#define | LPC32XX_BASE_ADC 0x40048000 |
#define | LPC32XX_BASE_SYSCON 0x40004000 |
#define | LPC32XX_BASE_DEBUG_CTRL 0x40040000 |
#define | LPC32XX_BASE_DMA 0x31000000 |
#define | LPC32XX_BASE_EMC 0x31080000 |
#define | LPC32XX_BASE_EMC_CS_0 0xe0000000 |
#define | LPC32XX_BASE_EMC_CS_1 0xe1000000 |
#define | LPC32XX_BASE_EMC_CS_2 0xe2000000 |
#define | LPC32XX_BASE_EMC_CS_3 0xe3000000 |
#define | LPC32XX_BASE_EMC_DYCS_0 0x80000000 |
#define | LPC32XX_BASE_EMC_DYCS_1 0xa0000000 |
#define | LPC32XX_BASE_ETB_CFG 0x310c0000 |
#define | LPC32XX_BASE_ETB_DATA 0x310e0000 |
#define | LPC32XX_BASE_ETHERNET 0x31060000 |
#define | LPC32XX_BASE_GPIO 0x40028000 |
#define | LPC32XX_BASE_I2C_1 0x400a0000 |
#define | LPC32XX_BASE_I2C_2 0x400a8000 |
#define | LPC32XX_BASE_I2S_0 0x20094000 |
#define | LPC32XX_BASE_I2S_1 0x2009c000 |
#define | LPC32XX_BASE_IRAM 0x08000000 |
#define | LPC32XX_BASE_IROM 0x0c000000 |
#define | LPC32XX_BASE_KEYSCAN 0x40050000 |
#define | LPC32XX_BASE_LCD 0x31040000 |
#define | LPC32XX_BASE_MCPWM 0x400e8000 |
#define | LPC32XX_BASE_MIC 0x40008000 |
#define | LPC32XX_BASE_NAND_MLC 0x200a8000 |
#define | LPC32XX_BASE_NAND_SLC 0x20020000 |
#define | LPC32XX_BASE_PWM_1 0x4005c000 |
#define | LPC32XX_BASE_PWM_2 0x4005c004 |
#define | LPC32XX_BASE_PWM_3 0x4002c000 |
#define | LPC32XX_BASE_PWM_4 0x40030000 |
#define | LPC32XX_BASE_RTC 0x40024000 |
#define | LPC32XX_BASE_RTC_RAM 0x40024080 |
#define | LPC32XX_BASE_SDCARD 0x20098000 |
#define | LPC32XX_BASE_SIC_1 0x4000c000 |
#define | LPC32XX_BASE_SIC_2 0x40010000 |
#define | LPC32XX_BASE_SPI_1 0x20088000 |
#define | LPC32XX_BASE_SPI_2 0x20090000 |
#define | LPC32XX_BASE_SSP_0 0x20084000 |
#define | LPC32XX_BASE_SSP_1 0x2008c000 |
#define | LPC32XX_BASE_TIMER_0 0x40044000 |
#define | LPC32XX_BASE_TIMER_1 0x4004c000 |
#define | LPC32XX_BASE_TIMER_2 0x40058000 |
#define | LPC32XX_BASE_TIMER_3 0x40060000 |
#define | LPC32XX_BASE_TIMER_5 0x4002c000 |
#define | LPC32XX_BASE_TIMER_6 0x40030000 |
#define | LPC32XX_BASE_TIMER_HS 0x40038000 |
#define | LPC32XX_BASE_TIMER_MS 0x40034000 |
#define | LPC32XX_BASE_UART_1 0x40014000 |
#define | LPC32XX_BASE_UART_2 0x40018000 |
#define | LPC32XX_BASE_UART_3 0x40080000 |
#define | LPC32XX_BASE_UART_4 0x40088000 |
#define | LPC32XX_BASE_UART_5 0x40090000 |
#define | LPC32XX_BASE_UART_6 0x40098000 |
#define | LPC32XX_BASE_UART_7 0x4001c000 |
#define | LPC32XX_BASE_USB 0x31020000 |
#define | LPC32XX_BASE_USB_OTG_I2C 0x31020300 |
#define | LPC32XX_BASE_WDT 0x4003c000 |
#define | LPC32XX_U3CLK (*(volatile uint32_t *) 0x400040d0) |
#define | LPC32XX_U4CLK (*(volatile uint32_t *) 0x400040d4) |
#define | LPC32XX_U5CLK (*(volatile uint32_t *) 0x400040d8) |
#define | LPC32XX_U6CLK (*(volatile uint32_t *) 0x400040dc) |
#define | LPC32XX_IRDACLK (*(volatile uint32_t *) 0x400040e0) |
#define | LPC32XX_UART_CTRL (*(volatile uint32_t *) 0x40054000) |
#define | LPC32XX_UART_CLKMODE (*(volatile uint32_t *) 0x40054004) |
#define | LPC32XX_UART_LOOP (*(volatile uint32_t *) 0x40054008) |
#define | LPC32XX_SW_INT (*(volatile uint32_t *) 0x400040a8) |
#define | LPC32XX_MAC_CLK_CTRL (*(volatile uint32_t *) 0x40004090) |
#define | LPC32XX_USB_DIV (*(volatile uint32_t *) 0x4000401c) |
#define | LPC32XX_OTG_CLK_CTRL (*(volatile uint32_t *) 0x31020ff4) |
#define | LPC32XX_OTG_CLK_STAT (*(volatile uint32_t *) 0x31020ff8) |
#define | LPC32XX_OTG_STAT_CTRL (*(volatile uint32_t *) 0x31020110) |
#define | LPC32XX_I2C_RX (*(volatile uint32_t *) 0x31020300) |
#define | LPC32XX_I2C_TX (*(volatile uint32_t *) 0x31020300) |
#define | LPC32XX_I2C_STS (*(volatile uint32_t *) 0x31020304) |
#define | LPC32XX_I2C_CTL (*(volatile uint32_t *) 0x31020308) |
#define | LPC32XX_I2C_CLKHI (*(volatile uint32_t *) 0x3102030c) |
#define | LPC32XX_I2C_CLKLO (*(volatile uint32_t *) 0x31020310) |
#define | LPC32XX_PWR_CTRL (*(volatile uint32_t *) 0x40004044) |
#define | LPC32XX_OSC_CTRL (*(volatile uint32_t *) 0x4000404c) |
#define | LPC32XX_SYSCLK_CTRL (*(volatile uint32_t *) 0x40004050) |
#define | LPC32XX_PLL397_CTRL (*(volatile uint32_t *) 0x40004048) |
#define | LPC32XX_HCLKPLL_CTRL (*(volatile uint32_t *) 0x40004058) |
#define | LPC32XX_HCLKDIV_CTRL (*(volatile uint32_t *) 0x40004040) |
#define | LPC32XX_TEST_CLK (*(volatile uint32_t *) 0x400040a4) |
#define | LPC32XX_AUTOCLK_CTRL (*(volatile uint32_t *) 0x400040ec) |
#define | LPC32XX_START_ER_PIN (*(volatile uint32_t *) 0x40004030) |
#define | LPC32XX_START_ER_INT (*(volatile uint32_t *) 0x40004020) |
#define | LPC32XX_P0_INTR_ER (*(volatile uint32_t *) 0x40004018) |
#define | LPC32XX_START_SR_PIN (*(volatile uint32_t *) 0x40004038) |
#define | LPC32XX_START_SR_INT (*(volatile uint32_t *) 0x40004028) |
#define | LPC32XX_START_RSR_PIN (*(volatile uint32_t *) 0x40004034) |
#define | LPC32XX_START_RSR_INT (*(volatile uint32_t *) 0x40004024) |
#define | LPC32XX_START_APR_PIN (*(volatile uint32_t *) 0x4000403c) |
#define | LPC32XX_START_APR_INT (*(volatile uint32_t *) 0x4000402c) |
#define | LPC32XX_USB_CTRL (*(volatile uint32_t *) 0x40004064) |
#define | LPC32XX_USBDIV_CTRL (*(volatile uint32_t *) 0x4000401c) |
#define | LPC32XX_MS_CTRL (*(volatile uint32_t *) 0x40004080) |
#define | LPC32XX_DMACLK_CTRL (*(volatile uint32_t *) 0x400040e8) |
#define | LPC32XX_FLASHCLK_CTRL (*(volatile uint32_t *) 0x400040c8) |
#define | LPC32XX_MACCLK_CTRL (*(volatile uint32_t *) 0x40004090) |
#define | LPC32XX_LCDCLK_CTRL (*(volatile uint32_t *) 0x40004054) |
#define | LPC32XX_I2S_CTRL (*(volatile uint32_t *) 0x4000407c) |
#define | LPC32XX_SSP_CTRL (*(volatile uint32_t *) 0x40004078) |
#define | LPC32XX_SPI_CTRL (*(volatile uint32_t *) 0x400040c4) |
#define | LPC32XX_I2CCLK_CTRL (*(volatile uint32_t *) 0x400040ac) |
#define | LPC32XX_TIMCLK_CTRL1 (*(volatile uint32_t *) 0x400040c0) |
#define | LPC32XX_TIMCLK_CTRL (*(volatile uint32_t *) 0x400040bc) |
#define | LPC32XX_ADCLK_CTRL (*(volatile uint32_t *) 0x400040b4) |
#define | LPC32XX_ADCLK_CTRL1 (*(volatile uint32_t *) 0x40004060) |
#define | LPC32XX_KEYCLK_CTRL (*(volatile uint32_t *) 0x400040b0) |
#define | LPC32XX_PWMCLK_CTRL (*(volatile uint32_t *) 0x400040b8) |
#define | LPC32XX_UARTCLK_CTRL (*(volatile uint32_t *) 0x400040e4) |
#define | LPC32XX_POS0_IRAM_CTRL (*(volatile uint32_t *) 0x40004110) |
#define | LPC32XX_POS1_IRAM_CTRL (*(volatile uint32_t *) 0x40004114) |
#define | LPC32XX_SDRAMCLK_CTRL (*(volatile uint32_t *) 0x40004068) |
#define | HCLK_PLL_LOCK BSP_BIT32(0) |
#define | HCLK_PLL_M(val) BSP_FLD32(val, 1, 8) |
#define | HCLK_PLL_M_GET(reg) BSP_FLD32GET(reg, 1, 8) |
#define | HCLK_PLL_N(val) BSP_FLD32(val, 9, 10) |
#define | HCLK_PLL_N_GET(reg) BSP_FLD32GET(reg, 9, 10) |
#define | HCLK_PLL_P(val) BSP_FLD32(val, 11, 12) |
#define | HCLK_PLL_P_GET(reg) BSP_FLD32GET(reg, 11, 12) |
#define | HCLK_PLL_FBD_FCLKOUT BSP_BIT32(13) |
#define | HCLK_PLL_DIRECT BSP_BIT32(14) |
#define | HCLK_PLL_BYPASS BSP_BIT32(15) |
#define | HCLK_PLL_POWER BSP_BIT32(16) |
Register definitions.
