RTEMS 6.1-rc8
Shared register definitions for or1k systems. More...
file  generic_or1k.h
 Register definitions.
Register Macros
#define OR1K_REG(x)   (*((volatile unsigned char *) (x)))
#define OR1K_BIT(n)   (1 << (n))
Internal OR1K UART Registers
#define OR1K_BSP_CLOCK_FREQ   50000000UL
#define OR1K_BSP_UART_BASE   0x90000000
#define OR1K_BSP_UART_REG_TX   (OR1K_BSP_UART_BASE+0)
#define OR1K_BSP_UART_REG_RX   (OR1K_BSP_UART_BASE+0)
#define OR1K_BSP_UART_REG_DEV_LATCH_LOW   (OR1K_BSP_UART_BASE+0)
#define OR1K_BSP_UART_REG_DEV_LATCH_HIGH   (OR1K_BSP_UART_BASE+1)
#define OR1K_BSP_UART_REG_INT_ENABLE   (OR1K_BSP_UART_BASE+1)
#define OR1K_BSP_UART_REG_INT_ID   (OR1K_BSP_UART_BASE+2)
#define OR1K_BSP_UART_REG_FIFO_CTRL   (OR1K_BSP_UART_BASE+2)
#define OR1K_BSP_UART_REG_LINE_CTRL   (OR1K_BSP_UART_BASE+3)
#define OR1K_BSP_UART_REG_MODEM_CTRL   (OR1K_BSP_UART_BASE+4)
#define OR1K_BSP_UART_REG_LINE_STATUS   (OR1K_BSP_UART_BASE+5)
#define OR1K_BSP_UART_REG_MODEM_STATUS   (OR1K_BSP_UART_BASE+6)
#define OR1K_BSP_UART_REG_SCRATCH   (OR1K_BSP_UART_BASE+7)
#define OR1K_BSP_UART_REG_FIFO_CTRL_TRIGGER_1   (0x00)
#define OR1K_BSP_UART_REG_FIFO_CTRL_ENABLE_FIFO   (0x01)
#define OR1K_BSP_UART_REG_FIFO_CTRL_CLEAR_RCVR   (0x02)
#define OR1K_BSP_UART_REG_FIFO_CTRL_CLEAR_XMIT   (0x03)
#define OR1K_BSP_UART_REG_FIFO_CTRL_DMA_SELECT   (0x08)
#define OR1K_BSP_UART_REG_FIFO_CTRL_TRIGGER_4   (0x40)
#define OR1K_BSP_UART_REG_FIFO_CTRL_TRIGGER_8   (0x80)
#define OR1K_BSP_UART_REG_FIFO_CTRL_TRIGGER_14   (0xC0)
#define OR1K_BSP_UART_REG_FIFO_CTRL_TRIGGER_MASK   (0xC0)
#define OR1K_BSP_UART_REG_LINE_CTRL_WLEN5   (0x00)
#define OR1K_BSP_UART_REG_LINE_CTRL_WLEN6   (0x01)
#define OR1K_BSP_UART_REG_LINE_CTRL_WLEN7   (0x02)
#define OR1K_BSP_UART_REG_LINE_CTRL_WLEN8   (0x03)
#define OR1K_BSP_UART_REG_LINE_CTRL_STOP   (0x04)
#define OR1K_BSP_UART_REG_LINE_CTRL_PARITY   (0x08)
#define OR1K_BSP_UART_REG_LINE_CTRL_EPAR   (0x10)
#define OR1K_BSP_UART_REG_LINE_CTRL_SPAR   (0x20)
#define OR1K_BSP_UART_REG_LINE_CTRL_SBC   (0x40)
#define OR1K_BSP_UART_REG_LINE_CTRL_DLAB   (0x80)
#define OR1K_BSP_UART_REG_LINE_STATUS_DR   (0x01)
#define OR1K_BSP_UART_REG_LINE_STATUS_OE   (0x02)
#define OR1K_BSP_UART_REG_LINE_STATUS_PE   (0x04)
#define OR1K_BSP_UART_REG_LINE_STATUS_FE   (0x08)
#define OR1K_BSP_UART_REG_LINE_STATUS_BI   (0x10)
#define OR1K_BSP_UART_REG_LINE_STATUS_THRE   (0x20)
#define OR1K_BSP_UART_REG_LINE_STATUS_TEMT   (0x40)
#define OR1K_BSP_UART_REG_MODEM_CTRL_DTR   (0x01)
#define OR1K_BSP_UART_REG_MODEM_CTRL_RTS   (0x02)
#define OR1K_BSP_UART_REG_MODEM_CTRL_OUT1   (0x04)
#define OR1K_BSP_UART_REG_MODEM_CTRL_OUT2   (0x08)
#define OR1K_BSP_UART_REG_MODEM_CTRL_LOOP   (0x10)
#define OR1K_BSP_UART_REG_MODEM_STATUS_DCTS   (0x01)
#define OR1K_BSP_UART_REG_MODEM_STATUS_DDSR   (0x02)
#define OR1K_BSP_UART_REG_MODEM_STATUS_TERI   (0x04)
#define OR1K_BSP_UART_REG_MODEM_STATUS_DDCD   (0x08)
#define OR1K_BSP_UART_REG_MODEM_STATUS_CTS   (0x10)
#define OR1K_BSP_UART_REG_MODEM_STATUS_DSR   (0x20)
#define OR1K_BSP_UART_REG_MODEM_STATUS_RI   (0x40)
#define OR1K_BSP_UART_REG_MODEM_STATUS_DCD   (0x80)
#define OR1K_BSP_UART_REG_MODEM_STATUS_ANY_DELTA   (0x0F)
