RTEMS 6.1-rc7
This group contains the GRGPIO interfaces. More...
Modules | |
Bypass register (BYPASS) | |
This group contains register bit definitions. | |
Capability register (CAP) | |
I/O port data register (DATA) | |
I/O port direction register (DIRECTION) | |
I/O port output register (OUTPUT) | |
Interrupt available register (IAVAIL) | |
Interrupt edge register (IEDGE) | |
Interrupt enable register (IPEN) | |
Interrupt flag register (IFLAG) | |
Interrupt map register n, where n = 0 .. 3 (IRQMAPR) | |
Interrupt mask register (IMASK) | |
Interrupt polarity register (IPOL) | |
Logical-AND registers (LAND) | |
Logical-OR registers (LOR) | |
Logical-XOR registers (LXOR) | |
Pulse register (PULSE) | |
Files | |
file | grgpio-regs.h |
This header file defines the GRGPIO register block interface. | |
struct | grgpio |
This structure defines the GRGPIO register block memory map. More... | |
Typedefs | |
typedef struct grgpio | grgpio |
This structure defines the GRGPIO register block memory map. | |
