RTEMS 6.1-rc8
Regulator Library Implementation. More...
#include <stdlib.h>#include <rtems.h>#include <rtems/regulator.h>#include <string.h>#include <rtems/regulatorimpl.h>Functions | |
| rtems_status_code | rtems_regulator_create (rtems_regulator_attributes *attributes, rtems_regulator_instance **regulator) |
| Create a regulator. | |
| rtems_status_code | rtems_regulator_delete (rtems_regulator_instance *regulator, rtems_interval ticks) |
| Delete a regulator. | |
| rtems_status_code | rtems_regulator_obtain_buffer (rtems_regulator_instance *regulator, void **buffer) |
| Obtain Buffer from Regulator. | |
| rtems_status_code | rtems_regulator_release_buffer (rtems_regulator_instance *regulator, void *buffer) |
| Release Previously Obtained Regulator Buffer. | |
| rtems_status_code | rtems_regulator_send (rtems_regulator_instance *regulator, void *message, size_t length) |
| Send to regulator instance. | |
| rtems_status_code | rtems_regulator_get_statistics (rtems_regulator_instance *regulator, rtems_regulator_statistics *statistics) |
| Obtain statistics for regulator instance. | |
