RTEMS 6.1-rc8
Tests system termination procedure. More...
Files | |
| file | tc-terminate.c |
| file | tc-userext.h |
| This header file provides functions used by corresponding test suite. | |
| struct | FatalInfo |
| void * | __real__CPU_Thread_Idle_body (void *arg) |
| void * | __wrap__CPU_Thread_Idle_body (void *arg) |
| void | FatalExtension0 (rtems_fatal_source source, bool always_set_to_false, rtems_fatal_code code) |
| void | FatalExtension1 (rtems_fatal_source source, bool always_set_to_false, rtems_fatal_code code) |
| T_TEST_CASE (ScoreInterrValTerminate) | |
This test case performs the following actions:
