RTEMS 6.1-rc7
Modules | Files | Data Structures | Typedefs
This group contains the DSU4 interfaces. More...
 AHB trace buffer break address registers (ATBBA)
 This group contains register bit definitions.
 AHB trace buffer break mask registers (ATBBM)
 AHB trace buffer control register (ATBC)
 AHB trace buffer filter control register (ATBFC)
 AHB trace buffer filter mask register (ATBFM)
 AHB trace buffer index register (ATBI)
 AHB watchpoint control register (AHBWPC)
 AHB watchpoint data registers (AHBWPD)
 AHB watchpoint mask registers (AHBWPM)
 DSU ASI diagnostic access register (DASI)
 DSU break and single step register (BRSS)
 DSU control register (CTRL)
 DSU debug mode mask register (DBGM)
 DSU time tag counter register (DTTC)
 DSU trap register (DTR)
 Instruction trace buffer control register 0 (ITBC0)
 Instruction trace buffer control register 1 (ITBC1)
 Instruction trace count register (ICNT)
file  dsu4-regs.h
 This header file defines the DSU4 register block interface.
struct  dsu4
 This structure defines the DSU4 register block memory map. More...
typedef struct dsu4 dsu4
