RTEMS 6.1-rc8
This group contains the GRCAN interfaces. More...
Modules | |
| Configuration Register (CanCONF) | |
| This group contains register bit definitions. | |
| Control Register (CanCTRL) | |
| Receive Channel Address Register (CanRxADDR) | |
| Receive Channel Code Register (CanRxCODE) | |
| Receive Channel Control Register (CanRxCTRL) | |
| Receive Channel Interrupt Register (CanRxIRQ) | |
| Receive Channel Mask Register (CanRxMASK) | |
| Receive Channel Read Register (CanRxRD) | |
| Receive Channel Size Register (CanRxSIZE) | |
| Receive Channel Write Register (CanRxWR) | |
| SYNC Code Filter Register (CanCODE) | |
| SYNC Mask Filter Register (CanMASK) | |
| Status Register (CanSTAT) | |
| Transmit Channel Address Register (CanTxADDR) | |
| Transmit Channel Control Register (CanTxCTRL) | |
| Transmit Channel Interrupt Register (CanTxIRQ) | |
| Transmit Channel Read Register (CanTxRD) | |
| Transmit Channel Size Register (CanTxSIZE) | |
| Transmit Channel Write Register (CanTxWR) | |
Files | |
| file | grcan-regs.h |
| This header file defines the GRCAN register block interface. | |
| struct | grcan |
| This structure defines the GRCAN register block memory map. More... | |
Typedefs | |
| typedef struct grcan | grcan |
| This structure defines the GRCAN register block memory map. | |
