RTEMS 6.1-rc8
This header file defines the GRETH_GBIT register block interface. More...
#include <stdint.h>Go to the source code of this file.
| struct | grethgbit |
| This structure defines the GRETH_GBIT register block memory map. More... | |
| #define | GRETHGBIT_CR_EA 0x80000000U |
| #define | GRETHGBIT_CR_BS_SHIFT 28 |
| #define | GRETHGBIT_CR_BS_MASK 0x70000000U |
| #define | GRETHGBIT_CR_BS_GET(_reg) |
| #define | GRETHGBIT_CR_BS_SET(_reg, _val) |
| #define | GRETHGBIT_CR_BS(_val) |
| #define | GRETHGBIT_CR_GA 0x8000000U |
| #define | GRETHGBIT_CR_MA 0x4000000U |
| #define | GRETHGBIT_CR_MC 0x2000000U |
| #define | GRETHGBIT_CR_ED 0x4000U |
| #define | GRETHGBIT_CR_RD 0x2000U |
| #define | GRETHGBIT_CR_DD 0x1000U |
| #define | GRETHGBIT_CR_ME 0x800U |
| #define | GRETHGBIT_CR_PI 0x400U |
| #define | GRETHGBIT_CR_BM 0x200U |
| #define | GRETHGBIT_CR_GB 0x100U |
| #define | GRETHGBIT_CR_SP 0x80U |
| #define | GRETHGBIT_CR_RS 0x40U |
| #define | GRETHGBIT_CR_PM 0x20U |
| #define | GRETHGBIT_CR_FD 0x10U |
| #define | GRETHGBIT_CR_RI 0x8U |
| #define | GRETHGBIT_CR_TI 0x4U |
| #define | GRETHGBIT_CR_RE 0x2U |
| #define | GRETHGBIT_CR_TE 0x1U |
| #define | GRETHGBIT_SR_PS 0x100U |
| #define | GRETHGBIT_SR_IA 0x80U |
| #define | GRETHGBIT_SR_TS 0x40U |
| #define | GRETHGBIT_SR_TA 0x20U |
| #define | GRETHGBIT_SR_RA 0x10U |
| #define | GRETHGBIT_SR_TI 0x8U |
| #define | GRETHGBIT_SR_RI 0x4U |
| #define | GRETHGBIT_SR_TE 0x2U |
| #define | GRETHGBIT_SR_RE 0x1U |
| #define | GRETHGBIT_MACMSB_MSB_SHIFT 0 |
| #define | GRETHGBIT_MACMSB_MSB_MASK 0xffffU |
| #define | GRETHGBIT_MACMSB_MSB_GET(_reg) |
| #define | GRETHGBIT_MACMSB_MSB_SET(_reg, _val) |
| #define | GRETHGBIT_MACMSB_MSB(_val) |
| #define | GRETHGBIT_MACLSB_LSB_SHIFT 0 |
| #define | GRETHGBIT_MACLSB_LSB_MASK 0xffffffffU |
| #define | GRETHGBIT_MACLSB_LSB_GET(_reg) |
| #define | GRETHGBIT_MACLSB_LSB_SET(_reg, _val) |
| #define | GRETHGBIT_MACLSB_LSB(_val) |
| #define | GRETHGBIT_MDIO_DATA_SHIFT 16 |
| #define | GRETHGBIT_MDIO_DATA_MASK 0xffff0000U |
| #define | GRETHGBIT_MDIO_DATA_GET(_reg) |
| #define | GRETHGBIT_MDIO_DATA_SET(_reg, _val) |
| #define | GRETHGBIT_MDIO_DATA(_val) |
| #define | GRETHGBIT_MDIO_PHYADDR_SHIFT 11 |
| #define | GRETHGBIT_MDIO_PHYADDR_MASK 0xf800U |
| #define | GRETHGBIT_MDIO_PHYADDR_GET(_reg) |
| #define | GRETHGBIT_MDIO_PHYADDR_SET(_reg, _val) |
| #define | GRETHGBIT_MDIO_PHYADDR(_val) |
| #define | GRETHGBIT_MDIO_REGADDR_SHIFT 6 |
| #define | GRETHGBIT_MDIO_REGADDR_MASK 0x7c0U |
| #define | GRETHGBIT_MDIO_REGADDR_GET(_reg) |
| #define | GRETHGBIT_MDIO_REGADDR_SET(_reg, _val) |
| #define | GRETHGBIT_MDIO_REGADDR(_val) |
| #define | GRETHGBIT_MDIO_BU 0x8U |
| #define | GRETHGBIT_MDIO_LF 0x4U |
| #define | GRETHGBIT_MDIO_RD 0x2U |
| #define | GRETHGBIT_MDIO_WR 0x1U |
| #define | GRETHGBIT_TDTBA_BASEADDR_SHIFT 10 |
| #define | GRETHGBIT_TDTBA_BASEADDR_MASK 0xfffffc00U |
| #define | GRETHGBIT_TDTBA_BASEADDR_GET(_reg) |
| #define | GRETHGBIT_TDTBA_BASEADDR_SET(_reg, _val) |
| #define | GRETHGBIT_TDTBA_BASEADDR(_val) |
| #define | GRETHGBIT_TDTBA_DESCPNT_SHIFT 3 |
| #define | GRETHGBIT_TDTBA_DESCPNT_MASK 0x3f8U |
| #define | GRETHGBIT_TDTBA_DESCPNT_GET(_reg) |
| #define | GRETHGBIT_TDTBA_DESCPNT_SET(_reg, _val) |
| #define | GRETHGBIT_TDTBA_DESCPNT(_val) |
| #define | GRETHGBIT_RDTBA_BASEADDR_SHIFT 10 |
| #define | GRETHGBIT_RDTBA_BASEADDR_MASK 0xfffffc00U |
| #define | GRETHGBIT_RDTBA_BASEADDR_GET(_reg) |
| #define | GRETHGBIT_RDTBA_BASEADDR_SET(_reg, _val) |
| #define | GRETHGBIT_RDTBA_BASEADDR(_val) |
| #define | GRETHGBIT_RDTBA_DESCPNT_SHIFT 3 |
| #define | GRETHGBIT_RDTBA_DESCPNT_MASK 0x3f8U |
| #define | GRETHGBIT_RDTBA_DESCPNT_GET(_reg) |
| #define | GRETHGBIT_RDTBA_DESCPNT_SET(_reg, _val) |
| #define | GRETHGBIT_RDTBA_DESCPNT(_val) |
| #define | GRETHGBIT_EDCLMACMSB_MSB_SHIFT 0 |
| #define | GRETHGBIT_EDCLMACMSB_MSB_MASK 0xffffU |
| #define | GRETHGBIT_EDCLMACMSB_MSB_GET(_reg) |
| #define | GRETHGBIT_EDCLMACMSB_MSB_SET(_reg, _val) |
| #define | GRETHGBIT_EDCLMACMSB_MSB(_val) |
| #define | GRETHGBIT_EDCLMACLSB_LSB_SHIFT 0 |
| #define | GRETHGBIT_EDCLMACLSB_LSB_MASK 0xffffffffU |
| #define | GRETHGBIT_EDCLMACLSB_LSB_GET(_reg) |
| #define | GRETHGBIT_EDCLMACLSB_LSB_SET(_reg, _val) |
| #define | GRETHGBIT_EDCLMACLSB_LSB(_val) |
Typedefs | |
| typedef struct grethgbit | grethgbit |
| This structure defines the GRETH_GBIT register block memory map. | |
