RTEMS
6.1-rc6
bsps
powerpc
include
bsp
u-boot-board-info.h
1
2
* (C) Copyright 2000 - 2002
3
* Wolfgang Denk, DENX Software Engineering, wd@denx.de.
4
5
* This program is free software; you can redistribute it and/or
6
* modify it under the terms of the GNU General Public License as
7
* published by the Free Software Foundation; either version 2 of
8
* the License, or (at your option) any later version.
9
10
* This program is distributed in the hope that it will be useful,
11
* but WITHOUT ANY WARRANTY; without even the implied warranty of
12
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
13
* GNU General Public License for more details.
14
15
* You should have received a copy of the GNU General Public License
16
* along with this program; if not, write to the Free Software
17
* Foundation, Inc., 59 Temple Place, Suite 330, Boston,
18
* MA 02111-1307 USA
19
20
21
* NOTE: This header file defines an interface to U-Boot. Including
22
* this (unmodified) header file in another file is considered normal
23
* use of U-Boot, and does *not* fall under the heading of "derived
24
* work".
25
26
27
28
#ifndef __U_BOOT_H__
29
#define __U_BOOT_H__
30
31
32
* Board information passed to Linux kernel from U-Boot
33
34
* include/asm-ppc/u-boot.h
35
36
37
#ifndef __ASSEMBLY__
38
39
typedef
struct
bd_info
40
unsigned
long
bi_memstart;
/* start of DRAM memory */
41
phys_size_t bi_memsize;
/* size of DRAM memory in bytes */
42
unsigned
long
bi_flashstart;
/* start of FLASH memory */
43
unsigned
long
bi_flashsize;
/* size of FLASH memory */
44
unsigned
long
bi_flashoffset;
/* reserved area for startup monitor */
45
unsigned
long
bi_sramstart;
/* start of SRAM memory */
46
unsigned
long
bi_sramsize;
/* size of SRAM memory */
47
#if defined(CONFIG_5xx) || defined(CONFIG_8xx) || defined(CONFIG_8260) \
48
|| defined(CONFIG_E500) || defined(CONFIG_MPC86xx)
49
unsigned
long
bi_immr_base;
/* base of IMMR register */
50
#endif
51
#if defined(CONFIG_MPC5xxx)
52
unsigned
long
bi_mbar_base;
/* base of internal registers */
53
#endif
54
#if defined(CONFIG_MPC83xx)
55
unsigned
long
bi_immrbar;
56
#endif
57
#if defined(CONFIG_MPC8220)
58
unsigned
long
bi_mbar_base;
59
unsigned
long
bi_inpfreq;
/* Input Freq, In MHz */
60
unsigned
long
bi_pcifreq;
/* PCI Freq, in MHz */
61
unsigned
long
bi_pevfreq;
/* PEV Freq, in MHz */
62
unsigned
long
bi_flbfreq;
/* Flexbus Freq, in MHz */
63
unsigned
long
bi_vcofreq;
/* VCO Freq, in MHz */
64
#endif
65
unsigned
long
bi_bootflags;
/* boot / reboot flag (Unused) */
66
unsigned
long
bi_ip_addr;
/* IP Address */
67
unsigned
char
bi_enetaddr[6];
/* OLD: see README.enetaddr */
68
unsigned
short
bi_ethspeed;
/* Ethernet speed in Mbps */
69
unsigned
long
bi_intfreq;
/* Internal Freq, in MHz */
70
unsigned
long
bi_busfreq;
/* Bus Freq, in MHz */
71
#if defined(CONFIG_CPM2)
72
unsigned
long
bi_cpmfreq;
/* CPM_CLK Freq, in MHz */
73
unsigned
long
bi_brgfreq;
/* BRG_CLK Freq, in MHz */
74
unsigned
long
bi_sccfreq;
/* SCC_CLK Freq, in MHz */
75
unsigned
long
bi_vco;
/* VCO Out from PLL, in MHz */
76
#endif
77
#if defined(CONFIG_MPC512X)
78
unsigned
long
bi_ipsfreq;
/* IPS Bus Freq, in MHz */
79
#endif
/* CONFIG_MPC512X */
80
81
unsigned
long
bi_ipbfreq;
/* IPB Bus Freq, in MHz */
82
unsigned
long
bi_pcifreq;
/* PCI Bus Freq, in MHz */
83
#endif
84
unsigned
long
bi_baudrate;
/* Console Baudrate */
85
#if defined(CONFIG_405) || \
86
defined(CONFIG_405GP) || \
87
defined(CONFIG_405CR) || \
88
defined(CONFIG_405EP) || \
89
defined(CONFIG_405EZ) || \
90
defined(CONFIG_405EX) || \
91
defined(CONFIG_440)
92
unsigned
char
bi_s_version[4];
/* Version of this structure */
93
unsigned
char
bi_r_version[32];
/* Version of the ROM (AMCC) */
94
unsigned
int
bi_procfreq;
/* CPU (Internal) Freq, in Hz */
95
unsigned
int
bi_plb_busfreq;
/* PLB Bus speed, in Hz */
96
unsigned
int
bi_pci_busfreq;
/* PCI Bus speed, in Hz */
97
unsigned
char
bi_pci_enetaddr[6];
/* PCI Ethernet MAC address */
98
#endif
99
#if defined(CONFIG_HYMOD)
100
hymod_conf_t bi_hymod_conf;
/* hymod configuration information */
101
#endif
102
103
#ifdef CONFIG_HAS_ETH1
104
unsigned
char
bi_enet1addr[6];
105
#endif
106
#ifdef CONFIG_HAS_ETH2
107
unsigned
char
bi_enet2addr[6];
108
#endif
109
#ifdef CONFIG_HAS_ETH3
110
unsigned
char
bi_enet3addr[6];
111
#endif
112
#ifdef CONFIG_HAS_ETH4
113
unsigned
char
bi_enet4addr[6];
114
#endif
115
#ifdef CONFIG_HAS_ETH5
116
unsigned
char
bi_enet5addr[6];
117
#endif
118
119
#if defined(CONFIG_405GP) || defined(CONFIG_405EP) || \
120
defined(CONFIG_405EZ) || defined(CONFIG_440GX) || \
121
defined(CONFIG_440EP) || defined(CONFIG_440GR) || \
122
defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \
123
defined(CONFIG_460EX) || defined(CONFIG_460GT)
124
unsigned
int
bi_opbfreq;
/* OPB clock in Hz */
125
int
bi_iic_fast[2];
/* Use fast i2c mode */
126
#endif
127
#if defined(CONFIG_NX823)
128
unsigned
char
bi_sernum[8];
129
#endif
130
#if defined(CONFIG_4xx)
131
#if defined(CONFIG_440GX) || \
132
133
int
bi_phynum[4];
/* Determines phy mapping */
134
int
bi_phymode[4];
/* Determines phy mode */
135
#elif defined(CONFIG_405EP) || defined(CONFIG_440)
136
int
bi_phynum[2];
137
int
bi_phymode[2];
138
#else
139
int
bi_phynum[1];
140
int
bi_phymode[1];
141
#endif
142
#endif
/* defined(CONFIG_4xx) */
143
bd_t
144
145
#endif
/* __ASSEMBLY__ */
146
#endif
/* __U_BOOT_H__ */
bd_info
Definition:
u-boot-board-info.h:39
