RTEMS 6.1-rc7
Modules | Files | Macros | Variables
spec:/testsuites/bsps/fatal-clock-xil-ttc-irq-install
This validation test suite contains a test case which triggers a fatal error during system initialization. More...
 spec:/dev/clock/xil-ttc/val/fatal-irq-install
 Tests a fatal error.
file  ts-fatal-clock-xil-ttc-irq-install.c
#define FATAL_SYSINIT_RUN   DevClockXilTtcValFatalIrqInstall_Run
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
const char rtems_test_name [] = "TestsuitesBspsFatalClockXilTtcIrqInstall"
 Each test must define a test name string.
