RTEMS 6.1-rc7
vpd.h
1#ifndef PPC_MOTLOAD_VPD_H
2#define PPC_MOTLOAD_VPD_H
3
4/* MotLoad VPD format */
5
6/* Till Straumann, 2005; see copyright notice at the end of this file */
7
8#ifdef __cplusplus
9 extern "C" {
10#endif
11
12/*
13VPD = "MOTOROLA" , { field }
14
15field = type_byte, length_byte, { data }
16*/
17
18/* Known fields so far */
19typedef enum {
20 ProductIdent = 0x01, /* String */
21 AssemblyNumber = 0x02, /* String */
22 SerialNumber = 0x03, /* String */
23 CpuClockHz = 0x05, /* binary (5bytes), 0x01 byte appended to unsigned int */
24 BusClockHz = 0x06, /* binary (5bytes), 0x01 byte appended to unsigned int */
25 EthernetAddr = 0x08, /* binary (7bytes), 0x00 byte appended, 2nd has 0x01 appended */
26 CpuType = 0x09, /* String */
27 EEpromCrc = 0x0a, /* binary (4bytes) */
28 FlashConfig = 0x0b, /* binary */
29 L2CacheConfig = 0x0e, /* binary */
30 VPDRevision = 0x0f, /* binary (4bytes) */
31 L3CacheConfig = 0x19, /* binary */
32 End = 0xff
33} VpdKey;
34
35typedef struct {
36 VpdKey key; /* key for the data item to be read into 'buf' */
37 char instance; /* instance # (starting with 0) - some keys are present more than one time */
38 void *buf; /* pointer to area where the data item is to be stored */
39 int buflen; /* available space in the buffer */
40 char found; /* set by BSP_vpdRetrieveFields() to the original length as found in the PROM */
42
43
44#define VPD_END { key:End, }
45
46
47/* Scan the VPD EEPROM for a number of fields
48 *
49 * Pass an array of VpdBufRec items. The routine
50 * fills the 'buf'fers for all keys that are found
51 * and sets the 'found' field to the original length
52 * of the data (i.e., as found in the PROM) so that
53 * the routine could be called again with a larger
54 * buffer.
55 *
56 * NOTE: - the array must be terminated by a VPD_END record!
57 * - no CRC check is performed.
58 * - INTERRUPT MANAGEMENT MUST BE FUNCTIONAL
59 *
60 * RETURNS: 0 on success, -1 if any read errors were
61 * encountered or if the "MOTOROLA" header
62 * was not found.
63 */
64int
65BSP_vpdRetrieveFields(VpdBuf data);
66
67/* Example:
68 * Read 2nd ethernet address:
69 *
70 * char enet_addr_2[6];
71 *
72 * VpdBufRec enetVpd [] = {
73 * { key: EthernetAddr, instance: 1, buf: enet_addr_2, buflen: 2},
74 * VPD_END
75 * };
76 *
77 * if ( BSP_vpdRetrieveFields(enetVpd) ) {
78 * error("ethernet address couldn't be read\n");
79 * } else if ( enetVpd[0].found < 6 ) {
80 * error("2nd ethernet address not found in VPD\n");
81 * } else {
82 * use_it(enet_addr_2);
83 * }
84 */
85
86
87/* Simple wrapper if only one field is needed
88 *
89 * RETURNS: original length if key is found, -1 on error or if key is not found
90 */
91int
92BSP_vpdRetrieveKey(VpdKey k, void *buf, int buflen, int instance);
93
94#ifdef __cplusplus
95 }
96#endif
97
98/*
99 * Authorship
100 * ----------
101 * This software ('beatnik' RTEMS BSP for MVME6100 and MVME5500) was
102 * created by Till Straumann <strauman@slac.stanford.edu>, 2005-2007,
103 * Stanford Linear Accelerator Center, Stanford University.
104 *
105 * Acknowledgement of sponsorship
106 * ------------------------------
107 * The 'beatnik' BSP was produced by
108 * the Stanford Linear Accelerator Center, Stanford University,
109 * under Contract DE-AC03-76SFO0515 with the Department of Energy.
110 *
111 * Government disclaimer of liability
112 * ----------------------------------
113 * Neither the United States nor the United States Department of Energy,
114 * nor any of their employees, makes any warranty, express or implied, or
115 * assumes any legal liability or responsibility for the accuracy,
116 * completeness, or usefulness of any data, apparatus, product, or process
117 * disclosed, or represents that its use would not infringe privately owned
118 * rights.
119 *
120 * Stanford disclaimer of liability
121 * --------------------------------
122 * Stanford University makes no representations or warranties, express or
123 * implied, nor assumes any liability for the use of this software.
124 *
125 * Stanford disclaimer of copyright
126 * --------------------------------
127 * Stanford University, owner of the copyright, hereby disclaims its
128 * copyright and all other rights in this software. Hence, anyone may
129 * freely use it for any purpose without restriction.
130 *
131 * Maintenance of notices
132 * ----------------------
133 * In the interest of clarity regarding the origin and status of this
134 * SLAC software, this and all the preceding Stanford University notices
135 * are to remain affixed to any copy or derivative of this software made
136 * or distributed by the recipient and are to be affixed to any copy of
137 * software made or distributed by the recipient that contains a copy or
138 * derivative of this software.
139 *
140 * ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
141 */
142
143#endif
Definition: vpd.h:35
