RTEMS
6.1-rc8
bsps
include
grlib
grpci.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
4
* COPYRIGHT (c) 2015.
5
* Cobham Gaisler.
6
7
8
* modification, are permitted provided that the following conditions
9
* are met:
10
* 1. Redistributions of source code must retain the above copyright
11
* notice, this list of conditions and the following disclaimer.
12
* 2. Redistributions in binary form must reproduce the above copyright
13
* notice, this list of conditions and the following disclaimer in the
14
* documentation and/or other materials provided with the distribution.
15
16
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
17
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
18
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
19
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
20
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
21
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
22
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
23
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
24
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
25
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
26
* POSSIBILITY OF SUCH DAMAGE.
27
28
29
30
#ifndef __GRPCI_H__
31
#define __GRPCI_H__
32
33
#ifdef __cplusplus
34
extern
"C"
35
#endif
36
37
/* Register the GRPCI driver to the Driver Manager */
38
extern
void
grpci_register_drv(
void
39
40
/* Transfer data using GRPCI DMA unit from AMBA to PCI space. Blocks until
41
* operation completes.
42
43
int
grpci_dma_to_pci(
44
unsigned
int
ahb_addr,
45
unsigned
int
pci_addr,
46
unsigned
int
len);
47
48
/* Transfer data using GRPCI DMA unit from PCI to AMBA space. Blocks until
49
50
51
int
grpci_dma_from_pci(
52
unsigned
int
ahb_addr,
53
unsigned
int
pci_addr,
54
unsigned
int
len);
55
56
#ifdef __cplusplus
57
58
#endif
59
60
#endif
