_MISR_MCMP3_Pos) |
| #define | HRTIM_MISR_MCMP3 HRTIM_MISR_MCMP3_Msk |
| #define | HRTIM_MISR_MCMP4_Pos (3U) |
| #define | HRTIM_MISR_MCMP4_Msk (0x1UL << HRTIM_MISR_MCMP4_Pos) |
| #define | HRTIM_MISR_MCMP4 HRTIM_MISR_MCMP4_Msk |
| #define | HRTIM_MISR_MREP_Pos (4U) |
| #define | HRTIM_MISR_MREP_Msk (0x1UL << HRTIM_MISR_MREP_Pos) |
| #define | HRTIM_MISR_MREP HRTIM_MISR_MREP_Msk |
| #define | HRTIM_MISR_SYNC_Pos (5U) |
| #define | HRTIM_MISR_SYNC_Msk (0x1UL << HRTIM_MISR_SYNC_Pos) |
| #define | HRTIM_MISR_SYNC HRTIM_MISR_SYNC_Msk |
| #define | HRTIM_MISR_MUPD_Pos (6U) |
| #define | HRTIM_MISR_MUPD_Msk (0x1UL << HRTIM_MISR_MUPD_Pos) |
| #define | HRTIM_MISR_MUPD HRTIM_MISR_MUPD_Msk |
| #define | HRTIM_MICR_MCMP1_Pos (0U) |
| #define | HRTIM_MICR_MCMP1_Msk (0x1UL << HRTIM_MICR_MCMP1_Pos) |
| #define | HRTIM_MICR_MCMP1 HRTIM_MICR_MCMP1_Msk |
| #define | HRTIM_MICR_MCMP2_Pos (1U) |
| #define | HRTIM_MICR_MCMP2_Msk (0x1UL << HRTIM_MICR_MCMP2_Pos) |
| #define | HRTIM_MICR_MCMP2 HRTIM_MICR_MCMP2_Msk |
| #define | HRTIM_MICR_MCMP3_Pos (2U) |
| #define | HRTIM_MICR_MCMP3_Msk (0x1UL << HRTIM_MICR_MCMP3_Pos) |
| #define | HRTIM_MICR_MCMP3 HRTIM_MICR_MCMP3_Msk |
| #define | HRTIM_MICR_MCMP4_Pos (3U) |
| #define | HRTIM_MICR_MCMP4_Msk (0x1UL << HRTIM_MICR_MCMP4_Pos) |
| #define | HRTIM_MICR_MCMP4 HRTIM_MICR_MCMP4_Msk |
| #define | HRTIM_MICR_MREP_Pos (4U) |
| #define | HRTIM_MICR_MREP_Msk (0x1UL << HRTIM_MICR_MREP_Pos) |
| #define | HRTIM_MICR_MREP HRTIM_MICR_MREP_Msk |
| #define | HRTIM_MICR_SYNC_Pos (5U) |
| #define | HRTIM_MICR_SYNC_Msk (0x1UL << HRTIM_MICR_SYNC_Pos) |
| #define | HRTIM_MICR_SYNC HRTIM_MICR_SYNC_Msk |
| #define | HRTIM_MICR_MUPD_Pos (6U) |
| #define | HRTIM_MICR_MUPD_Msk (0x1UL << HRTIM_MICR_MUPD_Pos) |
| #define | HRTIM_MICR_MUPD HRTIM_MICR_MUPD_Msk |
| #define | HRTIM_MDIER_MCMP1IE_Pos (0U) |
| #define | HRTIM_MDIER_MCMP1IE_Msk (0x1UL << HRTIM_MDIER_MCMP1IE_Pos) |
| #define | HRTIM_MDIER_MCMP1IE HRTIM_MDIER_MCMP1IE_Msk |
| #define | HRTIM_MDIER_MCMP2IE_Pos (1U) |
| #define | HRTIM_MDIER_MCMP2IE_Msk (0x1UL << HRTIM_MDIER_MCMP2IE_Pos) |
| #define | HRTIM_MDIER_MCMP2IE HRTIM_MDIER_MCMP2IE_Msk |
| #define | HRTIM_MDIER_MCMP3IE_Pos (2U) |
| #define | HRTIM_MDIER_MCMP3IE_Msk (0x1UL << HRTIM_MDIER_MCMP3IE_Pos) |
| #define | HRTIM_MDIER_MCMP3IE HRTIM_MDIER_MCMP3IE_Msk |
| #define | HRTIM_MDIER_MCMP4IE_Pos (3U) |
| #define | HRTIM_MDIER_MCMP4IE_Msk (0x1UL << HRTIM_MDIER_MCMP4IE_Pos) |
| #define | HRTIM_MDIER_MCMP4IE HRTIM_MDIER_MCMP4IE_Msk |
| #define | HRTIM_MDIER_MREPIE_Pos (4U) |
| #define | HRTIM_MDIER_MREPIE_Msk (0x1UL << HRTIM_MDIER_MREPIE_Pos) |
| #define | HRTIM_MDIER_MREPIE HRTIM_MDIER_MREPIE_Msk |
| #define | HRTIM_MDIER_SYNCIE_Pos (5U) |
| #define | HRTIM_MDIER_SYNCIE_Msk (0x1UL << HRTIM_MDIER_SYNCIE_Pos) |
| #define | HRTIM_MDIER_SYNCIE HRTIM_MDIER_SYNCIE_Msk |
| #define | HRTIM_MDIER_MUPDIE_Pos (6U) |
| #define | HRTIM_MDIER_MUPDIE_Msk (0x1UL << HRTIM_MDIER_MUPDIE_Pos) |
| #define | HRTIM_MDIER_MUPDIE HRTIM_MDIER_MUPDIE_Msk |
| #define | HRTIM_MDIER_MCMP1DE_Pos (16U) |
| #define | HRTIM_MDIER_MCMP1DE_Msk (0x1UL << HRTIM_MDIER_MCMP1DE_Pos) |
| #define | HRTIM_MDIER_MCMP1DE HRTIM_MDIER_MCMP1DE_Msk |
| #define | HRTIM_MDIER_MCMP2DE_Pos (17U) |
| #define | HRTIM_MDIER_MCMP2DE_Msk (0x1UL << HRTIM_MDIER_MCMP2DE_Pos) |
| #define | HRTIM_MDIER_MCMP2DE HRTIM_MDIER_MCMP2DE_Msk |
| #define | HRTIM_MDIER_MCMP3DE_Pos (18U) |
| #define | HRTIM_MDIER_MCMP3DE_Msk (0x1UL << HRTIM_MDIER_MCMP3DE_Pos) |
| #define | HRTIM_MDIER_MCMP3DE HRTIM_MDIER_MCMP3DE_Msk |
| #define | HRTIM_MDIER_MCMP4DE_Pos (19U) |
| #define | HRTIM_MDIER_MCMP4DE_Msk (0x1UL << HRTIM_MDIER_MCMP4DE_Pos) |
| #define | HRTIM_MDIER_MCMP4DE HRTIM_MDIER_MCMP4DE_Msk |
| #define | HRTIM_MDIER_MREPDE_Pos (20U) |
| #define | HRTIM_MDIER_MREPDE_Msk (0x1UL << HRTIM_MDIER_MREPDE_Pos) |
| #define | HRTIM_MDIER_MREPDE HRTIM_MDIER_MREPDE_Msk |
| #define | HRTIM_MDIER_SYNCDE_Pos (21U) |
| #define | HRTIM_MDIER_SYNCDE_Msk (0x1UL << HRTIM_MDIER_SYNCDE_Pos) |
| #define | HRTIM_MDIER_SYNCDE HRTIM_MDIER_SYNCDE_Msk |
| #define | HRTIM_MDIER_MUPDDE_Pos (22U) |
| #define | HRTIM_MDIER_MUPDDE_Msk (0x1UL << HRTIM_MDIER_MUPDDE_Pos) |
| #define | HRTIM_MDIER_MUPDDE HRTIM_MDIER_MUPDDE_Msk |
| #define | HRTIM_MCNTR_MCNTR_Pos (0U) |
| #define | HRTIM_MCNTR_MCNTR_Msk (0xFFFFUL << HRTIM_MCNTR_MCNTR_Pos) |
| #define | HRTIM_MCNTR_MCNTR HRTIM_MCNTR_MCNTR_Msk |
| #define | HRTIM_MPER_MPER_Pos (0U) |
| #define | HRTIM_MPER_MPER_Msk (0xFFFFUL << HRTIM_MPER_MPER_Pos) |
| #define | HRTIM_MPER_MPER HRTIM_MPER_MPER_Msk |
| #define | HRTIM_MREP_MREP_Pos (0U) |
| #define | HRTIM_MREP_MREP_Msk (0xFFUL << HRTIM_MREP_MREP_Pos) |
| #define | HRTIM_MREP_MREP HRTIM_MREP_MREP_Msk |
| #define | HRTIM_MCMP1R_MCMP1R_Pos (0U) |
| #define | HRTIM_MCMP1R_MCMP1R_Msk (0xFFFFUL << HRTIM_MCMP1R_MCMP1R_Pos) |
| #define | HRTIM_MCMP1R_MCMP1R HRTIM_MCMP1R_MCMP1R_Msk |
| #define | HRTIM_MCMP1R_MCMP2R_Pos (0U) |
| #define | HRTIM_MCMP1R_MCMP2R_Msk (0xFFFFUL << HRTIM_MCMP1R_MCMP2R_Pos) |
| #define | HRTIM_MCMP1R_MCMP2R HRTIM_MCMP1R_MCMP2R_Msk |
| #define | HRTIM_MCMP1R_MCMP3R_Pos (0U) |
| #define | HRTIM_MCMP1R_MCMP3R_Msk (0xFFFFUL << HRTIM_MCMP1R_MCMP3R_Pos) |
| #define | HRTIM_MCMP1R_MCMP3R HRTIM_MCMP1R_MCMP3R_Msk |
| #define | HRTIM_MCMP1R_MCMP4R_Pos (0U) |
| #define | HRTIM_MCMP1R_MCMP4R_Msk (0xFFFFUL << HRTIM_MCMP1R_MCMP4R_Pos) |
| #define | HRTIM_MCMP1R_MCMP4R HRTIM_MCMP1R_MCMP4R_Msk |
| #define | HRTIM_TIMCR_CK_PSC_Pos (0U) |
| #define | HRTIM_TIMCR_CK_PSC_Msk (0x7UL << HRTIM_TIMCR_CK_PSC_Pos) |
| #define | HRTIM_TIMCR_CK_PSC HRTIM_TIMCR_CK_PSC_Msk |
| #define | HRTIM_TIMCR_CK_PSC_0 (0x1UL << HRTIM_TIMCR_CK_PSC_Pos) |
| #define | HRTIM_TIMCR_CK_PSC_1 (0x2UL << HRTIM_TIMCR_CK_PSC_Pos) |
| #define | HRTIM_TIMCR_CK_PSC_2 (0x4UL << HRTIM_TIMCR_CK_PSC_Pos) |
| #define | HRTIM_TIMCR_CONT_Pos (3U) |
| #define | HRTIM_TIMCR_CONT_Msk (0x1UL << HRTIM_TIMCR_CONT_Pos) |
| #define | HRTIM_TIMCR_CONT HRTIM_TIMCR_CONT_Msk |
| #define | HRTIM_TIMCR_RETRIG_Pos (4U) |
| #define | HRTIM_TIMCR_RETRIG_Msk (0x1UL << HRTIM_TIMCR_RETRIG_Pos) |
| #define | HRTIM_TIMCR_RETRIG HRTIM_TIMCR_RETRIG_Msk |
| #define | HRTIM_TIMCR_HALF_Pos (5U) |
| #define | HRTIM_TIMCR_HALF_Msk (0x1UL << HRTIM_TIMCR_HALF_Pos) |
| #define | HRTIM_TIMCR_HALF HRTIM_TIMCR_HALF_Msk |
| #define | HRTIM_TIMCR_PSHPLL_Pos (6U) |
| #define | HRTIM_TIMCR_PSHPLL_Msk (0x1UL << HRTIM_TIMCR_PSHPLL_Pos) |
| #define | HRTIM_TIMCR_PSHPLL HRTIM_TIMCR_PSHPLL_Msk |
| #define | HRTIM_TIMCR_SYNCRST_Pos (10U) |
| #define | HRTIM_TIMCR_SYNCRST_Msk (0x1UL << HRTIM_TIMCR_SYNCRST_Pos) |
| #define | HRTIM_TIMCR_SYNCRST HRTIM_TIMCR_SYNCRST_Msk |
| #define | HRTIM_TIMCR_SYNCSTRT_Pos (11U) |
| #define | HRTIM_TIMCR_SYNCSTRT_Msk (0x1UL << HRTIM_TIMCR_SYNCSTRT_Pos) |
| #define | HRTIM_TIMCR_SYNCSTRT HRTIM_TIMCR_SYNCSTRT_Msk |
| #define | HRTIM_TIMCR_DELCMP2_Pos (12U) |
| #define | HRTIM_TIMCR_DELCMP2_Msk (0x3UL << HRTIM_TIMCR_DELCMP2_Pos) |
| #define | HRTIM_TIMCR_DELCMP2 HRTIM_TIMCR_DELCMP2_Msk |
| #define | HRTIM_TIMCR_DELCMP2_0 (0x1UL << HRTIM_TIMCR_DELCMP2_Pos) |
| #define | HRTIM_TIMCR_DELCMP2_1 (0x2UL << HRTIM_TIMCR_DELCMP2_Pos) |
| #define | HRTIM_TIMCR_DELCMP4_Pos (14U) |
| #define | HRTIM_TIMCR_DELCMP4_Msk (0x3UL << HRTIM_TIMCR_DELCMP4_Pos) |
| #define | HRTIM_TIMCR_DELCMP4 HRTIM_TIMCR_DELCMP4_Msk |
| #define | HRTIM_TIMCR_DELCMP4_0 (0x1UL << HRTIM_TIMCR_DELCMP4_Pos) |
| #define | HRTIM_TIMCR_DELCMP4_1 (0x2UL << HRTIM_TIMCR_DELCMP4_Pos) |
| #define | HRTIM_TIMCR_TREPU_Pos (17U) |
| #define | HRTIM_TIMCR_TREPU_Msk (0x1UL << HRTIM_TIMCR_TREPU_Pos) |
| #define | HRTIM_TIMCR_TREPU HRTIM_TIMCR_TREPU_Msk |
| #define | HRTIM_TIMCR_TRSTU_Pos (18U) |
| #define | HRTIM_TIMCR_TRSTU_Msk (0x1UL << HRTIM_TIMCR_TRSTU_Pos) |
| #define | HRTIM_TIMCR_TRSTU HRTIM_TIMCR_TRSTU_Msk |
| #define | HRTIM_TIMCR_TAU_Pos (19U) |
| #define | HRTIM_TIMCR_TAU_Msk (0x1UL << HRTIM_TIMCR_TAU_Pos) |
| #define | HRTIM_TIMCR_TAU HRTIM_TIMCR_TAU_Msk |
| #define | HRTIM_TIMCR_TBU_Pos (20U) |
| #define | HRTIM_TIMCR_TBU_Msk (0x1UL << HRTIM_TIMCR_TBU_Pos) |
| #define | HRTIM_TIMCR_TBU HRTIM_TIMCR_TBU_Msk |
| #define | HRTIM_TIMCR_TCU_Pos (21U) |
| #define | HRTIM_TIMCR_TCU_Msk (0x1UL << HRTIM_TIMCR_TCU_Pos) |
| #define | HRTIM_TIMCR_TCU HRTIM_TIMCR_TCU_Msk |
| #define | HRTIM_TIMCR_TDU_Pos (22U) |
| #define | HRTIM_TIMCR_TDU_Msk (0x1UL << HRTIM_TIMCR_TDU_Pos) |
| #define | HRTIM_TIMCR_TDU HRTIM_TIMCR_TDU_Msk |
| #define | HRTIM_TIMCR_TEU_Pos (23U) |
| #define | HRTIM_TIMCR_TEU_Msk (0x1UL << HRTIM_TIMCR_TEU_Pos) |
| #define | HRTIM_TIMCR_TEU HRTIM_TIMCR_TEU_Msk |
| #define | HRTIM_TIMCR_MSTU_Pos (24U) |
| #define | HRTIM_TIMCR_MSTU_Msk (0x1UL << HRTIM_TIMCR_MSTU_Pos) |
| #define | HRTIM_TIMCR_MSTU HRTIM_TIMCR_MSTU_Msk |
| #define | HRTIM_TIMCR_DACSYNC_Pos (25U) |
| #define | HRTIM_TIMCR_DACSYNC_Msk (0x3UL << HRTIM_TIMCR_DACSYNC_Pos) |
| #define | HRTIM_TIMCR_DACSYNC HRTIM_TIMCR_DACSYNC_Msk |
| #define | HRTIM_TIMCR_DACSYNC_0 (0x1UL << HRTIM_TIMCR_DACSYNC_Pos) |
| #define | HRTIM_TIMCR_DACSYNC_1 (0x2UL << HRTIM_TIMCR_DACSYNC_Pos) |
| #define | HRTIM_TIMCR_PREEN_Pos (27U) |
| #define | HRTIM_TIMCR_PREEN_Msk (0x1UL << HRTIM_TIMCR_PREEN_Pos) |
| #define | HRTIM_TIMCR_PREEN HRTIM_TIMCR_PREEN_Msk |
| #define | HRTIM_TIMCR_UPDGAT_Pos (28U) |
| #define | HRTIM_TIMCR_UPDGAT_Msk (0xFUL << HRTIM_TIMCR_UPDGAT_Pos) |
| #define | HRTIM_TIMCR_UPDGAT HRTIM_TIMCR_UPDGAT_Msk |
| #define | HRTIM_TIMCR_UPDGAT_0 (0x1UL << HRTIM_TIMCR_UPDGAT_Pos) |
| #define | HRTIM_TIMCR_UPDGAT_1 (0x2UL << HRTIM_TIMCR_UPDGAT_Pos) |
| #define | HRTIM_TIMCR_UPDGAT_2 (0x4UL << HRTIM_TIMCR_UPDGAT_Pos) |
| #define | HRTIM_TIMCR_UPDGAT_3 (0x8UL << HRTIM_TIMCR_UPDGAT_Pos) |
| #define | HRTIM_TIMISR_CMP1_Pos (0U) |
| #define | HRTIM_TIMISR_CMP1_Msk (0x1UL << HRTIM_TIMISR_CMP1_Pos) |
| #define | HRTIM_TIMISR_CMP1 HRTIM_TIMISR_CMP1_Msk |
| #define | HRTIM_TIMISR_CMP2_Pos (1U) |
| #define | HRTIM_TIMISR_CMP2_Msk (0x1UL << HRTIM_TIMISR_CMP2_Pos) |
| #define | HRTIM_TIMISR_CMP2 HRTIM_TIMISR_CMP2_Msk |
| #define | HRTIM_TIMISR_CMP3_Pos (2U) |
| #define | HRTIM_TIMISR_CMP3_Msk (0x1UL << HRTIM_TIMISR_CMP3_Pos) |
| #define | HRTIM_TIMISR_CMP3 HRTIM_TIMISR_CMP3_Msk |
| #define | HRTIM_TIMISR_CMP4_Pos (3U) |
| #define | HRTIM_TIMISR_CMP4_Msk (0x1UL << HRTIM_TIMISR_CMP4_Pos) |
| #define | HRTIM_TIMISR_CMP4 HRTIM_TIMISR_CMP4_Msk |
| #define | HRTIM_TIMISR_REP_Pos (4U) |
| #define | HRTIM_TIMISR_REP_Msk (0x1UL << HRTIM_TIMISR_REP_Pos) |
| #define | HRTIM_TIMISR_REP HRTIM_TIMISR_REP_Msk |
| #define | HRTIM_TIMISR_UPD_Pos (6U) |
| #define | HRTIM_TIMISR_UPD_Msk (0x1UL << HRTIM_TIMISR_UPD_Pos) |
| #define | HRTIM_TIMISR_UPD HRTIM_TIMISR_UPD_Msk |
| #define | HRTIM_TIMISR_CPT1_Pos (7U) |
| #define | HRTIM_TIMISR_CPT1_Msk (0x1UL << HRTIM_TIMISR_CPT1_Pos) |
| #define | HRTIM_TIMISR_CPT1 HRTIM_TIMISR_CPT1_Msk |
| #define | HRTIM_TIMISR_CPT2_Pos (8U) |
| #define | HRTIM_TIMISR_CPT2_Msk (0x1UL << HRTIM_TIMISR_CPT2_Pos) |
| #define | HRTIM_TIMISR_CPT2 HRTIM_TIMISR_CPT2_Msk |
| #define | HRTIM_TIMISR_SET1_Pos (9U) |
| #define | HRTIM_TIMISR_SET1_Msk (0x1UL << HRTIM_TIMISR_SET1_Pos) |
| #define | HRTIM_TIMISR_SET1 HRTIM_TIMISR_SET1_Msk |
| #define | HRTIM_TIMISR_RST1_Pos (10U) |
| #define | HRTIM_TIMISR_RST1_Msk (0x1UL << HRTIM_TIMISR_RST1_Pos) |
| #define | HRTIM_TIMISR_RST1 HRTIM_TIMISR_RST1_Msk |
| #define | HRTIM_TIMISR_SET2_Pos (11U) |
| #define | HRTIM_TIMISR_SET2_Msk (0x1UL << HRTIM_TIMISR_SET2_Pos) |
| #define | HRTIM_TIMISR_SET2 HRTIM_TIMISR_SET2_Msk |
| #define | HRTIM_TIMISR_RST2_Pos (12U) |
| #define | HRTIM_TIMISR_RST2_Msk (0x1UL << HRTIM_TIMISR_RST2_Pos) |
| #define | HRTIM_TIMISR_RST2 HRTIM_TIMISR_RST2_Msk |
| #define | HRTIM_TIMISR_RST_Pos (13U) |
| #define | HRTIM_TIMISR_RST_Msk (0x1UL << HRTIM_TIMISR_RST_Pos) |
| #define | HRTIM_TIMISR_RST HRTIM_TIMISR_RST_Msk |
| #define | HRTIM_TIMISR_DLYPRT_Pos (14U) |
| #define | HRTIM_TIMISR_DLYPRT_Msk (0x1UL << HRTIM_TIMISR_DLYPRT_Pos) |
| #define | HRTIM_TIMISR_DLYPRT HRTIM_TIMISR_DLYPRT_Msk |
| #define | HRTIM_TIMISR_CPPSTAT_Pos (16U) |
| #define | HRTIM_TIMISR_CPPSTAT_Msk (0x1UL << HRTIM_TIMISR_CPPSTAT_Pos) |
| #define | HRTIM_TIMISR_CPPSTAT HRTIM_TIMISR_CPPSTAT_Msk |
| #define | HRTIM_TIMISR_IPPSTAT_Pos (17U) |
| #define | HRTIM_TIMISR_IPPSTAT_Msk (0x1UL << HRTIM_TIMISR_IPPSTAT_Pos) |
| #define | HRTIM_TIMISR_IPPSTAT HRTIM_TIMISR_IPPSTAT_Msk |
| #define | HRTIM_TIMISR_O1STAT_Pos (18U) |
| #define | HRTIM_TIMISR_O1STAT_Msk (0x1UL << HRTIM_TIMISR_O1STAT_Pos) |
| #define | HRTIM_TIMISR_O1STAT HRTIM_TIMISR_O1STAT_Msk |
| #define | HRTIM_TIMISR_O2STAT_Pos (19U) |
| #define | HRTIM_TIMISR_O2STAT_Msk (0x1UL << HRTIM_TIMISR_O2STAT_Pos) |
| #define | HRTIM_TIMISR_O2STAT HRTIM_TIMISR_O2STAT_Msk |
| #define | HRTIM_TIMISR_O1CPY_Pos (20U) |
| #define | HRTIM_TIMISR_O1CPY_Msk (0x1UL << HRTIM_TIMISR_O1CPY_Pos) |
| #define | HRTIM_TIMISR_O1CPY HRTIM_TIMISR_O1CPY_Msk |
| #define | HRTIM_TIMISR_O2CPY_Pos (21U) |
| #define | HRTIM_TIMISR_O2CPY_Msk (0x1UL << HRTIM_TIMISR_O2CPY_Pos) |
| #define | HRTIM_TIMISR_O2CPY HRTIM_TIMISR_O2CPY_Msk |
| #define | HRTIM_TIMICR_CMP1C_Pos (0U) |
| #define | HRTIM_TIMICR_CMP1C_Msk (0x1UL << HRTIM_TIMICR_CMP1C_Pos) |
| #define | HRTIM_TIMICR_CMP1C HRTIM_TIMICR_CMP1C_Msk |
| #define | HRTIM_TIMICR_CMP2C_Pos (1U) |
| #define | HRTIM_TIMICR_CMP2C_Msk (0x1UL << HRTIM_TIMICR_CMP2C_Pos) |
| #define | HRTIM_TIMICR_CMP2C HRTIM_TIMICR_CMP2C_Msk |
| #define | HRTIM_TIMICR_CMP3C_Pos (2U) |
| #define | HRTIM_TIMICR_CMP3C_Msk (0x1UL << HRTIM_TIMICR_CMP3C_Pos) |
| #define | HRTIM_TIMICR_CMP3C HRTIM_TIMICR_CMP3C_Msk |
| #define | HRTIM_TIMICR_CMP4C_Pos (3U) |
| #define | HRTIM_TIMICR_CMP4C_Msk (0x1UL << HRTIM_TIMICR_CMP4C_Pos) |
| #define | HRTIM_TIMICR_CMP4C HRTIM_TIMICR_CMP4C_Msk |
| #define | HRTIM_TIMICR_REPC_Pos (4U) |
| #define | HRTIM_TIMICR_REPC_Msk (0x1UL << HRTIM_TIMICR_REPC_Pos) |
| #define | HRTIM_TIMICR_REPC HRTIM_TIMICR_REPC_Msk |
| #define | HRTIM_TIMICR_UPDC_Pos (6U) |
| #define | HRTIM_TIMICR_UPDC_Msk (0x1UL << HRTIM_TIMICR_UPDC_Pos) |
| #define | HRTIM_TIMICR_UPDC HRTIM_TIMICR_UPDC_Msk |
| #define | HRTIM_TIMICR_CPT1C_Pos (7U) |
| #define | HRTIM_TIMICR_CPT1C_Msk (0x1UL << HRTIM_TIMICR_CPT1C_Pos) |
| #define | HRTIM_TIMICR_CPT1C HRTIM_TIMICR_CPT1C_Msk |
| #define | HRTIM_TIMICR_CPT2C_Pos (8U) |
| #define | HRTIM_TIMICR_CPT2C_Msk (0x1UL << HRTIM_TIMICR_CPT2C_Pos) |
| #define | HRTIM_TIMICR_CPT2C HRTIM_TIMICR_CPT2C_Msk |
| #define | HRTIM_TIMICR_SET1C_Pos (9U) |
| #define | HRTIM_TIMICR_SET1C_Msk (0x1UL << HRTIM_TIMICR_SET1C_Pos) |
| #define | HRTIM_TIMICR_SET1C HRTIM_TIMICR_SET1C_Msk |
| #define | HRTIM_TIMICR_RST1C_Pos (10U) |
| #define | HRTIM_TIMICR_RST1C_Msk (0x1UL << HRTIM_TIMICR_RST1C_Pos) |
| #define | HRTIM_TIMICR_RST1C HRTIM_TIMICR_RST1C_Msk |
| #define | HRTIM_TIMICR_SET2C_Pos (11U) |
| #define | HRTIM_TIMICR_SET2C_Msk (0x1UL << HRTIM_TIMICR_SET2C_Pos) |
| #define | HRTIM_TIMICR_SET2C HRTIM_TIMICR_SET2C_Msk |
| #define | HRTIM_TIMICR_RST2C_Pos (12U) |
| #define | HRTIM_TIMICR_RST2C_Msk (0x1UL << HRTIM_TIMICR_RST2C_Pos) |
| #define | HRTIM_TIMICR_RST2C HRTIM_TIMICR_RST2C_Msk |
| #define | HRTIM_TIMICR_RSTC_Pos (13U) |
| #define | HRTIM_TIMICR_RSTC_Msk (0x1UL << HRTIM_TIMICR_RSTC_Pos) |
| #define | HRTIM_TIMICR_RSTC HRTIM_TIMICR_RSTC_Msk |
| #define | HRTIM_TIMICR_DLYPRTC_Pos (14U) |
| #define | HRTIM_TIMICR_DLYPRTC_Msk (0x1UL << HRTIM_TIMICR_DLYPRTC_Pos) |
| #define | HRTIM_TIMICR_DLYPRTC HRTIM_TIMICR_DLYPRTC_Msk |
| #define | HRTIM_TIMDIER_CMP1IE_Pos (0U) |
| #define | HRTIM_TIMDIER_CMP1IE_Msk (0x1UL << HRTIM_TIMDIER_CMP1IE_Pos) |
| #define | HRTIM_TIMDIER_CMP1IE HRTIM_TIMDIER_CMP1IE_Msk |
| #define | HRTIM_TIMDIER_CMP2IE_Pos (1U) |
| #define | HRTIM_TIMDIER_CMP2IE_Msk (0x1UL << HRTIM_TIMDIER_CMP2IE_Pos) |
| #define | HRTIM_TIMDIER_CMP2IE HRTIM_TIMDIER_CMP2IE_Msk |
| #define | HRTIM_TIMDIER_CMP3IE_Pos (2U) |
| #define | HRTIM_TIMDIER_CMP3IE_Msk (0x1UL << HRTIM_TIMDIER_CMP3IE_Pos) |
| #define | HRTIM_TIMDIER_CMP3IE HRTIM_TIMDIER_CMP3IE_Msk |
| #define | HRTIM_TIMDIER_CMP4IE_Pos (3U) |
| #define | HRTIM_TIMDIER_CMP4IE_Msk (0x1UL << HRTIM_TIMDIER_CMP4IE_Pos) |
| #define | HRTIM_TIMDIER_CMP4IE HRTIM_TIMDIER_CMP4IE_Msk |
| #define | HRTIM_TIMDIER_REPIE_Pos (4U) |
| #define | HRTIM_TIMDIER_REPIE_Msk (0x1UL << HRTIM_TIMDIER_REPIE_Pos) |
| #define | HRTIM_TIMDIER_REPIE HRTIM_TIMDIER_REPIE_Msk |
| #define | HRTIM_TIMDIER_UPDIE_Pos (6U) |
| #define | HRTIM_TIMDIER_UPDIE_Msk (0x1UL << HRTIM_TIMDIER_UPDIE_Pos) |
| #define | HRTIM_TIMDIER_UPDIE HRTIM_TIMDIER_UPDIE_Msk |
| #define | HRTIM_TIMDIER_CPT1IE_Pos (7U) |
| #define | HRTIM_TIMDIER_CPT1IE_Msk (0x1UL << HRTIM_TIMDIER_CPT1IE_Pos) |
| #define | HRTIM_TIMDIER_CPT1IE HRTIM_TIMDIER_CPT1IE_Msk |
| #define | HRTIM_TIMDIER_CPT2IE_Pos (8U) |
| #define | HRTIM_TIMDIER_CPT2IE_Msk (0x1UL << HRTIM_TIMDIER_CPT2IE_Pos) |
| #define | HRTIM_TIMDIER_CPT2IE HRTIM_TIMDIER_CPT2IE_Msk |
| #define | HRTIM_TIMDIER_SET1IE_Pos (9U) |
| #define | HRTIM_TIMDIER_SET1IE_Msk (0x1UL << HRTIM_TIMDIER_SET1IE_Pos) |
| #define | HRTIM_TIMDIER_SET1IE HRTIM_TIMDIER_SET1IE_Msk |
| #define | HRTIM_TIMDIER_RST1IE_Pos (10U) |
| #define | HRTIM_TIMDIER_RST1IE_Msk (0x1UL << HRTIM_TIMDIER_RST1IE_Pos) |
| #define | HRTIM_TIMDIER_RST1IE HRTIM_TIMDIER_RST1IE_Msk |
| #define | HRTIM_TIMDIER_SET2IE_Pos (11U) |
| #define | HRTIM_TIMDIER_SET2IE_Msk (0x1UL << HRTIM_TIMDIER_SET2IE_Pos) |
| #define | HRTIM_TIMDIER_SET2IE HRTIM_TIMDIER_SET2IE_Msk |
| #define | HRTIM_TIMDIER_RST2IE_Pos (12U) |
| #define | HRTIM_TIMDIER_RST2IE_Msk (0x1UL << HRTIM_TIMDIER_RST2IE_Pos) |
| #define | HRTIM_TIMDIER_RST2IE HRTIM_TIMDIER_RST2IE_Msk |
| #define | HRTIM_TIMDIER_RSTIE_Pos (13U) |
| #define | HRTIM_TIMDIER_RSTIE_Msk (0x1UL << HRTIM_TIMDIER_RSTIE_Pos) |
| #define | HRTIM_TIMDIER_RSTIE HRTIM_TIMDIER_RSTIE_Msk |
| #define | HRTIM_TIMDIER_DLYPRTIE_Pos (14U) |
| #define | HRTIM_TIMDIER_DLYPRTIE_Msk (0x1UL << HRTIM_TIMDIER_DLYPRTIE_Pos) |
| #define | HRTIM_TIMDIER_DLYPRTIE HRTIM_TIMDIER_DLYPRTIE_Msk |
| #define | HRTIM_TIMDIER_CMP1DE_Pos (16U) |
| #define | HRTIM_TIMDIER_CMP1DE_Msk (0x1UL << HRTIM_TIMDIER_CMP1DE_Pos) |
| #define | HRTIM_TIMDIER_CMP1DE HRTIM_TIMDIER_CMP1DE_Msk |
| #define | HRTIM_TIMDIER_CMP2DE_Pos (17U) |
| #define | HRTIM_TIMDIER_CMP2DE_Msk (0x1UL << HRTIM_TIMDIER_CMP2DE_Pos) |
| #define | HRTIM_TIMDIER_CMP2DE HRTIM_TIMDIER_CMP2DE_Msk |
| #define | HRTIM_TIMDIER_CMP3DE_Pos (18U) |
| #define | HRTIM_TIMDIER_CMP3DE_Msk (0x1UL << HRTIM_TIMDIER_CMP3DE_Pos) |
| #define | HRTIM_TIMDIER_CMP3DE HRTIM_TIMDIER_CMP3DE_Msk |
| #define | HRTIM_TIMDIER_CMP4DE_Pos (19U) |
| #define | HRTIM_TIMDIER_CMP4DE_Msk (0x1UL << HRTIM_TIMDIER_CMP4DE_Pos) |
| #define | HRTIM_TIMDIER_CMP4DE HRTIM_TIMDIER_CMP4DE_Msk |
| #define | HRTIM_TIMDIER_REPDE_Pos (20U) |
| #define | HRTIM_TIMDIER_REPDE_Msk (0x1UL << HRTIM_TIMDIER_REPDE_Pos) |
| #define | HRTIM_TIMDIER_REPDE HRTIM_TIMDIER_REPDE_Msk |
| #define | HRTIM_TIMDIER_UPDDE_Pos (22U) |
| #define | HRTIM_TIMDIER_UPDDE_Msk (0x1UL << HRTIM_TIMDIER_UPDDE_Pos) |
| #define | HRTIM_TIMDIER_UPDDE HRTIM_TIMDIER_UPDDE_Msk |
| #define | HRTIM_TIMDIER_CPT1DE_Pos (23U) |
| #define | HRTIM_TIMDIER_CPT1DE_Msk (0x1UL << HRTIM_TIMDIER_CPT1DE_Pos) |
| #define | HRTIM_TIMDIER_CPT1DE HRTIM_TIMDIER_CPT1DE_Msk |
| #define | HRTIM_TIMDIER_CPT2DE_Pos (24U) |
| #define | HRTIM_TIMDIER_CPT2DE_Msk (0x1UL << HRTIM_TIMDIER_CPT2DE_Pos) |
| #define | HRTIM_TIMDIER_CPT2DE HRTIM_TIMDIER_CPT2DE_Msk |
| #define | HRTIM_TIMDIER_SET1DE_Pos (25U) |
| #define | HRTIM_TIMDIER_SET1DE_Msk (0x1UL << HRTIM_TIMDIER_SET1DE_Pos) |
| #define | HRTIM_TIMDIER_SET1DE HRTIM_TIMDIER_SET1DE_Msk |
| #define | HRTIM_TIMDIER_RST1DE_Pos (26U) |
| #define | HRTIM_TIMDIER_RST1DE_Msk (0x1UL << HRTIM_TIMDIER_RST1DE_Pos) |
| #define | HRTIM_TIMDIER_RST1DE HRTIM_TIMDIER_RST1DE_Msk |
| #define | HRTIM_TIMDIER_SET2DE_Pos (27U) |
| #define | HRTIM_TIMDIER_SET2DE_Msk (0x1UL << HRTIM_TIMDIER_SET2DE_Pos) |
| #define | HRTIM_TIMDIER_SET2DE HRTIM_TIMDIER_SET2DE_Msk |
| #define | HRTIM_TIMDIER_RST2DE_Pos (28U) |
| #define | HRTIM_TIMDIER_RST2DE_Msk (0x1UL << HRTIM_TIMDIER_RST2DE_Pos) |
| #define | HRTIM_TIMDIER_RST2DE HRTIM_TIMDIER_RST2DE_Msk |
| #define | HRTIM_TIMDIER_RSTDE_Pos (29U) |
| #define | HRTIM_TIMDIER_RSTDE_Msk (0x1UL << HRTIM_TIMDIER_RSTDE_Pos) |
| #define | HRTIM_TIMDIER_RSTDE HRTIM_TIMDIER_RSTDE_Msk |
| #define | HRTIM_TIMDIER_DLYPRTDE_Pos (30U) |
| #define | HRTIM_TIMDIER_DLYPRTDE_Msk (0x1UL << HRTIM_TIMDIER_DLYPRTDE_Pos) |
| #define | HRTIM_TIMDIER_DLYPRTDE HRTIM_TIMDIER_DLYPRTDE_Msk |
| #define | HRTIM_CNTR_CNTR_Pos (0U) |
| #define | HRTIM_CNTR_CNTR_Msk (0xFFFFUL << HRTIM_CNTR_CNTR_Pos) |
| #define | HRTIM_CNTR_CNTR HRTIM_CNTR_CNTR_Msk |
| #define | HRTIM_PER_PER_Pos (0U) |
| #define | HRTIM_PER_PER_Msk (0xFFFFUL << HRTIM_PER_PER_Pos) |
| #define | HRTIM_PER_PER HRTIM_PER_PER_Msk |
| #define | HRTIM_REP_REP_Pos (0U) |
| #define | HRTIM_REP_REP_Msk (0xFFUL << HRTIM_REP_REP_Pos) |
| #define | HRTIM_REP_REP HRTIM_REP_REP_Msk |
| #define | HRTIM_CMP1R_CMP1R_Pos (0U) |
| #define | HRTIM_CMP1R_CMP1R_Msk (0xFFFFUL << HRTIM_CMP1R_CMP1R_Pos) |
| #define | HRTIM_CMP1R_CMP1R HRTIM_CMP1R_CMP1R_Msk |
| #define | HRTIM_CMP1CR_CMP1CR_Pos (0U) |
| #define | HRTIM_CMP1CR_CMP1CR_Msk (0xFFFFFFFFUL << HRTIM_CMP1CR_CMP1CR_Pos) |
| #define | HRTIM_CMP1CR_CMP1CR HRTIM_CMP1CR_CMP1CR_Msk |
| #define | HRTIM_CMP2R_CMP2R_Pos (0U) |
| #define | HRTIM_CMP2R_CMP2R_Msk (0xFFFFUL << HRTIM_CMP2R_CMP2R_Pos) |
| #define | HRTIM_CMP2R_CMP2R HRTIM_CMP2R_CMP2R_Msk |
| #define | HRTIM_CMP3R_CMP3R_Pos (0U) |
| #define | HRTIM_CMP3R_CMP3R_Msk (0xFFFFUL << HRTIM_CMP3R_CMP3R_Pos) |
| #define | HRTIM_CMP3R_CMP3R HRTIM_CMP3R_CMP3R_Msk |
| #define | HRTIM_CMP4R_CMP4R_Pos (0U) |
| #define | HRTIM_CMP4R_CMP4R_Msk (0xFFFFUL << HRTIM_CMP4R_CMP4R_Pos) |
| #define | HRTIM_CMP4R_CMP4R HRTIM_CMP4R_CMP4R_Msk |
| #define | HRTIM_CPT1R_CPT1R_Pos (0U) |
| #define | HRTIM_CPT1R_CPT1R_Msk (0xFFFFUL << HRTIM_CPT1R_CPT1R_Pos) |
| #define | HRTIM_CPT1R_CPT1R HRTIM_CPT1R_CPT1R_Msk |
| #define | HRTIM_CPT2R_CPT2R_Pos (0U) |
| #define | HRTIM_CPT2R_CPT2R_Msk (0xFFFFUL << HRTIM_CPT2R_CPT2R_Pos) |
| #define | HRTIM_CPT2R_CPT2R HRTIM_CPT2R_CPT2R_Msk |
| #define | HRTIM_DTR_DTR_Pos (0U) |
| #define | HRTIM_DTR_DTR_Msk (0x1FFUL << HRTIM_DTR_DTR_Pos) |
| #define | HRTIM_DTR_DTR HRTIM_DTR_DTR_Msk |
| #define | HRTIM_DTR_DTR_0 (0x001UL << HRTIM_DTR_DTR_Pos) |
| #define | HRTIM_DTR_DTR_1 (0x002UL << HRTIM_DTR_DTR_Pos) |
| #define | HRTIM_DTR_DTR_2 (0x004UL << HRTIM_DTR_DTR_Pos) |
| #define | HRTIM_DTR_DTR_3 (0x008UL << HRTIM_DTR_DTR_Pos) |
| #define | HRTIM_DTR_DTR_4 (0x010UL << HRTIM_DTR_DTR_Pos) |
| #define | HRTIM_DTR_DTR_5 (0x020UL << HRTIM_DTR_DTR_Pos) |
| #define | HRTIM_DTR_DTR_6 (0x040UL << HRTIM_DTR_DTR_Pos) |
| #define | HRTIM_DTR_DTR_7 (0x080UL << HRTIM_DTR_DTR_Pos) |
| #define | HRTIM_DTR_DTR_8 (0x100UL << HRTIM_DTR_DTR_Pos) |
| #define | HRTIM_DTR_SDTR_Pos (9U) |
| #define | HRTIM_DTR_SDTR_Msk (0x1UL << HRTIM_DTR_SDTR_Pos) |
| #define | HRTIM_DTR_SDTR HRTIM_DTR_SDTR_Msk |
| #define | HRTIM_DTR_DTPRSC_Pos (10U) |
| #define | HRTIM_DTR_DTPRSC_Msk (0x7UL << HRTIM_DTR_DTPRSC_Pos) |
| #define | HRTIM_DTR_DTPRSC HRTIM_DTR_DTPRSC_Msk |
| #define | HRTIM_DTR_DTPRSC_0 (0x1UL << HRTIM_DTR_DTPRSC_Pos) |
| #define | HRTIM_DTR_DTPRSC_1 (0x2UL << HRTIM_DTR_DTPRSC_Pos) |
| #define | HRTIM_DTR_DTPRSC_2 (0x4UL << HRTIM_DTR_DTPRSC_Pos) |
| #define | HRTIM_DTR_DTRSLK_Pos (14U) |
| #define | HRTIM_DTR_DTRSLK_Msk (0x1UL << HRTIM_DTR_DTRSLK_Pos) |
| #define | HRTIM_DTR_DTRSLK HRTIM_DTR_DTRSLK_Msk |
| #define | HRTIM_DTR_DTRLK_Pos (15U) |
| #define | HRTIM_DTR_DTRLK_Msk (0x1UL << HRTIM_DTR_DTRLK_Pos) |
| #define | HRTIM_DTR_DTRLK HRTIM_DTR_DTRLK_Msk |
| #define | HRTIM_DTR_DTF_Pos (16U) |
| #define | HRTIM_DTR_DTF_Msk (0x1FFUL << HRTIM_DTR_DTF_Pos) |
| #define | HRTIM_DTR_DTF HRTIM_DTR_DTF_Msk |
| #define | HRTIM_DTR_DTF_0 (0x001UL << HRTIM_DTR_DTF_Pos) |
| #define | HRTIM_DTR_DTF_1 (0x002UL << HRTIM_DTR_DTF_Pos) |
| #define | HRTIM_DTR_DTF_2 (0x004UL << HRTIM_DTR_DTF_Pos) |
| #define | HRTIM_DTR_DTF_3 (0x008UL << HRTIM_DTR_DTF_Pos) |
| #define | HRTIM_DTR_DTF_4 (0x010UL << HRTIM_DTR_DTF_Pos) |
| #define | HRTIM_DTR_DTF_5 (0x020UL << HRTIM_DTR_DTF_Pos) |
| #define | HRTIM_DTR_DTF_6 (0x040UL << HRTIM_DTR_DTF_Pos) |
| #define | HRTIM_DTR_DTF_7 (0x080UL << HRTIM_DTR_DTF_Pos) |
| #define | HRTIM_DTR_DTF_8 (0x100UL << HRTIM_DTR_DTF_Pos) |
| #define | HRTIM_DTR_SDTF_Pos (25U) |
| #define | HRTIM_DTR_SDTF_Msk (0x1UL << HRTIM_DTR_SDTF_Pos) |
| #define | HRTIM_DTR_SDTF HRTIM_DTR_SDTF_Msk |
| #define | HRTIM_DTR_DTFSLK_Pos (30U) |
| #define | HRTIM_DTR_DTFSLK_Msk (0x1UL << HRTIM_DTR_DTFSLK_Pos) |
| #define | HRTIM_DTR_DTFSLK HRTIM_DTR_DTFSLK_Msk |
| #define | HRTIM_DTR_DTFLK_Pos (31U) |
| #define | HRTIM_DTR_DTFLK_Msk (0x1UL << HRTIM_DTR_DTFLK_Pos) |
| #define | HRTIM_DTR_DTFLK HRTIM_DTR_DTFLK_Msk |
| #define | HRTIM_SET1R_SST_Pos (0U) |
| #define | HRTIM_SET1R_SST_Msk (0x1UL << HRTIM_SET1R_SST_Pos) |
| #define | HRTIM_SET1R_SST HRTIM_SET1R_SST_Msk |
| #define | HRTIM_SET1R_RESYNC_Pos (1U) |
| #define | HRTIM_SET1R_RESYNC_Msk (0x1UL << HRTIM_SET1R_RESYNC_Pos) |
| #define | HRTIM_SET1R_RESYNC HRTIM_SET1R_RESYNC_Msk |
| #define | HRTIM_SET1R_PER_Pos (2U) |
| #define | HRTIM_SET1R_PER_Msk (0x1UL << HRTIM_SET1R_PER_Pos) |
| #define | HRTIM_SET1R_PER HRTIM_SET1R_PER_Msk |
| #define | HRTIM_SET1R_CMP1_Pos (3U) |
| #define | HRTIM_SET1R_CMP1_Msk (0x1UL << HRTIM_SET1R_CMP1_Pos) |
| #define | HRTIM_SET1R_CMP1 HRTIM_SET1R_CMP1_Msk |
| #define | HRTIM_SET1R_CMP2_Pos (4U) |
| #define | HRTIM_SET1R_CMP2_Msk (0x1UL << HRTIM_SET1R_CMP2_Pos) |
| #define | HRTIM_SET1R_CMP2 HRTIM_SET1R_CMP2_Msk |
| #define | HRTIM_SET1R_CMP3_Pos (5U) |
| #define | HRTIM_SET1R_CMP3_Msk (0x1UL << HRTIM_SET1R_CMP3_Pos) |
| #define | HRTIM_SET1R_CMP3 HRTIM_SET1R_CMP3_Msk |
| #define | HRTIM_SET1R_CMP4_Pos (6U) |
| #define | HRTIM_SET1R_CMP4_Msk (0x1UL << HRTIM_SET1R_CMP4_Pos) |
| #define | HRTIM_SET1R_CMP4 HRTIM_SET1R_CMP4_Msk |
| #define | HRTIM_SET1R_MSTPER_Pos (7U) |
| #define | HRTIM_SET1R_MSTPER_Msk (0x1UL << HRTIM_SET1R_MSTPER_Pos) |
| #define | HRTIM_SET1R_MSTPER HRTIM_SET1R_MSTPER_Msk |
| #define | HRTIM_SET1R_MSTCMP1_Pos (8U) |
| #define | HRTIM_SET1R_MSTCMP1_Msk (0x1UL << HRTIM_SET1R_MSTCMP1_Pos) |
| #define | HRTIM_SET1R_MSTCMP1 HRTIM_SET1R_MSTCMP1_Msk |
| #define | HRTIM_SET1R_MSTCMP2_Pos (9U) |
| #define | HRTIM_SET1R_MSTCMP2_Msk (0x1UL << HRTIM_SET1R_MSTCMP2_Pos) |
| #define | HRTIM_SET1R_MSTCMP2 HRTIM_SET1R_MSTCMP2_Msk |
| #define | HRTIM_SET1R_MSTCMP3_Pos (10U) |
| #define | HRTIM_SET1R_MSTCMP3_Msk (0x1UL << HRTIM_SET1R_MSTCMP3_Pos) |
| #define | HRTIM_SET1R_MSTCMP3 HRTIM_SET1R_MSTCMP3_Msk |
| #define | HRTIM_SET1R_MSTCMP4_Pos (11U) |
| #define | HRTIM_SET1R_MSTCMP4_Msk (0x1UL << HRTIM_SET1R_MSTCMP4_Pos) |
| #define | HRTIM_SET1R_MSTCMP4 HRTIM_SET1R_MSTCMP4_Msk |
| #define | HRTIM_SET1R_TIMEVNT1_Pos (12U) |
| #define | HRTIM_SET1R_TIMEVNT1_Msk (0x1UL << HRTIM_SET1R_TIMEVNT1_Pos) |
| #define | HRTIM_SET1R_TIMEVNT1 HRTIM_SET1R_TIMEVNT1_Msk |
| #define | HRTIM_SET1R_TIMEVNT2_Pos (13U) |
| #define | HRTIM_SET1R_TIMEVNT2_Msk (0x1UL << HRTIM_SET1R_TIMEVNT2_Pos) |
| #define | HRTIM_SET1R_TIMEVNT2 HRTIM_SET1R_TIMEVNT2_Msk |
| #define | HRTIM_SET1R_TIMEVNT3_Pos (14U) |
| #define | HRTIM_SET1R_TIMEVNT3_Msk (0x1UL << HRTIM_SET1R_TIMEVNT3_Pos) |
| #define | HRTIM_SET1R_TIMEVNT3 HRTIM_SET1R_TIMEVNT3_Msk |
| #define | HRTIM_SET1R_TIMEVNT4_Pos (15U) |
| #define | HRTIM_SET1R_TIMEVNT4_Msk (0x1UL << HRTIM_SET1R_TIMEVNT4_Pos) |
| #define | HRTIM_SET1R_TIMEVNT4 HRTIM_SET1R_TIMEVNT4_Msk |
| #define | HRTIM_SET1R_TIMEVNT5_Pos (16U) |
| #define | HRTIM_SET1R_TIMEVNT5_Msk (0x1UL << HRTIM_SET1R_TIMEVNT5_Pos) |
| #define | HRTIM_SET1R_TIMEVNT5 HRTIM_SET1R_TIMEVNT5_Msk |
| #define | HRTIM_SET1R_TIMEVNT6_Pos (17U) |
| #define | HRTIM_SET1R_TIMEVNT6_Msk (0x1UL << HRTIM_SET1R_TIMEVNT6_Pos) |
| #define | HRTIM_SET1R_TIMEVNT6 HRTIM_SET1R_TIMEVNT6_Msk |
| #define | HRTIM_SET1R_TIMEVNT7_Pos (18U) |
| #define | HRTIM_SET1R_TIMEVNT7_Msk (0x1UL << HRTIM_SET1R_TIMEVNT7_Pos) |
| #define | HRTIM_SET1R_TIMEVNT7 HRTIM_SET1R_TIMEVNT7_Msk |
| #define | HRTIM_SET1R_TIMEVNT8_Pos (19U) |
| #define | HRTIM_SET1R_TIMEVNT8_Msk (0x1UL << HRTIM_SET1R_TIMEVNT8_Pos) |
| #define | HRTIM_SET1R_TIMEVNT8 HRTIM_SET1R_TIMEVNT8_Msk |
| #define | HRTIM_SET1R_TIMEVNT9_Pos (20U) |
| #define | HRTIM_SET1R_TIMEVNT9_Msk (0x1UL << HRTIM_SET1R_TIMEVNT9_Pos) |
| #define | HRTIM_SET1R_TIMEVNT9 HRTIM_SET1R_TIMEVNT9_Msk |
| #define | HRTIM_SET1R_EXTVNT1_Pos (21U) |
| #define | HRTIM_SET1R_EXTVNT1_Msk (0x1UL << HRTIM_SET1R_EXTVNT1_Pos) |
| #define | HRTIM_SET1R_EXTVNT1 HRTIM_SET1R_EXTVNT1_Msk |
| #define | HRTIM_SET1R_EXTVNT2_Pos (22U) |
| #define | HRTIM_SET1R_EXTVNT2_Msk (0x1UL << HRTIM_SET1R_EXTVNT2_Pos) |
| #define | HRTIM_SET1R_EXTVNT2 HRTIM_SET1R_EXTVNT2_Msk |
| #define | HRTIM_SET1R_EXTVNT3_Pos (23U) |
| #define | HRTIM_SET1R_EXTVNT3_Msk (0x1UL << HRTIM_SET1R_EXTVNT3_Pos) |
| #define | HRTIM_SET1R_EXTVNT3 HRTIM_SET1R_EXTVNT3_Msk |
| #define | HRTIM_SET1R_EXTVNT4_Pos (24U) |
| #define | HRTIM_SET1R_EXTVNT4_Msk (0x1UL << HRTIM_SET1R_EXTVNT4_Pos) |
| #define | HRTIM_SET1R_EXTVNT4 HRTIM_SET1R_EXTVNT4_Msk |
| #define | HRTIM_SET1R_EXTVNT5_Pos (25U) |
| #define | HRTIM_SET1R_EXTVNT5_Msk (0x1UL << HRTIM_SET1R_EXTVNT5_Pos) |
| #define | HRTIM_SET1R_EXTVNT5 HRTIM_SET1R_EXTVNT5_Msk |
| #define | HRTIM_SET1R_EXTVNT6_Pos (26U) |
| #define | HRTIM_SET1R_EXTVNT6_Msk (0x1UL << HRTIM_SET1R_EXTVNT6_Pos) |
| #define | HRTIM_SET1R_EXTVNT6 HRTIM_SET1R_EXTVNT6_Msk |
| #define | HRTIM_SET1R_EXTVNT7_Pos (27U) |
| #define | HRTIM_SET1R_EXTVNT7_Msk (0x1UL << HRTIM_SET1R_EXTVNT7_Pos) |
| #define | HRTIM_SET1R_EXTVNT7 HRTIM_SET1R_EXTVNT7_Msk |
| #define | HRTIM_SET1R_EXTVNT8_Pos (28U) |
| #define | HRTIM_SET1R_EXTVNT8_Msk (0x1UL << HRTIM_SET1R_EXTVNT8_Pos) |
| #define | HRTIM_SET1R_EXTVNT8 HRTIM_SET1R_EXTVNT8_Msk |
| #define | HRTIM_SET1R_EXTVNT9_Pos (29U) |
| #define | HRTIM_SET1R_EXTVNT9_Msk (0x1UL << HRTIM_SET1R_EXTVNT9_Pos) |
| #define | HRTIM_SET1R_EXTVNT9 HRTIM_SET1R_EXTVNT9_Msk |
| #define | HRTIM_SET1R_EXTVNT10_Pos (30U) |
| #define | HRTIM_SET1R_EXTVNT10_Msk (0x1UL << HRTIM_SET1R_EXTVNT10_Pos) |
| #define | HRTIM_SET1R_EXTVNT10 HRTIM_SET1R_EXTVNT10_Msk |
| #define | HRTIM_SET1R_UPDATE_Pos (31U) |
| #define | HRTIM_SET1R_UPDATE_Msk (0x1UL << HRTIM_SET1R_UPDATE_Pos) |
| #define | HRTIM_SET1R_UPDATE HRTIM_SET1R_UPDATE_Msk |
| #define | HRTIM_RST1R_SRT_Pos (0U) |
| #define | HRTIM_RST1R_SRT_Msk (0x1UL << HRTIM_RST1R_SRT_Pos) |
| #define | HRTIM_RST1R_SRT HRTIM_RST1R_SRT_Msk |
| #define | HRTIM_RST1R_RESYNC_Pos (1U) |
| #define | HRTIM_RST1R_RESYNC_Msk (0x1UL << HRTIM_RST1R_RESYNC_Pos) |
| #define | HRTIM_RST1R_RESYNC HRTIM_RST1R_RESYNC_Msk |
| #define | HRTIM_RST1R_PER_Pos (2U) |
| #define | HRTIM_RST1R_PER_Msk (0x1UL << HRTIM_RST1R_PER_Pos) |
| #define | HRTIM_RST1R_PER HRTIM_RST1R_PER_Msk |
| #define | HRTIM_RST1R_CMP1_Pos (3U) |
| #define | HRTIM_RST1R_CMP1_Msk (0x1UL << HRTIM_RST1R_CMP1_Pos) |
| #define | HRTIM_RST1R_CMP1 HRTIM_RST1R_CMP1_Msk |
| #define | HRTIM_RST1R_CMP2_Pos (4U) |
| #define | HRTIM_RST1R_CMP2_Msk (0x1UL << HRTIM_RST1R_CMP2_Pos) |
| #define | HRTIM_RST1R_CMP2 HRTIM_RST1R_CMP2_Msk |
| #define | HRTIM_RST1R_CMP3_Pos (5U) |
| #define | HRTIM_RST1R_CMP3_Msk (0x1UL << HRTIM_RST1R_CMP3_Pos) |
| #define | HRTIM_RST1R_CMP3 HRTIM_RST1R_CMP3_Msk |
| #define | HRTIM_RST1R_CMP4_Pos (6U) |
| #define | HRTIM_RST1R_CMP4_Msk (0x1UL << HRTIM_RST1R_CMP4_Pos) |
| #define | HRTIM_RST1R_CMP4 HRTIM_RST1R_CMP4_Msk |
| #define | HRTIM_RST1R_MSTPER_Pos (7U) |
| #define | HRTIM_RST1R_MSTPER_Msk (0x1UL << HRTIM_RST1R_MSTPER_Pos) |
| #define | HRTIM_RST1R_MSTPER HRTIM_RST1R_MSTPER_Msk |
| #define | HRTIM_RST1R_MSTCMP1_Pos (8U) |
| #define | HRTIM_RST1R_MSTCMP1_Msk (0x1UL << HRTIM_RST1R_MSTCMP1_Pos) |
| #define | HRTIM_RST1R_MSTCMP1 HRTIM_RST1R_MSTCMP1_Msk |
| #define | HRTIM_RST1R_MSTCMP2_Pos (9U) |
| #define | HRTIM_RST1R_MSTCMP2_Msk (0x1UL << HRTIM_RST1R_MSTCMP2_Pos) |
| #define | HRTIM_RST1R_MSTCMP2 HRTIM_RST1R_MSTCMP2_Msk |
| #define | HRTIM_RST1R_MSTCMP3_Pos (10U) |
| #define | HRTIM_RST1R_MSTCMP3_Msk (0x1UL << HRTIM_RST1R_MSTCMP3_Pos) |
| #define | HRTIM_RST1R_MSTCMP3 HRTIM_RST1R_MSTCMP3_Msk |
| #define | HRTIM_RST1R_MSTCMP4_Pos (11U) |
| #define | HRTIM_RST1R_MSTCMP4_Msk (0x1UL << HRTIM_RST1R_MSTCMP4_Pos) |
| #define | HRTIM_RST1R_MSTCMP4 HRTIM_RST1R_MSTCMP4_Msk |
| #define | HRTIM_RST1R_TIMEVNT1_Pos (12U) |
| #define | HRTIM_RST1R_TIMEVNT1_Msk (0x1UL << HRTIM_RST1R_TIMEVNT1_Pos) |
| #define | HRTIM_RST1R_TIMEVNT1 HRTIM_RST1R_TIMEVNT1_Msk |
| #define | HRTIM_RST1R_TIMEVNT2_Pos (13U) |
| #define | HRTIM_RST1R_TIMEVNT2_Msk (0x1UL << HRTIM_RST1R_TIMEVNT2_Pos) |
| #define | HRTIM_RST1R_TIMEVNT2 HRTIM_RST1R_TIMEVNT2_Msk |
| #define | HRTIM_RST1R_TIMEVNT3_Pos (14U) |
| #define | HRTIM_RST1R_TIMEVNT3_Msk (0x1UL << HRTIM_RST1R_TIMEVNT3_Pos) |
| #define | HRTIM_RST1R_TIMEVNT3 HRTIM_RST1R_TIMEVNT3_Msk |
| #define | HRTIM_RST1R_TIMEVNT4_Pos (15U) |
| #define | HRTIM_RST1R_TIMEVNT4_Msk (0x1UL << HRTIM_RST1R_TIMEVNT4_Pos) |
| #define | HRTIM_RST1R_TIMEVNT4 HRTIM_RST1R_TIMEVNT4_Msk |
| #define | HRTIM_RST1R_TIMEVNT5_Pos (16U) |
| #define | HRTIM_RST1R_TIMEVNT5_Msk (0x1UL << HRTIM_RST1R_TIMEVNT5_Pos) |
| #define | HRTIM_RST1R_TIMEVNT5 HRTIM_RST1R_TIMEVNT5_Msk |
| #define | HRTIM_RST1R_TIMEVNT6_Pos (17U) |
| #define | HRTIM_RST1R_TIMEVNT6_Msk (0x1UL << HRTIM_RST1R_TIMEVNT6_Pos) |
| #define | HRTIM_RST1R_TIMEVNT6 HRTIM_RST1R_TIMEVNT6_Msk |
| #define | HRTIM_RST1R_TIMEVNT7_Pos (18U) |
| #define | HRTIM_RST1R_TIMEVNT7_Msk (0x1UL << HRTIM_RST1R_TIMEVNT7_Pos) |
| #define | HRTIM_RST1R_TIMEVNT7 HRTIM_RST1R_TIMEVNT7_Msk |
| #define | HRTIM_RST1R_TIMEVNT8_Pos (19U) |
| #define | HRTIM_RST1R_TIMEVNT8_Msk (0x1UL << HRTIM_RST1R_TIMEVNT8_Pos) |
| #define | HRTIM_RST1R_TIMEVNT8 HRTIM_RST1R_TIMEVNT8_Msk |
| #define | HRTIM_RST1R_TIMEVNT9_Pos (20U) |
| #define | HRTIM_RST1R_TIMEVNT9_Msk (0x1UL << HRTIM_RST1R_TIMEVNT9_Pos) |
| #define | HRTIM_RST1R_TIMEVNT9 HRTIM_RST1R_TIMEVNT9_Msk |
| #define | HRTIM_RST1R_EXTVNT1_Pos (21U) |
| #define | HRTIM_RST1R_EXTVNT1_Msk (0x1UL << HRTIM_RST1R_EXTVNT1_Pos) |
| #define | HRTIM_RST1R_EXTVNT1 HRTIM_RST1R_EXTVNT1_Msk |
| #define | HRTIM_RST1R_EXTVNT2_Pos (22U) |
| #define | HRTIM_RST1R_EXTVNT2_Msk (0x1UL << HRTIM_RST1R_EXTVNT2_Pos) |
| #define | HRTIM_RST1R_EXTVNT2 HRTIM_RST1R_EXTVNT2_Msk |
| #define | HRTIM_RST1R_EXTVNT3_Pos (23U) |
| #define | HRTIM_RST1R_EXTVNT3_Msk (0x1UL << HRTIM_RST1R_EXTVNT3_Pos) |
| #define | HRTIM_RST1R_EXTVNT3 HRTIM_RST1R_EXTVNT3_Msk |
| #define | HRTIM_RST1R_EXTVNT4_Pos (24U) |
| #define | HRTIM_RST1R_EXTVNT4_Msk (0x1UL << HRTIM_RST1R_EXTVNT4_Pos) |
| #define | HRTIM_RST1R_EXTVNT4 HRTIM_RST1R_EXTVNT4_Msk |
| #define | HRTIM_RST1R_EXTVNT5_Pos (25U) |
| #define | HRTIM_RST1R_EXTVNT5_Msk (0x1UL << HRTIM_RST1R_EXTVNT5_Pos) |
| #define | HRTIM_RST1R_EXTVNT5 HRTIM_RST1R_EXTVNT5_Msk |
| #define | HRTIM_RST1R_EXTVNT6_Pos (26U) |
| #define | HRTIM_RST1R_EXTVNT6_Msk (0x1UL << HRTIM_RST1R_EXTVNT6_Pos) |
| #define | HRTIM_RST1R_EXTVNT6 HRTIM_RST1R_EXTVNT6_Msk |
| #define | HRTIM_RST1R_EXTVNT7_Pos (27U) |
| #define | HRTIM_RST1R_EXTVNT7_Msk (0x1UL << HRTIM_RST1R_EXTVNT7_Pos) |
| #define | HRTIM_RST1R_EXTVNT7 HRTIM_RST1R_EXTVNT7_Msk |
| #define | HRTIM_RST1R_EXTVNT8_Pos (28U) |
| #define | HRTIM_RST1R_EXTVNT8_Msk (0x1UL << HRTIM_RST1R_EXTVNT8_Pos) |
| #define | HRTIM_RST1R_EXTVNT8 HRTIM_RST1R_EXTVNT8_Msk |
| #define | HRTIM_RST1R_EXTVNT9_Pos (29U) |
| #define | HRTIM_RST1R_EXTVNT9_Msk (0x1UL << HRTIM_RST1R_EXTVNT9_Pos) |
| #define | HRTIM_RST1R_EXTVNT9 HRTIM_RST1R_EXTVNT9_Msk |
| #define | HRTIM_RST1R_EXTVNT10_Pos (30U) |
| #define | HRTIM_RST1R_EXTVNT10_Msk (0x1UL << HRTIM_RST1R_EXTVNT10_Pos) |
| #define | HRTIM_RST1R_EXTVNT10 HRTIM_RST1R_EXTVNT10_Msk |
| #define | HRTIM_RST1R_UPDATE_Pos (31U) |
| #define | HRTIM_RST1R_UPDATE_Msk (0x1UL << HRTIM_RST1R_UPDATE_Pos) |
| #define | HRTIM_RST1R_UPDATE HRTIM_RST1R_UPDATE_Msk |
| #define | HRTIM_SET2R_SST_Pos (0U) |
| #define | HRTIM_SET2R_SST_Msk (0x1UL << HRTIM_SET2R_SST_Pos) |
| #define | HRTIM_SET2R_SST HRTIM_SET2R_SST_Msk |
| #define | HRTIM_SET2R_RESYNC_Pos (1U) |
| #define | HRTIM_SET2R_RESYNC_Msk (0x1UL << HRTIM_SET2R_RESYNC_Pos) |
| #define | HRTIM_SET2R_RESYNC HRTIM_SET2R_RESYNC_Msk |
| #define | HRTIM_SET2R_PER_Pos (2U) |
| #define | HRTIM_SET2R_PER_Msk (0x1UL << HRTIM_SET2R_PER_Pos) |
| #define | HRTIM_SET2R_PER HRTIM_SET2R_PER_Msk |
| #define | HRTIM_SET2R_CMP1_Pos (3U) |
| #define | HRTIM_SET2R_CMP1_Msk (0x1UL << HRTIM_SET2R_CMP1_Pos) |
| #define | HRTIM_SET2R_CMP1 HRTIM_SET2R_CMP1_Msk |
| #define | HRTIM_SET2R_CMP2_Pos (4U) |
| #define | HRTIM_SET2R_CMP2_Msk (0x1UL << HRTIM_SET2R_CMP2_Pos) |
| #define | HRTIM_SET2R_CMP2 HRTIM_SET2R_CMP2_Msk |
| #define | HRTIM_SET2R_CMP3_Pos (5U) |
| #define | HRTIM_SET2R_CMP3_Msk (0x1UL << HRTIM_SET2R_CMP3_Pos) |
| #define | HRTIM_SET2R_CMP3 HRTIM_SET2R_CMP3_Msk |
| #define | HRTIM_SET2R_CMP4_Pos (6U) |
| #define | HRTIM_SET2R_CMP4_Msk (0x1UL << HRTIM_SET2R_CMP4_Pos) |
| #define | HRTIM_SET2R_CMP4 HRTIM_SET2R_CMP4_Msk |
| #define | HRTIM_SET2R_MSTPER_Pos (7U) |
| #define | HRTIM_SET2R_MSTPER_Msk (0x1UL << HRTIM_SET2R_MSTPER_Pos) |
| #define | HRTIM_SET2R_MSTPER HRTIM_SET2R_MSTPER_Msk |
| #define | HRTIM_SET2R_MSTCMP1_Pos (8U) |
| #define | HRTIM_SET2R_MSTCMP1_Msk (0x1UL << HRTIM_SET2R_MSTCMP1_Pos) |
| #define | HRTIM_SET2R_MSTCMP1 HRTIM_SET2R_MSTCMP1_Msk |
| #define | HRTIM_SET2R_MSTCMP2_Pos (9U) |
| #define | HRTIM_SET2R_MSTCMP2_Msk (0x1UL << HRTIM_SET2R_MSTCMP2_Pos) |
| #define | HRTIM_SET2R_MSTCMP2 HRTIM_SET2R_MSTCMP2_Msk |
| #define | HRTIM_SET2R_MSTCMP3_Pos (10U) |
| #define | HRTIM_SET2R_MSTCMP3_Msk (0x1UL << HRTIM_SET2R_MSTCMP3_Pos) |
| #define | HRTIM_SET2R_MSTCMP3 HRTIM_SET2R_MSTCMP3_Msk |
| #define | HRTIM_SET2R_MSTCMP4_Pos (11U) |
| #define | HRTIM_SET2R_MSTCMP4_Msk (0x1UL << HRTIM_SET2R_MSTCMP4_Pos) |
| #define | HRTIM_SET2R_MSTCMP4 HRTIM_SET2R_MSTCMP4_Msk |
| #define | HRTIM_SET2R_TIMEVNT1_Pos (12U) |
| #define | HRTIM_SET2R_TIMEVNT1_Msk (0x1UL << HRTIM_SET2R_TIMEVNT1_Pos) |
| #define | HRTIM_SET2R_TIMEVNT1 HRTIM_SET2R_TIMEVNT1_Msk |
| #define | HRTIM_SET2R_TIMEVNT2_Pos (13U) |
| #define | HRTIM_SET2R_TIMEVNT2_Msk (0x1UL << HRTIM_SET2R_TIMEVNT2_Pos) |
| #define | HRTIM_SET2R_TIMEVNT2 HRTIM_SET2R_TIMEVNT2_Msk |
| #define | HRTIM_SET2R_TIMEVNT3_Pos (14U) |
| #define | HRTIM_SET2R_TIMEVNT3_Msk (0x1UL << HRTIM_SET2R_TIMEVNT3_Pos) |
| #define | HRTIM_SET2R_TIMEVNT3 HRTIM_SET2R_TIMEVNT3_Msk |
| #define | HRTIM_SET2R_TIMEVNT4_Pos (15U) |
| #define | HRTIM_SET2R_TIMEVNT4_Msk (0x1UL << HRTIM_SET2R_TIMEVNT4_Pos) |
| #define | HRTIM_SET2R_TIMEVNT4 HRTIM_SET2R_TIMEVNT4_Msk |
| #define | HRTIM_SET2R_TIMEVNT5_Pos (16U) |
| #define | HRTIM_SET2R_TIMEVNT5_Msk (0x1UL << HRTIM_SET2R_TIMEVNT5_Pos) |
| #define | HRTIM_SET2R_TIMEVNT5 HRTIM_SET2R_TIMEVNT5_Msk |
| #define | HRTIM_SET2R_TIMEVNT6_Pos (17U) |
| #define | HRTIM_SET2R_TIMEVNT6_Msk (0x1UL << HRTIM_SET2R_TIMEVNT6_Pos) |
| #define | HRTIM_SET2R_TIMEVNT6 HRTIM_SET2R_TIMEVNT6_Msk |
| #define | HRTIM_SET2R_TIMEVNT7_Pos (18U) |
| #define | HRTIM_SET2R_TIMEVNT7_Msk (0x1UL << HRTIM_SET2R_TIMEVNT7_Pos) |
| #define | HRTIM_SET2R_TIMEVNT7 HRTIM_SET2R_TIMEVNT7_Msk |
| #define | HRTIM_SET2R_TIMEVNT8_Pos (19U) |
| #define | HRTIM_SET2R_TIMEVNT8_Msk (0x1UL << HRTIM_SET2R_TIMEVNT8_Pos) |
| #define | HRTIM_SET2R_TIMEVNT8 HRTIM_SET2R_TIMEVNT8_Msk |
| #define | HRTIM_SET2R_TIMEVNT9_Pos (20U) |
| #define | HRTIM_SET2R_TIMEVNT9_Msk (0x1UL << HRTIM_SET2R_TIMEVNT9_Pos) |
| #define | HRTIM_SET2R_TIMEVNT9 HRTIM_SET2R_TIMEVNT9_Msk |
| #define | HRTIM_SET2R_EXTVNT1_Pos (21U) |
| #define | HRTIM_SET2R_EXTVNT1_Msk (0x1UL << HRTIM_SET2R_EXTVNT1_Pos) |
| #define | HRTIM_SET2R_EXTVNT1 HRTIM_SET2R_EXTVNT1_Msk |
| #define | HRTIM_SET2R_EXTVNT2_Pos (22U) |
| #define | HRTIM_SET2R_EXTVNT2_Msk (0x1UL << HRTIM_SET2R_EXTVNT2_Pos) |
| #define | HRTIM_SET2R_EXTVNT2 HRTIM_SET2R_EXTVNT2_Msk |
| #define | HRTIM_SET2R_EXTVNT3_Pos (23U) |
| #define | HRTIM_SET2R_EXTVNT3_Msk (0x1UL << HRTIM_SET2R_EXTVNT3_Pos) |
| #define | HRTIM_SET2R_EXTVNT3 HRTIM_SET2R_EXTVNT3_Msk |
| #define | HRTIM_SET2R_EXTVNT4_Pos (24U) |
| #define | HRTIM_SET2R_EXTVNT4_Msk (0x1UL << HRTIM_SET2R_EXTVNT4_Pos) |
| #define | HRTIM_SET2R_EXTVNT4 HRTIM_SET2R_EXTVNT4_Msk |
| #define | HRTIM_SET2R_EXTVNT5_Pos (25U) |
| #define | HRTIM_SET2R_EXTVNT5_Msk (0x1UL << HRTIM_SET2R_EXTVNT5_Pos) |
| #define | HRTIM_SET2R_EXTVNT5 HRTIM_SET2R_EXTVNT5_Msk |
| #define | HRTIM_SET2R_EXTVNT6_Pos (26U) |
| #define | HRTIM_SET2R_EXTVNT6_Msk (0x1UL << HRTIM_SET2R_EXTVNT6_Pos) |
| #define | HRTIM_SET2R_EXTVNT6 HRTIM_SET2R_EXTVNT6_Msk |
| #define | HRTIM_SET2R_EXTVNT7_Pos (27U) |
| #define | HRTIM_SET2R_EXTVNT7_Msk (0x1UL << HRTIM_SET2R_EXTVNT7_Pos) |
| #define | HRTIM_SET2R_EXTVNT7 HRTIM_SET2R_EXTVNT7_Msk |
| #define | HRTIM_SET2R_EXTVNT8_Pos (28U) |
| #define | HRTIM_SET2R_EXTVNT8_Msk (0x1UL << HRTIM_SET2R_EXTVNT8_Pos) |
| #define | HRTIM_SET2R_EXTVNT8 HRTIM_SET2R_EXTVNT8_Msk |
| #define | HRTIM_SET2R_EXTVNT9_Pos (29U) |
| #define | HRTIM_SET2R_EXTVNT9_Msk (0x1UL << HRTIM_SET2R_EXTVNT9_Pos) |
| #define | HRTIM_SET2R_EXTVNT9 HRTIM_SET2R_EXTVNT9_Msk |
| #define | HRTIM_SET2R_EXTVNT10_Pos (30U) |
| #define | HRTIM_SET2R_EXTVNT10_Msk (0x1UL << HRTIM_SET2R_EXTVNT10_Pos) |
| #define | HRTIM_SET2R_EXTVNT10 HRTIM_SET2R_EXTVNT10_Msk |
| #define | HRTIM_SET2R_UPDATE_Pos (31U) |
| #define | HRTIM_SET2R_UPDATE_Msk (0x1UL << HRTIM_SET2R_UPDATE_Pos) |
| #define | HRTIM_SET2R_UPDATE HRTIM_SET2R_UPDATE_Msk |
| #define | HRTIM_RST2R_SRT_Pos (0U) |
| #define | HRTIM_RST2R_SRT_Msk (0x1UL << HRTIM_RST2R_SRT_Pos) |
| #define | HRTIM_RST2R_SRT HRTIM_RST2R_SRT_Msk |
| #define | HRTIM_RST2R_RESYNC_Pos (1U) |
| #define | HRTIM_RST2R_RESYNC_Msk (0x1UL << HRTIM_RST2R_RESYNC_Pos) |
| #define | HRTIM_RST2R_RESYNC HRTIM_RST2R_RESYNC_Msk |
| #define | HRTIM_RST2R_PER_Pos (2U) |
| #define | HRTIM_RST2R_PER_Msk (0x1UL << HRTIM_RST2R_PER_Pos) |
| #define | HRTIM_RST2R_PER HRTIM_RST2R_PER_Msk |
| #define | HRTIM_RST2R_CMP1_Pos (3U) |
| #define | HRTIM_RST2R_CMP1_Msk (0x1UL << HRTIM_RST2R_CMP1_Pos) |
| #define | HRTIM_RST2R_CMP1 HRTIM_RST2R_CMP1_Msk |
| #define | HRTIM_RST2R_CMP2_Pos (4U) |
| #define | HRTIM_RST2R_CMP2_Msk (0x1UL << HRTIM_RST2R_CMP2_Pos) |
| #define | HRTIM_RST2R_CMP2 HRTIM_RST2R_CMP2_Msk |
| #define | HRTIM_RST2R_CMP3_Pos (5U) |
| #define | HRTIM_RST2R_CMP3_Msk (0x1UL << HRTIM_RST2R_CMP3_Pos) |
| #define | HRTIM_RST2R_CMP3 HRTIM_RST2R_CMP3_Msk |
| #define | HRTIM_RST2R_CMP4_Pos (6U) |
| #define | HRTIM_RST2R_CMP4_Msk (0x1UL << HRTIM_RST2R_CMP4_Pos) |
| #define | HRTIM_RST2R_CMP4 HRTIM_RST2R_CMP4_Msk |
| #define | HRTIM_RST2R_MSTPER_Pos (7U) |
| #define | HRTIM_RST2R_MSTPER_Msk (0x1UL << HRTIM_RST2R_MSTPER_Pos) |
| #define | HRTIM_RST2R_MSTPER HRTIM_RST2R_MSTPER_Msk |
| #define | HRTIM_RST2R_MSTCMP1_Pos (8U) |
| #define | HRTIM_RST2R_MSTCMP1_Msk (0x1UL << HRTIM_RST2R_MSTCMP1_Pos) |
| #define | HRTIM_RST2R_MSTCMP1 HRTIM_RST2R_MSTCMP1_Msk |
| #define | HRTIM_RST2R_MSTCMP2_Pos (9U) |
| #define | HRTIM_RST2R_MSTCMP2_Msk (0x1UL << HRTIM_RST2R_MSTCMP2_Pos) |
| #define | HRTIM_RST2R_MSTCMP2 HRTIM_RST2R_MSTCMP2_Msk |
| #define | HRTIM_RST2R_MSTCMP3_Pos (10U) |
| #define | HRTIM_RST2R_MSTCMP3_Msk (0x1UL << HRTIM_RST2R_MSTCMP3_Pos) |
| #define | HRTIM_RST2R_MSTCMP3 HRTIM_RST2R_MSTCMP3_Msk |
| #define | HRTIM_RST2R_MSTCMP4_Pos (11U) |
| #define | HRTIM_RST2R_MSTCMP4_Msk (0x1UL << HRTIM_RST2R_MSTCMP4_Pos) |
| #define | HRTIM_RST2R_MSTCMP4 HRTIM_RST2R_MSTCMP4_Msk |
| #define | HRTIM_RST2R_TIMEVNT1_Pos (12U) |
| #define | HRTIM_RST2R_TIMEVNT1_Msk (0x1UL << HRTIM_RST2R_TIMEVNT1_Pos) |
| #define | HRTIM_RST2R_TIMEVNT1 HRTIM_RST2R_TIMEVNT1_Msk |
| #define | HRTIM_RST2R_TIMEVNT2_Pos (13U) |
| #define | HRTIM_RST2R_TIMEVNT2_Msk (0x1UL << HRTIM_RST2R_TIMEVNT2_Pos) |
| #define | HRTIM_RST2R_TIMEVNT2 HRTIM_RST2R_TIMEVNT2_Msk |
| #define | HRTIM_RST2R_TIMEVNT3_Pos (14U) |
| #define | HRTIM_RST2R_TIMEVNT3_Msk (0x1UL << HRTIM_RST2R_TIMEVNT3_Pos) |
| #define | HRTIM_RST2R_TIMEVNT3 HRTIM_RST2R_TIMEVNT3_Msk |
| #define | HRTIM_RST2R_TIMEVNT4_Pos (15U) |
| #define | HRTIM_RST2R_TIMEVNT4_Msk (0x1UL << HRTIM_RST2R_TIMEVNT4_Pos) |
| #define | HRTIM_RST2R_TIMEVNT4 HRTIM_RST2R_TIMEVNT4_Msk |
| #define | HRTIM_RST2R_TIMEVNT5_Pos (16U) |
| #define | HRTIM_RST2R_TIMEVNT5_Msk (0x1UL << HRTIM_RST2R_TIMEVNT5_Pos) |
| #define | HRTIM_RST2R_TIMEVNT5 HRTIM_RST2R_TIMEVNT5_Msk |
| #define | HRTIM_RST2R_TIMEVNT6_Pos (17U) |
| #define | HRTIM_RST2R_TIMEVNT6_Msk (0x1UL << HRTIM_RST2R_TIMEVNT6_Pos) |
| #define | HRTIM_RST2R_TIMEVNT6 HRTIM_RST2R_TIMEVNT6_Msk |
| #define | HRTIM_RST2R_TIMEVNT7_Pos (18U) |
| #define | HRTIM_RST2R_TIMEVNT7_Msk (0x1UL << HRTIM_RST2R_TIMEVNT7_Pos) |
| #define | HRTIM_RST2R_TIMEVNT7 HRTIM_RST2R_TIMEVNT7_Msk |
| #define | HRTIM_RST2R_TIMEVNT8_Pos (19U) |
| #define | HRTIM_RST2R_TIMEVNT8_Msk (0x1UL << HRTIM_RST2R_TIMEVNT8_Pos) |
| #define | HRTIM_RST2R_TIMEVNT8 HRTIM_RST2R_TIMEVNT8_Msk |
| #define | HRTIM_RST2R_TIMEVNT9_Pos (20U) |
| #define | HRTIM_RST2R_TIMEVNT9_Msk (0x1UL << HRTIM_RST2R_TIMEVNT9_Pos) |
| #define | HRTIM_RST2R_TIMEVNT9 HRTIM_RST2R_TIMEVNT9_Msk |
| #define | HRTIM_RST2R_EXTVNT1_Pos (21U) |
| #define | HRTIM_RST2R_EXTVNT1_Msk (0x1UL << HRTIM_RST2R_EXTVNT1_Pos) |
| #define | HRTIM_RST2R_EXTVNT1 HRTIM_RST2R_EXTVNT1_Msk |
| #define | HRTIM_RST2R_EXTVNT2_Pos (22U) |
| #define | HRTIM_RST2R_EXTVNT2_Msk (0x1UL << HRTIM_RST2R_EXTVNT2_Pos) |
| #define | HRTIM_RST2R_EXTVNT2 HRTIM_RST2R_EXTVNT2_Msk |
| #define | HRTIM_RST2R_EXTVNT3_Pos (23U) |
| #define | HRTIM_RST2R_EXTVNT3_Msk (0x1UL << HRTIM_RST2R_EXTVNT3_Pos) |
| #define | HRTIM_RST2R_EXTVNT3 HRTIM_RST2R_EXTVNT3_Msk |
| #define | HRTIM_RST2R_EXTVNT4_Pos (24U) |
| #define | HRTIM_RST2R_EXTVNT4_Msk (0x1UL << HRTIM_RST2R_EXTVNT4_Pos) |
| #define | HRTIM_RST2R_EXTVNT4 HRTIM_RST2R_EXTVNT4_Msk |
| #define | HRTIM_RST2R_EXTVNT5_Pos (25U) |
| #define | HRTIM_RST2R_EXTVNT5_Msk (0x1UL << HRTIM_RST2R_EXTVNT5_Pos) |
| #define | HRTIM_RST2R_EXTVNT5 HRTIM_RST2R_EXTVNT5_Msk |
| #define | HRTIM_RST2R_EXTVNT6_Pos (26U) |
| #define | HRTIM_RST2R_EXTVNT6_Msk (0x1UL << HRTIM_RST2R_EXTVNT6_Pos) |
| #define | HRTIM_RST2R_EXTVNT6 HRTIM_RST2R_EXTVNT6_Msk |
| #define | HRTIM_RST2R_EXTVNT7_Pos (27U) |
| #define | HRTIM_RST2R_EXTVNT7_Msk (0x1UL << HRTIM_RST2R_EXTVNT7_Pos) |
| #define | HRTIM_RST2R_EXTVNT7 HRTIM_RST2R_EXTVNT7_Msk |
| #define | HRTIM_RST2R_EXTVNT8_Pos (28U) |
| #define | HRTIM_RST2R_EXTVNT8_Msk (0x1UL << HRTIM_RST2R_EXTVNT8_Pos) |
| #define | HRTIM_RST2R_EXTVNT8 HRTIM_RST2R_EXTVNT8_Msk |
| #define | HRTIM_RST2R_EXTVNT9_Pos (29U) |
| #define | HRTIM_RST2R_EXTVNT9_Msk (0x1UL << HRTIM_RST2R_EXTVNT9_Pos) |
| #define | HRTIM_RST2R_EXTVNT9 HRTIM_RST2R_EXTVNT9_Msk |
| #define | HRTIM_RST2R_EXTVNT10_Pos (30U) |
| #define | HRTIM_RST2R_EXTVNT10_Msk (0x1UL << HRTIM_RST2R_EXTVNT10_Pos) |
| #define | HRTIM_RST2R_EXTVNT10 HRTIM_RST2R_EXTVNT10_Msk |
| #define | HRTIM_RST2R_UPDATE_Pos (31U) |
| #define | HRTIM_RST2R_UPDATE_Msk (0x1UL << HRTIM_RST2R_UPDATE_Pos) |
| #define | HRTIM_RST2R_UPDATE HRTIM_RST2R_UPDATE_Msk |
| #define | HRTIM_EEFR1_EE1LTCH_Pos (0U) |
| #define | HRTIM_EEFR1_EE1LTCH_Msk (0x1UL << HRTIM_EEFR1_EE1LTCH_Pos) |
| #define | HRTIM_EEFR1_EE1LTCH HRTIM_EEFR1_EE1LTCH_Msk |
| #define | HRTIM_EEFR1_EE1FLTR_Pos (1U) |
| #define | HRTIM_EEFR1_EE1FLTR_Msk (0xFUL << HRTIM_EEFR1_EE1FLTR_Pos) |
| #define | HRTIM_EEFR1_EE1FLTR HRTIM_EEFR1_EE1FLTR_Msk |
| #define | HRTIM_EEFR1_EE1FLTR_0 (0x1UL << HRTIM_EEFR1_EE1FLTR_Pos) |
| #define | HRTIM_EEFR1_EE1FLTR_1 (0x2UL << HRTIM_EEFR1_EE1FLTR_Pos) |
| #define | HRTIM_EEFR1_EE1FLTR_2 (0x4UL << HRTIM_EEFR1_EE1FLTR_Pos) |
| #define | HRTIM_EEFR1_EE1FLTR_3 (0x8UL << HRTIM_EEFR1_EE1FLTR_Pos) |
| #define | HRTIM_EEFR1_EE2LTCH_Pos (6U) |
| #define | HRTIM_EEFR1_EE2LTCH_Msk (0x1UL << HRTIM_EEFR1_EE2LTCH_Pos) |
| #define | HRTIM_EEFR1_EE2LTCH HRTIM_EEFR1_EE2LTCH_Msk |
| #define | HRTIM_EEFR1_EE2FLTR_Pos (7U) |
| #define | HRTIM_EEFR1_EE2FLTR_Msk (0xFUL << HRTIM_EEFR1_EE2FLTR_Pos) |
| #define | HRTIM_EEFR1_EE2FLTR HRTIM_EEFR1_EE2FLTR_Msk |
| #define | HRTIM_EEFR1_EE2FLTR_0 (0x1UL << HRTIM_EEFR1_EE2FLTR_Pos) |
| #define | HRTIM_EEFR1_EE2FLTR_1 (0x2UL << HRTIM_EEFR1_EE2FLTR_Pos) |
| #define | HRTIM_EEFR1_EE2FLTR_2 (0x4UL << HRTIM_EEFR1_EE2FLTR_Pos) |
| #define | HRTIM_EEFR1_EE2FLTR_3 (0x8UL << HRTIM_EEFR1_EE2FLTR_Pos) |
| #define | HRTIM_EEFR1_EE3LTCH_Pos (12U) |
| #define | HRTIM_EEFR1_EE3LTCH_Msk (0x1UL << HRTIM_EEFR1_EE3LTCH_Pos) |
| #define | HRTIM_EEFR1_EE3LTCH HRTIM_EEFR1_EE3LTCH_Msk |
| #define | HRTIM_EEFR1_EE3FLTR_Pos (13U) |
| #define | HRTIM_EEFR1_EE3FLTR_Msk (0xFUL << HRTIM_EEFR1_EE3FLTR_Pos) |
| #define | HRTIM_EEFR1_EE3FLTR HRTIM_EEFR1_EE3FLTR_Msk |
| #define | HRTIM_EEFR1_EE3FLTR_0 (0x1UL << HRTIM_EEFR1_EE3FLTR_Pos) |
| #define | HRTIM_EEFR1_EE3FLTR_1 (0x2UL << HRTIM_EEFR1_EE3FLTR_Pos) |
| #define | HRTIM_EEFR1_EE3FLTR_2 (0x4UL << HRTIM_EEFR1_EE3FLTR_Pos) |
| #define | HRTIM_EEFR1_EE3FLTR_3 (0x8UL << HRTIM_EEFR1_EE3FLTR_Pos) |
| #define | HRTIM_EEFR1_EE4LTCH_Pos (18U) |
| #define | HRTIM_EEFR1_EE4LTCH_Msk (0x1UL << HRTIM_EEFR1_EE4LTCH_Pos) |
| #define | HRTIM_EEFR1_EE4LTCH HRTIM_EEFR1_EE4LTCH_Msk |
| #define | HRTIM_EEFR1_EE4FLTR_Pos (19U) |
| #define | HRTIM_EEFR1_EE4FLTR_Msk (0xFUL << HRTIM_EEFR1_EE4FLTR_Pos) |
| #define | HRTIM_EEFR1_EE4FLTR HRTIM_EEFR1_EE4FLTR_Msk |
| #define | HRTIM_EEFR1_EE4FLTR_0 (0x1UL << HRTIM_EEFR1_EE4FLTR_Pos) |
| #define | HRTIM_EEFR1_EE4FLTR_1 (0x2UL << HRTIM_EEFR1_EE4FLTR_Pos) |
| #define | HRTIM_EEFR1_EE4FLTR_2 (0x4UL << HRTIM_EEFR1_EE4FLTR_Pos) |
| #define | HRTIM_EEFR1_EE4FLTR_3 (0x8UL << HRTIM_EEFR1_EE4FLTR_Pos) |
| #define | HRTIM_EEFR1_EE5LTCH_Pos (24U) |
| #define | HRTIM_EEFR1_EE5LTCH_Msk (0x1UL << HRTIM_EEFR1_EE5LTCH_Pos) |
| #define | HRTIM_EEFR1_EE5LTCH HRTIM_EEFR1_EE5LTCH_Msk |
| #define | HRTIM_EEFR1_EE5FLTR_Pos (25U) |
| #define | HRTIM_EEFR1_EE5FLTR_Msk (0xFUL << HRTIM_EEFR1_EE5FLTR_Pos) |
| #define | HRTIM_EEFR1_EE5FLTR HRTIM_EEFR1_EE5FLTR_Msk |
| #define | HRTIM_EEFR1_EE5FLTR_0 (0x1UL << HRTIM_EEFR1_EE5FLTR_Pos) |
| #define | HRTIM_EEFR1_EE5FLTR_1 (0x2UL << HRTIM_EEFR1_EE5FLTR_Pos) |
| #define | HRTIM_EEFR1_EE5FLTR_2 (0x4UL << HRTIM_EEFR1_EE5FLTR_Pos) |
| #define | HRTIM_EEFR1_EE5FLTR_3 (0x8UL << HRTIM_EEFR1_EE5FLTR_Pos) |
| #define | HRTIM_EEFR2_EE6LTCH_Pos (0U) |
| #define | HRTIM_EEFR2_EE6LTCH_Msk (0x1UL << HRTIM_EEFR2_EE6LTCH_Pos) |
| #define | HRTIM_EEFR2_EE6LTCH HRTIM_EEFR2_EE6LTCH_Msk |
| #define | HRTIM_EEFR2_EE6FLTR_Pos (1U) |
| #define | HRTIM_EEFR2_EE6FLTR_Msk (0xFUL << HRTIM_EEFR2_EE6FLTR_Pos) |
| #define | HRTIM_EEFR2_EE6FLTR HRTIM_EEFR2_EE6FLTR_Msk |
| #define | HRTIM_EEFR2_EE6FLTR_0 (0x1UL << HRTIM_EEFR2_EE6FLTR_Pos) |
| #define | HRTIM_EEFR2_EE6FLTR_1 (0x2UL << HRTIM_EEFR2_EE6FLTR_Pos) |
| #define | HRTIM_EEFR2_EE6FLTR_2 (0x4UL << HRTIM_EEFR2_EE6FLTR_Pos) |
| #define | HRTIM_EEFR2_EE6FLTR_3 (0x8UL << HRTIM_EEFR2_EE6FLTR_Pos) |
| #define | HRTIM_EEFR2_EE7LTCH_Pos (6U) |
| #define | HRTIM_EEFR2_EE7LTCH_Msk (0x1UL << HRTIM_EEFR2_EE7LTCH_Pos) |
| #define | HRTIM_EEFR2_EE7LTCH HRTIM_EEFR2_EE7LTCH_Msk |
| #define | HRTIM_EEFR2_EE7FLTR_Pos (7U) |
| #define | HRTIM_EEFR2_EE7FLTR_Msk (0xFUL << HRTIM_EEFR2_EE7FLTR_Pos) |
| #define | HRTIM_EEFR2_EE7FLTR HRTIM_EEFR2_EE7FLTR_Msk |
| #define | HRTIM_EEFR2_EE7FLTR_0 (0x1UL << HRTIM_EEFR2_EE7FLTR_Pos) |
| #define | HRTIM_EEFR2_EE7FLTR_1 (0x2UL << HRTIM_EEFR2_EE7FLTR_Pos) |
| #define | HRTIM_EEFR2_EE7FLTR_2 (0x4UL << HRTIM_EEFR2_EE7FLTR_Pos) |
| #define | HRTIM_EEFR2_EE7FLTR_3 (0x8UL << HRTIM_EEFR2_EE7FLTR_Pos) |
| #define | HRTIM_EEFR2_EE8LTCH_Pos (12U) |
| #define | HRTIM_EEFR2_EE8LTCH_Msk (0x1UL << HRTIM_EEFR2_EE8LTCH_Pos) |
| #define | HRTIM_EEFR2_EE8LTCH HRTIM_EEFR2_EE8LTCH_Msk |
| #define | HRTIM_EEFR2_EE8FLTR_Pos (13U) |
| #define | HRTIM_EEFR2_EE8FLTR_Msk (0xFUL << HRTIM_EEFR2_EE8FLTR_Pos) |
| #define | HRTIM_EEFR2_EE8FLTR HRTIM_EEFR2_EE8FLTR_Msk |
| #define | HRTIM_EEFR2_EE8FLTR_0 (0x1UL << HRTIM_EEFR2_EE8FLTR_Pos) |
| #define | HRTIM_EEFR2_EE8FLTR_1 (0x2UL << HRTIM_EEFR2_EE8FLTR_Pos) |
| #define | HRTIM_EEFR2_EE8FLTR_2 (0x4UL << HRTIM_EEFR2_EE8FLTR_Pos) |
| #define | HRTIM_EEFR2_EE8FLTR_3 (0x8UL << HRTIM_EEFR2_EE8FLTR_Pos) |
| #define | HRTIM_EEFR2_EE9LTCH_Pos (18U) |
| #define | HRTIM_EEFR2_EE9LTCH_Msk (0x1UL << HRTIM_EEFR2_EE9LTCH_Pos) |
| #define | HRTIM_EEFR2_EE9LTCH HRTIM_EEFR2_EE9LTCH_Msk |
| #define | HRTIM_EEFR2_EE9FLTR_Pos (19U) |
| #define | HRTIM_EEFR2_EE9FLTR_Msk (0xFUL << HRTIM_EEFR2_EE9FLTR_Pos) |
| #define | HRTIM_EEFR2_EE9FLTR HRTIM_EEFR2_EE9FLTR_Msk |
| #define | HRTIM_EEFR2_EE9FLTR_0 (0x1UL << HRTIM_EEFR2_EE9FLTR_Pos) |
| #define | HRTIM_EEFR2_EE9FLTR_1 (0x2UL << HRTIM_EEFR2_EE9FLTR_Pos) |
| #define | HRTIM_EEFR2_EE9FLTR_2 (0x4UL << HRTIM_EEFR2_EE9FLTR_Pos) |
| #define | HRTIM_EEFR2_EE9FLTR_3 (0x8UL << HRTIM_EEFR2_EE9FLTR_Pos) |
| #define | HRTIM_EEFR2_EE10LTCH_Pos (24U) |
| #define | HRTIM_EEFR2_EE10LTCH_Msk (0x1UL << HRTIM_EEFR2_EE10LTCH_Pos) |
| #define | HRTIM_EEFR2_EE10LTCH HRTIM_EEFR2_EE10LTCH_Msk |
| #define | HRTIM_EEFR2_EE10FLTR_Pos (25U) |
| #define | HRTIM_EEFR2_EE10FLTR_Msk (0xFUL << HRTIM_EEFR2_EE10FLTR_Pos) |
| #define | HRTIM_EEFR2_EE10FLTR HRTIM_EEFR2_EE10FLTR_Msk |
| #define | HRTIM_EEFR2_EE10FLTR_0 (0x1UL << HRTIM_EEFR2_EE10FLTR_Pos) |
| #define | HRTIM_EEFR2_EE10FLTR_1 (0x2UL << HRTIM_EEFR2_EE10FLTR_Pos) |
| #define | HRTIM_EEFR2_EE10FLTR_2 (0x4UL << HRTIM_EEFR2_EE10FLTR_Pos) |
| #define | HRTIM_EEFR2_EE10FLTR_3 (0x8UL << HRTIM_EEFR2_EE10FLTR_Pos) |
| #define | HRTIM_RSTR_UPDATE_Pos (1U) |
| #define | HRTIM_RSTR_UPDATE_Msk (0x1UL << HRTIM_RSTR_UPDATE_Pos) |
| #define | HRTIM_RSTR_UPDATE HRTIM_RSTR_UPDATE_Msk |
| #define | HRTIM_RSTR_CMP2_Pos (2U) |
| #define | HRTIM_RSTR_CMP2_Msk (0x1UL << HRTIM_RSTR_CMP2_Pos) |
| #define | HRTIM_RSTR_CMP2 HRTIM_RSTR_CMP2_Msk |
| #define | HRTIM_RSTR_CMP4_Pos (3U) |
| #define | HRTIM_RSTR_CMP4_Msk (0x1UL << HRTIM_RSTR_CMP4_Pos) |
| #define | HRTIM_RSTR_CMP4 HRTIM_RSTR_CMP4_Msk |
| #define | HRTIM_RSTR_MSTPER_Pos (4U) |
| #define | HRTIM_RSTR_MSTPER_Msk (0x1UL << HRTIM_RSTR_MSTPER_Pos) |
| #define | HRTIM_RSTR_MSTPER HRTIM_RSTR_MSTPER_Msk |
| #define | HRTIM_RSTR_MSTCMP1_Pos (5U) |
| #define | HRTIM_RSTR_MSTCMP1_Msk (0x1UL << HRTIM_RSTR_MSTCMP1_Pos) |
| #define | HRTIM_RSTR_MSTCMP1 HRTIM_RSTR_MSTCMP1_Msk |
| #define | HRTIM_RSTR_MSTCMP2_Pos (6U) |
| #define | HRTIM_RSTR_MSTCMP2_Msk (0x1UL << HRTIM_RSTR_MSTCMP2_Pos) |
| #define | HRTIM_RSTR_MSTCMP2 HRTIM_RSTR_MSTCMP2_Msk |
| #define | HRTIM_RSTR_MSTCMP3_Pos (7U) |
| #define | HRTIM_RSTR_MSTCMP3_Msk (0x1UL << HRTIM_RSTR_MSTCMP3_Pos) |
| #define | HRTIM_RSTR_MSTCMP3 HRTIM_RSTR_MSTCMP3_Msk |
| #define | HRTIM_RSTR_MSTCMP4_Pos (8U) |
| #define | HRTIM_RSTR_MSTCMP4_Msk (0x1UL << HRTIM_RSTR_MSTCMP4_Pos) |
| #define | HRTIM_RSTR_MSTCMP4 HRTIM_RSTR_MSTCMP4_Msk |
| #define | HRTIM_RSTR_EXTEVNT1_Pos (9U) |
| #define | HRTIM_RSTR_EXTEVNT1_Msk (0x1UL << HRTIM_RSTR_EXTEVNT1_Pos) |
| #define | HRTIM_RSTR_EXTEVNT1 HRTIM_RSTR_EXTEVNT1_Msk |
| #define | HRTIM_RSTR_EXTEVNT2_Pos (10U) |
| #define | HRTIM_RSTR_EXTEVNT2_Msk (0x1UL << HRTIM_RSTR_EXTEVNT2_Pos) |
| #define | HRTIM_RSTR_EXTEVNT2 HRTIM_RSTR_EXTEVNT2_Msk |
| #define | HRTIM_RSTR_EXTEVNT3_Pos (11U) |
| #define | HRTIM_RSTR_EXTEVNT3_Msk (0x1UL << HRTIM_RSTR_EXTEVNT3_Pos) |
| #define | HRTIM_RSTR_EXTEVNT3 HRTIM_RSTR_EXTEVNT3_Msk |
| #define | HRTIM_RSTR_EXTEVNT4_Pos (12U) |
| #define | HRTIM_RSTR_EXTEVNT4_Msk (0x1UL << HRTIM_RSTR_EXTEVNT4_Pos) |
| #define | HRTIM_RSTR_EXTEVNT4 HRTIM_RSTR_EXTEVNT4_Msk |
| #define | HRTIM_RSTR_EXTEVNT5_Pos (13U) |
| #define | HRTIM_RSTR_EXTEVNT5_Msk (0x1UL << HRTIM_RSTR_EXTEVNT5_Pos) |
| #define | HRTIM_RSTR_EXTEVNT5 HRTIM_RSTR_EXTEVNT5_Msk |
| #define | HRTIM_RSTR_EXTEVNT6_Pos (14U) |
| #define | HRTIM_RSTR_EXTEVNT6_Msk (0x1UL << HRTIM_RSTR_EXTEVNT6_Pos) |
| #define | HRTIM_RSTR_EXTEVNT6 HRTIM_RSTR_EXTEVNT6_Msk |
| #define | HRTIM_RSTR_EXTEVNT7_Pos (15U) |
| #define | HRTIM_RSTR_EXTEVNT7_Msk (0x1UL << HRTIM_RSTR_EXTEVNT7_Pos) |
| #define | HRTIM_RSTR_EXTEVNT7 HRTIM_RSTR_EXTEVNT7_Msk |
| #define | HRTIM_RSTR_EXTEVNT8_Pos (16U) |
| #define | HRTIM_RSTR_EXTEVNT8_Msk (0x1UL << HRTIM_RSTR_EXTEVNT8_Pos) |
| #define | HRTIM_RSTR_EXTEVNT8 HRTIM_RSTR_EXTEVNT8_Msk |
| #define | HRTIM_RSTR_EXTEVNT9_Pos (17U) |
| #define | HRTIM_RSTR_EXTEVNT9_Msk (0x1UL << HRTIM_RSTR_EXTEVNT9_Pos) |
| #define | HRTIM_RSTR_EXTEVNT9 HRTIM_RSTR_EXTEVNT9_Msk |
| #define | HRTIM_RSTR_EXTEVNT10_Pos (18U) |
| #define | HRTIM_RSTR_EXTEVNT10_Msk (0x1UL << HRTIM_RSTR_EXTEVNT10_Pos) |
| #define | HRTIM_RSTR_EXTEVNT10 HRTIM_RSTR_EXTEVNT10_Msk |
| #define | HRTIM_RSTR_TIMBCMP1_Pos (19U) |
| #define | HRTIM_RSTR_TIMBCMP1_Msk (0x1UL << HRTIM_RSTR_TIMBCMP1_Pos) |
| #define | HRTIM_RSTR_TIMBCMP1 HRTIM_RSTR_TIMBCMP1_Msk |
| #define | HRTIM_RSTR_TIMBCMP2_Pos (20U) |
| #define | HRTIM_RSTR_TIMBCMP2_Msk (0x1UL << HRTIM_RSTR_TIMBCMP2_Pos) |
| #define | HRTIM_RSTR_TIMBCMP2 HRTIM_RSTR_TIMBCMP2_Msk |
| #define | HRTIM_RSTR_TIMBCMP4_Pos (21U) |
| #define | HRTIM_RSTR_TIMBCMP4_Msk (0x1UL << HRTIM_RSTR_TIMBCMP4_Pos) |
| #define | HRTIM_RSTR_TIMBCMP4 HRTIM_RSTR_TIMBCMP4_Msk |
| #define | HRTIM_RSTR_TIMCCMP1_Pos (22U) |
| #define | HRTIM_RSTR_TIMCCMP1_Msk (0x1UL << HRTIM_RSTR_TIMCCMP1_Pos) |
| #define | HRTIM_RSTR_TIMCCMP1 HRTIM_RSTR_TIMCCMP1_Msk |
| #define | HRTIM_RSTR_TIMCCMP2_Pos (23U) |
| #define | HRTIM_RSTR_TIMCCMP2_Msk (0x1UL << HRTIM_RSTR_TIMCCMP2_Pos) |
| #define | HRTIM_RSTR_TIMCCMP2 HRTIM_RSTR_TIMCCMP2_Msk |
| #define | HRTIM_RSTR_TIMCCMP4_Pos (24U) |
| #define | HRTIM_RSTR_TIMCCMP4_Msk (0x1UL << HRTIM_RSTR_TIMCCMP4_Pos) |
| #define | HRTIM_RSTR_TIMCCMP4 HRTIM_RSTR_TIMCCMP4_Msk |
| #define | HRTIM_RSTR_TIMDCMP1_Pos (25U) |
| #define | HRTIM_RSTR_TIMDCMP1_Msk (0x1UL << HRTIM_RSTR_TIMDCMP1_Pos) |
| #define | HRTIM_RSTR_TIMDCMP1 HRTIM_RSTR_TIMDCMP1_Msk |
| #define | HRTIM_RSTR_TIMDCMP2_Pos (26U) |
| #define | HRTIM_RSTR_TIMDCMP2_Msk (0x1UL << HRTIM_RSTR_TIMDCMP2_Pos) |
| #define | HRTIM_RSTR_TIMDCMP2 HRTIM_RSTR_TIMDCMP2_Msk |
| #define | HRTIM_RSTR_TIMDCMP4_Pos (27U) |
| #define | HRTIM_RSTR_TIMDCMP4_Msk (0x1UL << HRTIM_RSTR_TIMDCMP4_Pos) |
| #define | HRTIM_RSTR_TIMDCMP4 HRTIM_RSTR_TIMDCMP4_Msk |
| #define | HRTIM_RSTR_TIMECMP1_Pos (28U) |
| #define | HRTIM_RSTR_TIMECMP1_Msk (0x1UL << HRTIM_RSTR_TIMECMP1_Pos) |
| #define | HRTIM_RSTR_TIMECMP1 HRTIM_RSTR_TIMECMP1_Msk |
| #define | HRTIM_RSTR_TIMECMP2_Pos (29U) |
| #define | HRTIM_RSTR_TIMECMP2_Msk (0x1UL << HRTIM_RSTR_TIMECMP2_Pos) |
| #define | HRTIM_RSTR_TIMECMP2 HRTIM_RSTR_TIMECMP2_Msk |
| #define | HRTIM_RSTR_TIMECMP4_Pos (30U) |
| #define | HRTIM_RSTR_TIMECMP4_Msk (0x1UL << HRTIM_RSTR_TIMECMP4_Pos) |
| #define | HRTIM_RSTR_TIMECMP4 HRTIM_RSTR_TIMECMP4_Msk |
| #define | HRTIM_RSTBR_TIMACMP1_Pos (19U) |
| #define | HRTIM_RSTBR_TIMACMP1_Msk (0x1UL << HRTIM_RSTBR_TIMACMP1_Pos) |
| #define | HRTIM_RSTBR_TIMACMP1 HRTIM_RSTBR_TIMACMP1_Msk |
| #define | HRTIM_RSTBR_TIMACMP2_Pos (20U) |
| #define | HRTIM_RSTBR_TIMACMP2_Msk (0x1UL << HRTIM_RSTBR_TIMACMP2_Pos) |
| #define | HRTIM_RSTBR_TIMACMP2 HRTIM_RSTBR_TIMACMP2_Msk |
| #define | HRTIM_RSTBR_TIMACMP4_Pos (21U) |
| #define | HRTIM_RSTBR_TIMACMP4_Msk (0x1UL << HRTIM_RSTBR_TIMACMP4_Pos) |
| #define | HRTIM_RSTBR_TIMACMP4 HRTIM_RSTBR_TIMACMP4_Msk |
| #define | HRTIM_RSTBR_TIMCCMP1_Pos (22U) |
| #define | HRTIM_RSTBR_TIMCCMP1_Msk (0x1UL << HRTIM_RSTBR_TIMCCMP1_Pos) |
| #define | HRTIM_RSTBR_TIMCCMP1 HRTIM_RSTBR_TIMCCMP1_Msk |
| #define | HRTIM_RSTBR_TIMCCMP2_Pos (23U) |
| #define | HRTIM_RSTBR_TIMCCMP2_Msk (0x1UL << HRTIM_RSTBR_TIMCCMP2_Pos) |
| #define | HRTIM_RSTBR_TIMCCMP2 HRTIM_RSTBR_TIMCCMP2_Msk |
| #define | HRTIM_RSTBR_TIMCCMP4_Pos (24U) |
| #define | HRTIM_RSTBR_TIMCCMP4_Msk (0x1UL << HRTIM_RSTBR_TIMCCMP4_Pos) |
| #define | HRTIM_RSTBR_TIMCCMP4 HRTIM_RSTBR_TIMCCMP4_Msk |
| #define | HRTIM_RSTBR_TIMDCMP1_Pos (25U) |
| #define | HRTIM_RSTBR_TIMDCMP1_Msk (0x1UL << HRTIM_RSTBR_TIMDCMP1_Pos) |
| #define | HRTIM_RSTBR_TIMDCMP1 HRTIM_RSTBR_TIMDCMP1_Msk |
| #define | HRTIM_RSTBR_TIMDCMP2_Pos (26U) |
| #define | HRTIM_RSTBR_TIMDCMP2_Msk (0x1UL << HRTIM_RSTBR_TIMDCMP2_Pos) |
| #define | HRTIM_RSTBR_TIMDCMP2 HRTIM_RSTBR_TIMDCMP2_Msk |
| #define | HRTIM_RSTBR_TIMDCMP4_Pos (27U) |
| #define | HRTIM_RSTBR_TIMDCMP4_Msk (0x1UL << HRTIM_RSTBR_TIMDCMP4_Pos) |
| #define | HRTIM_RSTBR_TIMDCMP4 HRTIM_RSTBR_TIMDCMP4_Msk |
| #define | HRTIM_RSTBR_TIMECMP1_Pos (28U) |
| #define | HRTIM_RSTBR_TIMECMP1_Msk (0x1UL << HRTIM_RSTBR_TIMECMP1_Pos) |
| #define | HRTIM_RSTBR_TIMECMP1 HRTIM_RSTBR_TIMECMP1_Msk |
| #define | HRTIM_RSTBR_TIMECMP2_Pos (29U) |
| #define | HRTIM_RSTBR_TIMECMP2_Msk (0x1UL << HRTIM_RSTBR_TIMECMP2_Pos) |
| #define | HRTIM_RSTBR_TIMECMP2 HRTIM_RSTBR_TIMECMP2_Msk |
| #define | HRTIM_RSTBR_TIMECMP4_Pos (30U) |
| #define | HRTIM_RSTBR_TIMECMP4_Msk (0x1UL << HRTIM_RSTBR_TIMECMP4_Pos) |
| #define | HRTIM_RSTBR_TIMECMP4 HRTIM_RSTBR_TIMECMP4_Msk |
| #define | HRTIM_RSTCR_TIMACMP1_Pos (19U) |
| #define | HRTIM_RSTCR_TIMACMP1_Msk (0x1UL << HRTIM_RSTCR_TIMACMP1_Pos) |
| #define | HRTIM_RSTCR_TIMACMP1 HRTIM_RSTCR_TIMACMP1_Msk |
| #define | HRTIM_RSTCR_TIMACMP2_Pos (20U) |
| #define | HRTIM_RSTCR_TIMACMP2_Msk (0x1UL << HRTIM_RSTCR_TIMACMP2_Pos) |
| #define | HRTIM_RSTCR_TIMACMP2 HRTIM_RSTCR_TIMACMP2_Msk |
| #define | HRTIM_RSTCR_TIMACMP4_Pos (21U) |
| #define | HRTIM_RSTCR_TIMACMP4_Msk (0x1UL << HRTIM_RSTCR_TIMACMP4_Pos) |
| #define | HRTIM_RSTCR_TIMACMP4 HRTIM_RSTCR_TIMACMP4_Msk |
| #define | HRTIM_RSTCR_TIMBCMP1_Pos (22U) |
| #define | HRTIM_RSTCR_TIMBCMP1_Msk (0x1UL << HRTIM_RSTCR_TIMBCMP1_Pos) |
| #define | HRTIM_RSTCR_TIMBCMP1 HRTIM_RSTCR_TIMBCMP1_Msk |
| #define | HRTIM_RSTCR_TIMBCMP2_Pos (23U) |
| #define | HRTIM_RSTCR_TIMBCMP2_Msk (0x1UL << HRTIM_RSTCR_TIMBCMP2_Pos) |
| #define | HRTIM_RSTCR_TIMBCMP2 HRTIM_RSTCR_TIMBCMP2_Msk |
| #define | HRTIM_RSTCR_TIMBCMP4_Pos (24U) |
| #define | HRTIM_RSTCR_TIMBCMP4_Msk (0x1UL << HRTIM_RSTCR_TIMBCMP4_Pos) |
| #define | HRTIM_RSTCR_TIMBCMP4 HRTIM_RSTCR_TIMBCMP4_Msk |
| #define | HRTIM_RSTCR_TIMDCMP1_Pos (25U) |
| #define | HRTIM_RSTCR_TIMDCMP1_Msk (0x1UL << HRTIM_RSTCR_TIMDCMP1_Pos) |
| #define | HRTIM_RSTCR_TIMDCMP1 HRTIM_RSTCR_TIMDCMP1_Msk |
| #define | HRTIM_RSTCR_TIMDCMP2_Pos (26U) |
| #define | HRTIM_RSTCR_TIMDCMP2_Msk (0x1UL << HRTIM_RSTCR_TIMDCMP2_Pos) |
| #define | HRTIM_RSTCR_TIMDCMP2 HRTIM_RSTCR_TIMDCMP2_Msk |
| #define | HRTIM_RSTCR_TIMDCMP4_Pos (27U) |
| #define | HRTIM_RSTCR_TIMDCMP4_Msk (0x1UL << HRTIM_RSTCR_TIMDCMP4_Pos) |
| #define | HRTIM_RSTCR_TIMDCMP4 HRTIM_RSTCR_TIMDCMP4_Msk |
| #define | HRTIM_RSTCR_TIMECMP1_Pos (28U) |
| #define | HRTIM_RSTCR_TIMECMP1_Msk (0x1UL << HRTIM_RSTCR_TIMECMP1_Pos) |
| #define | HRTIM_RSTCR_TIMECMP1 HRTIM_RSTCR_TIMECMP1_Msk |
| #define | HRTIM_RSTCR_TIMECMP2_Pos (29U) |
| #define | HRTIM_RSTCR_TIMECMP2_Msk (0x1UL << HRTIM_RSTCR_TIMECMP2_Pos) |
| #define | HRTIM_RSTCR_TIMECMP2 HRTIM_RSTCR_TIMECMP2_Msk |
| #define | HRTIM_RSTCR_TIMECMP4_Pos (30U) |
| #define | HRTIM_RSTCR_TIMECMP4_Msk (0x1UL << HRTIM_RSTCR_TIMECMP4_Pos) |
| #define | HRTIM_RSTCR_TIMECMP4 HRTIM_RSTCR_TIMECMP4_Msk |
| #define | HRTIM_RSTDR_TIMACMP1_Pos (19U) |
| #define | HRTIM_RSTDR_TIMACMP1_Msk (0x1UL << HRTIM_RSTDR_TIMACMP1_Pos) |
| #define | HRTIM_RSTDR_TIMACMP1 HRTIM_RSTDR_TIMACMP1_Msk |
| #define | HRTIM_RSTDR_TIMACMP2_Pos (20U) |
| #define | HRTIM_RSTDR_TIMACMP2_Msk (0x1UL << HRTIM_RSTDR_TIMACMP2_Pos) |
| #define | HRTIM_RSTDR_TIMACMP2 HRTIM_RSTDR_TIMACMP2_Msk |
| #define | HRTIM_RSTDR_TIMACMP4_Pos (21U) |
| #define | HRTIM_RSTDR_TIMACMP4_Msk (0x1UL << HRTIM_RSTDR_TIMACMP4_Pos) |
| #define | HRTIM_RSTDR_TIMACMP4 HRTIM_RSTDR_TIMACMP4_Msk |
| #define | HRTIM_RSTDR_TIMBCMP1_Pos (22U) |
| #define | HRTIM_RSTDR_TIMBCMP1_Msk (0x1UL << HRTIM_RSTDR_TIMBCMP1_Pos) |
| #define | HRTIM_RSTDR_TIMBCMP1 HRTIM_RSTDR_TIMBCMP1_Msk |
| #define | HRTIM_RSTDR_TIMBCMP2_Pos (23U) |
| #define | HRTIM_RSTDR_TIMBCMP2_Msk (0x1UL << HRTIM_RSTDR_TIMBCMP2_Pos) |
| #define | HRTIM_RSTDR_TIMBCMP2 HRTIM_RSTDR_TIMBCMP2_Msk |
| #define | HRTIM_RSTDR_TIMBCMP4_Pos (24U) |
| #define | HRTIM_RSTDR_TIMBCMP4_Msk (0x1UL << HRTIM_RSTDR_TIMBCMP4_Pos) |
| #define | HRTIM_RSTDR_TIMBCMP4 HRTIM_RSTDR_TIMBCMP4_Msk |
| #define | HRTIM_RSTDR_TIMCCMP1_Pos (25U) |
| #define | HRTIM_RSTDR_TIMCCMP1_Msk (0x1UL << HRTIM_RSTDR_TIMCCMP1_Pos) |
| #define | HRTIM_RSTDR_TIMCCMP1 HRTIM_RSTDR_TIMCCMP1_Msk |
| #define | HRTIM_RSTDR_TIMCCMP2_Pos (26U) |
| #define | HRTIM_RSTDR_TIMCCMP2_Msk (0x1UL << HRTIM_RSTDR_TIMCCMP2_Pos) |
| #define | HRTIM_RSTDR_TIMCCMP2 HRTIM_RSTDR_TIMCCMP2_Msk |
| #define | HRTIM_RSTDR_TIMCCMP4_Pos (27U) |
| #define | HRTIM_RSTDR_TIMCCMP4_Msk (0x1UL << HRTIM_RSTDR_TIMCCMP4_Pos) |
| #define | HRTIM_RSTDR_TIMCCMP4 HRTIM_RSTDR_TIMCCMP4_Msk |
| #define | HRTIM_RSTDR_TIMECMP1_Pos (28U) |
| #define | HRTIM_RSTDR_TIMECMP1_Msk (0x1UL << HRTIM_RSTDR_TIMECMP1_Pos) |
| #define | HRTIM_RSTDR_TIMECMP1 HRTIM_RSTDR_TIMECMP1_Msk |
| #define | HRTIM_RSTDR_TIMECMP2_Pos (29U) |
| #define | HRTIM_RSTDR_TIMECMP2_Msk (0x1UL << HRTIM_RSTDR_TIMECMP2_Pos) |
| #define | HRTIM_RSTDR_TIMECMP2 HRTIM_RSTDR_TIMECMP2_Msk |
| #define | HRTIM_RSTDR_TIMECMP4_Pos (30U) |
| #define | HRTIM_RSTDR_TIMECMP4_Msk (0x1UL << HRTIM_RSTDR_TIMECMP4_Pos) |
| #define | HRTIM_RSTDR_TIMECMP4 HRTIM_RSTDR_TIMECMP4_Msk |
| #define | HRTIM_RSTER_TIMACMP1_Pos (19U) |
| #define | HRTIM_RSTER_TIMACMP1_Msk (0x1UL << HRTIM_RSTER_TIMACMP1_Pos) |
| #define | HRTIM_RSTER_TIMACMP1 HRTIM_RSTER_TIMACMP1_Msk |
| #define | HRTIM_RSTER_TIMACMP2_Pos (20U) |
| #define | HRTIM_RSTER_TIMACMP2_Msk (0x1UL << HRTIM_RSTER_TIMACMP2_Pos) |
| #define | HRTIM_RSTER_TIMACMP2 HRTIM_RSTER_TIMACMP2_Msk |
| #define | HRTIM_RSTER_TIMACMP4_Pos (21U) |
| #define | HRTIM_RSTER_TIMACMP4_Msk (0x1UL << HRTIM_RSTER_TIMACMP4_Pos) |
| #define | HRTIM_RSTER_TIMACMP4 HRTIM_RSTER_TIMACMP4_Msk |
| #define | HRTIM_RSTER_TIMBCMP1_Pos (22U) |
| #define | HRTIM_RSTER_TIMBCMP1_Msk (0x1UL << HRTIM_RSTER_TIMBCMP1_Pos) |
| #define | HRTIM_RSTER_TIMBCMP1 HRTIM_RSTER_TIMBCMP1_Msk |
| #define | HRTIM_RSTER_TIMBCMP2_Pos (23U) |
| #define | HRTIM_RSTER_TIMBCMP2_Msk (0x1UL << HRTIM_RSTER_TIMBCMP2_Pos) |
| #define | HRTIM_RSTER_TIMBCMP2 HRTIM_RSTER_TIMBCMP2_Msk |
| #define | HRTIM_RSTER_TIMBCMP4_Pos (24U) |
| #define | HRTIM_RSTER_TIMBCMP4_Msk (0x1UL << HRTIM_RSTER_TIMBCMP4_Pos) |
| #define | HRTIM_RSTER_TIMBCMP4 HRTIM_RSTER_TIMBCMP4_Msk |
| #define | HRTIM_RSTER_TIMCCMP1_Pos (25U) |
| #define | HRTIM_RSTER_TIMCCMP1_Msk (0x1UL << HRTIM_RSTER_TIMCCMP1_Pos) |
| #define | HRTIM_RSTER_TIMCCMP1 HRTIM_RSTER_TIMCCMP1_Msk |
| #define | HRTIM_RSTER_TIMCCMP2_Pos (26U) |
| #define | HRTIM_RSTER_TIMCCMP2_Msk (0x1UL << HRTIM_RSTER_TIMCCMP2_Pos) |
| #define | HRTIM_RSTER_TIMCCMP2 HRTIM_RSTER_TIMCCMP2_Msk |
| #define | HRTIM_RSTER_TIMCCMP4_Pos (27U) |
| #define | HRTIM_RSTER_TIMCCMP4_Msk (0x1UL << HRTIM_RSTER_TIMCCMP4_Pos) |
| #define | HRTIM_RSTER_TIMCCMP4 HRTIM_RSTER_TIMCCMP4_Msk |
| #define | HRTIM_RSTER_TIMDCMP1_Pos (28U) |
| #define | HRTIM_RSTER_TIMDCMP1_Msk (0x1UL << HRTIM_RSTER_TIMDCMP1_Pos) |
| #define | HRTIM_RSTER_TIMDCMP1 HRTIM_RSTER_TIMDCMP1_Msk |
| #define | HRTIM_RSTER_TIMDCMP2_Pos (29U) |
| #define | HRTIM_RSTER_TIMDCMP2_Msk (0x1UL << HRTIM_RSTER_TIMDCMP2_Pos) |
| #define | HRTIM_RSTER_TIMDCMP2 HRTIM_RSTER_TIMDCMP2_Msk |
| #define | HRTIM_RSTER_TIMDCMP4_Pos (30U) |
| #define | HRTIM_RSTER_TIMDCMP4_Msk (0x1UL << HRTIM_RSTER_TIMDCMP4_Pos) |
| #define | HRTIM_RSTER_TIMDCMP4 HRTIM_RSTER_TIMDCMP4_Msk |
| #define | HRTIM_CHPR_CARFRQ_Pos (0U) |
| #define | HRTIM_CHPR_CARFRQ_Msk (0xFUL << HRTIM_CHPR_CARFRQ_Pos) |
| #define | HRTIM_CHPR_CARFRQ HRTIM_CHPR_CARFRQ_Msk |
| #define | HRTIM_CHPR_CARFRQ_0 (0x1UL << HRTIM_CHPR_CARFRQ_Pos) |
| #define | HRTIM_CHPR_CARFRQ_1 (0x2UL << HRTIM_CHPR_CARFRQ_Pos) |
| #define | HRTIM_CHPR_CARFRQ_2 (0x4UL << HRTIM_CHPR_CARFRQ_Pos) |
| #define | HRTIM_CHPR_CARFRQ_3 (0x8UL << HRTIM_CHPR_CARFRQ_Pos) |
| #define | HRTIM_CHPR_CARDTY_Pos (4U) |
| #define | HRTIM_CHPR_CARDTY_Msk (0x7UL << HRTIM_CHPR_CARDTY_Pos) |
| #define | HRTIM_CHPR_CARDTY HRTIM_CHPR_CARDTY_Msk |
| #define | HRTIM_CHPR_CARDTY_0 (0x1UL << HRTIM_CHPR_CARDTY_Pos) |
| #define | HRTIM_CHPR_CARDTY_1 (0x2UL << HRTIM_CHPR_CARDTY_Pos) |
| #define | HRTIM_CHPR_CARDTY_2 (0x4UL << HRTIM_CHPR_CARDTY_Pos) |
| #define | HRTIM_CHPR_STRPW_Pos (7U) |
| #define | HRTIM_CHPR_STRPW_Msk (0xFUL << HRTIM_CHPR_STRPW_Pos) |
| #define | HRTIM_CHPR_STRPW HRTIM_CHPR_STRPW_Msk |
| #define | HRTIM_CHPR_STRPW_0 (0x1UL << HRTIM_CHPR_STRPW_Pos) |
| #define | HRTIM_CHPR_STRPW_1 (0x2UL << HRTIM_CHPR_STRPW_Pos) |
| #define | HRTIM_CHPR_STRPW_2 (0x4UL << HRTIM_CHPR_STRPW_Pos) |
| #define | HRTIM_CHPR_STRPW_3 (0x8UL << HRTIM_CHPR_STRPW_Pos) |
| #define | HRTIM_CPT1CR_SWCPT_Pos (0U) |
| #define | HRTIM_CPT1CR_SWCPT_Msk (0x1UL << HRTIM_CPT1CR_SWCPT_Pos) |
| #define | HRTIM_CPT1CR_SWCPT HRTIM_CPT1CR_SWCPT_Msk |
| #define | HRTIM_CPT1CR_UPDCPT_Pos (1U) |
| #define | HRTIM_CPT1CR_UPDCPT_Msk (0x1UL << HRTIM_CPT1CR_UPDCPT_Pos) |
| #define | HRTIM_CPT1CR_UPDCPT HRTIM_CPT1CR_UPDCPT_Msk |
| #define | HRTIM_CPT1CR_EXEV1CPT_Pos (2U) |
| #define | HRTIM_CPT1CR_EXEV1CPT_Msk (0x1UL << HRTIM_CPT1CR_EXEV1CPT_Pos) |
| #define | HRTIM_CPT1CR_EXEV1CPT HRTIM_CPT1CR_EXEV1CPT_Msk |
| #define | HRTIM_CPT1CR_EXEV2CPT_Pos (3U) |
| #define | HRTIM_CPT1CR_EXEV2CPT_Msk (0x1UL << HRTIM_CPT1CR_EXEV2CPT_Pos) |
| #define | HRTIM_CPT1CR_EXEV2CPT HRTIM_CPT1CR_EXEV2CPT_Msk |
| #define | HRTIM_CPT1CR_EXEV3CPT_Pos (4U) |
| #define | HRTIM_CPT1CR_EXEV3CPT_Msk (0x1UL << HRTIM_CPT1CR_EXEV3CPT_Pos) |
| #define | HRTIM_CPT1CR_EXEV3CPT HRTIM_CPT1CR_EXEV3CPT_Msk |
| #define | HRTIM_CPT1CR_EXEV4CPT_Pos (5U) |
| #define | HRTIM_CPT1CR_EXEV4CPT_Msk (0x1UL << HRTIM_CPT1CR_EXEV4CPT_Pos) |
| #define | HRTIM_CPT1CR_EXEV4CPT HRTIM_CPT1CR_EXEV4CPT_Msk |
| #define | HRTIM_CPT1CR_EXEV5CPT_Pos (6U) |
| #define | HRTIM_CPT1CR_EXEV5CPT_Msk (0x1UL << HRTIM_CPT1CR_EXEV5CPT_Pos) |
| #define | HRTIM_CPT1CR_EXEV5CPT HRTIM_CPT1CR_EXEV5CPT_Msk |
| #define | HRTIM_CPT1CR_EXEV6CPT_Pos (7U) |
| #define | HRTIM_CPT1CR_EXEV6CPT_Msk (0x1UL << HRTIM_CPT1CR_EXEV6CPT_Pos) |
| #define | HRTIM_CPT1CR_EXEV6CPT HRTIM_CPT1CR_EXEV6CPT_Msk |
| #define | HRTIM_CPT1CR_EXEV7CPT_Pos (8U) |
| #define | HRTIM_CPT1CR_EXEV7CPT_Msk (0x1UL << HRTIM_CPT1CR_EXEV7CPT_Pos) |
| #define | HRTIM_CPT1CR_EXEV7CPT HRTIM_CPT1CR_EXEV7CPT_Msk |
| #define | HRTIM_CPT1CR_EXEV8CPT_Pos (9U) |
| #define | HRTIM_CPT1CR_EXEV8CPT_Msk (0x1UL << HRTIM_CPT1CR_EXEV8CPT_Pos) |
| #define | HRTIM_CPT1CR_EXEV8CPT HRTIM_CPT1CR_EXEV8CPT_Msk |
| #define | HRTIM_CPT1CR_EXEV9CPT_Pos (10U) |
| #define | HRTIM_CPT1CR_EXEV9CPT_Msk (0x1UL << HRTIM_CPT1CR_EXEV9CPT_Pos) |
| #define | HRTIM_CPT1CR_EXEV9CPT HRTIM_CPT1CR_EXEV9CPT_Msk |
| #define | HRTIM_CPT1CR_EXEV10CPT_Pos (11U) |
| #define | HRTIM_CPT1CR_EXEV10CPT_Msk (0x1UL << HRTIM_CPT1CR_EXEV10CPT_Pos) |
| #define | HRTIM_CPT1CR_EXEV10CPT HRTIM_CPT1CR_EXEV10CPT_Msk |
| #define | HRTIM_CPT1CR_TA1SET_Pos (12U) |
| #define | HRTIM_CPT1CR_TA1SET_Msk (0x1UL << HRTIM_CPT1CR_TA1SET_Pos) |
| #define | HRTIM_CPT1CR_TA1SET HRTIM_CPT1CR_TA1SET_Msk |
| #define | HRTIM_CPT1CR_TA1RST_Pos (13U) |
| #define | HRTIM_CPT1CR_TA1RST_Msk (0x1UL << HRTIM_CPT1CR_TA1RST_Pos) |
| #define | HRTIM_CPT1CR_TA1RST HRTIM_CPT1CR_TA1RST_Msk |
| #define | HRTIM_CPT1CR_TIMACMP1_Pos (14U) |
| #define | HRTIM_CPT1CR_TIMACMP1_Msk (0x1UL << HRTIM_CPT1CR_TIMACMP1_Pos) |
| #define | HRTIM_CPT1CR_TIMACMP1 HRTIM_CPT1CR_TIMACMP1_Msk |
| #define | HRTIM_CPT1CR_TIMACMP2_Pos (15U) |
| #define | HRTIM_CPT1CR_TIMACMP2_Msk (0x1UL << HRTIM_CPT1CR_TIMACMP2_Pos) |
| #define | HRTIM_CPT1CR_TIMACMP2 HRTIM_CPT1CR_TIMACMP2_Msk |
| #define | HRTIM_CPT1CR_TB1SET_Pos (16U) |
| #define | HRTIM_CPT1CR_TB1SET_Msk (0x1UL << HRTIM_CPT1CR_TB1SET_Pos) |
| #define | HRTIM_CPT1CR_TB1SET HRTIM_CPT1CR_TB1SET_Msk |
| #define | HRTIM_CPT1CR_TB1RST_Pos (17U) |
| #define | HRTIM_CPT1CR_TB1RST_Msk (0x1UL << HRTIM_CPT1CR_TB1RST_Pos) |
| #define | HRTIM_CPT1CR_TB1RST HRTIM_CPT1CR_TB1RST_Msk |
| #define | HRTIM_CPT1CR_TIMBCMP1_Pos (18U) |
| #define | HRTIM_CPT1CR_TIMBCMP1_Msk (0x1UL << HRTIM_CPT1CR_TIMBCMP1_Pos) |
| #define | HRTIM_CPT1CR_TIMBCMP1 HRTIM_CPT1CR_TIMBCMP1_Msk |
| #define | HRTIM_CPT1CR_TIMBCMP2_Pos (19U) |
| #define | HRTIM_CPT1CR_TIMBCMP2_Msk (0x1UL << HRTIM_CPT1CR_TIMBCMP2_Pos) |
| #define | HRTIM_CPT1CR_TIMBCMP2 HRTIM_CPT1CR_TIMBCMP2_Msk |
| #define | HRTIM_CPT1CR_TC1SET_Pos (20U) |
| #define | HRTIM_CPT1CR_TC1SET_Msk (0x1UL << HRTIM_CPT1CR_TC1SET_Pos) |
| #define | HRTIM_CPT1CR_TC1SET HRTIM_CPT1CR_TC1SET_Msk |
| #define | HRTIM_CPT1CR_TC1RST_Pos (21U) |
| #define | HRTIM_CPT1CR_TC1RST_Msk (0x1UL << HRTIM_CPT1CR_TC1RST_Pos) |
| #define | HRTIM_CPT1CR_TC1RST HRTIM_CPT1CR_TC1RST_Msk |
| #define | HRTIM_CPT1CR_TIMCCMP1_Pos (22U) |
| #define | HRTIM_CPT1CR_TIMCCMP1_Msk (0x1UL << HRTIM_CPT1CR_TIMCCMP1_Pos) |
| #define | HRTIM_CPT1CR_TIMCCMP1 HRTIM_CPT1CR_TIMCCMP1_Msk |
| #define | HRTIM_CPT1CR_TIMCCMP2_Pos (23U) |
| #define | HRTIM_CPT1CR_TIMCCMP2_Msk (0x1UL << HRTIM_CPT1CR_TIMCCMP2_Pos) |
| #define | HRTIM_CPT1CR_TIMCCMP2 HRTIM_CPT1CR_TIMCCMP2_Msk |
| #define | HRTIM_CPT1CR_TD1SET_Pos (24U) |
| #define | HRTIM_CPT1CR_TD1SET_Msk (0x1UL << HRTIM_CPT1CR_TD1SET_Pos) |
| #define | HRTIM_CPT1CR_TD1SET HRTIM_CPT1CR_TD1SET_Msk |
| #define | HRTIM_CPT1CR_TD1RST_Pos (25U) |
| #define | HRTIM_CPT1CR_TD1RST_Msk (0x1UL << HRTIM_CPT1CR_TD1RST_Pos) |
| #define | HRTIM_CPT1CR_TD1RST HRTIM_CPT1CR_TD1RST_Msk |
| #define | HRTIM_CPT1CR_TIMDCMP1_Pos (26U) |
| #define | HRTIM_CPT1CR_TIMDCMP1_Msk (0x1UL << HRTIM_CPT1CR_TIMDCMP1_Pos) |
| #define | HRTIM_CPT1CR_TIMDCMP1 HRTIM_CPT1CR_TIMDCMP1_Msk |
| #define | HRTIM_CPT1CR_TIMDCMP2_Pos (27U) |
| #define | HRTIM_CPT1CR_TIMDCMP2_Msk (0x1UL << HRTIM_CPT1CR_TIMDCMP2_Pos) |
| #define | HRTIM_CPT1CR_TIMDCMP2 HRTIM_CPT1CR_TIMDCMP2_Msk |
| #define | HRTIM_CPT1CR_TE1SET_Pos (28U) |
| #define | HRTIM_CPT1CR_TE1SET_Msk (0x1UL << HRTIM_CPT1CR_TE1SET_Pos) |
| #define | HRTIM_CPT1CR_TE1SET HRTIM_CPT1CR_TE1SET_Msk |
| #define | HRTIM_CPT1CR_TE1RST_Pos (29U) |
| #define | HRTIM_CPT1CR_TE1RST_Msk (0x1UL << HRTIM_CPT1CR_TE1RST_Pos) |
| #define | HRTIM_CPT1CR_TE1RST HRTIM_CPT1CR_TE1RST_Msk |
| #define | HRTIM_CPT1CR_TIMECMP1_Pos (30U) |
| #define | HRTIM_CPT1CR_TIMECMP1_Msk (0x1UL << HRTIM_CPT1CR_TIMECMP1_Pos) |
| #define | HRTIM_CPT1CR_TIMECMP1 HRTIM_CPT1CR_TIMECMP1_Msk |
| #define | HRTIM_CPT1CR_TIMECMP2_Pos (31U) |
| #define | HRTIM_CPT1CR_TIMECMP2_Msk (0x1UL << HRTIM_CPT1CR_TIMECMP2_Pos) |
| #define | HRTIM_CPT1CR_TIMECMP2 HRTIM_CPT1CR_TIMECMP2_Msk |
| #define | HRTIM_CPT2CR_SWCPT_Pos (0U) |
| #define | HRTIM_CPT2CR_SWCPT_Msk (0x1UL << HRTIM_CPT2CR_SWCPT_Pos) |
| #define | HRTIM_CPT2CR_SWCPT HRTIM_CPT2CR_SWCPT_Msk |
| #define | HRTIM_CPT2CR_UPDCPT_Pos (1U) |
| #define | HRTIM_CPT2CR_UPDCPT_Msk (0x1UL << HRTIM_CPT2CR_UPDCPT_Pos) |
| #define | HRTIM_CPT2CR_UPDCPT HRTIM_CPT2CR_UPDCPT_Msk |
| #define | HRTIM_CPT2CR_EXEV1CPT_Pos (2U) |
| #define | HRTIM_CPT2CR_EXEV1CPT_Msk (0x1UL << HRTIM_CPT2CR_EXEV1CPT_Pos) |
| #define | HRTIM_CPT2CR_EXEV1CPT HRTIM_CPT2CR_EXEV1CPT_Msk |
| #define | HRTIM_CPT2CR_EXEV2CPT_Pos (3U) |
| #define | HRTIM_CPT2CR_EXEV2CPT_Msk (0x1UL << HRTIM_CPT2CR_EXEV2CPT_Pos) |
| #define | HRTIM_CPT2CR_EXEV2CPT HRTIM_CPT2CR_EXEV2CPT_Msk |
| #define | HRTIM_CPT2CR_EXEV3CPT_Pos (4U) |
| #define | HRTIM_CPT2CR_EXEV3CPT_Msk (0x1UL << HRTIM_CPT2CR_EXEV3CPT_Pos) |
| #define | HRTIM_CPT2CR_EXEV3CPT HRTIM_CPT2CR_EXEV3CPT_Msk |
| #define | HRTIM_CPT2CR_EXEV4CPT_Pos (5U) |
| #define | HRTIM_CPT2CR_EXEV4CPT_Msk (0x1UL << HRTIM_CPT2CR_EXEV4CPT_Pos) |
| #define | HRTIM_CPT2CR_EXEV4CPT HRTIM_CPT2CR_EXEV4CPT_Msk |
| #define | HRTIM_CPT2CR_EXEV5CPT_Pos (6U) |
| #define | HRTIM_CPT2CR_EXEV5CPT_Msk (0x1UL << HRTIM_CPT2CR_EXEV5CPT_Pos) |
| #define | HRTIM_CPT2CR_EXEV5CPT HRTIM_CPT2CR_EXEV5CPT_Msk |
| #define | HRTIM_CPT2CR_EXEV6CPT_Pos (7U) |
| #define | HRTIM_CPT2CR_EXEV6CPT_Msk (0x1UL << HRTIM_CPT2CR_EXEV6CPT_Pos) |
| #define | HRTIM_CPT2CR_EXEV6CPT HRTIM_CPT2CR_EXEV6CPT_Msk |
| #define | HRTIM_CPT2CR_EXEV7CPT_Pos (8U) |
| #define | HRTIM_CPT2CR_EXEV7CPT_Msk (0x1UL << HRTIM_CPT2CR_EXEV7CPT_Pos) |
| #define | HRTIM_CPT2CR_EXEV7CPT HRTIM_CPT2CR_EXEV7CPT_Msk |
| #define | HRTIM_CPT2CR_EXEV8CPT_Pos (9U) |
| #define | HRTIM_CPT2CR_EXEV8CPT_Msk (0x1UL << HRTIM_CPT2CR_EXEV8CPT_Pos) |
| #define | HRTIM_CPT2CR_EXEV8CPT HRTIM_CPT2CR_EXEV8CPT_Msk |
| #define | HRTIM_CPT2CR_EXEV9CPT_Pos (10U) |
| #define | HRTIM_CPT2CR_EXEV9CPT_Msk (0x1UL << HRTIM_CPT2CR_EXEV9CPT_Pos) |
| #define | HRTIM_CPT2CR_EXEV9CPT HRTIM_CPT2CR_EXEV9CPT_Msk |
| #define | HRTIM_CPT2CR_EXEV10CPT_Pos (11U) |
| #define | HRTIM_CPT2CR_EXEV10CPT_Msk (0x1UL << HRTIM_CPT2CR_EXEV10CPT_Pos) |
| #define | HRTIM_CPT2CR_EXEV10CPT HRTIM_CPT2CR_EXEV10CPT_Msk |
| #define | HRTIM_CPT2CR_TA1SET_Pos (12U) |
| #define | HRTIM_CPT2CR_TA1SET_Msk (0x1UL << HRTIM_CPT2CR_TA1SET_Pos) |
| #define | HRTIM_CPT2CR_TA1SET HRTIM_CPT2CR_TA1SET_Msk |
| #define | HRTIM_CPT2CR_TA1RST_Pos (13U) |
| #define | HRTIM_CPT2CR_TA1RST_Msk (0x1UL << HRTIM_CPT2CR_TA1RST_Pos) |
| #define | HRTIM_CPT2CR_TA1RST HRTIM_CPT2CR_TA1RST_Msk |
| #define | HRTIM_CPT2CR_TIMACMP1_Pos (14U) |
| #define | HRTIM_CPT2CR_TIMACMP1_Msk (0x1UL << HRTIM_CPT2CR_TIMACMP1_Pos) |
| #define | HRTIM_CPT2CR_TIMACMP1 HRTIM_CPT2CR_TIMACMP1_Msk |
| #define | HRTIM_CPT2CR_TIMACMP2_Pos (15U) |
| #define | HRTIM_CPT2CR_TIMACMP2_Msk (0x1UL << HRTIM_CPT2CR_TIMACMP2_Pos) |
| #define | HRTIM_CPT2CR_TIMACMP2 HRTIM_CPT2CR_TIMACMP2_Msk |
| #define | HRTIM_CPT2CR_TB1SET_Pos (16U) |
| #define | HRTIM_CPT2CR_TB1SET_Msk (0x1UL << HRTIM_CPT2CR_TB1SET_Pos) |
| #define | HRTIM_CPT2CR_TB1SET HRTIM_CPT2CR_TB1SET_Msk |
| #define | HRTIM_CPT2CR_TB1RST_Pos (17U) |
| #define | HRTIM_CPT2CR_TB1RST_Msk (0x1UL << HRTIM_CPT2CR_TB1RST_Pos) |
| #define | HRTIM_CPT2CR_TB1RST HRTIM_CPT2CR_TB1RST_Msk |
| #define | HRTIM_CPT2CR_TIMBCMP1_Pos (18U) |
| #define | HRTIM_CPT2CR_TIMBCMP1_Msk (0x1UL << HRTIM_CPT2CR_TIMBCMP1_Pos) |
| #define | HRTIM_CPT2CR_TIMBCMP1 HRTIM_CPT2CR_TIMBCMP1_Msk |
| #define | HRTIM_CPT2CR_TIMBCMP2_Pos (19U) |
| #define | HRTIM_CPT2CR_TIMBCMP2_Msk (0x1UL << HRTIM_CPT2CR_TIMBCMP2_Pos) |
| #define | HRTIM_CPT2CR_TIMBCMP2 HRTIM_CPT2CR_TIMBCMP2_Msk |
| #define | HRTIM_CPT2CR_TC1SET_Pos (20U) |
| #define | HRTIM_CPT2CR_TC1SET_Msk (0x1UL << HRTIM_CPT2CR_TC1SET_Pos) |
| #define | HRTIM_CPT2CR_TC1SET HRTIM_CPT2CR_TC1SET_Msk |
| #define | HRTIM_CPT2CR_TC1RST_Pos (21U) |
| #define | HRTIM_CPT2CR_TC1RST_Msk (0x1UL << HRTIM_CPT2CR_TC1RST_Pos) |
| #define | HRTIM_CPT2CR_TC1RST HRTIM_CPT2CR_TC1RST_Msk |
| #define | HRTIM_CPT2CR_TIMCCMP1_Pos (22U) |
| #define | HRTIM_CPT2CR_TIMCCMP1_Msk (0x1UL << HRTIM_CPT2CR_TIMCCMP1_Pos) |
| #define | HRTIM_CPT2CR_TIMCCMP1 HRTIM_CPT2CR_TIMCCMP1_Msk |
| #define | HRTIM_CPT2CR_TIMCCMP2_Pos (23U) |
| #define | HRTIM_CPT2CR_TIMCCMP2_Msk (0x1UL << HRTIM_CPT2CR_TIMCCMP2_Pos) |
| #define | HRTIM_CPT2CR_TIMCCMP2 HRTIM_CPT2CR_TIMCCMP2_Msk |
| #define | HRTIM_CPT2CR_TD1SET_Pos (24U) |
| #define | HRTIM_CPT2CR_TD1SET_Msk (0x1UL << HRTIM_CPT2CR_TD1SET_Pos) |
| #define | HRTIM_CPT2CR_TD1SET HRTIM_CPT2CR_TD1SET_Msk |
| #define | HRTIM_CPT2CR_TD1RST_Pos (25U) |
| #define | HRTIM_CPT2CR_TD1RST_Msk (0x1UL << HRTIM_CPT2CR_TD1RST_Pos) |
| #define | HRTIM_CPT2CR_TD1RST HRTIM_CPT2CR_TD1RST_Msk |
| #define | HRTIM_CPT2CR_TIMDCMP1_Pos (26U) |
| #define | HRTIM_CPT2CR_TIMDCMP1_Msk (0x1UL << HRTIM_CPT2CR_TIMDCMP1_Pos) |
| #define | HRTIM_CPT2CR_TIMDCMP1 HRTIM_CPT2CR_TIMDCMP1_Msk |
| #define | HRTIM_CPT2CR_TIMDCMP2_Pos (27U) |
| #define | HRTIM_CPT2CR_TIMDCMP2_Msk (0x1UL << HRTIM_CPT2CR_TIMDCMP2_Pos) |
| #define | HRTIM_CPT2CR_TIMDCMP2 HRTIM_CPT2CR_TIMDCMP2_Msk |
| #define | HRTIM_CPT2CR_TE1SET_Pos (28U) |
| #define | HRTIM_CPT2CR_TE1SET_Msk (0x1UL << HRTIM_CPT2CR_TE1SET_Pos) |
| #define | HRTIM_CPT2CR_TE1SET HRTIM_CPT2CR_TE1SET_Msk |
| #define | HRTIM_CPT2CR_TE1RST_Pos (29U) |
| #define | HRTIM_CPT2CR_TE1RST_Msk (0x1UL << HRTIM_CPT2CR_TE1RST_Pos) |
| #define | HRTIM_CPT2CR_TE1RST HRTIM_CPT2CR_TE1RST_Msk |
| #define | HRTIM_CPT2CR_TIMECMP1_Pos (30U) |
| #define | HRTIM_CPT2CR_TIMECMP1_Msk (0x1UL << HRTIM_CPT2CR_TIMECMP1_Pos) |
| #define | HRTIM_CPT2CR_TIMECMP1 HRTIM_CPT2CR_TIMECMP1_Msk |
| #define | HRTIM_CPT2CR_TIMECMP2_Pos (31U) |
| #define | HRTIM_CPT2CR_TIMECMP2_Msk (0x1UL << HRTIM_CPT2CR_TIMECMP2_Pos) |
| #define | HRTIM_CPT2CR_TIMECMP2 HRTIM_CPT2CR_TIMECMP2_Msk |
| #define | HRTIM_OUTR_POL1_Pos (1U) |
| #define | HRTIM_OUTR_POL1_Msk (0x1UL << HRTIM_OUTR_POL1_Pos) |
| #define | HRTIM_OUTR_POL1 HRTIM_OUTR_POL1_Msk |
| #define | HRTIM_OUTR_IDLM1_Pos (2U) |
| #define | HRTIM_OUTR_IDLM1_Msk (0x1UL << HRTIM_OUTR_IDLM1_Pos) |
| #define | HRTIM_OUTR_IDLM1 HRTIM_OUTR_IDLM1_Msk |
| #define | HRTIM_OUTR_IDLES1_Pos (3U) |
| #define | HRTIM_OUTR_IDLES1_Msk (0x1UL << HRTIM_OUTR_IDLES1_Pos) |
| #define | HRTIM_OUTR_IDLES1 HRTIM_OUTR_IDLES1_Msk |
| #define | HRTIM_OUTR_FAULT1_Pos (4U) |
| #define | HRTIM_OUTR_FAULT1_Msk (0x3UL << HRTIM_OUTR_FAULT1_Pos) |
| #define | HRTIM_OUTR_FAULT1 HRTIM_OUTR_FAULT1_Msk |
| #define | HRTIM_OUTR_FAULT1_0 (0x1UL << HRTIM_OUTR_FAULT1_Pos) |
| #define | HRTIM_OUTR_FAULT1_1 (0x2UL << HRTIM_OUTR_FAULT1_Pos) |
| #define | HRTIM_OUTR_CHP1_Pos (6U) |
| #define | HRTIM_OUTR_CHP1_Msk (0x1UL << HRTIM_OUTR_CHP1_Pos) |
| #define | HRTIM_OUTR_CHP1 HRTIM_OUTR_CHP1_Msk |
| #define | HRTIM_OUTR_DIDL1_Pos (7U) |
| #define | HRTIM_OUTR_DIDL1_Msk (0x1UL << HRTIM_OUTR_DIDL1_Pos) |
| #define | HRTIM_OUTR_DIDL1 HRTIM_OUTR_DIDL1_Msk |
| #define | HRTIM_OUTR_DTEN_Pos (8U) |
| #define | HRTIM_OUTR_DTEN_Msk (0x1UL << HRTIM_OUTR_DTEN_Pos) |
| #define | HRTIM_OUTR_DTEN HRTIM_OUTR_DTEN_Msk |
| #define | HRTIM_OUTR_DLYPRTEN_Pos (9U) |
| #define | HRTIM_OUTR_DLYPRTEN_Msk (0x1UL << HRTIM_OUTR_DLYPRTEN_Pos) |
| #define | HRTIM_OUTR_DLYPRTEN HRTIM_OUTR_DLYPRTEN_Msk |
| #define | HRTIM_OUTR_DLYPRT_Pos (10U) |
| #define | HRTIM_OUTR_DLYPRT_Msk (0x7UL << HRTIM_OUTR_DLYPRT_Pos) |
| #define | HRTIM_OUTR_DLYPRT HRTIM_OUTR_DLYPRT_Msk |
| #define | HRTIM_OUTR_DLYPRT_0 (0x1UL << HRTIM_OUTR_DLYPRT_Pos) |
| #define | HRTIM_OUTR_DLYPRT_1 (0x2UL << HRTIM_OUTR_DLYPRT_Pos) |
| #define | HRTIM_OUTR_DLYPRT_2 (0x4UL << HRTIM_OUTR_DLYPRT_Pos) |
| #define | HRTIM_OUTR_POL2_Pos (17U) |
| #define | HRTIM_OUTR_POL2_Msk (0x1UL << HRTIM_OUTR_POL2_Pos) |
| #define | HRTIM_OUTR_POL2 HRTIM_OUTR_POL2_Msk |
| #define | HRTIM_OUTR_IDLM2_Pos (18U) |
| #define | HRTIM_OUTR_IDLM2_Msk (0x1UL << HRTIM_OUTR_IDLM2_Pos) |
| #define | HRTIM_OUTR_IDLM2 HRTIM_OUTR_IDLM2_Msk |
| #define | HRTIM_OUTR_IDLES2_Pos (19U) |
| #define | HRTIM_OUTR_IDLES2_Msk (0x1UL << HRTIM_OUTR_IDLES2_Pos) |
| #define | HRTIM_OUTR_IDLES2 HRTIM_OUTR_IDLES2_Msk |
| #define | HRTIM_OUTR_FAULT2_Pos (20U) |
| #define | HRTIM_OUTR_FAULT2_Msk (0x3UL << HRTIM_OUTR_FAULT2_Pos) |
| #define | HRTIM_OUTR_FAULT2 HRTIM_OUTR_FAULT2_Msk |
| #define | HRTIM_OUTR_FAULT2_0 (0x1UL << HRTIM_OUTR_FAULT2_Pos) |
| #define | HRTIM_OUTR_FAULT2_1 (0x2UL << HRTIM_OUTR_FAULT2_Pos) |
| #define | HRTIM_OUTR_CHP2_Pos (22U) |
| #define | HRTIM_OUTR_CHP2_Msk (0x1UL << HRTIM_OUTR_CHP2_Pos) |
| #define | HRTIM_OUTR_CHP2 HRTIM_OUTR_CHP2_Msk |
| #define | HRTIM_OUTR_DIDL2_Pos (23U) |
| #define | HRTIM_OUTR_DIDL2_Msk (0x1UL << HRTIM_OUTR_DIDL2_Pos) |
| #define | HRTIM_OUTR_DIDL2 HRTIM_OUTR_DIDL2_Msk |
| #define | HRTIM_FLTR_FLT1EN_Pos (0U) |
| #define | HRTIM_FLTR_FLT1EN_Msk (0x1UL << HRTIM_FLTR_FLT1EN_Pos) |
| #define | HRTIM_FLTR_FLT1EN HRTIM_FLTR_FLT1EN_Msk |
| #define | HRTIM_FLTR_FLT2EN_Pos (1U) |
| #define | HRTIM_FLTR_FLT2EN_Msk (0x1UL << HRTIM_FLTR_FLT2EN_Pos) |
| #define | HRTIM_FLTR_FLT2EN HRTIM_FLTR_FLT2EN_Msk |
| #define | HRTIM_FLTR_FLT3EN_Pos (2U) |
| #define | HRTIM_FLTR_FLT3EN_Msk (0x1UL << HRTIM_FLTR_FLT3EN_Pos) |
| #define | HRTIM_FLTR_FLT3EN HRTIM_FLTR_FLT3EN_Msk |
| #define | HRTIM_FLTR_FLT4EN_Pos (3U) |
| #define | HRTIM_FLTR_FLT4EN_Msk (0x1UL << HRTIM_FLTR_FLT4EN_Pos) |
| #define | HRTIM_FLTR_FLT4EN HRTIM_FLTR_FLT4EN_Msk |
| #define | HRTIM_FLTR_FLT5EN_Pos (4U) |
| #define | HRTIM_FLTR_FLT5EN_Msk (0x1UL << HRTIM_FLTR_FLT5EN_Pos) |
| #define | HRTIM_FLTR_FLT5EN HRTIM_FLTR_FLT5EN_Msk |
| #define | HRTIM_FLTR_FLTLCK_Pos (31U) |
| #define | HRTIM_FLTR_FLTLCK_Msk (0x1UL << HRTIM_FLTR_FLTLCK_Pos) |
| #define | HRTIM_FLTR_FLTLCK HRTIM_FLTR_FLTLCK_Msk |
| #define | HRTIM_CR1_MUDIS_Pos (0U) |
| #define | HRTIM_CR1_MUDIS_Msk (0x1UL << HRTIM_CR1_MUDIS_Pos) |
| #define | HRTIM_CR1_MUDIS HRTIM_CR1_MUDIS_Msk |
| #define | HRTIM_CR1_TAUDIS_Pos (1U) |
| #define | HRTIM_CR1_TAUDIS_Msk (0x1UL << HRTIM_CR1_TAUDIS_Pos) |
| #define | HRTIM_CR1_TAUDIS HRTIM_CR1_TAUDIS_Msk |
| #define | HRTIM_CR1_TBUDIS_Pos (2U) |
| #define | HRTIM_CR1_TBUDIS_Msk (0x1UL << HRTIM_CR1_TBUDIS_Pos) |
| #define | HRTIM_CR1_TBUDIS HRTIM_CR1_TBUDIS_Msk |
| #define | HRTIM_CR1_TCUDIS_Pos (3U) |
| #define | HRTIM_CR1_TCUDIS_Msk (0x1UL << HRTIM_CR1_TCUDIS_Pos) |
| #define | HRTIM_CR1_TCUDIS HRTIM_CR1_TCUDIS_Msk |
| #define | HRTIM_CR1_TDUDIS_Pos (4U) |
| #define | HRTIM_CR1_TDUDIS_Msk (0x1UL << HRTIM_CR1_TDUDIS_Pos) |
| #define | HRTIM_CR1_TDUDIS HRTIM_CR1_TDUDIS_Msk |
| #define | HRTIM_CR1_TEUDIS_Pos (5U) |
| #define | HRTIM_CR1_TEUDIS_Msk (0x1UL << HRTIM_CR1_TEUDIS_Pos) |
| #define | HRTIM_CR1_TEUDIS HRTIM_CR1_TEUDIS_Msk |
| #define | HRTIM_CR1_ADC1USRC_Pos (16U) |
| #define | HRTIM_CR1_ADC1USRC_Msk (0x7UL << HRTIM_CR1_ADC1USRC_Pos) |
| #define | HRTIM_CR1_ADC1USRC HRTIM_CR1_ADC1USRC_Msk |
| #define | HRTIM_CR1_ADC1USRC_0 (0x1UL << HRTIM_CR1_ADC1USRC_Pos) |
| #define | HRTIM_CR1_ADC1USRC_1 (0x2UL << HRTIM_CR1_ADC1USRC_Pos) |
| #define | HRTIM_CR1_ADC1USRC_2 (0x4UL << HRTIM_CR1_ADC1USRC_Pos) |
| #define | HRTIM_CR1_ADC2USRC_Pos (19U) |
| #define | HRTIM_CR1_ADC2USRC_Msk (0x7UL << HRTIM_CR1_ADC2USRC_Pos) |
| #define | HRTIM_CR1_ADC2USRC HRTIM_CR1_ADC2USRC_Msk |
| #define | HRTIM_CR1_ADC2USRC_0 (0x1UL << HRTIM_CR1_ADC2USRC_Pos) |
| #define | HRTIM_CR1_ADC2USRC_1 (0x2UL << HRTIM_CR1_ADC2USRC_Pos) |
| #define | HRTIM_CR1_ADC2USRC_2 (0x4UL << HRTIM_CR1_ADC2USRC_Pos) |
| #define | HRTIM_CR1_ADC3USRC_Pos (22U) |
| #define | HRTIM_CR1_ADC3USRC_Msk (0x7UL << HRTIM_CR1_ADC3USRC_Pos) |
| #define | HRTIM_CR1_ADC3USRC HRTIM_CR1_ADC3USRC_Msk |
| #define | HRTIM_CR1_ADC3USRC_0 (0x1UL << HRTIM_CR1_ADC3USRC_Pos) |
| #define | HRTIM_CR1_ADC3USRC_1 (0x2UL << HRTIM_CR1_ADC3USRC_Pos) |
| #define | HRTIM_CR1_ADC3USRC_2 (0x4UL << HRTIM_CR1_ADC3USRC_Pos) |
| #define | HRTIM_CR1_ADC4USRC_Pos (25U) |
| #define | HRTIM_CR1_ADC4USRC_Msk (0x7UL << HRTIM_CR1_ADC4USRC_Pos) |
| #define | HRTIM_CR1_ADC4USRC HRTIM_CR1_ADC4USRC_Msk |
| #define | HRTIM_CR1_ADC4USRC_0 (0x1UL << HRTIM_CR1_ADC4USRC_Pos) |
| #define | HRTIM_CR1_ADC4USRC_1 (0x2UL << HRTIM_CR1_ADC4USRC_Pos) |
| #define | HRTIM_CR1_ADC4USRC_2 (0x0UL << HRTIM_CR1_ADC4USRC_Pos) |
| #define | HRTIM_CR2_MSWU_Pos (0U) |
| #define | HRTIM_CR2_MSWU_Msk (0x1UL << HRTIM_CR2_MSWU_Pos) |
| #define | HRTIM_CR2_MSWU HRTIM_CR2_MSWU_Msk |
| #define | HRTIM_CR2_TASWU_Pos (1U) |
| #define | HRTIM_CR2_TASWU_Msk (0x1UL << HRTIM_CR2_TASWU_Pos) |
| #define | HRTIM_CR2_TASWU HRTIM_CR2_TASWU_Msk |
| #define | HRTIM_CR2_TBSWU_Pos (2U) |
| #define | HRTIM_CR2_TBSWU_Msk (0x1UL << HRTIM_CR2_TBSWU_Pos) |
| #define | HRTIM_CR2_TBSWU HRTIM_CR2_TBSWU_Msk |
| #define | HRTIM_CR2_TCSWU_Pos (3U) |
| #define | HRTIM_CR2_TCSWU_Msk (0x1UL << HRTIM_CR2_TCSWU_Pos) |
| #define | HRTIM_CR2_TCSWU HRTIM_CR2_TCSWU_Msk |
| #define | HRTIM_CR2_TDSWU_Pos (4U) |
| #define | HRTIM_CR2_TDSWU_Msk (0x1UL << HRTIM_CR2_TDSWU_Pos) |
| #define | HRTIM_CR2_TDSWU HRTIM_CR2_TDSWU_Msk |
| #define | HRTIM_CR2_TESWU_Pos (5U) |
| #define | HRTIM_CR2_TESWU_Msk (0x1UL << HRTIM_CR2_TESWU_Pos) |
| #define | HRTIM_CR2_TESWU HRTIM_CR2_TESWU_Msk |
| #define | HRTIM_CR2_MRST_Pos (8U) |
| #define | HRTIM_CR2_MRST_Msk (0x1UL << HRTIM_CR2_MRST_Pos) |
| #define | HRTIM_CR2_MRST HRTIM_CR2_MRST_Msk |
| #define | HRTIM_CR2_TARST_Pos (9U) |
| #define | HRTIM_CR2_TARST_Msk (0x1UL << HRTIM_CR2_TARST_Pos) |
| #define | HRTIM_CR2_TARST HRTIM_CR2_TARST_Msk |
| #define | HRTIM_CR2_TBRST_Pos (10U) |
| #define | HRTIM_CR2_TBRST_Msk (0x1UL << HRTIM_CR2_TBRST_Pos) |
| #define | HRTIM_CR2_TBRST HRTIM_CR2_TBRST_Msk |
| #define | HRTIM_CR2_TCRST_Pos (11U) |
| #define | HRTIM_CR2_TCRST_Msk (0x1UL << HRTIM_CR2_TCRST_Pos) |
| #define | HRTIM_CR2_TCRST HRTIM_CR2_TCRST_Msk |
| #define | HRTIM_CR2_TDRST_Pos (12U) |
| #define | HRTIM_CR2_TDRST_Msk (0x1UL << HRTIM_CR2_TDRST_Pos) |
| #define | HRTIM_CR2_TDRST HRTIM_CR2_TDRST_Msk |
| #define | HRTIM_CR2_TERST_Pos (13U) |
| #define | HRTIM_CR2_TERST_Msk (0x1UL << HRTIM_CR2_TERST_Pos) |
| #define | HRTIM_CR2_TERST HRTIM_CR2_TERST_Msk |
| #define | HRTIM_ISR_FLT1_Pos (0U) |
| #define | HRTIM_ISR_FLT1_Msk (0x1UL << HRTIM_ISR_FLT1_Pos) |
| #define | HRTIM_ISR_FLT1 HRTIM_ISR_FLT1_Msk |
| #define | HRTIM_ISR_FLT2_Pos (1U) |
| #define | HRTIM_ISR_FLT2_Msk (0x1UL << HRTIM_ISR_FLT2_Pos) |
| #define | HRTIM_ISR_FLT2 HRTIM_ISR_FLT2_Msk |
| #define | HRTIM_ISR_FLT3_Pos (2U) |
| #define | HRTIM_ISR_FLT3_Msk (0x1UL << HRTIM_ISR_FLT3_Pos) |
| #define | HRTIM_ISR_FLT3 HRTIM_ISR_FLT3_Msk |
| #define | HRTIM_ISR_FLT4_Pos (3U) |
| #define | HRTIM_ISR_FLT4_Msk (0x1UL << HRTIM_ISR_FLT4_Pos) |
| #define | HRTIM_ISR_FLT4 HRTIM_ISR_FLT4_Msk |
| #define | HRTIM_ISR_FLT5_Pos (4U) |
| #define | HRTIM_ISR_FLT5_Msk (0x1UL << HRTIM_ISR_FLT5_Pos) |
| #define | HRTIM_ISR_FLT5 HRTIM_ISR_FLT5_Msk |
| #define | HRTIM_ISR_SYSFLT_Pos (5U) |
| #define | HRTIM_ISR_SYSFLT_Msk (0x1UL << HRTIM_ISR_SYSFLT_Pos) |
| #define | HRTIM_ISR_SYSFLT HRTIM_ISR_SYSFLT_Msk |
| #define | HRTIM_ISR_BMPER_Pos (17U) |
| #define | HRTIM_ISR_BMPER_Msk (0x1UL << HRTIM_ISR_BMPER_Pos) |
| #define | HRTIM_ISR_BMPER HRTIM_ISR_BMPER_Msk |
| #define | HRTIM_ICR_FLT1C_Pos (0U) |
| #define | HRTIM_ICR_FLT1C_Msk (0x1UL << HRTIM_ICR_FLT1C_Pos) |
| #define | HRTIM_ICR_FLT1C HRTIM_ICR_FLT1C_Msk |
| #define | HRTIM_ICR_FLT2C_Pos (1U) |
| #define | HRTIM_ICR_FLT2C_Msk (0x1UL << HRTIM_ICR_FLT2C_Pos) |
| #define | HRTIM_ICR_FLT2C HRTIM_ICR_FLT2C_Msk |
| #define | HRTIM_ICR_FLT3C_Pos (2U) |
| #define | HRTIM_ICR_FLT3C_Msk (0x1UL << HRTIM_ICR_FLT3C_Pos) |
| #define | HRTIM_ICR_FLT3C HRTIM_ICR_FLT3C_Msk |
| #define | HRTIM_ICR_FLT4C_Pos (3U) |
| #define | HRTIM_ICR_FLT4C_Msk (0x1UL << HRTIM_ICR_FLT4C_Pos) |
| #define | HRTIM_ICR_FLT4C HRTIM_ICR_FLT4C_Msk |
| #define | HRTIM_ICR_FLT5C_Pos (4U) |
| #define | HRTIM_ICR_FLT5C_Msk (0x1UL << HRTIM_ICR_FLT5C_Pos) |
| #define | HRTIM_ICR_FLT5C HRTIM_ICR_FLT5C_Msk |
| #define | HRTIM_ICR_SYSFLTC_Pos (5U) |
| #define | HRTIM_ICR_SYSFLTC_Msk (0x1UL << HRTIM_ICR_SYSFLTC_Pos) |
| #define | HRTIM_ICR_SYSFLTC HRTIM_ICR_SYSFLTC_Msk |
| #define | HRTIM_ICR_BMPERC_Pos (17U) |
| #define | HRTIM_ICR_BMPERC_Msk (0x1UL << HRTIM_ICR_BMPERC_Pos) |
| #define | HRTIM_ICR_BMPERC HRTIM_ICR_BMPERC_Msk |
| #define | HRTIM_IER_FLT1_Pos (0U) |
| #define | HRTIM_IER_FLT1_Msk (0x1UL << HRTIM_IER_FLT1_Pos) |
| #define | HRTIM_IER_FLT1 HRTIM_IER_FLT1_Msk |
| #define | HRTIM_IER_FLT2_Pos (1U) |
| #define | HRTIM_IER_FLT2_Msk (0x1UL << HRTIM_IER_FLT2_Pos) |
| #define | HRTIM_IER_FLT2 HRTIM_IER_FLT2_Msk |
| #define | HRTIM_IER_FLT3_Pos (2U) |
| #define | HRTIM_IER_FLT3_Msk (0x1UL << HRTIM_IER_FLT3_Pos) |
| #define | HRTIM_IER_FLT3 HRTIM_IER_FLT3_Msk |
| #define | HRTIM_IER_FLT4_Pos (3U) |
| #define | HRTIM_IER_FLT4_Msk (0x1UL << HRTIM_IER_FLT4_Pos) |
| #define | HRTIM_IER_FLT4 HRTIM_IER_FLT4_Msk |
| #define | HRTIM_IER_FLT5_Pos (4U) |
| #define | HRTIM_IER_FLT5_Msk (0x1UL << HRTIM_IER_FLT5_Pos) |
| #define | HRTIM_IER_FLT5 HRTIM_IER_FLT5_Msk |
| #define | HRTIM_IER_SYSFLT_Pos (5U) |
| #define | HRTIM_IER_SYSFLT_Msk (0x1UL << HRTIM_IER_SYSFLT_Pos) |
| #define | HRTIM_IER_SYSFLT HRTIM_IER_SYSFLT_Msk |
| #define | HRTIM_IER_BMPER_Pos (17U) |
| #define | HRTIM_IER_BMPER_Msk (0x1UL << HRTIM_IER_BMPER_Pos) |
| #define | HRTIM_IER_BMPER HRTIM_IER_BMPER_Msk |
| #define | HRTIM_OENR_TA1OEN_Pos (0U) |
| #define | HRTIM_OENR_TA1OEN_Msk (0x1UL << HRTIM_OENR_TA1OEN_Pos) |
| #define | HRTIM_OENR_TA1OEN HRTIM_OENR_TA1OEN_Msk |
| #define | HRTIM_OENR_TA2OEN_Pos (1U) |
| #define | HRTIM_OENR_TA2OEN_Msk (0x1UL << HRTIM_OENR_TA2OEN_Pos) |
| #define | HRTIM_OENR_TA2OEN HRTIM_OENR_TA2OEN_Msk |
| #define | HRTIM_OENR_TB1OEN_Pos (2U) |
| #define | HRTIM_OENR_TB1OEN_Msk (0x1UL << HRTIM_OENR_TB1OEN_Pos) |
| #define | HRTIM_OENR_TB1OEN HRTIM_OENR_TB1OEN_Msk |
| #define | HRTIM_OENR_TB2OEN_Pos (3U) |
| #define | HRTIM_OENR_TB2OEN_Msk (0x1UL << HRTIM_OENR_TB2OEN_Pos) |
| #define | HRTIM_OENR_TB2OEN HRTIM_OENR_TB2OEN_Msk |
| #define | HRTIM_OENR_TC1OEN_Pos (4U) |
| #define | HRTIM_OENR_TC1OEN_Msk (0x1UL << HRTIM_OENR_TC1OEN_Pos) |
| #define | HRTIM_OENR_TC1OEN HRTIM_OENR_TC1OEN_Msk |
| #define | HRTIM_OENR_TC2OEN_Pos (5U) |
| #define | HRTIM_OENR_TC2OEN_Msk (0x1UL << HRTIM_OENR_TC2OEN_Pos) |
| #define | HRTIM_OENR_TC2OEN HRTIM_OENR_TC2OEN_Msk |
| #define | HRTIM_OENR_TD1OEN_Pos (6U) |
| #define | HRTIM_OENR_TD1OEN_Msk (0x1UL << HRTIM_OENR_TD1OEN_Pos) |
| #define | HRTIM_OENR_TD1OEN HRTIM_OENR_TD1OEN_Msk |
| #define | HRTIM_OENR_TD2OEN_Pos (7U) |
| #define | HRTIM_OENR_TD2OEN_Msk (0x1UL << HRTIM_OENR_TD2OEN_Pos) |
| #define | HRTIM_OENR_TD2OEN HRTIM_OENR_TD2OEN_Msk |
| #define | HRTIM_OENR_TE1OEN_Pos (8U) |
| #define | HRTIM_OENR_TE1OEN_Msk (0x1UL << HRTIM_OENR_TE1OEN_Pos) |
| #define | HRTIM_OENR_TE1OEN HRTIM_OENR_TE1OEN_Msk |
| #define | HRTIM_OENR_TE2OEN_Pos (9U) |
| #define | HRTIM_OENR_TE2OEN_Msk (0x1UL << HRTIM_OENR_TE2OEN_Pos) |
| #define | HRTIM_OENR_TE2OEN HRTIM_OENR_TE2OEN_Msk |
| #define | HRTIM_ODISR_TA1ODIS_Pos (0U) |
| #define | HRTIM_ODISR_TA1ODIS_Msk (0x1UL << HRTIM_ODISR_TA1ODIS_Pos) |
| #define | HRTIM_ODISR_TA1ODIS HRTIM_ODISR_TA1ODIS_Msk |
| #define | HRTIM_ODISR_TA2ODIS_Pos (1U) |
| #define | HRTIM_ODISR_TA2ODIS_Msk (0x1UL << HRTIM_ODISR_TA2ODIS_Pos) |
| #define | HRTIM_ODISR_TA2ODIS HRTIM_ODISR_TA2ODIS_Msk |
| #define | HRTIM_ODISR_TB1ODIS_Pos (2U) |
| #define | HRTIM_ODISR_TB1ODIS_Msk (0x1UL << HRTIM_ODISR_TB1ODIS_Pos) |
| #define | HRTIM_ODISR_TB1ODIS HRTIM_ODISR_TB1ODIS_Msk |
| #define | HRTIM_ODISR_TB2ODIS_Pos (3U) |
| #define | HRTIM_ODISR_TB2ODIS_Msk (0x1UL << HRTIM_ODISR_TB2ODIS_Pos) |
| #define | HRTIM_ODISR_TB2ODIS HRTIM_ODISR_TB2ODIS_Msk |
| #define | HRTIM_ODISR_TC1ODIS_Pos (4U) |
| #define | HRTIM_ODISR_TC1ODIS_Msk (0x1UL << HRTIM_ODISR_TC1ODIS_Pos) |
| #define | HRTIM_ODISR_TC1ODIS HRTIM_ODISR_TC1ODIS_Msk |
| #define | HRTIM_ODISR_TC2ODIS_Pos (5U) |
| #define | HRTIM_ODISR_TC2ODIS_Msk (0x1UL << HRTIM_ODISR_TC2ODIS_Pos) |
| #define | HRTIM_ODISR_TC2ODIS HRTIM_ODISR_TC2ODIS_Msk |
| #define | HRTIM_ODISR_TD1ODIS_Pos (6U) |
| #define | HRTIM_ODISR_TD1ODIS_Msk (0x1UL << HRTIM_ODISR_TD1ODIS_Pos) |
| #define | HRTIM_ODISR_TD1ODIS HRTIM_ODISR_TD1ODIS_Msk |
| #define | HRTIM_ODISR_TD2ODIS_Pos (7U) |
| #define | HRTIM_ODISR_TD2ODIS_Msk (0x1UL << HRTIM_ODISR_TD2ODIS_Pos) |
| #define | HRTIM_ODISR_TD2ODIS HRTIM_ODISR_TD2ODIS_Msk |
| #define | HRTIM_ODISR_TE1ODIS_Pos (8U) |
| #define | HRTIM_ODISR_TE1ODIS_Msk (0x1UL << HRTIM_ODISR_TE1ODIS_Pos) |
| #define | HRTIM_ODISR_TE1ODIS HRTIM_ODISR_TE1ODIS_Msk |
| #define | HRTIM_ODISR_TE2ODIS_Pos (9U) |
| #define | HRTIM_ODISR_TE2ODIS_Msk (0x1UL << HRTIM_ODISR_TE2ODIS_Pos) |
| #define | HRTIM_ODISR_TE2ODIS HRTIM_ODISR_TE2ODIS_Msk |
| #define | HRTIM_ODSR_TA1ODS_Pos (0U) |
| #define | HRTIM_ODSR_TA1ODS_Msk (0x1UL << HRTIM_ODSR_TA1ODS_Pos) |
| #define | HRTIM_ODSR_TA1ODS HRTIM_ODSR_TA1ODS_Msk |
| #define | HRTIM_ODSR_TA2ODS_Pos (1U) |
| #define | HRTIM_ODSR_TA2ODS_Msk (0x1UL << HRTIM_ODSR_TA2ODS_Pos) |
| #define | HRTIM_ODSR_TA2ODS HRTIM_ODSR_TA2ODS_Msk |
| #define | HRTIM_ODSR_TB1ODS_Pos (2U) |
| #define | HRTIM_ODSR_TB1ODS_Msk (0x1UL << HRTIM_ODSR_TB1ODS_Pos) |
| #define | HRTIM_ODSR_TB1ODS HRTIM_ODSR_TB1ODS_Msk |
| #define | HRTIM_ODSR_TB2ODS_Pos (3U) |
| #define | HRTIM_ODSR_TB2ODS_Msk (0x1UL << HRTIM_ODSR_TB2ODS_Pos) |
| #define | HRTIM_ODSR_TB2ODS HRTIM_ODSR_TB2ODS_Msk |
| #define | HRTIM_ODSR_TC1ODS_Pos (4U) |
| #define | HRTIM_ODSR_TC1ODS_Msk (0x1UL << HRTIM_ODSR_TC1ODS_Pos) |
| #define | HRTIM_ODSR_TC1ODS HRTIM_ODSR_TC1ODS_Msk |
| #define | HRTIM_ODSR_TC2ODS_Pos (5U) |
| #define | HRTIM_ODSR_TC2ODS_Msk (0x1UL << HRTIM_ODSR_TC2ODS_Pos) |
| #define | HRTIM_ODSR_TC2ODS HRTIM_ODSR_TC2ODS_Msk |
| #define | HRTIM_ODSR_TD1ODS_Pos (6U) |
| #define | HRTIM_ODSR_TD1ODS_Msk (0x1UL << HRTIM_ODSR_TD1ODS_Pos) |
| #define | HRTIM_ODSR_TD1ODS HRTIM_ODSR_TD1ODS_Msk |
| #define | HRTIM_ODSR_TD2ODS_Pos (7U) |
| #define | HRTIM_ODSR_TD2ODS_Msk (0x1UL << HRTIM_ODSR_TD2ODS_Pos) |
| #define | HRTIM_ODSR_TD2ODS HRTIM_ODSR_TD2ODS_Msk |
| #define | HRTIM_ODSR_TE1ODS_Pos (8U) |
| #define | HRTIM_ODSR_TE1ODS_Msk (0x1UL << HRTIM_ODSR_TE1ODS_Pos) |
| #define | HRTIM_ODSR_TE1ODS HRTIM_ODSR_TE1ODS_Msk |
| #define | HRTIM_ODSR_TE2ODS_Pos (9U) |
| #define | HRTIM_ODSR_TE2ODS_Msk (0x1UL << HRTIM_ODSR_TE2ODS_Pos) |
| #define | HRTIM_ODSR_TE2ODS HRTIM_ODSR_TE2ODS_Msk |
| #define | HRTIM_BMCR_BME_Pos (0U) |
| #define | HRTIM_BMCR_BME_Msk (0x1UL << HRTIM_BMCR_BME_Pos) |
| #define | HRTIM_BMCR_BME HRTIM_BMCR_BME_Msk |
| #define | HRTIM_BMCR_BMOM_Pos (1U) |
| #define | HRTIM_BMCR_BMOM_Msk (0x1UL << HRTIM_BMCR_BMOM_Pos) |
| #define | HRTIM_BMCR_BMOM HRTIM_BMCR_BMOM_Msk |
| #define | HRTIM_BMCR_BMCLK_Pos (2U) |
| #define | HRTIM_BMCR_BMCLK_Msk (0xFUL << HRTIM_BMCR_BMCLK_Pos) |
| #define | HRTIM_BMCR_BMCLK HRTIM_BMCR_BMCLK_Msk |
| #define | HRTIM_BMCR_BMCLK_0 (0x1UL << HRTIM_BMCR_BMCLK_Pos) |
| #define | HRTIM_BMCR_BMCLK_1 (0x2UL << HRTIM_BMCR_BMCLK_Pos) |
| #define | HRTIM_BMCR_BMCLK_2 (0x4UL << HRTIM_BMCR_BMCLK_Pos) |
| #define | HRTIM_BMCR_BMCLK_3 (0x8UL << HRTIM_BMCR_BMCLK_Pos) |
| #define | HRTIM_BMCR_BMPRSC_Pos (6U) |
| #define | HRTIM_BMCR_BMPRSC_Msk (0xFUL << HRTIM_BMCR_BMPRSC_Pos) |
| #define | HRTIM_BMCR_BMPRSC HRTIM_BMCR_BMPRSC_Msk |
| #define | HRTIM_BMCR_BMPRSC_0 (0x1UL << HRTIM_BMCR_BMPRSC_Pos) |
| #define | HRTIM_BMCR_BMPRSC_1 (0x2UL << HRTIM_BMCR_BMPRSC_Pos) |
| #define | HRTIM_BMCR_BMPRSC_2 (0x4UL << HRTIM_BMCR_BMPRSC_Pos) |
| #define | HRTIM_BMCR_BMPRSC_3 (0x8UL << HRTIM_BMCR_BMPRSC_Pos) |
| #define | HRTIM_BMCR_BMPREN_Pos (10U) |
| #define | HRTIM_BMCR_BMPREN_Msk (0x1UL << HRTIM_BMCR_BMPREN_Pos) |
| #define | HRTIM_BMCR_BMPREN HRTIM_BMCR_BMPREN_Msk |
| #define | HRTIM_BMCR_MTBM_Pos (16U) |
| #define | HRTIM_BMCR_MTBM_Msk (0x1UL << HRTIM_BMCR_MTBM_Pos) |
| #define | HRTIM_BMCR_MTBM HRTIM_BMCR_MTBM_Msk |
| #define | HRTIM_BMCR_TABM_Pos (17U) |
| #define | HRTIM_BMCR_TABM_Msk (0x1UL << HRTIM_BMCR_TABM_Pos) |
| #define | HRTIM_BMCR_TABM HRTIM_BMCR_TABM_Msk |
| #define | HRTIM_BMCR_TBBM_Pos (18U) |
| #define | HRTIM_BMCR_TBBM_Msk (0x1UL << HRTIM_BMCR_TBBM_Pos) |
| #define | HRTIM_BMCR_TBBM HRTIM_BMCR_TBBM_Msk |
| #define | HRTIM_BMCR_TCBM_Pos (19U) |
| #define | HRTIM_BMCR_TCBM_Msk (0x1UL << HRTIM_BMCR_TCBM_Pos) |
| #define | HRTIM_BMCR_TCBM HRTIM_BMCR_TCBM_Msk |
| #define | HRTIM_BMCR_TDBM_Pos (20U) |
| #define | HRTIM_BMCR_TDBM_Msk (0x1UL << HRTIM_BMCR_TDBM_Pos) |
| #define | HRTIM_BMCR_TDBM HRTIM_BMCR_TDBM_Msk |
| #define | HRTIM_BMCR_TEBM_Pos (21U) |
| #define | HRTIM_BMCR_TEBM_Msk (0x1UL << HRTIM_BMCR_TEBM_Pos) |
| #define | HRTIM_BMCR_TEBM HRTIM_BMCR_TEBM_Msk |
| #define | HRTIM_BMCR_BMSTAT_Pos (31U) |
| #define | HRTIM_BMCR_BMSTAT_Msk (0x1UL << HRTIM_BMCR_BMSTAT_Pos) |
| #define | HRTIM_BMCR_BMSTAT HRTIM_BMCR_BMSTAT_Msk |
| #define | HRTIM_BMTRGR_SW_Pos (0U) |
| #define | HRTIM_BMTRGR_SW_Msk (0x1UL << HRTIM_BMTRGR_SW_Pos) |
| #define | HRTIM_BMTRGR_SW HRTIM_BMTRGR_SW_Msk |
| #define | HRTIM_BMTRGR_MSTRST_Pos (1U) |
| #define | HRTIM_BMTRGR_MSTRST_Msk (0x1UL << HRTIM_BMTRGR_MSTRST_Pos) |
| #define | HRTIM_BMTRGR_MSTRST HRTIM_BMTRGR_MSTRST_Msk |
| #define | HRTIM_BMTRGR_MSTREP_Pos (2U) |
| #define | HRTIM_BMTRGR_MSTREP_Msk (0x1UL << HRTIM_BMTRGR_MSTREP_Pos) |
| #define | HRTIM_BMTRGR_MSTREP HRTIM_BMTRGR_MSTREP_Msk |
| #define | HRTIM_BMTRGR_MSTCMP1_Pos (3U) |
| #define | HRTIM_BMTRGR_MSTCMP1_Msk (0x1UL << HRTIM_BMTRGR_MSTCMP1_Pos) |
| #define | HRTIM_BMTRGR_MSTCMP1 HRTIM_BMTRGR_MSTCMP1_Msk |
| #define | HRTIM_BMTRGR_MSTCMP2_Pos (4U) |
| #define | HRTIM_BMTRGR_MSTCMP2_Msk (0x1UL << HRTIM_BMTRGR_MSTCMP2_Pos) |
| #define | HRTIM_BMTRGR_MSTCMP2 HRTIM_BMTRGR_MSTCMP2_Msk |
| #define | HRTIM_BMTRGR_MSTCMP3_Pos (5U) |
| #define | HRTIM_BMTRGR_MSTCMP3_Msk (0x1UL << HRTIM_BMTRGR_MSTCMP3_Pos) |
| #define | HRTIM_BMTRGR_MSTCMP3 HRTIM_BMTRGR_MSTCMP3_Msk |
| #define | HRTIM_BMTRGR_MSTCMP4_Pos (6U) |
| #define | HRTIM_BMTRGR_MSTCMP4_Msk (0x1UL << HRTIM_BMTRGR_MSTCMP4_Pos) |
| #define | HRTIM_BMTRGR_MSTCMP4 HRTIM_BMTRGR_MSTCMP4_Msk |
| #define | HRTIM_BMTRGR_TARST_Pos (7U) |
| #define | HRTIM_BMTRGR_TARST_Msk (0x1UL << HRTIM_BMTRGR_TARST_Pos) |
| #define | HRTIM_BMTRGR_TARST HRTIM_BMTRGR_TARST_Msk |
| #define | HRTIM_BMTRGR_TAREP_Pos (8U) |
| #define | HRTIM_BMTRGR_TAREP_Msk (0x1UL << HRTIM_BMTRGR_TAREP_Pos) |
| #define | HRTIM_BMTRGR_TAREP HRTIM_BMTRGR_TAREP_Msk |
| #define | HRTIM_BMTRGR_TACMP1_Pos (9U) |
| #define | HRTIM_BMTRGR_TACMP1_Msk (0x1UL << HRTIM_BMTRGR_TACMP1_Pos) |
| #define | HRTIM_BMTRGR_TACMP1 HRTIM_BMTRGR_TACMP1_Msk |
| #define | HRTIM_BMTRGR_TACMP2_Pos (10U) |
| #define | HRTIM_BMTRGR_TACMP2_Msk (0x1UL << HRTIM_BMTRGR_TACMP2_Pos) |
| #define | HRTIM_BMTRGR_TACMP2 HRTIM_BMTRGR_TACMP2_Msk |
| #define | HRTIM_BMTRGR_TBRST_Pos (11U) |
| #define | HRTIM_BMTRGR_TBRST_Msk (0x1UL << HRTIM_BMTRGR_TBRST_Pos) |
| #define | HRTIM_BMTRGR_TBRST HRTIM_BMTRGR_TBRST_Msk |
| #define | HRTIM_BMTRGR_TBREP_Pos (12U) |
| #define | HRTIM_BMTRGR_TBREP_Msk (0x1UL << HRTIM_BMTRGR_TBREP_Pos) |
| #define | HRTIM_BMTRGR_TBREP HRTIM_BMTRGR_TBREP_Msk |
| #define | HRTIM_BMTRGR_TBCMP1_Pos (13U) |
| #define | HRTIM_BMTRGR_TBCMP1_Msk (0x1UL << HRTIM_BMTRGR_TBCMP1_Pos) |
| #define | HRTIM_BMTRGR_TBCMP1 HRTIM_BMTRGR_TBCMP1_Msk |
| #define | HRTIM_BMTRGR_TBCMP2_Pos (14U) |
| #define | HRTIM_BMTRGR_TBCMP2_Msk (0x1UL << HRTIM_BMTRGR_TBCMP2_Pos) |
| #define | HRTIM_BMTRGR_TBCMP2 HRTIM_BMTRGR_TBCMP2_Msk |
| #define | HRTIM_BMTRGR_TCRST_Pos (15U) |
| #define | HRTIM_BMTRGR_TCRST_Msk (0x1UL << HRTIM_BMTRGR_TCRST_Pos) |
| #define | HRTIM_BMTRGR_TCRST HRTIM_BMTRGR_TCRST_Msk |
| #define | HRTIM_BMTRGR_TCREP_Pos (16U) |
| #define | HRTIM_BMTRGR_TCREP_Msk (0x1UL << HRTIM_BMTRGR_TCREP_Pos) |
| #define | HRTIM_BMTRGR_TCREP HRTIM_BMTRGR_TCREP_Msk |
| #define | HRTIM_BMTRGR_TCCMP1_Pos (17U) |
| #define | HRTIM_BMTRGR_TCCMP1_Msk (0x1UL << HRTIM_BMTRGR_TCCMP1_Pos) |
| #define | HRTIM_BMTRGR_TCCMP1 HRTIM_BMTRGR_TCCMP1_Msk |
| #define | HRTIM_BMTRGR_TCCMP2_Pos (18U) |
| #define | HRTIM_BMTRGR_TCCMP2_Msk (0x1UL << HRTIM_BMTRGR_TCCMP2_Pos) |
| #define | HRTIM_BMTRGR_TCCMP2 HRTIM_BMTRGR_TCCMP2_Msk |
| #define | HRTIM_BMTRGR_TDRST_Pos (19U) |
| #define | HRTIM_BMTRGR_TDRST_Msk (0x1UL << HRTIM_BMTRGR_TDRST_Pos) |
| #define | HRTIM_BMTRGR_TDRST HRTIM_BMTRGR_TDRST_Msk |
| #define | HRTIM_BMTRGR_TDREP_Pos (20U) |
| #define | HRTIM_BMTRGR_TDREP_Msk (0x1UL << HRTIM_BMTRGR_TDREP_Pos) |
| #define | HRTIM_BMTRGR_TDREP HRTIM_BMTRGR_TDREP_Msk |
| #define | HRTIM_BMTRGR_TDCMP1_Pos (21U) |
| #define | HRTIM_BMTRGR_TDCMP1_Msk (0x1UL << HRTIM_BMTRGR_TDCMP1_Pos) |
| #define | HRTIM_BMTRGR_TDCMP1 HRTIM_BMTRGR_TDCMP1_Msk |
| #define | HRTIM_BMTRGR_TDCMP2_Pos (22U) |
| #define | HRTIM_BMTRGR_TDCMP2_Msk (0x1UL << HRTIM_BMTRGR_TDCMP2_Pos) |
| #define | HRTIM_BMTRGR_TDCMP2 HRTIM_BMTRGR_TDCMP2_Msk |
| #define | HRTIM_BMTRGR_TERST_Pos (23U) |
| #define | HRTIM_BMTRGR_TERST_Msk (0x1UL << HRTIM_BMTRGR_TERST_Pos) |
| #define | HRTIM_BMTRGR_TERST HRTIM_BMTRGR_TERST_Msk |
| #define | HRTIM_BMTRGR_TEREP_Pos (24U) |
| #define | HRTIM_BMTRGR_TEREP_Msk (0x1UL << HRTIM_BMTRGR_TEREP_Pos) |
| #define | HRTIM_BMTRGR_TEREP HRTIM_BMTRGR_TEREP_Msk |
| #define | HRTIM_BMTRGR_TECMP1_Pos (25U) |
| #define | HRTIM_BMTRGR_TECMP1_Msk (0x1UL << HRTIM_BMTRGR_TECMP1_Pos) |
| #define | HRTIM_BMTRGR_TECMP1 HRTIM_BMTRGR_TECMP1_Msk |
| #define | HRTIM_BMTRGR_TECMP2_Pos (26U) |
| #define | HRTIM_BMTRGR_TECMP2_Msk (0x1UL << HRTIM_BMTRGR_TECMP2_Pos) |
| #define | HRTIM_BMTRGR_TECMP2 HRTIM_BMTRGR_TECMP2_Msk |
| #define | HRTIM_BMTRGR_TAEEV7_Pos (27U) |
| #define | HRTIM_BMTRGR_TAEEV7_Msk (0x1UL << HRTIM_BMTRGR_TAEEV7_Pos) |
| #define | HRTIM_BMTRGR_TAEEV7 HRTIM_BMTRGR_TAEEV7_Msk |
| #define | HRTIM_BMTRGR_TDEEV8_Pos (28U) |
| #define | HRTIM_BMTRGR_TDEEV8_Msk (0x1UL << HRTIM_BMTRGR_TDEEV8_Pos) |
| #define | HRTIM_BMTRGR_TDEEV8 HRTIM_BMTRGR_TDEEV8_Msk |
| #define | HRTIM_BMTRGR_EEV7_Pos (29U) |
| #define | HRTIM_BMTRGR_EEV7_Msk (0x1UL << HRTIM_BMTRGR_EEV7_Pos) |
| #define | HRTIM_BMTRGR_EEV7 HRTIM_BMTRGR_EEV7_Msk |
| #define | HRTIM_BMTRGR_EEV8_Pos (30U) |
| #define | HRTIM_BMTRGR_EEV8_Msk (0x1UL << HRTIM_BMTRGR_EEV8_Pos) |
| #define | HRTIM_BMTRGR_EEV8 HRTIM_BMTRGR_EEV8_Msk |
| #define | HRTIM_BMTRGR_OCHPEV_Pos (31U) |
| #define | HRTIM_BMTRGR_OCHPEV_Msk (0x1UL << HRTIM_BMTRGR_OCHPEV_Pos) |
| #define | HRTIM_BMTRGR_OCHPEV HRTIM_BMTRGR_OCHPEV_Msk |
| #define | HRTIM_BMCMPR_BMCMPR_Pos (0U) |
| #define | HRTIM_BMCMPR_BMCMPR_Msk (0xFFFFUL << HRTIM_BMCMPR_BMCMPR_Pos) |
| #define | HRTIM_BMCMPR_BMCMPR HRTIM_BMCMPR_BMCMPR_Msk |
| #define | HRTIM_BMPER_BMPER_Pos (0U) |
| #define | HRTIM_BMPER_BMPER_Msk (0xFFFFUL << HRTIM_BMPER_BMPER_Pos) |
| #define | HRTIM_BMPER_BMPER HRTIM_BMPER_BMPER_Msk |
| #define | HRTIM_EECR1_EE1SRC_Pos (0U) |
| #define | HRTIM_EECR1_EE1SRC_Msk (0x3UL << HRTIM_EECR1_EE1SRC_Pos) |
| #define | HRTIM_EECR1_EE1SRC HRTIM_EECR1_EE1SRC_Msk |
| #define | HRTIM_EECR1_EE1SRC_0 (0x1UL << HRTIM_EECR1_EE1SRC_Pos) |
| #define | HRTIM_EECR1_EE1SRC_1 (0x2UL << HRTIM_EECR1_EE1SRC_Pos) |
| #define | HRTIM_EECR1_EE1POL_Pos (2U) |
| #define | HRTIM_EECR1_EE1POL_Msk (0x1UL << HRTIM_EECR1_EE1POL_Pos) |
| #define | HRTIM_EECR1_EE1POL HRTIM_EECR1_EE1POL_Msk |
| #define | HRTIM_EECR1_EE1SNS_Pos (3U) |
| #define | HRTIM_EECR1_EE1SNS_Msk (0x3UL << HRTIM_EECR1_EE1SNS_Pos) |
| #define | HRTIM_EECR1_EE1SNS HRTIM_EECR1_EE1SNS_Msk |
| #define | HRTIM_EECR1_EE1SNS_0 (0x1UL << HRTIM_EECR1_EE1SNS_Pos) |
| #define | HRTIM_EECR1_EE1SNS_1 (0x2UL << HRTIM_EECR1_EE1SNS_Pos) |
| #define | HRTIM_EECR1_EE1FAST_Pos (5U) |
| #define | HRTIM_EECR1_EE1FAST_Msk (0x1UL << HRTIM_EECR1_EE1FAST_Pos) |
| #define | HRTIM_EECR1_EE1FAST HRTIM_EECR1_EE1FAST_Msk |
| #define | HRTIM_EECR1_EE2SRC_Pos (6U) |
| #define | HRTIM_EECR1_EE2SRC_Msk (0x3UL << HRTIM_EECR1_EE2SRC_Pos) |
| #define | HRTIM_EECR1_EE2SRC HRTIM_EECR1_EE2SRC_Msk |
| #define | HRTIM_EECR1_EE2SRC_0 (0x1UL << HRTIM_EECR1_EE2SRC_Pos) |
| #define | HRTIM_EECR1_EE2SRC_1 (0x2UL << HRTIM_EECR1_EE2SRC_Pos) |
| #define | HRTIM_EECR1_EE2POL_Pos (8U) |
| #define | HRTIM_EECR1_EE2POL_Msk (0x1UL << HRTIM_EECR1_EE2POL_Pos) |
| #define | HRTIM_EECR1_EE2POL HRTIM_EECR1_EE2POL_Msk |
| #define | HRTIM_EECR1_EE2SNS_Pos (9U) |
| #define | HRTIM_EECR1_EE2SNS_Msk (0x3UL << HRTIM_EECR1_EE2SNS_Pos) |
| #define | HRTIM_EECR1_EE2SNS HRTIM_EECR1_EE2SNS_Msk |
| #define | HRTIM_EECR1_EE2SNS_0 (0x1UL << HRTIM_EECR1_EE2SNS_Pos) |
| #define | HRTIM_EECR1_EE2SNS_1 (0x2UL << HRTIM_EECR1_EE2SNS_Pos) |
| #define | HRTIM_EECR1_EE2FAST_Pos (11U) |
| #define | HRTIM_EECR1_EE2FAST_Msk (0x1UL << HRTIM_EECR1_EE2FAST_Pos) |
| #define | HRTIM_EECR1_EE2FAST HRTIM_EECR1_EE2FAST_Msk |
| #define | HRTIM_EECR1_EE3SRC_Pos (12U) |
| #define | HRTIM_EECR1_EE3SRC_Msk (0x3UL << HRTIM_EECR1_EE3SRC_Pos) |
| #define | HRTIM_EECR1_EE3SRC HRTIM_EECR1_EE3SRC_Msk |
| #define | HRTIM_EECR1_EE3SRC_0 (0x1UL << HRTIM_EECR1_EE3SRC_Pos) |
| #define | HRTIM_EECR1_EE3SRC_1 (0x2UL << HRTIM_EECR1_EE3SRC_Pos) |
| #define | HRTIM_EECR1_EE3POL_Pos (14U) |
| #define | HRTIM_EECR1_EE3POL_Msk (0x1UL << HRTIM_EECR1_EE3POL_Pos) |
| #define | HRTIM_EECR1_EE3POL HRTIM_EECR1_EE3POL_Msk |
| #define | HRTIM_EECR1_EE3SNS_Pos (15U) |
| #define | HRTIM_EECR1_EE3SNS_Msk (0x3UL << HRTIM_EECR1_EE3SNS_Pos) |
| #define | HRTIM_EECR1_EE3SNS HRTIM_EECR1_EE3SNS_Msk |
| #define | HRTIM_EECR1_EE3SNS_0 (0x1UL << HRTIM_EECR1_EE3SNS_Pos) |
| #define | HRTIM_EECR1_EE3SNS_1 (0x2UL << HRTIM_EECR1_EE3SNS_Pos) |
| #define | HRTIM_EECR1_EE3FAST_Pos (17U) |
| #define | HRTIM_EECR1_EE3FAST_Msk (0x1UL << HRTIM_EECR1_EE3FAST_Pos) |
| #define | HRTIM_EECR1_EE3FAST HRTIM_EECR1_EE3FAST_Msk |
| #define | HRTIM_EECR1_EE4SRC_Pos (18U) |
| #define | HRTIM_EECR1_EE4SRC_Msk (0x3UL << HRTIM_EECR1_EE4SRC_Pos) |
| #define | HRTIM_EECR1_EE4SRC HRTIM_EECR1_EE4SRC_Msk |
| #define | HRTIM_EECR1_EE4SRC_0 (0x1UL << HRTIM_EECR1_EE4SRC_Pos) |
| #define | HRTIM_EECR1_EE4SRC_1 (0x2UL << HRTIM_EECR1_EE4SRC_Pos) |
| #define | HRTIM_EECR1_EE4POL_Pos (20U) |
| #define | HRTIM_EECR1_EE4POL_Msk (0x1UL << HRTIM_EECR1_EE4POL_Pos) |
| #define | HRTIM_EECR1_EE4POL HRTIM_EECR1_EE4POL_Msk |
| #define | HRTIM_EECR1_EE4SNS_Pos (21U) |
| #define | HRTIM_EECR1_EE4SNS_Msk (0x3UL << HRTIM_EECR1_EE4SNS_Pos) |
| #define | HRTIM_EECR1_EE4SNS HRTIM_EECR1_EE4SNS_Msk |
| #define | HRTIM_EECR1_EE4SNS_0 (0x1UL << HRTIM_EECR1_EE4SNS_Pos) |
| #define | HRTIM_EECR1_EE4SNS_1 (0x2UL << HRTIM_EECR1_EE4SNS_Pos) |
| #define | HRTIM_EECR1_EE4FAST_Pos (23U) |
| #define | HRTIM_EECR1_EE4FAST_Msk (0x1UL << HRTIM_EECR1_EE4FAST_Pos) |
| #define | HRTIM_EECR1_EE4FAST HRTIM_EECR1_EE4FAST_Msk |
| #define | HRTIM_EECR1_EE5SRC_Pos (24U) |
| #define | HRTIM_EECR1_EE5SRC_Msk (0x3UL << HRTIM_EECR1_EE5SRC_Pos) |
| #define | HRTIM_EECR1_EE5SRC HRTIM_EECR1_EE5SRC_Msk |
| #define | HRTIM_EECR1_EE5SRC_0 (0x1UL << HRTIM_EECR1_EE5SRC_Pos) |
| #define | HRTIM_EECR1_EE5SRC_1 (0x2UL << HRTIM_EECR1_EE5SRC_Pos) |
| #define | HRTIM_EECR1_EE5POL_Pos (26U) |
| #define | HRTIM_EECR1_EE5POL_Msk (0x1UL << HRTIM_EECR1_EE5POL_Pos) |
| #define | HRTIM_EECR1_EE5POL HRTIM_EECR1_EE5POL_Msk |
| #define | HRTIM_EECR1_EE5SNS_Pos (27U) |
| #define | HRTIM_EECR1_EE5SNS_Msk (0x3UL << HRTIM_EECR1_EE5SNS_Pos) |
| #define | HRTIM_EECR1_EE5SNS HRTIM_EECR1_EE5SNS_Msk |
| #define | HRTIM_EECR1_EE5SNS_0 (0x1UL << HRTIM_EECR1_EE5SNS_Pos) |
| #define | HRTIM_EECR1_EE5SNS_1 (0x2UL << HRTIM_EECR1_EE5SNS_Pos) |
| #define | HRTIM_EECR1_EE5FAST_Pos (29U) |
| #define | HRTIM_EECR1_EE5FAST_Msk (0x1UL << HRTIM_EECR1_EE5FAST_Pos) |
| #define | HRTIM_EECR1_EE5FAST HRTIM_EECR1_EE5FAST_Msk |
| #define | HRTIM_EECR2_EE6SRC_Pos (0U) |
| #define | HRTIM_EECR2_EE6SRC_Msk (0x3UL << HRTIM_EECR2_EE6SRC_Pos) |
| #define | HRTIM_EECR2_EE6SRC HRTIM_EECR2_EE6SRC_Msk |
| #define | HRTIM_EECR2_EE6SRC_0 (0x1UL << HRTIM_EECR2_EE6SRC_Pos) |
| #define | HRTIM_EECR2_EE6SRC_1 (0x2UL << HRTIM_EECR2_EE6SRC_Pos) |
| #define | HRTIM_EECR2_EE6POL_Pos (2U) |
| #define | HRTIM_EECR2_EE6POL_Msk (0x1UL << HRTIM_EECR2_EE6POL_Pos) |
| #define | HRTIM_EECR2_EE6POL HRTIM_EECR2_EE6POL_Msk |
| #define | HRTIM_EECR2_EE6SNS_Pos (3U) |
| #define | HRTIM_EECR2_EE6SNS_Msk (0x3UL << HRTIM_EECR2_EE6SNS_Pos) |
| #define | HRTIM_EECR2_EE6SNS HRTIM_EECR2_EE6SNS_Msk |
| #define | HRTIM_EECR2_EE6SNS_0 (0x1UL << HRTIM_EECR2_EE6SNS_Pos) |
| #define | HRTIM_EECR2_EE6SNS_1 (0x2UL << HRTIM_EECR2_EE6SNS_Pos) |
| #define | HRTIM_EECR2_EE7SRC_Pos (6U) |
| #define | HRTIM_EECR2_EE7SRC_Msk (0x3UL << HRTIM_EECR2_EE7SRC_Pos) |
| #define | HRTIM_EECR2_EE7SRC HRTIM_EECR2_EE7SRC_Msk |
| #define | HRTIM_EECR2_EE7SRC_0 (0x1UL << HRTIM_EECR2_EE7SRC_Pos) |
| #define | HRTIM_EECR2_EE7SRC_1 (0x2UL << HRTIM_EECR2_EE7SRC_Pos) |
| #define | HRTIM_EECR2_EE7POL_Pos (8U) |
| #define | HRTIM_EECR2_EE7POL_Msk (0x1UL << HRTIM_EECR2_EE7POL_Pos) |
| #define | HRTIM_EECR2_EE7POL HRTIM_EECR2_EE7POL_Msk |
| #define | HRTIM_EECR2_EE7SNS_Pos (9U) |
| #define | HRTIM_EECR2_EE7SNS_Msk (0x3UL << HRTIM_EECR2_EE7SNS_Pos) |
| #define | HRTIM_EECR2_EE7SNS HRTIM_EECR2_EE7SNS_Msk |
| #define | HRTIM_EECR2_EE7SNS_0 (0x1UL << HRTIM_EECR2_EE7SNS_Pos) |
| #define | HRTIM_EECR2_EE7SNS_1 (0x2UL << HRTIM_EECR2_EE7SNS_Pos) |
| #define | HRTIM_EECR2_EE8SRC_Pos (12U) |
| #define | HRTIM_EECR2_EE8SRC_Msk (0x3UL << HRTIM_EECR2_EE8SRC_Pos) |
| #define | HRTIM_EECR2_EE8SRC HRTIM_EECR2_EE8SRC_Msk |
| #define | HRTIM_EECR2_EE8SRC_0 (0x1UL << HRTIM_EECR2_EE8SRC_Pos) |
| #define | HRTIM_EECR2_EE8SRC_1 (0x2UL << HRTIM_EECR2_EE8SRC_Pos) |
| #define | HRTIM_EECR2_EE8POL_Pos (14U) |
| #define | HRTIM_EECR2_EE8POL_Msk (0x1UL << HRTIM_EECR2_EE8POL_Pos) |
| #define | HRTIM_EECR2_EE8POL HRTIM_EECR2_EE8POL_Msk |
| #define | HRTIM_EECR2_EE8SNS_Pos (15U) |
| #define | HRTIM_EECR2_EE8SNS_Msk (0x3UL << HRTIM_EECR2_EE8SNS_Pos) |
| #define | HRTIM_EECR2_EE8SNS HRTIM_EECR2_EE8SNS_Msk |
| #define | HRTIM_EECR2_EE8SNS_0 (0x1UL << HRTIM_EECR2_EE8SNS_Pos) |
| #define | HRTIM_EECR2_EE8SNS_1 (0x2UL << HRTIM_EECR2_EE8SNS_Pos) |
| #define | HRTIM_EECR2_EE9SRC_Pos (18U) |
| #define | HRTIM_EECR2_EE9SRC_Msk (0x3UL << HRTIM_EECR2_EE9SRC_Pos) |
| #define | HRTIM_EECR2_EE9SRC HRTIM_EECR2_EE9SRC_Msk |
| #define | HRTIM_EECR2_EE9SRC_0 (0x1UL << HRTIM_EECR2_EE9SRC_Pos) |
| #define | HRTIM_EECR2_EE9SRC_1 (0x2UL << HRTIM_EECR2_EE9SRC_Pos) |
| #define | HRTIM_EECR2_EE9POL_Pos (20U) |
| #define | HRTIM_EECR2_EE9POL_Msk (0x1UL << HRTIM_EECR2_EE9POL_Pos) |
| #define | HRTIM_EECR2_EE9POL HRTIM_EECR2_EE9POL_Msk |
| #define | HRTIM_EECR2_EE9SNS_Pos (21U) |
| #define | HRTIM_EECR2_EE9SNS_Msk (0x3UL << HRTIM_EECR2_EE9SNS_Pos) |
| #define | HRTIM_EECR2_EE9SNS HRTIM_EECR2_EE9SNS_Msk |
| #define | HRTIM_EECR2_EE9SNS_0 (0x1UL << HRTIM_EECR2_EE9SNS_Pos) |
| #define | HRTIM_EECR2_EE9SNS_1 (0x2UL << HRTIM_EECR2_EE9SNS_Pos) |
| #define | HRTIM_EECR2_EE10SRC_Pos (24U) |
| #define | HRTIM_EECR2_EE10SRC_Msk (0x3UL << HRTIM_EECR2_EE10SRC_Pos) |
| #define | HRTIM_EECR2_EE10SRC HRTIM_EECR2_EE10SRC_Msk |
| #define | HRTIM_EECR2_EE10SRC_0 (0x1UL << HRTIM_EECR2_EE10SRC_Pos) |
| #define | HRTIM_EECR2_EE10SRC_1 (0x2UL << HRTIM_EECR2_EE10SRC_Pos) |
| #define | HRTIM_EECR2_EE10POL_Pos (26U) |
| #define | HRTIM_EECR2_EE10POL_Msk (0x1UL << HRTIM_EECR2_EE10POL_Pos) |
| #define | HRTIM_EECR2_EE10POL HRTIM_EECR2_EE10POL_Msk |
| #define | HRTIM_EECR2_EE10SNS_Pos (27U) |
| #define | HRTIM_EECR2_EE10SNS_Msk (0x3UL << HRTIM_EECR2_EE10SNS_Pos) |
| #define | HRTIM_EECR2_EE10SNS HRTIM_EECR2_EE10SNS_Msk |
| #define | HRTIM_EECR2_EE10SNS_0 (0x1UL << HRTIM_EECR2_EE10SNS_Pos) |
| #define | HRTIM_EECR2_EE10SNS_1 (0x2UL << HRTIM_EECR2_EE10SNS_Pos) |
| #define | HRTIM_EECR3_EE6F_Pos (0U) |
| #define | HRTIM_EECR3_EE6F_Msk (0xFUL << HRTIM_EECR3_EE6F_Pos) |
| #define | HRTIM_EECR3_EE6F HRTIM_EECR3_EE6F_Msk |
| #define | HRTIM_EECR3_EE6F_0 (0x1UL << HRTIM_EECR3_EE6F_Pos) |
| #define | HRTIM_EECR3_EE6F_1 (0x2UL << HRTIM_EECR3_EE6F_Pos) |
| #define | HRTIM_EECR3_EE6F_2 (0x4UL << HRTIM_EECR3_EE6F_Pos) |
| #define | HRTIM_EECR3_EE6F_3 (0x8UL << HRTIM_EECR3_EE6F_Pos) |
| #define | HRTIM_EECR3_EE7F_Pos (6U) |
| #define | HRTIM_EECR3_EE7F_Msk (0xFUL << HRTIM_EECR3_EE7F_Pos) |
| #define | HRTIM_EECR3_EE7F HRTIM_EECR3_EE7F_Msk |
| #define | HRTIM_EECR3_EE7F_0 (0x1UL << HRTIM_EECR3_EE7F_Pos) |
| #define | HRTIM_EECR3_EE7F_1 (0x2UL << HRTIM_EECR3_EE7F_Pos) |
| #define | HRTIM_EECR3_EE7F_2 (0x4UL << HRTIM_EECR3_EE7F_Pos) |
| #define | HRTIM_EECR3_EE7F_3 (0x8UL << HRTIM_EECR3_EE7F_Pos) |
| #define | HRTIM_EECR3_EE8F_Pos (12U) |
| #define | HRTIM_EECR3_EE8F_Msk (0xFUL << HRTIM_EECR3_EE8F_Pos) |
| #define | HRTIM_EECR3_EE8F HRTIM_EECR3_EE8F_Msk |
| #define | HRTIM_EECR3_EE8F_0 (0x1UL << HRTIM_EECR3_EE8F_Pos) |
| #define | HRTIM_EECR3_EE8F_1 (0x2UL << HRTIM_EECR3_EE8F_Pos) |
| #define | HRTIM_EECR3_EE8F_2 (0x4UL << HRTIM_EECR3_EE8F_Pos) |
| #define | HRTIM_EECR3_EE8F_3 (0x8UL << HRTIM_EECR3_EE8F_Pos) |
| #define | HRTIM_EECR3_EE9F_Pos (18U) |
| #define | HRTIM_EECR3_EE9F_Msk (0xFUL << HRTIM_EECR3_EE9F_Pos) |
| #define | HRTIM_EECR3_EE9F HRTIM_EECR3_EE9F_Msk |
| #define | HRTIM_EECR3_EE9F_0 (0x1UL << HRTIM_EECR3_EE9F_Pos) |
| #define | HRTIM_EECR3_EE9F_1 (0x2UL << HRTIM_EECR3_EE9F_Pos) |
| #define | HRTIM_EECR3_EE9F_2 (0x4UL << HRTIM_EECR3_EE9F_Pos) |
| #define | HRTIM_EECR3_EE9F_3 (0x8UL << HRTIM_EECR3_EE9F_Pos) |
| #define | HRTIM_EECR3_EE10F_Pos (24U) |
| #define | HRTIM_EECR3_EE10F_Msk (0xFUL << HRTIM_EECR3_EE10F_Pos) |
| #define | HRTIM_EECR3_EE10F HRTIM_EECR3_EE10F_Msk |
| #define | HRTIM_EECR3_EE10F_0 (0x1UL << HRTIM_EECR3_EE10F_Pos) |
| #define | HRTIM_EECR3_EE10F_1 (0x2UL << HRTIM_EECR3_EE10F_Pos) |
| #define | HRTIM_EECR3_EE10F_2 (0x4UL << HRTIM_EECR3_EE10F_Pos) |
| #define | HRTIM_EECR3_EE10F_3 (0x8UL << HRTIM_EECR3_EE10F_Pos) |
| #define | HRTIM_EECR3_EEVSD_Pos (30U) |
| #define | HRTIM_EECR3_EEVSD_Msk (0x3UL << HRTIM_EECR3_EEVSD_Pos) |
| #define | HRTIM_EECR3_EEVSD HRTIM_EECR3_EEVSD_Msk |
| #define | HRTIM_EECR3_EEVSD_0 (0x1UL << HRTIM_EECR3_EEVSD_Pos) |
| #define | HRTIM_EECR3_EEVSD_1 (0x2UL << HRTIM_EECR3_EEVSD_Pos) |
| #define | HRTIM_ADC1R_AD1MC1_Pos (0U) |
| #define | HRTIM_ADC1R_AD1MC1_Msk (0x1UL << HRTIM_ADC1R_AD1MC1_Pos) |
| #define | HRTIM_ADC1R_AD1MC1 HRTIM_ADC1R_AD1MC1_Msk |
| #define | HRTIM_ADC1R_AD1MC2_Pos (1U) |
| #define | HRTIM_ADC1R_AD1MC2_Msk (0x1UL << HRTIM_ADC1R_AD1MC2_Pos) |
| #define | HRTIM_ADC1R_AD1MC2 HRTIM_ADC1R_AD1MC2_Msk |
| #define | HRTIM_ADC1R_AD1MC3_Pos (2U) |
| #define | HRTIM_ADC1R_AD1MC3_Msk (0x1UL << HRTIM_ADC1R_AD1MC3_Pos) |
| #define | HRTIM_ADC1R_AD1MC3 HRTIM_ADC1R_AD1MC3_Msk |
| #define | HRTIM_ADC1R_AD1MC4_Pos (3U) |
| #define | HRTIM_ADC1R_AD1MC4_Msk (0x1UL << HRTIM_ADC1R_AD1MC4_Pos) |
| #define | HRTIM_ADC1R_AD1MC4 HRTIM_ADC1R_AD1MC4_Msk |
| #define | HRTIM_ADC1R_AD1MPER_Pos (4U) |
| #define | HRTIM_ADC1R_AD1MPER_Msk (0x1UL << HRTIM_ADC1R_AD1MPER_Pos) |
| #define | HRTIM_ADC1R_AD1MPER HRTIM_ADC1R_AD1MPER_Msk |
| #define | HRTIM_ADC1R_AD1EEV1_Pos (5U) |
| #define | HRTIM_ADC1R_AD1EEV1_Msk (0x1UL << HRTIM_ADC1R_AD1EEV1_Pos) |
| #define | HRTIM_ADC1R_AD1EEV1 HRTIM_ADC1R_AD1EEV1_Msk |
| #define | HRTIM_ADC1R_AD1EEV2_Pos (6U) |
| #define | HRTIM_ADC1R_AD1EEV2_Msk (0x1UL << HRTIM_ADC1R_AD1EEV2_Pos) |
| #define | HRTIM_ADC1R_AD1EEV2 HRTIM_ADC1R_AD1EEV2_Msk |
| #define | HRTIM_ADC1R_AD1EEV3_Pos (7U) |
| #define | HRTIM_ADC1R_AD1EEV3_Msk (0x1UL << HRTIM_ADC1R_AD1EEV3_Pos) |
| #define | HRTIM_ADC1R_AD1EEV3 HRTIM_ADC1R_AD1EEV3_Msk |
| #define | HRTIM_ADC1R_AD1EEV4_Pos (8U) |
| #define | HRTIM_ADC1R_AD1EEV4_Msk (0x1UL << HRTIM_ADC1R_AD1EEV4_Pos) |
| #define | HRTIM_ADC1R_AD1EEV4 HRTIM_ADC1R_AD1EEV4_Msk |
| #define | HRTIM_ADC1R_AD1EEV5_Pos (9U) |
| #define | HRTIM_ADC1R_AD1EEV5_Msk (0x1UL << HRTIM_ADC1R_AD1EEV5_Pos) |
| #define | HRTIM_ADC1R_AD1EEV5 HRTIM_ADC1R_AD1EEV5_Msk |
| #define | HRTIM_ADC1R_AD1TAC2_Pos (10U) |
| #define | HRTIM_ADC1R_AD1TAC2_Msk (0x1UL << HRTIM_ADC1R_AD1TAC2_Pos) |
| #define | HRTIM_ADC1R_AD1TAC2 HRTIM_ADC1R_AD1TAC2_Msk |
| #define | HRTIM_ADC1R_AD1TAC3_Pos (11U) |
| #define | HRTIM_ADC1R_AD1TAC3_Msk (0x1UL << HRTIM_ADC1R_AD1TAC3_Pos) |
| #define | HRTIM_ADC1R_AD1TAC3 HRTIM_ADC1R_AD1TAC3_Msk |
| #define | HRTIM_ADC1R_AD1TAC4_Pos (12U) |
| #define | HRTIM_ADC1R_AD1TAC4_Msk (0x1UL << HRTIM_ADC1R_AD1TAC4_Pos) |
| #define | HRTIM_ADC1R_AD1TAC4 HRTIM_ADC1R_AD1TAC4_Msk |
| #define | HRTIM_ADC1R_AD1TAPER_Pos (13U) |
| #define | HRTIM_ADC1R_AD1TAPER_Msk (0x1UL << HRTIM_ADC1R_AD1TAPER_Pos) |
| #define | HRTIM_ADC1R_AD1TAPER HRTIM_ADC1R_AD1TAPER_Msk |
| #define | HRTIM_ADC1R_AD1TARST_Pos (14U) |
| #define | HRTIM_ADC1R_AD1TARST_Msk (0x1UL << HRTIM_ADC1R_AD1TARST_Pos) |
| #define | HRTIM_ADC1R_AD1TARST HRTIM_ADC1R_AD1TARST_Msk |
| #define | HRTIM_ADC1R_AD1TBC2_Pos (15U) |
| #define | HRTIM_ADC1R_AD1TBC2_Msk (0x1UL << HRTIM_ADC1R_AD1TBC2_Pos) |
| #define | HRTIM_ADC1R_AD1TBC2 HRTIM_ADC1R_AD1TBC2_Msk |
| #define | HRTIM_ADC1R_AD1TBC3_Pos (16U) |
| #define | HRTIM_ADC1R_AD1TBC3_Msk (0x1UL << HRTIM_ADC1R_AD1TBC3_Pos) |
| #define | HRTIM_ADC1R_AD1TBC3 HRTIM_ADC1R_AD1TBC3_Msk |
| #define | HRTIM_ADC1R_AD1TBC4_Pos (17U) |
| #define | HRTIM_ADC1R_AD1TBC4_Msk (0x1UL << HRTIM_ADC1R_AD1TBC4_Pos) |
| #define | HRTIM_ADC1R_AD1TBC4 HRTIM_ADC1R_AD1TBC4_Msk |
| #define | HRTIM_ADC1R_AD1TBPER_Pos (18U) |
| #define | HRTIM_ADC1R_AD1TBPER_Msk (0x1UL << HRTIM_ADC1R_AD1TBPER_Pos) |
| #define | HRTIM_ADC1R_AD1TBPER HRTIM_ADC1R_AD1TBPER_Msk |
| #define | HRTIM_ADC1R_AD1TBRST_Pos (19U) |
| #define | HRTIM_ADC1R_AD1TBRST_Msk (0x1UL << HRTIM_ADC1R_AD1TBRST_Pos) |
| #define | HRTIM_ADC1R_AD1TBRST HRTIM_ADC1R_AD1TBRST_Msk |
| #define | HRTIM_ADC1R_AD1TCC2_Pos (20U) |
| #define | HRTIM_ADC1R_AD1TCC2_Msk (0x1UL << HRTIM_ADC1R_AD1TCC2_Pos) |
| #define | HRTIM_ADC1R_AD1TCC2 HRTIM_ADC1R_AD1TCC2_Msk |
| #define | HRTIM_ADC1R_AD1TCC3_Pos (21U) |
| #define | HRTIM_ADC1R_AD1TCC3_Msk (0x1UL << HRTIM_ADC1R_AD1TCC3_Pos) |
| #define | HRTIM_ADC1R_AD1TCC3 HRTIM_ADC1R_AD1TCC3_Msk |
| #define | HRTIM_ADC1R_AD1TCC4_Pos (22U) |
| #define | HRTIM_ADC1R_AD1TCC4_Msk (0x1UL << HRTIM_ADC1R_AD1TCC4_Pos) |
| #define | HRTIM_ADC1R_AD1TCC4 HRTIM_ADC1R_AD1TCC4_Msk |
| #define | HRTIM_ADC1R_AD1TCPER_Pos (23U) |
| #define | HRTIM_ADC1R_AD1TCPER_Msk (0x1UL << HRTIM_ADC1R_AD1TCPER_Pos) |
| #define | HRTIM_ADC1R_AD1TCPER HRTIM_ADC1R_AD1TCPER_Msk |
| #define | HRTIM_ADC1R_AD1TDC2_Pos (24U) |
| #define | HRTIM_ADC1R_AD1TDC2_Msk (0x1UL << HRTIM_ADC1R_AD1TDC2_Pos) |
| #define | HRTIM_ADC1R_AD1TDC2 HRTIM_ADC1R_AD1TDC2_Msk |
| #define | HRTIM_ADC1R_AD1TDC3_Pos (25U) |
| #define | HRTIM_ADC1R_AD1TDC3_Msk (0x1UL << HRTIM_ADC1R_AD1TDC3_Pos) |
| #define | HRTIM_ADC1R_AD1TDC3 HRTIM_ADC1R_AD1TDC3_Msk |
| #define | HRTIM_ADC1R_AD1TDC4_Pos (26U) |
| #define | HRTIM_ADC1R_AD1TDC4_Msk (0x1UL << HRTIM_ADC1R_AD1TDC4_Pos) |
| #define | HRTIM_ADC1R_AD1TDC4 HRTIM_ADC1R_AD1TDC4_Msk |
| #define | HRTIM_ADC1R_AD1TDPER_Pos (27U) |
| #define | HRTIM_ADC1R_AD1TDPER_Msk (0x1UL << HRTIM_ADC1R_AD1TDPER_Pos) |
| #define | HRTIM_ADC1R_AD1TDPER HRTIM_ADC1R_AD1TDPER_Msk |
| #define | HRTIM_ADC1R_AD1TEC2_Pos (28U) |
| #define | HRTIM_ADC1R_AD1TEC2_Msk (0x1UL << HRTIM_ADC1R_AD1TEC2_Pos) |
| #define | HRTIM_ADC1R_AD1TEC2 HRTIM_ADC1R_AD1TEC2_Msk |
| #define | HRTIM_ADC1R_AD1TEC3_Pos (29U) |
| #define | HRTIM_ADC1R_AD1TEC3_Msk (0x1UL << HRTIM_ADC1R_AD1TEC3_Pos) |
| #define | HRTIM_ADC1R_AD1TEC3 HRTIM_ADC1R_AD1TEC3_Msk |
| #define | HRTIM_ADC1R_AD1TEC4_Pos (30U) |
| #define | HRTIM_ADC1R_AD1TEC4_Msk (0x1UL << HRTIM_ADC1R_AD1TEC4_Pos) |
| #define | HRTIM_ADC1R_AD1TEC4 HRTIM_ADC1R_AD1TEC4_Msk |
| #define | HRTIM_ADC1R_AD1TEPER_Pos (31U) |
| #define | HRTIM_ADC1R_AD1TEPER_Msk (0x1UL << HRTIM_ADC1R_AD1TEPER_Pos) |
| #define | HRTIM_ADC1R_AD1TEPER HRTIM_ADC1R_AD1TEPER_Msk |
| #define | HRTIM_ADC2R_AD2MC1_Pos (0U) |
| #define | HRTIM_ADC2R_AD2MC1_Msk (0x1UL << HRTIM_ADC2R_AD2MC1_Pos) |
| #define | HRTIM_ADC2R_AD2MC1 HRTIM_ADC2R_AD2MC1_Msk |
| #define | HRTIM_ADC2R_AD2MC2_Pos (1U) |
| #define | HRTIM_ADC2R_AD2MC2_Msk (0x1UL << HRTIM_ADC2R_AD2MC2_Pos) |
| #define | HRTIM_ADC2R_AD2MC2 HRTIM_ADC2R_AD2MC2_Msk |
| #define | HRTIM_ADC2R_AD2MC3_Pos (2U) |
| #define | HRTIM_ADC2R_AD2MC3_Msk (0x1UL << HRTIM_ADC2R_AD2MC3_Pos) |
| #define | HRTIM_ADC2R_AD2MC3 HRTIM_ADC2R_AD2MC3_Msk |
| #define | HRTIM_ADC2R_AD2MC4_Pos (3U) |
| #define | HRTIM_ADC2R_AD2MC4_Msk (0x1UL << HRTIM_ADC2R_AD2MC4_Pos) |
| #define | HRTIM_ADC2R_AD2MC4 HRTIM_ADC2R_AD2MC4_Msk |
| #define | HRTIM_ADC2R_AD2MPER_Pos (4U) |
| #define | HRTIM_ADC2R_AD2MPER_Msk (0x1UL << HRTIM_ADC2R_AD2MPER_Pos) |
| #define | HRTIM_ADC2R_AD2MPER HRTIM_ADC2R_AD2MPER_Msk |
| #define | HRTIM_ADC2R_AD2EEV6_Pos (5U) |
| #define | HRTIM_ADC2R_AD2EEV6_Msk (0x1UL << HRTIM_ADC2R_AD2EEV6_Pos) |
| #define | HRTIM_ADC2R_AD2EEV6 HRTIM_ADC2R_AD2EEV6_Msk |
| #define | HRTIM_ADC2R_AD2EEV7_Pos (6U) |
| #define | HRTIM_ADC2R_AD2EEV7_Msk (0x1UL << HRTIM_ADC2R_AD2EEV7_Pos) |
| #define | HRTIM_ADC2R_AD2EEV7 HRTIM_ADC2R_AD2EEV7_Msk |
| #define | HRTIM_ADC2R_AD2EEV8_Pos (7U) |
| #define | HRTIM_ADC2R_AD2EEV8_Msk (0x1UL << HRTIM_ADC2R_AD2EEV8_Pos) |
| #define | HRTIM_ADC2R_AD2EEV8 HRTIM_ADC2R_AD2EEV8_Msk |
| #define | HRTIM_ADC2R_AD2EEV9_Pos (8U) |
| #define | HRTIM_ADC2R_AD2EEV9_Msk (0x1UL << HRTIM_ADC2R_AD2EEV9_Pos) |
| #define | HRTIM_ADC2R_AD2EEV9 HRTIM_ADC2R_AD2EEV9_Msk |
| #define | HRTIM_ADC2R_AD2EEV10_Pos (9U) |
| #define | HRTIM_ADC2R_AD2EEV10_Msk (0x1UL << HRTIM_ADC2R_AD2EEV10_Pos) |
| #define | HRTIM_ADC2R_AD2EEV10 HRTIM_ADC2R_AD2EEV10_Msk |
| #define | HRTIM_ADC2R_AD2TAC2_Pos (10U) |
| #define | HRTIM_ADC2R_AD2TAC2_Msk (0x1UL << HRTIM_ADC2R_AD2TAC2_Pos) |
| #define | HRTIM_ADC2R_AD2TAC2 HRTIM_ADC2R_AD2TAC2_Msk |
| #define | HRTIM_ADC2R_AD2TAC3_Pos (11U) |
| #define | HRTIM_ADC2R_AD2TAC3_Msk (0x1UL << HRTIM_ADC2R_AD2TAC3_Pos) |
| #define | HRTIM_ADC2R_AD2TAC3 HRTIM_ADC2R_AD2TAC3_Msk |
| #define | HRTIM_ADC2R_AD2TAC4_Pos (12U) |
| #define | HRTIM_ADC2R_AD2TAC4_Msk (0x1UL << HRTIM_ADC2R_AD2TAC4_Pos) |
| #define | HRTIM_ADC2R_AD2TAC4 HRTIM_ADC2R_AD2TAC4_Msk |
| #define | HRTIM_ADC2R_AD2TAPER_Pos (13U) |
| #define | HRTIM_ADC2R_AD2TAPER_Msk (0x1UL << HRTIM_ADC2R_AD2TAPER_Pos) |
| #define | HRTIM_ADC2R_AD2TAPER HRTIM_ADC2R_AD2TAPER_Msk |
| #define | HRTIM_ADC2R_AD2TBC2_Pos (14U) |
| #define | HRTIM_ADC2R_AD2TBC2_Msk (0x1UL << HRTIM_ADC2R_AD2TBC2_Pos) |
| #define | HRTIM_ADC2R_AD2TBC2 HRTIM_ADC2R_AD2TBC2_Msk |
| #define | HRTIM_ADC2R_AD2TBC3_Pos (15U) |
| #define | HRTIM_ADC2R_AD2TBC3_Msk (0x1UL << HRTIM_ADC2R_AD2TBC3_Pos) |
| #define | HRTIM_ADC2R_AD2TBC3 HRTIM_ADC2R_AD2TBC3_Msk |
| #define | HRTIM_ADC2R_AD2TBC4_Pos (16U) |
| #define | HRTIM_ADC2R_AD2TBC4_Msk (0x1UL << HRTIM_ADC2R_AD2TBC4_Pos) |
| #define | HRTIM_ADC2R_AD2TBC4 HRTIM_ADC2R_AD2TBC4_Msk |
| #define | HRTIM_ADC2R_AD2TBPER_Pos (17U) |
| #define | HRTIM_ADC2R_AD2TBPER_Msk (0x1UL << HRTIM_ADC2R_AD2TBPER_Pos) |
| #define | HRTIM_ADC2R_AD2TBPER HRTIM_ADC2R_AD2TBPER_Msk |
| #define | HRTIM_ADC2R_AD2TCC2_Pos (18U) |
| #define | HRTIM_ADC2R_AD2TCC2_Msk (0x1UL << HRTIM_ADC2R_AD2TCC2_Pos) |
| #define | HRTIM_ADC2R_AD2TCC2 HRTIM_ADC2R_AD2TCC2_Msk |
| #define | HRTIM_ADC2R_AD2TCC3_Pos (19U) |
| #define | HRTIM_ADC2R_AD2TCC3_Msk (0x1UL << HRTIM_ADC2R_AD2TCC3_Pos) |
| #define | HRTIM_ADC2R_AD2TCC3 HRTIM_ADC2R_AD2TCC3_Msk |
| #define | HRTIM_ADC2R_AD2TCC4_Pos (20U) |
| #define | HRTIM_ADC2R_AD2TCC4_Msk (0x1UL << HRTIM_ADC2R_AD2TCC4_Pos) |
| #define | HRTIM_ADC2R_AD2TCC4 HRTIM_ADC2R_AD2TCC4_Msk |
| #define | HRTIM_ADC2R_AD2TCPER_Pos (21U) |
| #define | HRTIM_ADC2R_AD2TCPER_Msk (0x1UL << HRTIM_ADC2R_AD2TCPER_Pos) |
| #define | HRTIM_ADC2R_AD2TCPER HRTIM_ADC2R_AD2TCPER_Msk |
| #define | HRTIM_ADC2R_AD2TCRST_Pos (22U) |
| #define | HRTIM_ADC2R_AD2TCRST_Msk (0x1UL << HRTIM_ADC2R_AD2TCRST_Pos) |
| #define | HRTIM_ADC2R_AD2TCRST HRTIM_ADC2R_AD2TCRST_Msk |
| #define | HRTIM_ADC2R_AD2TDC2_Pos (23U) |
| #define | HRTIM_ADC2R_AD2TDC2_Msk (0x1UL << HRTIM_ADC2R_AD2TDC2_Pos) |
| #define | HRTIM_ADC2R_AD2TDC2 HRTIM_ADC2R_AD2TDC2_Msk |
| #define | HRTIM_ADC2R_AD2TDC3_Pos (24U) |
| #define | HRTIM_ADC2R_AD2TDC3_Msk (0x1UL << HRTIM_ADC2R_AD2TDC3_Pos) |
| #define | HRTIM_ADC2R_AD2TDC3 HRTIM_ADC2R_AD2TDC3_Msk |
| #define | HRTIM_ADC2R_AD2TDC4_Pos (25U) |
| #define | HRTIM_ADC2R_AD2TDC4_Msk (0x1UL << HRTIM_ADC2R_AD2TDC4_Pos) |
| #define | HRTIM_ADC2R_AD2TDC4 HRTIM_ADC2R_AD2TDC4_Msk |
| #define | HRTIM_ADC2R_AD2TDPER_Pos (26U) |
| #define | HRTIM_ADC2R_AD2TDPER_Msk (0x1UL << HRTIM_ADC2R_AD2TDPER_Pos) |
| #define | HRTIM_ADC2R_AD2TDPER HRTIM_ADC2R_AD2TDPER_Msk |
| #define | HRTIM_ADC2R_AD2TDRST_Pos (27U) |
| #define | HRTIM_ADC2R_AD2TDRST_Msk (0x1UL << HRTIM_ADC2R_AD2TDRST_Pos) |
| #define | HRTIM_ADC2R_AD2TDRST HRTIM_ADC2R_AD2TDRST_Msk |
| #define | HRTIM_ADC2R_AD2TEC2_Pos (28U) |
| #define | HRTIM_ADC2R_AD2TEC2_Msk (0x1UL << HRTIM_ADC2R_AD2TEC2_Pos) |
| #define | HRTIM_ADC2R_AD2TEC2 HRTIM_ADC2R_AD2TEC2_Msk |
| #define | HRTIM_ADC2R_AD2TEC3_Pos (29U) |
| #define | HRTIM_ADC2R_AD2TEC3_Msk (0x1UL << HRTIM_ADC2R_AD2TEC3_Pos) |
| #define | HRTIM_ADC2R_AD2TEC3 HRTIM_ADC2R_AD2TEC3_Msk |
| #define | HRTIM_ADC2R_AD2TEC4_Pos (30U) |
| #define | HRTIM_ADC2R_AD2TEC4_Msk (0x1UL << HRTIM_ADC2R_AD2TEC4_Pos) |
| #define | HRTIM_ADC2R_AD2TEC4 HRTIM_ADC2R_AD2TEC4_Msk |
| #define | HRTIM_ADC2R_AD2TERST_Pos (31U) |
| #define | HRTIM_ADC2R_AD2TERST_Msk (0x1UL << HRTIM_ADC2R_AD2TERST_Pos) |
| #define | HRTIM_ADC2R_AD2TERST HRTIM_ADC2R_AD2TERST_Msk |
| #define | HRTIM_ADC3R_AD3MC1_Pos (0U) |
| #define | HRTIM_ADC3R_AD3MC1_Msk (0x1UL << HRTIM_ADC3R_AD3MC1_Pos) |
| #define | HRTIM_ADC3R_AD3MC1 HRTIM_ADC3R_AD3MC1_Msk |
| #define | HRTIM_ADC3R_AD3MC2_Pos (1U) |
| #define | HRTIM_ADC3R_AD3MC2_Msk (0x1UL << HRTIM_ADC3R_AD3MC2_Pos) |
| #define | HRTIM_ADC3R_AD3MC2 HRTIM_ADC3R_AD3MC2_Msk |
| #define | HRTIM_ADC3R_AD3MC3_Pos (2U) |
| #define | HRTIM_ADC3R_AD3MC3_Msk (0x1UL << HRTIM_ADC3R_AD3MC3_Pos) |
| #define | HRTIM_ADC3R_AD3MC3 HRTIM_ADC3R_AD3MC3_Msk |
| #define | HRTIM_ADC3R_AD3MC4_Pos (3U) |
| #define | HRTIM_ADC3R_AD3MC4_Msk (0x1UL << HRTIM_ADC3R_AD3MC4_Pos) |
| #define | HRTIM_ADC3R_AD3MC4 HRTIM_ADC3R_AD3MC4_Msk |
| #define | HRTIM_ADC3R_AD3MPER_Pos (4U) |
| #define | HRTIM_ADC3R_AD3MPER_Msk (0x1UL << HRTIM_ADC3R_AD3MPER_Pos) |
| #define | HRTIM_ADC3R_AD3MPER HRTIM_ADC3R_AD3MPER_Msk |
| #define | HRTIM_ADC3R_AD3EEV1_Pos (5U) |
| #define | HRTIM_ADC3R_AD3EEV1_Msk (0x1UL << HRTIM_ADC3R_AD3EEV1_Pos) |
| #define | HRTIM_ADC3R_AD3EEV1 HRTIM_ADC3R_AD3EEV1_Msk |
| #define | HRTIM_ADC3R_AD3EEV2_Pos (6U) |
| #define | HRTIM_ADC3R_AD3EEV2_Msk (0x1UL << HRTIM_ADC3R_AD3EEV2_Pos) |
| #define | HRTIM_ADC3R_AD3EEV2 HRTIM_ADC3R_AD3EEV2_Msk |
| #define | HRTIM_ADC3R_AD3EEV3_Pos (7U) |
| #define | HRTIM_ADC3R_AD3EEV3_Msk (0x1UL << HRTIM_ADC3R_AD3EEV3_Pos) |
| #define | HRTIM_ADC3R_AD3EEV3 HRTIM_ADC3R_AD3EEV3_Msk |
| #define | HRTIM_ADC3R_AD3EEV4_Pos (8U) |
| #define | HRTIM_ADC3R_AD3EEV4_Msk (0x1UL << HRTIM_ADC3R_AD3EEV4_Pos) |
| #define | HRTIM_ADC3R_AD3EEV4 HRTIM_ADC3R_AD3EEV4_Msk |
| #define | HRTIM_ADC3R_AD3EEV5_Pos (9U) |
| #define | HRTIM_ADC3R_AD3EEV5_Msk (0x1UL << HRTIM_ADC3R_AD3EEV5_Pos) |
| #define | HRTIM_ADC3R_AD3EEV5 HRTIM_ADC3R_AD3EEV5_Msk |
| #define | HRTIM_ADC3R_AD3TAC2_Pos (10U) |
| #define | HRTIM_ADC3R_AD3TAC2_Msk (0x1UL << HRTIM_ADC3R_AD3TAC2_Pos) |
| #define | HRTIM_ADC3R_AD3TAC2 HRTIM_ADC3R_AD3TAC2_Msk |
| #define | HRTIM_ADC3R_AD3TAC3_Pos (11U) |
| #define | HRTIM_ADC3R_AD3TAC3_Msk (0x1UL << HRTIM_ADC3R_AD3TAC3_Pos) |
| #define | HRTIM_ADC3R_AD3TAC3 HRTIM_ADC3R_AD3TAC3_Msk |
| #define | HRTIM_ADC3R_AD3TAC4_Pos (12U) |
| #define | HRTIM_ADC3R_AD3TAC4_Msk (0x1UL << HRTIM_ADC3R_AD3TAC4_Pos) |
| #define | HRTIM_ADC3R_AD3TAC4 HRTIM_ADC3R_AD3TAC4_Msk |
| #define | HRTIM_ADC3R_AD3TAPER_Pos (13U) |
| #define | HRTIM_ADC3R_AD3TAPER_Msk (0x1UL << HRTIM_ADC3R_AD3TAPER_Pos) |
| #define | HRTIM_ADC3R_AD3TAPER HRTIM_ADC3R_AD3TAPER_Msk |
| #define | HRTIM_ADC3R_AD3TARST_Pos (14U) |
| #define | HRTIM_ADC3R_AD3TARST_Msk (0x1UL << HRTIM_ADC3R_AD3TARST_Pos) |
| #define | HRTIM_ADC3R_AD3TARST HRTIM_ADC3R_AD3TARST_Msk |
| #define | HRTIM_ADC3R_AD3TBC2_Pos (15U) |
| #define | HRTIM_ADC3R_AD3TBC2_Msk (0x1UL << HRTIM_ADC3R_AD3TBC2_Pos) |
| #define | HRTIM_ADC3R_AD3TBC2 HRTIM_ADC3R_AD3TBC2_Msk |
| #define | HRTIM_ADC3R_AD3TBC3_Pos (16U) |
| #define | HRTIM_ADC3R_AD3TBC3_Msk (0x1UL << HRTIM_ADC3R_AD3TBC3_Pos) |
| #define | HRTIM_ADC3R_AD3TBC3 HRTIM_ADC3R_AD3TBC3_Msk |
| #define | HRTIM_ADC3R_AD3TBC4_Pos (17U) |
| #define | HRTIM_ADC3R_AD3TBC4_Msk (0x1UL << HRTIM_ADC3R_AD3TBC4_Pos) |
| #define | HRTIM_ADC3R_AD3TBC4 HRTIM_ADC3R_AD3TBC4_Msk |
| #define | HRTIM_ADC3R_AD3TBPER_Pos (18U) |
| #define | HRTIM_ADC3R_AD3TBPER_Msk (0x1UL << HRTIM_ADC3R_AD3TBPER_Pos) |
| #define | HRTIM_ADC3R_AD3TBPER HRTIM_ADC3R_AD3TBPER_Msk |
| #define | HRTIM_ADC3R_AD3TBRST_Pos (19U) |
| #define | HRTIM_ADC3R_AD3TBRST_Msk (0x1UL << HRTIM_ADC3R_AD3TBRST_Pos) |
| #define | HRTIM_ADC3R_AD3TBRST HRTIM_ADC3R_AD3TBRST_Msk |
| #define | HRTIM_ADC3R_AD3TCC2_Pos (20U) |
| #define | HRTIM_ADC3R_AD3TCC2_Msk (0x1UL << HRTIM_ADC3R_AD3TCC2_Pos) |
| #define | HRTIM_ADC3R_AD3TCC2 HRTIM_ADC3R_AD3TCC2_Msk |
| #define | HRTIM_ADC3R_AD3TCC3_Pos (21U) |
| #define | HRTIM_ADC3R_AD3TCC3_Msk (0x1UL << HRTIM_ADC3R_AD3TCC3_Pos) |
| #define | HRTIM_ADC3R_AD3TCC3 HRTIM_ADC3R_AD3TCC3_Msk |
| #define | HRTIM_ADC3R_AD3TCC4_Pos (22U) |
| #define | HRTIM_ADC3R_AD3TCC4_Msk (0x1UL << HRTIM_ADC3R_AD3TCC4_Pos) |
| #define | HRTIM_ADC3R_AD3TCC4 HRTIM_ADC3R_AD3TCC4_Msk |
| #define | HRTIM_ADC3R_AD3TCPER_Pos (23U) |
| #define | HRTIM_ADC3R_AD3TCPER_Msk (0x1UL << HRTIM_ADC3R_AD3TCPER_Pos) |
| #define | HRTIM_ADC3R_AD3TCPER HRTIM_ADC3R_AD3TCPER_Msk |
| #define | HRTIM_ADC3R_AD3TDC2_Pos (24U) |
| #define | HRTIM_ADC3R_AD3TDC2_Msk (0x1UL << HRTIM_ADC3R_AD3TDC2_Pos) |
| #define | HRTIM_ADC3R_AD3TDC2 HRTIM_ADC3R_AD3TDC2_Msk |
| #define | HRTIM_ADC3R_AD3TDC3_Pos (25U) |
| #define | HRTIM_ADC3R_AD3TDC3_Msk (0x1UL << HRTIM_ADC3R_AD3TDC3_Pos) |
| #define | HRTIM_ADC3R_AD3TDC3 HRTIM_ADC3R_AD3TDC3_Msk |
| #define | HRTIM_ADC3R_AD3TDC4_Pos (26U) |
| #define | HRTIM_ADC3R_AD3TDC4_Msk (0x1UL << HRTIM_ADC3R_AD3TDC4_Pos) |
| #define | HRTIM_ADC3R_AD3TDC4 HRTIM_ADC3R_AD3TDC4_Msk |
| #define | HRTIM_ADC3R_AD3TDPER_Pos (27U) |
| #define | HRTIM_ADC3R_AD3TDPER_Msk (0x1UL << HRTIM_ADC3R_AD3TDPER_Pos) |
| #define | HRTIM_ADC3R_AD3TDPER HRTIM_ADC3R_AD3TDPER_Msk |
| #define | HRTIM_ADC3R_AD3TEC2_Pos (28U) |
| #define | HRTIM_ADC3R_AD3TEC2_Msk (0x1UL << HRTIM_ADC3R_AD3TEC2_Pos) |
| #define | HRTIM_ADC3R_AD3TEC2 HRTIM_ADC3R_AD3TEC2_Msk |
| #define | HRTIM_ADC3R_AD3TEC3_Pos (29U) |
| #define | HRTIM_ADC3R_AD3TEC3_Msk (0x1UL << HRTIM_ADC3R_AD3TEC3_Pos) |
| #define | HRTIM_ADC3R_AD3TEC3 HRTIM_ADC3R_AD3TEC3_Msk |
| #define | HRTIM_ADC3R_AD3TEC4_Pos (30U) |
| #define | HRTIM_ADC3R_AD3TEC4_Msk (0x1UL << HRTIM_ADC3R_AD3TEC4_Pos) |
| #define | HRTIM_ADC3R_AD3TEC4 HRTIM_ADC3R_AD3TEC4_Msk |
| #define | HRTIM_ADC3R_AD3TEPER_Pos (31U) |
| #define | HRTIM_ADC3R_AD3TEPER_Msk (0x1UL << HRTIM_ADC3R_AD3TEPER_Pos) |
| #define | HRTIM_ADC3R_AD3TEPER HRTIM_ADC3R_AD3TEPER_Msk |
| #define | HRTIM_ADC4R_AD4MC1_Pos (0U) |
| #define | HRTIM_ADC4R_AD4MC1_Msk (0x1UL << HRTIM_ADC4R_AD4MC1_Pos) |
| #define | HRTIM_ADC4R_AD4MC1 HRTIM_ADC4R_AD4MC1_Msk |
| #define | HRTIM_ADC4R_AD4MC2_Pos (1U) |
| #define | HRTIM_ADC4R_AD4MC2_Msk (0x1UL << HRTIM_ADC4R_AD4MC2_Pos) |
| #define | HRTIM_ADC4R_AD4MC2 HRTIM_ADC4R_AD4MC2_Msk |
| #define | HRTIM_ADC4R_AD4MC3_Pos (2U) |
| #define | HRTIM_ADC4R_AD4MC3_Msk (0x1UL << HRTIM_ADC4R_AD4MC3_Pos) |
| #define | HRTIM_ADC4R_AD4MC3 HRTIM_ADC4R_AD4MC3_Msk |
| #define | HRTIM_ADC4R_AD4MC4_Pos (3U) |
| #define | HRTIM_ADC4R_AD4MC4_Msk (0x1UL << HRTIM_ADC4R_AD4MC4_Pos) |
| #define | HRTIM_ADC4R_AD4MC4 HRTIM_ADC4R_AD4MC4_Msk |
| #define | HRTIM_ADC4R_AD4MPER_Pos (4U) |
| #define | HRTIM_ADC4R_AD4MPER_Msk (0x1UL << HRTIM_ADC4R_AD4MPER_Pos) |
| #define | HRTIM_ADC4R_AD4MPER HRTIM_ADC4R_AD4MPER_Msk |
| #define | HRTIM_ADC4R_AD4EEV6_Pos (5U) |
| #define | HRTIM_ADC4R_AD4EEV6_Msk (0x1UL << HRTIM_ADC4R_AD4EEV6_Pos) |
| #define | HRTIM_ADC4R_AD4EEV6 HRTIM_ADC4R_AD4EEV6_Msk |
| #define | HRTIM_ADC4R_AD4EEV7_Pos (6U) |
| #define | HRTIM_ADC4R_AD4EEV7_Msk (0x1UL << HRTIM_ADC4R_AD4EEV7_Pos) |
| #define | HRTIM_ADC4R_AD4EEV7 HRTIM_ADC4R_AD4EEV7_Msk |
| #define | HRTIM_ADC4R_AD4EEV8_Pos (7U) |
| #define | HRTIM_ADC4R_AD4EEV8_Msk (0x1UL << HRTIM_ADC4R_AD4EEV8_Pos) |
| #define | HRTIM_ADC4R_AD4EEV8 HRTIM_ADC4R_AD4EEV8_Msk |
| #define | HRTIM_ADC4R_AD4EEV9_Pos (8U) |
| #define | HRTIM_ADC4R_AD4EEV9_Msk (0x1UL << HRTIM_ADC4R_AD4EEV9_Pos) |
| #define | HRTIM_ADC4R_AD4EEV9 HRTIM_ADC4R_AD4EEV9_Msk |
| #define | HRTIM_ADC4R_AD4EEV10_Pos (9U) |
| #define | HRTIM_ADC4R_AD4EEV10_Msk (0x1UL << HRTIM_ADC4R_AD4EEV10_Pos) |
| #define | HRTIM_ADC4R_AD4EEV10 HRTIM_ADC4R_AD4EEV10_Msk |
| #define | HRTIM_ADC4R_AD4TAC2_Pos (10U) |
| #define | HRTIM_ADC4R_AD4TAC2_Msk (0x1UL << HRTIM_ADC4R_AD4TAC2_Pos) |
| #define | HRTIM_ADC4R_AD4TAC2 HRTIM_ADC4R_AD4TAC2_Msk |
| #define | HRTIM_ADC4R_AD4TAC3_Pos (11U) |
| #define | HRTIM_ADC4R_AD4TAC3_Msk (0x1UL << HRTIM_ADC4R_AD4TAC3_Pos) |
| #define | HRTIM_ADC4R_AD4TAC3 HRTIM_ADC4R_AD4TAC3_Msk |
| #define | HRTIM_ADC4R_AD4TAC4_Pos (12U) |
| #define | HRTIM_ADC4R_AD4TAC4_Msk (0x1UL << HRTIM_ADC4R_AD4TAC4_Pos) |
| #define | HRTIM_ADC4R_AD4TAC4 HRTIM_ADC4R_AD4TAC4_Msk |
| #define | HRTIM_ADC4R_AD4TAPER_Pos (13U) |
| #define | HRTIM_ADC4R_AD4TAPER_Msk (0x1UL << HRTIM_ADC4R_AD4TAPER_Pos) |
| #define | HRTIM_ADC4R_AD4TAPER HRTIM_ADC4R_AD4TAPER_Msk |
| #define | HRTIM_ADC4R_AD4TBC2_Pos (14U) |
| #define | HRTIM_ADC4R_AD4TBC2_Msk (0x1UL << HRTIM_ADC4R_AD4TBC2_Pos) |
| #define | HRTIM_ADC4R_AD4TBC2 HRTIM_ADC4R_AD4TBC2_Msk |
| #define | HRTIM_ADC4R_AD4TBC3_Pos (15U) |
| #define | HRTIM_ADC4R_AD4TBC3_Msk (0x1UL << HRTIM_ADC4R_AD4TBC3_Pos) |
| #define | HRTIM_ADC4R_AD4TBC3 HRTIM_ADC4R_AD4TBC3_Msk |
| #define | HRTIM_ADC4R_AD4TBC4_Pos (16U) |
| #define | HRTIM_ADC4R_AD4TBC4_Msk (0x1UL << HRTIM_ADC4R_AD4TBC4_Pos) |
| #define | HRTIM_ADC4R_AD4TBC4 HRTIM_ADC4R_AD4TBC4_Msk |
| #define | HRTIM_ADC4R_AD4TBPER_Pos (17U) |
| #define | HRTIM_ADC4R_AD4TBPER_Msk (0x1UL << HRTIM_ADC4R_AD4TBPER_Pos) |
| #define | HRTIM_ADC4R_AD4TBPER HRTIM_ADC4R_AD4TBPER_Msk |
| #define | HRTIM_ADC4R_AD4TCC2_Pos (18U) |
| #define | HRTIM_ADC4R_AD4TCC2_Msk (0x1UL << HRTIM_ADC4R_AD4TCC2_Pos) |
| #define | HRTIM_ADC4R_AD4TCC2 HRTIM_ADC4R_AD4TCC2_Msk |
| #define | HRTIM_ADC4R_AD4TCC3_Pos (19U) |
| #define | HRTIM_ADC4R_AD4TCC3_Msk (0x1UL << HRTIM_ADC4R_AD4TCC3_Pos) |
| #define | HRTIM_ADC4R_AD4TCC3 HRTIM_ADC4R_AD4TCC3_Msk |
| #define | HRTIM_ADC4R_AD4TCC4_Pos (20U) |
| #define | HRTIM_ADC4R_AD4TCC4_Msk (0x1UL << HRTIM_ADC4R_AD4TCC4_Pos) |
| #define | HRTIM_ADC4R_AD4TCC4 HRTIM_ADC4R_AD4TCC4_Msk |
| #define | HRTIM_ADC4R_AD4TCPER_Pos (21U) |
| #define | HRTIM_ADC4R_AD4TCPER_Msk (0x1UL << HRTIM_ADC4R_AD4TCPER_Pos) |
| #define | HRTIM_ADC4R_AD4TCPER HRTIM_ADC4R_AD4TCPER_Msk |
| #define | HRTIM_ADC4R_AD4TCRST_Pos (22U) |
| #define | HRTIM_ADC4R_AD4TCRST_Msk (0x1UL << HRTIM_ADC4R_AD4TCRST_Pos) |
| #define | HRTIM_ADC4R_AD4TCRST HRTIM_ADC4R_AD4TCRST_Msk |
| #define | HRTIM_ADC4R_AD4TDC2_Pos (23U) |
| #define | HRTIM_ADC4R_AD4TDC2_Msk (0x1UL << HRTIM_ADC4R_AD4TDC2_Pos) |
| #define | HRTIM_ADC4R_AD4TDC2 HRTIM_ADC4R_AD4TDC2_Msk |
| #define | HRTIM_ADC4R_AD4TDC3_Pos (24U) |
| #define | HRTIM_ADC4R_AD4TDC3_Msk (0x1UL << HRTIM_ADC4R_AD4TDC3_Pos) |
| #define | HRTIM_ADC4R_AD4TDC3 HRTIM_ADC4R_AD4TDC3_Msk |
| #define | HRTIM_ADC4R_AD4TDC4_Pos (25U) |
| #define | HRTIM_ADC4R_AD4TDC4_Msk (0x1UL << HRTIM_ADC4R_AD4TDC4_Pos) |
| #define | HRTIM_ADC4R_AD4TDC4 HRTIM_ADC4R_AD4TDC4_Msk |
| #define | HRTIM_ADC4R_AD4TDPER_Pos (26U) |
| #define | HRTIM_ADC4R_AD4TDPER_Msk (0x1UL << HRTIM_ADC4R_AD4TDPER_Pos) |
| #define | HRTIM_ADC4R_AD4TDPER HRTIM_ADC4R_AD4TDPER_Msk |
| #define | HRTIM_ADC4R_AD4TDRST_Pos (27U) |
| #define | HRTIM_ADC4R_AD4TDRST_Msk (0x1UL << HRTIM_ADC4R_AD4TDRST_Pos) |
| #define | HRTIM_ADC4R_AD4TDRST HRTIM_ADC4R_AD4TDRST_Msk |
| #define | HRTIM_ADC4R_AD4TEC2_Pos (28U) |
| #define | HRTIM_ADC4R_AD4TEC2_Msk (0x1UL << HRTIM_ADC4R_AD4TEC2_Pos) |
| #define | HRTIM_ADC4R_AD4TEC2 HRTIM_ADC4R_AD4TEC2_Msk |
| #define | HRTIM_ADC4R_AD4TEC3_Pos (29U) |
| #define | HRTIM_ADC4R_AD4TEC3_Msk (0x1UL << HRTIM_ADC4R_AD4TEC3_Pos) |
| #define | HRTIM_ADC4R_AD4TEC3 HRTIM_ADC4R_AD4TEC3_Msk |
| #define | HRTIM_ADC4R_AD4TEC4_Pos (30U) |
| #define | HRTIM_ADC4R_AD4TEC4_Msk (0x1UL << HRTIM_ADC4R_AD4TEC4_Pos) |
| #define | HRTIM_ADC4R_AD4TEC4 HRTIM_ADC4R_AD4TEC4_Msk |
| #define | HRTIM_ADC4R_AD4TERST_Pos (31U) |
| #define | HRTIM_ADC4R_AD4TERST_Msk (0x1UL << HRTIM_ADC4R_AD4TERST_Pos) |
| #define | HRTIM_ADC4R_AD4TERST HRTIM_ADC4R_AD4TERST_Msk |
| #define | HRTIM_FLTINR1_FLT1E_Pos (0U) |
| #define | HRTIM_FLTINR1_FLT1E_Msk (0x1UL << HRTIM_FLTINR1_FLT1E_Pos) |
| #define | HRTIM_FLTINR1_FLT1E HRTIM_FLTINR1_FLT1E_Msk |
| #define | HRTIM_FLTINR1_FLT1P_Pos (1U) |
| #define | HRTIM_FLTINR1_FLT1P_Msk (0x1UL << HRTIM_FLTINR1_FLT1P_Pos) |
| #define | HRTIM_FLTINR1_FLT1P HRTIM_FLTINR1_FLT1P_Msk |
| #define | HRTIM_FLTINR1_FLT1SRC_Pos (2U) |
| #define | HRTIM_FLTINR1_FLT1SRC_Msk (0x1UL << HRTIM_FLTINR1_FLT1SRC_Pos) |
| #define | HRTIM_FLTINR1_FLT1SRC HRTIM_FLTINR1_FLT1SRC_Msk |
| #define | HRTIM_FLTINR1_FLT1F_Pos (3U) |
| #define | HRTIM_FLTINR1_FLT1F_Msk (0xFUL << HRTIM_FLTINR1_FLT1F_Pos) |
| #define | HRTIM_FLTINR1_FLT1F HRTIM_FLTINR1_FLT1F_Msk |
| #define | HRTIM_FLTINR1_FLT1F_0 (0x1UL << HRTIM_FLTINR1_FLT1F_Pos) |
| #define | HRTIM_FLTINR1_FLT1F_1 (0x2UL << HRTIM_FLTINR1_FLT1F_Pos) |
| #define | HRTIM_FLTINR1_FLT1F_2 (0x4UL << HRTIM_FLTINR1_FLT1F_Pos) |
| #define | HRTIM_FLTINR1_FLT1F_3 (0x8UL << HRTIM_FLTINR1_FLT1F_Pos) |
| #define | HRTIM_FLTINR1_FLT1LCK_Pos (7U) |
| #define | HRTIM_FLTINR1_FLT1LCK_Msk (0x1UL << HRTIM_FLTINR1_FLT1LCK_Pos) |
| #define | HRTIM_FLTINR1_FLT1LCK HRTIM_FLTINR1_FLT1LCK_Msk |
| #define | HRTIM_FLTINR1_FLT2E_Pos (8U) |
| #define | HRTIM_FLTINR1_FLT2E_Msk (0x1UL << HRTIM_FLTINR1_FLT2E_Pos) |
| #define | HRTIM_FLTINR1_FLT2E HRTIM_FLTINR1_FLT2E_Msk |
| #define | HRTIM_FLTINR1_FLT2P_Pos (9U) |
| #define | HRTIM_FLTINR1_FLT2P_Msk (0x1UL << HRTIM_FLTINR1_FLT2P_Pos) |
| #define | HRTIM_FLTINR1_FLT2P HRTIM_FLTINR1_FLT2P_Msk |
| #define | HRTIM_FLTINR1_FLT2SRC_Pos (10U) |
| #define | HRTIM_FLTINR1_FLT2SRC_Msk (0x1UL << HRTIM_FLTINR1_FLT2SRC_Pos) |
| #define | HRTIM_FLTINR1_FLT2SRC HRTIM_FLTINR1_FLT2SRC_Msk |
| #define | HRTIM_FLTINR1_FLT2F_Pos (11U) |
| #define | HRTIM_FLTINR1_FLT2F_Msk (0xFUL << HRTIM_FLTINR1_FLT2F_Pos) |
| #define | HRTIM_FLTINR1_FLT2F HRTIM_FLTINR1_FLT2F_Msk |
| #define | HRTIM_FLTINR1_FLT2F_0 (0x1UL << HRTIM_FLTINR1_FLT2F_Pos) |
| #define | HRTIM_FLTINR1_FLT2F_1 (0x2UL << HRTIM_FLTINR1_FLT2F_Pos) |
| #define | HRTIM_FLTINR1_FLT2F_2 (0x4UL << HRTIM_FLTINR1_FLT2F_Pos) |
| #define | HRTIM_FLTINR1_FLT2F_3 (0x8UL << HRTIM_FLTINR1_FLT2F_Pos) |
| #define | HRTIM_FLTINR1_FLT2LCK_Pos (15U) |
| #define | HRTIM_FLTINR1_FLT2LCK_Msk (0x1UL << HRTIM_FLTINR1_FLT2LCK_Pos) |
| #define | HRTIM_FLTINR1_FLT2LCK HRTIM_FLTINR1_FLT2LCK_Msk |
| #define | HRTIM_FLTINR1_FLT3E_Pos (16U) |
| #define | HRTIM_FLTINR1_FLT3E_Msk (0x1UL << HRTIM_FLTINR1_FLT3E_Pos) |
| #define | HRTIM_FLTINR1_FLT3E HRTIM_FLTINR1_FLT3E_Msk |
| #define | HRTIM_FLTINR1_FLT3P_Pos (17U) |
| #define | HRTIM_FLTINR1_FLT3P_Msk (0x1UL << HRTIM_FLTINR1_FLT3P_Pos) |
| #define | HRTIM_FLTINR1_FLT3P HRTIM_FLTINR1_FLT3P_Msk |
| #define | HRTIM_FLTINR1_FLT3SRC_Pos (18U) |
| #define | HRTIM_FLTINR1_FLT3SRC_Msk (0x1UL << HRTIM_FLTINR1_FLT3SRC_Pos) |
| #define | HRTIM_FLTINR1_FLT3SRC HRTIM_FLTINR1_FLT3SRC_Msk |
| #define | HRTIM_FLTINR1_FLT3F_Pos (19U) |
| #define | HRTIM_FLTINR1_FLT3F_Msk (0xFUL << HRTIM_FLTINR1_FLT3F_Pos) |
| #define | HRTIM_FLTINR1_FLT3F HRTIM_FLTINR1_FLT3F_Msk |
| #define | HRTIM_FLTINR1_FLT3F_0 (0x1UL << HRTIM_FLTINR1_FLT3F_Pos) |
| #define | HRTIM_FLTINR1_FLT3F_1 (0x2UL << HRTIM_FLTINR1_FLT3F_Pos) |
| #define | HRTIM_FLTINR1_FLT3F_2 (0x4UL << HRTIM_FLTINR1_FLT3F_Pos) |
| #define | HRTIM_FLTINR1_FLT3F_3 (0x8UL << HRTIM_FLTINR1_FLT3F_Pos) |
| #define | HRTIM_FLTINR1_FLT3LCK_Pos (23U) |
| #define | HRTIM_FLTINR1_FLT3LCK_Msk (0x1UL << HRTIM_FLTINR1_FLT3LCK_Pos) |
| #define | HRTIM_FLTINR1_FLT3LCK HRTIM_FLTINR1_FLT3LCK_Msk |
| #define | HRTIM_FLTINR1_FLT4E_Pos (24U) |
| #define | HRTIM_FLTINR1_FLT4E_Msk (0x1UL << HRTIM_FLTINR1_FLT4E_Pos) |
| #define | HRTIM_FLTINR1_FLT4E HRTIM_FLTINR1_FLT4E_Msk |
| #define | HRTIM_FLTINR1_FLT4P_Pos (25U) |
| #define | HRTIM_FLTINR1_FLT4P_Msk (0x1UL << HRTIM_FLTINR1_FLT4P_Pos) |
| #define | HRTIM_FLTINR1_FLT4P HRTIM_FLTINR1_FLT4P_Msk |
| #define | HRTIM_FLTINR1_FLT4SRC_Pos (26U) |
| #define | HRTIM_FLTINR1_FLT4SRC_Msk (0x1UL << HRTIM_FLTINR1_FLT4SRC_Pos) |
| #define | HRTIM_FLTINR1_FLT4SRC HRTIM_FLTINR1_FLT4SRC_Msk |
| #define | HRTIM_FLTINR1_FLT4F_Pos (27U) |
| #define | HRTIM_FLTINR1_FLT4F_Msk (0xFUL << HRTIM_FLTINR1_FLT4F_Pos) |
| #define | HRTIM_FLTINR1_FLT4F HRTIM_FLTINR1_FLT4F_Msk |
| #define | HRTIM_FLTINR1_FLT4F_0 (0x1UL << HRTIM_FLTINR1_FLT4F_Pos) |
| #define | HRTIM_FLTINR1_FLT4F_1 (0x2UL << HRTIM_FLTINR1_FLT4F_Pos) |
| #define | HRTIM_FLTINR1_FLT4F_2 (0x4UL << HRTIM_FLTINR1_FLT4F_Pos) |
| #define | HRTIM_FLTINR1_FLT4F_3 (0x8UL << HRTIM_FLTINR1_FLT4F_Pos) |
| #define | HRTIM_FLTINR1_FLT4LCK_Pos (31U) |
| #define | HRTIM_FLTINR1_FLT4LCK_Msk (0x1UL << HRTIM_FLTINR1_FLT4LCK_Pos) |
| #define | HRTIM_FLTINR1_FLT4LCK HRTIM_FLTINR1_FLT4LCK_Msk |
| #define | HRTIM_FLTINR2_FLT5E_Pos (0U) |
| #define | HRTIM_FLTINR2_FLT5E_Msk (0x1UL << HRTIM_FLTINR2_FLT5E_Pos) |
| #define | HRTIM_FLTINR2_FLT5E HRTIM_FLTINR2_FLT5E_Msk |
| #define | HRTIM_FLTINR2_FLT5P_Pos (1U) |
| #define | HRTIM_FLTINR2_FLT5P_Msk (0x1UL << HRTIM_FLTINR2_FLT5P_Pos) |
| #define | HRTIM_FLTINR2_FLT5P HRTIM_FLTINR2_FLT5P_Msk |
| #define | HRTIM_FLTINR2_FLT5SRC_Pos (2U) |
| #define | HRTIM_FLTINR2_FLT5SRC_Msk (0x1UL << HRTIM_FLTINR2_FLT5SRC_Pos) |
| #define | HRTIM_FLTINR2_FLT5SRC HRTIM_FLTINR2_FLT5SRC_Msk |
| #define | HRTIM_FLTINR2_FLT5F_Pos (3U) |
| #define | HRTIM_FLTINR2_FLT5F_Msk (0xFUL << HRTIM_FLTINR2_FLT5F_Pos) |
| #define | HRTIM_FLTINR2_FLT5F HRTIM_FLTINR2_FLT5F_Msk |
| #define | HRTIM_FLTINR2_FLT5F_0 (0x1UL << HRTIM_FLTINR2_FLT5F_Pos) |
| #define | HRTIM_FLTINR2_FLT5F_1 (0x2UL << HRTIM_FLTINR2_FLT5F_Pos) |
| #define | HRTIM_FLTINR2_FLT5F_2 (0x4UL << HRTIM_FLTINR2_FLT5F_Pos) |
| #define | HRTIM_FLTINR2_FLT5F_3 (0x8UL << HRTIM_FLTINR2_FLT5F_Pos) |
| #define | HRTIM_FLTINR2_FLT5LCK_Pos (7U) |
| #define | HRTIM_FLTINR2_FLT5LCK_Msk (0x1UL << HRTIM_FLTINR2_FLT5LCK_Pos) |
| #define | HRTIM_FLTINR2_FLT5LCK HRTIM_FLTINR2_FLT5LCK_Msk |
| #define | HRTIM_FLTINR2_FLTSD_Pos (24U) |
| #define | HRTIM_FLTINR2_FLTSD_Msk (0x3UL << HRTIM_FLTINR2_FLTSD_Pos) |
| #define | HRTIM_FLTINR2_FLTSD HRTIM_FLTINR2_FLTSD_Msk |
| #define | HRTIM_FLTINR2_FLTSD_0 (0x1UL << HRTIM_FLTINR2_FLTSD_Pos) |
| #define | HRTIM_FLTINR2_FLTSD_1 (0x2UL << HRTIM_FLTINR2_FLTSD_Pos) |
| #define | HRTIM_BDMUPR_MCR_Pos (0U) |
| #define | HRTIM_BDMUPR_MCR_Msk (0x1UL << HRTIM_BDMUPR_MCR_Pos) |
| #define | HRTIM_BDMUPR_MCR HRTIM_BDMUPR_MCR_Msk |
| #define | HRTIM_BDMUPR_MICR_Pos (1U) |
| #define | HRTIM_BDMUPR_MICR_Msk (0x1UL << HRTIM_BDMUPR_MICR_Pos) |
| #define | HRTIM_BDMUPR_MICR HRTIM_BDMUPR_MICR_Msk |
| #define | HRTIM_BDMUPR_MDIER_Pos (2U) |
| #define | HRTIM_BDMUPR_MDIER_Msk (0x1UL << HRTIM_BDMUPR_MDIER_Pos) |
| #define | HRTIM_BDMUPR_MDIER HRTIM_BDMUPR_MDIER_Msk |
| #define | HRTIM_BDMUPR_MCNT_Pos (3U) |
| #define | HRTIM_BDMUPR_MCNT_Msk (0x1UL << HRTIM_BDMUPR_MCNT_Pos) |
| #define | HRTIM_BDMUPR_MCNT HRTIM_BDMUPR_MCNT_Msk |
| #define | HRTIM_BDMUPR_MPER_Pos (4U) |
| #define | HRTIM_BDMUPR_MPER_Msk (0x1UL << HRTIM_BDMUPR_MPER_Pos) |
| #define | HRTIM_BDMUPR_MPER HRTIM_BDMUPR_MPER_Msk |
| #define | HRTIM_BDMUPR_MREP_Pos (5U) |
| #define | HRTIM_BDMUPR_MREP_Msk (0x1UL << HRTIM_BDMUPR_MREP_Pos) |
| #define | HRTIM_BDMUPR_MREP HRTIM_BDMUPR_MREP_Msk |
| #define | HRTIM_BDMUPR_MCMP1_Pos (6U) |
| #define | HRTIM_BDMUPR_MCMP1_Msk (0x1UL << HRTIM_BDMUPR_MCMP1_Pos) |
| #define | HRTIM_BDMUPR_MCMP1 HRTIM_BDMUPR_MCMP1_Msk |
| #define | HRTIM_BDMUPR_MCMP2_Pos (7U) |
| #define | HRTIM_BDMUPR_MCMP2_Msk (0x1UL << HRTIM_BDMUPR_MCMP2_Pos) |
| #define | HRTIM_BDMUPR_MCMP2 HRTIM_BDMUPR_MCMP2_Msk |
| #define | HRTIM_BDMUPR_MCMP3_Pos (8U) |
| #define | HRTIM_BDMUPR_MCMP3_Msk (0x1UL << HRTIM_BDMUPR_MCMP3_Pos) |
| #define | HRTIM_BDMUPR_MCMP3 HRTIM_BDMUPR_MCMP3_Msk |
| #define | HRTIM_BDMUPR_MCMP4_Pos (9U) |
| #define | HRTIM_BDMUPR_MCMP4_Msk (0x1UL << HRTIM_BDMUPR_MCMP4_Pos) |
| #define | HRTIM_BDMUPR_MCMP4 HRTIM_BDMUPR_MCMP4_Msk |
| #define | HRTIM_BDTUPR_TIMCR_Pos (0U) |
| #define | HRTIM_BDTUPR_TIMCR_Msk (0x1UL << HRTIM_BDTUPR_TIMCR_Pos) |
| #define | HRTIM_BDTUPR_TIMCR HRTIM_BDTUPR_TIMCR_Msk |
| #define | HRTIM_BDTUPR_TIMICR_Pos (1U) |
| #define | HRTIM_BDTUPR_TIMICR_Msk (0x1UL << HRTIM_BDTUPR_TIMICR_Pos) |
| #define | HRTIM_BDTUPR_TIMICR HRTIM_BDTUPR_TIMICR_Msk |
| #define | HRTIM_BDTUPR_TIMDIER_Pos (2U) |
| #define | HRTIM_BDTUPR_TIMDIER_Msk (0x1UL << HRTIM_BDTUPR_TIMDIER_Pos) |
| #define | HRTIM_BDTUPR_TIMDIER HRTIM_BDTUPR_TIMDIER_Msk |
| #define | HRTIM_BDTUPR_TIMCNT_Pos (3U) |
| #define | HRTIM_BDTUPR_TIMCNT_Msk (0x1UL << HRTIM_BDTUPR_TIMCNT_Pos) |
| #define | HRTIM_BDTUPR_TIMCNT HRTIM_BDTUPR_TIMCNT_Msk |
| #define | HRTIM_BDTUPR_TIMPER_Pos (4U) |
| #define | HRTIM_BDTUPR_TIMPER_Msk (0x1UL << HRTIM_BDTUPR_TIMPER_Pos) |
| #define | HRTIM_BDTUPR_TIMPER HRTIM_BDTUPR_TIMPER_Msk |
| #define | HRTIM_BDTUPR_TIMREP_Pos (5U) |
| #define | HRTIM_BDTUPR_TIMREP_Msk (0x1UL << HRTIM_BDTUPR_TIMREP_Pos) |
| #define | HRTIM_BDTUPR_TIMREP HRTIM_BDTUPR_TIMREP_Msk |
| #define | HRTIM_BDTUPR_TIMCMP1_Pos (6U) |
| #define | HRTIM_BDTUPR_TIMCMP1_Msk (0x1UL << HRTIM_BDTUPR_TIMCMP1_Pos) |
| #define | HRTIM_BDTUPR_TIMCMP1 HRTIM_BDTUPR_TIMCMP1_Msk |
| #define | HRTIM_BDTUPR_TIMCMP2_Pos (7U) |
| #define | HRTIM_BDTUPR_TIMCMP2_Msk (0x1UL << HRTIM_BDTUPR_TIMCMP2_Pos) |
| #define | HRTIM_BDTUPR_TIMCMP2 HRTIM_BDTUPR_TIMCMP2_Msk |
| #define | HRTIM_BDTUPR_TIMCMP3_Pos (8U) |
| #define | HRTIM_BDTUPR_TIMCMP3_Msk (0x1UL << HRTIM_BDTUPR_TIMCMP3_Pos) |
| #define | HRTIM_BDTUPR_TIMCMP3 HRTIM_BDTUPR_TIMCMP3_Msk |
| #define | HRTIM_BDTUPR_TIMCMP4_Pos (9U) |
| #define | HRTIM_BDTUPR_TIMCMP4_Msk (0x1UL << HRTIM_BDTUPR_TIMCMP4_Pos) |
| #define | HRTIM_BDTUPR_TIMCMP4 HRTIM_BDTUPR_TIMCMP4_Msk |
| #define | HRTIM_BDTUPR_TIMDTR_Pos (10U) |
| #define | HRTIM_BDTUPR_TIMDTR_Msk (0x1UL << HRTIM_BDTUPR_TIMDTR_Pos) |
| #define | HRTIM_BDTUPR_TIMDTR HRTIM_BDTUPR_TIMDTR_Msk |
| #define | HRTIM_BDTUPR_TIMSET1R_Pos (11U) |
| #define | HRTIM_BDTUPR_TIMSET1R_Msk (0x1UL << HRTIM_BDTUPR_TIMSET1R_Pos) |
| #define | HRTIM_BDTUPR_TIMSET1R HRTIM_BDTUPR_TIMSET1R_Msk |
| #define | HRTIM_BDTUPR_TIMRST1R_Pos (12U) |
| #define | HRTIM_BDTUPR_TIMRST1R_Msk (0x1UL << HRTIM_BDTUPR_TIMRST1R_Pos) |
| #define | HRTIM_BDTUPR_TIMRST1R HRTIM_BDTUPR_TIMRST1R_Msk |
| #define | HRTIM_BDTUPR_TIMSET2R_Pos (13U) |
| #define | HRTIM_BDTUPR_TIMSET2R_Msk (0x1UL << HRTIM_BDTUPR_TIMSET2R_Pos) |
| #define | HRTIM_BDTUPR_TIMSET2R HRTIM_BDTUPR_TIMSET2R_Msk |
| #define | HRTIM_BDTUPR_TIMRST2R_Pos (14U) |
| #define | HRTIM_BDTUPR_TIMRST2R_Msk (0x1UL << HRTIM_BDTUPR_TIMRST2R_Pos) |
| #define | HRTIM_BDTUPR_TIMRST2R HRTIM_BDTUPR_TIMRST2R_Msk |
| #define | HRTIM_BDTUPR_TIMEEFR1_Pos (15U) |
| #define | HRTIM_BDTUPR_TIMEEFR1_Msk (0x1UL << HRTIM_BDTUPR_TIMEEFR1_Pos) |
| #define | HRTIM_BDTUPR_TIMEEFR1 HRTIM_BDTUPR_TIMEEFR1_Msk |
| #define | HRTIM_BDTUPR_TIMEEFR2_Pos (16U) |
| #define | HRTIM_BDTUPR_TIMEEFR2_Msk (0x1UL << HRTIM_BDTUPR_TIMEEFR2_Pos) |
| #define | HRTIM_BDTUPR_TIMEEFR2 HRTIM_BDTUPR_TIMEEFR2_Msk |
| #define | HRTIM_BDTUPR_TIMRSTR_Pos (17U) |
| #define | HRTIM_BDTUPR_TIMRSTR_Msk (0x1UL << HRTIM_BDTUPR_TIMRSTR_Pos) |
| #define | HRTIM_BDTUPR_TIMRSTR HRTIM_BDTUPR_TIMRSTR_Msk |
| #define | HRTIM_BDTUPR_TIMCHPR_Pos (18U) |
| #define | HRTIM_BDTUPR_TIMCHPR_Msk (0x1UL << HRTIM_BDTUPR_TIMCHPR_Pos) |
| #define | HRTIM_BDTUPR_TIMCHPR HRTIM_BDTUPR_TIMCHPR_Msk |
| #define | HRTIM_BDTUPR_TIMOUTR_Pos (19U) |
| #define | HRTIM_BDTUPR_TIMOUTR_Msk (0x1UL << HRTIM_BDTUPR_TIMOUTR_Pos) |
| #define | HRTIM_BDTUPR_TIMOUTR HRTIM_BDTUPR_TIMOUTR_Msk |
| #define | HRTIM_BDTUPR_TIMFLTR_Pos (20U) |
| #define | HRTIM_BDTUPR_TIMFLTR_Msk (0x1UL << HRTIM_BDTUPR_TIMFLTR_Pos) |
| #define | HRTIM_BDTUPR_TIMFLTR HRTIM_BDTUPR_TIMFLTR_Msk |
| #define | HRTIM_BDMADR_BDMADR_Pos (0U) |
| #define | HRTIM_BDMADR_BDMADR_Msk (0xFFFFFFFFUL << HRTIM_BDMADR_BDMADR_Pos) |
| #define | HRTIM_BDMADR_BDMADR HRTIM_BDMADR_BDMADR_Msk |
| #define | RAMECC_IER_GECCDEBWIE_Pos (3U) |
| #define | RAMECC_IER_GECCDEBWIE_Msk (0x1UL << RAMECC_IER_GECCDEBWIE_Pos) |
| #define | RAMECC_IER_GECCDEBWIE RAMECC_IER_GECCDEBWIE_Msk |
| #define | RAMECC_IER_GECCDEIE_Pos (2U) |
| #define | RAMECC_IER_GECCDEIE_Msk (0x1UL << RAMECC_IER_GECCDEIE_Pos) |
| #define | RAMECC_IER_GECCDEIE RAMECC_IER_GECCDEIE_Msk |
| #define | RAMECC_IER_GECCSEIE_Pos (1U) |
| #define | RAMECC_IER_GECCSEIE_Msk (0x1UL << RAMECC_IER_GECCSEIE_Pos) |
| #define | RAMECC_IER_GECCSEIE RAMECC_IER_GECCSEIE_Msk |
| #define | RAMECC_IER_GIE_Pos (0U) |
| #define | RAMECC_IER_GIE_Msk (0x1UL << RAMECC_IER_GIE_Pos) |
| #define | RAMECC_IER_GIE RAMECC_IER_GIE_Msk |
| #define | RAMECC_CR_ECCELEN_Pos (5U) |
| #define | RAMECC_CR_ECCELEN_Msk (0x1UL << RAMECC_CR_ECCELEN_Pos) |
| #define | RAMECC_CR_ECCELEN RAMECC_CR_ECCELEN_Msk |
| #define | RAMECC_CR_ECCDEBWIE_Pos (4U) |
| #define | RAMECC_CR_ECCDEBWIE_Msk (0x1UL << RAMECC_CR_ECCDEBWIE_Pos) |
| #define | RAMECC_CR_ECCDEBWIE RAMECC_CR_ECCDEBWIE_Msk |
| #define | RAMECC_CR_ECCDEIE_Pos (3U) |
| #define | RAMECC_CR_ECCDEIE_Msk (0x1UL << RAMECC_CR_ECCDEIE_Pos) |
| #define | RAMECC_CR_ECCDEIE RAMECC_CR_ECCDEIE_Msk |
| #define | RAMECC_CR_ECCSEIE_Pos (2U) |
| #define | RAMECC_CR_ECCSEIE_Msk (0x1UL << RAMECC_CR_ECCSEIE_Pos) |
| #define | RAMECC_CR_ECCSEIE RAMECC_CR_ECCSEIE_Msk |
| #define | RAMECC_SR_DEBWDF_Pos (2U) |
| #define | RAMECC_SR_DEBWDF_Msk (0x1UL << RAMECC_SR_DEBWDF_Pos) |
| #define | RAMECC_SR_DEBWDF RAMECC_SR_DEBWDF_Msk |
| #define | RAMECC_SR_DEDF_Pos (1U) |
| #define | RAMECC_SR_DEDF_Msk (0x1UL << RAMECC_SR_DEDF_Pos) |
| #define | RAMECC_SR_DEDF RAMECC_SR_DEDF_Msk |
| #define | RAMECC_SR_SEDCF_Pos (0U) |
| #define | RAMECC_SR_SEDCF_Msk (0x1UL << RAMECC_SR_SEDCF_Pos) |
| #define | RAMECC_SR_SEDCF RAMECC_SR_SEDCF_Msk |
| #define | RAMECC_FAR_FADD_Pos (0U) |
| #define | RAMECC_FAR_FADD_Msk (0xFFFFFFFFUL << RAMECC_FAR_FADD_Pos) |
| #define | RAMECC_FAR_FADD RAMECC_FAR_FADD_Msk |
| #define | RAMECC_FAR_FDATAL_Pos (0U) |
| #define | RAMECC_FAR_FDATAL_Msk (0xFFFFFFFFUL << RAMECC_FAR_FDATAL_Pos) |
| #define | RAMECC_FAR_FDATAL RAMECC_FAR_FDATAL_Msk |
| #define | RAMECC_FAR_FDATAH_Pos (0U) |
| #define | RAMECC_FAR_FDATAH_Msk (0xFFFFFFFFUL << RAMECC_FAR_FDATAH_Pos) |
| #define | RAMECC_FAR_FDATAH RAMECC_FAR_FDATAH_Msk /* Failing data high (64-bit memory) */ |
| #define | RAMECC_FECR_FEC_Pos (0U) |
| #define | RAMECC_FECR_FEC_Msk (0xFFFFFFFFUL << RAMECC_FECR_FEC_Pos) |
| #define | RAMECC_FECR_FEC RAMECC_FECR_FEC_Msk |
| #define | MDIOS_CR_EN_Pos (0U) |
| #define | MDIOS_CR_EN_Msk (0x1UL << MDIOS_CR_EN_Pos) |
| #define | MDIOS_CR_EN MDIOS_CR_EN_Msk |
| #define | MDIOS_CR_WRIE_Pos (1U) |
| #define | MDIOS_CR_WRIE_Msk (0x1UL << MDIOS_CR_WRIE_Pos) |
| #define | MDIOS_CR_WRIE MDIOS_CR_WRIE_Msk |
| #define | MDIOS_CR_RDIE_Pos (2U) |
| #define | MDIOS_CR_RDIE_Msk (0x1UL << MDIOS_CR_RDIE_Pos) |
| #define | MDIOS_CR_RDIE MDIOS_CR_RDIE_Msk |
| #define | MDIOS_CR_EIE_Pos (3U) |
| #define | MDIOS_CR_EIE_Msk (0x1UL << MDIOS_CR_EIE_Pos) |
| #define | MDIOS_CR_EIE MDIOS_CR_EIE_Msk |
| #define | MDIOS_CR_DPC_Pos (7U) |
| #define | MDIOS_CR_DPC_Msk (0x1UL << MDIOS_CR_DPC_Pos) |
| #define | MDIOS_CR_DPC MDIOS_CR_DPC_Msk |
| #define | MDIOS_CR_PORT_ADDRESS_Pos (8U) |
| #define | MDIOS_CR_PORT_ADDRESS_Msk (0x1FUL << MDIOS_CR_PORT_ADDRESS_Pos) |
| #define | MDIOS_CR_PORT_ADDRESS MDIOS_CR_PORT_ADDRESS_Msk |
| #define | MDIOS_CR_PORT_ADDRESS_0 (0x01UL << MDIOS_CR_PORT_ADDRESS_Pos) |
| #define | MDIOS_CR_PORT_ADDRESS_1 (0x02UL << MDIOS_CR_PORT_ADDRESS_Pos) |
| #define | MDIOS_CR_PORT_ADDRESS_2 (0x04UL << MDIOS_CR_PORT_ADDRESS_Pos) |
| #define | MDIOS_CR_PORT_ADDRESS_3 (0x08UL << MDIOS_CR_PORT_ADDRESS_Pos) |
| #define | MDIOS_CR_PORT_ADDRESS_4 (0x10UL << MDIOS_CR_PORT_ADDRESS_Pos) |
| #define | MDIOS_SR_PERF_Pos (0U) |
| #define | MDIOS_SR_PERF_Msk (0x1UL << MDIOS_SR_PERF_Pos) |
| #define | MDIOS_SR_PERF MDIOS_SR_PERF_Msk |
| #define | MDIOS_SR_SERF_Pos (1U) |
| #define | MDIOS_SR_SERF_Msk (0x1UL << MDIOS_SR_SERF_Pos) |
| #define | MDIOS_SR_SERF MDIOS_SR_SERF_Msk |
| #define | MDIOS_SR_TERF_Pos (2U) |
| #define | MDIOS_SR_TERF_Msk (0x1UL << MDIOS_SR_TERF_Pos) |
| #define | MDIOS_SR_TERF MDIOS_SR_TERF_Msk |
| #define | MDIOS_SR_CPERF_Pos (0U) |
| #define | MDIOS_SR_CPERF_Msk (0x1UL << MDIOS_SR_CPERF_Pos) |
| #define | MDIOS_SR_CPERF MDIOS_SR_CPERF_Msk |
| #define | MDIOS_SR_CSERF_Pos (1U) |
| #define | MDIOS_SR_CSERF_Msk (0x1UL << MDIOS_SR_CSERF_Pos) |
| #define | MDIOS_SR_CSERF MDIOS_SR_CSERF_Msk |
| #define | MDIOS_SR_CTERF_Pos (2U) |
| #define | MDIOS_SR_CTERF_Msk (0x1UL << MDIOS_SR_CTERF_Pos) |
| #define | MDIOS_SR_CTERF MDIOS_SR_CTERF_Msk |
| #define | USB_OTG_GOTGCTL_SRQSCS_Pos (0U) |
| #define | USB_OTG_GOTGCTL_SRQSCS_Msk (0x1UL << USB_OTG_GOTGCTL_SRQSCS_Pos) |
| #define | USB_OTG_GOTGCTL_SRQSCS USB_OTG_GOTGCTL_SRQSCS_Msk |
| #define | USB_OTG_GOTGCTL_SRQ_Pos (1U) |
| #define | USB_OTG_GOTGCTL_SRQ_Msk (0x1UL << USB_OTG_GOTGCTL_SRQ_Pos) |
| #define | USB_OTG_GOTGCTL_SRQ USB_OTG_GOTGCTL_SRQ_Msk |
| #define | USB_OTG_GOTGCTL_VBVALOEN_Pos (2U) |
| #define | USB_OTG_GOTGCTL_VBVALOEN_Msk (0x1UL << USB_OTG_GOTGCTL_VBVALOEN_Pos) |
| #define | USB_OTG_GOTGCTL_VBVALOEN USB_OTG_GOTGCTL_VBVALOEN_Msk |
| #define | USB_OTG_GOTGCTL_VBVALOVAL_Pos (3U) |
| #define | USB_OTG_GOTGCTL_VBVALOVAL_Msk (0x1UL << USB_OTG_GOTGCTL_VBVALOVAL_Pos) |
| #define | USB_OTG_GOTGCTL_VBVALOVAL USB_OTG_GOTGCTL_VBVALOVAL_Msk |
| #define | USB_OTG_GOTGCTL_AVALOEN_Pos (4U) |
| #define | USB_OTG_GOTGCTL_AVALOEN_Msk (0x1UL << USB_OTG_GOTGCTL_AVALOEN_Pos) |
| #define | USB_OTG_GOTGCTL_AVALOEN USB_OTG_GOTGCTL_AVALOEN_Msk |
| #define | USB_OTG_GOTGCTL_AVALOVAL_Pos (5U) |
| #define | USB_OTG_GOTGCTL_AVALOVAL_Msk (0x1UL << USB_OTG_GOTGCTL_AVALOVAL_Pos) |
| #define | USB_OTG_GOTGCTL_AVALOVAL USB_OTG_GOTGCTL_AVALOVAL_Msk |
| #define | USB_OTG_GOTGCTL_BVALOEN_Pos (6U) |
| #define | USB_OTG_GOTGCTL_BVALOEN_Msk (0x1UL << USB_OTG_GOTGCTL_BVALOEN_Pos) |
| #define | USB_OTG_GOTGCTL_BVALOEN USB_OTG_GOTGCTL_BVALOEN_Msk |
| #define | USB_OTG_GOTGCTL_BVALOVAL_Pos (7U) |
| #define | USB_OTG_GOTGCTL_BVALOVAL_Msk (0x1UL << USB_OTG_GOTGCTL_BVALOVAL_Pos) |
| #define | USB_OTG_GOTGCTL_BVALOVAL USB_OTG_GOTGCTL_BVALOVAL_Msk |
| #define | USB_OTG_GOTGCTL_HNGSCS_Pos (8U) |
| #define | USB_OTG_GOTGCTL_HNGSCS_Msk (0x1UL << USB_OTG_GOTGCTL_HNGSCS_Pos) |
| #define | USB_OTG_GOTGCTL_HNGSCS USB_OTG_GOTGCTL_HNGSCS_Msk |
| #define | USB_OTG_GOTGCTL_HNPRQ_Pos (9U) |
| #define | USB_OTG_GOTGCTL_HNPRQ_Msk (0x1UL << USB_OTG_GOTGCTL_HNPRQ_Pos) |
| #define | USB_OTG_GOTGCTL_HNPRQ USB_OTG_GOTGCTL_HNPRQ_Msk |
| #define | USB_OTG_GOTGCTL_HSHNPEN_Pos (10U) |
| #define | USB_OTG_GOTGCTL_HSHNPEN_Msk (0x1UL << USB_OTG_GOTGCTL_HSHNPEN_Pos) |
| #define | USB_OTG_GOTGCTL_HSHNPEN USB_OTG_GOTGCTL_HSHNPEN_Msk |
| #define | USB_OTG_GOTGCTL_DHNPEN_Pos (11U) |
| #define | USB_OTG_GOTGCTL_DHNPEN_Msk (0x1UL << USB_OTG_GOTGCTL_DHNPEN_Pos) |
| #define | USB_OTG_GOTGCTL_DHNPEN USB_OTG_GOTGCTL_DHNPEN_Msk |
| #define | USB_OTG_GOTGCTL_EHEN_Pos (12U) |
| #define | USB_OTG_GOTGCTL_EHEN_Msk (0x1UL << USB_OTG_GOTGCTL_EHEN_Pos) |
| #define | USB_OTG_GOTGCTL_EHEN USB_OTG_GOTGCTL_EHEN_Msk |
| #define | USB_OTG_GOTGCTL_CIDSTS_Pos (16U) |
| #define | USB_OTG_GOTGCTL_CIDSTS_Msk (0x1UL << USB_OTG_GOTGCTL_CIDSTS_Pos) |
| #define | USB_OTG_GOTGCTL_CIDSTS USB_OTG_GOTGCTL_CIDSTS_Msk |
| #define | USB_OTG_GOTGCTL_DBCT_Pos (17U) |
| #define | USB_OTG_GOTGCTL_DBCT_Msk (0x1UL << USB_OTG_GOTGCTL_DBCT_Pos) |
| #define | USB_OTG_GOTGCTL_DBCT USB_OTG_GOTGCTL_DBCT_Msk |
| #define | USB_OTG_GOTGCTL_ASVLD_Pos (18U) |
| #define | USB_OTG_GOTGCTL_ASVLD_Msk (0x1UL << USB_OTG_GOTGCTL_ASVLD_Pos) |
| #define | USB_OTG_GOTGCTL_ASVLD USB_OTG_GOTGCTL_ASVLD_Msk |
| #define | USB_OTG_GOTGCTL_BSESVLD_Pos (19U) |
| #define | USB_OTG_GOTGCTL_BSESVLD_Msk (0x1UL << USB_OTG_GOTGCTL_BSESVLD_Pos) |
| #define | USB_OTG_GOTGCTL_BSESVLD USB_OTG_GOTGCTL_BSESVLD_Msk |
| #define | USB_OTG_GOTGCTL_OTGVER_Pos (20U) |
| #define | USB_OTG_GOTGCTL_OTGVER_Msk (0x1UL << USB_OTG_GOTGCTL_OTGVER_Pos) |
| #define | USB_OTG_GOTGCTL_OTGVER USB_OTG_GOTGCTL_OTGVER_Msk |
| #define | USB_OTG_GOTGCTL_CURMOD_Pos (21U) |
| #define | USB_OTG_GOTGCTL_CURMOD_Msk (0x1UL << USB_OTG_GOTGCTL_CURMOD_Pos) |
| #define | USB_OTG_GOTGCTL_CURMOD USB_OTG_GOTGCTL_CURMOD_Msk |
| #define | USB_OTG_HCFG_FSLSPCS_Pos (0U) |
| #define | USB_OTG_HCFG_FSLSPCS_Msk (0x3UL << USB_OTG_HCFG_FSLSPCS_Pos) |
| #define | USB_OTG_HCFG_FSLSPCS USB_OTG_HCFG_FSLSPCS_Msk |
| #define | USB_OTG_HCFG_FSLSPCS_0 (0x1UL << USB_OTG_HCFG_FSLSPCS_Pos) |
| #define | USB_OTG_HCFG_FSLSPCS_1 (0x2UL << USB_OTG_HCFG_FSLSPCS_Pos) |
| #define | USB_OTG_HCFG_FSLSS_Pos (2U) |
| #define | USB_OTG_HCFG_FSLSS_Msk (0x1UL << USB_OTG_HCFG_FSLSS_Pos) |
| #define | USB_OTG_HCFG_FSLSS USB_OTG_HCFG_FSLSS_Msk |
| #define | USB_OTG_DCFG_DSPD_Pos (0U) |
| #define | USB_OTG_DCFG_DSPD_Msk (0x3UL << USB_OTG_DCFG_DSPD_Pos) |
| #define | USB_OTG_DCFG_DSPD USB_OTG_DCFG_DSPD_Msk |
| #define | USB_OTG_DCFG_DSPD_0 (0x1UL << USB_OTG_DCFG_DSPD_Pos) |
| #define | USB_OTG_DCFG_DSPD_1 (0x2UL << USB_OTG_DCFG_DSPD_Pos) |
| #define | USB_OTG_DCFG_NZLSOHSK_Pos (2U) |
| #define | USB_OTG_DCFG_NZLSOHSK_Msk (0x1UL << USB_OTG_DCFG_NZLSOHSK_Pos) |
| #define | USB_OTG_DCFG_NZLSOHSK USB_OTG_DCFG_NZLSOHSK_Msk |
| #define | USB_OTG_DCFG_DAD_Pos (4U) |
| #define | USB_OTG_DCFG_DAD_Msk (0x7FUL << USB_OTG_DCFG_DAD_Pos) |
| #define | USB_OTG_DCFG_DAD USB_OTG_DCFG_DAD_Msk |
| #define | USB_OTG_DCFG_DAD_0 (0x01UL << USB_OTG_DCFG_DAD_Pos) |
| #define | USB_OTG_DCFG_DAD_1 (0x02UL << USB_OTG_DCFG_DAD_Pos) |
| #define | USB_OTG_DCFG_DAD_2 (0x04UL << USB_OTG_DCFG_DAD_Pos) |
| #define | USB_OTG_DCFG_DAD_3 (0x08UL << USB_OTG_DCFG_DAD_Pos) |
| #define | USB_OTG_DCFG_DAD_4 (0x10UL << USB_OTG_DCFG_DAD_Pos) |
| #define | USB_OTG_DCFG_DAD_5 (0x20UL << USB_OTG_DCFG_DAD_Pos) |
| #define | USB_OTG_DCFG_DAD_6 (0x40UL << USB_OTG_DCFG_DAD_Pos) |
| #define | USB_OTG_DCFG_PFIVL_Pos (11U) |
| #define | USB_OTG_DCFG_PFIVL_Msk (0x3UL << USB_OTG_DCFG_PFIVL_Pos) |
| #define | USB_OTG_DCFG_PFIVL USB_OTG_DCFG_PFIVL_Msk |
| #define | USB_OTG_DCFG_PFIVL_0 (0x1UL << USB_OTG_DCFG_PFIVL_Pos) |
| #define | USB_OTG_DCFG_PFIVL_1 (0x2UL << USB_OTG_DCFG_PFIVL_Pos) |
| #define | USB_OTG_DCFG_XCVRDLY_Pos (14U) |
| #define | USB_OTG_DCFG_XCVRDLY_Msk (0x1UL << USB_OTG_DCFG_XCVRDLY_Pos) |
| #define | USB_OTG_DCFG_XCVRDLY USB_OTG_DCFG_XCVRDLY_Msk |
| #define | USB_OTG_DCFG_ERRATIM_Pos (15U) |
| #define | USB_OTG_DCFG_ERRATIM_Msk (0x1UL << USB_OTG_DCFG_ERRATIM_Pos) |
| #define | USB_OTG_DCFG_ERRATIM USB_OTG_DCFG_ERRATIM_Msk |
| #define | USB_OTG_DCFG_PERSCHIVL_Pos (24U) |
| #define | USB_OTG_DCFG_PERSCHIVL_Msk (0x3UL << USB_OTG_DCFG_PERSCHIVL_Pos) |
| #define | USB_OTG_DCFG_PERSCHIVL USB_OTG_DCFG_PERSCHIVL_Msk |
| #define | USB_OTG_DCFG_PERSCHIVL_0 (0x1UL << USB_OTG_DCFG_PERSCHIVL_Pos) |
| #define | USB_OTG_DCFG_PERSCHIVL_1 (0x2UL << USB_OTG_DCFG_PERSCHIVL_Pos) |
| #define | USB_OTG_PCGCR_STPPCLK_Pos (0U) |
| #define | USB_OTG_PCGCR_STPPCLK_Msk (0x1UL << USB_OTG_PCGCR_STPPCLK_Pos) |
| #define | USB_OTG_PCGCR_STPPCLK USB_OTG_PCGCR_STPPCLK_Msk |
| #define | USB_OTG_PCGCR_GATEHCLK_Pos (1U) |
| #define | USB_OTG_PCGCR_GATEHCLK_Msk (0x1UL << USB_OTG_PCGCR_GATEHCLK_Pos) |
| #define | USB_OTG_PCGCR_GATEHCLK USB_OTG_PCGCR_GATEHCLK_Msk |
| #define | USB_OTG_PCGCR_PHYSUSP_Pos (4U) |
| #define | USB_OTG_PCGCR_PHYSUSP_Msk (0x1UL << USB_OTG_PCGCR_PHYSUSP_Pos) |
| #define | USB_OTG_PCGCR_PHYSUSP USB_OTG_PCGCR_PHYSUSP_Msk |
| #define | USB_OTG_GOTGINT_SEDET_Pos (2U) |
| #define | USB_OTG_GOTGINT_SEDET_Msk (0x1UL << USB_OTG_GOTGINT_SEDET_Pos) |
| #define | USB_OTG_GOTGINT_SEDET USB_OTG_GOTGINT_SEDET_Msk |
| #define | USB_OTG_GOTGINT_SRSSCHG_Pos (8U) |
| #define | USB_OTG_GOTGINT_SRSSCHG_Msk (0x1UL << USB_OTG_GOTGINT_SRSSCHG_Pos) |
| #define | USB_OTG_GOTGINT_SRSSCHG USB_OTG_GOTGINT_SRSSCHG_Msk |
| #define | USB_OTG_GOTGINT_HNSSCHG_Pos (9U) |
| #define | USB_OTG_GOTGINT_HNSSCHG_Msk (0x1UL << USB_OTG_GOTGINT_HNSSCHG_Pos) |
| #define | USB_OTG_GOTGINT_HNSSCHG USB_OTG_GOTGINT_HNSSCHG_Msk |
| #define | USB_OTG_GOTGINT_HNGDET_Pos (17U) |
| #define | USB_OTG_GOTGINT_HNGDET_Msk (0x1UL << USB_OTG_GOTGINT_HNGDET_Pos) |
| #define | USB_OTG_GOTGINT_HNGDET USB_OTG_GOTGINT_HNGDET_Msk |
| #define | USB_OTG_GOTGINT_ADTOCHG_Pos (18U) |
| #define | USB_OTG_GOTGINT_ADTOCHG_Msk (0x1UL << USB_OTG_GOTGINT_ADTOCHG_Pos) |
| #define | USB_OTG_GOTGINT_ADTOCHG USB_OTG_GOTGINT_ADTOCHG_Msk |
| #define | USB_OTG_GOTGINT_DBCDNE_Pos (19U) |
| #define | USB_OTG_GOTGINT_DBCDNE_Msk (0x1UL << USB_OTG_GOTGINT_DBCDNE_Pos) |
| #define | USB_OTG_GOTGINT_DBCDNE USB_OTG_GOTGINT_DBCDNE_Msk |
| #define | USB_OTG_DCTL_RWUSIG_Pos (0U) |
| #define | USB_OTG_DCTL_RWUSIG_Msk (0x1UL << USB_OTG_DCTL_RWUSIG_Pos) |
| #define | USB_OTG_DCTL_RWUSIG USB_OTG_DCTL_RWUSIG_Msk |
| #define | USB_OTG_DCTL_SDIS_Pos (1U) |
| #define | USB_OTG_DCTL_SDIS_Msk (0x1UL << USB_OTG_DCTL_SDIS_Pos) |
| #define | USB_OTG_DCTL_SDIS USB_OTG_DCTL_SDIS_Msk |
| #define | USB_OTG_DCTL_GINSTS_Pos (2U) |
| #define | USB_OTG_DCTL_GINSTS_Msk (0x1UL << USB_OTG_DCTL_GINSTS_Pos) |
| #define | USB_OTG_DCTL_GINSTS USB_OTG_DCTL_GINSTS_Msk |
| #define | USB_OTG_DCTL_GONSTS_Pos (3U) |
| #define | USB_OTG_DCTL_GONSTS_Msk (0x1UL << USB_OTG_DCTL_GONSTS_Pos) |
| #define | USB_OTG_DCTL_GONSTS USB_OTG_DCTL_GONSTS_Msk |
| #define | USB_OTG_DCTL_TCTL_Pos (4U) |
| #define | USB_OTG_DCTL_TCTL_Msk (0x7UL << USB_OTG_DCTL_TCTL_Pos) |
| #define | USB_OTG_DCTL_TCTL USB_OTG_DCTL_TCTL_Msk |
| #define | USB_OTG_DCTL_TCTL_0 (0x1UL << USB_OTG_DCTL_TCTL_Pos) |
| #define | USB_OTG_DCTL_TCTL_1 (0x2UL << USB_OTG_DCTL_TCTL_Pos) |
| #define | USB_OTG_DCTL_TCTL_2 (0x4UL << USB_OTG_DCTL_TCTL_Pos) |
| #define | USB_OTG_DCTL_SGINAK_Pos (7U) |
| #define | USB_OTG_DCTL_SGINAK_Msk (0x1UL << USB_OTG_DCTL_SGINAK_Pos) |
| #define | USB_OTG_DCTL_SGINAK USB_OTG_DCTL_SGINAK_Msk |
| #define | USB_OTG_DCTL_CGINAK_Pos (8U) |
| #define | USB_OTG_DCTL_CGINAK_Msk (0x1UL << USB_OTG_DCTL_CGINAK_Pos) |
| #define | USB_OTG_DCTL_CGINAK USB_OTG_DCTL_CGINAK_Msk |
| #define | USB_OTG_DCTL_SGONAK_Pos (9U) |
| #define | USB_OTG_DCTL_SGONAK_Msk (0x1UL << USB_OTG_DCTL_SGONAK_Pos) |
| #define | USB_OTG_DCTL_SGONAK USB_OTG_DCTL_SGONAK_Msk |
| #define | USB_OTG_DCTL_CGONAK_Pos (10U) |
| #define | USB_OTG_DCTL_CGONAK_Msk (0x1UL << USB_OTG_DCTL_CGONAK_Pos) |
| #define | USB_OTG_DCTL_CGONAK USB_OTG_DCTL_CGONAK_Msk |
| #define | USB_OTG_DCTL_POPRGDNE_Pos (11U) |
| #define | USB_OTG_DCTL_POPRGDNE_Msk (0x1UL << USB_OTG_DCTL_POPRGDNE_Pos) |
| #define | USB_OTG_DCTL_POPRGDNE USB_OTG_DCTL_POPRGDNE_Msk |
| #define | USB_OTG_DCTL_ENCONTONBNA_Pos (17U) |
| #define | USB_OTG_DCTL_ENCONTONBNA_Msk (0x1UL << USB_OTG_DCTL_ENCONTONBNA_Pos) |
| #define | USB_OTG_DCTL_ENCONTONBNA USB_OTG_DCTL_ENCONTONBNA_Msk |
| #define | USB_OTG_DCTL_DSBESLRJCT_Pos (18U) |
| #define | USB_OTG_DCTL_DSBESLRJCT_Msk (0x1UL << USB_OTG_DCTL_DSBESLRJCT_Pos) |
| #define | USB_OTG_DCTL_DSBESLRJCT USB_OTG_DCTL_DSBESLRJCT_Msk |
| #define | USB_OTG_HFIR_FRIVL_Pos (0U) |
| #define | USB_OTG_HFIR_FRIVL_Msk (0xFFFFUL << USB_OTG_HFIR_FRIVL_Pos) |
| #define | USB_OTG_HFIR_FRIVL USB_OTG_HFIR_FRIVL_Msk |
| #define | USB_OTG_HFNUM_FRNUM_Pos (0U) |
| #define | USB_OTG_HFNUM_FRNUM_Msk (0xFFFFUL << USB_OTG_HFNUM_FRNUM_Pos) |
| #define | USB_OTG_HFNUM_FRNUM USB_OTG_HFNUM_FRNUM_Msk |
| #define | USB_OTG_HFNUM_FTREM_Pos (16U) |
| #define | USB_OTG_HFNUM_FTREM_Msk (0xFFFFUL << USB_OTG_HFNUM_FTREM_Pos) |
| #define | USB_OTG_HFNUM_FTREM USB_OTG_HFNUM_FTREM_Msk |
| #define | USB_OTG_DSTS_SUSPSTS_Pos (0U) |
| #define | USB_OTG_DSTS_SUSPSTS_Msk (0x1UL << USB_OTG_DSTS_SUSPSTS_Pos) |
| #define | USB_OTG_DSTS_SUSPSTS USB_OTG_DSTS_SUSPSTS_Msk |
| #define | USB_OTG_DSTS_ENUMSPD_Pos (1U) |
| #define | USB_OTG_DSTS_ENUMSPD_Msk (0x3UL << USB_OTG_DSTS_ENUMSPD_Pos) |
| #define | USB_OTG_DSTS_ENUMSPD USB_OTG_DSTS_ENUMSPD_Msk |
| #define | USB_OTG_DSTS_ENUMSPD_0 (0x1UL << USB_OTG_DSTS_ENUMSPD_Pos) |
| #define | USB_OTG_DSTS_ENUMSPD_1 (0x2UL << USB_OTG_DSTS_ENUMSPD_Pos) |
| #define | USB_OTG_DSTS_EERR_Pos (3U) |
| #define | USB_OTG_DSTS_EERR_Msk (0x1UL << USB_OTG_DSTS_EERR_Pos) |
| #define | USB_OTG_DSTS_EERR USB_OTG_DSTS_EERR_Msk |
| #define | USB_OTG_DSTS_FNSOF_Pos (8U) |
| #define | USB_OTG_DSTS_FNSOF_Msk (0x3FFFUL << USB_OTG_DSTS_FNSOF_Pos) |
| #define | USB_OTG_DSTS_FNSOF USB_OTG_DSTS_FNSOF_Msk |
| #define | USB_OTG_GAHBCFG_GINT_Pos (0U) |
| #define | USB_OTG_GAHBCFG_GINT_Msk (0x1UL << USB_OTG_GAHBCFG_GINT_Pos) |
| #define | USB_OTG_GAHBCFG_GINT USB_OTG_GAHBCFG_GINT_Msk |
| #define | USB_OTG_GAHBCFG_HBSTLEN_Pos (1U) |
| #define | USB_OTG_GAHBCFG_HBSTLEN_Msk (0xFUL << USB_OTG_GAHBCFG_HBSTLEN_Pos) |
| #define | USB_OTG_GAHBCFG_HBSTLEN USB_OTG_GAHBCFG_HBSTLEN_Msk |
| #define | USB_OTG_GAHBCFG_HBSTLEN_0 (0x0UL << USB_OTG_GAHBCFG_HBSTLEN_Pos) |
| #define | USB_OTG_GAHBCFG_HBSTLEN_1 (0x1UL << USB_OTG_GAHBCFG_HBSTLEN_Pos) |
| #define | USB_OTG_GAHBCFG_HBSTLEN_2 (0x3UL << USB_OTG_GAHBCFG_HBSTLEN_Pos) |
| #define | USB_OTG_GAHBCFG_HBSTLEN_3 (0x5UL << USB_OTG_GAHBCFG_HBSTLEN_Pos) |
| #define | USB_OTG_GAHBCFG_HBSTLEN_4 (0x7UL << USB_OTG_GAHBCFG_HBSTLEN_Pos) |
| #define | USB_OTG_GAHBCFG_DMAEN_Pos (5U) |
| #define | USB_OTG_GAHBCFG_DMAEN_Msk (0x1UL << USB_OTG_GAHBCFG_DMAEN_Pos) |
| #define | USB_OTG_GAHBCFG_DMAEN USB_OTG_GAHBCFG_DMAEN_Msk |
| #define | USB_OTG_GAHBCFG_TXFELVL_Pos (7U) |
| #define | USB_OTG_GAHBCFG_TXFELVL_Msk (0x1UL << USB_OTG_GAHBCFG_TXFELVL_Pos) |
| #define | USB_OTG_GAHBCFG_TXFELVL USB_OTG_GAHBCFG_TXFELVL_Msk |
| #define | USB_OTG_GAHBCFG_PTXFELVL_Pos (8U) |
| #define | USB_OTG_GAHBCFG_PTXFELVL_Msk (0x1UL << USB_OTG_GAHBCFG_PTXFELVL_Pos) |
| #define | USB_OTG_GAHBCFG_PTXFELVL USB_OTG_GAHBCFG_PTXFELVL_Msk |
| #define | USB_OTG_GUSBCFG_TOCAL_Pos (0U) |
| #define | USB_OTG_GUSBCFG_TOCAL_Msk (0x7UL << USB_OTG_GUSBCFG_TOCAL_Pos) |
| #define | USB_OTG_GUSBCFG_TOCAL USB_OTG_GUSBCFG_TOCAL_Msk |
| #define | USB_OTG_GUSBCFG_TOCAL_0 (0x1UL << USB_OTG_GUSBCFG_TOCAL_Pos) |
| #define | USB_OTG_GUSBCFG_TOCAL_1 (0x2UL << USB_OTG_GUSBCFG_TOCAL_Pos) |
| #define | USB_OTG_GUSBCFG_TOCAL_2 (0x4UL << USB_OTG_GUSBCFG_TOCAL_Pos) |
| #define | USB_OTG_GUSBCFG_PHYSEL_Pos (6U) |
| #define | USB_OTG_GUSBCFG_PHYSEL_Msk (0x1UL << USB_OTG_GUSBCFG_PHYSEL_Pos) |
| #define | USB_OTG_GUSBCFG_PHYSEL USB_OTG_GUSBCFG_PHYSEL_Msk |
| #define | USB_OTG_GUSBCFG_SRPCAP_Pos (8U) |
| #define | USB_OTG_GUSBCFG_SRPCAP_Msk (0x1UL << USB_OTG_GUSBCFG_SRPCAP_Pos) |
| #define | USB_OTG_GUSBCFG_SRPCAP USB_OTG_GUSBCFG_SRPCAP_Msk |
| #define | USB_OTG_GUSBCFG_HNPCAP_Pos (9U) |
| #define | USB_OTG_GUSBCFG_HNPCAP_Msk (0x1UL << USB_OTG_GUSBCFG_HNPCAP_Pos) |
| #define | USB_OTG_GUSBCFG_HNPCAP USB_OTG_GUSBCFG_HNPCAP_Msk |
| #define | USB_OTG_GUSBCFG_TRDT_Pos (10U) |
| #define | USB_OTG_GUSBCFG_TRDT_Msk (0xFUL << USB_OTG_GUSBCFG_TRDT_Pos) |
| #define | USB_OTG_GUSBCFG_TRDT USB_OTG_GUSBCFG_TRDT_Msk |
| #define | USB_OTG_GUSBCFG_TRDT_0 (0x1UL << USB_OTG_GUSBCFG_TRDT_Pos) |
| #define | USB_OTG_GUSBCFG_TRDT_1 (0x2UL << USB_OTG_GUSBCFG_TRDT_Pos) |
| #define | USB_OTG_GUSBCFG_TRDT_2 (0x4UL << USB_OTG_GUSBCFG_TRDT_Pos) |
| #define | USB_OTG_GUSBCFG_TRDT_3 (0x8UL << USB_OTG_GUSBCFG_TRDT_Pos) |
| #define | USB_OTG_GUSBCFG_PHYLPCS_Pos (15U) |
| #define | USB_OTG_GUSBCFG_PHYLPCS_Msk (0x1UL << USB_OTG_GUSBCFG_PHYLPCS_Pos) |
| #define | USB_OTG_GUSBCFG_PHYLPCS USB_OTG_GUSBCFG_PHYLPCS_Msk |
| #define | USB_OTG_GUSBCFG_ULPIFSLS_Pos (17U) |
| #define | USB_OTG_GUSBCFG_ULPIFSLS_Msk (0x1UL << USB_OTG_GUSBCFG_ULPIFSLS_Pos) |
| #define | USB_OTG_GUSBCFG_ULPIFSLS USB_OTG_GUSBCFG_ULPIFSLS_Msk |
| #define | USB_OTG_GUSBCFG_ULPIAR_Pos (18U) |
| #define | USB_OTG_GUSBCFG_ULPIAR_Msk (0x1UL << USB_OTG_GUSBCFG_ULPIAR_Pos) |
| #define | USB_OTG_GUSBCFG_ULPIAR USB_OTG_GUSBCFG_ULPIAR_Msk |
| #define | USB_OTG_GUSBCFG_ULPICSM_Pos (19U) |
| #define | USB_OTG_GUSBCFG_ULPICSM_Msk (0x1UL << USB_OTG_GUSBCFG_ULPICSM_Pos) |
| #define | USB_OTG_GUSBCFG_ULPICSM USB_OTG_GUSBCFG_ULPICSM_Msk |
| #define | USB_OTG_GUSBCFG_ULPIEVBUSD_Pos (20U) |
| #define | USB_OTG_GUSBCFG_ULPIEVBUSD_Msk (0x1UL << USB_OTG_GUSBCFG_ULPIEVBUSD_Pos) |
| #define | USB_OTG_GUSBCFG_ULPIEVBUSD USB_OTG_GUSBCFG_ULPIEVBUSD_Msk |
| #define | USB_OTG_GUSBCFG_ULPIEVBUSI_Pos (21U) |
| #define | USB_OTG_GUSBCFG_ULPIEVBUSI_Msk (0x1UL << USB_OTG_GUSBCFG_ULPIEVBUSI_Pos) |
| #define | USB_OTG_GUSBCFG_ULPIEVBUSI USB_OTG_GUSBCFG_ULPIEVBUSI_Msk |
| #define | USB_OTG_GUSBCFG_TSDPS_Pos (22U) |
| #define | USB_OTG_GUSBCFG_TSDPS_Msk (0x1UL << USB_OTG_GUSBCFG_TSDPS_Pos) |
| #define | USB_OTG_GUSBCFG_TSDPS USB_OTG_GUSBCFG_TSDPS_Msk |
| #define | USB_OTG_GUSBCFG_PCCI_Pos (23U) |
| #define | USB_OTG_GUSBCFG_PCCI_Msk (0x1UL << USB_OTG_GUSBCFG_PCCI_Pos) |
| #define | USB_OTG_GUSBCFG_PCCI USB_OTG_GUSBCFG_PCCI_Msk |
| #define | USB_OTG_GUSBCFG_PTCI_Pos (24U) |
| #define | USB_OTG_GUSBCFG_PTCI_Msk (0x1UL << USB_OTG_GUSBCFG_PTCI_Pos) |
| #define | USB_OTG_GUSBCFG_PTCI USB_OTG_GUSBCFG_PTCI_Msk |
| #define | USB_OTG_GUSBCFG_ULPIIPD_Pos (25U) |
| #define | USB_OTG_GUSBCFG_ULPIIPD_Msk (0x1UL << USB_OTG_GUSBCFG_ULPIIPD_Pos) |
| #define | USB_OTG_GUSBCFG_ULPIIPD USB_OTG_GUSBCFG_ULPIIPD_Msk |
| #define | USB_OTG_GUSBCFG_FHMOD_Pos (29U) |
| #define | USB_OTG_GUSBCFG_FHMOD_Msk (0x1UL << USB_OTG_GUSBCFG_FHMOD_Pos) |
| #define | USB_OTG_GUSBCFG_FHMOD USB_OTG_GUSBCFG_FHMOD_Msk |
| #define | USB_OTG_GUSBCFG_FDMOD_Pos (30U) |
| #define | USB_OTG_GUSBCFG_FDMOD_Msk (0x1UL << USB_OTG_GUSBCFG_FDMOD_Pos) |
| #define | USB_OTG_GUSBCFG_FDMOD USB_OTG_GUSBCFG_FDMOD_Msk |
| #define | USB_OTG_GUSBCFG_CTXPKT_Pos (31U) |
| #define | USB_OTG_GUSBCFG_CTXPKT_Msk (0x1UL << USB_OTG_GUSBCFG_CTXPKT_Pos) |
| #define | USB_OTG_GUSBCFG_CTXPKT USB_OTG_GUSBCFG_CTXPKT_Msk |
| #define | USB_OTG_GRSTCTL_CSRST_Pos (0U) |
| #define | USB_OTG_GRSTCTL_CSRST_Msk (0x1UL << USB_OTG_GRSTCTL_CSRST_Pos) |
| #define | USB_OTG_GRSTCTL_CSRST USB_OTG_GRSTCTL_CSRST_Msk |
| #define | USB_OTG_GRSTCTL_HSRST_Pos (1U) |
| #define | USB_OTG_GRSTCTL_HSRST_Msk (0x1UL << USB_OTG_GRSTCTL_HSRST_Pos) |
| #define | USB_OTG_GRSTCTL_HSRST USB_OTG_GRSTCTL_HSRST_Msk |
| #define | USB_OTG_GRSTCTL_FCRST_Pos (2U) |
| #define | USB_OTG_GRSTCTL_FCRST_Msk (0x1UL << USB_OTG_GRSTCTL_FCRST_Pos) |
| #define | USB_OTG_GRSTCTL_FCRST USB_OTG_GRSTCTL_FCRST_Msk |
| #define | USB_OTG_GRSTCTL_RXFFLSH_Pos (4U) |
| #define | USB_OTG_GRSTCTL_RXFFLSH_Msk (0x1UL << USB_OTG_GRSTCTL_RXFFLSH_Pos) |
| #define | USB_OTG_GRSTCTL_RXFFLSH USB_OTG_GRSTCTL_RXFFLSH_Msk |
| #define | USB_OTG_GRSTCTL_TXFFLSH_Pos (5U) |
| #define | USB_OTG_GRSTCTL_TXFFLSH_Msk (0x1UL << USB_OTG_GRSTCTL_TXFFLSH_Pos) |
| #define | USB_OTG_GRSTCTL_TXFFLSH USB_OTG_GRSTCTL_TXFFLSH_Msk |
| #define | USB_OTG_GRSTCTL_TXFNUM_Pos (6U) |
| #define | USB_OTG_GRSTCTL_TXFNUM_Msk (0x1FUL << USB_OTG_GRSTCTL_TXFNUM_Pos) |
| #define | USB_OTG_GRSTCTL_TXFNUM USB_OTG_GRSTCTL_TXFNUM_Msk |
| #define | USB_OTG_GRSTCTL_TXFNUM_0 (0x01UL << USB_OTG_GRSTCTL_TXFNUM_Pos) |
| #define | USB_OTG_GRSTCTL_TXFNUM_1 (0x02UL << USB_OTG_GRSTCTL_TXFNUM_Pos) |
| #define | USB_OTG_GRSTCTL_TXFNUM_2 (0x04UL << USB_OTG_GRSTCTL_TXFNUM_Pos) |
| #define | USB_OTG_GRSTCTL_TXFNUM_3 (0x08UL << USB_OTG_GRSTCTL_TXFNUM_Pos) |
| #define | USB_OTG_GRSTCTL_TXFNUM_4 (0x10UL << USB_OTG_GRSTCTL_TXFNUM_Pos) |
| #define | USB_OTG_GRSTCTL_DMAREQ_Pos (30U) |
| #define | USB_OTG_GRSTCTL_DMAREQ_Msk (0x1UL << USB_OTG_GRSTCTL_DMAREQ_Pos) |
| #define | USB_OTG_GRSTCTL_DMAREQ USB_OTG_GRSTCTL_DMAREQ_Msk |
| #define | USB_OTG_GRSTCTL_AHBIDL_Pos (31U) |
| #define | USB_OTG_GRSTCTL_AHBIDL_Msk (0x1UL << USB_OTG_GRSTCTL_AHBIDL_Pos) |
| #define | USB_OTG_GRSTCTL_AHBIDL USB_OTG_GRSTCTL_AHBIDL_Msk |
| #define | USB_OTG_DIEPMSK_XFRCM_Pos (0U) |
| #define | USB_OTG_DIEPMSK_XFRCM_Msk (0x1UL << USB_OTG_DIEPMSK_XFRCM_Pos) |
| #define | USB_OTG_DIEPMSK_XFRCM USB_OTG_DIEPMSK_XFRCM_Msk |
| #define | USB_OTG_DIEPMSK_EPDM_Pos (1U) |
| #define | USB_OTG_DIEPMSK_EPDM_Msk (0x1UL << USB_OTG_DIEPMSK_EPDM_Pos) |
| #define | USB_OTG_DIEPMSK_EPDM USB_OTG_DIEPMSK_EPDM_Msk |
| #define | USB_OTG_DIEPMSK_TOM_Pos (3U) |
| #define | USB_OTG_DIEPMSK_TOM_Msk (0x1UL << USB_OTG_DIEPMSK_TOM_Pos) |
| #define | USB_OTG_DIEPMSK_TOM USB_OTG_DIEPMSK_TOM_Msk |
| #define | USB_OTG_DIEPMSK_ITTXFEMSK_Pos (4U) |
| #define | USB_OTG_DIEPMSK_ITTXFEMSK_Msk (0x1UL << USB_OTG_DIEPMSK_ITTXFEMSK_Pos) |
| #define | USB_OTG_DIEPMSK_ITTXFEMSK USB_OTG_DIEPMSK_ITTXFEMSK_Msk |
| #define | USB_OTG_DIEPMSK_INEPNMM_Pos (5U) |
| #define | USB_OTG_DIEPMSK_INEPNMM_Msk (0x1UL << USB_OTG_DIEPMSK_INEPNMM_Pos) |
| #define | USB_OTG_DIEPMSK_INEPNMM USB_OTG_DIEPMSK_INEPNMM_Msk |
| #define | USB_OTG_DIEPMSK_INEPNEM_Pos (6U) |
| #define | USB_OTG_DIEPMSK_INEPNEM_Msk (0x1UL << USB_OTG_DIEPMSK_INEPNEM_Pos) |
| #define | USB_OTG_DIEPMSK_INEPNEM USB_OTG_DIEPMSK_INEPNEM_Msk |
| #define | USB_OTG_DIEPMSK_TXFURM_Pos (8U) |
| #define | USB_OTG_DIEPMSK_TXFURM_Msk (0x1UL << USB_OTG_DIEPMSK_TXFURM_Pos) |
| #define | USB_OTG_DIEPMSK_TXFURM USB_OTG_DIEPMSK_TXFURM_Msk |
| #define | USB_OTG_DIEPMSK_BIM_Pos (9U) |
| #define | USB_OTG_DIEPMSK_BIM_Msk (0x1UL << USB_OTG_DIEPMSK_BIM_Pos) |
| #define | USB_OTG_DIEPMSK_BIM USB_OTG_DIEPMSK_BIM_Msk |
| #define | USB_OTG_HPTXSTS_PTXFSAVL_Pos (0U) |
| #define | USB_OTG_HPTXSTS_PTXFSAVL_Msk (0xFFFFUL << USB_OTG_HPTXSTS_PTXFSAVL_Pos) |
| #define | USB_OTG_HPTXSTS_PTXFSAVL USB_OTG_HPTXSTS_PTXFSAVL_Msk |
| #define | USB_OTG_HPTXSTS_PTXQSAV_Pos (16U) |
| #define | USB_OTG_HPTXSTS_PTXQSAV_Msk (0xFFUL << USB_OTG_HPTXSTS_PTXQSAV_Pos) |
| #define | USB_OTG_HPTXSTS_PTXQSAV USB_OTG_HPTXSTS_PTXQSAV_Msk |
| #define | USB_OTG_HPTXSTS_PTXQSAV_0 (0x01UL << USB_OTG_HPTXSTS_PTXQSAV_Pos) |
| #define | USB_OTG_HPTXSTS_PTXQSAV_1 (0x02UL << USB_OTG_HPTXSTS_PTXQSAV_Pos) |
| #define | USB_OTG_HPTXSTS_PTXQSAV_2 (0x04UL << USB_OTG_HPTXSTS_PTXQSAV_Pos) |
| #define | USB_OTG_HPTXSTS_PTXQSAV_3 (0x08UL << USB_OTG_HPTXSTS_PTXQSAV_Pos) |
| #define | USB_OTG_HPTXSTS_PTXQSAV_4 (0x10UL << USB_OTG_HPTXSTS_PTXQSAV_Pos) |
| #define | USB_OTG_HPTXSTS_PTXQSAV_5 (0x20UL << USB_OTG_HPTXSTS_PTXQSAV_Pos) |
| #define | USB_OTG_HPTXSTS_PTXQSAV_6 (0x40UL << USB_OTG_HPTXSTS_PTXQSAV_Pos) |
| #define | USB_OTG_HPTXSTS_PTXQSAV_7 (0x80UL << USB_OTG_HPTXSTS_PTXQSAV_Pos) |
| #define | USB_OTG_HPTXSTS_PTXQTOP_Pos (24U) |
| #define | USB_OTG_HPTXSTS_PTXQTOP_Msk (0xFFUL << USB_OTG_HPTXSTS_PTXQTOP_Pos) |
| #define | USB_OTG_HPTXSTS_PTXQTOP USB_OTG_HPTXSTS_PTXQTOP_Msk |
| #define | USB_OTG_HPTXSTS_PTXQTOP_0 (0x01UL << USB_OTG_HPTXSTS_PTXQTOP_Pos) |
| #define | USB_OTG_HPTXSTS_PTXQTOP_1 (0x02UL << USB_OTG_HPTXSTS_PTXQTOP_Pos) |
| #define | USB_OTG_HPTXSTS_PTXQTOP_2 (0x04UL << USB_OTG_HPTXSTS_PTXQTOP_Pos) |
| #define | USB_OTG_HPTXSTS_PTXQTOP_3 (0x08UL << USB_OTG_HPTXSTS_PTXQTOP_Pos) |
| #define | USB_OTG_HPTXSTS_PTXQTOP_4 (0x10UL << USB_OTG_HPTXSTS_PTXQTOP_Pos) |
| #define | USB_OTG_HPTXSTS_PTXQTOP_5 (0x20UL << USB_OTG_HPTXSTS_PTXQTOP_Pos) |
| #define | USB_OTG_HPTXSTS_PTXQTOP_6 (0x40UL << USB_OTG_HPTXSTS_PTXQTOP_Pos) |
| #define | USB_OTG_HPTXSTS_PTXQTOP_7 (0x80UL << USB_OTG_HPTXSTS_PTXQTOP_Pos) |
| #define | USB_OTG_HAINT_HAINT_Pos (0U) |
| #define | USB_OTG_HAINT_HAINT_Msk (0xFFFFUL << USB_OTG_HAINT_HAINT_Pos) |
| #define | USB_OTG_HAINT_HAINT USB_OTG_HAINT_HAINT_Msk |
| #define | USB_OTG_DOEPMSK_XFRCM_Pos (0U) |
| #define | USB_OTG_DOEPMSK_XFRCM_Msk (0x1UL << USB_OTG_DOEPMSK_XFRCM_Pos) |
| #define | USB_OTG_DOEPMSK_XFRCM USB_OTG_DOEPMSK_XFRCM_Msk |
| #define | USB_OTG_DOEPMSK_EPDM_Pos (1U) |
| #define | USB_OTG_DOEPMSK_EPDM_Msk (0x1UL << USB_OTG_DOEPMSK_EPDM_Pos) |
| #define | USB_OTG_DOEPMSK_EPDM USB_OTG_DOEPMSK_EPDM_Msk |
| #define | USB_OTG_DOEPMSK_AHBERRM_Pos (2U) |
| #define | USB_OTG_DOEPMSK_AHBERRM_Msk (0x1UL << USB_OTG_DOEPMSK_AHBERRM_Pos) |
| #define | USB_OTG_DOEPMSK_AHBERRM USB_OTG_DOEPMSK_AHBERRM_Msk |
| #define | USB_OTG_DOEPMSK_STUPM_Pos (3U) |
| #define | USB_OTG_DOEPMSK_STUPM_Msk (0x1UL << USB_OTG_DOEPMSK_STUPM_Pos) |
| #define | USB_OTG_DOEPMSK_STUPM USB_OTG_DOEPMSK_STUPM_Msk |
| #define | USB_OTG_DOEPMSK_OTEPDM_Pos (4U) |
| #define | USB_OTG_DOEPMSK_OTEPDM_Msk (0x1UL << USB_OTG_DOEPMSK_OTEPDM_Pos) |
| #define | USB_OTG_DOEPMSK_OTEPDM USB_OTG_DOEPMSK_OTEPDM_Msk |
| #define | USB_OTG_DOEPMSK_OTEPSPRM_Pos (5U) |
| #define | USB_OTG_DOEPMSK_OTEPSPRM_Msk (0x1UL << USB_OTG_DOEPMSK_OTEPSPRM_Pos) |
| #define | USB_OTG_DOEPMSK_OTEPSPRM USB_OTG_DOEPMSK_OTEPSPRM_Msk |
| #define | USB_OTG_DOEPMSK_B2BSTUP_Pos (6U) |
| #define | USB_OTG_DOEPMSK_B2BSTUP_Msk (0x1UL << USB_OTG_DOEPMSK_B2BSTUP_Pos) |
| #define | USB_OTG_DOEPMSK_B2BSTUP USB_OTG_DOEPMSK_B2BSTUP_Msk |
| #define | USB_OTG_DOEPMSK_OPEM_Pos (8U) |
| #define | USB_OTG_DOEPMSK_OPEM_Msk (0x1UL << USB_OTG_DOEPMSK_OPEM_Pos) |
| #define | USB_OTG_DOEPMSK_OPEM USB_OTG_DOEPMSK_OPEM_Msk |
| #define | USB_OTG_DOEPMSK_BOIM_Pos (9U) |
| #define | USB_OTG_DOEPMSK_BOIM_Msk (0x1UL << USB_OTG_DOEPMSK_BOIM_Pos) |
| #define | USB_OTG_DOEPMSK_BOIM USB_OTG_DOEPMSK_BOIM_Msk |
| #define | USB_OTG_DOEPMSK_BERRM_Pos (12U) |
| #define | USB_OTG_DOEPMSK_BERRM_Msk (0x1UL << USB_OTG_DOEPMSK_BERRM_Pos) |
| #define | USB_OTG_DOEPMSK_BERRM USB_OTG_DOEPMSK_BERRM_Msk |
| #define | USB_OTG_DOEPMSK_NAKM_Pos (13U) |
| #define | USB_OTG_DOEPMSK_NAKM_Msk (0x1UL << USB_OTG_DOEPMSK_NAKM_Pos) |
| #define | USB_OTG_DOEPMSK_NAKM USB_OTG_DOEPMSK_NAKM_Msk |
| #define | USB_OTG_DOEPMSK_NYETM_Pos (14U) |
| #define | USB_OTG_DOEPMSK_NYETM_Msk (0x1UL << USB_OTG_DOEPMSK_NYETM_Pos) |
| #define | USB_OTG_DOEPMSK_NYETM USB_OTG_DOEPMSK_NYETM_Msk |
| #define | USB_OTG_GINTSTS_CMOD_Pos (0U) |
| #define | USB_OTG_GINTSTS_CMOD_Msk (0x1UL << USB_OTG_GINTSTS_CMOD_Pos) |
| #define | USB_OTG_GINTSTS_CMOD USB_OTG_GINTSTS_CMOD_Msk |
| #define | USB_OTG_GINTSTS_MMIS_Pos (1U) |
| #define | USB_OTG_GINTSTS_MMIS_Msk (0x1UL << USB_OTG_GINTSTS_MMIS_Pos) |
| #define | USB_OTG_GINTSTS_MMIS USB_OTG_GINTSTS_MMIS_Msk |
| #define | USB_OTG_GINTSTS_OTGINT_Pos (2U) |
| #define | USB_OTG_GINTSTS_OTGINT_Msk (0x1UL << USB_OTG_GINTSTS_OTGINT_Pos) |
| #define | USB_OTG_GINTSTS_OTGINT USB_OTG_GINTSTS_OTGINT_Msk |
| #define | USB_OTG_GINTSTS_SOF_Pos (3U) |
| #define | USB_OTG_GINTSTS_SOF_Msk (0x1UL << USB_OTG_GINTSTS_SOF_Pos) |
| #define | USB_OTG_GINTSTS_SOF USB_OTG_GINTSTS_SOF_Msk |
| #define | USB_OTG_GINTSTS_RXFLVL_Pos (4U) |
| #define | USB_OTG_GINTSTS_RXFLVL_Msk (0x1UL << USB_OTG_GINTSTS_RXFLVL_Pos) |
| #define | USB_OTG_GINTSTS_RXFLVL USB_OTG_GINTSTS_RXFLVL_Msk |
| #define | USB_OTG_GINTSTS_NPTXFE_Pos (5U) |
| #define | USB_OTG_GINTSTS_NPTXFE_Msk (0x1UL << USB_OTG_GINTSTS_NPTXFE_Pos) |
| #define | USB_OTG_GINTSTS_NPTXFE USB_OTG_GINTSTS_NPTXFE_Msk |
| #define | USB_OTG_GINTSTS_GINAKEFF_Pos (6U) |
| #define | USB_OTG_GINTSTS_GINAKEFF_Msk (0x1UL << USB_OTG_GINTSTS_GINAKEFF_Pos) |
| #define | USB_OTG_GINTSTS_GINAKEFF USB_OTG_GINTSTS_GINAKEFF_Msk |
| #define | USB_OTG_GINTSTS_BOUTNAKEFF_Pos (7U) |
| #define | USB_OTG_GINTSTS_BOUTNAKEFF_Msk (0x1UL << USB_OTG_GINTSTS_BOUTNAKEFF_Pos) |
| #define | USB_OTG_GINTSTS_BOUTNAKEFF USB_OTG_GINTSTS_BOUTNAKEFF_Msk |
| #define | USB_OTG_GINTSTS_ESUSP_Pos (10U) |
| #define | USB_OTG_GINTSTS_ESUSP_Msk (0x1UL << USB_OTG_GINTSTS_ESUSP_Pos) |
| #define | USB_OTG_GINTSTS_ESUSP USB_OTG_GINTSTS_ESUSP_Msk |
| #define | USB_OTG_GINTSTS_USBSUSP_Pos (11U) |
| #define | USB_OTG_GINTSTS_USBSUSP_Msk (0x1UL << USB_OTG_GINTSTS_USBSUSP_Pos) |
| #define | USB_OTG_GINTSTS_USBSUSP USB_OTG_GINTSTS_USBSUSP_Msk |
| #define | USB_OTG_GINTSTS_USBRST_Pos (12U) |
| #define | USB_OTG_GINTSTS_USBRST_Msk (0x1UL << USB_OTG_GINTSTS_USBRST_Pos) |
| #define | USB_OTG_GINTSTS_USBRST USB_OTG_GINTSTS_USBRST_Msk |
| #define | USB_OTG_GINTSTS_ENUMDNE_Pos (13U) |
| #define | USB_OTG_GINTSTS_ENUMDNE_Msk (0x1UL << USB_OTG_GINTSTS_ENUMDNE_Pos) |
| #define | USB_OTG_GINTSTS_ENUMDNE USB_OTG_GINTSTS_ENUMDNE_Msk |
| #define | USB_OTG_GINTSTS_ISOODRP_Pos (14U) |
| #define | USB_OTG_GINTSTS_ISOODRP_Msk (0x1UL << USB_OTG_GINTSTS_ISOODRP_Pos) |
| #define | USB_OTG_GINTSTS_ISOODRP USB_OTG_GINTSTS_ISOODRP_Msk |
| #define | USB_OTG_GINTSTS_EOPF_Pos (15U) |
| #define | USB_OTG_GINTSTS_EOPF_Msk (0x1UL << USB_OTG_GINTSTS_EOPF_Pos) |
| #define | USB_OTG_GINTSTS_EOPF USB_OTG_GINTSTS_EOPF_Msk |
| #define | USB_OTG_GINTSTS_IEPINT_Pos (18U) |
| #define | USB_OTG_GINTSTS_IEPINT_Msk (0x1UL << USB_OTG_GINTSTS_IEPINT_Pos) |
| #define | USB_OTG_GINTSTS_IEPINT USB_OTG_GINTSTS_IEPINT_Msk |
| #define | USB_OTG_GINTSTS_OEPINT_Pos (19U) |
| #define | USB_OTG_GINTSTS_OEPINT_Msk (0x1UL << USB_OTG_GINTSTS_OEPINT_Pos) |
| #define | USB_OTG_GINTSTS_OEPINT USB_OTG_GINTSTS_OEPINT_Msk |
| #define | USB_OTG_GINTSTS_IISOIXFR_Pos (20U) |
| #define | USB_OTG_GINTSTS_IISOIXFR_Msk (0x1UL << USB_OTG_GINTSTS_IISOIXFR_Pos) |
| #define | USB_OTG_GINTSTS_IISOIXFR USB_OTG_GINTSTS_IISOIXFR_Msk |
| #define | USB_OTG_GINTSTS_PXFR_INCOMPISOOUT_Pos (21U) |
| #define | USB_OTG_GINTSTS_PXFR_INCOMPISOOUT_Msk (0x1UL << USB_OTG_GINTSTS_PXFR_INCOMPISOOUT_Pos) |
| #define | USB_OTG_GINTSTS_PXFR_INCOMPISOOUT USB_OTG_GINTSTS_PXFR_INCOMPISOOUT_Msk |
| #define | USB_OTG_GINTSTS_DATAFSUSP_Pos (22U) |
| #define | USB_OTG_GINTSTS_DATAFSUSP_Msk (0x1UL << USB_OTG_GINTSTS_DATAFSUSP_Pos) |
| #define | USB_OTG_GINTSTS_DATAFSUSP USB_OTG_GINTSTS_DATAFSUSP_Msk |
| #define | USB_OTG_GINTSTS_RSTDET_Pos (23U) |
| #define | USB_OTG_GINTSTS_RSTDET_Msk (0x1UL << USB_OTG_GINTSTS_RSTDET_Pos) |
| #define | USB_OTG_GINTSTS_RSTDET USB_OTG_GINTSTS_RSTDET_Msk |
| #define | USB_OTG_GINTSTS_HPRTINT_Pos (24U) |
| #define | USB_OTG_GINTSTS_HPRTINT_Msk (0x1UL << USB_OTG_GINTSTS_HPRTINT_Pos) |
| #define | USB_OTG_GINTSTS_HPRTINT USB_OTG_GINTSTS_HPRTINT_Msk |
| #define | USB_OTG_GINTSTS_HCINT_Pos (25U) |
| #define | USB_OTG_GINTSTS_HCINT_Msk (0x1UL << USB_OTG_GINTSTS_HCINT_Pos) |
| #define | USB_OTG_GINTSTS_HCINT USB_OTG_GINTSTS_HCINT_Msk |
| #define | USB_OTG_GINTSTS_PTXFE_Pos (26U) |
| #define | USB_OTG_GINTSTS_PTXFE_Msk (0x1UL << USB_OTG_GINTSTS_PTXFE_Pos) |
| #define | USB_OTG_GINTSTS_PTXFE USB_OTG_GINTSTS_PTXFE_Msk |
| #define | USB_OTG_GINTSTS_LPMINT_Pos (27U) |
| #define | USB_OTG_GINTSTS_LPMINT_Msk (0x1UL << USB_OTG_GINTSTS_LPMINT_Pos) |
| #define | USB_OTG_GINTSTS_LPMINT USB_OTG_GINTSTS_LPMINT_Msk |
| #define | USB_OTG_GINTSTS_CIDSCHG_Pos (28U) |
| #define | USB_OTG_GINTSTS_CIDSCHG_Msk (0x1UL << USB_OTG_GINTSTS_CIDSCHG_Pos) |
| #define | USB_OTG_GINTSTS_CIDSCHG USB_OTG_GINTSTS_CIDSCHG_Msk |
| #define | USB_OTG_GINTSTS_DISCINT_Pos (29U) |
| #define | USB_OTG_GINTSTS_DISCINT_Msk (0x1UL << USB_OTG_GINTSTS_DISCINT_Pos) |
| #define | USB_OTG_GINTSTS_DISCINT USB_OTG_GINTSTS_DISCINT_Msk |
| #define | USB_OTG_GINTSTS_SRQINT_Pos (30U) |
| #define | USB_OTG_GINTSTS_SRQINT_Msk (0x1UL << USB_OTG_GINTSTS_SRQINT_Pos) |
| #define | USB_OTG_GINTSTS_SRQINT USB_OTG_GINTSTS_SRQINT_Msk |
| #define | USB_OTG_GINTSTS_WKUINT_Pos (31U) |
| #define | USB_OTG_GINTSTS_WKUINT_Msk (0x1UL << USB_OTG_GINTSTS_WKUINT_Pos) |
| #define | USB_OTG_GINTSTS_WKUINT USB_OTG_GINTSTS_WKUINT_Msk |
| #define | USB_OTG_GINTMSK_MMISM_Pos (1U) |
| #define | USB_OTG_GINTMSK_MMISM_Msk (0x1UL << USB_OTG_GINTMSK_MMISM_Pos) |
| #define | USB_OTG_GINTMSK_MMISM USB_OTG_GINTMSK_MMISM_Msk |
| #define | USB_OTG_GINTMSK_OTGINT_Pos (2U) |
| #define | USB_OTG_GINTMSK_OTGINT_Msk (0x1UL << USB_OTG_GINTMSK_OTGINT_Pos) |
| #define | USB_OTG_GINTMSK_OTGINT USB_OTG_GINTMSK_OTGINT_Msk |
| #define | USB_OTG_GINTMSK_SOFM_Pos (3U) |
| #define | USB_OTG_GINTMSK_SOFM_Msk (0x1UL << USB_OTG_GINTMSK_SOFM_Pos) |
| #define | USB_OTG_GINTMSK_SOFM USB_OTG_GINTMSK_SOFM_Msk |
| #define | USB_OTG_GINTMSK_RXFLVLM_Pos (4U) |
| #define | USB_OTG_GINTMSK_RXFLVLM_Msk (0x1UL << USB_OTG_GINTMSK_RXFLVLM_Pos) |
| #define | USB_OTG_GINTMSK_RXFLVLM USB_OTG_GINTMSK_RXFLVLM_Msk |
| #define | USB_OTG_GINTMSK_NPTXFEM_Pos (5U) |
| #define | USB_OTG_GINTMSK_NPTXFEM_Msk (0x1UL << USB_OTG_GINTMSK_NPTXFEM_Pos) |
| #define | USB_OTG_GINTMSK_NPTXFEM USB_OTG_GINTMSK_NPTXFEM_Msk |
| #define | USB_OTG_GINTMSK_GINAKEFFM_Pos (6U) |
| #define | USB_OTG_GINTMSK_GINAKEFFM_Msk (0x1UL << USB_OTG_GINTMSK_GINAKEFFM_Pos) |
| #define | USB_OTG_GINTMSK_GINAKEFFM USB_OTG_GINTMSK_GINAKEFFM_Msk |
| #define | USB_OTG_GINTMSK_GONAKEFFM_Pos (7U) |
| #define | USB_OTG_GINTMSK_GONAKEFFM_Msk (0x1UL << USB_OTG_GINTMSK_GONAKEFFM_Pos) |
| #define | USB_OTG_GINTMSK_GONAKEFFM USB_OTG_GINTMSK_GONAKEFFM_Msk |
| #define | USB_OTG_GINTMSK_ESUSPM_Pos (10U) |
| #define | USB_OTG_GINTMSK_ESUSPM_Msk (0x1UL << USB_OTG_GINTMSK_ESUSPM_Pos) |
| #define | USB_OTG_GINTMSK_ESUSPM USB_OTG_GINTMSK_ESUSPM_Msk |
| #define | USB_OTG_GINTMSK_USBSUSPM_Pos (11U) |
| #define | USB_OTG_GINTMSK_USBSUSPM_Msk (0x1UL << USB_OTG_GINTMSK_USBSUSPM_Pos) |
| #define | USB_OTG_GINTMSK_USBSUSPM USB_OTG_GINTMSK_USBSUSPM_Msk |
| #define | USB_OTG_GINTMSK_USBRST_Pos (12U) |
| #define | USB_OTG_GINTMSK_USBRST_Msk (0x1UL << USB_OTG_GINTMSK_USBRST_Pos) |
| #define | USB_OTG_GINTMSK_USBRST USB_OTG_GINTMSK_USBRST_Msk |
| #define | USB_OTG_GINTMSK_ENUMDNEM_Pos (13U) |
| #define | USB_OTG_GINTMSK_ENUMDNEM_Msk (0x1UL << USB_OTG_GINTMSK_ENUMDNEM_Pos) |
| #define | USB_OTG_GINTMSK_ENUMDNEM USB_OTG_GINTMSK_ENUMDNEM_Msk |
| #define | USB_OTG_GINTMSK_ISOODRPM_Pos (14U) |
| #define | USB_OTG_GINTMSK_ISOODRPM_Msk (0x1UL << USB_OTG_GINTMSK_ISOODRPM_Pos) |
| #define | USB_OTG_GINTMSK_ISOODRPM USB_OTG_GINTMSK_ISOODRPM_Msk |
| #define | USB_OTG_GINTMSK_EOPFM_Pos (15U) |
| #define | USB_OTG_GINTMSK_EOPFM_Msk (0x1UL << USB_OTG_GINTMSK_EOPFM_Pos) |
| #define | USB_OTG_GINTMSK_EOPFM USB_OTG_GINTMSK_EOPFM_Msk |
| #define | USB_OTG_GINTMSK_EPMISM_Pos (17U) |
| #define | USB_OTG_GINTMSK_EPMISM_Msk (0x1UL << USB_OTG_GINTMSK_EPMISM_Pos) |
| #define | USB_OTG_GINTMSK_EPMISM USB_OTG_GINTMSK_EPMISM_Msk |
| #define | USB_OTG_GINTMSK_IEPINT_Pos (18U) |
| #define | USB_OTG_GINTMSK_IEPINT_Msk (0x1UL << USB_OTG_GINTMSK_IEPINT_Pos) |
| #define | USB_OTG_GINTMSK_IEPINT USB_OTG_GINTMSK_IEPINT_Msk |
| #define | USB_OTG_GINTMSK_OEPINT_Pos (19U) |
| #define | USB_OTG_GINTMSK_OEPINT_Msk (0x1UL << USB_OTG_GINTMSK_OEPINT_Pos) |
| #define | USB_OTG_GINTMSK_OEPINT USB_OTG_GINTMSK_OEPINT_Msk |
| #define | USB_OTG_GINTMSK_IISOIXFRM_Pos (20U) |
| #define | USB_OTG_GINTMSK_IISOIXFRM_Msk (0x1UL << USB_OTG_GINTMSK_IISOIXFRM_Pos) |
| #define | USB_OTG_GINTMSK_IISOIXFRM USB_OTG_GINTMSK_IISOIXFRM_Msk |
| #define | USB_OTG_GINTMSK_PXFRM_IISOOXFRM_Pos (21U) |
| #define | USB_OTG_GINTMSK_PXFRM_IISOOXFRM_Msk (0x1UL << USB_OTG_GINTMSK_PXFRM_IISOOXFRM_Pos) |
| #define | USB_OTG_GINTMSK_PXFRM_IISOOXFRM USB_OTG_GINTMSK_PXFRM_IISOOXFRM_Msk |
| #define | USB_OTG_GINTMSK_FSUSPM_Pos (22U) |
| #define | USB_OTG_GINTMSK_FSUSPM_Msk (0x1UL << USB_OTG_GINTMSK_FSUSPM_Pos) |
| #define | USB_OTG_GINTMSK_FSUSPM USB_OTG_GINTMSK_FSUSPM_Msk |
| #define | USB_OTG_GINTMSK_RSTDEM_Pos (23U) |
| #define | USB_OTG_GINTMSK_RSTDEM_Msk (0x1UL << USB_OTG_GINTMSK_RSTDEM_Pos) |
| #define | USB_OTG_GINTMSK_RSTDEM USB_OTG_GINTMSK_RSTDEM_Msk |
| #define | USB_OTG_GINTMSK_PRTIM_Pos (24U) |
| #define | USB_OTG_GINTMSK_PRTIM_Msk (0x1UL << USB_OTG_GINTMSK_PRTIM_Pos) |
| #define | USB_OTG_GINTMSK_PRTIM USB_OTG_GINTMSK_PRTIM_Msk |
| #define | USB_OTG_GINTMSK_HCIM_Pos (25U) |
| #define | USB_OTG_GINTMSK_HCIM_Msk (0x1UL << USB_OTG_GINTMSK_HCIM_Pos) |
| #define | USB_OTG_GINTMSK_HCIM USB_OTG_GINTMSK_HCIM_Msk |
| #define | USB_OTG_GINTMSK_PTXFEM_Pos (26U) |
| #define | USB_OTG_GINTMSK_PTXFEM_Msk (0x1UL << USB_OTG_GINTMSK_PTXFEM_Pos) |
| #define | USB_OTG_GINTMSK_PTXFEM USB_OTG_GINTMSK_PTXFEM_Msk |
| #define | USB_OTG_GINTMSK_LPMINTM_Pos (27U) |
| #define | USB_OTG_GINTMSK_LPMINTM_Msk (0x1UL << USB_OTG_GINTMSK_LPMINTM_Pos) |
| #define | USB_OTG_GINTMSK_LPMINTM USB_OTG_GINTMSK_LPMINTM_Msk |
| #define | USB_OTG_GINTMSK_CIDSCHGM_Pos (28U) |
| #define | USB_OTG_GINTMSK_CIDSCHGM_Msk (0x1UL << USB_OTG_GINTMSK_CIDSCHGM_Pos) |
| #define | USB_OTG_GINTMSK_CIDSCHGM USB_OTG_GINTMSK_CIDSCHGM_Msk |
| #define | USB_OTG_GINTMSK_DISCINT_Pos (29U) |
| #define | USB_OTG_GINTMSK_DISCINT_Msk (0x1UL << USB_OTG_GINTMSK_DISCINT_Pos) |
| #define | USB_OTG_GINTMSK_DISCINT USB_OTG_GINTMSK_DISCINT_Msk |
| #define | USB_OTG_GINTMSK_SRQIM_Pos (30U) |
| #define | USB_OTG_GINTMSK_SRQIM_Msk (0x1UL << USB_OTG_GINTMSK_SRQIM_Pos) |
| #define | USB_OTG_GINTMSK_SRQIM USB_OTG_GINTMSK_SRQIM_Msk |
| #define | USB_OTG_GINTMSK_WUIM_Pos (31U) |
| #define | USB_OTG_GINTMSK_WUIM_Msk (0x1UL << USB_OTG_GINTMSK_WUIM_Pos) |
| #define | USB_OTG_GINTMSK_WUIM USB_OTG_GINTMSK_WUIM_Msk |
| #define | USB_OTG_DAINT_IEPINT_Pos (0U) |
| #define | USB_OTG_DAINT_IEPINT_Msk (0xFFFFUL << USB_OTG_DAINT_IEPINT_Pos) |
| #define | USB_OTG_DAINT_IEPINT USB_OTG_DAINT_IEPINT_Msk |
| #define | USB_OTG_DAINT_OEPINT_Pos (16U) |
| #define | USB_OTG_DAINT_OEPINT_Msk (0xFFFFUL << USB_OTG_DAINT_OEPINT_Pos) |
| #define | USB_OTG_DAINT_OEPINT USB_OTG_DAINT_OEPINT_Msk |
| #define | USB_OTG_HAINTMSK_HAINTM_Pos (0U) |
| #define | USB_OTG_HAINTMSK_HAINTM_Msk (0xFFFFUL << USB_OTG_HAINTMSK_HAINTM_Pos) |
| #define | USB_OTG_HAINTMSK_HAINTM USB_OTG_HAINTMSK_HAINTM_Msk |
| #define | USB_OTG_GRXSTSP_EPNUM_Pos (0U) |
| #define | USB_OTG_GRXSTSP_EPNUM_Msk (0xFUL << USB_OTG_GRXSTSP_EPNUM_Pos) |
| #define | USB_OTG_GRXSTSP_EPNUM USB_OTG_GRXSTSP_EPNUM_Msk |
| #define | USB_OTG_GRXSTSP_BCNT_Pos (4U) |
| #define | USB_OTG_GRXSTSP_BCNT_Msk (0x7FFUL << USB_OTG_GRXSTSP_BCNT_Pos) |
| #define | USB_OTG_GRXSTSP_BCNT USB_OTG_GRXSTSP_BCNT_Msk |
| #define | USB_OTG_GRXSTSP_DPID_Pos (15U) |
| #define | USB_OTG_GRXSTSP_DPID_Msk (0x3UL << USB_OTG_GRXSTSP_DPID_Pos) |
| #define | USB_OTG_GRXSTSP_DPID USB_OTG_GRXSTSP_DPID_Msk |
| #define | USB_OTG_GRXSTSP_PKTSTS_Pos (17U) |
| #define | USB_OTG_GRXSTSP_PKTSTS_Msk (0xFUL << USB_OTG_GRXSTSP_PKTSTS_Pos) |
| #define | USB_OTG_GRXSTSP_PKTSTS USB_OTG_GRXSTSP_PKTSTS_Msk |
| #define | USB_OTG_DAINTMSK_IEPM_Pos (0U) |
| #define | USB_OTG_DAINTMSK_IEPM_Msk (0xFFFFUL << USB_OTG_DAINTMSK_IEPM_Pos) |
| #define | USB_OTG_DAINTMSK_IEPM USB_OTG_DAINTMSK_IEPM_Msk |
| #define | USB_OTG_DAINTMSK_OEPM_Pos (16U) |
| #define | USB_OTG_DAINTMSK_OEPM_Msk (0xFFFFUL << USB_OTG_DAINTMSK_OEPM_Pos) |
| #define | USB_OTG_DAINTMSK_OEPM USB_OTG_DAINTMSK_OEPM_Msk |
| #define | USB_OTG_CHNUM_Pos (0U) |
| #define | USB_OTG_CHNUM_Msk (0xFUL << USB_OTG_CHNUM_Pos) |
| #define | USB_OTG_CHNUM USB_OTG_CHNUM_Msk |
| #define | USB_OTG_CHNUM_0 (0x1UL << USB_OTG_CHNUM_Pos) |
| #define | USB_OTG_CHNUM_1 (0x2UL << USB_OTG_CHNUM_Pos) |
| #define | USB_OTG_CHNUM_2 (0x4UL << USB_OTG_CHNUM_Pos) |
| #define | USB_OTG_CHNUM_3 (0x8UL << USB_OTG_CHNUM_Pos) |
| #define | USB_OTG_BCNT_Pos (4U) |
| #define | USB_OTG_BCNT_Msk (0x7FFUL << USB_OTG_BCNT_Pos) |
| #define | USB_OTG_BCNT USB_OTG_BCNT_Msk |
| #define | USB_OTG_DPID_Pos (15U) |
| #define | USB_OTG_DPID_Msk (0x3UL << USB_OTG_DPID_Pos) |
| #define | USB_OTG_DPID USB_OTG_DPID_Msk |
| #define | USB_OTG_DPID_0 (0x1UL << USB_OTG_DPID_Pos) |
| #define | USB_OTG_DPID_1 (0x2UL << USB_OTG_DPID_Pos) |
| #define | USB_OTG_PKTSTS_Pos (17U) |
| #define | USB_OTG_PKTSTS_Msk (0xFUL << USB_OTG_PKTSTS_Pos) |
| #define | USB_OTG_PKTSTS USB_OTG_PKTSTS_Msk |
| #define | USB_OTG_PKTSTS_0 (0x1UL << USB_OTG_PKTSTS_Pos) |
| #define | USB_OTG_PKTSTS_1 (0x2UL << USB_OTG_PKTSTS_Pos) |
| #define | USB_OTG_PKTSTS_2 (0x4UL << USB_OTG_PKTSTS_Pos) |
| #define | USB_OTG_PKTSTS_3 (0x8UL << USB_OTG_PKTSTS_Pos) |
| #define | USB_OTG_EPNUM_Pos (0U) |
| #define | USB_OTG_EPNUM_Msk (0xFUL << USB_OTG_EPNUM_Pos) |
| #define | USB_OTG_EPNUM USB_OTG_EPNUM_Msk |
| #define | USB_OTG_EPNUM_0 (0x1UL << USB_OTG_EPNUM_Pos) |
| #define | USB_OTG_EPNUM_1 (0x2UL << USB_OTG_EPNUM_Pos) |
| #define | USB_OTG_EPNUM_2 (0x4UL << USB_OTG_EPNUM_Pos) |
| #define | USB_OTG_EPNUM_3 (0x8UL << USB_OTG_EPNUM_Pos) |
| #define | USB_OTG_FRMNUM_Pos (21U) |
| #define | USB_OTG_FRMNUM_Msk (0xFUL << USB_OTG_FRMNUM_Pos) |
| #define | USB_OTG_FRMNUM USB_OTG_FRMNUM_Msk |
| #define | USB_OTG_FRMNUM_0 (0x1UL << USB_OTG_FRMNUM_Pos) |
| #define | USB_OTG_FRMNUM_1 (0x2UL << USB_OTG_FRMNUM_Pos) |
| #define | USB_OTG_FRMNUM_2 (0x4UL << USB_OTG_FRMNUM_Pos) |
| #define | USB_OTG_FRMNUM_3 (0x8UL << USB_OTG_FRMNUM_Pos) |
| #define | USB_OTG_GRXFSIZ_RXFD_Pos (0U) |
| #define | USB_OTG_GRXFSIZ_RXFD_Msk (0xFFFFUL << USB_OTG_GRXFSIZ_RXFD_Pos) |
| #define | USB_OTG_GRXFSIZ_RXFD USB_OTG_GRXFSIZ_RXFD_Msk |
| #define | USB_OTG_DVBUSDIS_VBUSDT_Pos (0U) |
| #define | USB_OTG_DVBUSDIS_VBUSDT_Msk (0xFFFFUL << USB_OTG_DVBUSDIS_VBUSDT_Pos) |
| #define | USB_OTG_DVBUSDIS_VBUSDT USB_OTG_DVBUSDIS_VBUSDT_Msk |
| #define | USB_OTG_NPTXFSA_Pos (0U) |
| #define | USB_OTG_NPTXFSA_Msk (0xFFFFUL << USB_OTG_NPTXFSA_Pos) |
| #define | USB_OTG_NPTXFSA USB_OTG_NPTXFSA_Msk |
| #define | USB_OTG_NPTXFD_Pos (16U) |
| #define | USB_OTG_NPTXFD_Msk (0xFFFFUL << USB_OTG_NPTXFD_Pos) |
| #define | USB_OTG_NPTXFD USB_OTG_NPTXFD_Msk |
| #define | USB_OTG_TX0FSA_Pos (0U) |
| #define | USB_OTG_TX0FSA_Msk (0xFFFFUL << USB_OTG_TX0FSA_Pos) |
| #define | USB_OTG_TX0FSA USB_OTG_TX0FSA_Msk |
| #define | USB_OTG_TX0FD_Pos (16U) |
| #define | USB_OTG_TX0FD_Msk (0xFFFFUL << USB_OTG_TX0FD_Pos) |
| #define | USB_OTG_TX0FD USB_OTG_TX0FD_Msk |
| #define | USB_OTG_DVBUSPULSE_DVBUSP_Pos (0U) |
| #define | USB_OTG_DVBUSPULSE_DVBUSP_Msk (0xFFFUL << USB_OTG_DVBUSPULSE_DVBUSP_Pos) |
| #define | USB_OTG_DVBUSPULSE_DVBUSP USB_OTG_DVBUSPULSE_DVBUSP_Msk |
| #define | USB_OTG_GNPTXSTS_NPTXFSAV_Pos (0U) |
| #define | USB_OTG_GNPTXSTS_NPTXFSAV_Msk (0xFFFFUL << USB_OTG_GNPTXSTS_NPTXFSAV_Pos) |
| #define | USB_OTG_GNPTXSTS_NPTXFSAV USB_OTG_GNPTXSTS_NPTXFSAV_Msk |
| #define | USB_OTG_GNPTXSTS_NPTQXSAV_Pos (16U) |
| #define | USB_OTG_GNPTXSTS_NPTQXSAV_Msk (0xFFUL << USB_OTG_GNPTXSTS_NPTQXSAV_Pos) |
| #define | USB_OTG_GNPTXSTS_NPTQXSAV USB_OTG_GNPTXSTS_NPTQXSAV_Msk |
| #define | USB_OTG_GNPTXSTS_NPTQXSAV_0 (0x01UL << USB_OTG_GNPTXSTS_NPTQXSAV_Pos) |
| #define | USB_OTG_GNPTXSTS_NPTQXSAV_1 (0x02UL << USB_OTG_GNPTXSTS_NPTQXSAV_Pos) |
| #define | USB_OTG_GNPTXSTS_NPTQXSAV_2 (0x04UL << USB_OTG_GNPTXSTS_NPTQXSAV_Pos) |
| #define | USB_OTG_GNPTXSTS_NPTQXSAV_3 (0x08UL << USB_OTG_GNPTXSTS_NPTQXSAV_Pos) |
| #define | USB_OTG_GNPTXSTS_NPTQXSAV_4 (0x10UL << USB_OTG_GNPTXSTS_NPTQXSAV_Pos) |
| #define | USB_OTG_GNPTXSTS_NPTQXSAV_5 (0x20UL << USB_OTG_GNPTXSTS_NPTQXSAV_Pos) |
| #define | USB_OTG_GNPTXSTS_NPTQXSAV_6 (0x40UL << USB_OTG_GNPTXSTS_NPTQXSAV_Pos) |
| #define | USB_OTG_GNPTXSTS_NPTQXSAV_7 (0x80UL << USB_OTG_GNPTXSTS_NPTQXSAV_Pos) |
| #define | USB_OTG_GNPTXSTS_NPTXQTOP_Pos (24U) |
| #define | USB_OTG_GNPTXSTS_NPTXQTOP_Msk (0x7FUL << USB_OTG_GNPTXSTS_NPTXQTOP_Pos) |
| #define | USB_OTG_GNPTXSTS_NPTXQTOP USB_OTG_GNPTXSTS_NPTXQTOP_Msk |
| #define | USB_OTG_GNPTXSTS_NPTXQTOP_0 (0x01UL << USB_OTG_GNPTXSTS_NPTXQTOP_Pos) |
| #define | USB_OTG_GNPTXSTS_NPTXQTOP_1 (0x02UL << USB_OTG_GNPTXSTS_NPTXQTOP_Pos) |
| #define | USB_OTG_GNPTXSTS_NPTXQTOP_2 (0x04UL << USB_OTG_GNPTXSTS_NPTXQTOP_Pos) |
| #define | USB_OTG_GNPTXSTS_NPTXQTOP_3 (0x08UL << USB_OTG_GNPTXSTS_NPTXQTOP_Pos) |
| #define | USB_OTG_GNPTXSTS_NPTXQTOP_4 (0x10UL << USB_OTG_GNPTXSTS_NPTXQTOP_Pos) |
| #define | USB_OTG_GNPTXSTS_NPTXQTOP_5 (0x20UL << USB_OTG_GNPTXSTS_NPTXQTOP_Pos) |
| #define | USB_OTG_GNPTXSTS_NPTXQTOP_6 (0x40UL << USB_OTG_GNPTXSTS_NPTXQTOP_Pos) |
| #define | USB_OTG_DTHRCTL_NONISOTHREN_Pos (0U) |
| #define | USB_OTG_DTHRCTL_NONISOTHREN_Msk (0x1UL << USB_OTG_DTHRCTL_NONISOTHREN_Pos) |
| #define | USB_OTG_DTHRCTL_NONISOTHREN USB_OTG_DTHRCTL_NONISOTHREN_Msk |
| #define | USB_OTG_DTHRCTL_ISOTHREN_Pos (1U) |
| #define | USB_OTG_DTHRCTL_ISOTHREN_Msk (0x1UL << USB_OTG_DTHRCTL_ISOTHREN_Pos) |
| #define | USB_OTG_DTHRCTL_ISOTHREN USB_OTG_DTHRCTL_ISOTHREN_Msk |
| #define | USB_OTG_DTHRCTL_TXTHRLEN_Pos (2U) |
| #define | USB_OTG_DTHRCTL_TXTHRLEN_Msk (0x1FFUL << USB_OTG_DTHRCTL_TXTHRLEN_Pos) |
| #define | USB_OTG_DTHRCTL_TXTHRLEN USB_OTG_DTHRCTL_TXTHRLEN_Msk |
| #define | USB_OTG_DTHRCTL_TXTHRLEN_0 (0x001UL << USB_OTG_DTHRCTL_TXTHRLEN_Pos) |
| #define | USB_OTG_DTHRCTL_TXTHRLEN_1 (0x002UL << USB_OTG_DTHRCTL_TXTHRLEN_Pos) |
| #define | USB_OTG_DTHRCTL_TXTHRLEN_2 (0x004UL << USB_OTG_DTHRCTL_TXTHRLEN_Pos) |
| #define | USB_OTG_DTHRCTL_TXTHRLEN_3 (0x008UL << USB_OTG_DTHRCTL_TXTHRLEN_Pos) |
| #define | USB_OTG_DTHRCTL_TXTHRLEN_4 (0x010UL << USB_OTG_DTHRCTL_TXTHRLEN_Pos) |
| #define | USB_OTG_DTHRCTL_TXTHRLEN_5 (0x020UL << USB_OTG_DTHRCTL_TXTHRLEN_Pos) |
| #define | USB_OTG_DTHRCTL_TXTHRLEN_6 (0x040UL << USB_OTG_DTHRCTL_TXTHRLEN_Pos) |
| #define | USB_OTG_DTHRCTL_TXTHRLEN_7 (0x080UL << USB_OTG_DTHRCTL_TXTHRLEN_Pos) |
| #define | USB_OTG_DTHRCTL_TXTHRLEN_8 (0x100UL << USB_OTG_DTHRCTL_TXTHRLEN_Pos) |
| #define | USB_OTG_DTHRCTL_RXTHREN_Pos (16U) |
| #define | USB_OTG_DTHRCTL_RXTHREN_Msk (0x1UL << USB_OTG_DTHRCTL_RXTHREN_Pos) |
| #define | USB_OTG_DTHRCTL_RXTHREN USB_OTG_DTHRCTL_RXTHREN_Msk |
| #define | USB_OTG_DTHRCTL_RXTHRLEN_Pos (17U) |
| #define | USB_OTG_DTHRCTL_RXTHRLEN_Msk (0x1FFUL << USB_OTG_DTHRCTL_RXTHRLEN_Pos) |
| #define | USB_OTG_DTHRCTL_RXTHRLEN USB_OTG_DTHRCTL_RXTHRLEN_Msk |
| #define | USB_OTG_DTHRCTL_RXTHRLEN_0 (0x001UL << USB_OTG_DTHRCTL_RXTHRLEN_Pos) |
| #define | USB_OTG_DTHRCTL_RXTHRLEN_1 (0x002UL << USB_OTG_DTHRCTL_RXTHRLEN_Pos) |
| #define | USB_OTG_DTHRCTL_RXTHRLEN_2 (0x004UL << USB_OTG_DTHRCTL_RXTHRLEN_Pos) |
| #define | USB_OTG_DTHRCTL_RXTHRLEN_3 (0x008UL << USB_OTG_DTHRCTL_RXTHRLEN_Pos) |
| #define | USB_OTG_DTHRCTL_RXTHRLEN_4 (0x010UL << USB_OTG_DTHRCTL_RXTHRLEN_Pos) |
| #define | USB_OTG_DTHRCTL_RXTHRLEN_5 (0x020UL << USB_OTG_DTHRCTL_RXTHRLEN_Pos) |
| #define | USB_OTG_DTHRCTL_RXTHRLEN_6 (0x040UL << USB_OTG_DTHRCTL_RXTHRLEN_Pos) |
| #define | USB_OTG_DTHRCTL_RXTHRLEN_7 (0x080UL << USB_OTG_DTHRCTL_RXTHRLEN_Pos) |
| #define | USB_OTG_DTHRCTL_RXTHRLEN_8 (0x100UL << USB_OTG_DTHRCTL_RXTHRLEN_Pos) |
| #define | USB_OTG_DTHRCTL_ARPEN_Pos (27U) |
| #define | USB_OTG_DTHRCTL_ARPEN_Msk (0x1UL << USB_OTG_DTHRCTL_ARPEN_Pos) |
| #define | USB_OTG_DTHRCTL_ARPEN USB_OTG_DTHRCTL_ARPEN_Msk |
| #define | USB_OTG_DIEPEMPMSK_INEPTXFEM_Pos (0U) |
| #define | USB_OTG_DIEPEMPMSK_INEPTXFEM_Msk (0xFFFFUL << USB_OTG_DIEPEMPMSK_INEPTXFEM_Pos) |
| #define | USB_OTG_DIEPEMPMSK_INEPTXFEM USB_OTG_DIEPEMPMSK_INEPTXFEM_Msk |
| #define | USB_OTG_DEACHINT_IEP1INT_Pos (1U) |
| #define | USB_OTG_DEACHINT_IEP1INT_Msk (0x1UL << USB_OTG_DEACHINT_IEP1INT_Pos) |
| #define | USB_OTG_DEACHINT_IEP1INT USB_OTG_DEACHINT_IEP1INT_Msk |
| #define | USB_OTG_DEACHINT_OEP1INT_Pos (17U) |
| #define | USB_OTG_DEACHINT_OEP1INT_Msk (0x1UL << USB_OTG_DEACHINT_OEP1INT_Pos) |
| #define | USB_OTG_DEACHINT_OEP1INT USB_OTG_DEACHINT_OEP1INT_Msk |
| #define | USB_OTG_GCCFG_DCDET_Pos (0U) |
| #define | USB_OTG_GCCFG_DCDET_Msk (0x1UL << USB_OTG_GCCFG_DCDET_Pos) |
| #define | USB_OTG_GCCFG_DCDET USB_OTG_GCCFG_DCDET_Msk |
| #define | USB_OTG_GCCFG_PDET_Pos (1U) |
| #define | USB_OTG_GCCFG_PDET_Msk (0x1UL << USB_OTG_GCCFG_PDET_Pos) |
| #define | USB_OTG_GCCFG_PDET USB_OTG_GCCFG_PDET_Msk |
| #define | USB_OTG_GCCFG_SDET_Pos (2U) |
| #define | USB_OTG_GCCFG_SDET_Msk (0x1UL << USB_OTG_GCCFG_SDET_Pos) |
| #define | USB_OTG_GCCFG_SDET USB_OTG_GCCFG_SDET_Msk |
| #define | USB_OTG_GCCFG_PS2DET_Pos (3U) |
| #define | USB_OTG_GCCFG_PS2DET_Msk (0x1UL << USB_OTG_GCCFG_PS2DET_Pos) |
| #define | USB_OTG_GCCFG_PS2DET USB_OTG_GCCFG_PS2DET_Msk |
| #define | USB_OTG_GCCFG_PWRDWN_Pos (16U) |
| #define | USB_OTG_GCCFG_PWRDWN_Msk (0x1UL << USB_OTG_GCCFG_PWRDWN_Pos) |
| #define | USB_OTG_GCCFG_PWRDWN USB_OTG_GCCFG_PWRDWN_Msk |
| #define | USB_OTG_GCCFG_BCDEN_Pos (17U) |
| #define | USB_OTG_GCCFG_BCDEN_Msk (0x1UL << USB_OTG_GCCFG_BCDEN_Pos) |
| #define | USB_OTG_GCCFG_BCDEN USB_OTG_GCCFG_BCDEN_Msk |
| #define | USB_OTG_GCCFG_DCDEN_Pos (18U) |
| #define | USB_OTG_GCCFG_DCDEN_Msk (0x1UL << USB_OTG_GCCFG_DCDEN_Pos) |
| #define | USB_OTG_GCCFG_DCDEN USB_OTG_GCCFG_DCDEN_Msk |
| #define | USB_OTG_GCCFG_PDEN_Pos (19U) |
| #define | USB_OTG_GCCFG_PDEN_Msk (0x1UL << USB_OTG_GCCFG_PDEN_Pos) |
| #define | USB_OTG_GCCFG_PDEN USB_OTG_GCCFG_PDEN_Msk |
| #define | USB_OTG_GCCFG_SDEN_Pos (20U) |
| #define | USB_OTG_GCCFG_SDEN_Msk (0x1UL << USB_OTG_GCCFG_SDEN_Pos) |
| #define | USB_OTG_GCCFG_SDEN USB_OTG_GCCFG_SDEN_Msk |
| #define | USB_OTG_GCCFG_VBDEN_Pos (21U) |
| #define | USB_OTG_GCCFG_VBDEN_Msk (0x1UL << USB_OTG_GCCFG_VBDEN_Pos) |
| #define | USB_OTG_GCCFG_VBDEN USB_OTG_GCCFG_VBDEN_Msk |
| #define | USB_OTG_GPWRDN_ADPMEN_Pos (0U) |
| #define | USB_OTG_GPWRDN_ADPMEN_Msk (0x1UL << USB_OTG_GPWRDN_ADPMEN_Pos) |
| #define | USB_OTG_GPWRDN_ADPMEN USB_OTG_GPWRDN_ADPMEN_Msk |
| #define | USB_OTG_GPWRDN_ADPIF_Pos (23U) |
| #define | USB_OTG_GPWRDN_ADPIF_Msk (0x1UL << USB_OTG_GPWRDN_ADPIF_Pos) |
| #define | USB_OTG_GPWRDN_ADPIF USB_OTG_GPWRDN_ADPIF_Msk |
| #define | USB_OTG_DEACHINTMSK_IEP1INTM_Pos (1U) |
| #define | USB_OTG_DEACHINTMSK_IEP1INTM_Msk (0x1UL << USB_OTG_DEACHINTMSK_IEP1INTM_Pos) |
| #define | USB_OTG_DEACHINTMSK_IEP1INTM USB_OTG_DEACHINTMSK_IEP1INTM_Msk |
| #define | USB_OTG_DEACHINTMSK_OEP1INTM_Pos (17U) |
| #define | USB_OTG_DEACHINTMSK_OEP1INTM_Msk (0x1UL << USB_OTG_DEACHINTMSK_OEP1INTM_Pos) |
| #define | USB_OTG_DEACHINTMSK_OEP1INTM USB_OTG_DEACHINTMSK_OEP1INTM_Msk |
| #define | USB_OTG_CID_PRODUCT_ID_Pos (0U) |
| #define | USB_OTG_CID_PRODUCT_ID_Msk (0xFFFFFFFFUL << USB_OTG_CID_PRODUCT_ID_Pos) |
| #define | USB_OTG_CID_PRODUCT_ID USB_OTG_CID_PRODUCT_ID_Msk |
| #define | USB_OTG_GLPMCFG_LPMEN_Pos (0U) |
| #define | USB_OTG_GLPMCFG_LPMEN_Msk (0x1UL << USB_OTG_GLPMCFG_LPMEN_Pos) |
| #define | USB_OTG_GLPMCFG_LPMEN USB_OTG_GLPMCFG_LPMEN_Msk |
| #define | USB_OTG_GLPMCFG_LPMACK_Pos (1U) |
| #define | USB_OTG_GLPMCFG_LPMACK_Msk (0x1UL << USB_OTG_GLPMCFG_LPMACK_Pos) |
| #define | USB_OTG_GLPMCFG_LPMACK USB_OTG_GLPMCFG_LPMACK_Msk |
| #define | USB_OTG_GLPMCFG_BESL_Pos (2U) |
| #define | USB_OTG_GLPMCFG_BESL_Msk (0xFUL << USB_OTG_GLPMCFG_BESL_Pos) |
| #define | USB_OTG_GLPMCFG_BESL USB_OTG_GLPMCFG_BESL_Msk |
| #define | USB_OTG_GLPMCFG_REMWAKE_Pos (6U) |
| #define | USB_OTG_GLPMCFG_REMWAKE_Msk (0x1UL << USB_OTG_GLPMCFG_REMWAKE_Pos) |
| #define | USB_OTG_GLPMCFG_REMWAKE USB_OTG_GLPMCFG_REMWAKE_Msk |
| #define | USB_OTG_GLPMCFG_L1SSEN_Pos (7U) |
| #define | USB_OTG_GLPMCFG_L1SSEN_Msk (0x1UL << USB_OTG_GLPMCFG_L1SSEN_Pos) |
| #define | USB_OTG_GLPMCFG_L1SSEN USB_OTG_GLPMCFG_L1SSEN_Msk |
| #define | USB_OTG_GLPMCFG_BESLTHRS_Pos (8U) |
| #define | USB_OTG_GLPMCFG_BESLTHRS_Msk (0xFUL << USB_OTG_GLPMCFG_BESLTHRS_Pos) |
| #define | USB_OTG_GLPMCFG_BESLTHRS USB_OTG_GLPMCFG_BESLTHRS_Msk |
| #define | USB_OTG_GLPMCFG_L1DSEN_Pos (12U) |
| #define | USB_OTG_GLPMCFG_L1DSEN_Msk (0x1UL << USB_OTG_GLPMCFG_L1DSEN_Pos) |
| #define | USB_OTG_GLPMCFG_L1DSEN USB_OTG_GLPMCFG_L1DSEN_Msk |
| #define | USB_OTG_GLPMCFG_LPMRSP_Pos (13U) |
| #define | USB_OTG_GLPMCFG_LPMRSP_Msk (0x3UL << USB_OTG_GLPMCFG_LPMRSP_Pos) |
| #define | USB_OTG_GLPMCFG_LPMRSP USB_OTG_GLPMCFG_LPMRSP_Msk |
| #define | USB_OTG_GLPMCFG_SLPSTS_Pos (15U) |
| #define | USB_OTG_GLPMCFG_SLPSTS_Msk (0x1UL << USB_OTG_GLPMCFG_SLPSTS_Pos) |
| #define | USB_OTG_GLPMCFG_SLPSTS USB_OTG_GLPMCFG_SLPSTS_Msk |
| #define | USB_OTG_GLPMCFG_L1RSMOK_Pos (16U) |
| #define | USB_OTG_GLPMCFG_L1RSMOK_Msk (0x1UL << USB_OTG_GLPMCFG_L1RSMOK_Pos) |
| #define | USB_OTG_GLPMCFG_L1RSMOK USB_OTG_GLPMCFG_L1RSMOK_Msk |
| #define | USB_OTG_GLPMCFG_LPMCHIDX_Pos (17U) |
| #define | USB_OTG_GLPMCFG_LPMCHIDX_Msk (0xFUL << USB_OTG_GLPMCFG_LPMCHIDX_Pos) |
| #define | USB_OTG_GLPMCFG_LPMCHIDX USB_OTG_GLPMCFG_LPMCHIDX_Msk |
| #define | USB_OTG_GLPMCFG_LPMRCNT_Pos (21U) |
| #define | USB_OTG_GLPMCFG_LPMRCNT_Msk (0x7UL << USB_OTG_GLPMCFG_LPMRCNT_Pos) |
| #define | USB_OTG_GLPMCFG_LPMRCNT USB_OTG_GLPMCFG_LPMRCNT_Msk |
| #define | USB_OTG_GLPMCFG_SNDLPM_Pos (24U) |
| #define | USB_OTG_GLPMCFG_SNDLPM_Msk (0x1UL << USB_OTG_GLPMCFG_SNDLPM_Pos) |
| #define | USB_OTG_GLPMCFG_SNDLPM USB_OTG_GLPMCFG_SNDLPM_Msk |
| #define | USB_OTG_GLPMCFG_LPMRCNTSTS_Pos (25U) |
| #define | USB_OTG_GLPMCFG_LPMRCNTSTS_Msk (0x7UL << USB_OTG_GLPMCFG_LPMRCNTSTS_Pos) |
| #define | USB_OTG_GLPMCFG_LPMRCNTSTS USB_OTG_GLPMCFG_LPMRCNTSTS_Msk |
| #define | USB_OTG_GLPMCFG_ENBESL_Pos (28U) |
| #define | USB_OTG_GLPMCFG_ENBESL_Msk (0x1UL << USB_OTG_GLPMCFG_ENBESL_Pos) |
| #define | USB_OTG_GLPMCFG_ENBESL USB_OTG_GLPMCFG_ENBESL_Msk |
| #define | USB_OTG_DIEPEACHMSK1_XFRCM_Pos (0U) |
| #define | USB_OTG_DIEPEACHMSK1_XFRCM_Msk (0x1UL << USB_OTG_DIEPEACHMSK1_XFRCM_Pos) |
| #define | USB_OTG_DIEPEACHMSK1_XFRCM USB_OTG_DIEPEACHMSK1_XFRCM_Msk |
| #define | USB_OTG_DIEPEACHMSK1_EPDM_Pos (1U) |
| #define | USB_OTG_DIEPEACHMSK1_EPDM_Msk (0x1UL << USB_OTG_DIEPEACHMSK1_EPDM_Pos) |
| #define | USB_OTG_DIEPEACHMSK1_EPDM USB_OTG_DIEPEACHMSK1_EPDM_Msk |
| #define | USB_OTG_DIEPEACHMSK1_TOM_Pos (3U) |
| #define | USB_OTG_DIEPEACHMSK1_TOM_Msk (0x1UL << USB_OTG_DIEPEACHMSK1_TOM_Pos) |
| #define | USB_OTG_DIEPEACHMSK1_TOM USB_OTG_DIEPEACHMSK1_TOM_Msk |
| #define | USB_OTG_DIEPEACHMSK1_ITTXFEMSK_Pos (4U) |
| #define | USB_OTG_DIEPEACHMSK1_ITTXFEMSK_Msk (0x1UL << USB_OTG_DIEPEACHMSK1_ITTXFEMSK_Pos) |
| #define | USB_OTG_DIEPEACHMSK1_ITTXFEMSK USB_OTG_DIEPEACHMSK1_ITTXFEMSK_Msk |
| #define | USB_OTG_DIEPEACHMSK1_INEPNMM_Pos (5U) |
| #define | USB_OTG_DIEPEACHMSK1_INEPNMM_Msk (0x1UL << USB_OTG_DIEPEACHMSK1_INEPNMM_Pos) |
| #define | USB_OTG_DIEPEACHMSK1_INEPNMM USB_OTG_DIEPEACHMSK1_INEPNMM_Msk |
| #define | USB_OTG_DIEPEACHMSK1_INEPNEM_Pos (6U) |
| #define | USB_OTG_DIEPEACHMSK1_INEPNEM_Msk (0x1UL << USB_OTG_DIEPEACHMSK1_INEPNEM_Pos) |
| #define | USB_OTG_DIEPEACHMSK1_INEPNEM USB_OTG_DIEPEACHMSK1_INEPNEM_Msk |
| #define | USB_OTG_DIEPEACHMSK1_TXFURM_Pos (8U) |
| #define | USB_OTG_DIEPEACHMSK1_TXFURM_Msk (0x1UL << USB_OTG_DIEPEACHMSK1_TXFURM_Pos) |
| #define | USB_OTG_DIEPEACHMSK1_TXFURM USB_OTG_DIEPEACHMSK1_TXFURM_Msk |
| #define | USB_OTG_DIEPEACHMSK1_BIM_Pos (9U) |
| #define | USB_OTG_DIEPEACHMSK1_BIM_Msk (0x1UL << USB_OTG_DIEPEACHMSK1_BIM_Pos) |
| #define | USB_OTG_DIEPEACHMSK1_BIM USB_OTG_DIEPEACHMSK1_BIM_Msk |
| #define | USB_OTG_DIEPEACHMSK1_NAKM_Pos (13U) |
| #define | USB_OTG_DIEPEACHMSK1_NAKM_Msk (0x1UL << USB_OTG_DIEPEACHMSK1_NAKM_Pos) |
| #define | USB_OTG_DIEPEACHMSK1_NAKM USB_OTG_DIEPEACHMSK1_NAKM_Msk |
| #define | USB_OTG_HPRT_PCSTS_Pos (0U) |
| #define | USB_OTG_HPRT_PCSTS_Msk (0x1UL << USB_OTG_HPRT_PCSTS_Pos) |
| #define | USB_OTG_HPRT_PCSTS USB_OTG_HPRT_PCSTS_Msk |
| #define | USB_OTG_HPRT_PCDET_Pos (1U) |
| #define | USB_OTG_HPRT_PCDET_Msk (0x1UL << USB_OTG_HPRT_PCDET_Pos) |
| #define | USB_OTG_HPRT_PCDET USB_OTG_HPRT_PCDET_Msk |
| #define | USB_OTG_HPRT_PENA_Pos (2U) |
| #define | USB_OTG_HPRT_PENA_Msk (0x1UL << USB_OTG_HPRT_PENA_Pos) |
| #define | USB_OTG_HPRT_PENA USB_OTG_HPRT_PENA_Msk |
| #define | USB_OTG_HPRT_PENCHNG_Pos (3U) |
| #define | USB_OTG_HPRT_PENCHNG_Msk (0x1UL << USB_OTG_HPRT_PENCHNG_Pos) |
| #define | USB_OTG_HPRT_PENCHNG USB_OTG_HPRT_PENCHNG_Msk |
| #define | USB_OTG_HPRT_POCA_Pos (4U) |
| #define | USB_OTG_HPRT_POCA_Msk (0x1UL << USB_OTG_HPRT_POCA_Pos) |
| #define | USB_OTG_HPRT_POCA USB_OTG_HPRT_POCA_Msk |
| #define | USB_OTG_HPRT_POCCHNG_Pos (5U) |
| #define | USB_OTG_HPRT_POCCHNG_Msk (0x1UL << USB_OTG_HPRT_POCCHNG_Pos) |
| #define | USB_OTG_HPRT_POCCHNG USB_OTG_HPRT_POCCHNG_Msk |
| #define | USB_OTG_HPRT_PRES_Pos (6U) |
| #define | USB_OTG_HPRT_PRES_Msk (0x1UL << USB_OTG_HPRT_PRES_Pos) |
| #define | USB_OTG_HPRT_PRES USB_OTG_HPRT_PRES_Msk |
| #define | USB_OTG_HPRT_PSUSP_Pos (7U) |
| #define | USB_OTG_HPRT_PSUSP_Msk (0x1UL << USB_OTG_HPRT_PSUSP_Pos) |
| #define | USB_OTG_HPRT_PSUSP USB_OTG_HPRT_PSUSP_Msk |
| #define | USB_OTG_HPRT_PRST_Pos (8U) |
| #define | USB_OTG_HPRT_PRST_Msk (0x1UL << USB_OTG_HPRT_PRST_Pos) |
| #define | USB_OTG_HPRT_PRST USB_OTG_HPRT_PRST_Msk |
| #define | USB_OTG_HPRT_PLSTS_Pos (10U) |
| #define | USB_OTG_HPRT_PLSTS_Msk (0x3UL << USB_OTG_HPRT_PLSTS_Pos) |
| #define | USB_OTG_HPRT_PLSTS USB_OTG_HPRT_PLSTS_Msk |
| #define | USB_OTG_HPRT_PLSTS_0 (0x1UL << USB_OTG_HPRT_PLSTS_Pos) |
| #define | USB_OTG_HPRT_PLSTS_1 (0x2UL << USB_OTG_HPRT_PLSTS_Pos) |
| #define | USB_OTG_HPRT_PPWR_Pos (12U) |
| #define | USB_OTG_HPRT_PPWR_Msk (0x1UL << USB_OTG_HPRT_PPWR_Pos) |
| #define | USB_OTG_HPRT_PPWR USB_OTG_HPRT_PPWR_Msk |
| #define | USB_OTG_HPRT_PTCTL_Pos (13U) |
| #define | USB_OTG_HPRT_PTCTL_Msk (0xFUL << USB_OTG_HPRT_PTCTL_Pos) |
| #define | USB_OTG_HPRT_PTCTL USB_OTG_HPRT_PTCTL_Msk |
| #define | USB_OTG_HPRT_PTCTL_0 (0x1UL << USB_OTG_HPRT_PTCTL_Pos) |
| #define | USB_OTG_HPRT_PTCTL_1 (0x2UL << USB_OTG_HPRT_PTCTL_Pos) |
| #define | USB_OTG_HPRT_PTCTL_2 (0x4UL << USB_OTG_HPRT_PTCTL_Pos) |
| #define | USB_OTG_HPRT_PTCTL_3 (0x8UL << USB_OTG_HPRT_PTCTL_Pos) |
| #define | USB_OTG_HPRT_PSPD_Pos (17U) |
| #define | USB_OTG_HPRT_PSPD_Msk (0x3UL << USB_OTG_HPRT_PSPD_Pos) |
| #define | USB_OTG_HPRT_PSPD USB_OTG_HPRT_PSPD_Msk |
| #define | USB_OTG_HPRT_PSPD_0 (0x1UL << USB_OTG_HPRT_PSPD_Pos) |
| #define | USB_OTG_HPRT_PSPD_1 (0x2UL << USB_OTG_HPRT_PSPD_Pos) |
| #define | USB_OTG_DOEPEACHMSK1_XFRCM_Pos (0U) |
| #define | USB_OTG_DOEPEACHMSK1_XFRCM_Msk (0x1UL << USB_OTG_DOEPEACHMSK1_XFRCM_Pos) |
| #define | USB_OTG_DOEPEACHMSK1_XFRCM USB_OTG_DOEPEACHMSK1_XFRCM_Msk |
| #define | USB_OTG_DOEPEACHMSK1_EPDM_Pos (1U) |
| #define | USB_OTG_DOEPEACHMSK1_EPDM_Msk (0x1UL << USB_OTG_DOEPEACHMSK1_EPDM_Pos) |
| #define | USB_OTG_DOEPEACHMSK1_EPDM USB_OTG_DOEPEACHMSK1_EPDM_Msk |
| #define | USB_OTG_DOEPEACHMSK1_TOM_Pos (3U) |
| #define | USB_OTG_DOEPEACHMSK1_TOM_Msk (0x1UL << USB_OTG_DOEPEACHMSK1_TOM_Pos) |
| #define | USB_OTG_DOEPEACHMSK1_TOM USB_OTG_DOEPEACHMSK1_TOM_Msk |
| #define | USB_OTG_DOEPEACHMSK1_ITTXFEMSK_Pos (4U) |
| #define | USB_OTG_DOEPEACHMSK1_ITTXFEMSK_Msk (0x1UL << USB_OTG_DOEPEACHMSK1_ITTXFEMSK_Pos) |
| #define | USB_OTG_DOEPEACHMSK1_ITTXFEMSK USB_OTG_DOEPEACHMSK1_ITTXFEMSK_Msk |
| #define | USB_OTG_DOEPEACHMSK1_INEPNMM_Pos (5U) |
| #define | USB_OTG_DOEPEACHMSK1_INEPNMM_Msk (0x1UL << USB_OTG_DOEPEACHMSK1_INEPNMM_Pos) |
| #define | USB_OTG_DOEPEACHMSK1_INEPNMM USB_OTG_DOEPEACHMSK1_INEPNMM_Msk |
| #define | USB_OTG_DOEPEACHMSK1_INEPNEM_Pos (6U) |
| #define | USB_OTG_DOEPEACHMSK1_INEPNEM_Msk (0x1UL << USB_OTG_DOEPEACHMSK1_INEPNEM_Pos) |
| #define | USB_OTG_DOEPEACHMSK1_INEPNEM USB_OTG_DOEPEACHMSK1_INEPNEM_Msk |
| #define | USB_OTG_DOEPEACHMSK1_TXFURM_Pos (8U) |
| #define | USB_OTG_DOEPEACHMSK1_TXFURM_Msk (0x1UL << USB_OTG_DOEPEACHMSK1_TXFURM_Pos) |
| #define | USB_OTG_DOEPEACHMSK1_TXFURM USB_OTG_DOEPEACHMSK1_TXFURM_Msk |
| #define | USB_OTG_DOEPEACHMSK1_BIM_Pos (9U) |
| #define | USB_OTG_DOEPEACHMSK1_BIM_Msk (0x1UL << USB_OTG_DOEPEACHMSK1_BIM_Pos) |
| #define | USB_OTG_DOEPEACHMSK1_BIM USB_OTG_DOEPEACHMSK1_BIM_Msk |
| #define | USB_OTG_DOEPEACHMSK1_BERRM_Pos (12U) |
| #define | USB_OTG_DOEPEACHMSK1_BERRM_Msk (0x1UL << USB_OTG_DOEPEACHMSK1_BERRM_Pos) |
| #define | USB_OTG_DOEPEACHMSK1_BERRM USB_OTG_DOEPEACHMSK1_BERRM_Msk |
| #define | USB_OTG_DOEPEACHMSK1_NAKM_Pos (13U) |
| #define | USB_OTG_DOEPEACHMSK1_NAKM_Msk (0x1UL << USB_OTG_DOEPEACHMSK1_NAKM_Pos) |
| #define | USB_OTG_DOEPEACHMSK1_NAKM USB_OTG_DOEPEACHMSK1_NAKM_Msk |
| #define | USB_OTG_DOEPEACHMSK1_NYETM_Pos (14U) |
| #define | USB_OTG_DOEPEACHMSK1_NYETM_Msk (0x1UL << USB_OTG_DOEPEACHMSK1_NYETM_Pos) |
| #define | USB_OTG_DOEPEACHMSK1_NYETM USB_OTG_DOEPEACHMSK1_NYETM_Msk |
| #define | USB_OTG_HPTXFSIZ_PTXSA_Pos (0U) |
| #define | USB_OTG_HPTXFSIZ_PTXSA_Msk (0xFFFFUL << USB_OTG_HPTXFSIZ_PTXSA_Pos) |
| #define | USB_OTG_HPTXFSIZ_PTXSA USB_OTG_HPTXFSIZ_PTXSA_Msk |
| #define | USB_OTG_HPTXFSIZ_PTXFD_Pos (16U) |
| #define | USB_OTG_HPTXFSIZ_PTXFD_Msk (0xFFFFUL << USB_OTG_HPTXFSIZ_PTXFD_Pos) |
| #define | USB_OTG_HPTXFSIZ_PTXFD USB_OTG_HPTXFSIZ_PTXFD_Msk |
| #define | USB_OTG_DIEPCTL_MPSIZ_Pos (0U) |
| #define | USB_OTG_DIEPCTL_MPSIZ_Msk (0x7FFUL << USB_OTG_DIEPCTL_MPSIZ_Pos) |
| #define | USB_OTG_DIEPCTL_MPSIZ USB_OTG_DIEPCTL_MPSIZ_Msk |
| #define | USB_OTG_DIEPCTL_USBAEP_Pos (15U) |
| #define | USB_OTG_DIEPCTL_USBAEP_Msk (0x1UL << USB_OTG_DIEPCTL_USBAEP_Pos) |
| #define | USB_OTG_DIEPCTL_USBAEP USB_OTG_DIEPCTL_USBAEP_Msk |
| #define | USB_OTG_DIEPCTL_EONUM_DPID_Pos (16U) |
| #define | USB_OTG_DIEPCTL_EONUM_DPID_Msk (0x1UL << USB_OTG_DIEPCTL_EONUM_DPID_Pos) |
| #define | USB_OTG_DIEPCTL_EONUM_DPID USB_OTG_DIEPCTL_EONUM_DPID_Msk |
| #define | USB_OTG_DIEPCTL_NAKSTS_Pos (17U) |
| #define | USB_OTG_DIEPCTL_NAKSTS_Msk (0x1UL << USB_OTG_DIEPCTL_NAKSTS_Pos) |
| #define | USB_OTG_DIEPCTL_NAKSTS USB_OTG_DIEPCTL_NAKSTS_Msk |
| #define | USB_OTG_DIEPCTL_EPTYP_Pos (18U) |
| #define | USB_OTG_DIEPCTL_EPTYP_Msk (0x3UL << USB_OTG_DIEPCTL_EPTYP_Pos) |
| #define | USB_OTG_DIEPCTL_EPTYP USB_OTG_DIEPCTL_EPTYP_Msk |
| #define | USB_OTG_DIEPCTL_EPTYP_0 (0x1UL << USB_OTG_DIEPCTL_EPTYP_Pos) |
| #define | USB_OTG_DIEPCTL_EPTYP_1 (0x2UL << USB_OTG_DIEPCTL_EPTYP_Pos) |
| #define | USB_OTG_DIEPCTL_STALL_Pos (21U) |
| #define | USB_OTG_DIEPCTL_STALL_Msk (0x1UL << USB_OTG_DIEPCTL_STALL_Pos) |
| #define | USB_OTG_DIEPCTL_STALL USB_OTG_DIEPCTL_STALL_Msk |
| #define | USB_OTG_DIEPCTL_TXFNUM_Pos (22U) |
| #define | USB_OTG_DIEPCTL_TXFNUM_Msk (0xFUL << USB_OTG_DIEPCTL_TXFNUM_Pos) |
| #define | USB_OTG_DIEPCTL_TXFNUM USB_OTG_DIEPCTL_TXFNUM_Msk |
| #define | USB_OTG_DIEPCTL_TXFNUM_0 (0x1UL << USB_OTG_DIEPCTL_TXFNUM_Pos) |
| #define | USB_OTG_DIEPCTL_TXFNUM_1 (0x2UL << USB_OTG_DIEPCTL_TXFNUM_Pos) |
| #define | USB_OTG_DIEPCTL_TXFNUM_2 (0x4UL << USB_OTG_DIEPCTL_TXFNUM_Pos) |
| #define | USB_OTG_DIEPCTL_TXFNUM_3 (0x8UL << USB_OTG_DIEPCTL_TXFNUM_Pos) |
| #define | USB_OTG_DIEPCTL_CNAK_Pos (26U) |
| #define | USB_OTG_DIEPCTL_CNAK_Msk (0x1UL << USB_OTG_DIEPCTL_CNAK_Pos) |
| #define | USB_OTG_DIEPCTL_CNAK USB_OTG_DIEPCTL_CNAK_Msk |
| #define | USB_OTG_DIEPCTL_SNAK_Pos (27U) |
| #define | USB_OTG_DIEPCTL_SNAK_Msk (0x1UL << USB_OTG_DIEPCTL_SNAK_Pos) |
| #define | USB_OTG_DIEPCTL_SNAK USB_OTG_DIEPCTL_SNAK_Msk |
| #define | USB_OTG_DIEPCTL_SD0PID_SEVNFRM_Pos (28U) |
| #define | USB_OTG_DIEPCTL_SD0PID_SEVNFRM_Msk (0x1UL << USB_OTG_DIEPCTL_SD0PID_SEVNFRM_Pos) |
| #define | USB_OTG_DIEPCTL_SD0PID_SEVNFRM USB_OTG_DIEPCTL_SD0PID_SEVNFRM_Msk |
| #define | USB_OTG_DIEPCTL_SODDFRM_Pos (29U) |
| #define | USB_OTG_DIEPCTL_SODDFRM_Msk (0x1UL << USB_OTG_DIEPCTL_SODDFRM_Pos) |
| #define | USB_OTG_DIEPCTL_SODDFRM USB_OTG_DIEPCTL_SODDFRM_Msk |
| #define | USB_OTG_DIEPCTL_EPDIS_Pos (30U) |
| #define | USB_OTG_DIEPCTL_EPDIS_Msk (0x1UL << USB_OTG_DIEPCTL_EPDIS_Pos) |
| #define | USB_OTG_DIEPCTL_EPDIS USB_OTG_DIEPCTL_EPDIS_Msk |
| #define | USB_OTG_DIEPCTL_EPENA_Pos (31U) |
| #define | USB_OTG_DIEPCTL_EPENA_Msk (0x1UL << USB_OTG_DIEPCTL_EPENA_Pos) |
| #define | USB_OTG_DIEPCTL_EPENA USB_OTG_DIEPCTL_EPENA_Msk |
| #define | USB_OTG_HCCHAR_MPSIZ_Pos (0U) |
| #define | USB_OTG_HCCHAR_MPSIZ_Msk (0x7FFUL << USB_OTG_HCCHAR_MPSIZ_Pos) |
| #define | USB_OTG_HCCHAR_MPSIZ USB_OTG_HCCHAR_MPSIZ_Msk |
| #define | USB_OTG_HCCHAR_EPNUM_Pos (11U) |
| #define | USB_OTG_HCCHAR_EPNUM_Msk (0xFUL << USB_OTG_HCCHAR_EPNUM_Pos) |
| #define | USB_OTG_HCCHAR_EPNUM USB_OTG_HCCHAR_EPNUM_Msk |
| #define | USB_OTG_HCCHAR_EPNUM_0 (0x1UL << USB_OTG_HCCHAR_EPNUM_Pos) |
| #define | USB_OTG_HCCHAR_EPNUM_1 (0x2UL << USB_OTG_HCCHAR_EPNUM_Pos) |
| #define | USB_OTG_HCCHAR_EPNUM_2 (0x4UL << USB_OTG_HCCHAR_EPNUM_Pos) |
| #define | USB_OTG_HCCHAR_EPNUM_3 (0x8UL << USB_OTG_HCCHAR_EPNUM_Pos) |
| #define | USB_OTG_HCCHAR_EPDIR_Pos (15U) |
| #define | USB_OTG_HCCHAR_EPDIR_Msk (0x1UL << USB_OTG_HCCHAR_EPDIR_Pos) |
| #define | USB_OTG_HCCHAR_EPDIR USB_OTG_HCCHAR_EPDIR_Msk |
| #define | USB_OTG_HCCHAR_LSDEV_Pos (17U) |
| #define | USB_OTG_HCCHAR_LSDEV_Msk (0x1UL << USB_OTG_HCCHAR_LSDEV_Pos) |
| #define | USB_OTG_HCCHAR_LSDEV USB_OTG_HCCHAR_LSDEV_Msk |
| #define | USB_OTG_HCCHAR_EPTYP_Pos (18U) |
| #define | USB_OTG_HCCHAR_EPTYP_Msk (0x3UL << USB_OTG_HCCHAR_EPTYP_Pos) |
| #define | USB_OTG_HCCHAR_EPTYP USB_OTG_HCCHAR_EPTYP_Msk |
| #define | USB_OTG_HCCHAR_EPTYP_0 (0x1UL << USB_OTG_HCCHAR_EPTYP_Pos) |
| #define | USB_OTG_HCCHAR_EPTYP_1 (0x2UL << USB_OTG_HCCHAR_EPTYP_Pos) |
| #define | USB_OTG_HCCHAR_MC_Pos (20U) |
| #define | USB_OTG_HCCHAR_MC_Msk (0x3UL << USB_OTG_HCCHAR_MC_Pos) |
| #define | USB_OTG_HCCHAR_MC USB_OTG_HCCHAR_MC_Msk |
| #define | USB_OTG_HCCHAR_MC_0 (0x1UL << USB_OTG_HCCHAR_MC_Pos) |
| #define | USB_OTG_HCCHAR_MC_1 (0x2UL << USB_OTG_HCCHAR_MC_Pos) |
| #define | USB_OTG_HCCHAR_DAD_Pos (22U) |
| #define | USB_OTG_HCCHAR_DAD_Msk (0x7FUL << USB_OTG_HCCHAR_DAD_Pos) |
| #define | USB_OTG_HCCHAR_DAD USB_OTG_HCCHAR_DAD_Msk |
| #define | USB_OTG_HCCHAR_DAD_0 (0x01UL << USB_OTG_HCCHAR_DAD_Pos) |
| #define | USB_OTG_HCCHAR_DAD_1 (0x02UL << USB_OTG_HCCHAR_DAD_Pos) |
| #define | USB_OTG_HCCHAR_DAD_2 (0x04UL << USB_OTG_HCCHAR_DAD_Pos) |
| #define | USB_OTG_HCCHAR_DAD_3 (0x08UL << USB_OTG_HCCHAR_DAD_Pos) |
| #define | USB_OTG_HCCHAR_DAD_4 (0x10UL << USB_OTG_HCCHAR_DAD_Pos) |
| #define | USB_OTG_HCCHAR_DAD_5 (0x20UL << USB_OTG_HCCHAR_DAD_Pos) |
| #define | USB_OTG_HCCHAR_DAD_6 (0x40UL << USB_OTG_HCCHAR_DAD_Pos) |
| #define | USB_OTG_HCCHAR_ODDFRM_Pos (29U) |
| #define | USB_OTG_HCCHAR_ODDFRM_Msk (0x1UL << USB_OTG_HCCHAR_ODDFRM_Pos) |
| #define | USB_OTG_HCCHAR_ODDFRM USB_OTG_HCCHAR_ODDFRM_Msk |
| #define | USB_OTG_HCCHAR_CHDIS_Pos (30U) |
| #define | USB_OTG_HCCHAR_CHDIS_Msk (0x1UL << USB_OTG_HCCHAR_CHDIS_Pos) |
| #define | USB_OTG_HCCHAR_CHDIS USB_OTG_HCCHAR_CHDIS_Msk |
| #define | USB_OTG_HCCHAR_CHENA_Pos (31U) |
| #define | USB_OTG_HCCHAR_CHENA_Msk (0x1UL << USB_OTG_HCCHAR_CHENA_Pos) |
| #define | USB_OTG_HCCHAR_CHENA USB_OTG_HCCHAR_CHENA_Msk |
| #define | USB_OTG_HCSPLT_PRTADDR_Pos (0U) |
| #define | USB_OTG_HCSPLT_PRTADDR_Msk (0x7FUL << USB_OTG_HCSPLT_PRTADDR_Pos) |
| #define | USB_OTG_HCSPLT_PRTADDR USB_OTG_HCSPLT_PRTADDR_Msk |
| #define | USB_OTG_HCSPLT_PRTADDR_0 (0x01UL << USB_OTG_HCSPLT_PRTADDR_Pos) |
| #define | USB_OTG_HCSPLT_PRTADDR_1 (0x02UL << USB_OTG_HCSPLT_PRTADDR_Pos) |
| #define | USB_OTG_HCSPLT_PRTADDR_2 (0x04UL << USB_OTG_HCSPLT_PRTADDR_Pos) |
| #define | USB_OTG_HCSPLT_PRTADDR_3 (0x08UL << USB_OTG_HCSPLT_PRTADDR_Pos) |
| #define | USB_OTG_HCSPLT_PRTADDR_4 (0x10UL << USB_OTG_HCSPLT_PRTADDR_Pos) |
| #define | USB_OTG_HCSPLT_PRTADDR_5 (0x20UL << USB_OTG_HCSPLT_PRTADDR_Pos) |
| #define | USB_OTG_HCSPLT_PRTADDR_6 (0x40UL << USB_OTG_HCSPLT_PRTADDR_Pos) |
| #define | USB_OTG_HCSPLT_HUBADDR_Pos (7U) |
| #define | USB_OTG_HCSPLT_HUBADDR_Msk (0x7FUL << USB_OTG_HCSPLT_HUBADDR_Pos) |
| #define | USB_OTG_HCSPLT_HUBADDR USB_OTG_HCSPLT_HUBADDR_Msk |
| #define | USB_OTG_HCSPLT_HUBADDR_0 (0x01UL << USB_OTG_HCSPLT_HUBADDR_Pos) |
| #define | USB_OTG_HCSPLT_HUBADDR_1 (0x02UL << USB_OTG_HCSPLT_HUBADDR_Pos) |
| #define | USB_OTG_HCSPLT_HUBADDR_2 (0x04UL << USB_OTG_HCSPLT_HUBADDR_Pos) |
| #define | USB_OTG_HCSPLT_HUBADDR_3 (0x08UL << USB_OTG_HCSPLT_HUBADDR_Pos) |
| #define | USB_OTG_HCSPLT_HUBADDR_4 (0x10UL << USB_OTG_HCSPLT_HUBADDR_Pos) |
| #define | USB_OTG_HCSPLT_HUBADDR_5 (0x20UL << USB_OTG_HCSPLT_HUBADDR_Pos) |
| #define | USB_OTG_HCSPLT_HUBADDR_6 (0x40UL << USB_OTG_HCSPLT_HUBADDR_Pos) |
| #define | USB_OTG_HCSPLT_XACTPOS_Pos (14U) |
| #define | USB_OTG_HCSPLT_XACTPOS_Msk (0x3UL << USB_OTG_HCSPLT_XACTPOS_Pos) |
| #define | USB_OTG_HCSPLT_XACTPOS USB_OTG_HCSPLT_XACTPOS_Msk |
| #define | USB_OTG_HCSPLT_XACTPOS_0 (0x1UL << USB_OTG_HCSPLT_XACTPOS_Pos) |
| #define | USB_OTG_HCSPLT_XACTPOS_1 (0x2UL << USB_OTG_HCSPLT_XACTPOS_Pos) |
| #define | USB_OTG_HCSPLT_COMPLSPLT_Pos (16U) |
| #define | USB_OTG_HCSPLT_COMPLSPLT_Msk (0x1UL << USB_OTG_HCSPLT_COMPLSPLT_Pos) |
| #define | USB_OTG_HCSPLT_COMPLSPLT USB_OTG_HCSPLT_COMPLSPLT_Msk |
| #define | USB_OTG_HCSPLT_SPLITEN_Pos (31U) |
| #define | USB_OTG_HCSPLT_SPLITEN_Msk (0x1UL << USB_OTG_HCSPLT_SPLITEN_Pos) |
| #define | USB_OTG_HCSPLT_SPLITEN USB_OTG_HCSPLT_SPLITEN_Msk |
| #define | USB_OTG_HCINT_XFRC_Pos (0U) |
| #define | USB_OTG_HCINT_XFRC_Msk (0x1UL << USB_OTG_HCINT_XFRC_Pos) |
| #define | USB_OTG_HCINT_XFRC USB_OTG_HCINT_XFRC_Msk |
| #define | USB_OTG_HCINT_CHH_Pos (1U) |
| #define | USB_OTG_HCINT_CHH_Msk (0x1UL << USB_OTG_HCINT_CHH_Pos) |
| #define | USB_OTG_HCINT_CHH USB_OTG_HCINT_CHH_Msk |
| #define | USB_OTG_HCINT_AHBERR_Pos (2U) |
| #define | USB_OTG_HCINT_AHBERR_Msk (0x1UL << USB_OTG_HCINT_AHBERR_Pos) |
| #define | USB_OTG_HCINT_AHBERR USB_OTG_HCINT_AHBERR_Msk |
| #define | USB_OTG_HCINT_STALL_Pos (3U) |
| #define | USB_OTG_HCINT_STALL_Msk (0x1UL << USB_OTG_HCINT_STALL_Pos) |
| #define | USB_OTG_HCINT_STALL USB_OTG_HCINT_STALL_Msk |
| #define | USB_OTG_HCINT_NAK_Pos (4U) |
| #define | USB_OTG_HCINT_NAK_Msk (0x1UL << USB_OTG_HCINT_NAK_Pos) |
| #define | USB_OTG_HCINT_NAK USB_OTG_HCINT_NAK_Msk |
| #define | USB_OTG_HCINT_ACK_Pos (5U) |
| #define | USB_OTG_HCINT_ACK_Msk (0x1UL << USB_OTG_HCINT_ACK_Pos) |
| #define | USB_OTG_HCINT_ACK USB_OTG_HCINT_ACK_Msk |
| #define | USB_OTG_HCINT_NYET_Pos (6U) |
| #define | USB_OTG_HCINT_NYET_Msk (0x1UL << USB_OTG_HCINT_NYET_Pos) |
| #define | USB_OTG_HCINT_NYET USB_OTG_HCINT_NYET_Msk |
| #define | USB_OTG_HCINT_TXERR_Pos (7U) |
| #define | USB_OTG_HCINT_TXERR_Msk (0x1UL << USB_OTG_HCINT_TXERR_Pos) |
| #define | USB_OTG_HCINT_TXERR USB_OTG_HCINT_TXERR_Msk |
| #define | USB_OTG_HCINT_BBERR_Pos (8U) |
| #define | USB_OTG_HCINT_BBERR_Msk (0x1UL << USB_OTG_HCINT_BBERR_Pos) |
| #define | USB_OTG_HCINT_BBERR USB_OTG_HCINT_BBERR_Msk |
| #define | USB_OTG_HCINT_FRMOR_Pos (9U) |
| #define | USB_OTG_HCINT_FRMOR_Msk (0x1UL << USB_OTG_HCINT_FRMOR_Pos) |
| #define | USB_OTG_HCINT_FRMOR USB_OTG_HCINT_FRMOR_Msk |
| #define | USB_OTG_HCINT_DTERR_Pos (10U) |
| #define | USB_OTG_HCINT_DTERR_Msk (0x1UL << USB_OTG_HCINT_DTERR_Pos) |
| #define | USB_OTG_HCINT_DTERR USB_OTG_HCINT_DTERR_Msk |
| #define | USB_OTG_DIEPINT_XFRC_Pos (0U) |
| #define | USB_OTG_DIEPINT_XFRC_Msk (0x1UL << USB_OTG_DIEPINT_XFRC_Pos) |
| #define | USB_OTG_DIEPINT_XFRC USB_OTG_DIEPINT_XFRC_Msk |
| #define | USB_OTG_DIEPINT_EPDISD_Pos (1U) |
| #define | USB_OTG_DIEPINT_EPDISD_Msk (0x1UL << USB_OTG_DIEPINT_EPDISD_Pos) |
| #define | USB_OTG_DIEPINT_EPDISD USB_OTG_DIEPINT_EPDISD_Msk |
| #define | USB_OTG_DIEPINT_AHBERR_Pos (2U) |
| #define | USB_OTG_DIEPINT_AHBERR_Msk (0x1UL << USB_OTG_DIEPINT_AHBERR_Pos) |
| #define | USB_OTG_DIEPINT_AHBERR USB_OTG_DIEPINT_AHBERR_Msk |
| #define | USB_OTG_DIEPINT_TOC_Pos (3U) |
| #define | USB_OTG_DIEPINT_TOC_Msk (0x1UL << USB_OTG_DIEPINT_TOC_Pos) |
| #define | USB_OTG_DIEPINT_TOC USB_OTG_DIEPINT_TOC_Msk |
| #define | USB_OTG_DIEPINT_ITTXFE_Pos (4U) |
| #define | USB_OTG_DIEPINT_ITTXFE_Msk (0x1UL << USB_OTG_DIEPINT_ITTXFE_Pos) |
| #define | USB_OTG_DIEPINT_ITTXFE USB_OTG_DIEPINT_ITTXFE_Msk |
| #define | USB_OTG_DIEPINT_INEPNM_Pos (5U) |
| #define | USB_OTG_DIEPINT_INEPNM_Msk (0x1UL << USB_OTG_DIEPINT_INEPNM_Pos) |
| #define | USB_OTG_DIEPINT_INEPNM USB_OTG_DIEPINT_INEPNM_Msk |
| #define | USB_OTG_DIEPINT_INEPNE_Pos (6U) |
| #define | USB_OTG_DIEPINT_INEPNE_Msk (0x1UL << USB_OTG_DIEPINT_INEPNE_Pos) |
| #define | USB_OTG_DIEPINT_INEPNE USB_OTG_DIEPINT_INEPNE_Msk |
| #define | USB_OTG_DIEPINT_TXFE_Pos (7U) |
| #define | USB_OTG_DIEPINT_TXFE_Msk (0x1UL << USB_OTG_DIEPINT_TXFE_Pos) |
| #define | USB_OTG_DIEPINT_TXFE USB_OTG_DIEPINT_TXFE_Msk |
| #define | USB_OTG_DIEPINT_TXFIFOUDRN_Pos (8U) |
| #define | USB_OTG_DIEPINT_TXFIFOUDRN_Msk (0x1UL << USB_OTG_DIEPINT_TXFIFOUDRN_Pos) |
| #define | USB_OTG_DIEPINT_TXFIFOUDRN USB_OTG_DIEPINT_TXFIFOUDRN_Msk |
| #define | USB_OTG_DIEPINT_BNA_Pos (9U) |
| #define | USB_OTG_DIEPINT_BNA_Msk (0x1UL << USB_OTG_DIEPINT_BNA_Pos) |
| #define | USB_OTG_DIEPINT_BNA USB_OTG_DIEPINT_BNA_Msk |
| #define | USB_OTG_DIEPINT_PKTDRPSTS_Pos (11U) |
| #define | USB_OTG_DIEPINT_PKTDRPSTS_Msk (0x1UL << USB_OTG_DIEPINT_PKTDRPSTS_Pos) |
| #define | USB_OTG_DIEPINT_PKTDRPSTS USB_OTG_DIEPINT_PKTDRPSTS_Msk |
| #define | USB_OTG_DIEPINT_BERR_Pos (12U) |
| #define | USB_OTG_DIEPINT_BERR_Msk (0x1UL << USB_OTG_DIEPINT_BERR_Pos) |
| #define | USB_OTG_DIEPINT_BERR USB_OTG_DIEPINT_BERR_Msk |
| #define | USB_OTG_DIEPINT_NAK_Pos (13U) |
| #define | USB_OTG_DIEPINT_NAK_Msk (0x1UL << USB_OTG_DIEPINT_NAK_Pos) |
| #define | USB_OTG_DIEPINT_NAK USB_OTG_DIEPINT_NAK_Msk |
| #define | USB_OTG_HCINTMSK_XFRCM_Pos (0U) |
| #define | USB_OTG_HCINTMSK_XFRCM_Msk (0x1UL << USB_OTG_HCINTMSK_XFRCM_Pos) |
| #define | USB_OTG_HCINTMSK_XFRCM USB_OTG_HCINTMSK_XFRCM_Msk |
| #define | USB_OTG_HCINTMSK_CHHM_Pos (1U) |
| #define | USB_OTG_HCINTMSK_CHHM_Msk (0x1UL << USB_OTG_HCINTMSK_CHHM_Pos) |
| #define | USB_OTG_HCINTMSK_CHHM USB_OTG_HCINTMSK_CHHM_Msk |
| #define | USB_OTG_HCINTMSK_AHBERR_Pos (2U) |
| #define | USB_OTG_HCINTMSK_AHBERR_Msk (0x1UL << USB_OTG_HCINTMSK_AHBERR_Pos) |
| #define | USB_OTG_HCINTMSK_AHBERR USB_OTG_HCINTMSK_AHBERR_Msk |
| #define | USB_OTG_HCINTMSK_STALLM_Pos (3U) |
| #define | USB_OTG_HCINTMSK_STALLM_Msk (0x1UL << USB_OTG_HCINTMSK_STALLM_Pos) |
| #define | USB_OTG_HCINTMSK_STALLM USB_OTG_HCINTMSK_STALLM_Msk |
| #define | USB_OTG_HCINTMSK_NAKM_Pos (4U) |
| #define | USB_OTG_HCINTMSK_NAKM_Msk (0x1UL << USB_OTG_HCINTMSK_NAKM_Pos) |
| #define | USB_OTG_HCINTMSK_NAKM USB_OTG_HCINTMSK_NAKM_Msk |
| #define | USB_OTG_HCINTMSK_ACKM_Pos (5U) |
| #define | USB_OTG_HCINTMSK_ACKM_Msk (0x1UL << USB_OTG_HCINTMSK_ACKM_Pos) |
| #define | USB_OTG_HCINTMSK_ACKM USB_OTG_HCINTMSK_ACKM_Msk |
| #define | USB_OTG_HCINTMSK_NYET_Pos (6U) |
| #define | USB_OTG_HCINTMSK_NYET_Msk (0x1UL << USB_OTG_HCINTMSK_NYET_Pos) |
| #define | USB_OTG_HCINTMSK_NYET USB_OTG_HCINTMSK_NYET_Msk |
| #define | USB_OTG_HCINTMSK_TXERRM_Pos (7U) |
| #define | USB_OTG_HCINTMSK_TXERRM_Msk (0x1UL << USB_OTG_HCINTMSK_TXERRM_Pos) |
| #define | USB_OTG_HCINTMSK_TXERRM USB_OTG_HCINTMSK_TXERRM_Msk |
| #define | USB_OTG_HCINTMSK_BBERRM_Pos (8U) |
| #define | USB_OTG_HCINTMSK_BBERRM_Msk (0x1UL << USB_OTG_HCINTMSK_BBERRM_Pos) |
| #define | USB_OTG_HCINTMSK_BBERRM USB_OTG_HCINTMSK_BBERRM_Msk |
| #define | USB_OTG_HCINTMSK_FRMORM_Pos (9U) |
| #define | USB_OTG_HCINTMSK_FRMORM_Msk (0x1UL << USB_OTG_HCINTMSK_FRMORM_Pos) |
| #define | USB_OTG_HCINTMSK_FRMORM USB_OTG_HCINTMSK_FRMORM_Msk |
| #define | USB_OTG_HCINTMSK_DTERRM_Pos (10U) |
| #define | USB_OTG_HCINTMSK_DTERRM_Msk (0x1UL << USB_OTG_HCINTMSK_DTERRM_Pos) |
| #define | USB_OTG_HCINTMSK_DTERRM USB_OTG_HCINTMSK_DTERRM_Msk |
| #define | USB_OTG_DIEPTSIZ_XFRSIZ_Pos (0U) |
| #define | USB_OTG_DIEPTSIZ_XFRSIZ_Msk (0x7FFFFUL << USB_OTG_DIEPTSIZ_XFRSIZ_Pos) |
| #define | USB_OTG_DIEPTSIZ_XFRSIZ USB_OTG_DIEPTSIZ_XFRSIZ_Msk |
| #define | USB_OTG_DIEPTSIZ_PKTCNT_Pos (19U) |
| #define | USB_OTG_DIEPTSIZ_PKTCNT_Msk (0x3FFUL << USB_OTG_DIEPTSIZ_PKTCNT_Pos) |
| #define | USB_OTG_DIEPTSIZ_PKTCNT USB_OTG_DIEPTSIZ_PKTCNT_Msk |
| #define | USB_OTG_DIEPTSIZ_MULCNT_Pos (29U) |
| #define | USB_OTG_DIEPTSIZ_MULCNT_Msk (0x3UL << USB_OTG_DIEPTSIZ_MULCNT_Pos) |
| #define | USB_OTG_DIEPTSIZ_MULCNT USB_OTG_DIEPTSIZ_MULCNT_Msk |
| #define | USB_OTG_HCTSIZ_XFRSIZ_Pos (0U) |
| #define | USB_OTG_HCTSIZ_XFRSIZ_Msk (0x7FFFFUL << USB_OTG_HCTSIZ_XFRSIZ_Pos) |
| #define | USB_OTG_HCTSIZ_XFRSIZ USB_OTG_HCTSIZ_XFRSIZ_Msk |
| #define | USB_OTG_HCTSIZ_PKTCNT_Pos (19U) |
| #define | USB_OTG_HCTSIZ_PKTCNT_Msk (0x3FFUL << USB_OTG_HCTSIZ_PKTCNT_Pos) |
| #define | USB_OTG_HCTSIZ_PKTCNT USB_OTG_HCTSIZ_PKTCNT_Msk |
| #define | USB_OTG_HCTSIZ_DOPING_Pos (31U) |
| #define | USB_OTG_HCTSIZ_DOPING_Msk (0x1UL << USB_OTG_HCTSIZ_DOPING_Pos) |
| #define | USB_OTG_HCTSIZ_DOPING USB_OTG_HCTSIZ_DOPING_Msk |
| #define | USB_OTG_HCTSIZ_DPID_Pos (29U) |
| #define | USB_OTG_HCTSIZ_DPID_Msk (0x3UL << USB_OTG_HCTSIZ_DPID_Pos) |
| #define | USB_OTG_HCTSIZ_DPID USB_OTG_HCTSIZ_DPID_Msk |
| #define | USB_OTG_HCTSIZ_DPID_0 (0x1UL << USB_OTG_HCTSIZ_DPID_Pos) |
| #define | USB_OTG_HCTSIZ_DPID_1 (0x2UL << USB_OTG_HCTSIZ_DPID_Pos) |
| #define | USB_OTG_DIEPDMA_DMAADDR_Pos (0U) |
| #define | USB_OTG_DIEPDMA_DMAADDR_Msk (0xFFFFFFFFUL << USB_OTG_DIEPDMA_DMAADDR_Pos) |
| #define | USB_OTG_DIEPDMA_DMAADDR USB_OTG_DIEPDMA_DMAADDR_Msk |
| #define | USB_OTG_HCDMA_DMAADDR_Pos (0U) |
| #define | USB_OTG_HCDMA_DMAADDR_Msk (0xFFFFFFFFUL << USB_OTG_HCDMA_DMAADDR_Pos) |
| #define | USB_OTG_HCDMA_DMAADDR USB_OTG_HCDMA_DMAADDR_Msk |
| #define | USB_OTG_DTXFSTS_INEPTFSAV_Pos (0U) |
| #define | USB_OTG_DTXFSTS_INEPTFSAV_Msk (0xFFFFUL << USB_OTG_DTXFSTS_INEPTFSAV_Pos) |
| #define | USB_OTG_DTXFSTS_INEPTFSAV USB_OTG_DTXFSTS_INEPTFSAV_Msk |
| #define | USB_OTG_DIEPTXF_INEPTXSA_Pos (0U) |
| #define | USB_OTG_DIEPTXF_INEPTXSA_Msk (0xFFFFUL << USB_OTG_DIEPTXF_INEPTXSA_Pos) |
| #define | USB_OTG_DIEPTXF_INEPTXSA USB_OTG_DIEPTXF_INEPTXSA_Msk |
| #define | USB_OTG_DIEPTXF_INEPTXFD_Pos (16U) |
| #define | USB_OTG_DIEPTXF_INEPTXFD_Msk (0xFFFFUL << USB_OTG_DIEPTXF_INEPTXFD_Pos) |
| #define | USB_OTG_DIEPTXF_INEPTXFD USB_OTG_DIEPTXF_INEPTXFD_Msk |
| #define | USB_OTG_DOEPCTL_MPSIZ_Pos (0U) |
| #define | USB_OTG_DOEPCTL_MPSIZ_Msk (0x7FFUL << USB_OTG_DOEPCTL_MPSIZ_Pos) |
| #define | USB_OTG_DOEPCTL_MPSIZ USB_OTG_DOEPCTL_MPSIZ_Msk /*!< Maximum packet size */ |
| #define | USB_OTG_DOEPCTL_USBAEP_Pos (15U) |
| #define | USB_OTG_DOEPCTL_USBAEP_Msk (0x1UL << USB_OTG_DOEPCTL_USBAEP_Pos) |
| #define | USB_OTG_DOEPCTL_USBAEP USB_OTG_DOEPCTL_USBAEP_Msk |
| #define | USB_OTG_DOEPCTL_NAKSTS_Pos (17U) |
| #define | USB_OTG_DOEPCTL_NAKSTS_Msk (0x1UL << USB_OTG_DOEPCTL_NAKSTS_Pos) |
| #define | USB_OTG_DOEPCTL_NAKSTS USB_OTG_DOEPCTL_NAKSTS_Msk |
| #define | USB_OTG_DOEPCTL_SD0PID_SEVNFRM_Pos (28U) |
| #define | USB_OTG_DOEPCTL_SD0PID_SEVNFRM_Msk (0x1UL << USB_OTG_DOEPCTL_SD0PID_SEVNFRM_Pos) |
| #define | USB_OTG_DOEPCTL_SD0PID_SEVNFRM USB_OTG_DOEPCTL_SD0PID_SEVNFRM_Msk |
| #define | USB_OTG_DOEPCTL_SODDFRM_Pos (29U) |
| #define | USB_OTG_DOEPCTL_SODDFRM_Msk (0x1UL << USB_OTG_DOEPCTL_SODDFRM_Pos) |
| #define | USB_OTG_DOEPCTL_SODDFRM USB_OTG_DOEPCTL_SODDFRM_Msk |
| #define | USB_OTG_DOEPCTL_EPTYP_Pos (18U) |
| #define | USB_OTG_DOEPCTL_EPTYP_Msk (0x3UL << USB_OTG_DOEPCTL_EPTYP_Pos) |
| #define | USB_OTG_DOEPCTL_EPTYP USB_OTG_DOEPCTL_EPTYP_Msk |
| #define | USB_OTG_DOEPCTL_EPTYP_0 (0x1UL << USB_OTG_DOEPCTL_EPTYP_Pos) |
| #define | USB_OTG_DOEPCTL_EPTYP_1 (0x2UL << USB_OTG_DOEPCTL_EPTYP_Pos) |
| #define | USB_OTG_DOEPCTL_SNPM_Pos (20U) |
| #define | USB_OTG_DOEPCTL_SNPM_Msk (0x1UL << USB_OTG_DOEPCTL_SNPM_Pos) |
| #define | USB_OTG_DOEPCTL_SNPM USB_OTG_DOEPCTL_SNPM_Msk |
| #define | USB_OTG_DOEPCTL_STALL_Pos (21U) |
| #define | USB_OTG_DOEPCTL_STALL_Msk (0x1UL << USB_OTG_DOEPCTL_STALL_Pos) |
| #define | USB_OTG_DOEPCTL_STALL USB_OTG_DOEPCTL_STALL_Msk |
| #define | USB_OTG_DOEPCTL_CNAK_Pos (26U) |
| #define | USB_OTG_DOEPCTL_CNAK_Msk (0x1UL << USB_OTG_DOEPCTL_CNAK_Pos) |
| #define | USB_OTG_DOEPCTL_CNAK USB_OTG_DOEPCTL_CNAK_Msk |
| #define | USB_OTG_DOEPCTL_SNAK_Pos (27U) |
| #define | USB_OTG_DOEPCTL_SNAK_Msk (0x1UL << USB_OTG_DOEPCTL_SNAK_Pos) |
| #define | USB_OTG_DOEPCTL_SNAK USB_OTG_DOEPCTL_SNAK_Msk |
| #define | USB_OTG_DOEPCTL_EPDIS_Pos (30U) |
| #define | USB_OTG_DOEPCTL_EPDIS_Msk (0x1UL << USB_OTG_DOEPCTL_EPDIS_Pos) |
| #define | USB_OTG_DOEPCTL_EPDIS USB_OTG_DOEPCTL_EPDIS_Msk |
| #define | USB_OTG_DOEPCTL_EPENA_Pos (31U) |
| #define | USB_OTG_DOEPCTL_EPENA_Msk (0x1UL << USB_OTG_DOEPCTL_EPENA_Pos) |
| #define | USB_OTG_DOEPCTL_EPENA USB_OTG_DOEPCTL_EPENA_Msk |
| #define | USB_OTG_DOEPINT_XFRC_Pos (0U) |
| #define | USB_OTG_DOEPINT_XFRC_Msk (0x1UL << USB_OTG_DOEPINT_XFRC_Pos) |
| #define | USB_OTG_DOEPINT_XFRC USB_OTG_DOEPINT_XFRC_Msk |
| #define | USB_OTG_DOEPINT_EPDISD_Pos (1U) |
| #define | USB_OTG_DOEPINT_EPDISD_Msk (0x1UL << USB_OTG_DOEPINT_EPDISD_Pos) |
| #define | USB_OTG_DOEPINT_EPDISD USB_OTG_DOEPINT_EPDISD_Msk |
| #define | USB_OTG_DOEPINT_AHBERR_Pos (2U) |
| #define | USB_OTG_DOEPINT_AHBERR_Msk (0x1UL << USB_OTG_DOEPINT_AHBERR_Pos) |
| #define | USB_OTG_DOEPINT_AHBERR USB_OTG_DOEPINT_AHBERR_Msk |
| #define | USB_OTG_DOEPINT_STUP_Pos (3U) |
| #define | USB_OTG_DOEPINT_STUP_Msk (0x1UL << USB_OTG_DOEPINT_STUP_Pos) |
| #define | USB_OTG_DOEPINT_STUP USB_OTG_DOEPINT_STUP_Msk |
| #define | USB_OTG_DOEPINT_OTEPDIS_Pos (4U) |
| #define | USB_OTG_DOEPINT_OTEPDIS_Msk (0x1UL << USB_OTG_DOEPINT_OTEPDIS_Pos) |
| #define | USB_OTG_DOEPINT_OTEPDIS USB_OTG_DOEPINT_OTEPDIS_Msk |
| #define | USB_OTG_DOEPINT_OTEPSPR_Pos (5U) |
| #define | USB_OTG_DOEPINT_OTEPSPR_Msk (0x1UL << USB_OTG_DOEPINT_OTEPSPR_Pos) |
| #define | USB_OTG_DOEPINT_OTEPSPR USB_OTG_DOEPINT_OTEPSPR_Msk |
| #define | USB_OTG_DOEPINT_B2BSTUP_Pos (6U) |
| #define | USB_OTG_DOEPINT_B2BSTUP_Msk (0x1UL << USB_OTG_DOEPINT_B2BSTUP_Pos) |
| #define | USB_OTG_DOEPINT_B2BSTUP USB_OTG_DOEPINT_B2BSTUP_Msk |
| #define | USB_OTG_DOEPINT_OUTPKTERR_Pos (8U) |
| #define | USB_OTG_DOEPINT_OUTPKTERR_Msk (0x1UL << USB_OTG_DOEPINT_OUTPKTERR_Pos) |
| #define | USB_OTG_DOEPINT_OUTPKTERR USB_OTG_DOEPINT_OUTPKTERR_Msk |
| #define | USB_OTG_DOEPINT_BERR_Pos (12U) |
| #define | USB_OTG_DOEPINT_BERR_Msk (0x1UL << USB_OTG_DOEPINT_BERR_Pos) |
| #define | USB_OTG_DOEPINT_BERR USB_OTG_DOEPINT_BERR_Msk |
| #define | USB_OTG_DOEPINT_NAK_Pos (13U) |
| #define | USB_OTG_DOEPINT_NAK_Msk (0x1UL << USB_OTG_DOEPINT_NAK_Pos) |
| #define | USB_OTG_DOEPINT_NAK USB_OTG_DOEPINT_NAK_Msk |
| #define | USB_OTG_DOEPINT_NYET_Pos (14U) |
| #define | USB_OTG_DOEPINT_NYET_Msk (0x1UL << USB_OTG_DOEPINT_NYET_Pos) |
| #define | USB_OTG_DOEPINT_NYET USB_OTG_DOEPINT_NYET_Msk |
| #define | USB_OTG_DOEPINT_STPKTRX_Pos (15U) |
| #define | USB_OTG_DOEPINT_STPKTRX_Msk (0x1UL << USB_OTG_DOEPINT_STPKTRX_Pos) |
| #define | USB_OTG_DOEPINT_STPKTRX USB_OTG_DOEPINT_STPKTRX_Msk |
| #define | USB_OTG_DOEPTSIZ_XFRSIZ_Pos (0U) |
| #define | USB_OTG_DOEPTSIZ_XFRSIZ_Msk (0x7FFFFUL << USB_OTG_DOEPTSIZ_XFRSIZ_Pos) |
| #define | USB_OTG_DOEPTSIZ_XFRSIZ USB_OTG_DOEPTSIZ_XFRSIZ_Msk |
| #define | USB_OTG_DOEPTSIZ_PKTCNT_Pos (19U) |
| #define | USB_OTG_DOEPTSIZ_PKTCNT_Msk (0x3FFUL << USB_OTG_DOEPTSIZ_PKTCNT_Pos) |
| #define | USB_OTG_DOEPTSIZ_PKTCNT USB_OTG_DOEPTSIZ_PKTCNT_Msk |
| #define | USB_OTG_DOEPTSIZ_STUPCNT_Pos (29U) |
| #define | USB_OTG_DOEPTSIZ_STUPCNT_Msk (0x3UL << USB_OTG_DOEPTSIZ_STUPCNT_Pos) |
| #define | USB_OTG_DOEPTSIZ_STUPCNT USB_OTG_DOEPTSIZ_STUPCNT_Msk |
| #define | USB_OTG_DOEPTSIZ_STUPCNT_0 (0x1UL << USB_OTG_DOEPTSIZ_STUPCNT_Pos) |
| #define | USB_OTG_DOEPTSIZ_STUPCNT_1 (0x2UL << USB_OTG_DOEPTSIZ_STUPCNT_Pos) |
| #define | USB_OTG_PCGCCTL_STOPCLK_Pos (0U) |
| #define | USB_OTG_PCGCCTL_STOPCLK_Msk (0x1UL << USB_OTG_PCGCCTL_STOPCLK_Pos) |
| #define | USB_OTG_PCGCCTL_STOPCLK USB_OTG_PCGCCTL_STOPCLK_Msk |
| #define | USB_OTG_PCGCCTL_GATECLK_Pos (1U) |
| #define | USB_OTG_PCGCCTL_GATECLK_Msk (0x1UL << USB_OTG_PCGCCTL_GATECLK_Pos) |
| #define | USB_OTG_PCGCCTL_GATECLK USB_OTG_PCGCCTL_GATECLK_Msk |
| #define | USB_OTG_PCGCCTL_PHYSUSP_Pos (4U) |
| #define | USB_OTG_PCGCCTL_PHYSUSP_Msk (0x1UL << USB_OTG_PCGCCTL_PHYSUSP_Pos) |
| #define | USB_OTG_PCGCCTL_PHYSUSP USB_OTG_PCGCCTL_PHYSUSP_Msk |
| #define | IS_ADC_ALL_INSTANCE(INSTANCE) |
| #define | IS_ADC_MULTIMODE_MASTER_INSTANCE(INSTANCE) ((INSTANCE) == ADC1) |
| #define | IS_ADC_COMMON_INSTANCE(INSTANCE) |
| #define | IS_COMP_ALL_INSTANCE(INSTANCE) |
| #define | IS_COMP_COMMON_INSTANCE(INSTANCE) ((INSTANCE) == COMP12_COMMON) |
| #define | IS_COMP_WINDOWMODE_INSTANCE(INSTANCE) ((INSTANCE) == COMP2) |
| #define | IS_CRC_ALL_INSTANCE(INSTANCE) ((INSTANCE) == CRC) |
| #define | IS_DAC_ALL_INSTANCE(INSTANCE) ((INSTANCE) == DAC1) |
| #define | IS_DCMI_ALL_INSTANCE(__INSTANCE__) ((__INSTANCE__) == DCMI) |
| #define | IS_DLYB_ALL_INSTANCE(INSTANCE) |
| #define | IS_DFSDM_FILTER_ALL_INSTANCE(INSTANCE) |
| #define | IS_DFSDM_CHANNEL_ALL_INSTANCE(INSTANCE) |
| #define | IS_RAMECC_MONITOR_ALL_INSTANCE(INSTANCE) |
| #define | IS_DMA_ALL_INSTANCE(INSTANCE) |
| #define | IS_BDMA_CHANNEL_INSTANCE(INSTANCE) |
| #define | IS_DMA_DMAMUX_ALL_INSTANCE(INSTANCE) |
| #define | IS_BDMA_CHANNEL_DMAMUX_INSTANCE(INSTANCE) |
| #define | IS_DMA_STREAM_INSTANCE(INSTANCE) |
| #define | IS_DMA_STREAM_DMAMUX_INSTANCE(INSTANCE) |
| #define | IS_DMA_REQUEST_GEN_ALL_INSTANCE(INSTANCE) |
| #define | IS_DMA2D_ALL_INSTANCE(__INSTANCE__) ((__INSTANCE__) == DMA2D) |
| #define | IS_MDMA_STREAM_ALL_INSTANCE(INSTANCE) |
| #define | IS_QSPI_ALL_INSTANCE(__INSTANCE__) ((__INSTANCE__) == QUADSPI) |
| #define | IS_FDCAN_ALL_INSTANCE(__INSTANCE__) |
| #define | IS_FDCAN_TT_INSTANCE(__INSTANCE__) ((__INSTANCE__) == FDCAN1) |
| #define | IS_GPIO_ALL_INSTANCE(INSTANCE) |
| #define | IS_GPIO_AF_INSTANCE(INSTANCE) IS_GPIO_ALL_INSTANCE(INSTANCE) |
| #define | IS_GPIO_LOCK_INSTANCE(INSTANCE) IS_GPIO_ALL_INSTANCE(INSTANCE) |
| #define | IS_HSEM_ALL_INSTANCE(INSTANCE) ((INSTANCE) == HSEM) |
| #define | HSEM_CPU1_COREID (0x00000003U) /* Semaphore Core CM7 ID */ |
| #define | HSEM_CR_COREID_CPU1 (HSEM_CPU1_COREID << HSEM_CR_COREID_Pos) |
| #define | HSEM_CR_COREID_CURRENT (HSEM_CPU1_COREID << HSEM_CR_COREID_Pos) |
| #define | HSEM_SEMID_MIN (0U) /* HSEM ID Min*/ |
| #define | HSEM_SEMID_MAX (31U) /* HSEM ID Max */ |
| #define | HSEM_PROCESSID_MIN (0U) /* HSEM Process ID Min */ |
| #define | HSEM_PROCESSID_MAX (255U) /* HSEM Process ID Max */ |
| #define | HSEM_CLEAR_KEY_MIN (0U) /* HSEM clear Key Min value */ |
| #define | HSEM_CLEAR_KEY_MAX (0xFFFFU) /* HSEM clear Key Max value */ |
| #define | IS_I2C_ALL_INSTANCE(INSTANCE) |
| #define | IS_SMBUS_ALL_INSTANCE(INSTANCE) |
| #define | IS_I2C_WAKEUP_FROMSTOP_INSTANCE(INSTANCE) IS_I2C_ALL_INSTANCE(INSTANCE) |
| #define | IS_I2S_ALL_INSTANCE(INSTANCE) |
| #define | IS_LTDC_ALL_INSTANCE(INSTANCE) ((INSTANCE) == LTDC) |
| #define | IS_RNG_ALL_INSTANCE(INSTANCE) ((INSTANCE) == RNG) |
| #define | IS_RTC_ALL_INSTANCE(INSTANCE) ((INSTANCE) == RTC) |
| #define | IS_SDMMC_ALL_INSTANCE(_INSTANCE_) |
| #define | IS_SPI_ALL_INSTANCE(INSTANCE) |
| #define | IS_SPI_HIGHEND_INSTANCE(INSTANCE) |
| #define | IS_SWPMI_INSTANCE(INSTANCE) ((INSTANCE) == SWPMI1) |
| #define | IS_LPTIM_INSTANCE(INSTANCE) |
| #define | IS_LPTIM_ENCODER_INTERFACE_INSTANCE(INSTANCE) |
| #define | IS_TIM_INSTANCE(INSTANCE) |
| #define | IS_TIM_CC1_INSTANCE(INSTANCE) |
| #define | IS_TIM_CC2_INSTANCE(INSTANCE) |
| #define | IS_TIM_CC3_INSTANCE(INSTANCE) |
| #define | IS_TIM_CC4_INSTANCE(INSTANCE) |
| #define | IS_TIM_CC5_INSTANCE(INSTANCE) |
| #define | IS_TIM_CC6_INSTANCE(INSTANCE) |
| #define | IS_TIM_ADVANCED_INSTANCE(__INSTANCE__) |
| #define | IS_TIM_XOR_INSTANCE(INSTANCE) |
| #define | IS_TIM_DMA_INSTANCE(INSTANCE) |
| #define | IS_TIM_DMA_CC_INSTANCE(INSTANCE) |
| #define | IS_TIM_CCDMA_INSTANCE(INSTANCE) |
| #define | IS_TIM_DMABURST_INSTANCE(INSTANCE) |
| #define | IS_TIM_ETR_INSTANCE(INSTANCE) |
| #define | IS_TIM_REMAP_INSTANCE(INSTANCE) |
| #define | IS_TIM_ETRSEL_INSTANCE(INSTANCE) |
| #define | IS_TIM_MASTER_INSTANCE(INSTANCE) |
| #define | IS_TIM_SLAVE_INSTANCE(INSTANCE) |
| #define | IS_TIM_TRGO2_INSTANCE(INSTANCE) |
| #define | IS_TIM_TISEL_INSTANCE(INSTANCE) |
| #define | IS_TIM_COMMUTATION_EVENT_INSTANCE(INSTANCE) |
| #define | IS_TIM_ENCODER_INTERFACE_INSTANCE(__INSTANCE__) |
| #define | IS_TIM_COMBINED3PHASEPWM_INSTANCE(INSTANCE) |
| #define | IS_TIM_CCX_INSTANCE(INSTANCE, CHANNEL) |
| #define | IS_TIM_BREAK_INSTANCE(INSTANCE) |
| #define | IS_TIM_BREAKSOURCE_INSTANCE(INSTANCE) |
| #define | IS_TIM_CCXN_INSTANCE(INSTANCE, CHANNEL) |
| #define | IS_TIM_COUNTER_MODE_SELECT_INSTANCE(INSTANCE) |
| #define | IS_TIM_REPETITION_COUNTER_INSTANCE(INSTANCE) |
| #define | IS_TIM_SYNCHRO_INSTANCE(__INSTANCE__) |
| #define | IS_TIM_CLOCK_DIVISION_INSTANCE(INSTANCE) |
| #define | IS_TIM_CLOCKSOURCE_ETRMODE1_INSTANCE(INSTANCE) |
| #define | IS_TIM_CLOCKSOURCE_ETRMODE2_INSTANCE(INSTANCE) |
| #define | IS_TIM_CLOCKSOURCE_TIX_INSTANCE(INSTANCE) |
| #define | IS_TIM_CLOCKSOURCE_ITRX_INSTANCE(INSTANCE) |
| #define | IS_TIM_OCXREF_CLEAR_INSTANCE(INSTANCE) |
| #define | IS_TIM_32B_COUNTER_INSTANCE(INSTANCE) |
| #define | IS_TIM_BKIN2_INSTANCE(INSTANCE) |
| #define | IS_TIM_HALL_SENSOR_INTERFACE_INSTANCE(__INSTANCE__) |
| #define | IS_HRTIM_ALL_INSTANCE(INSTANCE) (((INSTANCE) == HRTIM1)) |
| #define | IS_USART_INSTANCE(INSTANCE) |
| #define | IS_UART_SPI_SLAVE_INSTANCE(INSTANCE) |
| #define | IS_UART_INSTANCE(INSTANCE) |
| #define | IS_UART_FIFO_INSTANCE(INSTANCE) |
| #define | IS_USART_AUTOBAUDRATE_DETECTION_INSTANCE(INSTANCE) |
| #define | IS_UART_DRIVER_ENABLE_INSTANCE(INSTANCE) |
| #define | IS_UART_HALFDUPLEX_INSTANCE(INSTANCE) |
| #define | IS_UART_HWFLOW_INSTANCE(INSTANCE) |
| #define | IS_UART_LIN_INSTANCE(INSTANCE) |
| #define | IS_UART_WAKEUP_FROMSTOP_INSTANCE(INSTANCE) |
| #define | IS_IRDA_INSTANCE(INSTANCE) |
| #define | IS_SMARTCARD_INSTANCE(INSTANCE) |
| #define | IS_LPUART_INSTANCE(INSTANCE) ((INSTANCE) == LPUART1) |
| #define | IS_IWDG_ALL_INSTANCE(INSTANCE) ((INSTANCE) == IWDG1) |
| #define | IS_USB_ALL_INSTANCE(INSTANCE) ((INSTANCE) == USB) |
| #define | IS_WWDG_ALL_INSTANCE(INSTANCE) ((INSTANCE) == WWDG1) |
| #define | IS_MDIOS_ALL_INSTANCE(INSTANCE) ((INSTANCE) == MDIOS) |
| #define | IS_CEC_ALL_INSTANCE(__INSTANCE__) ((__INSTANCE__) == CEC) |
| #define | IS_SAI_ALL_INSTANCE(INSTANCE) |
| #define | IS_SPDIFRX_ALL_INSTANCE(INSTANCE) ((INSTANCE) == SPDIFRX) |
| #define | IS_OPAMP_ALL_INSTANCE(INSTANCE) |
| #define | IS_OPAMP_COMMON_INSTANCE(COMMON_INSTANCE) ((COMMON_INSTANCE) == OPAMP12_COMMON) |
| #define | IS_PCD_ALL_INSTANCE(INSTANCE) |
| #define | IS_HCD_ALL_INSTANCE(INSTANCE) |
| #define | RNG_IRQn HASH_RNG_IRQn |
| #define | TIM1_BRK_TIM9_IRQn TIM1_BRK_IRQn |
| #define | TIM1_UP_TIM10_IRQn TIM1_UP_IRQn |
| #define | TIM1_TRG_COM_TIM11_IRQn TIM1_TRG_COM_IRQn |
| #define | PVD_IRQn PVD_AVD_IRQn |
| #define | RNG_IRQHandler HASH_RNG_IRQHandler |
| #define | TIM1_BRK_TIM9_IRQHandler TIM1_BRK_IRQHandler |
| #define | TIM1_UP_TIM9_IRQHandler TIM1_UP_IRQHandler |
| #define | TIM1_TRG_COM_TIM11_IRQHandler TIM1_TRG_COM_IRQHandler |
| #define | PVD_IRQHandler PVD_AVD_IRQHandler |
| #define | COMP_IRQHandler COMP1_IRQHandler |
CMSIS STM32H753xx Device Peripheral Access Layer Header File.
Copyright (c) 2019 STMicroelectronics. All rights reserved.
