RTEMS
6.1-rc7
bsps
i386
pc386
include
bsp
fb_default_mode.h
1
10
11
* @brief Allows to enable initialization of specific framebuffer driver (e.g.
12
* VESA real mode) from an application by setting the value of this variable
13
* to non null value in user's module. The value of this variable will be then
14
* updated when linked with an application's object.
15
16
* Further the value should point to string in the following format:
17
* "<resX>x<resY>[-<bpp>]" - e.g. "1024x768-32"
18
* "auto" - select the graphic mode automatically
19
* "none" / "off" - do not initialize the driver
20
* the given parameters are used if applicable.
21
22
* Command line argument "--video=" has priority over this string if
23
* it is read/implemented by the driver.
24
25
extern
const
char
const
rtems_fb_default_mode
const char *const rtems_fb_default_mode
Allows to enable initialization of VESA real mode driver from an application by setting the value of ...
Definition:
fb_vesa_rm.c:91
