RTEMS 6.1-rc8
This group contains the GRSPW2 interfaces. More...
Modules | |
| Clock divisor (CLKDIV) | |
| This group contains register bit definitions. | |
| Control (CTRL) | |
| Default address (DEFADDR) | |
| Destination key (DKEY) | |
| GRSPW2 DMA | |
| This group contains the GRSPW2 DMA interfaces. | |
| Interrupt distribution INT / ACK timer reload (IATIMER) | |
| Interrupt distribution ISR (ISR) | |
| Interrupt distribution ISR extended (ISREXT) | |
| Interrupt distribution ISR timer reload (ISRTIMER) | |
| Interrupt distribution change timer reload (ICTIMER) | |
| Interrupt distribution configuration (INTCFG) | |
| Interrupt distribution control (INTCTRL) | |
| Interrupt distribution prescaler reload (PRESCALER) | |
| Interrupt tick-out mask (TICKMASK) | |
| Interrupt timeout (INTTO) | |
| Interrupt timeout extended (INTTOEXT) | |
| Interrupt-code auto acknowledge mask / interrupt tick-out mask extended (AUTOACK_TICKMASKEXT) | |
| Interrupt-code receive (INTRX) | |
| SpaceWire Plug-and-Play - Device ID (PNPDEVID) | |
| SpaceWire Plug-and-Play - Device Vendor and Product ID (PNPVEND) | |
| SpaceWire Plug-and-Play - Owner Address 0 (PNPOA0) | |
| SpaceWire Plug-and-Play - Owner Address 1 (PNPOA1) | |
| SpaceWire Plug-and-Play - Owner Address 2 (PNPOA2) | |
| SpaceWire Plug-and-Play - Unit Serial Number (PNPUSN) | |
| SpaceWire Plug-and-Play - Unit Vendor and Product ID (PNPUVEND) | |
| Status (STS) | |
| Time-code (TC) | |
Files | |
| file | grspw2-regs.h |
| This header file defines the GRSPW2 register block interface. | |
| struct | grspw2 |
| This structure defines the GRSPW2 register block memory map. More... | |
Typedefs | |
| typedef struct grspw2 | grspw2 |
| This structure defines the GRSPW2 register block memory map. | |
