RTEMS 6.1-rc7
board_lowlevel.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
37#ifndef BOARD_LOWLEVEL_H
38#define BOARD_LOWLEVEL_H
39
40/*----------------------------------------------------------------------------
41 * Exported functions
42 *----------------------------------------------------------------------------*/
43extern void LowLevelInit(void);
44extern void _SetupMemoryRegion(void);
45
46#endif /* BOARD_LOWLEVEL_H */
47
Performs the low-level initialization of the chip.
Definition: board_lowlevel.c:427
Set up a memory region.
Definition: board_lowlevel.c:82
