RTEMS 6.1-rc8
This validation test suite is intended test cases related to the use of timecouters. The Clock Driver is disabled. More...
Modules | |
| spec:/score/timecounter/val/get-smp | |
| Tests directives to get a time value. | |
Files | |
| file | ts-validation-timecounter-smp-0.c |
| #define | CONFIGURE_MAXIMUM_PROCESSORS 4 |
| #define | CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER |
| const char | rtems_test_name [] = "TestsuitesValidationTimecounterSmp0" |
| Each test must define a test name string. | |
