RTEMS 6.1-rc8
This general purpose validation test suite provides enough resources to run basic tests for all specified managers and functions. More...
Modules | |
| spec:/acfg/val/appl-needs-clock-driver | |
| Tests the effect of the CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER application configuration option. | |
| spec:/rtems/event/req/send-receive | |
| spec:/rtems/event/val/send-receive | |
| Tests the rtems_event_send() and rtems_event_receive() directives. | |
| spec:/rtems/event/val/system-send-receive | |
| Tests the rtems_event_system_send() and rtems_event_system_receive() directives. | |
| spec:/score/thread/val/idle-body-no-return | |
| Tests thread idle body behaviour. | |
Files | |
| file | ts-validation-0.c |
| #define | CONFIGURE_MAXIMUM_PROCESSORS 5 |
| const char | rtems_test_name [] = "TestsuitesValidation0" |
| Each test must define a test name string. | |
In SMP configurations, up to three scheduler instances using the SMP EDF scheduler are provided using up to four processors.
