RTEMS 6.1-rc7
stm32h7xx_hal_opamp.c File Reference
OPAMP HAL module driver. This file provides firmware functions to manage the following functionalities of the operational amplifier(s) peripheral: More...
#include "stm32h7xx_hal.h"
Author
MCD Application Team
  • Initialization and de-initialization functions
  • IO operation functions
  • Peripheral Control functions
  • Peripheral State functions
Attention
          ##### OPAMP Peripheral Features #####
  [..] The device integrates 2 operational amplifiers OPAMP1 & OPAMP2
       (#) The OPAMP(s) provides several exclusive running modes.
       (++) Standalone mode
       (++) Programmable Gain Amplifier (PGA) modes
       (++) Follower mode
       (#) Each OPAMP(s) can be configured in normal and high speed mode.
       (#) The OPAMP(s) provide(s) calibration capabilities.
       (++) Calibration aims at correcting some offset for running mode.
       (++) The OPAMP uses either factory calibration settings OR user defined
           calibration (trimming) settings (i.e. trimming mode).
       (++) The user defined settings can be figured out using self calibration
           handled by HAL_OPAMP_SelfCalibrate, HAL_OPAMPEx_SelfCalibrateAll
       (++) HAL_OPAMP_SelfCalibrate:
       (+++) Runs automatically the calibration in 2 steps.
            (90% of VDDA for NMOS transistors, 10% of VDDA for PMOS transistors).
            (As OPAMP is Rail-to-rail input/output, these 2 steps calibration is
             appropriate and enough in most cases).
       (+++) Runs automatically the calibration.
       (+++) Enables the user trimming mode
       (+++) Updates the init structure with trimming values with fresh calibration
            results.
            The user may store the calibration results for larger
            (ex monitoring the trimming as a function of temperature
            for instance)
       (+++) HAL_OPAMPEx_SelfCalibrateAll
            runs calibration of all OPAMPs in parallel to save search time.
       (#) Running mode: Standalone mode
       (++) Gain is set externally (gain depends on external loads).
       (++) Follower mode also possible externally by connecting the inverting input to
           the output.
       (#) Running mode: Follower mode
       (++) No Inverting Input is connected.
       (#) Running mode: Programmable Gain Amplifier (PGA) mode
           (Resistor feedback output)
       (#) The OPAMP(s) output(s) can be internally connected to resistor feedback
           output.
       (#) OPAMP gain can be selected as :
      (##) Gain of x2, x4, x8 or x16 for non inverting mode with:
      (+++) VREF- referenced.
      (+++) Filtering on VINM0, VREF- referenced.
      (+++) VINM0 node for bias voltage and VINP0 for input signal.
      (+++) VINM0 node for bias voltage and VINP0 for input signal, VINM1 node for filtering.
      (##) Gain of x-1, x-3, x-7 or x-15 for inverting mode with:
      (+++) VINM0 node for input signal and VINP0 for bias.
      (+++) VINM0 node for input signal and VINP0 for bias voltage, VINM1 node for filtering.
       (#) The OPAMPs inverting input can be selected according to the Reference Manual
           "OPAMP functional description" chapter.
       (#) The OPAMPs non inverting input can be selected according to the Reference Manual
            ##### How to use this driver #####
    *** High speed / normal power mode ***
    [..]  To run in high speed mode:
      (#) Configure the OPAMP using HAL_OPAMP_Init() function:
      (++) Select OPAMP_POWERMODE_HIGHSPEED
      (++) Otherwise select OPAMP_POWERMODE_NORMAL
    *** Calibration ***
    [..]  To run the OPAMP calibration self calibration:
      (#) Start calibration using HAL_OPAMP_SelfCalibrate.
           Store the calibration results.
    *** Running mode ***
    [..]  To use the OPAMP, perform the following steps:
      (#) Fill in the HAL_OPAMP_MspInit() to
      (++) Enable the OPAMP Peripheral clock using macro __HAL_RCC_OPAMP_CLK_ENABLE()
      (++) Configure the OPAMP input AND output in analog mode using
           HAL_GPIO_Init() to map the OPAMP output to the GPIO pin.
      (#) Registrate Callbacks
      (++) The compilation define  USE_HAL_OPAMP_REGISTER_CALLBACKS when set to 1
           allows the user to configure dynamically the driver callbacks.
      (++) Use Functions HAL_OPAMP_RegisterCallback() to register a user callback,
           it allows to register following callbacks:
      (+++) MspInitCallback         : OPAMP MspInit.
      (+++) MspDeInitCallback       : OPAMP MspDeInit.
           This function takes as parameters the HAL peripheral handle, the Callback ID
           and a pointer to the user callback function.
      (++) Use function HAL_OPAMP_UnRegisterCallback() to reset a callback to the default
           weak (overridden) function. It allows to reset following callbacks:
      (+++) All Callbacks
      (++) Select the mode
      (++) Select the inverting input
      (++) Select the non-inverting input
      (++) If PGA mode is enabled, Select if inverting input is connected.
      (++) Select either factory or user defined trimming mode.
      (++) If the user-defined trimming mode is enabled, select PMOS & NMOS trimming values
          (typically values set by HAL_OPAMP_SelfCalibrate function).
      (#) Enable the OPAMP using HAL_OPAMP_Start() function.
      (#) Disable the OPAMP using HAL_OPAMP_Stop() function.
      (#) Lock the OPAMP in running mode using HAL_OPAMP_Lock() function.
          Caution: On STM32H7, HAL OPAMP lock is software lock only (not
          hardware lock as on some other STM32 devices)
      (#) If needed, unlock the OPAMP using HAL_OPAMPEx_Unlock() function.
    *** Running mode: change of configuration while OPAMP ON  ***
    [..] To Re-configure OPAMP when OPAMP is ON (change on the fly)
      (#) If needed, fill in the HAL_OPAMP_MspInit()
      (++) This is the case for instance if you wish to use new OPAMP I/O
      (++) As in configure case, select first the parameters you wish to modify.
      (#) Change from high speed mode to normal power mode (& vice versa) requires
          first HAL_OPAMP_DeInit() (force OPAMP OFF) and then HAL_OPAMP_Init().
          In other words, of OPAMP is ON, HAL_OPAMP_Init can NOT change power mode
          alone.
Table 1. OPAMPs inverting/non-inverting inputs for the STM32H7 devices:
OPAMP1 OPAMP2
Inverting Input VM_SEL VINM0-> PC5 VINM0-> PE8
VINM1-> PA7 VINM1-> PG1
Internal: Internal:
ADC1_IN9 OPAMP2_OUT
ADC2_IN9 PGA mode
OPAMP1_OUT
PGA mode
Non Inverting VP_SEL
VP0 -> PB0 (GPIO) VP0 -> PE9 (GPIO)
Internal: Internal:
Input DAC1_CH1_int DAC1_CH2_int
ADC1_IN8 DAC2_CH1_int
ADC2_IN8 COMP2_INP
COMP1_INP
[..] Table 2. OPAMPs outputs for the STM32H7 devices:
OPAMP1 OPAMP2
Output VOUT PC4 PE7
| | | & ADC1_IN4| | & COMP2_INN7 if | | | | ADC2_IN4 |connected internally | | | | COMP1_INN7 if | | | | | connected internally | | |--------------—|-----—|--------------------—|------------------—|
