RTEMS 6.1-rc8
This validation test suite contains a test case which triggers a fatal error during system initialization. More...
Modules | |
| spec:/acfg/val/fatal-too-large-tls-size | |
| Tests a fatal error. | |
Files | |
| file | ts-fatal-too-large-tls-size.c |
| #define | FATAL_SYSINIT_RUN AcfgValFatalTooLargeTlsSize_Run |
| #define | CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER |
| #define | CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE RTEMS_TASK_STORAGE_ALIGNMENT |
| const char | rtems_test_name [] = "TestsuitesFatalTooLargeTlsSize" |
| Each test must define a test name string. | |
