RTEMS 6.1-rc8
#include "fsl_common.h"Go to the source code of this file.
| struct | _tempmon_config |
| TEMPMON temperature structure. More... | |
Driver version | |
| #define | FSL_TEMPMON_DRIVER_VERSION (MAKE_VERSION(2, 1, 1)) |
| TEMPMON driver version. | |
| enum | _tempmon_alarm_mode { kTEMPMON_HighAlarmMode = 0U , kTEMPMON_PanicAlarmMode = 1U , kTEMPMON_LowAlarmMode = 2U } |
| TEMPMON alarm mode. More... | |
| typedef struct _tempmon_config | tempmon_config_t |
| TEMPMON temperature structure. | |
| typedef enum _tempmon_alarm_mode | tempmon_alarm_mode |
| TEMPMON alarm mode. | |
| void | TEMPMON_Init (TEMPMON_Type *base, const tempmon_config_t *config) |
| Initializes the TEMPMON module. | |
| void | TEMPMON_Deinit (TEMPMON_Type *base) |
| Deinitializes the TEMPMON module. | |
| void | TEMPMON_GetDefaultConfig (tempmon_config_t *config) |
| Gets the default configuration structure. | |
| float | TEMPMON_GetCurrentTemperature (TEMPMON_Type *base) |
| Get current temperature with the fused temperature calibration data. | |
| void | TEMPMON_SetTempAlarm (TEMPMON_Type *base, int8_t tempVal, tempmon_alarm_mode alarmMode) |
| Set the temperature count (raw sensor output) that will generate an alarm interrupt. | |
